[U-Boot] [PATCH v6] net/phy: Add support for CS4315/CS4340 PHY
Add support for Cortina CS4315/CS4340 10G PHY. - This driver loads CS43xx firmware from NOR/NAND/SPI/SD device to initialize Cortina PHY. - Cortina PHY has non-standard offset of PHY ID registers, thus we define own get_phy_id() to override default get_phy_id(). - To define macro CONFIG_PHY_CORTINA will enable this driver.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- v6: polish it in phy.c and phy.h in alphabetical order v5: fix unclaimed variable in case of nand boot. v4: add support for loading cortina phy ucode from NAND/SPI/SD v3: move devad as '0' in cortina.c instead of in phy.c v2: no change.
drivers/net/phy/Makefile | 1 + drivers/net/phy/cortina.c | 333 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/phy/phy.c | 3 + include/cortina.h | 73 ++++++++++ include/phy.h | 2 + 5 files changed, 412 insertions(+) create mode 100644 drivers/net/phy/cortina.c create mode 100644 include/cortina.h
diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index 9556536..ffbaef7 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -23,3 +23,4 @@ obj-$(CONFIG_PHY_REALTEK) += realtek.o obj-$(CONFIG_PHY_SMSC) += smsc.o obj-$(CONFIG_PHY_TERANETICS) += teranetics.o obj-$(CONFIG_PHY_VITESSE) += vitesse.o +obj-$(CONFIG_PHY_CORTINA) += cortina.o diff --git a/drivers/net/phy/cortina.c b/drivers/net/phy/cortina.c new file mode 100644 index 0000000..e27dfed --- /dev/null +++ b/drivers/net/phy/cortina.c @@ -0,0 +1,333 @@ +/* + * Cortina CS4315/CS4340 10G PHY drivers + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Copyright 2014 Freescale Semiconductor, Inc. + * + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> +#include <linux/ctype.h> +#include <linux/string.h> +#include <linux/err.h> +#include <phy.h> +#include <cortina.h> +#ifdef CONFIG_SYS_CORTINA_FW_IN_NAND +#include <nand.h> +#elif defined(CONFIG_SYS_CORTINA_FW_IN_SPIFLASH) +#include <spi_flash.h> +#elif defined(CONFIG_SYS_CORTINA_FW_IN_MMC) +#include <mmc.h> +#endif + +#ifndef CONFIG_PHYLIB_10G +#error The Cortina PHY needs 10G support +#endif + +struct cortina_reg_config cortina_reg_cfg[] = { + /* CS4315_enable_sr_mode */ + {VILLA_GLOBAL_MSEQCLKCTRL, 0x8004}, + {VILLA_MSEQ_OPTIONS, 0xf}, + {VILLA_MSEQ_PC, 0x0}, + {VILLA_MSEQ_BANKSELECT, 0x4}, + {VILLA_LINE_SDS_COMMON_SRX0_RX_CPA, 0x55}, + {VILLA_LINE_SDS_COMMON_SRX0_RX_LOOP_FILTER, 0x30}, + {VILLA_DSP_SDS_SERDES_SRX_DFE0_SELECT, 0x1}, + {VILLA_DSP_SDS_DSP_COEF_DFE0_SELECT, 0x2}, + {VILLA_LINE_SDS_COMMON_SRX0_RX_CPB, 0x2003}, + {VILLA_DSP_SDS_SERDES_SRX_FFE_DELAY_CTRL, 0xF047}, + {VILLA_MSEQ_ENABLE_MSB, 0x0000}, + {VILLA_MSEQ_SPARE21_LSB, 0x6}, + {VILLA_MSEQ_RESET_COUNT_LSB, 0x0}, + {VILLA_MSEQ_SPARE12_MSB, 0x0000}, + /* + * to invert the receiver path, uncomment the next line + * write (VILLA_MSEQ_SPARE12_MSB, 0x4000) + * + * SPARE2_LSB is used to configure the device while in sr mode to + * enable power savings and to use the optical module LOS