[U-Boot] [PATCH v3] fsl/pci: Add workaround for erratum A-005434
By default, all PEX inbound windows PEX_PEXIWARn[TRGT] are mapped to 0xF, which is local memory. But for BSC9132, 0xF is CCSR, 0x0 is local memory.
Signed-off-by: Minghuan Lian Minghuan.Lian@freescale.com Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/include/asm/config_mpc85xx.h | 1 + drivers/pci/fsl_pci_init.c | 9 +++++++-- 3 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 8b79c05..4bf5bc7 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -277,6 +277,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (has_erratum_a006261()) puts("Work-around for Erratum A006261 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A005434 + puts("Work-around for Erratum A-005434 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index df44451..94c769d 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -583,6 +583,7 @@ #define CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_ERRATUM_A005125 +#define CONFIG_SYS_FSL_ERRATUM_A005434 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x11 #define CONFIG_ESDHC_HC_BLK_ADDR diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 6317fb1..3a41b0e 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -49,8 +49,13 @@ static void set_inbound_window(volatile pit_t *pi, u64 size) { u32 sz = (__ilog2_u64(size) - 1); - u32 flag = PIWAR_EN | PIWAR_LOCAL | - PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP; +#ifdef CONFIG_SYS_FSL_ERRATUM_A005434 + u32 flag = 0; +#else + u32 flag = PIWAR_LOCAL; +#endif + + flag |= PIWAR_EN | PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP;
out_be32(&pi->pitar, r->phys_start >> 12); out_be32(&pi->piwbar, r->bus_start >> 12);
Applied to u-boot-mpc85xx/master.
York
Chunhe Lan
York Sun
