[U-Boot] [PATCH v2 00/10] stm32f7: add clock and pin control drivers
This patchset: - adds support for stm32f7 clock driver. - adds support for stm32f7 pin control driver. - adds device tree nodes for stm32f7 serial & clock. - adds stm32f7 pin control device tree sub nodes : - serial usart1 - ethernet - qspi flash
Changed in v2: - added removed blank lines in code. - removed not used functions. - changed fixed length array read from device node to relaxed length read.
Vikas Manocha (10): serial: stm32f7: add device tree support clk: stm32f7: add clock driver for stm32f7 family stm32f7: serial: use clock driver to enable clock ARM: DT: stm32f7: add usart1 & clock device tree nodes stm32f7: clk: remove usart1 clock enable from board init PINCTRL: stm32f7: add pin control driver ARM: DT: stm32f7: add pin control device node ARM: DT: stm32f7: add pin control node for serial port pins ARM: DT: stm32f7: add ethernet pin contol node ARM: DT: stm32f7: add qspi pin contol node
arch/arm/dts/stm32f746-disco.dts | 13 ++ arch/arm/dts/stm32f746.dtsi | 72 +++++++++++ arch/arm/mach-stm32/stm32f7/Makefile | 2 +- arch/arm/mach-stm32/stm32f7/soc.c | 2 - board/st/stm32f746-disco/stm32f746-disco.c | 111 +---------------- configs/stm32f746-disco_defconfig | 4 + doc/device-tree-bindings/clock/st,stm32-rcc.txt | 95 +++++++++++++++ .../pinctrl/st,stm32-pinctrl.txt | 133 +++++++++++++++++++++ drivers/clk/Makefile | 2 +- .../stm32f7/clock.c => drivers/clk/clk_stm32f7.c | 64 +++++++++- drivers/pinctrl/Kconfig | 9 ++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl_stm32.c | 121 +++++++++++++++++++ drivers/serial/serial_stm32x7.c | 42 +++++++ 14 files changed, 552 insertions(+), 119 deletions(-) create mode 100644 doc/device-tree-bindings/clock/st,stm32-rcc.txt create mode 100644 doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt rename arch/arm/mach-stm32/stm32f7/clock.c => drivers/clk/clk_stm32f7.c (85%) create mode 100644 drivers/pinctrl/pinctrl_stm32.c
This patch adds device tree support for stm32f7 serial driver & removes serial platform data structure.
Signed-off-by: Vikas Manocha vikas.manocha@st.com ---
Changed in v2: None
board/st/stm32f746-disco/stm32f746-disco.c | 10 ---------- drivers/serial/serial_stm32x7.c | 24 ++++++++++++++++++++++++ 2 files changed, 24 insertions(+), 10 deletions(-)
diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 7ed7bf7..72212f4 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -267,16 +267,6 @@ out: return rv; }
-static const struct stm32x7_serial_platdata serial_platdata = { - .base = (struct stm32_usart *)USART1_BASE, - .clock = CONFIG_SYS_CLK_FREQ, -}; - -U_BOOT_DEVICE(stm32x7_serials) = { - .name = "serial_stm32x7", - .platdata = &serial_platdata, -}; - #ifdef CONFIG_ETH_DESIGNWARE const struct stm32_gpio_ctl gpio_ctl_eth = { .mode = STM32_GPIO_MODE_AF, diff --git a/drivers/serial/serial_stm32x7.c b/drivers/serial/serial_stm32x7.c index 592c0bd..2e6c676 100644 --- a/drivers/serial/serial_stm32x7.c +++ b/drivers/serial/serial_stm32x7.c @@ -81,6 +81,27 @@ static int stm32_serial_probe(struct udevice *dev) return 0; }
+#if CONFIG_IS_ENABLED(OF_CONTROL) +static const struct udevice_id stm32_serial_id[] = { + {.compatible = "st,stm32-usart"}, + {.compatible = "st,stm32-uart"}, + {} +}; + +static int stm32_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct stm32x7_serial_platdata *plat = dev_get_platdata(dev); + fdt_addr_t addr; + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->base = (struct stm32_usart *)addr; + return 0; +} +#endif + static const struct dm_serial_ops stm32_serial_ops = { .putc = stm32_serial_putc, .pending = stm32_serial_pending, @@ -91,6 +112,9 @@ static const struct dm_serial_ops stm32_serial_ops = { U_BOOT_DRIVER(serial_stm32) = { .name = "serial_stm32x7", .id = UCLASS_SERIAL, + .of_match = of_match_ptr(stm32_serial_id), + .ofdata_to_platdata = of_match_ptr(stm32_serial_ofdata_to_platdata), + .platdata_auto_alloc_size = sizeof(struct stm32x7_serial_platdata), .ops = &stm32_serial_ops, .probe = stm32_serial_probe, .flags = DM_FLAG_PRE_RELOC,
add basic clock driver support for stm32f7 to enable clocks required by the peripherals.
