[U-Boot] [PATCH v4 0/6] rockchip: rk3399: Make u-boot.itb as BUILD_TARGET
This is v4 set for supporting u-boot.itb build target image for rk3399. here is the previous version changes[1]
Changes for v4: - rebase on master - support u-boot.itb build even if bl31.elf available in PWD like what is doing right now. this would keep the backward compatible. - update board README changes Changes for v3: - skip binman changes - rebase on u-boot-rockchip/master
Note: While creating dummy bl31.elf (neither it available in PWD nor it as part of BL31 env), the build system is creating u-boot.its without firmware entry which indeed expected. but the resulting u-boot.itb seems booting on rk3399, which I'm not sure - any input would help on this regard.
Travis-CI: https://travis-ci.org/openedev/u-boot-amarula/builds/548123247
[1] https://patchwork.ozlabs.org/cover/1096499/
Any inputs? Jagan.
Jagan Teki (6): Makefile: clean image.map Makefile: clean bl31_*.bin travis.yml: Add pyelftools install entry rockchip: rk3399: Get bl31.elf via BL31 board: puma: Get bl31.bin via BL31 and rk3399m0.bin via PMUM0 Kconfig: Add u-boot.itb BUILD_TARGET for Rockchip
.travis.yml | 1 + Kconfig | 2 +- Makefile | 3 +- arch/arm/mach-rockchip/make_fit_atf.py | 20 +++- board/theobroma-systems/puma_rk3399/README | 2 +- .../puma_rk3399/fit_spl_atf.its | 58 ------------ .../puma_rk3399/fit_spl_atf.sh | 94 +++++++++++++++++++ board/vamrs/rock960_rk3399/README | 1 - configs/puma-rk3399_defconfig | 2 +- doc/README.rockchip | 14 ++- 10 files changed, 124 insertions(+), 73 deletions(-) delete mode 100644 board/theobroma-systems/puma_rk3399/fit_spl_atf.its create mode 100755 board/theobroma-systems/puma_rk3399/fit_spl_atf.sh
binman tools for creating single image build will create image.map at the end, which has information about binman image node details.
current u-boot, is unable to clean this image.map so add a command entry in clean target in Makefile.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 9fba74d3ed..804eb2c652 100644 --- a/Makefile +++ b/Makefile @@ -1847,7 +1847,8 @@ clean: $(clean-dirs) -o -name modules.builtin -o -name '.tmp_*.o.*' \ -o -name 'dsdt.aml' -o -name 'dsdt.asl.tmp' -o -name 'dsdt.c' \ -o -name '*.efi' -o -name '*.gcno' -o -name '*.so' ) \ - -type f -print | xargs rm -f + -type f -print | xargs rm -f \ + image.map
# mrproper - Delete all generated files, including .config #
Rockchip platform has its python script that would generate various bl31_*bin for creating u-boot.itb file by taking bl31.elf as input.
These bl31_*.bin files are generated in u-boot root directory and have no rule to clean it up. so add support for it by adding in command entry of clean target in Makefile.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 804eb2c652..a503ab9fc1 100644 --- a/Makefile +++ b/Makefile @@ -1848,7 +1848,7 @@ clean: $(clean-dirs) -o -name 'dsdt.aml' -o -name 'dsdt.asl.tmp' -o -name 'dsdt.c' \ -o -name '*.efi' -o -name '*.gcno' -o -name '*.so' ) \ -type f -print | xargs rm -f \ - image.map + bl31_*.bin image.map
Currently rockchip platform is using explicit 'make u-boot.itb' for building u-boot.itb but if we enable CONFIG_BUILD_TARGET as 'u-boot.itb' then the resulting u-boot.itb directly will create by make.
But, that indeed make travis build fail since it require python-pyelftools host package.
