[U-Boot] [PATCH 1/9] ARM: Define __raw_readX and __raw_writeX
These functions are undefined on ARM when using __io. These are the commonly used versions and can be redefined.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/include/asm/io.h | 46 +++++++++++++++++++++++++++++++++++++++----- 1 files changed, 40 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index e8f3eb1..ff1518e 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -75,13 +75,47 @@ static inline phys_addr_t virt_to_phys(void * vaddr) #define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v)) #define __arch_putl(v,a) (*(volatile unsigned int *)(a) = (v))
-extern void __raw_writesb(unsigned int addr, const void *data, int bytelen); -extern void __raw_writesw(unsigned int addr, const void *data, int wordlen); -extern void __raw_writesl(unsigned int addr, const void *data, int longlen); +extern inline void __raw_writesb(unsigned int addr, const void *data, int bytelen) +{ + uint8_t *buf = (uint8_t *)data; + while(bytelen--) + __arch_putb(*buf++, addr); +} + +extern inline void __raw_writesw(unsigned int addr, const void *data, int wordlen) +{ + uint16_t *buf = (uint16_t *)data; + while(wordlen--) + __arch_putw(*buf++, addr); +} + +extern inline void __raw_writesl(unsigned int addr, const void *data, int longlen) +{ + uint32_t *buf = (uint32_t *)data; + while(longlen--) + __arch_putl(*buf++, addr); +}
-extern void __raw_readsb(unsigned int addr, void *data, int bytelen); -extern void __raw_readsw(unsigned int addr, void *data, int wordlen); -extern void __raw_readsl(unsigned int addr, void *data, int longlen); +extern inline void __raw_readsb(unsigned int addr, void *data, int bytelen) +{ + uint8_t *buf = (uint8_t *)data; + while(bytelen--) + *buf++ = __arch_getb(addr); +} + +extern inline void __raw_readsw(unsigned int addr, void *data, int wordlen) +{ + uint16_t *buf = (uint16_t *)data; + while(wordlen--) + *buf++ = __arch_getw(addr); +} + +extern inline void __raw_readsl(unsigned int addr, void *data, int longlen) +{ + uint32_t *buf = (uint32_t *)data; + while(longlen--) + *buf++ = __arch_getl(addr); +}
#define __raw_writeb(v,a) __arch_putb(v,a) #define __raw_writew(v,a) __arch_putw(v,a)
ACX517AKN LCD panel is found in Palm Tungsten|C
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 34 ++++++++++++++++++++++++++++++++++ 1 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 524a03b..328fa7a 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -215,6 +215,40 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_ACX517AKN + +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f9 +# define REG_LCCR3 0x03700006 + +vidinfo_t panel_info = { + vl_col: 320, + vl_row: 320, + vl_width: 320, + vl_height: 320, + vl_clkp: CONFIG_SYS_HIGH, + vl_oep: CONFIG_SYS_LOW, + vl_hsp: CONFIG_SYS_LOW, + vl_vsp: CONFIG_SYS_LOW, + vl_dp: CONFIG_SYS_HIGH, + vl_bpix: LCD_BPP, + vl_lbw: 0, + vl_splt: 1, + vl_clor: 1, + vl_tft: 1, + vl_hpw: 0x04, + vl_blw: 0x1c, + vl_elw: 0x08, + vl_vpw: 0x01, + vl_bfw: 0x07, + vl_efw: 0x08, +}; +#endif /* CONFIG_ACX517AKN */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
Dear Marek Vasut,
In message 1281415810-31363-2-git-send-email-marek.vasut@gmail.com you wrote:
This is a resubmission, right?
Why do you not mark the patch version in the subject, like "[PATCH 2/9 v2]" or so?
And why is there no thread information present? (i. e. why are the In-reply-to: and References: headers not set to point to the previous versions of the patch?)
And why did you not include any information what has been changed between the previous version and this one?
I do not intend to run diff over your patches.
Please document your changes to the patches!
Dne Út 10. srpna 2010 23:45:05 Wolfgang Denk napsal(a):
Dear Marek Vasut,
Ok, there's nothing changed in this one. I'll document it properly in the next round. Sorry for the trouble.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- No changes
common/serial.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/serial.c b/common/serial.c index fceabfa..7148cb9 100644 --- a/common/serial.c +++ b/common/serial.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR; static struct serial_device *serial_devices = NULL; static struct serial_device *serial_current = NULL;
-#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA27X) +#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA27X) && !defined(CONFIG_PXA250) struct serial_device *__default_serial_console (void) { #if defined(CONFIG_8xx_CONS_SMC1) || defined(CONFIG_8xx_CONS_SMC2)
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- Fix line-over-80s Fix off-tree build Fix buggy comments Add missing MAINTAINERS and MAKEALL entries (the above is true for the rest of patches adding new platforms)
MAINTAINERS | 4 + MAKEALL | 1 + board/palmtc/Makefile | 49 +++++++++ board/palmtc/config.mk | 1 + board/palmtc/lowlevel_init.S | 39 +++++++ board/palmtc/palmtc.c | 58 ++++++++++ board/palmtc/u-boot.lds | 56 ++++++++++ boards.cfg | 1 + include/configs/palmtc.h | 247 ++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 456 insertions(+), 0 deletions(-) create mode 100644 board/palmtc/Makefile create mode 100644 board/palmtc/config.mk create mode 100644 board/palmtc/lowlevel_init.S create mode 100644 board/palmtc/palmtc.c create mode 100644 board/palmtc/u-boot.lds create mode 100644 include/configs/palmtc.h
diff --git a/MAINTAINERS b/MAINTAINERS index 4b91b0f..70f03fb 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -796,6 +796,10 @@ Greg Ungerer greg.ungerer@opengear.com cm4116 ks8695p cm4148 ks8695p
+Marek Vasut marek.vasut@gmail.com + + palmtc xscale + Hugo Villeneuve hugo.villeneuve@lyrtech.com
SFFSDR ARM926EJS diff --git a/MAKEALL b/MAKEALL index b34ae33..b871976 100755 --- a/MAKEALL +++ b/MAKEALL @@ -713,6 +713,7 @@ LIST_pxa=" \ delta \ innokom \ lubbock \ + palmtc \ pleb2 \ polaris \ pxa255_idp \ diff --git a/board/palmtc/Makefile b/board/palmtc/Makefile new file mode 100644 index 0000000..20ac4e1 --- /dev/null +++ b/board/palmtc/Makefile @@ -0,0 +1,49 @@ +# +# Palm Tungsten|C Support +# +# Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmtc.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmtc/config.mk b/board/palmtc/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmtc/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmtc/lowlevel_init.S b/board/palmtc/lowlevel_init.S new file mode 100644 index 0000000..74050dc --- /dev/null +++ b/board/palmtc/lowlevel_init.S @@ -0,0 +1,39 @@ +/* + * Palm Tungsten|C Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmtc/palmtc.c b/board/palmtc/palmtc.c new file mode 100644 index 0000000..0c98eb6 --- /dev/null +++ b/board/palmtc/palmtc.c @@ -0,0 +1,58 @@ +/* + * Palm Tungsten|C Support + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init (void) +{ + /* Arch number of Palm Tungsten|C */ + gd->bd->bi_arch_number = MACH_TYPE_PALMTC; + + /* Adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + PWM_CTRL1 = 0x5f; + PWM_PERVAL1 = 0x3ff; + PWM_PWDUTY1 = 892; + + return 0; +} + +struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + return 0; +} diff --git a/board/palmtc/u-boot.lds b/board/palmtc/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmtc/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index 69c6897..c6263c9 100644 --- a/boards.cfg +++ b/boards.cfg @@ -59,6 +59,7 @@ delta arm pxa innokom arm pxa logodl arm pxa lubbock arm pxa +palmtc arm pxa pleb2 arm pxa xaeniax arm pxa xm250 arm pxa diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h new file mode 100644 index 0000000..1fd9488 --- /dev/null +++ b/include/configs/palmtc.h @@ -0,0 +1,247 @@ +/* + * Palm Tungsten|C configuration file + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/pxa-regs.h> + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA250 1 /* Intel PXA255 CPU */ +#define CONFIG_PALMTC 1 /* Palm Tungsten|C board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmc init && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x80000; " \ + "fi; " +#define CONFIG_BOOTARGS \ + "console=tty0 console=ttyS0,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + * STUART - the lower serial port on Colibri board + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#define CONFIG_CMD_MMC +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_PXA_MMC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_ACX517AKN +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */ +#define CONFIG_SYS_CPUSPEED 0x161 /* 400MHz;L=1 M=3 T=1 */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x04000000 /* 64 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x01000000 /* 16 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 64 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR 0x40000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00011004 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5000008 +#define CONFIG_SYS_GAFR1_L_VAL 0x60888050 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa50aaa +#define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x00000000 +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPDR0_VAL 0xcfff8140 +#define CONFIG_SYS_GPDR1_VAL 0xfcbfbef3 +#define CONFIG_SYS_GPDR2_VAL 0x0001ffff +#define CONFIG_SYS_GPSR0_VAL 0x00010f8f +#define CONFIG_SYS_GPSR1_VAL 0x00bf5de5 +#define CONFIG_SYS_GPSR2_VAL 0x03fe0800 + +#define CONFIG_SYS_PSSR_VAL PSSR_RDH + +/* Clock setup: + * CKEN[1] - PWM1 + * CKEN[6] - FFUART + * CKEN[12] - MMC + * CKEN[16] - LCD + */ +#define CONFIG_SYS_CKEN 0x00011042 +#define CONFIG_SYS_CCCR 0x00000161 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x800092c2 +#define CONFIG_SYS_MSC1_VAL 0x80008000 +#define CONFIG_SYS_MSC2_VAL 0x80008000 +#define CONFIG_SYS_MDCNFG_VAL 0x00001ac9 +#define CONFIG_SYS_MDREFR_VAL 0x00118018 +#define CONFIG_SYS_MDMRS_VAL 0x00220032 +#define CONFIG_SYS_FLYCNFG_VAL 0x01fe01fe +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00010504 +#define CONFIG_SYS_MCMEM1_VAL 0x00010504 +#define CONFIG_SYS_MCATT0_VAL 0x00010504 +#define CONFIG_SYS_MCATT1_VAL 0x00010504 +#define CONFIG_SYS_MCIO0_VAL 0x00010e04 +#define CONFIG_SYS_MCIO1_VAL 0x00010e04 + +#endif /* __CONFIG_H */
This LCD panel is found in Palm LifeDrive handheld
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 328fa7a..066f49e 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -249,6 +249,40 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_LQ038J7DH53 + +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f9 +# define REG_LCCR3 0x03700004 + +vidinfo_t panel_info = { + vl_col: 320, + vl_row: 480, + vl_width: 320, + vl_height: 480, + vl_clkp: CONFIG_SYS_HIGH, + vl_oep: CONFIG_SYS_LOW, + vl_hsp: CONFIG_SYS_LOW, + vl_vsp: CONFIG_SYS_LOW, + vl_dp: CONFIG_SYS_HIGH, + vl_bpix: LCD_BPP, + vl_lbw: 0, + vl_splt: 1, + vl_clor: 1, + vl_tft: 1, + vl_hpw: 0x04, + vl_blw: 0x20, + vl_elw: 0x01, + vl_vpw: 0x01, + vl_bfw: 0x04, + vl_efw: 0x01, +}; +#endif /* CONFIG_ACX517AKN */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- Changes same as in PalmTC
MAINTAINERS | 1 + MAKEALL | 1 + board/palmld/Makefile | 49 ++++++++ board/palmld/config.mk | 1 + board/palmld/lowlevel_init.S | 45 +++++++ board/palmld/palmld.c | 68 +++++++++++ board/palmld/u-boot.lds | 56 +++++++++ boards.cfg | 1 + include/configs/palmld.h | 273 ++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 495 insertions(+), 0 deletions(-) create mode 100644 board/palmld/Makefile create mode 100644 board/palmld/config.mk create mode 100644 board/palmld/lowlevel_init.S create mode 100644 board/palmld/palmld.c create mode 100644 board/palmld/u-boot.lds create mode 100644 include/configs/palmld.h
diff --git a/MAINTAINERS b/MAINTAINERS index 70f03fb..5d20dca 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -798,6 +798,7 @@ Greg Ungerer greg.ungerer@opengear.com
+ palmld xscale palmtc xscale
Hugo Villeneuve hugo.villeneuve@lyrtech.com diff --git a/MAKEALL b/MAKEALL index b871976..1642abe 100755 --- a/MAKEALL +++ b/MAKEALL @@ -713,6 +713,7 @@ LIST_pxa=" \ delta \ innokom \ lubbock \ + palmld \ palmtc \ pleb2 \ polaris \ diff --git a/board/palmld/Makefile b/board/palmld/Makefile new file mode 100644 index 0000000..bcb014d --- /dev/null +++ b/board/palmld/Makefile @@ -0,0 +1,49 @@ +# +# Palm LifeDrive Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmld.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmld/config.mk b/board/palmld/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmld/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmld/lowlevel_init.S b/board/palmld/lowlevel_init.S new file mode 100644 index 0000000..e3382ee --- /dev/null +++ b/board/palmld/lowlevel_init.S @@ -0,0 +1,45 @@ +/* + * Palm LifeDrive Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + + /* Enable GPIO reset */ + ldr r0, =PCFR + mov r1, #0x30 + str r1, [r0] + + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmld/palmld.c b/board/palmld/palmld.c new file mode 100644 index 0000000..209f0b4 --- /dev/null +++ b/board/palmld/palmld.c @@ -0,0 +1,68 @@ +/* + * Palm LifeDrive Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> +#include <asm/arch/pxa-regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init (void) +{ + /* arch number of Lubbock-Board */ + gd->bd->bi_arch_number = MACH_TYPE_PALMLD; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + PWM_CTRL0 = 0x7; + PWM_PERVAL0 = 0x16c; + PWM_PWDUTY0 = 0x11a; + + return 0; +} + +struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) +{ + info->portwidth = FLASH_CFI_16BIT; + info->chipwidth = FLASH_CFI_BY16; + info->interface = FLASH_CFI_X16; + return 1; +} diff --git a/board/palmld/u-boot.lds b/board/palmld/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmld/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index c6263c9..b5ee531 100644 --- a/boards.cfg +++ b/boards.cfg @@ -59,6 +59,7 @@ delta arm pxa innokom arm pxa logodl arm pxa lubbock arm pxa +palmld arm pxa palmtc arm pxa pleb2 arm pxa xaeniax arm pxa diff --git a/include/configs/palmld.h b/include/configs/palmld.h new file mode 100644 index 0000000..affc116 --- /dev/null +++ b/include/configs/palmld.h @@ -0,0 +1,273 @@ +/* + * Palm LifeDrive configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_PALMLD 1 /* Palm LifeDrive board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmcinfo && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x0x60000; " \ + "fi; " +#define CONFIG_BOOTARGS "console=tty0 console=ttyS0,9600" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 9600 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_IDE +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_LQ038J7DH53 +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x210 /* 416MHz ; N=2,L=16 */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x02000000 /* 32 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00080000 /* 512 KB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 + +#define CONFIG_FLASH_CFI_LEGACY +#define CONFIG_SYS_FLASH_LEGACY_512Kx16 + +#define CONFIG_SYS_MONITOR_BASE 0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000 + +/* + * IDE + */ +#ifdef CONFIG_CMD_IDE +#define CONFIG_LBA48 +#undef CONFIG_IDE_LED +#undef CONFIG_IDE_RESET + +#define __io + +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 + +#define CONFIG_SYS_ATA_BASE_ADDR 0x20000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 + +#define CONFIG_SYS_ATA_DATA_OFFSET 0x10 +#define CONFIG_SYS_ATA_REG_OFFSET 0x10 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x10 + +#define CONFIG_SYS_ATA_STRIDE 1 +#endif + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00000000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5180012 +#define CONFIG_SYS_GAFR1_L_VAL 0x69988056 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa580aa +#define CONFIG_SYS_GAFR2_L_VAL 0x6aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01040001 +#define CONFIG_SYS_GAFR3_L_VAL 0x540a950c +#define CONFIG_SYS_GAFR3_U_VAL 0x00000009 +#define CONFIG_SYS_GPCR0_VAL 0x00000000 +#define CONFIG_SYS_GPCR1_VAL 0x00000000 +#define CONFIG_SYS_GPCR2_VAL 0x00000000 +#define CONFIG_SYS_GPCR3_VAL 0x00000000 +#define CONFIG_SYS_GPDR0_VAL 0xc26b0000 +#define CONFIG_SYS_GPDR1_VAL 0xfcdfaa93 +#define CONFIG_SYS_GPDR2_VAL 0x7bbaffff +#define CONFIG_SYS_GPDR3_VAL 0x006ff38d +#define CONFIG_SYS_GPSR0_VAL 0x0d9e45ee +#define CONFIG_SYS_GPSR1_VAL 0x03affdae +#define CONFIG_SYS_GPSR2_VAL 0x07554000 +#define CONFIG_SYS_GPSR3_VAL 0x01bc0785 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0x01ffffff +#define CONFIG_SYS_CCCR 0x02000210 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff844c8 +#define CONFIG_SYS_MSC1_VAL 0x7ff86ab4 +#define CONFIG_SYS_MSC2_VAL 0x7ff87ff8 +#define CONFIG_SYS_MDCNFG_VAL 0x0B880acd +#define CONFIG_SYS_MDREFR_VAL 0x201fa031 +#define CONFIG_SYS_MDMRS_VAL 0x00320032 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x40044004 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000003 +#define CONFIG_SYS_MCMEM0_VAL 0x0001c391 +#define CONFIG_SYS_MCMEM1_VAL 0x0001c391 +#define CONFIG_SYS_MCATT0_VAL 0x0001c391 +#define CONFIG_SYS_MCATT1_VAL 0x0001c391 +#define CONFIG_SYS_MCIO0_VAL 0x00014611 +#define CONFIG_SYS_MCIO1_VAL 0x0001c391 + +#endif /* __CONFIG_H */
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry.