signal. + * in power savings mode, the internal prbs checker can not be used. + * if the optical module LOS signal is used as an input to the micro + * code, then the micro code will wait until the optical module + * LOS = 0 before turning on the adaptive equalizer. + * Setting SPARE2_LSB bit 0 to 1 places the devie in power savings mode + * while setting bit 0 to 0 disables power savings mode. + * Setting SPARE2_LSB bit 2 to 0 configures the device to use the + * optical module LOS signal while setting bit 2 to 1 configures the + * device so that it will ignore the optical module LOS SPARE2_LSB = 0 + */ + + /* enable power savings, ignore optical module LOS */ + {VILLA_MSEQ_SPARE2_LSB, 0x5}, + + {VILLA_MSEQ_SPARE7_LSB, 0x1e}, + {VILLA_MSEQ_BANKSELECT, 0x4}, + {VILLA_MSEQ_SPARE9_LSB, 0x2}, + {VILLA_MSEQ_SPARE3_LSB, 0x0F53}, + {VILLA_MSEQ_SPARE3_MSB, 0x2006}, + {VILLA_MSEQ_SPARE8_LSB, 0x3FF7}, + {VILLA_MSEQ_SPARE8_MSB, 0x0A46}, + {VILLA_MSEQ_COEF8_FFE0_LSB, 0xD500}, + {VILLA_MSEQ_COEF8_FFE1_LSB, 0x0200}, + {VILLA_MSEQ_COEF8_FFE2_LSB, 0xBA00}, + {VILLA_MSEQ_COEF8_FFE3_LSB, 0x0100}, + {VILLA_MSEQ_COEF8_FFE4_LSB, 0x0300}, + {VILLA_MSEQ_COEF8_FFE5_LSB, 0x0300}, + {VILLA_MSEQ_COEF8_DFE0_LSB, 0x0700}, + {VILLA_MSEQ_COEF8_DFE0N_LSB, 0x0E00}, + {VILLA_MSEQ_COEF8_DFE1_LSB, 0x0B00}, + {VILLA_DSP_SDS_DSP_COEF_LARGE_LEAK, 0x2}, + {VILLA_DSP_SDS_SERDES_SRX_DAC_ENABLEB_LSB, 0xD000}, + {VILLA_MSEQ_POWER_DOWN_LSB, 0xFFFF}, + {VILLA_MSEQ_POWER_DOWN_MSB, 0x0}, + {VILLA_MSEQ_CAL_RX_SLICER, 0x80}, + {VILLA_DSP_SDS_SERDES_SRX_DAC_BIAS_SELECT1_MSB, 0x3f}, + {VILLA_GLOBAL_MSEQCLKCTRL, 0x4}, + {VILLA_MSEQ_OPTIONS, 0x7}, + + /* set up min value for ffe1 */ + {VILLA_MSEQ_COEF_INIT_SEL, 0x2}, + {VILLA_DSP_SDS_DSP_PRECODEDINITFFE21, 0x41}, + + /* CS4315_sr_rx_pre_eq_set_4in */ + {VILLA_GLOBAL_MSEQCLKCTRL, 0x8004}, + {VILLA_MSEQ_OPTIONS, 0xf}, + {VILLA_MSEQ_BANKSELECT, 0x4}, + {VILLA_MSEQ_PC, 0x0}, + + /* for lengths from 3.5 to 4.5inches */ + {VILLA_MSEQ_SERDES_PARAM_LSB, 0x0306}, + {VILLA_MSEQ_SPARE25_LSB, 0x0306}, + {VILLA_MSEQ_SPARE21_LSB, 0x2}, + {VILLA_MSEQ_SPARE23_LSB, 0x2}, + {VILLA_MSEQ_CAL_RX_DFE_EQ, 0x0}, + + {VILLA_GLOBAL_MSEQCLKCTRL, 0x4}, + {VILLA_MSEQ_OPTIONS, 0x7}, + + /* CS4315_rx_drive_4inch */ + /* for length 4inches */ + {VILLA_GLOBAL_VILLA2_COMPATIBLE, 0x0000}, + {VILLA_HOST_SDS_COMMON_STX0_TX_OUTPUT_CTRLA, 0x3023}, + {VILLA_LINE_SDS_COMMON_STX0_TX_OUTPUT_CTRLB, 0xc01E}, + + /* CS4315_tx_drive_4inch */ + /* for length 4inches */ + {VILLA_GLOBAL_VILLA2_COMPATIBLE, 0x0000}, + {VILLA_LINE_SDS_COMMON_STX0_TX_OUTPUT_CTRLA, 0x3023}, + {VILLA_LINE_SDS_COMMON_STX0_TX_OUTPUT_CTRLB, 0xc01E}, +}; + +void cs4340_upload_firmware(struct phy_device *phydev) +{ + char line_temp[0x50] = {0}; + char reg_addr[0x50] = {0}; + char reg_data[0x50] = {0}; + int i, line_cnt = 0, column_cnt = 0; + struct cortina_reg_config fw_temp; + char *addr = NULL; + +#if defined(CONFIG_SYS_CORTINA_FW_IN_NOR) || \ + defined(CONFIG_SYS_CORTINA_FW_IN_REMOTE) + + addr = (char *)CONFIG_CORTINA_FW_ADDR; +#elif defined(CONFIG_SYS_CORTINA_FW_IN_NAND) + int ret; + size_t fw_length = CONFIG_CORTINA_FW_LENGTH; + + addr = malloc(CONFIG_CORTINA_FW_LENGTH); + ret = nand_read(&nand_info[0], (loff_t)CONFIG_CORTINA_FW_ADDR, + &fw_length, (u_char *)addr); + if (ret == -EUCLEAN) { + printf("NAND read of Cortina firmware at 0x%x failed %d\n", + CONFIG_CORTINA_FW_ADDR, ret); + } +#elif defined(CONFIG_SYS_CORTINA_FW_IN_SPIFLASH) + int ret; + struct spi_flash *ucode_flash; + + addr = malloc(CONFIG_CORTINA_FW_LENGTH); + ucode_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); + if (!ucode_flash) { + puts("SF: probe for Cortina ucode failed\n"); + } else { + ret = spi_flash_read(ucode_flash, CONFIG_CORTINA_FW_ADDR, + CONFIG_CORTINA_FW_LENGTH, addr); + if (ret) + puts("SF: read for Cortina ucode failed\n"); + spi_flash_free(ucode_flash); + } +#elif defined(CONFIG_SYS_CORTINA_FW_IN_MMC) + int dev = CONFIG_SYS_MMC_ENV_DEV; + u32 cnt = CONFIG_CORTINA_FW_LENGTH / 512; + u32 blk = CONFIG_CORTINA_FW_ADDR / 512; + struct mmc *mmc = find_mmc_device(CONFIG_SYS_MMC_ENV_DEV); + + if (!mmc) { + puts("Failed to find MMC device for Cortina ucode\n"); + } else { + addr = malloc(CONFIG_CORTINA_FW_LENGTH); + printf("MMC read: dev # %u, block # %u, count %u ...\n", + dev, blk, cnt); + mmc_init(mmc); + (void)mmc->block_dev.block_read(dev, blk, cnt, addr); + /* flush cache after read */ + flush_cache((ulong)addr, cnt * 512); + } +#endif + + while (*addr != 'Q') { + i = 0; + + while (*addr != 0x0a) { + line_temp[i++] = *addr++; + if (0x50 < i) { + printf("Not found Cortina PHY ucode at 0x%x\n", + CONFIG_CORTINA_FW_ADDR); + return; + } + } + + addr++; /* skip '\n' */ + line_cnt++; + column_cnt = i; + line_temp[column_cnt] = '\0'; + + if (CONFIG_CORTINA_FW_LENGTH < line_cnt) + return; + + for (i = 0; i < column_cnt; i++) { + if (isspace(line_temp[i++])) + break; + } + + memcpy(reg_addr, line_temp, i); + memcpy(reg_data, &line_temp[i], column_cnt - i); + strim(reg_addr); + strim(reg_data); + fw_temp.reg_addr = (simple_strtoul(reg_addr, NULL, 0)) & 0xffff; + fw_temp.reg_value = (simple_strtoul(reg_data, NULL, 0)) & + 0xffff; + phy_write(phydev, 0x00, fw_temp.reg_addr, fw_temp.reg_value); + } +} + +int cs4340_phy_init(struct phy_device *phydev) +{ + int timeout = 100; /* 100ms */ + int reg_value = 0; + + /* step1: BIST test */ + phy_write(phydev, 0x00, VILLA_GLOBAL_MSEQCLKCTRL, 0x0004); + phy_write(phydev, 0x00, VILLA_GLOBAL_LINE_SOFT_RESET, 0x0000); + phy_write(phydev, 0x00, VILLA_GLOBAL_BIST_CONTROL, 0x0001); + while (--timeout) { + reg_value = phy_read(phydev, 0x00, VILLA_GLOBAL_BIST_STATUS); + if (reg_value & mseq_edc_bist_done) { + if (0 == (reg_value & mseq_edc_bist_fail)) + break; + } + udelay(1000); + } + + if (!timeout) { + printf("%s BIST mseq_edc_bist_done timeout!\n", __func__); + return -1; + } + + /* setp2: upload ucode */ + cs4340_upload_firmware(phydev); + reg_value = phy_read(phydev, 0x00, VILLA_GLOBAL_DWNLD_CHECKSUM_STATUS); + if (0x0 != reg_value) { + printf("%s error.