[U-Boot] [GIT PULL] MIPS patches
Please pull the MIPS updates, thanks in advance.
--- 8< --- The following changes since commit 67a490d60d70f2b01d55976440ba30154af96965:
atmel_nand: don't require CONFIG_SYS_NAND_ENABLE_PIN (2011-04-01 14:49:08 -0500)
are available in the git repository at: git://git.denx.de/u-boot-mips.git master
Daniel Schwierzeck (5): MIPS: Purple: Remove Purple support MIPS: Move content of arch/mips/cpu to arch/mips/cpu/mips32 MIPS: Optimize the setup of CPU optimization flags MIPS: IncaIP: Move all IncaIP specific code to separate subdirectory MIPS: Au1x00: Move all Au1x00 specific code to separate subdirectory
MAINTAINERS | 1 - MAKEALL | 4 +- arch/mips/cpu/{ => mips32}/Makefile | 5 - .../mips/cpu/mips32/au1x00}/Makefile | 15 +- arch/mips/cpu/{ => mips32/au1x00}/au1x00_eth.c | 0 arch/mips/cpu/{ => mips32/au1x00}/au1x00_serial.c | 0 .../mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.c | 0 .../mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.h | 0 .../mips/cpu/mips32/au1x00}/config.mk | 12 +- arch/mips/cpu/{ => mips32}/cache.S | 4 - arch/mips/cpu/{ => mips32}/config.mk | 15 +- arch/mips/cpu/{ => mips32}/cpu.c | 0 .../mips/cpu/mips32/incaip}/Makefile | 16 +- arch/mips/cpu/{ => mips32/incaip}/asc_serial.c | 83 --- arch/mips/cpu/{ => mips32/incaip}/asc_serial.h | 0 .../mips/cpu/mips32/incaip}/config.mk | 12 +- arch/mips/cpu/{ => mips32/incaip}/incaip_clock.c | 0 arch/mips/cpu/{ => mips32/incaip}/incaip_wdt.S | 0 arch/mips/cpu/{ => mips32}/interrupts.c | 0 arch/mips/cpu/{ => mips32}/start.S | 32 - arch/mips/include/asm/inca-ip.h | 10 - arch/mips/lib/board.c | 10 - board/purple/flash.c | 595 -------------------- board/purple/lowlevel_init.S | 36 -- board/purple/purple.c | 284 ---------- board/purple/sconsole.c | 125 ---- board/purple/sconsole.h | 46 -- board/purple/u-boot.lds | 75 --- boards.cfg | 51 +- doc/README.Purple | 84 --- include/configs/purple.h | 173 ------ 31 files changed, 53 insertions(+), 1635 deletions(-) rename arch/mips/cpu/{ => mips32}/Makefile (87%) copy {board/purple => arch/mips/cpu/mips32/au1x00}/Makefile (83%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_eth.c (100%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_serial.c (100%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.c (100%) rename arch/mips/cpu/{ => mips32/au1x00}/au1x00_usb_ohci.h (100%) copy {board/purple => arch/mips/cpu/mips32/au1x00}/config.mk (83%) rename arch/mips/cpu/{ => mips32}/cache.S (98%) rename arch/mips/cpu/{ => mips32}/config.mk (83%) rename arch/mips/cpu/{ => mips32}/cpu.c (100%) rename {board/purple => arch/mips/cpu/mips32/incaip}/Makefile (83%) rename arch/mips/cpu/{ => mips32/incaip}/asc_serial.c (77%) rename arch/mips/cpu/{ => mips32/incaip}/asc_serial.h (100%) rename {board/purple => arch/mips/cpu/mips32/incaip}/config.mk (83%) rename arch/mips/cpu/{ => mips32/incaip}/incaip_clock.c (100%) rename arch/mips/cpu/{ => mips32/incaip}/incaip_wdt.S (100%) rename arch/mips/cpu/{ => mips32}/interrupts.c (100%) rename arch/mips/cpu/{ => mips32}/start.S (92%) delete mode 100644 board/purple/flash.c delete mode 100644 board/purple/lowlevel_init.S delete mode 100644 board/purple/purple.c delete mode 100644 board/purple/sconsole.c delete mode 100644 board/purple/sconsole.h delete mode 100644 board/purple/u-boot.lds delete mode 100644 doc/README.Purple delete mode 100644 include/configs/purple.h
Dear Shinya Kuribayashi,
Applied, thanks.
Shinya Kuribayashi
