[PATCH 00/42] Tidy up use of 'SPL' and CONFIG_SPL_BUILD
When the SPL build-phase was first created it was designed to solve a particular problem (the need to init SDRAM so that U-Boot proper could be loaded). It has since expanded to become an important part of U-Boot, with three phases now present: TPL, VPL and SPL
Due to this history, the term 'SPL' is used to mean both a particular phase (the one before U-Boot proper) and all the non-proper phases. This has become confusing.
For a similar reason CONFIG_SPL_BUILD is set to 'y' for all 'SPL' phases, not just SPL. So code which can only be compiled for actual SPL, for example, must use something like this:
#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_TPL_BUILD)
In Makefiles we have similar issues. SPL_ has been used as a variable which expands to either SPL_ or nothing, to chose between options like CONFIG_BLK and CONFIG_SPL_BLK. When TPL appeared, a new SPL_TPL variable was created which expanded to 'SPL_', 'TPL_' or nothing. Later it was updated to support 'VPL_' as well.
This series starts a change in terminology and usage to resolve the above issues:
- The word 'xPL' is used instead of 'SPL' to mean a non-proper build - A new CONFIG_XPL_BUILD define indicates that the current build is an 'xPL' build - The existing CONFIG_SPL_BUILD is changed to mean SPL; it is not now defined for TPL and VPL phases - The existing SPL_ Makefile variable is renamed to SPL_ - The existing SPL_TPL Makefile variable is renamed to PHASE_
It should be noted that xpl_phase() can generally be used instead of the above CONFIGs without a code-space or run-time penalty.
This series does not attempt to convert all of U-Boot to use this new terminology but it makes a start. In particular, renaming spl.h and common/spl seems like a bridge too far at this point.
An attempt has been made to make this series bisectable, but this is a little tricky, so some logic errors may be present.
Some more analysis is probably needed, e.g. to make sure that the code size doesn't change for any board.
Simon Glass (42): Makefile: Add a u-boot.cfg file for VPL scripts: Rename Makefile.spl to Makefile.xpl scripts: Add some comments about autoconf.mk scripts: Define CONFIG_XPL_BUILD for all xPL builds global: Use CONFIG_XPL_BUILD instead of CONFIG_SPL_BUILD doc: Update SPL docs for the xPL changes net: freescale: Drop use of SPL_BUILD dependency x86: Update a comment to mention XPL tegra: Use SPL instead of SPL_BUILD log: global: Rename warn_non_spl() and update the condition qconfig: Add XPL_BUILD to ignored symbols boot: Drop unnecessary ifdef for LOAD_FIT xpl: Define CONFIG_SPL_BUILD only for the SPL build rockchip: Simplify check for SPL mips: Simplify check for SPL powerpc: Simplify check for SPL x86: Simplify check for SPL freescale: Simplify check for SPL mtd: Simplify check for SPL dm: Simplify check for SPL spl: Simplify check for SPL powerpc: Correct check for SPL serial: Make use of the SERIAL define stdio: Make use of the SERIAL define drivers: Simplify Makefile checks kconfig: binman: Check for SPL instead of XPL rockchip: Simplify Makefile condition drivers: Simplify Makefile condition global: Rename SPL_ to XPL_ global: Rename SPL_TPL_ to PHASE_ spl: Rename SPL_TPL_NAME and SPL_TPL_PROMPT qconfig: Update tool for new Makefile variables xpl: Rename u_boot_first_phase to xpl_is_first_phase() xpl: Rename spl_phase to xpl_phase_t xpl: Rename spl_phase() to xpl_phase() xpl: Rename spl_in_proper() to not_xpl() xpl: Add a function to indicate when in xPL xpl: Rename spl_next_phase() and spl_prev_phase() xpl: Rename spl_phase_prefix() and spl_phase_name() README: Drop SoC-specific comment about SPL doc: Move init-related things out of README doc: Update init docs for the xPL changes
Makefile | 14 +-- README | 99 +------------------ arch/arm/Makefile | 6 +- arch/arm/config.mk | 12 +-- arch/arm/cpu/arm11/Makefile | 2 +- arch/arm/cpu/arm1176/start.S | 2 +- arch/arm/cpu/arm920t/Makefile | 2 +- arch/arm/cpu/arm926ejs/Makefile | 4 +- arch/arm/cpu/arm926ejs/mxs/Makefile | 4 +- arch/arm/cpu/arm926ejs/sunxi/config.mk | 2 +- arch/arm/cpu/armv7/Makefile | 4 +- arch/arm/cpu/armv7/cpu.c | 2 +- arch/arm/cpu/armv7/lowlevel_init.S | 4 +- arch/arm/cpu/armv7/s5p-common/Makefile | 2 +- arch/arm/cpu/armv7/start.S | 2 +- arch/arm/cpu/armv7/sunxi/Makefile | 4 +- arch/arm/cpu/armv8/Makefile | 12 +-- arch/arm/cpu/armv8/cache_v8.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 14 +-- .../armv8/fsl-layerscape/fsl_lsch2_speed.c | 2 +- .../armv8/fsl-layerscape/fsl_lsch3_serdes.c | 6 +- arch/arm/cpu/armv8/fsl-layerscape/icid.c | 6 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 6 +- .../arm/cpu/armv8/fsl-layerscape/ls1043_ids.c | 2 +- .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 4 +- arch/arm/cpu/armv8/start.S | 8 +- arch/arm/dts/imx8qm-u-boot.dtsi | 2 +- arch/arm/dts/imx8qxp-u-boot.dtsi | 2 +- .../asm/arch-fsl-layerscape/fsl_icid.h | 6 +- arch/arm/include/asm/arch-imx8/boot0.h | 2 +- arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 2 +- arch/arm/include/asm/arch-mx6/litesom.h | 2 +- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 4 +- arch/arm/include/asm/arch-mxs/sys_proto.h | 2 +- arch/arm/include/asm/arch-rk3066/boot0.h | 4 +- arch/arm/include/asm/arch-rockchip/boot0.h | 7 +- .../include/asm/arch-rockchip/cru_rv1126.h | 10 +- arch/arm/include/asm/arch-sunxi/boot0.h | 4 +- arch/arm/include/asm/arch-sunxi/sys_proto.h | 2 +- arch/arm/include/asm/fsl_secure_boot.h | 4 +- arch/arm/include/asm/ti-common/sys_proto.h | 2 +- arch/arm/lib/Makefile | 20 ++-- arch/arm/lib/cache.c | 2 +- arch/arm/lib/crt0.S | 14 +-- arch/arm/lib/crt0_64.S | 10 +- arch/arm/lib/eabi_compat.c | 2 +- arch/arm/lib/stack.c | 2 +- arch/arm/lib/vectors.S | 6 +- arch/arm/lib/zimage.c | 4 +- arch/arm/mach-aspeed/ast2600/Makefile | 2 +- arch/arm/mach-aspeed/ast2600/lowlevel_init.S | 2 +- arch/arm/mach-at91/Makefile | 2 +- arch/arm/mach-at91/arm926ejs/Makefile | 4 +- arch/arm/mach-at91/config.mk | 2 +- arch/arm/mach-davinci/Makefile | 2 +- arch/arm/mach-davinci/config.mk | 2 +- arch/arm/mach-davinci/misc.c | 2 +- arch/arm/mach-exynos/Makefile | 2 +- arch/arm/mach-exynos/lowlevel_init.c | 4 +- arch/arm/mach-exynos/pinmux.c | 2 +- arch/arm/mach-imx/Makefile | 20 ++-- arch/arm/mach-imx/cpu.c | 6 +- arch/arm/mach-imx/hab.c | 8 +- arch/arm/mach-imx/imx8/cpu.c | 4 +- arch/arm/mach-imx/imx8m/clock_imx8mm.c | 2 +- arch/arm/mach-imx/imx8m/clock_imx8mq.c | 4 +- arch/arm/mach-imx/imx8m/soc.c | 16 +-- arch/arm/mach-imx/imx8ulp/Makefile | 2 +- arch/arm/mach-imx/imx8ulp/clock.c | 2 +- arch/arm/mach-imx/imx8ulp/lowlevel_init.S | 2 +- arch/arm/mach-imx/imx8ulp/soc.c | 12 +-- arch/arm/mach-imx/imx9/Makefile | 2 +- arch/arm/mach-imx/imx9/clock.c | 4 +- arch/arm/mach-imx/imx9/lowlevel_init.S | 2 +- arch/arm/mach-imx/imx9/soc.c | 12 +-- arch/arm/mach-imx/mx5/clock.c | 2 +- arch/arm/mach-imx/mx6/Makefile | 2 +- arch/arm/mach-imx/mx6/clock.c | 2 +- arch/arm/mach-imx/mx6/litesom.c | 2 +- arch/arm/mach-imx/mx6/opos6ul.c | 4 +- arch/arm/mach-imx/mx6/soc.c | 6 +- arch/arm/mach-imx/mx7/clock.c | 2 +- arch/arm/mach-imx/mx7/soc.c | 4 +- arch/arm/mach-imx/mx7ulp/clock.c | 2 +- arch/arm/mach-imx/mx7ulp/soc.c | 2 +- arch/arm/mach-imx/syscounter.c | 2 +- arch/arm/mach-k3/am62ax/Makefile | 2 +- arch/arm/mach-k3/am62px/Makefile | 2 +- arch/arm/mach-k3/am62x/Makefile | 2 +- arch/arm/mach-k3/am64x/Makefile | 2 +- arch/arm/mach-k3/am65x/Makefile | 2 +- arch/arm/mach-k3/arm64/cache.S | 2 +- arch/arm/mach-k3/j721e/Makefile | 2 +- arch/arm/mach-k3/j721s2/Makefile | 2 +- arch/arm/mach-k3/j721s2/j721s2_init.c | 2 +- arch/arm/mach-k3/j722s/Makefile | 2 +- arch/arm/mach-k3/j784s4/Makefile | 2 +- arch/arm/mach-k3/r5/Makefile | 2 +- arch/arm/mach-k3/security.c | 2 +- arch/arm/mach-keystone/Makefile | 2 +- arch/arm/mach-keystone/config.mk | 4 +- arch/arm/mach-keystone/mon.c | 2 +- arch/arm/mach-lpc32xx/Makefile | 2 +- arch/arm/mach-mediatek/Makefile | 2 +- arch/arm/mach-mediatek/mt7629/lowlevel_init.S | 2 +- arch/arm/mach-mvebu/Makefile | 8 +- arch/arm/mach-mvebu/cpu.c | 4 +- arch/arm/mach-mvebu/include/mach/cpu.h | 8 +- arch/arm/mach-mvebu/include/mach/soc.h | 2 +- arch/arm/mach-mvebu/serdes/a38x/Makefile | 8 +- arch/arm/mach-mvebu/serdes/axp/Makefile | 4 +- arch/arm/mach-nexell/include/mach/display.h | 2 +- arch/arm/mach-omap2/Makefile | 4 +- arch/arm/mach-omap2/am33xx/Makefile | 2 +- arch/arm/mach-omap2/am33xx/board.c | 20 ++-- arch/arm/mach-omap2/boot-common.c | 6 +- arch/arm/mach-omap2/clocks-common.c | 2 +- arch/arm/mach-omap2/config.mk | 2 +- arch/arm/mach-omap2/config_secure.mk | 2 +- arch/arm/mach-omap2/hwinit-common.c | 14 +-- arch/arm/mach-omap2/omap3/Makefile | 2 +- arch/arm/mach-omap2/omap3/board.c | 6 +- arch/arm/mach-omap2/omap3/sdrc.c | 4 +- arch/arm/mach-omap2/omap5/hwinit.c | 2 +- arch/arm/mach-omap2/sec-common.c | 2 +- arch/arm/mach-orion5x/Makefile | 4 +- arch/arm/mach-orion5x/cpu.c | 2 +- arch/arm/mach-orion5x/lowlevel_init.S | 4 +- arch/arm/mach-renesas/include/mach/boot0.h | 2 +- arch/arm/mach-renesas/lowlevel_init_ca15.S | 2 +- arch/arm/mach-rockchip/Makefile | 6 +- arch/arm/mach-rockchip/px30/px30.c | 2 +- arch/arm/mach-rockchip/rk3036/Makefile | 2 +- arch/arm/mach-rockchip/rk3066/rk3066.c | 2 +- arch/arm/mach-rockchip/rk3188/rk3188.c | 4 +- arch/arm/mach-rockchip/rk322x/rk322x.c | 2 +- arch/arm/mach-rockchip/rk3288/rk3288.c | 4 +- arch/arm/mach-rockchip/rk3308/rk3308.c | 2 +- arch/arm/mach-rockchip/rk3328/rk3328.c | 2 +- arch/arm/mach-rockchip/rk3368/rk3368.c | 2 +- arch/arm/mach-rockchip/rk3399/rk3399.c | 8 +- arch/arm/mach-rockchip/rk3568/rk3568.c | 2 +- arch/arm/mach-rockchip/rk3588/rk3588.c | 4 +- arch/arm/mach-rockchip/rv1108/Makefile | 2 +- arch/arm/mach-rockchip/rv1126/rv1126.c | 2 +- arch/arm/mach-sc5xx/Makefile | 2 +- arch/arm/mach-sc5xx/config.mk | 2 +- arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/board.c | 6 +- arch/arm/mach-socfpga/clock_manager.c | 2 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 2 +- arch/arm/mach-socfpga/include/mach/boot0.h | 2 +- .../include/mach/clock_manager_arria10.h | 2 +- arch/arm/mach-socfpga/lowlevel_init_soc64.S | 2 +- arch/arm/mach-socfpga/mailbox_s10.c | 2 +- arch/arm/mach-socfpga/misc.c | 2 +- arch/arm/mach-socfpga/misc_arria10.c | 2 +- arch/arm/mach-socfpga/misc_gen5.c | 2 +- arch/arm/mach-socfpga/reset_manager_s10.c | 2 +- arch/arm/mach-socfpga/secure_vab.c | 2 +- arch/arm/mach-socfpga/timer_s10.c | 4 +- arch/arm/mach-socfpga/wrap_pll_config_soc64.c | 6 +- arch/arm/mach-stm32mp/Makefile | 2 +- arch/arm/mach-stm32mp/bsec.c | 12 +-- arch/arm/mach-stm32mp/stm32mp1/Makefile | 4 +- arch/arm/mach-stm32mp/stm32mp1/cpu.c | 6 +- arch/arm/mach-stm32mp/stm32mp1/stm32mp15x.c | 4 +- arch/arm/mach-sunxi/Makefile | 2 +- arch/arm/mach-sunxi/board.c | 10 +- arch/arm/mach-sunxi/clock_sun4i.c | 4 +- arch/arm/mach-sunxi/clock_sun50i_h6.c | 4 +- arch/arm/mach-sunxi/clock_sun6i.c | 4 +- arch/arm/mach-sunxi/clock_sun8i_a83t.c | 4 +- arch/arm/mach-sunxi/clock_sun9i.c | 4 +- arch/arm/mach-sunxi/gtbus_sun9i.c | 2 +- arch/arm/mach-tegra/Makefile | 6 +- arch/arm/mach-tegra/board.c | 2 +- arch/arm/mach-tegra/board2.c | 2 +- arch/arm/mach-tegra/tegra114/Makefile | 2 +- arch/arm/mach-tegra/tegra124/Kconfig | 4 +- arch/arm/mach-tegra/tegra124/Makefile | 4 +- arch/arm/mach-tegra/tegra20/Makefile | 4 +- arch/arm/mach-tegra/tegra30/Makefile | 4 +- arch/arm/mach-uniphier/Makefile | 2 +- arch/arm/mach-uniphier/arm32/Makefile | 2 +- .../mach-uniphier/boot-device/boot-device.c | 4 +- arch/arm/mach-uniphier/clk/Makefile | 2 +- arch/arm/mach-uniphier/debug-uart/Makefile | 2 +- .../arm/mach-uniphier/debug-uart/debug-uart.c | 4 +- arch/arm/mach-uniphier/dram/Makefile | 2 +- arch/arm/mach-zynq/Makefile | 2 +- arch/arm/mach-zynq/cpu.c | 2 +- arch/arm/mach-zynqmp/Makefile | 8 +- arch/arm/mach-zynqmp/cpu.c | 4 +- arch/microblaze/config.mk | 2 +- arch/microblaze/cpu/Makefile | 2 +- arch/microblaze/cpu/start.S | 8 +- arch/mips/Makefile | 2 +- arch/mips/config.mk | 2 +- arch/mips/lib/Makefile | 2 +- arch/mips/mach-jz47xx/Makefile | 2 +- arch/mips/mach-jz47xx/include/mach/jz4780.h | 2 +- arch/mips/mach-jz47xx/jz4780/jz4780.c | 4 +- arch/mips/mach-jz47xx/start.S | 4 +- arch/mips/mach-mtmips/Makefile | 2 +- arch/mips/mach-mtmips/cpu.c | 2 +- arch/mips/mach-mtmips/mt7620/Makefile | 2 +- arch/mips/mach-mtmips/mt7621/Makefile | 11 +-- arch/mips/mach-mtmips/mt7628/Makefile | 2 +- arch/powerpc/config.mk | 2 +- arch/powerpc/cpu/mpc83xx/Makefile | 2 - arch/powerpc/cpu/mpc83xx/start.S | 6 +- arch/powerpc/cpu/mpc85xx/Makefile | 4 +- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 2 +- arch/powerpc/cpu/mpc85xx/start.S | 14 +-- arch/powerpc/cpu/mpc85xx/tlb.c | 4 +- arch/powerpc/cpu/mpc8xxx/Makefile | 2 +- arch/powerpc/cpu/mpc8xxx/fsl_pamu.c | 4 +- arch/powerpc/cpu/mpc8xxx/law.c | 4 +- arch/powerpc/cpu/mpc8xxx/pamu_table.c | 2 +- arch/powerpc/include/asm/fsl_secure_boot.h | 8 +- arch/powerpc/lib/Makefile | 6 +- arch/riscv/Makefile | 2 +- arch/riscv/cpu/fu540/Makefile | 2 +- arch/riscv/cpu/fu740/Makefile | 2 +- arch/riscv/cpu/jh7110/Makefile | 2 +- arch/riscv/cpu/start.S | 8 +- arch/riscv/lib/Makefile | 24 ++--- arch/riscv/lib/sifive_cache.c | 4 +- arch/sandbox/cpu/Makefile | 2 +- arch/sandbox/cpu/cpu.c | 2 +- arch/sandbox/cpu/spl.c | 8 +- arch/sandbox/cpu/start.c | 4 +- arch/x86/Makefile | 10 +- arch/x86/config.mk | 8 +- arch/x86/cpu/Makefile | 22 ++--- arch/x86/cpu/apollolake/Makefile | 10 +- arch/x86/cpu/apollolake/cpu_spl.c | 4 +- arch/x86/cpu/apollolake/fsp_bindings.c | 4 +- arch/x86/cpu/apollolake/hostbridge.c | 2 +- arch/x86/cpu/apollolake/lpc.c | 2 +- arch/x86/cpu/apollolake/pch.c | 2 +- arch/x86/cpu/apollolake/pmc.c | 4 +- arch/x86/cpu/apollolake/punit.c | 2 +- arch/x86/cpu/apollolake/spl.c | 2 +- arch/x86/cpu/broadwell/Makefile | 14 +-- arch/x86/cpu/broadwell/cpu.c | 2 +- arch/x86/cpu/broadwell/cpu_full.c | 2 +- arch/x86/cpu/broadwell/pch.c | 2 +- arch/x86/cpu/config.mk | 2 +- arch/x86/cpu/coreboot/Makefile | 2 +- arch/x86/cpu/coreboot/coreboot.c | 2 +- arch/x86/cpu/cpu.c | 4 +- arch/x86/cpu/i386/cpu.c | 2 +- arch/x86/cpu/intel_common/Makefile | 20 ++-- arch/x86/cpu/intel_common/mrc.c | 2 +- arch/x86/cpu/intel_common/p2sb.c | 6 +- arch/x86/cpu/ivybridge/Makefile | 8 +- arch/x86/cpu/qemu/Makefile | 2 +- arch/x86/include/asm/string.h | 2 +- arch/x86/lib/Makefile | 27 +++-- arch/x86/lib/fsp/Makefile | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 2 +- arch/x86/lib/fsp2/fsp_init.c | 4 +- arch/x86/lib/tpl.c | 2 +- board/BuR/brppt1/Makefile | 2 +- board/BuR/brppt1/board.c | 4 +- board/BuR/brppt2/board.c | 6 +- board/BuR/brppt2/config.mk | 2 +- board/BuR/brsmarc1/Makefile | 2 +- board/BuR/brsmarc1/board.c | 8 +- board/BuR/brxre1/Makefile | 2 +- board/BuR/brxre1/board.c | 4 +- board/BuR/common/common.c | 4 +- board/CZ.NIC/turris_1x/Makefile | 2 +- board/CZ.NIC/turris_1x/tlb.c | 2 +- board/CZ.NIC/turris_omnia/Makefile | 2 +- board/CZ.NIC/turris_omnia/turris_omnia.c | 2 +- board/Synology/ds414/Makefile | 2 +- board/advantech/imx8mp_rsb3720a1/Makefile | 4 +- board/advantech/imx8qm_dmsse20_a1/Makefile | 2 +- board/advantech/imx8qm_rom7720_a1/Makefile | 2 +- board/alliedtelesis/x530/Makefile | 2 +- board/asus/grouper/Makefile | 2 +- board/asus/transformer-t30/Makefile | 2 +- .../atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 2 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 +- .../atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 2 +- .../sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 2 +- board/atmel/sama5d2_icp/sama5d2_icp.c | 2 +- .../atmel/sama5d2_xplained/sama5d2_xplained.c | 2 +- .../atmel/sama5d3_xplained/sama5d3_xplained.c | 2 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- .../atmel/sama5d4_xplained/sama5d4_xplained.c | 2 +- board/atmel/sama5d4ek/sama5d4ek.c | 2 +- board/avionic-design/tec-ng/Makefile | 2 +- board/beacon/imx8mm/Makefile | 2 +- board/beacon/imx8mn/Makefile | 2 +- board/beacon/imx8mp/Makefile | 2 +- board/bitmain/antminer_s9/Makefile | 2 +- board/bosch/acc/acc.c | 2 +- board/bosch/guardian/Makefile | 2 +- board/bosch/shc/board.c | 4 +- board/bsh/imx6ulz_smm_m2/Makefile | 2 +- board/bsh/imx8mn_smm_s2/Makefile | 2 +- board/bticino/mamoj/Makefile | 2 +- board/cloos/imx8mm_phg/Makefile | 2 +- board/compulab/cl-som-imx7/Makefile | 2 +- board/compulab/cl-som-imx7/common.h | 4 +- board/compulab/cl-som-imx7/mux.c | 4 +- board/compulab/cm_fx6/Makefile | 2 +- board/compulab/cm_t43/Makefile | 2 +- board/compulab/imx8mm-cl-iot-gate/Makefile | 2 +- .../compulab/imx8mm-cl-iot-gate/eeprom_spl.c | 2 +- board/comvetia/lxr2/lxr2.c | 2 +- .../conclusive/kstr-sama5d27/kstr-sama5d27.c | 2 +- board/congatec/cgtqmx8/Makefile | 2 +- board/congatec/common/Makefile | 2 - board/coreboot/coreboot/Makefile | 2 +- board/data_modul/common/common.c | 2 +- board/data_modul/imx8mm_edm_sbc/Makefile | 2 +- board/data_modul/imx8mp_edm_sbc/Makefile | 2 +- board/davinci/da8xxevm/omapl138_lcdk.c | 2 +- board/dhelectronics/dh_imx6/Makefile | 2 +- board/dhelectronics/dh_imx8mp/Makefile | 2 +- board/dhelectronics/dh_stm32mp1/board.c | 6 +- board/ea/mx7ulp_com/mx7ulp_com.c | 2 +- board/eets/pdu001/board.c | 2 +- board/embest/mx6boards/mx6boards.c | 2 +- board/engicam/common/Makefile | 2 +- board/engicam/imx8mm/Makefile | 2 +- board/engicam/imx8mp/Makefile | 2 +- board/engicam/stm32mp1/Makefile | 2 +- board/firefly/firefly-rk3288/firefly-rk3288.c | 2 +- board/firefly/roc-pc-rk3399/roc-pc-rk3399.c | 2 +- board/freescale/common/Makefile | 10 +- board/freescale/common/cmd_esbc_validate.c | 2 +- board/freescale/common/fsl_chain_of_trust.c | 8 +- board/freescale/common/fsl_validate.c | 4 +- board/freescale/common/qixis.c | 2 +- board/freescale/imx8mm_evk/Makefile | 2 +- board/freescale/imx8mn_evk/Makefile | 2 +- board/freescale/imx8mp_evk/Makefile | 2 +- board/freescale/imx8mq_evk/Makefile | 2 +- board/freescale/imx8qm_mek/Makefile | 2 +- board/freescale/imx8qxp_mek/Makefile | 2 +- board/freescale/imx8ulp_evk/Makefile | 2 +- board/freescale/imx93_evk/Makefile | 2 +- board/freescale/imxrt1020-evk/imxrt1020-evk.c | 2 +- board/freescale/imxrt1050-evk/imxrt1050-evk.c | 2 +- board/freescale/imxrt1170-evk/imxrt1170-evk.c | 2 +- board/freescale/ls1012afrdm/ls1012afrdm.c | 2 +- board/freescale/ls1012aqds/ls1012aqds.c | 2 +- board/freescale/ls1012ardb/ls1012ardb.c | 2 +- board/freescale/ls1021aiot/ls1021aiot.c | 4 +- board/freescale/ls1021aqds/ddr.c | 4 +- board/freescale/ls1021aqds/ls1021aqds.c | 2 +- board/freescale/ls1021atsn/ls1021atsn.c | 10 +- board/freescale/ls1021atwr/ls1021atwr.c | 10 +- board/freescale/ls1028a/ls1028a.c | 2 +- board/freescale/ls1043aqds/Makefile | 2 +- board/freescale/ls1043aqds/ddr.c | 2 +- board/freescale/ls1043aqds/ls1043aqds.c | 2 +- board/freescale/ls1043ardb/Makefile | 2 +- board/freescale/ls1043ardb/ddr.c | 4 +- board/freescale/ls1043ardb/ls1043ardb.c | 2 +- board/freescale/ls1046aqds/Makefile | 2 +- board/freescale/ls1046aqds/ddr.c | 2 +- board/freescale/ls1046aqds/ls1046aqds.c | 2 +- board/freescale/ls1046ardb/Makefile | 2 +- board/freescale/ls1046ardb/ddr.c | 2 +- board/freescale/ls1046ardb/ls1046ardb.c | 2 +- board/freescale/ls1088a/Makefile | 2 +- board/freescale/ls1088a/ddr.c | 6 +- board/freescale/ls1088a/ls1088a.c | 8 +- board/freescale/ls2080aqds/ddr.c | 2 +- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- board/freescale/ls2080ardb/ddr.c | 2 +- board/freescale/ls2080ardb/eth_ls2080rdb.c | 2 +- board/freescale/lx2160a/lx2160a.c | 2 +- board/freescale/mx23evk/Makefile | 2 +- board/freescale/mx28evk/Makefile | 2 +- board/freescale/mx6memcal/Makefile | 2 +- board/freescale/mx6sabreauto/mx6sabreauto.c | 2 +- board/freescale/mx6sabresd/mx6sabresd.c | 2 +- board/freescale/mx6slevk/mx6slevk.c | 4 +- .../mx6ul_14x14_evk/mx6ul_14x14_evk.c | 4 +- board/freescale/p1010rdb/Makefile | 4 +- board/freescale/p1010rdb/p1010rdb.c | 2 +- board/freescale/p1010rdb/tlb.c | 2 +- board/freescale/p1_p2_rdb_pc/Makefile | 4 +- board/freescale/p1_p2_rdb_pc/tlb.c | 2 +- board/freescale/t102xrdb/Makefile | 2 +- board/freescale/t102xrdb/ddr.c | 4 +- board/freescale/t102xrdb/tlb.c | 4 +- board/freescale/t104xrdb/Makefile | 2 +- board/freescale/t104xrdb/ddr.c | 4 +- board/freescale/t104xrdb/tlb.c | 6 +- board/freescale/t208xqds/Makefile | 2 +- board/freescale/t208xqds/ddr.c | 2 +- board/freescale/t208xqds/tlb.c | 4 +- board/freescale/t208xrdb/Makefile | 2 +- board/freescale/t208xrdb/ddr.c | 2 +- board/freescale/t208xrdb/tlb.c | 4 +- board/freescale/t4rdb/Makefile | 2 +- board/freescale/t4rdb/cpld.c | 2 +- board/freescale/t4rdb/ddr.c | 2 +- board/freescale/t4rdb/tlb.c | 4 +- board/gardena/smart-gateway-at91sam/Makefile | 2 +- board/gardena/smart-gateway-mt7688/board.c | 2 +- board/gateworks/gw_ventana/Makefile | 2 +- board/gateworks/gw_ventana/eeprom.c | 2 +- board/gateworks/venice/Makefile | 2 +- board/gdsys/a38x/Makefile | 2 +- board/gdsys/a38x/controlcenterdc.c | 12 +-- board/ge/b1x5v2/b1x5v2.c | 4 +- board/ge/b1x5v2/spl.c | 2 +- board/google/chromebook_coral/coral.c | 2 +- board/google/gru/gru.c | 4 +- board/google/imx8mq_phanbell/Makefile | 2 +- board/google/veyron/veyron.c | 2 +- board/grinn/chiliboard/board.c | 2 +- board/grinn/liteboard/board.c | 2 +- board/htc/endeavoru/Makefile | 2 +- board/imgtec/ci20/ci20.c | 4 +- board/isee/igep003x/Makefile | 2 +- board/isee/igep003x/board.c | 2 +- board/isee/igep00x0/Makefile | 2 +- board/k+p/kp_imx6q_tpc/Makefile | 2 +- board/kontron/pitx_imx8m/Makefile | 2 +- board/kontron/sl-mx6ul/Makefile | 2 +- board/kontron/sl-mx8mm/Makefile | 2 +- board/kontron/sl28/Makefile | 4 +- board/kontron/sl28/ddr.c | 2 +- board/kosagi/novena/Makefile | 2 +- board/lenovo/ideapad-yoga-11/Makefile | 2 +- board/lg/sniper/sniper.c | 2 +- board/lg/x3-t30/Makefile | 2 +- board/liebherr/display5/Makefile | 2 +- board/liebherr/mccmon6/Makefile | 2 +- board/liebherr/xea/Makefile | 2 +- board/liebherr/xea/xea.c | 6 +- board/logicpd/am3517evm/am3517evm.c | 2 +- board/logicpd/imx6/imx6logic.c | 2 +- board/logicpd/omap3som/omap3logic.c | 2 +- board/menlo/m53menlo/m53menlo.c | 2 +- board/menlo/mx8menlo/Makefile | 4 +- board/microsoft/surface-rt/Makefile | 2 +- board/mntre/imx8mq_reform2/Makefile | 2 +- board/msc/sm2s_imx8mp/Makefile | 2 +- board/myir/mys_6ulx/Makefile | 2 +- board/nvidia/beaver/Makefile | 2 +- board/nvidia/cardhu/Makefile | 2 +- board/olimex/mx23_olinuxino/Makefile | 2 +- board/opalkelly/zynq/Makefile | 2 +- board/phytec/common/Makefile | 2 +- board/phytec/pcl063/Makefile | 2 +- board/phytec/pcm058/pcm058.c | 2 +- board/phytec/phycore_am335x_r2/Makefile | 2 +- board/phytec/phycore_am335x_r2/board.c | 2 +- board/phytec/phycore_am62x/phycore-am62x.c | 2 +- board/phytec/phycore_imx8mm/Makefile | 2 +- board/phytec/phycore_imx8mp/Makefile | 2 +- board/phytec/phycore_imx93/Makefile | 2 +- board/polyhex/imx8mp_debix_model_a/Makefile | 2 +- board/purism/librem5/Makefile | 2 +- board/purism/librem5/librem5.h | 4 +- board/radxa/rockpi4-rk3399/rockpi4-rk3399.c | 4 +- board/renesas/alt/Makefile | 2 +- board/renesas/condor/Makefile | 2 +- board/renesas/draak/Makefile | 2 +- board/renesas/eagle/Makefile | 2 +- board/renesas/ebisu/Makefile | 2 +- board/renesas/falcon/Makefile | 2 +- board/renesas/gose/Makefile | 2 +- board/renesas/koelsch/Makefile | 2 +- board/renesas/lager/Makefile | 2 +- board/renesas/porter/Makefile | 2 +- board/renesas/salvator-x/Makefile | 2 +- board/renesas/silk/Makefile | 2 +- board/renesas/stout/Makefile | 2 +- board/renesas/ulcb/Makefile | 2 +- board/renesas/v3hsk/Makefile | 2 +- board/renesas/v3msk/Makefile | 2 +- board/ronetix/imx7-cm/Makefile | 2 +- board/ronetix/imx8mq-cm/Makefile | 2 +- board/samsung/common/Makefile | 2 +- board/samsung/origen/Makefile | 2 +- board/samsung/smdkv310/Makefile | 2 +- board/seeed/npi_imx6ull/Makefile | 2 +- board/sielaff/imx6dl-sielaff/Makefile | 2 +- board/siemens/capricorn/Makefile | 2 +- board/siemens/capricorn/board.c | 8 +- board/siemens/common/board_am335x.c | 12 +-- board/siemens/common/board_am335x.h | 4 +- board/siemens/common/factoryset.c | 4 +- board/siemens/corvus/board.c | 2 +- board/siemens/draco/Makefile | 4 +- board/siemens/draco/board.c | 14 +-- board/siemens/pxm2/Makefile | 4 +- board/siemens/pxm2/board.c | 14 +-- board/siemens/rut/Makefile | 4 +- board/siemens/rut/board.c | 8 +- board/siemens/smartweb/smartweb.c | 2 +- board/siemens/taurus/taurus.c | 4 +- board/sifive/unleashed/Makefile | 2 +- board/sifive/unmatched/Makefile | 2 +- board/silinux/ek874/Makefile | 2 +- board/softing/vining_2000/vining_2000.c | 2 +- board/softing/vining_fpga/socfpga.c | 2 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 2 +- board/st/common/Makefile | 2 +- board/st/common/cmd_stboard.c | 2 +- board/st/stm32f746-disco/stm32f746-disco.c | 4 +- board/st/stm32mp1/Makefile | 2 +- board/starfive/visionfive2/Makefile | 2 +- board/sunxi/board.c | 6 +- board/tcl/sl50/Makefile | 2 +- board/tcl/sl50/board.c | 14 +-- board/technexion/pico-imx6/spl.c | 2 +- board/technexion/pico-imx6ul/spl.c | 2 +- board/technexion/pico-imx7d/spl.c | 2 +- board/technexion/pico-imx8mq/Makefile | 2 +- board/theadorable/theadorable.c | 6 +- .../theobroma-systems/jaguar_rk3588/Makefile | 2 +- board/theobroma-systems/puma_rk3399/Makefile | 2 +- .../theobroma-systems/ringneck_px30/Makefile | 2 +- board/theobroma-systems/tiger_rk3588/Makefile | 2 +- board/ti/am335x/Makefile | 2 +- board/ti/am335x/board.c | 12 +-- board/ti/am43xx/Makefile | 2 +- board/ti/am57xx/board.c | 10 +- board/ti/am62x/evm.c | 2 +- board/ti/am64x/evm.c | 2 +- board/ti/common/board_detect.c | 6 +- board/ti/dra7xx/evm.c | 6 +- board/ti/j721e/evm.c | 6 +- board/ti/j721s2/evm.c | 4 +- board/ti/ks2_evm/board.c | 2 +- board/ti/ks2_evm/board_k2e.c | 2 +- board/ti/ks2_evm/board_k2g.c | 4 +- board/ti/ks2_evm/board_k2hk.c | 2 +- board/ti/ks2_evm/board_k2l.c | 2 +- board/ti/omap3evm/evm.c | 4 +- board/timll/devkit8000/devkit8000.c | 2 +- board/topic/zynq/Makefile | 2 +- board/toradex/apalis_imx6/apalis_imx6.c | 12 +-- board/toradex/apalis_imx6/do_fuse.c | 4 +- board/toradex/apalis_imx6/pf0100.c | 4 +- board/toradex/apalis_t30/Makefile | 2 +- board/toradex/colibri_imx6/colibri_imx6.c | 12 +-- board/toradex/colibri_imx6/do_fuse.c | 4 +- board/toradex/colibri_imx6/pf0100.c | 4 +- board/toradex/colibri_t30/Makefile | 2 +- board/toradex/common/Makefile | 2 +- board/toradex/verdin-imx8mm/Makefile | 2 +- board/toradex/verdin-imx8mp/Makefile | 2 +- board/udoo/neo/neo.c | 2 +- board/udoo/udoo_spl.c | 2 +- board/variscite/common/imx9_eeprom.c | 2 +- board/variscite/dart_6ul/Makefile | 2 +- board/variscite/imx8mn_var_som/Makefile | 2 +- .../variscite/imx8mn_var_som/imx8mn_var_som.c | 4 +- board/variscite/imx93_var_som/Makefile | 2 +- board/vscom/baltos/Makefile | 2 +- board/vscom/baltos/board.c | 14 +-- board/wandboard/Makefile | 2 +- board/wexler/qc750/Makefile | 2 +- board/work-microwave/work_92105/Makefile | 2 +- board/xilinx/common/Makefile | 2 +- board/xilinx/common/board.c | 6 +- .../microblaze-generic/microblaze-generic.c | 2 +- board/xilinx/zynq/Makefile | 6 +- board/xilinx/zynq/board.c | 4 +- board/xilinx/zynqmp/Makefile | 8 +- board/xilinx/zynqmp/zynqmp.c | 6 +- boot/Makefile | 86 ++++++++-------- boot/fdt_simplefb.c | 2 +- boot/image-android-dt.c | 2 +- boot/image-android.c | 2 +- boot/image-fit-sig.c | 2 +- boot/vbe_simple_fw.c | 4 +- cmd/Makefile | 6 +- cmd/nvedit.c | 12 +-- cmd/vbe.c | 2 +- common/Makefile | 42 ++++---- common/bloblist.c | 6 +- common/board_f.c | 2 +- common/bootstage.c | 6 +- common/cli_readline.c | 2 +- common/console.c | 2 +- common/hash.c | 2 +- common/init/Makefile | 2 +- common/spl/Makefile | 58 +++++------ common/spl/spl.c | 61 ++++++------ common/spl/spl_fit.c | 2 +- common/spl/spl_legacy.c | 2 +- common/splash_source.c | 2 +- config.mk | 2 +- disk/Makefile | 18 ++-- disk/part.c | 2 +- disk/part_dos.c | 2 +- doc/develop/distro.rst | 4 +- doc/develop/index.rst | 1 + doc/develop/init.rst | 93 +++++++++++++++++ doc/develop/logging.rst | 2 +- doc/develop/qconfig.rst | 2 +- doc/develop/spl.rst | 83 ++++++++-------- doc/develop/tests_sandbox.rst | 2 +- doc/develop/tests_writing.rst | 6 +- doc/device-tree-bindings/bootph.yaml | 2 +- drivers/Makefile | 90 ++++++++--------- drivers/adc/Makefile | 2 +- drivers/ata/Makefile | 2 +- drivers/block/Makefile | 12 +-- drivers/bus/Makefile | 4 +- drivers/cache/Makefile | 2 +- drivers/clk/Makefile | 18 ++-- drivers/clk/altera/clk-agilex.c | 2 +- drivers/clk/altera/clk-agilex5.c | 2 +- drivers/clk/altera/clk-n5x.c | 2 +- drivers/clk/clk-uclass.c | 2 +- drivers/clk/clk_vexpress_osc.c | 4 +- drivers/clk/clk_zynq.c | 22 ++--- drivers/clk/exynos/Makefile | 2 +- drivers/clk/imx/Makefile | 20 ++-- drivers/clk/imx/clk-imx8mm.c | 6 +- drivers/clk/imx/clk-imx8mn.c | 6 +- drivers/clk/imx/clk-imxrt1020.c | 2 +- drivers/clk/imx/clk-imxrt1050.c | 2 +- drivers/clk/rockchip/clk_px30.c | 6 +- drivers/clk/rockchip/clk_rk3188.c | 6 +- drivers/clk/rockchip/clk_rk3288.c | 8 +- drivers/clk/rockchip/clk_rk3328.c | 4 +- drivers/clk/rockchip/clk_rk3368.c | 14 +-- drivers/clk/rockchip/clk_rk3399.c | 10 +- drivers/clk/rockchip/clk_rk3568.c | 10 +- drivers/clk/rockchip/clk_rk3588.c | 14 +-- drivers/clk/sifive/sifive-prci.c | 2 +- drivers/clk/starfive/clk-jh7110-pll.c | 4 +- drivers/clk/stm32/clk-stm32mp1.c | 6 +- drivers/clk/ti/Makefile | 4 +- drivers/core/Makefile | 16 +-- drivers/core/ofnode.c | 4 +- drivers/crypto/fsl/Makefile | 2 +- drivers/crypto/fsl/jobdesc.c | 2 +- drivers/crypto/fsl/jr.c | 6 +- drivers/ddr/altera/Makefile | 2 +- drivers/ddr/altera/sdram_gen5.c | 4 +- drivers/ddr/fsl/lc_common_dimm_params.c | 6 +- drivers/ddr/fsl/main.c | 6 +- drivers/ddr/imx/imx8m/Makefile | 2 +- drivers/ddr/imx/imx8ulp/Makefile | 2 +- drivers/ddr/imx/imx9/Makefile | 2 +- drivers/ddr/imx/phy/Makefile | 2 +- drivers/ddr/marvell/a38x/Makefile | 44 ++++----- drivers/ddr/marvell/a38x/old/Makefile | 28 +++--- drivers/ddr/marvell/axp/Makefile | 20 ++-- drivers/dfu/Makefile | 16 +-- drivers/firmware/Makefile | 2 +- drivers/firmware/firmware-zynqmp.c | 10 +- drivers/fpga/intel_sdm_mb.c | 2 +- drivers/fpga/zynqpl.c | 6 +- drivers/gpio/Makefile | 16 +-- drivers/gpio/gpio-uclass.c | 4 +- drivers/gpio/pca953x.c | 2 +- drivers/gpio/rk_gpio.c | 4 +- drivers/gpio/s5p_gpio.c | 10 +- drivers/gpio/sunxi_gpio.c | 2 +- drivers/gpio/tca642x.c | 2 +- drivers/gpio/tegra_gpio.c | 2 +- drivers/i2c/Makefile | 16 +-- drivers/i2c/designware_i2c_pci.c | 4 +- drivers/input/Makefile | 8 +- drivers/led/Makefile | 2 +- drivers/mailbox/Makefile | 2 +- drivers/mailbox/zynqmp-ipi.c | 6 +- drivers/misc/Makefile | 32 +++--- drivers/misc/gsc.c | 2 +- drivers/misc/imx8/scu.c | 2 +- drivers/misc/p2sb-uclass.c | 2 +- drivers/mmc/Makefile | 14 +-- drivers/mmc/mmc-uclass.c | 4 +- drivers/mmc/mmc.c | 20 ++-- drivers/mmc/mmc_legacy.c | 4 +- drivers/mmc/mmc_private.h | 2 +- drivers/mmc/omap_hsmmc.c | 4 +- drivers/mmc/rockchip_dw_mmc.c | 2 +- drivers/mmc/rockchip_sdhci.c | 2 +- drivers/mmc/socfpga_dw_mmc.c | 2 +- drivers/mmc/tmio-common.c | 2 +- drivers/mmc/uniphier-sd.c | 4 +- drivers/mmc/zynq_sdhci.c | 6 +- drivers/mtd/Makefile | 6 +- drivers/mtd/nand/Makefile | 4 +- drivers/mtd/nand/raw/Makefile | 4 +- drivers/mtd/nand/raw/atmel_nand.c | 4 +- drivers/mtd/nand/raw/lpc32xx_nand_mlc.c | 6 +- drivers/mtd/nand/raw/lpc32xx_nand_slc.c | 8 +- drivers/mtd/nand/raw/nand_base.c | 10 +- drivers/mtd/nand/raw/omap_gpmc.c | 4 +- drivers/mtd/nand/raw/sand_nand.c | 4 +- drivers/mtd/onenand/Makefile | 2 +- drivers/mtd/spi/Makefile | 10 +- drivers/mtd/spi/sf-uclass.c | 2 +- drivers/mtd/spi/sf_dataflash.c | 2 +- drivers/mtd/spi/spi-nor-core.c | 4 +- drivers/mux/Makefile | 2 +- drivers/net/Kconfig | 2 +- drivers/net/dwc_eth_xgmac_socfpga.c | 2 +- drivers/net/dwmac_socfpga.c | 2 +- drivers/nvme/Makefile | 2 +- drivers/pci/pci-uclass.c | 4 +- drivers/pci/pci_rom.c | 4 +- drivers/phy/Makefile | 6 +- drivers/phy/cadence/Makefile | 4 +- drivers/phy/ti/Makefile | 2 +- drivers/pinctrl/Makefile | 8 +- drivers/pinctrl/intel/pinctrl.c | 6 +- drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 4 +- drivers/pinctrl/pinctrl_stm32.c | 4 +- drivers/pinctrl/starfive/Makefile | 4 +- drivers/pinctrl/tegra/Makefile | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 2 +- drivers/power/Makefile | 10 +- drivers/power/acpi_pmc/Makefile | 2 +- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 2 +- drivers/power/domain/Makefile | 2 +- drivers/power/pmic/Makefile | 34 +++---- drivers/power/pmic/rk8xx.c | 4 +- drivers/power/pmic/stpmic1.c | 6 +- drivers/power/power_core.c | 2 +- drivers/power/regulator/Makefile | 48 ++++----- drivers/power/regulator/rk8xx.c | 2 +- drivers/power/sy8106a.c | 2 +- drivers/ram/Makefile | 4 +- drivers/ram/mediatek/ddr3-mt7629.c | 4 +- drivers/ram/rockchip/sdram_rk3188.c | 12 +-- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 4 +- drivers/ram/rockchip/sdram_rv1126.c | 9 +- drivers/ram/sifive/sifive_ddr.c | 6 +- drivers/ram/starfive/Makefile | 4 +- drivers/ram/stm32mp1/stm32mp1_ram.c | 2 +- drivers/remoteproc/Makefile | 2 +- drivers/reset/Makefile | 2 +- drivers/reset/reset-socfpga.c | 2 +- drivers/rng/Makefile | 2 +- drivers/rtc/Makefile | 6 +- drivers/scsi/Makefile | 6 +- drivers/serial/Makefile | 6 +- drivers/serial/atmel_usart.c | 2 +- drivers/serial/ns16550.c | 8 +- drivers/serial/serial-uclass.c | 2 +- drivers/serial/serial.c | 2 +- drivers/serial/serial_s5p.c | 2 +- drivers/serial/serial_zynq.c | 2 +- drivers/spi/Makefile | 2 +- drivers/spi/designware_spi.c | 4 +- drivers/spi/ich.c | 4 +- drivers/spi/rockchip_sfc.c | 2 +- drivers/spi/spi-uclass.c | 4 +- drivers/sysreset/Makefile | 14 +-- drivers/sysreset/sysreset-uclass.c | 2 +- drivers/sysreset/sysreset_ast.c | 2 +- drivers/timer/Makefile | 8 +- drivers/tpm/Makefile | 4 +- drivers/usb/cdns3/Makefile | 4 +- drivers/usb/cdns3/core.c | 6 +- drivers/usb/common/Makefile | 2 +- drivers/usb/dwc3/Makefile | 4 +- drivers/usb/gadget/Makefile | 10 +- drivers/usb/gadget/f_sdp.c | 10 +- drivers/usb/gadget/udc/Makefile | 4 +- drivers/usb/host/Makefile | 6 +- drivers/usb/mtu3/mtu3_plat.c | 4 +- drivers/video/Makefile | 18 ++-- drivers/video/console_truetype.c | 6 +- drivers/video/tidss/Makefile | 2 +- drivers/video/video-uclass.c | 6 +- drivers/watchdog/Makefile | 2 +- dts/Makefile | 2 +- env/Makefile | 24 ++--- env/common.c | 4 +- env/fat.c | 4 +- env/flash.c | 6 +- env/mmc.c | 6 +- env/nand.c | 8 +- env/nowhere.c | 2 +- env/sf.c | 2 +- fs/Makefile | 2 +- fs/fat/Makefile | 4 +- fs/fs.c | 6 +- fs/sandbox/Makefile | 2 +- fs/squashfs/Makefile | 2 +- include/asm-generic/global_data.h | 2 +- include/bootcount.h | 4 +- include/config_distro_bootcmd.h | 10 +- include/configs/P1010RDB.h | 4 +- include/configs/am335x_evm.h | 4 +- include/configs/am335x_guardian.h | 4 +- include/configs/am335x_shc.h | 4 +- include/configs/am43xx_evm.h | 4 +- include/configs/am57xx_evm.h | 2 +- include/configs/capricorn-common.h | 4 +- include/configs/cgtqmx8.h | 2 +- include/configs/da850evm.h | 2 +- include/configs/dra7xx_evm.h | 4 +- include/configs/ds116.h | 4 +- include/configs/ds414.h | 4 +- .../configs/gardena-smart-gateway-mt7688.h | 2 +- include/configs/imx6q-bosch-acc.h | 2 +- include/configs/imx6ulz_smm_m2.h | 4 +- include/configs/imx8mm-cl-iot-gate.h | 2 +- include/configs/imx8mm_beacon.h | 2 +- include/configs/imx8mm_data_modul_edm_sbc.h | 2 +- include/configs/imx8mm_evk.h | 2 +- include/configs/imx8mm_icore_mx8mm.h | 4 +- include/configs/imx8mm_phg.h | 2 +- include/configs/imx8mm_venice.h | 2 +- include/configs/imx8mp_rsb3720.h | 2 +- include/configs/imx8mq_cm.h | 2 +- include/configs/imx8mq_evk.h | 2 +- include/configs/imx8mq_phanbell.h | 2 +- include/configs/imx8mq_reform2.h | 2 +- include/configs/imx8qm_mek.h | 2 +- include/configs/imx8qxp_mek.h | 2 +- include/configs/imx8ulp_evk.h | 2 +- include/configs/imx93_evk.h | 2 +- include/configs/kontron-sl-mx8mm.h | 4 +- include/configs/kontron_pitx_imx8m.h | 2 +- include/configs/librem5.h | 2 +- include/configs/linkit-smart-7688.h | 2 +- include/configs/ls1043a_common.h | 6 +- include/configs/ls1046a_common.h | 6 +- include/configs/ls1088a_common.h | 2 +- include/configs/msc_sm2s_imx8mp.h | 2 +- include/configs/mt7621.h | 2 +- include/configs/mt7628.h | 2 +- include/configs/n2350.h | 4 +- include/configs/p1_p2_rdb_pc.h | 4 +- include/configs/phycore_imx8mm.h | 2 +- include/configs/pico-imx8mq.h | 2 +- include/configs/rk3399_common.h | 4 +- include/configs/rockchip-common.h | 2 +- include/configs/socfpga_common.h | 2 +- include/configs/stm32mp15_common.h | 4 +- include/configs/stm32mp15_dh_dhsom.h | 2 +- include/configs/ti_omap3_common.h | 2 +- include/configs/ti_omap4_common.h | 2 +- include/configs/turris_1x.h | 4 +- include/configs/turris_omnia.h | 4 +- include/configs/verdin-imx8mm.h | 2 +- include/configs/verdin-imx8mp.h | 4 +- include/configs/vining_2000.h | 2 +- include/configs/xilinx_zynqmp.h | 2 +- include/configs/zynq-common.h | 4 +- include/env.h | 2 +- include/env_callback.h | 2 +- include/fdtdec.h | 2 +- include/image-android-dt.h | 2 +- include/iotrace.h | 2 +- include/linux/kconfig.h | 8 +- include/log.h | 12 +-- include/mmc.h | 2 +- include/mtd/cfi_flash.h | 2 +- include/net.h | 6 +- include/part.h | 2 +- include/sdp.h | 2 +- include/search.h | 2 +- include/spl.h | 78 ++++++++------- include/stdio.h | 5 +- include/sunxi_gpio.h | 2 +- include/upl.h | 4 +- include/vbe.h | 2 +- lib/Makefile | 68 ++++++------- lib/acpi/Makefile | 10 +- lib/aes/Makefile | 2 +- lib/crypto/Makefile | 18 ++-- lib/display_options.c | 2 +- lib/ecdsa/Makefile | 2 +- lib/fdtdec.c | 8 +- lib/hang.c | 2 +- lib/hashtable.c | 4 +- lib/hexdump.c | 2 +- lib/libfdt/Makefile | 2 +- lib/lmb.c | 4 +- lib/rsa/Makefile | 4 +- lib/time.c | 2 +- lib/uuid.c | 2 +- net/Makefile | 12 +-- net/bootp.c | 2 +- net/net.c | 8 +- scripts/Kbuild.include | 14 +-- scripts/Makefile.autoconf | 6 +- scripts/{Makefile.spl => Makefile.xpl} | 60 ++++++----- test/Makefile | 24 ++--- test/cmd_ut.c | 2 +- test/dm/Makefile | 6 +- test/fuzz/Makefile | 2 +- test/lib/Makefile | 2 +- test/test-main.c | 2 +- tools/qconfig.py | 32 +++--- 906 files changed, 2243 insertions(+), 2257 deletions(-) create mode 100644 doc/develop/init.rst rename scripts/{Makefile.spl => Makefile.xpl} (92%)
Create this file for VPL as well, for consistency.
Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 525576f987d..300cee2e7f6 100644 --- a/Makefile +++ b/Makefile @@ -624,7 +624,7 @@ include/config/%.conf: $(KCONFIG_CONFIG) include/config/auto.conf.cmd @# Otherwise, 'make silentoldconfig' would be invoked twice. $(Q)touch include/config/auto.conf
-u-boot.cfg spl/u-boot.cfg tpl/u-boot.cfg: +u-boot.cfg spl/u-boot.cfg tpl/u-boot.cfg vpl/u-boot.cfg: $(Q)$(MAKE) -f $(srctree)/scripts/Makefile.autoconf $(@)
-include include/autoconf.mk
Rename this file to indicate that it refers to any non-U-Boot-proper phase, not just SPL, which is the phase immediately before U-Boot proper.
Makefile | 6 +++--- scripts/{Makefile.spl => Makefile.xpl} | 0 2 files changed, 3 insertions(+), 3 deletions(-) rename scripts/{Makefile.spl => Makefile.xpl} (100%)
diff --git a/Makefile b/Makefile index 300cee2e7f6..4378993ccfd 100644 --- a/Makefile +++ b/Makefile @@ -2094,7 +2094,7 @@ spl/u-boot-spl-dtb.hex: spl/u-boot-spl @:
spl/u-boot-spl: tools prepare $(if $(CONFIG_SPL_OF_CONTROL),dts/dt.dtb) - $(Q)$(MAKE) obj=spl -f $(srctree)/scripts/Makefile.spl all + $(Q)$(MAKE) obj=spl -f $(srctree)/scripts/Makefile.xpl all
spl/sunxi-spl.bin: spl/u-boot-spl @: @@ -2113,14 +2113,14 @@ tpl/u-boot-tpl.bin: tpl/u-boot-tpl $(TPL_SIZE_CHECK)
tpl/u-boot-tpl: tools prepare $(if $(CONFIG_TPL_OF_CONTROL),dts/dt.dtb) - $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all + $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.xpl all
vpl/u-boot-vpl.bin: vpl/u-boot-vpl @: $(VPL_SIZE_CHECK)
vpl/u-boot-vpl: tools prepare $(if $(CONFIG_TPL_OF_CONTROL),dts/dt.dtb) - $(Q)$(MAKE) obj=vpl -f $(srctree)/scripts/Makefile.spl all + $(Q)$(MAKE) obj=vpl -f $(srctree)/scripts/Makefile.xpl all
TAG_SUBDIRS := $(patsubst %,$(srctree)/%,$(u-boot-dirs) include)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.xpl similarity index 100% rename from scripts/Makefile.spl rename to scripts/Makefile.xpl
Now that the conversion of all CONFIG options to Kconfig is complete, these files only contain the xPL_BUILD defines. Add a comment to make this clear.
scripts/Makefile.xpl | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/scripts/Makefile.xpl b/scripts/Makefile.xpl index 1868f1beef6..3091311a3d2 100644 --- a/scripts/Makefile.xpl +++ b/scripts/Makefile.xpl @@ -20,6 +20,12 @@ _dummy := $(shell [ -d $(obj) ] || mkdir -p $(obj)) include $(srctree)/scripts/Kbuild.include
-include include/config/auto.conf + +# This file contains 0, 1 or 2 lines +# It is empty for U-Boot proper (where $(obj) is empty) +# For any xPL build it contains CONFIG_SPL_BUILD=y +# For TPL builds it has CONFIG_SPL_BUILD=y and CONFIG_TPL_BUILD=y +# For VPL builds it has CONFIG_SPL_BUILD=y and CONFIG_VPL_BUILD=y -include $(obj)/include/autoconf.mk
UBOOTINCLUDE := -I$(obj)/include $(UBOOTINCLUDE)
The new name 'xPL' is intended to indicate a build of any phase which is not U-Boot proper. Define it for all such phases.
Note that we also define CONFIG_SPL_BUILD for all xPL builds. This preserves existing behaviour, but future patches will adjust that.
scripts/Makefile.autoconf | 6 +++--- scripts/Makefile.xpl | 9 +++++---- 2 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index b42f9b525fe..d7544022a31 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -83,15 +83,15 @@ u-boot.cfg: include/config.h FORCE
spl/u-boot.cfg: include/config.h FORCE $(Q)mkdir -p $(dir $@) - $(call cmd,u_boot_cfg,-DCONFIG_SPL_BUILD) + $(call cmd,u_boot_cfg,-DCONFIG_XPL_BUILD -DCONFIG_SPL_BUILD)
tpl/u-boot.cfg: include/config.h FORCE $(Q)mkdir -p $(dir $@) - $(call cmd,u_boot_cfg,-DCONFIG_SPL_BUILD -DCONFIG_TPL_BUILD) + $(call cmd,u_boot_cfg,-DCONFIG_XPL_BUILD -DCONFIG_SPL_BUILD -DCONFIG_TPL_BUILD)
vpl/u-boot.cfg: include/config.h FORCE $(Q)mkdir -p $(dir $@) - $(call cmd,u_boot_cfg,-DCONFIG_SPL_BUILD -DCONFIG_VPL_BUILD) + $(call cmd,u_boot_cfg,-DCONFIG_XPL_BUILD -DCONFIG_SPL_BUILD -DCONFIG_VPL_BUILD)
include/autoconf.mk: u-boot.cfg $(call cmd,autoconf) diff --git a/scripts/Makefile.xpl b/scripts/Makefile.xpl index 3091311a3d2..ad21d451a30 100644 --- a/scripts/Makefile.xpl +++ b/scripts/Makefile.xpl @@ -21,15 +21,16 @@ include $(srctree)/scripts/Kbuild.include
-# This file contains 0, 1 or 2 lines +# This file contains 0, 2 or 3 lines # It is empty for U-Boot proper (where $(obj) is empty) -# For any xPL build it contains CONFIG_SPL_BUILD=y -# For TPL builds it has CONFIG_SPL_BUILD=y and CONFIG_TPL_BUILD=y -# For VPL builds it has CONFIG_SPL_BUILD=y and CONFIG_VPL_BUILD=y +# For any xPL build it contains CONFIG_SPL_BUILD=y and CONFIG_XPL_BUILD=y +# - for TPL builds it also contains CONFIG_TPL_BUILD=y +# - for VPL builds it also contains CONFIG_VPL_BUILD=y -include $(obj)/include/autoconf.mk
+KBUILD_CPPFLAGS += -DCONFIG_XPL_BUILD KBUILD_CPPFLAGS += -DCONFIG_SPL_BUILD ifeq ($(CONFIG_TPL_BUILD),y) KBUILD_CPPFLAGS += -DCONFIG_TPL_BUILD
Use the new symbol to refer to any 'SPL' build, including TPL and VPL
README | 4 +- arch/arm/Makefile | 6 +-- arch/arm/config.mk | 6 +-- arch/arm/cpu/arm11/Makefile | 2 +- arch/arm/cpu/arm1176/start.S | 2 +- arch/arm/cpu/arm926ejs/Makefile | 2 +- arch/arm/cpu/arm926ejs/mxs/Makefile | 4 +- arch/arm/cpu/arm926ejs/sunxi/config.mk | 2 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/cpu.c | 2 +- arch/arm/cpu/armv7/lowlevel_init.S | 4 +- arch/arm/cpu/armv7/s5p-common/Makefile | 2 +- arch/arm/cpu/armv7/start.S | 2 +- arch/arm/cpu/armv7/sunxi/Makefile | 4 +- arch/arm/cpu/armv8/Makefile | 6 +-- arch/arm/cpu/armv8/cache_v8.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 14 +++--- .../armv8/fsl-layerscape/fsl_lsch2_speed.c | 2 +- .../armv8/fsl-layerscape/fsl_lsch3_serdes.c | 6 +-- arch/arm/cpu/armv8/fsl-layerscape/icid.c | 6 +-- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 6 +-- .../arm/cpu/armv8/fsl-layerscape/ls1043_ids.c | 2 +- .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 4 +- arch/arm/cpu/armv8/start.S | 8 ++-- arch/arm/dts/imx8qm-u-boot.dtsi | 2 +- arch/arm/dts/imx8qxp-u-boot.dtsi | 2 +- .../asm/arch-fsl-layerscape/fsl_icid.h | 6 +-- arch/arm/include/asm/arch-imx8/boot0.h | 2 +- arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 2 +- arch/arm/include/asm/arch-mx6/litesom.h | 2 +- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 4 +- arch/arm/include/asm/arch-mxs/sys_proto.h | 2 +- arch/arm/include/asm/arch-rk3066/boot0.h | 4 +- arch/arm/include/asm/arch-rockchip/boot0.h | 6 +-- .../include/asm/arch-rockchip/cru_rv1126.h | 10 ++--- arch/arm/include/asm/arch-sunxi/boot0.h | 4 +- arch/arm/include/asm/arch-sunxi/sys_proto.h | 2 +- arch/arm/include/asm/fsl_secure_boot.h | 4 +- arch/arm/include/asm/ti-common/sys_proto.h | 2 +- arch/arm/lib/Makefile | 2 +- arch/arm/lib/crt0.S | 14 +++--- arch/arm/lib/crt0_64.S | 10 ++--- arch/arm/lib/eabi_compat.c | 2 +- arch/arm/lib/stack.c | 2 +- arch/arm/lib/vectors.S | 6 +-- arch/arm/lib/zimage.c | 4 +- arch/arm/mach-aspeed/ast2600/Makefile | 2 +- arch/arm/mach-aspeed/ast2600/lowlevel_init.S | 2 +- arch/arm/mach-at91/Makefile | 2 +- arch/arm/mach-at91/config.mk | 2 +- arch/arm/mach-davinci/Makefile | 2 +- arch/arm/mach-davinci/config.mk | 2 +- arch/arm/mach-davinci/misc.c | 2 +- arch/arm/mach-exynos/Makefile | 2 +- arch/arm/mach-exynos/lowlevel_init.c | 4 +- arch/arm/mach-exynos/pinmux.c | 2 +- arch/arm/mach-imx/Makefile | 18 ++++---- arch/arm/mach-imx/cpu.c | 6 +-- arch/arm/mach-imx/hab.c | 8 ++-- arch/arm/mach-imx/imx8/cpu.c | 4 +- arch/arm/mach-imx/imx8m/clock_imx8mm.c | 2 +- arch/arm/mach-imx/imx8m/clock_imx8mq.c | 4 +- arch/arm/mach-imx/imx8m/soc.c | 16 +++---- arch/arm/mach-imx/imx8ulp/Makefile | 2 +- arch/arm/mach-imx/imx8ulp/clock.c | 2 +- arch/arm/mach-imx/imx8ulp/lowlevel_init.S | 2 +- arch/arm/mach-imx/imx8ulp/soc.c | 12 ++--- arch/arm/mach-imx/imx9/Makefile | 2 +- arch/arm/mach-imx/imx9/clock.c | 4 +- arch/arm/mach-imx/imx9/lowlevel_init.S | 2 +- arch/arm/mach-imx/imx9/soc.c | 12 ++--- arch/arm/mach-imx/mx5/clock.c | 2 +- arch/arm/mach-imx/mx6/Makefile | 2 +- arch/arm/mach-imx/mx6/clock.c | 2 +- arch/arm/mach-imx/mx6/litesom.c | 2 +- arch/arm/mach-imx/mx6/opos6ul.c | 4 +- arch/arm/mach-imx/mx6/soc.c | 6 +-- arch/arm/mach-imx/mx7/clock.c | 2 +- arch/arm/mach-imx/mx7/soc.c | 4 +- arch/arm/mach-imx/mx7ulp/clock.c | 2 +- arch/arm/mach-imx/mx7ulp/soc.c | 2 +- arch/arm/mach-imx/syscounter.c | 2 +- arch/arm/mach-k3/am62ax/Makefile | 2 +- arch/arm/mach-k3/am62px/Makefile | 2 +- arch/arm/mach-k3/am62x/Makefile | 2 +- arch/arm/mach-k3/am64x/Makefile | 2 +- arch/arm/mach-k3/am65x/Makefile | 2 +- arch/arm/mach-k3/arm64/cache.S | 2 +- arch/arm/mach-k3/j721e/Makefile | 2 +- arch/arm/mach-k3/j721s2/Makefile | 2 +- arch/arm/mach-k3/j721s2/j721s2_init.c | 2 +- arch/arm/mach-k3/j722s/Makefile | 2 +- arch/arm/mach-k3/j784s4/Makefile | 2 +- arch/arm/mach-k3/r5/Makefile | 2 +- arch/arm/mach-k3/security.c | 2 +- arch/arm/mach-keystone/Makefile | 2 +- arch/arm/mach-keystone/config.mk | 4 +- arch/arm/mach-keystone/mon.c | 2 +- arch/arm/mach-lpc32xx/Makefile | 2 +- arch/arm/mach-mediatek/Makefile | 2 +- arch/arm/mach-mediatek/mt7629/lowlevel_init.S | 2 +- arch/arm/mach-mvebu/Makefile | 8 ++-- arch/arm/mach-mvebu/cpu.c | 4 +- arch/arm/mach-mvebu/include/mach/cpu.h | 8 ++-- arch/arm/mach-mvebu/include/mach/soc.h | 2 +- arch/arm/mach-mvebu/serdes/a38x/Makefile | 8 ++-- arch/arm/mach-mvebu/serdes/axp/Makefile | 4 +- arch/arm/mach-nexell/include/mach/display.h | 2 +- arch/arm/mach-omap2/Makefile | 2 +- arch/arm/mach-omap2/am33xx/board.c | 18 ++++---- arch/arm/mach-omap2/boot-common.c | 6 +-- arch/arm/mach-omap2/clocks-common.c | 2 +- arch/arm/mach-omap2/config.mk | 2 +- arch/arm/mach-omap2/config_secure.mk | 2 +- arch/arm/mach-omap2/hwinit-common.c | 14 +++--- arch/arm/mach-omap2/omap3/Makefile | 2 +- arch/arm/mach-omap2/omap3/board.c | 6 +-- arch/arm/mach-omap2/omap3/sdrc.c | 4 +- arch/arm/mach-omap2/omap5/hwinit.c | 2 +- arch/arm/mach-omap2/sec-common.c | 2 +- arch/arm/mach-orion5x/cpu.c | 2 +- arch/arm/mach-orion5x/lowlevel_init.S | 4 +- arch/arm/mach-renesas/include/mach/boot0.h | 2 +- arch/arm/mach-renesas/lowlevel_init_ca15.S | 2 +- arch/arm/mach-rockchip/Makefile | 4 +- arch/arm/mach-rockchip/px30/px30.c | 2 +- arch/arm/mach-rockchip/rk3036/Makefile | 2 +- arch/arm/mach-rockchip/rk3066/rk3066.c | 2 +- arch/arm/mach-rockchip/rk3188/rk3188.c | 4 +- arch/arm/mach-rockchip/rk322x/rk322x.c | 2 +- arch/arm/mach-rockchip/rk3288/rk3288.c | 4 +- arch/arm/mach-rockchip/rk3308/rk3308.c | 2 +- arch/arm/mach-rockchip/rk3328/rk3328.c | 2 +- arch/arm/mach-rockchip/rk3368/rk3368.c | 2 +- arch/arm/mach-rockchip/rk3399/rk3399.c | 8 ++-- arch/arm/mach-rockchip/rk3568/rk3568.c | 2 +- arch/arm/mach-rockchip/rk3588/rk3588.c | 4 +- arch/arm/mach-rockchip/rv1108/Makefile | 2 +- arch/arm/mach-rockchip/rv1126/rv1126.c | 2 +- arch/arm/mach-sc5xx/Makefile | 2 +- arch/arm/mach-sc5xx/config.mk | 2 +- arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/board.c | 6 +-- arch/arm/mach-socfpga/clock_manager.c | 2 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 2 +- arch/arm/mach-socfpga/include/mach/boot0.h | 2 +- .../include/mach/clock_manager_arria10.h | 2 +- arch/arm/mach-socfpga/lowlevel_init_soc64.S | 2 +- arch/arm/mach-socfpga/mailbox_s10.c | 2 +- arch/arm/mach-socfpga/misc.c | 2 +- arch/arm/mach-socfpga/misc_arria10.c | 2 +- arch/arm/mach-socfpga/misc_gen5.c | 2 +- arch/arm/mach-socfpga/reset_manager_s10.c | 2 +- arch/arm/mach-socfpga/secure_vab.c | 2 +- arch/arm/mach-socfpga/timer_s10.c | 4 +- arch/arm/mach-socfpga/wrap_pll_config_soc64.c | 6 +-- arch/arm/mach-stm32mp/Makefile | 2 +- arch/arm/mach-stm32mp/bsec.c | 12 ++--- arch/arm/mach-stm32mp/stm32mp1/Makefile | 2 +- arch/arm/mach-stm32mp/stm32mp1/cpu.c | 6 +-- arch/arm/mach-stm32mp/stm32mp1/stm32mp15x.c | 4 +- arch/arm/mach-sunxi/Makefile | 2 +- arch/arm/mach-sunxi/board.c | 10 ++--- arch/arm/mach-sunxi/clock_sun4i.c | 4 +- arch/arm/mach-sunxi/clock_sun50i_h6.c | 4 +- arch/arm/mach-sunxi/clock_sun6i.c | 4 +- arch/arm/mach-sunxi/clock_sun8i_a83t.c | 4 +- arch/arm/mach-sunxi/clock_sun9i.c | 4 +- arch/arm/mach-sunxi/gtbus_sun9i.c | 2 +- arch/arm/mach-tegra/Makefile | 4 +- arch/arm/mach-tegra/board.c | 2 +- arch/arm/mach-tegra/board2.c | 2 +- arch/arm/mach-tegra/tegra114/Makefile | 2 +- arch/arm/mach-tegra/tegra124/Makefile | 4 +- arch/arm/mach-tegra/tegra20/Makefile | 2 +- arch/arm/mach-tegra/tegra30/Makefile | 2 +- arch/arm/mach-uniphier/Makefile | 2 +- arch/arm/mach-uniphier/arm32/Makefile | 2 +- .../mach-uniphier/boot-device/boot-device.c | 4 +- arch/arm/mach-uniphier/clk/Makefile | 2 +- arch/arm/mach-uniphier/debug-uart/Makefile | 2 +- .../arm/mach-uniphier/debug-uart/debug-uart.c | 4 +- arch/arm/mach-uniphier/dram/Makefile | 2 +- arch/arm/mach-zynq/Makefile | 2 +- arch/arm/mach-zynq/cpu.c | 2 +- arch/arm/mach-zynqmp/Makefile | 6 +-- arch/arm/mach-zynqmp/cpu.c | 4 +- arch/microblaze/config.mk | 2 +- arch/microblaze/cpu/Makefile | 2 +- arch/microblaze/cpu/start.S | 8 ++-- arch/mips/Makefile | 2 +- arch/mips/config.mk | 2 +- arch/mips/lib/Makefile | 2 +- arch/mips/mach-jz47xx/Makefile | 2 +- arch/mips/mach-jz47xx/include/mach/jz4780.h | 2 +- arch/mips/mach-jz47xx/jz4780/jz4780.c | 4 +- arch/mips/mach-jz47xx/start.S | 4 +- arch/mips/mach-mtmips/Makefile | 2 +- arch/mips/mach-mtmips/cpu.c | 2 +- arch/mips/mach-mtmips/mt7620/Makefile | 2 +- arch/mips/mach-mtmips/mt7621/Makefile | 2 +- arch/mips/mach-mtmips/mt7628/Makefile | 2 +- arch/powerpc/config.mk | 2 +- arch/powerpc/cpu/mpc83xx/Makefile | 2 +- arch/powerpc/cpu/mpc83xx/start.S | 6 +-- arch/powerpc/cpu/mpc85xx/Makefile | 4 +- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 2 +- arch/powerpc/cpu/mpc85xx/start.S | 14 +++--- arch/powerpc/cpu/mpc85xx/tlb.c | 4 +- arch/powerpc/cpu/mpc8xxx/Makefile | 2 +- arch/powerpc/cpu/mpc8xxx/fsl_pamu.c | 4 +- arch/powerpc/cpu/mpc8xxx/law.c | 4 +- arch/powerpc/cpu/mpc8xxx/pamu_table.c | 2 +- arch/powerpc/include/asm/fsl_secure_boot.h | 8 ++-- arch/powerpc/lib/Makefile | 4 +- arch/riscv/cpu/fu540/Makefile | 2 +- arch/riscv/cpu/fu740/Makefile | 2 +- arch/riscv/cpu/jh7110/Makefile | 2 +- arch/riscv/cpu/start.S | 8 ++-- arch/riscv/lib/Makefile | 2 +- arch/riscv/lib/sifive_cache.c | 4 +- arch/sandbox/cpu/Makefile | 2 +- arch/sandbox/cpu/cpu.c | 2 +- arch/sandbox/cpu/start.c | 2 +- arch/x86/Makefile | 2 +- arch/x86/config.mk | 8 ++-- arch/x86/cpu/Makefile | 2 +- arch/x86/cpu/apollolake/Makefile | 10 ++--- arch/x86/cpu/apollolake/fsp_bindings.c | 4 +- arch/x86/cpu/broadwell/Makefile | 4 +- arch/x86/cpu/broadwell/cpu_full.c | 2 +- arch/x86/cpu/broadwell/pch.c | 2 +- arch/x86/cpu/config.mk | 2 +- arch/x86/cpu/coreboot/Makefile | 2 +- arch/x86/cpu/coreboot/coreboot.c | 2 +- arch/x86/cpu/cpu.c | 2 +- arch/x86/cpu/intel_common/Makefile | 6 +-- arch/x86/cpu/ivybridge/Makefile | 2 +- arch/x86/include/asm/string.h | 2 +- arch/x86/lib/Makefile | 10 ++--- arch/x86/lib/fsp/Makefile | 2 +- board/BuR/brppt1/Makefile | 2 +- board/BuR/brppt1/board.c | 4 +- board/BuR/brppt2/board.c | 6 +-- board/BuR/brppt2/config.mk | 2 +- board/BuR/brsmarc1/Makefile | 2 +- board/BuR/brsmarc1/board.c | 8 ++-- board/BuR/brxre1/Makefile | 2 +- board/BuR/brxre1/board.c | 4 +- board/BuR/common/common.c | 4 +- board/CZ.NIC/turris_1x/Makefile | 2 +- board/CZ.NIC/turris_1x/tlb.c | 2 +- board/CZ.NIC/turris_omnia/Makefile | 2 +- board/CZ.NIC/turris_omnia/turris_omnia.c | 2 +- board/Synology/ds414/Makefile | 2 +- board/advantech/imx8mp_rsb3720a1/Makefile | 4 +- board/advantech/imx8qm_dmsse20_a1/Makefile | 2 +- board/advantech/imx8qm_rom7720_a1/Makefile | 2 +- board/alliedtelesis/x530/Makefile | 2 +- board/asus/grouper/Makefile | 2 +- board/asus/transformer-t30/Makefile | 2 +- .../atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 2 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 +- .../atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 2 +- .../sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 2 +- board/atmel/sama5d2_icp/sama5d2_icp.c | 2 +- .../atmel/sama5d2_xplained/sama5d2_xplained.c | 2 +- .../atmel/sama5d3_xplained/sama5d3_xplained.c | 2 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- .../atmel/sama5d4_xplained/sama5d4_xplained.c | 2 +- board/atmel/sama5d4ek/sama5d4ek.c | 2 +- board/avionic-design/tec-ng/Makefile | 2 +- board/beacon/imx8mm/Makefile | 2 +- board/beacon/imx8mn/Makefile | 2 +- board/beacon/imx8mp/Makefile | 2 +- board/bitmain/antminer_s9/Makefile | 2 +- board/bosch/acc/acc.c | 2 +- board/bosch/shc/board.c | 4 +- board/bsh/imx6ulz_smm_m2/Makefile | 2 +- board/bsh/imx8mn_smm_s2/Makefile | 2 +- board/bticino/mamoj/Makefile | 2 +- board/cloos/imx8mm_phg/Makefile | 2 +- board/compulab/cl-som-imx7/Makefile | 2 +- board/compulab/cl-som-imx7/common.h | 4 +- board/compulab/cl-som-imx7/mux.c | 4 +- board/compulab/cm_fx6/Makefile | 2 +- board/compulab/cm_t43/Makefile | 2 +- board/compulab/imx8mm-cl-iot-gate/Makefile | 2 +- .../compulab/imx8mm-cl-iot-gate/eeprom_spl.c | 2 +- board/comvetia/lxr2/lxr2.c | 2 +- .../conclusive/kstr-sama5d27/kstr-sama5d27.c | 2 +- board/congatec/cgtqmx8/Makefile | 2 +- board/congatec/common/Makefile | 2 +- board/data_modul/common/common.c | 2 +- board/data_modul/imx8mm_edm_sbc/Makefile | 2 +- board/data_modul/imx8mp_edm_sbc/Makefile | 2 +- board/davinci/da8xxevm/omapl138_lcdk.c | 2 +- board/dhelectronics/dh_imx6/Makefile | 2 +- board/dhelectronics/dh_imx8mp/Makefile | 2 +- board/dhelectronics/dh_stm32mp1/board.c | 6 +-- board/ea/mx7ulp_com/mx7ulp_com.c | 2 +- board/eets/pdu001/board.c | 2 +- board/embest/mx6boards/mx6boards.c | 2 +- board/engicam/common/Makefile | 2 +- board/engicam/imx8mm/Makefile | 2 +- board/engicam/imx8mp/Makefile | 2 +- board/engicam/stm32mp1/Makefile | 2 +- board/firefly/firefly-rk3288/firefly-rk3288.c | 2 +- board/firefly/roc-pc-rk3399/roc-pc-rk3399.c | 2 +- board/freescale/common/Makefile | 6 +-- board/freescale/common/cmd_esbc_validate.c | 2 +- board/freescale/common/fsl_chain_of_trust.c | 8 ++-- board/freescale/common/fsl_validate.c | 4 +- board/freescale/common/qixis.c | 2 +- board/freescale/imx8mm_evk/Makefile | 2 +- board/freescale/imx8mn_evk/Makefile | 2 +- board/freescale/imx8mp_evk/Makefile | 2 +- board/freescale/imx8mq_evk/Makefile | 2 +- board/freescale/imx8qm_mek/Makefile | 2 +- board/freescale/imx8qxp_mek/Makefile | 2 +- board/freescale/imx8ulp_evk/Makefile | 2 +- board/freescale/imx93_evk/Makefile | 2 +- board/freescale/imxrt1020-evk/imxrt1020-evk.c | 2 +- board/freescale/imxrt1050-evk/imxrt1050-evk.c | 2 +- board/freescale/imxrt1170-evk/imxrt1170-evk.c | 2 +- board/freescale/ls1012afrdm/ls1012afrdm.c | 2 +- board/freescale/ls1012aqds/ls1012aqds.c | 2 +- board/freescale/ls1012ardb/ls1012ardb.c | 2 +- board/freescale/ls1021aiot/ls1021aiot.c | 4 +- board/freescale/ls1021aqds/ddr.c | 4 +- board/freescale/ls1021aqds/ls1021aqds.c | 2 +- board/freescale/ls1021atsn/ls1021atsn.c | 10 ++--- board/freescale/ls1021atwr/ls1021atwr.c | 10 ++--- board/freescale/ls1028a/ls1028a.c | 2 +- board/freescale/ls1043aqds/Makefile | 2 +- board/freescale/ls1043aqds/ddr.c | 2 +- board/freescale/ls1043aqds/ls1043aqds.c | 2 +- board/freescale/ls1043ardb/Makefile | 2 +- board/freescale/ls1043ardb/ddr.c | 4 +- board/freescale/ls1043ardb/ls1043ardb.c | 2 +- board/freescale/ls1046aqds/Makefile | 2 +- board/freescale/ls1046aqds/ddr.c | 2 +- board/freescale/ls1046aqds/ls1046aqds.c | 2 +- board/freescale/ls1046ardb/Makefile | 2 +- board/freescale/ls1046ardb/ddr.c | 2 +- board/freescale/ls1046ardb/ls1046ardb.c | 2 +- board/freescale/ls1088a/Makefile | 2 +- board/freescale/ls1088a/ddr.c | 6 +-- board/freescale/ls1088a/ls1088a.c | 8 ++-- board/freescale/ls2080aqds/ddr.c | 2 +- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- board/freescale/ls2080ardb/ddr.c | 2 +- board/freescale/ls2080ardb/eth_ls2080rdb.c | 2 +- board/freescale/lx2160a/lx2160a.c | 2 +- board/freescale/mx23evk/Makefile | 2 +- board/freescale/mx28evk/Makefile | 2 +- board/freescale/mx6memcal/Makefile | 2 +- board/freescale/mx6sabreauto/mx6sabreauto.c | 2 +- board/freescale/mx6sabresd/mx6sabresd.c | 2 +- board/freescale/mx6slevk/mx6slevk.c | 4 +- .../mx6ul_14x14_evk/mx6ul_14x14_evk.c | 4 +- board/freescale/p1010rdb/Makefile | 4 +- board/freescale/p1010rdb/p1010rdb.c | 2 +- board/freescale/p1010rdb/tlb.c | 2 +- board/freescale/p1_p2_rdb_pc/Makefile | 4 +- board/freescale/p1_p2_rdb_pc/tlb.c | 2 +- board/freescale/t102xrdb/Makefile | 2 +- board/freescale/t102xrdb/ddr.c | 4 +- board/freescale/t102xrdb/tlb.c | 4 +- board/freescale/t104xrdb/Makefile | 2 +- board/freescale/t104xrdb/ddr.c | 4 +- board/freescale/t104xrdb/tlb.c | 6 +-- board/freescale/t208xqds/Makefile | 2 +- board/freescale/t208xqds/ddr.c | 2 +- board/freescale/t208xqds/tlb.c | 4 +- board/freescale/t208xrdb/Makefile | 2 +- board/freescale/t208xrdb/ddr.c | 2 +- board/freescale/t208xrdb/tlb.c | 4 +- board/freescale/t4rdb/Makefile | 2 +- board/freescale/t4rdb/cpld.c | 2 +- board/freescale/t4rdb/ddr.c | 2 +- board/freescale/t4rdb/tlb.c | 4 +- board/gardena/smart-gateway-at91sam/Makefile | 2 +- board/gardena/smart-gateway-mt7688/board.c | 2 +- board/gateworks/gw_ventana/Makefile | 2 +- board/gateworks/gw_ventana/eeprom.c | 2 +- board/gateworks/venice/Makefile | 2 +- board/gdsys/a38x/Makefile | 2 +- board/gdsys/a38x/controlcenterdc.c | 12 ++--- board/ge/b1x5v2/b1x5v2.c | 4 +- board/ge/b1x5v2/spl.c | 2 +- board/google/chromebook_coral/coral.c | 2 +- board/google/gru/gru.c | 4 +- board/google/imx8mq_phanbell/Makefile | 2 +- board/google/veyron/veyron.c | 2 +- board/grinn/chiliboard/board.c | 2 +- board/grinn/liteboard/board.c | 2 +- board/htc/endeavoru/Makefile | 2 +- board/imgtec/ci20/ci20.c | 4 +- board/isee/igep003x/Makefile | 2 +- board/isee/igep003x/board.c | 2 +- board/isee/igep00x0/Makefile | 2 +- board/k+p/kp_imx6q_tpc/Makefile | 2 +- board/kontron/pitx_imx8m/Makefile | 2 +- board/kontron/sl-mx6ul/Makefile | 2 +- board/kontron/sl-mx8mm/Makefile | 2 +- board/kontron/sl28/Makefile | 4 +- board/kontron/sl28/ddr.c | 2 +- board/kosagi/novena/Makefile | 2 +- board/lenovo/ideapad-yoga-11/Makefile | 2 +- board/lg/sniper/sniper.c | 2 +- board/lg/x3-t30/Makefile | 2 +- board/liebherr/display5/Makefile | 2 +- board/liebherr/mccmon6/Makefile | 2 +- board/liebherr/xea/Makefile | 2 +- board/liebherr/xea/xea.c | 6 +-- board/logicpd/am3517evm/am3517evm.c | 2 +- board/logicpd/imx6/imx6logic.c | 2 +- board/logicpd/omap3som/omap3logic.c | 2 +- board/menlo/m53menlo/m53menlo.c | 2 +- board/menlo/mx8menlo/Makefile | 4 +- board/microsoft/surface-rt/Makefile | 2 +- board/mntre/imx8mq_reform2/Makefile | 2 +- board/msc/sm2s_imx8mp/Makefile | 2 +- board/myir/mys_6ulx/Makefile | 2 +- board/nvidia/beaver/Makefile | 2 +- board/nvidia/cardhu/Makefile | 2 +- board/olimex/mx23_olinuxino/Makefile | 2 +- board/opalkelly/zynq/Makefile | 2 +- board/phytec/common/Makefile | 2 +- board/phytec/pcl063/Makefile | 2 +- board/phytec/pcm058/pcm058.c | 2 +- board/phytec/phycore_am335x_r2/Makefile | 2 +- board/phytec/phycore_am335x_r2/board.c | 2 +- board/phytec/phycore_am62x/phycore-am62x.c | 2 +- board/phytec/phycore_imx8mm/Makefile | 2 +- board/phytec/phycore_imx8mp/Makefile | 2 +- board/phytec/phycore_imx93/Makefile | 2 +- board/polyhex/imx8mp_debix_model_a/Makefile | 2 +- board/purism/librem5/Makefile | 2 +- board/purism/librem5/librem5.h | 4 +- board/radxa/rockpi4-rk3399/rockpi4-rk3399.c | 4 +- board/renesas/alt/Makefile | 2 +- board/renesas/condor/Makefile | 2 +- board/renesas/draak/Makefile | 2 +- board/renesas/eagle/Makefile | 2 +- board/renesas/ebisu/Makefile | 2 +- board/renesas/falcon/Makefile | 2 +- board/renesas/gose/Makefile | 2 +- board/renesas/koelsch/Makefile | 2 +- board/renesas/lager/Makefile | 2 +- board/renesas/porter/Makefile | 2 +- board/renesas/salvator-x/Makefile | 2 +- board/renesas/silk/Makefile | 2 +- board/renesas/stout/Makefile | 2 +- board/renesas/ulcb/Makefile | 2 +- board/renesas/v3hsk/Makefile | 2 +- board/renesas/v3msk/Makefile | 2 +- board/ronetix/imx7-cm/Makefile | 2 +- board/ronetix/imx8mq-cm/Makefile | 2 +- board/samsung/common/Makefile | 2 +- board/samsung/origen/Makefile | 2 +- board/samsung/smdkv310/Makefile | 2 +- board/seeed/npi_imx6ull/Makefile | 2 +- board/sielaff/imx6dl-sielaff/Makefile | 2 +- board/siemens/capricorn/Makefile | 2 +- board/siemens/capricorn/board.c | 8 ++-- board/siemens/common/board_am335x.c | 12 ++--- board/siemens/common/board_am335x.h | 4 +- board/siemens/common/factoryset.c | 4 +- board/siemens/corvus/board.c | 2 +- board/siemens/draco/Makefile | 4 +- board/siemens/draco/board.c | 14 +++--- board/siemens/pxm2/Makefile | 4 +- board/siemens/pxm2/board.c | 14 +++--- board/siemens/rut/Makefile | 4 +- board/siemens/rut/board.c | 8 ++-- board/siemens/smartweb/smartweb.c | 2 +- board/siemens/taurus/taurus.c | 4 +- board/sifive/unleashed/Makefile | 2 +- board/sifive/unmatched/Makefile | 2 +- board/silinux/ek874/Makefile | 2 +- board/softing/vining_2000/vining_2000.c | 2 +- board/softing/vining_fpga/socfpga.c | 2 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 2 +- board/st/common/cmd_stboard.c | 2 +- board/st/stm32f746-disco/stm32f746-disco.c | 4 +- board/st/stm32mp1/Makefile | 2 +- board/starfive/visionfive2/Makefile | 2 +- board/sunxi/board.c | 6 +-- board/tcl/sl50/board.c | 14 +++--- board/technexion/pico-imx6/spl.c | 2 +- board/technexion/pico-imx6ul/spl.c | 2 +- board/technexion/pico-imx7d/spl.c | 2 +- board/technexion/pico-imx8mq/Makefile | 2 +- board/theadorable/theadorable.c | 6 +-- .../theobroma-systems/jaguar_rk3588/Makefile | 2 +- board/theobroma-systems/puma_rk3399/Makefile | 2 +- .../theobroma-systems/ringneck_px30/Makefile | 2 +- board/theobroma-systems/tiger_rk3588/Makefile | 2 +- board/ti/am335x/board.c | 12 ++--- board/ti/am57xx/board.c | 10 ++--- board/ti/am62x/evm.c | 2 +- board/ti/am64x/evm.c | 2 +- board/ti/common/board_detect.c | 6 +-- board/ti/dra7xx/evm.c | 6 +-- board/ti/j721e/evm.c | 6 +-- board/ti/j721s2/evm.c | 4 +- board/ti/ks2_evm/board.c | 2 +- board/ti/ks2_evm/board_k2e.c | 2 +- board/ti/ks2_evm/board_k2g.c | 4 +- board/ti/ks2_evm/board_k2hk.c | 2 +- board/ti/ks2_evm/board_k2l.c | 2 +- board/ti/omap3evm/evm.c | 4 +- board/timll/devkit8000/devkit8000.c | 2 +- board/topic/zynq/Makefile | 2 +- board/toradex/apalis_imx6/apalis_imx6.c | 12 ++--- board/toradex/apalis_imx6/do_fuse.c | 4 +- board/toradex/apalis_imx6/pf0100.c | 4 +- board/toradex/apalis_t30/Makefile | 2 +- board/toradex/colibri_imx6/colibri_imx6.c | 12 ++--- board/toradex/colibri_imx6/do_fuse.c | 4 +- board/toradex/colibri_imx6/pf0100.c | 4 +- board/toradex/colibri_t30/Makefile | 2 +- board/toradex/common/Makefile | 2 +- board/toradex/verdin-imx8mm/Makefile | 2 +- board/toradex/verdin-imx8mp/Makefile | 2 +- board/udoo/neo/neo.c | 2 +- board/udoo/udoo_spl.c | 2 +- board/variscite/common/imx9_eeprom.c | 2 +- board/variscite/dart_6ul/Makefile | 2 +- board/variscite/imx8mn_var_som/Makefile | 2 +- .../variscite/imx8mn_var_som/imx8mn_var_som.c | 4 +- board/variscite/imx93_var_som/Makefile | 2 +- board/vscom/baltos/board.c | 14 +++--- board/wandboard/Makefile | 2 +- board/wexler/qc750/Makefile | 2 +- board/work-microwave/work_92105/Makefile | 2 +- board/xilinx/common/Makefile | 2 +- board/xilinx/common/board.c | 6 +-- .../microblaze-generic/microblaze-generic.c | 2 +- board/xilinx/zynq/Makefile | 6 +-- board/xilinx/zynq/board.c | 4 +- board/xilinx/zynqmp/Makefile | 6 +-- board/xilinx/zynqmp/zynqmp.c | 6 +-- boot/Makefile | 2 +- boot/image-android-dt.c | 2 +- boot/image-android.c | 2 +- boot/image-fit-sig.c | 2 +- cmd/Makefile | 4 +- cmd/nvedit.c | 12 ++--- common/Makefile | 12 ++--- common/cli_readline.c | 2 +- common/console.c | 2 +- common/hash.c | 2 +- common/spl/Makefile | 2 +- common/splash_source.c | 2 +- config.mk | 2 +- disk/part.c | 2 +- disk/part_dos.c | 2 +- doc/develop/distro.rst | 4 +- doc/develop/qconfig.rst | 2 +- doc/develop/tests_sandbox.rst | 2 +- drivers/Makefile | 4 +- drivers/block/Makefile | 2 +- drivers/bus/Makefile | 2 +- drivers/clk/altera/clk-agilex.c | 2 +- drivers/clk/altera/clk-agilex5.c | 2 +- drivers/clk/altera/clk-n5x.c | 2 +- drivers/clk/clk-uclass.c | 2 +- drivers/clk/clk_vexpress_osc.c | 4 +- drivers/clk/clk_zynq.c | 22 +++++----- drivers/clk/imx/clk-imx8mm.c | 6 +-- drivers/clk/imx/clk-imx8mn.c | 6 +-- drivers/clk/imx/clk-imxrt1020.c | 2 +- drivers/clk/imx/clk-imxrt1050.c | 2 +- drivers/clk/rockchip/clk_px30.c | 6 +-- drivers/clk/rockchip/clk_rk3188.c | 6 +-- drivers/clk/rockchip/clk_rk3288.c | 8 ++-- drivers/clk/rockchip/clk_rk3328.c | 4 +- drivers/clk/rockchip/clk_rk3368.c | 14 +++--- drivers/clk/rockchip/clk_rk3399.c | 10 ++--- drivers/clk/rockchip/clk_rk3568.c | 10 ++--- drivers/clk/rockchip/clk_rk3588.c | 14 +++--- drivers/clk/sifive/sifive-prci.c | 2 +- drivers/clk/starfive/clk-jh7110-pll.c | 4 +- drivers/clk/stm32/clk-stm32mp1.c | 6 +-- drivers/core/ofnode.c | 4 +- drivers/crypto/fsl/jobdesc.c | 2 +- drivers/crypto/fsl/jr.c | 6 +-- drivers/ddr/altera/sdram_gen5.c | 4 +- drivers/ddr/fsl/lc_common_dimm_params.c | 6 +-- drivers/ddr/fsl/main.c | 6 +-- drivers/ddr/imx/imx8m/Makefile | 2 +- drivers/ddr/imx/imx8ulp/Makefile | 2 +- drivers/ddr/imx/imx9/Makefile | 2 +- drivers/ddr/imx/phy/Makefile | 2 +- drivers/ddr/marvell/a38x/Makefile | 44 +++++++++---------- drivers/ddr/marvell/a38x/old/Makefile | 28 ++++++------ drivers/ddr/marvell/axp/Makefile | 20 ++++----- drivers/firmware/firmware-zynqmp.c | 10 ++--- drivers/fpga/intel_sdm_mb.c | 2 +- drivers/fpga/zynqpl.c | 6 +-- drivers/gpio/Makefile | 2 +- drivers/gpio/gpio-uclass.c | 4 +- drivers/gpio/pca953x.c | 2 +- drivers/gpio/rk_gpio.c | 4 +- drivers/gpio/s5p_gpio.c | 10 ++--- drivers/gpio/sunxi_gpio.c | 2 +- drivers/gpio/tca642x.c | 2 +- drivers/gpio/tegra_gpio.c | 2 +- drivers/input/Makefile | 2 +- drivers/mailbox/zynqmp-ipi.c | 6 +-- drivers/misc/Makefile | 6 +-- drivers/misc/gsc.c | 2 +- drivers/misc/imx8/scu.c | 2 +- drivers/mmc/Makefile | 2 +- drivers/mmc/mmc-uclass.c | 4 +- drivers/mmc/mmc.c | 20 ++++----- drivers/mmc/mmc_legacy.c | 4 +- drivers/mmc/mmc_private.h | 2 +- drivers/mmc/omap_hsmmc.c | 4 +- drivers/mmc/rockchip_dw_mmc.c | 2 +- drivers/mmc/rockchip_sdhci.c | 2 +- drivers/mmc/socfpga_dw_mmc.c | 2 +- drivers/mmc/tmio-common.c | 2 +- drivers/mmc/uniphier-sd.c | 4 +- drivers/mmc/zynq_sdhci.c | 6 +-- drivers/mtd/Makefile | 2 +- drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/raw/Makefile | 2 +- drivers/mtd/nand/raw/atmel_nand.c | 4 +- drivers/mtd/nand/raw/lpc32xx_nand_mlc.c | 6 +-- drivers/mtd/nand/raw/lpc32xx_nand_slc.c | 8 ++-- drivers/mtd/nand/raw/nand_base.c | 10 ++--- drivers/mtd/nand/raw/omap_gpmc.c | 4 +- drivers/mtd/nand/raw/sand_nand.c | 2 +- drivers/mtd/onenand/Makefile | 2 +- drivers/mtd/spi/Makefile | 2 +- drivers/mtd/spi/sf-uclass.c | 2 +- drivers/mtd/spi/sf_dataflash.c | 2 +- drivers/mtd/spi/spi-nor-core.c | 4 +- drivers/net/dwc_eth_xgmac_socfpga.c | 2 +- drivers/net/dwmac_socfpga.c | 2 +- drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 4 +- drivers/pinctrl/pinctrl_stm32.c | 4 +- drivers/pinctrl/tegra/Makefile | 2 +- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 2 +- drivers/power/Makefile | 2 +- drivers/power/pmic/rk8xx.c | 4 +- drivers/power/pmic/stpmic1.c | 6 +-- drivers/power/power_core.c | 2 +- drivers/power/regulator/rk8xx.c | 2 +- drivers/power/sy8106a.c | 2 +- drivers/ram/Makefile | 2 +- drivers/ram/mediatek/ddr3-mt7629.c | 4 +- drivers/ram/rockchip/sdram_rk3188.c | 12 ++--- drivers/ram/rockchip/sdram_rk3288.c | 12 ++--- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/ram/rockchip/sdram_rv1126.c | 6 +-- drivers/ram/sifive/sifive_ddr.c | 6 +-- drivers/ram/starfive/Makefile | 4 +- drivers/ram/stm32mp1/stm32mp1_ram.c | 2 +- drivers/reset/reset-socfpga.c | 2 +- drivers/scsi/Makefile | 4 +- drivers/serial/Makefile | 2 +- drivers/serial/atmel_usart.c | 2 +- drivers/serial/ns16550.c | 4 +- drivers/serial/serial-uclass.c | 2 +- drivers/serial/serial.c | 2 +- drivers/serial/serial_s5p.c | 2 +- drivers/serial/serial_zynq.c | 2 +- drivers/spi/designware_spi.c | 4 +- drivers/spi/rockchip_sfc.c | 2 +- drivers/sysreset/sysreset_ast.c | 2 +- drivers/usb/cdns3/core.c | 6 +-- drivers/usb/gadget/Makefile | 4 +- drivers/usb/gadget/f_sdp.c | 10 ++--- drivers/usb/mtu3/mtu3_plat.c | 4 +- dts/Makefile | 2 +- env/Makefile | 2 +- env/common.c | 4 +- env/fat.c | 4 +- env/flash.c | 6 +-- env/mmc.c | 6 +-- env/nand.c | 8 ++-- env/nowhere.c | 2 +- env/sf.c | 2 +- fs/Makefile | 2 +- fs/fs.c | 6 +-- include/asm-generic/global_data.h | 2 +- include/bootcount.h | 4 +- include/config_distro_bootcmd.h | 10 ++--- include/configs/P1010RDB.h | 4 +- include/configs/am335x_evm.h | 4 +- include/configs/am335x_guardian.h | 4 +- include/configs/am335x_shc.h | 4 +- include/configs/am43xx_evm.h | 4 +- include/configs/am57xx_evm.h | 2 +- include/configs/capricorn-common.h | 4 +- include/configs/cgtqmx8.h | 2 +- include/configs/da850evm.h | 2 +- include/configs/dra7xx_evm.h | 4 +- include/configs/ds116.h | 4 +- include/configs/ds414.h | 4 +- .../configs/gardena-smart-gateway-mt7688.h | 2 +- include/configs/imx6q-bosch-acc.h | 2 +- include/configs/imx6ulz_smm_m2.h | 4 +- include/configs/imx8mm-cl-iot-gate.h | 2 +- include/configs/imx8mm_beacon.h | 2 +- include/configs/imx8mm_data_modul_edm_sbc.h | 2 +- include/configs/imx8mm_evk.h | 2 +- include/configs/imx8mm_icore_mx8mm.h | 4 +- include/configs/imx8mm_phg.h | 2 +- include/configs/imx8mm_venice.h | 2 +- include/configs/imx8mp_rsb3720.h | 2 +- include/configs/imx8mq_cm.h | 2 +- include/configs/imx8mq_evk.h | 2 +- include/configs/imx8mq_phanbell.h | 2 +- include/configs/imx8mq_reform2.h | 2 +- include/configs/imx8qm_mek.h | 2 +- include/configs/imx8qxp_mek.h | 2 +- include/configs/imx8ulp_evk.h | 2 +- include/configs/imx93_evk.h | 2 +- include/configs/kontron-sl-mx8mm.h | 4 +- include/configs/kontron_pitx_imx8m.h | 2 +- include/configs/librem5.h | 2 +- include/configs/linkit-smart-7688.h | 2 +- include/configs/ls1043a_common.h | 6 +-- include/configs/ls1046a_common.h | 6 +-- include/configs/ls1088a_common.h | 2 +- include/configs/msc_sm2s_imx8mp.h | 2 +- include/configs/mt7621.h | 2 +- include/configs/mt7628.h | 2 +- include/configs/n2350.h | 4 +- include/configs/p1_p2_rdb_pc.h | 4 +- include/configs/phycore_imx8mm.h | 2 +- include/configs/pico-imx8mq.h | 2 +- include/configs/rk3399_common.h | 4 +- include/configs/rockchip-common.h | 2 +- include/configs/socfpga_common.h | 2 +- include/configs/stm32mp15_common.h | 4 +- include/configs/stm32mp15_dh_dhsom.h | 2 +- include/configs/ti_omap3_common.h | 2 +- include/configs/ti_omap4_common.h | 2 +- include/configs/turris_1x.h | 4 +- include/configs/turris_omnia.h | 4 +- include/configs/verdin-imx8mm.h | 2 +- include/configs/verdin-imx8mp.h | 4 +- include/configs/vining_2000.h | 2 +- include/configs/xilinx_zynqmp.h | 2 +- include/configs/zynq-common.h | 4 +- include/env.h | 2 +- include/env_callback.h | 2 +- include/fdtdec.h | 2 +- include/image-android-dt.h | 2 +- include/iotrace.h | 2 +- include/linux/kconfig.h | 18 ++++---- include/log.h | 2 +- include/mmc.h | 2 +- include/mtd/cfi_flash.h | 2 +- include/net.h | 6 +-- include/part.h | 2 +- include/sdp.h | 2 +- include/search.h | 2 +- include/spl.h | 14 +++--- include/stdio.h | 4 +- include/sunxi_gpio.h | 2 +- include/upl.h | 4 +- include/vbe.h | 2 +- lib/Makefile | 6 +-- lib/crypto/Makefile | 4 +- lib/display_options.c | 2 +- lib/fdtdec.c | 4 +- lib/hang.c | 2 +- lib/hashtable.c | 4 +- lib/hexdump.c | 2 +- lib/uuid.c | 2 +- net/bootp.c | 2 +- net/net.c | 8 ++-- scripts/Kbuild.include | 2 +- scripts/Makefile.xpl | 4 +- test/Makefile | 2 +- test/cmd_ut.c | 2 +- test/dm/Makefile | 2 +- test/lib/Makefile | 2 +- test/test-main.c | 2 +- tools/binman/test/generated/autoconf.h | 2 +- 791 files changed, 1391 insertions(+), 1391 deletions(-)
