[U-Boot] [PATCH v2 0/7] MIPS: use an unified u-boot.lds script
This patch-set adds an unfied u-boot.lds file for the MIPS architecture, and removes the linker scripts of the individual boards.
The series depends on the following patch: MIPS: remove OUTPUT_FORMAT from linker scripts http://patchwork.ozlabs.org/patch/216892/
Gabor Juhos (7): MIPS: add unified u-boot.lds file MIPS: qemu-mips: use the unified u-boot.lds script MIPS: pb1x00: remove custom u-boot.lds script MIPS: vct: remove custom u-boot.lds script MIPS: incaip: remove custom u-boot.lds script MIPS: dbau1x00: remove custom u-boot.lds script MIPS: qi_lb60: remove custom u-boot.lds script
arch/mips/cpu/u-boot.lds | 84 +++++++++++++++++++++++++++++++++++++++++ board/dbau1x00/u-boot.lds | 65 ------------------------------- board/incaip/u-boot.lds | 65 ------------------------------- board/micronas/vct/u-boot.lds | 68 --------------------------------- board/pb1x00/u-boot.lds | 65 ------------------------------- board/qemu-mips/u-boot.lds | 70 ---------------------------------- board/qi/qi_lb60/u-boot.lds | 61 ------------------------------ 7 files changed, 84 insertions(+), 394 deletions(-) create mode 100644 arch/mips/cpu/u-boot.lds delete mode 100644 board/dbau1x00/u-boot.lds delete mode 100644 board/incaip/u-boot.lds delete mode 100644 board/micronas/vct/u-boot.lds delete mode 100644 board/pb1x00/u-boot.lds delete mode 100644 board/qemu-mips/u-boot.lds delete mode 100644 board/qi/qi_lb60/u-boot.lds
The patch adds an unified linker script file which can be used for all currently supported MIPS targets.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Stefan Roese sr@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Xiangfu Liu xiangfu@openmobilefree.net --- Changes since v1: - use consistent coding style for all sections - remove the OUTPUT_FORMAT command from the unified script --- arch/mips/cpu/u-boot.lds | 84 ++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 84 insertions(+) create mode 100644 arch/mips/cpu/u-boot.lds
diff --git a/arch/mips/cpu/u-boot.lds b/arch/mips/cpu/u-boot.lds new file mode 100644 index 0000000..37c9d23 --- /dev/null +++ b/arch/mips/cpu/u-boot.lds @@ -0,0 +1,84 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk Engineering, wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#if defined(CONFIG_64BIT) +#define PTR_COUNT_SHIFT 3 +#else +#define PTR_COUNT_SHIFT 2 +#endif + +OUTPUT_ARCH(mips) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : { + *(.text*) + } + + . = ALIGN(4); + .rodata : { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + + . = ALIGN(4); + .data : { + *(.data*) + } + + . = .; + _gp = ALIGN(16) + 0x7ff0; + + .got : { + __got_start = .; + *(.got) + __got_end = .; + } + + . = ALIGN(4); + .sdata : { + *(.sdata*) + } + + . = ALIGN(4); + .u_boot_list : { + #include <u-boot.lst> + } + + uboot_end_data = .; + + num_got_entries = (__got_end - __got_start) >> PTR_COUNT_SHIFT; + + . = ALIGN(4); + .sbss : { + *(.sbss*) + } + + .bss : { + *(.bss*) + . = ALIGN(4); + } + uboot_end = .; +}
Again, can't test but looks good. Thanks.
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Thanks!
-Gabor
Remove the board specific linker script. It is not needed anymore, the unified MIPS linker script can be used instead.
All qemu_mips targets are producing identical binary images after the change than before.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Changes since v1: --- --- board/qemu-mips/u-boot.lds | 70 -------------------------------------------- 1 file changed, 70 deletions(-) delete mode 100644 board/qemu-mips/u-boot.lds
diff --git a/board/qemu-mips/u-boot.lds b/board/qemu-mips/u-boot.lds deleted file mode 100644 index 33b42f3..0000000 --- a/board/qemu-mips/u-boot.lds +++ /dev/null @@ -1,70 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk Engineering, wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - *(.text*) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data*) } - - . = .; - _gp = ALIGN(16) +0x7ff0; - - .got : { - __got_start = .; - *(.got) - __got_end = .; - } - - . = ALIGN(4); - .sdata : { *(.sdata*) } - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - uboot_end_data = .; -#if defined(CONFIG_64BIT) - num_got_entries = (__got_end - __got_start) >> 3; -#else - num_got_entries = (__got_end - __got_start) >> 2; -#endif - - . = ALIGN(4); - .sbss : { *(.sbss*) } - .bss : { *(.bss*) . = ALIGN(4); } - uboot_end = .; -}
All pb1x00 targets are producing identical binary images after the change than before.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Changes since v1: --- --- board/pb1x00/u-boot.lds | 65 ----------------------------------------------- 1 file changed, 65 deletions(-) delete mode 100644 board/pb1x00/u-boot.lds
diff --git a/board/pb1x00/u-boot.lds b/board/pb1x00/u-boot.lds deleted file mode 100644 index d9c01af..0000000 --- a/board/pb1x00/u-boot.lds +++ /dev/null @@ -1,65 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk Engineering, wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - *(.text*) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data*) } - - . = .; - _gp = ALIGN(16) + 0x7ff0; - - .got : { - __got_start = .; - *(.got) - __got_end = .; - } - - .sdata : { *(.sdata*) } - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - uboot_end_data = .; - num_got_entries = (__got_end - __got_start) >> 2; - - . = ALIGN(4); - .sbss (NOLOAD) : { *(.sbss*) } - .bss (NOLOAD) : { *(.bss*) . = ALIGN(4); } - uboot_end = .; -}
