[PATCH 0/2] imx: Add i.MX93 9x9 QSB board
The i.MX 93 quick start evaluation kit provides a low-cost platform to evaluate the i.MX 93 applications processors in a 9x9mm package.
Patch 1 is to add a new pll entry for 3200MTS Patch 2 is to add the board support.
Patchset is based on imx/next tag:u-boot-imx-next-20241005
Signed-off-by: Peng Fan peng.fan@nxp.com --- Peng Fan (2): imx9: clock: Add 800MHz fracpll entry imx: Support i.MX93 9X9 QSB board
arch/arm/dts/imx93-9x9-qsb-u-boot.dtsi | 163 ++ arch/arm/mach-imx/imx9/Kconfig | 8 + arch/arm/mach-imx/imx9/clock.c | 1 + board/freescale/imx93_qsb/Kconfig | 12 + board/freescale/imx93_qsb/MAINTAINERS | 7 + board/freescale/imx93_qsb/Makefile | 16 + board/freescale/imx93_qsb/imx93_qsb.c | 67 + board/freescale/imx93_qsb/lpddr4_timing.c | 1995 +++++++++++++++++++++++++ board/freescale/imx93_qsb/lpddr4_timing_ecc.c | 1995 +++++++++++++++++++++++++ board/freescale/imx93_qsb/spl.c | 174 +++ configs/imx93_9x9_qsb_defconfig | 139 ++ configs/imx93_9x9_qsb_inline_ecc_defconfig | 140 ++ doc/board/nxp/imx93_9x9_qsb.rst | 68 + doc/board/nxp/index.rst | 1 + drivers/ddr/imx/imx9/Kconfig | 6 + include/configs/imx93_qsb.h | 138 ++ 16 files changed, 4930 insertions(+) --- base-commit: ef815d75514da91dd98f9e3278d810439fd1f1ea change-id: 20241009-imx93qsb-d0d769ade9f8
Add 800MHz fracpll entry to support DDR 3200MTS.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx9/clock.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-imx/imx9/clock.c b/arch/arm/mach-imx/imx9/clock.c index 12685f970de..e42ad263d63 100644 --- a/arch/arm/mach-imx/imx9/clock.c +++ b/arch/arm/mach-imx/imx9/clock.c @@ -35,6 +35,7 @@ static struct imx_intpll_rate_table imx9_intpll_tbl[] = { static struct imx_fracpll_rate_table imx9_fracpll_tbl[] = { FRAC_PLL_RATE(1000000000U, 1, 166, 4, 2, 3), /* 1000Mhz */ FRAC_PLL_RATE(933000000U, 1, 155, 4, 1, 2), /* 933Mhz */ + FRAC_PLL_RATE(800000000U, 1, 200, 6, 0, 1), /* 800Mhz */ FRAC_PLL_RATE(700000000U, 1, 145, 5, 5, 6), /* 700Mhz */ FRAC_PLL_RATE(484000000U, 1, 121, 6, 0, 1), FRAC_PLL_RATE(445333333U, 1, 167, 9, 0, 1),
Add i.MX93 9x9 Quick Start Board support. - Two ddr scripts included w/o inline ecc feature. - SDHC/NETWORK/I2C/UART supported - PCA9450 supported, default over drive mode - Documentation added.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx93-9x9-qsb-u-boot.dtsi | 163 ++ arch/arm/mach-imx/imx9/Kconfig | 8 + board/freescale/imx93_qsb/Kconfig | 12 + board/freescale/imx93_qsb/MAINTAINERS | 7 + board/freescale/imx93_qsb/Makefile | 16 + board/freescale/imx93_qsb/imx93_qsb.c | 67 + board/freescale/imx93_qsb/lpddr4_timing.c | 1995 +++++++++++++++++++++++++ board/freescale/imx93_qsb/lpddr4_timing_ecc.c | 1995 +++++++++++++++++++++++++ board/freescale/imx93_qsb/spl.c | 174 +++ configs/imx93_9x9_qsb_defconfig | 139 ++ configs/imx93_9x9_qsb_inline_ecc_defconfig | 140 ++ doc/board/nxp/imx93_9x9_qsb.rst | 68 + doc/board/nxp/index.rst | 1 + drivers/ddr/imx/imx9/Kconfig | 6 + include/configs/imx93_qsb.h | 138 ++ 15 files changed, 4929 insertions(+)
diff --git a/arch/arm/dts/imx93-9x9-qsb-u-boot.dtsi b/arch/arm/dts/imx93-9x9-qsb-u-boot.dtsi new file mode 100644 index 00000000000..0dd55f01875 --- /dev/null +++ b/arch/arm/dts/imx93-9x9-qsb-u-boot.dtsi @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 NXP + */ + +#include "imx93-u-boot.dtsi" + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog3>; + bootph-pre-ram; + bootph-some-ram; + }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +}; + +&{/soc@0} { + bootph-all; + bootph-pre-ram; +}; + +&aips1 { + bootph-pre-ram; + bootph-all; +}; + +&aips2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&aips3 { + bootph-pre-ram; + bootph-some-ram; +}; + +&iomuxc { + bootph-pre-ram; + bootph-some-ram; +}; + +®_usdhc2_vmmc { + u-boot,off-on-delay-us = <20000>; + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_reg_usdhc2_vmmc { + bootph-pre-ram; +}; + +&pinctrl_uart1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_usdhc2_gpio { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_usdhc2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio3 { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio4 { + bootph-pre-ram; + bootph-some-ram; +}; + +&lpuart1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&usdhc1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&usdhc2 { + bootph-pre-ram; + bootph-some-ram; + fsl,signal-voltage-switch-extra-delay-ms = <8>; +}; + +&lpi2c2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&{/soc@0/bus@44000000/i2c@44350000/pmic@25} { + bootph-pre-ram; + bootph-some-ram; +}; + +&{/soc@0/bus@44000000/i2c@44350000/pmic@25/regulators} { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_lpi2c2 { + bootph-pre-ram; + bootph-some-ram; +}; + +ðphy1 { + reset-gpios = <&pcal6524 15 GPIO_ACTIVE_LOW>; + reset-assert-us = <15000>; + reset-deassert-us = <100000>; +}; + +&s4muap { + bootph-pre-ram; + bootph-some-ram; + status = "okay"; +}; + +&clk { + bootph-all; + bootph-pre-ram; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-rates; + /delete-property/ assigned-clock-parents; +}; + +&osc_32k { + bootph-all; + bootph-pre-ram; +}; + +&osc_24m { + bootph-all; + bootph-pre-ram; +}; + +&clk_ext1 { + bootph-all; + bootph-pre-ram; +}; diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index 4d32c28670d..5c1054138fc 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -23,6 +23,13 @@ choice prompt "NXP i.MX9 board select" optional
+config TARGET_IMX93_9X9_QSB + bool "imx93_qsb" + select OF_BOARD_FIXUP + select IMX93 + select IMX9_LPDDR4X + imply OF_UPSTREAM + config TARGET_IMX93_11X11_EVK bool "imx93_11x11_evk" select OF_BOARD_FIXUP @@ -42,6 +49,7 @@ config TARGET_PHYCORE_IMX93 endchoice
source "board/freescale/imx93_evk/Kconfig" +source "board/freescale/imx93_qsb/Kconfig" source "board/phytec/phycore_imx93/Kconfig" source "board/variscite/imx93_var_som/Kconfig"
diff --git a/board/freescale/imx93_qsb/Kconfig b/board/freescale/imx93_qsb/Kconfig new file mode 100644 index 00000000000..fea69c85870 --- /dev/null +++ b/board/freescale/imx93_qsb/Kconfig @@ -0,0 +1,12 @@ +if TARGET_IMX93_9X9_QSB + +config SYS_BOARD + default "imx93_qsb" + +config SYS_VENDOR + default "freescale" + +config SYS_CONFIG_NAME + default "imx93_qsb" + +endif diff --git a/board/freescale/imx93_qsb/MAINTAINERS b/board/freescale/imx93_qsb/MAINTAINERS new file mode 100644 index 00000000000..a3247d17e7c --- /dev/null +++ b/board/freescale/imx93_qsb/MAINTAINERS @@ -0,0 +1,7 @@ +i.MX93 QSB BOARD +M: Peng Fan peng.fan@nxp.com +S: Maintained +F: board/freescale/imx93_qsb/ +F: include/configs/imx93_qsb.h +F: configs/imx93_9x9_qsb_defconfig +F: configs/imx93_9x9_qsb_inline_ecc_defconfig diff --git a/board/freescale/imx93_qsb/Makefile b/board/freescale/imx93_qsb/Makefile new file mode 100644 index 00000000000..c94a6b2279d --- /dev/null +++ b/board/freescale/imx93_qsb/Makefile @@ -0,0 +1,16 @@ +# +# Copyright 2024 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx93_qsb.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +ifdef CONFIG_IMX9_DRAM_INLINE_ECC +obj-$(CONFIG_TARGET_IMX93_9X9_QSB) += lpddr4_timing_ecc.o +else +obj-$(CONFIG_TARGET_IMX93_9X9_QSB) += lpddr4_timing.o +endif +endif diff --git a/board/freescale/imx93_qsb/imx93_qsb.c b/board/freescale/imx93_qsb/imx93_qsb.c new file mode 100644 index 00000000000..26e0c916c02 --- /dev/null +++ b/board/freescale/imx93_qsb/imx93_qsb.c @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 NXP + */ + +#include <env.h> +#include <init.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/global_data.h> +#include <asm/arch-imx9/ccm_regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch-imx9/imx93_pins.h> +#include <asm/arch/clock.h> +#include <power/pmic.h> +#include <dm/device.h> +#include <dm/uclass.h> +#include <usb.h> +#include <dwc3-uboot.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE(6) | PAD_CTL_FSEL2) +#define WDOG_PAD_CTRL (PAD_CTL_DSE(6) | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static iomux_v3_cfg_t const uart_pads[] = { + MX93_PAD_UART1_RXD__LPUART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX93_PAD_UART1_TXD__LPUART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_init(void) +{ + return 0; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_IS_IN_MMC + board_late_mmc_env_init(); +#endif + + env_set("sec_boot", "no"); +#ifdef CONFIG_AHAB_BOOT + env_set("sec_boot", "yes"); +#endif + +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "9X9_QSB"); + env_set("board_rev", "iMX93"); +#endif + return 0; +} diff --git a/board/freescale/imx93_qsb/lpddr4_timing.c b/board/freescale/imx93_qsb/lpddr4_timing.c new file mode 100644 index 00000000000..c589c165720 --- /dev/null +++ b/board/freescale/imx93_qsb/lpddr4_timing.c @@ -0,0 +1,1995 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright 2024 NXP + * + * Code generated with DDR Tool v3.4.0_8.3-4e2b550a. + * DDR PHY FW2022.01 + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x4e300110, 0x44100001}, + {0x4e300000, 0x8000ff}, + {0x4e300008, 0x0}, + {0x4e300080, 0x80000512}, + {0x4e300084, 0x0}, + {0x4e300114, 0x1002}, + {0x4e300260, 0x80}, + {0x4e300f04, 0x80}, + {0x4e300800, 0x43b30002}, + {0x4e300804, 0x1f1f1f1f}, + {0x4e301000, 0x0}, + {0x4e301240, 0x0}, + {0x4e301244, 0x0}, + {0x4e301248, 0x0}, + {0x4e30124c, 0x0}, + {0x4e301250, 0x0}, + {0x4e301254, 0x0}, + {0x4e301258, 0x0}, + {0x4e30125c, 0x0}, +}; + +/* dram fsp cfg */ +static struct dram_fsp_cfg ddr_dram_fsp_cfg[] = { + { + { + {0x4e300100, 0x1465311B}, + {0x4e300104, 0xF8CC0017}, + {0x4e300108, 0xD4D68E00}, + {0x4e30010C, 0x0071E100}, + {0x4e300124, 0x18660000}, + {0x4e300160, 0x00009102}, + {0x4e30016C, 0x33F00000}, + {0x4e300170, 0x8B0B0608}, + {0x4e300250, 0x00000022}, + {0x4e300254, 0x01280128}, + {0x4e300258, 0x00000008}, + {0x4e30025C, 0x00000400}, + {0x4e300300, 0x1D441D0D}, + {0x4e300304, 0x01281E10}, + {0x4e300308, 0x0C3C0C34}, + }, + { + {0x01, 0xD4}, + {0x02, 0x2D}, + {0x03, 0x33}, + {0x0b, 0x46}, + {0x0c, 0x48}, + {0x0e, 0x48}, + {0x16, 0x04}, + }, + 0, + }, + { + { + {0x4e300100, 0x02121100}, + {0x4e300104, 0xF866000C}, + {0x4e300108, 0xF2FA8088}, + {0x4e30010C, 0x006101A0}, + {0x4e300124, 0x0C340000}, + {0x4e300160, 0x00009101}, + {0x4e30016C, 0x30700000}, + {0x4e300170, 0x8A0A0508}, + {0x4e300250, 0x00000011}, + {0x4e300254, 0x00900090}, + {0x4e300258, 0x00000008}, + {0x4e30025C, 0x00000400}, + }, + { + {0x01, 0xA4}, + {0x02, 0x52}, + {0x03, 0x33}, + {0x0b, 0x46}, + {0x0c, 0x48}, + {0x0e, 0x48}, + {0x16, 0x04}, + }, + 0, + }, + { + { + {0x4e300100, 0x00061000}, + {0x4e300104, 0xF855000A}, + {0x4e300108, 0x6E62FA48}, + {0x4e30010C, 0x0031010D}, + {0x4e300124, 0x04C50000}, + {0x4e300160, 0x00009100}, + {0x4e30016C, 0x30000000}, + {0x4e300170, 0x89090408}, + {0x4e300250, 0x00000007}, + {0x4e300254, 