Changed in v2: - added blank lines in code like before return and after variable declaration. - re-arranged header file inclusion as per u-boot guidelines. - remove not used function.
arch/arm/mach-stm32/stm32f7/Makefile | 2 +- arch/arm/mach-stm32/stm32f7/soc.c | 2 - configs/stm32f746-disco_defconfig | 1 + doc/device-tree-bindings/clock/st,stm32-rcc.txt | 95 ++++++++++++++++++++++ drivers/clk/Makefile | 2 +- .../stm32f7/clock.c => drivers/clk/clk_stm32f7.c | 61 +++++++++++++- 6 files changed, 157 insertions(+), 6 deletions(-) create mode 100644 doc/device-tree-bindings/clock/st,stm32-rcc.txt rename arch/arm/mach-stm32/stm32f7/clock.c => drivers/clk/clk_stm32f7.c (86%)
diff --git a/arch/arm/mach-stm32/stm32f7/Makefile b/arch/arm/mach-stm32/stm32f7/Makefile index 643d4d9..03269bd 100644 --- a/arch/arm/mach-stm32/stm32f7/Makefile +++ b/arch/arm/mach-stm32/stm32f7/Makefile @@ -5,4 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += timer.o clock.o soc.o +obj-y += timer.o soc.o diff --git a/arch/arm/mach-stm32/stm32f7/soc.c b/arch/arm/mach-stm32/stm32f7/soc.c index 8baee99..06af631 100644 --- a/arch/arm/mach-stm32/stm32f7/soc.c +++ b/arch/arm/mach-stm32/stm32f7/soc.c @@ -17,8 +17,6 @@ u32 get_cpu_rev(void)
int arch_cpu_init(void) { - configure_clocks(); - /* * Configure the memory protection unit (MPU) * 0x00000000 - 0xffffffff: Strong-order, Shareable diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 51b779a..af1449c 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -38,3 +38,4 @@ CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set +CONFIG_CLK=y diff --git a/doc/device-tree-bindings/clock/st,stm32-rcc.txt b/doc/device-tree-bindings/clock/st,stm32-rcc.txt new file mode 100644 index 0000000..0532d81 --- /dev/null +++ b/doc/device-tree-bindings/clock/st,stm32-rcc.txt @@ -0,0 +1,95 @@ +STMicroelectronics STM32 Reset and Clock Controller +=================================================== + +The RCC IP is both a reset and a clock controller. + +Please refer to clock-bindings.txt for common clock controller binding usage. +Please also refer to reset.txt for common reset controller binding usage. + +Required properties: +- compatible: Should be: + "st,stm32f42xx-rcc" + "st,stm32f469-rcc" +- reg: should be register base and length as documented in the + datasheet +- #reset-cells: 1, see below +- #clock-cells: 2, device nodes should specify the clock in their "clocks" + property, containing a phandle to the clock device node, an index selecting + between gated clocks and other clocks and an index specifying the clock to + use. + +Example: + + rcc: rcc@40023800 { + #reset-cells = <1>; + #clock-cells = <2> + compatible = "st,stm32f42xx-rcc", "st,stm32-rcc"; + reg = <0x40023800 0x400>; + }; + +Specifying gated clocks +======================= + +The primary index must be set to 0. + +The secondary index is the bit number within the RCC register bank, starting +from the first RCC clock enable register (RCC_AHB1ENR, address offset 0x30). + +It is calculated as: index = register_offset / 4 * 32 + bit_offset. +Where bit_offset is the bit offset within the register (LSB is 0, MSB is 31). + +To simplify the usage and to share bit definition with the reset and clock +drivers of the RCC IP, macros are available to generate the index in +human-readble format. + +For STM32F4 series, the macro are available here: + - include/dt-bindings/mfd/stm32f4-rcc.h + +Example: + + /* Gated clock, AHB1 bit 0 (GPIOA) */ + ... { + clocks = <&rcc 0 STM32F4_AHB1_CLOCK(GPIOA)> + }; + + /* Gated clock, AHB2 bit 4 (CRYP) */ + ... { + clocks = <&rcc 0 STM32F4_AHB2_CLOCK(CRYP)> + }; + +Specifying other clocks +======================= + +The primary index must be set to 1. + +The secondary index is bound with the following magic numbers: + + 0 SYSTICK + 1 FCLK + +Example: + + /* Misc clock, FCLK */ + ... { + clocks = <&rcc 1 STM32F4_APB1_CLOCK(TIM2)> + }; + + +Specifying softreset control of devices +======================================= + +Device nodes should specify the reset channel required in their "resets" +property, containing a phandle to the reset device node and an index specifying +which channel to use. +The index is the bit number within the RCC registers bank, starting from RCC +base address. +It is calculated as: index = register_offset / 4 * 32 + bit_offset. +Where bit_offset is the bit offset within the