[PATCH v2 0/2] Add quad & octal spi flash mini u-boot configuration files
Add new configuration files for quad and octal spi flash mini u-boot. With these configs's mini u-boot will run from on chip memory(OCM) and uses DCC terminal for console output.
Changes in v2: - Removed configs/xilinx_* from MAINTAINERS as, it is already taken care. - Run savedefconfig and updated mini config to align with latest Kconfig layout - Run savedefconfig and updated mini config for ospi to align with latest Kconfig layout
Ashok Reddy Soma (2): arm64: versal: Add qspi flash mini u-boot configuration arm64: versal: Add octal spi flash mini u-boot configuration
configs/xilinx_versal_mini_ospi_defconfig | 70 ++++++++++++++++++++++ configs/xilinx_versal_mini_qspi_defconfig | 73 +++++++++++++++++++++++ 2 files changed, 143 insertions(+) create mode 100644 configs/xilinx_versal_mini_ospi_defconfig create mode 100644 configs/xilinx_versal_mini_qspi_defconfig
Add configuration file for mini u-boot configuration which runs on a smaller footprint from on chip memory(OCM). This configuration has required CONFIG's enabled to support qspi flash and uses DCC terminal for console output.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com ---
configs/xilinx_versal_mini_qspi_defconfig | 73 +++++++++++++++++++++++ 1 file changed, 73 insertions(+) create mode 100644 configs/xilinx_versal_mini_qspi_defconfig
diff --git a/configs/xilinx_versal_mini_qspi_defconfig b/configs/xilinx_versal_mini_qspi_defconfig new file mode 100644 index 0000000000..43074e2e5e --- /dev/null +++ b/configs/xilinx_versal_mini_qspi_defconfig @@ -0,0 +1,73 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_versal_mini_qspi" +CONFIG_COUNTER_FREQUENCY=100000000 +CONFIG_ARCH_VERSAL=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SYS_MALLOC_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="versal-mini-qspi-single" +CONFIG_SYS_PROMPT="Versal> " +CONFIG_SYS_MEM_RSVD_FOR_MMU=y +CONFIG_VERSAL_NO_DDR=y +# CONFIG_PSCI_RESET is not set +CONFIG_SYS_LOAD_ADDR=0x8000000 +# CONFIG_EXPERT is not set +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +# CONFIG_AUTOBOOT is not set +CONFIG_LOGLEVEL=0 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +# CONFIG_BOARD_LATE_INIT is not set +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +# CONFIG_SYS_XTRACE is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set +# CONFIG_NET is not set +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_GPIO is not set +# CONFIG_I2C is not set +# CONFIG_INPUT is not set +# CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +# CONFIG_SPI_FLASH_SMART_HWCAPS is not set +# CONFIG_SPI_FLASH_UNLOCK_ALL is not set +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +# CONFIG_POWER is not set +CONFIG_ARM_DCC=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ZYNQMP_GQSPI=y +# CONFIG_LMB is not set
Add configuration file for mini u-boot configuration which runs on a smaller footprint from on chip memory(OCM). This configuration has required CONFIG's enabled to support octal spi flash and uses DCC terminal for console output.
Changes in v2: - Run savedefconfig and updated mini config for ospi to align with latest Kconfig layout
configs/xilinx_versal_mini_ospi_defconfig | 70 +++++++++++++++++++++++ 1 file changed, 70 insertions(+) create mode 100644 configs/xilinx_versal_mini_ospi_defconfig
diff --git a/configs/xilinx_versal_mini_ospi_defconfig b/configs/xilinx_versal_mini_ospi_defconfig new file mode 100644 index 0000000000..037d63cd04 --- /dev/null +++ b/configs/xilinx_versal_mini_ospi_defconfig @@ -0,0 +1,70 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_versal_mini_qspi" +CONFIG_COUNTER_FREQUENCY=100000000 +CONFIG_ARCH_VERSAL=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SYS_MALLOC_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x500 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x80 +# CONFIG_DM_GPIO is not set +CONFIG_DEFAULT_DEVICE_TREE="versal-mini-ospi-single" +CONFIG_SYS_PROMPT="Versal> " +CONFIG_SYS_MEM_RSVD_FOR_MMU=y +CONFIG_VERSAL_NO_DDR=y +# CONFIG_PSCI_RESET is not set +CONFIG_SYS_LOAD_ADDR=0x8000000 +# CONFIG_EXPERT is not set +# CONFIG_AUTOBOOT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +# CONFIG_BOARD_LATE_INIT is not set +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_NET is not set +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +CONFIG_SPI_FLASH_SOFT_RESET=y +CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MT35XU=y +CONFIG_ARM_DCC=y +CONFIG_SOC_XILINX_VERSAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_HAS_CQSPI_REF_CLK=y +CONFIG_CQSPI_REF_CLK=200000000 +CONFIG_CADENCE_OSPI_VERSAL=y +# CONFIG_LMB is not set
Changes in v2:
care.
Kconfig layout
you should also add dtses And this series creates compilation error
arch/arm/lib/crt0_64.S: Assembler messages: arch/arm/lib/crt0_64.S:85: Error: constant expression expected at operand 2 -- `ldr x0,=((CONFIG_SYS_INIT_RAM_ADDR+CONFIG_SYS_INIT_RAM_SIZE-400))' make[1]: *** [scripts/Makefile.build:293: arch/arm/lib/crt0_64.o] Error 1
You should define CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xfffe0000
Thanks, Michal
Ashok Reddy Soma
Michal Simek