0x00340034}, + {0x4e300258, 0x00000008}, + {0x4e30025C, 0x00000400}, + }, + { + {0x01, 0x94}, + {0x02, 0x9}, + {0x03, 0x33}, + {0x0b, 0x46}, + {0x0c, 0x48}, + {0x0e, 0x48}, + {0x16, 0x04}, + }, + 1, + } +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x4}, + {0x100a1, 0x5}, + {0x100a2, 0x6}, + {0x100a3, 0x7}, + {0x100a4, 0x0}, + {0x100a5, 0x1}, + {0x100a6, 0x2}, + {0x100a7, 0x3}, + {0x110a0, 0x3}, + {0x110a1, 0x2}, + {0x110a2, 0x0}, + {0x110a3, 0x1}, + {0x110a4, 0x7}, + {0x110a5, 0x6}, + {0x110a6, 0x4}, + {0x110a7, 0x5}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0xb}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x1}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1e3}, + {0x2003a, 0x2}, + {0x2007d, 0x212}, + {0x2007c, 0x61}, + {0x120024, 0x1e3}, + {0x2003a, 0x2}, + {0x12007d, 0x212}, + {0x12007c, 0x61}, + {0x220024, 0x1e3}, + {0x2003a, 0x2}, + {0x22007d, 0x212}, + {0x22007c, 0x61}, + {0x20056, 0x3}, + {0x120056, 0x3}, + {0x220056, 0x3}, + {0x1004d, 0x600}, + {0x1014d, 0x600}, + {0x1104d, 0x600}, + {0x1114d, 0x600}, + {0x11004d, 0x600}, + {0x11014d, 0x600}, + {0x11104d, 0x600}, + {0x11114d, 0x600}, + {0x21004d, 0x600}, + {0x21014d, 0x600}, + {0x21104d, 0x600}, + {0x21114d, 0x600}, + {0x10049, 0xe3f}, + {0x10149, 0xe3f}, + {0x11049, 0xe3f}, + {0x11149, 0xe3f}, + {0x110049, 0xe3f}, + {0x110149, 0xe3f}, + {0x111049, 0xe3f}, + {0x111149, 0xe3f}, + {0x210049, 0xe3f}, + {0x210149, 0xe3f}, + {0x211049, 0xe3f}, + {0x211149, 0xe3f}, + {0x43, 0x7f}, + {0x1043, 0x7f}, + {0x2043, 0x7f}, + {0x20018, 0x1}, + {0x20075, 0x4}, + {0x20050, 0x11}, + {0x2009b, 0x2}, + {0x20008, 0x320}, + {0x120008, 0x190}, + {0x220008, 0x9c}, + {0x20088, 0x9}, + {0x200b2, 0x10c}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x1200b2, 0x10c}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x2200b2, 0x10c}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x200fa, 0x2}, + {0x1200fa, 0x2}, + {0x2200fa, 0x2}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x600}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5655}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x1004a, 0x500}, + {0x1104a, 0x500}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x2002c, 0x0}, + {0x20021, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, +}; + +/* PHY trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x1005f, 0x0}, + {0x1015f, 0x0}, + {0x1105f, 0x0}, + {0x1115f, 0x0}, + {0x11005f, 0x0}, + {0x11015f, 0x0}, + {0x11105f, 0x0}, + {0x11115f, 0x0}, + {0x21005f, 0x0}, + {0x21015f, 0x0}, + {0x21105f, 0x0}, + {0x21115f, 0x0}, + {0x55, 0x0}, + {0x1055, 0x0}, + {0x2055, 0x0}, + {0x200c5, 0x0}, + {0x1200c5, 0x0}, + {0x2200c5, 0x0}, + {0x2002e, 0x0}, + {0x12002e, 0x0}, + {0x22002e, 0x0}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x0}, + {0x2003a, 0x0}, + {0x2007d, 0x0}, + {0x2007c, 0x0}, + {0x120024, 0x0}, + {0x12007d, 0x0}, + {0x12007c, 0x0}, + {0x220024, 0x0}, + {0x22007d, 0x0}, + {0x22007c, 0x0}, + {0x20056, 0x0}, + {0x120056, 0x0}, + {0x220056, 0x0}, + {0x1004d, 0x0}, + {0x1014d, 0x0}, + {0x1104d, 0x0}, + {0x1114d, 0x0}, + {0x11004d, 0x0}, + {0x11014d, 0x0}, + {0x11104d, 0x0}, + {0x11114d, 0x0}, + {0x21004d, 0x0}, + {0x21014d, 0x0}, + {0x21104d, 0x0}, + {0x21114d, 0x0}, + {0x10049, 0x0}, + {0x10149, 0x0}, + {0x11049, 0x0}, + {0x11149, 0x0}, + {0x110049, 0x0}, + {0x110149, 0x0}, + {0x111049, 0x0}, + {0x111149, 0x0}, + {0x210049, 0x0}, + {0x210149, 0x0}, + {0x211049, 0x0}, + {0x211149, 0x0}, + {0x43, 0x0}, + {0x1043, 0x0}, + {0x2043, 0x0}, + {0x20018, 0x0}, + {0x20075, 0x0}, + {0x20050, 0x0}, + {0x2009b, 0x0}, + {0x20008, 0x0}, + {0x120008, 0x0}, + {0x220008, 0x0}, + {0x20088, 0x0}, + {0x200b2, 0x0}, + {0x10043, 0x0}, + {0x10143, 0x0}, + {0x11043, 0x0}, + {0x11143, 0x0}, + {0x1200b2, 0x0}, + {0x110043, 0x0}, + {0x110143, 0x0}, + {0x111043, 0x0}, + {0x111143, 0x0}, + {0x2200b2, 0x0}, + {0x210043, 0x0}, + {0x210143, 0x0}, + {0x211043, 0x0}, + {0x211143, 0x0}, + {0x200fa, 0x0}, + {0x1200fa, 0x0}, + {0x2200fa, 0x0}, + {0x20019, 0x0}, + {0x120019, 0x0}, + {0x220019, 0x0}, + {0x200f0, 0x0}, + {0x200f1, 0x0}, + {0x200f2, 0x0}, + {0x200f3, 0x0}, + {0x200f4, 0x0}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0x0}, + {0x1004a, 0x0}, + {0x1104a, 0x0}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x2002c, 0x0}, + {0xd0000, 0x0}, + {0x90000, 0x0}, + {0x90001, 0x0}, + {0x90002, 0x0}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x0}, + {0x90029, 0x0}, + {0x9002a, 0x0}, + {0x9002b, 0x0}, + {0x9002c, 0x0}, + {0x9002d, 0x0}, + {0x9002e, 0x0}, + {0x9002f, 0x0}, + {0x90030, 0x0}, + {0x90031, 0x0}, + {0x90032, 0x0}, + {0x90033, 0x0}, + {0x90034, 0x0}, + {0x90035, 0x0}, + {0x90036, 0x0}, + {0x90037, 0x0}, + {0x90038, 0x0}, + {0x90039, 0x0}, + {0x9003a, 0x0}, + {0x9003b, 0x0}, + {0x9003c, 0x0}, + {0x9003d, 0x0}, + {0x9003e, 0x0}, + {0x9003f, 0x0}, + {0x90040, 0x0}, + {0x90041, 0x0}, + {0x90042, 0x0}, + {0x90043, 0x0}, + {0x90044, 0x0}, + {0x90045, 0x0}, + {0x90046, 0x0}, + {0x90047, 0x0}, + {0x90048, 0x0}, + {0x90049, 0x0}, + {0x9004a, 0x0}, + {0x9004b, 0x0}, + {0x9004c, 0x0}, + {0x9004d, 0x0}, + {0x9004e, 0x0}, + {0x9004f, 0x0}, + {0x90050, 0x0}, + {0x90051, 0x0}, + {0x90052, 0x0}, + {0x90053, 0x0}, + {0x90054, 0x0}, + {0x90055, 0x0}, + {0x90056, 0x0}, + {0x90057, 0x0}, + {0x90058, 0x0}, + {0x90059, 0x0}, + {0x9005a, 0x0}, + {0x9005b, 0x0}, + {0x9005c, 0x0}, + {0x9005d, 0x0}, + {0x9005e, 0x0}, + {0x9005f, 0x0}, + {0x90060, 0x0}, + {0x90061, 0x0}, + {0x90062, 0x0}, + {0x90063, 0x0}, + {0x90064, 0x0}, + {0x90065, 0x0}, + {0x90066, 0x0}, + {0x90067, 0x0}, + {0x90068, 0x0}, + {0x90069, 0x0}, + {0x9006a, 0x0}, + {0x9006b, 0x0}, + {0x9006c, 0x0}, + {0x9006d, 0x0}, + {0x9006e, 0x0}, + {0x9006f, 0x0}, + {0x90070, 0x0}, + {0x90071, 0x0}, + {0x90072, 0x0}, + {0x90073, 0x0}, + {0x90074, 0x0}, + {0x90075, 0x0}, + {0x90076, 0x0}, + {0x90077, 0x0}, + {0x90078, 0x0}, + {0x90079, 0x0}, + {0x9007a, 0x0}, + {0x9007b, 0x0}, + {0x9007c, 0x0}, + {0x9007d, 0x0}, + {0x9007e, 0x0}, + {0x9007f, 0x0}, + {0x90080, 0x0}, + {0x90081, 0x0}, + {0x90082, 0x0}, + {0x90083, 0x0}, + {0x90084, 0x0}, + {0x90085, 0x0}, + {0x90086, 0x0}, + {0x90087, 0x0}, + {0x90088, 0x0}, + {0x90089, 0x0}, + {0x9008a, 0x0}, + {0x9008b, 0x0}, + {0x9008c, 0x0}, + {0x9008d, 0x0}, + {0x9008e, 0x0}, + {0x9008f, 0x0}, + {0x90090, 0x0}, + {0x90091, 0x0}, + {0x90092, 0x0}, + {0x90093, 0x0}, + {0x90094, 0x0}, + {0x90095, 0x0}, + {0x90096, 0x0}, + {0x90097, 0x0}, + {0x90098, 0x0}, + {0x90099, 0x0}, + {0x9009a, 0x0}, + {0x9009b, 0x0}, + {0x9009c, 0x0}, + {0x9009d, 0x0}, + {0x9009e, 0x0}, + {0x9009f, 0x0}, + {0x900a0, 0x0}, + {0x900a1, 0x0}, + {0x900a2, 0x0}, + {0x900a3, 0x0}, + {0x900a4, 0x0}, + {0x900a5, 0x0}, + {0x900a6, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x0}, + {0x900a9, 0x0}, + {0x40000, 0x0}, + {0x40020, 0x0}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x0}, + {0x40021, 0x0}, + {0x40041, 0x0}, + {0x40061, 0x0}, + {0x40002, 0x0}, + {0x40022, 0x0}, + {0x40042, 0x0}, + {0x40062, 0x0}, + {0x40003, 0x0}, + {0x40023, 0x0}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x0}, + {0x40024, 0x0}, + {0x40044, 0x0}, + {0x40064, 0x0}, + {0x40005, 0x0}, + {0x40025, 0x0}, + {0x40045, 0x0}, + {0x40065, 0x0}, + {0x40006, 0x0}, + {0x40026, 0x0}, + {0x40046, 0x0}, + {0x40066, 0x0}, + {0x40007, 0x0}, + {0x40027, 0x0}, + {0x40047, 0x0}, + {0x40067, 0x0}, + {0x40008, 0x0}, + {0x40028, 0x0}, + {0x40048, 0x0}, + {0x40068, 0x0}, + {0x40009, 0x0}, + {0x40029, 0x0}, + {0x40049, 0x0}, + {0x40069, 0x0}, + {0x4000a, 0x0}, + {0x4002a, 0x0}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x0}, + {0x4002b, 0x0}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x0}, + {0x4002c, 0x0}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0x0}, + {0x4002d, 0x0}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x0}, + {0x4002e, 0x0}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x0}, + {0x4002f, 0x0}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x0}, + {0x40030, 0x0}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x0}, + {0x40031, 0x0}, + {0x40051, 0x0}, + {0x40071, 0x0}, + {0x40012, 0x0}, + {0x40032, 0x0}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x0}, + {0x40033, 0x0}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x0}, + {0x40034, 0x0}, + {0x40054, 0x0}, + {0x40074, 0x0}, + {0x40015, 0x0}, + {0x40035, 0x0}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x0}, + {0x40036, 0x0}, + {0x40056, 0x0}, + {0x40076, 0x0}, + {0x40017, 0x0}, + {0x40037, 0x0}, + {0x40057, 0x0}, + {0x40077, 0x0}, + {0x40018, 0x0}, + {0x40038, 0x0}, + {0x40058, 0x0}, + {0x40078, 0x0}, + {0x40019, 0x0}, + {0x40039, 0x0}, + {0x40059, 0x0}, + {0x40079, 0x0}, + {0x4001a, 0x0}, + {0x4003a, 0x0}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900aa, 0x0}, + {0x900ab, 0x0}, + {0x900ac, 0x0}, + {0x900ad, 0x0}, + {0x900ae, 0x0}, + {0x900af, 0x0}, + {0x900b0, 0x0}, + {0x900b1, 0x0}, + {0x900b2, 0x0}, + {0x900b3, 0x0}, + {0x900b4, 0x0}, + {0x900b5, 0x0}, + {0x900b6, 0x0}, + {0x900b7, 0x0}, + {0x900b8, 0x0}, + {0x900b9, 0x0}, + {0x900ba, 0x0}, + {0x900bb, 0x0}, + {0x900bc, 0x0}, + {0x900bd, 0x0}, + {0x900be, 0x0}, + {0x900bf, 0x0}, + {0x900c0, 0x0}, + {0x900c1, 0x0}, + {0x900c2, 0x0}, + {0x900c3, 0x0}, + {0x900c4, 0x0}, + {0x900c5, 0x0}, + {0x900c6, 0x0}, + {0x900c7, 0x0}, + {0x900c8, 0x0}, + {0x900c9, 0x0}, + {0x900ca, 0x0}, + {0x900cb, 0x0}, + {0x900cc, 0x0}, + {0x900cd, 0x0}, + {0x900ce, 0x0}, + {0x900cf, 0x0}, + {0x900d0, 0x0}, + {0x900d1, 0x0}, + {0x900d2, 0x0}, + {0x900d3, 0x0}, + {0x900d4, 0x0}, + {0x900d5, 0x0}, + {0x900d6, 0x0}, + {0x900d7, 0x0}, + {0x900d8, 0x0}, + {0x900d9, 0x0}, + {0x900da, 0x0}, + {0x900db, 0x0}, + {0x900dc, 0x0}, + {0x900dd, 0x0}, + {0x900de, 0x0}, + {0x900df, 0x0}, + {0x900e0, 0x0}, + {0x900e1, 0x0}, + {0x900e2, 0x0}, + {0x900e3, 0x0}, + {0x900e4, 0x0}, + {0x900e5, 0x0}, + {0x900e6, 0x0}, + {0x900e7, 0x0}, + {0x900e8, 0x0}, + {0x900e9, 0x0}, + {0x900ea, 0x0}, + {0x900eb, 0x0}, + {0x900ec, 0x0}, + {0x900ed, 0x0}, + {0x900ee, 0x0}, + {0x900ef, 0x0}, + {0x900f0, 0x0}, + {0x900f1, 0x0}, + {0x900f2, 0x0}, + {0x900f3, 0x0}, + {0x900f4, 0x0}, + {0x900f5, 0x0}, + {0x900f6, 0x0}, + {0x900f7, 0x0}, + {0x900f8, 0x0}, + {0x900f9, 0x0}, + {0x900fa, 0x0}, + {0x900fb, 0x0}, + {0x900fc, 0x0}, + {0x900fd, 0x0}, + {0x900fe, 0x0}, + {0x900ff, 0x0}, + {0x90100, 0x0}, + {0x90101, 0x0}, + {0x90102, 0x0}, + {0x90103, 0x0}, + {0x90104, 0x0}, + {0x90105, 0x0}, + {0x90106, 0x0}, + {0x90107, 0x0}, + {0x90108, 0x0}, + {0x90109, 0x0}, + {0x9010a, 0x0}, + {0x9010b, 0x0}, + {0x9010c, 0x0}, + {0x9010d, 0x0}, + {0x9010e, 0x0}, + {0x9010f, 0x0}, + {0x90110, 0x0}, + {0x90111, 0x0}, + {0x90112, 0x0}, + {0x90113, 0x0}, + {0x90114, 0x0}, + {0x90115, 0x0}, + {0x90116, 0x0}, + {0x90117, 0x0}, + {0x90118, 0x0}, + {0x90119, 0x0}, + {0x9011a, 0x0}, + {0x9011b, 0x0}, + {0x9011c, 0x0}, + {0x9011d, 0x0}, + {0x9011e, 