diff --git a/README b/README index 4be1e8c22a0..a88e14a0449 100644 --- a/README +++ b/README @@ -1508,13 +1508,13 @@ Low Level (hardware related) configuration options: This only takes effect if the memory commands are activated globally (CONFIG_CMD_MEMORY).
-- CONFIG_SPL_BUILD +- CONFIG_XPL_BUILD Set when the currently running compilation is for an artifact that will end up in one of the 'xPL' builds, i.e. SPL, TPL or VPL. Code that needs phase-specific behaviour can check this, or (where possible) use spl_phase() instead.
- Note that CONFIG_SPL_BUILD *is* always defined when either + Note that CONFIG_XPL_BUILD *is* always defined when either of CONFIG_TPL_BUILD / CONFIG_VPL_BUILD is defined. This can be counter-intuitive and should perhaps be changed.
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index dbeedbe544b..cb87a684754 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_ARCH_TEGRA),yy) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_ARCH_TEGRA),yy) CONFIG_CPU_V7A= CONFIG_CPU_ARM720T=y endif @@ -24,7 +24,7 @@ endif
# On Tegra systems we must build SPL for the armv4 core on the device # but otherwise we can use the value in CONFIG_SYS_ARM_ARCH -ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_ARCH_TEGRA),yy) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_ARCH_TEGRA),yy) arch-y += -D__LINUX_ARM_ARCH__=4 else arch-y += -D__LINUX_ARM_ARCH__=$(CONFIG_SYS_ARM_ARCH) @@ -106,7 +106,7 @@ libs-y += $(machdirs)
head-y := arch/arm/cpu/$(CPU)/start.o
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) ifeq ($(CONFIG_SYS_SOC)$(CONFIG_SPL_FRAMEWORK),"mxs") head-y := arch/arm/cpu/arm926ejs/mxs/start.o endif diff --git a/arch/arm/config.mk b/arch/arm/config.mk index 5530d02b66c..084fd399931 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -99,7 +99,7 @@ PLATFORM_CPPFLAGS += $(PF_CPPFLAGS_ARM) $(PF_CPPFLAGS_ABI) ifneq (,$(findstring -mabi=aapcs-linux,$(PLATFORM_CPPFLAGS))) # This file is parsed many times, so the string may get added multiple # times. Also, the prefix needs to be different based on whether -# CONFIG_SPL_BUILD is defined or not. 'filter-out' the existing entry +# CONFIG_XPL_BUILD is defined or not. 'filter-out' the existing entry # before adding the correct one. PLATFORM_LIBS := arch/arm/lib/eabi_compat.o \ $(filter-out arch/arm/lib/eabi_compat.o, $(PLATFORM_LIBS)) @@ -126,7 +126,7 @@ PLATFORM_RELFLAGS += -fno-optimize-sibling-calls endif endif
-ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) # Check that only R_ARM_RELATIVE relocations are generated. INPUTS-y += checkarmreloc # The movt / movw can hardcode 16 bit parts of the addresses in the @@ -160,7 +160,7 @@ endif ifdef CONFIG_MACH_IMX ifneq ($(CONFIG_IMX_CONFIG),"") ifdef CONFIG_SPL -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD INPUTS-y += SPL endif else diff --git a/arch/arm/cpu/arm11/Makefile b/arch/arm/cpu/arm11/Makefile index 5dfa01ae8d0..38a3e4d95e2 100644 --- a/arch/arm/cpu/arm11/Makefile +++ b/arch/arm/cpu/arm11/Makefile @@ -5,6 +5,6 @@
obj-y = cpu.o
-ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_EFI_LOADER) += sctlr.o endif diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 78a9cc173a3..d3ab5928eee 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -65,7 +65,7 @@ cpu_init_crit: * When booting from NAND - it has definitely been a reset, so, no need * to flush caches and disable the MMU */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * flush v4 I/D caches */ diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index 8cfe3f0fbbc..75513889c5d 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -6,7 +6,7 @@ extra-y = start.o obj-y = cpu.o cache.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifdef CONFIG_SPL_NO_CPU_SUPPORT extra-y := endif diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile index 1638ef8fd8d..f633e54ba62 100644 --- a/arch/arm/cpu/arm926ejs/mxs/Makefile +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -3,11 +3,11 @@ # (C) Copyright 2000-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-extra-$(CONFIG_SPL_BUILD) := start.o +extra-$(CONFIG_XPL_BUILD) := start.o
obj-y = clock.o mxs.o iomux.o timer.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o endif
diff --git a/arch/arm/cpu/arm926ejs/sunxi/config.mk b/arch/arm/cpu/arm926ejs/sunxi/config.mk index 76ffec9df6a..50899d20316 100644 --- a/arch/arm/cpu/arm926ejs/sunxi/config.mk +++ b/arch/arm/cpu/arm926ejs/sunxi/config.mk @@ -1,6 +1,6 @@ # Build a combined spl + u-boot image ifdef CONFIG_SPL -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD ALL-y += u-boot-sunxi-with-spl.bin endif endif diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 99cf9eb515f..0e7d769bd40 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -12,7 +12,7 @@ obj-y += syslib.o
obj-$(CONFIG_SYS_ARM_MPU) += mpu_v7r.o
-ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_EFI_LOADER) += sctlr.o obj-$(CONFIG_ARMV7_NONSEC) += exception_level.o endif diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index aa981faef00..8082f369ed6 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -32,7 +32,7 @@ int cleanup_before_linux_select(int flags) * * we turn off caches etc ... */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD disable_interrupts(); #endif
diff --git a/arch/arm/cpu/armv7/lowlevel_init.S b/arch/arm/cpu/armv7/lowlevel_init.S index 3c8c07fe016..a6c844b7e3d 100644 --- a/arch/arm/cpu/armv7/lowlevel_init.S +++ b/arch/arm/cpu/armv7/lowlevel_init.S @@ -26,7 +26,7 @@ WEAK(lowlevel_init) /* * Setup a temporary stack. Global data is not available yet. */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_STACK) ldr sp, =CONFIG_SPL_STACK #else ldr sp, =SYS_INIT_SP_ADDR @@ -39,7 +39,7 @@ WEAK(lowlevel_init) * Set up global data for boards that still need it. This will be * removed soon. */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD ldr r9, =gdata #else sub sp, sp, #GD_SIZE diff --git a/arch/arm/cpu/armv7/s5p-common/Makefile b/arch/arm/cpu/armv7/s5p-common/Makefile index 0985420fe5c..4660ff0057e 100644 --- a/arch/arm/cpu/armv7/s5p-common/Makefile +++ b/arch/arm/cpu/armv7/s5p-common/Makefile @@ -8,7 +8,7 @@ ifdef CONFIG_ARCH_NEXELL obj-$(CONFIG_S5P4418_ONEWIRE) += pwm.o else obj-y += cpu_info.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += timer.o obj-y += sromc.o endif diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 7730a16e512..b63481b43ca 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -279,7 +279,7 @@ ENTRY(cpu_init_cp15) orr r2, r4, r2 @ r2 has combined CPU variant + revision
/* Early stack for ERRATA that needs into call C code */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_STACK) ldr r0, =(CONFIG_SPL_STACK) #else ldr r0, =(SYS_INIT_SP_ADDR) diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 3e975b366c4..0624e93efde 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -12,10 +12,10 @@ obj-$(CONFIG_MACH_SUN8I_H3) += tzpc.o obj-$(CONFIG_MACH_SUN6I) += sram.o obj-$(CONFIG_MACH_SUN8I) += sram.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ARMV7_PSCI) += psci.o endif
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += fel_utils.o endif diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index bba4f570dbb..722ec89d239 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -13,7 +13,7 @@ ifndef CONFIG_$(SPL_)SYS_DCACHE_OFF obj-y += cache_v8.o obj-y += cache.o endif -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_ARMV8_SPL_EXCEPTION_VECTORS) += exceptions.o else obj-y += exceptions.o @@ -27,14 +27,14 @@ endif obj-y += cpu-dt.o obj-$(CONFIG_ARM_SMCCC) += smccc-call.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ARMV8_SPIN_TABLE) += spin_table.o spin_table_v8.o else obj-$(CONFIG_ARCH_SUNXI) += fel_utils.o endif obj-$(CONFIG_$(SPL_)ARMV8_SEC_FIRMWARE_SUPPORT) += sec_firmware.o sec_firmware_asm.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_RECOVER_DATA_SECTION) += spl_data.o endif
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 631d9efa5e1..e6be6359c5d 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -1016,7 +1016,7 @@ void mmu_change_region_attr(phys_addr_t addr, size_t siz, u64 attrs) * running however really wants to have dcache and the MMU active. Check that * everything is sane and give the developer a hint if it isn't. */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #error Please describe your MMU layout in CONFIG_SYS_MEM_MAP and enable dcache. #endif
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index eefdf12369c..e2033dc5aff 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -5,7 +5,7 @@ obj-y += cpu.o obj-y += lowlevel.o obj-y += soc.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_MP) += mp.o spintable.o obj-$(CONFIG_OF_LIBFDT) += fdt.o endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index d2dbfdd08a0..f9c2083677a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -122,7 +122,7 @@ static struct mm_region early_map[] = { { CFG_SYS_FSL_DRAM_BASE1, CFG_SYS_FSL_DRAM_BASE1, CFG_SYS_FSL_DRAM_SIZE1, #if defined(CONFIG_TFABOOT) || \ - (defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD)) + (defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD)) PTE_BLOCK_MEMTYPE(MT_NORMAL) | #else /* Start with nGnRnE and PXN and UXN to prevent speculative access */ PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_PXN | PTE_BLOCK_UXN | @@ -181,7 +181,7 @@ static struct mm_region early_map[] = { { CFG_SYS_FSL_DRAM_BASE1, CFG_SYS_FSL_DRAM_BASE1, CFG_SYS_FSL_DRAM_SIZE1, #if defined(CONFIG_TFABOOT) || \ - (defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD)) + (defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD)) PTE_BLOCK_MEMTYPE(MT_NORMAL) | #else /* Start with nGnRnE and PXN and UXN to prevent speculative access */ PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_PXN | PTE_BLOCK_UXN | @@ -1055,7 +1055,7 @@ int cpu_eth_init(struct bd_info *bis) { int error = 0;
-#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_XPL_BUILD) error = fsl_mc_ldpaa_init(bis); #endif return error; @@ -1285,7 +1285,7 @@ phys_size_t board_reserve_ram_top(phys_size_t ram_size) { phys_size_t ram_top = ram_size;
-#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_XPL_BUILD) ram_top = mc_get_dram_block_size(); if (ram_top > ram_size) return ram_size + ram_top; @@ -1381,7 +1381,7 @@ static int tfa_dram_init_banksize(void) if (i > 0) ret = 0;
-#if defined(CONFIG_RESV_RAM) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RESV_RAM) && !defined(CONFIG_XPL_BUILD) /* Assign memory for MC */ #ifdef CONFIG_SYS_DDR_BLOCK3_BASE if (gd->bd->bi_dram[2].size >= @@ -1467,7 +1467,7 @@ int dram_init_banksize(void) } #endif /* CFG_SYS_MEM_RESERVE_SECURE */
-#if defined(CONFIG_RESV_RAM) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RESV_RAM) && !defined(CONFIG_XPL_BUILD) /* Assign memory for MC */ #ifdef CONFIG_SYS_DDR_BLOCK3_BASE if (gd->bd->bi_dram[2].size >= @@ -1624,7 +1624,7 @@ __weak int dram_init(void) #ifdef CONFIG_SYS_FSL_DDR fsl_initdram(); #if (!defined(CONFIG_SPL) && !defined(CONFIG_TFABOOT)) || \ - defined(CONFIG_SPL_BUILD) + defined(CONFIG_XPL_BUILD) /* This will break-before-make MMU for DDR */ update_early_mmu_table(); #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 9a24d4b3031..1f03f5e2ecd 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -93,7 +93,7 @@ void get_sys_info(struct sys_info *sys_info)
#define HWA_CGA_M1_CLK_SEL 0xe0000000 #define HWA_CGA_M1_CLK_SHIFT 29 -#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_XPL_BUILD) rcw_tmp = in_be32(&gur->rcwsr[7]); switch ((rcw_tmp & HWA_CGA_M1_CLK_SEL) >> HWA_CGA_M1_CLK_SHIFT) { case 2: diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index b768790437f..b5213c780fb 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -25,7 +25,7 @@ static u8 serdes2_prtcl_map[SERDES_PRCTL_COUNT]; static u8 serdes3_prtcl_map[SERDES_PRCTL_COUNT]; #endif
-#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_XPL_BUILD) #if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) int xfi_dpmac[XFI14 + 1]; int sgmii_dpmac[SGMII18 + 1]; @@ -162,7 +162,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask, debug("Unknown SerDes lane protocol %d\n", lane_prtcl); else { serdes_prtcl_map[lane_prtcl] = 1; -#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_XPL_BUILD) #if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) if (lane_prtcl >= XFI1 && lane_prtcl <= XFI14) wriop_init_dpmac(sd, xfi_dpmac[lane_prtcl], @@ -553,7 +553,7 @@ int setup_serdes_volt(u32 svdd)
void fsl_serdes_init(void) { -#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_XPL_BUILD) int i , j;
#if defined(CONFIG_ARCH_LX2160A) || defined(CONFIG_ARCH_LX2162A) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/icid.c b/arch/arm/cpu/armv8/fsl-layerscape/icid.c index 04ffefafbf7..aa0af077d2f 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/icid.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/icid.c @@ -23,7 +23,7 @@ static void set_icid(struct icid_id_table *tbl, int size) out_be32((u32 *)(tbl[i].reg_addr), tbl[i].reg); }
-#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_XPL_BUILD) static void set_fman_icids(struct fman_icid_id_table *tbl, int size) { int i; @@ -41,12 +41,12 @@ void set_icids(void) /* setup general icid offsets */ set_icid(icid_tbl, icid_tbl_sz);
-#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_XPL_BUILD) set_fman_icids(fman_icid_tbl, fman_icid_tbl_sz); #endif }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids) { int i, ret; diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 4358c6ed11c..75c204e8309 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -183,7 +183,7 @@ ENTRY(lowlevel_init) #endif
/* Initialize GIC Secure Bank Status */ -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) #if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) branch_if_slave x0, 1f bl get_gic_offset @@ -306,7 +306,7 @@ ENTRY(lowlevel_init) #endif
#if !defined(CONFIG_TFABOOT) && \ - (defined(CONFIG_FSL_LSCH2) && !defined(CONFIG_SPL_BUILD)) + (defined(CONFIG_FSL_LSCH2) && !defined(CONFIG_XPL_BUILD)) bl fsl_ocram_init #endif
@@ -314,7 +314,7 @@ ENTRY(lowlevel_init) ret ENDPROC(lowlevel_init)
-#if defined(CONFIG_FSL_LSCH2) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_LSCH2) && !defined(CONFIG_XPL_BUILD) ENTRY(fsl_ocram_init) mov x28, lr /* Save LR */ bl fsl_clear_ocram diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c index ec80e42055d..48b95627bae 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c @@ -60,7 +60,7 @@ struct icid_id_table icid_tbl[] = {
int icid_tbl_sz = ARRAY_SIZE(icid_tbl);
-#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_XPL_BUILD) struct fman_icid_id_table fman_icid_tbl[] = { /* port id, icid */ SET_FMAN_ICID_ENTRY(0x02, FSL_DPAA1_STREAM_ID_END), diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c index a73dd316f8d..ab175b60c6c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -59,7 +59,7 @@ struct icid_id_table icid_tbl[] = {
-#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SYS_DPAA_FMAN) && !defined(CONFIG_XPL_BUILD) struct fman_icid_id_table fman_icid_tbl[] = { /* port id, icid */ SET_FMAN_ICID_ENTRY(0x02, FSL_DPAA1_STREAM_ID_END), diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index a739ff2da58..1f1e3d4a97b 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -41,7 +41,7 @@ u32 spl_boot_device(void) return 0; }
void spl_board_init(void) { @@ -136,4 +136,4 @@ int spl_start_uboot(void) return 1; } #endif /* CONFIG_SPL_OS_BOOT */ -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 74612802617..4a3b9f60e46 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -58,7 +58,7 @@ reset: .globl save_boot_params_ret save_boot_params_ret:
-#if CONFIG_POSITION_INDEPENDENT && !defined(CONFIG_SPL_BUILD) +#if CONFIG_POSITION_INDEPENDENT && !defined(CONFIG_XPL_BUILD) /* Verify that we're 4K aligned. */ adr x0, _start ands x0, x0, #0xfff @@ -104,7 +104,7 @@ pie_skip_reloc: pie_fixup_done: #endif
-#if defined(CONFIG_ARMV8_SPL_EXCEPTION_VECTORS) || !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_ARMV8_SPL_EXCEPTION_VECTORS) || !defined(CONFIG_XPL_BUILD) .macro set_vbar, regname, reg msr \regname, \reg .endm @@ -174,7 +174,7 @@ pie_fixup_done: /* Processor specific initialization */ bl lowlevel_init
-#if defined(CONFIG_ARMV8_SPIN_TABLE) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_ARMV8_SPIN_TABLE) && !defined(CONFIG_XPL_BUILD) branch_if_master x0, master_cpu b spin_table_secondary_jump /* never return */ @@ -354,7 +354,7 @@ ENDPROC(smp_kick_all_cpus) /*-----------------------------------------------------------------------*/
ENTRY(c_runtime_cpu_setup) -#if defined(CONFIG_ARMV8_SPL_EXCEPTION_VECTORS) || !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_ARMV8_SPL_EXCEPTION_VECTORS) || !defined(CONFIG_XPL_BUILD) /* Relocate vBAR */ adr x0, vectors switch_el x1, 3f, 2f, 1f diff --git a/arch/arm/dts/imx8qm-u-boot.dtsi b/arch/arm/dts/imx8qm-u-boot.dtsi index d316e869516..af229501a4d 100644 --- a/arch/arm/dts/imx8qm-u-boot.dtsi +++ b/arch/arm/dts/imx8qm-u-boot.dtsi @@ -10,7 +10,7 @@ };
&binman { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD u-boot-spl-ddr { align = <4>; align-size = <4>; diff --git a/arch/arm/dts/imx8qxp-u-boot.dtsi b/arch/arm/dts/imx8qxp-u-boot.dtsi index 7622c40906f..62791c34c77 100644 --- a/arch/arm/dts/imx8qxp-u-boot.dtsi +++ b/arch/arm/dts/imx8qxp-u-boot.dtsi @@ -10,7 +10,7 @@ };
&binman { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD u-boot-spl-ddr { align = <4>; align-size = <4>; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index d5f63f4a7ed..22671d4bbfd 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -12,13 +12,13 @@ #include <asm/armv8/sec_firmware.h>
struct icid_id_table { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD const char *compat; phys_addr_t compat_addr; #endif phys_addr_t reg_addr; u32 reg; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD u32 id; #endif bool le; @@ -35,7 +35,7 @@ int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids); void set_icids(void); void fdt_fixup_icid(void *blob);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define SET_ICID_ENTRY(name, idA, regA, addr, compataddr, _le) \ { .reg = regA, \ .reg_addr = addr, \ diff --git a/arch/arm/include/asm/arch-imx8/boot0.h b/arch/arm/include/asm/arch-imx8/boot0.h index 5ce781adb75..fc580b20a46 100644 --- a/arch/arm/include/asm/arch-imx8/boot0.h +++ b/arch/arm/include/asm/arch-imx8/boot0.h @@ -3,7 +3,7 @@ * Copyright 2019 NXP */
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) /* * We use absolute address not PC relative address to jump. * When running SPL on iMX8, the A core starts at address 0, a alias to OCRAM 0x100000, diff --git a/arch/arm/include/asm/arch-lpc32xx/sys_proto.h b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h index 4675dc3c533..b499d975526 100644 --- a/arch/arm/include/asm/arch-lpc32xx/sys_proto.h +++ b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h @@ -16,7 +16,7 @@ void lpc32xx_slc_nand_init(void); void lpc32xx_i2c_init(unsigned int devnum); void lpc32xx_ssp_init(void); void lpc32xx_usb_init(void); -#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) void ddr_init(const struct emc_dram_settings *dram); #endif #endif /* _LPC32XX_SYS_PROTO_H */ diff --git a/arch/arm/include/asm/arch-mx6/litesom.h b/arch/arm/include/asm/arch-mx6/litesom.h index 37a16d2c309..642ed22bffc 100644 --- a/arch/arm/include/asm/arch-mx6/litesom.h +++ b/arch/arm/include/asm/arch-mx6/litesom.h @@ -8,7 +8,7 @@
int litesom_mmc_init(struct bd_info *bis);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void litesom_init_f(void); #endif
diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index dbc97b25df8..ad9c1ac906a 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -5,7 +5,7 @@ #ifndef __ASM_ARCH_MX6_DDR_H__ #define __ASM_ARCH_MX6_DDR_H__
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #ifdef CONFIG_MX6Q #include "mx6q-ddr.h" #else @@ -488,7 +488,7 @@ void mx6_dram_cfg(const struct mx6_ddr_sysinfo *, const struct mx6_mmdc_calibration *, const void *);
#define MX6_MMDC_P0_MDCTL 0x021b0000 #define MX6_MMDC_P0_MDPDC 0x021b0004 diff --git a/arch/arm/include/asm/arch-mxs/sys_proto.h b/arch/arm/include/asm/arch-mxs/sys_proto.h index 17afd1b29e4..f8a56495acd 100644 --- a/arch/arm/include/asm/arch-mxs/sys_proto.h +++ b/arch/arm/include/asm/arch-mxs/sys_proto.h @@ -14,7 +14,7 @@ int mxsmmc_initialize(struct bd_info *bis, int id, int (*wp)(int), int (*cd)(int));
#if defined(CONFIG_MX23) #include <asm/arch/iomux-mx23.h> diff --git a/arch/arm/include/asm/arch-rk3066/boot0.h b/arch/arm/include/asm/arch-rk3066/boot0.h index 6bf3828c84e..eaf81554f5b 100644 --- a/arch/arm/include/asm/arch-rk3066/boot0.h +++ b/arch/arm/include/asm/arch-rk3066/boot0.h @@ -10,7 +10,7 @@ * (containing the magic 'RK30'). This magic constant will be written into * the final image by the rkimage tool, but we need to reserve space for it here. */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD b 1f /* if overwritten, entry-address is at the next word */ 1: #endif @@ -68,7 +68,7 @@ back_to_bootrom: pop {r1-r12, pc} #endif
-#if (defined(CONFIG_SPL_BUILD)) +#if (defined(CONFIG_XPL_BUILD)) /* U-Boot proper of armv7 does not need this */ b reset #endif diff --git a/arch/arm/include/asm/arch-rockchip/boot0.h b/arch/arm/include/asm/arch-rockchip/boot0.h index 0c375e543a5..edb2a31c348 100644 --- a/arch/arm/include/asm/arch-rockchip/boot0.h +++ b/arch/arm/include/asm/arch-rockchip/boot0.h @@ -12,7 +12,7 @@ * To make life easier for everyone, we build the SPL binary with * space for this 4-byte header already included in the binary. */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * We need to add 4 bytes of space for the 'RK33' at the * beginning of the executable. However, as we want to keep @@ -39,7 +39,7 @@ entry_counter: .word 0 #endif
-#if (defined(CONFIG_SPL_BUILD) || defined(CONFIG_ARM64)) +#if (defined(CONFIG_XPL_BUILD) || defined(CONFIG_ARM64)) /* U-Boot proper of armv7 do not need this */ b reset #endif @@ -54,7 +54,7 @@ _start: ARM_VECTORS #endif
-#if !defined(CONFIG_TPL_BUILD) && defined(CONFIG_SPL_BUILD) && \ +#if !defined(CONFIG_TPL_BUILD) && defined(CONFIG_XPL_BUILD) && \ (CONFIG_ROCKCHIP_SPL_RESERVE_IRAM > 0) .space CONFIG_ROCKCHIP_SPL_RESERVE_IRAM /* space for the ATF data */ #endif diff --git a/arch/arm/include/asm/arch-rockchip/cru_rv1126.h b/arch/arm/include/asm/arch-rockchip/cru_rv1126.h index 49a1f763795..ae273de3144 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rv1126.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rv1126.h @@ -11,7 +11,7 @@ #define KHz 1000 #define OSC_HZ (24 * MHz)
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) #define APLL_HZ (1008 * MHz) #else #define APLL_HZ (816 * MHz) @@ -20,7 +20,7 @@ #define CPLL_HZ (500 * MHz) #define HPLL_HZ (1400 * MHz) #define PCLK_PDPMU_HZ (100 * MHz) -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) #define ACLK_PDBUS_HZ (396 * MHz) #else #define ACLK_PDBUS_HZ (500 * MHz) @@ -32,7 +32,7 @@ #define HCLK_PDCORE_HZ (200 * MHz) #define HCLK_PDAUDIO_HZ (150 * MHz) #define CLK_OSC0_DIV_HZ (32768) -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) #define ACLK_PDVI_HZ (297 * MHz) #define CLK_ISP_HZ (297 * MHz) #define ACLK_PDISPP_HZ (297 * MHz) @@ -324,7 +324,7 @@ enum { DCLK_VOP_DIV_SHIFT = 0, DCLK_VOP_DIV_MASK = 0xff,
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) /* CRU_CLK_SEL49_CON */ ACLK_PDVI_SEL_SHIFT = 6, ACLK_PDVI_SEL_MASK = 0x3 << ACLK_PDVI_SEL_SHIFT, @@ -397,7 +397,7 @@ enum { CLK_GMAC_SRC_DIV_SHIFT = 0, CLK_GMAC_SRC_DIV_MASK = 0x1f << CLK_GMAC_SRC_DIV_SHIFT,
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) /* CRU_CLK_SEL68_CON */ ACLK_PDISPP_SEL_SHIFT = 6, ACLK_PDISPP_SEL_MASK = 0x3 << ACLK_PDISPP_SEL_SHIFT, diff --git a/arch/arm/include/asm/arch-sunxi/boot0.h b/arch/arm/include/asm/arch-sunxi/boot0.h index cad25c50bc6..6b2bb5a4586 100644 --- a/arch/arm/include/asm/arch-sunxi/boot0.h +++ b/arch/arm/include/asm/arch-sunxi/boot0.h @@ -5,7 +5,7 @@
#include <asm/arch/cpu.h>
-#if defined(CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER) && !defined(CONFIG_XPL_BUILD) /* reserve space for BOOT0 header information */ b reset .space 1532 @@ -49,7 +49,7 @@ .word CONFIG_SUNXI_RVBAR_ADDRESS // writable RVBAR mapping addr .word SUNXI_SRAMC_BASE .word CONFIG_SUNXI_RVBAR_ALTERNATIVE // address for die variant -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD .word CONFIG_SPL_TEXT_BASE #else .word CONFIG_TEXT_BASE diff --git a/arch/arm/include/asm/arch-sunxi/sys_proto.h b/arch/arm/include/asm/arch-sunxi/sys_proto.h index 064602292b6..92c7721a530 100644 --- a/arch/arm/include/asm/arch-sunxi/sys_proto.h +++ b/arch/arm/include/asm/arch-sunxi/sys_proto.h @@ -23,7 +23,7 @@ void sdelay(unsigned long); void return_to_fel(uint32_t lr, uint32_t sp);
/* Board / SoC level designware gmac init */ -#if !defined CONFIG_SPL_BUILD && defined CONFIG_SUN7I_GMAC +#if !defined CONFIG_XPL_BUILD && defined CONFIG_SUN7I_GMAC void eth_init_board(void); #else static inline void eth_init_board(void) {} diff --git a/arch/arm/include/asm/fsl_secure_boot.h b/arch/arm/include/asm/fsl_secure_boot.h index 15627c96e90..382a6d420a2 100644 --- a/arch/arm/include/asm/fsl_secure_boot.h +++ b/arch/arm/include/asm/fsl_secure_boot.h @@ -8,8 +8,8 @@ #define __FSL_SECURE_BOOT_H
#ifdef CONFIG_CHAIN_OF_TRUST -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD
-#endif /* #ifndef CONFIG_SPL_BUILD */ +#endif /* #ifndef CONFIG_XPL_BUILD */ #endif /* #ifdef CONFIG_CHAIN_OF_TRUST */ #endif diff --git a/arch/arm/include/asm/ti-common/sys_proto.h b/arch/arm/include/asm/ti-common/sys_proto.h index a96a8382fb6..514086a1bc4 100644 --- a/arch/arm/include/asm/ti-common/sys_proto.h +++ b/arch/arm/include/asm/ti-common/sys_proto.h @@ -57,7 +57,7 @@ static inline u8 uboot_loaded_by_spl(void) */ static inline u32 omap_hw_init_context(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD return OMAP_INIT_CONTEXT_SPL; #else if (uboot_loaded_by_spl()) diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 67275fba616..e343e81cf32 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -21,7 +21,7 @@ else obj-y += setjmp.o endif
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD ifdef CONFIG_ARM64 obj-y += relocate_64.o else diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index a0311438b45..3e4906e273d 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -102,7 +102,7 @@ ENTRY(_main)
#if defined(CONFIG_TPL_BUILD) && defined(CONFIG_TPL_NEEDS_SEPARATE_STACK) ldr r0, =(CONFIG_TPL_STACK) -#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#elif defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_STACK) ldr r0, =(CONFIG_SPL_STACK) #else ldr r0, =(SYS_INIT_SP_ADDR) @@ -119,14 +119,14 @@ ENTRY(_main) bl debug_uart_init #endif
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_EARLY_BSS) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_EARLY_BSS) CLEAR_BSS #endif
mov r0, #0 bl board_init_f
-#if ! defined(CONFIG_SPL_BUILD) +#if ! defined(CONFIG_XPL_BUILD)
/* * Set up intermediate environment (new sp and gd) and call @@ -171,13 +171,13 @@ here:
bl c_runtime_cpu_setup /* we still call old routine here */ #endif -#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(FRAMEWORK) +#if !defined(CONFIG_XPL_BUILD) || CONFIG_IS_ENABLED(FRAMEWORK)
-#if !defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL_EARLY_BSS) +#if !defined(CONFIG_XPL_BUILD) || !defined(CONFIG_SPL_EARLY_BSS) CLEAR_BSS #endif
-# ifdef CONFIG_SPL_BUILD +# ifdef CONFIG_XPL_BUILD /* Use a DRAM stack for the rest of SPL, if requested */ bl spl_relocate_stack_gd cmp r0, #0 @@ -185,7 +185,7 @@ here: movne r9, r0 # endif
-#if ! defined(CONFIG_SPL_BUILD) +#if ! defined(CONFIG_XPL_BUILD) bl coloured_LED_init bl red_led_on #endif diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S index dcc924dd2f4..32401f544a7 100644 --- a/arch/arm/lib/crt0_64.S +++ b/arch/arm/lib/crt0_64.S @@ -71,7 +71,7 @@ ENTRY(_main) */ #if defined(CONFIG_TPL_BUILD) && defined(CONFIG_TPL_NEEDS_SEPARATE_STACK) ldr x0, =(CONFIG_TPL_STACK) -#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#elif defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_STACK) ldr x0, =(CONFIG_SPL_STACK) #elif defined(CONFIG_INIT_SP_RELATIVE) #if CONFIG_POSITION_INDEPENDENT @@ -99,7 +99,7 @@ ENTRY(_main) mov x0, #0 bl board_init_f
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) /* * Set up intermediate environment (new sp and gd) and call * relocate_code(addr_moni). Trick here is that we'll return @@ -139,9 +139,9 @@ relocation_return: * Set up final (full) environment */ bl c_runtime_cpu_setup /* still call old routine */ -#endif /* !CONFIG_SPL_BUILD */ -#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(FRAMEWORK) -#if defined(CONFIG_SPL_BUILD) +#endif /* !CONFIG_XPL_BUILD */ +#if !defined(CONFIG_XPL_BUILD) || CONFIG_IS_ENABLED(FRAMEWORK) +#if defined(CONFIG_XPL_BUILD) bl spl_relocate_stack_gd /* may return NULL */ /* set up gd here, outside any C code, if new stack is returned */ cmp x0, #0 diff --git a/arch/arm/lib/eabi_compat.c b/arch/arm/lib/eabi_compat.c index 0a96ba1355f..602efe04c04 100644 --- a/arch/arm/lib/eabi_compat.c +++ b/arch/arm/lib/eabi_compat.c @@ -12,7 +12,7 @@ int raise (int signum) { /* Even if printf() is available, it's large. Punt it for SPL builds */ -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) printf("raise: Signal # %d caught\n", signum); #endif return 0; diff --git a/arch/arm/lib/stack.c b/arch/arm/lib/stack.c index 2b21ec0734e..78507b76894 100644 --- a/arch/arm/lib/stack.c +++ b/arch/arm/lib/stack.c @@ -17,7 +17,7 @@ DECLARE_GLOBAL_DATA_PTR;
int arch_reserve_stacks(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD gd->start_addr_sp -= 128; /* leave 32 words for abort-stack */ gd->irq_sp = gd->start_addr_sp; #else diff --git a/arch/arm/lib/vectors.S b/arch/arm/lib/vectors.S index b6b879339df..cf3f6c3e65c 100644 --- a/arch/arm/lib/vectors.S +++ b/arch/arm/lib/vectors.S @@ -133,7 +133,7 @@ _fiq: .word fiq
/* SPL interrupt handling: just hang */
#if !CONFIG_IS_ENABLED(SYS_NO_VECTOR_TABLE) .align 5 @@ -166,7 +166,7 @@ fiq: b 1b /* hang and never return */ #endif
-#else /* !CONFIG_SPL_BUILD */ +#else /* !CONFIG_XPL_BUILD */
/* IRQ stack memory (calculated at run-time) + 8 bytes */ .globl IRQ_STACK_START_IN @@ -332,4 +332,4 @@ fiq: bad_save_user_regs bl do_fiq
-#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/arch/arm/lib/zimage.c b/arch/arm/lib/zimage.c index 51287251b3f..7e1cd4dd8bc 100644 --- a/arch/arm/lib/zimage.c +++ b/arch/arm/lib/zimage.c @@ -24,14 +24,14 @@ int bootz_setup(ulong image, ulong *start, ulong *end)
if (zi->zi_magic != LINUX_ARM_ZIMAGE_MAGIC && zi->zi_magic != BAREBOX_IMAGE_MAGIC) { - if (!IS_ENABLED(CONFIG_SPL_BUILD)) + if (!IS_ENABLED(CONFIG_XPL_BUILD)) puts("zimage: Bad magic!\n"); return 1; }
*start = zi->zi_start; *end = zi->zi_end; - if (!IS_ENABLED(CONFIG_SPL_BUILD)) + if (!IS_ENABLED(CONFIG_XPL_BUILD)) printf("Kernel image @ %#08lx [ %#08lx - %#08lx ]\n", image, *start, *end);
diff --git a/arch/arm/mach-aspeed/ast2600/Makefile b/arch/arm/mach-aspeed/ast2600/Makefile index 448d3201aff..18f9f75e8ef 100644 --- a/arch/arm/mach-aspeed/ast2600/Makefile +++ b/arch/arm/mach-aspeed/ast2600/Makefile @@ -1,2 +1,2 @@ obj-y += lowlevel_init.o board_common.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/arch/arm/mach-aspeed/ast2600/lowlevel_init.S b/arch/arm/mach-aspeed/ast2600/lowlevel_init.S index 594963d039d..d1c31068685 100644 --- a/arch/arm/mach-aspeed/ast2600/lowlevel_init.S +++ b/arch/arm/mach-aspeed/ast2600/lowlevel_init.S @@ -97,7 +97,7 @@ .globl lowlevel_init
lowlevel_init: -#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD) mov pc, lr #else /* setup ARM arch timer frequency */ diff --git a/arch/arm/mach-at91/Makefile b/arch/arm/mach-at91/Makefile index cbd0ed68c27..447cd80642c 100644 --- a/arch/arm/mach-at91/Makefile +++ b/arch/arm/mach-at91/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_AT91_WANTS_COMMON_PHY) += phy.o -ifneq ($(CONFIG_SPL_BUILD),) +ifneq ($(CONFIG_XPL_BUILD),) obj-$(CONFIG_AT91SAM9260) += sdram.o spl_at91.o obj-$(CONFIG_AT91SAM9G20) += sdram.o spl_at91.o obj-$(CONFIG_AT91SAM9M10G45) += mpddrc.o spl_at91.o diff --git a/arch/arm/mach-at91/config.mk b/arch/arm/mach-at91/config.mk index 5426394651e..a31612b8179 100644 --- a/arch/arm/mach-at91/config.mk +++ b/arch/arm/mach-at91/config.mk @@ -3,7 +3,7 @@ PLATFORM_CPPFLAGS += $(call cc-option,-mtune=arm926ejs,) endif
ifeq ($(CONFIG_CPU_V7A),y) -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD INPUTS-y += u-boot.img endif endif diff --git a/arch/arm/mach-davinci/Makefile b/arch/arm/mach-davinci/Makefile index ae171e3ee22..c994f97bab8 100644 --- a/arch/arm/mach-davinci/Makefile +++ b/arch/arm/mach-davinci/Makefile @@ -9,7 +9,7 @@ obj-y += cpu.o misc.o timer.o psc.o pinmux.o reset.o obj-$(CONFIG_DA850_LOWLEVEL) += da850_lowlevel.o obj-$(CONFIG_SOC_DA850) += da850_pinmux.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_FRAMEWORK) += spl.o obj-$(CONFIG_SOC_DA8XX) += da850_lowlevel.o endif diff --git a/arch/arm/mach-davinci/config.mk b/arch/arm/mach-davinci/config.mk index edbac8e8e21..3b972a26c0c 100644 --- a/arch/arm/mach-davinci/config.mk +++ b/arch/arm/mach-davinci/config.mk @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (C) 2012, Texas Instruments, Incorporated - https://www.ti.com/ -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD INPUTS-$(CONFIG_SPL_FRAMEWORK) += u-boot.ais endif diff --git a/arch/arm/mach-davinci/misc.c b/arch/arm/mach-davinci/misc.c index 6c97e5810cd..07125eac7cd 100644 --- a/arch/arm/mach-davinci/misc.c +++ b/arch/arm/mach-davinci/misc.c @@ -21,7 +21,7 @@
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ diff --git a/arch/arm/mach-exynos/Makefile b/arch/arm/mach-exynos/Makefile index dd097cf5418..ebdc3b89d05 100644 --- a/arch/arm/mach-exynos/Makefile +++ b/arch/arm/mach-exynos/Makefile @@ -9,7 +9,7 @@ obj-$(CONFIG_ARM64) += mmu-arm64.o