MAINTAINERS | 1 + MAKEALL | 3 +- Makefile | 7 ++- board/vpac270/Makefile | 7 +-- board/vpac270/lowlevel_init.S | 1 - board/vpac270/vpac270.c | 41 ++++++---------- include/configs/vpac270.h | 106 +++++++++++++++++++++++----------------- 7 files changed, 87 insertions(+), 79 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 5d20dca..c35a277 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -800,6 +800,7 @@ Marek Vasut marek.vasut@gmail.com
palmld xscale palmtc xscale + vpac270 xscale
diff --git a/MAKEALL b/MAKEALL index 1642abe..52472de 100755 --- a/MAKEALL +++ b/MAKEALL @@ -719,7 +719,8 @@ LIST_pxa=" \ polaris \ pxa255_idp \ trizepsiv \ - vpac270_nor \ + vpac270_128M_nor\ + vpac270_256M_nor\ vpac270_onenand \ wepep250 \ xaeniax \ diff --git a/Makefile b/Makefile index 4f1cb1b..3f2b304 100644 --- a/Makefile +++ b/Makefile @@ -2180,13 +2180,18 @@ trizepsiv_config : unconfig fi; @$(MKCONFIG) -n $@ -a trizepsiv arm pxa trizepsiv
-vpac270_nor_config \ +vpac270_nor_256M_config \ +vpac270_nor_128M_config \ vpac270_onenand_config : unconfig @mkdir -p $(obj)include @if [ "$(findstring onenand,$@)" ] ; then \ echo "#define CONFIG_ONENAND_U_BOOT" \ >>$(obj)include/config.h ; \ fi; + @if [ "$(findstring 256M,$@)" ] ; then \ + echo "#define CONFIG_256M_U_BOOT" \ + >>$(obj)include/config.h ; \ + fi; @$(MKCONFIG) -n $@ -a vpac270 arm pxa vpac270
######################################################################### diff --git a/board/vpac270/Makefile b/board/vpac270/Makefile index c6f4c7c..f5014fc 100644 --- a/board/vpac270/Makefile +++ b/board/vpac270/Makefile @@ -1,10 +1,7 @@ - # -# (C) Copyright 2000 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Voipac PXA270 Support # -# See file CREDITS for list of people who contributed to this -# project. +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com # # This program is free software; you can redistribute it and/or # modify it under the terms of the GNU General Public License as diff --git a/board/vpac270/lowlevel_init.S b/board/vpac270/lowlevel_init.S index ec0d12c..c40d12f 100644 --- a/board/vpac270/lowlevel_init.S +++ b/board/vpac270/lowlevel_init.S @@ -3,7 +3,6 @@ * * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * - * * See file CREDITS for list of people who contributed to this * project. * diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 18e47e2..2d01e22 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -1,16 +1,7 @@ /* - * (C) Copyright 2004 - * Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net + * Voipac PXA270 Support * - * (C) Copyright 2002 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * See file CREDITS for list of people who contributed to this - * project. + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -31,29 +22,19 @@ #include <common.h> #include <asm/arch/hardware.h> #include <netdev.h> +#include <serial.h>
-/* ------------------------------------------------------------------------- */ - /* * Miscelaneous platform dependent initialisations */ -extern struct serial_device serial_ffuart_device; -extern struct serial_device serial_btuart_device; -extern struct serial_device serial_stuart_device; - -struct serial_device *default_serial_console (void) -{ - return &serial_ffuart_device; -} - int board_init (void) { /* memory and cpu-speed are setup before relocation */ /* so we do _nothing_ here */
- /* arch number of vpac270 */ + /* Arch number of vpac270 */ gd->bd->bi_arch_number = MACH_TYPE_VPAC270;
/* adress of boot parameters */ @@ -62,17 +43,24 @@ int board_init (void) return 0; }
+struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + int dram_init (void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE;
+#ifdef CONFIG_256M_U_BOOT + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +#endif return 0; }
+#ifdef CONFIG_CMD_USB int usb_board_init(void) { UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & @@ -119,6 +107,7 @@ void usb_board_stop(void)
return; } +#endif
#ifdef CONFIG_DRIVER_DM9000 int board_eth_init(bd_t *bis) diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index d3e22d9..694a8f9 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -10,7 +10,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -19,8 +19,8 @@ * MA 02111-1307 USA */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_H +#define __CONFIG_H
/* * High Level Board Configuration Options @@ -28,20 +28,13 @@ #define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ #define CONFIG_VPAC270 1 /* Voipac PXA270 board */
-#undef BOARD_LATE_INIT -#undef CONFIG_SKIP_RELOCATE_UBOOT -#undef CONFIG_USE_IRQ -#undef CONFIG_SKIP_LOWLEVEL_INIT - /* * Environment settings */ -#define CONFIG_ENV_SIZE 0x4000 -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_SYS_GBL_DATA_SIZE 128
-#define CONFIG_ENV_OVERWRITE /* override default environment */ - #define CONFIG_BOOTCOMMAND \ "if mmc init && fatload mmc 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ @@ -49,6 +42,9 @@ "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ + "if ide reset && fatload ide 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ "bootm 0x40000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP @@ -97,9 +93,9 @@
#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ -#define DM9000_IO (CONFIG_DM9000_BASE) -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ +#define DM9000_IO (CONFIG_DM9000_BASE) +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) #define CONFIG_NET_RETRY_COUNT 10
#define CONFIG_BOOTP_BOOTFILESIZE @@ -116,6 +112,7 @@ #define CONFIG_PXA_MMC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #endif
@@ -123,8 +120,8 @@ * KGDB */ #ifdef CONFIG_CMD_KGDB -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
/* @@ -133,16 +130,17 @@ #define CONFIG_SYS_HUSH_PARSER 1 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
-#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LONGHELP #ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "$ " #else -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "=> " #endif -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_DEVICE_NULLDEV 1
/* @@ -150,12 +148,10 @@ */ #undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ -#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ +#define CONFIG_SYS_CPUSPEED 0x190 /* 312MHz */
/* * Stack sizes - * - * The stack sizes are set up in start.S using the settings below */ #define CONFIG_STACKSIZE (128*1024) /* regular stack */ #ifdef CONFIG_USE_IRQ @@ -166,17 +162,24 @@ /* * DRAM Map */ -#define CONFIG_NR_DRAM_BANKS 2 /* We have 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 /* 2 banks of DRAM */ #define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #2 */ #define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#endif
#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_DRAM_SIZE 0x10000000 /* 256 MB DRAM */ +#else +#define CONFIG_SYS_DRAM_SIZE 0x08000000 /* 128 MB DRAM */ +#endif
-#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_LOAD_ADDR (0x5c000000)
@@ -185,14 +188,22 @@ */ #if defined(CONFIG_CMD_FLASH) /* NOR */ #define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_FLASH_2 0x02000000 /* Flash Bank #2 */ +#endif
#define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER 1
#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MAX_FLASH_BANKS 2 #define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } +#else +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#endif
#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) #define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) @@ -200,25 +211,26 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 #define CONFIG_SYS_FLASH_PROTECTION 1
-#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x4000
#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ONENAND_BASE 0x00000000 + #define CONFIG_ENV_IS_IN_ONENAND 1 +#define CONFIG_ENV_SECT_SIZE 0x20000
#else /* No flash */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ENV_IS_NOWHERE #endif
-#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_BASE 0x0 #define CONFIG_SYS_MONITOR_LEN 0x40000
-#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x40000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000
/* * IDE @@ -230,15 +242,15 @@
#define __io
-#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1
-#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 +#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0
-#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 -#define CONFIG_SYS_ATA_REG_OFFSET 0x120 -#define CONFIG_SYS_ATA_ALT_OFFSET 0x120 +#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 +#define CONFIG_SYS_ATA_REG_OFFSET 0x120 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x120
#define CONFIG_SYS_ATA_STRIDE 2 #endif @@ -284,7 +296,11 @@ #define CONFIG_SYS_MSC0_VAL 0x3ffc95fa #define CONFIG_SYS_MSC1_VAL 0x02ccf974 #define CONFIG_SYS_MSC2_VAL 0x00000000 +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MDCNFG_VAL 0x8ad30ad3 +#else +#define CONFIG_SYS_MDCNFG_VAL 0x88000ad3 +#endif #define CONFIG_SYS_MDREFR_VAL 0x201fe01e #define CONFIG_SYS_MDMRS_VAL 0x00000000 #define CONFIG_SYS_FLYCNFG_VAL 0x00000000 @@ -306,13 +322,13 @@ * LCD */ #ifdef CONFIG_LCD -#define CONFIG_VOIPAC_LCD +#define CONFIG_VOIPAC_LCD #endif
/* * USB */ -#ifdef CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_BOARD_INIT
Dear Marek Vasut,
In message 1282296691-15910-6-git-send-email-marek.vasut@gmail.com you wrote:
- vpac270 xscale
Um... we don't accept such changes to the Makefile any more. Such configuration should be moved to the boards.cfg file instead.
- (C) Copyright 2004
- Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net
- Voipac PXA270 Support
- (C) Copyright 2002
- Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
- project.
- Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com
What makes you think it was legitimate to delete these old Copyright notices?