All vct targets are producing identical binary images after the change than before.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Acked-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Changes since v1: --- --- board/micronas/vct/u-boot.lds | 68 ----------------------------------------- 1 file changed, 68 deletions(-) delete mode 100644 board/micronas/vct/u-boot.lds
diff --git a/board/micronas/vct/u-boot.lds b/board/micronas/vct/u-boot.lds deleted file mode 100644 index cc7db1b..0000000 --- a/board/micronas/vct/u-boot.lds +++ /dev/null @@ -1,68 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk Engineering, wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - *(.text*) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data*) } - - . = .; - _gp = ALIGN(16) + 0x7ff0; - - .got : { - __got_start = .; - *(.got) - __got_end = .; - } - - . = ALIGN(4); - .sdata : { *(.sdata*) } - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - . = ALIGN(4); - uboot_end_data = .; - num_got_entries = (__got_end - __got_start) >> 2; - - . = ALIGN(4); - .sbss (NOLOAD) : { *(.sbss*) } - . = ALIGN(4); - .bss (NOLOAD) : { *(.bss*) } - uboot_end = .; -}
All incaip targets are producing identical binary images after the change than before.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Wolfgang Denk wd@denx.de --- Changes since v1: --- --- board/incaip/u-boot.lds | 65 ----------------------------------------------- 1 file changed, 65 deletions(-) delete mode 100644 board/incaip/u-boot.lds
diff --git a/board/incaip/u-boot.lds b/board/incaip/u-boot.lds deleted file mode 100644 index d9c01af..0000000 --- a/board/incaip/u-boot.lds +++ /dev/null @@ -1,65 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk Engineering, wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - *(.text*) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data*) } - - . = .; - _gp = ALIGN(16) + 0x7ff0; - - .got : { - __got_start = .; - *(.got) - __got_end = .; - } - - .sdata : { *(.sdata*) } - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - uboot_end_data = .; - num_got_entries = (__got_end - __got_start) >> 2; - - . = ALIGN(4); - .sbss (NOLOAD) : { *(.sbss*) } - .bss (NOLOAD) : { *(.bss*) . = ALIGN(4); } - uboot_end = .; -}
All dbau1x00 targets are producing identical binary images after the change than before.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Changes since v1: --- --- board/dbau1x00/u-boot.lds | 65 --------------------------------------------- 1 file changed, 65 deletions(-) delete mode 100644 board/dbau1x00/u-boot.lds
diff --git a/board/dbau1x00/u-boot.lds b/board/dbau1x00/u-boot.lds deleted file mode 100644 index d9c01af..0000000 --- a/board/dbau1x00/u-boot.lds +++ /dev/null @@ -1,65 +0,0 @@ -/* - * (C) Copyright 2003 - * Wolfgang Denk Engineering, wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - *(.text*) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data*) } - - . = .; - _gp = ALIGN(16) + 0x7ff0; - - .got : { - __got_start = .; - *(.got) - __got_end = .; - } - - .sdata : { *(.sdata*) } - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - uboot_end_data = .; - num_got_entries = (__got_end - __got_start) >> 2; - - . = ALIGN(4); - .sbss (NOLOAD) : { *(.sbss*) } - .bss (NOLOAD) : { *(.bss*) . = ALIGN(4); } - uboot_end = .; -}
The qi_lb60 target produces a slightly different image after the change than before. The value of 'num_got_entries' symbol is different:
@@ -49,7 +49,7 @@ 801000b4: 80122d00 lb s2,11520(zero) 801000b8: 80123500 lb s2,13568(zero) 801000bc: 80123ef8 lb s2,16120(zero) -801000c0: 00000139 0x139 +801000c0: 00000136 tne zero,zero,0x4
801000c4 <in_ram>: 801000c4: 8d0bfffc lw t3,-4(t0)
This is caused by the different placement of the '__got_start' and '__got_end' symbols between the board specific scrip and the unified script.
board specific script:
__got_start = .; .got : { *(.got) } __got_end = .;
unified script: .got : { __got_start = .; *(.got) __got_end = .; }
Despite this difference, the resulting images are functionally identical.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com Cc: Xiangfu Liu xiangfu@openmobilefree.net --- Changes since v1: --- --- board/qi/qi_lb60/u-boot.lds | 61 ------------------------------------------- 1 file changed, 61 deletions(-) delete mode 100644 board/qi/qi_lb60/u-boot.lds
diff --git a/board/qi/qi_lb60/u-boot.lds b/board/qi/qi_lb60/u-boot.lds deleted file mode 100644 index d074a27..0000000 --- a/board/qi/qi_lb60/u-boot.lds +++ /dev/null @@ -1,61 +0,0 @@ -/* - * (C) Copyright 2006 - * Ingenic Semiconductor, jlwei@ingenic.cn - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - *(.text*) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data*) } - - . = .; - _gp = ALIGN(16) + 0x7ff0; - - __got_start = .; - .got : { *(.got) } - __got_end = .; - - .sdata : { *(.sdata*) } - - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - uboot_end_data = .; - num_got_entries = (__got_end - __got_start) >> 2; - - . = ALIGN(4); - .sbss : { *(.sbss*) } - .bss : { *(.bss*) . = ALIGN(4); } - uboot_end = .; -}
Gabor Juhos
Stefan Roese