obj-$(CONFIG_EXYNOS5420) += sec_boot.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_ARCH_EXYNOS5) += clock_init_exynos5.o obj-$(CONFIG_ARCH_EXYNOS5) += dmc_common.o dmc_init_ddr3.o obj-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o diff --git a/arch/arm/mach-exynos/lowlevel_init.c b/arch/arm/mach-exynos/lowlevel_init.c index 0967ab995a9..0c50b2e2b99 100644 --- a/arch/arm/mach-exynos/lowlevel_init.c +++ b/arch/arm/mach-exynos/lowlevel_init.c @@ -221,8 +221,8 @@ int do_lowlevel_init(void) if (actions & DO_CLOCKS) { system_clock_init(); #ifdef CONFIG_DEBUG_UART -#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL)) || \ - !defined(CONFIG_SPL_BUILD) +#if (defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_SERIAL)) || \ + !defined(CONFIG_XPL_BUILD) exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); debug_uart_init(); #endif diff --git a/arch/arm/mach-exynos/pinmux.c b/arch/arm/mach-exynos/pinmux.c index 07d19fd17ba..48c325190d5 100644 --- a/arch/arm/mach-exynos/pinmux.c +++ b/arch/arm/mach-exynos/pinmux.c @@ -171,7 +171,7 @@ static int exynos5420_mmc_config(int peripheral, int flags) * this same assumption. */ if ((peripheral == PERIPH_ID_SDMMC0) && (i == (start + 2))) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD gpio_request(i, "sdmmc0_vdden"); #endif gpio_set_value(i, 1); diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index f8903afc92e..af62a39a671 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -10,7 +10,7 @@ obj-y = iomux-v3.o endif
ifeq ($(SOC),$(filter $(SOC),imx8m)) -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_IMX_BOOTAUX) += imx_bootaux.o endif obj-$(CONFIG_ENV_IS_IN_MMC) += mmc_env.o @@ -22,7 +22,7 @@ obj-y += cpu.o endif
ifeq ($(SOC),$(filter $(SOC),imx8m imx9)) -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-y += fdt.o endif endif @@ -38,7 +38,7 @@ endif ifeq ($(SOC),$(filter $(SOC),mx7 mx6 mxs imx8m imx8 imx9 imxrt)) obj-y += misc.o obj-$(CONFIG_CMD_PRIBLOB) += priblob.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o endif ifeq ($(SOC),$(filter $(SOC),mx7)) obj-y += cpu.o @@ -46,7 +46,7 @@ obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o obj-$(CONFIG_ENV_IS_IN_MMC) += mmc_env.o endif ifeq ($(SOC),$(filter $(SOC),mx7 imx8m)) -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_FSL_MFGPROT) += cmd_mfgprot.o endif endif @@ -57,7 +57,7 @@ ifeq ($(SOC),$(filter $(SOC),mx6 mx7)) obj-y += cache.o init.o obj-$(CONFIG_FEC_MXC) += mac.o obj-$(CONFIG_IMX_RDC) += rdc-sema.o -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_IMX_BOOTAUX) += imx_bootaux.o endif obj-$(CONFIG_$(SPL_)SATA) += sata.o @@ -73,18 +73,18 @@ obj-y += ddrmc-vf610.o obj-$(CONFIG_DDRMC_VF610_CALIBRATION) += ddrmc-vf610-calibration.o endif ifeq ($(SOC),$(filter $(SOC),imx8)) -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_IMX_BOOTAUX) += imx_bootaux.o endif endif -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_CMD_BMODE) += cmd_bmode.o obj-$(CONFIG_CMD_HDMIDETECT) += cmd_hdmidet.o obj-$(CONFIG_CMD_DEKBLOB) += cmd_dek.o obj-$(CONFIG_CMD_NANDBCB) += cmd_nandbcb.o endif
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_SPL_LOAD_IMX_CONTAINER) += image-container.o endif
@@ -128,7 +128,7 @@ container.cfg: $(IMX_CONTAINER_CFG) FORCE ifeq ($(CONFIG_ARCH_IMX8), y) CNTR_DEPFILES := $(srctree)/tools/imx_cntr_image.sh IMAGE_TYPE := imx8image -ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) SPL_DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o spl/u-boot-spl.cfgout $(srctree)/$(IMX_CONFIG); if [ -f spl/u-boot-spl.cfgout ]; then $(CNTR_DEPFILES) spl/u-boot-spl.cfgout; echo $$?; fi) endif DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o u-boot-dtb.cfgout $(srctree)/$(IMX_CONFIG); if [ -f u-boot-dtb.cfgout ]; then $(CNTR_DEPFILES) u-boot-dtb.cfgout; echo $$?; fi) diff --git a/arch/arm/mach-imx/cpu.c b/arch/arm/mach-imx/cpu.c index ceee31eecd7..17de9ff98ec 100644 --- a/arch/arm/mach-imx/cpu.c +++ b/arch/arm/mach-imx/cpu.c @@ -39,7 +39,7 @@ u32 get_imx_reset_cause(void) if (reset_cause == -1) { reset_cause = readl(&src_regs->srsr); /* preserve the value for U-Boot proper */ -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) writel(reset_cause, &src_regs->srsr); #endif } @@ -47,7 +47,7 @@ u32 get_imx_reset_cause(void) return reset_cause; }
-#if defined(CONFIG_DISPLAY_CPUINFO) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_DISPLAY_CPUINFO) && !defined(CONFIG_XPL_BUILD) static char *get_reset_cause(void) { switch (get_imx_reset_cause()) { @@ -92,7 +92,7 @@ static char *get_reset_cause(void) } #endif
const char *get_imx_type(u32 imxtype) { diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 85d90686f68..a8107f46ae5 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -245,7 +245,7 @@ void *hab_rvt_authenticate_image(uint8_t cid, ptrdiff_t ivt_offset, return ret; }
#define MAX_RECORD_BYTES (8*1024) /* 4 kbytes */
@@ -727,7 +727,7 @@ U_BOOT_CMD( "" );
-#endif /* !defined(CONFIG_SPL_BUILD) */ +#endif /* !defined(CONFIG_XPL_BUILD) */
/* Get CSF Header length */ static int get_hab_hdr_len(struct hab_hdr *hdr) @@ -939,7 +939,7 @@ int imx_hab_authenticate_image(uint32_t ddr_start, uint32_t image_size, puts("Dumping CSF Header\n"); print_buffer(ivt->csf, (void *)(uintptr_t)(ivt->csf), 4, 0x10, 0);
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) get_hab_status(); #endif
@@ -989,7 +989,7 @@ int imx_hab_authenticate_image(uint32_t ddr_start, uint32_t image_size, }
hab_exit_failure_print_status: -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) get_hab_status(); #endif
diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach-imx/imx8/cpu.c index 834aca82bcf..2ff4ff35e49 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -89,11 +89,11 @@ __weak void reset_cpu(void)
int arch_cpu_init(void) { -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RECOVER_DATA_SECTION) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_RECOVER_DATA_SECTION) spl_save_restore_data(); #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD struct pass_over_info_t *pass_over;
if (is_soc_rev(CHIP_REV_A)) { diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mm.c b/arch/arm/mach-imx/imx8m/clock_imx8mm.c index d7fd102c955..d5745f67262 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mm.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mm.c @@ -51,7 +51,7 @@ int enable_i2c_clk(unsigned char enable, unsigned i2c_num) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static struct imx_int_pll_rate_table imx8mm_fracpll_tbl[] = { PLL_1443X_RATE(1000000000U, 250, 3, 1, 0), PLL_1443X_RATE(933000000U, 311, 4, 1, 0), diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mq.c b/arch/arm/mach-imx/imx8m/clock_imx8mq.c index 43e677deae2..2f53430b4d0 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mq.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mq.c @@ -611,7 +611,7 @@ void dram_disable_bypass(void) CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV5)); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void dram_pll_init(ulong pll_val) { u32 val; @@ -791,7 +791,7 @@ int clock_init(void) /* * Dump some clockes. */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int do_imx8m_showclocks(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 46974bf0618..b0ab00fbd98 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -45,7 +45,7 @@ struct imx_sec_config_fuse_t const imx_sec_config_fuse = {
int timer_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD struct sctr_regs *sctr = (struct sctr_regs *)SYSCNT_CTRL_BASE_ADDR; unsigned long freq = readl(&sctr->cntfid0);
@@ -255,7 +255,7 @@ int dram_init(void) return ret;
/* rom_pointer[1] contains the size of TEE occupies */ - if (!IS_ENABLED(CONFIG_ARMV8_PSCI) && !IS_ENABLED(CONFIG_SPL_BUILD) && rom_pointer[1]) + if (!IS_ENABLED(CONFIG_ARMV8_PSCI) && !IS_ENABLED(CONFIG_XPL_BUILD) && rom_pointer[1]) gd->ram_size = sdram_size - rom_pointer[1]; else gd->ram_size = sdram_size; @@ -284,7 +284,7 @@ int dram_init_banksize(void) }
gd->bd->bi_dram[bank].start = PHYS_SDRAM; - if (!IS_ENABLED(CONFIG_ARMV8_PSCI) && !IS_ENABLED(CONFIG_SPL_BUILD) && rom_pointer[1]) { + if (!IS_ENABLED(CONFIG_ARMV8_PSCI) && !IS_ENABLED(CONFIG_XPL_BUILD) && rom_pointer[1]) { phys_addr_t optee_start = (phys_addr_t)rom_pointer[0]; phys_size_t optee_size = (size_t)rom_pointer[1];
@@ -329,7 +329,7 @@ phys_size_t get_effective_memsize(void) sdram_b1_size = sdram_size; }
- if (!IS_ENABLED(CONFIG_ARMV8_PSCI) && !IS_ENABLED(CONFIG_SPL_BUILD) && + if (!IS_ENABLED(CONFIG_ARMV8_PSCI) && !IS_ENABLED(CONFIG_XPL_BUILD) && rom_pointer[1]) { /* We will relocate u-boot to Top of dram1. Tee position has two cases: * 1. At the top of dram1, Then return the size removed optee size. @@ -612,7 +612,7 @@ static void early_enable_caches(void) phys_size_t sdram_size; int entry, ret;
- if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return;
if (CONFIG_IS_ENABLED(SYS_ICACHE_OFF) || CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) @@ -646,7 +646,7 @@ int arch_cpu_init(void) * ROM might disable clock for SCTR, * enable the clock before timer_init. */ - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) clock_enable(CCGR_SCTR, 1); /* * Init timer at very early state, because sscg pll setting @@ -654,7 +654,7 @@ int arch_cpu_init(void) */ timer_init();
- if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { clock_init(); imx_set_wdog_powerdown(false);
@@ -1476,7 +1476,7 @@ int arch_misc_init(void) } #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #if defined(CONFIG_IMX8MQ) || defined(CONFIG_IMX8MM) || defined(CONFIG_IMX8MN) bool serror_need_skip = true;
diff --git a/arch/arm/mach-imx/imx8ulp/Makefile b/arch/arm/mach-imx/imx8ulp/Makefile index 2c9938fcdf0..b478dab59d0 100644 --- a/arch/arm/mach-imx/imx8ulp/Makefile +++ b/arch/arm/mach-imx/imx8ulp/Makefile @@ -6,6 +6,6 @@ obj-y += lowlevel_init.o obj-y += soc.o clock.o iomux.o pcc.o cgc.o rdc.o
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-y += upower/ endif diff --git a/arch/arm/mach-imx/imx8ulp/clock.c b/arch/arm/mach-imx/imx8ulp/clock.c index fadf165ece2..c390f20d769 100644 --- a/arch/arm/mach-imx/imx8ulp/clock.c +++ b/arch/arm/mach-imx/imx8ulp/clock.c @@ -519,7 +519,7 @@ u32 get_lpuart_clk(void) return pcc_clock_get_rate(lpuart_pcc[index], lpuart_pcc_slots[index]); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Dump some core clockes. */ diff --git a/arch/arm/mach-imx/imx8ulp/lowlevel_init.S b/arch/arm/mach-imx/imx8ulp/lowlevel_init.S index 791c26407c9..9ede695dbba 100644 --- a/arch/arm/mach-imx/imx8ulp/lowlevel_init.S +++ b/arch/arm/mach-imx/imx8ulp/lowlevel_init.S @@ -16,7 +16,7 @@ rom_pointer:
.global save_boot_params save_boot_params: -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* The firmware provided ATAG/FDT address can be found in r2/x0 */ adr x0, rom_pointer stp x1, x2, [x0], #16 diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index c3722c60836..b5dc45296d1 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -104,7 +104,7 @@ enum bt_mode get_boot_mode(void)
bool m33_image_booted(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { u32 gp6 = 0;
/* DGO_GP6 */ @@ -124,7 +124,7 @@ bool m33_image_booted(void)
bool rdc_enabled_in_boot(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { u32 val = 0; int ret; bool rdc_en = true; /* Default assume DBD_EN is set */ @@ -146,7 +146,7 @@ bool rdc_enabled_in_boot(void)
static void spl_pass_boot_info(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { bool m33_booted = m33_image_booted(); bool rdc_en = rdc_enabled_in_boot(); u32 val = 0; @@ -164,7 +164,7 @@ static void spl_pass_boot_info(void) bool is_m33_handshake_necessary(void) { /* Only need handshake in u-boot */ - if (!IS_ENABLED(CONFIG_SPL_BUILD)) + if (!IS_ENABLED(CONFIG_XPL_BUILD)) return (m33_image_booted() || rdc_enabled_in_boot()); else return false; @@ -716,7 +716,7 @@ void set_lpav_qos(void)
int arch_cpu_init(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { /* Enable System Reset Interrupt using WDOG_AD */ setbits_le32(CMC1_BASE_ADDR + 0x8C, BIT(13)); /* Clear AD_PERIPH Power switch domain out of reset interrupt flag */ @@ -805,7 +805,7 @@ int imx8ulp_dm_post_init(void) } EVENT_SPY_SIMPLE(EVT_DM_POST_INIT_F, imx8ulp_dm_post_init);
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { debug("image entry point: 0x%lx\n", spl_image->entry_point); diff --git a/arch/arm/mach-imx/imx9/Makefile b/arch/arm/mach-imx/imx9/Makefile index e1b09ab5341..45a9105a75a 100644 --- a/arch/arm/mach-imx/imx9/Makefile +++ b/arch/arm/mach-imx/imx9/Makefile @@ -5,6 +5,6 @@ obj-y += lowlevel_init.o obj-y += soc.o clock.o clock_root.o trdc.o
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD obj-y += imx_bootaux.o #endif diff --git a/arch/arm/mach-imx/imx9/clock.c b/arch/arm/mach-imx/imx9/clock.c index 12685f970de..dda57ed7f55 100644 --- a/arch/arm/mach-imx/imx9/clock.c +++ b/arch/arm/mach-imx/imx9/clock.c @@ -640,7 +640,7 @@ void enable_usboh3_clk(unsigned char enable) } }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void dram_pll_init(ulong pll_val) { configure_fracpll(DRAM_PLL_CLK, pll_val); @@ -950,7 +950,7 @@ int set_clk_enet(enum enet_freq type) /* * Dump some clockes. */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int do_showclocks(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) { u32 freq; diff --git a/arch/arm/mach-imx/imx9/lowlevel_init.S b/arch/arm/mach-imx/imx9/lowlevel_init.S index 1dc1dbfcddc..97d85911041 100644 --- a/arch/arm/mach-imx/imx9/lowlevel_init.S +++ b/arch/arm/mach-imx/imx9/lowlevel_init.S @@ -16,7 +16,7 @@ rom_pointer:
.global save_boot_params save_boot_params: -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* The firmware provided ATAG/FDT address can be found in r2/x0 */ adr x0, rom_pointer stp x1, x2, [x0], #16 diff --git a/arch/arm/mach-imx/imx9/soc.c b/arch/arm/mach-imx/imx9/soc.c index 04b21207a28..7c28fa39e14 100644 --- a/arch/arm/mach-imx/imx9/soc.c +++ b/arch/arm/mach-imx/imx9/soc.c @@ -383,7 +383,7 @@ int dram_init(void) return ret;
/* rom_pointer[1] contains the size of TEE occupies */ - if (!IS_ENABLED(CONFIG_SPL_BUILD) && rom_pointer[1]) + if (!IS_ENABLED(CONFIG_XPL_BUILD) && rom_pointer[1]) gd->ram_size = sdram_size - rom_pointer[1]; else gd->ram_size = sdram_size; @@ -412,7 +412,7 @@ int dram_init_banksize(void) }
gd->bd->bi_dram[bank].start = PHYS_SDRAM; - if (!IS_ENABLED(CONFIG_SPL_BUILD) && rom_pointer[1]) { + if (!IS_ENABLED(CONFIG_XPL_BUILD) && rom_pointer[1]) { phys_addr_t optee_start = (phys_addr_t)rom_pointer[0]; phys_size_t optee_size = (size_t)rom_pointer[1];
@@ -457,7 +457,7 @@ phys_size_t get_effective_memsize(void) else sdram_b1_size = sdram_size;
- if (!IS_ENABLED(CONFIG_SPL_BUILD) && rom_pointer[1]) { + if (!IS_ENABLED(CONFIG_XPL_BUILD) && rom_pointer[1]) { /* We will relocate u-boot to top of dram1. TEE position has two cases: * 1. At the top of dram1, Then return the size removed optee size. * 2. In the middle of dram1, return the size of dram1. @@ -629,7 +629,7 @@ static int low_drive_freq_update(void *blob) }
#ifdef CONFIG_OF_BOARD_FIXUP -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int board_fix_fdt(void *fdt) { /* Update dtb clocks for low drive mode */ @@ -701,7 +701,7 @@ static void save_reset_cause(void)
int arch_cpu_init(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { /* Disable wdog */ init_wdog();
@@ -745,7 +745,7 @@ EVENT_SPY_SIMPLE(EVT_DM_POST_INIT_R, imx9_probe_mu);
diff --git a/arch/arm/mach-imx/mx5/clock.c b/arch/arm/mach-imx/mx5/clock.c index 0b8a10fd729..41116e2c6a2 100644 --- a/arch/arm/mach-imx/mx5/clock.c +++ b/arch/arm/mach-imx/mx5/clock.c @@ -940,7 +940,7 @@ void mxc_set_sata_internal_clock(void) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Dump some core clockes. */ diff --git a/arch/arm/mach-imx/mx6/Makefile b/arch/arm/mach-imx/mx6/Makefile index 7ea8f91e4f0..da461b0be9b 100644 --- a/arch/arm/mach-imx/mx6/Makefile +++ b/arch/arm/mach-imx/mx6/Makefile @@ -7,7 +7,7 @@
obj-y := soc.o clock.o obj-$(CONFIG_IMX_MODULE_FUSE) += module_fuse.o -obj-$(CONFIG_SPL_BUILD) += ddr.o +obj-$(CONFIG_XPL_BUILD) += ddr.o obj-$(CONFIG_MP) += mp.o obj-$(CONFIG_MX6UL_LITESOM) += litesom.o obj-$(CONFIG_MX6UL_OPOS6UL) += opos6ul.o diff --git a/arch/arm/mach-imx/mx6/clock.c b/arch/arm/mach-imx/mx6/clock.c index fb9f56d2e63..b5aa606b8d0 100644 --- a/arch/arm/mach-imx/mx6/clock.c +++ b/arch/arm/mach-imx/mx6/clock.c @@ -1367,7 +1367,7 @@ void disable_ipu_clock(void) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Dump some core clockes. */ diff --git a/arch/arm/mach-imx/mx6/litesom.c b/arch/arm/mach-imx/mx6/litesom.c index 03e1214c060..c6bf933df94 100644 --- a/arch/arm/mach-imx/mx6/litesom.c +++ b/arch/arm/mach-imx/mx6/litesom.c @@ -78,7 +78,7 @@ int litesom_mmc_init(struct bd_info *bis) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <linux/libfdt.h> #include <spl.h> #include <asm/arch/mx6-ddr.h> diff --git a/arch/arm/mach-imx/mx6/opos6ul.c b/arch/arm/mach-imx/mx6/opos6ul.c index 340e6147b63..6a79dcb5bd1 100644 --- a/arch/arm/mach-imx/mx6/opos6ul.c +++ b/arch/arm/mach-imx/mx6/opos6ul.c @@ -79,7 +79,7 @@ int dram_init(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <asm/arch/mx6-ddr.h> #include <linux/libfdt.h> #include <spl.h> @@ -210,4 +210,4 @@ void board_init_f(ulong dummy) /* DDR initialization */ spl_dram_init(); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach-imx/mx6/soc.c index 2c0c77e1a56..9b40fe9235a 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -37,7 +37,7 @@ struct scu_regs { u32 fpga_rev; };
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_IMX_THERMAL) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_IMX_THERMAL) static const struct imx_thermal_plat imx6_thermal_plat = { .regs = (void *)ANATOP_BASE_ADDR, .fuse_bank = 1, @@ -565,7 +565,7 @@ int board_postclk_init(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * cfg_val will be used for * Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] @@ -600,7 +600,7 @@ const struct boot_mode soc_boot_modes[] = {
void reset_misc(void) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #if defined(CONFIG_VIDEO_MXS) && !defined(CONFIG_VIDEO) lcdif_power_down(); #endif diff --git a/arch/arm/mach-imx/mx7/clock.c b/arch/arm/mach-imx/mx7/clock.c index a8606fa9b24..a8328a0b224 100644 --- a/arch/arm/mach-imx/mx7/clock.c +++ b/arch/arm/mach-imx/mx7/clock.c @@ -1100,7 +1100,7 @@ void epdc_clock_disable(void) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Dump some core clockes. */ diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index 16c77cbf7be..1b891a2db3d 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -432,7 +432,7 @@ void s_init(void) return; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD const struct boot_mode soc_boot_modes[] = { {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, {"primary", MAKE_CFGVAL_PRIMARY_BOOT}, @@ -450,7 +450,7 @@ int boot_mode_getprisec(void)
void reset_misc(void) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #if defined(CONFIG_VIDEO_MXS) && !defined(CONFIG_VIDEO) lcdif_power_down(); #endif diff --git a/arch/arm/mach-imx/mx7ulp/clock.c b/arch/arm/mach-imx/mx7ulp/clock.c index fb19c62a520..eca92955a17 100644 --- a/arch/arm/mach-imx/mx7ulp/clock.c +++ b/arch/arm/mach-imx/mx7ulp/clock.c @@ -327,7 +327,7 @@ void hab_caam_clock_enable(unsigned char enable) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Dump some core clockes. */ diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index 198ae2d919c..980e0226156 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -171,7 +171,7 @@ static bool ldo_mode_is_enabled(void) return false; }
-#if !defined(CONFIG_SPL) || (defined(CONFIG_SPL) && defined(CONFIG_SPL_BUILD)) +#if !defined(CONFIG_SPL) || (defined(CONFIG_SPL) && defined(CONFIG_XPL_BUILD)) #if defined(CONFIG_LDO_ENABLED_MODE) static void init_ldo_mode(void) { diff --git a/arch/arm/mach-imx/syscounter.c b/arch/arm/mach-imx/syscounter.c index 922f851c56b..96fe2c7c17b 100644 --- a/arch/arm/mach-imx/syscounter.c +++ b/arch/arm/mach-imx/syscounter.c @@ -59,7 +59,7 @@ static inline unsigned long long us_to_tick(unsigned long long usec) return usec; }
-#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) || IS_ENABLED(CONFIG_SPL_BUILD) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) || IS_ENABLED(CONFIG_XPL_BUILD) int timer_init(void) { struct sctr_regs *sctr = (struct sctr_regs *)SCTR_BASE_ADDR; diff --git a/arch/arm/mach-k3/am62ax/Makefile b/arch/arm/mach-k3/am62ax/Makefile index 1717ca343d6..e2ef88196f8 100644 --- a/arch/arm/mach-k3/am62ax/Makefile +++ b/arch/arm/mach-k3/am62ax/Makefile @@ -4,4 +4,4 @@ # Andrew Davis afd@ti.com
obj-$(CONFIG_OF_SYSTEM_SETUP) += am62a7_fdt.o -obj-$(CONFIG_SPL_BUILD) += am62a7_init.o +obj-$(CONFIG_XPL_BUILD) += am62a7_init.o diff --git a/arch/arm/mach-k3/am62px/Makefile b/arch/arm/mach-k3/am62px/Makefile index eed91a033eb..3165435f265 100644 --- a/arch/arm/mach-k3/am62px/Makefile +++ b/arch/arm/mach-k3/am62px/Makefile @@ -4,4 +4,4 @@ # Andrew Davis afd@ti.com
obj-$(CONFIG_OF_SYSTEM_SETUP) += am62p5_fdt.o -obj-$(CONFIG_SPL_BUILD) += am62p5_init.o +obj-$(CONFIG_XPL_BUILD) += am62p5_init.o diff --git a/arch/arm/mach-k3/am62x/Makefile b/arch/arm/mach-k3/am62x/Makefile index 8494cdda482..ca10b6a8d3d 100644 --- a/arch/arm/mach-k3/am62x/Makefile +++ b/arch/arm/mach-k3/am62x/Makefile @@ -1,5 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_OF_SYSTEM_SETUP) += am625_fdt.o -obj-$(CONFIG_SPL_BUILD) += am625_init.o +obj-$(CONFIG_XPL_BUILD) += am625_init.o obj-y += boot.o diff --git a/arch/arm/mach-k3/am64x/Makefile b/arch/arm/mach-k3/am64x/Makefile index d0b286276c8..053a8239999 100644 --- a/arch/arm/mach-k3/am64x/Makefile +++ b/arch/arm/mach-k3/am64x/Makefile @@ -1,4 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_SPL_BUILD) += am642_init.o +obj-$(CONFIG_XPL_BUILD) += am642_init.o obj-y += boot.o diff --git a/arch/arm/mach-k3/am65x/Makefile b/arch/arm/mach-k3/am65x/Makefile index 20d5f1d3bf1..34734f24ff7 100644 --- a/arch/arm/mach-k3/am65x/Makefile +++ b/arch/arm/mach-k3/am65x/Makefile @@ -4,4 +4,4 @@ # Andrew Davis afd@ti.com
obj-$(CONFIG_OF_SYSTEM_SETUP) += am654_fdt.o -obj-$(CONFIG_SPL_BUILD) += am654_init.o +obj-$(CONFIG_XPL_BUILD) += am654_init.o diff --git a/arch/arm/mach-k3/arm64/cache.S b/arch/arm/mach-k3/arm64/cache.S index 17cfb12f108..6a507ae3af5 100644 --- a/arch/arm/mach-k3/arm64/cache.S +++ b/arch/arm/mach-k3/arm64/cache.S @@ -7,7 +7,7 @@ #include <config.h> #include <linux/linkage.h>
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) ENTRY(__asm_invalidate_l3_dcache) /* Invalidate SPL address range */ mov x0, #CONFIG_SPL_TEXT_BASE diff --git a/arch/arm/mach-k3/j721e/Makefile b/arch/arm/mach-k3/j721e/Makefile index 982b88db57d..e4b0e5a8193 100644 --- a/arch/arm/mach-k3/j721e/Makefile +++ b/arch/arm/mach-k3/j721e/Makefile @@ -4,4 +4,4 @@ # Andrew Davis afd@ti.com
obj-$(CONFIG_OF_SYSTEM_SETUP) += j721e_fdt.o -obj-$(CONFIG_SPL_BUILD) += j721e_init.o +obj-$(CONFIG_XPL_BUILD) += j721e_init.o diff --git a/arch/arm/mach-k3/j721s2/Makefile b/arch/arm/mach-k3/j721s2/Makefile index ceef68297c9..051ef1b11d8 100644 --- a/arch/arm/mach-k3/j721s2/Makefile +++ b/arch/arm/mach-k3/j721s2/Makefile @@ -4,4 +4,4 @@ # Andrew Davis afd@ti.com
obj-$(CONFIG_OF_SYSTEM_SETUP) += j721s2_fdt.o -obj-$(CONFIG_SPL_BUILD) += j721s2_init.o +obj-$(CONFIG_XPL_BUILD) += j721s2_init.o diff --git a/arch/arm/mach-k3/j721s2/j721s2_init.c b/arch/arm/mach-k3/j721s2/j721s2_init.c index 05453fcad41..64c34d3dbd6 100644 --- a/arch/arm/mach-k3/j721s2/j721s2_init.c +++ b/arch/arm/mach-k3/j721s2/j721s2_init.c @@ -312,7 +312,7 @@ void do_dt_magic(void) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { k3_spl_init(); diff --git a/arch/arm/mach-k3/j722s/Makefile b/arch/arm/mach-k3/j722s/Makefile index 2b1fec131ed..9b0dd8afd8b 100644 --- a/arch/arm/mach-k3/j722s/Makefile +++ b/arch/arm/mach-k3/j722s/Makefile @@ -4,4 +4,4 @@ # Jayesh Choudhary j-choudhary@ti.com
obj-$(CONFIG_OF_SYSTEM_SETUP) += j722s_fdt.o -obj-$(CONFIG_SPL_BUILD) += j722s_init.o +obj-$(CONFIG_XPL_BUILD) += j722s_init.o diff --git a/arch/arm/mach-k3/j784s4/Makefile b/arch/arm/mach-k3/j784s4/Makefile index 6d1841e3f9e..1d51bcf6e8c 100644 --- a/arch/arm/mach-k3/j784s4/Makefile +++ b/arch/arm/mach-k3/j784s4/Makefile @@ -4,4 +4,4 @@ # Andrew Davis afd@ti.com
obj-$(CONFIG_OF_SYSTEM_SETUP) += j784s4_fdt.o -obj-$(CONFIG_SPL_BUILD) += j784s4_init.o +obj-$(CONFIG_XPL_BUILD) += j784s4_init.o diff --git a/arch/arm/mach-k3/r5/Makefile b/arch/arm/mach-k3/r5/Makefile index d3886caa064..f533c5e7743 100644 --- a/arch/arm/mach-k3/r5/Makefile +++ b/arch/arm/mach-k3/r5/Makefile @@ -16,6 +16,6 @@ obj-y += common.o obj-y += lowlevel_init.o obj-y += r5_mpu.o
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_K3_LOAD_SYSFW) += sysfw-loader.o endif diff --git a/arch/arm/mach-k3/security.c b/arch/arm/mach-k3/security.c index 7c46914d9dd..3468a370a45 100644 --- a/arch/arm/mach-k3/security.c +++ b/arch/arm/mach-k3/security.c @@ -126,7 +126,7 @@ void ti_secure_image_post_process(void **p_image, size_t *p_size) * via YMODEM. This is done to avoid disturbing the YMODEM serial * protocol transactions. */ - if (!(IS_ENABLED(CONFIG_SPL_BUILD) && + if (!(IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_SPL_YMODEM_SUPPORT) && spl_boot_device() == BOOT_DEVICE_UART)) printf("Authentication passed\n"); diff --git a/arch/arm/mach-keystone/Makefile b/arch/arm/mach-keystone/Makefile index 6c7c25090a2..c864317baea 100644 --- a/arch/arm/mach-keystone/Makefile +++ b/arch/arm/mach-keystone/Makefile @@ -10,7 +10,7 @@ obj-y += psc.o obj-y += clock.o obj-y += mon.o CFLAGS_REMOVE_mon.o := $(LTO_CFLAGS) -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += cmd_clock.o obj-y += cmd_mon.o obj-y += cmd_poweroff.o diff --git a/arch/arm/mach-keystone/config.mk b/arch/arm/mach-keystone/config.mk index 8eccbdb3018..925a2deee23 100644 --- a/arch/arm/mach-keystone/config.mk +++ b/arch/arm/mach-keystone/config.mk @@ -7,7 +7,7 @@
include $(srctree)/arch/arm/mach-omap2/config_secure.mk
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD ifeq ($(CONFIG_TI_SECURE_DEVICE),y) INPUTS-y += u-boot_HS_MLO else @@ -25,7 +25,7 @@ OBJCOPYFLAGS_u-boot-spi.gph = -I binary -O binary --pad-to=$(CONFIG_SPL_PAD_TO) u-boot-spi.gph: spl/u-boot-spl.gph u-boot.img FORCE $(call if_changed,pad_cat)
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD MKIMAGEFLAGS_MLO = -A $(ARCH) -T gpimage -C none \ -a $(CONFIG_TEXT_BASE) -e $(CONFIG_TEXT_BASE) -n U-Boot MLO: u-boot.bin FORCE diff --git a/arch/arm/mach-keystone/mon.c b/arch/arm/mach-keystone/mon.c index b945e19ec77..f99b9fbca2e 100644 --- a/arch/arm/mach-keystone/mon.c +++ b/arch/arm/mach-keystone/mon.c @@ -134,7 +134,7 @@ void board_fit_image_post_process(const void *fit, int node, void **p_image, * via YMODEM. This is done to avoid disturbing the YMODEM serial * protocol transactions. */ - if (!(IS_ENABLED(CONFIG_SPL_BUILD) && + if (!(IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_SPL_YMODEM_SUPPORT) && spl_boot_device() == BOOT_DEVICE_UART)) printf("Authentication passed\n"); diff --git a/arch/arm/mach-lpc32xx/Makefile b/arch/arm/mach-lpc32xx/Makefile index 6303570beea..f551abb4772 100644 --- a/arch/arm/mach-lpc32xx/Makefile +++ b/arch/arm/mach-lpc32xx/Makefile @@ -5,4 +5,4 @@
obj-y = cpu.o clk.o devices.o timer.o
-obj-$(CONFIG_SPL_BUILD) += dram.o lowlevel_init.o +obj-$(CONFIG_XPL_BUILD) += dram.o lowlevel_init.o diff --git a/arch/arm/mach-mediatek/Makefile b/arch/arm/mach-mediatek/Makefile index 46bdab88206..3d9e4684fb4 100644 --- a/arch/arm/mach-mediatek/Makefile +++ b/arch/arm/mach-mediatek/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0
obj-y += cpu.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o
obj-$(CONFIG_MT8512) += mt8512/ obj-$(CONFIG_TARGET_MT7622) += mt7622/ diff --git a/arch/arm/mach-mediatek/mt7629/lowlevel_init.S b/arch/arm/mach-mediatek/mt7629/lowlevel_init.S index 0a0672cbea7..9f19003e43b 100644 --- a/arch/arm/mach-mediatek/mt7629/lowlevel_init.S +++ b/arch/arm/mach-mediatek/mt7629/lowlevel_init.S @@ -16,7 +16,7 @@
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* Return to U-Boot via saved link register */ mov pc, lr #else diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 329c2e49153..35fd2d0a1d2 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -22,7 +22,7 @@ else # CONFIG_ARCH_KIRKWOOD obj-y = cpu.o obj-y += dram.o obj-y += lowlevel.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ARMADA_375) += ../../../drivers/ddr/marvell/axp/xor.o obj-$(CONFIG_ARMADA_38X) += ../../../drivers/ddr/marvell/a38x/xor.o obj-$(CONFIG_ARMADA_XP) += ../../../drivers/ddr/marvell/axp/xor.o @@ -110,11 +110,11 @@ $(obj)/kwbimage.cfg: $(src)/kwbimage.cfg.in include/autoconf.mk \ include/config/auto.conf $(call cmd,kwbcfg)
-endif # CONFIG_SPL_BUILD +endif # CONFIG_XPL_BUILD obj-y += gpio.o obj-y += mbus.o -obj-$(CONFIG_SPL_BUILD) += spl.o -obj-$(CONFIG_SPL_BUILD) += lowlevel_spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += lowlevel_spl.o
obj-$(CONFIG_ARMADA_38X) += serdes/a38x/ obj-$(CONFIG_ARMADA_XP) += serdes/axp/ diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 8a145a5f742..da44727cf4f 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -52,7 +52,7 @@ void lowlevel_init(void) */ }
-#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_ARMADA_32BIT_SYSCON_SYSRESET) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_ARMADA_32BIT_SYSCON_SYSRESET) void reset_cpu(void) { struct mvebu_system_registers *reg = @@ -549,7 +549,7 @@ static void ahci_mvebu_mbus_config(void __iomem *base) int i;
/* mbus is not initialized in SPL; keep the ROM settings */ - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return;
dram = mvebu_mbus_dram_info(); diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index af6ce2920e6..37a00501214 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -66,7 +66,7 @@ enum cpu_attrib { /* * Default Device Address MAP BAR values */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #ifdef CONFIG_ARMADA_38X #define MBUS_PCI_MEM_BASE 0x88000000 #define MBUS_PCI_MEM_SIZE ((3 * 128) << 20) @@ -81,19 +81,19 @@ enum cpu_attrib { #define MBUS_PCI_IO_BASE 0xF1100000 #define MBUS_PCI_IO_SIZE ((MBUS_PCI_MAX_PORTS * 64) << 10) #endif -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define MBUS_SPI_BASE 0xD4000000 #define MBUS_SPI_SIZE (64 << 20) #else #define MBUS_SPI_BASE 0xF4000000 #define MBUS_SPI_SIZE (8 << 20) #endif -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define MBUS_DFX_BASE 0xF6000000 #define MBUS_DFX_SIZE (1 << 20) #endif #define MBUS_BOOTROM_BASE 0xF8000000 -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define MBUS_BOOTROM_SIZE (128 << 20) #else #define MBUS_BOOTROM_SIZE (8 << 20) diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index dc68d406f99..495530d8452 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -36,7 +36,7 @@ /* SOC specific definations */ #define INTREG_BASE 0xd0000000 #define INTREG_BASE_ADDR_REG (INTREG_BASE + 0x20080) -#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_ARMADA_3700) +#if defined(CONFIG_XPL_BUILD) || defined(CONFIG_ARMADA_3700) /* * The SPL U-Boot version still runs with the default * address for the internal registers, configured by diff --git a/arch/arm/mach-mvebu/serdes/a38x/Makefile b/arch/arm/mach-mvebu/serdes/a38x/Makefile index 5a70b375966..c33e272217d 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/Makefile +++ b/arch/arm/mach-mvebu/serdes/a38x/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_SPL_BUILD) += high_speed_env_spec.o -obj-$(CONFIG_SPL_BUILD) += high_speed_env_spec-38x.o -obj-$(CONFIG_SPL_BUILD) += seq_exec.o -obj-$(CONFIG_SPL_BUILD) += sys_env_lib.o +obj-$(CONFIG_XPL_BUILD) += high_speed_env_spec.o +obj-$(CONFIG_XPL_BUILD) += high_speed_env_spec-38x.o +obj-$(CONFIG_XPL_BUILD) += seq_exec.o +obj-$(CONFIG_XPL_BUILD) += sys_env_lib.o diff --git a/arch/arm/mach-mvebu/serdes/axp/Makefile b/arch/arm/mach-mvebu/serdes/axp/Makefile index 897afb703ad..7d48f8da9ed 100644 --- a/arch/arm/mach-mvebu/serdes/axp/Makefile +++ b/arch/arm/mach-mvebu/serdes/axp/Makefile @@ -1,4 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_SPL_BUILD) = high_speed_env_lib.o -obj-$(CONFIG_SPL_BUILD) += high_speed_env_spec.o +obj-$(CONFIG_XPL_BUILD) = high_speed_env_lib.o +obj-$(CONFIG_XPL_BUILD) += high_speed_env_spec.o diff --git a/arch/arm/mach-nexell/include/mach/display.h b/arch/arm/mach-nexell/include/mach/display.h index b0ee9126057..3a4e2c47f5e 100644 --- a/arch/arm/mach-nexell/include/mach/display.h +++ b/arch/arm/mach-nexell/include/mach/display.h @@ -265,7 +265,7 @@ int dp_plane_set_enable(int module, int layer, int on); int dp_plane_set_address(int module, int layer, unsigned int address); int dp_plane_wait_vsync(int module, int layer, int fps);
-#if defined CONFIG_SPL_BUILD || \ +#if defined CONFIG_XPL_BUILD || \ (!defined(CONFIG_DM) && !defined(CONFIG_OF_CONTROL)) int nx_display_probe(struct nx_display_plat *plat); #endif diff --git a/arch/arm/mach-omap2/Makefile b/arch/arm/mach-omap2/Makefile index d683c64566a..9a85c764a55 100644 --- a/arch/arm/mach-omap2/Makefile +++ b/arch/arm/mach-omap2/Makefile @@ -11,7 +11,7 @@ obj-y += reset.o ifeq ($(CONFIG_TIMER),) obj-y += timer.o else -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += timer.o endif endif diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index abdc1e40335..e720fb6b21f 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -209,7 +209,7 @@ int cpu_mmc_init(struct bd_info *bis)
/* AM33XX has two MUSB controllers which can be host or gadget */ #if (defined(CONFIG_AM335X_USB0) || defined(CONFIG_AM335X_USB1)) && \ - defined(CONFIG_SPL_BUILD) + defined(CONFIG_XPL_BUILD)
static struct musb_hdrc_config musb_config = { .multipoint = 1, @@ -282,7 +282,7 @@ int arch_misc_init(void) #if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT)
#if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC) || \ - (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT)) + (defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT)) static void rtc32k_unlock(struct davinci_rtc *rtc) { /* @@ -295,7 +295,7 @@ static void rtc32k_unlock(struct davinci_rtc *rtc) } #endif
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) /* * Write contents of the RTC_SCRATCH1 register based on board type * Two things are passed @@ -331,7 +331,7 @@ int board_early_init_f(void) { set_mux_conf_regs(); prcm_init(); -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) update_rtc_magic(); #endif return 0; @@ -379,7 +379,7 @@ static void watchdog_disable(void) ; }
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) /* * Check if we are executing rtc-only + DDR mode, and resume from it if needed */ @@ -455,7 +455,7 @@ am43xx_wait:
void s_init(void) { -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) rtc_only(); #endif } @@ -474,7 +474,7 @@ void early_system_init(void) set_uart_mux_conf(); setup_early_clocks(); uart_soft_reset(); -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * Save the boot parameters passed from romcode. * We cannot delay the saving further than this, @@ -483,7 +483,7 @@ void early_system_init(void) save_omap_boot_params(); #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD spl_early_init(); #endif