N900 again, sorry. ----- Původní zpráva -----
Dear Marek Vasut,
I'm aware of this. Though I have to admit I don't know how to do it through boards.cfg. I will take a look when I get home (in about 1 hour). Or if you'd be so kind to point me in some direction?
Thanks
- project.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de HEALTH WARNING: Care Should Be Taken When Lifting This Product, Since Its Mass, and Thus Its Weight, Is Dependent on Its Velocity Relative to the User.
Dne Út 7. září 2010 23:30:16 Marek Vasut napsal(a):
Dear Marek Vasut,
- vpac270 xscale
Thanks
- project.
btw. this file never had anything to do with these people ... it's just a fix for a copy-paste thing/mistake.
The following hardware is currently supported: - UART - USB Host - FPGA
MAINTAINERS | 1 + MAKEALL | 1 + board/balloon3/Makefile | 49 +++++++ board/balloon3/balloon3.c | 224 +++++++++++++++++++++++++++++++++ board/balloon3/config.mk | 1 + board/balloon3/lowlevel_init.S | 36 ++++++ board/balloon3/u-boot.lds | 55 ++++++++ boards.cfg | 1 + include/configs/balloon3.h | 269 ++++++++++++++++++++++++++++++++++++++++ 9 files changed, 637 insertions(+), 0 deletions(-) create mode 100644 board/balloon3/Makefile create mode 100644 board/balloon3/balloon3.c create mode 100644 board/balloon3/config.mk create mode 100644 board/balloon3/lowlevel_init.S create mode 100644 board/balloon3/u-boot.lds create mode 100644 include/configs/balloon3.h
diff --git a/MAINTAINERS b/MAINTAINERS index c35a277..433eae4 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -798,6 +798,7 @@ Greg Ungerer greg.ungerer@opengear.com
+ balloon3 xscale palmld xscale palmtc xscale vpac270 xscale diff --git a/MAKEALL b/MAKEALL index 52472de..9d149e2 100755 --- a/MAKEALL +++ b/MAKEALL @@ -706,6 +706,7 @@ LIST_at91=" \ #########################################################################
LIST_pxa=" \ + balloon3 \ cerf250 \ colibri_pxa270 \ cradle \ diff --git a/board/balloon3/Makefile b/board/balloon3/Makefile new file mode 100644 index 0000000..3928e1f --- /dev/null +++ b/board/balloon3/Makefile @@ -0,0 +1,49 @@ +# +# Balloon3 Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := balloon3.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c new file mode 100644 index 0000000..6d682d9 --- /dev/null +++ b/board/balloon3/balloon3.c @@ -0,0 +1,224 @@ +/* + * Balloon3 Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <serial.h> +#include <asm/io.h> +#include <spartan3.h> +#include <command.h> + +DECLARE_GLOBAL_DATA_PTR; + +void balloon3_init_fpga(void); + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init (void) +{ + /* arch number of vpac270 */ + gd->bd->bi_arch_number = MACH_TYPE_BALLOON3; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Init the FPGA */ + balloon3_init_fpga(); + + return 0; +} + +struct serial_device *default_serial_console (void) +{ + return &serial_stuart_device; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; + + return 0; +} + +#ifdef CONFIG_CMD_USB +int usb_board_init(void) +{ + UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + + UHCHR |= UHCHR_FSBIR; + + while (UHCHR & UHCHR_FSBIR); + + UHCHR &= ~UHCHR_SSE; + UHCHIE = (UHCHIE_UPRIE | UHCHIE_RWIE); + + /* Clear any OTG Pin Hold */ + if (PSSR & PSSR_OTGPH) + PSSR |= PSSR_OTGPH; + + UHCRHDA &= ~(0x200); + UHCRHDA |= 0x100; + + /* Set port power control mask bits, only 3 ports. */ + UHCRHDB |= (0x7<<17); + + /* enable port 2 */ + UP2OCR |= UP2OCR_HXOE | UP2OCR_HXS | UP2OCR_DMPDE | UP2OCR_DPPDE; + + return 0; +} + +void usb_board_init_fail(void) +{ + return; +} + +void usb_board_stop(void) +{ + UHCHR |= UHCHR_FHR; + udelay(11); + UHCHR &= ~UHCHR_FHR; + + UHCCOMS |= 1; + udelay(10); + + CKEN &= ~CKEN10_USBHOST; + + return; +} +#endif + +#if defined(CONFIG_FPGA) +/* Toggle GPIO103 and GPIO104 -- PROGB and RDnWR */ +int fpga_pgm_fn(int nassert, int nflush, int cookie) +{ + if (nassert) + GPCR3 = 0x80; + else + GPSR3 = 0x80; + if (nflush) + GPCR3 = 0x100; + else + GPSR3 = 0x100; + return nassert; +} + +/* Check GPIO83 -- INITB */ +int fpga_init_fn(int cookie) +{ + return !(GPLR2 & 0x80000); +} + +/* Check GPIO84 -- BUSY */ +int fpga_busy_fn(int cookie) +{ + return !(GPLR2 & 0x100000); +} + +/* Check GPIO111 -- DONE */ +int fpga_done_fn(int cookie) +{ + return GPLR3 & 0x8000; +} + +/* Configure GPIO104 as GPIO and deassert it */ +int fpga_pre_config_fn(int cookie) +{ + GAFR3_L &= ~0x30000; + GPCR3 = 0x100; + return 0; +} + +/* Configure GPIO104 as nSKTSEL */ +int fpga_post_config_fn(int cookie) +{ + GAFR3_L |= 0x10000; + return 0; +} + +/* Toggle RDnWR */ +int fpga_wr_fn(int nassert_write, int flush, int cookie) +{ + udelay(1000); + + if (nassert_write) + GPCR3 = 0x100; + else + GPSR3 = 0x100; + + return nassert_write; +} + +/* Write program to the FPGA */ +int fpga_wdata_fn(uchar data, int flush, int cookie) +{ + writeb(data, 0x10f00000); + return 0; +} + +/* Toggle Clock pin -- NO-OP */ +int fpga_clk_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +/* Toggle ChipSelect pin -- NO-OP */ +int fpga_cs_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +Xilinx_Spartan3_Slave_Parallel_fns balloon3_fpga_fns = { + fpga_pre_config_fn, + fpga_pgm_fn, + fpga_init_fn, + NULL, /* err */ + fpga_done_fn, + fpga_clk_fn, + fpga_cs_fn, + fpga_wr_fn, + NULL, /* rdata */ + fpga_wdata_fn, + fpga_busy_fn, + NULL, /* abort */ + fpga_post_config_fn, +}; + +Xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, (void *)&balloon3_fpga_fns, 0); + +/* Initialize the FPGA */ +void balloon3_init_fpga(void) +{ + fpga_init(); + fpga_add (fpga_xilinx, &fpga); +} +#else +void balloon3_init_fpga(void) {} +#endif /* CONFIG_FPGA */ diff --git a/board/balloon3/config.mk b/board/balloon3/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/balloon3/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/balloon3/lowlevel_init.S b/board/balloon3/lowlevel_init.S new file mode 100644 index 0000000..d7b5be6 --- /dev/null +++ b/board/balloon3/lowlevel_init.S @@ -0,0 +1,36 @@ +/* + * Balloon3 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/balloon3/u-boot.lds b/board/balloon3/u-boot.lds new file mode 100644 index 0000000..58c371d --- /dev/null +++ b/board/balloon3/u-boot.lds @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index b5ee531..04ca7de 100644 --- a/boards.cfg +++ b/boards.cfg @@ -51,6 +51,7 @@ actux2 arm ixp actux3 arm ixp actux4 arm ixp ixdp425 arm ixp +balloon3 arm pxa cerf250 arm pxa colibri_pxa270 arm pxa cradle arm pxa diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h new file mode 100644 index 0000000..9066a24 --- /dev/null +++ b/include/configs/balloon3.h @@ -0,0 +1,269 @@ +/* + * Balloon3 configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_BALLOON3 1 /* Balloon3 board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ + "bootm 0x40000;" +#define CONFIG_BOOTARGS "console=tty0 console=ttyS2,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_STUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_USB +#define CONFIG_CMD_FPGA +#undef CONFIG_LCD + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 3 /* 2 banks of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_2 0xb0000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_3 0x80000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_3_SIZE 0x08000000 /* 128 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x18000000 /* 384 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0xa1000000 + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_ENV_IS_IN_FLASH +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x10000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GPSR0_VAL 0x307dc7fd +#define CONFIG_SYS_GPSR1_VAL 0x03cffa4e +#define CONFIG_SYS_GPSR2_VAL 0x7131c000 +#define CONFIG_SYS_GPSR3_VAL 0x01e1f3ff + +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPCR3_VAL 0x0 + +#define CONFIG_SYS_GPDR0_VAL 0xc0f98e02 +#define CONFIG_SYS_GPDR1_VAL 0xfcffa8b7 +#define CONFIG_SYS_GPDR2_VAL 0x22e3ffff +#define CONFIG_SYS_GPDR3_VAL 0x000201fe + +#define CONFIG_SYS_GAFR0_L_VAL 0x96c00000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5e5459b +#define CONFIG_SYS_GAFR1_L_VAL 0x699b759a +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa5a5aa +#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01f9a6aa +#define CONFIG_SYS_GAFR3_L_VAL 0x54510003 +#define CONFIG_SYS_GAFR3_U_VAL 0x00001599 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0xffffffff +#define CONFIG_SYS_CCCR 0x00000290 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff07ff8 +#define CONFIG_SYS_MSC1_VAL 0x7ff07ff0 +#define CONFIG_SYS_MSC2_VAL 0x74a42491 +#define CONFIG_SYS_MDCNFG_VAL 0x89d309d3 +#define CONFIG_SYS_MDREFR_VAL 0x001d8018 +#define CONFIG_SYS_MDMRS_VAL 0x00220022 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 +#define CONFIG_SYS_MEM_BUF_IMP 0x0f + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MCMEM1_VAL 0x00014307 +#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT1_VAL 0x0001c787 +#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO1_VAL 0x0001430f + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_BALLOON3LCD +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * USB + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_BOARD_INIT +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x4C000000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "balloon3" +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#endif + +/* + * FPGA + */ +#ifdef CONFIG_CMD_FPGA +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 +#define CONFIG_MAX_FPGA_DEVICES 1 +#endif + +#endif /* __CONFIG_H */
Dear Marek Vasut,
In message 1282296691-15910-7-git-send-email-marek.vasut@gmail.com you wrote:
- UART
- USB Host
- FPGA
- UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) &
- UHCHR |= UHCHR_FSBIR;
- while (UHCHR & UHCHR_FSBIR);
- UHCHR &= ~UHCHR_SSE;
- UHCHIE = (UHCHIE_UPRIE | UHCHIE_RWIE);
- /* Clear any OTG Pin Hold */
- if (PSSR & PSSR_OTGPH)
PSSR |= PSSR_OTGPH;
- UHCRHDA &= ~(0x200);
- UHCRHDA |= 0x100;
- /* Set port power control mask bits, only 3 ports. */
- UHCRHDB |= (0x7<<17);
- /* enable port 2 */
- UP2OCR |= UP2OCR_HXOE | UP2OCR_HXS | UP2OCR_DMPDE | UP2OCR_DPPDE;
Why aren't you using I/O accessors here?
