[U-Boot] [RFC PATCH] Convert ARCH_OMAP2PLUS boards' CONFIG_SYS_TEXT_BASE to Kconfig
This converts the following to Kconfig: CONFIG_SYS_TEXT_BASE
I left the header file data intact (for now), but I tested this on the omap3_logic_defconfig and am3517_evm_defconfig without any errors. I did this partially because I wanted to retain the message about the value of SYS_TEXT_BASE and how it was decided. The ti_armv7_common.h defined SYS_TEXT_BASE to 0x80800000 when it was not already defined, so that is the number I used for the default.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/Kconfig b/Kconfig index bb80ada..11fe2e6 100644 --- a/Kconfig +++ b/Kconfig @@ -325,7 +325,7 @@ config SYS_EXTRA_OPTIONS config SYS_TEXT_BASE depends on ARC || X86 || ARCH_UNIPHIER || ARCH_ZYNQMP || \ (M68K && !TARGET_ASTRO_MCF5373L) || MICROBLAZE || MIPS || \ - ARCH_ZYNQ || ARCH_KEYSTONE + ARCH_ZYNQ || ARCH_KEYSTONE || ARCH_OMAP2PLUS depends on !EFI_APP hex "Text Base" help diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 013586e..ac18d59 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -1,5 +1,8 @@ if ARCH_OMAP2PLUS
+config SYS_TEXT_BASE + default 0x80800000 + choice prompt "OMAP2+ platform select" default OMAP34XX diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index f121e2f..7f1fbab 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x08000000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_AM33XX=y CONFIG_NOR=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 2102956..f16decc 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 # CONFIG_SPL_GPIO_SUPPORT is not set CONFIG_TARGET_AM3517_CRANE=y CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index eddeb5e..863e8e7 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 # CONFIG_SPL_GPIO_SUPPORT is not set CONFIG_TARGET_AM3517_EVM=y CONFIG_SYS_EXTRA_OPTIONS="NAND" diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 5d26532..6118495 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_OMAP3_CAIRO=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=-2 diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index d37b693..1b5282a 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_CM_T3517=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=3 diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index ba76463..05190bd 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_CM_T35=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=3 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index f5e5317..c9bf519 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_DEVKIT8000=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 763e96b..fc87a5a 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index 0bcc75b..d794c57 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_ECO5PK=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=10 diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index ab3ef75..577c07e 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index c680bb1..125876e 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_OMAP44XX=y CONFIG_TARGET_KC1=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index 5a9d7cc..b9761d7 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 # CONFIG_SPL_GPIO_SUPPORT is not set CONFIG_TARGET_MCX=y CONFIG_VIDEO=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index ef7d153..bc3e3cf 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_MT_VENTOUX=y CONFIG_VIDEO=y CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index eb47bc1..3802bc5 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_NOKIA_RX51=y CONFIG_VIDEO=y CONFIG_ENV_IS_NOWHERE=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 72a4ef1..be02f43 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_OMAP3_BEAGLE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index d7bbf2d..4029391 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_OMAP3_EVM=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=3 diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index c51309c..f78b864 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_TAO3530=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BOARD_OMAP3_HA" CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index 466564b..d81b633 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_OMAP3_PANDORA=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index ac2d4bb..6e45088 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index cc40f91..ea54a7e 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 9220458..d7c54b3 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index f56274e..f365efc 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_SNIPER=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_ENV_IS_NOWHERE=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index a572db2..85e2ce8 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_TAO3530=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=3 diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index e4e99be..22d009a 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index dc3a572..80da61a 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_TRICORDER=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=0 diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 6e45252..0b368f0 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_TRICORDER=y CONFIG_SYS_EXTRA_OPTIONS="FLASHCARD" CONFIG_ENV_IS_NOWHERE=y diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 7d80a41..76039a3 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y +CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_TWISTER=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTDELAY=10
depends on !EFI_APP hex "Text Base" helpARCH_ZYNQ || ARCH_KEYSTONE || ARCH_OMAP2PLUS
default 0x80800000 if ARCH_OMAP2PLUS ?
- default 0x80800000
You can remove this if you add a default option above.
Thanks and regards, Lokesh
I was trying to be consistent with other architectures. Nobody else put their defaults here, and if everyone did, it would get cluttered quickly.
default 0x80800000
See my note above, but I think this keeps it cleaner.
adam
Yeah, it will get a little cluttered looking, but no, this is the right way to have default values.
Adam Ford
Lokesh Vutla
