[PATCH v9 00/37] Implement ACPI on aarch64
Based on the existing work done by Simon Glass this series adds support for booting aarch64 devices using ACPI only. As first target QEMU SBSA support is added, which relies on ACPI only to boot an OS. As secondary target the Raspberry Pi4 was used, which is broadly available and allows easy testing of the proposed solution.
The series is split into ACPI cleanups and code movements, adding Arm specific ACPI tables and finally SoC and mainboard related changes to boot a Linux on the QEMU SBSA and RPi4. Currently only the mandatory ACPI tables are supported, allowing to boot into Linux without errors.
The QEMU SBSA support is feature complete and provides the same functionality as the EDK2 implementation.
The changes were tested on real hardware as well on QEMU v9.0:
qemu-system-aarch64 -machine sbsa-ref -nographic -cpu cortex-a57 \ -pflash secure-world.rom \ -pflash unsecure-world.rom
qemu-system-aarch64 -machine raspi4b -kernel u-boot.bin -cpu cortex-a72 \ -smp 4 -m 2G -drive file=raspbian.img,format=raw,index=0 \ -dtb bcm2711-rpi-4-b.dtb -nographic
Tested against FWTS V24.03.00.
Known issues: - The QEMU rpi4 support is currently limited as it doesn't emulate PCI, USB or ethernet devices! - The SMP bringup doesn't work on RPi4, but works in QEMU (Possibly cache related). - PCI on RPI4 isn't working on real hardware since the pcie_brcmstb Linux kernel module doesn't support ACPI yet.
Maximilian Brune (3): acpi: x86: Move SPCR and DBG2 into common code acpi: x86: Write FADT in common code serial: serial_pl01x: Implement .getinfo() for PL01
Patrick Rudolph (32): acpi: x86: Move MADT to common code acpi: Fix typo acpi: Add define for GTDT arm: acpi: Add generic ACPI methods acpi: Add fill_madt to acpi_ops acpi: acpi_table: Bump revisions acpi: Add ACPITAB for PPTT and GTDT acpi: acpi_table: Add IORT support acpi: Move function prototype acpi_table: Support platforms with unusable RSDT acpi: Allocate and write ACPI tables acpi: Add processor device drivers: usb: Add generic XHCI drivers: ata: Rename ahci_mvebu drivers/cpu: Add generic armv8 cpu driver arm: gic-v3-its: Rename objects arm: gic-v3-its: Implement of_xlate arm: lib: Add GICV2 driver drivers: misc: irq-uclass: Update irq_get_by_index drivers/arm: Implement acpi_fill_madt common: Enable BLOBLIST_TABLES on arm board: emulation: Add QEMU sbsa support arm: mach-bcm283x: Map the ARM local MMIO as well arm: bcm283x: Generate ACPI tables arm: cpu: Add ACPI parking protocol support armv8: cpu: Enable ACPI parking protocol arm: Implement read_mpidr on armv7 arm: mach-bcm283x: Add ARMV8_MULTIENTRY support arm: mach-bcm283x: Enable ARMV8_MULTIENTRY bloblist: Fix use of uninitialized variable configs: Add RPI4 ACPI defconfig CI: Enable qemu_sbsa
Simon Glass (2): arm: mach-bcm283x: Bring in some header files from tianocore board: raspberrypi: Add ASL files from tianocore
.azure-pipelines.yml | 8 + .gitlab-ci.yml | 11 + MAINTAINERS | 2 +- arch/arm/Kconfig | 11 +- arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/acpi_park_v8.S | 113 ++++ arch/arm/cpu/armv8/start.S | 12 + arch/arm/dts/qemu-sbsa.dts | 138 ++++ arch/arm/include/asm/acpi_table.h | 147 ++++ arch/arm/include/asm/arch-qemu-sbsa/boot0.h | 34 + arch/arm/include/asm/system.h | 9 + arch/arm/lib/Makefile | 2 + arch/arm/lib/acpi_table.c | 276 ++++++++ arch/arm/lib/gic-v2.c | 89 +++ arch/arm/lib/gic-v3-its.c | 121 +++- arch/arm/mach-bcm283x/Kconfig | 16 +- arch/arm/mach-bcm283x/Makefile | 4 + arch/arm/mach-bcm283x/bcm2711_acpi.c | 128 ++++ .../mach-bcm283x/include/mach/acpi/bcm2711.h | 152 +++++ .../mach-bcm283x/include/mach/acpi/bcm2836.h | 127 ++++ .../include/mach/acpi/bcm2836_gpio.h | 19 + .../include/mach/acpi/bcm2836_gpu.h | 47 ++ .../include/mach/acpi/bcm2836_pwm.h | 33 + .../include/mach/acpi/bcm2836_sdhost.h | 18 + .../include/mach/acpi/bcm2836_sdio.h | 21 + arch/arm/mach-bcm283x/init.c | 2 +- arch/arm/mach-qemu/Kconfig | 36 +- arch/sandbox/dts/test.dts | 3 + arch/sandbox/lib/Makefile | 9 +- arch/sandbox/lib/acpi_table.c | 11 + arch/x86/cpu/apollolake/acpi.c | 20 +- arch/x86/cpu/baytrail/acpi.c | 17 +- arch/x86/cpu/intel_common/acpi.c | 22 +- arch/x86/cpu/quark/acpi.c | 19 +- arch/x86/cpu/tangier/acpi.c | 33 +- arch/x86/include/asm/acpi_table.h | 28 +- arch/x86/lib/acpi_table.c | 245 +------ board/emulation/qemu-arm/MAINTAINERS | 2 + board/emulation/qemu-sbsa/Kconfig | 59 ++ board/emulation/qemu-sbsa/Makefile | 8 + board/emulation/qemu-sbsa/acpi.c | 192 ++++++ board/emulation/qemu-sbsa/dsdt.asl | 483 ++++++++++++++ board/emulation/qemu-sbsa/lowlevel_init.S | 22 + board/emulation/qemu-sbsa/qemu-sbsa.c | 273 ++++++++ board/emulation/qemu-sbsa/qemu-sbsa.env | 14 + board/emulation/qemu-sbsa/qemu-sbsa.h | 38 ++ board/emulation/qemu-sbsa/smc.c | 71 ++ board/raspberrypi/rpi/.gitignore | 3 + board/raspberrypi/rpi/Makefile | 2 + board/raspberrypi/rpi/acpitables.h | 90 +++ board/raspberrypi/rpi/dsdt.asl | 254 +++++++ board/raspberrypi/rpi/emmc.asl | 136 ++++ board/raspberrypi/rpi/gpudevs.asl | 372 +++++++++++ board/raspberrypi/rpi/pci.asl | 177 +++++ board/raspberrypi/rpi/pep.asl | 90 +++ board/raspberrypi/rpi/rhpx.asl | 195 ++++++ board/raspberrypi/rpi/rpi.c | 183 +++++ board/raspberrypi/rpi/sdhc.asl | 111 +++ board/raspberrypi/rpi/uart.asl | 208 ++++++ boot/bootflow.c | 8 +- common/Kconfig | 2 + common/bloblist.c | 2 +- configs/clearfog_defconfig | 2 +- configs/clearfog_gt_8k_defconfig | 2 +- configs/clearfog_sata_defconfig | 2 +- configs/clearfog_spi_defconfig | 2 +- configs/db-88f6820-gp_defconfig | 2 +- configs/ds116_defconfig | 2 +- configs/helios4_defconfig | 2 +- configs/mvebu_crb_cn9130_defconfig | 2 +- configs/mvebu_db-88f3720_defconfig | 2 +- configs/mvebu_db_armada8k_defconfig | 2 +- configs/mvebu_db_cn9130_defconfig | 2 +- configs/mvebu_espressobin-88f3720_defconfig | 2 +- .../mvebu_espressobin_ultra-88f3720_defconfig | 2 +- configs/mvebu_mcbin-88f8040_defconfig | 2 +- configs/mvebu_puzzle-m801-88f8040_defconfig | 2 +- configs/n2350_defconfig | 2 +- configs/octeon_nic23_defconfig | 2 +- configs/qemu-arm-sbsa_defconfig | 10 + configs/rpi_4_acpi_defconfig | 10 + configs/turris_omnia_defconfig | 2 +- doc/board/emulation/index.rst | 1 + doc/board/emulation/qemu-sbsa.rst | 98 +++ doc/develop/driver-model/virtio.rst | 1 + drivers/ata/Kconfig | 12 +- drivers/ata/Makefile | 2 +- drivers/ata/{ahci_mvebu.c => ahci_generic.c} | 17 +- drivers/core/acpi.c | 16 + drivers/cpu/Kconfig | 7 + drivers/cpu/Makefile | 2 + drivers/cpu/armv8_cpu.c | 151 +++++ drivers/cpu/armv8_cpu.h | 31 + drivers/cpu/bcm283x_cpu.c | 214 ++++++ drivers/misc/irq-uclass.c | 66 +- drivers/pci/pcie_brcmstb.c | 101 +-- drivers/serial/serial_pl01x.c | 24 + drivers/usb/host/Kconfig | 8 + drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-generic.c | 75 +++ include/acpi/acpi_table.h | 324 ++++++++- include/acpi/acpigen.h | 12 + include/bloblist.h | 1 + include/configs/qemu-sbsa.h | 89 +++ include/dm/acpi.h | 26 + include/irq.h | 14 + include/serial.h | 1 + lib/Kconfig | 31 +- lib/acpi/acpi_table.c | 630 +++++++++++++++++- lib/acpi/acpigen.c | 11 + test/dm/acpi.c | 43 ++ test/dm/irq.c | 15 + test/py/tests/test_event_dump.py | 1 + 113 files changed, 6518 insertions(+), 542 deletions(-) create mode 100644 arch/arm/cpu/armv8/acpi_park_v8.S create mode 100644 arch/arm/dts/qemu-sbsa.dts create mode 100644 arch/arm/include/asm/arch-qemu-sbsa/boot0.h create mode 100644 arch/arm/lib/acpi_table.c create mode 100644 arch/arm/lib/gic-v2.c create mode 100644 arch/arm/mach-bcm283x/bcm2711_acpi.c create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2711.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpio.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpu.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_pwm.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdhost.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdio.h create mode 100644 arch/sandbox/lib/acpi_table.c create mode 100644 board/emulation/qemu-sbsa/Kconfig create mode 100644 board/emulation/qemu-sbsa/Makefile create mode 100644 board/emulation/qemu-sbsa/acpi.c create mode 100644 board/emulation/qemu-sbsa/dsdt.asl create mode 100644 board/emulation/qemu-sbsa/lowlevel_init.S create mode 100644 board/emulation/qemu-sbsa/qemu-sbsa.c create mode 100644 board/emulation/qemu-sbsa/qemu-sbsa.env create mode 100644 board/emulation/qemu-sbsa/qemu-sbsa.h create mode 100644 board/emulation/qemu-sbsa/smc.c create mode 100644 board/raspberrypi/rpi/.gitignore create mode 100644 board/raspberrypi/rpi/acpitables.h create mode 100644 board/raspberrypi/rpi/dsdt.asl create mode 100644 board/raspberrypi/rpi/emmc.asl create mode 100644 board/raspberrypi/rpi/gpudevs.asl create mode 100644 board/raspberrypi/rpi/pci.asl create mode 100644 board/raspberrypi/rpi/pep.asl create mode 100644 board/raspberrypi/rpi/rhpx.asl create mode 100644 board/raspberrypi/rpi/sdhc.asl create mode 100644 board/raspberrypi/rpi/uart.asl create mode 100644 configs/qemu-arm-sbsa_defconfig create mode 100644 configs/rpi_4_acpi_defconfig create mode 100644 doc/board/emulation/qemu-sbsa.rst rename drivers/ata/{ahci_mvebu.c => ahci_generic.c} (71%) create mode 100644 drivers/cpu/armv8_cpu.c create mode 100644 drivers/cpu/armv8_cpu.h create mode 100644 drivers/cpu/bcm283x_cpu.c create mode 100644 drivers/usb/host/xhci-generic.c create mode 100644 include/configs/qemu-sbsa.h
From: Maximilian Brune maximilian.brune@9elements.com
This moves the SPCR and DBG2 table generation into common code, so that they can be used by architectures other than x86.
Signed-off-by: Maximilian Brune maximilian.brune@9elements.com Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com --- Changelog v2: - Do not add new features, just move code and make it compile on 64bit. --- arch/x86/include/asm/acpi_table.h | 11 -- arch/x86/lib/acpi_table.c | 174 ---------------------------- include/acpi/acpi_table.h | 11 ++ lib/acpi/acpi_table.c | 184 ++++++++++++++++++++++++++++++ 4 files changed, 195 insertions(+), 185 deletions(-)
diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 57e41654ce..e617524617 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -45,17 +45,6 @@ int acpi_create_mcfg_mmconfig(struct acpi_mcfg_mmconfig *mmconfig, u32 base, */ int acpi_write_hpet(struct acpi_ctx *ctx);
-/** - * acpi_write_dbg2_pci_uart() - Write out a DBG2 table - * - * @ctx: Current ACPI context - * @dev: Debug UART device to describe - * @access_size: Access size for UART (e.g. ACPI_ACCESS_SIZE_DWORD_ACCESS) - * Return: 0 if OK, -ve on error - */ -int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev, - uint access_size); - /** * acpi_create_gnvs() - Create a GNVS (Global Non Volatile Storage) table * diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index e38ce19ff7..08fd1e54ce 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -279,140 +279,6 @@ static int acpi_write_tpm2(struct acpi_ctx *ctx, } ACPI_WRITER(5tpm2, "TPM2", acpi_write_tpm2, 0);
-int acpi_write_spcr(struct acpi_ctx *ctx, const struct acpi_writer *entry) -{ - struct serial_device_info serial_info = {0}; - ulong serial_address, serial_offset; - struct acpi_table_header *header; - struct acpi_spcr *spcr; - struct udevice *dev; - uint serial_config; - uint serial_width; - int access_size; - int space_id; - int ret = -ENODEV; - - spcr = ctx->current; - header = &spcr->header; - - memset(spcr, '\0', sizeof(struct acpi_spcr)); - - /* Fill out header fields */ - acpi_fill_header(header, "SPCR"); - header->length = sizeof(struct acpi_spcr); - header->revision = 2; - - /* Read the device once, here. It is reused below */ - dev = gd->cur_serial_dev; - if (dev) - ret = serial_getinfo(dev, &serial_info); - if (ret) - serial_info.type = SERIAL_CHIP_UNKNOWN; - - /* Encode chip type */ - switch (serial_info.type) { - case SERIAL_CHIP_16550_COMPATIBLE: - spcr->interface_type = ACPI_DBG2_16550_COMPATIBLE; - break; - case SERIAL_CHIP_UNKNOWN: - default: - spcr->interface_type = ACPI_DBG2_UNKNOWN; - break; - } - - /* Encode address space */ - switch (serial_info.addr_space) { - case SERIAL_ADDRESS_SPACE_MEMORY: - space_id = ACPI_ADDRESS_SPACE_MEMORY; - break; - case SERIAL_ADDRESS_SPACE_IO: - default: - space_id = ACPI_ADDRESS_SPACE_IO; - break; - } - - serial_width = serial_info.reg_width * 8; - serial_offset = serial_info.reg_offset << serial_info.reg_shift; - serial_address = serial_info.addr + serial_offset; - - /* Encode register access size */ - switch (serial_info.reg_shift) { - case 0: - access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - break; - case 1: - access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; - break; - case 2: - access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; - break; - case 3: - access_size = ACPI_ACCESS_SIZE_QWORD_ACCESS; - break; - default: - access_size = ACPI_ACCESS_SIZE_UNDEFINED; - break; - } - - debug("UART type %u @ %lx\n", spcr->interface_type, serial_address); - - /* Fill GAS */ - spcr->serial_port.space_id = space_id; - spcr->serial_port.bit_width = serial_width; - spcr->serial_port.bit_offset = 0; - spcr->serial_port.access_size = access_size; - spcr->serial_port.addrl = lower_32_bits(serial_address); - spcr->serial_port.addrh = upper_32_bits(serial_address); - - /* Encode baud rate */ - switch (serial_info.baudrate) { - case 9600: - spcr->baud_rate = 3; - break; - case 19200: - spcr->baud_rate = 4; - break; - case 57600: - spcr->baud_rate = 6; - break; - case 115200: - spcr->baud_rate = 7; - break; - default: - spcr->baud_rate = 0; - break; - } - - serial_config = SERIAL_DEFAULT_CONFIG; - if (dev) - ret = serial_getconfig(dev, &serial_config); - - spcr->parity = SERIAL_GET_PARITY(serial_config); - spcr->stop_bits = SERIAL_GET_STOP(serial_config); - - /* No PCI devices for now */ - spcr->pci_device_id = 0xffff; - spcr->pci_vendor_id = 0xffff; - - /* - * SPCR has no clue if the UART base clock speed is different - * to the default one. However, the SPCR 1.04 defines baud rate - * 0 as a preconfigured state of UART and OS is supposed not - * to touch the configuration of the serial device. - */ - if (serial_info.clock != SERIAL_DEFAULT_CLOCK) - spcr->baud_rate = 0; - - /* Fix checksum */ - header->checksum = table_compute_checksum((void *)spcr, header->length); - - acpi_add_table(ctx, spcr); - acpi_inc(ctx, spcr->header.length); - - return 0; -} -ACPI_WRITER(5spcr, "SPCR", acpi_write_spcr, 0); - int acpi_write_gnvs(struct acpi_ctx *ctx, const struct acpi_writer *entry) { ulong addr; @@ -515,46 +381,6 @@ int acpi_write_hpet(struct acpi_ctx *ctx) return 0; }
-int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev, - uint access_size) -{ - struct acpi_dbg2_header *dbg2 = ctx->current; - char path[ACPI_PATH_MAX]; - struct acpi_gen_regaddr address; - phys_addr_t addr; - int ret; - - if (!device_active(dev)) { - log_info("Device not enabled\n"); - return -EACCES; - } - /* - * PCI devices don't remember their resource allocation information in - * U-Boot at present. We assume that MMIO is used for the UART and that - * the address space is 32 bytes: ns16550 uses 8 registers of up to - * 32-bits each. This is only for debugging so it is not a big deal. - */ - addr = dm_pci_read_bar32(dev, 0); - log_debug("UART addr %lx\n", (ulong)addr); - - memset(&address, '\0', sizeof(address)); - address.space_id = ACPI_ADDRESS_SPACE_MEMORY; - address.addrl = (uint32_t)addr; - address.addrh = (uint32_t)((addr >> 32) & 0xffffffff); - address.access_size = access_size; - - ret = acpi_device_path(dev, path, sizeof(path)); - if (ret) - return log_msg_ret("path", ret); - acpi_create_dbg2(dbg2, ACPI_DBG2_SERIAL_PORT, - ACPI_DBG2_16550_COMPATIBLE, &address, 0x1000, path); - - acpi_inc_align(ctx, dbg2->header.length); - acpi_add_table(ctx, dbg2); - - return 0; -} - void acpi_fadt_common(struct acpi_fadt *fadt, struct acpi_facs *facs, void *dsdt) { diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 15fd61a51d..a372435492 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -913,6 +913,17 @@ static inline int acpi_add_fadt(struct acpi_ctx *ctx, struct acpi_fadt *fadt) return 0; }
+/** + * acpi_write_dbg2_pci_uart() - Write out a DBG2 table + * + * @ctx: Current ACPI context + * @dev: Debug UART device to describe + * @access_size: Access size for UART (e.g. ACPI_ACCESS_SIZE_DWORD_ACCESS) + * Return: 0 if OK, -ve on error + */ +int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev, + uint access_size); + /** * acpi_write_rsdp() - Write out an RSDP indicating where the ACPI tables are * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 6dbfdb22de..c9ddcca8cb 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -10,8 +10,10 @@ #include <log.h> #include <mapmem.h> #include <tables_csum.h> +#include <serial.h> #include <version_string.h> #include <acpi/acpi_table.h> +#include <acpi/acpi_device.h> #include <asm/global_data.h> #include <dm/acpi.h>
@@ -262,3 +264,185 @@ void acpi_create_dbg2(struct acpi_dbg2_header *dbg2, header->length = current - (uintptr_t)dbg2; header->checksum = table_compute_checksum(dbg2, header->length); } + +int acpi_write_dbg2_pci_uart(struct acpi_ctx *ctx, struct udevice *dev, + uint access_size) +{ + struct acpi_dbg2_header *dbg2 = ctx->current; + char path[ACPI_PATH_MAX]; + struct acpi_gen_regaddr address; + u64 addr; + int ret; + + if (!device_active(dev)) { + log_info("Device not enabled\n"); + return -EACCES; + } + /* + * PCI devices don't remember their resource allocation information in + * U-Boot at present. We assume that MMIO is used for the UART and that + * the address space is 32 bytes: ns16550 uses 8 registers of up to + * 32-bits each. This is only for debugging so it is not a big deal. + */ + addr = dm_pci_read_bar32(dev, 0); + log_debug("UART addr %lx\n", (ulong)addr); + + ret = acpi_device_path(dev, path, sizeof(path)); + if (ret) + return log_msg_ret("path", ret); + + memset(&address, '\0', sizeof(address)); + address.space_id = ACPI_ADDRESS_SPACE_MEMORY; + address.addrl = (uint32_t)addr; + address.addrh = (uint32_t)((addr >> 32) & 0xffffffff); + address.access_size = access_size; + + ret = acpi_device_path(dev, path, sizeof(path)); + if (ret) + return log_msg_ret("path", ret); + acpi_create_dbg2(dbg2, ACPI_DBG2_SERIAL_PORT, + ACPI_DBG2_16550_COMPATIBLE, &address, 0x1000, path); + + acpi_inc_align(ctx, dbg2->header.length); + acpi_add_table(ctx, dbg2); + + return 0; +} + +static int acpi_write_spcr(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct serial_device_info serial_info = {0}; + ulong serial_address, serial_offset; + struct acpi_table_header *header; + struct acpi_spcr *spcr; + struct udevice *dev; + uint serial_config; + uint serial_width; + int access_size; + int space_id; + int ret = -ENODEV; + + spcr = ctx->current; + header = &spcr->header; + + memset(spcr, '\0', sizeof(struct acpi_spcr)); + + /* Fill out header fields */ + acpi_fill_header(header, "SPCR"); + header->length = sizeof(struct acpi_spcr); + header->revision = 2; + + /* Read the device once, here. It is reused below */ + dev = gd->cur_serial_dev; + if (dev) + ret = serial_getinfo(dev, &serial_info); + if (ret) + serial_info.type = SERIAL_CHIP_UNKNOWN; + + /* Encode chip type */ + switch (serial_info.type) { + case SERIAL_CHIP_16550_COMPATIBLE: + spcr->interface_type = ACPI_DBG2_16550_COMPATIBLE; + break; + case SERIAL_CHIP_PL01X: + spcr->interface_type = ACPI_DBG2_ARM_PL011; + break; + case SERIAL_CHIP_UNKNOWN: + default: + spcr->interface_type = ACPI_DBG2_UNKNOWN; + break; + } + + /* Encode address space */ + switch (serial_info.addr_space) { + case SERIAL_ADDRESS_SPACE_MEMORY: + space_id = ACPI_ADDRESS_SPACE_MEMORY; + break; + case SERIAL_ADDRESS_SPACE_IO: + default: + space_id = ACPI_ADDRESS_SPACE_IO; + break; + } + + serial_width = serial_info.reg_width * 8; + serial_offset = serial_info.reg_offset << serial_info.reg_shift; + serial_address = serial_info.addr + serial_offset; + + /* Encode register access size */ + switch (serial_info.reg_shift) { + case 0: + access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + break; + case 1: + access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; + break; + case 2: + access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + break; + case 3: + access_size = ACPI_ACCESS_SIZE_QWORD_ACCESS; + break; + default: + access_size = ACPI_ACCESS_SIZE_UNDEFINED; + break; + } + + debug("UART type %u @ %lx\n", spcr->interface_type, serial_address); + + /* Fill GAS */ + spcr->serial_port.space_id = space_id; + spcr->serial_port.bit_width = serial_width; + spcr->serial_port.bit_offset = 0; + spcr->serial_port.access_size = access_size; + spcr->serial_port.addrl = lower_32_bits(serial_address); + spcr->serial_port.addrh = upper_32_bits(serial_address); + + /* Encode baud rate */ + switch (serial_info.baudrate) { + case 9600: + spcr->baud_rate = 3; + break; + case 19200: + spcr->baud_rate = 4; + break; + case 57600: + spcr->baud_rate = 6; + break; + case 115200: + spcr->baud_rate = 7; + break; + default: + spcr->baud_rate = 0; + break; + } + + serial_config = SERIAL_DEFAULT_CONFIG; + if (dev) + ret = serial_getconfig(dev, &serial_config); + + spcr->parity = SERIAL_GET_PARITY(serial_config); + spcr->stop_bits = SERIAL_GET_STOP(serial_config); + + /* No PCI devices for now */ + spcr->pci_device_id = 0xffff; + spcr->pci_vendor_id = 0xffff; + + /* + * SPCR has no clue if the UART base clock speed is different + * to the default one. However, the SPCR 1.04 defines baud rate + * 0 as a preconfigured state of UART and OS is supposed not + * to touch the configuration of the serial device. + */ + if (serial_info.clock != SERIAL_DEFAULT_CLOCK) + spcr->baud_rate = 0; + + /* Fix checksum */ + header->checksum = table_compute_checksum((void *)spcr, header->length); + + acpi_add_table(ctx, spcr); + acpi_inc(ctx, spcr->header.length); + + return 0; +} + +ACPI_WRITER(5spcr, "SPCR", acpi_write_spcr, 0);
Write the FADT in common code since it's used on all architectures. Since the FADT is mandatory all SoCs or mainboards must implement the introduced function acpi_fill_fadt() and properly update the FADT.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com --- Changelog v4: - Drop __weak attribute --- arch/sandbox/lib/acpi_table.c | 6 +++++ arch/x86/cpu/apollolake/acpi.c | 20 ++++------------ arch/x86/cpu/baytrail/acpi.c | 17 +------------- arch/x86/cpu/quark/acpi.c | 19 +--------------- arch/x86/cpu/tangier/acpi.c | 25 ++------------------ arch/x86/include/asm/acpi_table.h | 12 ---------- arch/x86/lib/acpi_table.c | 23 ------------------- include/acpi/acpi_table.h | 9 ++++++++ lib/acpi/acpi_table.c | 38 +++++++++++++++++++++++++++++++ 9 files changed, 61 insertions(+), 108 deletions(-) create mode 100644 arch/sandbox/lib/acpi_table.c
diff --git a/arch/sandbox/lib/acpi_table.c b/arch/sandbox/lib/acpi_table.c new file mode 100644 index 0000000000..10b7ce441a --- /dev/null +++ b/arch/sandbox/lib/acpi_table.c @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <acpi/acpi_table.h> + +void acpi_fill_fadt(struct acpi_fadt *fadt) +{ +} \ No newline at end of file diff --git a/arch/x86/cpu/apollolake/acpi.c b/arch/x86/cpu/apollolake/acpi.c index 76230aea83..93040e7bb3 100644 --- a/arch/x86/cpu/apollolake/acpi.c +++ b/arch/x86/cpu/apollolake/acpi.c @@ -128,8 +128,10 @@ int arch_madt_sci_irq_polarity(int sci) return MP_IRQ_POLARITY_LOW; }
-void fill_fadt(struct acpi_fadt *fadt) +void acpi_fill_fadt(struct acpi_fadt *fadt) { + intel_acpi_fill_fadt(fadt); + fadt->pm_tmr_blk = IOMAP_ACPI_BASE + PM1_TMR;
fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; @@ -143,23 +145,9 @@ void fill_fadt(struct acpi_fadt *fadt) fadt->x_pm_tmr_blk.space_id = 1; fadt->x_pm_tmr_blk.bit_width = fadt->pm_tmr_len * 8; fadt->x_pm_tmr_blk.addrl = IOMAP_ACPI_BASE + PM1_TMR; -} - -static int apl_write_fadt(struct acpi_ctx *ctx, const struct acpi_writer *entry) -{ - struct acpi_table_header *header; - struct acpi_fadt *fadt; - - fadt = ctx->current; - acpi_fadt_common(fadt, ctx->facs, ctx->dsdt); - intel_acpi_fill_fadt(fadt); - fill_fadt(fadt); - header = &fadt->header; - header->checksum = table_compute_checksum(fadt, header->length);
- return acpi_add_fadt(ctx, fadt); + fadt->preferred_pm_profile = ACPI_PM_MOBILE; } -ACPI_WRITER(5fadt, "FADT", apl_write_fadt, 0);
int apl_acpi_fill_dmar(struct acpi_ctx *ctx) { diff --git a/arch/x86/cpu/baytrail/acpi.c b/arch/x86/cpu/baytrail/acpi.c index 7821964f1f..7e1c2de3d3 100644 --- a/arch/x86/cpu/baytrail/acpi.c +++ b/arch/x86/cpu/baytrail/acpi.c @@ -15,20 +15,13 @@ #include <asm/arch/iomap.h> #include <dm/uclass-internal.h>
-static int baytrail_write_fadt(struct acpi_ctx *ctx, - const struct acpi_writer *entry) +void acpi_fill_fadt(struct acpi_fadt *fadt) { struct acpi_table_header *header; - struct acpi_fadt *fadt;
- fadt = ctx->current; header = &fadt->header; u16 pmbase = ACPI_BASE_ADDRESS;
- memset(fadt, '\0', sizeof(struct acpi_fadt)); - - acpi_fill_header(header, "FACP"); - header->length = sizeof(struct acpi_fadt); header->revision = 4;
fadt->preferred_pm_profile = ACPI_PM_MOBILE; @@ -77,9 +70,6 @@ static int baytrail_write_fadt(struct acpi_ctx *ctx, fadt->reset_reg.addrh = 0; fadt->reset_value = SYS_RST | RST_CPU | FULL_RST;
- fadt->x_firmware_ctrl = map_to_sysmem(ctx->facs); - fadt->x_dsdt = map_to_sysmem(ctx->dsdt); - fadt->x_pm1a_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; fadt->x_pm1a_evt_blk.bit_width = fadt->pm1_evt_len * 8; fadt->x_pm1a_evt_blk.bit_offset = 0; @@ -135,12 +125,7 @@ static int baytrail_write_fadt(struct acpi_ctx *ctx, fadt->x_gpe1_blk.access_size = 0; fadt->x_gpe1_blk.addrl = 0x0; fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = table_compute_checksum(fadt, header->length); - - return acpi_add_fadt(ctx, fadt); } -ACPI_WRITER(5fadt, "FADT", baytrail_write_fadt, 0);
int acpi_create_gnvs(struct acpi_global_nvs *gnvs) { diff --git a/arch/x86/cpu/quark/acpi.c b/arch/x86/cpu/quark/acpi.c index 80e94600fc..0fe5f2bafb 100644 --- a/arch/x86/cpu/quark/acpi.c +++ b/arch/x86/cpu/quark/acpi.c @@ -11,23 +11,14 @@ #include <asm/arch/iomap.h> #include <linux/string.h>
-static int quark_write_fadt(struct acpi_ctx *ctx, - const struct acpi_writer *entry) +void acpi_fill_fadt(struct acpi_fadt *fadt) { u16 pmbase = ACPI_PM1_BASE_ADDRESS; struct acpi_table_header *header; - struct acpi_fadt *fadt;
- fadt = ctx->current; header = &fadt->header; - - memset(fadt, '\0', sizeof(struct acpi_fadt)); - - acpi_fill_header(header, "FACP"); - header->length = sizeof(struct acpi_fadt); header->revision = 4;
- fadt->preferred_pm_profile = ACPI_PM_UNSPECIFIED; fadt->sci_int = 9; fadt->smi_cmd = 0; fadt->acpi_enable = 0; @@ -73,9 +64,6 @@ static int quark_write_fadt(struct acpi_ctx *ctx, fadt->reset_reg.addrh = 0; fadt->reset_value = SYS_RST | RST_CPU | FULL_RST;
- fadt->x_firmware_ctrl = map_to_sysmem(ctx->facs); - fadt->x_dsdt = map_to_sysmem(ctx->dsdt); - fadt->x_pm1a_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; fadt->x_pm1a_evt_blk.bit_width = fadt->pm1_evt_len * 8; fadt->x_pm1a_evt_blk.bit_offset = 0; @@ -131,12 +119,7 @@ static int quark_write_fadt(struct acpi_ctx *ctx, fadt->x_gpe1_blk.access_size = 0; fadt->x_gpe1_blk.addrl = 0x0; fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = table_compute_checksum(fadt, header->length); - - return acpi_add_fadt(ctx, fadt); } -ACPI_WRITER(5fadt, "FADT", quark_write_fadt, 0);
int acpi_create_gnvs(struct acpi_global_nvs *gnvs) { diff --git a/arch/x86/cpu/tangier/acpi.c b/arch/x86/cpu/tangier/acpi.c index d4d0ef6f85..1c73a9dbfe 100644 --- a/arch/x86/cpu/tangier/acpi.c +++ b/arch/x86/cpu/tangier/acpi.c @@ -16,21 +16,8 @@ #include <asm/arch/iomap.h> #include <dm/uclass-internal.h>
-static int tangier_write_fadt(struct acpi_ctx *ctx, - const struct acpi_writer *entry) +void acpi_fill_fadt(struct acpi_fadt *fadt) { - struct acpi_table_header *header; - struct acpi_fadt *fadt; - - fadt = ctx->current; - header = &fadt->header; - - memset(fadt, '\0', sizeof(struct acpi_fadt)); - - acpi_fill_header(header, "FACP"); - header->length = sizeof(struct acpi_fadt); - header->revision = 6; - fadt->preferred_pm_profile = ACPI_PM_UNSPECIFIED;
fadt->iapc_boot_arch = ACPI_FADT_VGA_NOT_PRESENT | @@ -40,17 +27,9 @@ static int tangier_write_fadt(struct acpi_ctx *ctx, ACPI_FADT_POWER_BUTTON | ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_SEALED_CASE | ACPI_FADT_HEADLESS | ACPI_FADT_HW_REDUCED_ACPI; - + fadt->header.revision = 6; fadt->minor_revision = 2; - - fadt->x_firmware_ctrl = map_to_sysmem(ctx->facs); - fadt->x_dsdt = map_to_sysmem(ctx->dsdt); - - header->checksum = table_compute_checksum(fadt, header->length); - - return acpi_add_fadt(ctx, fadt); } -ACPI_WRITER(5fadt, "FADT", tangier_write_fadt, 0);
u32 acpi_fill_madt(u32 current) { diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index e617524617..3988898f66 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -168,18 +168,6 @@ int acpi_create_dmar_ds_ioapic(struct acpi_ctx *ctx, uint enumeration_id, int acpi_create_dmar_ds_msi_hpet(struct acpi_ctx *ctx, uint enumeration_id, pci_dev_t bdf);
-/** - * acpi_fadt_common() - Handle common parts of filling out an FADT - * - * This sets up the Fixed ACPI Description Table - * - * @fadt: Pointer to place to put FADT - * @facs: Pointer to the FACS - * @dsdt: Pointer to the DSDT - */ -void acpi_fadt_common(struct acpi_fadt *fadt, struct acpi_facs *facs, - void *dsdt); - /** * intel_acpi_fill_fadt() - Set up the contents of the FADT * diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 08fd1e54ce..ff02ce80d1 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -381,29 +381,6 @@ int acpi_write_hpet(struct acpi_ctx *ctx) return 0; }
-void acpi_fadt_common(struct acpi_fadt *fadt, struct acpi_facs *facs, - void *dsdt) -{ - struct acpi_table_header *header = &fadt->header; - - memset((void *)fadt, '\0', sizeof(struct acpi_fadt)); - - acpi_fill_header(header, "FACP"); - header->length = sizeof(struct acpi_fadt); - header->revision = 4; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, OEM_TABLE_ID, 8); - memcpy(header->creator_id, ASLC_ID, 4); - - fadt->x_firmware_ctrl = map_to_sysmem(facs); - fadt->x_dsdt = map_to_sysmem(dsdt); - - fadt->preferred_pm_profile = ACPI_PM_MOBILE; - - /* Use ACPI 3.0 revision */ - fadt->header.revision = 4; -} - void acpi_create_dmar_drhd(struct acpi_ctx *ctx, uint flags, uint segment, u64 bar) { diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index a372435492..19cf0fb43c 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -954,6 +954,15 @@ void acpi_fill_header(struct acpi_table_header *header, char *signature); */ int acpi_fill_csrt(struct acpi_ctx *ctx);
+/** + * acpi_fill_fadt() - Fill out the body of the FADT + * + * Must be implemented in SoC specific code or in mainboard code. + * + * @fadt: Pointer to FADT to update + */ +void acpi_fill_fadt(struct acpi_fadt *fadt); + /** * acpi_get_rsdp_addr() - get ACPI RSDP table address * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index c9ddcca8cb..9eb0b507a0 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -202,6 +202,44 @@ int acpi_add_table(struct acpi_ctx *ctx, void *table) return 0; }
+int acpi_write_fadt(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_header *header; + struct acpi_fadt *fadt; + + fadt = ctx->current; + header = &fadt->header; + + memset((void *)fadt, '\0', sizeof(struct acpi_fadt)); + + acpi_fill_header(header, "FACP"); + header->length = sizeof(struct acpi_fadt); + header->revision = acpi_get_table_revision(ACPITAB_FADT); + memcpy(header->oem_id, OEM_ID, 6); + memcpy(header->oem_table_id, OEM_TABLE_ID, 8); + memcpy(header->creator_id, ASLC_ID, 4); + header->creator_revision = 1; + + fadt->x_firmware_ctrl = map_to_sysmem(ctx->facs); + fadt->x_dsdt = map_to_sysmem(ctx->dsdt); + + if (fadt->x_firmware_ctrl < 0x100000000ULL) + fadt->firmware_ctrl = fadt->x_firmware_ctrl; + + if (fadt->x_dsdt < 0x100000000ULL) + fadt->dsdt = fadt->x_dsdt; + + fadt->preferred_pm_profile = ACPI_PM_UNSPECIFIED; + + acpi_fill_fadt(fadt); + + header->checksum = table_compute_checksum(fadt, header->length); + + return acpi_add_fadt(ctx, fadt); +} + +ACPI_WRITER(5fadt, "FADT", acpi_write_fadt, 0); + void acpi_create_dbg2(struct acpi_dbg2_header *dbg2, int port_type, int port_subtype, struct acpi_gen_regaddr *address, u32 address_size,
Write MADT in common code and let the SoC fill out the body by calling acpi_fill_madt() which must be implemented at SoC level.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com --- Changelog v3: - Pass ACPI context to acpi_fill_madt --- arch/sandbox/lib/Makefile | 9 +++--- arch/sandbox/lib/acpi_table.c | 7 ++++- arch/x86/cpu/intel_common/acpi.c | 22 +++++++++----- arch/x86/cpu/tangier/acpi.c | 8 +++++- arch/x86/include/asm/acpi_table.h | 3 +- arch/x86/lib/acpi_table.c | 48 +++++++------------------------ include/acpi/acpi_table.h | 11 +++++++ lib/acpi/acpi_table.c | 31 ++++++++++++++++++++ 8 files changed, 86 insertions(+), 53 deletions(-)
diff --git a/arch/sandbox/lib/Makefile b/arch/sandbox/lib/Makefile index d7d15a50bb..5d7beb250c 100644 --- a/arch/sandbox/lib/Makefile +++ b/arch/sandbox/lib/Makefile @@ -5,7 +5,8 @@ # (C) Copyright 2002-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-y += fdt_fixup.o interrupts.o -obj-$(CONFIG_PCI) += pci_io.o -obj-$(CONFIG_CMD_BOOTM) += bootm.o -obj-$(CONFIG_CMD_BOOTZ) += bootm.o +obj-y += fdt_fixup.o interrupts.o +obj-$(CONFIG_PCI) += pci_io.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_CMD_BOOTZ) += bootm.o +obj-$(CONFIG_$(SPL_)ACPIGEN) += acpi_table.o diff --git a/arch/sandbox/lib/acpi_table.c b/arch/sandbox/lib/acpi_table.c index 10b7ce441a..90bb96d1e3 100644 --- a/arch/sandbox/lib/acpi_table.c +++ b/arch/sandbox/lib/acpi_table.c @@ -3,4 +3,9 @@
void acpi_fill_fadt(struct acpi_fadt *fadt) { -} \ No newline at end of file +} + +void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx) +{ + return ctx->current; +} diff --git a/arch/x86/cpu/intel_common/acpi.c b/arch/x86/cpu/intel_common/acpi.c index 29676b4abf..982149b394 100644 --- a/arch/x86/cpu/intel_common/acpi.c +++ b/arch/x86/cpu/intel_common/acpi.c @@ -19,6 +19,7 @@ #include <asm/global_data.h> #include <asm/intel_acpi.h> #include <asm/ioapic.h> +#include <asm/lapic.h> #include <asm/mpspec.h> #include <asm/smm.h> #include <asm/turbo.h> @@ -80,33 +81,40 @@ static int acpi_sci_irq(void) return sci_irq; }
-static unsigned long acpi_madt_irq_overrides(unsigned long current) +static void *acpi_madt_irq_overrides(void *current) { int sci = acpi_sci_irq(); u16 flags = MP_IRQ_TRIGGER_LEVEL;
- if (sci < 0) - return log_msg_ret("sci irq", sci); + if (sci < 0) { + log_err("sci irq %d", sci); + return current; + }
/* INT_SRC_OVR */ - current += acpi_create_madt_irqoverride((void *)current, 0, 0, 2, 0); + current += acpi_create_madt_irqoverride(current, 0, 0, 2, 0);
flags |= arch_madt_sci_irq_polarity(sci);
/* SCI */ current += - acpi_create_madt_irqoverride((void *)current, 0, sci, sci, flags); + acpi_create_madt_irqoverride(current, 0, sci, sci, flags);
return current; }
-u32 acpi_fill_madt(u32 current) +void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx) { + void *current = ctx->current; + + madt->lapic_addr = LAPIC_DEFAULT_BASE; + madt->flags = ACPI_MADT_PCAT_COMPAT; + /* Local APICs */ current += acpi_create_madt_lapics(current);
/* IOAPIC */ - current += acpi_create_madt_ioapic((void *)current, 2, IO_APIC_ADDR, 0); + current += acpi_create_madt_ioapic(current, 2, IO_APIC_ADDR, 0);
return acpi_madt_irq_overrides(current); } diff --git a/arch/x86/cpu/tangier/acpi.c b/arch/x86/cpu/tangier/acpi.c index 1c73a9dbfe..3d11787861 100644 --- a/arch/x86/cpu/tangier/acpi.c +++ b/arch/x86/cpu/tangier/acpi.c @@ -10,6 +10,7 @@ #include <mapmem.h> #include <acpi/acpi_table.h> #include <asm/ioapic.h> +#include <asm/lapic.h> #include <asm/mpspec.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> @@ -31,8 +32,13 @@ void acpi_fill_fadt(struct acpi_fadt *fadt) fadt->minor_revision = 2; }
-u32 acpi_fill_madt(u32 current) +void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx) { + void *current = ctx->current; + + madt->lapic_addr = LAPIC_DEFAULT_BASE; + madt->flags = ACPI_MADT_PCAT_COMPAT; + current += acpi_create_madt_lapics(current);
current += acpi_create_madt_ioapic((struct acpi_madt_ioapic *)current, diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 3988898f66..3254bbc380 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -24,14 +24,13 @@ struct acpi_table_header;
/* These can be used by the target port */
-int acpi_create_madt_lapics(u32 current); +int acpi_create_madt_lapics(void *current); int acpi_create_madt_ioapic(struct acpi_madt_ioapic *ioapic, u8 id, u32 addr, u32 gsi_base); int acpi_create_madt_irqoverride(struct acpi_madt_irqoverride *irqoverride, u8 bus, u8 source, u32 gsirq, u16 flags); int acpi_create_madt_lapic_nmi(struct acpi_madt_lapic_nmi *lapic_nmi, u8 cpu, u16 flags, u8 lint); -u32 acpi_fill_madt(u32 current); int acpi_create_mcfg_mmconfig(struct acpi_mcfg_mmconfig *mmconfig, u32 base, u16 seg_nr, u8 start, u8 end);
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index ff02ce80d1..3186e48d63 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -40,7 +40,7 @@ static int acpi_create_madt_lapic(struct acpi_madt_lapic *lapic, return lapic->length; }
-int acpi_create_madt_lapics(u32 current) +int acpi_create_madt_lapics(void *current) { struct udevice *dev; int total_length = 0; @@ -100,23 +100,28 @@ int acpi_create_madt_lapic_nmi(struct acpi_madt_lapic_nmi *lapic_nmi, return lapic_nmi->length; }
-static int acpi_create_madt_irq_overrides(u32 current) +static int acpi_create_madt_irq_overrides(void *current) { struct acpi_madt_irqoverride *irqovr; u16 sci_flags = MP_IRQ_TRIGGER_LEVEL | MP_IRQ_POLARITY_HIGH; int length = 0;
- irqovr = (void *)current; + irqovr = current; length += acpi_create_madt_irqoverride(irqovr, 0, 0, 2, 0);
- irqovr = (void *)(current + length); + irqovr = current + length; length += acpi_create_madt_irqoverride(irqovr, 0, 9, 9, sci_flags);
return length; }
-__weak u32 acpi_fill_madt(u32 current) +__weak void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx) { + void *current = ctx->current; + + madt->lapic_addr = LAPIC_DEFAULT_BASE; + madt->flags = ACPI_MADT_PCAT_COMPAT; + current += acpi_create_madt_lapics(current);
current += acpi_create_madt_ioapic((struct acpi_madt_ioapic *)current, @@ -127,39 +132,6 @@ __weak u32 acpi_fill_madt(u32 current) return current; }
-int acpi_write_madt(struct acpi_ctx *ctx, const struct acpi_writer *entry) -{ - struct acpi_table_header *header; - struct acpi_madt *madt; - u32 current; - - madt = ctx->current; - - memset(madt, '\0', sizeof(struct acpi_madt)); - header = &madt->header; - - /* Fill out header fields */ - acpi_fill_header(header, "APIC"); - header->length = sizeof(struct acpi_madt); - header->revision = ACPI_MADT_REV_ACPI_3_0; - - madt->lapic_addr = LAPIC_DEFAULT_BASE; - madt->flags = ACPI_MADT_PCAT_COMPAT; - - current = (u32)madt + sizeof(struct acpi_madt); - current = acpi_fill_madt(current); - - /* (Re)calculate length and checksum */ - header->length = current - (u32)madt; - - header->checksum = table_compute_checksum((void *)madt, header->length); - acpi_add_table(ctx, madt); - acpi_inc(ctx, madt->header.length); - - return 0; -} -ACPI_WRITER(5x86, NULL, acpi_write_madt, 0); - /** * acpi_create_tcpa() - Create a TCPA table * diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 19cf0fb43c..c356df72ba 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -963,6 +963,17 @@ int acpi_fill_csrt(struct acpi_ctx *ctx); */ void acpi_fill_fadt(struct acpi_fadt *fadt);
+/** + * acpi_fill_madt() - Fill out the body of the MADT + * + * Must be implemented in SoC specific code. + * + * @madt: The MADT to update + * @ctx: ACPI context to write MADT sub-tables to + * @return Pointer to the end of tables, where the next tables can be written + */ +void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx); + /** * acpi_get_rsdp_addr() - get ACPI RSDP table address * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 9eb0b507a0..639d78125f 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -240,6 +240,37 @@ int acpi_write_fadt(struct acpi_ctx *ctx, const struct acpi_writer *entry)
+int acpi_write_madt(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_header *header; + struct acpi_madt *madt; + void *current; + + madt = ctx->current; + + memset(madt, '\0', sizeof(struct acpi_madt)); + header = &madt->header; + + /* Fill out header fields */ + acpi_fill_header(header, "APIC"); + header->length = sizeof(struct acpi_madt); + header->revision = ACPI_MADT_REV_ACPI_3_0; + + acpi_inc(ctx, sizeof(struct acpi_madt)); + current = acpi_fill_madt(madt, ctx); + + /* (Re)calculate length and checksum */ + header->length = (uintptr_t)current - (uintptr_t)madt; + + header->checksum = table_compute_checksum((void *)madt, header->length); + acpi_add_table(ctx, madt); + ctx->current = (void *)madt + madt->header.length; + + return 0; +} + +ACPI_WRITER(5madt, "MADT", acpi_write_madt, 0); + void acpi_create_dbg2(struct acpi_dbg2_header *dbg2, int port_type, int port_subtype, struct acpi_gen_regaddr *address, u32 address_size,
Rename ACPI tables MADR to MADT.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- include/acpi/acpi_table.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index c356df72ba..a1bdab7305 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -386,20 +386,20 @@ struct __packed acpi_madt_lapic_nmi { u8 lint; /* Local APIC LINT# */ };
-/* flags for acpi_madr_gicc flags word */ +/* flags for acpi_madt_gicc flags word */ enum { - ACPI_MADRF_ENABLED = BIT(0), - ACPI_MADRF_PERF = BIT(1), - ACPI_MADRF_VGIC = BIT(2), + ACPI_MADTF_ENABLED = BIT(0), + ACPI_MADTF_PERF = BIT(1), + ACPI_MADTF_VGIC = BIT(2), };
/** - * struct __packed acpi_madr_gicc - GIC CPU interface (type 0xb) + * struct __packed acpi_madt_gicc - GIC CPU interface (type 0xb) * * This holds information about the Generic Interrupt Controller (GIC) CPU * interface. See ACPI Spec v6.3 section 5.2.12.14 */ -struct acpi_madr_gicc { +struct acpi_madt_gicc { u8 type; u8 length; u16 reserved; @@ -421,12 +421,12 @@ struct acpi_madr_gicc { } __packed;
/** - * struct __packed acpi_madr_gicc - GIC distributor (type 0xc) + * struct __packed acpi_madt_gicc - GIC distributor (type 0xc) * * This holds information about the Generic Interrupt Controller (GIC) * Distributor interface. See ACPI Spec v6.3 section 5.2.12.15 */ -struct acpi_madr_gicd { +struct acpi_madt_gicd { u8 type; u8 length; u16 reserved;
When ACPI is enabled on arm it will use the getinfo function to fill the SPCR ACPI table.