- UHCHR |= UHCHR_FHR;
- udelay(11);
- UHCHR &= ~UHCHR_FHR;
- UHCCOMS |= 1;
- udelay(10);
- CKEN &= ~CKEN10_USBHOST;
And here, and so on?
N900 mailclient is stupid ... Bear with it please. ----- Původní zpráva -----
Dear Marek Vasut,
- UART
- USB Host
- FPGA
Hey Wolfgang,
we already discussed this somewhere. Check how arch/arm/include/mach-pxa/pxa-regs.h is done. It's ripped off the linux kernel. We already came to a conclusion that it needs to be reworked (remove the _REG() macro crud and use io accessors).
Though I'd like to propose if we could get this stuff in prior to reworking pxa-regs.h as the change will be very intrusive. To have a stable revision where the boards work in case something went wrong.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Don't tell me how hard you work. Tell me how much you get done. -- James J. Ling
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- No changes
MAINTAINERS | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 433eae4..7d66f7d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -799,9 +799,11 @@ Greg Ungerer greg.ungerer@opengear.com Marek Vasut marek.vasut@gmail.com
balloon3 xscale + colibri_pxa270 xscale palmld xscale palmtc xscale vpac270 xscale + zipitz2 xscale
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- common/serial.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/serial.c b/common/serial.c index fceabfa..7148cb9 100644 --- a/common/serial.c +++ b/common/serial.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR; static struct serial_device *serial_devices = NULL; static struct serial_device *serial_current = NULL;
-#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA27X) +#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA27X) && !defined(CONFIG_PXA250) struct serial_device *__default_serial_console (void) { #if defined(CONFIG_8xx_CONS_SMC1) || defined(CONFIG_8xx_CONS_SMC2)
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 1 + board/palmtc/Makefile | 49 +++++++++ board/palmtc/config.mk | 1 + board/palmtc/lowlevel_init.S | 39 +++++++ board/palmtc/palmtc.c | 61 +++++++++++ board/palmtc/u-boot.lds | 56 ++++++++++ boards.cfg | 1 + include/configs/palmtc.h | 246 ++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 454 insertions(+), 0 deletions(-) create mode 100644 board/palmtc/Makefile create mode 100644 board/palmtc/config.mk create mode 100644 board/palmtc/lowlevel_init.S create mode 100644 board/palmtc/palmtc.c create mode 100644 board/palmtc/u-boot.lds create mode 100644 include/configs/palmtc.h
diff --git a/MAKEALL b/MAKEALL index b34ae33..b871976 100755 --- a/MAKEALL +++ b/MAKEALL @@ -713,6 +713,7 @@ LIST_pxa=" \ delta \ innokom \ lubbock \ + palmtc \ pleb2 \ polaris \ pxa255_idp \ diff --git a/board/palmtc/Makefile b/board/palmtc/Makefile new file mode 100644 index 0000000..20ac4e1 --- /dev/null +++ b/board/palmtc/Makefile @@ -0,0 +1,49 @@ +# +# Palm Tungsten|C Support +# +# Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmtc.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmtc/config.mk b/board/palmtc/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmtc/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmtc/lowlevel_init.S b/board/palmtc/lowlevel_init.S new file mode 100644 index 0000000..74050dc --- /dev/null +++ b/board/palmtc/lowlevel_init.S @@ -0,0 +1,39 @@ +/* + * Palm Tungsten|C Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmtc/palmtc.c b/board/palmtc/palmtc.c new file mode 100644 index 0000000..6083065 --- /dev/null +++ b/board/palmtc/palmtc.c @@ -0,0 +1,61 @@ +/* + * Palm Tungsten|C Support + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init (void) +{ + /* memory and cpu-speed are setup before relocation */ + /* so we do _nothing_ here */ + + /* Arch number of Palm Tungsten|C */ + gd->bd->bi_arch_number = MACH_TYPE_PALMTC; + + /* Adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + PWM_CTRL1 = 0x5f; + PWM_PERVAL1 = 0x3ff; + PWM_PWDUTY1 = 892; + + return 0; +} + +struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + return 0; +} diff --git a/board/palmtc/u-boot.lds b/board/palmtc/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmtc/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index 69c6897..c6263c9 100644 --- a/boards.cfg +++ b/boards.cfg @@ -59,6 +59,7 @@ delta arm pxa innokom arm pxa logodl arm pxa lubbock arm pxa +palmtc arm pxa pleb2 arm pxa xaeniax arm pxa xm250 arm pxa diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h new file mode 100644 index 0000000..5de5dfe --- /dev/null +++ b/include/configs/palmtc.h @@ -0,0 +1,246 @@ +/* + * Palm Tungsten|C configuration file + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/pxa-regs.h> + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA250 1 /* Intel PXA255 CPU */ +#define CONFIG_PALMTC 1 /* Palm Tungsten|C board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmc init && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x80000; " \ + "fi; " +#define CONFIG_BOOTARGS \ + "console=tty0 console=ttyS0,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + * STUART - the lower serial port on Colibri board + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#define CONFIG_CMD_MMC +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_PXA_MMC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_ACX517AKN +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#else +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#endif +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */ +#define CONFIG_SYS_CPUSPEED 0x161 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* We have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x04000000 /* 64 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x01000000 /* 16 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 64 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR 0x40000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00011004 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5000008 +#define CONFIG_SYS_GAFR1_L_VAL 0x60888050 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa50aaa +#define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x00000000 +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPDR0_VAL 0xcfff8140 +#define CONFIG_SYS_GPDR1_VAL 0xfcbfbef3 +#define CONFIG_SYS_GPDR2_VAL 0x0001ffff +#define CONFIG_SYS_GPSR0_VAL 0x00010f8f +#define CONFIG_SYS_GPSR1_VAL 0x00bf5de5 +#define CONFIG_SYS_GPSR2_VAL 0x03fe0800 + +#define CONFIG_SYS_PSSR_VAL PSSR_RDH + +/* Clock setup: + * CKEN[1] - PWM1 + * CKEN[6] - FFUART + * CKEN[12] - MMC + * CKEN[16] - LCD + */ +#define CONFIG_SYS_CKEN 0x00011042 +#define CONFIG_SYS_CCCR 0x00000161 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x800092c2 +#define CONFIG_SYS_MSC1_VAL 0x80008000 +#define CONFIG_SYS_MSC2_VAL 0x80008000 +#define CONFIG_SYS_MDCNFG_VAL 0x00001ac9 +#define CONFIG_SYS_MDREFR_VAL 0x00118018 +#define CONFIG_SYS_MDMRS_VAL 0x00220032 +#define CONFIG_SYS_FLYCNFG_VAL 0x01fe01fe +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00010504 +#define CONFIG_SYS_MCMEM1_VAL 0x00010504 +#define CONFIG_SYS_MCATT0_VAL 0x00010504 +#define CONFIG_SYS_MCATT1_VAL 0x00010504 +#define CONFIG_SYS_MCIO0_VAL 0x00010e04 +#define CONFIG_SYS_MCIO1_VAL 0x00010e04 + +#endif /* __CONFIG_H */
This LCD panel is found in Palm LifeDrive handheld
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 34 ++++++++++++++++++++++++++++++++++ 1 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 328fa7a..066f49e 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -249,6 +249,40 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_LQ038J7DH53 + +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f9 +# define REG_LCCR3 0x03700004 + +vidinfo_t panel_info = { + vl_col: 320, + vl_row: 480, + vl_width: 320, + vl_height: 480, + vl_clkp: CONFIG_SYS_HIGH, + vl_oep: CONFIG_SYS_LOW, + vl_hsp: CONFIG_SYS_LOW, + vl_vsp: CONFIG_SYS_LOW, + vl_dp: CONFIG_SYS_HIGH, + vl_bpix: LCD_BPP, + vl_lbw: 0, + vl_splt: 1, + vl_clor: 1, + vl_tft: 1, + vl_hpw: 0x04, + vl_blw: 0x20, + vl_elw: 0x01, + vl_vpw: 0x01, + vl_bfw: 0x04, + vl_efw: 0x01, +}; +#endif /* CONFIG_ACX517AKN */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 1 + board/palmld/Makefile | 49 ++++++++ board/palmld/config.mk | 1 + board/palmld/lowlevel_init.S | 45 +++++++ board/palmld/palmld.c | 71 +++++++++++ board/palmld/u-boot.lds | 56 +++++++++ boards.cfg | 1 + include/configs/palmld.h | 272 ++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 496 insertions(+), 0 deletions(-) create mode 100644 board/palmld/Makefile create mode 100644 board/palmld/config.mk create mode 100644 board/palmld/lowlevel_init.S create mode 100644 board/palmld/palmld.c create mode 100644 board/palmld/u-boot.lds create mode 100644 include/configs/palmld.h
