[PATCH 1/1] power: mfd: k3_avs: update am65xx MPU_VDD voltage values
The latest data manual SPRSP08I –NOVEMBER 2017–REVISED DECEMBER 2019[1] for am65xx SoC states the new MPU nominal voltages to be 1.1V (OPP_NOM), 1.2V (OPP_OD) and 1.24V (OPP_TURBO). Update the nominal voltages in the K3 AVS driver to reflect this.
[1] http://www.ti.com/lit/gpn/am6528
Signed-off-by: Tero Kristo t-kristo@ti.com --- drivers/misc/k3_avs.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/misc/k3_avs.c b/drivers/misc/k3_avs.c index 47e42738e0..e4857ddd97 100644 --- a/drivers/misc/k3_avs.c +++ b/drivers/misc/k3_avs.c @@ -312,15 +312,15 @@ static struct vd_data am654_vd_data[] = { .opp = AM6_OPP_NOM, .opps = { [AM6_OPP_NOM] = { - .volt = 1000000, + .volt = 1100000, .freq = 800000000, }, [AM6_OPP_OD] = { - .volt = 1100000, + .volt = 1200000, .freq = 1000000000, }, [AM6_OPP_TURBO] = { - .volt = 1220000, + .volt = 1240000, .freq = 1100000000, }, }, @@ -332,15 +332,15 @@ static struct vd_data am654_vd_data[] = { .clk_id = 0, /* ARM clock */ .opps = { [AM6_OPP_NOM] = { - .volt = 1000000, + .volt = 1100000, .freq = 800000000, }, [AM6_OPP_OD] = { - .volt = 1100000, + .volt = 1200000, .freq = 1000000000, }, [AM6_OPP_TURBO] = { - .volt = 1220000, + .volt = 1240000, .freq = 1100000000, }, },
Applied to u-boot-ti next branch.
Thanks and regards, Lokesh
Lokesh Vutla
Tero Kristo