Signed-off-by: Maximilian Brune maximilian.brune@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- boot/bootflow.c | 8 ++++++-- drivers/serial/serial_pl01x.c | 24 ++++++++++++++++++++++++ include/serial.h | 1 + 3 files changed, 31 insertions(+), 2 deletions(-)
diff --git a/boot/bootflow.c b/boot/bootflow.c index 59d77d2385..d8807eb109 100644 --- a/boot/bootflow.c +++ b/boot/bootflow.c @@ -936,11 +936,15 @@ int bootflow_cmdline_auto(struct bootflow *bflow, const char *arg) return ret;
*buf = '\0'; - if (!strcmp("earlycon", arg)) { + if (!strcmp("earlycon", arg) && info.type == SERIAL_CHIP_16550_COMPATIBLE) { snprintf(buf, sizeof(buf), "uart8250,mmio32,%#lx,%dn8", info.addr, info.baudrate); - } else if (!strcmp("console", arg)) { + } else if (!strcmp("earlycon", arg) && info.type == SERIAL_CHIP_PL01X) { + snprintf(buf, sizeof(buf), + "pl011,mmio32,%#lx,%dn8", info.addr, + info.baudrate); + } else if (!strcmp("console", arg) && info.type == SERIAL_CHIP_16550_COMPATIBLE) { snprintf(buf, sizeof(buf), "ttyS0,%dn8", info.baudrate); } diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index 80c35963b8..ab67922d18 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -19,6 +19,7 @@ #include <watchdog.h> #include <asm/io.h> #include <serial.h> +#include <spl.h> #include <dm/device_compat.h> #include <dm/platform_data/serial_pl01x.h> #include <linux/compiler.h> @@ -272,6 +273,28 @@ __weak struct serial_device *default_serial_console(void) return &pl01x_serial_drv; } #else + +static int pl01x_serial_getinfo(struct udevice *dev, + struct serial_device_info *info) +{ + struct pl01x_serial_plat *plat = dev_get_plat(dev); + + /* save code size */ + if (!spl_in_proper()) + return -ENOSYS; + + info->type = SERIAL_CHIP_PL01X; + info->addr_space = SERIAL_ADDRESS_SPACE_MEMORY; + info->addr = plat->base; + info->size = 0x1000; + info->reg_width = 4; + info->reg_shift = 2; + info->reg_offset = 0; + info->clock = plat->clock; + + return 0; +} + int pl01x_serial_setbrg(struct udevice *dev, int baudrate) { struct pl01x_serial_plat *plat = dev_get_plat(dev); @@ -341,6 +364,7 @@ static const struct dm_serial_ops pl01x_serial_ops = { .pending = pl01x_serial_pending, .getc = pl01x_serial_getc, .setbrg = pl01x_serial_setbrg, + .getinfo = pl01x_serial_getinfo, };
#if CONFIG_IS_ENABLED(OF_REAL) diff --git a/include/serial.h b/include/serial.h index d129dc3253..d7a9a8cfb8 100644 --- a/include/serial.h +++ b/include/serial.h @@ -124,6 +124,7 @@ enum serial_stop { enum serial_chip_type { SERIAL_CHIP_UNKNOWN = -1, SERIAL_CHIP_16550_COMPATIBLE, + SERIAL_CHIP_PL01X, };
enum adr_space_type {
Add the interrupt flag used in ACPI GTDT table as define.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- include/acpi/acpi_table.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index a1bdab7305..c6a3e44a95 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -707,6 +707,8 @@ struct acpi_gtdt { u32 virt_el2_flags; } __packed;
+#define GTDT_FLAG_INT_ACTIVE_LOW BIT(1) + /** * struct acpi_bgrt - Boot Graphics Resource Table (BGRT) *
Add generic ACPI code to generate - MADT GICC - MADT GICD - MADT GICR - MADT GIC ITS - PPTT processor - PPTT cache
as commonly used on arm platforms.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org --- Changelog v2: - Add full comments to exported functions Changelog v6: - Update header order --- arch/arm/include/asm/acpi_table.h | 115 ++++++++++++++++++++++++++++++ arch/arm/lib/Makefile | 1 + arch/arm/lib/acpi_table.c | 114 +++++++++++++++++++++++++++++ include/acpi/acpi_table.h | 34 ++++++++- 4 files changed, 263 insertions(+), 1 deletion(-) create mode 100644 arch/arm/lib/acpi_table.c
diff --git a/arch/arm/include/asm/acpi_table.h b/arch/arm/include/asm/acpi_table.h index e69de29bb2..c65eabe837 100644 --- a/arch/arm/include/asm/acpi_table.h +++ b/arch/arm/include/asm/acpi_table.h @@ -0,0 +1,115 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __ASM_ACPI_TABLE_H__ +#define __ASM_ACPI_TABLE_H__ + +#ifndef __ACPI__ + +#include <acpi/acpi_table.h> + +/** + * acpi_write_madt_gicc() - Write out a MADT GICC sub-table + * + * Write out the GIC CPU Interface sub-table. + * + * @gicc: Pointer to place to put the sub-table + * @cpu_num: GIC's CPU Interface Number + * @perf_gsiv: The GSIV used for Performance Monitoring Interrupts + * @phys_base: Address at which the processor can access this + * GIC CPU Interface + * @gicv: Address of the GIC virtual CPU interface registers + * @gich: Address of the GIC virtual interface control block + * registers + * @vgic_maint_irq: GSIV for Virtual GIC maintenance interrupt + * @gicr_base: Physical address of the associated Redistributor + * @mpidr: MPIDR as defined by ARM architecture + * @efficiency: Describes the relative power efficiency + */ +void acpi_write_madt_gicc(struct acpi_madt_gicc *gicc, uint cpu_num, + uint perf_gsiv, ulong phys_base, ulong gicv, + ulong gich, uint vgic_maint_irq, u64 gicr_base, + ulong mpidr, uint efficiency); + +/** + * acpi_write_madt_gicd() - Write out a MADT GICD sub-table + * + * Write out the GIC Distributor sub-table. + * + * @gicd: Pointer to place to put the sub-table + * @gic_id: This GIC Distributor's hardware ID + * @phys_base: The 64-bit physical address for this Distributor + * @gic_version: GIC version + */ +void acpi_write_madt_gicd(struct acpi_madt_gicd *gicd, uint gic_id, + ulong phys_base, uint gic_version); + +/** + * acpi_write_madt_gicr() - Write out a MADT GICR sub-table + * + * Write out the GIC Redistributor sub-table. + * + * @gicr: Pointer to place to put the sub-table + * @discovery_range_base_address: Physical address of a page range + * containing all GIC Redistributors + * @discovery_range_length: Length of the GIC Redistributor + * Discovery page range + */ +void acpi_write_madt_gicr(struct acpi_madt_gicr *gicr, + u64 discovery_range_base_address, + u32 discovery_range_length); + +/** + * acpi_write_madt_its() - Write out a MADT ITS sub-table + * + * Write out the GIC Interrupt Translation Service sub-table. + * + * @its: Pointer to place to put the sub-table + * @its_id: Uniqueue GIC ITS ID + * @physical_base_address: Physical address for the Interrupt + * Translation Service + */ +void acpi_write_madt_its(struct acpi_madt_its *its, + u32 its_id, + u64 physical_base_address); + +/** + * acpi_pptt_add_proc() - Write out a PPTT processor sub-table + * + * Write out the Processor Properties Topology Table processor sub-table. + * + * @ctx: ACPI context pointer + * @flags: Processor Structure Flags + * @parent: Reference to parent processor + * @proc_id: ACPI processor ID as defined in MADT + * @num_resources: Number of resource structure references + * @resource_list: References to other PPTT structures + * Return: offset from start of PPTT in bytes + */ +int acpi_pptt_add_proc(struct acpi_ctx *ctx, const u32 flags, const u32 parent, + const u32 proc_id, const u32 num_resources, + const u32 *resource_list); + +/** + * acpi_pptt_add_cache() - Write out a PPTT cache sub-table + * + * Write out the Processor Properties Topology Table cache sub-table. + * + * @ctx: ACPI context pointer + * @flags: Cache Structure Flags + * @next_cache_level: Reference to next level of cache + * @size: Size of the cache in bytes + * @sets: Number of sets in the cache + * @assoc: Integer number of ways + * @attributes: Allocation type, Cache type, policy + * @line_size: Line size in bytes + * Return: offset from start of PPTT in bytes + */ +int acpi_pptt_add_cache(struct acpi_ctx *ctx, const u32 flags, + const u32 next_cache_level, const u32 size, + const u32 sets, const u8 assoc, const u8 attributes, + const u16 line_size); + +#endif /* !__ASSEMBLY__ */ +#endif /* !__ACPI__ */ + +#endif /* __ASM_ACPI_TABLE_H__ */ diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 67275fba61..a7efed6771 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -86,6 +86,7 @@ obj-y += psci-dt.o obj-$(CONFIG_DEBUG_LL) += debug.o
obj-$(CONFIG_BLOBLIST) += xferlist.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o
# For EABI conformant tool chains, provide eabi_compat() ifneq (,$(findstring -mabi=aapcs-linux,$(PLATFORM_CPPFLAGS))) diff --git a/arch/arm/lib/acpi_table.c b/arch/arm/lib/acpi_table.c new file mode 100644 index 0000000000..286ed7ceca --- /dev/null +++ b/arch/arm/lib/acpi_table.c @@ -0,0 +1,114 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Based on acpi.c from coreboot + * + * Copyright (C) 2024 9elements GmbH + */ + +#define LOG_CATEGORY LOGC_ACPI + +#include <string.h> +#include <acpi/acpigen.h> +#include <acpi/acpi_device.h> +#include <acpi/acpi_table.h> + +void acpi_write_madt_gicc(struct acpi_madt_gicc *gicc, uint cpu_num, + uint perf_gsiv, ulong phys_base, ulong gicv, + ulong gich, uint vgic_maint_irq, u64 gicr_base, + ulong mpidr, uint efficiency) +{ + memset(gicc, '\0', sizeof(struct acpi_madt_gicc)); + gicc->type = ACPI_APIC_GICC; + gicc->length = sizeof(struct acpi_madt_gicc); + gicc->cpu_if_num = cpu_num; + gicc->processor_id = cpu_num; + gicc->flags = ACPI_MADTF_ENABLED; + gicc->perf_gsiv = perf_gsiv; + gicc->phys_base = phys_base; + gicc->gicv = gicv; + gicc->gich = gich; + gicc->vgic_maint_irq = vgic_maint_irq; + gicc->gicr_base = gicr_base; + gicc->mpidr = mpidr; + gicc->efficiency = efficiency; +} + +void acpi_write_madt_gicd(struct acpi_madt_gicd *gicd, uint gic_id, + ulong phys_base, uint gic_version) +{ + memset(gicd, '\0', sizeof(struct acpi_madt_gicd)); + gicd->type = ACPI_APIC_GICD; + gicd->length = sizeof(struct acpi_madt_gicd); + gicd->gic_id = gic_id; + gicd->phys_base = phys_base; + gicd->gic_version = gic_version; +} + +void acpi_write_madt_gicr(struct acpi_madt_gicr *gicr, + u64 discovery_range_base_address, + u32 discovery_range_length) +{ + memset(gicr, '\0', sizeof(struct acpi_madt_gicr)); + gicr->type = ACPI_APIC_GICR; + gicr->length = sizeof(struct acpi_madt_gicr); + gicr->discovery_range_base_address = discovery_range_base_address; + gicr->discovery_range_length = discovery_range_length; +} + +void acpi_write_madt_its(struct acpi_madt_its *its, + u32 its_id, + u64 physical_base_address) +{ + memset(its, '\0', sizeof(struct acpi_madt_its)); + its->type = ACPI_APIC_ITS; + its->length = sizeof(struct acpi_madt_its); + its->gic_its_id = its_id; + its->physical_base_address = physical_base_address; +} + +int acpi_pptt_add_proc(struct acpi_ctx *ctx, const u32 flags, const u32 parent, + const u32 proc_id, const u32 num_resources, + const u32 *resource_list) +{ + struct acpi_pptt_proc *proc = ctx->current; + int offset; + + offset = ctx->current - ctx->tab_start; + proc->hdr.type = ACPI_PPTT_TYPE_PROC; + proc->flags = flags; + proc->parent = parent; + proc->proc_id = proc_id; + proc->num_resources = num_resources; + proc->hdr.length = sizeof(struct acpi_pptt_proc) + + sizeof(u32) * num_resources; + + if (resource_list) + memcpy(proc + 1, resource_list, sizeof(u32) * num_resources); + + acpi_inc(ctx, proc->hdr.length); + + return offset; +} + +int acpi_pptt_add_cache(struct acpi_ctx *ctx, const u32 flags, + const u32 next_cache_level, const u32 size, + const u32 sets, const u8 assoc, const u8 attributes, + const u16 line_size) +{ + struct acpi_pptt_cache *cache = ctx->current; + int offset; + + offset = ctx->current - ctx->tab_start; + cache->hdr.type = ACPI_PPTT_TYPE_CACHE; + cache->hdr.length = sizeof(struct acpi_pptt_cache); + cache->flags = flags; + cache->next_cache_level = next_cache_level; + cache->size = size; + cache->sets = sets; + cache->assoc = assoc; + cache->attributes = attributes; + cache->line_size = line_size; + acpi_inc(ctx, cache->hdr.length); + + return offset; +} diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index c6a3e44a95..7d994a985f 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -342,7 +342,10 @@ enum acpi_apic_types { ACPI_APIC_LX2APIC, /* Processor local x2APIC */ ACPI_APIC_LX2APIC_NMI, /* Local x2APIC NMI */ ACPI_APIC_GICC, /* Generic Interrupt Ctlr CPU i/f */ - ACPI_APIC_GICD /* Generic Interrupt Ctlr Distributor */ + ACPI_APIC_GICD, /* Generic Interrupt Ctlr Distributor */ + ACPI_APIC_MSI_FRAME, /* Generic Interrupt MSI Frame */ + ACPI_APIC_GICR, /* Generic Interrupt Ctlr Redistributor */ + ACPI_APIC_ITS, /* Interrupt Translation Service */ };
/* MADT: Processor Local APIC Structure */ @@ -437,6 +440,35 @@ struct acpi_madt_gicd { u8 reserved3[3]; } __packed;
+/** + * struct __packed acpi_madt_gicr - GIC Redistributor (type 0xe) + * + * This holds information about the Generic Interrupt Controller (GIC) + * Redistributor interface. See ACPI Spec v6.3 section 5.2.12.17 + */ +struct acpi_madt_gicr { + u8 type; + u8 length; + u16 reserved; + u64 discovery_range_base_address; + u32 discovery_range_length; +} __packed; + +/** + * struct __packed acpi_madt_its - GIC Interrupt Translation Service (type 0xf) + * + * This holds information about the Interrupt Translation Service (ITS) + * Structure. See ACPI Spec v6.3 section 5.2.12.18 + */ +struct acpi_madt_its { + u8 type; + u8 length; + u16 reserved; + u32 gic_its_id; + u64 physical_base_address; + u32 reserved2; +} __packed; + /* MCFG (PCI Express MMIO config space BAR description table) */ struct acpi_mcfg { struct acpi_table_header header;
Add a new method to acpi_ops to let drivers fill out ACPI MADT. The code is unused for now until drivers implement the new ops.
TEST: Booted on QEMU sbsa using driver model generated MADT.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- Changelog v4: - Drop __weak attribute and make driver model mandatory on Arm Changelog v8: - Rebase on -next --- arch/arm/lib/acpi_table.c | 13 ++++++++++++ drivers/core/acpi.c | 16 +++++++++++++++ include/dm/acpi.h | 26 +++++++++++++++++++++++ lib/acpi/acpi_table.c | 2 +- test/dm/acpi.c | 43 +++++++++++++++++++++++++++++++++++++++ 5 files changed, 99 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/acpi_table.c b/arch/arm/lib/acpi_table.c index 286ed7ceca..e0add04926 100644 --- a/arch/arm/lib/acpi_table.c +++ b/arch/arm/lib/acpi_table.c @@ -11,6 +11,8 @@ #include <acpi/acpigen.h> #include <acpi/acpi_device.h> #include <acpi/acpi_table.h> +#include <dm/acpi.h> +#include <dm/uclass.h>
void acpi_write_madt_gicc(struct acpi_madt_gicc *gicc, uint cpu_num, uint perf_gsiv, ulong phys_base, ulong gicv, @@ -112,3 +114,14 @@ int acpi_pptt_add_cache(struct acpi_ctx *ctx, const u32 flags,
return offset; } + +void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx) +{ + uclass_probe_all(UCLASS_CPU); + uclass_probe_all(UCLASS_IRQ); + + /* All SoCs must use the driver model */ + acpi_fill_madt_subtbl(ctx); + + return ctx->current; +} diff --git a/drivers/core/acpi.c b/drivers/core/acpi.c index 9f78422892..4763963914 100644 --- a/drivers/core/acpi.c +++ b/drivers/core/acpi.c @@ -48,6 +48,7 @@ enum method_t { METHOD_FILL_SSDT, METHOD_INJECT_DSDT, METHOD_SETUP_NHLT, + METHOD_FILL_MADT, };
/* Prototype for all methods */ @@ -282,6 +283,8 @@ acpi_method acpi_get_method(struct udevice *dev, enum method_t method) switch (method) { case METHOD_WRITE_TABLES: return aops->write_tables; + case METHOD_FILL_MADT: + return aops->fill_madt; case METHOD_FILL_SSDT: return aops->fill_ssdt; case METHOD_INJECT_DSDT: @@ -328,6 +331,19 @@ int acpi_recurse_method(struct acpi_ctx *ctx, struct udevice *parent, return 0; }
+int acpi_fill_madt_subtbl(struct acpi_ctx *ctx) +{ + int ret; + + log_debug("Writing MADT table\n"); + ret = acpi_recurse_method(ctx, dm_root(), METHOD_FILL_MADT, TYPE_NONE); + log_debug("Writing MADT finished, err=%d\n", ret); + if (ret) + return log_msg_ret("build", ret); + + return ret; +} + int acpi_fill_ssdt(struct acpi_ctx *ctx) { void *start = ctx->current; diff --git a/include/dm/acpi.h b/include/dm/acpi.h index 3adfe21767..d6bc0c099a 100644 --- a/include/dm/acpi.h +++ b/include/dm/acpi.h @@ -146,6 +146,22 @@ struct acpi_ops { */ int (*write_tables)(const struct udevice *dev, struct acpi_ctx *ctx);
+ /** + * fill_madt() - Generate MADT sub-tables for a device + * + * This is called to create the MADT table. The method should write out + * whatever sub-table is needed by this device. It will end up in the + * MADT table. + * + * Note that this is called 'fill' because the entire contents of the + * MADT is build by calling this method on all devices. + * + * @dev: Device to write + * @ctx: ACPI context to use + * @return 0 if OK, -ve on error + */ + int (*fill_madt)(const struct udevice *dev, struct acpi_ctx *ctx); + /** * fill_ssdt() - Generate SSDT code for a device * @@ -231,6 +247,16 @@ int acpi_copy_name(char *out_name, const char *name); */ int acpi_write_dev_tables(struct acpi_ctx *ctx);
+/** + * acpi_fill_madt_subtbl() - Generate ACPI tables for MADT + * + * This is called to create the MADT sub-tables for all devices. + * + * @ctx: ACPI context to use + * Return: 0 if OK, -ve on error + */ +int acpi_fill_madt_subtbl(struct acpi_ctx *ctx); + /** * acpi_fill_ssdt() - Generate ACPI tables for SSDT * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 639d78125f..5b9b4d2f29 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -257,11 +257,11 @@ int acpi_write_madt(struct acpi_ctx *ctx, const struct acpi_writer *entry) header->revision = ACPI_MADT_REV_ACPI_3_0;
acpi_inc(ctx, sizeof(struct acpi_madt)); + /* TODO: Get rid of acpi_fill_madt and use driver model */ current = acpi_fill_madt(madt, ctx);
/* (Re)calculate length and checksum */ header->length = (uintptr_t)current - (uintptr_t)madt; - header->checksum = table_compute_checksum((void *)madt, header->length); acpi_add_table(ctx, madt); ctx->current = (void *)madt + madt->header.length; diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 7ccd7f8d20..39a26bbb49 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -95,6 +95,21 @@ static int testacpi_get_name(const struct udevice *dev, char *out_name) return acpi_copy_name(out_name, ACPI_TEST_DEV_NAME); }
+static int testacpi_fill_madt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + u64 *data = ctx->current; + + /* Only fill madt once */ + if (device_get_uclass_id(dev->parent) != UCLASS_TEST_ACPI) + return 0; + + *data = 0xdeadbeef; + + acpi_inc(ctx, sizeof(u64)); + + return 0; +} + static int testacpi_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) { const char *data; @@ -124,6 +139,7 @@ static int testacpi_inject_dsdt(const struct udevice *dev, struct acpi_ctx *ctx) struct acpi_ops testacpi_ops = { .get_name = testacpi_get_name, .write_tables = testacpi_write_tables, + .fill_madt = testacpi_fill_madt, .fill_ssdt = testacpi_fill_ssdt, .inject_dsdt = testacpi_inject_dsdt, }; @@ -527,6 +543,33 @@ static int dm_test_acpi_fill_ssdt(struct unit_test_state *uts) } DM_TEST(dm_test_acpi_fill_ssdt, UTF_SCAN_PDATA | UTF_SCAN_FDT);
+/* Test acpi_fill_madt() */ +static int dm_test_acpi_fill_madt(struct unit_test_state *uts) +{ + struct acpi_ctx ctx; + u64 *buf; + + buf = malloc(BUF_SIZE); + ut_assertnonnull(buf); + + acpi_reset_items(); + ctx.current = buf; + buf[1] = 'z'; /* sentinel */ + ut_assertok(acpi_fill_madt_subtbl(&ctx)); + + /* + * These values come from acpi-test2's acpi-ssdt-test-data property. + * This device comes first because of u-boot,acpi-ssdt-order + */ + ut_asserteq(0xdeadbeef, buf[0]); + + ut_asserteq('z', buf[1]); + + return 0; +} + +DM_TEST(dm_test_acpi_fill_madt, UTF_SCAN_PDATA | UTF_SCAN_FDT); + /* Test acpi_inject_dsdt() */ static int dm_test_acpi_inject_dsdt(struct unit_test_state *uts) {
The FADT structure found in U-Boot represents FADT revision 6 and the GICC and GICD structures defined in U-Boot are based on ACPI revision 6.3.
Bump the table revision to fix FWTS failures seen on aarch64.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com --- arch/x86/cpu/tangier/acpi.c | 2 -- include/acpi/acpi_table.h | 3 ++- lib/acpi/acpi_table.c | 7 ++++--- 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/x86/cpu/tangier/acpi.c b/arch/x86/cpu/tangier/acpi.c index 3d11787861..8ea764f7cc 100644 --- a/arch/x86/cpu/tangier/acpi.c +++ b/arch/x86/cpu/tangier/acpi.c @@ -28,8 +28,6 @@ void acpi_fill_fadt(struct acpi_fadt *fadt) ACPI_FADT_POWER_BUTTON | ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_SEALED_CASE | ACPI_FADT_HEADLESS | ACPI_FADT_HW_REDUCED_ACPI; - fadt->header.revision = 6; - fadt->minor_revision = 2; }
void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx) diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 7d994a985f..48f8ce248f 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -290,7 +290,8 @@ struct __packed acpi_fadt { #define ACPI_MADT_REV_ACPI_3_0 2 #define ACPI_MADT_REV_ACPI_4_0 3 #define ACPI_MADT_REV_ACPI_5_0 3 -#define ACPI_MADT_REV_ACPI_6_0 5 +#define ACPI_MADT_REV_ACPI_6_2 4 +#define ACPI_MADT_REV_ACPI_6_3 5
#define ACPI_MCFG_REV_ACPI_3_0 1
diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 5b9b4d2f29..959cac9e2e 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -63,9 +63,9 @@ int acpi_get_table_revision(enum acpi_tables table) { switch (table) { case ACPITAB_FADT: - return ACPI_FADT_REV_ACPI_3_0; + return ACPI_FADT_REV_ACPI_6_0; case ACPITAB_MADT: - return ACPI_MADT_REV_ACPI_3_0; + return ACPI_MADT_REV_ACPI_6_2; case ACPITAB_MCFG: return ACPI_MCFG_REV_ACPI_3_0; case ACPITAB_TCPA: @@ -219,6 +219,7 @@ int acpi_write_fadt(struct acpi_ctx *ctx, const struct acpi_writer *entry) memcpy(header->oem_table_id, OEM_TABLE_ID, 8); memcpy(header->creator_id, ASLC_ID, 4); header->creator_revision = 1; + fadt->minor_revision = 2;
fadt->x_firmware_ctrl = map_to_sysmem(ctx->facs); fadt->x_dsdt = map_to_sysmem(ctx->dsdt); @@ -254,7 +255,7 @@ int acpi_write_madt(struct acpi_ctx *ctx, const struct acpi_writer *entry) /* Fill out header fields */ acpi_fill_header(header, "APIC"); header->length = sizeof(struct acpi_madt); - header->revision = ACPI_MADT_REV_ACPI_3_0; + header->revision = acpi_get_table_revision(ACPITAB_MADT);
acpi_inc(ctx, sizeof(struct acpi_madt)); /* TODO: Get rid of acpi_fill_madt and use driver model */
Return the ACPI table revision in acpi_get_table_revision() for PPTT and GTDT. Match both to ACPI 6.2.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- include/acpi/acpi_table.h | 2 ++ lib/acpi/acpi_table.c | 4 ++++ 2 files changed, 6 insertions(+)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 48f8ce248f..7ee3248ff6 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -841,12 +841,14 @@ enum acpi_tables { ACPITAB_ECDT, ACPITAB_FACS, ACPITAB_FADT, + ACPITAB_GTDT, ACPITAB_HEST, ACPITAB_HPET, ACPITAB_IVRS, ACPITAB_MADT, ACPITAB_MCFG, ACPITAB_NHLT, + ACPITAB_PPTT, ACPITAB_RSDP, ACPITAB_RSDT, ACPITAB_SLIT, diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 959cac9e2e..2dc7b998e2 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -107,6 +107,10 @@ int acpi_get_table_revision(enum acpi_tables table) return 1; case ACPITAB_SPCR: return 2; + case ACPITAB_PPTT: /* ACPI 6.2: 1 */ + return 1; + case ACPITAB_GTDT: /* ACPI 6.2: 2, ACPI 6.3: 3 */ + return 2; default: return -EINVAL; }
The SoC can implement acpi_fill_iort to update the IORT table. Add a helper function to fill out the NAMED_COMPONENT node.
TEST=Run FWTS V24.03.00 on RPi4 and round no problems.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- include/acpi/acpi_table.h | 213 ++++++++++++++++++++++++++++++++++++++ lib/acpi/acpi_table.c | 213 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 426 insertions(+)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 7ee3248ff6..5a30465ad2 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -832,6 +832,117 @@ struct acpi_pptt_cache { u16 line_size; } __packed;
+/** IORT - IO Remapping Table revision 6 + * Document number: ARM DEN 0049E.e, Sep 2022 + */ +struct acpi_table_iort { + struct acpi_table_header header; + u32 node_count; + u32 node_offset; + u32 reserved; +} __packed; + +/* + * IORT subtables + */ +struct acpi_iort_node { + u8 type; + u16 length; + u8 revision; + u32 identifier; + u32 mapping_count; + u32 mapping_offset; + char node_data[]; +} __packed; + +/* Values for subtable Type above */ +enum acpi_iort_node_type { + ACPI_IORT_NODE_ITS_GROUP = 0x00, + ACPI_IORT_NODE_NAMED_COMPONENT = 0x01, + ACPI_IORT_NODE_PCI_ROOT_COMPLEX = 0x02, + ACPI_IORT_NODE_SMMU = 0x03, + ACPI_IORT_NODE_SMMU_V3 = 0x04, + ACPI_IORT_NODE_PMCG = 0x05, + ACPI_IORT_NODE_RMR = 0x06, +}; + +/* ITS Group revision 1 */ +struct acpi_iort_its_group { + u32 its_count; + u32 identifiers[]; /* GIC ITS identifier array */ +} __packed; + +/* PCI root complex node revision 2 */ +struct acpi_iort_rc { + u64 mem_access_properties; + u32 ats_attributes; + u32 pci_segment_number; + u8 memory_address_size_limit; + u8 reserved[3]; +} __packed; + +/* SMMUv3 revision 5 */ +struct acpi_iort_smmu_v3 { + u64 base_address; /* SMMUv3 base address */ + u32 flags; + u32 reserved; + u64 vatos_address; + u32 model; + u32 event_gsiv; + u32 pri_gsiv; + u32 gerr_gsiv; + u32 sync_gsiv; + u32 pxm; + u32 id_mapping_index; +} __packed; + +/* Masks for Flags field above */ +#define ACPI_IORT_SMMU_V3_COHACC_OVERRIDE (1) +#define ACPI_IORT_SMMU_V3_HTTU_OVERRIDE (3 << 1) +#define ACPI_IORT_SMMU_V3_PXM_VALID (1 << 3) +#define ACPI_IORT_SMMU_V3_DEVICEID_VALID (1 << 4) + +struct acpi_iort_id_mapping { + u32 input_base; /* Lowest value in input range */ + u32 id_count; /* Number of IDs */ + u32 output_base; /* Lowest value in output range */ + u32 output_reference; /* A reference to the output node */ + u32 flags; +} __packed; + +/* Masks for Flags field above for IORT subtable */ +#define ACPI_IORT_ID_SINGLE_MAPPING (1) + +/* Named Component revision 4 */ +struct acpi_iort_named_component { + u32 node_flags; + u64 memory_properties; /* Memory access properties */ + u8 memory_address_limit; /* Memory address size limit */ + char device_name[]; /* Path of namespace object */ +} __packed; + +/* Masks for Flags field above */ +#define ACPI_IORT_NC_STALL_SUPPORTED (1) +#define ACPI_IORT_NC_PASID_BITS (31 << 1) + +struct acpi_iort_root_complex { + u64 memory_properties; /* Memory access properties */ + u32 ats_attribute; + u32 pci_segment_number; + u8 memory_address_limit;/* Memory address size limit */ + u16 pasid_capabilities; /* PASID Capabilities */ + u8 reserved; /* Reserved, must be zero */ + u32 flags; /* Flags */ +} __packed; + +/* Masks for ats_attribute field above */ +#define ACPI_IORT_ATS_SUPPORTED (1) /* The root complex ATS support */ +#define ACPI_IORT_PRI_SUPPORTED (1 << 1) /* The root complex PRI support */ +#define ACPI_IORT_PASID_FWD_SUPPORTED (1 << 2) /* The root complex PASID forward support */ + +/* Masks for pasid_capabilities field above */ +#define ACPI_IORT_PASID_MAX_WIDTH (0x1F) /* Bits 0-4 */ + /* Tables defined/reserved by ACPI and generated by U-Boot */ enum acpi_tables { ACPITAB_BERT, @@ -1000,6 +1111,108 @@ int acpi_fill_csrt(struct acpi_ctx *ctx); */ void acpi_fill_fadt(struct acpi_fadt *fadt);
+/** + * acpi_fill_iort() - Fill out the body of the IORT table + * + * Should be implemented in SoC specific code. + * + * @ctx: ACPI context to write to + * @offset: Offset from the start of the IORT + */ +int acpi_fill_iort(struct acpi_ctx *ctx); + +/** + * acpi_iort_add_its_group() - Add ITS group node to IORT table + * + * Called by SoC specific code within acpi_fill_iort(). + * + * @ctx: ACPI context to write to + * @its_count: Elements in identifiers + * @identifiers: The array of ITS identifiers. These IDs must match the value + * used in the Multiple APIC Description Table (MADT) GIC ITS + * structure for each relevant ITS unit. + * @return Offset of table within parent + */ +int acpi_iort_add_its_group(struct acpi_ctx *ctx, + const u32 its_count, + const u32 *identifiers); + +/** + * acpi_iort_add_named_component() - Add named component to IORT table + * + * Called by SoC specific code within acpi_fill_iort(). + * + * @ctx: ACPI context to write to + * @node_flags: Node flags + * @memory_properties: Memory properties + * @memory_address_limit: Memory address limit + * @device_name: ACPI device path + * @return Offset of table within parent + */ +int acpi_iort_add_named_component(struct acpi_ctx *ctx, + const u32 node_flags, + const u64 memory_properties, + const u8 memory_address_limit, + const char *device_name); + +/** + * acpi_iort_add_rc() - Add PCI root complex node to IORT table + * + * Called by SoC specific code within acpi_fill_iort(). + * + * @ctx: ACPI context to write to + * @mem_access_properties: Memory access properties + * @ats_attributes: Support for ATS and its ancillary feature + * @pci_segment_number: The PCI segment number, as in MCFG + * @memory_address_size_limit: The number of address bits, starting from LSB + * @num_mappings: Number of elements in map + * @map: ID mappings for this node + * @return Offset of table within parent + */ +int acpi_iort_add_rc(struct acpi_ctx *ctx, + const u64 mem_access_properties, + const u32 ats_attributes, + const u32 pci_segment_number, + const u8 memory_address_size_limit, + const int num_mappings, + const struct acpi_iort_id_mapping *map); + +/** + * acpi_iort_add_smmu_v3() - Add PCI root complex node to IORT table + * + * Called by SoC specific code within acpi_fill_iort(). + * + * @ctx: ACPI context to write to + * @base_address: Base address of SMMU + * @flags: SMMUv3 flags + * @vatos_address: Optional, set to zero if not supported + * @model: Model ID + * @event_gsiv: GSIV of the Event interrupt if SPI based + * @pri_gsiv: GSIV of the PRI interrupt if SPI based + * @gerr_gsiv: GSIV of the GERR interrupt if GSIV based + * @sync_gsiv: TGSIV of the Sync interrupt if GSIV based + * @pxm: Proximity Domain + * @id_mapping_index: If all the SMMU control interrupts are GSIV based, + * this field is ignored. Index into the array of ID + * mapping otherwise. + * @num_mappings: Number of elements in map + * @map: ID mappings for this node + * @return Offset of table within parent + */ +int acpi_iort_add_smmu_v3(struct acpi_ctx *ctx, + const u64 base_address, + const u32 flags, + const u64 vatos_address, + const u32 model, + const u32 event_gsiv, + const u32 pri_gsiv, + const u32 gerr_gsiv, + const u32 sync_gsiv, + const u32 pxm, + const u32 id_mapping_index, + const int num_mappings, + const struct acpi_iort_id_mapping *map); + /** * acpi_fill_madt() - Fill out the body of the MADT * diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 2dc7b998e2..9d9c8befe8 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -520,3 +520,216 @@ static int acpi_write_spcr(struct acpi_ctx *ctx, const struct acpi_writer *entry }
ACPI_WRITER(5spcr, "SPCR", acpi_write_spcr, 0); + +__weak int acpi_fill_iort(struct acpi_ctx *ctx) +{ + return 0; +} + +int acpi_iort_add_its_group(struct acpi_ctx *ctx, + const u32 its_count, + const u32 *identifiers) +{ + struct acpi_iort_node *node; + struct acpi_iort_its_group *group; + int offset; + + offset = ctx->current - ctx->tab_start; + + node = ctx->current; + memset(node, '\0', sizeof(struct acpi_iort_node)); + + node->type = ACPI_IORT_NODE_ITS_GROUP; + node->revision = 1; + + node->length = sizeof(struct acpi_iort_node); + node->length += sizeof(struct acpi_iort_its_group); + node->length += sizeof(u32) * its_count; + + group = (struct acpi_iort_its_group *)node->node_data; + group->its_count = its_count; + memcpy(&group->identifiers, identifiers, sizeof(u32) * its_count); + + ctx->current += node->length; + + return offset; +} + +int acpi_iort_add_named_component(struct acpi_ctx *ctx, + const u32 node_flags, + const u64 memory_properties, + const u8 memory_address_limit, + const char *device_name) +{ + struct acpi_iort_node *node; + struct acpi_iort_named_component *comp; + int offset; + + offset = ctx->current - ctx->tab_start; + + node = ctx->current; + memset(node, '\0', sizeof(struct acpi_iort_node)); + + node->type = ACPI_IORT_NODE_NAMED_COMPONENT; + node->revision = 4; + node->length = sizeof(struct acpi_iort_node); + node->length += sizeof(struct acpi_iort_named_component); + node->length += strlen(device_name) + 1; + + comp = (struct acpi_iort_named_component *)node->node_data; + + comp->node_flags = node_flags; + comp->memory_properties = memory_properties; + comp->memory_address_limit = memory_address_limit; + memcpy(comp->device_name, device_name, strlen(device_name) + 1); + + ctx->current += node->length; + + return offset; +} + +int acpi_iort_add_rc(struct acpi_ctx *ctx, + const u64 mem_access_properties, + const u32 ats_attributes, + const u32 pci_segment_number, + const u8 memory_address_size_limit, + const int num_mappings, + const struct acpi_iort_id_mapping *map) +{ + struct acpi_iort_id_mapping *mapping; + struct acpi_iort_node *node; + struct acpi_iort_rc *rc; + int offset; + + offset = ctx->current - ctx->tab_start; + + node = ctx->current; + memset(node, '\0', sizeof(struct acpi_iort_node)); + + node->type = ACPI_IORT_NODE_PCI_ROOT_COMPLEX; + node->revision = 2; + + node->length = sizeof(struct acpi_iort_node); + node->length += sizeof(struct acpi_iort_rc); + node->length += sizeof(struct acpi_iort_id_mapping) * num_mappings; + + rc = (struct acpi_iort_rc *)node->node_data; + rc->mem_access_properties = mem_access_properties; + rc->ats_attributes = ats_attributes; + rc->pci_segment_number = pci_segment_number; + rc->memory_address_size_limit = memory_address_size_limit; + + mapping = (struct acpi_iort_id_mapping *)(rc + 1); + for (int i = 0; i < num_mappings; i++) { + memcpy(mapping, &map[i], sizeof(struct acpi_iort_id_mapping)); + mapping++; + } + + ctx->current += node->length; + + return offset; +} + +int acpi_iort_add_smmu_v3(struct acpi_ctx *ctx, + const u64 base_address, + const u32 flags, + const u64 vatos_address, + const u32 model, + const u32 event_gsiv, + const u32 pri_gsiv, + const u32 gerr_gsiv, + const u32 sync_gsiv, + const u32 pxm, + const u32 id_mapping_index, + const int num_mappings, + const struct acpi_iort_id_mapping *map) +{ + struct acpi_iort_node *node; + struct acpi_iort_smmu_v3 *smmu; + struct acpi_iort_id_mapping *mapping; + int offset; + + offset = ctx->current - ctx->tab_start; + + node = ctx->current; + memset(node, '\0', sizeof(struct acpi_iort_node)); + + node->type = ACPI_IORT_NODE_SMMU_V3; + node->revision = 5; + node->mapping_count = num_mappings; + node->mapping_offset = sizeof(struct acpi_iort_node) + sizeof(struct acpi_iort_smmu_v3); + + node->length = sizeof(struct acpi_iort_node); + node->length += sizeof(struct acpi_iort_smmu_v3); + node->length += sizeof(struct acpi_iort_id_mapping) * num_mappings; + + smmu = (struct acpi_iort_smmu_v3 *)node->node_data; + + smmu->base_address = base_address; + smmu->flags = flags; + smmu->vatos_address = vatos_address; + smmu->model = model; + smmu->event_gsiv = event_gsiv; + smmu->pri_gsiv = pri_gsiv; + smmu->gerr_gsiv = gerr_gsiv; + smmu->sync_gsiv = sync_gsiv; + smmu->pxm = pxm; + smmu->id_mapping_index = id_mapping_index; + + mapping = (struct acpi_iort_id_mapping *)(smmu + 1); + for (int i = 0; i < num_mappings; i++) { + memcpy(mapping, &map[i], sizeof(struct acpi_iort_id_mapping)); + mapping++; + } + + ctx->current += node->length; + + return offset; +} + +static int acpi_write_iort(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_iort *iort; + struct acpi_iort_node *node; + u32 offset; + int ret; + + iort = ctx->current; + ctx->tab_start = ctx->current; + memset(iort, '\0', sizeof(struct acpi_table_iort)); + + acpi_fill_header(&iort->header, "IORT"); + iort->header.revision = 1; + iort->header.creator_revision = 1; + iort->header.length = sizeof(struct acpi_table_iort); + iort->node_offset = sizeof(struct acpi_table_iort); + + acpi_inc(ctx, sizeof(struct acpi_table_iort)); + + offset = sizeof(struct acpi_table_iort); + ret = acpi_fill_iort(ctx); + if (ret) { + ctx->current = iort; + return log_msg_ret("fill", ret); + } + + /* Count nodes filled in */ + for (node = (void *)iort + iort->node_offset; + node->length > 0 && (void *)node < ctx->current; + node = (void *)node + node->length) + iort->node_count++; + + /* (Re)calculate length and checksum */ + iort->header.length = ctx->current - (void *)iort; + iort->header.checksum = table_compute_checksum((void *)iort, iort->header.length); + log_debug("IORT at %p, length %x\n", iort, iort->header.length); + + /* Drop the table if it is empty */ + if (iort->header.length == sizeof(struct acpi_table_iort)) + return log_msg_ret("fill", -ENOENT); + acpi_add_table(ctx, iort); + + return 0; +} + +ACPI_WRITER(5iort, "IORT", acpi_write_iort, 0);
Allow other architectures to use acpi_create_mcfg_mmconfig as well by moving the function prototype to common code.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- arch/x86/include/asm/acpi_table.h | 2 -- include/acpi/acpi_table.h | 13 +++++++++++++ 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 3254bbc380..ff60384e62 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -31,8 +31,6 @@ int acpi_create_madt_irqoverride(struct acpi_madt_irqoverride *irqoverride, u8 bus, u8 source, u32 gsirq, u16 flags); int acpi_create_madt_lapic_nmi(struct acpi_madt_lapic_nmi *lapic_nmi, u8 cpu, u16 flags, u8 lint); -int acpi_create_mcfg_mmconfig(struct acpi_mcfg_mmconfig *mmconfig, u32 base, - u16 seg_nr, u8 start, u8 end);
/** * acpi_write_hpet() - Write out a HPET table diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 5a30465ad2..07c5f65d75 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -994,6 +994,19 @@ int acpi_get_table_revision(enum acpi_tables table); */ int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags);
+/** + * acpi_create_mcfg_mmconfig() - Create a MCFG table entry + * + * @mmconfig: Place to put the table + * @base: Base address of the ECAM space + * @seg_nr: PCI segment number + * @start: PCI bus start number + * @end: PCI bus end number + * Return: size of data written in bytes + */ +int acpi_create_mcfg_mmconfig(struct acpi_mcfg_mmconfig *mmconfig, u32 base, + u16 seg_nr, u8 start, u8 end); + /** * acpi_create_dbg2() - Create a DBG2 table *
Since ACPI 2.0 the RSDT is deprecated and the XSDT should be preferred. Until now the RSDT and XSDT entries were keept in sync as all platforms that installed ACPI tables placed them below 4GiB and thus the address would fit into the 32bit RSDT.