register. +For example, for CRC reset: + crc = AHB1RSTR_offset / 4 * 32 + CRCRST_bit_offset = 0x10 / 4 * 32 + 12 = 140 + +example: + + timer2 { + resets = <&rcc STM32F4_APB1_RESET(TIM2)>; + }; diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 884c21c..1ed29c7 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -17,5 +17,5 @@ obj-$(CONFIG_CLK_UNIPHIER) += uniphier/ obj-$(CONFIG_CLK_EXYNOS) += exynos/ obj-$(CONFIG_CLK_AT91) += at91/ obj-$(CONFIG_CLK_BOSTON) += clk_boston.o - obj-$(CONFIG_ARCH_ASPEED) += aspeed/ +obj-$(CONFIG_STM32F7) += clk_stm32f7.o diff --git a/arch/arm/mach-stm32/stm32f7/clock.c b/drivers/clk/clk_stm32f7.c similarity index 86% rename from arch/arm/mach-stm32/stm32f7/clock.c rename to drivers/clk/clk_stm32f7.c index e1ee173..4c5388a 100644 --- a/arch/arm/mach-stm32/stm32f7/clock.c +++ b/drivers/clk/clk_stm32f7.c @@ -1,11 +1,12 @@ /* - * (C) Copyright 2016 + * (C) Copyright 2017 * Vikas Manocha, vikas.manocha@st.com * * SPDX-License-Identifier: GPL-2.0+ */ - #include <common.h> +#include <clk-uclass.h> +#include <dm.h> #include <asm/io.h> #include <asm/arch/rcc.h> #include <asm/arch/stm32.h> @@ -212,6 +213,17 @@ unsigned long clock_get(enum clock clck) } }
+static int stm32_clk_enable(struct clk *clk) +{ + u32 offset = clk->id / 32; + u32 bit_index = clk->id % 32; + + debug("%s: clkid = %ld, offset from AHB1ENR is %d, bit_index = %d\n", + __func__, clk->id, offset, bit_index); + setbits_le32(&STM32_RCC->ahb1enr + offset, BIT(bit_index)); + + return 0; +}
void clock_setup(int peripheral) { @@ -273,3 +285,48 @@ void clock_setup(int peripheral) break; } } + +static int stm32_clk_probe(struct udevice *dev) +{ + debug("%s: stm32_clk_probe\n", __func__); + configure_clocks(); + + return 0; +} + +static int stm32_clk_of_xlate(struct clk *clk, + struct fdtdec_phandle_args *args) +{ + debug("%s(clk=%p)\n", __func__, clk); + + if (args->args_count != 2) { + debug("Invaild args_count: %d\n", args->args_count); + return -EINVAL; + } + + if (args->args_count) + clk->id = args->args[1]; + else + clk->id = 0; + + return 0; +} + +static struct clk_ops stm32_clk_ops = { + .of_xlate = stm32_clk_of_xlate, + .enable = stm32_clk_enable, +}; + +static const struct udevice_id stm32_clk_ids[] = { + { .compatible = "st,stm32f42xx-rcc"}, + {} +}; + +U_BOOT_DRIVER(stm32f7_clk) = { + .name = "stm32f7_clk", + .id = UCLASS_CLK, + .of_match = stm32_clk_ids, + .ops = &stm32_clk_ops, + .probe = stm32_clk_probe, + .flags = DM_FLAG_PRE_RELOC, +};
Adding this back:
Hi Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Saturday, February 11, 2017 12:20 PM To: Vikas MANOCHA vikas.manocha@st.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Albert Aribaud albert.u.boot@aribaud.net; Heiko Stübner heiko@sntech.de; Joe Hershberger joe.hershberger@ni.com; Kever Yang kever.yang@rock-chips.com; Masahiro Yamada yamada.masahiro@socionext.com; maxims@google.com; Michael Kurz michi.kurz@gmail.com; Paul Burton paul.burton@imgtec.com; Stephen Warren swarren@nvidia.com; Thomas Abraham thomas.ab@samsung.com; Tom Warren twarren@nvidia.com; Toshifumi NISHINAGA tnishinaga.dev@gmail.com Subject: Re: [PATCH v2 02/10] clk: stm32f7: add clock driver for stm32f7 family
Adding this back:
Missed it adding in v2, I will add it in v3 for this patch & others also.
Cheers, Vikas
drivers/serial/serial_stm32x7.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/drivers/serial/serial_stm32x7.c b/drivers/serial/serial_stm32x7.c index 2e6c676..1907cef 100644 --- a/drivers/serial/serial_stm32x7.c +++ b/drivers/serial/serial_stm32x7.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <asm/io.h> #include <serial.h> @@ -76,6 +77,22 @@ static int stm32_serial_probe(struct udevice *dev) { struct stm32x7_serial_platdata *plat = dev->platdata; struct stm32_usart *const usart = plat->base; + +#ifdef CONFIG_CLK + int ret; + struct clk clk; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) + return ret; + + ret = clk_enable(&clk); + if (ret) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } +#endif + setbits_le32(&usart->cr1, USART_CR1_RE | USART_CR1_TE | USART_CR1_UE);
return 0; @@ -98,6 +115,7 @@ static int stm32_serial_ofdata_to_platdata(struct udevice *dev) return -EINVAL;
plat->base = (struct stm32_usart *)addr; + return 0; } #endif
Adding this back:
Also created alias for usart1 and specified oscillator clock for stm32f7 discovery board.
