[PATCH] libfdt: migrate fdt_ro.c to a wrapper of scripts/dtc/libfdt/fdt_ro.c
There is no essential difference between scripts/dtc/libfdt/fdt_ro.c and lib/libfdt/fdt_ro.c
Migrate to a simple wrapper like the other files.
Signed-off-by: Masahiro Yamada masahiroy@kernel.org ---
lib/libfdt/Makefile | 5 +- lib/libfdt/fdt_ro.c | 925 +------------------------------------------- 2 files changed, 2 insertions(+), 928 deletions(-)
diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index 5d3ae4e2f1..65981a6131 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -6,6 +6,7 @@ # Use upstream code. obj-y += \ fdt.o \ + fdt_ro.o \ fdt_wip.o \ fdt_strerror.o \ fdt_sw.o \ @@ -15,10 +16,6 @@ obj-y += \
obj-$(CONFIG_OF_LIBFDT_OVERLAY) += fdt_overlay.o
-# Locally modified for U-Boot. -# TODO: split out the local modifiction. -obj-y += fdt_ro.o - # U-Boot own file obj-y += fdt_region.o
diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index be03aea9eb..7ede074537 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -1,925 +1,2 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-2-Clause -/* - * libfdt - Flat Device Tree manipulation - * Copyright (C) 2006 David Gibson, IBM Corporation. - */ #include <linux/libfdt_env.h> - -#ifndef USE_HOSTCC -#include <fdt.h> -#include <linux/libfdt.h> -#else -#include "fdt_host.h" -#endif - -#include "libfdt_internal.h" - -static int fdt_nodename_eq_(const void *fdt, int offset, - const char *s, int len) -{ - int olen; - const char *p = fdt_get_name(fdt, offset, &olen); - - if (!p || (fdt_chk_extra() && olen < len)) - /* short match */ - return 0; - - if (memcmp(p, s, len) != 0) - return 0; - - if (p[len] == '\0') - return 1; - else if (!memchr(s, '@', len) && (p[len] == '@')) - return 1; - else - return 0; -} - -const char *fdt_get_string(const void *fdt, int stroffset, int *lenp) -{ - int32_t totalsize; - uint32_t absoffset; - size_t len; - int err; - const char *s, *n; - - if (!fdt_chk_extra()) { - s = (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset; - - if (lenp) - *lenp = strlen(s); - return s; - } - totalsize = fdt_ro_probe_(fdt); - err = totalsize; - if (totalsize < 0) - goto fail; - - err = -FDT_ERR_BADOFFSET; - absoffset = stroffset + fdt_off_dt_strings(fdt); - if (absoffset >= totalsize) - goto fail; - len = totalsize - absoffset; - - if (fdt_magic(fdt) == FDT_MAGIC) { - if (stroffset < 0) - goto fail; - if (!fdt_chk_version() || fdt_version(fdt) >= 17) { - if (stroffset >= fdt_size_dt_strings(fdt)) - goto fail; - if ((fdt_size_dt_strings(fdt) - stroffset) < len) - len = fdt_size_dt_strings(fdt) - stroffset; - } - } else if (fdt_magic(fdt) == FDT_SW_MAGIC) { - if ((stroffset >= 0) - || (stroffset < -fdt_size_dt_strings(fdt))) - goto fail; - if ((-stroffset) < len) - len = -stroffset; - } else { - err = -FDT_ERR_INTERNAL; - goto fail; - } - - s = (const char *)fdt + absoffset; - n = memchr(s, '\0', len); - if (!n) { - /* missing terminating NULL */ - err = -FDT_ERR_TRUNCATED; - goto fail; - } - - if (lenp) - *lenp = n - s; - return s; - -fail: - if (lenp) - *lenp = err; - return NULL; -} - -const char *fdt_string(const void *fdt, int stroffset) -{ - return fdt_get_string(fdt, stroffset, NULL); -} - -static int fdt_string_eq_(const void *fdt, int stroffset, - const char *s, int len) -{ - int slen; - const char *p = fdt_get_string(fdt, stroffset, &slen); - - return p && (slen == len) && (memcmp(p, s, len) == 0); -} - -int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) -{ - uint32_t max = 0; - int offset = -1; - - while (true) { - uint32_t value; - - offset = fdt_next_node(fdt, offset, NULL); - if (offset < 0) { - if (offset == -FDT_ERR_NOTFOUND) - break; - - return offset; - } - - value = fdt_get_phandle(fdt, offset); - - if (value > max) - max = value; - } - - if (phandle) - *phandle = max; - - return 0; -} - -int fdt_generate_phandle(const void *fdt, uint32_t *phandle) -{ - uint32_t max; - int err; - - err = fdt_find_max_phandle(fdt, &max); - if (err < 0) - return err; - - if (max == FDT_MAX_PHANDLE) - return -FDT_ERR_NOPHANDLES; - - if (phandle) - *phandle = max + 1; - - return 0; -} - -static const struct fdt_reserve_entry *fdt_mem_rsv(const void *fdt, int n) -{ - int offset = n * sizeof(struct fdt_reserve_entry); - int absoffset = fdt_off_mem_rsvmap(fdt) + offset; - - if (fdt_chk_extra()) { - if (absoffset < fdt_off_mem_rsvmap(fdt)) - return NULL; - if (absoffset > fdt_totalsize(fdt) - - sizeof(struct fdt_reserve_entry)) - return NULL; - } - return fdt_mem_rsv_(fdt, n); -} - -int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size) -{ - const struct fdt_reserve_entry *re; - - FDT_RO_PROBE(fdt); - re = fdt_mem_rsv(fdt, n); - if (fdt_chk_extra() && !re) - return -FDT_ERR_BADOFFSET; - - *address = fdt64_to_cpu(re->address); - *size = fdt64_to_cpu(re->size); - return 0; -} - -int fdt_num_mem_rsv(const void *fdt) -{ - int i; - const struct fdt_reserve_entry *re; - - for (i = 0; (re = fdt_mem_rsv(fdt, i)) != NULL; i++) { - if (fdt64_to_cpu(re->size) == 0) - return i; - } - return -FDT_ERR_TRUNCATED; -} - -static int nextprop_(const void *fdt, int offset) -{ - uint32_t tag; - int nextoffset; - - do { - tag = fdt_next_tag(fdt, offset, &nextoffset); - - switch (tag) { - case FDT_END: - if (nextoffset >= 0) - return -FDT_ERR_BADSTRUCTURE; - else - return nextoffset; - - case FDT_PROP: - return offset; - } - offset = nextoffset; - } while (tag == FDT_NOP); - - return -FDT_ERR_NOTFOUND; -} - -int fdt_subnode_offset_namelen(const void *fdt, int offset, - const char *name, int namelen) -{ - int depth; - - FDT_RO_PROBE(fdt); - - for (depth = 0; - (offset >= 0) && (depth >= 0); - offset = fdt_next_node(fdt, offset, &depth)) - if ((depth == 1) - && fdt_nodename_eq_(fdt, offset, name, namelen)) - return offset; - - if (depth < 0) - return -FDT_ERR_NOTFOUND; - return offset; /* error */ -} - -int fdt_subnode_offset(const void *fdt, int parentoffset, - const char *name) -{ - return fdt_subnode_offset_namelen(fdt, parentoffset, name, strlen(name)); -} - -int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) -{ - const char *end = path + namelen; - const char *p = path; - int offset = 0; - - FDT_RO_PROBE(fdt); - - /* see if we have an alias */ - if (*path != '/') { - const char *q = memchr(path, '/', end - p); - - if (!q) - q = end; - - p = fdt_get_alias_namelen(fdt, p, q - p); - if (!p) - return -FDT_ERR_BADPATH; - offset = fdt_path_offset(fdt, p); - - p = q; - } - - while (p < end) { - const char *q; - - while (*p == '/') { - p++; - if (p == end) - return offset; - } - q = memchr(p, '/', end - p); - if (! q) - q = end; - - offset = fdt_subnode_offset_namelen(fdt, offset, p, q-p); - if (offset < 0) - return offset; - - p = q; - } - - return offset; -} - -int fdt_path_offset(const void *fdt, const char *path) -{ - return fdt_path_offset_namelen(fdt, path, strlen(path)); -} - -const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) -{ - const struct