[PATCH] azure: Add -E back for the world build script
Commit dd5c954e917b ("travis/gitlab/azure: Use -W to avoid warnings check") added -W to avoid warnings check, but it mistakenly dropped -E for the world build script in the azure pipelines.
This caused builds on the azure pipelines fail to report warnings. Let's add it back.
Fixes: dd5c954e917b ("travis/gitlab/azure: Use -W to avoid warnings check") Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
.azure-pipelines.yml | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 7a3eb78a5e..a6279427e1 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -458,7 +458,7 @@ jobs: cat << "EOF" >> build.sh if [[ "${BUILDMAN}" != "" ]]; then ret=0; - tools/buildman/buildman -o /tmp -P -W ${BUILDMAN} ${OVERRIDE} || ret=$?; + tools/buildman/buildman -o /tmp -P -E -W ${BUILDMAN} ${OVERRIDE} || ret=$?; if [[ $ret -ne 0 ]]; then tools/buildman/buildman -o /tmp -seP ${BUILDMAN}; exit $ret;
Fixes: dd5c954e917b ("travis/gitlab/azure: Use -W to avoid warnings check") Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
Bin Meng