So add pyelftools install entry as 'pip install pyelftools', this would create pyelftools on travis host which are required to build rk3399 itb.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- .travis.yml | 1 + 1 file changed, 1 insertion(+)
diff --git a/.travis.yml b/.travis.yml index 8bd49ef1a5..94b795ef21 100644 --- a/.travis.yml +++ b/.travis.yml @@ -50,6 +50,7 @@ install: - . /tmp/venv/bin/activate - pip install pytest==2.8.7 - pip install python-subunit + - pip install pyelftools - grub-mkimage -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd - grub-mkimage -o ~/grub_x64.efi -O x86_64-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd - mkdir ~/grub2-arm
Right now rockchip platform need to copy bl31.elf into u-boot source directory to make use of building u-boot.itb.
So, add environment variable BL31 like Allwinner SoC so-that the bl31.elf would available via BL31.
If the builds are not exporting BL31 env, the make_fit_atf.py explicitly create dummy bl31.elf in u-boot root directory to satisfy travis builds and it will show the warning on console as
WARNING: BL31 file bl31.elf NOT found, resulting binary is non-functional WARNING: Please read Building section in doc/README.rockchip
Note, that the dummy bl31 files were created during not exporting BL31 case would be removed via clean target in Makefile.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Makefile | 2 +- arch/arm/mach-rockchip/make_fit_atf.py | 20 ++++++++++++++++++-- doc/README.rockchip | 4 ++-- 3 files changed, 21 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index a503ab9fc1..3ede10ff68 100644 --- a/Makefile +++ b/Makefile @@ -1848,7 +1848,7 @@ clean: $(clean-dirs) -o -name 'dsdt.aml' -o -name 'dsdt.asl.tmp' -o -name 'dsdt.c' \ -o -name '*.efi' -o -name '*.gcno' -o -name '*.so' ) \ -type f -print | xargs rm -f \ - bl31_*.bin image.map + bl31.c bl31.elf bl31_*.bin image.map
# mrproper - Delete all generated files, including .config # diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py index 212bd0a854..e7d3846a13 100755 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ b/arch/arm/mach-rockchip/make_fit_atf.py @@ -12,6 +12,7 @@ import os import sys import getopt +import logging
# pip install pyelftools from elftools.elf.elffile import ELFFile @@ -89,13 +90,17 @@ def append_conf_section(file, cnt, dtname, segments): file.write('\t\tconfig_%d {\n' % cnt) file.write('\t\t\tdescription = "%s";\n' % dtname) file.write('\t\t\tfirmware = "atf_1";\n') - file.write('\t\t\tloadables = "uboot",') + file.write('\t\t\tloadables = "uboot"') + if segments != 0: + file.write(',') for i in range(1, segments): file.write('"atf_%d"' % (i)) if i != (segments - 1): file.write(',') else: file.write(';\n') + if segments == 0: + file.write(';\n') file.write('\t\t\tfdt = "fdt_1";\n') file.write('\t\t};\n') file.write('\n') @@ -171,8 +176,19 @@ def generate_atf_binary(bl31_file_name):
def main(): uboot_elf = "./u-boot" - bl31_elf = "./bl31.elf" + bl31_elf = os.path.isfile("./bl31.elf") fit_its = sys.stdout + if bl31_elf: + bl31_elf = "./bl31.elf" + elif "BL31" in os.environ: + bl31_elf=os.getenv("BL31"); + else: + os.system("echo 'int main(){}' > bl31.c") + os.system("${CROSS_COMPILE}gcc -c bl31.c -o bl31.elf") + bl31_elf = "./bl31.elf" + logging.basicConfig(format='%(levelname)s:%(message)s', level=logging.DEBUG) + logging.warning(' BL31 file bl31.elf NOT found, resulting binary is non-functional') + logging.warning(' Please read Building section in doc/README.rockchip')
opts, args = getopt.getopt(sys.argv[1:], "o:u:b:h") for opt, val in opts: diff --git a/doc/README.rockchip b/doc/README.rockchip index 264f7e4994..5680c075fa 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -149,8 +149,8 @@ For example: => make realclean => make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399
- (copy bl31.elf into U-Boot root dir) - => cp build/rk3399/release/bl31/bl31.elf /path/to/u-boot + (export bl31.elf) + => export BL31=/path/to/arm-trusted-firmware/build/rk3399/release/bl31/bl31.elf
- Compile PMU M0 firmware
Hi Jagan:
Thanks, - Kever
- file.write('\t\t\tloadables = "uboot"')
- if segments != 0:
for i in range(1, segments): file.write('"atf_%d"' % (i)) if i != (segments - 1): file.write(',') else: file.write(';\n')file.write(',')
- if segments == 0:
file.write('\t\t\tfdt = "fdt_1";\n') file.write('\t\t};\n') file.write('\n')file.write(';\n')
if bl31_elf:
else:
(export bl31.elf)
Right now puma rk3399 board need to copy bl31-rk3399.bin and rk3399m0.bin into u-boot source directory to make use of building u-boot.itb.