On platforms that do not have usable DRAM below 4GiB, like QEMU sbsa, the RSDT cannot be used. Allow both RSDT and XSDT to be null and only fill those tables that are present in acpi_add_table().
TEST: Fixes a crash on QEMU sbsa and allows to boot on QEMU sbsa.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- Changelog v4: - Updated commit message and better explain why this change is needed --- lib/acpi/acpi_table.c | 95 ++++++++++++++++++++++++++----------------- 1 file changed, 57 insertions(+), 38 deletions(-)
diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 9d9c8befe8..d6357bdc4d 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -157,51 +157,70 @@ int acpi_add_table(struct acpi_ctx *ctx, void *table) struct acpi_rsdt *rsdt; struct acpi_xsdt *xsdt;
- /* The RSDT is mandatory while the XSDT is not */ - rsdt = ctx->rsdt; - - /* This should always be MAX_ACPI_TABLES */ - entries_num = ARRAY_SIZE(rsdt->entry); - - for (i = 0; i < entries_num; i++) { - if (rsdt->entry[i] == 0) - break; - } - - if (i >= entries_num) { - log_err("ACPI: Error: too many tables\n"); - return -E2BIG; - } + /* On legacy x86 platforms the RSDT is mandatory while the XSDT is not. + * On other platforms there might be no memory below 4GiB, thus RSDT is NULL. + */ + if (ctx->rsdt) { + rsdt = ctx->rsdt;
- /* Add table to the RSDT */ - rsdt->entry[i] = nomap_to_sysmem(table); + /* This should always be MAX_ACPI_TABLES */ + entries_num = ARRAY_SIZE(rsdt->entry);
- /* Fix RSDT length or the kernel will assume invalid entries */ - rsdt->header.length = sizeof(struct acpi_table_header) + - (sizeof(u32) * (i + 1)); + for (i = 0; i < entries_num; i++) { + if (rsdt->entry[i] == 0) + break; + }
- /* Re-calculate checksum */ - rsdt->header.checksum = 0; - rsdt->header.checksum = table_compute_checksum((u8 *)rsdt, - rsdt->header.length); + if (i >= entries_num) { + log_err("ACPI: Error: too many tables\n"); + return -E2BIG; + }
- /* - * And now the same thing for the XSDT. We use the same index as for - * now we want the XSDT and RSDT to always be in sync in U-Boot - */ - xsdt = ctx->xsdt; + /* Add table to the RSDT */ + rsdt->entry[i] = nomap_to_sysmem(table);
- /* Add table to the XSDT */ - xsdt->entry[i] = nomap_to_sysmem(table); + /* Fix RSDT length or the kernel will assume invalid entries */ + rsdt->header.length = sizeof(struct acpi_table_header) + + (sizeof(u32) * (i + 1));
- /* Fix XSDT length */ - xsdt->header.length = sizeof(struct acpi_table_header) + - (sizeof(u64) * (i + 1)); + /* Re-calculate checksum */ + rsdt->header.checksum = 0; + rsdt->header.checksum = table_compute_checksum((u8 *)rsdt, + rsdt->header.length); + }
- /* Re-calculate checksum */ - xsdt->header.checksum = 0; - xsdt->header.checksum = table_compute_checksum((u8 *)xsdt, - xsdt->header.length); + if (ctx->xsdt) { + /* + * And now the same thing for the XSDT. We use the same index as for + * now we want the XSDT and RSDT to always be in sync in U-Boot + */ + xsdt = ctx->xsdt; + + /* This should always be MAX_ACPI_TABLES */ + entries_num = ARRAY_SIZE(xsdt->entry); + + for (i = 0; i < entries_num; i++) { + if (xsdt->entry[i] == 0) + break; + } + + if (i >= entries_num) { + log_err("ACPI: Error: too many tables\n"); + return -E2BIG; + } + + /* Add table to the XSDT */ + xsdt->entry[i] = nomap_to_sysmem(table); + + /* Fix XSDT length */ + xsdt->header.length = sizeof(struct acpi_table_header) + + (sizeof(u64) * (i + 1)); + + /* Re-calculate checksum */ + xsdt->header.checksum = 0; + xsdt->header.checksum = table_compute_checksum((u8 *)xsdt, + xsdt->header.length); + }
return 0; }
Allocate memory for ACPI tables in generic acpi code. When ACPI wasn't installed in other places, install the ACPI table using BLOBLISTs.
This allows non x86 platforms to boot using ACPI only in case the EFI loader is being used, since EFI is necessary to advertise the location of the ACPI tables in memory.
TEST: Booted QEMU SBSA (no QFW) using EFI and ACPI only.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- Changelog v8: - Only use bloblist to store tables on arm --- lib/acpi/acpi_table.c | 66 +++++++++++++++++++++++++++++++- test/py/tests/test_event_dump.py | 1 + 2 files changed, 66 insertions(+), 1 deletion(-)
diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index d6357bdc4d..e6ebffcf1b 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -5,8 +5,11 @@ * Copyright 2019 Google LLC */
-#include <dm.h> +#include <bloblist.h> #include <cpu.h> +#include <dm.h> +#include <efi_api.h> +#include <efi_loader.h> #include <log.h> #include <mapmem.h> #include <tables_csum.h> @@ -16,6 +19,14 @@ #include <acpi/acpi_device.h> #include <asm/global_data.h> #include <dm/acpi.h> +#include <linux/sizes.h> +#include <linux/log2.h> + +enum { + TABLE_SIZE = SZ_64K, +}; + +DECLARE_GLOBAL_DATA_PTR;
/* * OEM_REVISION is 32-bit unsigned number. It should be increased only when @@ -752,3 +763,56 @@ static int acpi_write_iort(struct acpi_ctx *ctx, const struct acpi_writer *entry }
ACPI_WRITER(5iort, "IORT", acpi_write_iort, 0); + +/* + * Allocate memory for ACPI tables and write ACPI tables to the + * allocated buffer. + * + * Return: status code + */ +static int alloc_write_acpi_tables(void) +{ + u64 table_end; + void *addr; + + if (IS_ENABLED(CONFIG_X86) || + IS_ENABLED(CONFIG_QFW_ACPI) || + IS_ENABLED(CONFIG_SANDBOX)) { + log_debug("Skipping writing ACPI tables as already done\n"); + return 0; + } + + if (!IS_ENABLED(CONFIG_BLOBLIST_TABLES)) { + log_debug("Skipping writing ACPI tables as BLOBLIST_TABLES is not selected\n"); + return 0; + } + + /* Align the table to a 4KB boundary to keep EFI happy */ + addr = bloblist_add(BLOBLISTT_ACPI_TABLES, TABLE_SIZE, + ilog2(SZ_4K)); + + if (!addr) + return log_msg_ret("mem", -ENOMEM); + + gd->arch.table_start_high = virt_to_phys(addr); + gd->arch.table_end_high = gd->arch.table_start_high + TABLE_SIZE; + + table_end = write_acpi_tables(gd->arch.table_start_high); + if (!table_end) { + log_err("Can't create ACPI configuration table\n"); + return -EINTR; + } + + log_debug("- wrote 'acpi' to %lx, end %llx\n", gd->arch.table_start_high, table_end); + if (table_end > gd->arch.table_end_high) { + log_err("Out of space for configuration tables: need %llx, have %x\n", + table_end - gd->arch.table_start_high, TABLE_SIZE); + return log_msg_ret("acpi", -ENOSPC); + } + + log_debug("- done writing tables\n"); + + return 0; +} + +EVENT_SPY_SIMPLE(EVT_LAST_STAGE_INIT, alloc_write_acpi_tables); diff --git a/test/py/tests/test_event_dump.py b/test/py/tests/test_event_dump.py index e282c67335..45143c1c7d 100644 --- a/test/py/tests/test_event_dump.py +++ b/test/py/tests/test_event_dump.py @@ -18,6 +18,7 @@ def test_event_dump(u_boot_console): -------------------- ------------------------------ ------------------------------ EVT_FT_FIXUP bootmeth_vbe_ft_fixup .*boot/vbe_request.c:.* EVT_FT_FIXUP bootmeth_vbe_simple_ft_fixup .*boot/vbe_simple_os.c:.* +EVT_LAST_STAGE_INIT alloc_write_acpi_tables .*lib/acpi/acpi_table.c:.* EVT_LAST_STAGE_INIT install_smbios_table .*lib/efi_loader/efi_smbios.c:.* EVT_MISC_INIT_F sandbox_early_getopt_check .*arch/sandbox/cpu/start.c:.* EVT_TEST h_adder_simple .*test/common/event.c:'''
Add a new method to write the processor device identified by _HID ACPI0007, that is preferred over the Processor OpCode since ACPI 6.0.
Fixes booting arm using ACPI only since the Processor OpCode isn't found valid by the Linux kernel.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- include/acpi/acpigen.h | 12 ++++++++++++ lib/acpi/acpigen.c | 11 +++++++++++ 2 files changed, 23 insertions(+)
diff --git a/include/acpi/acpigen.h b/include/acpi/acpigen.h index 3aa94d70b9..16df85b9c1 100644 --- a/include/acpi/acpigen.h +++ b/include/acpi/acpigen.h @@ -833,6 +833,7 @@ void acpigen_write_dsm_end(struct acpi_ctx *ctx); * * This emits a Processor package header with the required information. The * caller must complete the information and call acpigen_pop_len() at the end + * Deprecated since ACPI 6.0. * * @ctx: ACPI context pointer * @cpuindex: CPU number @@ -842,6 +843,17 @@ void acpigen_write_dsm_end(struct acpi_ctx *ctx); void acpigen_write_processor(struct acpi_ctx *ctx, uint cpuindex, u32 pblock_addr, uint pblock_len);
+/** + * acpigen_write_processor_device() - Write a Processor device + * + * Write a device with _HID ACPI0007 identifying a processor. + * Replacement for the Processor OpCode. + * + * @ctx: ACPI context pointer + * @cpuindex: CPU number + */ +void acpigen_write_processor_device(struct acpi_ctx *ctx, uint cpuindex); + /** * acpigen_write_processor_package() - Write a package containing the processors * diff --git a/lib/acpi/acpigen.c b/lib/acpi/acpigen.c index ecff5a50d5..fa9dad32a3 100644 --- a/lib/acpi/acpigen.c +++ b/lib/acpi/acpigen.c @@ -361,6 +361,17 @@ void acpigen_write_processor(struct acpi_ctx *ctx, uint cpuindex, acpigen_emit_byte(ctx, pblock_len); }
+void acpigen_write_processor_device(struct acpi_ctx *ctx, uint cpuindex) +{ + char pscope[16]; + + snprintf(pscope, sizeof(pscope), ACPI_CPU_STRING, cpuindex); + acpigen_write_device(ctx, pscope); + acpigen_write_name_string(ctx, "_HID", "ACPI0007"); + acpigen_write_name_integer(ctx, "_UID", cpuindex); + acpigen_pop_len(ctx); /* Device */ +} + void acpigen_write_processor_package(struct acpi_ctx *ctx, const char *const name, const uint first_core,
Add support for the generic XHCI driver that contains no SoC specific code. It can be used on platforms that simply work out of the box, like on emulated platforms.
TEST: Booted on QEMU sbsa machine using the generic xhci driver.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Marek Vasut marex@denx.de --- Changelog v3: - Drop weak board_xhci_enable() Changelog v4: - Use dev_dbg() instead of debug() Changelog v6: - Update header order --- drivers/usb/host/Kconfig | 8 ++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-generic.c | 75 +++++++++++++++++++++++++++++++++ 3 files changed, 84 insertions(+) create mode 100644 drivers/usb/host/xhci-generic.c
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 6e10b629a3..bb5893d56d 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -68,6 +68,14 @@ config USB_XHCI_MVEBU SoCs, which includes Armada8K, Armada3700 and other Armada family SoCs.
+config USB_XHCI_GENERIC + bool "Generic SoC USB 3.0 support" + depends on OF_CONTROL + default n + help + Choose this option to add support for USB 3.0 driver for SoCs + that do not need platform specific code, like on emulated targets. + config USB_XHCI_OCTEON bool "Support for Marvell Octeon family on-chip xHCI USB controller" depends on ARCH_OCTEON diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 8dad36f936..9e880195ec 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -50,6 +50,7 @@ obj-$(CONFIG_USB_XHCI_EXYNOS) += xhci-exynos5.o obj-$(CONFIG_USB_XHCI_FSL) += xhci-fsl.o obj-$(CONFIG_USB_XHCI_MTK) += xhci-mtk.o obj-$(CONFIG_USB_XHCI_MVEBU) += xhci-mvebu.o +obj-$(CONFIG_USB_XHCI_GENERIC) += xhci-generic.o obj-$(CONFIG_USB_XHCI_OMAP) += xhci-omap.o obj-$(CONFIG_USB_XHCI_PCI) += xhci-pci.o obj-$(CONFIG_USB_XHCI_RCAR) += xhci-rcar.o diff --git a/drivers/usb/host/xhci-generic.c b/drivers/usb/host/xhci-generic.c new file mode 100644 index 0000000000..355d488317 --- /dev/null +++ b/drivers/usb/host/xhci-generic.c @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2024 9elements GmbH + * + * GENERIC USB HOST xHCI Controller + */ +#include <dm.h> +#include <fdtdec.h> +#include <log.h> +#include <usb.h> +#include <asm/io.h> +#include <dm/device_compat.h> +#include <usb/xhci.h> + +struct generic_xhci_plat { + fdt_addr_t hcd_base; +}; + +/** + * Contains pointers to register base addresses + * for the usb controller. + */ +struct generic_xhci { + struct xhci_ctrl ctrl; /* Needs to come first in this struct! */ + struct usb_plat usb_plat; + struct xhci_hccr *hcd; +}; + +static int xhci_usb_probe(struct udevice *dev) +{ + struct generic_xhci_plat *plat = dev_get_plat(dev); + struct generic_xhci *ctx = dev_get_priv(dev); + struct xhci_hcor *hcor; + int len; + + ctx->hcd = (struct xhci_hccr *)phys_to_virt(plat->hcd_base); + len = HC_LENGTH(xhci_readl(&ctx->hcd->cr_capbase)); + hcor = (struct xhci_hcor *)((uintptr_t)ctx->hcd + len); + + return xhci_register(dev, ctx->hcd, hcor); +} + +static int xhci_usb_of_to_plat(struct udevice *dev) +{ + struct generic_xhci_plat *plat = dev_get_plat(dev); + + /* + * Get the base address for XHCI controller from the device node + */ + plat->hcd_base = dev_read_addr(dev); + if (plat->hcd_base == FDT_ADDR_T_NONE) { + dev_dbg(dev, "Can't get the XHCI register base address\n"); + return -ENXIO; + } + + return 0; +} + +static const struct udevice_id xhci_usb_ids[] = { + { .compatible = "generic-xhci" }, + { } +}; + +U_BOOT_DRIVER(usb_xhci) = { + .name = "xhci_generic", + .id = UCLASS_USB, + .of_match = xhci_usb_ids, + .of_to_plat = xhci_usb_of_to_plat, + .probe = xhci_usb_probe, + .remove = xhci_deregister, + .ops = &xhci_usb_ops, + .plat_auto = sizeof(struct generic_xhci_plat), + .priv_auto = sizeof(struct generic_xhci), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
Rename 'ahci_mvebu' to 'ahci_generic' and select it by default. The AHCI driver contains no SoC specific code and only expects the base address to be passed, thus rename it to ahci_generic and add the DT compatible string "generic-ahci".
Update existing defconfigs to use the new Kconfig name as well.
TEST: Booted on QEMU sbsa using the generic-ahci node.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Stefan Roese sr@denx.de --- MAINTAINERS | 2 +- configs/clearfog_defconfig | 2 +- configs/clearfog_gt_8k_defconfig | 2 +- configs/clearfog_sata_defconfig | 2 +- configs/clearfog_spi_defconfig | 2 +- configs/db-88f6820-gp_defconfig | 2 +- configs/ds116_defconfig | 2 +- configs/helios4_defconfig | 2 +- configs/mvebu_crb_cn9130_defconfig | 2 +- configs/mvebu_db-88f3720_defconfig | 2 +- configs/mvebu_db_armada8k_defconfig | 2 +- configs/mvebu_db_cn9130_defconfig | 2 +- configs/mvebu_espressobin-88f3720_defconfig | 2 +- .../mvebu_espressobin_ultra-88f3720_defconfig | 2 +- configs/mvebu_mcbin-88f8040_defconfig | 2 +- configs/mvebu_puzzle-m801-88f8040_defconfig | 2 +- configs/n2350_defconfig | 2 +- configs/octeon_nic23_defconfig | 2 +- configs/turris_omnia_defconfig | 2 +- drivers/ata/Kconfig | 12 +++++++----- drivers/ata/Makefile | 2 +- drivers/ata/{ahci_mvebu.c => ahci_generic.c} | 17 +++++++++-------- 22 files changed, 36 insertions(+), 33 deletions(-) rename drivers/ata/{ahci_mvebu.c => ahci_generic.c} (71%)
diff --git a/MAINTAINERS b/MAINTAINERS index 7aefda93d0..7fbc87b93f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -356,7 +356,7 @@ S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-marvell.git F: arch/arm/mach-kirkwood/ F: arch/arm/mach-mvebu/ -F: drivers/ata/ahci_mvebu.c +F: drivers/ata/ahci_generic.c F: drivers/clk/mvebu/ F: drivers/ddr/marvell/ F: drivers/gpio/mvebu_gpio.c diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 62dbf2aa48..9cb4753685 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -52,7 +52,7 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/clearfog_gt_8k_defconfig b/configs/clearfog_gt_8k_defconfig index df7e04a75b..66eb5e2407 100644 --- a/configs/clearfog_gt_8k_defconfig +++ b/configs/clearfog_gt_8k_defconfig @@ -46,7 +46,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y diff --git a/configs/clearfog_sata_defconfig b/configs/clearfog_sata_defconfig index 41382f995d..b1e1fc75dd 100644 --- a/configs/clearfog_sata_defconfig +++ b/configs/clearfog_sata_defconfig @@ -52,7 +52,7 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/clearfog_spi_defconfig b/configs/clearfog_spi_defconfig index f345b12e6c..64f862d298 100644 --- a/configs/clearfog_spi_defconfig +++ b/configs/clearfog_spi_defconfig @@ -52,7 +52,7 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index ee8cb8ae66..16417a4e12 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -58,7 +58,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_SPL_OF_TRANSLATE=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/ds116_defconfig b/configs/ds116_defconfig index 1173e3a0f6..d687be2d5b 100644 --- a/configs/ds116_defconfig +++ b/configs/ds116_defconfig @@ -65,7 +65,7 @@ CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 29b6230e90..c0ae1de264 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -52,7 +52,7 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mvebu_crb_cn9130_defconfig b/configs/mvebu_crb_cn9130_defconfig index 4d5f575b03..d253fe88d6 100644 --- a/configs/mvebu_crb_cn9130_defconfig +++ b/configs/mvebu_crb_cn9130_defconfig @@ -46,7 +46,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index b955abb31e..1e9332c845 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -43,7 +43,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index 6913796c01..a9b76a3843 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -42,7 +42,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y diff --git a/configs/mvebu_db_cn9130_defconfig b/configs/mvebu_db_cn9130_defconfig index 9133e25b24..2c345f7436 100644 --- a/configs/mvebu_db_cn9130_defconfig +++ b/configs/mvebu_db_cn9130_defconfig @@ -47,7 +47,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_GPIO_LOOKUP_LABEL=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 7ecf5ab0d6..c7015c9b13 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -54,7 +54,7 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_AHCI_PCI=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y diff --git a/configs/mvebu_espressobin_ultra-88f3720_defconfig b/configs/mvebu_espressobin_ultra-88f3720_defconfig index 974b6df165..0a4329d786 100644 --- a/configs/mvebu_espressobin_ultra-88f3720_defconfig +++ b/configs/mvebu_espressobin_ultra-88f3720_defconfig @@ -53,7 +53,7 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_AHCI_PCI=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index eef612a261..8bb26bd3d6 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -46,7 +46,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y diff --git a/configs/mvebu_puzzle-m801-88f8040_defconfig b/configs/mvebu_puzzle-m801-88f8040_defconfig index b00e92908b..db7881c3fc 100644 --- a/configs/mvebu_puzzle-m801-88f8040_defconfig +++ b/configs/mvebu_puzzle-m801-88f8040_defconfig @@ -49,7 +49,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_PCA953X=y diff --git a/configs/n2350_defconfig b/configs/n2350_defconfig index e7d7deabfe..b6fc333906 100644 --- a/configs/n2350_defconfig +++ b/configs/n2350_defconfig @@ -65,7 +65,7 @@ CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y diff --git a/configs/octeon_nic23_defconfig b/configs/octeon_nic23_defconfig index 5a8db5a087..d19d459555 100644 --- a/configs/octeon_nic23_defconfig +++ b/configs/octeon_nic23_defconfig @@ -46,7 +46,7 @@ CONFIG_EFI_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_TFTP_TSIZE=y CONFIG_SATA=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_LBA48=y CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 93f0bc53f9..85c71f2eef 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -90,7 +90,7 @@ CONFIG_NET_RETRY_COUNT=50 CONFIG_NETCONSOLE=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_AHCI_PCI=y -CONFIG_AHCI_MVEBU=y +CONFIG_AHCI_GENERIC=y CONFIG_DM_PCA953X=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MV=y diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 6cca561f97..4fbb63a148 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -78,14 +78,16 @@ config MTK_AHCI Enable this driver to support Sata devices through Mediatek AHCI controller (e.g. MT7622).
-config AHCI_MVEBU - bool "Marvell EBU AHCI SATA support" - depends on ARCH_MVEBU || ARCH_OCTEON +config AHCI_GENERIC + bool "Generic AHCI SATA support" + depends on OF_CONTROL select SCSI_AHCI select SCSI help - This option enables support for the Marvell EBU SoC's - onboard AHCI SATA. + This option enables support for generic onboard AHCI SATA controller + that do not need platform specific quirks, like emulated devices, + Marvell EBU SoC's onboard AHCI SATA controllers or Cavium's Octeon + 7130 AHCI controllers.
If unsure, say N.
diff --git a/drivers/ata/Makefile b/drivers/ata/Makefile index af6f0bf278..507bf84c14 100644 --- a/drivers/ata/Makefile +++ b/drivers/ata/Makefile @@ -14,6 +14,6 @@ obj-$(CONFIG_SATA) += sata.o sata_bootdev.o obj-$(CONFIG_SATA_CEVA) += sata_ceva.o obj-$(CONFIG_SATA_MV) += sata_mv.o obj-$(CONFIG_SATA_SIL) += sata_sil.o -obj-$(CONFIG_AHCI_MVEBU) += ahci_mvebu.o +obj-$(CONFIG_AHCI_GENERIC) += ahci_generic.o obj-$(CONFIG_SUNXI_AHCI) += ahci_sunxi.o obj-$(CONFIG_MTK_AHCI) += mtk_ahci.o diff --git a/drivers/ata/ahci_mvebu.c b/drivers/ata/ahci_generic.c similarity index 71% rename from drivers/ata/ahci_mvebu.c rename to drivers/ata/ahci_generic.c index f6e2d6bee4..6e5a6cbafd 100644 --- a/drivers/ata/ahci_mvebu.c +++ b/drivers/ata/ahci_generic.c @@ -16,7 +16,7 @@ __weak int board_ahci_enable(void) return 0; }
-static int mvebu_ahci_bind(struct udevice *dev) +static int generic_ahci_bind(struct udevice *dev) { struct udevice *scsi_dev; int ret; @@ -30,7 +30,7 @@ static int mvebu_ahci_bind(struct udevice *dev) return 0; }
-static int mvebu_ahci_probe(struct udevice *dev) +static int generic_ahci_probe(struct udevice *dev) { /* * Board specific SATA / AHCI enable code, e.g. enable the @@ -43,18 +43,19 @@ static int mvebu_ahci_probe(struct udevice *dev) return 0; }
-static const struct udevice_id mvebu_ahci_ids[] = { +static const struct udevice_id generic_ahci_ids[] = { { .compatible = "marvell,armada-380-ahci" }, { .compatible = "marvell,armada-3700-ahci" }, { .compatible = "marvell,armada-8k-ahci" }, { .compatible = "cavium,octeon-7130-ahci" }, + { .compatible = "generic-ahci" }, { } };
-U_BOOT_DRIVER(ahci_mvebu_drv) = { - .name = "ahci_mvebu", +U_BOOT_DRIVER(ahci_generic_drv) = { + .name = "ahci_generic", .id = UCLASS_AHCI, - .of_match = mvebu_ahci_ids, - .bind = mvebu_ahci_bind, - .probe = mvebu_ahci_probe, + .of_match = generic_ahci_ids, + .bind = generic_ahci_bind, + .probe = generic_ahci_probe, };
Add a generic driver that binds to armv8 CPU nodes. The generic driver allows - to enumerate CPUs present in a system, even when no other driver binds it - generates ACPI SSDT code for each CPU - Fill the ACPI MADT table (implemented in a follow up patch)
The newly introduced code could also be reused on other CPU drivers that are compatible with armv8.
TEST: Booted on QEMU sbsa and verify the driver binds to CPU nodes. Confirmed with FWTS that all ACPI processor devices are present.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org --- Changelog v4: - Export armv8_cpu_fill_ssdt to use it in other CPU drivers Changelog v6: - Update header order --- drivers/cpu/Kconfig | 6 ++++ drivers/cpu/Makefile | 2 ++ drivers/cpu/armv8_cpu.c | 73 +++++++++++++++++++++++++++++++++++++++++ drivers/cpu/armv8_cpu.h | 21 ++++++++++++ 4 files changed, 102 insertions(+) create mode 100644 drivers/cpu/armv8_cpu.c create mode 100644 drivers/cpu/armv8_cpu.h
diff --git a/drivers/cpu/Kconfig b/drivers/cpu/Kconfig index 5c06cd9f60..9c0df331d7 100644 --- a/drivers/cpu/Kconfig +++ b/drivers/cpu/Kconfig @@ -26,6 +26,12 @@ config CPU_RISCV help Support CPU cores for RISC-V architecture.
+config CPU_ARMV8 + bool "Enable generic ARMv8 CPU driver" + depends on CPU && ARM64 + help + Support CPU cores for armv8 architecture. + config CPU_MICROBLAZE bool "Enable Microblaze CPU driver" depends on CPU && MICROBLAZE diff --git a/drivers/cpu/Makefile b/drivers/cpu/Makefile index bc75d9b974..773395693a 100644 --- a/drivers/cpu/Makefile +++ b/drivers/cpu/Makefile @@ -6,10 +6,12 @@
obj-$(CONFIG_CPU) += cpu-uclass.o
+ obj-$(CONFIG_ARCH_BMIPS) += bmips_cpu.o obj-$(CONFIG_ARCH_IMX8) += imx8_cpu.o obj-$(CONFIG_ARCH_AT91) += at91_cpu.o obj-$(CONFIG_ARCH_MEDIATEK) += mtk_cpu.o +obj-$(CONFIG_CPU_ARMV8) += armv8_cpu.o obj-$(CONFIG_CPU_IMX) += imx8_cpu.o obj-$(CONFIG_CPU_MPC83XX) += mpc83xx_cpu.o obj-$(CONFIG_CPU_RISCV) += riscv_cpu.o diff --git a/drivers/cpu/armv8_cpu.c b/drivers/cpu/armv8_cpu.c new file mode 100644 index 0000000000..19f072be43 --- /dev/null +++ b/drivers/cpu/armv8_cpu.c @@ -0,0 +1,73 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 9elements GmbH + */ +#include <cpu.h> +#include <dm.h> +#include <acpi/acpigen.h> +#include <asm/armv8/cpu.h> +#include <dm/acpi.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <linux/printk.h> +#include <linux/sizes.h> + +static int armv8_cpu_get_desc(const struct udevice *dev, char *buf, int size) +{ + int cpuid; + + cpuid = (read_midr() & MIDR_PARTNUM_MASK) >> MIDR_PARTNUM_SHIFT; + + snprintf(buf, size, "CPU MIDR %04x", cpuid); + + return 0; +} + +static int armv8_cpu_get_info(const struct udevice *dev, + struct cpu_info *info) +{ + info->cpu_freq = 0; + info->features = BIT(CPU_FEAT_L1_CACHE) | BIT(CPU_FEAT_MMU); + + return 0; +} + +static int armv8_cpu_get_count(const struct udevice *dev) +{ + return uclass_id_count(UCLASS_CPU); +} + +#ifdef CONFIG_ACPIGEN +int armv8_cpu_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + uint core_id = dev_seq(dev); + + acpigen_write_processor_device(ctx, core_id); + + return 0; +} + +struct acpi_ops armv8_cpu_acpi_ops = { + .fill_ssdt = armv8_cpu_fill_ssdt, +}; +#endif + +static const struct cpu_ops cpu_ops = { + .get_count = armv8_cpu_get_count, + .get_desc = armv8_cpu_get_desc, + .get_info = armv8_cpu_get_info, +}; + +static const struct udevice_id cpu_ids[] = { + { .compatible = "arm,armv8" }, + {} +}; + +U_BOOT_DRIVER(arm_cpu) = { + .name = "arm-cpu", + .id = UCLASS_CPU, + .of_match = cpu_ids, + .ops = &cpu_ops, + .flags = DM_FLAG_PRE_RELOC, + ACPI_OPS_PTR(&armv8_cpu_acpi_ops) +}; diff --git a/drivers/cpu/armv8_cpu.h b/drivers/cpu/armv8_cpu.h new file mode 100644 index 0000000000..2c4b0252cf --- /dev/null +++ b/drivers/cpu/armv8_cpu.h @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 9elements GmbH + */ +#include <dm/acpi.h> +#include <dm/device.h> + +#ifndef _ARMV8_CPU_H_ +#define _ARMV8_CPU_H_ + +/** + * armv8_cpu_fill_ssdt() - Fill the SSDT + * Parses the FDT and writes the SSDT nodes. + * + * @dev: cpu device to generate ACPI tables for + * @ctx: ACPI context pointer + * @return: 0 if OK, or a negative error code. + */ +int armv8_cpu_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx); + +#endif \ No newline at end of file
The code accesses the gic-v3 node, but not the gic-v3-its node, thus rename the objects to clarify which node it operates on.
The following commit will make use of the gic-v3-its node for real.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/lib/gic-v3-its.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/lib/gic-v3-its.c b/arch/arm/lib/gic-v3-its.c index 2cc0a32f9d..22fa46a341 100644 --- a/arch/arm/lib/gic-v3-its.c +++ b/arch/arm/lib/gic-v3-its.c @@ -35,10 +35,10 @@ static int gic_v3_its_get_gic_addr(struct gic_v3_its_priv *priv) int ret;
ret = uclass_get_device_by_driver(UCLASS_IRQ, - DM_DRIVER_GET(arm_gic_v3_its), &dev); + DM_DRIVER_GET(arm_gic_v3), &dev); if (ret) { pr_err("%s: failed to get %s irq device\n", __func__, - DM_DRIVER_GET(arm_gic_v3_its)->name); + DM_DRIVER_GET(arm_gic_v3)->name); return ret; }
@@ -158,13 +158,13 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) return 0; }
-static const struct udevice_id gic_v3_its_ids[] = { +static const struct udevice_id gic_v3_ids[] = { { .compatible = "arm,gic-v3" }, {} };
-U_BOOT_DRIVER(arm_gic_v3_its) = { +U_BOOT_DRIVER(arm_gic_v3) = { .name = "gic-v3", .id = UCLASS_IRQ, - .of_match = gic_v3_its_ids, + .of_match = gic_v3_ids, };
Translate IRQs by implementing of_xlate() as required by irq_get_by_index() to parse interrupt properties.
Map DT interrupts to ARM GIC interrupts as follows:
- Interrupt numbers ID32-ID1019 are used for SPIs - ID0-ID15 are used for SGIs - ID16-ID31 are used for PPIs
TEST: Booted on qemu sbsa-ref that has a GICV3.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- Changelog v9: - Require at least 3 interrupt-cells - Map SPI interrupts to ID32+ - Map PPI interrupts to ID16+ --- arch/arm/lib/gic-v3-its.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/arch/arm/lib/gic-v3-its.c b/arch/arm/lib/gic-v3-its.c index 22fa46a341..58f8bf864f 100644 --- a/arch/arm/lib/gic-v3-its.c +++ b/arch/arm/lib/gic-v3-its.c @@ -4,9 +4,11 @@ */ #include <cpu_func.h> #include <dm.h> +#include <irq.h> #include <asm/gic.h> #include <asm/gic-v3.h> #include <asm/io.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> #include <linux/bitops.h> #include <linux/printk.h> #include <linux/sizes.h> @@ -163,8 +165,30 @@ static const struct udevice_id gic_v3_ids[] = { {} };
+static int arm_gic_v3_of_xlate(struct irq *irq, struct ofnode_phandle_args *args) +{ + if (args->args_count < 3) { + log_debug("Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + if (args->args[0] == GIC_SPI) + irq->id = args->args[1] + 32; + else + irq->id = args->args[1] + 16; + + irq->flags = args->args[2]; + + return 0; +} + +static const struct irq_ops arm_gic_v3_ops = { + .of_xlate = arm_gic_v3_of_xlate, +}; + U_BOOT_DRIVER(arm_gic_v3) = { .name = "gic-v3", .id = UCLASS_IRQ, .of_match = gic_v3_ids, + .ops = &arm_gic_v3_ops, };
On Tue, Oct 15, 2024 at 11:15 PM Patrick Rudolph patrick.rudolph@9elements.com wrote:
Reviewed-by: Moritz Fischer moritzf@google.com
Changelog v9:
return -EINVAL;
else
2.46.2
Add a generic GICV2 driver that: - parses the DT and generates the ACPI MADT subtables - implement of_xlate() and allows irq_get_by_index() to return the correct interrupt mappings
TEST: Booted on QEMU raspb4 using GICV2 driver model generated MADT.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- Changelog v6: - Update header order Changelog v9: - Map SPI interrupts to ID32+ - Map PPI interrupts to ID16+ --- arch/arm/Kconfig | 7 ++++ arch/arm/lib/Makefile | 1 + arch/arm/lib/gic-v2.c | 89 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 97 insertions(+) create mode 100644 arch/arm/lib/gic-v2.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 060636e9e2..263f85b0d0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -113,6 +113,13 @@ config GICV2 config GICV3 bool
+config DRIVER_GICV2 + bool "ARM GICV2 driver" + select IRQ + help + ARM GICV2 driver. + Basic support for parsing the GICV2 node and generate ACPI tables. + config GIC_V3_ITS bool "ARM GICV3 ITS" select IRQ diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index a7efed6771..cf76051450 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -68,6 +68,7 @@ obj-$(CONFIG_FSL_LAYERSCAPE) += ccn504.o ifneq ($(CONFIG_GICV2)$(CONFIG_GICV3),) obj-y += gic_64.o endif +obj-$(CONFIG_DRIVER_GICV2) += gic-v2.o obj-$(CONFIG_GIC_V3_ITS) += gic-v3-its.o obj-y += interrupts_64.o else diff --git a/arch/arm/lib/gic-v2.c b/arch/arm/lib/gic-v2.c new file mode 100644 index 0000000000..b70434a45d --- /dev/null +++ b/arch/arm/lib/gic-v2.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Broadcom. + */ +#include <dm.h> +#include <irq.h> +#include <asm/gic.h> +#include <asm/acpi_table.h> +#include <cpu_func.h> +#include <dm/acpi.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +#ifdef CONFIG_ACPIGEN +/** + * acpi_gicv2_fill_madt() - Fill out the body of the MADT + * + * Write GICD and GICR tables based on collected devicetree data. + * + * @dev: Device to write ACPI tables for + * @ctx: ACPI context to write MADT sub-tables to + * Return: 0 if OK + */ +static int acpi_gicv2_fill_madt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + struct acpi_madt_gicd *gicd; + fdt_addr_t addr; + + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) { + pr_err("%s: failed to get GICD address\n", __func__); + return -EINVAL; + } + + gicd = ctx->current; + acpi_write_madt_gicd(gicd, dev_seq(dev), addr, 2); + acpi_inc(ctx, gicd->length); + + return 0; +} + +static struct acpi_ops gic_v2_acpi_ops = { + .fill_madt = acpi_gicv2_fill_madt, +}; +#endif + +static const struct udevice_id gic_v2_ids[] = { + { .compatible = "arm,arm11mp-gic" }, + { .compatible = "arm,cortex-a15-gic" }, + { .compatible = "arm,cortex-a7-gic" }, + { .compatible = "arm,cortex-a5-gic" }, + { .compatible = "arm,cortex-a9-gic" }, + { .compatible = "arm,eb11mp-gic" }, + { .compatible = "arm,gic-400" }, + { .compatible = "arm,pl390" }, + { .compatible = "arm,tc11mp-gic" }, + { .compatible = "qcom,msm-8660-qgic" }, + { .compatible = "qcom,msm-qgic2" }, + {} +}; + +static int arm_gic_v2_of_xlate(struct irq *irq, struct ofnode_phandle_args *args) +{ + if (args->args_count != 3) { + log_debug("Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + /* ARM Generic Interrupt Controller v1 and v2 */ + if (args->args[0] == GIC_SPI) + irq->id = args->args[1] + 32; + else + irq->id = args->args[1] + 16; + + irq->flags = args->args[2]; + + return 0; +} + +static const struct irq_ops arm_gic_v2_ops = { + .of_xlate = arm_gic_v2_of_xlate, +}; + +U_BOOT_DRIVER(arm_gic_v2) = { + .name = "gic-v2", + .id = UCLASS_IRQ, + .of_match = gic_v2_ids, + .ops = &arm_gic_v2_ops, + ACPI_OPS_PTR(&gic_v2_acpi_ops) +};
On Wed, 16 Oct 2024 at 00:16, Patrick Rudolph patrick.rudolph@9elements.com wrote:
Changelog v6:
Changelog v9:
Support reading the "interrupts" property from the devicetree in case the "interrupts-extended" property isn't found. As the "interrupts" property is commonly used, this allows to parse all existing FDT and makes irq_get_by_index() more useful.
The "interrupts" property doesn't contain a phandle as "interrupts-extended" does, so implement a new method to locate the interrupt-parent called irq_get_interrupt_parent().