Changed in v2: None
arch/arm/dts/stm32f746-disco.dts | 5 +++++ arch/arm/dts/stm32f746.dtsi | 27 +++++++++++++++++++++++++++ 2 files changed, 32 insertions(+)
diff --git a/arch/arm/dts/stm32f746-disco.dts b/arch/arm/dts/stm32f746-disco.dts index bad0698..454b515 100644 --- a/arch/arm/dts/stm32f746-disco.dts +++ b/arch/arm/dts/stm32f746-disco.dts @@ -61,10 +61,15 @@ };
aliases { + serial0 = &usart1; spi0 = &qspi; }; };
+&clk_hse { + clock-frequency = <25000000>; +}; + &mac { status = "okay"; phy-mode = "rmii"; diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index 3902e76..afcd327 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -48,7 +48,16 @@ #include <dt-bindings/pinctrl/stm32f746-pinfunc.h>
/ { + clocks { + clk_hse: clk-hse { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; +}; + soc { + u-boot,dm-pre-reloc; mac: ethernet@40028000 { compatible = "st,stm32-dwmac"; reg = <0x40028000 0x8000>; @@ -71,6 +80,24 @@ spi-max-frequency = <108000000>; status = "disabled"; }; + usart1: serial@40011000 { + compatible = "st,stm32-usart", "st,stm32-uart"; + reg = <0x40011000 0x400>; + interrupts = <37>; + clocks = <&rcc 0 164>; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + rcc: rcc@40023810 { + #reset-cells = <1>; + #clock-cells = <2>; + compatible = "st,stm32f42xx-rcc", "st,stm32-rcc"; + reg = <0x40023800 0x400>; + clocks = <&clk_hse>; + u-boot,dm-pre-reloc; + }; + + }; };
Before clock driver availability it was required to enable usart1 clock for serial init but now with clock driver is taking care of usart1 clock.
Changed in v2: None
board/st/stm32f746-disco/stm32f746-disco.c | 1 - drivers/clk/clk_stm32f7.c | 3 --- 2 files changed, 4 deletions(-)
diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 72212f4..ee1deb5 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -380,7 +380,6 @@ int board_early_init_f(void) int res;
res = uart_setup_gpio(); - clock_setup(USART1_CLOCK_CFG); if (res) return res;
diff --git a/drivers/clk/clk_stm32f7.c b/drivers/clk/clk_stm32f7.c index 4c5388a..0d86395 100644 --- a/drivers/clk/clk_stm32f7.c +++ b/drivers/clk/clk_stm32f7.c @@ -228,9 +228,6 @@ static int stm32_clk_enable(struct clk *clk) void clock_setup(int peripheral) { switch (peripheral) { - case USART1_CLOCK_CFG: - setbits_le32(&STM32_RCC->apb2enr, RCC_APB2ENR_USART1EN); - break; case GPIO_A_CLOCK_CFG: setbits_le32(&STM32_RCC->ahb1enr, RCC_AHB1ENR_GPIO_A_EN); break;
This driver uses the same pin control binding as that of linux, binding document of this patch is copied from linux. One addition done is for GPIO input and output mode configuration which was missing.
Changed in v2: - added blank lines in code like before return and after variable declaration. - remove not used function. - changed fixed length array read from DT node to relaxed length read.
configs/stm32f746-disco_defconfig | 3 + .../pinctrl/st,stm32-pinctrl.txt | 133 +++++++++++++++++++++ drivers/pinctrl/Kconfig | 9 ++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl_stm32.c | 121 +++++++++++++++++++ 5 files changed, 267 insertions(+) create mode 100644 doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt create mode 100644 drivers/pinctrl/pinctrl_stm32.c
diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index af1449c..e77ebfc 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -39,3 +39,6 @@ CONFIG_STM32_QSPI=y CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_EFI_LOADER is not set CONFIG_CLK=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_PINCTRL_STM32=y diff --git a/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt b/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt new file mode 100644 index 0000000..c41ae91 --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt @@ -0,0 +1,133 @@ +* STM32 GPIO and Pin Mux/Config controller + +STMicroelectronics's STM32 MCUs intregrate a GPIO and Pin mux/config hardware +controller. It controls the input/output settings on the available pins and +also provides ability to multiplex and configure the output of various on-chip +controllers onto these pads. + +Pin controller node: +Required properies: + - compatible: value should be one of the following: + (a) "st,stm32f429-pinctrl" + (b) "st,stm32f746-pinctrl" + - #address-cells: The value of this property must be 1 + - #size-cells : The value of this property must be 1 + - ranges : defines mapping between pin controller node (parent) to + gpio-bank node (children). + - pins-are-numbered: Specify the subnodes are using numbered pinmux to + specify pins. + +GPIO controller/bank node: +Required properties: + - gpio-controller : Indicates this device is a GPIO controller + - #gpio-cells : Should be two. + The first cell is the pin number + The second one is the polarity: + - 0 for active high + - 1 for active low + - reg : The gpio address range, relative to the pinctrl range + - clocks : clock that drives this bank + - st,bank-name : Should be a name string for this bank as specified in + the datasheet + +Optional properties: + - reset: : Reference to the reset controller + - interrupt-parent: phandle of the interrupt parent to which the external + GPIO interrupts are forwarded to. + - st,syscfg: Should be phandle/offset pair. The phandle to the syscon node + which includes IRQ mux selection register, and the offset of the IRQ mux + selection register. + +Example: +#include <dt-bindings/pinctrl/stm32f429-pinfunc.h> +... + + pin-controller { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,stm32f429-pinctrl"; + ranges = <0 0x40020000 0x3000>; + pins-are-numbered; + + gpioa: gpio@40020000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x0 0x400>; + resets = <&reset_ahb1 0>; + st,bank-name = "GPIOA"; + }; + ... + pin-functions nodes follow... + }; + +Contents of function subnode node: +---------------------------------- +Subnode format +A pinctrl node should contain at least one subnode representing the +pinctrl group available on the machine. Each subnode will list the +pins it needs, and how they should be configured, with regard to muxer +configuration, pullups, drive, output high/low and output speed. + + node { + pinmux = <PIN_NUMBER_PINMUX>; + GENERIC_PINCONFIG; + }; + +Required properties: +- pinmux: integer array, represents gpio pin number and mux setting. + Supported pin number and mux varies for different SoCs, and are defined in + dt-bindings/pinctrl/<soc>-pinfunc.h directly. + These defines are calculated as: + ((port * 16 + line) << 8) | function + With: + - port: The gpio port index (PA = 0, PB = 1, ..., PK = 11) + - line: The line offset within the port (PA0 = 0, PA1 = 1, ..., PA15 = 15) + - function: The function number, can be: + * 0 : GPIO IN + * 1 : Alternate Function 0 + * 2 : Alternate Function 1 + * 3 : Alternate Function 2 + * ... + * 16 : Alternate Function 15 + * 17 : Analog + * 18 : GPIO OUT + +Optional properties: +- GENERIC_PINCONFIG: is the generic pinconfig options to use. + Available options are: + - bias-disable, + - bias-pull-down, + - bias-pull-up, + - drive-push-pull, + - drive-open-drain, + - output-low + - output-high + - slew-rate = <x>, with x being: + < 0 > : Low speed + < 1 > : Medium speed + < 2 > : Fast speed + < 3 > : High speed + +Example: + +pin-controller { +... + usart1_pins_a: usart1@0 { + pins1 { + pinmux = <STM32F429_PA9_FUNC_USART1_TX>; + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32F429_PA10_FUNC_USART1_RX>; + bias-disable; + }; + }; +}; + +&usart1 { + pinctrl-0 = <&usart1_pins_a>; + pinctrl-names = "default"; + status = "okay"; +}; diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index efcb4c0..2dc420c 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -175,6 +175,15 @@ config PIC32_PINCTRL by a device tree node which contains both GPIO defintion and pin control functions.
+config PINCTRL_STM32 + bool "ST STM32 pin control driver" + depends on DM + help + Supports pin multiplexing control on stm32 SoCs. The driver is + controlled by a device tree node which contains both the GPIO + definitions and pin control functions for each available multiplex + function. + endif