@@ -497,7 +497,7 @@ void early_system_init(void) #endif }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { hw_data_init(); diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index 649bc07047a..ddd7eeaf052 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -173,7 +173,7 @@ void save_omap_boot_params(void) #endif }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD u32 spl_boot_device(void) { return gd->arch.omap_boot_device; @@ -208,7 +208,7 @@ void spl_boot_ipu(void) int ret, size; u32 loadaddr = IPU1_LOAD_ADDR;
- if (!IS_ENABLED(CONFIG_SPL_BUILD) || + if (!IS_ENABLED(CONFIG_XPL_BUILD) || !IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) return;
@@ -286,7 +286,7 @@ void spl_soc_init(void) #if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) hw_watchdog_init(); #endif - if (IS_ENABLED(CONFIG_SPL_BUILD) && + if (IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) spl_boot_ipu(); } diff --git a/arch/arm/mach-omap2/clocks-common.c b/arch/arm/mach-omap2/clocks-common.c index 18d099145c5..f05b16797ec 100644 --- a/arch/arm/mach-omap2/clocks-common.c +++ b/arch/arm/mach-omap2/clocks-common.c @@ -24,7 +24,7 @@ #include <asm/omap_gpio.h> #include <asm/emif.h>
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * printing to console doesn't work unless * this code is executed from SPL diff --git a/arch/arm/mach-omap2/config.mk b/arch/arm/mach-omap2/config.mk index 30d8fb1b1d9..02b26733ee6 100644 --- a/arch/arm/mach-omap2/config.mk +++ b/arch/arm/mach-omap2/config.mk @@ -5,7 +5,7 @@
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifeq ($(CONFIG_TI_SECURE_DEVICE),y) # Refer to README.ti-secure for more info # On DRA7xx/AM57xx: # diff --git a/arch/arm/mach-omap2/config_secure.mk b/arch/arm/mach-omap2/config_secure.mk index 40db1aec142..62ac27dfa90 100644 --- a/arch/arm/mach-omap2/config_secure.mk +++ b/arch/arm/mach-omap2/config_secure.mk @@ -4,7 +4,7 @@ quiet_cmd_mkomapsecimg = SECURE $@ ifneq ($(TI_SECURE_DEV_PKG),) ifneq ($(wildcard $(TI_SECURE_DEV_PKG)/scripts/create-boot-image.sh),) -ifneq ($(CONFIG_SPL_BUILD),) +ifneq ($(CONFIG_XPL_BUILD),) cmd_mkomapsecimg = $(TI_SECURE_DEV_PKG)/scripts/create-boot-image.sh \ $(patsubst u-boot-spl_HS_%,%,$(@F)) $< $@ $(CONFIG_SPL_TEXT_BASE) \ $(if $(KBUILD_VERBOSE:1=), >/dev/null) diff --git a/arch/arm/mach-omap2/hwinit-common.c b/arch/arm/mach-omap2/hwinit-common.c index bb67e50fd56..b1e486a99d9 100644 --- a/arch/arm/mach-omap2/hwinit-common.c +++ b/arch/arm/mach-omap2/hwinit-common.c @@ -113,7 +113,7 @@ static void omap_rev_string(void) puts("\n"); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_display_print(void) { omap_rev_string(); @@ -175,7 +175,7 @@ void __weak init_package_revision(void) */ int early_system_init(void) { -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_MULTI_DTB_FIT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_MULTI_DTB_FIT) int ret; int rescan; #endif @@ -183,19 +183,19 @@ int early_system_init(void) hw_data_init(); init_package_revision();
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD if (warm_reset()) force_emif_self_refresh(); #endif watchdog_init(); set_mux_conf_regs(); -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD srcomp_enable(); do_io_settings(); #endif setup_early_clocks();
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * Save the boot parameters passed from romcode. * We cannot delay the saving further than this, @@ -206,7 +206,7 @@ int early_system_init(void) #endif do_board_detect();
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_MULTI_DTB_FIT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_MULTI_DTB_FIT) /* * Board detection has been done. * Let us see if another dtb wouldn't be a better match @@ -228,7 +228,7 @@ int early_system_init(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { early_system_init(); diff --git a/arch/arm/mach-omap2/omap3/Makefile b/arch/arm/mach-omap2/omap3/Makefile index 151bdf6ebc9..159633e7f6d 100644 --- a/arch/arm/mach-omap2/omap3/Makefile +++ b/arch/arm/mach-omap2/omap3/Makefile @@ -15,7 +15,7 @@ obj-y += clock.o obj-y += sys_info.o obj-y += prcm-regs.o obj-y += hw_data.o -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_OMAP3_ID_NAND) += spl_id_nand.o endif
diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index 1de343ff48e..4b6ce6940a9 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -211,7 +211,7 @@ void s_init(void) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { early_system_init(); @@ -280,7 +280,7 @@ void abort(void) { }
-#if defined(CONFIG_NAND_OMAP_GPMC) & !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_NAND_OMAP_GPMC) & !defined(CONFIG_XPL_BUILD) /****************************************************************************** * OMAP3 specific command to switch between NAND HW and SW ecc *****************************************************************************/ @@ -331,7 +331,7 @@ U_BOOT_CMD( "nandecc sw - Switch to NAND software ecc algorithm." );
-#endif /* CONFIG_NAND_OMAP_GPMC & !CONFIG_SPL_BUILD */ +#endif /* CONFIG_NAND_OMAP_GPMC & !CONFIG_XPL_BUILD */
#ifdef CONFIG_DISPLAY_BOARDINFO /** diff --git a/arch/arm/mach-omap2/omap3/sdrc.c b/arch/arm/mach-omap2/omap3/sdrc.c index 404333689f6..24fae484369 100644 --- a/arch/arm/mach-omap2/omap3/sdrc.c +++ b/arch/arm/mach-omap2/omap3/sdrc.c @@ -146,7 +146,7 @@ static void do_sdrc_init(u32 cs, u32 early) * then set cs_cfg to the appropriate value then try and * setup CS1. */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* set/modify board-specific timings */ get_board_mem_timings(&timings); #endif @@ -166,7 +166,7 @@ static void do_sdrc_init(u32 cs, u32 early)
writel(ENADLL | DLLPHASE_90, &sdrc_base->dlla_ctrl); sdelay(0x20000); -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD write_sdrc_timings(CS0, sdrc_actim_base0, &timings); make_cs1_contiguous(); write_sdrc_timings(CS1, sdrc_actim_base1, &timings); diff --git a/arch/arm/mach-omap2/omap5/hwinit.c b/arch/arm/mach-omap2/omap5/hwinit.c index 7f41e85c4a6..42f9c63fe12 100644 --- a/arch/arm/mach-omap2/omap5/hwinit.c +++ b/arch/arm/mach-omap2/omap5/hwinit.c @@ -50,7 +50,7 @@ void do_set_mux32(u32 base, struct pad_conf_entry const *array, int size) writel(pad->val, base + pad->offset); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* LPDDR2 specific IO settings */ static void io_settings_lpddr2(void) { diff --git a/arch/arm/mach-omap2/sec-common.c b/arch/arm/mach-omap2/sec-common.c index 16bbc93f4a3..b1d11a4d1a4 100644 --- a/arch/arm/mach-omap2/sec-common.c +++ b/arch/arm/mach-omap2/sec-common.c @@ -178,7 +178,7 @@ auth_exit: * via YMODEM. This is done to avoid disturbing the YMODEM serial * protocol transactions. */ - if (!(IS_ENABLED(CONFIG_SPL_BUILD) && + if (!(IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_SPL_YMODEM_SUPPORT) && spl_boot_device() == BOOT_DEVICE_UART)) printf("Authentication passed\n"); diff --git a/arch/arm/mach-orion5x/cpu.c b/arch/arm/mach-orion5x/cpu.c index 58ee67eca50..4eba69a6909 100644 --- a/arch/arm/mach-orion5x/cpu.c +++ b/arch/arm/mach-orion5x/cpu.c @@ -235,7 +235,7 @@ int arch_cpu_init(void) /* Enable and invalidate L2 cache in write through mode */ invalidate_l2_cache();
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD orion5x_config_adr_windows(); #endif
diff --git a/arch/arm/mach-orion5x/lowlevel_init.S b/arch/arm/mach-orion5x/lowlevel_init.S index aa3fcf7c301..358d2a49fbb 100644 --- a/arch/arm/mach-orion5x/lowlevel_init.S +++ b/arch/arm/mach-orion5x/lowlevel_init.S @@ -69,7 +69,7 @@
lowlevel_init:
/* Use 'r2 as the base for internal register accesses */ ldr r2, =ORION5X_REGS_PHY_BASE @@ -280,7 +280,7 @@ lowlevel_init: ldr r0, =0x7fff0001 str r0, [r3, #0x504]
/* Return to U-Boot via saved link register */ mov pc, lr diff --git a/arch/arm/mach-renesas/include/mach/boot0.h b/arch/arm/mach-renesas/include/mach/boot0.h index 1d8c3eea99c..fe88a2e0373 100644 --- a/arch/arm/mach-renesas/include/mach/boot0.h +++ b/arch/arm/mach-renesas/include/mach/boot0.h @@ -9,7 +9,7 @@ _start: ARM_VECTORS
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD .word 0x0badc0d3; .word 0x0badc0d3; .word 0x0badc0d3; diff --git a/arch/arm/mach-renesas/lowlevel_init_ca15.S b/arch/arm/mach-renesas/lowlevel_init_ca15.S index 059cd738785..ecefa3d5c43 100644 --- a/arch/arm/mach-renesas/lowlevel_init_ca15.S +++ b/arch/arm/mach-renesas/lowlevel_init_ca15.S @@ -11,7 +11,7 @@ #include <system-constants.h>
ENTRY(lowlevel_init) -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD mrc p15, 0, r4, c0, c0, 5 /* mpidr */ orr r4, r4, r4, lsr #6 and r4, r4, #7 /* id 0-3 = ca15.0,1,2,3 */ diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 3b13891ec24..76756c3661b 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -15,7 +15,7 @@ obj-tpl-$(CONFIG_ROCKCHIP_PX30) += px30-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o
-ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),)
# Always include boot_mode.o, as we bypass it (i.e. turn it off) # inside of boot_mode.c when CONFIG_ROCKCHIP_BOOT_MODE_REG is 0. This way, @@ -51,5 +51,5 @@ obj-$(CONFIG_ROCKCHIP_RV1126) += rv1126/ obj-spl-$(CONFIG_TPL_BUILD) =
# Now add SPL/TPL objects back into the main build -obj-$(CONFIG_SPL_BUILD) += $(obj-spl-y) +obj-$(CONFIG_XPL_BUILD) += $(obj-spl-y) obj-$(CONFIG_TPL_BUILD) += $(obj-tpl-y) diff --git a/arch/arm/mach-rockchip/px30/px30.c b/arch/arm/mach-rockchip/px30/px30.c index 8b1509e55f2..8ce9ac561f0 100644 --- a/arch/arm/mach-rockchip/px30/px30.c +++ b/arch/arm/mach-rockchip/px30/px30.c @@ -244,7 +244,7 @@ int arch_cpu_init(void) static struct px30_cru * const cru = (void *)CRU_BASE; u32 __maybe_unused val;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* We do some SoC one time setting here. */ /* Disable the ddr secure region setting to make it non-secure */ writel(0x0, DDR_FW_BASE + FW_DDR_CON); diff --git a/arch/arm/mach-rockchip/rk3036/Makefile b/arch/arm/mach-rockchip/rk3036/Makefile index 299fc50635d..038180c275c 100644 --- a/arch/arm/mach-rockchip/rk3036/Makefile +++ b/arch/arm/mach-rockchip/rk3036/Makefile @@ -6,7 +6,7 @@
obj-y += clk_rk3036.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += syscon_rk3036.o endif
diff --git a/arch/arm/mach-rockchip/rk3066/rk3066.c b/arch/arm/mach-rockchip/rk3066/rk3066.c index 70b55ca8abf..b8c177a4d0d 100644 --- a/arch/arm/mach-rockchip/rk3066/rk3066.c +++ b/arch/arm/mach-rockchip/rk3066/rk3066.c @@ -27,7 +27,7 @@ void board_debug_uart_init(void)
void spl_board_init(void) { - if (!IS_ENABLED(CONFIG_SPL_BUILD)) + if (!IS_ENABLED(CONFIG_XPL_BUILD)) return;
if (IS_ENABLED(CONFIG_SPL_DM_MMC)) { diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index 53b2eaa2d53..7cce1112fbd 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -51,7 +51,7 @@ void board_debug_uart_init(void) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD int arch_cpu_init(void) { struct rk3188_grf *grf; @@ -106,7 +106,7 @@ int rk_board_late_init(void) return rk3188_board_late_init(); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static int setup_led(void) { #ifdef CONFIG_SPL_LED diff --git a/arch/arm/mach-rockchip/rk322x/rk322x.c b/arch/arm/mach-rockchip/rk322x/rk322x.c index 712c0524266..e35ca7778e7 100644 --- a/arch/arm/mach-rockchip/rk322x/rk322x.c +++ b/arch/arm/mach-rockchip/rk322x/rk322x.c @@ -51,7 +51,7 @@ void board_debug_uart_init(void)
int arch_cpu_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define SGRF_BASE 0x10150000 static struct rk322x_sgrf * const sgrf = (void *)SGRF_BASE;
diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index d1170f7e23d..62dd9da6578 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -31,7 +31,7 @@ const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_SD] = "/mmc@ff0c0000", };
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static void configure_l2ctlr(void) { u32 l2ctlr; @@ -72,7 +72,7 @@ int rk3288_qos_init(void)
int arch_cpu_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD configure_l2ctlr(); #else /* We do some SoC one time setting here. */ diff --git a/arch/arm/mach-rockchip/rk3308/rk3308.c b/arch/arm/mach-rockchip/rk3308/rk3308.c index 6f88638d156..c6b1a35f47e 100644 --- a/arch/arm/mach-rockchip/rk3308/rk3308.c +++ b/arch/arm/mach-rockchip/rk3308/rk3308.c @@ -185,7 +185,7 @@ __weak void board_debug_uart_init(void) } #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) int arch_cpu_init(void) { static struct rk3308_sgrf * const sgrf = (void *)SGRF_BASE; diff --git a/arch/arm/mach-rockchip/rk3328/rk3328.c b/arch/arm/mach-rockchip/rk3328/rk3328.c index c86d11943d6..12ad17d9e8b 100644 --- a/arch/arm/mach-rockchip/rk3328/rk3328.c +++ b/arch/arm/mach-rockchip/rk3328/rk3328.c @@ -62,7 +62,7 @@ struct mm_region *mem_map = rk3328_mem_map;
int arch_cpu_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD u32 reg;
/* We do some SoC one time setting here. */ diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index f589bf67328..97b9500da25 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -93,7 +93,7 @@ int arch_early_init_r(void) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * The SPL (and also the full U-Boot stage on the RK3368) will run in * secure mode (i.e. EL3) and an ATF will eventually be booted before diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 2d7d0f82a2f..edccb2a3980 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -51,7 +51,7 @@ static struct mm_region rk3399_mem_map[] = {
struct mm_region *mem_map = rk3399_mem_map;
#define TIMER_END_COUNT_L 0x00 #define TIMER_END_COUNT_H 0x04 @@ -83,7 +83,7 @@ void rockchip_stimer_init(void) int arch_cpu_init(void) {
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD struct rk3399_pmusgrf_regs *sgrf; struct rk3399_grf_regs *grf;
@@ -136,7 +136,7 @@ void board_debug_uart_init(void) struct rk3399_pmugrf_regs * const pmugrf = (void *)PMUGRF_BASE; struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE;
- if (IS_ENABLED(CONFIG_SPL_BUILD) && + if (IS_ENABLED(CONFIG_XPL_BUILD) && (IS_ENABLED(CONFIG_TARGET_CHROMEBOOK_BOB) || IS_ENABLED(CONFIG_TARGET_CHROMEBOOK_KEVIN))) { rk_setreg(&grf->io_vsel, 1 << 0); @@ -169,7 +169,7 @@ void board_debug_uart_init(void) } #endif
-#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_TPL_BUILD) +#if defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) static void rk3399_force_power_on_reset(void) { ofnode node; diff --git a/arch/arm/mach-rockchip/rk3568/rk3568.c b/arch/arm/mach-rockchip/rk3568/rk3568.c index 1b3e40074e3..768a3739329 100644 --- a/arch/arm/mach-rockchip/rk3568/rk3568.c +++ b/arch/arm/mach-rockchip/rk3568/rk3568.c @@ -105,7 +105,7 @@ void board_debug_uart_init(void)
int arch_cpu_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * When perform idle operation, corresponding clock can * be opened or gated automatically. diff --git a/arch/arm/mach-rockchip/rk3588/rk3588.c b/arch/arm/mach-rockchip/rk3588/rk3588.c index d3162d3447e..e2dac2a5b80 100644 --- a/arch/arm/mach-rockchip/rk3588/rk3588.c +++ b/arch/arm/mach-rockchip/rk3588/rk3588.c @@ -111,7 +111,7 @@ void board_debug_uart_init(void) GPIO0B5_UART2_TX_M0 << GPIO0B5_SHIFT); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void rockchip_stimer_init(void) { /* If Timer already enabled, don't re-init it */ @@ -130,7 +130,7 @@ void rockchip_stimer_init(void) #ifndef CONFIG_TPL_BUILD int arch_cpu_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #ifdef CONFIG_ROCKCHIP_DISABLE_FORCE_JTAG static struct rk3588_sysgrf * const sys_grf = (void *)SYS_GRF_BASE; #endif diff --git a/arch/arm/mach-rockchip/rv1108/Makefile b/arch/arm/mach-rockchip/rv1108/Makefile index 9035a1a8923..283fc966e7b 100644 --- a/arch/arm/mach-rockchip/rv1108/Makefile +++ b/arch/arm/mach-rockchip/rv1108/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += syscon_rv1108.o endif obj-y += rv1108.o diff --git a/arch/arm/mach-rockchip/rv1126/rv1126.c b/arch/arm/mach-rockchip/rv1126/rv1126.c index 1c10e9b9f23..27ed5dc19e1 100644 --- a/arch/arm/mach-rockchip/rv1126/rv1126.c +++ b/arch/arm/mach-rockchip/rv1126/rv1126.c @@ -66,7 +66,7 @@ int arch_cpu_init(void) * since they are unsecure. * (Note: only secure-world can access this register) */ - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) writel(0, FIREWALL_APB_BASE + FW_DDR_CON_REG);
return 0; diff --git a/arch/arm/mach-sc5xx/Makefile b/arch/arm/mach-sc5xx/Makefile index eeb56c078b3..598a13031b4 100644 --- a/arch/arm/mach-sc5xx/Makefile +++ b/arch/arm/mach-sc5xx/Makefile @@ -15,5 +15,5 @@ obj-$(CONFIG_SC58X) += sc58x.o obj-$(CONFIG_SC59X) += sc59x.o obj-$(CONFIG_SC59X_64) += sc59x_64.o
-obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o obj-$(CONFIG_SYSCON) += rcu.o diff --git a/arch/arm/mach-sc5xx/config.mk b/arch/arm/mach-sc5xx/config.mk index 580964e559c..e7e4c9a1181 100644 --- a/arch/arm/mach-sc5xx/config.mk +++ b/arch/arm/mach-sc5xx/config.mk @@ -8,7 +8,7 @@ # Contact: Greg Malysa greg.malysa@timesys.com #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD INPUTS-y += $(obj)/u-boot-spl.ldr endif
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 67c6a8dfec5..5fc61b4a5c6 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -80,7 +80,7 @@ obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o endif
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifdef CONFIG_TARGET_SOCFPGA_GEN5 obj-y += spl_gen5.o obj-y += freeze_controller.o diff --git a/arch/arm/mach-socfpga/board.c b/arch/arm/mach-socfpga/board.c index feaf5ce4596..24a15f7903f 100644 --- a/arch/arm/mach-socfpga/board.c +++ b/arch/arm/mach-socfpga/board.c @@ -102,7 +102,7 @@ u8 socfpga_get_board_id(void) u32 jtag_usercode; int err;
-#if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF) +#if !IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF) err = smc_get_usercode(&jtag_usercode); #else u32 resp_len = 1; @@ -130,7 +130,7 @@ u8 socfpga_get_board_id(void) return board_id; }
-#if IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_TARGET_SOCFPGA_SOC64) +#if IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_TARGET_SOCFPGA_SOC64) int board_fit_config_name_match(const char *name) { char board_name[10]; @@ -154,7 +154,7 @@ void board_fit_image_post_process(const void *fit, int node, void **p_image, } #endif
-#if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_FIT) +#if !IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_FIT) void board_prep_linux(struct bootm_headers *images) { bool use_fit = false; diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index 160f6e73ca9..134eaf08e0a 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -99,7 +99,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int do_showclocks(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c index 58b9321131a..5674194f4d1 100644 --- a/arch/arm/mach-socfpga/clock_manager_arria10.c +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -12,7 +12,7 @@ #include <asm/arch/clock_manager.h> #include <linux/delay.h>
void sdelay(unsigned long loops); u32 wait_on_value(u32 read_bit_mask, u32 match_value, void *read_addr, diff --git a/arch/arm/mach-socfpga/include/mach/boot0.h b/arch/arm/mach-socfpga/include/mach/boot0.h index c78def5066e..2676d6c8283 100644 --- a/arch/arm/mach-socfpga/include/mach/boot0.h +++ b/arch/arm/mach-socfpga/include/mach/boot0.h @@ -9,7 +9,7 @@ _start: ARM_VECTORS
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD .balignl 64,0xf33db33f;
.word 0x1337c0d3; /* SoCFPGA preloader validation word */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h index 553ebe660de..80d5047b469 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h @@ -62,7 +62,7 @@ #define CLKMGR_INTER CLKMGR_A10_INTER #define CLKMGR_PERPLL_EN CLKMGR_A10_PERPLL_EN
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD int cm_basic_init(const void *blob); #endif
diff --git a/arch/arm/mach-socfpga/lowlevel_init_soc64.S b/arch/arm/mach-socfpga/lowlevel_init_soc64.S index 875927cc4d9..8926c2d1d9c 100644 --- a/arch/arm/mach-socfpga/lowlevel_init_soc64.S +++ b/arch/arm/mach-socfpga/lowlevel_init_soc64.S @@ -13,7 +13,7 @@ ENTRY(lowlevel_init) mov x29, lr /* Save LR */
#if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_ATF) wait_for_atf: ldr x4, =CPU_RELEASE_ADDR ldr x5, [x4] diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c index 4c86f1e9917..2b4f26040fe 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -400,7 +400,7 @@ error:
int mbox_reset_cold(void) { -#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_ATF) psci_system_reset(); #else int ret; diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 495ba2a0d41..46f9c82bbb2 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -180,7 +180,7 @@ int arch_cpu_init(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int do_bridge(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c index 34c21317894..c442af02888 100644 --- a/arch/arm/mach-socfpga/misc_arria10.c +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -58,7 +58,7 @@ static Altera_desc altera_fpga[] = { }, };
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) static struct pl310_regs *const pl310 = (struct pl310_regs *)CFG_SYS_PL310_BASE; static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index b898b6f8f22..b136691c685 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -213,7 +213,7 @@ int arch_early_init_r(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static struct socfpga_sdr_ctrl *sdr_ctrl = (struct socfpga_sdr_ctrl *)SDR_CTRLGRP_ADDRESS;
diff --git a/arch/arm/mach-socfpga/reset_manager_s10.c b/arch/arm/mach-socfpga/reset_manager_s10.c index dd0383c7c76..a634c11a028 100644 --- a/arch/arm/mach-socfpga/reset_manager_s10.c +++ b/arch/arm/mach-socfpga/reset_manager_s10.c @@ -58,7 +58,7 @@ void socfpga_per_reset_all(void)
void socfpga_bridges_reset(int enable) { -#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_ATF) u64 arg = enable;
int ret = invoke_smc(INTEL_SIP_SMC_HPS_SET_BRIDGES, &arg, 1, NULL, 0); diff --git a/arch/arm/mach-socfpga/secure_vab.c b/arch/arm/mach-socfpga/secure_vab.c index 4347bf6e792..e931f1043b3 100644 --- a/arch/arm/mach-socfpga/secure_vab.c +++ b/arch/arm/mach-socfpga/secure_vab.c @@ -120,7 +120,7 @@ int socfpga_vendor_authentication(void **p_image, size_t *p_size) debug("mbox_relocate_data_addr = 0x%p\n", mbox_relocate_data_addr);
do { - if (!IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_SPL_ATF)) { /* Invoke SMC call to ATF to send the VAB certificate to SDM */ ret = smc_send_mailbox(MBOX_VAB_SRC_CERT, mbox_data_sz, (u32 *)mbox_relocate_data_addr, 0, &resp_len, diff --git a/arch/arm/mach-socfpga/timer_s10.c b/arch/arm/mach-socfpga/timer_s10.c index 80933586319..1a4e7c0e7e2 100644 --- a/arch/arm/mach-socfpga/timer_s10.c +++ b/arch/arm/mach-socfpga/timer_s10.c @@ -14,7 +14,7 @@ */ int timer_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD int enable = 0x3; /* timer enable + output signal masked */ int loadval = ~0;
@@ -56,4 +56,4 @@ __always_inline void __udelay(unsigned long usec)
while (__get_time_stamp() < tmp + 1) /* loop till event */ ; -} \ No newline at end of file +} diff --git a/arch/arm/mach-socfpga/wrap_pll_config_soc64.c b/arch/arm/mach-socfpga/wrap_pll_config_soc64.c index f13581033e6..60ba557d390 100644 --- a/arch/arm/mach-socfpga/wrap_pll_config_soc64.c +++ b/arch/arm/mach-socfpga/wrap_pll_config_soc64.c @@ -11,7 +11,7 @@
const struct cm_config * const cm_get_default_config(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD struct cm_config *cm_handoff_cfg = (struct cm_config *) (SOC64_HANDOFF_CLOCK + SOC64_HANDOFF_OFFSET_DATA); u32 *conversion = (u32 *)cm_handoff_cfg; @@ -32,7 +32,7 @@ const struct cm_config * const cm_get_default_config(void)
const unsigned int cm_get_osc_clk_hz(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD
u32 clock = readl(SOC64_HANDOFF_CLOCK_OSC);
@@ -50,7 +50,7 @@ const unsigned int cm_get_intosc_clk_hz(void)
const unsigned int cm_get_fpga_clk_hz(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD u32 clock = readl(SOC64_HANDOFF_CLOCK_FPGA);
writel(clock, diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index ee8a5428feb..db7ed19bd91 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -13,7 +13,7 @@ obj-$(CONFIG_STM32MP13X) += stm32mp1/ obj-$(CONFIG_STM32MP25X) += stm32mp2/
obj-$(CONFIG_STM32_ECDSA_VERIFY) += ecdsa_romapi.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += cmd_stm32prog/ obj-$(CONFIG_CMD_STM32KEY) += cmd_stm32key.o obj-$(CONFIG_TFABOOT) += boot_params.o diff --git a/arch/arm/mach-stm32mp/bsec.c b/arch/arm/mach-stm32mp/bsec.c index 9ba7a6c9a89..9cbe6a52623 100644 --- a/arch/arm/mach-stm32mp/bsec.c +++ b/arch/arm/mach-stm32mp/bsec.c @@ -409,7 +409,7 @@ static int stm32mp_bsec_read_otp(struct udevice *dev, u32 *val, u32 otp) u32 tmp_data = 0; int ret;
- if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_XPL_BUILD)) return stm32_smc(STM32_SMC_BSEC, STM32_SMC_READ_OTP, otp, 0, val); @@ -440,7 +440,7 @@ static int stm32mp_bsec_read_shadow(struct udevice *dev, u32 *val, u32 otp) { struct stm32mp_bsec_plat *plat;
- if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_XPL_BUILD)) return stm32_smc(STM32_SMC_BSEC, STM32_SMC_READ_SHADOW, otp, 0, val); @@ -469,7 +469,7 @@ static int stm32mp_bsec_write_otp(struct udevice *dev, u32 val, u32 otp) { struct stm32mp_bsec_plat *plat;
- if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_XPL_BUILD)) return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_PROG_OTP, otp, val); @@ -484,7 +484,7 @@ static int stm32mp_bsec_write_shadow(struct udevice *dev, u32 val, u32 otp) { struct stm32mp_bsec_plat *plat;
- if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_XPL_BUILD)) return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_WRITE_SHADOW, otp, val); @@ -504,7 +504,7 @@ static int stm32mp_bsec_write_lock(struct udevice *dev, u32 val, u32 otp) return 0; /* nothing to do */ }
- if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_ARM_SMCCC) && !IS_ENABLED(CONFIG_XPL_BUILD)) return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_WRLOCK_OTP, otp, 0); @@ -762,7 +762,7 @@ static int stm32mp_bsec_probe(struct udevice *dev) * update unlocked shadow for OTP cleared by the rom code * only executed in SPL, it is done in TF-A for TFABOOT */ - if (IS_ENABLED(CONFIG_SPL_BUILD) && !data->ta) { + if (IS_ENABLED(CONFIG_XPL_BUILD) && !data->ta) { plat = dev_get_plat(dev);
/* here 57 is the value for STM32MP15x ROM code, only MPU with SPL support*/ diff --git a/arch/arm/mach-stm32mp/stm32mp1/Makefile b/arch/arm/mach-stm32mp/stm32mp1/Makefile index ebae50f66c9..5ae1a536ff1 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/Makefile +++ b/arch/arm/mach-stm32mp/stm32mp1/Makefile @@ -8,7 +8,7 @@ obj-y += cpu.o obj-$(CONFIG_STM32MP13X) += stm32mp13x.o obj-$(CONFIG_STM32MP15X) += stm32mp15x.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-y += tzc400.o else diff --git a/arch/arm/mach-stm32mp/stm32mp1/cpu.c b/arch/arm/mach-stm32mp/stm32mp1/cpu.c index 64480da9f8d..26c073f06a0 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/cpu.c +++ b/arch/arm/mach-stm32mp/stm32mp1/cpu.c @@ -57,7 +57,7 @@ void dram_bank_mmu_setup(int bank) bool use_lmb = false; enum dcache_option option;
- if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { /* STM32_SYSRAM_BASE exist only when SPL is supported */ #ifdef CONFIG_SPL start = ALIGN_DOWN(STM32_SYSRAM_BASE, MMU_SECTION_SIZE); @@ -133,7 +133,7 @@ int mach_cpu_init(void) if (IS_ENABLED(CONFIG_CMD_STM32PROG_SERIAL) && (boot_mode & TAMP_BOOT_DEVICE_MASK) == BOOT_SERIAL_UART) gd->flags |= GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE; - else if (IS_ENABLED(CONFIG_DEBUG_UART) && IS_ENABLED(CONFIG_SPL_BUILD)) + else if (IS_ENABLED(CONFIG_DEBUG_UART) && IS_ENABLED(CONFIG_XPL_BUILD)) debug_uart_init();
return 0; @@ -339,7 +339,7 @@ uintptr_t get_stm32mp_bl2_dtb(void) return nt_fw_dtb; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { typedef void __noreturn (*image_entry_stm32_t)(u32 romapi); diff --git a/arch/arm/mach-stm32mp/stm32mp1/stm32mp15x.c b/arch/arm/mach-stm32mp/stm32mp1/stm32mp15x.c index f096fe538d8..b6a0ac14101 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/stm32mp15x.c +++ b/arch/arm/mach-stm32mp/stm32mp1/stm32mp15x.c @@ -214,13 +214,13 @@ static void update_bootmode(void) /* weak function: STM32MP15x mach init for boot without TFA */ void stm32mp_cpu_init(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { security_init(); update_bootmode(); }
/* reset copro state in SPL, when used, or in U-Boot */ - if (!IS_ENABLED(CONFIG_SPL) || IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_SPL) || IS_ENABLED(CONFIG_XPL_BUILD)) { /* Reset Coprocessor state unless it wakes up from Standby power mode */ if (!(readl(PWR_MCUCR) & PWR_MCUCR_SBF)) { writel(TAMP_COPRO_STATE_OFF, TAMP_COPRO_STATE); diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 3f83c0280ef..eb6a49119a1 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -29,7 +29,7 @@ ifndef CONFIG_ARM64 obj-y += timer.o endif
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += clock.o obj-$(CONFIG_MACH_SUNIV) += dram_suniv.o obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 2b64ddc0dc7..701899ee4b2 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -74,7 +74,7 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) } #endif /* CONFIG_ARM64 */
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static int gpio_init(void) { __maybe_unused uint val; @@ -209,7 +209,7 @@ static int spl_board_load_image(struct spl_image_info *spl_image, return 0; } SPL_LOAD_IMAGE_METHOD("FEL", 0, BOOT_DEVICE_BOARD, spl_board_load_image); -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#define SUNXI_INVALID_BOOT_SOURCE -1
@@ -258,7 +258,7 @@ static int sunxi_get_boot_source(void) * proper, just return MMC0 as a placeholder, for now. */ if (IS_ENABLED(CONFIG_MACH_SUNIV) && - !IS_ENABLED(CONFIG_SPL_BUILD)) + !IS_ENABLED(CONFIG_XPL_BUILD)) return SUNXI_BOOTED_FROM_MMC0;
if (IS_ENABLED(CONFIG_MACH_SUNIV)) @@ -314,7 +314,7 @@ uint32_t sunxi_get_boot_device(void) return -1; /* Never reached */ }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD uint32_t sunxi_get_spl_size(void) { struct boot_file_head *egon_head = (void *)SPL_ADDR; @@ -478,7 +478,7 @@ void board_init_f(ulong dummy) #endif sunxi_board_init(); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#if !CONFIG_IS_ENABLED(SYSRESET) void reset_cpu(void) diff --git a/arch/arm/mach-sunxi/clock_sun4i.c b/arch/arm/mach-sunxi/clock_sun4i.c index 6458d066f7e..1367b439b83 100644 --- a/arch/arm/mach-sunxi/clock_sun4i.c +++ b/arch/arm/mach-sunxi/clock_sun4i.c @@ -13,7 +13,7 @@ #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void clock_init_safe(void) { struct sunxi_ccm_reg * const ccm = @@ -175,7 +175,7 @@ void clock_set_pll1(unsigned int hz) &ccm->cpu_ahb_apb0_cfg); sdelay(20); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* video, DRAM, PLL_PERIPH clocks */ void clock_set_pll3(unsigned int clk) diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index cc2ee336416..b424a7893ea 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -3,7 +3,7 @@ #include <asm/arch/clock.h> #include <asm/arch/prcm.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void clock_init_safe(void) { struct sunxi_ccm_reg *const ccm = @@ -131,7 +131,7 @@ int clock_twi_onoff(int port, int state)
return 0; } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* PLL_PERIPH0 clock, used by the MMC driver */ unsigned int clock_get_pll6(void) diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 59f7e15ffe8..657736c7ac2 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -16,7 +16,7 @@ #include <linux/bitops.h> #include <linux/delay.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void clock_init_safe(void) { struct sunxi_ccm_reg * const ccm = @@ -169,7 +169,7 @@ void clock_set_pll1(unsigned int clk) &ccm->cpu_axi_cfg); } } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* video, DRAM, PLL_PERIPH clocks */ void clock_set_pll3(unsigned int clk) diff --git a/arch/arm/mach-sunxi/clock_sun8i_a83t.c b/arch/arm/mach-sunxi/clock_sun8i_a83t.c index c00d16a918d..f593749028c 100644 --- a/arch/arm/mach-sunxi/clock_sun8i_a83t.c +++ b/arch/arm/mach-sunxi/clock_sun8i_a83t.c @@ -15,7 +15,7 @@ #include <asm/arch/sys_proto.h> #include <linux/delay.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void clock_init_safe(void) { struct sunxi_ccm_reg * const ccm = @@ -100,7 +100,7 @@ void clock_set_pll1(unsigned int clk) CPU_CLK_SRC_PLL1 << C1_CPUX_CLK_SRC_SHIFT, &ccm->cpu_axi_cfg); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* DRAM and PLL_PERIPH0 clock (used by the MMC driver) */ void clock_set_pll5(unsigned int clk) diff --git a/arch/arm/mach-sunxi/clock_sun9i.c b/arch/arm/mach-sunxi/clock_sun9i.c index abdab405445..5f99071f21b 100644 --- a/arch/arm/mach-sunxi/clock_sun9i.c +++ b/arch/arm/mach-sunxi/clock_sun9i.c @@ -14,7 +14,7 @@ #include <asm/arch/prcm.h> #include <asm/arch/sys_proto.h>
static void clock_set_pll2(unsigned int clk) { @@ -188,7 +188,7 @@ int clock_twi_onoff(int port, int state)
/* PLL_PERIPH0 clock (used by the MMC driver) */ unsigned int clock_get_pll4_periph0(void) diff --git a/arch/arm/mach-sunxi/gtbus_sun9i.c b/arch/arm/mach-sunxi/gtbus_sun9i.c index a058fea6bef..aa93defb25e 100644 --- a/arch/arm/mach-sunxi/gtbus_sun9i.c +++ b/arch/arm/mach-sunxi/gtbus_sun9i.c @@ -11,7 +11,7 @@ #include <asm/arch/gtbus_sun9i.h> #include <asm/arch/sys_proto.h>
void gtbus_init(void) { diff --git a/arch/arm/mach-tegra/Makefile b/arch/arm/mach-tegra/Makefile index 1d22dc3942f..a87e6a6c352 100644 --- a/arch/arm/mach-tegra/Makefile +++ b/arch/arm/mach-tegra/Makefile @@ -5,7 +5,7 @@ # (C) Copyright 2000-2008 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-y += cpu.o else @@ -25,7 +25,7 @@ obj-y += dt-setup.o obj-$(CONFIG_TEGRA_CLOCK_SCALING) += emc.o obj-$(CONFIG_TEGRA_GPU) += gpu.o obj-$(CONFIG_TEGRA_IVC) += ivc.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ARMV7_PSCI) += psci.o endif obj-$(CONFIG_DISPLAY_CPUINFO) += sys_info.o diff --git a/arch/arm/mach-tegra/board.c b/arch/arm/mach-tegra/board.c index c382e042860..cc37878b8d1 100644 --- a/arch/arm/mach-tegra/board.c +++ b/arch/arm/mach-tegra/board.c @@ -47,7 +47,7 @@ enum {
static bool from_spl __section(".data");
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD void save_boot_params(unsigned long r0, unsigned long r1, unsigned long r2, unsigned long r3) { diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 7971e3b68d5..e68b8c894bb 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -46,7 +46,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* TODO(sjg@chromium.org): Remove once SPL supports device tree */ U_BOOT_DRVINFO(tegra_gpios) = { "gpio_tegra" diff --git a/arch/arm/mach-tegra/tegra114/Makefile b/arch/arm/mach-tegra/tegra114/Makefile index 346d6cb5696..f1c1042b4e2 100644 --- a/arch/arm/mach-tegra/tegra114/Makefile +++ b/arch/arm/mach-tegra/tegra114/Makefile @@ -2,6 +2,6 @@ # # Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved.
