[U-Boot] [PATCH] ARM: imx6q_logic: Enable SPL Booting from NAND
This patch fixes a few values that were incorrect, and this now lets SPL boot from NAND.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 457366a664..f56f532631 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_TPL_BANNER_PRINT is not set # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set @@ -30,7 +31,8 @@ CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_PROMPT="i.MX6 Logic # " CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_WRITE_SIZE=0x20000 +CONFIG_CMD_SPL_NAND_OFS=0x1500000 +CONFIG_CMD_SPL_WRITE_SIZE=0x00100000 CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index e55941408c..70cc63fc1b 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -144,6 +144,8 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00500000 +#define CONFIG_SYS_NAND_USE_FLASH_BBT + /* MTD device */
/* DMA stuff, needed for GPMI/MXS NAND support */ @@ -162,7 +164,7 @@ /* Falcon Mode */ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" #define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_SYS_SPL_ARGS_ADDR 0x15000000 +#define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x800 /* 1MB */
This patch fixes a few values that were incorrect, and this now lets SPL boot from NAND. Signed-off-by: Adam Ford aford173@gmail.com diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 457366a664..f56f532631 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_TPL_BANNER_PRINT is not set # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set @@ -30,7 +31,8 @@ CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_PROMPT="i.MX6 Logic # " CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_WRITE_SIZE=0x20000 +CONFIG_CMD_SPL_NAND_OFS=0x1500000 +CONFIG_CMD_SPL_WRITE_SIZE=0x00100000 CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index e55941408c..70cc63fc1b 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -144,6 +144,8 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00500000 +#define CONFIG_SYS_NAND_USE_FLASH_BBT
/* MTD device */
Best regards, Stefano Babic
Adam Ford
sbabic@denx.de