source "drivers/pinctrl/meson/Kconfig" diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 512112a..2e23b05 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -16,3 +16,4 @@ obj-$(CONFIG_PIC32_PINCTRL) += pinctrl_pic32.o obj-$(CONFIG_PINCTRL_EXYNOS) += exynos/ obj-$(CONFIG_PINCTRL_MESON) += meson/ obj-$(CONFIG_PINCTRL_MVEBU) += mvebu/ +obj-$(CONFIG_PINCTRL_STM32) += pinctrl_stm32.o diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c new file mode 100644 index 0000000..df38adf --- /dev/null +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -0,0 +1,121 @@ +#include <common.h> +#include <asm/arch/gpio.h> +#include <dm.h> +#include <dm/pinctrl.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int prep_gpio_dsc(struct stm32_gpio_dsc *gpio_dsc, u32 port_pin) +{ + gpio_dsc->port = (port_pin & 0xF000) >> 12; + gpio_dsc->pin = (port_pin & 0x0F00) >> 8; + debug("%s: GPIO:port= %d, pin= %d\n", __func__, gpio_dsc->port, + gpio_dsc->pin); + + return 0; +} + +static int prep_gpio_ctl(struct stm32_gpio_ctl *gpio_ctl, u32 gpio_fn, int node) +{ + gpio_fn &= 0x00FF; + + switch (gpio_fn) { + case 0: + gpio_ctl->mode = STM32_GPIO_MODE_IN; + break; + case 1 ... 16: + gpio_ctl->mode = STM32_GPIO_MODE_AF; + gpio_ctl->af = gpio_fn - 1; + break; + case 17: + gpio_ctl->mode = STM32_GPIO_MODE_AN; + break; + default: + gpio_ctl->mode = STM32_GPIO_MODE_OUT; + break; + } + + gpio_ctl->speed = fdtdec_get_int(gd->fdt_blob, node, "slew-rate", 0); + + if (fdtdec_get_bool(gd->fdt_blob, node, "drive-open-drain")) + gpio_ctl->otype = STM32_GPIO_OTYPE_OD; + else + gpio_ctl->otype = STM32_GPIO_OTYPE_PP; + + if (fdtdec_get_bool(gd->fdt_blob, node, "bias-pull-up")) + gpio_ctl->pupd = STM32_GPIO_PUPD_UP; + else if (fdtdec_get_bool(gd->fdt_blob, node, "bias-pull-down")) + gpio_ctl->pupd = STM32_GPIO_PUPD_DOWN; + else + gpio_ctl->pupd = STM32_GPIO_PUPD_NO; + + debug("%s: gpio fn= %d, slew-rate= %x, op type= %x, pull-upd is = %x\n", + __func__, gpio_fn, gpio_ctl->speed, gpio_ctl->otype, + gpio_ctl->pupd); + + return 0; +} + +static int stm32_pinctrl_set_state_simple(struct udevice *dev, + struct udevice *periph) +{ + u32 pin_mux[50]; + struct fdtdec_phandle_args args; + int rv, len; + + /* Get node pinctrl-0 */ + rv = fdtdec_parse_phandle_with_args(gd->fdt_blob, periph->of_offset, + "pinctrl-0", 0, 0, 0, &args); + if (rv) + return rv; + /* + * check for "pinmux" property in each subnode (e.g. pins1 and pins2 for + * usart1) of pin controller phandle "pinctrl-0" + * */ + fdt_for_each_subnode(args.node, gd->fdt_blob, args.node) { + struct stm32_gpio_dsc gpio_dsc; + struct stm32_gpio_ctl gpio_ctl; + int i; + + /* + * just to get the length of "pinmux" to allocate correct size + * or memory + * */ + fdt_get_property(gd->fdt_blob, args.node, "pinmux", &len); + len /= 4; + debug("%s: no of pinmux entries= %d\n", __func__, len); + len = fdtdec_get_int_array_count(gd->fdt_blob, args.node, + "pinmux", pin_mux, len); + if (len < 0) + return -EINVAL; + for (i = 0; i < len; i++) { + debug("%s: pinmux = %x\n", __func__, *(pin_mux + i)); + prep_gpio_dsc(&gpio_dsc, *(pin_mux + i)); + prep_gpio_ctl(&gpio_ctl, *(pin_mux + i), args.node); + + rv = stm32_gpio_config(&gpio_dsc, &gpio_ctl); + debug("%s: rv = %d\n\n", __func__, rv); + if (rv) + return rv; + } + } + + return 0; +} + +static struct pinctrl_ops stm32_pinctrl_ops = { + .set_state_simple = stm32_pinctrl_set_state_simple, +}; + +static const struct udevice_id stm32_pinctrl_ids[] = { + { .compatible = "st,stm32f746-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(pinctrl_stm32) = { + .name = "pinctrl_stm32", + .id = UCLASS_PINCTRL, + .of_match = stm32_pinctrl_ids, + .ops = &stm32_pinctrl_ops, + .bind = dm_scan_fdt_dev, +};
(if you add that to the patch I don't need to remember whether I reviewed it or not)
read.
u32 pin_mux[50];
int rv, len;
periph->of_offset,
if (rv)
return rv;
pins2 for
int i;
size
* or memory
len /= 4;
Just to be clear, instead of those 5 lines, you should be able to do:
len = fdtdec_get_int_array_count(gd->fdt_blob, args.node, "pinmux", pin_mux, ARRAY_SIZE(pin_mux));
if (len < 0)
return -EINVAL;
Changed in v2: None
arch/arm/dts/stm32f746.dtsi | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index afcd327..f59eca8 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -97,7 +97,14 @@ u-boot,dm-pre-reloc; };
- + pinctrl: pin-controller { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,stm32f746-pinctrl"; + ranges = <0 0x40020000 0x3000>; + u-boot,dm-pre-reloc; + pins-are-numbered; + }; }; };
And remove the uart pin configuration from board initialization.