0x0}, + {0x9011f, 0x0}, + {0x90120, 0x0}, + {0x90121, 0x0}, + {0x90122, 0x0}, + {0x90123, 0x0}, + {0x90124, 0x0}, + {0x90125, 0x0}, + {0x90126, 0x0}, + {0x90127, 0x0}, + {0x90128, 0x0}, + {0x90129, 0x0}, + {0x9012a, 0x0}, + {0x9012b, 0x0}, + {0x9012c, 0x0}, + {0x9012d, 0x0}, + {0x9012e, 0x0}, + {0x9012f, 0x0}, + {0x90130, 0x0}, + {0x90131, 0x0}, + {0x90132, 0x0}, + {0x90133, 0x0}, + {0x90134, 0x0}, + {0x90135, 0x0}, + {0x90136, 0x0}, + {0x90137, 0x0}, + {0x90138, 0x0}, + {0x90139, 0x0}, + {0x9013a, 0x0}, + {0x9013b, 0x0}, + {0x9013c, 0x0}, + {0x9013d, 0x0}, + {0x9013e, 0x0}, + {0x9013f, 0x0}, + {0x90140, 0x0}, + {0x90141, 0x0}, + {0x90142, 0x0}, + {0x90143, 0x0}, + {0x90144, 0x0}, + {0x90145, 0x0}, + {0x90146, 0x0}, + {0x90147, 0x0}, + {0x90148, 0x0}, + {0x90149, 0x0}, + {0x9014a, 0x0}, + {0x9014b, 0x0}, + {0x9014c, 0x0}, + {0x9014d, 0x0}, + {0x9014e, 0x0}, + {0x9014f, 0x0}, + {0x90150, 0x0}, + {0x90151, 0x0}, + {0x90152, 0x0}, + {0x90153, 0x0}, + {0x90154, 0x0}, + {0x90155, 0x0}, + {0x90156, 0x0}, + {0x90157, 0x0}, + {0x90158, 0x0}, + {0x90159, 0x0}, + {0x9015a, 0x0}, + {0x9015b, 0x0}, + {0x9015c, 0x0}, + {0x9015d, 0x0}, + {0x9015e, 0x0}, + {0x9015f, 0x0}, + {0x90160, 0x0}, + {0x90161, 0x0}, + {0x90162, 0x0}, + {0x90163, 0x0}, + {0x90164, 0x0}, + {0x90165, 0x0}, + {0x90166, 0x0}, + {0x90167, 0x0}, + {0x90168, 0x0}, + {0x90169, 0x0}, + {0x9016a, 0x0}, + {0x9016b, 0x0}, + {0x9016c, 0x0}, + {0x9016d, 0x0}, + {0x9016e, 0x0}, + {0x9016f, 0x0}, + {0x90170, 0x0}, + {0x90171, 0x0}, + {0x90172, 0x0}, + {0x90173, 0x0}, + {0x90174, 0x0}, + {0x90175, 0x0}, + {0x90176, 0x0}, + {0x90177, 0x0}, + {0x90178, 0x0}, + {0x90179, 0x0}, + {0x9017a, 0x0}, + {0x9017b, 0x0}, + {0x9017c, 0x0}, + {0x9017d, 0x0}, + {0x9017e, 0x0}, + {0x9017f, 0x0}, + {0x90180, 0x0}, + {0x90181, 0x0}, + {0x90182, 0x0}, + {0x90183, 0x0}, + {0x90184, 0x0}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x0}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x0}, + {0x90017, 0x0}, + {0x9001f, 0x0}, + {0x90026, 0x0}, + {0x400d0, 0x0}, + {0x400d1, 0x0}, + {0x400d2, 0x0}, + {0x400d3, 0x0}, + {0x400d4, 0x0}, + {0x400d5, 0x0}, + {0x400d6, 0x0}, + {0x400d7, 0x0}, + {0x200be, 0x0}, + {0x2000b, 0x0}, + {0x2000c, 0x0}, + {0x2000d, 0x0}, + {0x2000e, 0x0}, + {0x12000b, 0x0}, + {0x12000c, 0x0}, + {0x12000d, 0x0}, + {0x12000e, 0x0}, + {0x22000b, 0x0}, + {0x22000c, 0x0}, + {0x22000d, 0x0}, + {0x22000e, 0x0}, + {0x9000c, 0x0}, + {0x9000d, 0x0}, + {0x9000e, 0x0}, + {0x9000f, 0x0}, + {0x90010, 0x0}, + {0x90011, 0x0}, + {0x90012, 0x0}, + {0x90013, 0x0}, + {0x20010, 0x0}, + {0x20011, 0x0}, + {0x120010, 0x0}, + {0x120011, 0x0}, + {0x40080, 0x0}, + {0x40081, 0x0}, + {0x40082, 0x0}, + {0x40083, 0x0}, + {0x40084, 0x0}, + {0x40085, 0x0}, + {0x140080, 0x0}, + {0x140081, 0x0}, + {0x140082, 0x0}, + {0x140083, 0x0}, + {0x140084, 0x0}, + {0x140085, 0x0}, + {0x240080, 0x0}, + {0x240081, 0x0}, + {0x240082, 0x0}, + {0x240083, 0x0}, + {0x240084, 0x0}, + {0x240085, 0x0}, + {0x400fd, 0x0}, + {0x400f1, 0x0}, + {0x10011, 0x0}, + {0x10012, 0x0}, + {0x10013, 0x0}, + {0x10018, 0x0}, + {0x10002, 0x0}, + {0x100b2, 0x0}, + {0x101b4, 0x0}, + {0x102b4, 0x0}, + {0x103b4, 0x0}, + {0x104b4, 0x0}, + {0x105b4, 0x0}, + {0x106b4, 0x0}, + {0x107b4, 0x0}, + {0x108b4, 0x0}, + {0x11011, 0x0}, + {0x11012, 0x0}, + {0x11013, 0x0}, + {0x11018, 0x0}, + {0x11002, 0x0}, + {0x110b2, 0x0}, + {0x111b4, 0x0}, + {0x112b4, 0x0}, + {0x113b4, 0x0}, + {0x114b4, 0x0}, + {0x115b4, 0x0}, + {0x116b4, 0x0}, + {0x117b4, 0x0}, + {0x118b4, 0x0}, + {0x20089, 0x0}, + {0xc0080, 0x0}, + {0x200cb, 0x0}, + {0x10068, 0x0}, + {0x10069, 0x0}, + {0x10168, 0x0}, + {0x10169, 0x0}, + {0x10268, 0x0}, + {0x10269, 0x0}, + {0x10368, 0x0}, + {0x10369, 0x0}, + {0x10468, 0x0}, + {0x10469, 0x0}, + {0x10568, 0x0}, + {0x10569, 0x0}, + {0x10668, 0x0}, + {0x10669, 0x0}, + {0x10768, 0x0}, + {0x10769, 0x0}, + {0x10868, 0x0}, + {0x10869, 0x0}, + {0x100aa, 0x0}, + {0x10062, 0x0}, + {0x10001, 0x0}, + {0x100a0, 0x0}, + {0x100a1, 0x0}, + {0x100a2, 0x0}, + {0x100a3, 0x0}, + {0x100a4, 0x0}, + {0x100a5, 0x0}, + {0x100a6, 0x0}, + {0x100a7, 0x0}, + {0x11068, 0x0}, + {0x11069, 0x0}, + {0x11168, 0x0}, + {0x11169, 0x0}, + {0x11268, 0x0}, + {0x11269, 0x0}, + {0x11368, 0x0}, + {0x11369, 0x0}, + {0x11468, 0x0}, + {0x11469, 0x0}, + {0x11568, 0x0}, + {0x11569, 0x0}, + {0x11668, 0x0}, + {0x11669, 0x0}, + {0x11768, 0x0}, + {0x11769, 0x0}, + {0x11868, 0x0}, + {0x11869, 0x0}, + {0x110aa, 0x0}, + {0x11062, 0x0}, + {0x11001, 0x0}, + {0x110a0, 0x0}, + {0x110a1, 0x0}, + {0x110a2, 0x0}, + {0x110a3, 0x0}, + {0x110a4, 0x0}, + {0x110a5, 0x0}, + {0x110a6, 0x0}, + {0x110a7, 0x0}, + {0x80, 0x0}, + {0x1080, 0x0}, + {0x2080, 0x0}, + {0x10020, 0x0}, + {0x10080, 0x0}, + {0x10081, 0x0}, + {0x100d0, 0x0}, + {0x100d1, 0x0}, + {0x1008c, 0x0}, + {0x1008d, 0x0}, + {0x10180, 0x0}, + {0x10181, 0x0}, + {0x101d0, 0x0}, + {0x101d1, 0x0}, + {0x1018c, 0x0}, + {0x1018d, 0x0}, + {0x100c0, 0x0}, + {0x100c1, 0x0}, + {0x101c0, 0x0}, + {0x101c1, 0x0}, + {0x102c0, 0x0}, + {0x102c1, 0x0}, + {0x103c0, 0x0}, + {0x103c1, 0x0}, + {0x104c0, 0x0}, + {0x104c1, 0x0}, + {0x105c0, 0x0}, + {0x105c1, 0x0}, + {0x106c0, 0x0}, + {0x106c1, 0x0}, + {0x107c0, 0x0}, + {0x107c1, 0x0}, + {0x108c0, 0x0}, + {0x108c1, 0x0}, + {0x100ae, 0x0}, + {0x100af, 0x0}, + {0x11020, 0x0}, + {0x11080, 0x0}, + {0x11081, 0x0}, + {0x110d0, 0x0}, + {0x110d1, 0x0}, + {0x1108c, 0x0}, + {0x1108d, 0x0}, + {0x11180, 0x0}, + {0x11181, 0x0}, + {0x111d0, 0x0}, + {0x111d1, 0x0}, + {0x1118c, 0x0}, + {0x1118d, 0x0}, + {0x110c0, 0x0}, + {0x110c1, 0x0}, + {0x111c0, 0x0}, + {0x111c1, 0x0}, + {0x112c0, 0x0}, + {0x112c1, 0x0}, + {0x113c0, 0x0}, + {0x113c1, 0x0}, + {0x114c0, 0x0}, + {0x114c1, 0x0}, + {0x115c0, 0x0}, + {0x115c1, 0x0}, + {0x116c0, 0x0}, + {0x116c1, 0x0}, + {0x117c0, 0x0}, + {0x117c1, 0x0}, + {0x118c0, 0x0}, + {0x118c1, 0x0}, + {0x110ae, 0x0}, + {0x110af, 0x0}, + {0x90201, 0x0}, + {0x90202, 0x0}, + {0x90203, 0x0}, + {0x90205, 0x0}, + {0x90206, 0x0}, + {0x90207, 0x0}, + {0x90208, 0x0}, + {0x20020, 0x0}, + {0x100080, 0x0}, + {0x101080, 0x0}, + {0x102080, 0x0}, + {0x110020, 0x0}, + {0x110080, 0x0}, + {0x110081, 0x0}, + {0x1100d0, 0x0}, + {0x1100d1, 0x0}, + {0x11008c, 0x0}, + {0x11008d, 0x0}, + {0x110180, 0x0}, + {0x110181, 0x0}, + {0x1101d0, 0x0}, + {0x1101d1, 0x0}, + {0x11018c, 0x0}, + {0x11018d, 0x0}, + {0x1100c0, 0x0}, + {0x1100c1, 0x0}, + {0x1101c0, 0x0}, + {0x1101c1, 0x0}, + {0x1102c0, 0x0}, + {0x1102c1, 0x0}, + {0x1103c0, 0x0}, + {0x1103c1, 0x0}, + {0x1104c0, 0x0}, + {0x1104c1, 0x0}, + {0x1105c0, 0x0}, + {0x1105c1, 0x0}, + {0x1106c0, 0x0}, + {0x1106c1, 0x0}, + {0x1107c0, 0x0}, + {0x1107c1, 0x0}, + {0x1108c0, 0x0}, + {0x1108c1, 0x0}, + {0x1100ae, 0x0}, + {0x1100af, 0x0}, + {0x111020, 0x0}, + {0x111080, 0x0}, + {0x111081, 0x0}, + {0x1110d0, 0x0}, + {0x1110d1, 0x0}, + {0x11108c, 0x0}, + {0x11108d, 0x0}, + {0x111180, 0x0}, + {0x111181, 0x0}, + {0x1111d0, 0x0}, + {0x1111d1, 0x0}, + {0x11118c, 0x0}, + {0x11118d, 0x0}, + {0x1110c0, 0x0}, + {0x1110c1, 0x0}, + {0x1111c0, 0x0}, + {0x1111c1, 0x0}, + {0x1112c0, 0x0}, + {0x1112c1, 0x0}, + {0x1113c0, 0x0}, + {0x1113c1, 0x0}, + {0x1114c0, 0x0}, + {0x1114c1, 0x0}, + {0x1115c0, 0x0}, + {0x1115c1, 0x0}, + {0x1116c0, 0x0}, + {0x1116c1, 0x0}, + {0x1117c0, 0x0}, + {0x1117c1, 0x0}, + {0x1118c0, 0x0}, + {0x1118c1, 0x0}, + {0x1110ae, 0x0}, + {0x1110af, 0x0}, + {0x190201, 0x0}, + {0x190202, 0x0}, + {0x190203, 0x0}, + {0x190205, 0x0}, + {0x190206, 0x0}, + {0x190207, 0x0}, + {0x190208, 0x0}, + {0x120020, 0x0}, + {0x200080, 0x0}, + {0x201080, 0x0}, + {0x202080, 0x0}, + {0x210020, 0x0}, + {0x210080, 0x0}, + {0x210081, 0x0}, + {0x2100d0, 0x0}, + {0x2100d1, 0x0}, + {0x21008c, 0x0}, + {0x21008d, 0x0}, + {0x210180, 0x0}, + {0x210181, 0x0}, + {0x2101d0, 0x0}, + {0x2101d1, 0x0}, + {0x21018c, 0x0}, + {0x21018d, 0x0}, + {0x2100c0, 0x0}, + {0x2100c1, 0x0}, + {0x2101c0, 0x0}, + {0x2101c1, 0x0}, + {0x2102c0, 0x0}, + {0x2102c1, 0x0}, + {0x2103c0, 0x0}, + {0x2103c1, 0x0}, + {0x2104c0, 0x0}, + {0x2104c1, 0x0}, + {0x2105c0, 0x0}, + {0x2105c1, 0x0}, + {0x2106c0, 0x0}, + {0x2106c1, 0x0}, + {0x2107c0, 0x0}, + {0x2107c1, 0x0}, + {0x2108c0, 0x0}, + {0x2108c1, 0x0}, + {0x2100ae, 0x0}, + {0x2100af, 0x0}, + {0x211020, 0x0}, + {0x211080, 0x0}, + {0x211081, 0x0}, + {0x2110d0, 0x0}, + {0x2110d1, 0x0}, + {0x21108c, 0x0}, + {0x21108d, 0x0}, + {0x211180, 0x0}, + {0x211181, 0x0}, + {0x2111d0, 0x0}, + {0x2111d1, 0x0}, + {0x21118c, 0x0}, + {0x21118d, 0x0}, + {0x2110c0, 0x0}, + {0x2110c1, 0x0}, + {0x2111c0, 0x0}, + {0x2111c1, 0x0}, + {0x2112c0, 0x0}, + {0x2112c1, 0x0}, + {0x2113c0, 0x0}, + {0x2113c1, 0x0}, + {0x2114c0, 0x0}, + {0x2114c1, 0x0}, + {0x2115c0, 0x0}, + {0x2115c1, 0x0}, + {0x2116c0, 0x0}, + {0x2116c1, 0x0}, + {0x2117c0, 0x0}, + {0x2117c1, 0x0}, + {0x2118c0, 0x0}, + {0x2118c1, 0x0}, + {0x2110ae, 0x0}, + {0x2110af, 0x0}, + {0x290201, 0x0}, + {0x290202, 0x0}, + {0x290203, 0x0}, + {0x290205, 0x0}, + {0x290206, 0x0}, + {0x290207, 0x0}, + {0x290208, 0x0}, + {0x220020, 0x0}, + {0x20077, 0x0}, + {0x20072, 0x0}, + {0x20073, 0x0}, + {0x400c0, 0x0}, + {0x10040, 0x0}, + {0x10140, 0x0}, + {0x10240, 0x0}, + {0x10340, 0x0}, + {0x10440, 0x0}, + {0x10540, 0x0}, + {0x10640, 0x0}, + {0x10740, 0x0}, + {0x10840, 0x0}, + {0x11040, 0x0}, + {0x11140, 0x0}, + {0x11240, 0x0}, + {0x11340, 0x0}, + {0x11440, 0x0}, + {0x11540, 0x0}, + {0x11640, 0x0}, + {0x11740, 0x0}, + {0x11840, 0x0}, +}; + +/* P0 message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4808}, + {0x5401e, 0x4}, + {0x5401f, 0x2dd4}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4808}, + {0x54024, 0x4}, + {0x54032, 0xd400}, + {0x54033, 0x332d}, + {0x54034, 0x4600}, + {0x54035, 0x848}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0xd400}, + {0x54039, 0x332d}, + {0x5403a, 0x4600}, + {0x5403b, 0x848}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* P1 message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x1}, + {0x54003, 0x640}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x52a4}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4808}, + {0x5401e, 0x4}, + {0x5401f, 0x52a4}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4808}, + {0x54024, 0x4}, + {0x54032, 0xa400}, + {0x54033, 0x3352}, + {0x54034, 0x4600}, + {0x54035, 0x848}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0xa400}, + {0x54039, 0x3352}, + {0x5403a, 0x4600}, + {0x5403b, 0x848}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* P2 message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x270}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x994}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4800}, + {0x5401e, 0x4}, + {0x5401f, 0x994}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4800}, + {0x54024, 0x4}, + {0x54032, 0x9400}, + {0x54033, 0x3309}, + {0x54034, 0x4600}, + {0x54035, 0x48}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0x9400}, + {0x54039, 0x3309}, + {0x5403a, 0x4600}, + {0x5403b, 