[U-Boot] [PATCH] ARM: at91: mmc portA support is only for at91sam9g20ek_2mmc board
Current the MMC support will enable MCI port A, Which is only exist for 2mmc board. So by default we need to disable MMC (port A) support. And only enable it for 2mmc board. Otherwise, dataflash won't work in at91sam9260ek board as MMC has confliction with Dataflash in the CLK pin.
Signed-off-by: Josh Wu josh.wu@atmel.com ---
configs/at91sam9g20ek_2mmc_defconfig | 3 +++ configs/at91sam9g20ek_mmc_defconfig | 3 --- include/configs/at91sam9260ek.h | 6 ++++-- 3 files changed, 7 insertions(+), 5 deletions(-) create mode 100644 configs/at91sam9g20ek_2mmc_defconfig delete mode 100644 configs/at91sam9g20ek_mmc_defconfig
diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig new file mode 100644 index 0000000..4eef04f --- /dev/null +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" +CONFIG_ARM=y +CONFIG_TARGET_AT91SAM9260EK=y diff --git a/configs/at91sam9g20ek_mmc_defconfig b/configs/at91sam9g20ek_mmc_defconfig deleted file mode 100644 index 8cca2e5..0000000 --- a/configs/at91sam9g20ek_mmc_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_MMC" -CONFIG_ARM=y -CONFIG_TARGET_AT91SAM9260EK=y diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index a6a80de..c4b2e16 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -90,7 +90,6 @@ #define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_MMC #define CONFIG_CMD_FAT #define CONFIG_CMD_USB 1
@@ -133,14 +132,17 @@ # define CONFIG_MACH_TYPE MACH_TYPE_AT91SAM9260EK #endif
-/* DataFlash */ #ifndef CONFIG_AT91SAM9G20EK_2MMC +/* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI #define CONFIG_HAS_DATAFLASH 1 #define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ #define AT91_SPI_CLK 15000000 +#else +/* Enable MMC. The MCCK is conflicted with DataFlash */ +#define CONFIG_CMD_MMC #endif
#ifdef CONFIG_AT91SAM9G20EK
Hi Josh,
If removed this default configuration file, we can not use mmc at all, am I right?
Best Regards, Bo Shen
Hi, Bo
On 1/19/2015 4:30 PM, Bo Shen wrote:
Hi Josh,
I change this file name from 'at91sam9g20ek_mmc_defconfig' to 'at91sam9g20ek_2mmc_defconfig'. So only when you use 'at91sam9g20ek_2mmc_defconfig', the mmc is enabled.
Best Regards, Josh Wu
Dear Josh Wu,
Josh Wu Josh.wu@atmel.com writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Bo Shen
Josh Wu
