[U-Boot] [PATCH] nds32: Fix compile error.
Fix compile error with gcc 4.9.3
Signed-off-by: rick rick@andestech.com Cc: Andes uboot@andestech.com --- arch/nds32/cpu/n1213/start.S | 2 +- arch/nds32/include/asm/macro.h | 22 +++++++++++----------- arch/nds32/include/asm/posix_types.h | 4 ++++ 3 files changed, 16 insertions(+), 12 deletions(-)
diff --git a/arch/nds32/cpu/n1213/start.S b/arch/nds32/cpu/n1213/start.S index 2f0b76c..8b7f8f4 100644 --- a/arch/nds32/cpu/n1213/start.S +++ b/arch/nds32/cpu/n1213/start.S @@ -400,7 +400,7 @@ end_flush_dcache: ! FIXME: Other way to get PC? ! FIXME: Update according to the newest spec!! 1: - la $r28, 1 + li $r28, 1 push $r28 mfsr $r28, PSW ! $PSW push $r28 diff --git a/arch/nds32/include/asm/macro.h b/arch/nds32/include/asm/macro.h index f5c8539..66be258 100644 --- a/arch/nds32/include/asm/macro.h +++ b/arch/nds32/include/asm/macro.h @@ -23,20 +23,20 @@ */
.macro write32, addr, data - li $r4, addr - li $r5, data + li $r4, \addr + li $r5, \data swi $r5, [$r4] .endm
.macro write16, addr, data - li $r4, addr - li $r5, data + li $r4, \addr + li $r5, \data shi $r5, [$r4] .endm
.macro write8, addr, data - li $r4, addr - li $r5, data + li $r4, \addr + li $r5, \data sbi $r5, [$r4] .endm
@@ -46,17 +46,17 @@ * Note: Instruction 'ori' supports immediate value up to 15 bits. */ .macro setbf32, addr, data - li $r4, addr + li $r4, \addr lwi $r5, [$r4] - li $r6, data + li $r6, \data or $r5, $r5, $r6 swi $r5, [$r4] .endm
.macro setbf15, addr, data - li $r4, addr + li $r4, \addr lwi $r5, [$r4] - ori $r5, $r5, data + ori $r5, $r5, \data swi $r5, [$r4] .endm
@@ -69,7 +69,7 @@ */
.macro wait_timer, time - li $r4, time + li $r4, \time 1: nop addi $r4, $r4, -1 diff --git a/arch/nds32/include/asm/posix_types.h b/arch/nds32/include/asm/posix_types.h index a928038..e6c591d 100644 --- a/arch/nds32/include/asm/posix_types.h +++ b/arch/nds32/include/asm/posix_types.h @@ -33,7 +33,11 @@ typedef int __kernel_pid_t; typedef unsigned short __kernel_ipc_pid_t; typedef unsigned short __kernel_uid_t; typedef unsigned short __kernel_gid_t; +#ifdef __GNUC__ +typedef __SIZE_TYPE__ __kernel_size_t; +#else typedef unsigned int __kernel_size_t; +#endif typedef int __kernel_ssize_t; typedef int __kernel_ptrdiff_t; typedef long __kernel_time_t;
Andes