0x48}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* P0 2D message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54010, 0x2080}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4808}, + {0x5401e, 0x4}, + {0x5401f, 0x2dd4}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4808}, + {0x54024, 0x4}, + {0x54032, 0xd400}, + {0x54033, 0x332d}, + {0x54034, 0x4600}, + {0x54035, 0x848}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0xd400}, + {0x54039, 0x332d}, + {0x5403a, 0x4600}, + {0x5403b, 0x848}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xb}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x633}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x633}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x633}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x30}, + {0x90051, 0x65a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x45a}, + {0x90055, 0x9}, + {0x90056, 0x0}, + {0x90057, 0x448}, + {0x90058, 0x109}, + {0x90059, 0x40}, + {0x9005a, 0x633}, + {0x9005b, 0x179}, + {0x9005c, 0x1}, + {0x9005d, 0x618}, + {0x9005e, 0x109}, + {0x9005f, 0x40c0}, + {0x90060, 0x633}, + {0x90061, 0x149}, + {0x90062, 0x8}, + {0x90063, 0x4}, + {0x90064, 0x48}, + {0x90065, 0x4040}, + {0x90066, 0x633}, + {0x90067, 0x149}, + {0x90068, 0x0}, + {0x90069, 0x4}, + {0x9006a, 0x48}, + {0x9006b, 0x40}, + {0x9006c, 0x633}, + {0x9006d, 0x149}, + {0x9006e, 0x0}, + {0x9006f, 0x658}, + {0x90070, 0x109}, + {0x90071, 0x10}, + {0x90072, 0x4}, + {0x90073, 0x18}, + {0x90074, 0x0}, + {0x90075, 0x4}, + {0x90076, 0x78}, + {0x90077, 0x549}, + {0x90078, 0x633}, + {0x90079, 0x159}, + {0x9007a, 0xd49}, + {0x9007b, 0x633}, + {0x9007c, 0x159}, + {0x9007d, 0x94a}, + {0x9007e, 0x633}, + {0x9007f, 0x159}, + {0x90080, 0x441}, + {0x90081, 0x633}, + {0x90082, 0x149}, + {0x90083, 0x42}, + {0x90084, 0x633}, + {0x90085, 0x149}, + {0x90086, 0x1}, + {0x90087, 0x633}, + {0x90088, 0x149}, + {0x90089, 0x0}, + {0x9008a, 0xe0}, + {0x9008b, 0x109}, + {0x9008c, 0xa}, + {0x9008d, 0x10}, + {0x9008e, 0x109}, + {0x9008f, 0x9}, + {0x90090, 0x3c0}, + {0x90091, 0x149}, + {0x90092, 0x9}, + {0x90093, 0x3c0}, + {0x90094, 0x159}, + {0x90095, 0x18}, + {0x90096, 0x10}, + {0x90097, 0x109}, + {0x90098, 0x0}, + {0x90099, 0x3c0}, + {0x9009a, 0x109}, + {0x9009b, 0x18}, + {0x9009c, 0x4}, + {0x9009d, 0x48}, + {0x9009e, 0x18}, + {0x9009f, 0x4}, + {0x900a0, 0x58}, + {0x900a1, 0xb}, + {0x900a2, 0x10}, + {0x900a3, 0x109}, + {0x900a4, 0x1}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x900a7, 0x5}, + {0x900a8, 0x7c0}, + {0x900a9, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x625}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x625}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900aa, 0x0}, + {0x900ab, 0x790}, + {0x900ac, 0x11a}, + {0x900ad, 0x8}, + {0x900ae, 0x7aa}, + {0x900af, 0x2a}, + {0x900b0, 0x10}, + {0x900b1, 0x7b2}, + {0x900b2, 0x2a}, + {0x900b3, 0x0}, + {0x900b4, 0x7c8}, + {0x900b5, 0x109}, + {0x900b6, 0x10}, + {0x900b7, 0x10}, + {0x900b8, 0x109}, + {0x900b9, 0x10}, + {0x900ba, 0x2a8}, + {0x900bb, 0x129}, + {0x900bc, 0x8}, + {0x900bd, 0x370}, + {0x900be, 0x129}, + {0x900bf, 0xa}, + {0x900c0, 0x3c8}, + {0x900c1, 0x1a9}, + {0x900c2, 0xc}, + {0x900c3, 0x408}, + {0x900c4, 0x199}, + {0x900c5, 0x14}, + {0x900c6, 0x790}, + {0x900c7, 0x11a}, + {0x900c8, 0x8}, + {0x900c9, 0x4}, + {0x900ca, 0x18}, + {0x900cb, 0xe}, + {0x900cc, 0x408}, + {0x900cd, 0x199}, + {0x900ce, 0x8}, + {0x900cf, 0x8568}, + {0x900d0, 0x108}, + {0x900d1, 0x18}, + {0x900d2, 0x790}, + {0x900d3, 0x16a}, + {0x900d4, 0x8}, + {0x900d5, 0x1d8}, + {0x900d6, 0x169}, + {0x900d7, 0x10}, + {0x900d8, 0x8558}, + {0x900d9, 0x168}, + {0x900da, 0x1ff8}, + {0x900db, 0x85a8}, + {0x900dc, 0x1e8}, + {0x900dd, 0x50}, + {0x900de, 0x798}, + {0x900df, 0x16a}, + {0x900e0, 0x60}, + {0x900e1, 0x7a0}, + {0x900e2, 0x16a}, + {0x900e3, 0x8}, + {0x900e4, 0x8310}, + {0x900e5, 0x168}, + {0x900e6, 0x8}, + {0x900e7, 0xa310}, + {0x900e8, 0x168}, + {0x900e9, 0xa}, + {0x900ea, 0x408}, + {0x900eb, 0x169}, + {0x900ec, 0x6e}, + {0x900ed, 0x0}, + {0x900ee, 0x68}, + {0x900ef, 0x0}, + {0x900f0, 0x408}, + {0x900f1, 0x169}, + {0x900f2, 0x0}, + {0x900f3, 0x8310}, + {0x900f4, 0x168}, + {0x900f5, 0x0}, + {0x900f6, 0xa310}, + {0x900f7, 0x168}, + {0x900f8, 0x1ff8}, + {0x900f9, 0x85a8}, + {0x900fa, 0x1e8}, + {0x900fb, 0x68}, + {0x900fc, 0x798}, + {0x900fd, 0x16a}, + {0x900fe, 0x78}, + {0x900ff, 0x7a0}, + {0x90100, 0x16a}, + {0x90101, 0x68}, + {0x90102, 0x790}, + {0x90103, 0x16a}, + {0x90104, 0x8}, + {0x90105, 0x8b10}, + {0x90106, 0x168}, + {0x90107, 0x8}, + {0x90108, 0xab10}, + {0x90109, 0x168}, + {0x9010a, 0xa}, + {0x9010b, 0x408}, + {0x9010c, 0x169}, + {0x9010d, 0x58}, + {0x9010e, 0x0}, + {0x9010f, 0x68}, + {0x90110, 0x0}, + {0x90111, 0x408}, + {0x90112, 0x169}, + {0x90113, 0x0}, + {0x90114, 0x8b10}, + {0x90115, 0x168}, + {0x90116, 0x1}, + {0x90117, 0xab10}, + {0x90118, 0x168}, + {0x90119, 0x0}, + {0x9011a, 0x1d8}, + {0x9011b, 0x169}, + {0x9011c, 0x80}, + {0x9011d, 0x790}, + {0x9011e, 0x16a}, + {0x9011f, 0x18}, + {0x90120, 0x7aa}, + {0x90121, 0x6a}, + {0x90122, 0xa}, + {0x90123, 0x0}, + {0x90124, 0x1e9}, + {0x90125, 0x8}, + {0x90126, 0x8080}, + {0x90127, 0x108}, + {0x90128, 0xf}, + {0x90129, 0x408}, + {0x9012a, 0x169}, + {0x9012b, 0xc}, + {0x9012c, 0x0}, + {0x9012d, 0x68}, + {0x9012e, 0x9}, + {0x9012f, 0x0}, + {0x90130, 0x1a9}, + {0x90131, 0x0}, + {0x90132, 0x408}, + {0x90133, 0x169}, + {0x90134, 0x0}, + {0x90135, 0x8080}, + {0x90136, 0x108}, + {0x90137, 0x8}, + {0x90138, 0x7aa}, + {0x90139, 0x6a}, + {0x9013a, 0x0}, + {0x9013b, 0x8568}, + {0x9013c, 0x108}, + {0x9013d, 0xb7}, + {0x9013e, 0x790}, + {0x9013f, 0x16a}, + {0x90140, 0x1f}, + {0x90141, 0x0}, + {0x90142, 0x68}, + {0x90143, 0x8}, + {0x90144, 0x8558}, + {0x90145, 0x168}, + {0x90146, 0xf}, + {0x90147, 0x408}, + {0x90148, 0x169}, + {0x90149, 0xd}, + {0x9014a, 0x0}, + {0x9014b, 0x68}, + {0x9014c, 0x0}, + {0x9014d, 0x408}, + {0x9014e, 0x169}, + {0x9014f, 0x0}, + {0x90150, 0x8558}, + {0x90151, 0x168}, + {0x90152, 0x8}, + {0x90153, 0x3c8}, + {0x90154, 0x1a9}, + {0x90155, 0x3}, + {0x90156, 0x370}, + {0x90157, 0x129}, + {0x90158, 0x20}, + {0x90159, 0x2aa}, + {0x9015a, 0x9}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x104}, + {0x90164, 0x8}, + {0x90165, 0x448}, + {0x90166, 0x109}, + {0x90167, 0xf}, + {0x90168, 0x7c0}, + {0x90169, 0x109}, + {0x9016a, 0x0}, + {0x9016b, 0xe8}, + {0x9016c, 0x109}, + {0x9016d, 0x47}, + {0x9016e, 0x630}, + {0x9016f, 0x109}, + {0x90170, 0x8}, + {0x90171, 0x618}, + {0x90172, 0x109}, + {0x90173, 0x8}, + {0x90174, 0xe0}, + {0x90175, 0x109}, + {0x90176, 0x0}, + {0x90177, 0x7c8}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0x8140}, + {0x9017b, 0x10c}, + {0x9017c, 0x0}, + {0x9017d, 0x478}, + {0x9017e, 0x109}, + {0x9017f, 0x0}, + {0x90180, 0x1}, + {0x90181, 0x8}, + {0x90182, 0x8}, + {0x90183, 0x4}, + {0x90184, 0x0}, + {0x90006, 0x8}, + {0x90007, 0x7c8}, + {0x90008, 0x109}, + {0x90009, 0x0}, + {0x9000a, 0x400}, + {0x9000b, 0x106}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2b}, + {0x90026, 0x69}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x200be, 0x3}, + {0x2000b, 0x384}, + {0x2000c, 0xc8}, + {0x2000d, 0x7d0}, + {0x2000e, 0x2c}, + {0x12000b, 0x1c2}, + {0x12000c, 0x64}, + {0x12000d, 0x3e8}, + {0x12000e, 0x2c}, + {0x22000b, 0xb0}, + {0x22000c, 0x27}, + {0x22000d, 0x186}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x2060}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x400f1, 0xe}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x20089, 0x1}, + {0x20088, 0x19}, + {0xc0080, 0x0}, + {0xd0000, 0x1}, +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 1600mts 1D */ + .drate = 1600, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 625mts 1D */ + .drate = 625, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 1600, 625, }, + .fsp_cfg = ddr_dram_fsp_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_dram_fsp_cfg), +}; diff --git a/board/freescale/imx93_qsb/lpddr4_timing_ecc.c b/board/freescale/imx93_qsb/lpddr4_timing_ecc.c new file mode 100644 index 00000000000..60cd4908f4a --- /dev/null +++ b/board/freescale/imx93_qsb/lpddr4_timing_ecc.c @@ -0,0 +1,1995 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright 2024 NXP + * + * Code generated with DDR Tool v3.4.0_8.3-4e2b550a. + * DDR PHY FW2022.01 + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /* Initialize DDRC registers */ + {0x4e300110, 0x44100001}, + {0x4e300000, 0x8000ef}, + {0x4e300008, 0x0}, + {0x4e300080, 0x80000512}, + {0x4e300084, 0x0}, + {0x4e300114, 0x1012}, + {0x4e300260, 0x80}, + {0x4e300f04, 0x80}, + {0x4e300800, 0x43b30d00}, + {0x4e300804, 0x1f1f1f1f}, + {0x4e301000, 0xc0000000}, + {0x4e301240, 0x0}, + {0x4e301244, 0x0}, + {0x4e301248, 0x0}, + {0x4e30124c, 0x0}, + {0x4e301250, 0x0}, + {0x4e301254, 0x0}, + {0x4e301258, 0x0}, + {0x4e30125c, 0x0}, +}; + +/* dram fsp cfg */ +static struct dram_fsp_cfg ddr_dram_fsp_cfg[] = { + { + { + {0x4e300100, 0x1465311B}, + {0x4e300104, 0xF8CC0017}, + {0x4e300108, 0xD4D68E00}, + {0x4e30010C, 0x0071E100}, + {0x4e300124, 0x18660000}, + {0x4e300160, 0x00009102}, + {0x4e30016C, 0x33F00000}, + {0x4e300170, 0x8B0B0608}, + {0x4e300250, 0x00000022}, + {0x4e300254, 0x01280128}, + {0x4e300258, 0x00000008}, + {0x4e30025C, 0x00000400}, + {0x4e300300, 0x1D441D0D}, + {0x4e300304, 0x01281E10}, + {0x4e300308, 0x0C3C0C34}, + }, + { + {0x01, 0xD4}, + {0x02, 0x2D}, + {0x03, 0x33}, + {0x0b, 0x46}, + {0x0c, 0x48}, + {0x0e, 0x48}, + {0x16, 0x04}, + }, + 0, + }, + { + { + {0x4e300100, 0x02121100}, + {0x4e300104, 0xF866000C}, + {0x4e300108, 0xF2FA8088}, + {0x4e30010C, 0x006101A0}, + {0x4e300124, 0x0C340000}, + {0x4e300160, 0x00009101}, + {0x4e30016C, 0x30700000}, + {0x4e300170, 0x8A0A0508}, + {0x4e300250, 0x00000011}, + {0x4e300254, 0x00900090}, + {0x4e300258, 0x00000008}, + {0x4e30025C, 0x00000400}, + }, + { + {0x01, 0xA4}, + {0x02, 0x52}, + {0x03, 0x33}, + {0x0b, 0x46}, + {0x0c, 0x48}, + {0x0e, 0x48}, + {0x16, 0x04}, + }, + 0, + }, + { + { + {0x4e300100, 0x00061000}, + {0x4e300104, 0xF855000A}, + {0x4e300108, 0x6E62FA48}, + {0x4e30010C, 0x0031010D}, + {0x4e300124, 0x04C50000}, + {0x4e300160, 0x00009100}, + {0x4e30016C, 0x30000000}, + {0x4e300170, 0x89090408}, + {0x4e300250, 0x00000007}, + {0x4e300254, 0x00340034}, + {0x4e300258, 0x00000008}, + {0x4e30025C, 0x00000400}, + }, + { + {0x01, 0x94}, + {0x02, 0x9}, + {0x03, 0x33}, + {0x0b, 0x46}, + {0x0c, 0x48}, + {0x0e, 0x48}, + {0x16, 0x04}, + }, + 1, + } +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x4}, + {0x100a1, 0x5}, + {0x100a2, 0x6}, + {0x100a3, 0x7}, + {0x100a4, 0x0}, + {0x100a5, 0x1}, + {0x100a6, 0x2}, + {0x100a7, 0x3}, + {0x110a0, 0x3}, + {0x110a1, 0x2}, + {0x110a2, 0x0}, + {0x110a3, 0x1}, + {0x110a4, 0x7}, + {0x110a5, 0x6}, + {0x110a6, 0x4}, + {0x110a7, 0x5}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0xb}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x1}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1e3}, + {0x2003a, 