[PATCH][V2] Fix fastboot handling of partitions when no slots are supported
The fastboot module has a bug that prevents some command to work properly on devices that haven't an Android-like partition scheme, that is, just one spl and one kernel partition, instead of the redundant scheme with _a and _b slots.
This is the schema of our NAND storage (board is based on an AllWinner A33 sunxi chip):
=> mtdparts
device nand0 <1c03000.nand>, # parts = 4 #: name size net size offset mask_flags 0: spl 0x00020000 0x00020000 0x00000000 0 1: uboot 0x00100000 0x00100000 0x00020000 0 2: kernel_a 0x00400000 0x00400000 0x00120000 0 3: ubi 0x07ae0000 0x079e0000 (!) 0x00520000 0
active partition: nand0,0 - (spl) 0x00020000 @ 0x00000000
This happens when we try to erase the spl partition using fastboot:
$ fastboot erase spl Erasing 'spl_a' FAILED (remote: 'invalid NAND device') fastboot: error: Command failed
The error occurs because getvars fails to handle the error returned by nand layer when a partition cannot be found.
Indeed, getvar_get_part_info returns what is returned by fastboot_nand_get_part_info (0 on success, 1 on failure) but it should return -ENODEV or -EINVAL instead. Since the cause of failure is not returned by the nand function, I decided to return -EINVAL to make it simple.
Signed-off-by: Federico Fuga fuga@studiofuga.com --- drivers/fastboot/fb_getvar.c | 5 ++++- drivers/fastboot/fb_nand.c | 2 +- 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index 9c2ce65a4e..816ed8a621 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -121,8 +121,11 @@ static int getvar_get_part_info(const char *part_name, char *response, *size = disk_part.size * disk_part.blksz; } else if (IS_ENABLED(CONFIG_FASTBOOT_FLASH_NAND)) { r = fastboot_nand_get_part_info(part_name, &part_info, response); - if (r >= 0 && size) + if (r == 0 && size) { *size = part_info->size; + } else { + r = -EINVAL; + } } else { fastboot_fail("this storage is not supported in bootloader", response); r = -ENODEV; diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index afc64fd528..9e2f7c0189 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -151,7 +151,7 @@ static lbaint_t fb_nand_sparse_reserve(struct sparse_storage *info, * * @part_name: Named device to lookup * @part_info: Pointer to returned part_info pointer - * @response: Pointer to fastboot response buffer + * @response: 0 on success, 1 otherwise */ int fastboot_nand_get_part_info(const char *part_name, struct part_info **part_info, char *response)
Hi Federico,
Thank you for the patch.
This patch has incorrect recipients. This has only been send to the U-Boot.
However, when running:
$ ./scripts/get_maintainer.pl -f drivers/fastboot
Mattijs Korpershoek mkorpershoek@baylibre.com (maintainer:FASTBOOT,commit_signer:7/10=70%) Tom Rini trini@konsulko.com (maintainer:THE REST,authored:5/10=50%) Simon Glass sjg@chromium.org (commit_signer:2/10=20%,authored:2/10=20%) Caleb Connolly caleb.connolly@linaro.org (commit_signer:1/10=10%,authored:1/10=10%) Ilias Apalodimas ilias.apalodimas@linaro.org (commit_signer:1/10=10%) Quentin Schulz quentin.schulz@cherry.de (commit_signer:1/10=10%) Jerome Forissier jerome.forissier@linaro.org (authored:1/10=10%) Alexey Romanov avromanov@salutedevices.com (authored:1/10=10%) u-boot@lists.denx.de (open list)
We see that I should have been copied as well (since I'm the fastboot maintainer)
Please make sure you run ./scripts/get_maintainer when submitting changes. If patches are not addressed to the right people, they might get lost and have no answer to them. This will probably discourage further contributions, which is a shame!
Consider using tools like b4 which help automating such things for you: https://people.kernel.org/monsieuricon/sending-a-kernel-patch-with-b4-part-1 https://b4.docs.kernel.org/en/latest/contributor/overview.html
b4 is aimed at kernel developers first, but works great for U-Boot submissions as well.
Please see some more remarks below.
=> mtdparts
The patch is still not applicable for me. I see: $ b4 shazam -s -l --check 906b4d88-39c6-4e85-b9b1-62527a87d640@studiofuga.com Grabbing thread from lore.kernel.org/all/906b4d88-39c6-4e85-b9b1-62527a87d640@studiofuga.com/t.mbox.gz Checking for newer revisions Grabbing search results from lore.kernel.org Analyzing 3 messages in the thread Looking for additional code-review trailers on lore.kernel.org Analyzing 2 code-review messages Checking attestation on all messages, may take a moment... --- [PATCH v2] Fix fastboot handling of partitions when no slots are supported + Link: https://lore.kernel.org/r/906b4d88-39c6-4e85-b9b1-62527a87d640@studiofuga.co... + Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com ● checkpatch.pl: 116: WARNING: Possible unwrapped commit description (prefer a maximum 75 chars per line) ● checkpatch.pl: 150: ERROR: patch seems to be corrupt (line wrapped?) ● checkpatch.pl: 155: WARNING: suspect code indent for conditional statements (0, 0) ● checkpatch.pl: 157: WARNING: suspect code indent for conditional statements (0, 0)
If we look below:
Here, for example, I see some strange characters " "
Are you sure that this patch has been properly formatted using git-format patch?
Can you try to download it from patchwork and apply yourself? https://patchwork.ozlabs.org/project/uboot/patch/906b4d88-39c6-4e85-b9b1-625...
- @response: Pointer to fastboot response buffer
- @response: 0 on success, 1 otherwise
*/ int fastboot_nand_get_part_info(const char *part_name, struct part_info **part_info, char *response) -- 2.48.1
Federico Fuga
Mattijs Korpershoek
