[U-Boot] [PATCH] sf: probe: Add support to set Quad enable bit for ISSI
Added support to set the quad enable bit in status register for ISSI parts. Tis would be same as for Macronix parts.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- - This patch is based on u-boot-spi/master --- drivers/mtd/spi/sf_internal.h | 1 + drivers/mtd/spi/sf_probe.c | 5 +++-- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 9c95d56..a995d9b 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -60,6 +60,7 @@ enum { #define SPI_FLASH_CFI_MFR_STMICRO 0x20 #define SPI_FLASH_CFI_MFR_MACRONIX 0xc2 #define SPI_FLASH_CFI_MFR_WINBOND 0xef +#define SPI_FLASH_CFI_MFR_ISSI 0x9d
/* Erase commands */ #define CMD_ERASE_4K 0x20 diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 954376d..b4f8a33 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -32,7 +32,7 @@ static u8 spi_read_cmds_array[] = { CMD_READ_QUAD_IO_FAST, };
-#ifdef CONFIG_SPI_FLASH_MACRONIX +#if defined(CONFIG_SPI_FLASH_MACRONIX) || defined(CONFIG_SPI_FLASH_ISSI) static int spi_flash_set_qeb_mxic(struct spi_flash *flash) { u8 qeb_status; @@ -79,8 +79,9 @@ static int spi_flash_set_qeb_winspan(struct spi_flash *flash) static int spi_flash_set_qeb(struct spi_flash *flash, u8 idcode0) { switch (idcode0) { -#ifdef CONFIG_SPI_FLASH_MACRONIX +#if defined(CONFIG_SPI_FLASH_MACRONIX) || defined(CONFIG_SPI_FLASH_ISSI) case SPI_FLASH_CFI_MFR_MACRONIX: + case SPI_FLASH_CFI_MFR_ISSI: return spi_flash_set_qeb_mxic(flash); #endif #if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND)