0x2}, + {0x2007d, 0x212}, + {0x2007c, 0x61}, + {0x120024, 0x1e3}, + {0x2003a, 0x2}, + {0x12007d, 0x212}, + {0x12007c, 0x61}, + {0x220024, 0x1e3}, + {0x2003a, 0x2}, + {0x22007d, 0x212}, + {0x22007c, 0x61}, + {0x20056, 0x3}, + {0x120056, 0x3}, + {0x220056, 0x3}, + {0x1004d, 0x600}, + {0x1014d, 0x600}, + {0x1104d, 0x600}, + {0x1114d, 0x600}, + {0x11004d, 0x600}, + {0x11014d, 0x600}, + {0x11104d, 0x600}, + {0x11114d, 0x600}, + {0x21004d, 0x600}, + {0x21014d, 0x600}, + {0x21104d, 0x600}, + {0x21114d, 0x600}, + {0x10049, 0xe3f}, + {0x10149, 0xe3f}, + {0x11049, 0xe3f}, + {0x11149, 0xe3f}, + {0x110049, 0xe3f}, + {0x110149, 0xe3f}, + {0x111049, 0xe3f}, + {0x111149, 0xe3f}, + {0x210049, 0xe3f}, + {0x210149, 0xe3f}, + {0x211049, 0xe3f}, + {0x211149, 0xe3f}, + {0x43, 0x7f}, + {0x1043, 0x7f}, + {0x2043, 0x7f}, + {0x20018, 0x1}, + {0x20075, 0x4}, + {0x20050, 0x11}, + {0x2009b, 0x2}, + {0x20008, 0x320}, + {0x120008, 0x190}, + {0x220008, 0x9c}, + {0x20088, 0x9}, + {0x200b2, 0x10c}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x1200b2, 0x10c}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x2200b2, 0x10c}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x200fa, 0x2}, + {0x1200fa, 0x2}, + {0x2200fa, 0x2}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x600}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5655}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x1004a, 0x500}, + {0x1104a, 0x500}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x2002c, 0x0}, + {0x20021, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, +}; + +/* PHY trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x1005f, 0x0}, + {0x1015f, 0x0}, + {0x1105f, 0x0}, + {0x1115f, 0x0}, + {0x11005f, 0x0}, + {0x11015f, 0x0}, + {0x11105f, 0x0}, + {0x11115f, 0x0}, + {0x21005f, 0x0}, + {0x21015f, 0x0}, + {0x21105f, 0x0}, + {0x21115f, 0x0}, + {0x55, 0x0}, + {0x1055, 0x0}, + {0x2055, 0x0}, + {0x200c5, 0x0}, + {0x1200c5, 0x0}, + {0x2200c5, 0x0}, + {0x2002e, 0x0}, + {0x12002e, 0x0}, + {0x22002e, 0x0}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x0}, + {0x2003a, 0x0}, + {0x2007d, 0x0}, + {0x2007c, 0x0}, + {0x120024, 0x0}, + {0x12007d, 0x0}, + {0x12007c, 0x0}, + {0x220024, 0x0}, + {0x22007d, 0x0}, + {0x22007c, 0x0}, + {0x20056, 0x0}, + {0x120056, 0x0}, + {0x220056, 0x0}, + {0x1004d, 0x0}, + {0x1014d, 0x0}, + {0x1104d, 0x0}, + {0x1114d, 0x0}, + {0x11004d, 0x0}, + {0x11014d, 0x0}, + {0x11104d, 0x0}, + {0x11114d, 0x0}, + {0x21004d, 0x0}, + {0x21014d, 0x0}, + {0x21104d, 0x0}, + {0x21114d, 0x0}, + {0x10049, 0x0}, + {0x10149, 0x0}, + {0x11049, 0x0}, + {0x11149, 0x0}, + {0x110049, 0x0}, + {0x110149, 0x0}, + {0x111049, 0x0}, + {0x111149, 0x0}, + {0x210049, 0x0}, + {0x210149, 0x0}, + {0x211049, 0x0}, + {0x211149, 0x0}, + {0x43, 0x0}, + {0x1043, 0x0}, + {0x2043, 0x0}, + {0x20018, 0x0}, + {0x20075, 0x0}, + {0x20050, 0x0}, + {0x2009b, 0x0}, + {0x20008, 0x0}, + {0x120008, 0x0}, + {0x220008, 0x0}, + {0x20088, 0x0}, + {0x200b2, 0x0}, + {0x10043, 0x0}, + {0x10143, 0x0}, + {0x11043, 0x0}, + {0x11143, 0x0}, + {0x1200b2, 0x0}, + {0x110043, 0x0}, + {0x110143, 0x0}, + {0x111043, 0x0}, + {0x111143, 0x0}, + {0x2200b2, 0x0}, + {0x210043, 0x0}, + {0x210143, 0x0}, + {0x211043, 0x0}, + {0x211143, 0x0}, + {0x200fa, 0x0}, + {0x1200fa, 0x0}, + {0x2200fa, 0x0}, + {0x20019, 0x0}, + {0x120019, 0x0}, + {0x220019, 0x0}, + {0x200f0, 0x0}, + {0x200f1, 0x0}, + {0x200f2, 0x0}, + {0x200f3, 0x0}, + {0x200f4, 0x0}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0x0}, + {0x1004a, 0x0}, + {0x1104a, 0x0}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x2002c, 0x0}, + {0xd0000, 0x0}, + {0x90000, 0x0}, + {0x90001, 0x0}, + {0x90002, 0x0}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x0}, + {0x90029, 0x0}, + {0x9002a, 0x0}, + {0x9002b, 0x0}, + {0x9002c, 0x0}, + {0x9002d, 0x0}, + {0x9002e, 0x0}, + {0x9002f, 0x0}, + {0x90030, 0x0}, + {0x90031, 0x0}, + {0x90032, 0x0}, + {0x90033, 0x0}, + {0x90034, 0x0}, + {0x90035, 0x0}, + {0x90036, 0x0}, + {0x90037, 0x0}, + {0x90038, 0x0}, + {0x90039, 0x0}, + {0x9003a, 0x0}, + {0x9003b, 0x0}, + {0x9003c, 0x0}, + {0x9003d, 0x0}, + {0x9003e, 0x0}, + {0x9003f, 0x0}, + {0x90040, 0x0}, + {0x90041, 0x0}, + {0x90042, 0x0}, + {0x90043, 0x0}, + {0x90044, 0x0}, + {0x90045, 0x0}, + {0x90046, 0x0}, + {0x90047, 0x0}, + {0x90048, 0x0}, + {0x90049, 0x0}, + {0x9004a, 0x0}, + {0x9004b, 0x0}, + {0x9004c, 0x0}, + {0x9004d, 0x0}, + {0x9004e, 0x0}, + {0x9004f, 0x0}, + {0x90050, 0x0}, + {0x90051, 0x0}, + {0x90052, 0x0}, + {0x90053, 0x0}, + {0x90054, 0x0}, + {0x90055, 0x0}, + {0x90056, 0x0}, + {0x90057, 0x0}, + {0x90058, 0x0}, + {0x90059, 0x0}, + {0x9005a, 0x0}, + {0x9005b, 0x0}, + {0x9005c, 0x0}, + {0x9005d, 0x0}, + {0x9005e, 0x0}, + {0x9005f, 0x0}, + {0x90060, 0x0}, + {0x90061, 0x0}, + {0x90062, 0x0}, + {0x90063, 0x0}, + {0x90064, 0x0}, + {0x90065, 0x0}, + {0x90066, 0x0}, + {0x90067, 0x0}, + {0x90068, 0x0}, + {0x90069, 0x0}, + {0x9006a, 0x0}, + {0x9006b, 0x0}, + {0x9006c, 0x0}, + {0x9006d, 0x0}, + {0x9006e, 0x0}, + {0x9006f, 0x0}, + {0x90070, 0x0}, + {0x90071, 0x0}, + {0x90072, 0x0}, + {0x90073, 0x0}, + {0x90074, 0x0}, + {0x90075, 0x0}, + {0x90076, 0x0}, + {0x90077, 0x0}, + {0x90078, 0x0}, + {0x90079, 0x0}, + {0x9007a, 0x0}, + {0x9007b, 0x0}, + {0x9007c, 0x0}, + {0x9007d, 0x0}, + {0x9007e, 0x0}, + {0x9007f, 0x0}, + {0x90080, 0x0}, + {0x90081, 0x0}, + {0x90082, 0x0}, + {0x90083, 0x0}, + {0x90084, 0x0}, + {0x90085, 0x0}, + {0x90086, 0x0}, + {0x90087, 0x0}, + {0x90088, 0x0}, + {0x90089, 0x0}, + {0x9008a, 0x0}, + {0x9008b, 0x0}, + {0x9008c, 0x0}, + {0x9008d, 0x0}, + {0x9008e, 0x0}, + {0x9008f, 0x0}, + {0x90090, 0x0}, + {0x90091, 0x0}, + {0x90092, 0x0}, + {0x90093, 0x0}, + {0x90094, 0x0}, + {0x90095, 0x0}, + {0x90096, 0x0}, + {0x90097, 0x0}, + {0x90098, 0x0}, + {0x90099, 0x0}, + {0x9009a, 0x0}, + {0x9009b, 0x0}, + {0x9009c, 0x0}, + {0x9009d, 0x0}, + {0x9009e, 0x0}, + {0x9009f, 0x0}, + {0x900a0, 0x0}, + {0x900a1, 0x0}, + {0x900a2, 0x0}, + {0x900a3, 0x0}, + {0x900a4, 0x0}, + {0x900a5, 0x0}, + {0x900a6, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x0}, + {0x900a9, 0x0}, + {0x40000, 0x0}, + {0x40020, 0x0}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x0}, + {0x40021, 0x0}, + {0x40041, 0x0}, + {0x40061, 0x0}, + {0x40002, 0x0}, + {0x40022, 0x0}, + {0x40042, 0x0}, + {0x40062, 0x0}, + {0x40003, 0x0}, + {0x40023, 0x0}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x0}, + {0x40024, 0x0}, + {0x40044, 0x0}, + {0x40064, 0x0}, + {0x40005, 0x0}, + {0x40025, 0x0}, + {0x40045, 0x0}, + {0x40065, 0x0}, + {0x40006, 0x0}, + {0x40026, 0x0}, + {0x40046, 0x0}, + {0x40066, 0x0}, + {0x40007, 0x0}, + {0x40027, 0x0}, + {0x40047, 0x0}, + {0x40067, 0x0}, + {0x40008, 0x0}, + {0x40028, 0x0}, + {0x40048, 0x0}, + {0x40068, 0x0}, + {0x40009, 0x0}, + {0x40029, 0x0}, + {0x40049, 0x0}, + {0x40069, 0x0}, + {0x4000a, 0x0}, + {0x4002a, 0x0}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x0}, + {0x4002b, 0x0}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x0}, + {0x4002c, 0x0}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0x0}, + {0x4002d, 0x0}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x0}, + {0x4002e, 0x0}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x0}, + {0x4002f, 0x0}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x0}, + {0x40030, 0x0}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x0}, + {0x40031, 0x0}, + {0x40051, 0x0}, + {0x40071, 0x0}, + {0x40012, 0x0}, + {0x40032, 0x0}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x0}, + {0x40033, 0x0}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x0}, + {0x40034, 0x0}, + {0x40054, 0x0}, + {0x40074, 0x0}, + {0x40015, 0x0}, + {0x40035, 0x0}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x0}, + {0x40036, 0x0}, + {0x40056, 0x0}, + {0x40076, 0x0}, + {0x40017, 0x0}, + {0x40037, 0x0}, + {0x40057, 0x0}, + {0x40077, 0x0}, + {0x40018, 0x0}, + {0x40038, 0x0}, + {0x40058, 0x0}, + {0x40078, 0x0}, + {0x40019, 0x0}, + {0x40039, 0x0}, + {0x40059, 0x0}, + {0x40079, 0x0}, + {0x4001a, 0x0}, + {0x4003a, 0x0}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900aa, 0x0}, + {0x900ab, 0x0}, + {0x900ac, 0x0}, + {0x900ad, 0x0}, + {0x900ae, 0x0}, + {0x900af, 0x0}, + {0x900b0, 0x0}, + {0x900b1, 0x0}, + {0x900b2, 0x0}, + {0x900b3, 0x0}, + {0x900b4, 0x0}, + {0x900b5, 0x0}, + {0x900b6, 0x0}, + {0x900b7, 0x0}, + {0x900b8, 0x0}, + {0x900b9, 0x0}, + {0x900ba, 0x0}, + {0x900bb, 0x0}, + {0x900bc, 0x0}, + {0x900bd, 0x0}, + {0x900be, 0x0}, + {0x900bf, 0x0}, + {0x900c0, 0x0}, + {0x900c1, 0x0}, + {0x900c2, 0x0}, + {0x900c3, 0x0}, + {0x900c4, 0x0}, + {0x900c5, 0x0}, + {0x900c6, 0x0}, + {0x900c7, 0x0}, + {0x900c8, 0x0}, + {0x900c9, 0x0}, + {0x900ca, 0x0}, + {0x900cb, 0x0}, + {0x900cc, 0x0}, + {0x900cd, 0x0}, + {0x900ce, 0x0}, + {0x900cf, 0x0}, + {0x900d0, 0x0}, + {0x900d1, 0x0}, + {0x900d2, 0x0}, + {0x900d3, 0x0}, + {0x900d4, 0x0}, + {0x900d5, 0x0}, + {0x900d6, 0x0}, + {0x900d7, 0x0}, + {0x900d8, 0x0}, + {0x900d9, 0x0}, + {0x900da, 0x0}, + {0x900db, 0x0}, + {0x900dc, 0x0}, + {0x900dd, 0x0}, + {0x900de, 0x0}, + {0x900df, 0x0}, + {0x900e0, 0x0}, + {0x900e1, 0x0}, + {0x900e2, 0x0}, + {0x900e3, 0x0}, + {0x900e4, 0x0}, + {0x900e5, 0x0}, + {0x900e6, 0x0}, + {0x900e7, 0x0}, + {0x900e8, 0x0}, + {0x900e9, 0x0}, + {0x900ea, 0x0}, + {0x900eb, 0x0}, + {0x900ec, 0x0}, + {0x900ed, 0x0}, + {0x900ee, 0x0}, + {0x900ef, 0x0}, + {0x900f0, 0x0}, + {0x900f1, 0x0}, + {0x900f2, 0x0}, + {0x900f3, 0x0}, + {0x900f4, 0x0}, + {0x900f5, 0x0}, + {0x900f6, 0x0}, + {0x900f7, 0x0}, + {0x900f8, 0x0}, + {0x900f9, 0x0}, + {0x900fa, 0x0}, + {0x900fb, 0x0}, + {0x900fc, 0x0}, + {0x900fd, 0x0}, + {0x900fe, 0x0}, + {0x900ff, 0x0}, + {0x90100, 0x0}, + {0x90101, 0x0}, + {0x90102, 0x0}, + {0x90103, 0x0}, + {0x90104, 0x0}, + {0x90105, 0x0}, + {0x90106, 0x0}, + {0x90107, 0x0}, + {0x90108, 0x0}, + {0x90109, 0x0}, + {0x9010a, 0x0}, + {0x9010b, 0x0}, + {0x9010c, 0x0}, + {0x9010d, 0x0}, + {0x9010e, 0x0}, + {0x9010f, 0x0}, + {0x90110, 0x0}, + {0x90111, 0x0}, + {0x90112, 0x0}, + {0x90113, 0x0}, + {0x90114, 0x0}, + {0x90115, 0x0}, + {0x90116, 0x0}, + {0x90117, 0x0}, + {0x90118, 0x0}, + {0x90119, 0x0}, + {0x9011a, 0x0}, + {0x9011b, 0x0}, + {0x9011c, 0x0}, + {0x9011d, 0x0}, + {0x9011e, 0x0}, + {0x9011f, 0x0}, + {0x90120, 0x0}, + {0x90121, 0x0}, + {0x90122, 0x0}, + {0x90123, 0x0}, + {0x90124, 0x0}, + {0x90125, 0x0}, + {0x90126, 0x0}, + {0x90127, 0x0}, + {0x90128, 0x0}, + {0x90129, 0x0}, + {0x9012a, 0x0}, + {0x9012b, 0x0}, + {0x9012c, 0x0}, + {0x9012d, 0x0}, + {0x9012e, 0x0}, + {0x9012f, 0x0}, + {0x90130, 0x0}, + {0x90131, 0x0}, + {0x90132, 0x0}, + {0x90133, 0x0}, + {0x90134, 0x0}, + {0x90135, 0x0}, + {0x90136, 0x0}, + {0x90137, 0x0}, + {0x90138, 0x0}, + {0x90139, 0x0}, + {0x9013a, 0x0}, + {0x9013b, 0x0}, + {0x9013c, 0x0}, + {0x9013d, 0x0}, + {0x9013e, 0x0}, + {0x9013f, 0x0}, + {0x90140, 0x0}, + {0x90141, 