[U-Boot-Users] omap2420h4 error
Looking at arm-errors.tar.gz -> omap2420h4.ERR
common/libcommon.a(env_flash.o): In function `env_init': /.automount/castor-vlab/root/home/wd/git/u-boot/work/common/env_flash.c:265: undefined reference to `flash_probe' make: *** [/work/wd/tmp/u-boot-arm/u-boot] Error 1
is because in board/omap2420h4 file flash.c isn't used any more. This file contains flash_probe(), but it isn't compiled. If enabled for test, there are tons of link conflicts with cfi_flash.c.
So looks to me that omap2420h4 switch to cfi disabled flash.c (and didn't remove it) but missed to resolve flash_probe() call in env_flash.c.
http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=commitdiff;h=49a7581c6c...
Proposal to fix this is to remove unused file board/omap2420h4/flash.c and remove calls of flash_probe()/omap2420h4 #ifdefs in env_flash.c. However, not sure if this is correct.
Opinions?
Cheers
Dirk
Dirk Behme stated on 8/19/2007 12:05 PM:
I think a more details solution is required for all omap2 SDPs.. the newer H4's seem to have larger range of device supports and i am looking to work towards a common code base for all SDP platforms(2430,3430 etc).. something like board/omap-common directory.. i have started a bit on it.. but it will take a bit of time before i can get it out as working patches.. Regards, NM
Well, I think these are two different things:
Dirk is proposing a fix for the current tree, i. e. for the next release to make the board build.
You are proposing a more general solution, which involves bigger changes than just a bug fix, and thus has to wait for the next merge window.
That means we need both...
Yes, thanks for clarification.
What's about this regarding the first step, make board build for next release?
Fix compilation error for omap2420h4_config. omap2420h4 switched to cfi, so remove old (already disabled) flash.c and flash_probe() calls in env_flash.c.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Index: uboot_davinci/common/env_flash.c =================================================================== --- uboot_davinci.orig/common/env_flash.c +++ uboot_davinci/common/env_flash.c @@ -107,13 +107,6 @@ int env_init(void) ulong addr1 = (ulong)&(flash_addr->data); ulong addr2 = (ulong)&(flash_addr_new->data);
-#ifdef CONFIG_OMAP2420H4 - int flash_probe(void); - - if(flash_probe() == 0) - goto bad_flash; -#endif - crc1_ok = (crc32(0, flash_addr->data, ENV_SIZE) == flash_addr->crc); crc2_ok = (crc32(0, flash_addr_new->data, ENV_SIZE) == flash_addr_new->crc);
@@ -143,9 +136,6 @@ int env_init(void) gd->env_valid = 2; }
-#ifdef CONFIG_OMAP2420H4 -bad_flash: -#endif return (0); }
@@ -259,20 +249,12 @@ Done:
int env_init(void) { -#ifdef CONFIG_OMAP2420H4 - int flash_probe(void); - - if(flash_probe() == 0) - goto bad_flash; -#endif if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { gd->env_addr = (ulong)&(env_ptr->data); gd->env_valid = 1; return(0); } -#ifdef CONFIG_OMAP2420H4 -bad_flash: -#endif + gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = 0; return (0); Index: uboot_davinci/board/omap2420h4/flash.c =================================================================== --- uboot_davinci.orig/board/omap2420h4/flash.c +++ /dev/null @@ -1,537 +0,0 @@ -/* - * (C) Copyright 2001 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2001-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2003 - * Texas Instruments, <www.ti.com> - * Kshitij Gupta Kshitij@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/arch/sizes.h> -#include <linux/byteorder/swab.h> - -#define PHYS_FLASH_SECT_SIZE SZ_128K -flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/* Board support for 1 or 2 flash devices */ -#undef