So, add environment variable - BL31 for bl31.bin (instead of bl31-rk3399.bin to compatible with other platform BL31 env) - PMUM0 for rk3399m0.bin
If the builds are not exporting BL31, PMUM0 env, the fit_spl_atf.sh will notify with warning about which document to refer for more information like this:
WARNING: BL31 file bl31.bin NOT found, resulting binary is non-functional Please read Building section in doc/README.rockchip WARNING: PMUM0 file rk3399m0.bin NOT found, resulting binary is non-functional Please read Building section in doc/README.rockchip
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- .../puma_rk3399/fit_spl_atf.its | 58 ------------ .../puma_rk3399/fit_spl_atf.sh | 94 +++++++++++++++++++ configs/puma-rk3399_defconfig | 2 +- doc/README.rockchip | 8 +- 4 files changed, 99 insertions(+), 63 deletions(-) delete mode 100644 board/theobroma-systems/puma_rk3399/fit_spl_atf.its create mode 100755 board/theobroma-systems/puma_rk3399/fit_spl_atf.sh
diff --git a/board/theobroma-systems/puma_rk3399/fit_spl_atf.its b/board/theobroma-systems/puma_rk3399/fit_spl_atf.its deleted file mode 100644 index 530f059f3d..0000000000 --- a/board/theobroma-systems/puma_rk3399/fit_spl_atf.its +++ /dev/null @@ -1,58 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR X11 */ -/* - * Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH - * - * Minimal dts for a SPL FIT image payload. - */ - -/dts-v1/; - -/ { - description = "FIT image with U-Boot proper, ATF bl31, M0 Firmware, DTB"; - #address-cells = <1>; - - images { - uboot { - description = "U-Boot (64-bit)"; - data = /incbin/("../../../u-boot-nodtb.bin"); - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <0x00200000>; - }; - atf { - description = "ARM Trusted Firmware"; - data = /incbin/("../../../bl31-rk3399.bin"); - type = "firmware"; - arch = "arm64"; - os = "arm-trusted-firmware"; - compression = "none"; - load = <0x1000>; - entry = <0x1000>; - }; - pmu { - description = "Cortex-M0 firmware"; - data = /incbin/("../../../rk3399m0.bin"); - type = "pmu-firmware"; - compression = "none"; - load = <0x180000>; - }; - fdt { - description = "RK3399-Q7 (Puma) flat device-tree"; - data = /incbin/("../../../u-boot.dtb"); - type = "flat_dt"; - compression = "none"; - }; - }; - - configurations { - default = "conf"; - conf { - description = "Theobroma Systems RK3399-Q7 (Puma) SoM"; - firmware = "atf"; - loadables = "uboot", "pmu"; - fdt = "fdt"; - }; - }; -}; diff --git a/board/theobroma-systems/puma_rk3399/fit_spl_atf.sh b/board/theobroma-systems/puma_rk3399/fit_spl_atf.sh new file mode 100755 index 0000000000..420e7daf4c --- /dev/null +++ b/board/theobroma-systems/puma_rk3399/fit_spl_atf.sh @@ -0,0 +1,94 @@ +#!