diff --git a/MAKEALL b/MAKEALL index b871976..1642abe 100755 --- a/MAKEALL +++ b/MAKEALL @@ -713,6 +713,7 @@ LIST_pxa=" \ delta \ innokom \ lubbock \ + palmld \ palmtc \ pleb2 \ polaris \ diff --git a/board/palmld/Makefile b/board/palmld/Makefile new file mode 100644 index 0000000..bcb014d --- /dev/null +++ b/board/palmld/Makefile @@ -0,0 +1,49 @@ +# +# Palm LifeDrive Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmld.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmld/config.mk b/board/palmld/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmld/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmld/lowlevel_init.S b/board/palmld/lowlevel_init.S new file mode 100644 index 0000000..e3382ee --- /dev/null +++ b/board/palmld/lowlevel_init.S @@ -0,0 +1,45 @@ +/* + * Palm LifeDrive Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + + /* Enable GPIO reset */ + ldr r0, =PCFR + mov r1, #0x30 + str r1, [r0] + + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmld/palmld.c b/board/palmld/palmld.c new file mode 100644 index 0000000..22362b2 --- /dev/null +++ b/board/palmld/palmld.c @@ -0,0 +1,71 @@ +/* + * Palm LifeDrive Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> +#include <asm/arch/pxa-regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init (void) +{ + /* memory and cpu-speed are setup before relocation */ + /* so we do _nothing_ here */ + + /* arch number of Lubbock-Board */ + gd->bd->bi_arch_number = MACH_TYPE_PALMLD; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + PWM_CTRL0 = 0x7; + PWM_PERVAL0 = 0x16c; + PWM_PWDUTY0 = 0x11a; + + return 0; +} + +struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) +{ + info->portwidth = FLASH_CFI_16BIT; + info->chipwidth = FLASH_CFI_BY16; + info->interface = FLASH_CFI_X16; + return 1; +} diff --git a/board/palmld/u-boot.lds b/board/palmld/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmld/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index c6263c9..b5ee531 100644 --- a/boards.cfg +++ b/boards.cfg @@ -59,6 +59,7 @@ delta arm pxa innokom arm pxa logodl arm pxa lubbock arm pxa +palmld arm pxa palmtc arm pxa pleb2 arm pxa xaeniax arm pxa diff --git a/include/configs/palmld.h b/include/configs/palmld.h new file mode 100644 index 0000000..942ca5a --- /dev/null +++ b/include/configs/palmld.h @@ -0,0 +1,272 @@ +/* + * Palm LifeDrive configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_PALMLD 1 /* Palm LifeDrive board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmcinfo && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x0x60000; " \ + "fi; " +#define CONFIG_BOOTARGS "console=tty0 console=ttyS0,9600" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 9600 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_IDE +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_LQ038J7DH53 +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#else +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#endif +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x210 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* We have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x02000000 /* 32 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00080000 /* 512 KB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 + +#define CONFIG_FLASH_CFI_LEGACY +#define CONFIG_SYS_FLASH_LEGACY_512Kx16 + +#define CONFIG_SYS_MONITOR_BASE 0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000 + +/* + * IDE + */ +#ifdef CONFIG_CMD_IDE +#define CONFIG_LBA48 +#undef CONFIG_IDE_LED +#undef CONFIG_IDE_RESET + +#define __io + +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 + +#define CONFIG_SYS_ATA_BASE_ADDR 0x20000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 + +#define CONFIG_SYS_ATA_DATA_OFFSET 0x10 +#define CONFIG_SYS_ATA_REG_OFFSET 0x10 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x10 + +#define CONFIG_SYS_ATA_STRIDE 1 +#endif + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00000000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5180012 +#define CONFIG_SYS_GAFR1_L_VAL 0x69988056 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa580aa +#define CONFIG_SYS_GAFR2_L_VAL 0x6aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01040001 +#define CONFIG_SYS_GAFR3_L_VAL 0x540a950c +#define CONFIG_SYS_GAFR3_U_VAL 0x00000009 +#define CONFIG_SYS_GPCR0_VAL 0x00000000 +#define CONFIG_SYS_GPCR1_VAL 0x00000000 +#define CONFIG_SYS_GPCR2_VAL 0x00000000 +#define CONFIG_SYS_GPCR3_VAL 0x00000000 +#define CONFIG_SYS_GPDR0_VAL 0xc26b0000 +#define CONFIG_SYS_GPDR1_VAL 0xfcdfaa93 +#define CONFIG_SYS_GPDR2_VAL 0x7bbaffff +#define CONFIG_SYS_GPDR3_VAL 0x006ff38d +#define CONFIG_SYS_GPSR0_VAL 0x0d9e45ee +#define CONFIG_SYS_GPSR1_VAL 0x03affdae +#define CONFIG_SYS_GPSR2_VAL 0x07554000 +#define CONFIG_SYS_GPSR3_VAL 0x01bc0785 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0x01ffffff +#define CONFIG_SYS_CCCR 0x02000210 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff844c8 +#define CONFIG_SYS_MSC1_VAL 0x7ff86ab4 +#define CONFIG_SYS_MSC2_VAL 0x7ff87ff8 +#define CONFIG_SYS_MDCNFG_VAL 0x0B880acd +#define CONFIG_SYS_MDREFR_VAL 0x201fa031 +#define CONFIG_SYS_MDMRS_VAL 0x00320032 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x40044004 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000003 +#define CONFIG_SYS_MCMEM0_VAL 0x0001c391 +#define CONFIG_SYS_MCMEM1_VAL 0x0001c391 +#define CONFIG_SYS_MCATT0_VAL 0x0001c391 +#define CONFIG_SYS_MCATT1_VAL 0x0001c391 +#define CONFIG_SYS_MCIO0_VAL 0x00014611 +#define CONFIG_SYS_MCIO1_VAL 0x0001c391 + +#endif /* __CONFIG_H */
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 3 +- Makefile | 7 +++- board/vpac270/Makefile | 7 +-- board/vpac270/lowlevel_init.S | 1 - board/vpac270/vpac270.c | 41 +++++++------------- include/configs/vpac270.h | 83 ++++++++++++++++++++++++---------------- 6 files changed, 75 insertions(+), 67 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 1642abe..52472de 100755 --- a/MAKEALL +++ b/MAKEALL @@ -719,7 +719,8 @@ LIST_pxa=" \ polaris \ pxa255_idp \ trizepsiv \ - vpac270_nor \ + vpac270_128M_nor\ + vpac270_256M_nor\ vpac270_onenand \ wepep250 \ xaeniax \ diff --git a/Makefile b/Makefile index 4f1cb1b..3f2b304 100644 --- a/Makefile +++ b/Makefile @@ -2180,13 +2180,18 @@ trizepsiv_config : unconfig fi; @$(MKCONFIG) -n $@ -a trizepsiv arm pxa trizepsiv
-vpac270_nor_config \ +vpac270_nor_256M_config \ +vpac270_nor_128M_config \ vpac270_onenand_config : unconfig @mkdir -p $(obj)include @if [ "$(findstring onenand,$@)" ] ; then \ echo "#define CONFIG_ONENAND_U_BOOT" \ >>$(obj)include/config.h ; \ fi; + @if [ "$(findstring 256M,$@)" ] ; then \ + echo "#define CONFIG_256M_U_BOOT" \ + >>$(obj)include/config.h ; \ + fi; @$(MKCONFIG) -n $@ -a vpac270 arm pxa vpac270
######################################################################### diff --git a/board/vpac270/Makefile b/board/vpac270/Makefile index c6f4c7c..f5014fc 100644 --- a/board/vpac270/Makefile +++ b/board/vpac270/Makefile @@ -1,10 +1,7 @@ - # -# (C) Copyright 2000 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Voipac PXA270 Support # -# See file CREDITS for list of people who contributed to this -# project. +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com # # This program is free software; you can redistribute it and/or # modify it under the terms of the GNU General Public License as diff --git a/board/vpac270/lowlevel_init.S b/board/vpac270/lowlevel_init.S index ec0d12c..c40d12f 100644 --- a/board/vpac270/lowlevel_init.S +++ b/board/vpac270/lowlevel_init.S @@ -3,7 +3,6 @@ * * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * - * * See file CREDITS for list of people who contributed to this * project. * diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 18e47e2..2d01e22 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -1,16 +1,7 @@ /* - * (C) Copyright 2004 - * Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net + * Voipac PXA270 Support * - * (C) Copyright 2002 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * See file CREDITS for list of people who contributed to this - * project. + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -31,29 +22,19 @@ #include <common.h> #include <asm/arch/hardware.h> #include <netdev.h> +#include <serial.h>
