[U-Boot] [PATCH v3] mtd: move & update nand_ecclayout structure (plus board changes)
nand_ecclayout is present in mtd.h at Linux. Move this structure to mtd.h to comply with Linux.
Also, increase the ecc placement locations to 640 to suport device having writesize/oobsize of 8KB/640B. This means that the maximum oobsize has gone up to 640 bytes and consequently the maximum ecc placement locations have also gone up to 640.
Changes from Prabhabkar's version (squashed into one patch to preserve bisectability): - Added _LARGE to MTD_MAX_*_ENTRIES
This makes the names match current Linux source, and resolves a conflict between http://patchwork.ozlabs.org/patch/280488/ and http://patchwork.ozlabs.org/patch/284513/
The former was posted first and is closer to matching Linux, but unlike Linux it does not add _LARGE to the names. The second adds _LARGE to one of the names, and depends on it in a subsequent patch (http://patchwork.ozlabs.org/patch/284512/).
- Made max oobfree/eccpos configurable, and used this on tricorder, alpr, ASH405, T4160QDS, and T4240QDS (these boards failed to build for me without doing so, due to a size increase).
On tricorder SPL, this saves 2576 bytes (and makes the SPL build again) versus the new default of 640 eccpos and 32 oobfree, and saves 336 bytes versus the old default of 128 eccpos and 8 oobfree.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com CC: Vipin Kumar vipin.kumar@st.com [scottwood@freescale.com: changes as described above] Signed-off-by: Scott Wood scottwood@freescale.com Cc: Thomas Weber weber@corscience.de Cc: Matthias Fuchs matthias.fuchs@esd-electronics.com Cc: Stefan Roese sr@denx.de Cc: York Sun yorksun@freescale.com Cc: Tom Rini trini@ti.com --- v3: fix some PPC boards as well
v2: add a fix for SPL size on tricorder, and squash patches together for bisectability
doc/README.nand | 10 ++++++++++ drivers/mtd/onenand/onenand_base.c | 15 ++++++++++----- include/configs/ASH405.h | 2 ++ include/configs/MPC8572DS.h | 2 ++ include/configs/T4240QDS.h | 2 ++ include/configs/alpr.h | 2 ++ include/configs/tricorder.h | 2 ++ include/linux/mtd/mtd.h | 23 +++++++++++++++++++++++ include/mtd/mtd-abi.h | 12 ------------ 9 files changed, 53 insertions(+), 17 deletions(-)
diff --git a/doc/README.nand b/doc/README.nand index 913e9b5..3a507b6 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -104,6 +104,16 @@ Configuration Options: CONFIG_SYS_MAX_NAND_DEVICE The maximum number of NAND devices you want to support.
+ CONFIG_SYS_NAND_MAX_ECCPOS + If specified, overrides the maximum number of ECC bytes + supported. Useful for reducing image size, especially with SPL. + This must be at least 48 if nand_base.c is used. + + CONFIG_SYS_NAND_MAX_OOBFREE + If specified, overrides the maximum number of free OOB regions + supported. Useful for reducing image size, especially with SPL. + This must be at least 2 if nand_base.c is used. + CONFIG_SYS_NAND_MAX_CHIPS The maximum number of NAND chips per device to be supported.
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 067f8ef..979e4af 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -761,7 +761,8 @@ static int onenand_transfer_auto_oob(struct mtd_info *mtd, uint8_t *buf, uint8_t *oob_buf = this->oob_buf;
free = this->ecclayout->oobfree; - for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES && free->length; i++, free++) { + for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES_LARGE && free->length; + i++, free++) { if (readcol >= lastgap) readcol += free->offset - lastgap; if (readend >= lastgap) @@ -770,7 +771,8 @@ static int onenand_transfer_auto_oob(struct mtd_info *mtd, uint8_t *buf, } this->read_bufferram(mtd, 0, ONENAND_SPARERAM, oob_buf, 0, mtd->oobsize); free = this->ecclayout->oobfree; - for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES && free->length; i++, free++) { + for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES_LARGE && free->length; + i++, free++) { int free_end = free->offset + free->length; if (free->offset < readend && free_end > readcol) { int st = max_t(int,free->offset,readcol); @@ -1356,7 +1358,8 @@ static int onenand_fill_auto_oob(struct mtd_info *mtd, u_char *oob_buf, unsigned int i;
free = this->ecclayout->oobfree; - for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES && free->length; i++, free++) { + for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES_LARGE && free->length; + i++, free++) { if (writecol >= lastgap) writecol += free->offset - lastgap; if (writeend >= lastgap) @@ -1364,7 +1367,8 @@ static int onenand_fill_auto_oob(struct mtd_info *mtd, u_char *oob_buf, lastgap = free->offset + free->length; } free = this->ecclayout->oobfree; - for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES && free->length; i++, free++) { + for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES_LARGE && free->length; + i++, free++) { int free_end = free->offset + free->length; if (free->offset < writeend && free_end > writecol) { int st = max_t(int,free->offset,writecol); @@ -2750,7 +2754,8 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) * the out of band area */ this->ecclayout->oobavail = 0; - for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES && + + for (i = 0; i < MTD_MAX_OOBFREE_ENTRIES_LARGE && this->ecclayout->oobfree[i].length; i++) this->ecclayout->oobavail += this->ecclayout->oobfree[i].length; diff --git a/include/configs/ASH405.h b/include/configs/ASH405.h index 9460be3..2f53407 100644 --- a/include/configs/ASH405.h +++ b/include/configs/ASH405.h @@ -143,6 +143,8 @@