-obj-$(CONFIG_SPL_BUILD) += cpu.o +obj-$(CONFIG_XPL_BUILD) += cpu.o
obj-y += clock.o diff --git a/arch/arm/mach-tegra/tegra124/Makefile b/arch/arm/mach-tegra/tegra124/Makefile index 6ea511e7b25..dee790015a3 100644 --- a/arch/arm/mach-tegra/tegra124/Makefile +++ b/arch/arm/mach-tegra/tegra124/Makefile @@ -5,13 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
obj-y += clock.o obj-y += pmc.o obj-y += xusb-padctl.o obj-y += ../xusb-padctl-common.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ARMV7_NONSEC) += psci.o endif diff --git a/arch/arm/mach-tegra/tegra20/Makefile b/arch/arm/mach-tegra/tegra20/Makefile index c2ae98eb376..2774c866b02 100644 --- a/arch/arm/mach-tegra/tegra20/Makefile +++ b/arch/arm/mach-tegra/tegra20/Makefile @@ -2,7 +2,7 @@ # # (C) Copyright 2010,2011 Nvidia Corporation.
-obj-$(CONFIG_SPL_BUILD) += cpu.o +obj-$(CONFIG_XPL_BUILD) += cpu.o obj-$(CONFIG_$(SPL_)CMD_EBTUPDATE) += bct.o
# The AVP is ARMv4T architecture so we must use special compiler diff --git a/arch/arm/mach-tegra/tegra30/Makefile b/arch/arm/mach-tegra/tegra30/Makefile index ee0e6f5b948..5edc7c9ce7d 100644 --- a/arch/arm/mach-tegra/tegra30/Makefile +++ b/arch/arm/mach-tegra/tegra30/Makefile @@ -2,7 +2,7 @@ # # Copyright (c) 2010-2012, NVIDIA CORPORATION. All rights reserved.
obj-y += clock.o diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index 5172efac0c4..d1ec8195dcb 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += boards.o obj-y += spl_board_init.o diff --git a/arch/arm/mach-uniphier/arm32/Makefile b/arch/arm/mach-uniphier/arm32/Makefile index b41aba7e29a..c8ce67ac05a 100644 --- a/arch/arm/mach-uniphier/arm32/Makefile +++ b/arch/arm/mach-uniphier/arm32/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += lowlevel_init.o obj-$(CONFIG_DEBUG_LL) += debug_ll.o else diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index 1e6bc8433f7..9d0fe5c8583 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -214,7 +214,7 @@ int uniphier_boot_from_backend(void) return !!(readl(sg_base + SG_PINMON0) & BIT(27)); }
static int do_pinmon(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -267,4 +267,4 @@ U_BOOT_CMD( "" );
-#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/arch/arm/mach-uniphier/clk/Makefile b/arch/arm/mach-uniphier/clk/Makefile index c49e44754c0..0e47beb5f22 100644 --- a/arch/arm/mach-uniphier/clk/Makefile +++ b/arch/arm/mach-uniphier/clk/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_ARCH_UNIPHIER_LD4) += clk-early-ld4.o clk-dram-ld4.o dpll-ld4.o obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += clk-early-ld4.o clk-dram-ld4.o dpll-pro4.o diff --git a/arch/arm/mach-uniphier/debug-uart/Makefile b/arch/arm/mach-uniphier/debug-uart/Makefile index 81e9314a50d..4202cb3503b 100644 --- a/arch/arm/mach-uniphier/debug-uart/Makefile +++ b/arch/arm/mach-uniphier/debug-uart/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_ARCH_UNIPHIER_LD4) += debug-uart-ld4.o obj-$(CONFIG_ARCH_UNIPHIER_PRO4) += debug-uart-pro4.o obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += debug-uart-sld8.o diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart.c b/arch/arm/mach-uniphier/debug-uart/debug-uart.c index 1ba012ca45d..6836eb63bfa 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart.c @@ -26,7 +26,7 @@ static void _debug_uart_putc(int c) writel(c, base + UNIPHIER_UART_TX); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void sg_set_pinsel(unsigned int pin, unsigned int muxval, unsigned int mux_bits, unsigned int reg_stride) { @@ -56,7 +56,7 @@ void sg_set_iectrl(unsigned int pin)
void _debug_uart_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void __iomem *base = (void __iomem *)CONFIG_VAL(DEBUG_UART_BASE); unsigned int divisor;
diff --git a/arch/arm/mach-uniphier/dram/Makefile b/arch/arm/mach-uniphier/dram/Makefile index 7d11315d07f..36188c38cf9 100644 --- a/arch/arm/mach-uniphier/dram/Makefile +++ b/arch/arm/mach-uniphier/dram/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_ARCH_UNIPHIER_LD4) += umc-ld4.o \ ddrphy-training.o ddrphy-ld4.o diff --git a/arch/arm/mach-zynq/Makefile b/arch/arm/mach-zynq/Makefile index d9b2b999e10..8545331c54a 100644 --- a/arch/arm/mach-zynq/Makefile +++ b/arch/arm/mach-zynq/Makefile @@ -12,4 +12,4 @@ obj-y += slcr.o obj-y += clk.o obj-y += lowlevel_init.o AFLAGS_lowlevel_init.o := -mfpu=neon -obj-$(CONFIG_SPL_BUILD) += spl.o ps7_spl_init.o +obj-$(CONFIG_XPL_BUILD) += spl.o ps7_spl_init.o diff --git a/arch/arm/mach-zynq/cpu.c b/arch/arm/mach-zynq/cpu.c index 5b6d765099d..74dddc25988 100644 --- a/arch/arm/mach-zynq/cpu.c +++ b/arch/arm/mach-zynq/cpu.c @@ -52,7 +52,7 @@ static const struct { int arch_cpu_init(void) { zynq_slcr_unlock(); -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* Device config APB, unlock the PCAP */ writel(0x757BDF0D, &devcfg_base->unlock); writel(0xFFFFFFFF, &devcfg_base->rom_shadow); diff --git a/arch/arm/mach-zynqmp/Makefile b/arch/arm/mach-zynqmp/Makefile index 38be1627eeb..7c95f32a5c3 100644 --- a/arch/arm/mach-zynqmp/Makefile +++ b/arch/arm/mach-zynqmp/Makefile @@ -5,10 +5,10 @@
obj-y += aes.o clk.o cpu.o obj-$(CONFIG_MP) += mp.o -obj-$(CONFIG_SPL_BUILD) += spl.o handoff.o psu_spl_init.o +obj-$(CONFIG_XPL_BUILD) += spl.o handoff.o psu_spl_init.o obj-$(CONFIG_SPL_ZYNQMP_DRAM_ECC_INIT) += ecc_spl_init.o obj-$(CONFIG_$(SPL_)ZYNQMP_PSU_INIT_ENABLED) += psu_spl_init.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_ZYNQMP) += zynqmp.o -endif # !CONFIG_SPL_BUILD +endif # !CONFIG_XPL_BUILD diff --git a/arch/arm/mach-zynqmp/cpu.c b/arch/arm/mach-zynqmp/cpu.c index 07668c94689..24fd5751216 100644 --- a/arch/arm/mach-zynqmp/cpu.c +++ b/arch/arm/mach-zynqmp/cpu.c @@ -187,7 +187,7 @@ int zynqmp_mmio_write(const u32 address, const u32 mask, const u32 value) { - if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) + if (IS_ENABLED(CONFIG_XPL_BUILD) || current_el() == 3) return zynqmp_mmio_rawwrite(address, mask, value); #if defined(CONFIG_ZYNQMP_FIRMWARE) else @@ -205,7 +205,7 @@ int zynqmp_mmio_read(const u32 address, u32 *value) if (!value) return ret;
- if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (IS_ENABLED(CONFIG_XPL_BUILD) || current_el() == 3) { ret = zynqmp_mmio_rawread(address, value); } #if defined(CONFIG_ZYNQMP_FIRMWARE) diff --git a/arch/microblaze/config.mk b/arch/microblaze/config.mk index 64c3f313195..53244046f19 100644 --- a/arch/microblaze/config.mk +++ b/arch/microblaze/config.mk @@ -11,7 +11,7 @@ PLATFORM_CPPFLAGS += -fdata-sections -ffunction-sections
LDFLAGS_FINAL += --gc-sections
-ifeq ($(CONFIG_SPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD),) PLATFORM_CPPFLAGS += -fPIC LDFLAGS_u-boot += -pic endif diff --git a/arch/microblaze/cpu/Makefile b/arch/microblaze/cpu/Makefile index b8c1dcbe14f..4d4919c3e3f 100644 --- a/arch/microblaze/cpu/Makefile +++ b/arch/microblaze/cpu/Makefile @@ -7,4 +7,4 @@ extra-y = start.o obj-y = irq.o obj-y += interrupts.o cache.o exception.o cpuinfo.o relocate.o obj-$(CONFIG_XILINX_MICROBLAZE0_PVR) += pvr.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/arch/microblaze/cpu/start.S b/arch/microblaze/cpu/start.S index c1e0fcda0a4..69c4efdad7f 100644 --- a/arch/microblaze/cpu/start.S +++ b/arch/microblaze/cpu/start.S @@ -26,7 +26,7 @@ _start: mts rslr, r0 mts rshr, r20
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) addi r1, r0, CONFIG_SPL_STACK #else add r1, r0, r20 @@ -83,7 +83,7 @@ uboot_sym_start: brlid r15, board_init_f_init_reserve nop
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) /* Setup vectors with pre-relocation symbols */ or r5, r0, r0 brlid r15, __setup_exceptions @@ -122,7 +122,7 @@ clear_bss: brlid r15, debug_uart_init nop #endif -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD or r5, r0, r0 /* flags - empty */ bri board_init_f #else @@ -130,7 +130,7 @@ clear_bss: #endif 1: bri 1b
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD .text .ent __setup_exceptions .align 2 diff --git a/arch/mips/Makefile b/arch/mips/Makefile index a007914590f..453c7885075 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -2,7 +2,7 @@
head-y := arch/mips/cpu/start.o
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) head-$(CONFIG_ARCH_JZ47XX) := arch/mips/mach-jz47xx/start.o head-$(CONFIG_SOC_MT7621) := arch/mips/mach-mtmips/mt7621/spl/start.o endif diff --git a/arch/mips/config.mk b/arch/mips/config.mk index 745f03190e9..ad2ea11f72c 100644 --- a/arch/mips/config.mk +++ b/arch/mips/config.mk @@ -53,7 +53,7 @@ PLATFORM_ELFFLAGS += -B mips $(OBJCOPYFLAGS) # LDFLAGS_vmlinux += -G 0 -static -n -nostdlib # MODFLAGS += -mlong-calls # -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD OBJCOPYFLAGS += -j .data.reloc -j .dtb.init.rodata LDFLAGS_FINAL += --emit-relocs endif diff --git a/arch/mips/lib/Makefile b/arch/mips/lib/Makefile index 1621cc9a1ff..79841dbe5ed 100644 --- a/arch/mips/lib/Makefile +++ b/arch/mips/lib/Makefile @@ -12,6 +12,6 @@ obj-y += traps.o
obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_GO) += boot.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o
lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashldi3.o ashrdi3.o lshrdi3.o udivdi3.o diff --git a/arch/mips/mach-jz47xx/Makefile b/arch/mips/mach-jz47xx/Makefile index dbb8229f785..5621a09b6dd 100644 --- a/arch/mips/mach-jz47xx/Makefile +++ b/arch/mips/mach-jz47xx/Makefile @@ -1,5 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+
-extra-$(CONFIG_SPL_BUILD) := start.o +extra-$(CONFIG_XPL_BUILD) := start.o
obj-$(CONFIG_SOC_JZ4780) += jz4780/ diff --git a/arch/mips/mach-jz47xx/include/mach/jz4780.h b/arch/mips/mach-jz47xx/include/mach/jz4780.h index 880445dac39..9f9a8cf9438 100644 --- a/arch/mips/mach-jz47xx/include/mach/jz4780.h +++ b/arch/mips/mach-jz47xx/include/mach/jz4780.h @@ -94,7 +94,7 @@ void jz4780_efuse_init(u32 ahb2_rate);
void jz4780_tcu_wdt_start(void);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD int jz_mmc_init(void __iomem *base); #endif
diff --git a/arch/mips/mach-jz47xx/jz4780/jz4780.c b/arch/mips/mach-jz47xx/jz4780/jz4780.c index 1d6fb6a4e27..504fd27d285 100644 --- a/arch/mips/mach-jz47xx/jz4780/jz4780.c +++ b/arch/mips/mach-jz47xx/jz4780/jz4780.c @@ -19,7 +19,7 @@ #include <mmc.h> #include <spl.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* Pointer to the global data structure for SPL */ DECLARE_GLOBAL_DATA_PTR; gd_t gdata __section(".bss"); @@ -73,7 +73,7 @@ void board_init_f(ulong dummy)
hang(); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { diff --git a/arch/mips/mach-jz47xx/start.S b/arch/mips/mach-jz47xx/start.S index 760d0215493..0d40e637a68 100644 --- a/arch/mips/mach-jz47xx/start.S +++ b/arch/mips/mach-jz47xx/start.S @@ -18,7 +18,7 @@ .globl _start .text _start: -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD
/* magic value ("MSPL") */ .word 0x4d53504c @@ -95,4 +95,4 @@ enable_caches: .end enable_caches
#endif /* CONFIG_SOC_JZ4780 */ -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index 19f1e07033e..2f35b1a925c 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -5,7 +5,7 @@ obj-y += cpu.o ifneq ($(CONFIG_SOC_MT7621),y) obj-y += ddr_init.o obj-y += ddr_cal.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o endif
obj-$(CONFIG_SOC_MT7620) += mt7620/ diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach-mtmips/cpu.c index 243938a0ebb..982a5889df8 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -21,7 +21,7 @@ int dram_init(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int last_stage_init(void) { void *src, *dst; diff --git a/arch/mips/mach-mtmips/mt7620/Makefile b/arch/mips/mach-mtmips/mt7620/Makefile index 649f6c3798f..d2d79e3424b 100644 --- a/arch/mips/mach-mtmips/mt7620/Makefile +++ b/arch/mips/mach-mtmips/mt7620/Makefile @@ -5,6 +5,6 @@ obj-y += init.o obj-y += dram.o obj-y += serial.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += sysc.o endif diff --git a/arch/mips/mach-mtmips/mt7621/Makefile b/arch/mips/mach-mtmips/mt7621/Makefile index bf1b0bb688b..f48083e3559 100644 --- a/arch/mips/mach-mtmips/mt7621/Makefile +++ b/arch/mips/mach-mtmips/mt7621/Makefile @@ -3,7 +3,7 @@ obj-y += init.o obj-y += serial.o
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) ifeq ($(CONFIG_TPL_BUILD),y) obj-y += tpl/ else diff --git a/arch/mips/mach-mtmips/mt7628/Makefile b/arch/mips/mach-mtmips/mt7628/Makefile index 7e139d5adfd..63acf54536b 100644 --- a/arch/mips/mach-mtmips/mt7628/Makefile +++ b/arch/mips/mach-mtmips/mt7628/Makefile @@ -3,4 +3,4 @@ obj-y += lowlevel_init.o obj-y += init.o obj-y += ddr.o -obj-$(CONFIG_SPL_BUILD) += serial.o +obj-$(CONFIG_XPL_BUILD) += serial.o diff --git a/arch/powerpc/config.mk b/arch/powerpc/config.mk index 725a4f48aad..dd0124cace1 100644 --- a/arch/powerpc/config.mk +++ b/arch/powerpc/config.mk @@ -27,7 +27,7 @@ PLATFORM_CPPFLAGS+= -D__PPC__ endif
# Only test once -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) archprepare: checkgcc4
# GCC 3.x is reported to have problems generating the type of relocation diff --git a/arch/powerpc/cpu/mpc83xx/Makefile b/arch/powerpc/cpu/mpc83xx/Makefile index 1255f533e34..9974239f881 100644 --- a/arch/powerpc/cpu/mpc83xx/Makefile +++ b/arch/powerpc/cpu/mpc83xx/Makefile @@ -7,7 +7,7 @@
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y diff --git a/arch/powerpc/cpu/mpc83xx/start.S b/arch/powerpc/cpu/mpc83xx/start.S index ceb54867894..78762f000df 100644 --- a/arch/powerpc/cpu/mpc83xx/start.S +++ b/arch/powerpc/cpu/mpc83xx/start.S @@ -41,11 +41,11 @@ #endif
#if defined(CONFIG_NAND_SPL) || \ - (defined(CONFIG_SPL_BUILD) && CONFIG_IS_ENABLED(INIT_MINIMAL)) + (defined(CONFIG_XPL_BUILD) && CONFIG_IS_ENABLED(INIT_MINIMAL)) #define MINIMAL_SPL #endif
-#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NAND_SPL) && \ +#if !defined(CONFIG_XPL_BUILD) && !defined(CONFIG_NAND_SPL) && \ !defined(CONFIG_SYS_RAMBOOT) #define CFG_SYS_FLASHBOOT #endif @@ -168,7 +168,7 @@ _start: /* time t 0 */ /* Initialise the E300 processor core */ /*------------------------------------------*/
-#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_MPC83XX_WAIT_FOR_NAND)) || \ +#if (defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_MPC83XX_WAIT_FOR_NAND)) || \ defined(CONFIG_NAND_SPL) /* The FCM begins execution after only the first page * is loaded. Wait for the rest before branching diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index f3ee7d34949..bf74228efde 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -8,7 +8,7 @@
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y @@ -26,7 +26,7 @@ else
obj-$(CONFIG_MP) += release.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_ERRATA) += cmd_errata.o endif
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 574510fa088..75bfc07fe97 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -179,7 +179,7 @@ void cpu_init_early_f(void *fdt) invalidate_tlb(1);
#if defined(CONFIG_SYS_PPC_E500_DEBUG_TLB) && \ - !(CONFIG_IS_ENABLED(INIT_MINIMAL) && defined(CONFIG_SPL_BUILD)) && \ + !(CONFIG_IS_ENABLED(INIT_MINIMAL) && defined(CONFIG_XPL_BUILD)) && \ !defined(CONFIG_NAND_SPL) disable_tlb(CONFIG_SYS_PPC_E500_DEBUG_TLB); #endif diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 3e24a90233c..89bce5bed69 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -28,7 +28,7 @@ #define LAW_EN 0x80000000
@@ -58,16 +58,16 @@ END_GOT
#ifdef CONFIG_FSL_PREPBL_ESDHC_BOOT_SECTOR -#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD)
/* Maximal size of the image */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define MAX_IMAGE_SIZE (CONFIG_SPL_MAX_SIZE - (CONFIG_FSL_PREPBL_ESDHC_BOOT_SECTOR_DATA * 512)) #else #define MAX_IMAGE_SIZE CONFIG_SYS_L2_SIZE #endif
-#if defined(CONFIG_SPL_BUILD) && CONFIG_SPL_MAX_SIZE < CONFIG_FSL_PREPBL_ESDHC_BOOT_SECTOR_DATA * 512 +#if defined(CONFIG_XPL_BUILD) && CONFIG_SPL_MAX_SIZE < CONFIG_FSL_PREPBL_ESDHC_BOOT_SECTOR_DATA * 512 #error "CONFIG_SPL_MAX_SIZE is too small for CONFIG_FSL_PREPBL_ESDHC_BOOT_SECTOR_DATA" #endif
@@ -1138,10 +1138,10 @@ create_init_ram_area: /* * For Targets without CONFIG_SPL like P3, P5 * and for targets with CONFIG_SPL like T1, T2, T4, only for - * u-boot-spl i.e. CONFIG_SPL_BUILD + * u-boot-spl i.e. CONFIG_XPL_BUILD */ #elif defined(CONFIG_RAMBOOT_PBL) && defined(CONFIG_NXP_ESBC) && \ - (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD)) /* create a temp mapping in AS = 1 for mapping CONFIG_VAL(SYS_MONITOR_BASE) * to L3 Address configured by PBL for ISBC code */ @@ -1617,7 +1617,7 @@ relocate_code: mr r10,r5 /* Save copy of Destination Address */
GET_GOT -#if !defined(CONFIG_SPL_SKIP_RELOCATE) || !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_SPL_SKIP_RELOCATE) || !defined(CONFIG_XPL_BUILD) mr r3,r5 /* Destination Address */ lis r4,CONFIG_VAL(SYS_MONITOR_BASE)@h /* Source Address */ ori r4,r4,CONFIG_VAL(SYS_MONITOR_BASE)@l diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 32b68a169a4..415ab1096c6 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -45,7 +45,7 @@ __weak void init_tlbs(void) }
#if !defined(CONFIG_NAND_SPL) && \ - (!defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) + (!defined(CONFIG_XPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) void read_tlbcam_entry(int idx, u32 *valid, u32 *tsize, unsigned long *epn, phys_addr_t *rpn) { @@ -313,7 +313,7 @@ unsigned int setup_ddr_tlbs_phys(phys_addr_t p_addr, print_size(memsize > CFG_MAX_MEM_MAPPED ? memsize - CFG_MAX_MEM_MAPPED + size : size, " of DDR memory left unmapped in U-Boot\n"); -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD puts(" "); #endif } diff --git a/arch/powerpc/cpu/mpc8xxx/Makefile b/arch/powerpc/cpu/mpc8xxx/Makefile index e3a536d4f8c..a44b5165d74 100644 --- a/arch/powerpc/cpu/mpc8xxx/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/Makefile @@ -4,7 +4,7 @@
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c b/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c index 3a82e60a247..638c3a6fee5 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c @@ -241,7 +241,7 @@ int pamu_init(void) spaact_size = sizeof(struct paace) * NUM_SPAACT_ENTRIES;
/* Allocate space for Primary PAACT Table */ -#if (defined(CONFIG_SPL_BUILD) && defined(CFG_SPL_PPAACT_ADDR)) +#if (defined(CONFIG_XPL_BUILD) && defined(CFG_SPL_PPAACT_ADDR)) ppaact = (void *)CFG_SPL_PPAACT_ADDR; #else ppaact = memalign(PAMU_TABLE_ALIGNMENT, ppaact_size); @@ -251,7 +251,7 @@ int pamu_init(void) memset(ppaact, 0, ppaact_size);
/* Allocate space for Secondary PAACT Table */ -#if (defined(CONFIG_SPL_BUILD) && defined(CFG_SPL_SPAACT_ADDR)) +#if (defined(CONFIG_XPL_BUILD) && defined(CFG_SPL_SPAACT_ADDR)) sec = (void *)CFG_SPL_SPAACT_ADDR; #else sec = memalign(PAMU_TABLE_ALIGNMENT, spaact_size); diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index b4695cc99cb..3fd80eb29c0 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -78,7 +78,7 @@ void disable_law(u8 idx) }
#if !defined(CONFIG_NAND_SPL) && \ - (!defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) + (!defined(CONFIG_XPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) static int get_law_entry(u8 i, struct law_entry *e) { u32 lawar; @@ -109,7 +109,7 @@ int set_next_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) }
#if !defined(CONFIG_NAND_SPL) && \ - (!defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) + (!defined(CONFIG_XPL_BUILD) || !CONFIG_IS_ENABLED(INIT_MINIMAL)) int set_last_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) { u32 idx; diff --git a/arch/powerpc/cpu/mpc8xxx/pamu_table.c b/arch/powerpc/cpu/mpc8xxx/pamu_table.c index 831a11736cc..bd3f69b469e 100644 --- a/arch/powerpc/cpu/mpc8xxx/pamu_table.c +++ b/arch/powerpc/cpu/mpc8xxx/pamu_table.c @@ -28,7 +28,7 @@ void construct_pamu_addr_table(struct pamu_addr_tbl *tbl, int *num_entries)
i++; #endif -#if (defined(CONFIG_SPL_BUILD) && (CFG_SYS_INIT_L3_VADDR)) +#if (defined(CONFIG_XPL_BUILD) && (CFG_SYS_INIT_L3_VADDR)) tbl->start_addr[i] = (uint64_t)virt_to_phys((void *)CFG_SYS_INIT_L3_VADDR); tbl->size[i] = 256 * 1024; /* 256K CPC flash */ diff --git a/arch/powerpc/include/asm/fsl_secure_boot.h b/arch/powerpc/include/asm/fsl_secure_boot.h index 221f9d842a8..f12830984c6 100644 --- a/arch/powerpc/include/asm/fsl_secure_boot.h +++ b/arch/powerpc/include/asm/fsl_secure_boot.h @@ -36,7 +36,7 @@ #endif /* #ifdef CONFIG_NXP_ESBC */
#ifdef CONFIG_CHAIN_OF_TRUST -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * PPAACT and SPAACT table for PAMU must be placed on DDR after DDR init * due to space crunch on CPC and thus malloc will not work. @@ -45,10 +45,10 @@ #define CFG_SPL_SPAACT_ADDR 0x2f000000 #define CFG_SPL_JR0_LIODN_S 454 #define CFG_SPL_JR0_LIODN_NS 458 -#endif /* ifdef CONFIG_SPL_BUILD */ +#endif /* ifdef CONFIG_XPL_BUILD */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #include <config_fsl_chain_trust.h> -#endif /* #ifndef CONFIG_SPL_BUILD */ +#endif /* #ifndef CONFIG_XPL_BUILD */ #endif /* #ifdef CONFIG_CHAIN_OF_TRUST */ #endif diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index ecc2aba8f3c..f797f8cee66 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -9,7 +9,7 @@ lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _lshrdi3.o
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y @@ -45,6 +45,6 @@ obj-y += time.o obj-y += traps.o endif # not minimal
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_$(SPL_TPL)_FRAMEWORK) += spl.o endif diff --git a/arch/riscv/cpu/fu540/Makefile b/arch/riscv/cpu/fu540/Makefile index 043fb961a51..69759c55658 100644 --- a/arch/riscv/cpu/fu540/Makefile +++ b/arch/riscv/cpu/fu540/Makefile @@ -3,7 +3,7 @@ # Copyright (C) 2020 SiFive, Inc # Pragnesh Patel pragnesh.patel@sifive.com
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-y += spl.o else obj-y += dram.o diff --git a/arch/riscv/cpu/fu740/Makefile b/arch/riscv/cpu/fu740/Makefile index 1d1ad98ba7c..9071c831992 100644 --- a/arch/riscv/cpu/fu740/Makefile +++ b/arch/riscv/cpu/fu740/Makefile @@ -3,7 +3,7 @@ # Copyright (C) 2020-2021 SiFive, Inc # Pragnesh Patel pragnesh.patel@sifive.com
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-y += spl.o else obj-y += dram.o diff --git a/arch/riscv/cpu/jh7110/Makefile b/arch/riscv/cpu/jh7110/Makefile index 951c95631e9..0939c1061d0 100644 --- a/arch/riscv/cpu/jh7110/Makefile +++ b/arch/riscv/cpu/jh7110/Makefile @@ -2,7 +2,7 @@ # # Copyright (C) 2022 StarFive Technology Co., Ltd.
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-y += spl.o else obj-y += cpu.o diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 8e58f641f1b..3f78932aa9d 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -90,7 +90,7 @@ _start: * Set stackpointer in internal/ex RAM to call board_init_f */ call_board_init_f: -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_STACK) li t0, CONFIG_SPL_STACK #else li t0, SYS_INIT_SP_ADDR @@ -218,7 +218,7 @@ wait_for_gd_init: la t5, board_init_f jalr t5 /* jump to board_init_f() */
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD spl_clear_bss: la t0, __bss_start la t1, __bss_end @@ -271,7 +271,7 @@ spl_call_board_init_r: j board_init_r #endif
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) /* * void relocate_code(addr_sp, gd, addr_moni) * @@ -420,7 +420,7 @@ call_board_init_r: * jump to it ... */ jr t4 /* jump to board_init_r() */ -#endif /* !defined(CONFIG_SPL_BUILD) */ +#endif /* !defined(CONFIG_XPL_BUILD) */
#if CONFIG_IS_ENABLED(SMP) hart_out_of_bounds_loop: diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 65dc49f6fa5..3bc34cd61fb 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -24,7 +24,7 @@ obj-y += reset.o endif obj-y += setjmp.o obj-$(CONFIG_$(SPL_)SMP) += smp.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o obj-y += fdt_fixup.o obj-$(CONFIG_$(SPL)CMD_BDI) += bdinfo.o
diff --git a/arch/riscv/lib/sifive_cache.c b/arch/riscv/lib/sifive_cache.c index d8fe1dfa958..d74544b93d8 100644 --- a/arch/riscv/lib/sifive_cache.c +++ b/arch/riscv/lib/sifive_cache.c @@ -10,7 +10,7 @@ #include <dm/device-internal.h> #include <dm/uclass-internal.h>
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD void enable_caches(void) { struct udevice *dev; @@ -45,4 +45,4 @@ void enable_caches(void)
probe_cache_device(DM_DRIVER_GET(sifive_pl2), dev); } -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/arch/sandbox/cpu/Makefile b/arch/sandbox/cpu/Makefile index 7c5c52652f5..bfcdc335d32 100644 --- a/arch/sandbox/cpu/Makefile +++ b/arch/sandbox/cpu/Makefile @@ -8,7 +8,7 @@ obj-y := cache.o cpu.o state.o extra-y := start.o os.o extra-$(CONFIG_SANDBOX_SDL) += sdl.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o obj-$(CONFIG_ETH_SANDBOX_RAW) += eth-raw-os.o
# os.c is build in the system environment, so needs standard includes diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index 51ce40e7f08..06f8c13fab9 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -165,7 +165,7 @@ phys_addr_t virt_to_phys(void *ptr)
void *map_physmem(phys_addr_t paddr, unsigned long len, unsigned long flags) { -#if defined(CONFIG_PCI) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_PCI) && !defined(CONFIG_XPL_BUILD) unsigned long plen = len; void *ptr;
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 9ad5d46271a..ef587ef48b0 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -129,7 +129,7 @@ static int sandbox_cmdline_cb_help(struct sandbox_state *state, const char *arg) } SANDBOX_CMDLINE_OPT_SHORT(help, 'h', 0, "Display help");
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int sandbox_main_loop_init(void) { struct sandbox_state *state = state_get_current(); diff --git a/arch/x86/Makefile b/arch/x86/Makefile index f1afc74fff8..3c8c541efbc 100644 --- a/arch/x86/Makefile +++ b/arch/x86/Makefile @@ -10,7 +10,7 @@ else ifndef CONFIG_SPL head-y := arch/x86/cpu/start.o else -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD head-y = arch/x86/cpu/start_from_tpl.o else head-y = arch/x86/cpu/start_from_spl.o diff --git a/arch/x86/config.mk b/arch/x86/config.mk index 2e3a7119e79..6d4839dfb38 100644 --- a/arch/x86/config.mk +++ b/arch/x86/config.mk @@ -10,7 +10,7 @@ PF_CPPFLAGS_X86 := $(call cc-option, -fno-toplevel-reorder, \ PLATFORM_CPPFLAGS += $(PF_CPPFLAGS_X86) PLATFORM_CPPFLAGS += -fno-dwarf2-cfi-asm
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD IS_32BIT := y else ifndef CONFIG_X86_64 @@ -26,7 +26,7 @@ endif ifeq ($(IS_32BIT),y) PLATFORM_CPPFLAGS += -march=i386 -m32 else -PLATFORM_CPPFLAGS += $(if $(CONFIG_SPL_BUILD),,-fpic) -fno-common -march=core2 -m64 +PLATFORM_CPPFLAGS += $(if $(CONFIG_XPL_BUILD),,-fpic) -fno-common -march=core2 -m64
ifndef CONFIG_X86_HARDFP PLATFORM_CPPFLAGS += -mno-mmx -mno-sse @@ -86,12 +86,12 @@ ifeq ($(IS_32BIT),y) PLATFORM_CPPFLAGS += -mregparm=3 endif KBUILD_LDFLAGS += --emit-relocs -LDFLAGS_FINAL += --gc-sections $(if $(CONFIG_SPL_BUILD),,-pie) +LDFLAGS_FINAL += --gc-sections $(if $(CONFIG_XPL_BUILD),,-pie)
endif
ifdef CONFIG_X86_64 -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD PLATFORM_CPPFLAGS += -D__x86_64__ else PLATFORM_CPPFLAGS += -D__I386__ diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 16e67e3da24..c21d6d6d438 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -15,7 +15,7 @@ else ifndef CONFIG_SPL extra-y = start.o else -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD extra-y = start_from_tpl.o else extra-y = start_from_spl.o diff --git a/arch/x86/cpu/apollolake/Makefile b/arch/x86/cpu/apollolake/Makefile index 2ddf4af62c5..f481f40d9bb 100644 --- a/arch/x86/cpu/apollolake/Makefile +++ b/arch/x86/cpu/apollolake/Makefile @@ -2,20 +2,20 @@ # # Copyright 2019 Google LLC
-obj-$(CONFIG_SPL_BUILD) += cpu_spl.o -obj-$(CONFIG_SPL_BUILD) += spl.o -obj-$(CONFIG_SPL_BUILD) += systemagent.o +obj-$(CONFIG_XPL_BUILD) += cpu_spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += systemagent.o obj-y += cpu_common.o
ifndef CONFIG_TPL_BUILD obj-y += cpu.o obj-y += punit.o obj-y += fsp_bindings.o -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += fsp_m.o endif endif -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += acpi.o obj-y += fsp_s.o endif diff --git a/arch/x86/cpu/apollolake/fsp_bindings.c b/arch/x86/cpu/apollolake/fsp_bindings.c index f6fbddce922..b4bb677f5cd 100644 --- a/arch/x86/cpu/apollolake/fsp_bindings.c +++ b/arch/x86/cpu/apollolake/fsp_bindings.c @@ -247,7 +247,7 @@ static int fsp_update_config_from_dtb(ofnode node, u8 *cfg, return 0; }
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) const struct fsp_binding fsp_m_bindings[] = { { .type = FSP_UINT32, @@ -653,7 +653,7 @@ int fsp_m_update_config_from_dtb(ofnode node, struct fsp_m_config *cfg) } #endif
-#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_TPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) const struct fsp_binding fsp_s_bindings[] = { { .type = FSP_UINT8, diff --git a/arch/x86/cpu/broadwell/Makefile b/arch/x86/cpu/broadwell/Makefile index 3e1f76d6118..6c6d0edac9b 100644 --- a/arch/x86/cpu/broadwell/Makefile +++ b/arch/x86/cpu/broadwell/Makefile @@ -6,12 +6,12 @@ obj-$(CONFIG_$(SPL_TPL_)X86_16BIT_INIT) += cpu.o obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += cpu_full.o
ifdef CONFIG_SPL -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += cpu_from_spl.o obj-y += cpu_full.o obj-y += refcode.o endif -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD # obj-y += cpu_from_spl.o obj-y += adsp.o obj-y += sata.o diff --git a/arch/x86/cpu/broadwell/cpu_full.c b/arch/x86/cpu/broadwell/cpu_full.c index c43fb7a608b..529dab18d5d 100644 --- a/arch/x86/cpu/broadwell/cpu_full.c +++ b/arch/x86/cpu/broadwell/cpu_full.c @@ -84,7 +84,7 @@ static const u8 power_limit_time_msr_to_sec[] = { [0x11] = 128, };
-#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_TPL_BUILD) +#if defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) int arch_cpu_init(void) { return 0; diff --git a/arch/x86/cpu/broadwell/pch.c b/arch/x86/cpu/broadwell/pch.c index 2c8b7380d96..5b6147432a7 100644 --- a/arch/x86/cpu/broadwell/pch.c +++ b/arch/x86/cpu/broadwell/pch.c @@ -606,7 +606,7 @@ static int broadwell_pch_probe(struct udevice *dev) return broadwell_pch_early_init(dev); else return broadwell_pch_init(dev); - } else if (IS_ENABLED(CONFIG_SPL) && !IS_ENABLED(CONFIG_SPL_BUILD)) { + } else if (IS_ENABLED(CONFIG_SPL) && !IS_ENABLED(CONFIG_XPL_BUILD)) { return broadwell_pch_init(dev); } else { return 0; diff --git a/arch/x86/cpu/config.mk b/arch/x86/cpu/config.mk index 87e242a2065..6acdf9b3b23 100644 --- a/arch/x86/cpu/config.mk +++ b/arch/x86/cpu/config.mk @@ -9,7 +9,7 @@ LDPPFLAGS += -DRESET_VEC_LOC=$(CONFIG_RESET_VEC_LOC) LDPPFLAGS += -DSTART_16=$(CONFIG_SYS_X86_START16)
ifdef CONFIG_X86_64 -ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_EFI_APP),) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_EFI_APP),) LDSCRIPT = $(srctree)/arch/x86/cpu/u-boot-64.lds endif endif diff --git a/arch/x86/cpu/coreboot/Makefile b/arch/x86/cpu/coreboot/Makefile index a6cdb9a1485..a6c7d0e56d5 100644 --- a/arch/x86/cpu/coreboot/Makefile +++ b/arch/x86/cpu/coreboot/Makefile @@ -14,7 +14,7 @@ ifndef CONFIG_SPL obj-y += car.o endif -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += coreboot_spl.o else obj-y += sdram.o diff --git a/arch/x86/cpu/coreboot/coreboot.c b/arch/x86/cpu/coreboot/coreboot.c index d474c79e25e..c3d7442b4a8 100644 --- a/arch/x86/cpu/coreboot/coreboot.c +++ b/arch/x86/cpu/coreboot/coreboot.c @@ -82,7 +82,7 @@ static void board_final_init(void)
static int last_stage_init(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return 0;
board_final_init(); diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index ad21fdb457a..fbd23af6ce9 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -185,7 +185,7 @@ void show_boot_progress(int val) #endif
#if !defined(CONFIG_SYS_COREBOOT) && !defined(CONFIG_EFI_STUB) && \ - !defined(CONFIG_SPL_BUILD) + !defined(CONFIG_XPL_BUILD) /* * Implement a weak default function for boards that need to do some final init * before the system is ready. diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index 1dc17b45879..2e312a30353 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -11,13 +11,13 @@ obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += report_platform.o obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += mrc.o endif
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_INTEL_GMA_ACPI) += intel_opregion.o endif
ifdef CONFIG_INTEL_CAR_CQOS obj-$(CONFIG_TPL_BUILD) += car2.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += car2_uninit.o endif endif @@ -38,7 +38,7 @@ obj-$(CONFIG_HAVE_ITSS) += itss.o obj-$(CONFIG_HAVE_P2SB) += p2sb.o
ifdef CONFIG_SPL -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD ifndef CONFIG_SYS_COREBOOT obj-y += cpu_from_spl.o endif diff --git a/arch/x86/cpu/ivybridge/Makefile b/arch/x86/cpu/ivybridge/Makefile index 716134e9ff3..1f3b0c092f1 100644 --- a/arch/x86/cpu/ivybridge/Makefile +++ b/arch/x86/cpu/ivybridge/Makefile @@ -9,7 +9,7 @@ obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += cpu.o obj-y += early_me.o obj-y += lpc.o obj-y += northbridge.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += sata.o endif obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += sdram.o diff --git a/arch/x86/include/asm/string.h b/arch/x86/include/asm/string.h index 5c49b0f009b..f6836b74488 100644 --- a/arch/x86/include/asm/string.h +++ b/arch/x86/include/asm/string.h @@ -18,7 +18,7 @@ extern char *strchr(const char *s, int c); * Our assembly routines do not work on in 64-bit mode and we don't do a lot of * copying in SPL, so code size is more important there. */ -#if defined(CONFIG_SPL_BUILD) || !IS_ENABLED(CONFIG_X86_32BIT_INIT) +#if defined(CONFIG_XPL_BUILD) || !IS_ENABLED(CONFIG_X86_32BIT_INIT)
#undef __HAVE_ARCH_MEMCPY extern void *memcpy(void *, const void *, __kernel_size_t); diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 8fc35e1b51e..2738f0b577b 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -11,11 +11,11 @@ obj-y += bios_asm.o obj-y += bios_interrupts.o endif
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_X86_32BIT_INIT) += string.o endif
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_BOOTM) += bootm.o endif obj-y += cmd_boot.o @@ -47,7 +47,7 @@ obj-y += acpigen.o obj-$(CONFIG_$(SPL_TPL_)GENERATE_ACPI_TABLE) += acpi_table.o endif obj-y += tables.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ZBOOT) += zimage.o endif obj-$(CONFIG_USE_HOB) += hob.o @@ -58,7 +58,7 @@ obj-$(CONFIG_FSP_VERSION1) += fsp1/ obj-$(CONFIG_FSP_VERSION2) += fsp2/ endif
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifdef CONFIG_TPL_BUILD obj-y += tpl.o else @@ -96,7 +96,7 @@ endif
else
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD ifneq ($(CONFIG_CMD_BOOTEFI_SELFTEST)$(CONFIG_CMD_BOOTEFI_HELLO_COMPILE),) extra-y += $(EFI_CRT0) $(EFI_RELOC) endif diff --git a/arch/x86/lib/fsp/Makefile b/arch/x86/lib/fsp/Makefile index da6c0a886ae..0039dd1bf5c 100644 --- a/arch/x86/lib/fsp/Makefile +++ b/arch/x86/lib/fsp/Makefile @@ -4,7 +4,7 @@
obj-y += fsp_common.o obj-y += fsp_dram.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_VIDEO_FSP) += fsp_graphics.o endif obj-y += fsp_support.o diff --git a/board/BuR/brppt1/Makefile b/board/BuR/brppt1/Makefile index 3dec0e6522a..417afacad15 100644 --- a/board/BuR/brppt1/Makefile +++ b/board/BuR/brppt1/Makefile @@ -5,7 +5,7 @@ # Copyright (C) 2013 Hannes Schmelzer oe5hpm@oevsv.at # Bernecker & Rainer Industrieelektronik GmbH - http://www.br-automation.com
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-y := mux.o endif obj-y += ../common/common.o diff --git a/board/BuR/brppt1/board.c b/board/BuR/brppt1/board.c index 80e0ca805b5..8b7def06cc4 100644 --- a/board/BuR/brppt1/board.c +++ b/board/BuR/brppt1/board.c @@ -38,7 +38,7 @@ DECLARE_GLOBAL_DATA_PTR; /* -- defines for GPIO -- */ #define REPSWITCH (0+20) /* GPIO0_20 */
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) /* TODO: check ram-timing ! */ static const struct ddr_data ddr3_data = { .datardsratio0 = MT41K256M16HA125E_RD_DQS, @@ -142,7 +142,7 @@ void sdram_init(void) &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* Basic board specific setup. Pinmux has been handled already. */ int board_init(void) diff --git a/board/BuR/brppt2/board.c b/board/BuR/brppt2/board.c index 105fac8912d..c0a163251b4 100644 --- a/board/BuR/brppt2/board.c +++ b/board/BuR/brppt2/board.c @@ -16,7 +16,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD # include <asm/arch/mx6-ddr.h> #endif #include <asm/arch/clock.h> @@ -82,7 +82,7 @@
#define MUXDESC(pad, ctrl) IOMUX_PADS(pad | MUX_PAD_CTRL(ctrl))
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) static iomux_v3_cfg_t const eth_pads[] = { /* * Gigabit Ethernet @@ -542,4 +542,4 @@ void board_init_f(ulong dummy) void reset_cpu(void) { } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/board/BuR/brppt2/config.mk b/board/BuR/brppt2/config.mk index 0d1638a97ac..f2362d16dc4 100644 --- a/board/BuR/brppt2/config.mk +++ b/board/BuR/brppt2/config.mk @@ -23,7 +23,7 @@ cmd_prodzip = \ zip -9 -r $@ misc/* >/dev/null $<
ifeq ($(hw-platform-y),brppt2) -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) INPUTS-y += $(hw-platform-y)_prog.bin INPUTS-y += $(hw-platform-y)_prod.zip endif diff --git a/board/BuR/brsmarc1/Makefile b/board/BuR/brsmarc1/Makefile index 1c3f64dea4d..42b647af58d 100644 --- a/board/BuR/brsmarc1/Makefile +++ b/board/BuR/brsmarc1/Makefile @@ -4,7 +4,7 @@ # B&R Industrial Automation GmbH - http://www.br-automation.com/ #
-obj-$(CONFIG_SPL_BUILD) += mux.o +obj-$(CONFIG_XPL_BUILD) += mux.o obj-y += ../common/br_resetc.o obj-y += ../common/common.o obj-y += board.o diff --git a/board/BuR/brsmarc1/board.c b/board/BuR/brsmarc1/board.c index bfb6adf6d5c..c05eec6b35e 100644 --- a/board/BuR/brsmarc1/board.c +++ b/board/BuR/brsmarc1/board.c @@ -32,7 +32,7 @@
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) static const struct ddr_data ddr3_data = { .datardsratio0 = MT41K256M16HA125E_RD_DQS, .datawdsratio0 = MT41K256M16HA125E_WR_DQS, @@ -124,8 +124,8 @@ void sdram_init(void) &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); } -#endif /* CONFIG_SPL_BUILD */ -#if !defined(CONFIG_SPL_BUILD) +#endif /* CONFIG_XPL_BUILD */ +#if !defined(CONFIG_XPL_BUILD)
/* decision if backlight is switched on or not on powerup */ int board_backlightstate(void) @@ -166,4 +166,4 @@ int board_late_init(void) }
#endif /* CONFIG_BOARD_LATE_INIT */ -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/board/BuR/brxre1/Makefile b/board/BuR/brxre1/Makefile index 1d224e9e719..c4b1a67be3e 100644 --- a/board/BuR/brxre1/Makefile +++ b/board/BuR/brxre1/Makefile @@ -5,7 +5,7 @@ # Copyright (C) 2014 Hannes Schmelzer oe5hpm@oevsv.at - # Bernecker & Rainer Industrielektronik GmbH - http://www.br-automation.com/
-obj-$(CONFIG_SPL_BUILD) += mux.o +obj-$(CONFIG_XPL_BUILD) += mux.o obj-y += ../common/br_resetc.o obj-y += ../common/common.o obj-y += board.o diff --git a/board/BuR/brxre1/board.c b/board/BuR/brxre1/board.c index 510d2af3147..c25af42e70a 100644 --- a/board/BuR/brxre1/board.c +++ b/board/BuR/brxre1/board.c @@ -39,7 +39,7 @@