TEST: Read the interrupts from the GIC node for ACPI MADT generation.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- Changelog v9: - Read interrupt-cells from interrupt parent --- arch/sandbox/dts/test.dts | 3 ++ drivers/misc/irq-uclass.c | 66 ++++++++++++++++++++++++++++++++++++++- include/irq.h | 14 +++++++++ test/dm/irq.c | 15 +++++++++ 4 files changed, 97 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 8412506c17..9599a8db9c 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -522,6 +522,9 @@ };
f-test { + #interrupt-cells = <2>; + interrupt-parent = <&irq>; + interrupts = <4 0>; compatible = "denx,u-boot-fdt-test"; };
diff --git a/drivers/misc/irq-uclass.c b/drivers/misc/irq-uclass.c index 79eb7c200d..ac778593c9 100644 --- a/drivers/misc/irq-uclass.c +++ b/drivers/misc/irq-uclass.c @@ -62,6 +62,40 @@ int irq_read_and_clear(struct irq *irq) return ops->read_and_clear(irq); }
+int irq_get_interrupt_parent(const struct udevice *dev, + struct udevice **interrupt_parent) +{ + struct ofnode_phandle_args phandle_args; + struct udevice *irq = NULL; + ofnode node; + int ret; + + if (!dev || !interrupt_parent) + return -EINVAL; + + *interrupt_parent = NULL; + + node = dev_ofnode(dev); + if (!ofnode_valid(node)) + return -EINVAL; + + while (ofnode_valid(node)) { + ret = ofnode_parse_phandle_with_args(node, "interrupt-parent", + NULL, 0, 0, &phandle_args); + if (!ret && !device_get_global_by_ofnode(phandle_args.node, &irq)) + break; + node = ofnode_get_parent(node); + } + + if (!irq) { + log_err("Cannot find an interrupt parent for device %s\n", dev->name); + return -ENODEV; + } + *interrupt_parent = irq; + + return 0; +} + #if CONFIG_IS_ENABLED(OF_PLATDATA) int irq_get_by_phandle(struct udevice *dev, const struct phandle_2_arg *cells, struct irq *irq) @@ -142,10 +176,40 @@ err: int irq_get_by_index(struct udevice *dev, int index, struct irq *irq) { struct ofnode_phandle_args args; - int ret; + struct udevice *interrupt_parent; + int ret, size, i; + const __be32 *list; + u32 count;
ret = dev_read_phandle_with_args(dev, "interrupts-extended", "#interrupt-cells", 0, index, &args); + if (ret) { + list = dev_read_prop(dev, "interrupts", &size); + if (!list) + return -ENOENT; + + ret = irq_get_interrupt_parent(dev, &interrupt_parent); + if (ret) + return -ENODEV; + args.node = dev_ofnode(interrupt_parent); + + if (dev_read_u32(interrupt_parent, "#interrupt-cells", &count)) { + log_err("%s: could not get #interrupt-cells for %s\n", + __func__, dev->name); + return -ENOENT; + } + + if (index * count >= size / sizeof(*list)) + return -ENOENT; + if (count > OF_MAX_PHANDLE_ARGS) + count = OF_MAX_PHANDLE_ARGS; + args.args_count = count; + for (i = 0; i < count; i++) + args.args[i] = be32_to_cpup(&list[index * count + i]); + + return irq_get_by_index_tail(ret, dev_ofnode(dev), &args, + "interrupts", index, irq); + }
return irq_get_by_index_tail(ret, dev_ofnode(dev), &args, "interrupts-extended", index > 0, irq); diff --git a/include/irq.h b/include/irq.h index 5638c10128..0fbc1a5f48 100644 --- a/include/irq.h +++ b/include/irq.h @@ -200,6 +200,20 @@ int irq_restore_polarities(struct udevice *dev); */ int irq_read_and_clear(struct irq *irq);
+/** + * irq_get_interrupt_parent() - returns the interrupt parent + * + * Walks the devicetree and returns the interrupt parent's ofnode + * for the specified device. + * + * @dev: device + * @interrupt_parent: The interrupt parent's ofnode' + * Return: 0 success, or error value + * + */ +int irq_get_interrupt_parent(const struct udevice *dev, + struct udevice **interrupt_parent); + struct phandle_2_arg; /** * irq_get_by_phandle() - Get an irq by its phandle information (of-platadata) diff --git a/test/dm/irq.c b/test/dm/irq.c index 836f2d82e7..ca3e188065 100644 --- a/test/dm/irq.c +++ b/test/dm/irq.c @@ -76,6 +76,21 @@ static int dm_test_request(struct unit_test_state *uts) } DM_TEST(dm_test_request, UTF_SCAN_PDATA | UTF_SCAN_FDT);
+/* Test of irq_get_by_index() */ +static int dm_test_irq_get_by_index(struct unit_test_state *uts) +{ + struct udevice *dev; + struct irq irq; + + ut_assertok(uclass_get_device_by_name(UCLASS_TEST_FDT, "f-test", + &dev)); + ut_assertok(irq_get_by_index(dev, 0, &irq)); + ut_asserteq(4, irq.id); + + return 0; +} +DM_TEST(dm_test_irq_get_by_index, UTF_SCAN_PDATA | UTF_SCAN_FDT); + /* Test of irq_get_acpi() */ static int dm_test_irq_get_acpi(struct unit_test_state *uts) {
On Tue, Oct 15, 2024 at 11:16 PM Patrick Rudolph patrick.rudolph@9elements.com wrote:
Changelog v9:
f-test {
ofnode node;
int ret;
return -EINVAL;
return -EINVAL;
break;
if (!irq) {
return -ENODEV;
int ret;
int ret, size, i;
const __be32 *list;
u32 count; ret = dev_read_phandle_with_args(dev, "interrupts-extended", "#interrupt-cells", 0, index, &args);
if (ret) {
if (!list)
return -ENOENT;
if (ret)
return -ENODEV;
return -ENOENT;
return -ENOENT;
} return irq_get_by_index_tail(ret, dev_ofnode(dev), &args, "interrupts-extended", index > 0, irq);
- irq_get_interrupt_parent() - returns the interrupt parent
- Walks the devicetree and returns the interrupt parent's ofnode
- for the specified device.
- @dev: device
- @interrupt_parent: The interrupt parent's ofnode'
- Return: 0 success, or error value
- irq_get_by_phandle() - Get an irq by its phandle information (of-platadata)
struct irq irq;
&dev));
/* Test of irq_get_acpi() */ static int dm_test_irq_get_acpi(struct unit_test_state *uts) { -- 2.46.2
Fill the MADT table in the GIC driver and armv8 CPU driver to drop SoC specific code. While the GIC only needs devicetree data, the CPU driver needs additional information stored in the cpu_plat struct.
While on it update the only board making use of the existing drivers and writing ACPI MADT in mainboard code.
TEST: Booted on QEMU sbsa-ref using GICV3 driver model generated MADT. Booted on QEMU raspb4 using GICV2 driver model generated MADT.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org --- Changelog v4: - Read everything from the DT - Export armv8_cpu_fill_madt() to use it in other CPU drivers - Depend on IRQ Changelog v6: - Update header order --- arch/arm/lib/gic-v3-its.c | 89 ++++++++++++++++++++++++++++++++++++++- drivers/cpu/Kconfig | 1 + drivers/cpu/armv8_cpu.c | 80 ++++++++++++++++++++++++++++++++++- drivers/cpu/armv8_cpu.h | 10 +++++ 4 files changed, 178 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/gic-v3-its.c b/arch/arm/lib/gic-v3-its.c index 58f8bf864f..51cc239776 100644 --- a/arch/arm/lib/gic-v3-its.c +++ b/arch/arm/lib/gic-v3-its.c @@ -5,9 +5,11 @@ #include <cpu_func.h> #include <dm.h> #include <irq.h> +#include <asm/acpi_table.h> #include <asm/gic.h> #include <asm/gic-v3.h> #include <asm/io.h> +#include <dm/acpi.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <linux/bitops.h> #include <linux/printk.h> @@ -28,12 +30,14 @@ static u32 lpi_id_bits; struct gic_v3_its_priv { ulong gicd_base; ulong gicr_base; + ulong gicr_length; };
static int gic_v3_its_get_gic_addr(struct gic_v3_its_priv *priv) { struct udevice *dev; fdt_addr_t addr; + fdt_size_t size; int ret;
ret = uclass_get_device_by_driver(UCLASS_IRQ, @@ -51,12 +55,13 @@ static int gic_v3_its_get_gic_addr(struct gic_v3_its_priv *priv) } priv->gicd_base = addr;
- addr = dev_read_addr_index(dev, 1); + addr = dev_read_addr_size_index(dev, 1, &size); if (addr == FDT_ADDR_T_NONE) { pr_err("%s: failed to get GICR address\n", __func__); return -EINVAL; } priv->gicr_base = addr; + priv->gicr_length = size;
return 0; } @@ -160,6 +165,42 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) return 0; }
+#ifdef CONFIG_ACPIGEN +/** + * acpi_gicv3_fill_madt() - Fill out the body of the MADT + * + * Write GICD and GICR tables based on collected devicetree data. + * + * @dev: Device to write ACPI tables for + * @ctx: ACPI context to write MADT sub-tables to + * Return: 0 if OK + */ +static int acpi_gicv3_fill_madt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + struct acpi_madt_gicd *gicd; + struct acpi_madt_gicr *gicr; + + struct gic_v3_its_priv priv; + + if (gic_v3_its_get_gic_addr(&priv)) + return -EINVAL; + + gicd = ctx->current; + acpi_write_madt_gicd(gicd, dev_seq(dev), priv.gicd_base, 3); + acpi_inc(ctx, gicd->length); + + gicr = ctx->current; + acpi_write_madt_gicr(gicr, priv.gicr_base, priv.gicr_length); + acpi_inc(ctx, gicr->length); + + return 0; +} + +struct acpi_ops gic_v3_acpi_ops = { + .fill_madt = acpi_gicv3_fill_madt, +}; +#endif + static const struct udevice_id gic_v3_ids[] = { { .compatible = "arm,gic-v3" }, {} @@ -191,4 +232,50 @@ U_BOOT_DRIVER(arm_gic_v3) = { .id = UCLASS_IRQ, .of_match = gic_v3_ids, .ops = &arm_gic_v3_ops, + ACPI_OPS_PTR(&gic_v3_acpi_ops) +}; + +#ifdef CONFIG_ACPIGEN +/** + * acpi_gic_its_fill_madt() - Fill out the body of the MADT + * + * Write ITS tables based on collected devicetree data. + * + * @dev: Device to write ACPI tables for + * @ctx: ACPI context to write MADT sub-tables to + * Return: 0 if OK + */ +static int acpi_gic_its_fill_madt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + struct acpi_madt_its *its; + fdt_addr_t addr; + + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) { + pr_err("%s: failed to get GIC ITS address\n", __func__); + return -EINVAL; + } + + its = ctx->current; + acpi_write_madt_its(its, dev_seq(dev), addr); + acpi_inc(ctx, its->length); + + return 0; +} + +struct acpi_ops gic_v3_its_acpi_ops = { + .fill_madt = acpi_gic_its_fill_madt, +}; +#endif + +static const struct udevice_id gic_v3_its_ids[] = { + { .compatible = "arm,gic-v3-its" }, + {} +}; + +U_BOOT_DRIVER(arm_gic_v3_its) = { + .name = "gic-v3-its", + .id = UCLASS_IRQ, + .of_match = gic_v3_its_ids, + ACPI_OPS_PTR(&gic_v3_its_acpi_ops) }; diff --git a/drivers/cpu/Kconfig b/drivers/cpu/Kconfig index 9c0df331d7..4cc3679c00 100644 --- a/drivers/cpu/Kconfig +++ b/drivers/cpu/Kconfig @@ -29,6 +29,7 @@ config CPU_RISCV config CPU_ARMV8 bool "Enable generic ARMv8 CPU driver" depends on CPU && ARM64 + select IRQ help Support CPU cores for armv8 architecture.
diff --git a/drivers/cpu/armv8_cpu.c b/drivers/cpu/armv8_cpu.c index 19f072be43..4eedfe5e2c 100644 --- a/drivers/cpu/armv8_cpu.c +++ b/drivers/cpu/armv8_cpu.c @@ -4,10 +4,11 @@ */ #include <cpu.h> #include <dm.h> +#include <irq.h> #include <acpi/acpigen.h> #include <asm/armv8/cpu.h> -#include <dm/acpi.h> #include <asm/io.h> +#include <dm/acpi.h> #include <linux/bitops.h> #include <linux/printk.h> #include <linux/sizes.h> @@ -47,8 +48,85 @@ int armv8_cpu_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) return 0; }
+int armv8_cpu_fill_madt(const struct udevice *dev, struct acpi_ctx *ctx) +{ + struct acpi_madt_gicc *gicc; + struct cpu_plat *cpu_plat; + struct udevice *gic; + u64 gicc_gicv = 0; + u64 gicc_gich = 0; + u64 gicc_gicr_base = 0; + u64 gicc_phys_base = 0; + u32 gicc_perf_gsiv = 0; + u64 gicc_mpidr; + u32 gicc_vgic_maint_irq = 0; + int addr_index; + fdt_addr_t addr; + int ret; + struct irq req_irq; + + cpu_plat = dev_get_parent_plat(dev); + if (!cpu_plat) + return 0; + + ret = irq_get_interrupt_parent(dev, &gic); + if (ret) { + log_err("%s: Failed to find interrupt parent for %s\n", + __func__, dev->name); + return -ENODEV; + } + + addr_index = 1; + + if (device_is_compatible(gic, "arm,gic-v3")) { + addr = dev_read_addr_index(gic, addr_index++); + if (addr != FDT_ADDR_T_NONE) + gicc_gicr_base = addr; + } + + addr = dev_read_addr_index(gic, addr_index++); + if (addr != FDT_ADDR_T_NONE) + gicc_phys_base = addr; + + addr = dev_read_addr_index(gic, addr_index++); + if (addr != FDT_ADDR_T_NONE) + gicc_gich = addr; + + addr = dev_read_addr_index(gic, addr_index++); + if (addr != FDT_ADDR_T_NONE) + gicc_gicv = addr; + + ret = irq_get_by_index(gic, 0, &req_irq); + if (!ret) + gicc_vgic_maint_irq = req_irq.id; + + gicc_mpidr = dev_read_u64_default(dev, "reg", 0); + if (!gicc_mpidr) + gicc_mpidr = dev_read_u32_default(dev, "reg", 0); + + /* + * gicc_vgic_maint_irq and gicc_gicv are the same for every CPU + */ + gicc = ctx->current; + acpi_write_madt_gicc(gicc, + dev_seq(dev), + gicc_perf_gsiv, /* FIXME: needs a PMU driver */ + gicc_phys_base, + gicc_gicv, + gicc_gich, + gicc_vgic_maint_irq, + gicc_gicr_base, + gicc_mpidr, + 0); /* FIXME: Not defined in DT */ + + acpi_inc(ctx, gicc->length); + + return 0; +} + struct acpi_ops armv8_cpu_acpi_ops = { .fill_ssdt = armv8_cpu_fill_ssdt, + .fill_madt = armv8_cpu_fill_madt, }; #endif
diff --git a/drivers/cpu/armv8_cpu.h b/drivers/cpu/armv8_cpu.h index 2c4b0252cf..48c705e98d 100644 --- a/drivers/cpu/armv8_cpu.h +++ b/drivers/cpu/armv8_cpu.h @@ -18,4 +18,14 @@ */ int armv8_cpu_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx);
+/** + * armv8_cpu_fill_madt() - Fill the MADT + * Parses the FDT and writes the MADT subtables. + * + * @dev: cpu device to generate ACPI tables for + * @ctx: ACPI context pointer + * @return: 0 if OK, or a negative error code. + */ +int armv8_cpu_fill_madt(const struct udevice *dev, struct acpi_ctx *ctx); + #endif \ No newline at end of file
Allow to use BLOBLIST_TABLES on arm to store ACPI or other tables.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Cc: Tom Rini trini@konsulko.com --- Changelog v9: - default to BLOBLIST_ALLOC on arm - Move default for BLOBLIST_SIZE_RELOC up --- common/Kconfig | 2 ++ lib/Kconfig | 15 +++++++++------ 2 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 957de0c5c0..9ceca8a2f5 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -1035,6 +1035,7 @@ if BLOBLIST
choice prompt "Bloblist location" + default BLOBLIST_ALLOC if ARM help Select the location of the bloblist, via various means.
@@ -1075,6 +1076,7 @@ config BLOBLIST_SIZE
config BLOBLIST_SIZE_RELOC hex "Size of bloblist after relocation" + default 0x20000 if (ARM && EFI_LOADER && GENERATE_ACPI_TABLE) default BLOBLIST_SIZE if BLOBLIST_FIXED || BLOBLIST_ALLOC default 0x0 if BLOBLIST_PASSAGE help diff --git a/lib/Kconfig b/lib/Kconfig index 1dd4f27159..2e0fc1bc8f 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -984,12 +984,15 @@ menu "System tables"
config BLOBLIST_TABLES bool "Put tables in a bloblist" - depends on X86 && BLOBLIST - help - Normally tables are placed at address 0xf0000 and can be up to 64KB - long. With this option, tables are instead placed in the bloblist - with a pointer from 0xf0000. The size can then be larger and the - tables can be placed high in memory. + depends on BLOBLIST + default y if (ARM && EFI_LOADER && GENERATE_ACPI_TABLE) + default n + help + On x86 normally tables are placed at address 0xf0000 and can be up + to 64KB long. With this option, tables are instead placed in the + bloblist with a pointer from 0xf0000. The size can then be larger + and the tables can be placed high in memory. + On other architectures the tables are always placed in high memory.
config GENERATE_SMBIOS_TABLE bool "Generate an SMBIOS (System Management BIOS) table"
Hi Patrick,
Changelog v9:
This is fine, but please disable it for snow since it needs the FIXED option for now.
Hi Simon, On Fri, Oct 18, 2024 at 1:18 AM Simon Glass sjg@chromium.org wrote:
Hi Patrick,
Changelog v9:
I cannot follow. What needs the FIXED option and what to disable? I run this patch on the CI and test_py_sandbox tests are still working.
Hi Patrick,
On Mon, 21 Oct 2024 at 10:26, Patrick Rudolph patrick.rudolph@9elements.com wrote:
Hi Patrick,
Changelog v9:
I mean that snow cannot use BLOBLIST_ALLOC and needs BLOBLIST_FIXED so if you make ALLOC the default you need to change the default for snow.
My lab is still not running, unfortunately, but I will try to get it sorted out soon.
Changelog v9:
Simon by snow do you mean the device (configs/snow_defconfig) snow, I think Patrick doesn't know you're referring to what I believe to be a device config.
Hi Peter,
Changelog v9:
Oh OK, yes that is what I mean. If it is too confusing I can send a fix-up patch after this series is applied.
Regards, SImon
Hi Simon, On Tue, Oct 22, 2024 at 2:16 PM Simon Glass sjg@chromium.org wrote:
Hi Peter,
Changelog v9:
Oh OK, got it. I wasn't aware that BLOBLIST is already used on some ARM devices. I'll send an updated version. Is it possible to migrate those to BLOBLIST_ALLOC? Any reason they would use a fixed address?
Regards, SImon
Hi Patrick,
On Tue, 22 Oct 2024 at 18:18, Patrick Rudolph patrick.rudolph@9elements.com wrote:
Hi Peter,
> Allow to use BLOBLIST_TABLES on arm to store ACPI or other tables. > > Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com > Cc: Tom Rini trini@konsulko.com > --- > Changelog v9: > - default to BLOBLIST_ALLOC on arm > - Move default for BLOBLIST_SIZE_RELOC up > --- > common/Kconfig | 2 ++ > lib/Kconfig | 15 +++++++++------ > 2 files changed, 11 insertions(+), 6 deletions(-) >
Not easily, since it puts the table in SRAM. But it would be possible to migrate snow to use the handle protocol.
Add support for Arm sbsa [1] v0.3+ that is supported by QEMU [2].
Unlike other Arm based platforms the machine only provides a minimal FDT that contains number of CPUs, ammount of memory and machine-version. The boot firmware has to provide ACPI tables to the OS. Due to this design a full DTB is added here as well that allows U-Boot's driver to properly function. The DTB is appended at the end of the U-Boot image and will be merged with the QEMU provided DTB.
In addition provide documentation how to use, enable binman to fabricate both ROMs that are required to boot and add ACPI tables to make it full compatible to the EDK2 reference implementation.
The board was tested using Fedora 40 Aarch64 Workstation. It's able to boot from USB and AHCI or network.
Tested and found working: - serial - PCI - xHCI - Bochs display - AHCI - network using e1000e - CPU init - Booting Fedora 40
1: Server Base System Architecture (SBSA) 2: https://www.qemu.org/docs/master/system/arm/sbsa.html
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- Changelog v3: - Add GIC and GIC-ITS to devicetree - Select GICv3 driver - Drop acpi_fill_madt and use driver model instead Changelog v4: - Drop CPU platform code - Enhance the DT to allow MADT generation from DT Changelog v5: - Add full DT and place it at the end of U-Boot - Merge DT with QEMU's DT - Drop DT generation code - Fix flash region length - Drop enable_caches() - Support platforms that do not pass FDT in x0 Changelog v6: - Update header order - Drop pad-byte from DT - select BINMAN_FDT - select E1000_NO_NVM - drop config.h include - drop a few CFG_ defines that were used for SPL Changelog v8: - Use /bits/ 64 in DT - Drop flash access helper functions - Add cfi-flash to DT - Mark secure-flash as no execute - Only use defines in DT when it's also used in other files Changelog v9: - Use interrupt-cells=3 - Select BLOBLIST --- arch/arm/Kconfig | 3 +- arch/arm/dts/qemu-sbsa.dts | 138 ++++++ arch/arm/include/asm/arch-qemu-sbsa/boot0.h | 34 ++ arch/arm/mach-qemu/Kconfig | 36 +- board/emulation/qemu-arm/MAINTAINERS | 2 + board/emulation/qemu-sbsa/Kconfig | 59 +++ board/emulation/qemu-sbsa/Makefile | 8 + board/emulation/qemu-sbsa/acpi.c | 192 ++++++++ board/emulation/qemu-sbsa/dsdt.asl | 483 ++++++++++++++++++++ board/emulation/qemu-sbsa/lowlevel_init.S | 22 + board/emulation/qemu-sbsa/qemu-sbsa.c | 273 +++++++++++ board/emulation/qemu-sbsa/qemu-sbsa.env | 14 + board/emulation/qemu-sbsa/qemu-sbsa.h | 38 ++ board/emulation/qemu-sbsa/smc.c | 71 +++ configs/qemu-arm-sbsa_defconfig | 10 + doc/board/emulation/index.rst | 1 + doc/board/emulation/qemu-sbsa.rst | 98 ++++ doc/develop/driver-model/virtio.rst | 1 + include/configs/qemu-sbsa.h | 89 ++++ 19 files changed, 1565 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/qemu-sbsa.dts create mode 100644 arch/arm/include/asm/arch-qemu-sbsa/boot0.h create mode 100644 board/emulation/qemu-sbsa/Kconfig create mode 100644 board/emulation/qemu-sbsa/Makefile create mode 100644 board/emulation/qemu-sbsa/acpi.c create mode 100644 board/emulation/qemu-sbsa/dsdt.asl create mode 100644 board/emulation/qemu-sbsa/lowlevel_init.S create mode 100644 board/emulation/qemu-sbsa/qemu-sbsa.c create mode 100644 board/emulation/qemu-sbsa/qemu-sbsa.env create mode 100644 board/emulation/qemu-sbsa/qemu-sbsa.h create mode 100644 board/emulation/qemu-sbsa/smc.c create mode 100644 configs/qemu-arm-sbsa_defconfig create mode 100644 doc/board/emulation/qemu-sbsa.rst create mode 100644 include/configs/qemu-sbsa.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 263f85b0d0..0d0c731dd0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1054,7 +1054,7 @@ config ARCH_QEMU imply DM_RNG imply DM_RTC imply RTC_PL031 - imply OF_HAS_PRIOR_STAGE + imply OF_HAS_PRIOR_STAGE if !TARGET_QEMU_ARM_SBSA imply VIDEO imply VIDEO_BOCHS imply SYS_WHITE_ON_BLACK @@ -2381,6 +2381,7 @@ source "board/broadcom/bcmns3/Kconfig" source "board/cavium/thunderx/Kconfig" source "board/eets/pdu001/Kconfig" source "board/emulation/qemu-arm/Kconfig" +source "board/emulation/qemu-sbsa/Kconfig" source "board/freescale/ls2080aqds/Kconfig" source "board/freescale/ls2080ardb/Kconfig" source "board/freescale/ls1088a/Kconfig" diff --git a/arch/arm/dts/qemu-sbsa.dts b/arch/arm/dts/qemu-sbsa.dts new file mode 100644 index 0000000000..ed00e50136 --- /dev/null +++ b/arch/arm/dts/qemu-sbsa.dts @@ -0,0 +1,138 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Devicetree with onboard devices for qemu_sbsa-ref for internal use only! + * DO NOT PASS TO THE OS! + * + * As QEMU provides only a minimal devicetree this one is merged with + * it and then fixed at runtime. + * + * Copyright 2024 9elements GmbH + */ +#include "configs/qemu-sbsa.h" +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/dts-v1/; + +/ { + #address-cells = <2>; + #size-cells = <2>; + interrupt-parent = <&intc>; + compatible = "linux,sbsa-ref"; + + binman: binman { + multiple-images; + }; + + cpus { + /* Filled by fdtdec_board_setup() */ + }; + + memory { + /* Filled by fdtdec_board_setup() */ + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + cfi_flash { + compatible = "cfi-flash"; + reg = /bits/ 64 <SBSA_FLASH_BASE_ADDR + SBSA_FLASH_LENGTH>; + status = "okay"; + }; + + uart0 { + compatible = "arm,pl011"; + status = "okay"; + reg = /bits/ 64 <SBSA_UART_BASE_ADDR + SBSA_UART_LENGTH>; + }; + + ahci { + compatible = "generic-ahci"; + status = "okay"; + reg = /bits/ 64 <0x60100000 0x00010000>; + }; + + xhci { + compatible = "generic-xhci"; + status = "okay"; + reg = /bits/ 64 <0x60110000 0x00010000>; + }; + + pci { + #address-cells = <3>; + #size-cells = <2>; + compatible = "pci-host-ecam-generic"; + device_type = "pci"; + status = "okay"; + reg = /bits/ 64 <0xf0000000 0x10000000>; + bus-range = <0 0xff>; + ranges = /bits/ 32 <0x01000000>, + /bits/ 64 <0 + SBSA_PIO_BASE_ADDR + SBSA_PIO_LENGTH>, + /bits/ 32 <0x02000000>, + /bits/ 64 <SBSA_PCIE_MMIO_BASE_ADDR + SBSA_PCIE_MMIO_BASE_ADDR + SBSA_PCIE_MMIO_LENGTH>, + /bits/ 32 <0x43000000>, + /bits/ 64 <SBSA_PCIE_MMIO_HIGH_BASE_ADDR + SBSA_PCIE_MMIO_HIGH_BASE_ADDR + SBSA_PCIE_MMIO_HIGH_LENGTH>; + }; + }; + + intc: interrupt-controller { + compatible = "arm,gic-v3"; + #interrupt-cells = <3>; + status = "okay"; + interrupt-controller; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = /bits/ 64 <SBSA_GIC_DIST_BASE_ADDR SBSA_GIC_DIST_LENGTH>, + /bits/ 64 <SBSA_GIC_REDIST_BASE_ADDR SBSA_GIC_REDIST_LENGTH>, + /bits/ 64 <0 0>, + /bits/ 64 <SBSA_GIC_HBASE_ADDR SBSA_GIC_HBASE_LENGTH>, + /bits/ 64 <SBSA_GIC_VBASE_ADDR SBSA_GIC_VBASE_LENGTH>; + }; + + its { + compatible = "arm,gic-v3-its"; + status = "disabled"; + }; +}; + +&binman { + secure-world { + filename = "secure-world.rom"; + size = <SBSA_SECURE_FLASH_LENGTH>; + + bl1 { + offset = <0x0>; + description = "ARM Trusted Firmware BL1"; + filename = "bl1.bin"; + type = "blob-ext"; + }; + + fip { + offset = <0x12000>; + description = "ARM Trusted Firmware FIP"; + filename = "fip.bin"; + type = "blob-ext"; + }; + }; + + unsecure-world { + filename = "unsecure-world.rom"; + size = <SBSA_FLASH_LENGTH>; + + u-boot { + }; + u-boot-dtb { + compress = "lz4"; + }; + }; +}; diff --git a/arch/arm/include/asm/arch-qemu-sbsa/boot0.h b/arch/arm/include/asm/arch-qemu-sbsa/boot0.h new file mode 100644 index 0000000000..4a1a254b92 --- /dev/null +++ b/arch/arm/include/asm/arch-qemu-sbsa/boot0.h @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * sbsa-ref starts U-Boot in XIP memory. Need to relocate U-Boot + * to DRAM which is already up. Instead of using SPL this simple loader + * is being used. + */ +relocate_check: + /* x0 contains the pointer to FDT provided by ATF */ + adr x1, _start /* x1 <- Runtime value of _start */ + ldr x2, _TEXT_BASE /* x2 <- Linked value of _start */ + subs x9, x1, x2 /* x9 <- Run-vs-link offset */ + beq reset + + adrp x1, __image_copy_start /* x2 <- address bits [31:12] */ + add x1, x1, :lo12:__image_copy_start/* x2 <- address bits [11:00] */ + adrp x3, __image_copy_end /* x3 <- address bits [31:12] */ + add x3, x3, :lo12:__image_copy_end /* x3 <- address bits [11:00] */ + add x3, x3, #0x100000 /* 1 MiB for the DTB found at _end */ + +copy_loop: + ldp x10, x11, [x1], #16 /* copy from source address [x1] */ + stp x10, x11, [x2], #16 /* copy to target address [x2] */ + cmp x1, x3 /* until source end address [x3] */ + b.lo copy_loop + + isb + ldr x2, _TEXT_BASE /* x2 <- Linked value of _start */ + br x2 /* Jump to linked address */ + /* Never reaches this point */ +1: + wfi + b 1b + +relocate_done: \ No newline at end of file diff --git a/arch/arm/mach-qemu/Kconfig b/arch/arm/mach-qemu/Kconfig index 186c3582eb..9c06c6a3a5 100644 --- a/arch/arm/mach-qemu/Kconfig +++ b/arch/arm/mach-qemu/Kconfig @@ -3,12 +3,6 @@ if ARCH_QEMU config SYS_VENDOR default "emulation"
-config SYS_BOARD - default "qemu-arm" - -config SYS_CONFIG_NAME - default "qemu-arm" - choice prompt "QEMU ARM architecture" default TARGET_QEMU_ARM_64BIT @@ -25,6 +19,36 @@ config TARGET_QEMU_ARM_64BIT select ARM64 select BOARD_LATE_INIT
+config TARGET_QEMU_ARM_SBSA + bool "SBSA Reference" + select ARM64 + select BINMAN + select BOARD_LATE_INIT + select ENABLE_ARM_SOC_BOOT0_HOOK + select MISC_INIT_R endchoice
+if TARGET_QEMU_ARM_32BIT || TARGET_QEMU_ARM_64BIT + +config SYS_BOARD + default "qemu-arm" + +config SYS_CONFIG_NAME + default "qemu-arm" + +endif + +if TARGET_QEMU_ARM_SBSA + +config SYS_BOARD + default "qemu-sbsa" + +config SYS_CONFIG_NAME + default "qemu-sbsa" + +config SYS_SOC + default "qemu-sbsa" + +endif + endif diff --git a/board/emulation/qemu-arm/MAINTAINERS b/board/emulation/qemu-arm/MAINTAINERS index 5154262f29..7bc0ee698c 100644 --- a/board/emulation/qemu-arm/MAINTAINERS +++ b/board/emulation/qemu-arm/MAINTAINERS @@ -4,5 +4,7 @@ S: Maintained F: board/emulation/qemu-arm/ F: board/emulation/common/ F: include/configs/qemu-arm.h +F: include/configs/qemu-sbsa.h F: configs/qemu_arm_defconfig F: configs/qemu_arm64_defconfig +F: configs/qemu-arm-sbsa_defconfig diff --git a/board/emulation/qemu-sbsa/Kconfig b/board/emulation/qemu-sbsa/Kconfig new file mode 100644 index 0000000000..72c76b351f --- /dev/null +++ b/board/emulation/qemu-sbsa/Kconfig @@ -0,0 +1,59 @@ +if TARGET_QEMU_ARM_SBSA + +config SYS_SOC + default "qemu-sbsa" + +config TEXT_BASE + default 0x10000100000 + +config SYS_LOAD_ADDR + default 0x10000100000 + +config PRE_CON_BUF_ADDR + default 0x100000FF000 + +config DEFAULT_DEVICE_TREE + default "qemu-sbsa" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select AHCI + select ACPIGEN + select ACPI + select BLOBLIST + select CPU + select CPU_ARMV8 + select DM + select DM_USB + select DM_MTD + select GENERATE_ACPI_TABLE + select HAS_ROM + select MTD + select OF_LIBFDT_OVERLAY + select OF_SEPARATE + select PCI + select PCIE_ECAM_GENERIC + select USB + select GIC_V3 + select GIC_V3_ITS + select SYS_FLASH_CFI_WIDTH_16BIT + imply AHCI_GENERIC + imply USB_XHCI_HCD + imply USB_XHCI_GENERIC + imply USB_STORAGE + imply E1000 + imply E1000_NO_NVM + imply NET_RANDOM_ETHADDR + imply VIDEO_BOCHS + imply CFI_FLASH + imply SYS_MTDPARTS_RUNTIME + imply SET_DFU_ALT_INFO + +if DEBUG_UART + +config DEBUG_UART_BASE + default 0x60000000 +endif + +source "board/emulation/common/Kconfig" +endif diff --git a/board/emulation/qemu-sbsa/Makefile b/board/emulation/qemu-sbsa/Makefile new file mode 100644 index 0000000000..bacae320e7 --- /dev/null +++ b/board/emulation/qemu-sbsa/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += qemu-sbsa.o +obj-y += lowlevel_init.o +obj-y += smc.o + +obj-$(CONFIG_GENERATE_ACPI_TABLE) += dsdt_generated.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi.o diff --git a/board/emulation/qemu-sbsa/acpi.c b/board/emulation/qemu-sbsa/acpi.c new file mode 100644 index 0000000000..ba85e08fc7 --- /dev/null +++ b/board/emulation/qemu-sbsa/acpi.c @@ -0,0 +1,192 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024 9elements GmbH + */ + +#include <cpu.h> +#include <tables_csum.h> +#include <string.h> +#include <acpi/acpi_table.h> +#include <asm/acpi_table.h> +#include <asm/armv8/sec_firmware.h> +#include <configs/qemu-sbsa.