[U-Boot] [PATCH] EXYNOS: PINMUX: modify the gpio function value for mmc
In Exynos5, if used 8-bit busmode, set the gpio configuration to GPIO_FUNC(0x2).
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/cpu/armv7/exynos/pinmux.c | 20 +++++++++++--------- 1 files changed, 11 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index d2b7d2c..356cf8d 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -66,12 +66,14 @@ static int exynos5_mmc_config(int peripheral, int flags) struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); struct s5p_gpio_bank *bank, *bank_ext; - int i; + int i, gpio_func, gpio_start;
switch (peripheral) { case PERIPH_ID_SDMMC0: bank = &gpio1->c0; bank_ext = &gpio1->c1; + gpio_func = GPIO_FUNC(0x2); + gpio_start = 0; break; case PERIPH_ID_SDMMC1: bank = &gpio1->c1; @@ -80,6 +82,8 @@ static int exynos5_mmc_config(int peripheral, int flags) case PERIPH_ID_SDMMC2: bank = &gpio1->c2; bank_ext = &gpio1->c3; + gpio_func = GPIO_FUNC(0x3); + gpio_start = 3; break; case PERIPH_ID_SDMMC3: bank = &gpio1->c3; @@ -92,18 +96,16 @@ static int exynos5_mmc_config(int peripheral, int flags) return -1; } if (flags & PINMUX_FLAG_8BIT_MODE) { - for (i = 3; i <= 6; i++) { - s5p_gpio_cfg_pin(bank_ext, i, GPIO_FUNC(0x3)); + for (i = gpio_start; i <= gpio_start + 3; i++) { + s5p_gpio_cfg_pin(bank_ext, i, gpio_func); s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_UP); s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); } } - for (i = 0; i < 2; i++) { - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); - } - for (i = 3; i <= 6; i++) { + + for (i = 0; i <= 6; i++) { + if (i == 2) + continue; s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); s5p_gpio_set_pull(bank, i, GPIO_PULL_UP); s5p_gpio_set_drv(bank, i, GPIO_DRV_4X);
Hi Jaehoon Chung,
Had few comments...
Is this changes for EVT1 board? As per the EVT1 Manual I have it is: MMC0: Correct as per your changes. MMC1: Bank C2 - 4 bit: func - 0x2 MMC2: Bank C3 - 4 bit: func - 0x2, You have made it 8 bit. (EVT0 the manual I have it says func 0x2) MMC3 not there.
On Wed, Jun 20, 2012 at 10:31 AM, Jaehoon Chung jh80.chung@samsung.com wrote:
- int i;
- int i, gpio_func, gpio_start;
- gpio_func = GPIO_FUNC(0x2);
- gpio_start = 0;
- gpio_func = GPIO_FUNC(0x3);
- gpio_start = 3;
- for (i = gpio_start; i <= gpio_start + 3; i++) {
- s5p_gpio_cfg_pin(bank_ext, i, gpio_func);
- for (i = 0; i <= 6; i++) {
- if (i == 2)
- continue;
--- Do we have to pull up for CMD, and CLK gpio ? -- CD line not set?
s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Rajeshwari,
I just considered the EVT1 board. I will resend the patch for this.
Best Regards, Jaehoon Chung
On 06/20/2012 02:55 PM, Rajeshwari Birje wrote:
Hi Jaehoon Chung,
Had few comments...
int i;
int i, gpio_func, gpio_start; switch (peripheral) { case PERIPH_ID_SDMMC0: bank = &gpio1->c0; bank_ext = &gpio1->c1;
if (i == 2)
Jaehoon Chung
Rajeshwari Birje