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) static const struct ddr_data ddr3_data = { .datardsratio0 = MT41K256M16HA125E_RD_DQS, .datawdsratio0 = MT41K256M16HA125E_WR_DQS, @@ -134,7 +134,7 @@ void sdram_init(void) &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ /* * Basic board specific setup. Pinmux has been handled already. */ diff --git a/board/BuR/common/common.c b/board/BuR/common/common.c index 8aff821cfe8..7fb61736710 100644 --- a/board/BuR/common/common.c +++ b/board/BuR/common/common.c @@ -83,7 +83,7 @@ int overwrite_console(void) return 1; }
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_AM33XX) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_AM33XX) #include <asm/arch/hardware.h> #include <asm/arch/omap.h> #include <asm/arch/clock.h> @@ -175,4 +175,4 @@ void set_mux_conf_regs(void) enable_board_pin_mux(); }
-#endif /* CONFIG_SPL_BUILD && CONFIG_AM33XX */ +#endif /* CONFIG_XPL_BUILD && CONFIG_AM33XX */ diff --git a/board/CZ.NIC/turris_1x/Makefile b/board/CZ.NIC/turris_1x/Makefile index a24aee9161b..1bf370122d9 100644 --- a/board/CZ.NIC/turris_1x/Makefile +++ b/board/CZ.NIC/turris_1x/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # (C) 2022 Pali Rohár pali@kernel.org
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += ../../freescale/p1_p2_rdb_pc/spl.o endif
diff --git a/board/CZ.NIC/turris_1x/tlb.c b/board/CZ.NIC/turris_1x/tlb.c index f35a5558385..5e5892ee1e5 100644 --- a/board/CZ.NIC/turris_1x/tlb.c +++ b/board/CZ.NIC/turris_1x/tlb.c @@ -111,7 +111,7 @@ struct fsl_e_tlb_entry tlb_table[] = { 0, 9, BOOKE_PAGESZ_256K, 1), #endif
-#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD) /* **M** - SDRAM 2G */ SET_TLB_ENTRY(1, CFG_SYS_DDR_SDRAM_BASE, CFG_SYS_DDR_SDRAM_BASE, diff --git a/board/CZ.NIC/turris_omnia/Makefile b/board/CZ.NIC/turris_omnia/Makefile index d1ef5cb8600..acaa3b8ef31 100644 --- a/board/CZ.NIC/turris_omnia/Makefile +++ b/board/CZ.NIC/turris_omnia/Makefile @@ -4,4 +4,4 @@
obj-y := turris_omnia.o ../turris_atsha_otp.o ../turris_common.o obj-$(CONFIG_CMD_EEPROM_LAYOUT) += eeprom.o -obj-$(CONFIG_SPL_BUILD) += old_ddr3_training.o +obj-$(CONFIG_XPL_BUILD) += old_ddr3_training.o diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index eb88ee7f1ed..b7588fa4eec 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -494,7 +494,7 @@ static bool omnia_read_eeprom(struct omnia_eeprom *oep) if (!eeprom) return false;
- if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) ret = dm_i2c_read(eeprom, 0, (void *)oep, sizeof(*oep)); else ret = i2c_eeprom_read(eeprom, 0, (void *)oep, sizeof(*oep)); diff --git a/board/Synology/ds414/Makefile b/board/Synology/ds414/Makefile index b1d018effaa..1a10e9d8d54 100644 --- a/board/Synology/ds414/Makefile +++ b/board/Synology/ds414/Makefile @@ -3,6 +3,6 @@ # Copyright (C) 2015 Phil Sutter phil@nwl.cc
obj-y += ds414.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += cmd_syno.o endif diff --git a/board/advantech/imx8mp_rsb3720a1/Makefile b/board/advantech/imx8mp_rsb3720a1/Makefile index eb6b18b04a2..39fb0d4fb62 100644 --- a/board/advantech/imx8mp_rsb3720a1/Makefile +++ b/board/advantech/imx8mp_rsb3720a1/Makefile @@ -8,7 +8,7 @@ ifdef CONFIG_TARGET_IMX8MP_RSB3720A1_6G obj-y += imx8mp_rsb3720a1.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_rsb3720a1_6G.o endif @@ -17,7 +17,7 @@ endif ifdef CONFIG_TARGET_IMX8MP_RSB3720A1_4G obj-y += imx8mp_rsb3720a1.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_rsb3720a1_4G.o endif diff --git a/board/advantech/imx8qm_dmsse20_a1/Makefile b/board/advantech/imx8qm_dmsse20_a1/Makefile index 262ffcd6834..c82fcc85636 100644 --- a/board/advantech/imx8qm_dmsse20_a1/Makefile +++ b/board/advantech/imx8qm_dmsse20_a1/Makefile @@ -5,4 +5,4 @@ #
obj-y += imx8qm_dmsse20_a1.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/advantech/imx8qm_rom7720_a1/Makefile b/board/advantech/imx8qm_rom7720_a1/Makefile index 51c5de251c4..d8792c6c687 100644 --- a/board/advantech/imx8qm_rom7720_a1/Makefile +++ b/board/advantech/imx8qm_rom7720_a1/Makefile @@ -6,6 +6,6 @@
obj-y += imx8qm_rom7720_a1.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o endif diff --git a/board/alliedtelesis/x530/Makefile b/board/alliedtelesis/x530/Makefile index 97de1d463fe..467c55d7e66 100644 --- a/board/alliedtelesis/x530/Makefile +++ b/board/alliedtelesis/x530/Makefile @@ -4,6 +4,6 @@ #
obj-y := $(BOARD).o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += ../common/gpio_hog.o endif diff --git a/board/asus/grouper/Makefile b/board/asus/grouper/Makefile index d041cf80870..05c6ffb405b 100644 --- a/board/asus/grouper/Makefile +++ b/board/asus/grouper/Makefile @@ -6,7 +6,7 @@ # (C) Copyright 2021 # Svyatoslav Ryhel clamor95@gmail.com
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_DM_PMIC_MAX77663) += grouper-spl-max.o obj-$(CONFIG_DM_PMIC_TPS65910) += grouper-spl-ti.o endif diff --git a/board/asus/transformer-t30/Makefile b/board/asus/transformer-t30/Makefile index c083f2289ba..ad700786b70 100644 --- a/board/asus/transformer-t30/Makefile +++ b/board/asus/transformer-t30/Makefile @@ -6,6 +6,6 @@ # (C) Copyright 2021 # Svyatoslav Ryhel clamor95@gmail.com
-obj-$(CONFIG_SPL_BUILD) += transformer-t30-spl.o +obj-$(CONFIG_XPL_BUILD) += transformer-t30-spl.o
obj-y += transformer-t30.o diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index af486e977e5..d94904366ed 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -70,7 +70,7 @@ void at91sam9m10g45ek_nand_hw_init(void) } #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #include <spl.h> #include <nand.h>
diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index 6f9abcbb127..2cddc2175ac 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -119,7 +119,7 @@ int dram_init(void) return 0; }
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index f52b9a97731..3f41fb1c983 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -134,7 +134,7 @@ int dram_init(void) return 0; }
diff --git a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c index cb3cd7ac9ae..bf54fc33df4 100644 --- a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c +++ b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c @@ -105,7 +105,7 @@ int misc_init_r(void) #endif
/* SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { } diff --git a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c index 15cbd0daa6f..04de1257eca 100644 --- a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c +++ b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c @@ -90,7 +90,7 @@ int dram_init(void) }
static void board_leds_init(void) { diff --git a/board/atmel/sama5d2_icp/sama5d2_icp.c b/board/atmel/sama5d2_icp/sama5d2_icp.c index 6f0d578abf7..113bd2feb62 100644 --- a/board/atmel/sama5d2_icp/sama5d2_icp.c +++ b/board/atmel/sama5d2_icp/sama5d2_icp.c @@ -79,7 +79,7 @@ int misc_init_r(void) }
/* must set PB25 low to enable the CAN transceivers */ static void board_can_stdby_dis(void) diff --git a/board/atmel/sama5d2_xplained/sama5d2_xplained.c b/board/atmel/sama5d2_xplained/sama5d2_xplained.c index d104736fa7c..eca5b2bf107 100644 --- a/board/atmel/sama5d2_xplained/sama5d2_xplained.c +++ b/board/atmel/sama5d2_xplained/sama5d2_xplained.c @@ -105,7 +105,7 @@ int misc_init_r(void) #endif
/* SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { } diff --git a/board/atmel/sama5d3_xplained/sama5d3_xplained.c b/board/atmel/sama5d3_xplained/sama5d3_xplained.c index f98322fb540..7a813c19ff2 100644 --- a/board/atmel/sama5d3_xplained/sama5d3_xplained.c +++ b/board/atmel/sama5d3_xplained/sama5d3_xplained.c @@ -117,7 +117,7 @@ int dram_init(void) }
/* SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { #ifdef CONFIG_SD_BOOT diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index 28079a81517..555a8c0970b 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -194,7 +194,7 @@ int board_late_init(void) #endif
/* SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { #if CONFIG_NAND_BOOT diff --git a/board/atmel/sama5d4_xplained/sama5d4_xplained.c b/board/atmel/sama5d4_xplained/sama5d4_xplained.c index f9112fc5321..e296b0466aa 100644 --- a/board/atmel/sama5d4_xplained/sama5d4_xplained.c +++ b/board/atmel/sama5d4_xplained/sama5d4_xplained.c @@ -141,7 +141,7 @@ int dram_init(void) }
/* SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { #if CONFIG_NAND_BOOT diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c index 0bdc6adbdc8..e820605d3b9 100644 --- a/board/atmel/sama5d4ek/sama5d4ek.c +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -127,7 +127,7 @@ int dram_init(void) }
/* SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { #if CONFIG_NAND_BOOT diff --git a/board/avionic-design/tec-ng/Makefile b/board/avionic-design/tec-ng/Makefile index d6890e5797f..ec1710e137e 100644 --- a/board/avionic-design/tec-ng/Makefile +++ b/board/avionic-design/tec-ng/Makefile @@ -3,6 +3,6 @@ # (C) Copyright 2013 # Avionic Design GmbH <www.avionic-design.de>
-obj-$(CONFIG_SPL_BUILD) += tec-ng-spl.o +obj-$(CONFIG_XPL_BUILD) += tec-ng-spl.o
obj-y += ../common/tamonten-ng.o diff --git a/board/beacon/imx8mm/Makefile b/board/beacon/imx8mm/Makefile index 7d3bd3112cb..b33dc8b05b9 100644 --- a/board/beacon/imx8mm/Makefile +++ b/board/beacon/imx8mm/Makefile @@ -7,7 +7,7 @@ obj-y += imx8mm_beacon.o obj-y += ../../freescale/common/
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-y += lpddr4_timing.o endif diff --git a/board/beacon/imx8mn/Makefile b/board/beacon/imx8mn/Makefile index d620ccb7723..48b7b0952cc 100644 --- a/board/beacon/imx8mn/Makefile +++ b/board/beacon/imx8mn/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mn_beacon.o obj-y += ../../freescale/common/ -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o ifdef CONFIG_IMX8MN_BEACON_2GB_LPDDR obj-y += lpddr4_2g_timing.o diff --git a/board/beacon/imx8mp/Makefile b/board/beacon/imx8mp/Makefile index 264720f6d49..7b994d2c8a1 100644 --- a/board/beacon/imx8mp/Makefile +++ b/board/beacon/imx8mp/Makefile @@ -7,7 +7,7 @@ obj-y += imx8mp_beacon.o obj-y += ../../freescale/common/
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/bitmain/antminer_s9/Makefile b/board/bitmain/antminer_s9/Makefile index 1af01d6d808..57580f3730b 100644 --- a/board/bitmain/antminer_s9/Makefile +++ b/board/bitmain/antminer_s9/Makefile @@ -6,4 +6,4 @@ obj-y += ../../xilinx/common/board.o # Remove quotes hw-platform-y :=$(shell echo $(CONFIG_DEFAULT_DEVICE_TREE))
-obj-$(CONFIG_SPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o +obj-$(CONFIG_XPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o diff --git a/board/bosch/acc/acc.c b/board/bosch/acc/acc.c index a1a00e7ffc4..4c7c9d38a44 100644 --- a/board/bosch/acc/acc.c +++ b/board/bosch/acc/acc.c @@ -269,7 +269,7 @@ int dram_init(void) return 0; }
-#if IS_ENABLED(CONFIG_SPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) #include <asm/arch/crm_regs.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> diff --git a/board/bosch/shc/board.c b/board/bosch/shc/board.c index 1f9dc2d8df1..02f51ca2ca8 100644 --- a/board/bosch/shc/board.c +++ b/board/bosch/shc/board.c @@ -259,7 +259,7 @@ static void check_button_status(void) } }
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { @@ -473,7 +473,7 @@ int board_late_init(void) #endif
#if defined(CONFIG_USB_ETHER) && \ - (!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_USB_ETHER)) + (!defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_USB_ETHER)) int board_eth_init(struct bd_info *bis) { return usb_eth_initialize(bis); diff --git a/board/bsh/imx6ulz_smm_m2/Makefile b/board/bsh/imx6ulz_smm_m2/Makefile index b761bbb2f90..59870419bdd 100644 --- a/board/bsh/imx6ulz_smm_m2/Makefile +++ b/board/bsh/imx6ulz_smm_m2/Makefile @@ -2,5 +2,5 @@ # (C) Copyright 2021 Amarula Solutions B.V.
obj-y := imx6ulz_smm_m2.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o
diff --git a/board/bsh/imx8mn_smm_s2/Makefile b/board/bsh/imx8mn_smm_s2/Makefile index 19d37a723ea..3050194ff89 100644 --- a/board/bsh/imx8mn_smm_s2/Makefile +++ b/board/bsh/imx8mn_smm_s2/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mn_smm_s2.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_BSH_SMM_S2_DDR3L_256) += ddr3l_timing_256m.o obj-$(CONFIG_BSH_SMM_S2_DDR3L_512) += ddr3l_timing_512m.o diff --git a/board/bticino/mamoj/Makefile b/board/bticino/mamoj/Makefile index f1ddda48918..b83e667e828 100644 --- a/board/bticino/mamoj/Makefile +++ b/board/bticino/mamoj/Makefile @@ -5,4 +5,4 @@ #
obj-y := mamoj.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/cloos/imx8mm_phg/Makefile b/board/cloos/imx8mm_phg/Makefile index 2b36931fcf7..c3e54bfc2e0 100644 --- a/board/cloos/imx8mm_phg/Makefile +++ b/board/cloos/imx8mm_phg/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mm_phg.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/compulab/cl-som-imx7/Makefile b/board/compulab/cl-som-imx7/Makefile index 8f0e068b7e9..35cf2c13562 100644 --- a/board/compulab/cl-som-imx7/Makefile +++ b/board/compulab/cl-som-imx7/Makefile @@ -10,7 +10,7 @@
obj-y := mux.o common.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += cl-som-imx7.o diff --git a/board/compulab/cl-som-imx7/common.h b/board/compulab/cl-som-imx7/common.h index bc19867f876..5b29763b340 100644 --- a/board/compulab/cl-som-imx7/common.h +++ b/board/compulab/cl-som-imx7/common.h @@ -18,7 +18,7 @@ PADS_SET_PROT(uart1_pads); PADS_SET_PROT(espi1_pads); #endif /* CONFIG_SPI */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #ifdef CONFIG_FSL_ESDHC_IMX PADS_SET_PROT(usdhc3_emmc_pads); #endif /* CONFIG_FSL_ESDHC_IMX */ @@ -28,4 +28,4 @@ PADS_SET_PROT(fec1_pads); #endif /* CONFIG_FEC_MXC */ PADS_SET_PROT(usb_otg1_pads); PADS_SET_PROT(wdog_pads); -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/board/compulab/cl-som-imx7/mux.c b/board/compulab/cl-som-imx7/mux.c index 25123ee145a..da8848b9f57 100644 --- a/board/compulab/cl-som-imx7/mux.c +++ b/board/compulab/cl-som-imx7/mux.c @@ -67,7 +67,7 @@ PADS_SET(espi1_pads)
@@ -138,4 +138,4 @@ static iomux_v3_cfg_t const wdog_pads[] = {
PADS_SET(wdog_pads)
-#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/board/compulab/cm_fx6/Makefile b/board/compulab/cm_fx6/Makefile index e648db26a1d..e9f86cb8410 100644 --- a/board/compulab/cm_fx6/Makefile +++ b/board/compulab/cm_fx6/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2014 CompuLab, Ltd. <www.compulab.co.il> # # Authors: Nikita Kiryanov nikita@compulab.co.il -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y = common.o spl.o else obj-y = common.o cm_fx6.o diff --git a/board/compulab/cm_t43/Makefile b/board/compulab/cm_t43/Makefile index 6fa231a045e..221d1b432fd 100644 --- a/board/compulab/cm_t43/Makefile +++ b/board/compulab/cm_t43/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2015 Compulab, Ltd.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o mux.o else obj-y += cm_t43.o mux.o diff --git a/board/compulab/imx8mm-cl-iot-gate/Makefile b/board/compulab/imx8mm-cl-iot-gate/Makefile index 3800b21a6fd..7c2d6e508b3 100644 --- a/board/compulab/imx8mm-cl-iot-gate/Makefile +++ b/board/compulab/imx8mm-cl-iot-gate/Makefile @@ -7,7 +7,7 @@
obj-y += imx8mm-cl-iot-gate.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o eeprom_spl.o obj-y += ddr/ endif diff --git a/board/compulab/imx8mm-cl-iot-gate/eeprom_spl.c b/board/compulab/imx8mm-cl-iot-gate/eeprom_spl.c index 1256848f9a9..a22e6ef1d96 100644 --- a/board/compulab/imx8mm-cl-iot-gate/eeprom_spl.c +++ b/board/compulab/imx8mm-cl-iot-gate/eeprom_spl.c @@ -10,7 +10,7 @@ #include <asm/setup.h> #include <linux/delay.h>
#define CFG_SYS_I2C_EEPROM_ADDR_P1 0x51
diff --git a/board/comvetia/lxr2/lxr2.c b/board/comvetia/lxr2/lxr2.c index 173263522bd..dc7fc202049 100644 --- a/board/comvetia/lxr2/lxr2.c +++ b/board/comvetia/lxr2/lxr2.c @@ -138,7 +138,7 @@ int board_late_init(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <spl.h>
#define MX6_PHYFLEX_ERR006282 IMX_GPIO_NR(2, 11) diff --git a/board/conclusive/kstr-sama5d27/kstr-sama5d27.c b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c index 37750137ad9..15dba146eb8 100644 --- a/board/conclusive/kstr-sama5d27/kstr-sama5d27.c +++ b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c @@ -141,7 +141,7 @@ int dram_init(void) }
/* SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { } diff --git a/board/congatec/cgtqmx8/Makefile b/board/congatec/cgtqmx8/Makefile index 4b59dbb6bc7..2a02cec4f15 100644 --- a/board/congatec/cgtqmx8/Makefile +++ b/board/congatec/cgtqmx8/Makefile @@ -6,6 +6,6 @@
obj-y += cgtqmx8.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o endif diff --git a/board/congatec/common/Makefile b/board/congatec/common/Makefile index 2db0fc1ae5c..f8170d9c653 100644 --- a/board/congatec/common/Makefile +++ b/board/congatec/common/Makefile @@ -7,7 +7,7 @@
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y diff --git a/board/data_modul/common/common.c b/board/data_modul/common/common.c index b4d74a8fd8b..b5f83908771 100644 --- a/board/data_modul/common/common.c +++ b/board/data_modul/common/common.c @@ -72,7 +72,7 @@ int board_phys_sdram_size(phys_size_t *size) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static void data_modul_imx_edm_sbc_early_init_f(const iomux_v3_cfg_t wdog_pad) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; diff --git a/board/data_modul/imx8mm_edm_sbc/Makefile b/board/data_modul/imx8mm_edm_sbc/Makefile index 6d72e930fca..3d8fedf74d4 100644 --- a/board/data_modul/imx8mm_edm_sbc/Makefile +++ b/board/data_modul/imx8mm_edm_sbc/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o lpddr4_timing_2G_32.o lpddr4_timing_4G_32.o else obj-y += imx8mm_data_modul_edm_sbc.o diff --git a/board/data_modul/imx8mp_edm_sbc/Makefile b/board/data_modul/imx8mp_edm_sbc/Makefile index 28c1d62f2bb..7e1fe855799 100644 --- a/board/data_modul/imx8mp_edm_sbc/Makefile +++ b/board/data_modul/imx8mp_edm_sbc/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o lpddr4_timing_4G_32.o else obj-y += imx8mp_data_modul_edm_sbc.o diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 03c34455c50..dc42a4a7b53 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -311,7 +311,7 @@ int board_mmc_init(struct bd_info *bis) #endif #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static const struct ns16550_plat serial_pdata = { .base = DAVINCI_UART2_BASE, .reg_shift = 2, diff --git a/board/dhelectronics/dh_imx6/Makefile b/board/dhelectronics/dh_imx6/Makefile index 70ca30d3971..7102a47450e 100644 --- a/board/dhelectronics/dh_imx6/Makefile +++ b/board/dhelectronics/dh_imx6/Makefile @@ -2,7 +2,7 @@ # # Copyright (C) 2017 Marek Vasut marex@denx.de
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := dh_imx6_spl.o else obj-y := dh_imx6.o diff --git a/board/dhelectronics/dh_imx8mp/Makefile b/board/dhelectronics/dh_imx8mp/Makefile index e5a29fdd122..7bc8dc21e64 100644 --- a/board/dhelectronics/dh_imx8mp/Makefile +++ b/board/dhelectronics/dh_imx8mp/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o lpddr4_timing_2G_32.o lpddr4_timing_4G_32.o else obj-y += imx8mp_dhcom_pdk2.o diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 4f4f537fee5..073f32d1380 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -260,13 +260,13 @@ int board_stm32mp1_ddr_config_name_match(struct udevice *dev,
void board_vddcore_init(u32 voltage_mv) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) opp_voltage_mv = voltage_mv; }
int board_early_init_f(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) stpmic1_init(opp_voltage_mv); board_get_coding_straps();
@@ -767,7 +767,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) } #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) void spl_perform_fixups(struct spl_image_info *spl_image) { dh_stm32_ks8851_fixup(spl_image_fdt_addr(spl_image)); diff --git a/board/ea/mx7ulp_com/mx7ulp_com.c b/board/ea/mx7ulp_com/mx7ulp_com.c index 8f78937e097..d3a65fd820b 100644 --- a/board/ea/mx7ulp_com/mx7ulp_com.c +++ b/board/ea/mx7ulp_com/mx7ulp_com.c @@ -52,7 +52,7 @@ int board_init(void) return 0; }
#ifdef CONFIG_SPL_LOAD_FIT diff --git a/board/eets/pdu001/board.c b/board/eets/pdu001/board.c index 00f9a5ef341..16af687d9cc 100644 --- a/board/eets/pdu001/board.c +++ b/board/eets/pdu001/board.c @@ -65,7 +65,7 @@ DECLARE_GLOBAL_DATA_PTR; #define CFG_SYS_RTC_SCRATCH0 0x60 #define BOOT_DEVICE_SAVE_REGISTER (RTC_BASE + CFG_SYS_RTC_SCRATCH0)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static void save_boot_device(void) { *((u32 *)(BOOT_DEVICE_SAVE_REGISTER)) = spl_boot_device(); diff --git a/board/embest/mx6boards/mx6boards.c b/board/embest/mx6boards/mx6boards.c index cf3368c253b..5ed41d01d9b 100644 --- a/board/embest/mx6boards/mx6boards.c +++ b/board/embest/mx6boards/mx6boards.c @@ -394,7 +394,7 @@ int checkboard(void) return 0; }
void board_init_f(ulong dummy) diff --git a/board/engicam/common/Makefile b/board/engicam/common/Makefile index 15f0eaa1ec4..dc8be383c23 100644 --- a/board/engicam/common/Makefile +++ b/board/engicam/common/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # Copyright (C) 2016 Amarula Solutions B.V.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_IMX6_ENGICAM_COMMON) += spl.o else obj-$(CONFIG_IMX6_ENGICAM_COMMON) += board.o diff --git a/board/engicam/imx8mm/Makefile b/board/engicam/imx8mm/Makefile index 3392d61920a..d6ad299f830 100644 --- a/board/engicam/imx8mm/Makefile +++ b/board/engicam/imx8mm/Makefile @@ -6,7 +6,7 @@
obj-y += icore_mx8mm.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-y += lpddr4_timing.o endif diff --git a/board/engicam/imx8mp/Makefile b/board/engicam/imx8mp/Makefile index c3ec09d6e38..f21a31b8078 100644 --- a/board/engicam/imx8mp/Makefile +++ b/board/engicam/imx8mp/Makefile @@ -6,7 +6,7 @@
obj-y += icore_mx8mp.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/engicam/stm32mp1/Makefile b/board/engicam/stm32mp1/Makefile index 155d33f9eec..9ac78e4d1aa 100644 --- a/board/engicam/stm32mp1/Makefile +++ b/board/engicam/stm32mp1/Makefile @@ -3,7 +3,7 @@ # Copyright (C) 2018, STMicroelectronics - All Rights Reserved #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += stm32mp1.o diff --git a/board/firefly/firefly-rk3288/firefly-rk3288.c b/board/firefly/firefly-rk3288/firefly-rk3288.c index 8e67ab4b132..c65ce5890e5 100644 --- a/board/firefly/firefly-rk3288/firefly-rk3288.c +++ b/board/firefly/firefly-rk3288/firefly-rk3288.c @@ -9,7 +9,7 @@ #include <asm/global_data.h> #include <dm/ofnode.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static int setup_led(void) { #ifdef CONFIG_SPL_LED diff --git a/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c b/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c index a149e4fe822..6937a27176f 100644 --- a/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c +++ b/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c @@ -13,7 +13,7 @@ #include <asm/arch-rockchip/gpio.h> #include <asm/arch-rockchip/grf_rk3399.h>
#define PMUGRF_BASE 0xff320000 #define GPIO0_BASE 0xff720000 diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index b4faf6f9e0a..c491dc8b241 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -5,7 +5,7 @@
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y @@ -29,14 +29,14 @@ endif obj-$(CONFIG_FSL_CADMUS) += cadmus.o obj-$(CONFIG_FSL_VIA) += cds_via.o obj-$(CONFIG_FMAN_ENET) += fman.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_FSL_NGPIXIS) += ngpixis.o endif obj-$(I2C_COMMON) += i2c_common.o obj-$(CONFIG_FSL_USE_PCA9547_MUX) += i2c_mux.o obj-$(CONFIG_$(SPL_)VID) += vid.o obj-$(CONFIG_FSL_QIXIS) += qixis.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ID_EEPROM) += sys_eeprom.o endif ifndef CONFIG_RAMBOOT_PBL diff --git a/board/freescale/common/cmd_esbc_validate.c b/board/freescale/common/cmd_esbc_validate.c index 3344653ba2d..7629d7091e9 100644 --- a/board/freescale/common/cmd_esbc_validate.c +++ b/board/freescale/common/cmd_esbc_validate.c @@ -23,7 +23,7 @@ loop: return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int do_esbc_validate(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/board/freescale/common/fsl_chain_of_trust.c b/board/freescale/common/fsl_chain_of_trust.c index 27a33924c84..194a0907e72 100644 --- a/board/freescale/common/fsl_chain_of_trust.c +++ b/board/freescale/common/fsl_chain_of_trust.c @@ -15,7 +15,7 @@ #include <dm/root.h> #include <asm/fsl_secure_boot.h>
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_FRAMEWORK) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_FRAMEWORK) #include <spl.h> #endif
@@ -67,7 +67,7 @@ int fsl_check_boot_mode_secure(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int fsl_setenv_chain_of_trust(void) { /* Check Boot Mode @@ -92,7 +92,7 @@ int fsl_setenv_chain_of_trust(void) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_validate_uboot(uint32_t hdr_addr, uintptr_t img_addr) { int res; @@ -157,4 +157,4 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) image_entry(); } #endif /* ifdef CONFIG_SPL_FRAMEWORK */ -#endif /* ifdef CONFIG_SPL_BUILD */ +#endif /* ifdef CONFIG_XPL_BUILD */ diff --git a/board/freescale/common/fsl_validate.c b/board/freescale/common/fsl_validate.c index 657f4533bcd..df0c1a1f406 100644 --- a/board/freescale/common/fsl_validate.c +++ b/board/freescale/common/fsl_validate.c @@ -396,7 +396,7 @@ static void fsl_secboot_bootscript_parse_failure(void) */ void fsl_secboot_handle_error(int error) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD const struct fsl_secboot_errcode *e;
for (e = fsl_secboot_errcodes; e->errcode != ERROR_ESBC_CLIENT_MAX; @@ -807,7 +807,7 @@ static int calculate_cmp_img_sig(struct fsl_secboot_img_priv *img) prop.num_bits = key_len * 8; prop.exp_len = key_len;
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) ret = device_bind_driver(NULL, "fsl_rsa_mod_exp", "fsl_rsa_mod_exp", NULL); if (ret) { printf("Couldn't bind fsl_rsa_mod_exp driver (%d)\n", ret); diff --git a/board/freescale/common/qixis.c b/board/freescale/common/qixis.c index 6400ac05245..7815ba2dbce 100644 --- a/board/freescale/common/qixis.c +++ b/board/freescale/common/qixis.c @@ -161,7 +161,7 @@ void board_deassert_mem_reset(void) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static void qixis_reset(void) { QIXIS_WRITE(rst_ctl, QIXIS_RST_CTL_RESET); diff --git a/board/freescale/imx8mm_evk/Makefile b/board/freescale/imx8mm_evk/Makefile index 1db7b62cafc..9fecd8dd8cb 100644 --- a/board/freescale/imx8mm_evk/Makefile +++ b/board/freescale/imx8mm_evk/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mm_evk.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/freescale/imx8mn_evk/Makefile b/board/freescale/imx8mn_evk/Makefile index 42d1179724d..5ef666a36dd 100644 --- a/board/freescale/imx8mn_evk/Makefile +++ b/board/freescale/imx8mn_evk/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mn_evk.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o ifdef CONFIG_IMX8MN_LOW_DRIVE_MODE obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_ld.o diff --git a/board/freescale/imx8mp_evk/Makefile b/board/freescale/imx8mp_evk/Makefile index 106bf9a1edf..3c154d7f7f5 100644 --- a/board/freescale/imx8mp_evk/Makefile +++ b/board/freescale/imx8mp_evk/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mp_evk.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/freescale/imx8mq_evk/Makefile b/board/freescale/imx8mq_evk/Makefile index cf046963d25..ca449e6f369 100644 --- a/board/freescale/imx8mq_evk/Makefile +++ b/board/freescale/imx8mq_evk/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mq_evk.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o lpddr4_timing_b0.o endif diff --git a/board/freescale/imx8qm_mek/Makefile b/board/freescale/imx8qm_mek/Makefile index bc9a1260bde..53b33a0dfb1 100644 --- a/board/freescale/imx8qm_mek/Makefile +++ b/board/freescale/imx8qm_mek/Makefile @@ -5,4 +5,4 @@ #
obj-y += imx8qm_mek.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/freescale/imx8qxp_mek/Makefile b/board/freescale/imx8qxp_mek/Makefile index acaadcd84a4..459ec771eea 100644 --- a/board/freescale/imx8qxp_mek/Makefile +++ b/board/freescale/imx8qxp_mek/Makefile @@ -5,4 +5,4 @@ #
obj-y += imx8qxp_mek.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/freescale/imx8ulp_evk/Makefile b/board/freescale/imx8ulp_evk/Makefile index 1cf148ab910..7819b2675b3 100644 --- a/board/freescale/imx8ulp_evk/Makefile +++ b/board/freescale/imx8ulp_evk/Makefile @@ -2,7 +2,7 @@
obj-y += imx8ulp_evk.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o ifdef CONFIG_IMX8ULP_ND_MODE obj-y += lpddr4_timing_264.o diff --git a/board/freescale/imx93_evk/Makefile b/board/freescale/imx93_evk/Makefile index ede8d20ff5c..b077acc70a5 100644 --- a/board/freescale/imx93_evk/Makefile +++ b/board/freescale/imx93_evk/Makefile @@ -6,7 +6,7 @@
obj-y += imx93_evk.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX93_EVK_LPDDR4X) += lpddr4x_timing.o lpddr4x_timing_1866mts.o endif diff --git a/board/freescale/imxrt1020-evk/imxrt1020-evk.c b/board/freescale/imxrt1020-evk/imxrt1020-evk.c index 42a0a67ae93..11dbef84688 100644 --- a/board/freescale/imxrt1020-evk/imxrt1020-evk.c +++ b/board/freescale/imxrt1020-evk/imxrt1020-evk.c @@ -37,7 +37,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/board/freescale/imxrt1050-evk/imxrt1050-evk.c b/board/freescale/imxrt1050-evk/imxrt1050-evk.c index 46a644908e9..056489932ac 100644 --- a/board/freescale/imxrt1050-evk/imxrt1050-evk.c +++ b/board/freescale/imxrt1050-evk/imxrt1050-evk.c @@ -37,7 +37,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/board/freescale/imxrt1170-evk/imxrt1170-evk.c b/board/freescale/imxrt1170-evk/imxrt1170-evk.c index e10b8830ec6..047aea8181a 100644 --- a/board/freescale/imxrt1170-evk/imxrt1170-evk.c +++ b/board/freescale/imxrt1170-evk/imxrt1170-evk.c @@ -37,7 +37,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index dae2cf097bc..f157e75e385 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -140,7 +140,7 @@ int dram_init(void) #endif mmdc_init(&mparam);
-#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD) /* This will break-before-make MMU for DDR */ update_early_mmu_table(); #endif diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 7d56eb0117d..b21c4d917d0 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -88,7 +88,7 @@ int dram_init(void)
mmdc_init(&mparam); gd->ram_size = CFG_SYS_SDRAM_SIZE; -#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD) /* This will break-before-make MMU for DDR */ update_early_mmu_table(); #endif diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 5f0564f1b23..ab69eab8408 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -138,7 +138,7 @@ int dram_init(void) #endif
gd->ram_size = CFG_SYS_SDRAM_SIZE; -#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD) /* This will break-before-make MMU for DDR */ update_early_mmu_table(); #endif diff --git a/board/freescale/ls1021aiot/ls1021aiot.c b/board/freescale/ls1021aiot/ls1021aiot.c index 2fdac87bc29..4eff0a3fee0 100644 --- a/board/freescale/ls1021aiot/ls1021aiot.c +++ b/board/freescale/ls1021aiot/ls1021aiot.c @@ -99,7 +99,7 @@ void ddrmc_init(void)
int dram_init(void) { -#if (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) +#if (!defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD)) ddrmc_init(); #endif
@@ -125,7 +125,7 @@ int board_early_init_f(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { /* Clear the BSS */ diff --git a/board/freescale/ls1021aqds/ddr.c b/board/freescale/ls1021aqds/ddr.c index 5b0f23688f0..fd897e832c8 100644 --- a/board/freescale/ls1021aqds/ddr.c +++ b/board/freescale/ls1021aqds/ddr.c @@ -172,14 +172,14 @@ int fsl_initdram(void) { phys_size_t dram_size;
-#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_SPL) puts("Initializing DDR....using SPD\n"); dram_size = fsl_ddr_sdram(); #else dram_size = fsl_ddr_sdram_size(); #endif
-#if defined(CONFIG_DEEP_SLEEP) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_DEEP_SLEEP) && !defined(CONFIG_XPL_BUILD) fsl_dp_resume(); #endif
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 930ef6be385..0bdd468d9a7 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -181,7 +181,7 @@ int board_early_init_f(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { #ifdef CONFIG_NAND_BOOT diff --git a/board/freescale/ls1021atsn/ls1021atsn.c b/board/freescale/ls1021atsn/ls1021atsn.c index b7e043b2e62..d1acccec110 100644 --- a/board/freescale/ls1021atsn/ls1021atsn.c +++ b/board/freescale/ls1021atsn/ls1021atsn.c @@ -27,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR;
static void ddrmc_init(void) { -#if (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) +#if (!defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD)) struct ccsr_ddr *ddr = (struct ccsr_ddr *)CFG_SYS_FSL_DDR_ADDR; u32 temp_sdram_cfg, tmp;
@@ -105,7 +105,7 @@ static void ddrmc_init(void) out_be32(&ddr->sdram_cfg_2, temp_sdram_cfg); } #endif -#endif /* !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) */ +#endif /* !defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD) */ }
int dram_init(void) @@ -116,7 +116,7 @@ int dram_init(void)
gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
@@ -156,7 +156,7 @@ int board_early_init_f(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { void (*second_uboot)(void); @@ -214,7 +214,7 @@ int board_init(void) return 0; }
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) void spl_board_init(void) { ls102xa_smmu_stream_id_init(); diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 78006afce86..cc9665c0410 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -224,7 +224,7 @@ void ddrmc_init(void)
@@ -232,7 +232,7 @@ int dram_init(void)
@@ -407,7 +407,7 @@ int board_early_init_f(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_init_f(ulong dummy) { void (*second_uboot)(void); @@ -527,7 +527,7 @@ int board_init(void) return 0; }
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) void spl_board_init(void) { if (IS_ENABLED(CONFIG_FSL_CAAM)) { @@ -607,7 +607,7 @@ u16 flash_read16(void *addr) }
#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) \ - && !defined(CONFIG_SPL_BUILD) + && !defined(CONFIG_XPL_BUILD) static void convert_flash_bank(char bank) { struct cpld_data *cpld_data = (void *)(CFG_SYS_CPLD_BASE); diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index e01b5a8c2eb..db94d9c1fa8 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -123,7 +123,7 @@ int board_early_init_f(void) u8 uart; #endif
-#if defined(CONFIG_SYS_I2C_EARLY_INIT) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SYS_I2C_EARLY_INIT) && defined(CONFIG_XPL_BUILD) i2c_early_init_f(); #endif
diff --git a/board/freescale/ls1043aqds/Makefile b/board/freescale/ls1043aqds/Makefile index 49d8d7d9b96..ff830788fd7 100644 --- a/board/freescale/ls1043aqds/Makefile +++ b/board/freescale/ls1043aqds/Makefile @@ -5,7 +5,7 @@ #
obj-y += ddr.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += eth.o endif obj-y += ls1043aqds.o diff --git a/board/freescale/ls1043aqds/ddr.c b/board/freescale/ls1043aqds/ddr.c index 2a9717df616..137ad7395ad 100644 --- a/board/freescale/ls1043aqds/ddr.c +++ b/board/freescale/ls1043aqds/ddr.c @@ -123,7 +123,7 @@ int fsl_initdram(void) { phys_size_t dram_size;
-#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD) gd->ram_size = fsl_ddr_sdram_size();
return 0; diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index 2ecf5a74a03..f043599fbb8 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -288,7 +288,7 @@ int dram_init(void) select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, 0); fsl_initdram(); #if (!defined(CONFIG_SPL) && !defined(CONFIG_TFABOOT)) || \ - defined(CONFIG_SPL_BUILD) + defined(CONFIG_XPL_BUILD) /* This will break-before-make MMU for DDR */ update_early_mmu_table(); #endif diff --git a/board/freescale/ls1043ardb/Makefile b/board/freescale/ls1043ardb/Makefile index 5309576c688..95745bf3a9c 100644 --- a/board/freescale/ls1043ardb/Makefile +++ b/board/freescale/ls1043ardb/Makefile @@ -4,7 +4,7 @@
obj-y += ddr.o obj-y += ls1043ardb.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_NET) += eth.o obj-y += cpld.o endif diff --git a/board/freescale/ls1043ardb/ddr.c b/board/freescale/ls1043ardb/ddr.c index 187925e981a..231b60d1b3d 100644 --- a/board/freescale/ls1043ardb/ddr.c +++ b/board/freescale/ls1043ardb/ddr.c @@ -225,14 +225,14 @@ int fsl_initdram(void) phys_size_t dram_size;
#ifdef CONFIG_SYS_DDR_RAW_TIMING -#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_SPL) puts("Initializing DDR....\n"); dram_size = fsl_ddr_sdram(); #else dram_size = fsl_ddr_sdram_size(); #endif #else -#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_SPL) puts("Initialzing DDR using fixed setting\n"); dram_size = fixed_sdram(); #else diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index cf84ff9e638..bba041065b5 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -132,7 +132,7 @@ int board_early_init_f(void) return 0; }
int checkboard(void) { diff --git a/board/freescale/ls1046aqds/Makefile b/board/freescale/ls1046aqds/Makefile index 6267522cc26..365247d92bc 100644 --- a/board/freescale/ls1046aqds/Makefile +++ b/board/freescale/ls1046aqds/Makefile @@ -5,7 +5,7 @@ #
obj-y += ddr.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += eth.o endif obj-y += ls1046aqds.o diff --git a/board/freescale/ls1046aqds/ddr.c b/board/freescale/ls1046aqds/ddr.c index ac1b6049721..57790335f0a 100644 --- a/board/freescale/ls1046aqds/ddr.c +++ b/board/freescale/ls1046aqds/ddr.c @@ -107,7 +107,7 @@ int fsl_initdram(void) { phys_size_t dram_size;
return 0; diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index a83b2170651..7df12550868 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -284,7 +284,7 @@ int dram_init(void) select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, 0); fsl_initdram(); #if (!defined(CONFIG_SPL) && !defined(CONFIG_TFABOOT)) || \ - defined(CONFIG_SPL_BUILD) + defined(CONFIG_XPL_BUILD) /* This will break-before-make MMU for DDR */ update_early_mmu_table(); #endif diff --git a/board/freescale/ls1046ardb/Makefile b/board/freescale/ls1046ardb/Makefile index 1c13ed6b6f0..9e5d24f53c8 100644 --- a/board/freescale/ls1046ardb/Makefile +++ b/board/freescale/ls1046ardb/Makefile @@ -4,7 +4,7 @@
obj-y += ddr.o obj-y += ls1046ardb.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_NET) += eth.o obj-y += cpld.o endif diff --git a/board/freescale/ls1046ardb/ddr.c b/board/freescale/ls1046ardb/ddr.c index 68353022e7d..4170666c420 100644 --- a/board/freescale/ls1046ardb/ddr.c +++ b/board/freescale/ls1046ardb/ddr.c @@ -113,7 +113,7 @@ int fsl_initdram(void) { phys_size_t dram_size;