FLASH_PORT_WIDTH32 -#define FLASH_PORT_WIDTH16 - -#ifdef FLASH_PORT_WIDTH16 -# define FLASH_PORT_WIDTH ushort -# define FLASH_PORT_WIDTHV vu_short -# define SWAP(x) __swab16(x) -#else -# define FLASH_PORT_WIDTH ulong -# define FLASH_PORT_WIDTHV vu_long -# define SWAP(x) __swab32(x) -#endif - -#define FPW FLASH_PORT_WIDTH -#define FPWV FLASH_PORT_WIDTHV - -#define mb() __asm__ __volatile__ ("" : : : "memory") - - -/* Flash Organization Structure */ -typedef struct OrgDef { - unsigned int sector_number; - unsigned int sector_size; -} OrgDef; - - -/* Flash Organizations */ -OrgDef OrgIntel_28F256L18T[] = { - {4, SZ_32K}, /* 4 * 32kBytes sectors */ - {255, SZ_128K}, /* 255 * 128kBytes sectors */ -}; - - -/*----------------------------------------------------------------------- - * Functions - */ -unsigned long flash_init (void); -static ulong flash_get_size (FPW * addr, flash_info_t * info); -static int write_data (flash_info_t * info, ulong dest, FPW data); -static void flash_get_offsets (ulong base, flash_info_t * info); -void inline spin_wheel (void); -void flash_print_info (flash_info_t * info); -void flash_unprotect_sectors (FPWV * addr); -int flash_erase (flash_info_t * info, int s_first, int s_last); -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt); -void flash_unlock(flash_info_t * info, int bank); -int flash_probe(void); - -/*----------------------------------------------------------------------- - */ - -/* see if flash is ok */ -int flash_probe(void) -{ - return(flash_get_size ((FPW *) PHYS_FLASH_1, &flash_info[0])); -} - -unsigned long flash_init (void) -{ - int i; - ulong size = 0; - for (i = 0; i < CFG_MAX_FLASH_BANKS; i++) { - switch (i) { - case 0: - flash_get_size ((FPW *) PHYS_FLASH_1, &flash_info[i]); - flash_get_offsets (PHYS_FLASH_1, &flash_info[i]); - /* to reset the lock bit */ - flash_unlock(&flash_info[i],i); - break; - case 1: - flash_get_size ((FPW *) PHYS_FLASH_2, &flash_info[i]); - flash_get_offsets (PHYS_FLASH_2, &flash_info[i]); - /* to reset the lock bit */ - flash_unlock(&flash_info[i],i); - break; - - default: - panic ("configured too many flash banks!\n"); - break; - } - size += flash_info[i].size; - } - -#ifdef CFG_ENV_IS_IN_FLASH - /* Protect monitor and environment sectors - */ - flash_protect (FLAG_PROTECT_SET, - CFG_FLASH_BASE, - CFG_FLASH_BASE + monitor_flash_len - 1, &flash_info[0]); - - flash_protect (FLAG_PROTECT_SET, - CFG_ENV_ADDR, - CFG_ENV_ADDR + CFG_ENV_SIZE - 1, &flash_info[0]); -#endif - return size; -} - -/*----------------------------------------------------------------------- - */ -void flash_unlock(flash_info_t * info, int bank) -{ - int j; - if (!bank) - j=2; /* leave 0,1 locked for boot bank */ - else - j=0; /* get the whole bank for #2 */ - - for (;j<CFG_MAX_FLASH_SECT;j++) { - FPWV *addr = (FPWV *) (info->start[j]); - if (addr == NULL) { - printf("Warning Flash probe failed\n"); - break; - } - flash_unprotect_sectors (addr); - *addr = (FPW) 0x00500050;/* clear status register */ - *addr = (FPW) 0x00FF00FF;/* resest to read mode */ - } -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t * info) -{ - int i; - volatile int r; /* gcc 3.4.0-1 strangeness, need to follow up.