[U-Boot] [PATCH v2] efi_loader: Check machine type in the image header
Check FileHeader.Machine to make sure the EFI executable image is built for the same architecture. For example, 32-bit U-Boot on x86 will print an error message instead of loading an x86_64 image and crashing.
Signed-off-by: Ivan Gorinov ivan.gorinov@intel.com --- include/pe.h | 24 ++++++++++++++++++++++++ lib/efi_loader/efi_image_loader.c | 24 ++++++++++++------------ 2 files changed, 36 insertions(+), 12 deletions(-)
diff --git a/include/pe.h b/include/pe.h index c3a19ce..0dc33f0 100644 --- a/include/pe.h +++ b/include/pe.h @@ -38,11 +38,35 @@ typedef struct _IMAGE_DOS_HEADER { #define IMAGE_DOS_SIGNATURE 0x5A4D /* MZ */ #define IMAGE_NT_SIGNATURE 0x00004550 /* PE00 */
+#define IMAGE_FILE_MACHINE_I386 0x014c #define IMAGE_FILE_MACHINE_ARM 0x01c0 #define IMAGE_FILE_MACHINE_THUMB 0x01c2 #define IMAGE_FILE_MACHINE_ARMNT 0x01c4 #define IMAGE_FILE_MACHINE_AMD64 0x8664 #define IMAGE_FILE_MACHINE_ARM64 0xaa64 +#define IMAGE_FILE_MACHINE_RISCV32 0x5032 +#define IMAGE_FILE_MACHINE_RISCV64 0x5064 + +#if defined(CONFIG_ARM64) +#define TARGET_PE_MACHINE_TYPE IMAGE_FILE_MACHINE_ARM64 +#elif defined(CONFIG_ARM) +#define TARGET_PE_MACHINE_TYPE IMAGE_FILE_MACHINE_THUMB +#endif + +#if defined(CONFIG_X86_64) +#define TARGET_PE_MACHINE_TYPE IMAGE_FILE_MACHINE_AMD64 +#elif defined(CONFIG_X86) +#define TARGET_PE_MACHINE_TYPE IMAGE_FILE_MACHINE_I386 +#endif + +#if defined(CONFIG_CPU_RISCV_32) +#define TARGET_PE_MACHINE_TYPE IMAGE_FILE_MACHINE_RISCV32 +#endif + +#if defined(CONFIG_CPU_RISCV_64) +#define TARGET_PE_MACHINE_TYPE IMAGE_FILE_MACHINE_RISCV64 +#endif + #define IMAGE_NT_OPTIONAL_HDR32_MAGIC 0x10b #define IMAGE_NT_OPTIONAL_HDR64_MAGIC 0x20b #define IMAGE_SUBSYSTEM_EFI_APPLICATION 10 diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index f588576..ac20488 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -172,14 +172,6 @@ void *efi_load_pe(void *efi, struct efi_loaded_image *loaded_image_info) void *entry; uint64_t image_size; unsigned long virt_size = 0; - bool can_run_nt64 = true; - bool can_run_nt32 = true; - -#if defined(CONFIG_ARM64) - can_run_nt32 = false; -#elif defined(CONFIG_ARM) - can_run_nt64 = false; -#endif
dos = efi; if (dos->e_magic != IMAGE_DOS_SIGNATURE) { @@ -193,6 +185,16 @@ void *efi_load_pe(void *efi, struct efi_loaded_image *loaded_image_info) return NULL; }
+#ifdef TARGET_PE_MACHINE_TYPE + + if (nt->FileHeader.Machine != TARGET_PE_MACHINE_TYPE) { + printf("%s: Machine type 0x%04x is not supported\n", + __func__, nt->FileHeader.Machine); + return NULL; + } + +#endif + /* Calculate upper virtual address boundary */ num_sections = nt->FileHeader.NumberOfSections; sections = (void *)&nt->OptionalHeader + @@ -205,8 +207,7 @@ void *efi_load_pe(void *efi, struct efi_loaded_image *loaded_image_info) }
/* Read 32/64bit specific header bits */ - if (can_run_nt64 && - (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR64_MAGIC)) { + if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR64_MAGIC) { IMAGE_NT_HEADERS64 *nt64 = (void *)nt; IMAGE_OPTIONAL_HEADER64 *opt = &nt64->OptionalHeader; image_size = opt->SizeOfImage; @@ -222,8 +223,7 @@ void *efi_load_pe(void *efi, struct efi_loaded_image *loaded_image_info) rel_size = opt->DataDirectory[rel_idx].Size; rel = efi_reloc + opt->DataDirectory[rel_idx].VirtualAddress; virt_size = ALIGN(virt_size, opt->SectionAlignment); - } else if (can_run_nt32 && - (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR32_MAGIC)) { + } else if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR32_MAGIC) { IMAGE_OPTIONAL_HEADER32 *opt = &nt->OptionalHeader; image_size = opt->SizeOfImage; efi_set_code_and_data_type(loaded_image_info, opt->Subsystem);
Are you sure we always have thumb as machine type here? Aren't we compatible with either ARM or THUMB?
-#endif
I don't think we should have the #ifdef here. Let' make sure we always know which platform we want to run on.
Alex
- if (nt->FileHeader.Machine != TARGET_PE_MACHINE_TYPE) {
return NULL;
- /* Calculate upper virtual address boundary */ num_sections = nt->FileHeader.NumberOfSections; sections = (void *)&nt->OptionalHeader +
- if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR64_MAGIC) { IMAGE_NT_HEADERS64 *nt64 = (void *)nt; IMAGE_OPTIONAL_HEADER64 *opt = &nt64->OptionalHeader; image_size = opt->SizeOfImage;
- } else if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR32_MAGIC) { IMAGE_OPTIONAL_HEADER32 *opt = &nt->OptionalHeader; image_size = opt->SizeOfImage; efi_set_code_and_data_type(loaded_image_info, opt->Subsystem);
The value 0x01c2 means ARM or THUMB It is used by Linux, GRUB, iPXE.
Regards
Heinrich
-#endif
Alex
return NULL;
I'm not sure that's fully accurate. ARM means some old legacy one, but ARMNT and THUMB can both be used, no?
https://www.npmjs.com/package/binarycpu
What I'm trying to say is that a 1:1 matching might not be the only thing we want.
Alex
Revision 8.3 – February 6th, 2013 of the PECOFF spec is the most explicit:
IMAGE_FILE_MACHINE_ARMNT 0x1c4 ARMv7 (or higher) Thumb mode only IMAGE_FILE_MACHINE_THUMB 0x1c2 ARM or Thumb (“interworking”)
EDK2 has only these values (with some names not matching the standard):
IMAGE_FILE_MACHINE_I386 0x014c IMAGE_FILE_MACHINE_IA64 0x0200 IMAGE_FILE_MACHINE_EBC 0x0EBC IMAGE_FILE_MACHINE_X64 0x8664 IMAGE_FILE_MACHINE_ARMTHUMB_MIXED 0x01c2 IMAGE_FILE_MACHINE_ARM64 0xAA64
On ARM only IMAGE_FILE_MACHINE_ARMTHUMB_MIXED and IMAGE_FILE_MACHINE_ARMTHUMB_MIXED are IMAGE_FILE_MACHINE_EBC are supported. But we do not support IMAGE_FILE_MACHINE_EBC.
So EDK2 would not be able load a 0x01c4 ARM binary.
Best regards
Heinrich
Ok, so let's leave it at one target for now. If later on someone wants to enable thumb only mode for example, they'll have to come up with a way to identify it more smartly.
Alex
Alexander Graf
Ivan Gorinov