/bin/sh +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com +# +# Based on the board/sunxi/mksunxi_fit_atf.sh +# +# Script to generate FIT image source for 64-bit puma boards with +# U-Boot proper, ATF, PMU firmware and devicetree. +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +[ -z "$BL31" ] && BL31="bl31.bin" + +if [ ! -f $BL31 ]; then + echo "WARNING: BL31 file $BL31 NOT found, resulting binary is non-functional" >&2 + echo "Please read Building section in doc/README.rockchip" >&2 + BL31=/dev/null +fi + +[ -z "$PMUM0" ] && PMUM0="rk3399m0.bin" + +if [ ! -f $PMUM0 ]; then + echo "WARNING: PMUM0 file $PMUM0 NOT found, resulting binary is non-functional" >&2 + echo "Please read Building section in doc/README.rockchip" >&2 + PMUM0=/dev/null +fi + +cat << __HEADER_EOF +/* SPDX-License-Identifier: GPL-2.0+ OR X11 */ +/* + * Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH + * + * Minimal dts for a SPL FIT image payload. + */ + +/dts-v1/; + +/ { + description = "FIT image with U-Boot proper, ATF bl31, M0 Firmware, DTB"; + #address-cells = <1>; + + images { + uboot { + description = "U-Boot (64-bit)"; + data = /incbin/("u-boot-nodtb.bin"); + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <0x4a000000>; + }; + atf { + description = "ARM Trusted Firmware"; + data = /incbin/("$BL31"); + type = "firmware"; + arch = "arm64"; + os = "arm-trusted-firmware"; + compression = "none"; + load = <0x1000>; + entry = <0x1000>; + }; + pmu { + description = "Cortex-M0 firmware"; + data = /incbin/("$PMUM0"); + type = "pmu-firmware"; + compression = "none"; + load = <0x180000>; + }; + fdt { + description = "RK3399-Q7 (Puma) flat device-tree"; + data = /incbin/("u-boot.dtb"); + type = "flat_dt"; + compression = "none"; + }; +__HEADER_EOF + +cat << __CONF_HEADER_EOF + }; + + configurations { + default = "conf"; + conf { + description = "Theobroma Systems RK3399-Q7 (Puma) SoM"; + firmware = "atf"; + loadables = "uboot", "pmu"; + fdt = "fdt"; + }; +__CONF_HEADER_EOF + +cat << __ITS_EOF + }; +}; +__ITS_EOF diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 03f0bfdb59..ebc78fb216 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -15,7 +15,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y -CONFIG_SPL_FIT_SOURCE="board/theobroma-systems/puma_rk3399/fit_spl_atf.its" +CONFIG_SPL_FIT_GENERATOR="board/theobroma-systems/puma_rk3399/fit_spl_atf.sh" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/doc/README.rockchip b/doc/README.rockchip index 5680c075fa..0ee54cd00e 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -137,8 +137,8 @@ For example: => cd arm-trusted-firmware => make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31
- (copy bl31.bin into U-Boot root dir) - => cp build/rk3399/release/bl31/bl31.bin /path/to/u-boot/bl31-rk3399.bin + (export bl31.bin) + => export BL31=/path/to/arm-trusted-firmware/build/rk3399/release/bl31/bl31.bin
For rest of rk3399 boards.
@@ -162,8 +162,8 @@ For example: (export cross compiler path for Cortex-M0 PMU) => make CROSS_COMPILE=arm-cortex_m0-eabi-
- (copy rk3399m0.bin into U-Boot root dir) - => cp rk3399m0.bin /path/to/u-boot + (export rk3399m0.bin) + => export PMUM0=/path/to/rk3399-cortex-m0/rk3399m0.bin
- Compile U-Boot
Thanks, - Kever
- Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH
- Minimal dts for a SPL FIT image payload.