\n", __func__); + return -1; + } + + return 0; +} + +int cs4340_config(struct phy_device *phydev) +{ + cs4340_phy_init(phydev); + return 0; +} + +int cs4340_startup(struct phy_device *phydev) +{ + phydev->link = 1; + + /* For now just lie and say it's 10G all the time */ + phydev->speed = SPEED_10000; + phydev->duplex = DUPLEX_FULL; + return 0; +} + +struct phy_driver cs4340_driver = { + .name = "Cortina CS4315/CS4340", + .uid = PHY_UID_CS4340, + .mask = 0xfffffff0, + .features = PHY_10G_FEATURES, + .mmds = (MDIO_DEVS_PMAPMD | MDIO_DEVS_PCS | + MDIO_DEVS_PHYXS | MDIO_DEVS_AN | + MDIO_DEVS_VEND1 | MDIO_DEVS_VEND2), + .config = &cs4340_config, + .startup = &cs4340_startup, + .shutdown = &gen10g_shutdown, +}; + +int phy_cortina_init(void) +{ + phy_register(&cs4340_driver); + return 0; +} + +int get_phy_id(struct mii_dev *bus, int addr, int devad, u32 *phy_id) +{ + int phy_reg; + bool is_cortina_phy = false; + + switch (addr) { +#ifdef CORTINA_PHY_ADDR1 + case CORTINA_PHY_ADDR1: +#endif +#ifdef CORTINA_PHY_ADDR2 + case CORTINA_PHY_ADDR2: +#endif +#ifdef CORTINA_PHY_ADDR3 + case CORTINA_PHY_ADDR3: +#endif +#ifdef CORTINA_PHY_ADDR4 + case CORTINA_PHY_ADDR4: +#endif + is_cortina_phy = true; + break; + default: + break; + } + + /* Cortina PHY has non-standard offset of PHY ID registers */ + if (is_cortina_phy) + phy_reg = bus->read(bus, addr, 0, VILLA_GLOBAL_CHIP_ID_LSB); + else + phy_reg = bus->read(bus, addr, devad, MII_PHYSID1); + + if (phy_reg < 0) + return -EIO; + + *phy_id = (phy_reg & 0xffff) << 16; + if (is_cortina_phy) + phy_reg = bus->read(bus, addr, 0, VILLA_GLOBAL_CHIP_ID_MSB); + else + phy_reg = bus->read(bus, addr, devad, MII_PHYSID2); + + if (phy_reg < 0) + return -EIO; + + *phy_id |= (phy_reg & 0xffff); + + return 0; +} diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 1d6c14f..1782159 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -448,6 +448,9 @@ int phy_init(void) #ifdef CONFIG_PHY_BROADCOM phy_broadcom_init(); #endif +#ifdef CONFIG_PHY_CORTINA + phy_cortina_init(); +#endif #ifdef CONFIG_PHY_DAVICOM phy_davicom_init(); #endif diff --git a/include/cortina.h b/include/cortina.h new file mode 100644 index 0000000..3e4ac62 --- /dev/null +++ b/include/cortina.h @@ -0,0 +1,73 @@ +/* + * Cortina PHY drivers + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Copyright 2014 Freescale Semiconductor, Inc. + */ + +#ifndef _CORTINA_H_ +#define _CORTINA_H_ + +#define VILLA_GLOBAL_CHIP_ID_LSB 0x000 +#define VILLA_GLOBAL_CHIP_ID_MSB 0x001 +#define VILLA_GLOBAL_BIST_CONTROL 0x002 +#define VILLA_GLOBAL_BIST_STATUS 0x003 +#define VILLA_GLOBAL_LINE_SOFT_RESET 0x007 +#define VILLA_GLOBAL_DWNLD_CHECKSUM_STATUS 0x00B +#define VILLA_GLOBAL_MSEQCLKCTRL 0x00E +#define VILLA_MSEQ_OPTIONS 0x1D0 +#define VILLA_MSEQ_PC 0x1D3 +#define VILLA_MSEQ_BANKSELECT 0x1DF +#define VILLA_DSP_SDS_DSP_COEF_DFE0_SELECT 0x2DB +#define VILLA_DSP_SDS_SERDES_SRX_DFE0_SELECT 0x36E +#define