[U-Boot] [PATCH 1/1] efi_loader: check memory address before freeing
When we call FreePages() we essentially add memory to our memory map. We shouldn't do this for memory that does not exit.
Check if the memory that is to be freed via FreePages() or FreePool() is in our memory map and is not EFI_CONVENTIONAL_MEMORY.
This check is mandated by the UEFI specification.
Cf. UEFI SCT II (2017), 3.2.2 FreePages(), 5.1.2.1 - 5.1.2.2
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_memory.c | 52 +++++++++++++++++++++++++++++++++---- 1 file changed, 47 insertions(+), 5 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 776077cc35..b75722dac3 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -318,6 +318,42 @@ uint64_t efi_add_memory_map(uint64_t start, uint64_t pages, int memory_type, return start; }
+/** + * efi_check_allocated() - validate address to be freed + * + * Check that the address is within allocated memory: + * + * * The address cannot be NULL. + * * The address must be in a range of the memory map. + * * The address may not point to EFI_CONVENTIONAL_MEMORY. + * + * Page alignment is not checked as this is not a requirement of + * efi_free_pool(). + * + * @addr: address of page to be freed + * Return: status code + */ +static efi_status_t efi_check_allocated(u64 addr) +{ + struct efi_mem_list *item; + + if (!addr) + return EFI_INVALID_PARAMETER; + list_for_each_entry(item, &efi_mem, link) { + u64 start = item->desc.physical_start; + u64 end = start + (item->desc.num_pages << EFI_PAGE_SHIFT); + + if (addr >= start && addr < end) { + if (item->desc.type != EFI_CONVENTIONAL_MEMORY) + return EFI_SUCCESS; + else + return EFI_NOT_FOUND; + } + } + + return EFI_NOT_FOUND; +} + static uint64_t efi_find_free_memory(uint64_t len, uint64_t max_addr) { struct list_head *lhandle; @@ -450,6 +486,11 @@ void *efi_alloc(uint64_t len, int memory_type) efi_status_t efi_free_pages(uint64_t memory, efi_uintn_t pages) { uint64_t r = 0; + efi_status_t ret; + + ret = efi_check_allocated(memory); + if (ret != EFI_SUCCESS) + return ret;
/* Sanity check */ if (!memory || (memory & EFI_PAGE_MASK) || !pages) { @@ -511,11 +552,12 @@ efi_status_t efi_allocate_pool(int pool_type, efi_uintn_t size, void **buffer) */ efi_status_t efi_free_pool(void *buffer) { - efi_status_t r; + efi_status_t ret; struct efi_pool_allocation *alloc;
- if (buffer == NULL) - return EFI_INVALID_PARAMETER; + ret = efi_check_allocated((uintptr_t)buffer); + if (ret != EFI_SUCCESS) + return ret;
alloc = container_of(buffer, struct efi_pool_allocation, data);
@@ -528,9 +570,9 @@ efi_status_t efi_free_pool(void *buffer) /* Avoid double free */ alloc->checksum = 0;
- r = efi_free_pages((uintptr_t)alloc, alloc->num_pages); + ret = efi_free_pages((uintptr_t)alloc, alloc->num_pages);
- return r; + return ret; }
/* -- 2.20.1