-/dts-v1/;
- images {
uboot {
os = "U-Boot";
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x1000>;
entry = <0x1000>;
pmu {
load = <0x180000>;
fdt {
type = "flat_dt";
- configurations {
default = "conf";
conf {
firmware = "atf";
fdt = "fdt";
- echo "WARNING: BL31 file $BL31 NOT found, resulting binary is non-functional" >&2
- echo "Please read Building section in doc/README.rockchip" >&2
- BL31=/dev/null
+fi
- echo "WARNING: PMUM0 file $PMUM0 NOT found, resulting binary is non-functional" >&2
- PMUM0=/dev/null
+fi
+/dts-v1/;
- images {
uboot {
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x1000>;
entry = <0x1000>;
pmu {
load = <0x180000>;
fdt {
type = "flat_dt";
+__HEADER_EOF
- configurations {
default = "conf";
conf {
firmware = "atf";
fdt = "fdt";
+__CONF_HEADER_EOF
+cat << __ITS_EOF
(export bl31.bin)
- Compile U-Boot
Add u-boot.itb BUILD_TARGET for Rockchip platform when SPL_LOAD_FIT is being used.
This can get rid of building itb explicitly with 'make u-boot.itb' so, from now all required images will build just by make.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Kconfig | 2 +- board/theobroma-systems/puma_rk3399/README | 2 +- board/vamrs/rock960_rk3399/README | 1 - doc/README.rockchip | 2 -- 4 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/Kconfig b/Kconfig index 6b44256538..df8f2946c5 100644 --- a/Kconfig +++ b/Kconfig @@ -250,7 +250,7 @@ config BUILD_TARGET default "u-boot-with-spl.sfp" if TARGET_SOCFPGA_GEN5 default "u-boot-spl.kwb" if ARCH_MVEBU && SPL default "u-boot-elf.srec" if RCAR_GEN3 - default "u-boot.itb" if SPL_LOAD_FIT && ARCH_SUNXI + default "u-boot.itb" if SPL_LOAD_FIT && (ROCKCHIP_RK3399 || ARCH_SUNXI) default "u-boot.kwb" if KIRKWOOD default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT help diff --git a/board/theobroma-systems/puma_rk3399/README b/board/theobroma-systems/puma_rk3399/README index f67dfb451f..9b31b0b379 100644 --- a/board/theobroma-systems/puma_rk3399/README +++ b/board/theobroma-systems/puma_rk3399/README @@ -60,7 +60,7 @@ Creating a SPL image for SD-Card/eMMC Creating a SPL image for SPI-NOR
tools/mkimage -n rk3399 -T rkspi -d spl/u-boot-spl.bin spl_nor.img
Create the FIT image containing U-Boot proper, ATF, M0 Firmware, devicetree - > make CROSS_COMPILE=aarch64-linux-gnu- u-boot.itb + > make CROSS_COMPILE=aarch64-linux-gnu-
Flash the image =============== diff --git a/board/vamrs/rock960_rk3399/README b/board/vamrs/rock960_rk3399/README index d14399090e..c5c675c4ea 100644 --- a/board/vamrs/rock960_rk3399/README +++ b/board/vamrs/rock960_rk3399/README @@ -61,7 +61,6 @@ Compile the U-Boot
export CROSS_COMPILE=aarch64-linux-gnu- make rock960-rk3399_defconfig make
- > make u-boot.itb
Compile the rkdeveloptool ========================= diff --git a/doc/README.rockchip b/doc/README.rockchip index 0ee54cd00e..fac87ade2c 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -103,7 +103,6 @@ For example: => cd /path/to/u-boot => make nanopi-neo4-rk3399_defconfig => make - => make u-boot.itb
- Get the rkbin
@@ -170,7 +169,6 @@ For example: => cd /path/to/u-boot => make orangepi-rk3399_defconfig => make - => make u-boot.itb
(Get spl/u-boot-spl-dtb.bin, u-boot.itb images and some boards would get spl/u-boot-spl.bin since it doesn't enable CONFIG_SPL_OF_CONTROL
Jagan Teki
Kever Yang
