[U-Boot-Users] [Patch]resubmit PPC440EPx: Make Sequoia boot vxWorks
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- vxWorks expects in TLB 0 a entry for the Machine Check interrupt TLB 1 a entry for the RAM TLB 2 a entry for the EBC TLB 3 a entry for the boot flash
After changing the baudrate to 9600 I had no problems to boot the vxWorks image as distributed by WindRiver (Revision 2.0/1 from June 18, 2007)
board/amcc/sequoia/init.S | 26 ++++++++++++++------------ include/configs/sequoia.h | 1 + 2 files changed, 15 insertions(+), 12 deletions(-)
diff --git a/board/amcc/sequoia/init.S b/board/amcc/sequoia/init.S index ff6ae66..306c92c 100644 --- a/board/amcc/sequoia/init.S +++ b/board/amcc/sequoia/init.S @@ -39,15 +39,8 @@ tlbtab: tlbtab_start
- /* - * BOOT_CS (FLASH) must be first. Before relocation SA_I can be off to use the - * speed up boot process. It is patched after relocation to enable SA_I - */ -#ifndef CONFIG_NAND_SPL - tlbentry( CFG_BOOT_BASE_ADDR, SZ_256M, CFG_BOOT_BASE_ADDR, 1, AC_R|AC_W|AC_X|SA_G ) -#else - tlbentry( CFG_NAND_BOOT_SPL_SRC, SZ_4K, CFG_NAND_BOOT_SPL_SRC, 1, AC_R|AC_W|AC_X|SA_G ) -#endif + /* vxWorks needs this as first entry for the Machine Check interrupt */ + tlbentry( 0x40000000, SZ_256M, 0, 0, AC_R|AC_W|AC_X|SA_G|SA_I )
/* TLB-entry for DDR SDRAM (Up to 2GB) */ #ifdef CONFIG_4xx_DCACHE @@ -56,6 +49,18 @@ tlbtab: tlbentry( CFG_SDRAM_BASE, SZ_256M, CFG_SDRAM_BASE, 0, AC_R|AC_W|AC_X|SA_G|SA_I ) #endif
+ /* TLB-entry for EBC */ + tlbentry( CFG_BCSR_BASE, SZ_256M, CFG_BCSR_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) + + /* BOOT_CS (FLASH) must be forth. Before relocation SA_I can be off to use the + * speed up boot process. It is patched after relocation to enable SA_I + */ +#ifndef CONFIG_NAND_SPL + tlbentry( CFG_BOOT_BASE_ADDR, SZ_256M, CFG_BOOT_BASE_ADDR, 1, AC_R|AC_W|AC_X|SA_G ) +#else + tlbentry( CFG_NAND_BOOT_SPL_SRC, SZ_4K, CFG_NAND_BOOT_SPL_SRC, 1, AC_R|AC_W|AC_X|SA_G ) +#endif + #ifdef CFG_INIT_RAM_DCACHE /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ tlbentry( CFG_INIT_RAM_ADDR, SZ_64K, CFG_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G ) @@ -67,9 +72,6 @@ tlbtab: tlbentry( CFG_PCI_MEMBASE2, SZ_256M, CFG_PCI_MEMBASE2, 1, AC_R|AC_W|SA_G|SA_I ) tlbentry( CFG_PCI_MEMBASE3, SZ_256M, CFG_PCI_MEMBASE3, 1, AC_R|AC_W|SA_G|SA_I )
- /* TLB-entry for EBC */ - tlbentry( CFG_BCSR_BASE, SZ_1K, CFG_BCSR_BASE, 1, AC_R|AC_W|AC_X|SA_G|SA_I ) - /* TLB-entry for NAND */ tlbentry( CFG_NAND_ADDR, SZ_1K, CFG_NAND_ADDR, 1, AC_R|AC_W|AC_X|SA_G|SA_I )
diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 8929134..056c288 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -61,6 +61,7 @@ #define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ #define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */
+#define CFG_TLB_FOR_BOOT_FLASH 0x0003 #define CFG_BOOT_BASE_ADDR 0xf0000000 #define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ #define CFG_FLASH_BASE 0xfc000000 /* start of FLASH */
Niklaus, you moved the patch description again below the "---". This way it will not be added to the commit text. I changed this manually and commited the patch now.
Please add "ppc4xx:" to the beginning of all ppc4xx related patches in the email subject. Example:
ppc4xx: Fix dflush() to restore DVLIM register
Thanks.
Best regards, Stefan
Niklaus Giger
Stefan Roese
