[PATCH 1/1] common: static fdt_simplefb_enable_existing_node()
Function fdt_simplefb_enable_existing_node() should be static as it is not used outside common/fdt_simplefb.c.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- common/fdt_simplefb.c | 8 +++++++- include/fdt_simplefb.h | 1 - 2 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/common/fdt_simplefb.c b/common/fdt_simplefb.c index 282c34fe0b..069ced75a7 100644 --- a/common/fdt_simplefb.c +++ b/common/fdt_simplefb.c @@ -71,7 +71,13 @@ int fdt_simplefb_add_node(void *blob) return fdt_simplefb_configure_node(blob, off); }
-int fdt_simplefb_enable_existing_node(void *blob) +/** + * fdt_simplefb_enable_existing_node() - enable simple-framebuffer DT node + * + * @blob: device-tree + * Return: 0 on success, non-zero otherwise + */ +static int fdt_simplefb_enable_existing_node(void *blob) { int off;
diff --git a/include/fdt_simplefb.h b/include/fdt_simplefb.h index 41cd740ac0..af93e3be63 100644 --- a/include/fdt_simplefb.h +++ b/include/fdt_simplefb.h @@ -9,6 +9,5 @@ #ifndef _FDT_SIMPLEFB_H_ #define _FDT_SIMPLEFB_H_ int fdt_simplefb_add_node(void *blob); -int fdt_simplefb_enable_existing_node(void *blob); int fdt_simplefb_enable_and_mem_rsv(void *blob); #endif
On Tue, 4 Apr 2023 at 06:47, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Applied to u-boot-dm, thanks!