0x0}, + {0x90142, 0x0}, + {0x90143, 0x0}, + {0x90144, 0x0}, + {0x90145, 0x0}, + {0x90146, 0x0}, + {0x90147, 0x0}, + {0x90148, 0x0}, + {0x90149, 0x0}, + {0x9014a, 0x0}, + {0x9014b, 0x0}, + {0x9014c, 0x0}, + {0x9014d, 0x0}, + {0x9014e, 0x0}, + {0x9014f, 0x0}, + {0x90150, 0x0}, + {0x90151, 0x0}, + {0x90152, 0x0}, + {0x90153, 0x0}, + {0x90154, 0x0}, + {0x90155, 0x0}, + {0x90156, 0x0}, + {0x90157, 0x0}, + {0x90158, 0x0}, + {0x90159, 0x0}, + {0x9015a, 0x0}, + {0x9015b, 0x0}, + {0x9015c, 0x0}, + {0x9015d, 0x0}, + {0x9015e, 0x0}, + {0x9015f, 0x0}, + {0x90160, 0x0}, + {0x90161, 0x0}, + {0x90162, 0x0}, + {0x90163, 0x0}, + {0x90164, 0x0}, + {0x90165, 0x0}, + {0x90166, 0x0}, + {0x90167, 0x0}, + {0x90168, 0x0}, + {0x90169, 0x0}, + {0x9016a, 0x0}, + {0x9016b, 0x0}, + {0x9016c, 0x0}, + {0x9016d, 0x0}, + {0x9016e, 0x0}, + {0x9016f, 0x0}, + {0x90170, 0x0}, + {0x90171, 0x0}, + {0x90172, 0x0}, + {0x90173, 0x0}, + {0x90174, 0x0}, + {0x90175, 0x0}, + {0x90176, 0x0}, + {0x90177, 0x0}, + {0x90178, 0x0}, + {0x90179, 0x0}, + {0x9017a, 0x0}, + {0x9017b, 0x0}, + {0x9017c, 0x0}, + {0x9017d, 0x0}, + {0x9017e, 0x0}, + {0x9017f, 0x0}, + {0x90180, 0x0}, + {0x90181, 0x0}, + {0x90182, 0x0}, + {0x90183, 0x0}, + {0x90184, 0x0}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x0}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x0}, + {0x90017, 0x0}, + {0x9001f, 0x0}, + {0x90026, 0x0}, + {0x400d0, 0x0}, + {0x400d1, 0x0}, + {0x400d2, 0x0}, + {0x400d3, 0x0}, + {0x400d4, 0x0}, + {0x400d5, 0x0}, + {0x400d6, 0x0}, + {0x400d7, 0x0}, + {0x200be, 0x0}, + {0x2000b, 0x0}, + {0x2000c, 0x0}, + {0x2000d, 0x0}, + {0x2000e, 0x0}, + {0x12000b, 0x0}, + {0x12000c, 0x0}, + {0x12000d, 0x0}, + {0x12000e, 0x0}, + {0x22000b, 0x0}, + {0x22000c, 0x0}, + {0x22000d, 0x0}, + {0x22000e, 0x0}, + {0x9000c, 0x0}, + {0x9000d, 0x0}, + {0x9000e, 0x0}, + {0x9000f, 0x0}, + {0x90010, 0x0}, + {0x90011, 0x0}, + {0x90012, 0x0}, + {0x90013, 0x0}, + {0x20010, 0x0}, + {0x20011, 0x0}, + {0x120010, 0x0}, + {0x120011, 0x0}, + {0x40080, 0x0}, + {0x40081, 0x0}, + {0x40082, 0x0}, + {0x40083, 0x0}, + {0x40084, 0x0}, + {0x40085, 0x0}, + {0x140080, 0x0}, + {0x140081, 0x0}, + {0x140082, 0x0}, + {0x140083, 0x0}, + {0x140084, 0x0}, + {0x140085, 0x0}, + {0x240080, 0x0}, + {0x240081, 0x0}, + {0x240082, 0x0}, + {0x240083, 0x0}, + {0x240084, 0x0}, + {0x240085, 0x0}, + {0x400fd, 0x0}, + {0x400f1, 0x0}, + {0x10011, 0x0}, + {0x10012, 0x0}, + {0x10013, 0x0}, + {0x10018, 0x0}, + {0x10002, 0x0}, + {0x100b2, 0x0}, + {0x101b4, 0x0}, + {0x102b4, 0x0}, + {0x103b4, 0x0}, + {0x104b4, 0x0}, + {0x105b4, 0x0}, + {0x106b4, 0x0}, + {0x107b4, 0x0}, + {0x108b4, 0x0}, + {0x11011, 0x0}, + {0x11012, 0x0}, + {0x11013, 0x0}, + {0x11018, 0x0}, + {0x11002, 0x0}, + {0x110b2, 0x0}, + {0x111b4, 0x0}, + {0x112b4, 0x0}, + {0x113b4, 0x0}, + {0x114b4, 0x0}, + {0x115b4, 0x0}, + {0x116b4, 0x0}, + {0x117b4, 0x0}, + {0x118b4, 0x0}, + {0x20089, 0x0}, + {0xc0080, 0x0}, + {0x200cb, 0x0}, + {0x10068, 0x0}, + {0x10069, 0x0}, + {0x10168, 0x0}, + {0x10169, 0x0}, + {0x10268, 0x0}, + {0x10269, 0x0}, + {0x10368, 0x0}, + {0x10369, 0x0}, + {0x10468, 0x0}, + {0x10469, 0x0}, + {0x10568, 0x0}, + {0x10569, 0x0}, + {0x10668, 0x0}, + {0x10669, 0x0}, + {0x10768, 0x0}, + {0x10769, 0x0}, + {0x10868, 0x0}, + {0x10869, 0x0}, + {0x100aa, 0x0}, + {0x10062, 0x0}, + {0x10001, 0x0}, + {0x100a0, 0x0}, + {0x100a1, 0x0}, + {0x100a2, 0x0}, + {0x100a3, 0x0}, + {0x100a4, 0x0}, + {0x100a5, 0x0}, + {0x100a6, 0x0}, + {0x100a7, 0x0}, + {0x11068, 0x0}, + {0x11069, 0x0}, + {0x11168, 0x0}, + {0x11169, 0x0}, + {0x11268, 0x0}, + {0x11269, 0x0}, + {0x11368, 0x0}, + {0x11369, 0x0}, + {0x11468, 0x0}, + {0x11469, 0x0}, + {0x11568, 0x0}, + {0x11569, 0x0}, + {0x11668, 0x0}, + {0x11669, 0x0}, + {0x11768, 0x0}, + {0x11769, 0x0}, + {0x11868, 0x0}, + {0x11869, 0x0}, + {0x110aa, 0x0}, + {0x11062, 0x0}, + {0x11001, 0x0}, + {0x110a0, 0x0}, + {0x110a1, 0x0}, + {0x110a2, 0x0}, + {0x110a3, 0x0}, + {0x110a4, 0x0}, + {0x110a5, 0x0}, + {0x110a6, 0x0}, + {0x110a7, 0x0}, + {0x80, 0x0}, + {0x1080, 0x0}, + {0x2080, 0x0}, + {0x10020, 0x0}, + {0x10080, 0x0}, + {0x10081, 0x0}, + {0x100d0, 0x0}, + {0x100d1, 0x0}, + {0x1008c, 0x0}, + {0x1008d, 0x0}, + {0x10180, 0x0}, + {0x10181, 0x0}, + {0x101d0, 0x0}, + {0x101d1, 0x0}, + {0x1018c, 0x0}, + {0x1018d, 0x0}, + {0x100c0, 0x0}, + {0x100c1, 0x0}, + {0x101c0, 0x0}, + {0x101c1, 0x0}, + {0x102c0, 0x0}, + {0x102c1, 0x0}, + {0x103c0, 0x0}, + {0x103c1, 0x0}, + {0x104c0, 0x0}, + {0x104c1, 0x0}, + {0x105c0, 0x0}, + {0x105c1, 0x0}, + {0x106c0, 0x0}, + {0x106c1, 0x0}, + {0x107c0, 0x0}, + {0x107c1, 0x0}, + {0x108c0, 0x0}, + {0x108c1, 0x0}, + {0x100ae, 0x0}, + {0x100af, 0x0}, + {0x11020, 0x0}, + {0x11080, 0x0}, + {0x11081, 0x0}, + {0x110d0, 0x0}, + {0x110d1, 0x0}, + {0x1108c, 0x0}, + {0x1108d, 0x0}, + {0x11180, 0x0}, + {0x11181, 0x0}, + {0x111d0, 0x0}, + {0x111d1, 0x0}, + {0x1118c, 0x0}, + {0x1118d, 0x0}, + {0x110c0, 0x0}, + {0x110c1, 0x0}, + {0x111c0, 0x0}, + {0x111c1, 0x0}, + {0x112c0, 0x0}, + {0x112c1, 0x0}, + {0x113c0, 0x0}, + {0x113c1, 0x0}, + {0x114c0, 0x0}, + {0x114c1, 0x0}, + {0x115c0, 0x0}, + {0x115c1, 0x0}, + {0x116c0, 0x0}, + {0x116c1, 0x0}, + {0x117c0, 0x0}, + {0x117c1, 0x0}, + {0x118c0, 0x0}, + {0x118c1, 0x0}, + {0x110ae, 0x0}, + {0x110af, 0x0}, + {0x90201, 0x0}, + {0x90202, 0x0}, + {0x90203, 0x0}, + {0x90205, 0x0}, + {0x90206, 0x0}, + {0x90207, 0x0}, + {0x90208, 0x0}, + {0x20020, 0x0}, + {0x100080, 0x0}, + {0x101080, 0x0}, + {0x102080, 0x0}, + {0x110020, 0x0}, + {0x110080, 0x0}, + {0x110081, 0x0}, + {0x1100d0, 0x0}, + {0x1100d1, 0x0}, + {0x11008c, 0x0}, + {0x11008d, 0x0}, + {0x110180, 0x0}, + {0x110181, 0x0}, + {0x1101d0, 0x0}, + {0x1101d1, 0x0}, + {0x11018c, 0x0}, + {0x11018d, 0x0}, + {0x1100c0, 0x0}, + {0x1100c1, 0x0}, + {0x1101c0, 0x0}, + {0x1101c1, 0x0}, + {0x1102c0, 0x0}, + {0x1102c1, 0x0}, + {0x1103c0, 0x0}, + {0x1103c1, 0x0}, + {0x1104c0, 0x0}, + {0x1104c1, 0x0}, + {0x1105c0, 0x0}, + {0x1105c1, 0x0}, + {0x1106c0, 0x0}, + {0x1106c1, 0x0}, + {0x1107c0, 0x0}, + {0x1107c1, 0x0}, + {0x1108c0, 0x0}, + {0x1108c1, 0x0}, + {0x1100ae, 0x0}, + {0x1100af, 0x0}, + {0x111020, 0x0}, + {0x111080, 0x0}, + {0x111081, 0x0}, + {0x1110d0, 0x0}, + {0x1110d1, 0x0}, + {0x11108c, 0x0}, + {0x11108d, 0x0}, + {0x111180, 0x0}, + {0x111181, 0x0}, + {0x1111d0, 0x0}, + {0x1111d1, 0x0}, + {0x11118c, 0x0}, + {0x11118d, 0x0}, + {0x1110c0, 0x0}, + {0x1110c1, 0x0}, + {0x1111c0, 0x0}, + {0x1111c1, 0x0}, + {0x1112c0, 0x0}, + {0x1112c1, 0x0}, + {0x1113c0, 0x0}, + {0x1113c1, 0x0}, + {0x1114c0, 0x0}, + {0x1114c1, 0x0}, + {0x1115c0, 0x0}, + {0x1115c1, 0x0}, + {0x1116c0, 0x0}, + {0x1116c1, 0x0}, + {0x1117c0, 0x0}, + {0x1117c1, 0x0}, + {0x1118c0, 0x0}, + {0x1118c1, 0x0}, + {0x1110ae, 0x0}, + {0x1110af, 0x0}, + {0x190201, 0x0}, + {0x190202, 0x0}, + {0x190203, 0x0}, + {0x190205, 0x0}, + {0x190206, 0x0}, + {0x190207, 0x0}, + {0x190208, 0x0}, + {0x120020, 0x0}, + {0x200080, 0x0}, + {0x201080, 0x0}, + {0x202080, 0x0}, + {0x210020, 0x0}, + {0x210080, 0x0}, + {0x210081, 0x0}, + {0x2100d0, 0x0}, + {0x2100d1, 0x0}, + {0x21008c, 0x0}, + {0x21008d, 0x0}, + {0x210180, 0x0}, + {0x210181, 0x0}, + {0x2101d0, 0x0}, + {0x2101d1, 0x0}, + {0x21018c, 0x0}, + {0x21018d, 0x0}, + {0x2100c0, 0x0}, + {0x2100c1, 0x0}, + {0x2101c0, 0x0}, + {0x2101c1, 0x0}, + {0x2102c0, 0x0}, + {0x2102c1, 0x0}, + {0x2103c0, 0x0}, + {0x2103c1, 0x0}, + {0x2104c0, 0x0}, + {0x2104c1, 0x0}, + {0x2105c0, 0x0}, + {0x2105c1, 0x0}, + {0x2106c0, 0x0}, + {0x2106c1, 0x0}, + {0x2107c0, 0x0}, + {0x2107c1, 0x0}, + {0x2108c0, 0x0}, + {0x2108c1, 0x0}, + {0x2100ae, 0x0}, + {0x2100af, 0x0}, + {0x211020, 0x0}, + {0x211080, 0x0}, + {0x211081, 0x0}, + {0x2110d0, 0x0}, + {0x2110d1, 0x0}, + {0x21108c, 0x0}, + {0x21108d, 0x0}, + {0x211180, 0x0}, + {0x211181, 0x0}, + {0x2111d0, 0x0}, + {0x2111d1, 0x0}, + {0x21118c, 0x0}, + {0x21118d, 0x0}, + {0x2110c0, 0x0}, + {0x2110c1, 0x0}, + {0x2111c0, 0x0}, + {0x2111c1, 0x0}, + {0x2112c0, 0x0}, + {0x2112c1, 0x0}, + {0x2113c0, 0x0}, + {0x2113c1, 0x0}, + {0x2114c0, 0x0}, + {0x2114c1, 0x0}, + {0x2115c0, 0x0}, + {0x2115c1, 0x0}, + {0x2116c0, 0x0}, + {0x2116c1, 0x0}, + {0x2117c0, 0x0}, + {0x2117c1, 0x0}, + {0x2118c0, 0x0}, + {0x2118c1, 0x0}, + {0x2110ae, 0x0}, + {0x2110af, 0x0}, + {0x290201, 0x0}, + {0x290202, 0x0}, + {0x290203, 0x0}, + {0x290205, 0x0}, + {0x290206, 0x0}, + {0x290207, 0x0}, + {0x290208, 0x0}, + {0x220020, 0x0}, + {0x20077, 0x0}, + {0x20072, 0x0}, + {0x20073, 0x0}, + {0x400c0, 0x0}, + {0x10040, 0x0}, + {0x10140, 0x0}, + {0x10240, 0x0}, + {0x10340, 0x0}, + {0x10440, 0x0}, + {0x10540, 0x0}, + {0x10640, 0x0}, + {0x10740, 0x0}, + {0x10840, 0x0}, + {0x11040, 0x0}, + {0x11140, 0x0}, + {0x11240, 0x0}, + {0x11340, 0x0}, + {0x11440, 0x0}, + {0x11540, 0x0}, + {0x11640, 0x0}, + {0x11740, 0x0}, + {0x11840, 0x0}, +}; + +/* P0 message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4808}, + {0x5401e, 0x4}, + {0x5401f, 0x2dd4}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4808}, + {0x54024, 0x4}, + {0x54032, 0xd400}, + {0x54033, 0x332d}, + {0x54034, 0x4600}, + {0x54035, 0x848}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0xd400}, + {0x54039, 0x332d}, + {0x5403a, 0x4600}, + {0x5403b, 0x848}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* P1 message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x1}, + {0x54003, 0x640}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x52a4}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4808}, + {0x5401e, 0x4}, + {0x5401f, 0x52a4}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4808}, + {0x54024, 0x4}, + {0x54032, 0xa400}, + {0x54033, 0x3352}, + {0x54034, 0x4600}, + {0x54035, 0x848}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0xa400}, + {0x54039, 0x3352}, + {0x5403a, 0x4600}, + {0x5403b, 0x848}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* P2 message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x270}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x994}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4800}, + {0x5401e, 0x4}, + {0x5401f, 0x994}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4800}, + {0x54024, 0x4}, + {0x54032, 0x9400}, + {0x54033, 0x3309}, + {0x54034, 0x4600}, + {0x54035, 0x48}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0x9400}, + {0x54039, 0x3309}, + {0x5403a, 0x4600}, + {0x5403b, 0x48}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* P0 2D message block parameter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54010, 0x2080}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x33}, + {0x5401b, 0x4846}, + {0x5401c, 0x4808}, + {0x5401e, 0x4}, + {0x5401f, 0x2dd4}, + {0x54020, 0x33}, + {0x54021, 0x4846}, + {0x54022, 0x4808}, + {0x54024, 0x4}, + {0x54032, 0xd400}, + {0x54033, 0x332d}, + {0x54034, 0x4600}, + {0x54035, 0x848}, + {0x54036, 0x48}, + {0x54037, 0x400}, + {0x54038, 0xd400}, + {0x54039, 0x332d}, + {0x5403a, 0x4600}, + {0x5403b, 0x848}, + {0x5403c, 