*/ - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - for (i = 0; i < info->sector_count; i++) { - if (i > 254) { /* 255,256,257,258 */ - r=i; - info->start[i] = base + (((r-(int)255) * SZ_32K) + (255*PHYS_FLASH_SECT_SIZE)); - info->protect[i] = 0; - } else { - info->start[i] = base + (i * PHYS_FLASH_SECT_SIZE); - info->protect[i] = 0; - } - } - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F256L18T: - printf ("FLASH 28F256L18T\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - return; -} - -/* - * The following code cannot be run from FLASH! - */ -static ulong flash_get_size (FPW * addr, flash_info_t * info) -{ - volatile FPW value; - /* mb(); this one makes ARM11 err go away, but I want it :) as a guide to problems */ - - /* Write auto select command: read Manufacturer ID */ - addr[0x5555] = (FPW) 0x00AA00AA; - addr[0x2AAA] = (FPW) 0x00550055; - addr[0x5555] = (FPW) 0x00900090; - - mb (); - value = addr[0] & 0xFF; /* just looking for 89 (8989 is hw pat)*/ - - switch (value) { - - case (FPW) INTEL_MANUFACT: - info->flash_id = FLASH_MAN_INTEL; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - addr[0] = (FPW) 0x00FF00FF; /* restore read mode */ - return(0); /* no or unknown flash */ - } - - mb (); - value = addr[1]; /* device ID */ - switch (value) { - - case (FPW) (INTEL_ID_28F256L18T): /* 880D */ - info->flash_id += FLASH_28F256L18T; - info->sector_count = 259; /*0-258*/ - info->size = SZ_32M; - break; /* => 32 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - break; - } - - if (info->sector_count > CFG_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CFG_MAX_FLASH_SECT); - info->sector_count = CFG_MAX_FLASH_SECT; - } - - addr[0] = (FPW) 0x00FF00FF; /* restore read mode */ - - return(info->size); -} - - -/* unprotects a sector for write and erase - * on some intel parts, this unprotects the entire chip, but it - * wont hurt to call this additional times per sector... - */ -void flash_unprotect_sectors (FPWV * addr) -{ -#define PD_FINTEL_WSMS_READY_MASK 0x0080 - - *addr = (FPW) 0x00500050; /* clear status register */ - - /* this sends the clear lock bit command */ - *addr = (FPW) 0x00600060; - *addr = (FPW) 0x00D000D0; -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int prot, sect; - ulong type, start, last; - int rcode = 0; -#ifdef CONFIG_USE_IRQ - int iflag; -#endif - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - type = (info->flash_id & FLASH_VENDMASK); - if ((type != FLASH_MAN_INTEL)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - - start = get_timer (0); - last = start; - -#ifdef CONFIG_USE_IRQ - /* Disable interrupts which might cause a timeout here */ - iflag = disable_interrupts (); -#endif - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - FPWV *addr = (FPWV *) (info->start[sect]); - FPW status; - - printf ("Erasing sector %2d ... ", sect); - - flash_unprotect_sectors (addr); - - /* arm simple, non interrupt dependent timer */ - reset_timer_masked (); - - *addr = (FPW) 0x00500050;/* clear status register */ - *addr = (FPW) 0x00200020;/* erase setup */ - *addr = (FPW) 0x00D000D0;/* erase confirm */ - - while (((status = - *addr) & (FPW) 0x00800080) != - (FPW) 0x00800080) { - if (get_timer_masked () > - CFG_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - /* suspend erase */ - *addr = (FPW) 0x00B000B0; - /* reset to read mode */ - *addr = (FPW) 0x00FF00FF; - rcode = 1; - break; - } - } - - /* clear status register cmd. */ - *addr = (FPW) 0x00500050; - *addr = (FPW) 0x00FF00FF;/* resest to read mode */ - printf (" done\n"); - } - } -#ifdef CONFIG_USE_IRQ - if (iflag) - enable_interrupts(); -#endif - - return rcode; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong cp, wp; - FPW data; - int count, i, l, rc, port_width; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } -/* get lower word aligned address */ -#ifdef FLASH_PORT_WIDTH16 - wp = (addr & ~1); - port_width = 2; -#else - wp = (addr & ~3); - port_width = 4; -#endif - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i = 0, cp = wp; i < l; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - for (; i < port_width && cnt > 0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt == 0 && i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - if ((rc = write_data (info, wp, SWAP (data))) != 0) { - return(rc); - } - wp += port_width; - } - - /* - * handle word aligned part - */ - count = 0; - while (cnt >= port_width) { - data = 0; - for (i = 0; i < port_width; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_data (info, wp, SWAP (data))) != 0) { - return(rc); - } - wp += port_width; - cnt -= port_width; - if (count++ > 0x800) { - spin_wheel (); - count = 0; - } - } - - if (cnt == 0) { - return(0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < port_width && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return(write_data (info, wp, SWAP (data))); -} - -/*----------------------------------------------------------------------- - * Write a word or halfword to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t * info, ulong dest, FPW data) -{ - FPWV *addr = (FPWV *) dest; - ulong status; -#ifdef CONFIG_USE_IRQ - int iflag; -#endif - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & data) != data) { - printf ("not erased at %08lx (%x)\n", (ulong) addr, *addr); - return(2); - } - /* Disable interrupts which might cause a timeout here */ -#ifdef CONFIG_USE_IRQ - iflag = disable_interrupts (); -#endif - *addr = (FPW) 0x00400040; /* write setup */ - *addr = data; - - /* arm simple, non interrupt dependent timer */ - reset_timer_masked (); - - /* wait while polling the status register */ - while (((status = *addr) & (FPW) 0x00800080) != (FPW) 0x00800080) { - if (get_timer_masked () > CFG_FLASH_WRITE_TOUT) { - *addr = (FPW) 0x00FF00FF; /* restore read mode */ - return(1); - } - } - *addr = (FPW) 0x00FF00FF; /* restore read mode */ - -#ifdef CONFIG_USE_IRQ - if (iflag) - enable_interrupts(); -#endif - - return(0); -} - -void inline spin_wheel (void) -{ - static int p = 0; - static char w[] = "\/-"; - - printf ("\010%c", w[p]); - (++p == 3) ? (p = 0) : 0; -}
Applied, thanks.
That was fixed a while back but the patch was pulled. I had like many other older ports had done cloned a generic flash file and made it private. This allowed sibley addition and other fixes. At that time WD objected and not much has happened since then. H4 and 2430SDP support many many different memories configurations across their versions. Providing support for them all in the generic areas requires a good amount of clean up.
This leaves a few approaches with functionality and time/effort as variables.
- Provide support for 1 of the 10 configuration very neatly with minimal effort (only allow 10% of users to work). - Provide all 10 neatly with high effort (works for 98%). - Provide all 10 functioning not so neatly but confining it to the board port directory (works for 98%).
Our own port structure now makes omap242x and 243x boards common in several spots and has omap34xx in places. None of this is reflected in the public git code.
If Peter is up to a big diff we might sync them all up to a point where they are all including and booting. Doing it in many patches would probably be unproductive.
Further clean up perhaps with what Nishant was saying could also happen.
I'm happy to allocate a couple days and make them work in the quick method but that might not be the path which goes in... Giving days is do-able weeks is not right now. If others have time then perhaps there are some other options.
Regards, Richard W.
common/libcommon.a(env_flash.o): In function `env_init': /.automount/castor-vlab/root/home/wd/git/u- boot/work/common/env_flash.c:265: undefined reference to `flash_probe' make: *** [/work/wd/tmp/u-boot-arm/u-boot] Error 1
http://www.denx.de/cgi-bin/gitweb.cgi?p=u- boot.git;a=commitdiff;h=49a7581c6ced35379ec3c450bb60fe736db9d733
Opinions?
Cheers
Dirk
Dirk Behme
Nishanth Menon
Woodruff, Richard