-/* ------------------------------------------------------------------------- */ - /* * Miscelaneous platform dependent initialisations */ -extern struct serial_device serial_ffuart_device; -extern struct serial_device serial_btuart_device; -extern struct serial_device serial_stuart_device; - -struct serial_device *default_serial_console (void) -{ - return &serial_ffuart_device; -} - int board_init (void) { /* memory and cpu-speed are setup before relocation */ /* so we do _nothing_ here */
- /* arch number of vpac270 */ + /* Arch number of vpac270 */ gd->bd->bi_arch_number = MACH_TYPE_VPAC270;
/* adress of boot parameters */ @@ -62,17 +43,24 @@ int board_init (void) return 0; }
+struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + int dram_init (void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE;
+#ifdef CONFIG_256M_U_BOOT + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +#endif return 0; }
+#ifdef CONFIG_CMD_USB int usb_board_init(void) { UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & @@ -119,6 +107,7 @@ void usb_board_stop(void)
return; } +#endif
#ifdef CONFIG_DRIVER_DM9000 int board_eth_init(bd_t *bis) diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index d3e22d9..09c040b 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -10,7 +10,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -19,8 +19,8 @@ * MA 02111-1307 USA */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_H +#define __CONFIG_H
/* * High Level Board Configuration Options @@ -28,20 +28,13 @@ #define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ #define CONFIG_VPAC270 1 /* Voipac PXA270 board */
-#undef BOARD_LATE_INIT -#undef CONFIG_SKIP_RELOCATE_UBOOT -#undef CONFIG_USE_IRQ -#undef CONFIG_SKIP_LOWLEVEL_INIT - /* * Environment settings */ -#define CONFIG_ENV_SIZE 0x4000 -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_SYS_GBL_DATA_SIZE 128
-#define CONFIG_ENV_OVERWRITE /* override default environment */ - #define CONFIG_BOOTCOMMAND \ "if mmc init && fatload mmc 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ @@ -49,6 +42,9 @@ "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ + "if ide reset && fatload ide 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ "bootm 0x40000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP @@ -97,9 +93,9 @@
#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ -#define DM9000_IO (CONFIG_DM9000_BASE) -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ +#define DM9000_IO (CONFIG_DM9000_BASE) +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) #define CONFIG_NET_RETRY_COUNT 10
#define CONFIG_BOOTP_BOOTFILESIZE @@ -116,6 +112,7 @@ #define CONFIG_PXA_MMC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #endif
@@ -150,7 +147,7 @@ */ #undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ -#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ +#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */
/* * Stack sizes @@ -169,14 +166,21 @@ #define CONFIG_NR_DRAM_BANKS 2 /* We have 2 banks of DRAM */ #define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #2 */ #define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#endif
#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_DRAM_SIZE 0x10000000 /* 256 MB DRAM */ +#else +#define CONFIG_SYS_DRAM_SIZE 0x08000000 /* 128 MB DRAM */ +#endif
-#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_LOAD_ADDR (0x5c000000)
@@ -185,14 +189,22 @@ */ #if defined(CONFIG_CMD_FLASH) /* NOR */ #define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_FLASH_2 0x02000000 /* Flash Bank #2 */ +#endif
#define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER 1
#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MAX_FLASH_BANKS 2 #define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } +#else +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#endif
#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) #define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) @@ -200,25 +212,26 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 #define CONFIG_SYS_FLASH_PROTECTION 1
-#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x4000
#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ONENAND_BASE 0x00000000 + #define CONFIG_ENV_IS_IN_ONENAND 1 +#define CONFIG_ENV_SECT_SIZE 0x20000
#else /* No flash */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ENV_IS_NOWHERE #endif
-#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_BASE 0x0 #define CONFIG_SYS_MONITOR_LEN 0x40000
-#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x40000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000
/* * IDE @@ -230,15 +243,15 @@
#define __io
-#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1
-#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 +#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0
-#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 -#define CONFIG_SYS_ATA_REG_OFFSET 0x120 -#define CONFIG_SYS_ATA_ALT_OFFSET 0x120 +#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 +#define CONFIG_SYS_ATA_REG_OFFSET 0x120 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x120
#define CONFIG_SYS_ATA_STRIDE 2 #endif @@ -284,7 +297,11 @@ #define CONFIG_SYS_MSC0_VAL 0x3ffc95fa #define CONFIG_SYS_MSC1_VAL 0x02ccf974 #define CONFIG_SYS_MSC2_VAL 0x00000000 +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MDCNFG_VAL 0x8ad30ad3 +#else +#define CONFIG_SYS_MDCNFG_VAL 0x88000ad3 +#endif #define CONFIG_SYS_MDREFR_VAL 0x201fe01e #define CONFIG_SYS_MDMRS_VAL 0x00000000 #define CONFIG_SYS_FLYCNFG_VAL 0x00000000 @@ -306,13 +323,13 @@ * LCD */ #ifdef CONFIG_LCD -#define CONFIG_VOIPAC_LCD +#define CONFIG_VOIPAC_LCD #endif
/* * USB */ -#ifdef CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_BOARD_INIT
The following hardware is currently supported: - UART - USB Host - FPGA
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 1 + board/balloon3/Makefile | 49 +++++++ board/balloon3/balloon3.c | 227 +++++++++++++++++++++++++++++++++ board/balloon3/config.mk | 1 + board/balloon3/lowlevel_init.S | 36 ++++++ board/balloon3/u-boot.lds | 55 ++++++++ boards.cfg | 1 + include/configs/balloon3.h | 270 ++++++++++++++++++++++++++++++++++++++++ 8 files changed, 640 insertions(+), 0 deletions(-) create mode 100644 board/balloon3/Makefile create mode 100644 board/balloon3/balloon3.c create mode 100644 board/balloon3/config.mk create mode 100644 board/balloon3/lowlevel_init.S create mode 100644 board/balloon3/u-boot.lds create mode 100644 include/configs/balloon3.h
diff --git a/MAKEALL b/MAKEALL index 52472de..9d149e2 100755 --- a/MAKEALL +++ b/MAKEALL @@ -706,6 +706,7 @@ LIST_at91=" \ #########################################################################
LIST_pxa=" \ + balloon3 \ cerf250 \ colibri_pxa270 \ cradle \ diff --git a/board/balloon3/Makefile b/board/balloon3/Makefile new file mode 100644 index 0000000..3928e1f --- /dev/null +++ b/board/balloon3/Makefile @@ -0,0 +1,49 @@ +# +# Balloon3 Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := balloon3.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c new file mode 100644 index 0000000..1ab06d9 --- /dev/null +++ b/board/balloon3/balloon3.c @@ -0,0 +1,227 @@ +/* + * Balloon3 Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <serial.h> +#include <asm/io.h> +#include <spartan3.h> +#include <command.h> + +DECLARE_GLOBAL_DATA_PTR; + +void balloon3_init_fpga(void); + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init (void) +{ + /* memory and cpu-speed are setup before relocation */ + /* so we do _nothing_ here */ + + /* arch number of vpac270 */ + gd->bd->bi_arch_number = MACH_TYPE_BALLOON3; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Init the FPGA */ + balloon3_init_fpga(); + + return 0; +} + +struct serial_device *default_serial_console (void) +{ + return &serial_stuart_device; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; + + return 0; +} + +#ifdef CONFIG_CMD_USB +int usb_board_init(void) +{ + UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + + UHCHR |= UHCHR_FSBIR; + + while (UHCHR & UHCHR_FSBIR); + + UHCHR &= ~UHCHR_SSE; + UHCHIE = (UHCHIE_UPRIE | UHCHIE_RWIE); + + /* Clear any OTG Pin Hold */ + if (PSSR & PSSR_OTGPH) + PSSR |= PSSR_OTGPH; + + UHCRHDA &= ~(0x200); + UHCRHDA |= 0x100; + + /* Set port power control mask bits, only 3 ports. */ + UHCRHDB |= (0x7<<17); + + /* enable port 2 */ + UP2OCR |= UP2OCR_HXOE | UP2OCR_HXS | UP2OCR_DMPDE | UP2OCR_DPPDE; + + return 0; +} + +void usb_board_init_fail(void) +{ + return; +} + +void usb_board_stop(void) +{ + UHCHR |= UHCHR_FHR; + udelay(11); + UHCHR &= ~UHCHR_FHR; + + UHCCOMS |= 1; + udelay(10); + + CKEN &= ~CKEN10_USBHOST; + + return; +} +#endif + +#if defined(CONFIG_FPGA) +/* Toggle GPIO103 and GPIO104 -- PROGB and RDnWR */ +int fpga_pgm_fn(int nassert, int nflush, int cookie) +{ + if (nassert) + GPCR3 = 0x80; + else + GPSR3 = 0x80; + if (nflush) + GPCR3 = 0x100; + else + GPSR3 = 0x100; + return nassert; +} + +/* Check GPIO83 -- INITB */ +int fpga_init_fn(int cookie) +{ + return !