Changed in v2: None
arch/arm/dts/stm32f746-disco.dts | 6 ++++++ arch/arm/dts/stm32f746.dtsi | 13 +++++++++++++ board/st/stm32f746-disco/stm32f746-disco.c | 25 +------------------------ 3 files changed, 20 insertions(+), 24 deletions(-)
diff --git a/arch/arm/dts/stm32f746-disco.dts b/arch/arm/dts/stm32f746-disco.dts index 454b515..6734f23 100644 --- a/arch/arm/dts/stm32f746-disco.dts +++ b/arch/arm/dts/stm32f746-disco.dts @@ -70,6 +70,12 @@ clock-frequency = <25000000>; };
+&usart1 { + pinctrl-0 = <&usart1_pins_a>; + pinctrl-names = "default"; + status = "okay"; +}; + &mac { status = "okay"; phy-mode = "rmii"; diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index f59eca8..867f399 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -104,6 +104,19 @@ ranges = <0 0x40020000 0x3000>; u-boot,dm-pre-reloc; pins-are-numbered; + + usart1_pins_a: usart1@0 { + pins1 { + pinmux = <STM32F746_PA9_FUNC_USART1_TX>; + bias-disable; + drive-push-pull; + slew-rate = <2>; + }; + pins2 { + pinmux = <STM32F746_PB7_FUNC_USART1_RX>; + bias-disable; + }; + }; }; }; }; diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index ee1deb5..9ebc36b 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -27,14 +27,6 @@ const struct stm32_gpio_ctl gpio_ctl_gpout = { .af = STM32_GPIO_AF0 };
-const struct stm32_gpio_ctl gpio_ctl_usart = { - .mode = STM32_GPIO_MODE_AF, - .otype = STM32_GPIO_OTYPE_PP, - .speed = STM32_GPIO_SPEED_50M, - .pupd = STM32_GPIO_PUPD_UP, - .af = STM32_GPIO_AF7 -}; - const struct stm32_gpio_ctl gpio_ctl_fmc = { .mode = STM32_GPIO_MODE_AF, .otype = STM32_GPIO_OTYPE_PP, @@ -245,26 +237,11 @@ int dram_init(void) return rv; }
-static const struct stm32_gpio_dsc usart_gpio[] = { - {STM32_GPIO_PORT_A, STM32_GPIO_PIN_9}, /* TX */ - {STM32_GPIO_PORT_B, STM32_GPIO_PIN_7}, /* RX */ -}; - int uart_setup_gpio(void) { - int i; - int rv = 0; - clock_setup(GPIO_A_CLOCK_CFG); clock_setup(GPIO_B_CLOCK_CFG); - for (i = 0; i < ARRAY_SIZE(usart_gpio); i++) { - rv = stm32_gpio_config(&usart_gpio[i], &gpio_ctl_usart); - if (rv) - goto out; - } - -out: - return rv; + return 0; }
It also removes the ethernet pin configuration done during the board initialization.
Changed in v2: None
arch/arm/dts/stm32f746-disco.dts | 1 + arch/arm/dts/stm32f746.dtsi | 14 +++++++++++++ board/st/stm32f746-disco/stm32f746-disco.c | 32 ------------------------------ 3 files changed, 15 insertions(+), 32 deletions(-)
diff --git a/arch/arm/dts/stm32f746-disco.dts b/arch/arm/dts/stm32f746-disco.dts index 6734f23..3d6002f 100644 --- a/arch/arm/dts/stm32f746-disco.dts +++ b/arch/arm/dts/stm32f746-disco.dts @@ -78,6 +78,7 @@
&mac { status = "okay"; + pinctrl-0 = <ðernet_mii>; phy-mode = "rmii"; phy-handle = <&phy0>;
diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index 867f399..431e79c 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -117,6 +117,20 @@ bias-disable; }; }; + ethernet_mii: mii@0 { + pins { + pinmux = <STM32F746_PG13_FUNC_ETH_MII_TXD0_ETH_RMII_TXD0>, + <STM32F746_PG14_FUNC_ETH_MII_TXD1_ETH_RMII_TXD1>, + <STM32F746_PG11_FUNC_ETH_MII_TX_EN_ETH_RMII_TX_EN>, + <STM32F746_PA2_FUNC_ETH_MDIO>, + <STM32F746_PC1_FUNC_ETH_MDC>, + <STM32F746_PA1_FUNC_ETH_MII_RX_CLK_ETH_RMII_REF_CLK>, + <STM32F746_PA7_FUNC_ETH_MII_RX_DV_ETH_RMII_CRS_DV>, + <STM32F746_PC4_FUNC_ETH_MII_RXD0_ETH_RMII_RXD0>, + <STM32F746_PC5_FUNC_ETH_MII_RXD1_ETH_RMII_RXD1>; + slew-rate = <2>; + }; + }; }; }; }; diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 9ebc36b..8343f82 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -245,48 +245,16 @@ int uart_setup_gpio(void) }
#ifdef CONFIG_ETH_DESIGNWARE -const struct stm32_gpio_ctl gpio_ctl_eth = { - .mode = STM32_GPIO_MODE_AF, - .otype = STM32_GPIO_OTYPE_PP, - .speed = STM32_GPIO_SPEED_100M, - .pupd = STM32_GPIO_PUPD_NO, - .af = STM32_GPIO_AF11 -}; - -static const struct stm32_gpio_dsc eth_gpio[] = { - {STM32_GPIO_PORT_A, STM32_GPIO_PIN_1}, /* ETH_RMII_REF_CLK */ - {STM32_GPIO_PORT_A, STM32_GPIO_PIN_2}, /* ETH_MDIO */ - {STM32_GPIO_PORT_A, STM32_GPIO_PIN_7}, /* ETH_RMII_CRS_DV */ - - {STM32_GPIO_PORT_C, STM32_GPIO_PIN_1}, /* ETH_MDC */ - {STM32_GPIO_PORT_C, STM32_GPIO_PIN_4}, /* ETH_RMII_RXD0 */ - {STM32_GPIO_PORT_C, STM32_GPIO_PIN_5}, /* ETH_RMII_RXD1 */ - - {STM32_GPIO_PORT_G, STM32_GPIO_PIN_11}, /* ETH_RMII_TX_EN */ - {STM32_GPIO_PORT_G, STM32_GPIO_PIN_13}, /* ETH_RMII_TXD0 */ - {STM32_GPIO_PORT_G, STM32_GPIO_PIN_14}, /* ETH_RMII_TXD1 */ -};
static int stmmac_setup(void) { - int res = 0; - int i; - clock_setup(SYSCFG_CLOCK_CFG); - /* Set >RMII mode */ STM32_SYSCFG->pmc |= SYSCFG_PMC_MII_RMII_SEL;
clock_setup(GPIO_A_CLOCK_CFG); clock_setup(GPIO_C_CLOCK_CFG); clock_setup(GPIO_G_CLOCK_CFG); - - for (i = 0; i < ARRAY_SIZE(eth_gpio); i++) { - res = stm32_gpio_config(ð_gpio[i], &gpio_ctl_eth); - if (res) - return res; - } - clock_setup(STMMAC_CLOCK_CFG);
It also removes the qspi pin configuration done during the board initialization.
