[PATCH 1/1] smbios: convert function descriptions to Sphinx style
Use 'Return:' instead of '@return:'.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/smbios.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/lib/smbios.c b/lib/smbios.c index 9eb226ec9f..26df2bf123 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -47,7 +47,7 @@ struct smbios_ctx { * @addr: start address to write the structure * @handle: the structure's handle, a unique 16-bit number * @ctx: context for writing the tables - * @return: size of the structure + * Return: size of the structure */ typedef int (*smbios_write_type)(ulong *addr, int handle, struct smbios_ctx *ctx); @@ -72,7 +72,7 @@ struct smbios_write_method { * * @ctx: SMBIOS context * @str: string to add - * @return: string number in the string area (1 or more) + * Return: string number in the string area (1 or more) */ static int smbios_add_string(struct smbios_ctx *ctx, const char *str) { @@ -111,7 +111,7 @@ static int smbios_add_string(struct smbios_ctx *ctx, const char *str) * * @ctx: context for writing the tables * @prop: property to write - * @return 0 if not found, else SMBIOS string number (1 or more) + * Return: 0 if not found, else SMBIOS string number (1 or more) */ static int smbios_add_prop_si(struct smbios_ctx *ctx, const char *prop, int sysinfo_id) @@ -139,7 +139,7 @@ static int smbios_add_prop_si(struct smbios_ctx *ctx, const char *prop, * smbios_add_prop() - Add a property from the devicetree * * @prop: property to write - * @return 0 if not found, else SMBIOS string number (1 or more) + * Return: 0 if not found, else SMBIOS string number (1 or more) */ static int smbios_add_prop(struct smbios_ctx *ctx, const char *prop) { @@ -187,7 +187,7 @@ int smbios_update_version(const char *version) * This computes the size of the string area including the string terminator. * * @ctx: SMBIOS context - * @return: string area size + * Return: string area size */ static int smbios_string_table_len(const struct smbios_ctx *ctx) { -- 2.30.2