0x48}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xb}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x633}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x633}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x633}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x30}, + {0x90051, 0x65a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x45a}, + {0x90055, 0x9}, + {0x90056, 0x0}, + {0x90057, 0x448}, + {0x90058, 0x109}, + {0x90059, 0x40}, + {0x9005a, 0x633}, + {0x9005b, 0x179}, + {0x9005c, 0x1}, + {0x9005d, 0x618}, + {0x9005e, 0x109}, + {0x9005f, 0x40c0}, + {0x90060, 0x633}, + {0x90061, 0x149}, + {0x90062, 0x8}, + {0x90063, 0x4}, + {0x90064, 0x48}, + {0x90065, 0x4040}, + {0x90066, 0x633}, + {0x90067, 0x149}, + {0x90068, 0x0}, + {0x90069, 0x4}, + {0x9006a, 0x48}, + {0x9006b, 0x40}, + {0x9006c, 0x633}, + {0x9006d, 0x149}, + {0x9006e, 0x0}, + {0x9006f, 0x658}, + {0x90070, 0x109}, + {0x90071, 0x10}, + {0x90072, 0x4}, + {0x90073, 0x18}, + {0x90074, 0x0}, + {0x90075, 0x4}, + {0x90076, 0x78}, + {0x90077, 0x549}, + {0x90078, 0x633}, + {0x90079, 0x159}, + {0x9007a, 0xd49}, + {0x9007b, 0x633}, + {0x9007c, 0x159}, + {0x9007d, 0x94a}, + {0x9007e, 0x633}, + {0x9007f, 0x159}, + {0x90080, 0x441}, + {0x90081, 0x633}, + {0x90082, 0x149}, + {0x90083, 0x42}, + {0x90084, 0x633}, + {0x90085, 0x149}, + {0x90086, 0x1}, + {0x90087, 0x633}, + {0x90088, 0x149}, + {0x90089, 0x0}, + {0x9008a, 0xe0}, + {0x9008b, 0x109}, + {0x9008c, 0xa}, + {0x9008d, 0x10}, + {0x9008e, 0x109}, + {0x9008f, 0x9}, + {0x90090, 0x3c0}, + {0x90091, 0x149}, + {0x90092, 0x9}, + {0x90093, 0x3c0}, + {0x90094, 0x159}, + {0x90095, 0x18}, + {0x90096, 0x10}, + {0x90097, 0x109}, + {0x90098, 0x0}, + {0x90099, 0x3c0}, + {0x9009a, 0x109}, + {0x9009b, 0x18}, + {0x9009c, 0x4}, + {0x9009d, 0x48}, + {0x9009e, 0x18}, + {0x9009f, 0x4}, + {0x900a0, 0x58}, + {0x900a1, 0xb}, + {0x900a2, 0x10}, + {0x900a3, 0x109}, + {0x900a4, 0x1}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x900a7, 0x5}, + {0x900a8, 0x7c0}, + {0x900a9, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x625}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x625}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900aa, 0x0}, + {0x900ab, 0x790}, + {0x900ac, 0x11a}, + {0x900ad, 0x8}, + {0x900ae, 0x7aa}, + {0x900af, 0x2a}, + {0x900b0, 0x10}, + {0x900b1, 0x7b2}, + {0x900b2, 0x2a}, + {0x900b3, 0x0}, + {0x900b4, 0x7c8}, + {0x900b5, 0x109}, + {0x900b6, 0x10}, + {0x900b7, 0x10}, + {0x900b8, 0x109}, + {0x900b9, 0x10}, + {0x900ba, 0x2a8}, + {0x900bb, 0x129}, + {0x900bc, 0x8}, + {0x900bd, 0x370}, + {0x900be, 0x129}, + {0x900bf, 0xa}, + {0x900c0, 0x3c8}, + {0x900c1, 0x1a9}, + {0x900c2, 0xc}, + {0x900c3, 0x408}, + {0x900c4, 0x199}, + {0x900c5, 0x14}, + {0x900c6, 0x790}, + {0x900c7, 0x11a}, + {0x900c8, 0x8}, + {0x900c9, 0x4}, + {0x900ca, 0x18}, + {0x900cb, 0xe}, + {0x900cc, 0x408}, + {0x900cd, 0x199}, + {0x900ce, 0x8}, + {0x900cf, 0x8568}, + {0x900d0, 0x108}, + {0x900d1, 0x18}, + {0x900d2, 0x790}, + {0x900d3, 0x16a}, + {0x900d4, 0x8}, + {0x900d5, 0x1d8}, + {0x900d6, 0x169}, + {0x900d7, 0x10}, + {0x900d8, 0x8558}, + {0x900d9, 0x168}, + {0x900da, 0x1ff8}, + {0x900db, 0x85a8}, + {0x900dc, 0x1e8}, + {0x900dd, 0x50}, + {0x900de, 0x798}, + {0x900df, 0x16a}, + {0x900e0, 0x60}, + {0x900e1, 0x7a0}, + {0x900e2, 0x16a}, + {0x900e3, 0x8}, + {0x900e4, 0x8310}, + {0x900e5, 0x168}, + {0x900e6, 0x8}, + {0x900e7, 0xa310}, + {0x900e8, 0x168}, + {0x900e9, 0xa}, + {0x900ea, 0x408}, + {0x900eb, 0x169}, + {0x900ec, 0x6e}, + {0x900ed, 0x0}, + {0x900ee, 0x68}, + {0x900ef, 0x0}, + {0x900f0, 0x408}, + {0x900f1, 0x169}, + {0x900f2, 0x0}, + {0x900f3, 0x8310}, + {0x900f4, 0x168}, + {0x900f5, 0x0}, + {0x900f6, 0xa310}, + {0x900f7, 0x168}, + {0x900f8, 0x1ff8}, + {0x900f9, 0x85a8}, + {0x900fa, 0x1e8}, + {0x900fb, 0x68}, + {0x900fc, 0x798}, + {0x900fd, 0x16a}, + {0x900fe, 0x78}, + {0x900ff, 0x7a0}, + {0x90100, 0x16a}, + {0x90101, 0x68}, + {0x90102, 0x790}, + {0x90103, 0x16a}, + {0x90104, 0x8}, + {0x90105, 0x8b10}, + {0x90106, 0x168}, + {0x90107, 0x8}, + {0x90108, 0xab10}, + {0x90109, 0x168}, + {0x9010a, 0xa}, + {0x9010b, 0x408}, + {0x9010c, 0x169}, + {0x9010d, 0x58}, + {0x9010e, 0x0}, + {0x9010f, 0x68}, + {0x90110, 0x0}, + {0x90111, 0x408}, + {0x90112, 0x169}, + {0x90113, 0x0}, + {0x90114, 0x8b10}, + {0x90115, 0x168}, + {0x90116, 0x1}, + {0x90117, 0xab10}, + {0x90118, 0x168}, + {0x90119, 0x0}, + {0x9011a, 0x1d8}, + {0x9011b, 0x169}, + {0x9011c, 0x80}, + {0x9011d, 0x790}, + {0x9011e, 0x16a}, + {0x9011f, 0x18}, + {0x90120, 0x7aa}, + {0x90121, 0x6a}, + {0x90122, 0xa}, + {0x90123, 0x0}, + {0x90124, 0x1e9}, + {0x90125, 0x8}, + {0x90126, 0x8080}, + {0x90127, 0x108}, + {0x90128, 0xf}, + {0x90129, 0x408}, + {0x9012a, 0x169}, + {0x9012b, 0xc}, + {0x9012c, 0x0}, + {0x9012d, 0x68}, + {0x9012e, 0x9}, + {0x9012f, 0x0}, + {0x90130, 0x1a9}, + {0x90131, 0x0}, + {0x90132, 0x408}, + {0x90133, 0x169}, + {0x90134, 0x0}, + {0x90135, 0x8080}, + {0x90136, 0x108}, + {0x90137, 0x8}, + {0x90138, 0x7aa}, + {0x90139, 0x6a}, + {0x9013a, 0x0}, + {0x9013b, 0x8568}, + {0x9013c, 0x108}, + {0x9013d, 0xb7}, + {0x9013e, 0x790}, + {0x9013f, 0x16a}, + {0x90140, 0x1f}, + {0x90141, 0x0}, + {0x90142, 0x68}, + {0x90143, 0x8}, + {0x90144, 0x8558}, + {0x90145, 0x168}, + {0x90146, 0xf}, + {0x90147, 0x408}, + {0x90148, 0x169}, + {0x90149, 0xd}, + {0x9014a, 0x0}, + {0x9014b, 0x68}, + {0x9014c, 0x0}, + {0x9014d, 0x408}, + {0x9014e, 0x169}, + {0x9014f, 0x0}, + {0x90150, 0x8558}, + {0x90151, 0x168}, + {0x90152, 0x8}, + {0x90153, 0x3c8}, + {0x90154, 0x1a9}, + {0x90155, 0x3}, + {0x90156, 0x370}, + {0x90157, 0x129}, + {0x90158, 0x20}, + {0x90159, 0x2aa}, + {0x9015a, 0x9}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x104}, + {0x90164, 0x8}, + {0x90165, 0x448}, + {0x90166, 0x109}, + {0x90167, 0xf}, + {0x90168, 0x7c0}, + {0x90169, 0x109}, + {0x9016a, 0x0}, + {0x9016b, 0xe8}, + {0x9016c, 0x109}, + {0x9016d, 0x47}, + {0x9016e, 0x630}, + {0x9016f, 0x109}, + {0x90170, 0x8}, + {0x90171, 0x618}, + {0x90172, 0x109}, + {0x90173, 0x8}, + {0x90174, 0xe0}, + {0x90175, 0x109}, + {0x90176, 0x0}, + {0x90177, 0x7c8}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0x8140}, + {0x9017b, 0x10c}, + {0x9017c, 0x0}, + {0x9017d, 0x478}, + {0x9017e, 0x109}, + {0x9017f, 0x0}, + {0x90180, 0x1}, + {0x90181, 0x8}, + {0x90182, 0x8}, + {0x90183, 0x4}, + {0x90184, 0x0}, + {0x90006, 0x8}, + {0x90007, 0x7c8}, + {0x90008, 0x109}, + {0x90009, 0x0}, + {0x9000a, 0x400}, + {0x9000b, 0x106}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2b}, + {0x90026, 0x69}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x200be, 0x3}, + {0x2000b, 0x384}, + {0x2000c, 0xc8}, + {0x2000d, 0x7d0}, + {0x2000e, 0x2c}, + {0x12000b, 0x1c2}, + {0x12000c, 0x64}, + {0x12000d, 0x3e8}, + {0x12000e, 0x2c}, + {0x22000b, 0xb0}, + {0x22000c, 0x27}, + {0x22000d, 0x186}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x2060}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x400f1, 0xe}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x20089, 0x1}, + {0x20088, 0x19}, + {0xc0080, 0x0}, + {0xd0000, 0x1}, +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 1600mts 1D */ + .drate = 1600, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 625mts 1D */ + .drate = 625, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 1600, 625, }, + .fsp_cfg = ddr_dram_fsp_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_dram_fsp_cfg), +}; diff --git a/board/freescale/imx93_qsb/spl.c b/board/freescale/imx93_qsb/spl.c new file mode 100644 index 00000000000..6fb69df1d8a --- /dev/null +++ b/board/freescale/imx93_qsb/spl.c @@ -0,0 +1,174 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 NXP + */ + +#include <command.h> +#include <cpu_func.h> +#include <hang.h> +#include <image.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/imx93_pins.h> +#include <asm/arch/mu.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch-mx7ulp/gpio.h> +#include <asm/mach-imx/ele_api.h> +#include <asm/mach-imx/syscounter.h> +#include <asm/sections.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> +#include <linux/delay.h> +#include <asm/arch/clock.h> +#include <asm/arch/ccm_regs.h> +#include <asm/arch/ddr.h> +#include <power/pmic.h> +#include <power/pca9450.h> +#include <asm/arch/trdc.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + return BOOT_DEVICE_BOOTROM; +} + +void spl_board_init(void) +{ + int ret; + + ret = ele_start_rng(); + if (ret) + printf("Fail to start RNG: %d\n", ret); + + puts("Normal Boot\n"); +} + +void spl_dram_init(void) +{ + struct dram_timing_info *ptiming = &dram_timing; + + printf("DDR: %uMTS\n", ptiming->fsp_msg[0].drate); + ddr_init(ptiming); +} + +#if CONFIG_IS_ENABLED(DM_PMIC_PCA9450) +int power_init_board(void) +{ + struct udevice *dev; + int ret; + unsigned int val = 0, buck_val; + + ret = pmic_get("pmic@25", &dev); + if (ret == -ENODEV) { + puts("No pca9450@25\n"); + return 0; + } + if (ret != 0) + return ret; + + /* BUCKxOUT_DVS0/1 control BUCK123 output */ + pmic_reg_write(dev, PCA9450_BUCK123_DVS, 0x29); + + /* enable DVS control through PMIC_STBY_REQ */ + pmic_reg_write(dev, PCA9450_BUCK1CTRL, 0x59); + + ret = pmic_reg_read(dev, PCA9450_PWR_CTRL); + if (ret < 0) + return ret; + + val = ret; + + if (is_voltage_mode(VOLT_LOW_DRIVE)) { + buck_val = 0x0c; /* 0.8v for Low drive mode */ + printf("PMIC: Low Drive Voltage Mode\n"); + } else if (is_voltage_mode(VOLT_NOMINAL_DRIVE)) { + buck_val = 0x10; /* 0.85v for Nominal drive mode */ + printf("PMIC: Nominal Voltage Mode\n"); + } else { + buck_val = 0x14; /* 0.9v for Over drive mode */ + printf("PMIC: Over Drive Voltage Mode\n"); + } + + if (val & PCA9450_REG_PWRCTRL_TOFF_DEB) { + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, buck_val); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, buck_val); + } else { + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, buck_val + 0x4); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, buck_val + 0x4); + } + + /* set standby voltage to 0.65v */ + if (val & PCA9450_REG_PWRCTRL_TOFF_DEB) + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x0); + else + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x4); + + /* 1.1v for LPDDR4 */ + pmic_reg_write(dev, PCA9450_BUCK2OUT_DVS0, 0x28); + + /* I2C_LT_EN*/ + pmic_reg_write(dev, 0xa, 0x3); + + /* set WDOG_B_CFG to cold reset */ + pmic_reg_write(dev, PCA9450_RESET_CTRL, 0xA1); + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + timer_init(); + + arch_cpu_init(); + + board_early_init_f(); + + spl_early_init(); + + preloader_console_init(); + + ret = imx9_probe_mu(); + if (ret) { + printf("Fail to init ELE API\n"); + } else { + debug("SOC: 0x%x\n", gd->arch.soc_rev); + debug("LC: 0x%x\n", gd->arch.lifecycle); + } + + clock_init_late(); + + power_init_board(); + + if (!is_voltage_mode(VOLT_LOW_DRIVE)) + set_arm_clk(get_cpu_speed_grade_hz()); + + /* Init power of mix */ + soc_power_init(); + + /* Setup TRDC for