#define CONFIG_SYS_NAND_SKIP_BAD_DOT_I 1 /* ".i" read skips bad blocks */ #define CONFIG_SYS_NAND_QUIET 1 +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 +#define CONFIG_SYS_NAND_MAX_ECCPOS 56
/*----------------------------------------------------------------------- * PCI stuff diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index c751144..9ad9402 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -322,6 +322,8 @@ #define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1 #define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_MAX_OOBFREE 5 +#define CONFIG_SYS_NAND_MAX_ECCPOS 56
/* NAND boot: 4K NAND loader config */ #define CONFIG_SYS_NAND_SPL_SIZE 0x1000 diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 3777ccb..c96df54 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -229,6 +229,8 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_NAND
#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 +#define CONFIG_SYS_NAND_MAX_ECCPOS 256
#if defined(CONFIG_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT diff --git a/include/configs/alpr.h b/include/configs/alpr.h index 2bf1986..61fdeba 100644 --- a/include/configs/alpr.h +++ b/include/configs/alpr.h @@ -324,6 +324,8 @@ #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE + 0, CONFIG_SYS_NAND_BASE + 2, \ CONFIG_SYS_NAND_BASE + 4, CONFIG_SYS_NAND_BASE + 6 } #define CONFIG_SYS_NAND_QUIET_TEST 1 /* don't warn upon unknown NAND flash */ +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 +#define CONFIG_SYS_NAND_MAX_ECCPOS 56
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index d57394e..590eab7 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -140,6 +140,8 @@ /* devices */ #define CONFIG_NAND_OMAP_BCH8 #define CONFIG_BCH +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 +#define CONFIG_SYS_NAND_MAX_ECCPOS 56
/* commands to include */ #include <config_cmd_default.h> diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 6f44abd..a65b681 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -96,6 +96,29 @@ struct mtd_oob_ops { uint8_t *oobbuf; };
+#ifdef CONFIG_SYS_NAND_MAX_OOBFREE +#define MTD_MAX_OOBFREE_ENTRIES_LARGE CONFIG_SYS_NAND_MAX_OOBFREE +#else +#define MTD_MAX_OOBFREE_ENTRIES_LARGE 32 +#endif + +#ifdef CONFIG_SYS_NAND_MAX_ECCPOS +#define MTD_MAX_ECCPOS_ENTRIES_LARGE CONFIG_SYS_NAND_MAX_ECCPOS +#else +#define MTD_MAX_ECCPOS_ENTRIES_LARGE 640 +#endif + +/* + * ECC layout control structure. Exported to userspace for + * diagnosis and to allow creation of raw images + */ +struct nand_ecclayout { + uint32_t eccbytes; + uint32_t eccpos[MTD_MAX_ECCPOS_ENTRIES_LARGE]; + uint32_t oobavail; + struct nand_oobfree oobfree[MTD_MAX_OOBFREE_ENTRIES_LARGE]; +}; + struct mtd_info { u_char type; u_int32_t flags; diff --git a/include/mtd/mtd-abi.h b/include/mtd/mtd-abi.h index d51c1ab..ac3c298 100644 --- a/include/mtd/mtd-abi.h +++ b/include/mtd/mtd-abi.h @@ -155,18 +155,6 @@ struct nand_oobfree { uint32_t length; };
-#define MTD_MAX_OOBFREE_ENTRIES 8 -/* - * ECC layout control structure. Exported to userspace for - * diagnosis and to allow creation of raw images - */ -struct nand_ecclayout { - uint32_t eccbytes; - uint32_t eccpos[128]; - uint32_t oobavail; - struct nand_oobfree oobfree[MTD_MAX_OOBFREE_ENTRIES]; -}; - /** * struct mtd_ecc_stats - error correction stats *
Hi Scott,
I don't have any affected board to test this on (maintained by myself), but this change looks reasonable. So:
Thanks, Stefan
[snip]
- PCI stuff
- External Bus Controller (EBC) Setup
So, cam_enc_4xx (ARM) also fails to build with ELDK 5.2.1 (is fine with newer toolchains), so I dug into this patch to shrink things there. But looking above, are all of these right? It seems like generally we say OOBFREE=2, ECCPOS=56, except once you say OOBFREE=5 ECCPOS=56 and once OOBFREE=5 ECCPOS=256. Are these really right and just 'odd' due to the chip used?
Also, Heiko, what should these values be for cam_enc_4xx? Thanks!
2/56 is the minimum based on layouts in generic code (until such a time as we allow those to be configured out), but if a board enables a NAND driver that specifies a layout with larger arrays, the values need to be larger. If the values specified are too small, you'll get a compiler warning about too many elements in an array initializer.
It looks like 2/56 will work for that (davinci with CONFIG_SYS_NAND_PAGE_2K but not CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC). If I misread the ifdef flow, then the compiler will let you know.
CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC would require OOBFREE of at least 4, and CONFIG_SYS_NAND_PAGE_4K would require ECCPOS of at least 80.
-Scott
Scott Wood
Stefan Roese