(GPLR2 & 0x80000); +} + +/* Check GPIO84 -- BUSY */ +int fpga_busy_fn(int cookie) +{ + return !(GPLR2 & 0x100000); +} + +/* Check GPIO111 -- DONE */ +int fpga_done_fn(int cookie) +{ + return GPLR3 & 0x8000; +} + +/* Configure GPIO104 as GPIO and deassert it */ +int fpga_pre_config_fn(int cookie) +{ + GAFR3_L &= ~0x30000; + GPCR3 = 0x100; + return 0; +} + +/* Configure GPIO104 as nSKTSEL */ +int fpga_post_config_fn(int cookie) +{ + GAFR3_L |= 0x10000; + return 0; +} + +/* Toggle RDnWR */ +int fpga_wr_fn(int nassert_write, int flush, int cookie) +{ + udelay(1000); + + if (nassert_write) + GPCR3 = 0x100; + else + GPSR3 = 0x100; + + return nassert_write; +} + +/* Write program to the FPGA */ +int fpga_wdata_fn(uchar data, int flush, int cookie) +{ + writeb(data, 0x10f00000); + return 0; +} + +/* Toggle Clock pin -- NO-OP */ +int fpga_clk_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +/* Toggle ChipSelect pin -- NO-OP */ +int fpga_cs_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +Xilinx_Spartan3_Slave_Parallel_fns balloon3_fpga_fns = { + fpga_pre_config_fn, + fpga_pgm_fn, + fpga_init_fn, + NULL, /* err */ + fpga_done_fn, + fpga_clk_fn, + fpga_cs_fn, + fpga_wr_fn, + NULL, /* rdata */ + fpga_wdata_fn, + fpga_busy_fn, + NULL, /* abort */ + fpga_post_config_fn, +}; + +Xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, (void *)&balloon3_fpga_fns, 0); + +/* Initialize the FPGA */ +void balloon3_init_fpga(void) +{ + fpga_init(); + fpga_add (fpga_xilinx, &fpga); +} +#else +void balloon3_init_fpga(void) {} +#endif /* CONFIG_FPGA */ diff --git a/board/balloon3/config.mk b/board/balloon3/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/balloon3/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/balloon3/lowlevel_init.S b/board/balloon3/lowlevel_init.S new file mode 100644 index 0000000..d7b5be6 --- /dev/null +++ b/board/balloon3/lowlevel_init.S @@ -0,0 +1,36 @@ +/* + * Balloon3 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/balloon3/u-boot.lds b/board/balloon3/u-boot.lds new file mode 100644 index 0000000..58c371d --- /dev/null +++ b/board/balloon3/u-boot.lds @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index b5ee531..04ca7de 100644 --- a/boards.cfg +++ b/boards.cfg @@ -51,6 +51,7 @@ actux2 arm ixp actux3 arm ixp actux4 arm ixp ixdp425 arm ixp +balloon3 arm pxa cerf250 arm pxa colibri_pxa270 arm pxa cradle arm pxa diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h new file mode 100644 index 0000000..4082768 --- /dev/null +++ b/include/configs/balloon3.h @@ -0,0 +1,270 @@ +/* + * Balloon3 configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_BALLOON3 1 /* Balloon3 board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ + "bootm 0x40000;" +#define CONFIG_BOOTARGS "console=tty0 console=ttyS2,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_STUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_USB +#define CONFIG_CMD_FPGA +#undef CONFIG_LCD + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#else +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#endif +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x290 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 3 /* We have 2 banks of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_2 0xb0000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_3 0x80000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_3_SIZE 0x08000000 /* 128 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x18000000 /* 384 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0xa1000000 + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_ENV_IS_IN_FLASH +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x10000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GPSR0_VAL 0x307dc7fd +#define CONFIG_SYS_GPSR1_VAL 0x03cffa4e +#define CONFIG_SYS_GPSR2_VAL 0x7131c000 +#define CONFIG_SYS_GPSR3_VAL 0x01e1f3ff + +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPCR3_VAL 0x0 + +#define CONFIG_SYS_GPDR0_VAL 0xc0f98e02 +#define CONFIG_SYS_GPDR1_VAL 0xfcffa8b7 +#define CONFIG_SYS_GPDR2_VAL 0x22e3ffff +#define CONFIG_SYS_GPDR3_VAL 0x000201fe + +#define CONFIG_SYS_GAFR0_L_VAL 0x96c00000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5e5459b +#define CONFIG_SYS_GAFR1_L_VAL 0x699b759a +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa5a5aa +#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01f9a6aa +#define CONFIG_SYS_GAFR3_L_VAL 0x54510003 +#define CONFIG_SYS_GAFR3_U_VAL 0x00001599 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0xffffffff +#define CONFIG_SYS_CCCR 0x00000290 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff07ff8 +#define CONFIG_SYS_MSC1_VAL 0x7ff07ff0 +#define CONFIG_SYS_MSC2_VAL 0x74a42491 +#define CONFIG_SYS_MDCNFG_VAL 0x89d309d3 +#define CONFIG_SYS_MDREFR_VAL 0x001d8018 +#define CONFIG_SYS_MDMRS_VAL 0x00220022 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 +#define CONFIG_SYS_MEM_BUF_IMP 0x0f + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MCMEM1_VAL 0x00014307 +#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT1_VAL 0x0001c787 +#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO1_VAL 0x0001430f + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_BALLOON3LCD +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * USB + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_BOARD_INIT +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x4C000000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "balloon3" +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#endif + +/* + * FPGA + */ +#ifdef CONFIG_CMD_FPGA +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 +#define CONFIG_MAX_FPGA_DEVICES 1 +#endif + +#endif /* __CONFIG_H */
Dear Marek Vasut,
In message 1281415810-31363-8-git-send-email-marek.vasut@gmail.com you wrote:
- UART
- USB Host
- FPGA
MAINTAINERS entry missing.
- /* memory and cpu-speed are setup before relocation */
- /* so we do _nothing_ here */
Nothing? This comment is wrong.
- gd->bd->bi_arch_number = MACH_TYPE_BALLOON3;
- /* adress of boot parameters */
- gd->bd->bi_boot_params = 0xa0000100;
- /* Init the FPGA */
- balloon3_init_fpga();
This is definitely more than nothing.
- UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) &
- UHCHR |= UHCHR_FSBIR;
Please use I/O accessors to access device registers. Please fix globally.
- while (UHCHR & UHCHR_FSBIR);
The semicolon goes to the next line.
Line too long. Please fix globally.
I stop reviewing here. Please check the other patches for similar issues, and fix these as well. Please also re-read the review comments for the first patch series.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 4b91b0f..f782f64 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -815,6 +815,15 @@ Alex Z lart SA1100 dnp1110 SA1110
+Marek Vasut marek.vasut@gmail.com + + balloon3 xscale + colibri_pxa270 xscale + palmld xscale + palmtc xscale + vpac270 xscale + zipitz2 xscale + -------------------------------------------------------------------------
Unknown / orphaned boards:
Dear Marek Vasut,
In message 1281415810-31363-9-git-send-email-marek.vasut@gmail.com you wrote:
Please keep the list sorted. "V" goes before "Z".
- balloon3 xscale
- colibri_pxa270 xscale
- palmld xscale
- palmtc xscale
- vpac270 xscale
- zipitz2 xscale
NAK!!
These changes should be squashed into the commits that add the board support. OK, colibri_pxa270, vpac270 and zipitz2 these affect boards already present. But the other ones must be merged into the respective commits.
Dear Marek Vasut,
In message 1281415810-31363-1-git-send-email-marek.vasut@gmail.com you wrote:
These functions are undefined on ARM when using __io. These are the commonly used versions and can be redefined.
arch/arm/include/asm/io.h | 46 +++++++++++++++++++++++++++++++++++++++----- 1 files changed, 40 insertions(+), 6 deletions(-)
Why are you submitting this? This patch has been pulled into mainline on Thu Jul 22 already.
If there should be anything wrong with these, please submit an incremental patch.
Dne Út 10. srpna 2010 23:38:25 Wolfgang Denk napsal(a):
Dear Marek Vasut,
Sorry, ignore this please.
