[U-Boot] [PATCH v2] regulator: fixed: Modify enable-active-high behavior
Regulator should not be enabled at probe time if regulator-boot-on property is not in the dt node.
"enable-active-high" property is only used to indicate the GPIO polarity.
See kernel documentation : - Documentation/devicetree/bindings/regulator/fixed-regulator.yaml - Documentation/devicetree/bindings/regulator/gpio-regulator.yaml
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Changes in v2: - fix build issue
drivers/power/regulator/regulator_common.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/power/regulator/regulator_common.c b/drivers/power/regulator/regulator_common.c index 3dabbe2a85..2041086567 100644 --- a/drivers/power/regulator/regulator_common.c +++ b/drivers/power/regulator/regulator_common.c @@ -12,10 +12,15 @@ int regulator_common_ofdata_to_platdata(struct udevice *dev, struct regulator_common_platdata *dev_pdata, const char *enable_gpio_name) { struct gpio_desc *gpio; + struct dm_regulator_uclass_platdata *uc_pdata; int flags = GPIOD_IS_OUT; int ret;
- if (dev_read_bool(dev, "enable-active-high")) + uc_pdata = dev_get_uclass_platdata(dev); + + if (!dev_read_bool(dev, "enable-active-high")) + flags |= GPIOD_ACTIVE_LOW; + if (uc_pdata->boot_on) flags |= GPIOD_IS_OUT_ACTIVE;
/* Get optional enable GPIO desc */
It's a gentle reminder to not forgot this patch.
Thanks
Patrice
Changes in v2:
- fix build issue
- struct dm_regulator_uclass_platdata *uc_pdata; int flags = GPIOD_IS_OUT; int ret;
Patrice CHOTARD
Patrice Chotard