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include "qemu-sbsa.h" + +#define SBSAQEMU_MADT_GIC_VBASE 0x2c020000 +#define SBSAQEMU_MADT_GIC_HBASE 0x2c010000 +#define SBSAQEMU_MADT_GIC_PMU_IRQ 23 + +#define SBSA_PLATFORM_WATCHDOG_COUNT 1 +#define SBSA_PLATFORM_TIMER_COUNT (SBSA_PLATFORM_WATCHDOG_COUNT) + +#define L2_ATTRIBUTES (ACPI_PPTT_READ_ALLOC | ACPI_PPTT_WRITE_ALLOC | \ + (ACPI_PPTT_CACHE_TYPE_UNIFIED << \ + ACPI_PPTT_CACHE_TYPE_SHIFT)) +#define L2_SIZE 0x80000 +#define L2_SETS 0x400 +#define L2_WAYS 8 + +#define L1D_ATTRIBUTES (ACPI_PPTT_READ_ALLOC | ACPI_PPTT_WRITE_ALLOC | \ + (ACPI_PPTT_CACHE_TYPE_DATA << \ + ACPI_PPTT_CACHE_TYPE_SHIFT)) +#define L1D_SIZE 0x8000 +#define L1D_SETS 0x100 +#define L1D_WAYS 2 + +#define L1I_ATTRIBUTES (ACPI_PPTT_READ_ALLOC | \ + (ACPI_PPTT_CACHE_TYPE_INSTR << \ + ACPI_PPTT_CACHE_TYPE_SHIFT)) +#define L1I_SIZE 0x8000 +#define L1I_SETS 0x100 +#define L1I_WAYS 2 + +int acpi_fill_iort(struct acpi_ctx *ctx) +{ + u32 its_offset, smmu_offset; + u64 gic_its_base = 0; + + smc_get_gic_its_base(&gic_its_base); + if (gic_its_base == 0) + return 0; + + u32 identifiers[] = { 0 }; + + its_offset = acpi_iort_add_its_group(ctx, ARRAY_SIZE(identifiers), + identifiers); + + struct acpi_iort_id_mapping map_smmu[] = {{ + 0, 0xffff, 0, its_offset, 0 + }}; + + smmu_offset = acpi_iort_add_smmu_v3(ctx, + SBSA_SMMU_BASE_ADDR, // Base address + ACPI_IORT_SMMU_V3_COHACC_OVERRIDE, // Flags + 0, // VATOS address + 0, // SMMUv3 Model + 74, // Event + 75, // Pri + 77, // Gerror + 76, // Sync + 0, // Proximity domain + 1, // DevIDMappingIndex + ARRAY_SIZE(map_smmu), + map_smmu); + + struct acpi_iort_id_mapping map_rc[] = {{ + 0, 0xffff, 0, smmu_offset, 0 + }}; + + acpi_iort_add_rc(ctx, + BIT(0) | BIT(56), // CacheCoherent + CPM + 0, // AtsAttribute + 0, // PciSegmentNumber + 64, // MemoryAddressSizeLimit + ARRAY_SIZE(map_rc), + map_rc); + return 0; +} + +void acpi_fill_fadt(struct acpi_fadt *fadt) +{ + fadt->flags = ACPI_FADT_HW_REDUCED_ACPI | ACPI_FADT_LOW_PWR_IDLE_S0; + fadt->preferred_pm_profile = ACPI_PM_PERFORMANCE_SERVER; + fadt->arm_boot_arch = ACPI_ARM_PSCI_COMPLIANT; +} + +int acpi_fill_mcfg(struct acpi_ctx *ctx) +{ + size_t size; + + /* PCI Segment Group 0, Start Bus Number 0, End Bus Number is 255 */ + size = acpi_create_mcfg_mmconfig((void *)ctx->current, + SBSA_PCIE_ECAM_BASE_ADDR, 0, 0, 255); + acpi_inc(ctx, size); + + return 0; +} + +static int sbsa_write_gtdt(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_header *header; + struct acpi_gtdt *gtdt; + + gtdt = ctx->current; + header = >dt->header; + + memset(gtdt, '\0', sizeof(struct acpi_gtdt)); + + acpi_fill_header(header, "GTDT"); + header->length = sizeof(struct acpi_gtdt); + header->revision = acpi_get_table_revision(ACPITAB_GTDT); + + gtdt->cnt_ctrl_base = 0xFFFFFFFFFFFFFFFF; + gtdt->sec_el1_gsiv = 29; + gtdt->sec_el1_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->el1_gsiv = 30; + gtdt->el1_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->virt_el1_gsiv = 27; + gtdt->virt_el1_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->el2_gsiv = 26; + gtdt->el2_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->cnt_read_base = 0xffffffffffffffff; + + // FIXME: VirtualPL2Timer + header->checksum = table_compute_checksum(header, header->length); + + acpi_add_table(ctx, gtdt); + + acpi_inc(ctx, sizeof(struct acpi_gtdt)); + + return 0; +}; + +ACPI_WRITER(5gtdt, "GTDT", sbsa_write_gtdt, 0); + +static int acpi_write_pptt(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_header *header; + int cluster_offset, l2_offset; + u32 offsets[2]; + + header = ctx->current; + ctx->tab_start = ctx->current; + + memset(header, '\0', sizeof(struct acpi_table_header)); + + acpi_fill_header(header, "PPTT"); + header->revision = acpi_get_table_revision(ACPITAB_PPTT); + acpi_inc(ctx, sizeof(*header)); + + cluster_offset = acpi_pptt_add_proc(ctx, ACPI_PPTT_PHYSICAL_PACKAGE | + ACPI_PPTT_CHILDREN_IDENTICAL, + 0, 0, 0, NULL); + + l2_offset = acpi_pptt_add_cache(ctx, ACPI_PPTT_ALL_VALID, 0, L2_SIZE, + L2_SETS, L2_WAYS, L2_ATTRIBUTES, 64); + + offsets[0] = acpi_pptt_add_cache(ctx, ACPI_PPTT_ALL_VALID, l2_offset, + L1D_SIZE, L1D_SETS, L1D_WAYS, + L1D_ATTRIBUTES, 64); + + offsets[1] = acpi_pptt_add_cache(ctx, ACPI_PPTT_ALL_BUT_WRITE_POL, + l2_offset, L1I_SIZE, L1I_SETS, + L1I_WAYS, L1I_ATTRIBUTES, 64); + + for (int i = 0; i < uclass_id_count(UCLASS_CPU); i++) { + acpi_pptt_add_proc(ctx, ACPI_PPTT_CHILDREN_IDENTICAL | + ACPI_PPTT_NODE_IS_LEAF | ACPI_PPTT_PROC_ID_VALID, + cluster_offset, i, 2, offsets); + } + + header->length = ctx->current - ctx->tab_start; + header->checksum = table_compute_checksum(header, header->length); + + acpi_inc(ctx, header->length); + acpi_add_table(ctx, header); + + return 0; +}; + +ACPI_WRITER(5pptt, "PPTT", acpi_write_pptt, 0); diff --git a/board/emulation/qemu-sbsa/dsdt.asl b/board/emulation/qemu-sbsa/dsdt.asl new file mode 100644 index 0000000000..f12cca04e2 --- /dev/null +++ b/board/emulation/qemu-sbsa/dsdt.asl @@ -0,0 +1,483 @@ +/** @file +* Differentiated System Description Table Fields (DSDT). +* +* Copyright (c) 2020, Linaro Ltd. All rights reserved. +* +* SPDX-License-Identifier: BSD-2-Clause-Patent +**/ + +#include <configs/qemu-sbsa.h> + +#define LINK_DEVICE(Uid, LinkName, Irq) \ + Device (LinkName) { \ + Name (_HID, EISAID("PNP0C0F")) \ + Name (_UID, Uid) \ + Name (_PRS, ResourceTemplate() { \ + Interrupt (ResourceProducer, Level, ActiveHigh, Exclusive) { Irq } \ + }) \ + Method (_STA) { \ + Return (0xF) \ + } \ + Method (_CRS, 0) { Return (_PRS) } \ + Method (_SRS, 1) { } \ + Method (_DIS) { } \ + } + +#define PRT_ENTRY(Address, Pin, Link) \ + Package (4) { \ + Address, Pin, Link, Zero \ + } + +DefinitionBlock ("Dsdt.aml", "DSDT", 2, "U-Boot", "SBSAQEMU", 2) { + Scope (_SB) { + // UART PL011 + Device (COM0) { + Name (_HID, "ARMH0011") + Name (_UID, Zero) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, + SBSA_UART_BASE_ADDR, + SBSA_UART_LENGTH) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { 33 } + }) + Method (_STA) { + Return (0xF) + } + } + + // AHCI Host Controller + Device (AHC0) { + Name (_HID, "LNRO001E") + Name (_CLS, Package (3) { + 0x01, + 0x06, + 0x01, + }) + Name (_CCA, 1) + Name (_CRS, ResourceTemplate() { + Memory32Fixed (ReadWrite, + SBSA_AHCI_BASE_ADDR, + SBSA_AHCI_LENGTH) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { 42 } + }) + Method (_STA) { + Return (0xF) + } + } + + + // USB XHCI Host Controller + Device (USB0) { + Name (_HID, "PNP0D10") // _HID: Hardware ID + Name (_UID, 0x00) // _UID: Unique ID + Name (_CCA, 0x01) // _CCA: Cache Coherency Attribute + Name (XHCI, 0xF) // will be set using AcpiLib + Method (_STA) { + Return (XHCI) + } + Name (_CRS, ResourceTemplate() { + Memory32Fixed (ReadWrite, + SBSA_XHCI_BASE_ADDR, + SBSA_XHCI_LENGTH) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { 43 } + }) + + // Root Hub + Device (RHUB) { + Name (_ADR, 0x00000000) // Address of Root Hub should be 0 as per ACPI 5.0 spec + Method (_STA) { + Return (0xF) + } + + // Ports connected to Root Hub + Device (HUB1) { + Name (_ADR, 0x00000001) + Name (_UPC, Package() { + 0x00, // Port is NOT connectable + 0xFF, // Don't care + 0x00000000, // Reserved 0 must be zero + 0x00000000 // Reserved 1 must be zero + }) + Method (_STA) { + Return (0xF) + } + + Device (PRT1) { + Name (_ADR, 0x00000001) + Name (_UPC, Package() { + 0xFF, // Port is connectable + 0x00, // Port connector is A + 0x00000000, + 0x00000000 + }) + Name (_PLD, Package() { + Buffer(0x10) { + 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x31, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 + } + }) + Method (_STA) { + Return (0xF) + } + } // USB0_RHUB_HUB1_PRT1 + Device (PRT2) { + Name (_ADR, 0x00000002) + Name (_UPC, Package() { + 0xFF, // Port is connectable + 0x00, // Port connector is A + 0x00000000, + 0x00000000 + }) + Name (_PLD, Package() { + Buffer(0x10) { + 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x31, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 + } + }) + Method (_STA) { + Return (0xF) + } + } // USB0_RHUB_HUB1_PRT2 + + Device (PRT3) { + Name (_ADR, 0x00000003) + Name (_UPC, Package() { + 0xFF, // Port is connectable + 0x09, // Type C connector - USB2 and SS with Switch + 0x00000000, + 0x00000000 + }) + Name (_PLD, Package() { + Buffer (0x10) { + 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x31, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 + } + }) + Method (_STA) { + Return (0xF) + } + } // USB0_RHUB_HUB1_PRT3 + + Device (PRT4) { + Name (_ADR, 0x00000004) + Name (_UPC, Package() { + 0xFF, // Port is connectable + 0x09, // Type C connector - USB2 and SS with Switch + 0x00000000, + 0x00000000 + }) + Name (_PLD, Package() { + Buffer (0x10){ + 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x31, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 + } + }) + Method (_STA) { + Return (0xF) + } + } // USB0_RHUB_HUB1_PRT4 + } // USB0_RHUB_HUB1 + } // USB0_RHUB + } // USB0 + + Device (PCI0) + { + Name (_HID, EISAID ("PNP0A08")) // PCI Express Root Bridge + Name (_CID, EISAID ("PNP0A03")) // Compatible PCI Root Bridge + Name (_SEG, Zero) // PCI Segment Group number + Name (_BBN, Zero) // PCI Base Bus Number + Name (_UID, "PCI0") + Name (_CCA, One) // Initially mark the PCI coherent (for JunoR1) + + Method (_STA) { + Return (0xF) + } + + Method (_CBA, 0, NotSerialized) { + return (SBSA_PCIE_ECAM_BASE_ADDR) + } + + LINK_DEVICE(0, GSI0, 0x23) + LINK_DEVICE(1, GSI1, 0x24) + LINK_DEVICE(2, GSI2, 0x25) + LINK_DEVICE(3, GSI3, 0x26) + + Name (_PRT, Package () // _PRT: PCI Routing Table + { + PRT_ENTRY(0x0000FFFF, 0, GSI0), + PRT_ENTRY(0x0000FFFF, 0, GSI1), + PRT_ENTRY(0x0000FFFF, 0, GSI2), + PRT_ENTRY(0x0000FFFF, 0, GSI3), + + PRT_ENTRY(0x0001FFFF, 0, GSI1), + PRT_ENTRY(0x0001FFFF, 1, GSI2), + PRT_ENTRY(0x0001FFFF, 2, GSI3), + PRT_ENTRY(0x0001FFFF, 3, GSI0), + + PRT_ENTRY(0x0002FFFF, 0, GSI2), + PRT_ENTRY(0x0002FFFF, 1, GSI3), + PRT_ENTRY(0x0002FFFF, 2, GSI0), + PRT_ENTRY(0x0002FFFF, 3, GSI1), + + PRT_ENTRY(0x0003FFFF, 0, GSI3), + PRT_ENTRY(0x0003FFFF, 1, GSI0), + PRT_ENTRY(0x0003FFFF, 2, GSI1), + PRT_ENTRY(0x0003FFFF, 3, GSI2), + + PRT_ENTRY(0x0004FFFF, 0, GSI0), + PRT_ENTRY(0x0004FFFF, 1, GSI1), + PRT_ENTRY(0x0004FFFF, 2, GSI2), + PRT_ENTRY(0x0004FFFF, 3, GSI3), + + PRT_ENTRY(0x0005FFFF, 0, GSI1), + PRT_ENTRY(0x0005FFFF, 1, GSI2), + PRT_ENTRY(0x0005FFFF, 2, GSI3), + PRT_ENTRY(0x0005FFFF, 3, GSI0), + + PRT_ENTRY(0x0006FFFF, 0, GSI2), + PRT_ENTRY(0x0006FFFF, 1, GSI3), + PRT_ENTRY(0x0006FFFF, 2, GSI0), + PRT_ENTRY(0x0006FFFF, 3, GSI1), + + PRT_ENTRY(0x0007FFFF, 0, GSI3), + PRT_ENTRY(0x0007FFFF, 1, GSI0), + PRT_ENTRY(0x0007FFFF, 2, GSI1), + PRT_ENTRY(0x0007FFFF, 3, GSI2), + + PRT_ENTRY(0x0008FFFF, 0, GSI0), + PRT_ENTRY(0x0008FFFF, 1, GSI1), + PRT_ENTRY(0x0008FFFF, 2, GSI2), + PRT_ENTRY(0x0008FFFF, 3, GSI3), + + PRT_ENTRY(0x0009FFFF, 0, GSI1), + PRT_ENTRY(0x0009FFFF, 1, GSI2), + PRT_ENTRY(0x0009FFFF, 2, GSI3), + PRT_ENTRY(0x0009FFFF, 3, GSI0), + + PRT_ENTRY(0x000AFFFF, 0, GSI2), + PRT_ENTRY(0x000AFFFF, 1, GSI3), + PRT_ENTRY(0x000AFFFF, 2, GSI0), + PRT_ENTRY(0x000AFFFF, 3, GSI1), + + PRT_ENTRY(0x000BFFFF, 0, GSI3), + PRT_ENTRY(0x000BFFFF, 1, GSI0), + PRT_ENTRY(0x000BFFFF, 2, GSI1), + PRT_ENTRY(0x000BFFFF, 3, GSI2), + + PRT_ENTRY(0x000CFFFF, 0, GSI0), + PRT_ENTRY(0x000CFFFF, 1, GSI1), + PRT_ENTRY(0x000CFFFF, 2, GSI2), + PRT_ENTRY(0x000CFFFF, 3, GSI3), + + PRT_ENTRY(0x000DFFFF, 0, GSI1), + PRT_ENTRY(0x000DFFFF, 1, GSI2), + PRT_ENTRY(0x000DFFFF, 2, GSI3), + PRT_ENTRY(0x000DFFFF, 3, GSI0), + + PRT_ENTRY(0x000EFFFF, 0, GSI2), + PRT_ENTRY(0x000EFFFF, 1, GSI3), + PRT_ENTRY(0x000EFFFF, 2, GSI0), + PRT_ENTRY(0x000EFFFF, 3, GSI1), + + PRT_ENTRY(0x000FFFFF, 0, GSI3), + PRT_ENTRY(0x000FFFFF, 1, GSI0), + PRT_ENTRY(0x000FFFFF, 2, GSI1), + PRT_ENTRY(0x000FFFFF, 3, GSI2), + + PRT_ENTRY(0x0010FFFF, 0, GSI0), + PRT_ENTRY(0x0010FFFF, 1, GSI1), + PRT_ENTRY(0x0010FFFF, 2, GSI2), + PRT_ENTRY(0x0010FFFF, 3, GSI3), + + PRT_ENTRY(0x0011FFFF, 0, GSI1), + PRT_ENTRY(0x0011FFFF, 1, GSI2), + PRT_ENTRY(0x0011FFFF, 2, GSI3), + PRT_ENTRY(0x0011FFFF, 3, GSI0), + + PRT_ENTRY(0x0012FFFF, 0, GSI2), + PRT_ENTRY(0x0012FFFF, 1, GSI3), + PRT_ENTRY(0x0012FFFF, 2, GSI0), + PRT_ENTRY(0x0012FFFF, 3, GSI1), + + PRT_ENTRY(0x0013FFFF, 0, GSI3), + PRT_ENTRY(0x0013FFFF, 1, GSI0), + PRT_ENTRY(0x0013FFFF, 2, GSI1), + PRT_ENTRY(0x0013FFFF, 3, GSI2), + + PRT_ENTRY(0x0014FFFF, 0, GSI0), + PRT_ENTRY(0x0014FFFF, 1, GSI1), + PRT_ENTRY(0x0014FFFF, 2, GSI2), + PRT_ENTRY(0x0014FFFF, 3, GSI3), + + PRT_ENTRY(0x0015FFFF, 0, GSI1), + PRT_ENTRY(0x0015FFFF, 1, GSI2), + PRT_ENTRY(0x0015FFFF, 2, GSI3), + PRT_ENTRY(0x0015FFFF, 3, GSI0), + + PRT_ENTRY(0x0016FFFF, 0, GSI2), + PRT_ENTRY(0x0016FFFF, 1, GSI3), + PRT_ENTRY(0x0016FFFF, 2, GSI0), + PRT_ENTRY(0x0016FFFF, 3, GSI1), + + PRT_ENTRY(0x0017FFFF, 0, GSI3), + PRT_ENTRY(0x0017FFFF, 1, GSI0), + PRT_ENTRY(0x0017FFFF, 2, GSI1), + PRT_ENTRY(0x0017FFFF, 3, GSI2), + + PRT_ENTRY(0x0018FFFF, 0, GSI0), + PRT_ENTRY(0x0018FFFF, 1, GSI1), + PRT_ENTRY(0x0018FFFF, 2, GSI2), + PRT_ENTRY(0x0018FFFF, 3, GSI3), + + PRT_ENTRY(0x0019FFFF, 0, GSI1), + PRT_ENTRY(0x0019FFFF, 1, GSI2), + PRT_ENTRY(0x0019FFFF, 2, GSI3), + PRT_ENTRY(0x0019FFFF, 3, GSI0), + + PRT_ENTRY(0x001AFFFF, 0, GSI2), + PRT_ENTRY(0x001AFFFF, 1, GSI3), + PRT_ENTRY(0x001AFFFF, 2, GSI0), + PRT_ENTRY(0x001AFFFF, 3, GSI1), + + PRT_ENTRY(0x001BFFFF, 0, GSI3), + PRT_ENTRY(0x001BFFFF, 1, GSI0), + PRT_ENTRY(0x001BFFFF, 2, GSI1), + PRT_ENTRY(0x001BFFFF, 3, GSI2), + + PRT_ENTRY(0x001CFFFF, 0, GSI0), + PRT_ENTRY(0x001CFFFF, 1, GSI1), + PRT_ENTRY(0x001CFFFF, 2, GSI2), + PRT_ENTRY(0x001CFFFF, 3, GSI3), + + PRT_ENTRY(0x001DFFFF, 0, GSI1), + PRT_ENTRY(0x001DFFFF, 1, GSI2), + PRT_ENTRY(0x001DFFFF, 2, GSI3), + PRT_ENTRY(0x001DFFFF, 3, GSI0), + + PRT_ENTRY(0x001EFFFF, 0, GSI2), + PRT_ENTRY(0x001EFFFF, 1, GSI3), + PRT_ENTRY(0x001EFFFF, 2, GSI0), + PRT_ENTRY(0x001EFFFF, 3, GSI1), + + PRT_ENTRY(0x001FFFFF, 0, GSI3), + PRT_ENTRY(0x001FFFFF, 1, GSI0), + PRT_ENTRY(0x001FFFFF, 2, GSI1), + PRT_ENTRY(0x001FFFFF, 3, GSI2), + }) + + // Root complex resources + Name (_CRS, ResourceTemplate () { + WordBusNumber ( // Bus numbers assigned to this root + ResourceProducer, + MinFixed, MaxFixed, PosDecode, + 0, // AddressGranularity + 0, // AddressMinimum - Minimum Bus Number + 0xff,// AddressMaximum - Maximum Bus Number + 0, // AddressTranslation - Set to 0 + 256 // RangeLength - Number of Busses + ) + + // IO to mmio window + QWordIO ( + ResourceProducer, MinFixed, + MaxFixed, PosDecode, + EntireRange, + 0x00000000, // Granularity + 0x0000, // Min Base Address + 0xffff, // Max Base Address + SBSA_PIO_BASE_ADDR, // Translate + SBSA_PIO_LENGTH // Length + ) + + DWordMemory ( // 32-bit BAR Windows + ResourceProducer, PosDecode, + MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, // Granularity + SBSA_PCIE_MMIO_BASE_ADDR, // Min Base Address + SBSA_PCIE_MMIO_END, // Max Base Address + 0, // Translate + SBSA_PCIE_MMIO_LENGTH // Length + ) + + QWordMemory ( // 64-bit BAR Windows + ResourceProducer, PosDecode, + MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, // Granularity + SBSA_PCIE_MMIO_HIGH_BASE_ADDR, // Min Base Address + SBSA_PCIE_MMIO_HIGH_END, // Max Base Address + 0, // Translate + SBSA_PCIE_MMIO_HIGH_LENGTH // Length + ) + }) // Name(_CRS) + + Device (RES0) + { + Name (_HID, "PNP0C02" /* PNP Motherboard Resources */) // _HID: Hardware ID + Name (_CRS, ResourceTemplate () // _CRS: Current Resource Settings + { + QWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, NonCacheable, ReadWrite, + 0x0000000000000000, // Granularity + SBSA_PCIE_ECAM_BASE_ADDR, // Range Minimum + SBSA_PCIE_ECAM_END, // Range Maximum + 0x0000000000000000, // Translation Offset + SBSA_PCIE_ECAM_LENGTH, // Length + ,, , AddressRangeMemory, TypeStatic) + }) + Method (_STA) { + Return (0xF) + } + } + + // OS Control Handoff + Name (SUPP, Zero) // PCI _OSC Support Field value + Name (CTRL, Zero) // PCI _OSC Control Field value + + /* + * See [1] 6.2.10, [2] 4.5 + */ + Method (_OSC,4) { + // Check for proper UUID + If (Arg0 == ToUUID("33DB4D5B-1FF7-401C-9657-7441C03DD766")) { + // Create DWord-adressable fields from the Capabilities Buffer + CreateDWordField (Arg3,0,CDW1) + CreateDWordField (Arg3,4,CDW2) + CreateDWordField (Arg3,8,CDW3) + + // Save Capabilities DWord2 & 3 + Store (CDW2,SUPP) + Store (CDW3,CTRL) + + // Only allow native hot plug control if OS supports: + // * ASPM + // * Clock PM + // * MSI/MSI-X + If ((SUPP & 0x16) != 0x16) { + CTRL &= 0x1E // Mask bit 0 (and undefined bits) + } + + // Always allow native PME, AER (no dependencies) + + // Never allow SHPC (no SHPC controller in this system) + CTRL &= 0x1D + + If (Arg1 != One) { // Unknown revision + CDW1 |= 0x08 + } + + If (CDW3 != CTRL) { // Capabilities bits were masked + CDW1 |= 0x10 + } + + // Update DWORD3 in the buffer + Store (CTRL,CDW3) + Return (Arg3) + } Else { + CDW1 |= 4 // Unrecognized UUID + Return (Arg3) + } + } // End _OSC + } + } // Scope (_SB) +} diff --git a/board/emulation/qemu-sbsa/lowlevel_init.S b/board/emulation/qemu-sbsa/lowlevel_init.S new file mode 100644 index 0000000000..c997721af9 --- /dev/null +++ b/board/emulation/qemu-sbsa/lowlevel_init.S @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2016 + * Cédric Schieli cschieli@gmail.com + */ + +#include <config.h> + +/* + * Routine: save_boot_params (called after reset from start.S) + * Description: save ATAG/FDT address provided by the firmware at boot time + */ + +.global save_boot_params +save_boot_params: + /* The firmware provided ATAG/FDT address can be found in r2/x0 */ + adr x8, fw_dtb_pointer + str x0, [x8] + + + /* Returns */ + b save_boot_params_ret diff --git a/board/emulation/qemu-sbsa/qemu-sbsa.c b/board/emulation/qemu-sbsa/qemu-sbsa.c new file mode 100644 index 0000000000..3943c92432 --- /dev/null +++ b/board/emulation/qemu-sbsa/qemu-sbsa.c @@ -0,0 +1,273 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2017 Tuomas Tynkkynen + */ + +#include <cpu_func.h> +#include <dm.h> +#include <env.h> +#include <fdtdec.h> +#include <fdt_support.h> +#include <init.h> +#include <log.h> +#include <usb.h> +#include <asm/armv8/mmu.h> + +#include "qemu-sbsa.h" + +/* Assigned in lowlevel_init.S + * Push the variable into the .data section so that it + * does not get cleared later. + */ +unsigned long __section(".data") fw_dtb_pointer; + +static struct mm_region qemu_sbsa_mem_map[] = { + { + /* Secure flash */ + .virt = SBSA_SECURE_FLASH_BASE_ADDR, + .phys = SBSA_SECURE_FLASH_BASE_ADDR, + .size = SBSA_SECURE_FLASH_LENGTH, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_INNER_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* Flash */ + .virt = SBSA_FLASH_BASE_ADDR, + .phys = SBSA_FLASH_BASE_ADDR, + .size = SBSA_FLASH_LENGTH, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_INNER_SHARE + }, { + /* Lowmem peripherals */ + .virt = SBSA_PERIPH_BASE_ADDR, + .phys = SBSA_PERIPH_BASE_ADDR, + .size = SBSA_PCIE_MMIO_BASE_ADDR - SBSA_PERIPH_BASE_ADDR, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* 32-bit address PCIE MMIO space */ + .virt = SBSA_PCIE_MMIO_BASE_ADDR, + .phys = SBSA_PCIE_MMIO_BASE_ADDR, + .size = SBSA_PCIE_MMIO_LENGTH, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* PCI-E ECAM memory area */ + .virt = SBSA_PCIE_ECAM_BASE_ADDR, + .phys = SBSA_PCIE_ECAM_BASE_ADDR, + .size = SBSA_PCIE_ECAM_LENGTH, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* Highmem PCI-E MMIO memory area */ + .virt = SBSA_PCIE_MMIO_HIGH_BASE_ADDR, + .phys = SBSA_PCIE_MMIO_HIGH_BASE_ADDR, + .size = SBSA_PCIE_MMIO_HIGH_LENGTH, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* DRAM */ + .virt = SBSA_MEM_BASE_ADDR, + .phys = SBSA_MEM_BASE_ADDR, + .size = 0x800000000000ULL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = qemu_sbsa_mem_map; + +int board_late_init(void) +{ + /* start usb so that usb keyboard can be used as input device */ + if (CONFIG_IS_ENABLED(USB_KEYBOARD)) + usb_init(); + + return 0; +} + +int board_init(void) +{ + return 0; +} + +/** + * dtb_dt_qemu - Return the address of the QEMU provided FDT. + * + * @return: Pointer to FDT or NULL on failure + */ +static void *dtb_dt_qemu(void) +{ + /* FDT might be at start of DRAM */ + if (fdt_magic(SBSA_MEM_BASE_ADDR) == FDT_MAGIC) + return (void *)(u64)SBSA_MEM_BASE_ADDR; + + /* When ARM_LINUX_KERNEL_AS_BL33 is enabled in ATF, it's passed in x0 */ + if (fw_dtb_pointer >= SBSA_MEM_BASE_ADDR && + fdt_magic(fw_dtb_pointer) == FDT_MAGIC) { + return (void *)fw_dtb_pointer; + } + + return NULL; +} + +/* + * QEMU doesn't set compatible on cpus. + * Add them to make sure the U-Boot driver properly bind. + */ +static int fdtdec_fix_cpus(void *fdt_blob) +{ + int cpus_offset, off, ret; + u64 mpidr, i = 0; + + cpus_offset = fdt_path_offset(fdt_blob, "/cpus"); + if (cpus_offset < 0) { + puts("couldn't find /cpus node\n"); + return cpus_offset; + } + + fdt_for_each_subnode(off, fdt_blob, cpus_offset) { + if (strncmp(fdt_get_name(fdt_blob, off, NULL), "cpu@", 4)) + continue; + + mpidr = 0; + ret = smc_get_mpidr(i, &mpidr); + if (ret) { + log_warning("Failed to get MPIDR for processor %lld from SMC: %d\n", + i, ret); + mpidr = i; + } + + ret = fdt_setprop_string(fdt_blob, off, "compatible", "arm,armv8"); + if (ret < 0) + return ret; + + ret = fdt_setprop_string(fdt_blob, off, "device_type", "cpu"); + if (ret < 0) + return ret; + + ret = fdt_setprop_u64(fdt_blob, off, "reg", mpidr); + if (ret < 0) + return ret; + i++; + } + return 0; +} + +/* + * Update the GIC node when necessary and add optional ITS when it has a + * non zero base-address. + */ +static int fdtdec_fix_gic(void *fdt) +{ + u64 gic_dist_base = SBSA_GIC_DIST_BASE_ADDR; + u64 gic_redist_base = SBSA_GIC_REDIST_BASE_ADDR; + u64 gic_its_base = 0; + int offs, ret; + u64 reg[10]; + + /* Invoke SMC to get real base-address */ + smc_get_gic_dist_base(&gic_dist_base); + smc_get_gic_redist_base(&gic_redist_base); + + if ((gic_dist_base != SBSA_GIC_DIST_BASE_ADDR) || + (gic_redist_base != SBSA_GIC_REDIST_BASE_ADDR)) { + offs = fdt_path_offset(fdt, "/interrupt-controller"); + if (offs < 0) { + puts("couldn't find /interrupt-controller node\n"); + return offs; + } + + reg[0] = cpu_to_fdt64(gic_dist_base); + reg[1] = cpu_to_fdt64((u64)SBSA_GIC_DIST_LENGTH); + reg[2] = cpu_to_fdt64(gic_redist_base); + reg[3] = cpu_to_fdt64((u64)SBSA_GIC_REDIST_LENGTH); + reg[4] = cpu_to_fdt64(0); + reg[5] = cpu_to_fdt64(0); + reg[6] = cpu_to_fdt64(SBSA_GIC_HBASE_ADDR); + reg[7] = cpu_to_fdt64((u64)SBSA_GIC_HBASE_LENGTH); + reg[8] = cpu_to_fdt64(SBSA_GIC_VBASE_ADDR); + reg[9] = cpu_to_fdt64((u64)SBSA_GIC_VBASE_LENGTH); + + ret = fdt_setprop_inplace(fdt, offs, "reg", reg, sizeof(reg)); + } + + smc_get_gic_its_base(&gic_its_base); + + if (gic_its_base != 0) { + offs = fdt_path_offset(fdt, "/its"); + if (offs < 0) + return offs; + + ret = fdt_setprop_string(fdt, offs, "status", "okay"); + if (ret < 0) + return ret; + + reg[0] = cpu_to_fdt64(gic_its_base); + reg[1] = 0; + + ret = fdt_setprop(fdt, offs, "reg", reg, sizeof(u64) * 2); + if (ret < 0) + return ret; + } + + return 0; +} + +int fdtdec_board_setup(const void *fdt_blob) +{ + void *qemu_fdt; + int ret; + + /* + * Locate the QEMU provided DTB that contains the CPUs and amount of DRAM. + */ + qemu_fdt = dtb_dt_qemu(); + if (!qemu_fdt) { + log_err("QEMU FDT not found\n"); + return -ENODEV; + } + + ret = fdt_increase_size((void *)fdt_blob, 1024 + fdt_totalsize(qemu_fdt)); + if (ret) + return -ENOMEM; + + /* + * Merge the QEMU DTB as overlay into the U-Boot provided DTB. + */ + ret = fdt_overlay_apply_node((void *)fdt_blob, 0, qemu_fdt, 0); + if (ret < 0) + log_err("Failed to apply overlay: %d\n", ret); + + /* Fix QEMU nodes to make sure U-Boot drivers are properly working */ + ret = fdtdec_fix_cpus((void *)fdt_blob); + if (ret < 0) + log_err("Failed to fix CPUs in FDT: %d\n", ret); + + ret = fdtdec_fix_gic((void *)fdt_blob); + if (ret < 0) + log_err("Failed to fix INTC in FDT: %d\n", ret); + + return 0; +} + +int misc_init_r(void) +{ + return env_set_hex("fdt_addr", (uintptr_t)gd->fdt_blob); +} + +void reset_cpu(void) +{ +} + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} \ No newline at end of file diff --git a/board/emulation/qemu-sbsa/qemu-sbsa.env b/board/emulation/qemu-sbsa/qemu-sbsa.env new file mode 100644 index 0000000000..88fdb0ec1c --- /dev/null +++ b/board/emulation/qemu-sbsa/qemu-sbsa.env @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +/* environment for qemu-arm and qemu-arm64 */ + +stdin=serial,usbkbd +stdout=serial,vidconsole +stderr=serial,vidconsole +fdt_high=0xffffffffffffffff +initrd_high=0xffffffffffffffff +scriptaddr=0x100000300000 +pxefile_addr_r=0x10000400000 +kernel_addr_r=0x10000200000 +ramdisk_addr_r=0x10001000000 +boot_targets=qfw usb scsi virtio nvme dhcp diff --git a/board/emulation/qemu-sbsa/qemu-sbsa.h b/board/emulation/qemu-sbsa/qemu-sbsa.h new file mode 100644 index 0000000000..391a70bdc4 --- /dev/null +++ b/board/emulation/qemu-sbsa/qemu-sbsa.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024 9elements GmbH + */ + +/** + * smc_get_mpidr() - Call into SMC and get the MPIDR for given CPU + * + * @id: CPU index + * @mpidr: Pointer where to place the MPIDR + * @return 0 if OK, other -ve on error + */ +int smc_get_mpidr(unsigned long id, u64 *mpidr); + +/** + * smc_get_gic_dist_base() - Call into SMC and get GIC dist base address + * + * @mpidr: Pointer where to place the base address + * @return 0 if OK, other -ve on error + */ +int smc_get_gic_dist_base(u64 *base); + +/** + * smc_get_gic_redist_base() - Call into SMC and get the GIC redistributor + * base address + * + * @mpidr: Pointer where to place the base address + * @return 0 if OK, other -ve on error + */ +int smc_get_gic_redist_base(u64 *base); + +/** + * smc_get_gic_its_base() - Call into SMC and get the ITS base address + * + * @mpidr: Pointer where to place the base address + * @return 0 if OK, other -ve on error + */ +int smc_get_gic_its_base(u64 *base); diff --git a/board/emulation/qemu-sbsa/smc.c b/board/emulation/qemu-sbsa/smc.c new file mode 100644 index 0000000000..9a2d091bea --- /dev/null +++ b/board/emulation/qemu-sbsa/smc.c @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2024 9elements GmbH + */ + +#include <cpu.h> +#include <init.h> +#include <log.h> +#include <linux/arm-smccc.h> + +#define SMC_SIP_FUNCTION_ID(n) (0xC2000000 | (n)) + +#define SIP_SVC_VERSION SMC_SIP_FUNCTION_ID(1) +#define SIP_SVC_GET_GIC SMC_SIP_FUNCTION_ID(100) +#define SIP_SVC_GET_GIC_ITS SMC_SIP_FUNCTION_ID(101) +#define SIP_SVC_GET_CPU_COUNT SMC_SIP_FUNCTION_ID(200) +#define SIP_SVC_GET_CPU_NODE SMC_SIP_FUNCTION_ID(201) +#define SIP_SVC_GET_MEMORY_NODE_COUNT SMC_SIP_FUNCTION_ID(300) +#define SIP_SVC_GET_MEMORY_NODE SMC_SIP_FUNCTION_ID(301) + +int smc_get_mpidr(unsigned long id, u64 *mpidr) +{ + struct arm_smccc_res res; + + res.a0 = ~0; + arm_smccc_smc(SIP_SVC_GET_CPU_NODE, id, 0, 0, 0, 0, 0, 0, &res); + + if (!res.a0) + *mpidr = res.a2; + + return res.a0; +} + +int smc_get_gic_dist_base(u64 *base) +{ + struct arm_smccc_res res; + + res.a0 = ~0; + arm_smccc_smc(SIP_SVC_GET_GIC, 0, 0, 0, 0, 0, 0, 0, &res); + + if (!res.a0) + *base = res.a1; + + return res.a0; +} + +int smc_get_gic_redist_base(u64 *base) +{ + struct arm_smccc_res res; + + res.a0 = ~0; + arm_smccc_smc(SIP_SVC_GET_GIC, 0, 0, 0, 0, 0, 0, 0, &res); + + if (!res.a0) + *base = res.a2; + + return res.a0; +} + +int smc_get_gic_its_base(u64 *base) +{ + struct arm_smccc_res res; + + res.a0 = ~0; + arm_smccc_smc(SIP_SVC_GET_GIC_ITS, 0, 0, 0, 0, 0, 0, 0, &res); + + if (!res.a0) + *base = res.a1; + + return res.a0; +} diff --git a/configs/qemu-arm-sbsa_defconfig b/configs/qemu-arm-sbsa_defconfig new file mode 100644 index 0000000000..a58c3dec4c --- /dev/null +++ b/configs/qemu-arm-sbsa_defconfig @@ -0,0 +1,10 @@ +CONFIG_ARM=y +CONFIG_ARCH_QEMU=y +CONFIG_TARGET_QEMU_ARM_SBSA=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="bootflow scan" +CONFIG_EFI_PARTITION=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_EFI_MEDIA=y +CONFIG_FS_FAT=y +CONFIG_EFI_VARIABLE_NO_STORE=y diff --git a/doc/board/emulation/index.rst b/doc/board/emulation/index.rst index 98a0b26ad2..0419d72415 100644 --- a/doc/board/emulation/index.rst +++ b/doc/board/emulation/index.rst @@ -13,5 +13,6 @@ Emulation qemu-mips qemu-ppce500 qemu-riscv + qemu-sbsa qemu-x86 qemu-xtensa diff --git a/doc/board/emulation/qemu-sbsa.rst b/doc/board/emulation/qemu-sbsa.rst new file mode 100644 index 0000000000..fe1dc3249e --- /dev/null +++ b/doc/board/emulation/qemu-sbsa.rst @@ -0,0 +1,98 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2024, Patrick Rudolph patrick.rudolph@9elements.com + +QEMU ARM SBSA +============= + +QEMU for ARM supports Arm Server Base System Architecture Reference board, +short 'sbsa-ref' that utilizes ACPI over FDT. This document describes how to run +U-Boot under it. Only AArch64 is supported. + +The 'sbsa' platform provides the following as the basic functionality: + + - A freely configurable amount of CPU cores + - U-Boot loaded and executing in the emulated flash at address 0x10000000 + - No device tree blob + - A freely configurable amount of RAM + - A PL011 serial port + - An ARMv7/ARMv8 architected timer + - PSCI for rebooting the system + - A generic ECAM-based PCI host controller + +Additionally, a number of optional peripherals can be added to the PCI bus. + +Compile ARM Trusted Firmware (ATF) +---------------------------------- + +Get and Build the ARM Trusted firmware +-------------------------------------- + +Note: srctree is U-Boot source directory +Get ATF from: https://github.com/ARM-software/arm-trusted-firmware + +.. code-block:: bash + + git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git tfa + cd tfa + make CROSS_COMPILE=aarch64-linux-gnu- all fip \ + ARM_LINUX_KERNEL_AS_BL33=1 DEBUG=1 PLAT=qemu_sbsa + +Copy the resulting FIP and BL1 binary + +.. code-block:: bash + + cp build/qemu_sbsa/debug/fip.bin ../ + cp build/qemu_sbsa/debug/bl1.bin ../ + +Building U-Boot +--------------- +Set the CROSS_COMPILE environment variable as usual, and run: + +.. code-block:: bash + + make qemu-arm-sbsa_defconfig + make + +Running U-Boot +-------------- +The minimal QEMU command line to get U-Boot up and running is: + +.. code-block:: bash + + qemu-system-aarch64 -machine sbsa-ref -nographic -cpu cortex-a57 \ + -pflash secure-world.rom \ + -pflash unsecure-world.rom + +Note that for some odd reason qemu-system-aarch64 needs to be explicitly +told to use a 64-bit CPU or it will boot in 32-bit mode. The -nographic argument +ensures that output appears on the terminal. Use Ctrl-A X to quit. + +Booting distros +--------------- + +It is possible to install and boot a standard Linux distribution using +sbsa by setting up a root disk:: + +.. code-block:: bash + + qemu-img create root.img 20G + +then using the installer to install. For example, with Debian 12:: + +.. code-block:: bash + + qemu-system-aarch64 \ + -machine sbsa-ref -cpu cortex-a57 -m 4G -smp 4 \ + -pflash secure-world.rom \ + -pflash unsecure-world.rom \ + -device virtio-rng-pci \ + -device usb-kbd -device usb-tablet \ + -cdrom debian-12.0.0-arm64-netinst.iso \ + -hda root.img + +Debug UART +---------- + +The debug UART on the ARM sbsa board uses these settings:: + + CONFIG_DEBUG_UART=y diff --git a/doc/develop/driver-model/virtio.rst b/doc/develop/driver-model/virtio.rst index 8ac9c94caf..31b94d0467 100644 --- a/doc/develop/driver-model/virtio.rst +++ b/doc/develop/driver-model/virtio.rst @@ -34,6 +34,7 @@ The following QEMU targets are supported.
- qemu_arm_defconfig - qemu_arm64_defconfig + - qemu-arm-sbsa_defconfig - qemu-riscv32_defconfig - qemu-riscv64_defconfig - qemu-x86_defconfig diff --git a/include/configs/qemu-sbsa.h b/include/configs/qemu-sbsa.h new file mode 100644 index 0000000000..aff78160e1 --- /dev/null +++ b/include/configs/qemu-sbsa.h @@ -0,0 +1,89 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024 9elements GmbH + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Physical memory map */ + +/* SECURE_FLASH */ +#define SBSA_SECURE_FLASH_BASE_ADDR 0x00000000 +#define SBSA_SECURE_FLASH_LENGTH 0x10000000 + +/* FLASH */ +#define SBSA_FLASH_BASE_ADDR 0x10000000 +#define SBSA_FLASH_LENGTH 0x10000000 + +/* PERIPH */ +#define SBSA_PERIPH_BASE_ADDR 0x40000000 + +/* GIC_DIST */ +#define SBSA_GIC_DIST_BASE_ADDR 0x40060000 +#define SBSA_GIC_DIST_LENGTH 0x00020000 + +#define SBSA_GIC_VBASE_ADDR 0x2c020000 +#define SBSA_GIC_VBASE_LENGTH 0x00010000 + +#define SBSA_GIC_HBASE_ADDR 0x2c010000 +#define SBSA_GIC_HBASE_LENGTH 0x00010000 + +/* GIC_REDIST */ +#define SBSA_GIC_REDIST_BASE_ADDR 0x40080000 +#define SBSA_GIC_REDIST_LENGTH 0x04000000 + +/* GIC_ITS */ +#define SBSA_GIC_ITS_BASE_ADDR 0x44081000 + +/* UART */ +#define SBSA_UART_BASE_ADDR 0x60000000 +#define SBSA_UART_LENGTH 0x00001000 + +/* SMMU */ +#define SBSA_SMMU_BASE_ADDR 0x60050000 + +/* SATA */ +#define SBSA_AHCI_BASE_ADDR 0x60100000 +#define SBSA_AHCI_LENGTH 0x00010000 + +/* xHCI */ +#define SBSA_XHCI_BASE_ADDR 0x60110000 +#define SBSA_XHCI_LENGTH 0x00010000 + +/* PIO */ +#define SBSA_PIO_BASE_ADDR 0x7fff0000 +#define SBSA_PIO_LENGTH 0x00010000 + +/* PCIE_MMIO */ +#define SBSA_PCIE_MMIO_BASE_ADDR 0x80000000 +#define SBSA_PCIE_MMIO_LENGTH 0x70000000 +#define SBSA_PCIE_MMIO_END 0xefffffff + +/* PCIE_ECAM */ +#define SBSA_PCIE_ECAM_BASE_ADDR 0xf0000000 +#define SBSA_PCIE_ECAM_LENGTH 0x10000000 +#define SBSA_PCIE_ECAM_END 0xffffffff + +/* PCIE_MMIO_HIGH */ +#ifdef __ACPI__ +#define SBSA_PCIE_MMIO_HIGH_BASE_ADDR 0x100000000 +#define SBSA_PCIE_MMIO_HIGH_LENGTH 0xFF00000000 +#define SBSA_PCIE_MMIO_HIGH_END 0xFFFFFFFFFF +#else +#define SBSA_PCIE_MMIO_HIGH_BASE_ADDR 0x100000000ULL +#define SBSA_PCIE_MMIO_HIGH_LENGTH 0xFF00000000ULL +#define SBSA_PCIE_MMIO_HIGH_END 0xFFFFFFFFFFULL +#endif + +/* MEM */ +#ifdef __ACPI__ +#define SBSA_MEM_BASE_ADDR 0x10000000000 +#else +#define SBSA_MEM_BASE_ADDR 0x10000000000ULL +#endif + +#define CFG_SYS_INIT_RAM_ADDR SBSA_MEM_BASE_ADDR +#define CFG_SYS_INIT_RAM_SIZE 0x1000000 + +#endif /* __CONFIG_H */
On Wed, 16 Oct 2024 at 00:13, Patrick Rudolph patrick.rudolph@9elements.com wrote:
- serial
- PCI
- xHCI
- Bochs display
- AHCI
- CPU init
- Booting Fedora 40
Changelog v3:
Changelog v4:
Changelog v5:
Changelog v6:
- select BINMAN_FDT
Changelog v8:
Changelog v9:
- Select BLOBLIST
Cover the "ARM local MMIO" range as well in the default MMU mapping in order to allow future code to access the GIC-400 without crashing. For now the GIC is not touched in u-boot, thus this change is a noop.
See [1](BCM2711 ARM Peripherals) for reference.
TEST: Enabled CONFIG_GICV2 and accessed the GIC in C code without crash.
1: https://datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Matthias Brugger mbrugger@suse.com Cc: Matthias Brugger mbrugger@suse.com Cc: Peter Robinson pbrobinson@gmail.com --- arch/arm/mach-bcm283x/init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 1b459707bc..7a1de22e0a 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -50,7 +50,7 @@ static struct mm_region bcm2711_mem_map[MEM_MAP_MAX_ENTRIES] = { }, { .virt = 0xfc000000UL, .phys = 0xfc000000UL, - .size = 0x03800000UL, + .size = 0x04000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN
These header files presumably duplicate things already in the U-Boot devicetree. For now, bring them in to get the ASL code and ACPI table code to compile.