DDR access */ + trdc_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Put M33 into CPUWAIT for following kick */ + ret = m33_prepare(); + if (!ret) + printf("M33 prepare ok\n"); + + board_init_r(NULL, 0); +} diff --git a/configs/imx93_9x9_qsb_defconfig b/configs/imx93_9x9_qsb_defconfig new file mode 100644 index 00000000000..b6d23d2decd --- /dev/null +++ b/configs/imx93_9x9_qsb_defconfig @@ -0,0 +1,139 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX9=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-9x9-qsb" +CONFIG_SPL_TEXT_BASE=0x2049A000 +CONFIG_TARGET_IMX93_9X9_QSB=y +CONFIG_SYS_MONITOR_LEN=524288 +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK=0x20519dd0 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x18000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2051a000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SYS_LOAD_ADDR=0x80400000 +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x90000000 +CONFIG_REMAKE_ELF=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_DEFAULT_FDT_FILE="imx93-9x9-qsb.dtb" +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_LOAD_IMX_CONTAINER=y +CONFIG_IMX_CONTAINER_CFG="arch/arm/mach-imx/imx9/container.cfg" +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x83200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_CPU=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="eth1" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_IMX93=y +CONFIG_CLK_IMX93=y +CONFIG_CPU=y +CONFIG_CPU_IMX=y +CONFIG_IMX_RGPIO2P=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_ANEG_TIMEOUT=20000 +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH_PHY=y +CONFIG_PHY_GIGE=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX93=y +CONFIG_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PCA9450=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_NXP_FSPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_CMD_POWEROFF=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_ULP_WATCHDOG=y +CONFIG_WDT=y +CONFIG_LZO=y +CONFIG_BZIP2=y diff --git a/configs/imx93_9x9_qsb_inline_ecc_defconfig b/configs/imx93_9x9_qsb_inline_ecc_defconfig new file mode 100644 index 00000000000..4fe6620d8ca --- /dev/null +++ b/configs/imx93_9x9_qsb_inline_ecc_defconfig @@ -0,0 +1,140 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX9=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-9x9-qsb" +CONFIG_SPL_TEXT_BASE=0x2049A000 +CONFIG_TARGET_IMX93_9X9_QSB=y +CONFIG_SYS_MONITOR_LEN=524288 +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK=0x20519dd0 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x18000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2051a000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SYS_LOAD_ADDR=0x80400000 +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x90000000 +CONFIG_REMAKE_ELF=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_DEFAULT_FDT_FILE="imx93-9x9-qsb.dtb" +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_LOAD_IMX_CONTAINER=y +CONFIG_IMX_CONTAINER_CFG="arch/arm/mach-imx/imx9/container.cfg" +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x83200000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_CPU=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="eth1" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_IMX93=y +CONFIG_CLK_IMX93=y +CONFIG_CPU=y +CONFIG_CPU_IMX=y +CONFIG_IMX9_DRAM_INLINE_ECC=y +CONFIG_IMX_RGPIO2P=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_ANEG_TIMEOUT=20000 +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH_PHY=y +CONFIG_PHY_GIGE=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX93=y +CONFIG_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PCA9450=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_NXP_FSPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_CMD_POWEROFF=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_ULP_WATCHDOG=y +CONFIG_WDT=y +CONFIG_LZO=y +CONFIG_BZIP2=y diff --git a/doc/board/nxp/imx93_9x9_qsb.rst b/doc/board/nxp/imx93_9x9_qsb.rst new file mode 100644 index 00000000000..f2520fb302f --- /dev/null +++ b/doc/board/nxp/imx93_9x9_qsb.rst @@ -0,0 +1,68 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +imx93_9x9_qsb +======================= + +U-Boot for the NXP i.MX93 Quick Starter Board + +Quick Start +----------- + +- Get and Build the ARM Trusted firmware +- Get the DDR firmware +- Get ahab-container.img +- Build U-Boot +- Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +Note: srctree is U-Boot source directory +Get ATF from: https://github.com/nxp-imx/imx-atf/ +branch: lf_v2.10 + +.. code-block:: bash + + $ unset LDFLAGS + $ make PLAT=imx93 bl31 + $ cp build/imx93/release/bl31.bin $(srctree) + +Get the DDR firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.21.bin + $ chmod +x firmware-imx-8.21.bin + $ ./firmware-imx-8.21.bin + $ cp firmware-imx-8.21/firmware/ddr/synopsys/lpddr4*.bin $(srctree) + +Get ahab-container.img +--------------------------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-sentinel-0.11.bin + $ chmod +x firmware-sentinel-0.11.bin + $ ./firmware-sentinel-0.11.bin + $ cp firmware-sentinel-0.11/mx93a1-ahab-container.img $(srctree) + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=aarch64-poky-linux- + $ make imx93_9x9_qsb_defconfig + $ make + +Burn the flash.bin to MicroSD card offset 32KB: + +.. code-block:: bash + + $ dd if=flash.bin of=/dev/sd[x] bs=1024 seek=32 conv=notrunc + +Boot +---- + +Set Boot switch to SD boot diff --git a/doc/board/nxp/index.rst b/doc/board/nxp/index.rst index 5f1e878508e..734bab69807 100644 --- a/doc/board/nxp/index.rst +++ b/doc/board/nxp/index.rst @@ -12,6 +12,7 @@ NXP Semiconductors imx8mq_evk imx8qxp_mek imx8ulp_evk + imx93_9x9_qsb imx93_11x11_evk imxrt1020-evk imxrt1050-evk diff --git a/drivers/ddr/imx/imx9/Kconfig b/drivers/ddr/imx/imx9/Kconfig index b1795eec353..0c2ee89c31f 100644 --- a/drivers/ddr/imx/imx9/Kconfig +++ b/drivers/ddr/imx/imx9/Kconfig @@ -17,6 +17,12 @@ config IMX9_DRAM_PM_COUNTER help Enable DDR controller performance monitor counter for reference events.
+config IMX9_DRAM_INLINE_ECC + bool "Enable DDR INLINE ECC feature" + default n + help + Select to enable DDR INLINE ECC feature + config SAVED_DRAM_TIMING_BASE hex "Define the base address for saved dram timing" help diff --git a/include/configs/imx93_qsb.h b/include/configs/imx93_qsb.h new file mode 100644 index 00000000000..43ef07be902 --- /dev/null +++ b/include/configs/imx93_qsb.h @@ -0,0 +1,138 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2024 NXP + */ + +#ifndef __IMX93_QSB_H +#define __IMX93_QSB_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CFG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#ifdef CONFIG_SPL_BUILD +#define CFG_MALLOC_F_ADDR 0x204D0000 +#endif + +#ifdef CONFIG_DISTRO_DEFAULTS +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + +#include <config_distro_bootcmd.h> +#else +#define BOOTENV +#endif + +/* Initial environment variables */ +#define CFG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + "prepare_mcore=setenv mcore_clk clk-imx93.mcore_booted;\0" \ + "scriptaddr=0x83500000\0" \ + "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "image=Image\0" \ + "splashimage=0x90000000\0" \ + "console=ttyLP0,115200 earlycon\0" \ + "fdt_addr_r=0x83000000\0" \ + "fdt_addr=0x83000000\0" \ + "cntr_addr=0x98000000\0" \ + "cntr_file=os_cntr_signed.bin\0" \ + "boot_fit=no\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "bootm_size=0x10000000\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk1p2 rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot}\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile}\0" \ + "loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file}\0" \ + "auth_os=auth_cntr ${cntr_addr}\0" \ + "boot_os=booti ${loadaddr} - ${fdt_addr_r};\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${sec_boot} = yes; then " \ + "if run auth_os; then " \ + "run boot_os; " \ + "else " \ + "echo ERR: failed to authenticate; " \ + "fi; " \ + "else " \ + "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ + "bootm ${loadaddr}; " \ + "else " \ + "if run loadfdt; then " \ + "run boot_os; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi;" \ + "fi;\0" \ + "netargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "if test ${sec_boot} = yes; then " \ + "${get_cmd} ${cntr_addr} ${cntr_file}; " \ + "if run auth_os; then " \ + "run boot_os; " \ + "else " \ + "echo ERR: failed to authenticate; " \ + "fi; " \ + "else " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ + "bootm ${loadaddr}; " \ + "else " \ + "if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then " \ + "run boot_os; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi;" \ + "fi;\0" \ + "bsp_bootcmd=echo Running BSP bootcmd ...; " \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if test ${sec_boot} = yes; then " \ + "if run loadcntr; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "fi; " \ + "fi;" + +/* Link Definitions */ + +#define CFG_SYS_INIT_RAM_ADDR 0x80000000 +#define CFG_SYS_INIT_RAM_SIZE 0x200000 + +#define CFG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM 0x80000000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ + +/* Using ULP WDOG for reset */ +#define WDOG_BASE_ADDR WDG3_BASE_ADDR + +#endif
On Wed, Oct 9, 2024 at 4:27 AM Peng Fan (OSS) peng.fan@oss.nxp.com wrote:
+&usdhc2 {
bootph-pre-ram;
bootph-some-ram;
fsl,signal-voltage-switch-extra-delay-ms = <8>;
Why is 'fsl,signal-voltage-switch-extra-delay-ms' a U-Boot-only property?
How does kernel handle usdhc2 without this property?
+#include <usb.h> +#include <dwc3-uboot.h>
I don't see USB support in this file.
+#define UART_PAD_CTRL (PAD_CTL_DSE(6) | PAD_CTL_FSEL2) +#define WDOG_PAD_CTRL (PAD_CTL_DSE(6) | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
+static iomux_v3_cfg_t const uart_pads[] = {
MX93_PAD_UART1_RXD__LPUART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
MX93_PAD_UART1_TXD__LPUART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
+int board_early_init_f(void) +{
imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads));
With DM_SERIAL, there is no need for UART board code and watchdog IOMUX settings.
+int board_phy_config(struct phy_device *phydev) +{
if (phydev->drv->config)
phydev->drv->config(phydev);
Is this really needed?
val = ret;
The unit for Volt is V with a capital letter. Please fix it globally.
In the commit log you put "Quick Start". Please be consistent.
- $ export CROSS_COMPILE=aarch64-poky-linux-
- $ make imx93_9x9_qsb_defconfig
Please also explain when imx93_9x9_qsb_inline_ecc_defconfig could be used, the difference between the two defconfigs, etc.
default n
default n is already the default. Just remove it.
BOOTENV \
"image=Image\0" \
Please move it to a .env file instead.
Fabio Estevam
Peng Fan (OSS)