fdt_node_header *nh = fdt_offset_ptr_(fdt, nodeoffset); - const char *nameptr; - int err; - - if (fdt_chk_extra() && - (((err = fdt_ro_probe_(fdt)) < 0) - || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))) - goto fail; - - nameptr = nh->name; - - if (fdt_chk_version() && fdt_version(fdt) < 0x10) { - /* - * For old FDT versions, match the naming conventions of V16: - * give only the leaf name (after all /). The actual tree - * contents are loosely checked. - */ - const char *leaf; - leaf = strrchr(nameptr, '/'); - if (leaf == NULL) { - err = -FDT_ERR_BADSTRUCTURE; - goto fail; - } - nameptr = leaf+1; - } - - if (len) - *len = strlen(nameptr); - - return nameptr; - - fail: - if (len) - *len = err; - return NULL; -} - -int fdt_first_property_offset(const void *fdt, int nodeoffset) -{ - int offset; - - if ((offset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) - return offset; - - return nextprop_(fdt, offset); -} - -int fdt_next_property_offset(const void *fdt, int offset) -{ - if ((offset = fdt_check_prop_offset_(fdt, offset)) < 0) - return offset; - - return nextprop_(fdt, offset); -} - -static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, - int offset, - int *lenp) -{ - int err; - const struct fdt_property *prop; - - if (fdt_chk_basic() && (err = fdt_check_prop_offset_(fdt, offset)) < 0) { - if (lenp) - *lenp = err; - return NULL; - } - - prop = fdt_offset_ptr_(fdt, offset); - - if (lenp) - *lenp = fdt32_to_cpu(prop->len); - - return prop; -} - -const struct fdt_property *fdt_get_property_by_offset(const void *fdt, - int offset, - int *lenp) -{ - /* Prior to version 16, properties may need realignment - * and this API does not work. fdt_getprop_*() will, however. */ - - if (fdt_chk_version() && fdt_version(fdt) < 0x10) { - if (lenp) - *lenp = -FDT_ERR_BADVERSION; - return NULL; - } - - return fdt_get_property_by_offset_(fdt, offset, lenp); -} - -static const struct fdt_property *fdt_get_property_namelen_(const void *fdt, - int offset, - const char *name, - int namelen, - int *lenp, - int *poffset) -{ - for (offset = fdt_first_property_offset(fdt, offset); - (offset >= 0); - (offset = fdt_next_property_offset(fdt, offset))) { - const struct fdt_property *prop; - - prop = fdt_get_property_by_offset_(fdt, offset, lenp); - if (fdt_chk_extra() && !prop) { - offset = -FDT_ERR_INTERNAL; - break; - } - if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff), - name, namelen)) { - if (poffset) - *poffset = offset; - return prop; - } - } - - if (lenp) - *lenp = offset; - return NULL; -} - - -const struct fdt_property *fdt_get_property_namelen(const void *fdt, - int offset, - const char *name, - int namelen, int *lenp) -{ - /* Prior to version 16, properties may need realignment - * and this API does not work. fdt_getprop_*() will, however. */ - if (fdt_chk_version() && fdt_version(fdt) < 0x10) { - if (lenp) - *lenp = -FDT_ERR_BADVERSION; - return NULL; - } - - return fdt_get_property_namelen_(fdt, offset, name, namelen, lenp, - NULL); -} - - -const struct fdt_property *fdt_get_property(const void *fdt, - int nodeoffset, - const char *name, int *lenp) -{ - return fdt_get_property_namelen(fdt, nodeoffset, name, - strlen(name), lenp); -} - -const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, - const char *name, int namelen, int *lenp) -{ - int poffset; - const struct fdt_property *prop; - - prop = fdt_get_property_namelen_(fdt, nodeoffset, name, namelen, lenp, - &poffset); - if (!prop) - return NULL; - - /* Handle realignment */ - if (fdt_chk_version() && fdt_version(fdt) < 0x10 && - (poffset + sizeof(*prop)) % 8 && fdt32_to_cpu(prop->len) >= 8) - return prop->data + 4; - return prop->data; -} - -const void *fdt_getprop_by_offset(const void *fdt, int offset, - const char **namep, int *lenp) -{ - const struct fdt_property *prop; - - prop = fdt_get_property_by_offset_(fdt, offset, lenp); - if (!prop) - return NULL; - if (namep) { - const char *name; - int namelen; - - if (fdt_chk_extra()) { - name = fdt_get_string(fdt, fdt32_to_cpu(prop->nameoff), - &namelen); - if (!name) { - if (lenp) - *lenp = namelen; - return NULL; - } - *namep = name; - } else { - *namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff)); - } - } - - /* Handle realignment */ - if (fdt_chk_version() && fdt_version(fdt) < 0x10 && - (offset + sizeof(*prop)) % 8 && fdt32_to_cpu(prop->len) >= 8) - return prop->data + 4; - return prop->data; -} - -const void *fdt_getprop(const void *fdt, int nodeoffset, - const char *name, int *lenp) -{ - return fdt_getprop_namelen(fdt, nodeoffset, name, strlen(name), lenp); -} - -uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) -{ - const fdt32_t *php; - int len; - - /* FIXME: This is a bit sub-optimal, since we potentially scan - * over all the properties twice. */ - php = fdt_getprop(fdt, nodeoffset, "phandle", &len); - if (!php || (len != sizeof(*php))) { - php = fdt_getprop(fdt, nodeoffset, "linux,phandle", &len); - if (!php || (len != sizeof(*php))) - return 0; - } - - return fdt32_to_cpu(*php); -} - -const char *fdt_get_alias_namelen(const void *fdt, - const char *name, int namelen) -{ - int aliasoffset; - - aliasoffset = fdt_path_offset(fdt, "/aliases"); - if (aliasoffset < 0) - return NULL; - - return fdt_getprop_namelen(fdt, aliasoffset, name, namelen, NULL); -} - -const char *fdt_get_alias(const void *fdt, const char *name) -{ - return fdt_get_alias_namelen(fdt, name, strlen(name)); -} - -int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) -{ - int pdepth = 0, p = 0; - int offset, depth, namelen; - const char *name; - - FDT_RO_PROBE(fdt); - - if (buflen < 2) - return -FDT_ERR_NOSPACE; - - for (offset = 0, depth = 0; - (offset >= 0) && (offset <= nodeoffset); - offset = fdt_next_node(fdt, offset, &depth)) { - while (pdepth > depth) { - do { - p--; - } while (buf[p-1] != '/'); - pdepth--; - } - - if (pdepth >= depth) { - name = fdt_get_name(fdt, offset, &namelen); - if (!name) - return namelen; - if ((p + namelen + 1) <= buflen) { - memcpy(buf + p, name, namelen); - p += namelen; - buf[p++] = '/'; - pdepth++; - } - } - - if (offset == nodeoffset) { - if (pdepth < (depth + 1)) - return -FDT_ERR_NOSPACE; - - if (p > 1) /* special case so that root path is "/", not "" */ - p--; - buf[p] = '\0'; - return 0; - } - } - - if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0)) - return -FDT_ERR_BADOFFSET; - else if (offset == -FDT_ERR_BADOFFSET) - return -FDT_ERR_BADSTRUCTURE; - - return offset; /* error from fdt_next_node() */ -} - -int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, - int supernodedepth, int *nodedepth) -{ - int offset, depth; - int supernodeoffset = -FDT_ERR_INTERNAL; - - FDT_RO_PROBE(fdt); - - if (supernodedepth < 0) - return -FDT_ERR_NOTFOUND; - - for (offset = 0, depth = 0; - (offset >= 0) && (offset <= nodeoffset); - offset = fdt_next_node(fdt, offset, &depth)) { - if (depth == supernodedepth) - supernodeoffset = offset; - - if (offset == nodeoffset) { - if (nodedepth) - *nodedepth = depth; - - if (supernodedepth > depth) - return -FDT_ERR_NOTFOUND; - else - return supernodeoffset; - } - } - - if (fdt_chk_extra()) { - if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0)) - return -FDT_ERR_BADOFFSET; - else if (offset == -FDT_ERR_BADOFFSET) - return -FDT_ERR_BADSTRUCTURE; - } - - return offset; /* error from fdt_next_node() */ -} - -int fdt_node_depth(const void *fdt, int nodeoffset) -{ - int nodedepth; - int err; - - err = fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, &nodedepth); - if (err) - return (!fdt_chk_extra() || err < 0) ? err : -FDT_ERR_INTERNAL; - return nodedepth; -} - -int fdt_parent_offset(const void *fdt, int nodeoffset) -{ - int nodedepth = fdt_node_depth(fdt, nodeoffset); - - if (nodedepth < 0) - return nodedepth; - return fdt_supernode_atdepth_offset(fdt, nodeoffset, - nodedepth - 1, NULL); -} - -int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, - const char *propname, - const void *propval, int proplen) -{ - int offset; - const void *val; - int len; - - FDT_RO_PROBE(fdt); - - /* FIXME: The algorithm here is pretty horrible: we scan each - * property of a node in fdt_getprop(), then if that didn't - * find what we want, we scan over them again making our way - * to the next node. Still it's the easiest to implement - * approach; performance can come later. */ - for (offset = fdt_next_node(fdt, startoffset, NULL); - offset >= 0; - offset = fdt_next_node(fdt, offset, NULL)) { - val = fdt_getprop(fdt, offset, propname, &len); - if (val && (len == proplen) - && (memcmp(val, propval, len) == 0)) - return offset; - } - - return offset; /* error from fdt_next_node() */ -} - -int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) -{ - int offset; - - if ((phandle == 0) || (phandle == -1)) - return -FDT_ERR_BADPHANDLE; - - FDT_RO_PROBE(fdt); - - /* FIXME: The algorithm here is pretty horrible: we - * potentially scan each property of a node in - * fdt_get_phandle(), then if that didn't find what - * we want, we scan over them again making our way to the next - * node. Still it's the easiest to implement approach; - * performance can come later. */ - for (offset = fdt_next_node(fdt, -1, NULL); - offset >= 0; - offset = fdt_next_node(fdt, offset, NULL)) { - if (fdt_get_phandle(fdt, offset) == phandle) - return offset; - } - - return offset; /* error from fdt_next_node() */ -} - -int fdt_stringlist_contains(const char *strlist, int listlen, const char *str) -{ - int len = strlen(str); - const char *p; - - while (listlen >= len) { - if (memcmp(str, strlist, len+1) == 0) - return 1; - p = memchr(strlist, '\0', listlen); - if (!p) - return 0; /* malformed strlist.. */ - listlen -= (p-strlist) + 1; - strlist = p + 1; - } - return 0; -} - -int fdt_stringlist_count(const void *fdt, int nodeoffset, const char *property) -{ - const char *list, *end; - int length, count = 0; - - list = fdt_getprop(fdt, nodeoffset, property, &length); - if (!list) - return length; - - end = list + length; - - while (list < end) { - length = strnlen(list, end - list) + 1; - - /* Abort if the last string isn't properly NUL-terminated. */ - if (list + length > end) - return -FDT_ERR_BADVALUE; - - list += length; - count++; - } - - return count; -} - -int fdt_stringlist_search(const void *fdt, int nodeoffset, const char *property, - const char *string) -{ - int length, len, idx = 0; - const char *list, *end; - - list = fdt_getprop(fdt, nodeoffset, property, &length); - if (!list) - return length; - - len = strlen(string) + 1; - end = list + length; - - while (list < end) { - length = strnlen(list, end - list) + 1; - - /* Abort if the last string isn't properly NUL-terminated. */ - if (list + length > end) - return -FDT_ERR_BADVALUE; - - if (length == len && memcmp(list, string, length) == 0) - return idx; - - list += length; - idx++; - } - - return -FDT_ERR_NOTFOUND; -} - -const char *fdt_stringlist_get(const void *fdt, int nodeoffset, - const char *property, int idx, - int *lenp) -{ - const char *list, *end; - int length; - - list = fdt_getprop(fdt, nodeoffset, property, &length); - if (!list) { - if (lenp) - *lenp = length; - - return NULL; - } - - end = list + length; - - while (list < end) { - length = strnlen(list, end - list) + 1; - - /* Abort if the last string isn't properly NUL-terminated. */ - if (list + length > end) { - if (lenp) - *lenp = -FDT_ERR_BADVALUE; - - return NULL; - } - - if (idx == 0) { - if (lenp) - *lenp = length - 1; - - return list; - } - - list += length; - idx--; - } - - if (lenp) - *lenp = -FDT_ERR_NOTFOUND; - - return NULL; -} - -int fdt_node_check_compatible(const void *fdt, int nodeoffset, - const char *compatible) -{ - const void *prop; - int len; - - prop = fdt_getprop(fdt, nodeoffset, "compatible", &len); - if (!prop) - return len; - - return !fdt_stringlist_contains(prop, len, compatible); -} - -int fdt_node_offset_by_compatible(const void *fdt, int startoffset, - const char *compatible) -{ - int offset, err; - - FDT_RO_PROBE(fdt); - - /* FIXME: The algorithm here is pretty horrible: we scan each - * property of a node in fdt_node_check_compatible(), then if - * that didn't find what we want, we scan over them again - * making our way to the next node. Still it's the easiest to - * implement approach; performance can come later. */ - for (offset = fdt_next_node(fdt, startoffset, NULL); - offset >= 0; - offset = fdt_next_node(fdt, offset, NULL)) { - err = fdt_node_check_compatible(fdt, offset, compatible); - if ((err < 0) && (err != -FDT_ERR_NOTFOUND)) - return err; - else if (err == 0) - return offset; - } - - return offset; /* error from fdt_next_node() */ -} - -#if !defined(CHECK_LEVEL) || CHECK_LEVEL > 0 -int fdt_check_full(const void *fdt, size_t bufsize) -{ - int err; - int num_memrsv; - int offset, nextoffset = 0; - uint32_t tag; - unsigned depth = 0; - const void *prop; - const char *propname; - - if (bufsize < FDT_V1_SIZE) - return -FDT_ERR_TRUNCATED; - err = fdt_check_header(fdt); - if (err != 0) - return err; - if (bufsize < fdt_totalsize(fdt)) - return -FDT_ERR_TRUNCATED; - - num_memrsv = fdt_num_mem_rsv(fdt); - if (num_memrsv < 0) - return num_memrsv; - - while (1) { - offset = nextoffset; - tag = fdt_next_tag(fdt, offset, &nextoffset); - - if (nextoffset < 0) - return nextoffset; - - switch (tag) { - case FDT_NOP: - break; - - case FDT_END: - if (depth != 0) - return -FDT_ERR_BADSTRUCTURE; - return 0; - - case FDT_BEGIN_NODE: - depth++; - if (depth > INT_MAX) - return -FDT_ERR_BADSTRUCTURE; - break; - - case FDT_END_NODE: - if (depth == 0) - return -FDT_ERR_BADSTRUCTURE; - depth--; - break; - - case FDT_PROP: - prop = fdt_getprop_by_offset(fdt, offset, &propname, - &err); - if (!prop) - return err; - break; - - default: - return -FDT_ERR_INTERNAL; - } - } -} -#endif +#include "../../scripts/dtc/libfdt/fdt_ro.c"
I will sync tools/Makefile, too. Will send v2.
Masahiro Yamada