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Matthias Brugger mbrugger@suse.com Cc: Matthias Brugger mbrugger@suse.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Tom Rini trini@konsulko.com --- .../mach-bcm283x/include/mach/acpi/bcm2711.h | 152 ++++++++++++++++++ .../mach-bcm283x/include/mach/acpi/bcm2836.h | 127 +++++++++++++++ .../include/mach/acpi/bcm2836_gpio.h | 19 +++ .../include/mach/acpi/bcm2836_gpu.h | 47 ++++++ .../include/mach/acpi/bcm2836_pwm.h | 33 ++++ .../include/mach/acpi/bcm2836_sdhost.h | 18 +++ .../include/mach/acpi/bcm2836_sdio.h | 21 +++ drivers/pci/pcie_brcmstb.c | 101 ++---------- 8 files changed, 427 insertions(+), 91 deletions(-) create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2711.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpio.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpu.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_pwm.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdhost.h create mode 100644 arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdio.h
diff --git a/arch/arm/mach-bcm283x/include/mach/acpi/bcm2711.h b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2711.h new file mode 100644 index 0000000000..a86875b183 --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2711.h @@ -0,0 +1,152 @@ +/* SPDX-License-Identifier: BSD-2-Clause-Patent */ +/** + * + * Copyright (c) 2019, Jeremy Linton + * Copyright (c) 2019, Pete Batard pete@akeo.ie. + * + **/ + +#ifndef BCM2711_H__ +#define BCM2711_H__ + +#define BCM2711_SOC_REGISTERS 0xfc000000 +#define BCM2711_SOC_REGISTER_LENGTH 0x02000000 + +#define BCM2711_ARM_LOCAL_REGISTERS 0xfe000000 +#define BCM2711_ARM_LOCAL_REGISTER_LENGTH 0x02000000 + +/* arm local addresses */ +#define BCM2711_ARMC_OFFSET 0x0000b000 +#define BCM2711_ARMC_BASE_ADDRESS (BCM2711_ARM_LOCAL_REGISTERS + BCM2711_ARMC_OFFSET) +#define BCM2711_ARMC_LENGTH 0x00000400 + +#define BCM2711_ARM_LOCAL_OFFSET 0x01800000 +#define BCM2711_ARM_LOCAL_BASE_ADDRESS (BCM2711_ARM_LOCAL_REGISTERS + BCM2711_ARM_LOCAL_OFFSET) +#define BCM2711_ARM_LOCAL_LENGTH 0x00000080 + +#define BCM2711_GIC400_OFFSET 0x01840000 +#define BCM2711_GIC400_BASE_ADDRESS (BCM2711_ARM_LOCAL_REGISTERS + BCM2711_GIC400_OFFSET) +#define BCM2711_GIC400_LENGTH 0x00008000 + +/* Generic PCI addresses */ +#define PCIE_TOP_OF_MEM_WIN 0xf8000000 +#define PCIE_CPU_MMIO_WINDOW 0x600000000 +#define PCIE_BRIDGE_MMIO_LEN 0x3ffffff + +/* PCI root bridge control registers location */ +#define PCIE_REG_BASE 0xfd500000 +#define PCIE_REG_LIMIT 0x9310 + +/* PCI root bridge control registers */ +#define BRCM_PCIE_CAP_REGS 0x00ac +#define PCIE_RC_CFG_VENDOR_VENDOR_SPECIFIC_REG1 0x0188 +#define VENDOR_SPECIFIC_REG1_LITTLE_ENDIAN 0x0 +#define PCIE_RC_CFG_PRIV1_ID_VAL3 0x043c +#define PCIE_RC_CFG_PRIV1_LINK_CAPABILITY 0x04dc +#define LINK_CAPABILITY_ASPM_SUPPORT_MASK 0xc00 + +#define PCIE_RC_DL_MDIO_ADDR 0x1100 +#define PCIE_RC_DL_MDIO_WR_DATA 0x1104 +#define PCIE_RC_DL_MDIO_RD_DATA 0x1108 + +#define PCIE_MISC_MISC_CTRL 0x4008 +#define MISC_CTRL_SCB_ACCESS_EN_MASK 0x1000 +#define MISC_CTRL_CFG_READ_UR_MODE_MASK 0x2000 +#define MISC_CTRL_MAX_BURST_SIZE_MASK 0x300000 +#define MISC_CTRL_MAX_BURST_SIZE_128 0x0 +#define MISC_CTRL_SCB0_SIZE_MASK 0xf8000000 + +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LO 0x400c +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_HI 0x4010 +#define PCIE_MEM_WIN0_LO(win) \ + PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LO + ((win) * 4) + +#define PCIE_MEM_WIN0_HI(win) \ + PCIE_MISC_CPU_2_PCIE_MEM_WIN0_HI + ((win) * 4) +#define PCIE_MISC_RC_BAR1_CONFIG_LO 0x402c +#define RC_BAR1_CONFIG_LO_SIZE_MASK 0x1f +#define PCIE_MISC_RC_BAR2_CONFIG_LO 0x4034 +#define RC_BAR2_CONFIG_LO_SIZE_MASK 0x1f +#define PCIE_MISC_RC_BAR2_CONFIG_HI 0x4038 +#define PCIE_MISC_RC_BAR3_CONFIG_LO 0x403c +#define RC_BAR3_CONFIG_LO_SIZE_MASK 0x1f +#define PCIE_MISC_PCIE_STATUS 0x4068 +#define STATUS_PCIE_PORT_MASK 0x80 +#define STATUS_PCIE_PORT_SHIFT 7 +#define STATUS_PCIE_DL_ACTIVE_MASK 0x20 +#define STATUS_PCIE_DL_ACTIVE_SHIFT 5 +#define STATUS_PCIE_PHYLINKUP_MASK 0x10 +#define STATUS_PCIE_PHYLINKUP_SHIFT 4 +#define PCIE_MISC_REVISION 0x406c +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_LIMIT 0x4070 +#define MEM_WIN0_BASE_LIMIT_LIMIT_MASK 0xfff00000 +#define MEM_WIN0_BASE_LIMIT_BASE_MASK 0xfff0 +#define MEM_WIN0_BASE_LIMIT_BASE_HI_SHIFT 12 +#define PCIE_MEM_WIN0_BASE_LIMIT(win) \ + PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_LIMIT + ((win) * 4) +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_HI 0x4080 +#define MEM_WIN0_BASE_HI_BASE_MASK 0xff +#define PCIE_MEM_WIN0_BASE_HI(win) \ + PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_HI + ((win) * 8) +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LIMIT_HI 0x4084 +#define PCIE_MEM_WIN0_LIMIT_HI_LIMIT_MASK 0xff +#define PCIE_MEM_WIN0_LIMIT_HI(win) \ + PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LIMIT_HI + ((win) * 8) + +#define PCIE_MISC_HARD_PCIE_HARD_DEBUG 0x4204 +#define PCIE_HARD_DEBUG_SERDES_IDDQ_MASK 0x08000000 + +#define PCIE_INTR2_CPU_STATUS 0x4300 +#define PCIE_INTR2_CPU_SET 0x4304 +#define PCIE_INTR2_CPU_CLR 0x4308 +#define PCIE_INTR2_CPU_MASK_STATUS 0x430c +#define PCIE_INTR2_CPU_MASK_SET 0x4310 +#define PCIE_INTR2_CPU_MASK_CLR 0x4314 + +#define PCIE_MSI_INTR2_CLR 0x4508 +#define PCIE_MSI_INTR2_MASK_SET 0x4510 + +#define PCIE_RGR1_SW_INIT_1 0x9210 +#define PCIE_EXT_CFG_INDEX 0x9000 +/* A small window pointing at the ECAM of the device selected by CFG_INDEX */ +#define PCIE_EXT_CFG_DATA 0x8000 + +#define PCIE_RC_CFG_VENDOR_VENDOR_SPECIFIC_REG1_ENDIAN_MODE_BAR2_MASK 0xc +#define PCIE_RC_CFG_PRIV1_ID_VAL3_CLASS_CODE_MASK 0xffffff + +#define PCIE_MISC_MISC_CTRL_SCB_ACCESS_EN_MASK 0x1000 +#define PCIE_MISC_MISC_CTRL_CFG_READ_UR_MODE_MASK 0x2000 +#define PCIE_MISC_MISC_CTRL_MAX_BURST_SIZE_MASK 0x300000 +#define PCIE_MISC_MISC_CTRL_SCB0_SIZE_MASK 0xf8000000 +#define PCIE_MISC_MISC_CTRL_SCB1_SIZE_MASK 0x7c00000 +#define PCIE_MISC_MISC_CTRL_SCB2_SIZE_MASK 0x1f +#define PCIE_MISC_RC_BAR2_CONFIG_LO_SIZE_MASK 0x1f + +#define PCIE_RGR1_SW_INIT_1_INIT_MASK 0x2 +#define PCIE_RGR1_SW_INIT_1_PERST_MASK 0x1 + +#define PCIE_MISC_HARD_PCIE_HARD_DEBUG_SERDES_IDDQ_MASK 0x08000000 + +#define PCIE_MISC_HARD_PCIE_HARD_DEBUG_CLKREQ_DEBUG_ENABLE_MASK 0x2 + +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_LIMIT_LIMIT_MASK 0xfff00000 +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_LIMIT_BASE_MASK 0xfff0 +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_HI_BASE_MASK 0xff +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LIMIT_HI_LIMIT_MASK 0xff +#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_MASK_BITS 0xc + +#define PCIE_MISC_REVISION_MAJMIN_MASK 0xffff + +#define BURST_SIZE_128 0 +#define BURST_SIZE_256 1 +#define BURST_SIZE_512 2 + +#define BCM2711_THERM_SENSOR_OFFSET 0x015d2200 +#define BCM2711_THERM_SENSOR_BASE_ADDRESS (BCM2711_SOC_REGISTERS + BCM2711_THERM_SENSOR_OFFSET) +#define BCM2711_THERM_SENSOR_LENGTH 0x00000008 + +#define BCM2711_GENET_BASE_OFFSET 0x01580000 +#define BCM2711_GENET_BASE_ADDRESS (BCM2711_SOC_REGISTERS + BCM2711_GENET_BASE_OFFSET) +#define BCM2711_GENET_LENGTH 0x10000 + +#endif /* BCM2711_H__ */ diff --git a/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836.h b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836.h new file mode 100644 index 0000000000..64cec36a94 --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836.h @@ -0,0 +1,127 @@ +/* SPDX-License-Identifier: BSD-2-Clause-Patent */ +/** + * + * Copyright (c) 2019, ARM Limited. All rights reserved. + * Copyright (c) 2017, Andrei Warkentin andrey.warkentin@gmail.com + * Copyright (c) 2016, Linaro Limited. All rights reserved. + * + **/ + +#ifndef __BCM2836_H__ +#define __BCM2836_H__ + +/* + * Both "core" and SoC perpherals (1M each). + */ +#define BCM2836_SOC_REGISTERS 0xfe000000 +#define BCM2836_SOC_REGISTER_LENGTH 0x02000000 + +/* + * Offset between the CPU's view and the VC's view of system memory. + */ +#define BCM2836_DMA_DEVICE_OFFSET 0xc0000000 + +/* watchdog constants */ +#define BCM2836_WDOG_OFFSET 0x00100000 +#define BCM2836_WDOG_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_WDOG_OFFSET) +#define BCM2836_WDOG_PASSWORD 0x5a000000 +#define BCM2836_WDOG_RSTC_OFFSET 0x0000001c +#define BCM2836_WDOG_WDOG_OFFSET 0x00000024 +#define BCM2836_WDOG_RSTC_WRCFG_MASK 0x00000030 +#define BCM2836_WDOG_RSTC_WRCFG_FULL_RESET 0x00000020 + +/* clock manager constants */ +#define BCM2836_CM_OFFSET 0x00101000 +#define BCM2836_CM_BASE (BCM2836_SOC_REGISTERS + BCM2836_CM_OFFSET) +#define BCM2836_CM_GEN_CLOCK_CONTROL 0x0000 +#define BCM2836_CM_GEN_CLOCK_DIVISOR 0x0004 +#define BCM2836_CM_VPU_CLOCK_CONTROL 0x0008 +#define BCM2836_CM_VPU_CLOCK_DIVISOR 0x000c +#define BCM2836_CM_SYSTEM_CLOCK_CONTROL 0x0010 +#define BCM2836_CM_SYSTEM_CLOCK_DIVISOR 0x0014 +#define BCM2836_CM_H264_CLOCK_CONTROL 0x0028 +#define BCM2836_CM_H264_CLOCK_DIVISOR 0x002c +#define BCM2836_CM_PWM_CLOCK_CONTROL 0x00a0 +#define BCM2836_CM_PWM_CLOCK_DIVISOR 0x00a4 +#define BCM2836_CM_UART_CLOCK_CONTROL 0x00f0 +#define BCM2836_CM_UART_CLOCK_DIVISOR 0x00f4 +#define BCM2836_CM_SDC_CLOCK_CONTROL 0x01a8 +#define BCM2836_CM_SDC_CLOCK_DIVISOR 0x01ac +#define BCM2836_CM_ARM_CLOCK_CONTROL 0x01b0 +#define BCM2836_CM_ARM_CLOCK_DIVISOR 0x01b4 +#define BCM2836_CM_EMMC_CLOCK_CONTROL 0x01c0 +#define BCM2836_CM_EMMC_CLOCK_DIVISOR 0x01c4 + +/* mailbox interface constants */ +#define BCM2836_MBOX_OFFSET 0x0000b880 +#define BCM2836_MBOX_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_MBOX_OFFSET) +#define BCM2836_MBOX_LENGTH 0x00000024 +#define BCM2836_MBOX_READ_OFFSET 0x00000000 +#define BCM2836_MBOX_STATUS_OFFSET 0x00000018 +#define BCM2836_MBOX_CONFIG_OFFSET 0x0000001c +#define BCM2836_MBOX_WRITE_OFFSET 0x00000020 + +#define BCM2836_MBOX_STATUS_FULL 0x1f +#define BCM2836_MBOX_STATUS_EMPTY 0x1e + +#define BCM2836_MBOX_NUM_CHANNELS 16 + +/* interrupt controller constants */ +#define BCM2836_INTC_TIMER_CONTROL_OFFSET 0x00000040 +#define BCM2836_INTC_TIMER_PENDING_OFFSET 0x00000060 + +/* usb constants */ +#define BCM2836_USB_OFFSET 0x00980000 +#define BCM2836_USB_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_USB_OFFSET) +#define BCM2836_USB_LENGTH 0x00010000 + +/* serial based protocol constants */ +#define BCM2836_PL011_UART_OFFSET 0x00201000 +#define BCM2836_PL011_UART_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_PL011_UART_OFFSET) +#define BCM2836_PL011_UART_LENGTH 0x00001000 + +#define BCM2836_MINI_UART_OFFSET 0x00215000 +#define BCM2836_MINI_UART_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_MINI_UART_OFFSET) +#define BCM2836_MINI_UART_LENGTH 0x00000070 + +#define BCM2836_I2C0_OFFSET 0x00205000 +#define BCM2836_I2C0_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_I2C0_OFFSET) +#define BCM2836_I2C0_LENGTH 0x00000020 + +#define BCM2836_I2C1_OFFSET 0x00804000 +#define BCM2836_I2C1_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_I2C1_OFFSET) +#define BCM2836_I2C1_LENGTH 0x00000020 + +#define BCM2836_I2C2_OFFSET 0x00805000 +#define BCM2836_I2C2_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_I2C2_OFFSET) +#define BCM2836_I2C2_LENGTH 0x00000020 + +#define BCM2836_SPI0_OFFSET 0x00204000 +#define BCM2836_SPI0_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_SPI0_OFFSET) +#define BCM2836_SPI0_LENGTH 0x00000020 + +#define BCM2836_SPI1_OFFSET 0x00215080 +#define BCM2836_SPI1_LENGTH 0x00000040 +#define BCM2836_SPI1_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_SPI1_OFFSET) + +#define BCM2836_SPI2_OFFSET 0x002150C0 +#define BCM2836_SPI2_LENGTH 0x00000040 +#define BCM2836_SPI2_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_SPI2_OFFSET) + +#define BCM2836_SYSTEM_TIMER_OFFSET 0x00003000 +#define BCM2836_SYSTEM_TIMER_LENGTH 0x00000020 +#define BCM2836_SYSTEM_TIMER_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_SYSTEM_TIMER_OFFSET) + +/* dma constants */ +#define BCM2836_DMA0_OFFSET 0x00007000 +#define BCM2836_DMA0_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_DMA0_OFFSET) + +#define BCM2836_DMA15_OFFSET 0x00E05000 +#define BCM2836_DMA15_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_DMA15_OFFSET) + +#define BCM2836_DMA_CTRL_OFFSET 0x00007FE0 +#define BCM2836_DMA_CTRL_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_DMA_CTRL_OFFSET) + +#define BCM2836_DMA_CHANNEL_LENGTH 0x00000100 + +#endif /*__BCM2836_H__ */ diff --git a/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpio.h b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpio.h new file mode 100644 index 0000000000..c5b858b412 --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpio.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: BSD-2-Clause-Patent */ +/** + * + * Copyright (c) 2020, Pete Batard pete@akeo.ie + * Copyright (c) 2018, Andrei Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + **/ + +#include <asm/arch/acpi/bcm2836.h> + +#ifndef __BCM2836_GPIO_H__ +#define __BCM2836_GPIO_H__ + +#define GPIO_OFFSET 0x00200000 +#define GPIO_BASE_ADDRESS (BCM2836_SOC_REGISTERS + GPIO_OFFSET) +#define GPIO_LENGTH 0x000000B4 + +#endif /* __BCM2836_GPIO_H__ */ diff --git a/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpu.h b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpu.h new file mode 100644 index 0000000000..5857d7581a --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_gpu.h @@ -0,0 +1,47 @@ +/* SPDX-License-Identifier: BSD-2-Clause-Patent */ +/** + * + * Copyright (c) 2020, Pete Batard pete@akeo.ie + * + **/ + +#include <asm/arch/acpi/bcm2836.h> + +#ifndef __BCM2836_GPU_H__ +#define __BCM2836_GPU_H__ + +/* VideoCore constants */ + +#define BCM2836_VCHIQ_OFFSET 0x0000B840 +#define BCM2836_VCHIQ_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_VCHIQ_OFFSET) +#define BCM2836_VCHIQ_LENGTH 0x00000010 + +#define BCM2836_V3D_BUS_OFFSET 0x00C00000 +#define BCM2836_V3D_BUS_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_V3D_BUS_OFFSET) +#define BCM2836_V3D_BUS_LENGTH 0x00001000 + +#define BCM2836_HVS_OFFSET 0x00400000 +#define BCM2836_HVS_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_HVS_OFFSET) +#define BCM2836_HVS_LENGTH 0x00006000 + +#define BCM2836_PV0_OFFSET 0x00206000 +#define BCM2836_PV0_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_PV0_OFFSET) +#define BCM2836_PV0_LENGTH 0x00000100 + +#define BCM2836_PV1_OFFSET 0x00207000 +#define BCM2836_PV1_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_PV1_OFFSET) +#define BCM2836_PV1_LENGTH 0x00000100 + +#define BCM2836_PV2_OFFSET 0x00807000 +#define BCM2836_PV2_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_PV2_OFFSET) +#define BCM2836_PV2_LENGTH 0x00000100 + +#define BCM2836_HDMI0_OFFSET 0x00902000 +#define BCM2836_HDMI0_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_HDMI0_OFFSET) +#define BCM2836_HDMI0_LENGTH 0x00000600 + +#define BCM2836_HDMI1_OFFSET 0x00808000 +#define BCM2836_HDMI1_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_HDMI1_OFFSET) +#define BCM2836_HDMI1_LENGTH 0x00000100 + +#endif /* __BCM2836_MISC_H__ */ diff --git a/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_pwm.h b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_pwm.h new file mode 100644 index 0000000000..78a8486673 --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_pwm.h @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: BSD-2-Clause-Patent */ +/** + * + * Copyright (c) 2020, Pete Batard pete@akeo.ie + * + **/ + +#include <asm/arch/acpi/bcm2836.h> + +#ifndef __BCM2836_PWM_H__ +#define __BCM2836_PWM_H__ + +/* PWM controller constants */ + +#define BCM2836_PWM_DMA_OFFSET 0x00007B00 +#define BCM2836_PWM_DMA_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_PWM_DMA_OFFSET) +#define BCM2836_PWM_DMA_LENGTH 0x00000100 + +#define BCM2836_PWM_CLK_OFFSET 0x001010A0 +#define BCM2836_PWM_CLK_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_PWM_CLK_OFFSET) +#define BCM2836_PWM_CLK_LENGTH 0x00000008 + +#define BCM2836_PWM_CTRL_OFFSET 0x0020C000 +#define BCM2836_PWM_CTRL_BASE_ADDRESS (BCM2836_SOC_REGISTERS + BCM2836_PWM_CTRL_OFFSET) +#define BCM2836_PWM_CTRL_LENGTH 0x00000028 + +#define BCM2836_PWM_BUS_BASE_ADDRESS 0x7E20C000 +#define BCM2836_PWM_BUS_LENGTH 0x00000028 + +#define BCM2836_PWM_CTRL_UNCACHED_BASE_ADDRESS 0xFF20C000 +#define BCM2836_PWM_CTRL_UNCACHED_LENGTH 0x00000028 + +#endif /* __BCM2836_PWM_H__ */ diff --git a/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdhost.h b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdhost.h new file mode 100644 index 0000000000..9b1afe8440 --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdhost.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: BSD-2-Clause-Patent */ +/** + * + * Copyright (c) 2017, Andrei Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + **/ + +#include <asm/arch/acpi/bcm2836.h> + +#ifndef __BCM2836_SDHOST_H__ +#define __BCM2836_SDHOST_H__ + +#define SDHOST_OFFSET 0x00202000 +#define SDHOST_BASE_ADDRESS (BCM2836_SOC_REGISTERS + SDHOST_OFFSET) +#define SDHOST_LENGTH 0x00000100 + +#endif /*__BCM2836_SDHOST_H__ */ diff --git a/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdio.h b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdio.h new file mode 100644 index 0000000000..48d073d434 --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/acpi/bcm2836_sdio.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: BSD-2-Clause-Patent */ +/** + * + * Copyright (c) Microsoft Corporation. All rights reserved. + * + **/ + +#include <asm/arch/acpi/bcm2836.h> + +#ifndef __BCM2836_SDIO_H__ +#define __BCM2836_SDIO_H__ + +// MMC/SD/SDIO1 register definitions. +#define MMCHS1_OFFSET 0x00300000 +#define MMCHS2_OFFSET 0x00340000 +#define MMCHS1_BASE (BCM2836_SOC_REGISTERS + MMCHS1_OFFSET) +#define MMCHS2_BASE (BCM2836_SOC_REGISTERS + MMCHS2_OFFSET) +#define MMCHS1_LENGTH 0x00000100 +#define MMCHS2_LENGTH 0x00000100 + +#endif /* __BCM2836_SDIO_H__ */ diff --git a/drivers/pci/pcie_brcmstb.c b/drivers/pci/pcie_brcmstb.c index f978c64365..f089c48f02 100644 --- a/drivers/pci/pcie_brcmstb.c +++ b/drivers/pci/pcie_brcmstb.c @@ -12,6 +12,7 @@ * Copyright (C) 2020 Nicolas Saenz Julienne nsaenzjulienne@suse.de */
+#include <asm/arch/acpi/bcm2711.h> #include <errno.h> #include <dm.h> #include <dm/ofnode.h> @@ -21,88 +22,6 @@ #include <linux/log2.h> #include <linux/iopoll.h>
-/* Offset of the mandatory PCIe capability config registers */ -#define BRCM_PCIE_CAP_REGS 0x00ac - -/* The PCIe controller register offsets */ -#define PCIE_RC_CFG_VENDOR_SPECIFIC_REG1 0x0188 -#define VENDOR_SPECIFIC_REG1_ENDIAN_MODE_BAR2_MASK 0xc -#define VENDOR_SPECIFIC_REG1_LITTLE_ENDIAN 0x0 - -#define PCIE_RC_CFG_PRIV1_ID_VAL3 0x043c -#define CFG_PRIV1_ID_VAL3_CLASS_CODE_MASK 0xffffff - -#define PCIE_RC_CFG_PRIV1_LINK_CAPABILITY 0x04dc -#define PCIE_RC_CFG_PRIV1_LINK_CAPABILITY_ASPM_SUPPORT_MASK 0xc00 - -#define PCIE_RC_DL_MDIO_ADDR 0x1100 -#define PCIE_RC_DL_MDIO_WR_DATA 0x1104 -#define PCIE_RC_DL_MDIO_RD_DATA 0x1108 - -#define PCIE_MISC_MISC_CTRL 0x4008 -#define MISC_CTRL_SCB_ACCESS_EN_MASK 0x1000 -#define MISC_CTRL_CFG_READ_UR_MODE_MASK 0x2000 -#define MISC_CTRL_MAX_BURST_SIZE_MASK 0x300000 -#define MISC_CTRL_MAX_BURST_SIZE_128 0x0 -#define MISC_CTRL_SCB0_SIZE_MASK 0xf8000000 - -#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LO 0x400c -#define PCIE_MEM_WIN0_LO(win) \ - PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LO + ((win) * 4) - -#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_HI 0x4010 -#define PCIE_MEM_WIN0_HI(win) \ - PCIE_MISC_CPU_2_PCIE_MEM_WIN0_HI + ((win) * 4) - -#define PCIE_MISC_RC_BAR1_CONFIG_LO 0x402c -#define RC_BAR1_CONFIG_LO_SIZE_MASK 0x1f - -#define PCIE_MISC_RC_BAR2_CONFIG_LO 0x4034 -#define RC_BAR2_CONFIG_LO_SIZE_MASK 0x1f -#define PCIE_MISC_RC_BAR2_CONFIG_HI 0x4038 - -#define PCIE_MISC_RC_BAR3_CONFIG_LO 0x403c -#define RC_BAR3_CONFIG_LO_SIZE_MASK 0x1f - -#define PCIE_MISC_PCIE_STATUS 0x4068 -#define STATUS_PCIE_PORT_MASK 0x80 -#define STATUS_PCIE_PORT_SHIFT 7 -#define STATUS_PCIE_DL_ACTIVE_MASK 0x20 -#define STATUS_PCIE_DL_ACTIVE_SHIFT 5 -#define STATUS_PCIE_PHYLINKUP_MASK 0x10 -#define STATUS_PCIE_PHYLINKUP_SHIFT 4 - -#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_LIMIT 0x4070 -#define MEM_WIN0_BASE_LIMIT_LIMIT_MASK 0xfff00000 -#define MEM_WIN0_BASE_LIMIT_BASE_MASK 0xfff0 -#define MEM_WIN0_BASE_LIMIT_BASE_HI_SHIFT 12 -#define PCIE_MEM_WIN0_BASE_LIMIT(win) \ - PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_LIMIT + ((win) * 4) - -#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_HI 0x4080 -#define MEM_WIN0_BASE_HI_BASE_MASK 0xff -#define PCIE_MEM_WIN0_BASE_HI(win) \ - PCIE_MISC_CPU_2_PCIE_MEM_WIN0_BASE_HI + ((win) * 8) - -#define PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LIMIT_HI 0x4084 -#define PCIE_MEM_WIN0_LIMIT_HI_LIMIT_MASK 0xff -#define PCIE_MEM_WIN0_LIMIT_HI(win) \ - PCIE_MISC_CPU_2_PCIE_MEM_WIN0_LIMIT_HI + ((win) * 8) - -#define PCIE_MISC_HARD_PCIE_HARD_DEBUG 0x4204 -#define PCIE_HARD_DEBUG_SERDES_IDDQ_MASK 0x08000000 - -#define PCIE_MSI_INTR2_CLR 0x4508 -#define PCIE_MSI_INTR2_MASK_SET 0x4510 - -#define PCIE_EXT_CFG_DATA 0x8000 - -#define PCIE_EXT_CFG_INDEX 0x9000 - -#define PCIE_RGR1_SW_INIT_1 0x9210 -#define RGR1_SW_INIT_1_PERST_MASK 0x1 -#define RGR1_SW_INIT_1_INIT_MASK 0x2 - /* PCIe parameters */ #define BRCM_NUM_PCIE_OUT_WINS 4
@@ -447,7 +366,7 @@ static int brcm_pcie_probe(struct udevice *dev) * This will need to be changed when support for other SoCs is added. */ setbits_le32(base + PCIE_RGR1_SW_INIT_1, - RGR1_SW_INIT_1_INIT_MASK | RGR1_SW_INIT_1_PERST_MASK); + PCIE_RGR1_SW_INIT_1_INIT_MASK | PCIE_RGR1_SW_INIT_1_PERST_MASK); /* * The delay is a safety precaution to preclude the reset signal * from looking like a glitch. @@ -455,7 +374,7 @@ static int brcm_pcie_probe(struct udevice *dev) udelay(100);
/* Take the bridge out of reset */ - clrbits_le32(base + PCIE_RGR1_SW_INIT_1, RGR1_SW_INIT_1_INIT_MASK); + clrbits_le32(base + PCIE_RGR1_SW_INIT_1, PCIE_RGR1_SW_INIT_1_INIT_MASK);
clrbits_le32(base + PCIE_MISC_HARD_PCIE_HARD_DEBUG, PCIE_HARD_DEBUG_SERDES_IDDQ_MASK); @@ -508,7 +427,7 @@ static int brcm_pcie_probe(struct udevice *dev)
/* Unassert the fundamental reset */ clrbits_le32(pcie->base + PCIE_RGR1_SW_INIT_1, - RGR1_SW_INIT_1_PERST_MASK); + PCIE_RGR1_SW_INIT_1_PERST_MASK);
/* * Wait for 100ms after PERST# deassertion; see PCIe CEM specification @@ -552,7 +471,7 @@ static int brcm_pcie_probe(struct udevice *dev) * a PCIe-PCIe bridge (the default setting is to be EP mode). */ clrsetbits_le32(base + PCIE_RC_CFG_PRIV1_ID_VAL3, - CFG_PRIV1_ID_VAL3_CLASS_CODE_MASK, 0x060400); + PCIE_RC_CFG_PRIV1_ID_VAL3_CLASS_CODE_MASK, 0x060400);
if (pcie->ssc) { ret = brcm_pcie_set_ssc(pcie->base); @@ -570,8 +489,8 @@ static int brcm_pcie_probe(struct udevice *dev) nlw, ssc_good ? "(SSC)" : "(!SSC)");
/* PCIe->SCB endian mode for BAR */ - clrsetbits_le32(base + PCIE_RC_CFG_VENDOR_SPECIFIC_REG1, - VENDOR_SPECIFIC_REG1_ENDIAN_MODE_BAR2_MASK, + clrsetbits_le32(base + PCIE_RC_CFG_VENDOR_VENDOR_SPECIFIC_REG1, + PCIE_RC_CFG_VENDOR_VENDOR_SPECIFIC_REG1_ENDIAN_MODE_BAR2_MASK, VENDOR_SPECIFIC_REG1_LITTLE_ENDIAN);
/* @@ -584,7 +503,7 @@ static int brcm_pcie_probe(struct udevice *dev) * let's instead just unadvertise ASPM support. */ clrbits_le32(base + PCIE_RC_CFG_PRIV1_LINK_CAPABILITY, - PCIE_RC_CFG_PRIV1_LINK_CAPABILITY_ASPM_SUPPORT_MASK); + LINK_CAPABILITY_ASPM_SUPPORT_MASK);
return 0; } @@ -595,14 +514,14 @@ static int brcm_pcie_remove(struct udevice *dev) void __iomem *base = pcie->base;
/* Assert fundamental reset */ - setbits_le32(base + PCIE_RGR1_SW_INIT_1, RGR1_SW_INIT_1_PERST_MASK); + setbits_le32(base + PCIE_RGR1_SW_INIT_1, PCIE_RGR1_SW_INIT_1_PERST_MASK);
/* Turn off SerDes */ setbits_le32(base + PCIE_MISC_HARD_PCIE_HARD_DEBUG, PCIE_HARD_DEBUG_SERDES_IDDQ_MASK);
/* Shutdown bridge */ - setbits_le32(base + PCIE_RGR1_SW_INIT_1, RGR1_SW_INIT_1_INIT_MASK); + setbits_le32(base + PCIE_RGR1_SW_INIT_1, PCIE_RGR1_SW_INIT_1_INIT_MASK);
return 0; }
Generate SoC specific ACPI tables for BCM2711: - FADT - PPTT - GTDT
Board specific tables like DSDT and SSDT are added in a separate patch.
MADT is already properly generated from the FDT.
When ACPI is enabled for a different SoC compliation will fail by design, indicating the required functions that needs to be implemented. When ACPI is not enabled the added code does nothing, keeping existing behaviour.
TEST: Booted on RPi4 with only ACPI enabled, providing no FDT to the OS.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Matthias Brugger mbrugger@suse.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Tom Rini trini@konsulko.com --- Changelog v2: - Drop duplicated code to generate ACPI tables. Is now part of efi loader. Changelog v4: - Drop acpi_fill_madt() as it's now generated by drivers Changelog v6: - Update header order --- arch/arm/mach-bcm283x/Makefile | 4 + arch/arm/mach-bcm283x/bcm2711_acpi.c | 128 +++++++++++++++++++++++++++ 2 files changed, 132 insertions(+) create mode 100644 arch/arm/mach-bcm283x/bcm2711_acpi.c
diff --git a/arch/arm/mach-bcm283x/Makefile b/arch/arm/mach-bcm283x/Makefile index 7cd068832f..38e320307d 100644 --- a/arch/arm/mach-bcm283x/Makefile +++ b/arch/arm/mach-bcm283x/Makefile @@ -4,3 +4,7 @@
obj-$(CONFIG_BCM2835) += lowlevel_init.o obj-y += init.o reset.o mbox.o msg.o phys2bus.o + +ifeq ($(CONFIG_GENERATE_ACPI_TABLE),y) +obj-$(CONFIG_BCM2711) += bcm2711_acpi.o +endif \ No newline at end of file diff --git a/arch/arm/mach-bcm283x/bcm2711_acpi.c b/arch/arm/mach-bcm283x/bcm2711_acpi.c new file mode 100644 index 0000000000..79b283353c --- /dev/null +++ b/arch/arm/mach-bcm283x/bcm2711_acpi.c @@ -0,0 +1,128 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2024 9elements GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + */ + +#include <string.h> +#include <tables_csum.h> +#include <acpi/acpi_table.h> +#include <asm/acpi_table.h> +#include <asm/armv8/sec_firmware.h> +#include <asm/arch/acpi/bcm2711.h> +#include <dm/uclass.h> + +void acpi_fill_fadt(struct acpi_fadt *fadt) +{ + fadt->flags = ACPI_FADT_HW_REDUCED_ACPI | ACPI_FADT_LOW_PWR_IDLE_S0; + + if (CONFIG_IS_ENABLED(SEC_FIRMWARE_ARMV8_PSCI) && + sec_firmware_support_psci_version() != PSCI_INVALID_VER) + fadt->arm_boot_arch = ACPI_ARM_PSCI_COMPLIANT; +} + +#define L3_ATTRIBUTES (ACPI_PPTT_READ_ALLOC | ACPI_PPTT_WRITE_ALLOC | \ + (ACPI_PPTT_CACHE_TYPE_UNIFIED << \ + ACPI_PPTT_CACHE_TYPE_SHIFT)) +#define L3_SIZE 0x100000 +#define L3_SETS 0x400 +#define L3_WAYS 0x10 + +#define L1D_ATTRIBUTES (ACPI_PPTT_READ_ALLOC | ACPI_PPTT_WRITE_ALLOC | \ + (ACPI_PPTT_CACHE_TYPE_DATA << \ + ACPI_PPTT_CACHE_TYPE_SHIFT)) +#define L1D_SIZE 0x8000 +#define L1D_SETS 0x100 +#define L1D_WAYS 2 + +#define L1I_ATTRIBUTES (ACPI_PPTT_READ_ALLOC | \ + (ACPI_PPTT_CACHE_TYPE_INSTR << \ + ACPI_PPTT_CACHE_TYPE_SHIFT)) +#define L1I_SIZE 0xc000 +#define L1I_SETS 0x100 +#define L1I_WAYS 3 + +static int acpi_write_pptt(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_header *header; + int cluster_offset, l3_offset; + u32 offsets[2]; + + header = ctx->current; + ctx->tab_start = ctx->current; + + memset(header, '\0', sizeof(struct acpi_table_header)); + + acpi_fill_header(header, "PPTT"); + header->revision = acpi_get_table_revision(ACPITAB_PPTT); + acpi_inc(ctx, sizeof(*header)); + + l3_offset = acpi_pptt_add_cache(ctx, ACPI_PPTT_ALL_VALID, 0, L3_SIZE, + L3_SETS, L3_WAYS, L3_ATTRIBUTES, 64); + + cluster_offset = acpi_pptt_add_proc(ctx, ACPI_PPTT_PHYSICAL_PACKAGE | + ACPI_PPTT_CHILDREN_IDENTICAL, + 0, 0, 1, &l3_offset); + + offsets[0] = acpi_pptt_add_cache(ctx, ACPI_PPTT_ALL_VALID, 0, L1D_SIZE, + L1D_SETS, L1D_WAYS, L1D_ATTRIBUTES, 64); + + offsets[1] = acpi_pptt_add_cache(ctx, ACPI_PPTT_ALL_BUT_WRITE_POL, 0, + L1I_SIZE, L1I_SETS, L1I_WAYS, + L1I_ATTRIBUTES, 64); + + for (int i = 0; i < uclass_id_count(UCLASS_CPU); i++) { + acpi_pptt_add_proc(ctx, ACPI_PPTT_CHILDREN_IDENTICAL | + ACPI_PPTT_NODE_IS_LEAF | + ACPI_PPTT_PROC_ID_VALID, + cluster_offset, i, 2, offsets); + } + + header->length = ctx->current - ctx->tab_start; + header->checksum = table_compute_checksum(header, header->length); + + acpi_inc(ctx, header->length); + acpi_add_table(ctx, header); + + return 0; +}; + +ACPI_WRITER(5pptt, "PPTT", acpi_write_pptt, 0); + +static int rpi_write_gtdt(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_header *header; + struct acpi_gtdt *gtdt; + + gtdt = ctx->current; + header = >dt->header; + + memset(gtdt, '\0', sizeof(struct acpi_gtdt)); + + acpi_fill_header(header, "GTDT"); + header->length = sizeof(struct acpi_gtdt); + header->revision = acpi_get_table_revision(ACPITAB_GTDT); + + gtdt->cnt_ctrl_base = BCM2711_ARM_LOCAL_BASE_ADDRESS + 0x1c; + gtdt->sec_el1_gsiv = 29; + gtdt->sec_el1_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->el1_gsiv = 30; + gtdt->el1_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->virt_el1_gsiv = 27; + gtdt->virt_el1_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->el2_gsiv = 26; + gtdt->el2_flags = GTDT_FLAG_INT_ACTIVE_LOW; + gtdt->cnt_read_base = 0xffffffffffffffff; + + header->checksum = table_compute_checksum(header, header->length); + + acpi_add_table(ctx, gtdt); + + acpi_inc(ctx, sizeof(struct acpi_gtdt)); + + return 0; +}; + +ACPI_WRITER(5gtdt, "GTDT", rpi_write_gtdt, 0);
Add the necessary DSDT files copied from tianocore to boot the RPi4. In addition generate a board specific SSDT to dynamically enable/disable ACPI devices based on FDT. This is required to support the various variants and boot options. It also allows to test the code on QEMU 9.0 without modifications, since it doesn't emulate PCIe yet.