Changed in v2: None
arch/arm/dts/stm32f746-disco.dts | 1 + arch/arm/dts/stm32f746.dtsi | 11 ++++++++ board/st/stm32f746-disco/stm32f746-disco.c | 43 ------------------------------ 3 files changed, 12 insertions(+), 43 deletions(-)
diff --git a/arch/arm/dts/stm32f746-disco.dts b/arch/arm/dts/stm32f746-disco.dts index 3d6002f..07e0ca7 100644 --- a/arch/arm/dts/stm32f746-disco.dts +++ b/arch/arm/dts/stm32f746-disco.dts @@ -93,6 +93,7 @@ };
&qspi { + pinctrl-0 = <&qspi_pins>; status = "okay";
qflash0: n25q128a { diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index 431e79c..b2b0b5f 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -131,6 +131,17 @@ slew-rate = <2>; }; }; + qspi_pins: qspi@0{ + pins { + pinmux = <STM32F746_PB2_FUNC_QUADSPI_CLK>, + <STM32F746_PB6_FUNC_QUADSPI_BK1_NCS>, + <STM32F746_PD11_FUNC_QUADSPI_BK1_IO0>, + <STM32F746_PD12_FUNC_QUADSPI_BK1_IO1>, + <STM32F746_PD13_FUNC_QUADSPI_BK1_IO3>, + <STM32F746_PE2_FUNC_QUADSPI_BK1_IO2>; + slew-rate = <2>; + }; + }; }; }; }; diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 8343f82..fdad8d1 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -262,55 +262,12 @@ static int stmmac_setup(void) #endif
#ifdef CONFIG_STM32_QSPI -const struct stm32_gpio_ctl gpio_ctl_qspi_9 = { - .mode = STM32_GPIO_MODE_AF, - .otype = STM32_GPIO_OTYPE_PP, - .speed = STM32_GPIO_SPEED_100M, - .pupd = STM32_GPIO_PUPD_NO, - .af = STM32_GPIO_AF9 -}; - -const struct stm32_gpio_ctl gpio_ctl_qspi_10 = { - .mode = STM32_GPIO_MODE_AF, - .otype = STM32_GPIO_OTYPE_PP, - .speed = STM32_GPIO_SPEED_100M, - .pupd = STM32_GPIO_PUPD_NO, - .af = STM32_GPIO_AF10 -}; - -static const struct stm32_gpio_dsc qspi_af9_gpio[] = { - {STM32_GPIO_PORT_B, STM32_GPIO_PIN_2}, /* QUADSPI_CLK */ - {STM32_GPIO_PORT_D, STM32_GPIO_PIN_11}, /* QUADSPI_BK1_IO0 */ - {STM32_GPIO_PORT_D, STM32_GPIO_PIN_12}, /* QUADSPI_BK1_IO1 */ - {STM32_GPIO_PORT_D, STM32_GPIO_PIN_13}, /* QUADSPI_BK1_IO3 */ - {STM32_GPIO_PORT_E, STM32_GPIO_PIN_2}, /* QUADSPI_BK1_IO2 */ -}; - -static const struct stm32_gpio_dsc qspi_af10_gpio[] = { - {STM32_GPIO_PORT_B, STM32_GPIO_PIN_6}, /* QUADSPI_BK1_NCS */ -};
static int qspi_setup(void) { - int res = 0; - int i; - clock_setup(GPIO_B_CLOCK_CFG); clock_setup(GPIO_D_CLOCK_CFG); clock_setup(GPIO_E_CLOCK_CFG); - - for (i = 0; i < ARRAY_SIZE(qspi_af9_gpio); i++) { - res = stm32_gpio_config(&qspi_af9_gpio[i], &gpio_ctl_qspi_9); - if (res) - return res; - } - - for (i = 0; i < ARRAY_SIZE(qspi_af10_gpio); i++) { - res = stm32_gpio_config(&qspi_af10_gpio[i], &gpio_ctl_qspi_10); - if (res) - return res; - } - return 0; } #endif
Vikas MANOCHA
Vikas Manocha
