[PATCH] sunxi: spl: Fix H616 clock initialization
It turns out that there is a magic bit in PRCM region which seemingly makes PLLs work if it's enabled. Sadly, there is no documentation what it does exactly, so we'll just mimick BSP boot0 behaviour and enable it before any clock is set up.
Fixes: b18bd53d6cde ("sunxi: introduce support for H616 clocks") Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net --- arch/arm/mach-sunxi/clock_sun50i_h6.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index 06d84eb158d7..68c8e7f2afbe 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -9,6 +9,12 @@ void clock_init_safe(void) { struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + +#ifdef CONFIG_MACH_SUN50I_H616 + /* this seems to enable PLLs */ + setbits_le32(SUNXI_PRCM_BASE + 0x250, 0x10); +#endif + clock_set_pll1(408000000);
writel(CCM_PLL6_DEFAULT, &ccm->pll6_cfg);
On Sun, 31 Jan 2021 21:25:39 +0100 Jernej Skrabec jernej.skrabec@siol.net wrote:
Hi Jernej,
Good job of figuring this out!
Can you change this to: if (IS_ENABLED())?
- /* this seems to enable PLLs */
Out of curiosity, what makes you think it's PLL related? At least the PERIPH0 and CPU PLLs seem to work without it?
Cheers, Andre
- setbits_le32(SUNXI_PRCM_BASE + 0x250, 0x10);
Dne ponedeljek, 01. februar 2021 ob 01:46:22 CET je Andre Przywara napisal(a):
Hi Jernej,
ok.
Because I was able to configure TCON TOP -> TCON TV0 -> HDMI chain just fine, but nothing would be shown on screen, not even test patterns from TCON. HDMI itself worked ok (EDID could be read). I noticed that vblank interrupts were not genereted. This and no image is consisted with disabling bus clock to TCON and HDMI. I checked several times that clock configuration matches to that in BSP... I also moved both to another PLL without success. Also, this bit was discovered in function, which does clock initialization.
PLL cpu is always special case, otherwise nothing would work at boot. I have no real explanation for PLL periph...
Best regards, Jernej
Cheers, Andre
Andre Przywara
Jernej Skrabec
Jernej Škrabec