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Matthias Brugger mbrugger@suse.com Cc: Peter Robinson pbrobinson@gmail.com --- Changelog v5: - Drop CPU device from DSDT - Add Extern to CPU devices in SSDT --- board/raspberrypi/rpi/.gitignore | 3 + board/raspberrypi/rpi/Makefile | 2 + board/raspberrypi/rpi/acpitables.h | 90 +++++++ board/raspberrypi/rpi/dsdt.asl | 254 ++++++++++++++++++++ board/raspberrypi/rpi/emmc.asl | 136 +++++++++++ board/raspberrypi/rpi/gpudevs.asl | 372 +++++++++++++++++++++++++++++ board/raspberrypi/rpi/pci.asl | 177 ++++++++++++++ board/raspberrypi/rpi/pep.asl | 90 +++++++ board/raspberrypi/rpi/rhpx.asl | 195 +++++++++++++++ board/raspberrypi/rpi/rpi.c | 183 ++++++++++++++ board/raspberrypi/rpi/sdhc.asl | 111 +++++++++ board/raspberrypi/rpi/uart.asl | 208 ++++++++++++++++ 12 files changed, 1821 insertions(+) create mode 100644 board/raspberrypi/rpi/.gitignore create mode 100644 board/raspberrypi/rpi/acpitables.h create mode 100644 board/raspberrypi/rpi/dsdt.asl create mode 100644 board/raspberrypi/rpi/emmc.asl create mode 100644 board/raspberrypi/rpi/gpudevs.asl create mode 100644 board/raspberrypi/rpi/pci.asl create mode 100644 board/raspberrypi/rpi/pep.asl create mode 100644 board/raspberrypi/rpi/rhpx.asl create mode 100644 board/raspberrypi/rpi/sdhc.asl create mode 100644 board/raspberrypi/rpi/uart.asl
diff --git a/board/raspberrypi/rpi/.gitignore b/board/raspberrypi/rpi/.gitignore new file mode 100644 index 0000000000..39e46ba0ae --- /dev/null +++ b/board/raspberrypi/rpi/.gitignore @@ -0,0 +1,3 @@ +dsdt_generated.aml +dsdt_generated.asl.tmp +dsdt_generated.c diff --git a/board/raspberrypi/rpi/Makefile b/board/raspberrypi/rpi/Makefile index b1186cdf10..bb1b7cc630 100644 --- a/board/raspberrypi/rpi/Makefile +++ b/board/raspberrypi/rpi/Makefile @@ -4,3 +4,5 @@
obj-y := rpi.o obj-y += lowlevel_init.o + +obj-$(CONFIG_GENERATE_ACPI_TABLE) += dsdt_generated.o diff --git a/board/raspberrypi/rpi/acpitables.h b/board/raspberrypi/rpi/acpitables.h new file mode 100644 index 0000000000..3ba8f19808 --- /dev/null +++ b/board/raspberrypi/rpi/acpitables.h @@ -0,0 +1,90 @@ +/** @file + * + * RPi defines for constructing ACPI tables + * + * Copyright (c) 2020, Pete Batard pete@akeo.ie + * Copyright (c) 2019, ARM Ltd. All rights reserved. + * Copyright (c) 2018, Andrei Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +#ifndef __RPI_ACPITABLES_H__ +#define __RPI_ACPITABLES_H__ + +#include <acpi/acpi_table.h> + +// The ASL compiler can't perform arithmetic on MEMORY32FIXED () +// parameters so you can't pass a constant like BASE + OFFSET. +// We therefore define a macro that can perform arithmetic base +// address update with an offset. +#define MEMORY32SETBASE(BufName, MemName, VarName, Offset) \ + CreateDwordField (^BufName, ^MemName._BAS, VarName) \ + Add (BCM2836_SOC_REGISTERS, Offset, VarName) + +//------------------------------------------------------------------------ +// Interrupts. These are specific to each platform +//------------------------------------------------------------------------ +#if defined(CONFIG_TARGET_RPI_3) +#define BCM2836_V3D_BUS_INTERRUPT 0x2A +#define BCM2836_DMA_INTERRUPT 0x3B +#define BCM2836_SPI1_INTERRUPT 0x3D +#define BCM2836_SPI2_INTERRUPT 0x3D +#define BCM2836_HVS_INTERRUPT 0x41 +#define BCM2836_HDMI0_INTERRUPT 0x48 +#define BCM2836_HDMI1_INTERRUPT 0x49 +#define BCM2836_PV2_INTERRUPT 0x4A +#define BCM2836_PV0_INTERRUPT 0x4D +#define BCM2836_PV1_INTERRUPT 0x4E +#define BCM2836_MBOX_INTERRUPT 0x61 +#define BCM2836_VCHIQ_INTERRUPT 0x62 +#define BCM2386_GPIO_INTERRUPT0 0x51 +#define BCM2386_GPIO_INTERRUPT1 0x52 +#define BCM2386_GPIO_INTERRUPT2 0x53 +#define BCM2386_GPIO_INTERRUPT3 0x54 +#define BCM2836_I2C1_INTERRUPT 0x55 +#define BCM2836_I2C2_INTERRUPT 0x55 +#define BCM2836_SPI0_INTERRUPT 0x56 +#define BCM2836_USB_INTERRUPT 0x29 +#define BCM2836_SDHOST_INTERRUPT 0x58 +#define BCM2836_MMCHS1_INTERRUPT 0x5E +#define BCM2836_MINI_UART_INTERRUPT 0x3D +#define BCM2836_PL011_UART_INTERRUPT 0x59 +#elif defined(CONFIG_TARGET_RPI_4) +#define BCM2836_V3D_BUS_INTERRUPT 0x2A +#define BCM2836_DMA_INTERRUPT 0x3B +#define BCM2836_SPI1_INTERRUPT 0x7D +#define BCM2836_SPI2_INTERRUPT 0x7D +#define BCM2836_HVS_INTERRUPT 0x41 +#define BCM2836_HDMI0_INTERRUPT 0x48 +#define BCM2836_HDMI1_INTERRUPT 0x49 +#define BCM2836_PV2_INTERRUPT 0x4A +#define BCM2836_PV0_INTERRUPT 0x4D +#define BCM2836_PV1_INTERRUPT 0x4E +#define BCM2836_MBOX_INTERRUPT 0x41 +#define BCM2836_VCHIQ_INTERRUPT 0x42 +#define BCM2386_GPIO_INTERRUPT0 0x91 +#define BCM2386_GPIO_INTERRUPT1 0x92 +#define BCM2386_GPIO_INTERRUPT2 0x93 +#define BCM2386_GPIO_INTERRUPT3 0x94 +#define BCM2836_I2C1_INTERRUPT 0x95 +#define BCM2836_I2C2_INTERRUPT 0x95 +#define BCM2836_SPI0_INTERRUPT 0x96 +#define BCM2836_USB_INTERRUPT 0x69 +#define BCM2836_SDHOST_INTERRUPT 0x98 +#define BCM2836_MMCHS1_INTERRUPT 0x9E +#define BCM2836_MINI_UART_INTERRUPT 0x7D +#define BCM2836_PL011_UART_INTERRUPT 0x99 +#define GENET_INTERRUPT0 0xBD +#define GENET_INTERRUPT1 0xBE +#define GENET_BASE_ADDRESS 0xFD580000 +#define GENET_LENGTH 0x10000 +#define THERM_SENSOR_BASE_ADDRESS 0xFD5d2200 +#define THERM_SENSOR_LENGTH 0x8 +#else +#error "Unsupported rpi module for ACPI tables" +#endif + +#endif // __ACPITABLES_H__ diff --git a/board/raspberrypi/rpi/dsdt.asl b/board/raspberrypi/rpi/dsdt.asl new file mode 100644 index 0000000000..c89b08d5ea --- /dev/null +++ b/board/raspberrypi/rpi/dsdt.asl @@ -0,0 +1,254 @@ +/** @file + * + * Differentiated System Definition Table (DSDT) + * + * Copyright (c) 2020, Pete Batard pete@akeo.ie + * Copyright (c) 2018-2020, Andrey Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * Copyright (c) 2021, ARM Limited. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +#include <asm/arch/acpi/bcm2711.h> +#include <asm/arch/acpi/bcm2836.h> +#include <asm/arch/acpi/bcm2836_gpio.h> +#include <asm/arch/acpi/bcm2836_gpu.h> +#include <asm/arch/acpi/bcm2836_pwm.h> +#include <asm/arch/acpi/bcm2836_sdio.h> +#include <asm/arch/acpi/bcm2836_sdhost.h> + +#include "acpitables.h" + +#define BCM_ALT0 0x4 +#define BCM_ALT1 0x5 +#define BCM_ALT2 0x6 +#define BCM_ALT3 0x7 +#define BCM_ALT4 0x3 +#define BCM_ALT5 0x2 + +// +// The ASL compiler does not support argument arithmetic in functions +// like QWordMemory (). So we need to instantiate dummy qword regions +// that we can then update the Min, Max and Length attributes of. +// The three macros below help accomplish this. +// +// QWORDMEMORYSET specifies a CPU memory range (whose base address is +// BCM2836_SOC_REGISTERS + Offset), and QWORDBUSMEMORYSET specifies +// a VPU memory range (whose base address is provided directly). +// +#define QWORDMEMORYBUF(Index) \ + QWordMemory (ResourceProducer,, \ + MinFixed, MaxFixed, NonCacheable, ReadWrite, \ + 0x0, 0x0, 0x0, 0x0, 0x1,,, RB ## Index) + +#define QWORDMEMORYSET(Index, Offset, Length) \ + CreateQwordField (RBUF, RB ## Index._MIN, MI ## Index) \ + CreateQwordField (RBUF, RB ## Index._MAX, MA ## Index) \ + CreateQwordField (RBUF, RB ## Index._LEN, LE ## Index) \ + Store (Length, LE ## Index) \ + Add (BCM2836_SOC_REGISTERS, Offset, MI ## Index) \ + Add (MI ## Index, LE ## Index - 1, MA ## Index) + +#define QWORDBUSMEMORYSET(Index, Base, Length) \ + CreateQwordField (RBUF, RB ## Index._MIN, MI ## Index) \ + CreateQwordField (RBUF, RB ## Index._MAX, MA ## Index) \ + CreateQwordField (RBUF, RB ## Index._LEN, LE ## Index) \ + Store (Base, MI ## Index) \ + Store (Length, LE ## Index) \ + Add (MI ## Index, LE ## Index - 1, MA ## Index) + +DefinitionBlock ("Dsdt.aml", "DSDT", 2, "RPIFDN", "RPI", 2) +{ + External (_PR.CP00, DeviceObj) + External (_PR.CP01, DeviceObj) + External (_PR.CP02, DeviceObj) + External (_PR.CP03, DeviceObj) + Scope (_SB_) + { + include ("pep.asl") + + // + // GPU device container describes the DMA translation required + // when a device behind the GPU wants to access Arm memory. + // Only the first GB can be addressed. + // + Device (GDV0) + { + Name (_HID, "ACPI0004") + Name (_UID, 0x1) + Name (_CCA, 0x0) + + Method (_CRS, 0, Serialized) { + // + // Container devices with _DMA must have _CRS, meaning GDV0 + // to provide all resources that GpuDevs.asl consume (except + // interrupts). + // + Name (RBUF, ResourceTemplate () { + QWORDMEMORYBUF(01) + QWORDMEMORYBUF(02) + QWORDMEMORYBUF(03) + // QWORDMEMORYBUF(04) + // QWORDMEMORYBUF(05) + QWORDMEMORYBUF(06) + QWORDMEMORYBUF(07) + QWORDMEMORYBUF(08) + QWORDMEMORYBUF(09) + QWORDMEMORYBUF(10) + QWORDMEMORYBUF(11) + QWORDMEMORYBUF(12) + QWORDMEMORYBUF(13) + QWORDMEMORYBUF(14) + QWORDMEMORYBUF(15) + // QWORDMEMORYBUF(16) + QWORDMEMORYBUF(17) + QWORDMEMORYBUF(18) + QWORDMEMORYBUF(19) + QWORDMEMORYBUF(20) + QWORDMEMORYBUF(21) + QWORDMEMORYBUF(22) + QWORDMEMORYBUF(23) + QWORDMEMORYBUF(24) + QWORDMEMORYBUF(25) + }) + + // USB + QWORDMEMORYSET(01, BCM2836_USB_OFFSET, BCM2836_USB_LENGTH) + + // GPU + QWORDMEMORYSET(02, BCM2836_V3D_BUS_OFFSET, BCM2836_V3D_BUS_LENGTH) + QWORDMEMORYSET(03, BCM2836_HVS_OFFSET, BCM2836_HVS_LENGTH) + // QWORDMEMORYSET(04, BCM2836_PV0_OFFSET, BCM2836_PV0_LENGTH) + // QWORDMEMORYSET(05, BCM2836_PV1_OFFSET, BCM2836_PV1_LENGTH) + QWORDMEMORYSET(06, BCM2836_PV2_OFFSET, BCM2836_PV2_LENGTH) + QWORDMEMORYSET(07, BCM2836_HDMI0_OFFSET, BCM2836_HDMI0_LENGTH) + QWORDMEMORYSET(08, BCM2836_HDMI1_OFFSET, BCM2836_HDMI1_LENGTH) + + // Mailbox + QWORDMEMORYSET(09, BCM2836_MBOX_OFFSET, BCM2836_MBOX_LENGTH) + + // VCHIQ + QWORDMEMORYSET(10, BCM2836_VCHIQ_OFFSET, BCM2836_VCHIQ_LENGTH) + + // GPIO + QWORDMEMORYSET(11, GPIO_OFFSET, GPIO_LENGTH) + + // I2C + QWORDMEMORYSET(12, BCM2836_I2C1_OFFSET, BCM2836_I2C1_LENGTH) + QWORDMEMORYSET(13, BCM2836_I2C2_OFFSET, BCM2836_I2C2_LENGTH) + + // SPI + QWORDMEMORYSET(14, BCM2836_SPI0_OFFSET, BCM2836_SPI0_LENGTH) + QWORDMEMORYSET(15, BCM2836_SPI1_OFFSET, BCM2836_SPI1_LENGTH) + // QWORDMEMORYSET(16, BCM2836_SPI2_OFFSET, BCM2836_SPI2_LENGTH) + + // PWM + QWORDMEMORYSET(17, BCM2836_PWM_DMA_OFFSET, BCM2836_PWM_DMA_LENGTH) + QWORDMEMORYSET(18, BCM2836_PWM_CTRL_OFFSET, BCM2836_PWM_CTRL_LENGTH) + QWORDBUSMEMORYSET(19, BCM2836_PWM_BUS_BASE_ADDRESS, BCM2836_PWM_BUS_LENGTH) + QWORDBUSMEMORYSET(20, BCM2836_PWM_CTRL_UNCACHED_BASE_ADDRESS, BCM2836_PWM_CTRL_UNCACHED_LENGTH) + QWORDMEMORYSET(21, BCM2836_PWM_CLK_OFFSET, BCM2836_PWM_CLK_LENGTH) + + // UART + QWORDMEMORYSET(22, BCM2836_PL011_UART_OFFSET, BCM2836_PL011_UART_LENGTH) + QWORDMEMORYSET(23, BCM2836_MINI_UART_OFFSET, BCM2836_MINI_UART_LENGTH) + + // SDC + QWORDMEMORYSET(24, MMCHS1_OFFSET, MMCHS1_LENGTH) + QWORDMEMORYSET(25, SDHOST_OFFSET, SDHOST_LENGTH) + + Return (RBUF) + } + + Name (_DMA, ResourceTemplate() { + // + // Only the first GB is available. + // Bus 0xC0000000 -> CPU 0x00000000. + // + QWordMemory (ResourceProducer, + , + MinFixed, + MaxFixed, + NonCacheable, + ReadWrite, + 0x0, + 0x00000000C0000000, // MIN + 0x00000000FFFFFFFF, // MAX + 0xFFFFFFFF40000000, // TRA + 0x0000000040000000, // LEN + , + , + ) + }) +#include "gpudevs.asl" + } + +#if defined(CONFIG_TARGET_RPI_4) + Device (ETH0) + { + Name (_HID, "BCM6E4E") + Name (_CID, "BCM6E4E") + Name (_UID, 0x0) + Name (_CCA, 0x0) + + Method (_CRS, 0x0, Serialized) + { + Return (ResourceTemplate () + { + // No need for MEMORY32SETBASE on Genet as we have a straight base address constant + MEMORY32FIXED (ReadWrite, GENET_BASE_ADDRESS, GENET_LENGTH, ) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { GENET_INTERRUPT0, GENET_INTERRUPT1 } + }) + } + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () { "brcm,max-dma-burst-size", 0x08 }, + Package () { "phy-mode", "rgmii-rxid" }, + } + }) + } + + // Define a simple thermal zone. The idea here is we compute the SOC temp + // via a register we can read, and give it to the OS. This enables basic + // reports from the "sensors" utility, and the OS can then poll and take + // actions if that temp exceeds any of the given thresholds. + Device (EC00) + { + Name (_HID, EISAID ("PNP0C06")) + Name (_CCA, 0x0) + + // all temps in are tenths of K (aka 2732 is the min temps in Linux (aka 0C)) + ThermalZone (TZ00) { + OperationRegion (TEMS, SystemMemory, THERM_SENSOR_BASE_ADDRESS, THERM_SENSOR_LENGTH) + Field (TEMS, DWordAcc, NoLock, Preserve) { + TMPS, 32 + } + Method (_TMP, 0, Serialized) { + return (((410040 - ((TMPS & 0x3ff) * 487)) / 100) + 2732); + } + + Method (_SCP, 3) { } // receive cooling policy from OS + + Method (_CRT) { Return (3632) } // (90C) Critical temp point (immediate power-off) + Method (_HOT) { Return (3582) } // (85C) HOT state where OS should hibernate + Method (_PSV) { Return (3532) } // (80C) Passive cooling (CPU throttling) trip point + + // SSDT inserts _AC0/_AL0 @60C here, if a FAN is configured + + Name (_TZP, 10) //The OSPM must poll this device every 1 seconds + Name (_PSL, Package () { _PR.CP00, _PR.CP01, _PR.CP02, _PR.CP03 }) + } + } +#endif + + +#include "uart.asl" +#include "rhpx.asl" +#include "sdhc.asl" +#include "emmc.asl" +#include "pci.asl" + } +} diff --git a/board/raspberrypi/rpi/emmc.asl b/board/raspberrypi/rpi/emmc.asl new file mode 100644 index 0000000000..63f01362c9 --- /dev/null +++ b/board/raspberrypi/rpi/emmc.asl @@ -0,0 +1,136 @@ +/** @file + * + * Copyright (c) 2021, ARM Limited. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +#include <asm/arch/acpi/bcm2836_sdhost.h> +#include <asm/arch/acpi/bcm2836_sdio.h> +#include <asm/arch/acpi/bcm2711.h> + +Device (GDV1) { + Name (_HID, "ACPI0004") + Name (_UID, 0x2) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, MMCHS2_LENGTH, RMEM) + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, MMCHS2_OFFSET) + Return (^RBUF) + } + + // Translated DMA region for BCM2711 silicon revisions older than C0 + Name (DMTR, ResourceTemplate() { + QWordMemory (ResourceProducer, + , + MinFixed, + MaxFixed, + NonCacheable, + ReadWrite, + 0x0, + 0x00000000C0000000, // MIN + 0x00000000FFFFFFFF, // MAX + 0xFFFFFFFF40000000, // TRA + 0x0000000040000000, // LEN + , + , + ) + }) + + // Non translated DMA region for BCM2711 revisions C0 and newer + Name (DMNT, ResourceTemplate() { + QWordMemory (ResourceProducer, + , + MinFixed, + MaxFixed, + NonCacheable, + ReadWrite, + 0x0, + 0x0000000000000000, // MIN + 0x000000FFFFFFFFFF, // MAX + 0x0000000000000000, // TRA + 0x0000010000000000, // LEN + , + , + ) + }) + + // emmc2 Host Controller. (brcm,bcm2711-emmc2) + Device (SDC3) + { + Name (_HID, "BRCME88C") + Name (_UID, 0x1) + Name (_CCA, 0x0) + Name (_S1D, 0x1) + Name (_S2D, 0x1) + Name (_S3D, 0x1) + Name (_S4D, 0x1) + Name (SDMA, 0x2) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, MMCHS2_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Shared) { BCM2836_MMCHS1_INTERRUPT } + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, MMCHS2_OFFSET) + Return (^RBUF) + } + + // Unfortunately this controller doesn't honor the + // standard SDHCI voltage control registers + // (or at least Linux's standard code can't + // lower the voltage) So, UHS mode is disabled with caps + Name (DSD1, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () { "sdhci-caps-mask", 0x0000000500080000 }, + } + }) + // Along with disabling UHS, here both SDMA and ADMA2 + // are also disabled until the linux _DMA() mask/translate + // works properly. + Name (DSD2, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () { "sdhci-caps-mask", 0x0000000504480000 }, + } + }) + Method (_DSD, 0x0, Serialized) + { + // Select one of the sdhci-caps-mask definitions + // depending on whether we also want to disable DMA + if (SDMA == 0) + { + return (^DSD2) + } + else + { + return (^DSD1) + } + } + + // + // A child device that represents the + // sd card, which is marked as non-removable. + // + Device (SDMM) + { + Method (_ADR) + { + Return (0) + } + Method (_RMV) // Is removable + { + Return (0) // 0 - fixed + } + } + } //SDC3 +} //GDV1 diff --git a/board/raspberrypi/rpi/gpudevs.asl b/board/raspberrypi/rpi/gpudevs.asl new file mode 100644 index 0000000000..a3077a9c3b --- /dev/null +++ b/board/raspberrypi/rpi/gpudevs.asl @@ -0,0 +1,372 @@ +/** @file + * + * [DSDT] Devices behind the GPU. + * + * Copyright (c) 2018-2020, Andrey Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +// DWC OTG Controller +Device (USB0) +{ + Name (_HID, "BCM2848") +#if defined(CONFIG_TARGET_RPI_3) + Name (_CID, "DWC_OTG") +#elif defined(CONFIG_TARGET_RPI_4) + Name (_CID, "BCM2848") +#endif + Name (_UID, 0x0) + Name (_CCA, 0x0) + Method (_STA) + { + Return (0xf) + } + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_USB_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_USB_INTERRUPT } + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_USB_OFFSET) + Return (^RBUF) + } +} + +// Video Core 4 GPU +Device (GPU0) +{ + Name (_HID, "BCM2850") + Name (_CID, "BCM2850") + Name (_UID, 0x0) + Name (_CCA, 0x0) + Method (_STA) + { + Return (0xf) + } + Name (RBUF, ResourceTemplate () + { + // Memory and interrupt for the GPU + MEMORY32FIXED (ReadWrite, 0, BCM2836_V3D_BUS_LENGTH, RM01) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_V3D_BUS_INTERRUPT } + + // HVS - Hardware Video Scalar + MEMORY32FIXED (ReadWrite, 0, BCM2836_HVS_LENGTH, RM02) + // The HVS interrupt is reserved by the VPU + // Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_HVS_INTERRUPT } + + // PixelValve0 - DSI0 or DPI + // MEMORY32FIXED (ReadWrite, BCM2836_PV0_BASE_ADDRESS, BCM2836_PV0_LENGTH, RM03) + // Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_PV0_INTERRUPT } + + // PixelValve1 - DS1 or SMI + // MEMORY32FIXED (ReadWrite, BCM2836_PV1_BASE_ADDRESS, BCM2836_PV1_LENGTH, RM04) + // Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_PV1_INTERRUPT } + + // PixelValve2 - HDMI output - connected to HVS display FIFO 1 + MEMORY32FIXED (ReadWrite, 0, BCM2836_PV2_LENGTH, RM05) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_PV2_INTERRUPT } + + // HDMI registers + MEMORY32FIXED (ReadWrite, 0, BCM2836_HDMI0_LENGTH, RM06) + MEMORY32FIXED (ReadWrite, 0, BCM2836_HDMI1_LENGTH, RM07) + // hdmi_int[0] + // Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_HDMI0_INTERRUPT } + // hdmi_int[1] + // Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_HDMI1_INTERRUPT } + + // HDMI DDC connection + I2CSerialBus (0x50,, 100000,, "\_SB.GDV0.I2C2",,,,) // EDID + I2CSerialBus (0x30,, 100000,, "\_SB.GDV0.I2C2",,,,) // E-DDC Segment Pointer + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RM01, RB01, BCM2836_V3D_BUS_OFFSET) + MEMORY32SETBASE (RBUF, RM02, RB02, BCM2836_HVS_OFFSET) + MEMORY32SETBASE (RBUF, RM05, RB05, BCM2836_PV2_OFFSET) + MEMORY32SETBASE (RBUF, RM06, RB06, BCM2836_HDMI0_OFFSET) + MEMORY32SETBASE (RBUF, RM07, RB07, BCM2836_HDMI1_OFFSET) + Return (^RBUF) + } + + // GPU Power Management Component Data + // Reference : https://github.com/Microsoft/graphics-driver-samples/wiki/Install-Driver-in-... + Method (PMCD, 0, Serialized) + { + Name (RBUF, Package () + { + 1, // Version + 1, // Number of graphics power components + Package () // Power components package + { + Package () // GPU component package + { + 0, // Component Index + 0, // DXGK_POWER_COMPONENT_MAPPING.ComponentType (0 = DXGK_POWER_COMPONENT_ENGINE) + 0, // DXGK_POWER_COMPONENT_MAPPING.NodeIndex + + Buffer () // DXGK_POWER_RUNTIME_COMPONENT.ComponentGuid + { // 9B2D1E26-1575-4747-8FC0-B9EB4BAA2D2B + 0x26, 0x1E, 0x2D, 0x9B, 0x75, 0x15, 0x47, 0x47, + 0x8f, 0xc0, 0xb9, 0xeb, 0x4b, 0xaa, 0x2d, 0x2b + }, + + "VC4_Engine_00",// DXGK_POWER_RUNTIME_COMPONENT.ComponentName + 2, // DXGK_POWER_RUNTIME_COMPONENT.StateCount + + Package () // DXGK_POWER_RUNTIME_COMPONENT.States[] package + { + Package () // F0 + { + 0, // DXGK_POWER_RUNTIME_STATE.TransitionLatency + 0, // DXGK_POWER_RUNTIME_STATE.ResidencyRequirement + 1210000, // DXGK_POWER_RUNTIME_STATE.NominalPower (microwatt) + }, + + Package () // F1 - Placeholder + { + 10000, // DXGK_POWER_RUNTIME_STATE.TransitionLatency + 10000, // DXGK_POWER_RUNTIME_STATE.ResidencyRequirement + 4, // DXGK_POWER_RUNTIME_STATE.NominalPower + }, + } + } + } + }) + Return (RBUF) + } +} + +// PiQ Mailbox Driver +Device (RPIQ) +{ + Name (_HID, "BCM2849") + Name (_CID, "BCM2849") + Name (_UID, 0) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_MBOX_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_MBOX_INTERRUPT } + }) + + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_MBOX_OFFSET) + Return (^RBUF) + } +} + +// VCHIQ Driver +Device (VCIQ) +{ + Name (_HID, "BCM2835") + Name (_CID, "BCM2835") + Name (_UID, 0) + Name (_CCA, 0x0) + Name (_DEP, Package() { _SB.GDV0.RPIQ }) + Method (_STA) + { + Return (0xf) + } + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_VCHIQ_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_VCHIQ_INTERRUPT } + }) + + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_VCHIQ_OFFSET) + Return (^RBUF) + } +} + +// VC Shared Memory Driver +Device (VCSM) +{ + Name (_HID, "BCM2856") + Name (_CID, "BCM2856") + Name (_UID, 0) + Name (_CCA, 0x0) + Name (_DEP, Package() { _SB.GDV0.VCIQ }) + Method (_STA) + { + Return (0xf) + } +} + +// Description: GPIO +Device (GPI0) +{ + Name (_HID, "BCM2845") + Name (_CID, "BCM2845") + Name (_UID, 0x0) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, GPIO_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Shared) + { + BCM2386_GPIO_INTERRUPT0, BCM2386_GPIO_INTERRUPT1, + BCM2386_GPIO_INTERRUPT2, BCM2386_GPIO_INTERRUPT3 + } + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, GPIO_OFFSET) + Return (^RBUF) + } +} + +// Description: I2C +Device (I2C1) +{ + Name (_HID, "BCM2841") + Name (_CID, "BCM2841") + Name (_UID, 0x1) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_I2C1_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Shared) { BCM2836_I2C1_INTERRUPT } + PinFunction (Exclusive, PullUp, BCM_ALT0, "\_SB.GDV0.GPI0", 0, ResourceConsumer, , ) { 2, 3 } + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_I2C1_OFFSET) + Return (^RBUF) + } +} + +// I2C2 is the HDMI DDC connection +Device (I2C2) +{ + Name (_HID, "BCM2841") + Name (_CID, "BCM2841") + Name (_UID, 0x2) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate() + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_I2C2_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Shared) { BCM2836_I2C2_INTERRUPT } + }) + + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_I2C2_OFFSET) + Return (^RBUF) + } +} + +// SPI +Device (SPI0) +{ + Name (_HID, "BCM2838") + Name (_CID, "BCM2838") + Name (_UID, 0x0) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_SPI0_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Shared) { BCM2836_SPI0_INTERRUPT } + PinFunction (Exclusive, PullDown, BCM_ALT0, "\_SB.GDV0.GPI0", 0, ResourceConsumer, , ) { 9, 10, 11 } // MISO, MOSI, SCLK + PinFunction (Exclusive, PullUp, BCM_ALT0, "\_SB.GDV0.GPI0", 0, ResourceConsumer, , ) { 8 } // CE0 + PinFunction (Exclusive, PullUp, BCM_ALT0, "\_SB.GDV0.GPI0", 0, ResourceConsumer, , ) { 7 } // CE1 + }) + + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_SPI0_OFFSET) + Return (^RBUF) + } +} + +Device (SPI1) +{ + Name (_HID, "BCM2839") + Name (_CID, "BCM2839") + Name (_UID, 0x1) + Name (_CCA, 0x0) + Name (_DEP, Package() { _SB.GDV0.RPIQ }) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_SPI1_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Shared,) { BCM2836_SPI1_INTERRUPT } + PinFunction (Exclusive, PullDown, BCM_ALT4, "\_SB.GDV0.GPI0", 0, ResourceConsumer, , ) { 19, 20, 21 } // MISO, MOSI, SCLK + PinFunction (Exclusive, PullDown, BCM_ALT4, "\_SB.GDV0.GPI0", 0, ResourceConsumer, , ) { 16 } // CE2 + }) + + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_SPI1_OFFSET) + Return (^RBUF) + } +} + +// SPI2 has no pins on GPIO header +// Device (SPI2) +// { +// Name (_HID, "BCM2839") +// Name (_CID, "BCM2839") +// Name (_UID, 0x2) +// Name (_CCA, 0x0) +// Name (_DEP, Package() { _SB.GDV0.RPIQ }) +// Method (_STA) +// { +// Return (0xf) // Disabled +// } +// Method (_CRS, 0x0, Serialized) +// { +// Name (RBUF, ResourceTemplate () +// { +// MEMORY32FIXED (ReadWrite, BCM2836_SPI2_BASE_ADDRESS, BCM2836_SPI2_LENGTH, RMEM) +// Interrupt (ResourceConsumer, Level, ActiveHigh, Shared,) { BCM2836_SPI2_INTERRUPT } +// }) +// Return (RBUF) +// } +// } + +// PWM Driver +Device (PWM0) +{ + Name (_HID, "BCM2844") + Name (_CID, "BCM2844") + Name (_UID, 0) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + // DMA channel 11 control + MEMORY32FIXED (ReadWrite, 0, BCM2836_PWM_DMA_LENGTH, RM01) + // PWM control + MEMORY32FIXED (ReadWrite, 0, BCM2836_PWM_CTRL_LENGTH, RM02) + // PWM control bus + MEMORY32FIXED (ReadWrite, BCM2836_PWM_BUS_BASE_ADDRESS, BCM2836_PWM_BUS_LENGTH, ) + // PWM control uncached + MEMORY32FIXED (ReadWrite, BCM2836_PWM_CTRL_UNCACHED_BASE_ADDRESS, BCM2836_PWM_CTRL_UNCACHED_LENGTH, ) + // PWM clock control + MEMORY32FIXED (ReadWrite, 0, BCM2836_PWM_CLK_LENGTH, RM03) + // Interrupt DMA channel 11 + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_DMA_INTERRUPT } + // DMA channel 11, DREQ 5 for PWM + FixedDMA (5, 11, Width32Bit, ) + }) + + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RM01, RB01, BCM2836_PWM_DMA_OFFSET) + MEMORY32SETBASE (RBUF, RM02, RB02, BCM2836_PWM_CTRL_OFFSET) + MEMORY32SETBASE (RBUF, RM03, RB03, BCM2836_PWM_CLK_OFFSET) + Return (^RBUF) + } +} \ No newline at end of file diff --git a/board/raspberrypi/rpi/pci.asl b/board/raspberrypi/rpi/pci.asl new file mode 100644 index 0000000000..a7a09df5cd --- /dev/null +++ b/board/raspberrypi/rpi/pci.asl @@ -0,0 +1,177 @@ +/** @file + * + * Copyright (c) 2019 Linaro, Limited. All rights reserved. + * Copyright (c) 2021 Arm + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +Device(PCI0) +{ + Name(_HID, EISAID("PNP0A08")) // PCI Express Root Bridge + Name(_CID, EISAID("PNP0A03")) // Compatible PCI Root Bridge + Name(_SEG, Zero) // PCI Segment Group number + Name(_BBN, Zero) // PCI Base Bus Number + Name(_CCA, 0) // Mark the PCI noncoherent + + // PCIe can only DMA to first 3GB with early SOC's + // But we keep the restriction on the later ones + // To avoid DMA translation problems. + Name (_DMA, ResourceTemplate() { + QWordMemory (ResourceProducer, + , + MinFixed, + MaxFixed, + NonCacheable, + ReadWrite, + 0x0, + 0x0, // MIN + 0xbfffffff, // MAX + 0x0, // TRA + 0xc0000000, // LEN + , + , + ) + }) + + // PCI Routing Table + Name(_PRT, Package() { + Package (4) { 0x0000FFFF, 0, zero, 175 }, + Package (4) { 0x0000FFFF, 1, zero, 176 }, + Package (4) { 0x0000FFFF, 2, zero, 177 }, + Package (4) { 0x0000FFFF, 3, zero, 178 } + }) + + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () { "linux-ecam-quirk-id", "bcm2711" }, + } + }) + + // Root complex resources + Method (_CRS, 0, Serialized) { + Name (RBUF, ResourceTemplate () { + + // bus numbers assigned to this root + WordBusNumber ( + ResourceProducer, + MinFixed, MaxFixed, PosDecode, + 0, // AddressGranularity + 0, // AddressMinimum - Minimum Bus Number + 255, // AddressMaximum - Maximum Bus Number + 0, // AddressTranslation - Set to 0 + 256 // RangeLength - Number of Busses + ) + + // 32-bit mmio window in 64-bit addr + QWordMemory ( + ResourceProducer, PosDecode, + MinFixed, MaxFixed, + NonCacheable, ReadWrite, // cacheable + 0x00000000, // Granularity + 0, // PCIE_PCI_MMIO_BEGIN + 1, // PCIE_MMIO_LEN + PCIE_PCI_MMIO_BEGIN + PCIE_CPU_MMIO_WINDOW, // PCIE_PCI_MMIO_BEGIN - PCIE_CPU_MMIO_WINDOW + 2 // PCIE_MMIO_LEN + 1 + ,,,MMI1 + ) + + // root port registers, not to be used if SMCCC is utilized + QWordMemory ( + ResourceConsumer, , + MinFixed, MaxFixed, + NonCacheable, ReadWrite, // cacheable + 0x00000000, // Granularity + 0xFD500000, // Root port begin + 0xFD509FFF, // Root port end + 0x00000000, // no translation + 0x0000A000, // size + ,, + ) + }) // end Name(RBUF) + + // Work around ASL's inability to add in a resource definition + // or for that matter compute the min,max,len properly + CreateQwordField (RBUF, MMI1._MIN, MMIB) + CreateQwordField (RBUF, MMI1._MAX, MMIE) + CreateQwordField (RBUF, MMI1._TRA, MMIT) + CreateQwordField (RBUF, MMI1._LEN, MMIL) + Add (MMIB, PCIE_TOP_OF_MEM_WIN, MMIB) + Add (PCIE_BRIDGE_MMIO_LEN, PCIE_TOP_OF_MEM_WIN, MMIE) + Subtract (MMIT, PCIE_TOP_OF_MEM_WIN, MMIT) + Add (PCIE_BRIDGE_MMIO_LEN, 1 , MMIL) + + Return (RBUF) + } // end Method(_CRS) + + // OS Control Handoff + Name(SUPP, Zero) // PCI _OSC Support Field value + Name(CTRL, Zero) // PCI _OSC Control Field value + + // See [1] 6.2.10, [2] 4.5 + Method(_OSC,4) { + // Note, This code is very similar to the code in the PCIe firmware + // specification which can be used as a reference + // Check for proper UUID + If(LEqual(Arg0,ToUUID("33DB4D5B-1FF7-401C-9657-7441C03DD766"))) { + // Create DWord-adressable fields from the Capabilities Buffer + CreateDWordField(Arg3,0,CDW1) + CreateDWordField(Arg3,4,CDW2) + CreateDWordField(Arg3,8,CDW3) + // Save Capabilities DWord2 & 3 + Store(CDW2,SUPP) + Store(CDW3,CTRL) + // Mask out Native HotPlug + And(CTRL,0x1E,CTRL) + // Always allow native PME, AER (no dependencies) + // Never allow SHPC (no SHPC controller in this system) + And(CTRL,0x1D,CTRL) + + If(LNotEqual(Arg1,One)) { // Unknown revision + Or(CDW1,0x08,CDW1) + } + + If(LNotEqual(CDW3,CTRL)) { // Capabilities bits were masked + Or(CDW1,0x10,CDW1) + } + // Update DWORD3 in the buffer + Store(CTRL,CDW3) + Return(Arg3) + } Else { + Or(CDW1,4,CDW1) // Unrecognized UUID + Return(Arg3) + } + } // End _OSC + + Device (XHC0) + { + Name (_ADR, 0x00010000) + Name (_CID, "PNP0D10") + Name (_UID, 0x0) // _UID: Unique ID + Name (_CCA, 0x0) // _CCA: Cache Coherency Attribute + + /* + * Microsoft's USB Device-Specific Methods. See: + * https://docs.microsoft.com/en-us/windows-hardware/drivers/bringup/usb-device... + */ + Name (DSMU, ToUUID ("ce2ee385-00e6-48cb-9f05-2edb927c4899")) + + Method (_DSM, 4, Serialized) { + If (LEqual (Arg0, DSMU)) { // USB capabilities UUID + Switch (ToInteger (Arg2)) { + Case (0) { // Function 0: List of supported functions + Return (Buffer () { 0x41 }) // 0x41 - Functions 0 and 6 supported + } + Case (6) { // Function 6: RegisterAccessType + Return (Buffer () { 0x01 }) // 0x01 - Must use 32bit register access + } + Default { } // Unsupported + } + } + return (Buffer () { 0x00 }) // Return 0x00 for anything unsupported + } + } // end XHC0 + +} // PCI0 \ No newline at end of file diff --git a/board/raspberrypi/rpi/pep.asl b/board/raspberrypi/rpi/pep.asl new file mode 100644 index 0000000000..87469e2e5a --- /dev/null +++ b/board/raspberrypi/rpi/pep.asl @@ -0,0 +1,90 @@ +/** @file + * + * Platform Extension Plugin (PEP). + * + * Copyright (c) 2019, ARM Ltd. All rights reserved. + * Copyright (c) 2018, Andrey Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +Device(PEPD) +{ + // + // PEP virtual device. + // + Name (_HID, "BCM2854") // Note: Since PEP on RPi is a virtual device, + Name (_CID, "BCM2854") // its device id needs to be generated by Microsoft + Name (_UID, 0x0) + Name (_CRS, ResourceTemplate () + { + // No hardware resources for PEP driver are needed. + }) + + // + // Processor info. PEP proprietary method to return + // PEP_PROCESSOR_TABLE_PLAT structure. + // + // See Pep.h and Pep.c. + // + Name (_GPI, Buffer() + { + 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x5C, 0x00, 0x5F, 0x00, 0x53, + 0x00, 0x42, 0x00, 0x2E, 0x00, 0x43, 0x00, 0x50, 0x00, 0x55, 0x00, 0x30, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 + }) + + // + // Coordinated state info. PEP proprietary method to return + // PEP_COORDINATED_STATE_TABLE_PLAT structure. + // + // See Pep.h and Pep.c. + // + Name (_GCI, Buffer() + { + 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00 + }) + + // + // Device info. PEP proprietary method to return + // PEP_DEVICE_TABLE_PLAT structure. + // + // See Pep.h and Pep.c. + // + Name (_GDI, Buffer() + { + 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x5C, 0x00, 0x5F, 0x00, 0x53, + 0x00, 0x42, 0x00, 0x2E, 0x00, 0x49, 0x00, 0x32, 0x00, 0x43, 0x00, 0x30, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 + }) +} diff --git a/board/raspberrypi/rpi/rhpx.asl b/board/raspberrypi/rpi/rhpx.asl new file mode 100644 index 0000000000..214b55c656 --- /dev/null +++ b/board/raspberrypi/rpi/rhpx.asl @@ -0,0 +1,195 @@ +/** @file + * + * [DSDT] RHProxy device to enable WinRT API (RHPX) + * + * Copyright (c) 2018, Andrey Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +Device (RHPX) +{ + Name (_HID, "MSFT8000") + Name (_CID, "MSFT8000") + Name (_UID, 1) + + Name(_CRS, ResourceTemplate () + { + // Index 0 + SPISerialBus ( // SCKL - GPIO 11 - Pin 23 + // MOSI - GPIO 10 - Pin 19 + // MISO - GPIO 9 - Pin 21 + // CE0 - GPIO 8 - Pin 24 + 0, // Device selection (CE0) + PolarityLow, // Device selection polarity + FourWireMode, // WireMode + 8, // DataBit len + ControllerInitiated, // Slave mode + 4000000, // Connection speed + ClockPolarityLow, // Clock polarity + ClockPhaseFirst, // Clock phase + "\_SB.GDV0.SPI0", // ResourceSource: SPI bus controller name + 0, // ResourceSourceIndex + // Resource usage + // DescriptorName: creates name for offset of resource descriptor + ) // Vendor Data + + // Index 1 + SPISerialBus ( // SCKL - GPIO 11 - Pin 23 + // MOSI - GPIO 10 - Pin 19 + // MISO - GPIO 9 - Pin 21 + // CE1 - GPIO 7 - Pin 26 + 1, // Device selection (CE1) + PolarityLow, // Device selection polarity + FourWireMode, // WireMode + 8, // DataBit len + ControllerInitiated, // Slave mode + 4000000, // Connection speed + ClockPolarityLow, // Clock polarity + ClockPhaseFirst, // Clock phase + "\_SB.GDV0.SPI0", // ResourceSource: SPI bus controller name + 0, // ResourceSourceIndex + // Resource usage + // DescriptorName: creates name for offset of resource descriptor + ) // Vendor Data + + // Index 2 + I2CSerialBus ( // Pin 3 (GPIO2, SDA1), 5 (GPIO3, SCL1) + 0xFFFF, // SlaveAddress: placeholder + , // SlaveMode: default to ControllerInitiated + 0, // ConnectionSpeed: placeholder + , // Addressing Mode: default to 7 bit + "\_SB.GDV0.I2C1", // ResourceSource: I2C bus controller name + , + , + , // Descriptor Name: creates name for offset of resource descriptor + ) // Vendor Data + + // Index 3 + SPISerialBus ( // SPI1_SCLK - GPIO21 + // SPI1_MOSI - GPIO20 + // SPI1_MISO - GPIO19 + // SPI1_CE2_N - GPIO16 + 2, // Device selection (CE2) + PolarityLow, // Device selection polarity + FourWireMode, // WireMode + 8, // DataBit len + ControllerInitiated, // Slave mode + 4000000, // Connection speed + ClockPolarityLow, // Clock polarity + ClockPhaseFirst, // Clock phase + "\_SB.GDV0.SPI1", // ResourceSource: SPI bus controller name + 0, // ResourceSourceIndex + // Resource usage + // DescriptorName: creates name for offset of resource descriptor + ) // Vendor Data + + // GPIO 2 + GpioIO (Shared, PullUp, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 2 } + GpioInt (Edge, ActiveBoth, Shared, PullUp, 0, "\_SB.GDV0.GPI0",) { 2 } + // GPIO 3 + GpioIO (Shared, PullUp, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 3 } + GpioInt (Edge, ActiveBoth, Shared, PullUp, 0, "\_SB.GDV0.GPI0",) { 3 } + // GPIO 4 + GpioIO (Shared, PullUp, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 4 } + GpioInt (Edge, ActiveBoth, Shared, PullUp, 0, "\_SB.GDV0.GPI0",) { 4 } + // GPIO 5 + GpioIO (Shared, PullUp, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 5 } + GpioInt (Edge, ActiveBoth, Shared, PullUp, 0, "\_SB.GDV0.GPI0",) { 5 } + // GPIO 6 + GpioIO (Shared, PullUp, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 6 } + GpioInt (Edge, ActiveBoth, Shared, PullUp, 0, "\_SB.GDV0.GPI0",) { 6 } + // GPIO 7 + GpioIO (Shared, PullUp, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 7 } + GpioInt (Edge, ActiveBoth, Shared, PullUp, 0, "\_SB.GDV0.GPI0",) { 7 } + // GPIO 8 + GpioIO (Shared, PullUp, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 8 } + GpioInt (Edge, ActiveBoth, Shared, PullUp, 0, "\_SB.GDV0.GPI0",) { 8 } + // GPIO 9 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 9 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 9 } + // GPIO 10 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 10 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 10 } + // GPIO 11 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 11 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 11 } + // GPIO 12 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 12 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 12 } + // GPIO 13 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 13 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 13 } + // NTRAID#MSFT-7141401-2016/04/7-jordanrh - disable UART muxing + // until a proper solution can be created for the dmap conflict + // GPIO 14 - UART TX + // GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 14 } + // GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 14 } + // GPIO 15 - UART RX + // GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 15 } + // GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 15 } + // GPIO 16 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 16 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 16 } + // GPIO 17 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 17 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 17 } + // GPIO 18 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 18 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 18 } + // GPIO 19 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 19 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 19 } + // GPIO 20 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 20 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 20 } + // GPIO 21 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 21 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 21 } + // GPIO 22 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 22 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 22 } + // GPIO 23 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 23 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 23 } + // GPIO 24 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 24 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 24 } + // GPIO 25 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 25 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 25 } + // GPIO 26 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 26 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 26 } + // GPIO 27 + GpioIO (Shared, PullDown, 0, 0, IoRestrictionNone, "\_SB.GDV0.GPI0", 0, ResourceConsumer,,) { 27 } + GpioInt (Edge, ActiveBoth, Shared, PullDown, 0, "\_SB.GDV0.GPI0",) { 27 } + }) + + Name (_DSD, Package() + { + ToUUID ("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () + { + // Reference http://www.raspberrypi.org/documentation/hardware/raspberrypi/spi/README.md + // SPI 0 + Package (2) { "bus-SPI-SPI0", Package() { 0, 1 } }, // Index 0 & 1 + Package (2) { "SPI0-MinClockInHz", 7629 }, // 7629 Hz + Package (2) { "SPI0-MaxClockInHz", 125000000 }, // 125 MHz + Package (2) { "SPI0-SupportedDataBitLengths", Package() { 8 } }, // Data Bit Length + // I2C1 + Package (2) { "bus-I2C-I2C1", Package() { 2 } }, + // GPIO Pin Count and supported drive modes + Package (2) { "GPIO-PinCount", 54 }, + Package (2) { "GPIO-UseDescriptorPinNumbers", 1 }, + Package (2) { "GPIO-SupportedDriveModes", 0xf }, // InputHighImpedance, InputPullUp, InputPullDown, OutputCmos + // SPI 1 + Package (2) { "bus-SPI-SPI1", Package() { 3 }}, // Index 3 + Package (2) { "SPI1-MinClockInHz", 30511 }, // 30.5 kHz + Package (2) { "SPI1-MaxClockInHz", 20000000 }, // 20 MHz + Package (2) { "SPI1-SupportedDataBitLengths", Package() { 8 } }, // Data Bit Length + } + }) +} diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index ab5ea85cf9..9122f33d88 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -23,6 +23,11 @@ #endif #include <watchdog.h> #include <dm/pinctrl.h> +#include <dm/ofnode.h> +#include <acpi/acpi_table.h> +#include <acpi/acpigen.h> +#include <dm/lists.h> +#include <tables_csum.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -583,3 +588,181 @@ int ft_board_setup(void *blob, struct bd_info *bd)
return 0; } + +#if CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) +static bool is_rpi4(void) +{ + return of_machine_is_compatible("brcm,bcm2711") || + of_machine_is_compatible("brcm,bcm2712"); +} + +static bool is_rpi3(void) +{ + return of_machine_is_compatible("brcm,bcm2837"); +} + +static int acpi_rpi_board_fill_ssdt(struct acpi_ctx *ctx) +{ + int node, ret, uart_in_use, mini_clock_rate; + bool enabled; + struct udevice *dev; + struct { + const char *fdt_compatible; + const char *acpi_scope; + bool on_rpi4; + bool on_rpi3; + u32 mmio_address; + } map[] = { + {"brcm,bcm2711-pcie", "\_SB.PCI0", true, false}, + {"brcm,bcm2711-emmc2", "\_SB.GDV1.SDC3", true, false}, + {"brcm,bcm2835-pwm", "\_SB.GDV0.PWM0", true, true}, + {"brcm,bcm2711-genet-v5", "\_SB.ETH0", true, false}, + {"brcm,bcm2711-thermal", "\_SB.EC00", true, true}, + {"brcm,bcm2835-sdhci", "\_SB.SDC1", true, true}, + {"brcm,bcm2835-sdhost", "\_SB.SDC2", false, true}, + {"brcm,bcm2835-mbox", "\_SB.GDV0.RPIQ", true, true}, + {"brcm,bcm2835-i2c", "\_SB.GDV0.I2C1", true, true, 0xfe205000}, + {"brcm,bcm2835-i2c", "\_SB.GDV0.I2C2", true, true, 0xfe804000}, + {"brcm,bcm2835-spi", "\_SB.GDV0.SPI0", true, true}, + {"brcm,bcm2835-aux-spi", "\_SB.GDV0.SPI1", true, true, 0xfe215080}, + {"arm,pl011", "\_SB.URT0", true, true}, + {"brcm,bcm2835-aux-uart", "\_SB.URTM", true, true}, + { /* Sentinel */ } + }; + + /* Device enable */ + for (int i = 0; map[i].fdt_compatible; i++) { + if ((is_rpi4() && !map[i].on_rpi4) || + (is_rpi3() && !map[i].on_rpi3)) { + enabled = false; + } else { + node = fdt_node_offset_by_compatible(gd->fdt_blob, -1, + map[i].fdt_compatible); + while (node != -FDT_ERR_NOTFOUND && map[i].mmio_address) { + struct fdt_resource r; + + ret = fdt_get_resource(gd->fdt_blob, node, "reg", 0, &r); + if (ret) { + node = -FDT_ERR_NOTFOUND; + break; + } + + if (r.start == map[i].mmio_address) + break; + + node = fdt_node_offset_by_compatible(gd->fdt_blob, node, + map[i].fdt_compatible); + } + + enabled = (node > 0) ? fdtdec_get_is_enabled(gd->fdt_blob, node) : 0; + } + acpigen_write_scope(ctx, map[i].acpi_scope); + acpigen_write_name_integer(ctx, "_STA", enabled ? 0xf : 0); + acpigen_pop_len(ctx); + } + + /* GPIO quirks */ + node = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "brcm,bcm2835-gpio"); + if (node <= 0) + node = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "brcm,bcm2711-gpio"); + + acpigen_write_scope(ctx, "\_SB.GDV0.GPI0"); + enabled = (node > 0) ? fdtdec_get_is_enabled(gd->fdt_blob, node) : 0; + acpigen_write_name_integer(ctx, "_STA", enabled ? 0xf : 0); + acpigen_pop_len(ctx); + + if (is_rpi4()) { + /* eMMC quirks */ + node = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "brcm,bcm2711-emmc2"); + if (node) { + phys_addr_t cpu; + dma_addr_t bus; + u64 size; + + ret = fdt_get_dma_range(gd->fdt_blob, node, &cpu, &bus, &size); + + acpigen_write_scope(ctx, "\_SB.GDV1"); + acpigen_write_method_serialized(ctx, "_DMA", 0); + acpigen_emit_byte(ctx, RETURN_OP); + + if (!ret && bus != cpu) /* Translated DMA range */ + acpigen_emit_namestring(ctx, "\_SB.GDV1.DMTR"); + else if (!ret && bus == cpu) /* Non translated DMA */ + acpigen_emit_namestring(ctx, "\_SB.GDV1.DMNT"); + else /* Silicon revisions older than C0: Translated DMA range */ + acpigen_emit_namestring(ctx, "\_SB.GDV1.DMTR"); + acpigen_pop_len(ctx); + } + } + + /* Serial */ + uart_in_use = ~0; + mini_clock_rate = 0x1000000; + + ret = uclass_get_device_by_driver(UCLASS_SERIAL, + DM_DRIVER_GET(bcm283x_pl011_uart), + &dev); + if (!ret) + uart_in_use = 0; + + ret = uclass_get_device_by_driver(UCLASS_SERIAL, + DM_DRIVER_GET(serial_bcm283x_mu), + &dev); + if (!ret) { + if (uart_in_use == 0) + log_err("Invalid config: PL011 and MiniUART are both enabled."); + else + uart_in_use = 1; + + mini_clock_rate = dev_read_u32_default(dev, "clock", 0x1000000); + } + if (uart_in_use > 1) + log_err("No working serial: PL011 and MiniUART are both disabled."); + + acpigen_write_scope(ctx, "\_SB.BTH0"); + acpigen_write_name_integer(ctx, "URIU", uart_in_use); + acpigen_pop_len(ctx); + + acpigen_write_scope(ctx, "\_SB.URTM"); + acpigen_write_name_integer(ctx, "MUCR", mini_clock_rate); + acpigen_pop_len(ctx); + + return 0; +} + +static int rpi_acpi_write_ssdt(struct acpi_ctx *ctx, const struct acpi_writer *entry) +{ + struct acpi_table_header *ssdt; + int ret; + + ssdt = ctx->current; + memset(ssdt, '\0', sizeof(struct acpi_table_header)); + + acpi_fill_header(ssdt, "SSDT"); + ssdt->revision = acpi_get_table_revision(ACPITAB_SSDT); + ssdt->creator_revision = 1; + ssdt->length = sizeof(struct acpi_table_header); + + acpi_inc(ctx, sizeof(struct acpi_table_header)); + + ret = acpi_rpi_board_fill_ssdt(ctx); + if (ret) { + ctx->current = ssdt; + return log_msg_ret("fill", ret); + } + + /* (Re)calculate length and checksum */ + ssdt->length = ctx->current - (void *)ssdt; + ssdt->checksum = table_compute_checksum((void *)ssdt, ssdt->length); + log_debug("SSDT at %p, length %x\n", ssdt, ssdt->length); + + /* Drop the table if it is empty */ + if (ssdt->length == sizeof(struct acpi_table_header)) + return log_msg_ret("fill", -ENOENT); + acpi_add_table(ctx, ssdt); + + return 0; +} + +ACPI_WRITER(5ssdt, "SSDT", rpi_acpi_write_ssdt, 0); +#endif diff --git a/board/raspberrypi/rpi/sdhc.asl b/board/raspberrypi/rpi/sdhc.asl new file mode 100644 index 0000000000..3feac14acf --- /dev/null +++ b/board/raspberrypi/rpi/sdhc.asl @@ -0,0 +1,111 @@ +/** @file + * + * [DSDT] SD controller/card definition (SDHC) + * + * Copyright (c) 2020, Pete Batard pete@akeo.ie + * Copyright (c) 2018, Andrey Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +#include <asm/arch/acpi/bcm2836_sdhost.h> +#include <asm/arch/acpi/bcm2836_sdio.h> + +#include "acpitables.h" + +// +// Note: UEFI can use either SDHost or Arasan. We expose both to the OS. +// + +// ArasanSD 3.0 SD Host Controller. (brcm,bcm2835-sdhci) +Device (SDC1) +{ + Name (_HID, "BCM2847") + Name (_CID, "BCM2847") + Name (_UID, 0x0) + Name (_CCA, 0x0) + Name (_S1D, 0x1) + Name (_S2D, 0x1) + Name (_S3D, 0x1) + Name (_S4D, 0x1) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, MMCHS1_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Shared) { BCM2836_MMCHS1_INTERRUPT } + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, MMCHS1_OFFSET) + Return (^RBUF) + } + + // The standard CAPs registers on this controller + // appear to be 0, lets set some minimal defaults + // Since this cap doesn't indicate DMA capability + // we don't need a _DMA() + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () { "sdhci-caps", 0x0120fa81 }, + } + }) + + // + // A child device that represents the + // sd card, which is marked as non-removable. + // + Device (SDMM) + { + Method (_ADR) + { + Return (0) + } + Method (_RMV) // Is removable + { + Return (0) // 0 - fixed + } + } +} + +// Broadcom SDHost 2.0 SD Host Controller +Device (SDC2) +{ + Name (_HID, "BCM2855") + Name (_CID, "BCM2855") + Name (_UID, 0x0) + Name (_CCA, 0x0) + Name (_S1D, 0x1) + Name (_S2D, 0x1) + Name (_S3D, 0x1) + Name (_S4D, 0x1) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, SDHOST_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_SDHOST_INTERRUPT } + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, SDHOST_OFFSET) + Return (^RBUF) + } + + // + // A child device that represents the + // sd card, which is marked as non-removable. + // + Device (SDMM) + { + Method (_ADR) + { + Return (0) + } + Method (_RMV) // Is removable + { + Return (0) // 0 - fixed + } + } +} \ No newline at end of file diff --git a/board/raspberrypi/rpi/uart.asl b/board/raspberrypi/rpi/uart.asl new file mode 100644 index 0000000000..78dc9a74df --- /dev/null +++ b/board/raspberrypi/rpi/uart.asl @@ -0,0 +1,208 @@ +/** @file + * + * [DSDT] Serial devices (UART). + * + * Copyright (c) 2021, ARM Limited. All rights reserved. + * Copyright (c) 2020, Pete Batard pete@akeo.ie + * Copyright (c) 2018, Andrey Warkentin andrey.warkentin@gmail.com + * Copyright (c) Microsoft Corporation. All rights reserved. + * + * SPDX-License-Identifier: BSD-2-Clause-Patent + * + **/ + +#include <asm/arch/acpi/bcm2836.h> + +#include "acpitables.h" + +// PL011 based UART. +Device (URT0) +{ + Name (_HID, "BCM2837") + Name (_CID, "ARMH0011") + Name (_UID, 0x4) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_PL011_UART_LENGTH, RMEM) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) { BCM2836_PL011_UART_INTERRUPT } + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_PL011_UART_OFFSET) + Return (^RBUF) + } + + Name (CLCK, 48000000) + + Name (_DSD, Package () + { + ToUUID ("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), Package () + { + Package (2) { "clock-frequency", CLCK }, + } + }) +} + +// +// UART Mini. +// +// This device is referenced in the DBG2 table, which will cause the system to +// not start the driver when the debugger is enabled and to mark the device +// with problem code 53 (CM_PROB_USED_BY_DEBUGGER). +// + +Device (URTM) +{ + Name (_HID, "BCM2836") + Name (_CID, "BCM2836") + Name (_UID, 0x0) + Name (_CCA, 0x0) + + Name (RBUF, ResourceTemplate () + { + MEMORY32FIXED (ReadWrite, 0, BCM2836_MINI_UART_LENGTH, RMEM) + Interrupt(ResourceConsumer, Level, ActiveHigh, Shared) { BCM2836_MINI_UART_INTERRUPT } + + }) + Method (_CRS, 0x0, Serialized) + { + MEMORY32SETBASE (RBUF, RMEM, RBAS, BCM2836_MINI_UART_OFFSET) + Return (^RBUF) + } + + // + // Mini Uart Clock Rate will be dynamically updated during boot + // + External (_SB.URTM.MUCR, IntObj) + + Name (_DSD, Package () + { + ToUUID ("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), Package () + { + Package (2) { "clock-frequency", MUCR }, + } + }) +} + +// +// Multifunction serial bus device to support Bluetooth function. +// +Device(BTH0) +{ + Name (_HID, "BCM2EA6") + Name (_CID, "BCM2EA6") + + // + // UART In Use will be dynamically updated during boot + // + External (_SB.BTH0.URIU, IntObj) + + Method (_STA) + { + Return (0xf) + } + + // + // Resource for URT0 (PL011) + // + Name (BTPL, ResourceTemplate () + { + UARTSerialBus( + 115200, // InitialBaudRate: in BPS + , // BitsPerByte: default to 8 bits + , // StopBits: Defaults to one bit + 0x00, // LinesInUse: 8 1-bit flags to + // declare enabled control lines. + // Raspberry Pi does not exposed + // HW control signals -> not supported. + // Optional bits: + // - Bit 7 (0x80) Request To Send (RTS) + // - Bit 6 (0x40) Clear To Send (CTS) + // - Bit 5 (0x20) Data Terminal Ready (DTR) + // - Bit 4 (0x10) Data Set Ready (DSR) + // - Bit 3 (0x08) Ring Indicator (RI) + // - Bit 2 (0x04) Data Carrier Detect (DTD) + // - Bit 1 (0x02) Reserved. Must be 0. + // - Bit 0 (0x01) Reserved. Must be 0. + , // IsBigEndian: + // default to LittleEndian. + , // Parity: Defaults to no parity + , // FlowControl: Defaults to + // no flow control. + 16, // ReceiveBufferSize + 16, // TransmitBufferSize + "\_SB.GDV0.URT0", // ResourceSource: + // UART bus controller name + , // ResourceSourceIndex: assumed to be 0 + , // ResourceUsage: assumed to be + // ResourceConsumer + UAR0, // DescriptorName: creates name + // for offset of resource descriptor + ) // Vendor data + }) + + // + // Resource for URTM (miniUART) + // + Name (BTMN, ResourceTemplate () + { + // + // BT UART: ResourceSource will be dynamically updated to + // either URT0 (PL011) or URTM (miniUART) during boot + // + UARTSerialBus( + 115200, // InitialBaudRate: in BPS + , // BitsPerByte: default to 8 bits + , // StopBits: Defaults to one bit + 0x00, // LinesInUse: 8 1-bit flags to + // declare enabled control lines. + // Raspberry Pi does not exposed + // HW control signals -> not supported. + // Optional bits: + // - Bit 7 (0x80) Request To Send (RTS) + // - Bit 6 (0x40) Clear To Send (CTS) + // - Bit 5 (0x20) Data Terminal Ready (DTR) + // - Bit 4 (0x10) Data Set Ready (DSR) + // - Bit 3 (0x08) Ring Indicator (RI) + // - Bit 2 (0x04) Data Carrier Detect (DTD) + // - Bit 1 (0x02) Reserved. Must be 0. + // - Bit 0 (0x01) Reserved. Must be 0. + , // IsBigEndian: + // default to LittleEndian. + , // Parity: Defaults to no parity + , // FlowControl: Defaults to + // no flow control. + 16, // ReceiveBufferSize + 16, // TransmitBufferSize + "\_SB.GDV0.URTM", // ResourceSource: + // UART bus controller name + , // ResourceSourceIndex: assumed to be 0 + , // ResourceUsage: assumed to be + // ResourceConsumer + UARM, // DescriptorName: creates name + // for offset of resource descriptor + ) // Vendor data + }) + + Method (_CRS, 0x0, Serialized) + { + if (URIU == 0) + { + // + // PL011 UART is configured for console output + // Return Mini UART for Bluetooth + // + return (^BTMN) + } + else + { + // + // Mini UART is configured for console output + // Return PL011 UART for Bluetooth + // + return (^BTPL) + } + } +}
On Arm platforms that use ACPI they cannot rely on the "spin-table" CPU bringup usually defined in the FDT. Thus implement the 'ACPI Multi-processor Startup for ARM Platforms', also referred to as 'ACPI parking protocol'.