VILLA_LINE_SDS_COMMON_SRX0_RX_LOOP_FILTER 0x403 +#define VILLA_LINE_SDS_COMMON_SRX0_RX_CPA 0x404 +#define VILLA_LINE_SDS_COMMON_SRX0_RX_CPB 0x405 +#define VILLA_DSP_SDS_SERDES_SRX_FFE_DELAY_CTRL 0x369 +#define VILLA_MSEQ_ENABLE_MSB 0x194 +#define VILLA_MSEQ_SPARE21_LSB 0x226 +#define VILLA_MSEQ_RESET_COUNT_LSB 0x1E0 +#define VILLA_MSEQ_SPARE12_MSB 0x215 +#define VILLA_MSEQ_SPARE2_LSB 0x200 +#define VILLA_MSEQ_SPARE7_LSB 0x20A +#define VILLA_MSEQ_SPARE9_LSB 0x20E +#define VILLA_MSEQ_SPARE3_LSB 0x202 +#define VILLA_MSEQ_SPARE3_MSB 0x203 +#define VILLA_MSEQ_SPARE8_LSB 0x20C +#define VILLA_MSEQ_SPARE8_MSB 0x20D +#define VILLA_MSEQ_COEF8_FFE0_LSB 0x1E2 +#define VILLA_MSEQ_COEF8_FFE1_LSB 0x1E4 +#define VILLA_MSEQ_COEF8_FFE2_LSB 0x1E6 +#define VILLA_MSEQ_COEF8_FFE3_LSB 0x1E8 +#define VILLA_MSEQ_COEF8_FFE4_LSB 0x1EA +#define VILLA_MSEQ_COEF8_FFE5_LSB 0x1EC +#define VILLA_MSEQ_COEF8_DFE0_LSB 0x1F0 +#define VILLA_MSEQ_COEF8_DFE0N_LSB 0x1EE +#define VILLA_MSEQ_COEF8_DFE1_LSB 0x1F2 +#define VILLA_DSP_SDS_DSP_COEF_LARGE_LEAK 0x2E2 +#define VILLA_DSP_SDS_SERDES_SRX_DAC_ENABLEB_LSB 0x360 +#define VILLA_MSEQ_POWER_DOWN_LSB 0x198 +#define VILLA_MSEQ_POWER_DOWN_MSB 0x199 +#define VILLA_MSEQ_CAL_RX_SLICER 0x1B8 +#define VILLA_DSP_SDS_SERDES_SRX_DAC_BIAS_SELECT1_MSB 0x365 +#define VILLA_MSEQ_COEF_INIT_SEL 0x1AE +#define VILLA_DSP_SDS_DSP_PRECODEDINITFFE21 0x26A +#define VILLA_MSEQ_SERDES_PARAM_LSB 0x195 +#define VILLA_MSEQ_SPARE25_LSB 0x22E +#define VILLA_MSEQ_SPARE23_LSB 0x22A +#define VILLA_MSEQ_CAL_RX_DFE_EQ 0x1BA +#define VILLA_GLOBAL_VILLA2_COMPATIBLE 0x030 +#define VILLA_HOST_SDS_COMMON_STX0_TX_OUTPUT_CTRLA 0x812 +#define VILLA_HOST_SDS_COMMON_STX0_TX_OUTPUT_CTRLB 0x813 +#define VILLA_LINE_SDS_COMMON_STX0_TX_OUTPUT_CTRLA 0x427 +#define VILLA_LINE_SDS_COMMON_STX0_TX_OUTPUT_CTRLB 0x428 + +#define mseq_edc_bist_done (0x1<<0) +#define mseq_edc_bist_fail (0x1<<8) + +struct cortina_reg_config { + unsigned short reg_addr; + unsigned short reg_value; +}; +#endif diff --git a/include/phy.h b/include/phy.h index 5eafe6b..0520435 100644 --- a/include/phy.h +++ b/include/phy.h @@ -225,6 +225,7 @@ int gen10g_discover_mmds(struct phy_device *phydev);
int phy_atheros_init(void); int phy_broadcom_init(void); +int phy_cortina_init(void); int phy_davicom_init(void); int phy_et1011c_init(void); int phy_lxt_init(void); @@ -239,6 +240,7 @@ int phy_vitesse_init(void); int board_phy_config(struct phy_device *phydev);
/* PHY UIDs for various PHYs that are referenced in external code */ +#define PHY_UID_CS4340 0x13e51002 #define PHY_UID_TN2020 0x00a19410
#endif
-----Original Message----- From: Shengzhou Liu [mailto:Shengzhou.Liu@freescale.com] Sent: Wednesday, November 05, 2014 1:33 PM To: u-boot@lists.denx.de; Sun York-R58495; joe.hershberger@gmail.com Cc: Liu Shengzhou-B36685 Subject: [PATCH v6] net/phy: Add support for CS4315/CS4340 PHY
The link of previous version v5 http://patchwork.ozlabs.org/patch/350162/
Shengzhou Liu
Shengzhou.Liuļ¼ freescale.com
