[U-Boot] [PATCH] config: remove platform CONFIG_SYS_HZ definition part 3
This commit removes platform CONFIG_SYS_HZ definition for the remainders of part1 (commit cdb23792) and part2 (commit f232950f).
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Rob Herring rob.herring@calxeda.com --- board/fads/fads.h | 2 -- include/configs/T1040QDS.h | 1 - include/configs/T1040RDB.h | 1 - include/configs/T1042RDB_PI.h | 1 - include/configs/T2080QDS.h | 1 - include/configs/apf27.h | 5 ----- include/configs/balloon3.h | 1 - include/configs/corvus.h | 1 - include/configs/hummingboard.h | 1 - include/configs/koelsch.h | 1 - include/configs/lager.h | 1 - include/configs/palmld.h | 1 - include/configs/palmtc.h | 1 - include/configs/scb9328.h | 1 - include/configs/taurus.h | 1 - include/configs/udoo.h | 1 - include/configs/usb_a9263.h | 1 - include/configs/zipitz2.h | 1 - 18 files changed, 23 deletions(-)
diff --git a/board/fads/fads.h b/board/fads/fads.h index cf6c928..fa49080 100644 --- a/board/fads/fads.h +++ b/board/fads/fads.h @@ -127,8 +127,6 @@
#define CONFIG_SYS_LOAD_ADDR 0x00100000
-#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ - /* * Low Level Configuration Settings * (address mappings, register initial values, etc.) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 8234a82..bf82c3e 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -670,7 +670,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/
/* * For booting Linux, the board info and command line data diff --git a/include/configs/T1040RDB.h b/include/configs/T1040RDB.h index 5e988c2..998abe3 100644 --- a/include/configs/T1040RDB.h +++ b/include/configs/T1040RDB.h @@ -596,7 +596,6 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/
/* * For booting Linux, the board info and command line data diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h index aafa813..6804a8d 100644 --- a/include/configs/T1042RDB_PI.h +++ b/include/configs/T1042RDB_PI.h @@ -600,7 +600,6 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/
/* * For booting Linux, the board info and command line data diff --git a/include/configs/T2080QDS.h b/include/configs/T2080QDS.h index 9bd0fe2..9448ec8 100644 --- a/include/configs/T2080QDS.h +++ b/include/configs/T2080QDS.h @@ -680,7 +680,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/
/* * For booting Linux, the board info and command line data diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 1193013..b10c48c 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -356,11 +356,6 @@ #endif /* CONFIG_CMD_DATE */
/* - * Clocks - */ -#define CONFIG_SYS_HZ 1000 /* Ticks per second */ - -/* * PLL * * 31 | x |x| x x x x |x x x x x x x x x x |x x|x x x x|x x x x x x x x x x| 0 diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index b41a823..5228ba6 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -84,7 +84,6 @@ * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */
/* diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 11ba4cf..959e188 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -33,7 +33,6 @@ /* ARM asynchronous clock */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ -#define CONFIG_SYS_HZ 1000
#define CONFIG_AT91FAMILY
diff --git a/include/configs/hummingboard.h b/include/configs/hummingboard.h index 4055af5..d36d16e 100644 --- a/include/configs/hummingboard.h +++ b/include/configs/hummingboard.h @@ -190,7 +190,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR -#define CONFIG_SYS_HZ 1000
#define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index cc3c7a8..964d0dc 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -171,7 +171,6 @@ #define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ #define CONFIG_SH_SCIF_CLK_FREQ 14745600 #define CONFIG_SYS_TMU_CLK_DIV 4 -#define CONFIG_SYS_HZ 1000
/* i2c */ #define CONFIG_CMD_I2C diff --git a/include/configs/lager.h b/include/configs/lager.h index b6c1954..32a2655 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -196,6 +196,5 @@ #define CONFIG_SH_SCIF_CLK_FREQ CONFIG_MP_CLK_FREQ
#endif /* __LAGER_H */ diff --git a/include/configs/palmld.h b/include/configs/palmld.h index 2a9fd22..9480d8d 100644 --- a/include/configs/palmld.h +++ b/include/configs/palmld.h @@ -115,7 +115,6 @@ * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x210 /* 416MHz ; N=2,L=16 */
/* diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h index de25407..8abce1b 100644 --- a/include/configs/palmtc.h +++ b/include/configs/palmtc.h @@ -117,7 +117,6 @@ * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x161 /* 400MHz;L=1 M=3 T=1 */
/* diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index c0048ac..e6d272d 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_MEMTEST_START 0x08100000 /* memtest test area */ #define CONFIG_SYS_MEMTEST_END 0x08F00000
-#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x141 /* core clock - register value */
#define CONFIG_BAUDRATE 115200 diff --git a/include/configs/taurus.h b/include/configs/taurus.h index c980023..20d4cee 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -37,7 +37,6 @@ /* ARM asynchronous clock */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* main clock xtal */ -#define CONFIG_SYS_HZ 1000
/* Misc CPU related */ #define CONFIG_ARCH_CPU_INIT diff --git a/include/configs/udoo.h b/include/configs/udoo.h index 614e1fe..28e20b9 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -199,7 +199,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index c4d04de..3c54870 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -20,7 +20,6 @@ /* ARM asynchronous clock */ #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 -#define CONFIG_SYS_HZ 1000
#define CONFIG_MACH_TYPE MACH_TYPE_USB_A9263
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index e38fa89..41a7c99 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -138,7 +138,6 @@ unsigned char zipitz2_spi_read(void); * Clock Configuration */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */
Masahiro Yamada