The ACPI parking protocol works similar to the spin-table mechanism, but the specification also covers lots of shortcomings of the spin-table implementations.
Every CPU defined in the ACPI MADT table has it's own 4K page where the spinloop code and the OS mailbox resides. When selected the U-Boot board code must make sure that the secondary CPUs enter u-boot after relocation as well, so that they can enter the spinloop code residing in the ACPI parking protocol pages.
The OS will then write to the mailbox and generate an IPI to release the CPUs from the spinloop code.
For now it's only implemented on ARMv8, but can easily be extended to other platforms, like ARMv7.
TEST: Boots all CPUs on qemu-system-aarch64 -machine raspi4b
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- Changelog v2: - Use shorter function names - Drop the use of atomics, they do not work on real hardware - Rewrite code and verify on real hardware that CPUs are spinning inside their parking protocol spin-loop code Changelog v4: - Shorten names - Fix coding style - Drop extern from the headers Changelog v6: - Update header order --- arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/acpi_park_v8.S | 113 ++++++++++++++++++++++ arch/arm/include/asm/acpi_table.h | 32 +++++++ arch/arm/lib/acpi_table.c | 149 ++++++++++++++++++++++++++++++ include/acpi/acpi_table.h | 10 ++ include/bloblist.h | 1 + lib/Kconfig | 16 ++++ lib/acpi/acpi_table.c | 4 + 8 files changed, 326 insertions(+) create mode 100644 arch/arm/cpu/armv8/acpi_park_v8.S
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index bba4f570db..4f4368ff8c 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -29,6 +29,7 @@ obj-$(CONFIG_ARM_SMCCC) += smccc-call.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMV8_SPIN_TABLE) += spin_table.o spin_table_v8.o +obj-$(CONFIG_ACPI_PARKING_PROTOCOL) += acpi_park_v8.o else obj-$(CONFIG_ARCH_SUNXI) += fel_utils.o endif diff --git a/arch/arm/cpu/armv8/acpi_park_v8.S b/arch/arm/cpu/armv8/acpi_park_v8.S new file mode 100644 index 0000000000..0bc605d28d --- /dev/null +++ b/arch/arm/cpu/armv8/acpi_park_v8.S @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2024 9elements GmbH + * Author: Patrick Rudolph patrick.rudolph@9elements.com + * + * This file provides ARMv8 specific code for the generic part of the + * ACPI parking protocol implementation. It contains the spinning code + * that will be installed into the parking protocol and it points the + * secondary CPUs to their own parking protocol page once it has been + * set up by the generic part. + */ + +#include <asm/acpi_table.h> +#include <linux/linkage.h> + +/* Filled by C code */ +.global acpi_pp_tables +acpi_pp_tables: + .quad 0 + +.global acpi_pp_etables +acpi_pp_etables: + .quad 0 + +/* Read by C code */ +.global acpi_pp_code_size +acpi_pp_code_size: + .word __secondary_pp_code_end - __secondary_pp_code_start + +.global acpi_pp_secondary_jump +ENTRY(acpi_pp_secondary_jump) +0: + /* + * Cannot use atomic operations since the MMU and D-cache + * might be off. Use the MPIDR instead to find the spintable. + */ + + /* Check if parking protocol table is ready */ + ldr x1, =acpi_pp_tables + ldr x0, [x1] + cbnz x0, 0f + wfe + b 0b + +0: /* Get end of page tables in x3 */ + ldr x1, =acpi_pp_etables + ldr x3, [x1] + + /* Get own CPU ID in w2 */ + mrs x2, mpidr_el1 + lsr x9, x2, #32 + bfi x2, x9, #24, #8 /* w2 is aff3:aff2:aff1:aff0 */ + +0: /* Loop over all parking protocol pages */ + cmp x0, x3 + b.ge hlt + + /* Fetch CPU_ID from current page */ + ldr x1, [x0, #ACPI_PP_CPU_ID_OFFSET] + lsr x9, x1, #32 + bfi x1, x9, #24, #8 /* w1 is aff3:aff2:aff1:aff0 */ + + /* Compare CPU_IDs */ + cmp w1, w2 + b.eq 0f + + add x0, x0, #ACPI_PP_PAGE_SIZE + b 0b + +hlt: wfi + b hlt /* Should never happen. */ + +0: /* x0 points to the 4K-aligned, parking protocol page */ + add x2, x0, #ACPI_PP_CPU_CODE_OFFSET + + /* Jump to spin code in own parking protocol page */ + br x2 +ENDPROC(acpi_pp_secondary_jump) + +.align 8 +__secondary_pp_code_start: +.global acpi_pp_code_start +ENTRY(acpi_pp_code_start) + /* x0 points to the 4K-aligned, parking protocol page */ + + /* Prepare defines for spinning code */ + mov w3, #ACPI_PP_CPU_ID_INVALID + mov x2, #ACPI_PP_JMP_ADR_INVALID + + /* Mark parking protocol page as ready */ + str w3, [x0, #ACPI_PP_CPU_ID_OFFSET] + dsb sy + +0: wfe + ldr w1, [x0, #ACPI_PP_CPU_ID_OFFSET] + + /* Check CPU ID is valid */ + cmp w1, w3 + b.eq 0b + + /* Check jump address valid */ + ldr x1, [x0, #ACPI_PP_CPU_JMP_OFFSET] + cmp x1, x2 + b.eq 0b + + /* Clear jump address before jump */ + str x2, [x0, #ACPI_PP_CPU_JMP_OFFSET] + dsb sy + + br x1 +ENDPROC(acpi_pp_code_start) + /* Secondary Boot Code ends here */ +__secondary_pp_code_end: diff --git a/arch/arm/include/asm/acpi_table.h b/arch/arm/include/asm/acpi_table.h index c65eabe837..7386f55ad3 100644 --- a/arch/arm/include/asm/acpi_table.h +++ b/arch/arm/include/asm/acpi_table.h @@ -4,6 +4,7 @@ #define __ASM_ACPI_TABLE_H__
#ifndef __ACPI__ +#ifndef __ASSEMBLY__
@@ -109,7 +110,38 @@ int acpi_pptt_add_cache(struct acpi_ctx *ctx, const u32 flags, const u32 sets, const u8 assoc, const u8 attributes, const u16 line_size);
+/* Multi-processor Startup for ARM Platforms */ +/** + * struct acpi_pp_page - MP startup handshake mailbox + * + * Defines a 4096 byte memory region that is used for starting secondary CPUs on + * an Arm system that follows the "Multi-processor Startup for ARM Platforms" spec. + * + * @cpu_id: MPIDR as returned by the Multiprocessor Affinity Register. + * On 32bit Arm systems the upper bits are unused. + * @jumping_address: On 32bit Arm systems the address must be below 4 GiB + * @os_reserved: Reserved for OS use. Firmware must not access this memory. + * @spinning_code: Reserved for firmware use. OS must not access this memory. + * The spinning code will be installed by firmware and the secondary + * CPUs will enter it before the control is handed over to the OS. + */ +struct acpi_pp_page { + u64 cpu_id; + u64 jumping_address; + u8 os_reserved[2032]; + u8 spinning_code[2048]; +} __packed; + #endif /* !__ASSEMBLY__ */ #endif /* !__ACPI__ */
+/* Multi-processor Startup for ARM Platforms defines */ +#define ACPI_PP_CPU_ID_INVALID 0xffffffff +#define ACPI_PP_JMP_ADR_INVALID 0 +#define ACPI_PP_PAGE_SIZE 4096 +#define ACPI_PP_CPU_ID_OFFSET 0 +#define ACPI_PP_CPU_JMP_OFFSET 8 +#define ACPI_PP_CPU_CODE_OFFSET 2048 +#define ACPI_PP_VERSION 1 + #endif /* __ASM_ACPI_TABLE_H__ */ diff --git a/arch/arm/lib/acpi_table.c b/arch/arm/lib/acpi_table.c index e0add04926..f760b7fbce 100644 --- a/arch/arm/lib/acpi_table.c +++ b/arch/arm/lib/acpi_table.c @@ -7,12 +7,48 @@
#define LOG_CATEGORY LOGC_ACPI
+#include <bloblist.h> +#include <cpu_func.h> +#include <efi_loader.h> +#include <malloc.h> #include <string.h> +#include <tables_csum.h> #include <acpi/acpigen.h> #include <acpi/acpi_device.h> #include <acpi/acpi_table.h> +#include <asm-generic/io.h> #include <dm/acpi.h> #include <dm/uclass.h> +#include <linux/log2.h> +#include <linux/sizes.h> + +/* defined in assembly file */ +/** + * acpi_pp_code_size - Spinloop code size * + */ +extern u16 acpi_pp_code_size; + +/** + * acpi_pp_tables - Start of ACPI PP tables. + */ +extern ulong acpi_pp_tables; + +/** + * acpi_pp_etables - End of ACPI PP tables. + */ +extern ulong acpi_pp_etables; + +/** + * acpi_pp_code_start() - Spinloop code + * + * Architectural spinloop code to be installed in each parking protocol + * page. The spinloop code must be less than 2048 bytes. + * + * The spinloop code will be entered after calling + * acpi_parking_protocol_install(). + * + */ +void acpi_pp_code_start(void);
void acpi_write_madt_gicc(struct acpi_madt_gicc *gicc, uint cpu_num, uint perf_gsiv, ulong phys_base, ulong gicv, @@ -125,3 +161,116 @@ void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx)
return ctx->current; } + +/** + * acpi_write_pp_setup_one_page() - Fill out one page used by the PP + * + * Fill out the struct acpi_pp_page to contain the spin-loop + * code and the mailbox area. After this function the page is ready for + * the secondary core's to enter the spin-loop code. + * + * @page: Pointer to current parking protocol page + * @gicc: Pointer to corresponding GICC sub-table + */ +static void acpi_write_pp_setup_one_page(struct acpi_pp_page *page, + struct acpi_madt_gicc *gicc) +{ + void *reloc; + + /* Update GICC. Mark parking protocol as available. */ + gicc->parking_proto = ACPI_PP_VERSION; + gicc->parked_addr = virt_to_phys(page); + + /* Prepare parking protocol page */ + memset(page, '\0', sizeof(struct acpi_pp_page)); + + /* Init mailbox. Set MPIDR so core's will find their page. */ + page->cpu_id = gicc->mpidr; + page->jumping_address = ACPI_PP_JMP_ADR_INVALID; + + /* Relocate spinning code */ + reloc = &page->spinning_code[0]; + + log_debug("Relocating spin table from %lx to %lx (size %x)\n", + (ulong)&acpi_pp_code_start, (ulong)reloc, acpi_pp_code_size); + memcpy(reloc, &acpi_pp_code_start, acpi_pp_code_size); + + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) + flush_dcache_range((unsigned long)page, + (unsigned long)(page + 1)); +} + +void acpi_write_park(struct acpi_madt *madt) +{ + struct acpi_pp_page *start, *page; + struct acpi_madt_gicc *gicc; + int ret, i, ncpus = 0; + + /* + * According to the "Multi-processor Startup for ARM Platforms": + * - Every CPU as specified by MADT GICC has it's own 4K page + * - Every page is divided into two sections: OS and FW reserved + * - Memory occupied by "Parking Protocol" must be marked 'Reserved' + * - Spinloop code should reside in FW reserved 2048 bytes + * - Spinloop code will check the mailbox in OS reserved area + */ + + if (acpi_pp_code_size > sizeof(page->spinning_code)) { + log_err("Spinning code too big to fit: %d\n", + acpi_pp_code_size); + return; + } + + /* Count all MADT GICCs including BSP */ + for (i = sizeof(struct acpi_madt); i < madt->header.length; + i += gicc->length) { + gicc = (struct acpi_madt_gicc *)((void *)madt + i); + if (gicc->type != ACPI_APIC_GICC) + continue; + ncpus++; + } + log_debug("Found %#x GICCs in MADT\n", ncpus); + + /* Allocate pages linearly due to assembly code requirements */ + start = bloblist_add(BLOBLISTT_ACPI_PP, ACPI_PP_PAGE_SIZE * ncpus, + ilog2(SZ_4K)); + if (!start) { + log_err("Failed to allocate memory for ACPI-parking-protocol pages\n"); + return; + } + log_debug("Allocated parking protocol at %p\n", start); + page = start; + + if (IS_ENABLED(CONFIG_EFI_LOADER)) { + /* Default mapping is 'BOOT CODE'. Mark as reserved instead. */ + ret = efi_add_memory_map((u64)(uintptr_t)start, + ncpus * ACPI_PP_PAGE_SIZE, + EFI_RESERVED_MEMORY_TYPE); + + if (ret) + log_err("Reserved memory mapping failed addr %p size %x\n", + start, ncpus * ACPI_PP_PAGE_SIZE); + } + + /* Prepare the parking protocol pages */ + for (i = sizeof(struct acpi_madt); i < madt->header.length; + i += gicc->length) { + gicc = (struct acpi_madt_gicc *)((void *)madt + i); + if (gicc->type != ACPI_APIC_GICC) + continue; + + acpi_write_pp_setup_one_page(page++, gicc); + } + + acpi_pp_etables = virt_to_phys(start) + + ACPI_PP_PAGE_SIZE * ncpus; + acpi_pp_tables = virt_to_phys(start); + + /* Make sure other cores see written value in memory */ + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) + flush_dcache_all(); + + /* Send an event to wake up the secondary CPU. */ + asm("dsb ishst\n" + "sev"); +} diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 07c5f65d75..b8b1f1338c 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -1237,6 +1237,16 @@ int acpi_iort_add_smmu_v3(struct acpi_ctx *ctx, */ void *acpi_fill_madt(struct acpi_madt *madt, struct acpi_ctx *ctx);
+/** + * acpi_write_park() - Installs the ACPI parking protocol. + * + * Sets up the ACPI parking protocol and installs the spinning code for + * secondary CPUs. + * + * @madt: The MADT to update + */ +void acpi_write_park(struct acpi_madt *madt); + /** * acpi_get_rsdp_addr() - get ACPI RSDP table address * diff --git a/include/bloblist.h b/include/bloblist.h index b0706b5637..ff32d3fecf 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -110,6 +110,7 @@ enum bloblist_tag_t { BLOBLISTT_ACPI_TABLES = 4, BLOBLISTT_TPM_EVLOG = 5, BLOBLISTT_TPM_CRB_BASE = 6, + BLOBLISTT_ACPI_PP = 7,
/* Standard area to allocate blobs used across firmware components */ BLOBLISTT_AREA_FIRMWARE = 0x10, diff --git a/lib/Kconfig b/lib/Kconfig index 2e0fc1bc8f..6ad079a128 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -315,6 +315,22 @@ config GENERATE_ACPI_TABLE by the operating system. It defines platform-independent interfaces for configuration and power management monitoring.
+config ACPI_PARKING_PROTOCOL + bool "Support ACPI parking protocol method" + depends on GENERATE_ACPI_TABLE + depends on ARMV8_MULTIENTRY + depends on BLOBLIST_TABLES + default y if !SEC_FIRMWARE_ARMV8_PSCI && !ARMV8_PSCI + help + Say Y here to support "ACPI parking protocol" enable method + for booting Linux. + + To use this feature, you must do: + - Bring secondary CPUs into U-Boot proper in a board-specific + manner. This must be done *after* relocation. Otherwise, the + secondary CPUs will spin in unprotected memory-area because the + master CPU protects the relocated spin code. + config SPL_TINY_MEMSET bool "Use a very small memset() in SPL" depends on SPL diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index e6ebffcf1b..6473d95c10 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -297,6 +297,10 @@ int acpi_write_madt(struct acpi_ctx *ctx, const struct acpi_writer *entry)
/* (Re)calculate length and checksum */ header->length = (uintptr_t)current - (uintptr_t)madt; + + if (IS_ENABLED(CONFIG_ACPI_PARKING_PROTOCOL)) + acpi_write_park(madt); + header->checksum = table_compute_checksum((void *)madt, header->length); acpi_add_table(ctx, madt); ctx->current = (void *)madt + madt->header.length;
Update the generic entry point code to support the ACPI parking protocol. The ACPI parking protocol can be used when PSCI is not available to bring up secondary CPU cores.
When enabled secondary CPUs will enter U-Boot proper and spin in their own 4KiB reserved memory page, which also acts as mailbox with the OS to release the CPU.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/cpu/armv8/start.S | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 7461280261..544a4a5364 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -178,6 +178,18 @@ pie_fixup_done: branch_if_master x0, master_cpu b spin_table_secondary_jump /* never return */ +#elif defined(CONFIG_ACPI_PARKING_PROTOCOL) && !defined(CONFIG_SPL_BUILD) + branch_if_master x0, master_cpu + /* + * Waits for ACPI parking protocol memory to be allocated and the spin-table + * code to be written. Once ready the secondary CPUs will jump and spin in + * their own 4KiB memory region, which is also used as mailbox, until released + * by the OS. + * The mechanism is similar to the DT enable-method = "spin-table", but works + * with ACPI enabled platforms. + */ + b acpi_pp_secondary_jump + /* never return */ #elif defined(CONFIG_ARMV8_MULTIENTRY) branch_if_master x0, master_cpu
Implement read_mpidr() on armv7 to make use of it in generic code that compiles on both armv7 and armv8.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/include/asm/system.h | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index 2237d7d006..9eb30c2ade 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -394,6 +394,15 @@ void switch_to_hypervisor_ret(void); #define wfi() #endif
+static inline unsigned long read_mpidr(void) +{ + unsigned long val; + + asm volatile("mrc p15, 0, %0, c0, c0, 5" : "=r" (val)); + + return val; +} + static inline unsigned long get_cpsr(void) { unsigned long cpsr;
When ACPI is enabled over FDT the APs cannot be brought out of reset by the OS using the "FDT spin-table" mechanism, as no FDT is provided to the OS. The APs must be released out of reset in u-boot and then brought up in an ACPI compliant fashion.
When ARMV8_MULTIENTRY is specified, the APs are released from reset and will enter U-Boot after it has been relocated as well.
By default ARMV8_MULTIENTRY is not selected, keeping existing behaviour.
TEST: All APs enter U-Boot when run on qemu-system-aarch64 and on real hardware.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Matthias Brugger mbrugger@suse.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Tom Rini trini@konsulko.com --- Changelog v2: - Drop CPU code from board - Add CPU driver to release APs from reset Changelog v4: - Use the generic armv8 CPU driver - Probe all CPUs - Release secondary CPUs in the probe function - Use of_to_plat() to parse DT - Drop udelay() - Select the GICv2 driver Changelog v5: - Cosmetic fixes - Drop arch_early_init_r() Changelog v6: - Update header order - Drop ifdef --- arch/arm/Kconfig | 1 + arch/arm/mach-bcm283x/Kconfig | 5 +- drivers/cpu/Makefile | 2 +- drivers/cpu/bcm283x_cpu.c | 214 ++++++++++++++++++++++++++++++++++ 4 files changed, 220 insertions(+), 2 deletions(-) create mode 100644 drivers/cpu/bcm283x_cpu.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0d0c731dd0..787f983ffd 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -651,6 +651,7 @@ config ARCH_ORION5X
config ARCH_BCM283X bool "Broadcom BCM283X family" + select CPU select DM select DM_GPIO select DM_SERIAL diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index b3287ce8bc..0ef8156c64 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -24,7 +24,9 @@ config BCM2837_64B bool "Broadcom BCM2837 SoC 64-bit support" depends on ARCH_BCM283X select BCM2837 + select DRIVER_GICV2 select ARM64 + select CPU_ARMV8
config BCM2711 bool "Broadcom BCM2711 SoC support" @@ -42,11 +44,12 @@ config BCM2711_64B bool "Broadcom BCM2711 SoC 64-bit support" depends on ARCH_BCM283X select BCM2711 + select DRIVER_GICV2 select ARM64 + select CPU_ARMV8
menu "Broadcom BCM283X family" depends on ARCH_BCM283X - choice prompt "Broadcom BCM283X board select" optional diff --git a/drivers/cpu/Makefile b/drivers/cpu/Makefile index 773395693a..eaf494706e 100644 --- a/drivers/cpu/Makefile +++ b/drivers/cpu/Makefile @@ -6,7 +6,7 @@
obj-$(CONFIG_CPU) += cpu-uclass.o
- +obj-$(CONFIG_ARCH_BCM283X) += bcm283x_cpu.o obj-$(CONFIG_ARCH_BMIPS) += bmips_cpu.o obj-$(CONFIG_ARCH_IMX8) += imx8_cpu.o obj-$(CONFIG_ARCH_AT91) += at91_cpu.o diff --git a/drivers/cpu/bcm283x_cpu.c b/drivers/cpu/bcm283x_cpu.c new file mode 100644 index 0000000000..59a7b142c9 --- /dev/null +++ b/drivers/cpu/bcm283x_cpu.c @@ -0,0 +1,214 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 9elements GmbH + */ + +#include <cpu.h> +#include <cpu_func.h> +#include <dm.h> +#include <fdt_support.h> +#include <acpi/acpigen.h> +#include <asm/armv8/cpu.h> +#include <asm/cache.h> +#include <asm/io.h> +#include <asm/global_data.h> +#include <asm/system.h> +#include <asm-generic/sections.h> +#include <linux/bitops.h> +#include <linux/clk-provider.h> +#include <linux/delay.h> +#include "armv8_cpu.h" + +DECLARE_GLOBAL_DATA_PTR; + +struct bcm_plat { + u64 release_addr; +}; + +static int cpu_bcm_get_desc(const struct udevice *dev, char *buf, int size) +{ + struct cpu_plat *plat = dev_get_parent_plat(dev); + const char *name; + + if (size < 32) + return -ENOSPC; + + if (device_is_compatible(dev, "arm,cortex-a53")) + name = "A53"; + else if (device_is_compatible(dev, "arm,cortex-a72")) + name = "A72"; + else + name = "?"; + + snprintf(buf, size, "Broadcom Cortex-%s at %u MHz\n", + name, plat->timebase_freq); + + return 0; +} + +static int cpu_bcm_get_info(const struct udevice *dev, struct cpu_info *info) +{ + struct cpu_plat *plat = dev_get_parent_plat(dev); + + info->cpu_freq = plat->timebase_freq * 1000; + info->features = BIT(CPU_FEAT_L1_CACHE) | BIT(CPU_FEAT_MMU); + + return 0; +} + +static int cpu_bcm_get_count(const struct udevice *dev) +{ + return uclass_id_count(UCLASS_CPU); +} + +static int cpu_bcm_get_vendor(const struct udevice *dev, char *buf, int size) +{ + snprintf(buf, size, "Broadcom"); + + return 0; +} + +static int cpu_bcm_is_current(struct udevice *dev) +{ + struct cpu_plat *plat = dev_get_parent_plat(dev); + + if (plat->cpu_id == (read_mpidr() & 0xffff)) + return 1; + + return 0; +} + +/** + * bcm_cpu_on - Releases the secondary CPU from it's spintable + * + * Write the CPU's spintable mailbox and let the CPU enter U-Boot. + * + * @dev: Device to start + * @return: zero on success or error code on failure. + */ +static int bcm_cpu_on(struct udevice *dev) +{ + struct bcm_plat *plat = dev_get_plat(dev); + ulong *start_address; + + if (plat->release_addr == ~0ULL) + return -ENODATA; + + start_address = map_physmem(plat->release_addr, sizeof(uintptr_t), MAP_NOCACHE); + + /* Point secondary CPU to U-Boot entry */ + *start_address = (uintptr_t)_start; + + /* Make sure the other CPUs see the written start address */ + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) + flush_dcache_all(); + + /* Send an event to wake up the secondary CPU. */ + asm("dsb ishst\n" + "sev"); + + unmap_physmem(start_address, MAP_NOCACHE); + + return 0; +} + +static const struct cpu_ops cpu_bcm_ops = { + .get_desc = cpu_bcm_get_desc, + .get_info = cpu_bcm_get_info, + .get_count = cpu_bcm_get_count, + .get_vendor = cpu_bcm_get_vendor, + .is_current = cpu_bcm_is_current, +}; + +static const struct udevice_id cpu_bcm_ids[] = { + { .compatible = "arm,cortex-a53" }, /* RPi 3 */ + { .compatible = "arm,cortex-a72" }, /* RPi 4 */ + { } +}; + +static int bcm_cpu_bind(struct udevice *dev) +{ + struct cpu_plat *plat = dev_get_parent_plat(dev); + + plat->cpu_id = dev_read_addr(dev); + + return 0; +} + +/** + * bcm_cpu_of_to_plat - Gather spin-table release address + * + * Read the spin-table release address to allow all seconary CPUs to enter + * U-Boot when necessary. + * + * @dev: Device to start + */ +static int bcm_cpu_of_to_plat(struct udevice *dev) +{ + struct bcm_plat *plat = dev_get_plat(dev); + const char *prop; + + if (CONFIG_IS_ENABLED(ARMV8_MULTIENTRY)) { + plat->release_addr = ~0ULL; + + prop = dev_read_string(dev, "enable-method"); + if (!prop || strcmp(prop, "spin-table")) + return -ENODEV; + + plat->release_addr = dev_read_u64_default(dev, "cpu-release-addr", ~0ULL); + + if (plat->release_addr == ~0ULL) + return -ENODEV; + } + + return 0; +} + +static int bcm_cpu_probe(struct udevice *dev) +{ + struct cpu_plat *plat = dev_get_parent_plat(dev); + struct clk clk; + int ret; + + /* Get a clock if it exists */ + ret = clk_get_by_index(dev, 0, &clk); + if (!ret) { + ret = clk_enable(&clk); + if (ret && (ret != -ENOSYS || ret != -EOPNOTSUPP)) + return ret; + ret = clk_get_rate(&clk); + if (IS_ERR_VALUE(ret)) + return ret; + plat->timebase_freq = ret; + } + + /* + * The armstub holds the secondary CPUs in a spinloop. When + * ARMV8_MULTIENTRY is enabled release the secondary CPUs and + * let them enter U-Boot as well. + */ + if (CONFIG_IS_ENABLED(ARMV8_MULTIENTRY)) { + ret = bcm_cpu_on(dev); + if (ret) + return ret; + } + + return ret; +} + +struct acpi_ops bcm283x_cpu_acpi_ops = { + .fill_ssdt = armv8_cpu_fill_ssdt, + .fill_madt = armv8_cpu_fill_madt, +}; + +U_BOOT_DRIVER(cpu_bcm_drv) = { + .name = "bcm283x_cpu", + .id = UCLASS_CPU, + .of_match = cpu_bcm_ids, + .ops = &cpu_bcm_ops, + .probe = bcm_cpu_probe, + .bind = bcm_cpu_bind, + .of_to_plat = bcm_cpu_of_to_plat, + .plat_auto = sizeof(struct bcm_plat), + ACPI_OPS_PTR(&bcm283x_cpu_acpi_ops) +};
On FDT platforms the APs are brought out of reset using the spin-table as defined in the DT. On ACPI enabled platforms there's no FDT, thus enable the ARMV8_MULTIENTRY and BLOBLIST to use the ACPI parking protocol instead.
TEST: - APs enter Linux when run on qemu-system-aarch64 -machine raspi4b - APs on real hardware do not enter Linux, but continue spinning in their ACPI parking protocol spinloop. To be investigated.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Matthias Brugger mbrugger@suse.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Tom Rini trini@konsulko.com --- arch/arm/mach-bcm283x/Kconfig | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index 0ef8156c64..d9303e8c28 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -27,6 +27,10 @@ config BCM2837_64B select DRIVER_GICV2 select ARM64 select CPU_ARMV8 + select ARMV8_MULTIENTRY if GENERATE_ACPI_TABLE + select BLOBLIST if GENERATE_ACPI_TABLE + select BLOBLIST_ALLOC if GENERATE_ACPI_TABLE + select BLOBLIST_TABLES if GENERATE_ACPI_TABLE
config BCM2711 bool "Broadcom BCM2711 SoC support" @@ -47,6 +51,10 @@ config BCM2711_64B select DRIVER_GICV2 select ARM64 select CPU_ARMV8 + select ARMV8_MULTIENTRY if GENERATE_ACPI_TABLE + select BLOBLIST if GENERATE_ACPI_TABLE + select BLOBLIST_ALLOC if GENERATE_ACPI_TABLE + select BLOBLIST_TABLES if GENERATE_ACPI_TABLE
menu "Broadcom BCM283X family" depends on ARCH_BCM283X @@ -213,6 +221,9 @@ config SYS_SOC config SYS_CONFIG_NAME default "rpi"
+config BLOBLIST_SIZE_RELOC + default 0x20000 + source "board/raspberrypi/rpi/Kconfig"
endmenu
Initialize addr to zero which allows to build on the CI which is more strict.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org --- common/bloblist.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/bloblist.c b/common/bloblist.c index 2008ab4d25..cf1a3b8b62 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -499,7 +499,7 @@ int bloblist_init(void) { bool fixed = IS_ENABLED(CONFIG_BLOBLIST_FIXED); int ret = -ENOENT; - ulong addr, size; + ulong addr = 0, size; /* * If U-Boot is not in the first phase, an existing bloblist must be * at a fixed address.
Allows to build the RPi4 with ACPI enabled.
TEST: - Boots on qemu-system-aarch64 -machine raspi4b - Boots on real hardware with arm_64bit=1 in config.txt
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Matthias Brugger mbrugger@suse.com Cc: Peter Robinson pbrobinson@gmail.com --- Changelog v4: - Enable BLOBLISTS Changelog v5: - Enable OF_BOARD Changelog v5: - Use include --- configs/rpi_4_acpi_defconfig | 10 ++++++++++ 1 file changed, 10 insertions(+) create mode 100644 configs/rpi_4_acpi_defconfig
diff --git a/configs/rpi_4_acpi_defconfig b/configs/rpi_4_acpi_defconfig new file mode 100644 index 0000000000..b32dfc16a1 --- /dev/null +++ b/configs/rpi_4_acpi_defconfig @@ -0,0 +1,10 @@ +#include <configs/rpi_4_defconfig> + +CONFIG_ARM=y +CONFIG_ARCH_BCM283X=y +CONFIG_TARGET_RPI_4=y +CONFIG_BLOBLIST_ALLOC=y +CONFIG_OF_BOARD=y +CONFIG_ACPI=y +CONFIG_GENERATE_ACPI_TABLE=y +
Add QEMU's SBSA ref board to azure pipelines and gitlab CI to run tests on it. TEST: Run on Azure pipelines and confirmed that tests succeed.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-by: Tom Rini trini@konsulko.com --- Changelog v6: - Add gitlab CI support --- .azure-pipelines.yml | 8 ++++++++ .gitlab-ci.yml | 11 +++++++++++ 2 files changed, 19 insertions(+)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 93111eb612..2881851ecf 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -250,6 +250,11 @@ stages: wget -O - https://github.com/riscv-software-src/opensbi/releases/download/v1.3.1/opens... | tar -C /tmp -xJ; export OPENSBI=/tmp/opensbi-1.3.1-rv-bin/share/opensbi/lp64/generic/firmware/fw_dynamic.bin; fi + if [[ "${TEST_PY_BD}" == "qemu-arm-sbsa" ]]; then + wget -O /tmp/bl1.bin https://artifacts.codelinaro.org/artifactory/linaro-419-sbsa-ref/latest/tf-a...; + wget -O /tmp/fip.bin https://artifacts.codelinaro.org/artifactory/linaro-419-sbsa-ref/latest/tf-a...; + export BINMAN_INDIRS=/tmp + fi # the below corresponds to .gitlab-ci.yml "script" cd ${WORK_DIR} export UBOOT_TRAVIS_BUILD_DIR=/tmp/${TEST_PY_BD} @@ -415,6 +420,9 @@ stages: qemu_arm64: TEST_PY_BD: "qemu_arm64" TEST_PY_TEST_SPEC: "not sleep" + qemu_arm_sbsa_ref: + TEST_PY_BD: "qemu-arm-sbsa" + TEST_PY_TEST_SPEC: "not sleep" qemu_m68k: TEST_PY_BD: "M5208EVBE" TEST_PY_ID: "--id qemu" diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 7d621031b8..3f02a492d5 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -39,6 +39,11 @@ stages: wget -O - https://github.com/riscv-software-src/opensbi/releases/download/v1.3.1/opens... | tar -C /tmp -xJ; export OPENSBI=/tmp/opensbi-1.3.1-rv-bin/share/opensbi/lp64/generic/firmware/fw_dynamic.bin; fi + - if [[ "${TEST_PY_BD}" == "qemu-arm-sbsa" ]]; then + wget -O /tmp/bl1.bin https://artifacts.codelinaro.org/artifactory/linaro-419-sbsa-ref/latest/tf-a...; + wget -O /tmp/fip.bin https://artifacts.codelinaro.org/artifactory/linaro-419-sbsa-ref/latest/tf-a...; + export BINMAN_INDIRS=/tmp + fi
after_script: - cp -v /tmp/${TEST_PY_BD}/*.{html,css,xml} . @@ -344,6 +349,12 @@ qemu_arm64 test.py: TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
+qemu_arm_sbsa test.py: + variables: + TEST_PY_BD: "qemu-arm-sbsa" + TEST_PY_TEST_SPEC: "not sleep" + <<: *buildman_and_testpy_dfn + qemu_m68k test.py: variables: TEST_PY_BD: "M5208EVBE"
Moritz Fischer
Patrick Rudolph
Peter Robinson