return 0; diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c index 0492f0a8c0a..83b280f7646 100644 --- a/board/freescale/ls1046ardb/ls1046ardb.c +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -44,7 +44,7 @@ int board_early_init_f(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int checkboard(void) { static const char *freq[2] = {"100.00MHZ", "156.25MHZ"}; diff --git a/board/freescale/ls1088a/Makefile b/board/freescale/ls1088a/Makefile index c2b0e7dc0f4..e54d6cad9e1 100644 --- a/board/freescale/ls1088a/Makefile +++ b/board/freescale/ls1088a/Makefile @@ -4,7 +4,7 @@
obj-y += ls1088a.o obj-y += ddr.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_TARGET_LS1088ARDB) += eth_ls1088ardb.o obj-$(CONFIG_TARGET_LS1088AQDS) += eth_ls1088aqds.o endif diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index 54b432ad794..cd590af9534 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -13,7 +13,7 @@
-#if defined(CONFIG_VID) && (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) +#if defined(CONFIG_VID) && (!defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD)) static void fsl_ddr_setup_0v9_volt(memctl_options_t *popts) { int vdd; @@ -101,7 +101,7 @@ found: popts->addr_hash = 1;
popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_60ohm); -#if defined(CONFIG_VID) && (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) +#if defined(CONFIG_VID) && (!defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD)) fsl_ddr_setup_0v9_volt(popts); #endif
@@ -124,7 +124,7 @@ int fsl_initdram(void) { puts("Initializing DDR....using SPD\n");
-#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD) gd->ram_size = fsl_ddr_sdram_size(); #else gd->ram_size = fsl_ddr_sdram(); diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 58951f2bb2a..9f4eb4811d9 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -248,7 +248,7 @@ int fixup_ls1088ardb_pb_banner(void *fdt) return 0; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) int checkboard(void) { #ifdef CONFIG_TFABOOT @@ -421,7 +421,7 @@ unsigned long get_board_ddr_clk(void) } #endif
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) void board_retimer_init(void) { u8 reg; @@ -804,7 +804,7 @@ exit: return ret; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) int board_init(void) { init_final_memctl_regs(); @@ -995,7 +995,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; } #endif -#endif /* defined(CONFIG_SPL_BUILD) */ +#endif /* defined(CONFIG_XPL_BUILD) */
#ifdef CONFIG_TFABOOT #ifdef CONFIG_MTD_NOR_FLASH diff --git a/board/freescale/ls2080aqds/ddr.c b/board/freescale/ls2080aqds/ddr.c index d19c061e122..31ed72c949b 100644 --- a/board/freescale/ls2080aqds/ddr.c +++ b/board/freescale/ls2080aqds/ddr.c @@ -168,7 +168,7 @@ int fsl_initdram(void) #else int fsl_initdram(void) { -#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD) gd->ram_size = fsl_ddr_sdram_size(); #else puts("Initializing DDR....using SPD\n"); diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 4c8d0706688..aba0560181a 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -264,7 +264,7 @@ void detail_board_ddr_info(void) #endif }
-#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_XPL_BUILD) void fdt_fixup_board_enet(void *fdt) { int offset; @@ -323,7 +323,7 @@ int ft_board_setup(void *blob, struct bd_info *bd)
fsl_fdt_fixup_dr_usb(blob, bd);
-#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_XPL_BUILD) fdt_fixup_board_enet(blob); fdt_reserve_mc_mem(blob, 0x300); #endif diff --git a/board/freescale/ls2080ardb/ddr.c b/board/freescale/ls2080ardb/ddr.c index a1a97f9f8c2..e56667c846f 100644 --- a/board/freescale/ls2080ardb/ddr.c +++ b/board/freescale/ls2080ardb/ddr.c @@ -173,7 +173,7 @@ int fsl_initdram(void) #else int fsl_initdram(void) { -#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SPL) && !defined(CONFIG_XPL_BUILD) gd->ram_size = fsl_ddr_sdram_size(); #else puts("Initializing DDR....using SPD\n"); diff --git a/board/freescale/ls2080ardb/eth_ls2080rdb.c b/board/freescale/ls2080ardb/eth_ls2080rdb.c index 7fc4fecf774..7d5beb32417 100644 --- a/board/freescale/ls2080ardb/eth_ls2080rdb.c +++ b/board/freescale/ls2080ardb/eth_ls2080rdb.c @@ -12,7 +12,7 @@ DECLARE_GLOBAL_DATA_PTR; int board_eth_init(struct bd_info *bis) {
-#if defined(CONFIG_PHY_AQUANTIA) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_PHY_AQUANTIA) && !defined(CONFIG_XPL_BUILD) /* * Export functions to be used by AQ firmware * upload application diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index 3aa984dab8e..341f82ce724 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -58,7 +58,7 @@ DECLARE_GLOBAL_DATA_PTR;
int board_early_init_f(void) { -#if defined(CONFIG_SYS_I2C_EARLY_INIT) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SYS_I2C_EARLY_INIT) && defined(CONFIG_XPL_BUILD) i2c_early_init_f(); #endif
diff --git a/board/freescale/mx23evk/Makefile b/board/freescale/mx23evk/Makefile index 6fe6992a5fc..5cc99ab1836 100644 --- a/board/freescale/mx23evk/Makefile +++ b/board/freescale/mx23evk/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y := mx23evk.o else obj-y := spl_boot.o diff --git a/board/freescale/mx28evk/Makefile b/board/freescale/mx28evk/Makefile index 057760433da..1fd2a439f7a 100644 --- a/board/freescale/mx28evk/Makefile +++ b/board/freescale/mx28evk/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y := mx28evk.o else obj-y := iomux.o diff --git a/board/freescale/mx6memcal/Makefile b/board/freescale/mx6memcal/Makefile index fc2d3eb9e10..b4088b9f2ec 100644 --- a/board/freescale/mx6memcal/Makefile +++ b/board/freescale/mx6memcal/Makefile @@ -4,7 +4,7 @@ # # (C) Copyright 2011 Freescale Semiconductor, Inc.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := spl.o else obj-y := mx6memcal.o diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index bab62fd4421..8ca57e0b2ac 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -545,7 +545,7 @@ int board_ehci_hcd_init(int port) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <asm/arch/mx6-ddr.h> #include <spl.h> #include <linux/libfdt.h> diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index bb066a5d36c..dff3a9c33bf 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -507,7 +507,7 @@ int board_late_init(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <asm/arch/mx6-ddr.h> #include <spl.h> #include <linux/libfdt.h> diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index d37d8a4136f..fb145fa6aac 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -61,7 +61,7 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_UART1_RXD__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static iomux_v3_cfg_t const usdhc1_pads[] = { /* 8 bit SD */ MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -195,7 +195,7 @@ int checkboard(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <spl.h> #include <linux/libfdt.h>
diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index e5a0197e2fd..c4ab59da78c 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -123,7 +123,7 @@ static int board_qspi_init(void) } #endif
#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ @@ -346,7 +346,7 @@ void board_preboot_os(void) gpio_set_value(IMX_GPIO_NR(5, 9), 0); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <linux/libfdt.h> #include <spl.h> #include <asm/arch/mx6-ddr.h> diff --git a/board/freescale/p1010rdb/Makefile b/board/freescale/p1010rdb/Makefile index a00806e6aae..df4e8001d38 100644 --- a/board/freescale/p1010rdb/Makefile +++ b/board/freescale/p1010rdb/Makefile @@ -4,7 +4,7 @@
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y @@ -15,7 +15,7 @@ endif ifdef MINIMAL obj-y += spl_minimal.o else -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o endif obj-y += p1010rdb.o diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index e386840d9ef..9b4b6f34f46 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -656,7 +656,7 @@ int misc_init_r(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int pin_mux_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/board/freescale/p1010rdb/tlb.c b/board/freescale/p1010rdb/tlb.c index 44acebaa2bb..aa130ccf78b 100644 --- a/board/freescale/p1010rdb/tlb.c +++ b/board/freescale/p1010rdb/tlb.c @@ -41,7 +41,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 1, BOOKE_PAGESZ_1M, 1),
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD SET_TLB_ENTRY(1, CFG_SYS_FLASH_BASE, CFG_SYS_FLASH_BASE_PHYS, MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_16M, 1), diff --git a/board/freescale/p1_p2_rdb_pc/Makefile b/board/freescale/p1_p2_rdb_pc/Makefile index cbdb2507e83..8c13813e3b0 100644 --- a/board/freescale/p1_p2_rdb_pc/Makefile +++ b/board/freescale/p1_p2_rdb_pc/Makefile @@ -4,7 +4,7 @@
MINIMAL=
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y @@ -15,7 +15,7 @@ endif ifdef MINIMAL obj-y += spl_minimal.o else -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o endif obj-y += p1_p2_rdb_pc.o diff --git a/board/freescale/p1_p2_rdb_pc/tlb.c b/board/freescale/p1_p2_rdb_pc/tlb.c index ae0b7adbe54..f27821418eb 100644 --- a/board/freescale/p1_p2_rdb_pc/tlb.c +++ b/board/freescale/p1_p2_rdb_pc/tlb.c @@ -37,7 +37,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 1, BOOKE_PAGESZ_1M, 1),
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* W**G* - Flash/promjet, localbus */ /* This will be changed to *I*G* after relocation to RAM. */ SET_TLB_ENTRY(1, CFG_SYS_FLASH_BASE, CFG_SYS_FLASH_BASE_PHYS, diff --git a/board/freescale/t102xrdb/Makefile b/board/freescale/t102xrdb/Makefile index e597486c940..b0f27c47191 100644 --- a/board/freescale/t102xrdb/Makefile +++ b/board/freescale/t102xrdb/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += t102xrdb.o diff --git a/board/freescale/t102xrdb/ddr.c b/board/freescale/t102xrdb/ddr.c index f8d504fb3c7..1a8a131cdcc 100644 --- a/board/freescale/t102xrdb/ddr.c +++ b/board/freescale/t102xrdb/ddr.c @@ -236,7 +236,7 @@ int dram_init(void) { phys_size_t dram_size;
-#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) #ifndef CONFIG_SYS_DDR_RAW_TIMING puts("Initializing....using SPD\n"); #endif @@ -248,7 +248,7 @@ int dram_init(void) dram_size = setup_ddr_tlbs(dram_size / 0x100000); dram_size *= 0x100000;
diff --git a/board/freescale/t102xrdb/tlb.c b/board/freescale/t102xrdb/tlb.c index 008bd6e72b7..8e99c2c7022 100644 --- a/board/freescale/t102xrdb/tlb.c +++ b/board/freescale/t102xrdb/tlb.c @@ -53,7 +53,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* *I*G* - PCI */ SET_TLB_ENTRY(1, CFG_SYS_PCIE1_MEM_VIRT, CFG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -100,7 +100,7 @@ struct fsl_e_tlb_entry tlb_table[] = { 0, 11, BOOKE_PAGESZ_256K, 1), #endif
-#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_XPL_BUILD) SET_TLB_ENTRY(1, CFG_SYS_DDR_SDRAM_BASE, CFG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, 0, 12, BOOKE_PAGESZ_1G, 1), diff --git a/board/freescale/t104xrdb/Makefile b/board/freescale/t104xrdb/Makefile index a9495019430..9bca1a1fbcc 100644 --- a/board/freescale/t104xrdb/Makefile +++ b/board/freescale/t104xrdb/Makefile @@ -2,7 +2,7 @@ # # Copyright 2013 Freescale Semiconductor, Inc.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += t104xrdb.o diff --git a/board/freescale/t104xrdb/ddr.c b/board/freescale/t104xrdb/ddr.c index bab684860da..6c066480b46 100644 --- a/board/freescale/t104xrdb/ddr.c +++ b/board/freescale/t104xrdb/ddr.c @@ -129,7 +129,7 @@ int dram_init(void) { phys_size_t dram_size;
-#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) puts("Initializing....using SPD\n"); dram_size = fsl_ddr_sdram(); #else @@ -138,7 +138,7 @@ int dram_init(void) dram_size = setup_ddr_tlbs(dram_size / 0x100000); dram_size *= 0x100000;
diff --git a/board/freescale/t104xrdb/tlb.c b/board/freescale/t104xrdb/tlb.c index 24bc83f756b..7b2183da8b0 100644 --- a/board/freescale/t104xrdb/tlb.c +++ b/board/freescale/t104xrdb/tlb.c @@ -38,7 +38,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_256K, 1),
-#elif defined(CONFIG_NXP_ESBC) && defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_NXP_ESBC) && defined(CONFIG_XPL_BUILD) /* * *I*G - L3SRAM. When L3 is used as 256K SRAM, in case of Secure Boot * the physical address of the SRAM is at 0xbffc0000, @@ -66,7 +66,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* *I*G* - PCI */ SET_TLB_ENTRY(1, CFG_SYS_PCIE1_MEM_VIRT, CFG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -118,7 +118,7 @@ struct fsl_e_tlb_entry tlb_table[] = { 0, 11, BOOKE_PAGESZ_256K, 1), #endif
-#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_XPL_BUILD) SET_TLB_ENTRY(1, CFG_SYS_DDR_SDRAM_BASE, CFG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, 0, 12, BOOKE_PAGESZ_1G, 1), diff --git a/board/freescale/t208xqds/Makefile b/board/freescale/t208xqds/Makefile index de8613058de..eb99d921b4a 100644 --- a/board/freescale/t208xqds/Makefile +++ b/board/freescale/t208xqds/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-$(CONFIG_TARGET_T2080QDS) += t208xqds.o eth_t208xqds.o diff --git a/board/freescale/t208xqds/ddr.c b/board/freescale/t208xqds/ddr.c index 9076fbba10a..77c8ce0c870 100644 --- a/board/freescale/t208xqds/ddr.c +++ b/board/freescale/t208xqds/ddr.c @@ -109,7 +109,7 @@ int dram_init(void) { phys_size_t dram_size;
-#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) puts("Initializing....using SPD\n"); dram_size = fsl_ddr_sdram(); #else diff --git a/board/freescale/t208xqds/tlb.c b/board/freescale/t208xqds/tlb.c index a4cc532acda..08c140afc68 100644 --- a/board/freescale/t208xqds/tlb.c +++ b/board/freescale/t208xqds/tlb.c @@ -65,7 +65,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* *I*G* - PCIe 1, 0x80000000 */ SET_TLB_ENTRY(1, CFG_SYS_PCIE1_MEM_VIRT, CFG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -142,7 +142,7 @@ struct fsl_e_tlb_entry tlb_table[] = { 0, 18, BOOKE_PAGESZ_1M, 1), #endif
-#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_XPL_BUILD) SET_TLB_ENTRY(1, CFG_SYS_DDR_SDRAM_BASE, CFG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, 0, 19, BOOKE_PAGESZ_2G, 1) diff --git a/board/freescale/t208xrdb/Makefile b/board/freescale/t208xrdb/Makefile index 7af3cd0ac4c..e5ef250c8b2 100644 --- a/board/freescale/t208xrdb/Makefile +++ b/board/freescale/t208xrdb/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-$(CONFIG_TARGET_T2080RDB) += t208xrdb.o eth_t208xrdb.o cpld.o diff --git a/board/freescale/t208xrdb/ddr.c b/board/freescale/t208xrdb/ddr.c index fe98f62668a..cc9586eaa14 100644 --- a/board/freescale/t208xrdb/ddr.c +++ b/board/freescale/t208xrdb/ddr.c @@ -102,7 +102,7 @@ int dram_init(void) { phys_size_t dram_size;
-#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) puts("Initializing....using SPD\n"); dram_size = fsl_ddr_sdram(); #else diff --git a/board/freescale/t208xrdb/tlb.c b/board/freescale/t208xrdb/tlb.c index a9a03908dfb..a3f283548f3 100644 --- a/board/freescale/t208xrdb/tlb.c +++ b/board/freescale/t208xrdb/tlb.c @@ -65,7 +65,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* *I*G* - PCIe 1, 0x80000000 */ SET_TLB_ENTRY(1, CFG_SYS_PCIE1_MEM_VIRT, CFG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -141,7 +141,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, 0, 18, BOOKE_PAGESZ_1M, 1), #endif -#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_XPL_BUILD) SET_TLB_ENTRY(1, CFG_SYS_DDR_SDRAM_BASE, CFG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, 0, 19, BOOKE_PAGESZ_2G, 1) diff --git a/board/freescale/t4rdb/Makefile b/board/freescale/t4rdb/Makefile index 3106848639c..8d94faaba1c 100644 --- a/board/freescale/t4rdb/Makefile +++ b/board/freescale/t4rdb/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-$(CONFIG_TARGET_T4240RDB) += t4240rdb.o diff --git a/board/freescale/t4rdb/cpld.c b/board/freescale/t4rdb/cpld.c index cd14d5895f5..f076350c1c5 100644 --- a/board/freescale/t4rdb/cpld.c +++ b/board/freescale/t4rdb/cpld.c @@ -94,7 +94,7 @@ static void cpld_dump_regs(void) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int do_cpld(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { int rc = 0; diff --git a/board/freescale/t4rdb/ddr.c b/board/freescale/t4rdb/ddr.c index bbe31d4a54e..1ce70962264 100644 --- a/board/freescale/t4rdb/ddr.c +++ b/board/freescale/t4rdb/ddr.c @@ -111,7 +111,7 @@ int dram_init(void)
-#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) +#if defined(CONFIG_XPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) dram_size = fsl_ddr_sdram(); #else /* DDR has been initialised by first stage boot loader */ diff --git a/board/freescale/t4rdb/tlb.c b/board/freescale/t4rdb/tlb.c index 1fb9d41d52b..7c58c14f3b6 100644 --- a/board/freescale/t4rdb/tlb.c +++ b/board/freescale/t4rdb/tlb.c @@ -51,7 +51,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* *I*G* - PCI */ SET_TLB_ENTRY(1, CFG_SYS_PCIE1_MEM_VIRT, CFG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -114,7 +114,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SW|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 17, BOOKE_PAGESZ_4K, 1), #endif -#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_XPL_BUILD) SET_TLB_ENTRY(1, CFG_SYS_DDR_SDRAM_BASE, CFG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, 0, 18, BOOKE_PAGESZ_2G, 1) diff --git a/board/gardena/smart-gateway-at91sam/Makefile b/board/gardena/smart-gateway-at91sam/Makefile index a2ed79fd06c..ac9e57938b3 100644 --- a/board/gardena/smart-gateway-at91sam/Makefile +++ b/board/gardena/smart-gateway-at91sam/Makefile @@ -2,6 +2,6 @@
obj-y += board.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o endif diff --git a/board/gardena/smart-gateway-mt7688/board.c b/board/gardena/smart-gateway-mt7688/board.c index eb7fcd630a1..b6c0fe960ea 100644 --- a/board/gardena/smart-gateway-mt7688/board.c +++ b/board/gardena/smart-gateway-mt7688/board.c @@ -295,7 +295,7 @@ err_free: return ret; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD U_BOOT_CMD( fd_write, 1, 0, do_fd_write, "Write test factory-data values to SPI NOR", diff --git a/board/gateworks/gw_ventana/Makefile b/board/gateworks/gw_ventana/Makefile index c407f8e6c54..08859a963d0 100644 --- a/board/gateworks/gw_ventana/Makefile +++ b/board/gateworks/gw_ventana/Makefile @@ -7,4 +7,4 @@ #
obj-y := gw_ventana.o eeprom.o common.o -obj-$(CONFIG_SPL_BUILD) += gw_ventana_spl.o +obj-$(CONFIG_XPL_BUILD) += gw_ventana_spl.o diff --git a/board/gateworks/gw_ventana/eeprom.c b/board/gateworks/gw_ventana/eeprom.c index b37f1972249..447862dfee1 100644 --- a/board/gateworks/gw_ventana/eeprom.c +++ b/board/gateworks/gw_ventana/eeprom.c @@ -327,7 +327,7 @@ struct ventana_eeprom_config econfig[] = { { /* Sentinel */ } };
-#if defined(CONFIG_CMD_EECONFIG) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_EECONFIG) && !defined(CONFIG_XPL_BUILD) static struct ventana_eeprom_config *get_config(const char *name) { struct ventana_eeprom_config *cfg = econfig; diff --git a/board/gateworks/venice/Makefile b/board/gateworks/venice/Makefile index faf1348cfa9..ab69e07ba7b 100644 --- a/board/gateworks/venice/Makefile +++ b/board/gateworks/venice/Makefile @@ -6,7 +6,7 @@
obj-y += venice.o eeprom.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o ifdef CONFIG_IMX8MM obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_imx8mm.o diff --git a/board/gdsys/a38x/Makefile b/board/gdsys/a38x/Makefile index 4b13859fed1..2713633730f 100644 --- a/board/gdsys/a38x/Makefile +++ b/board/gdsys/a38x/Makefile @@ -6,6 +6,6 @@
obj-$(CONFIG_TARGET_CONTROLCENTERDC) += controlcenterdc.o hre.o keyprogram.o dt_helpers.o
-ifeq ($(CONFIG_SPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD),) obj-$(CONFIG_TARGET_CONTROLCENTERDC) += hydra.o ihs_phys.o endif diff --git a/board/gdsys/a38x/controlcenterdc.c b/board/gdsys/a38x/controlcenterdc.c index 4abb3e45128..659dfddecea 100644 --- a/board/gdsys/a38x/controlcenterdc.c +++ b/board/gdsys/a38x/controlcenterdc.c @@ -84,7 +84,7 @@ int hws_board_topology_load(struct serdes_map **serdes_map_array, u8 *count)
void spl_board_init(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD uint k; struct gpio_desc gpio = {};
@@ -139,7 +139,7 @@ struct mv_ddr_topology_map *mv_ddr_topology_map_get(void)
int board_early_init_f(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* Configure MPP */ writel(0x00111111, MVEBU_MPP_BASE + 0x00); writel(0x40040000, MVEBU_MPP_BASE + 0x04); @@ -174,7 +174,7 @@ int board_init(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD void init_host_phys(struct mii_dev *bus) { uint k; @@ -241,7 +241,7 @@ int ccdc_eth_init(void)
int board_late_init(void) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD hydra_initialize(); #endif return 0; @@ -272,13 +272,13 @@ int board_fix_fdt(void *rw_fdt_blob) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int last_stage_init(void) { struct udevice *tpm; int ret;
- if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return 0; ccdc_eth_init();
diff --git a/board/ge/b1x5v2/b1x5v2.c b/board/ge/b1x5v2/b1x5v2.c index 031773bc5ef..c1aacd1458b 100644 --- a/board/ge/b1x5v2/b1x5v2.c +++ b/board/ge/b1x5v2/b1x5v2.c @@ -35,7 +35,7 @@
#define B1X5V2_GE_VPD_OFFSET 0x0100000 #define B1X5V2_GE_VPD_SIZE 1022 @@ -695,4 +695,4 @@ U_BOOT_CMD( "" );
-#endif // CONFIG_SPL_BUILD +#endif // CONFIG_XPL_BUILD diff --git a/board/ge/b1x5v2/spl.c b/board/ge/b1x5v2/spl.c index 460d3be1d83..b6f23345acd 100644 --- a/board/ge/b1x5v2/spl.c +++ b/board/ge/b1x5v2/spl.c @@ -20,7 +20,7 @@ #include <spi_flash.h> #include <spl.h>
diff --git a/board/google/chromebook_coral/coral.c b/board/google/chromebook_coral/coral.c index 7b2724c01d0..3443dc91885 100644 --- a/board/google/chromebook_coral/coral.c +++ b/board/google/chromebook_coral/coral.c @@ -147,7 +147,7 @@ static int coral_get_str(struct udevice *dev, int id, size_t size, char *val) { int ret;
- if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return -ENOSYS;
switch (id) { diff --git a/board/google/gru/gru.c b/board/google/gru/gru.c index e08cb42c27e..f3a1a19f2b6 100644 --- a/board/google/gru/gru.c +++ b/board/google/gru/gru.c @@ -7,7 +7,7 @@ #include <init.h> #include <asm/arch-rockchip/clock.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* provided to defeat compiler optimisation in board_init_f() */ void gru_dummy_function(int i) { @@ -33,7 +33,7 @@ int board_early_init_f(void) } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int board_early_init_r(void) { struct udevice *clk; diff --git a/board/google/imx8mq_phanbell/Makefile b/board/google/imx8mq_phanbell/Makefile index d6427cf8e90..ac6418e49a7 100644 --- a/board/google/imx8mq_phanbell/Makefile +++ b/board/google/imx8mq_phanbell/Makefile @@ -5,7 +5,7 @@
obj-y += imx8mq_phanbell.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_1g.o endif diff --git a/board/google/veyron/veyron.c b/board/google/veyron/veyron.c index bd8ce633772..7057b76e290 100644 --- a/board/google/veyron/veyron.c +++ b/board/google/veyron/veyron.c @@ -19,7 +19,7 @@ * There is a U-Boot driver for this but it may need to add support for the * 'voltage-table' property. */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #if !CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) static int veyron_init(void) { diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index e0eb8aa9f2b..d5491d5076f 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -104,7 +104,7 @@ int board_init(void) #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo;
diff --git a/board/grinn/liteboard/board.c b/board/grinn/liteboard/board.c index 07bb5b7d797..c2a44b4aa2d 100644 --- a/board/grinn/liteboard/board.c +++ b/board/grinn/liteboard/board.c @@ -229,7 +229,7 @@ int checkboard(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void board_boot_order(u32 *spl_boot_list) { struct src *psrc = (struct src *)SRC_BASE_ADDR; diff --git a/board/htc/endeavoru/Makefile b/board/htc/endeavoru/Makefile index 0c6ba4af3b1..57f84d6ea98 100644 --- a/board/htc/endeavoru/Makefile +++ b/board/htc/endeavoru/Makefile @@ -6,6 +6,6 @@ # (C) Copyright 2021 # Svyatoslav Ryhel clamor95@gmail.com
-obj-$(CONFIG_SPL_BUILD) += endeavoru-spl.o +obj-$(CONFIG_XPL_BUILD) += endeavoru-spl.o
obj-y += endeavoru.o diff --git a/board/imgtec/ci20/ci20.c b/board/imgtec/ci20/ci20.c index 4e268381d3c..3e9833d684f 100644 --- a/board/imgtec/ci20/ci20.c +++ b/board/imgtec/ci20/ci20.c @@ -39,7 +39,7 @@ static void ci20_mux_mmc(void) jz4780_clk_ungate_mmc(); }
static void ci20_mux_eth(void) { @@ -251,7 +251,7 @@ int checkboard(void) return 0; }
#if defined(CONFIG_SPL_MMC) int board_mmc_init(struct bd_info *bd) diff --git a/board/isee/igep003x/Makefile b/board/isee/igep003x/Makefile index c3e39745252..02ec0ccbdb2 100644 --- a/board/isee/igep003x/Makefile +++ b/board/isee/igep003x/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += mux.o endif
diff --git a/board/isee/igep003x/board.c b/board/isee/igep003x/board.c index 7cd26ce3c34..162467c803a 100644 --- a/board/isee/igep003x/board.c +++ b/board/isee/igep003x/board.c @@ -68,7 +68,7 @@ static int get_board_revision(void) return revision; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* PN H5TQ4G63AFR is equivalent to MT41K256M16HA125*/ static const struct ddr_data ddr3_igep0034_data = { .datardsratio0 = MT41K256M16HA125E_RD_DQS, diff --git a/board/isee/igep00x0/Makefile b/board/isee/igep00x0/Makefile index e095bcada29..527748cdadd 100644 --- a/board/isee/igep00x0/Makefile +++ b/board/isee/igep00x0/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000, 2001, 2002 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := spl.o common.o else obj-y := igep00x0.o common.o diff --git a/board/k+p/kp_imx6q_tpc/Makefile b/board/k+p/kp_imx6q_tpc/Makefile index 6551b2bfa2d..6444628c649 100644 --- a/board/k+p/kp_imx6q_tpc/Makefile +++ b/board/k+p/kp_imx6q_tpc/Makefile @@ -2,7 +2,7 @@ # # Copyright (C) 2018 Lukasz Majewski lukma@denx.de
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := kp_imx6q_tpc_spl.o else obj-y := kp_imx6q_tpc.o diff --git a/board/kontron/pitx_imx8m/Makefile b/board/kontron/pitx_imx8m/Makefile index 6ebe5d07709..50ca56f4efd 100644 --- a/board/kontron/pitx_imx8m/Makefile +++ b/board/kontron/pitx_imx8m/Makefile @@ -2,7 +2,7 @@
obj-y += pitx_imx8m.o pitx_misc.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o pitx_misc.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_2gb.o lpddr4_timing_4gb.o endif diff --git a/board/kontron/sl-mx6ul/Makefile b/board/kontron/sl-mx6ul/Makefile index 6af5f65450a..dfed1991ee7 100644 --- a/board/kontron/sl-mx6ul/Makefile +++ b/board/kontron/sl-mx6ul/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # (C) Copyright 2018 Kontron Electronics GmbH
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := spl.o else obj-y := sl-mx6ul.o diff --git a/board/kontron/sl-mx8mm/Makefile b/board/kontron/sl-mx8mm/Makefile index fceed684ede..b47fafc5733 100644 --- a/board/kontron/sl-mx8mm/Makefile +++ b/board/kontron/sl-mx8mm/Makefile @@ -3,7 +3,7 @@
obj-y := sl-mx8mm.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/kontron/sl28/Makefile b/board/kontron/sl28/Makefile index 084c11da376..2cb41251708 100644 --- a/board/kontron/sl28/Makefile +++ b/board/kontron/sl28/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += sl28.o cmds.o endif
@@ -8,7 +8,7 @@ obj-y += common.o ddr.o
obj-$(CONFIG_ARMV8_PSCI) += psci.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_SPL_ATF) += spl_atf.o endif diff --git a/board/kontron/sl28/ddr.c b/board/kontron/sl28/ddr.c index 9b881fdc265..1f1a6aa1b16 100644 --- a/board/kontron/sl28/ddr.c +++ b/board/kontron/sl28/ddr.c @@ -98,7 +98,7 @@ int fsl_initdram(void) break; }
- if (!IS_ENABLED(CONFIG_SPL) || IS_ENABLED(CONFIG_SPL_BUILD)) + if (!IS_ENABLED(CONFIG_SPL) || IS_ENABLED(CONFIG_XPL_BUILD)) fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0, 0);
gd->ram_size = dram_size; diff --git a/board/kosagi/novena/Makefile b/board/kosagi/novena/Makefile index 64d32f5a963..fdcd8b5f422 100644 --- a/board/kosagi/novena/Makefile +++ b/board/kosagi/novena/Makefile @@ -2,7 +2,7 @@ # # Copyright (C) 2014 Marek Vasut marex@denx.de
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := novena_spl.o else obj-y := novena.o diff --git a/board/lenovo/ideapad-yoga-11/Makefile b/board/lenovo/ideapad-yoga-11/Makefile index 186f1cb4ee5..fd9736d1bf1 100644 --- a/board/lenovo/ideapad-yoga-11/Makefile +++ b/board/lenovo/ideapad-yoga-11/Makefile @@ -3,4 +3,4 @@ # (C) Copyright 2022 # Open Surface RT
-obj-$(CONFIG_SPL_BUILD) += ideapad-yoga-11-spl.o +obj-$(CONFIG_XPL_BUILD) += ideapad-yoga-11-spl.o diff --git a/board/lg/sniper/sniper.c b/board/lg/sniper/sniper.c index 9d0959f294e..d4db32ee69b 100644 --- a/board/lg/sniper/sniper.c +++ b/board/lg/sniper/sniper.c @@ -54,7 +54,7 @@ void set_muxconf_regs(void) MUX_SNIPER(); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void get_board_mem_timings(struct board_sdrc_timings *timings) { timings->mcfg = HYNIX_V_MCFG_200(256 << 20); diff --git a/board/lg/x3-t30/Makefile b/board/lg/x3-t30/Makefile index 3eeb132f3c6..fb2527f9ee8 100644 --- a/board/lg/x3-t30/Makefile +++ b/board/lg/x3-t30/Makefile @@ -6,6 +6,6 @@ # (C) Copyright 2021 # Svyatoslav Ryhel clamor95@gmail.com
-obj-$(CONFIG_SPL_BUILD) += x3-t30-spl.o +obj-$(CONFIG_XPL_BUILD) += x3-t30-spl.o
obj-y += x3-t30.o diff --git a/board/liebherr/display5/Makefile b/board/liebherr/display5/Makefile index ee503add75d..c62583a9806 100644 --- a/board/liebherr/display5/Makefile +++ b/board/liebherr/display5/Makefile @@ -4,7 +4,7 @@ # # SPDX-License-Identifier: GPL-2.0+ # -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y = spl.o else obj-y := display5.o diff --git a/board/liebherr/mccmon6/Makefile b/board/liebherr/mccmon6/Makefile index 3c9786c6b7d..d5fdc2011b0 100644 --- a/board/liebherr/mccmon6/Makefile +++ b/board/liebherr/mccmon6/Makefile @@ -2,7 +2,7 @@ # # (C) Copyright 2016-2017 # Lukasz Majewski, DENX Software Engineering, lukma@denx.de -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := spl.o else obj-y := mccmon6.o diff --git a/board/liebherr/xea/Makefile b/board/liebherr/xea/Makefile index abf500857f6..6efa07ca004 100644 --- a/board/liebherr/xea/Makefile +++ b/board/liebherr/xea/Makefile @@ -7,6 +7,6 @@
obj-y := xea.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl_xea.o endif diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index 9ade3563b25..1d4f165fd13 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -37,7 +37,7 @@ #include <spi.h> #include <spi_flash.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <spl.h> #endif
@@ -62,7 +62,7 @@ static void init_clocks(void) mxs_set_sspclk(MXC_SSPCLK3, 96000, 0); }
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_FRAMEWORK) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_FRAMEWORK) void board_init_f(ulong arg) { init_clocks(); @@ -355,4 +355,4 @@ U_BOOT_DRIVER(fsl_imx28_clkctrl) = { .id = UCLASS_CLK, .of_match = imx28_clk_ids, }; -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/board/logicpd/am3517evm/am3517evm.c b/board/logicpd/am3517evm/am3517evm.c index e6ca31016b7..e4f619d0942 100644 --- a/board/logicpd/am3517evm/am3517evm.c +++ b/board/logicpd/am3517evm/am3517evm.c @@ -39,7 +39,7 @@ DECLARE_GLOBAL_DATA_PTR; #define CPGMACSS_SW_RST (1 << 1) #define PHY_GPIO 30
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #if defined(CONFIG_SPL_OS_BOOT) int spl_start_uboot(void) { diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index 589136fd64a..652994df616 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -135,7 +135,7 @@ int board_late_init(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <asm/arch/mx6-ddr.h> #include <asm/arch/mx6q-ddr.h> #include <spl.h> diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index a9fe61918b6..352b519b451 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -68,7 +68,7 @@ int spl_start_uboot(void) } #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) /* * Routine: get_board_mem_timings * Description: If we use SPL then there is no x-loader nor config header diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index 79351f47273..fc76d5765fa 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -524,7 +524,7 @@ int checkboard(void) /* * NAND SPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { setup_iomux_nand(); diff --git a/board/menlo/mx8menlo/Makefile b/board/menlo/mx8menlo/Makefile index fd5ec826336..62939395ba1 100644 --- a/board/menlo/mx8menlo/Makefile +++ b/board/menlo/mx8menlo/Makefile @@ -9,13 +9,13 @@ obj-y := mx8menlo.o
obj-y += ../../toradex/verdin-imx8mm/verdin-imx8mm.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += ../../toradex/verdin-imx8mm/spl.o obj-$(CONFIG_IMX8M_LPDDR4) += ../../toradex/verdin-imx8mm/lpddr4_timing.o endif
# Common for all Toradex modules -ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) # Necessary to create built-in.o obj- := __dummy__.o else diff --git a/board/microsoft/surface-rt/Makefile b/board/microsoft/surface-rt/Makefile index da4094a7df3..feda1dba3bd 100644 --- a/board/microsoft/surface-rt/Makefile +++ b/board/microsoft/surface-rt/Makefile @@ -3,4 +3,4 @@ # (C) Copyright 2021 # Open Surface RT
-obj-$(CONFIG_SPL_BUILD) += surface-rt-spl.o +obj-$(CONFIG_XPL_BUILD) += surface-rt-spl.o diff --git a/board/mntre/imx8mq_reform2/Makefile b/board/mntre/imx8mq_reform2/Makefile index 2efd56bb4ad..2772c8dc717 100644 --- a/board/mntre/imx8mq_reform2/Makefile +++ b/board/mntre/imx8mq_reform2/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mq_reform2.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/msc/sm2s_imx8mp/Makefile b/board/msc/sm2s_imx8mp/Makefile index 7908a0ceb04..48dc885b8f6 100644 --- a/board/msc/sm2s_imx8mp/Makefile +++ b/board/msc/sm2s_imx8mp/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o lpddr4_timing.o else obj-y += sm2s_imx8mp.o diff --git a/board/myir/mys_6ulx/Makefile b/board/myir/mys_6ulx/Makefile index 3c63e439aba..9b76595701e 100644 --- a/board/myir/mys_6ulx/Makefile +++ b/board/myir/mys_6ulx/Makefile @@ -1,4 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y := mys_6ulx.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/nvidia/beaver/Makefile b/board/nvidia/beaver/Makefile index 5e9e70825c7..d56c7151af6 100644 --- a/board/nvidia/beaver/Makefile +++ b/board/nvidia/beaver/Makefile @@ -2,6 +2,6 @@ # # Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved.
-obj-$(CONFIG_SPL_BUILD) += beaver-spl.o +obj-$(CONFIG_XPL_BUILD) += beaver-spl.o
obj-y = ../cardhu/cardhu.o diff --git a/board/nvidia/cardhu/Makefile b/board/nvidia/cardhu/Makefile index 6f480cdfd3b..85d88295c08 100644 --- a/board/nvidia/cardhu/Makefile +++ b/board/nvidia/cardhu/Makefile @@ -3,6 +3,6 @@ # (C) Copyright 2010-2012 # NVIDIA Corporation <www.nvidia.com>
-obj-$(CONFIG_SPL_BUILD) += cardhu-spl.o +obj-$(CONFIG_XPL_BUILD) += cardhu-spl.o
obj-y += cardhu.o diff --git a/board/olimex/mx23_olinuxino/Makefile b/board/olimex/mx23_olinuxino/Makefile index b2ea8974344..0a6beb10ded 100644 --- a/board/olimex/mx23_olinuxino/Makefile +++ b/board/olimex/mx23_olinuxino/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y := mx23_olinuxino.o else obj-y := spl_boot.o diff --git a/board/opalkelly/zynq/Makefile b/board/opalkelly/zynq/Makefile index 19e893e43d7..8a2375a1068 100644 --- a/board/opalkelly/zynq/Makefile +++ b/board/opalkelly/zynq/Makefile @@ -4,4 +4,4 @@ obj-y := board.o
hw-platform-y :=$(shell echo $(CONFIG_DEFAULT_DEVICE_TREE))
-obj-$(CONFIG_SPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o +obj-$(CONFIG_XPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o diff --git a/board/phytec/common/Makefile b/board/phytec/common/Makefile index 04469d0a924..cd78f7686fe 100644 --- a/board/phytec/common/Makefile +++ b/board/phytec/common/Makefile @@ -2,7 +2,7 @@ # Copyright (C) 2023 PHYTEC Messtechnik GmbH # Author: Teresa Remmet t.remmet@phytec.de
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD # necessary to create built-in.o obj- := __dummy__.o endif diff --git a/board/phytec/pcl063/Makefile b/board/phytec/pcl063/Makefile index 53c73c9b082..0f17eb466c5 100644 --- a/board/phytec/pcl063/Makefile +++ b/board/phytec/pcl063/Makefile @@ -4,4 +4,4 @@ #
obj-y := pcl063.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/phytec/pcm058/pcm058.c b/board/phytec/pcm058/pcm058.c index ecc5b75d8d4..4a95376b359 100644 --- a/board/phytec/pcm058/pcm058.c +++ b/board/phytec/pcm058/pcm058.c @@ -108,7 +108,7 @@ int board_late_init(void) return 0; }
diff --git a/board/phytec/phycore_am335x_r2/Makefile b/board/phytec/phycore_am335x_r2/Makefile index 16ac38fd8be..4f865ab9e10 100644 --- a/board/phytec/phycore_am335x_r2/Makefile +++ b/board/phytec/phycore_am335x_r2/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2011 Texas Instruments Incorporated - https://www.ti.com/
diff --git a/board/phytec/phycore_am335x_r2/board.c b/board/phytec/phycore_am335x_r2/board.c index 2022525651d..a2a488a0e30 100644 --- a/board/phytec/phycore_am335x_r2/board.c +++ b/board/phytec/phycore_am335x_r2/board.c @@ -26,7 +26,7 @@
static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
diff --git a/board/phytec/phycore_am62x/phycore-am62x.c b/board/phytec/phycore_am62x/phycore-am62x.c index 9f6bc736cbb..a0e098e010e 100644 --- a/board/phytec/phycore_am62x/phycore-am62x.c +++ b/board/phytec/phycore_am62x/phycore-am62x.c @@ -182,7 +182,7 @@ int do_board_detect(void) } #endif
-#if IS_ENABLED(CONFIG_SPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) void spl_perform_fixups(struct spl_image_info *spl_image) { u64 start[CONFIG_NR_DRAM_BANKS]; diff --git a/board/phytec/phycore_imx8mm/Makefile b/board/phytec/phycore_imx8mm/Makefile index 27f6c027b6c..2fb59761fc9 100644 --- a/board/phytec/phycore_imx8mm/Makefile +++ b/board/phytec/phycore_imx8mm/Makefile @@ -5,7 +5,7 @@
obj-y += phycore-imx8mm.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/phytec/phycore_imx8mp/Makefile b/board/phytec/phycore_imx8mp/Makefile index c4c434c9475..8cf1f4dcea3 100644 --- a/board/phytec/phycore_imx8mp/Makefile +++ b/board/phytec/phycore_imx8mp/Makefile @@ -5,7 +5,7 @@
obj-y += phycore-imx8mp.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/phytec/phycore_imx93/Makefile b/board/phytec/phycore_imx93/Makefile index ce35326a156..dd5085e160f 100644 --- a/board/phytec/phycore_imx93/Makefile +++ b/board/phytec/phycore_imx93/Makefile @@ -9,6 +9,6 @@
obj-y += phycore-imx93.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o lpddr4_timing.o endif diff --git a/board/polyhex/imx8mp_debix_model_a/Makefile b/board/polyhex/imx8mp_debix_model_a/Makefile index e5cdc850878..3d50c7af4af 100644 --- a/board/polyhex/imx8mp_debix_model_a/Makefile +++ b/board/polyhex/imx8mp_debix_model_a/Makefile @@ -7,7 +7,7 @@
obj-y += imx8mp_debix_model_a.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/purism/librem5/Makefile b/board/purism/librem5/Makefile index 47f25f047b7..4514add3a5b 100644 --- a/board/purism/librem5/Makefile +++ b/board/purism/librem5/Makefile @@ -7,7 +7,7 @@
obj-y += librem5.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o lpddr4_timing_b0.o endif diff --git a/board/purism/librem5/librem5.h b/board/purism/librem5/librem5.h index 0d24edea9b1..69475a5b063 100644 --- a/board/purism/librem5/librem5.h +++ b/board/purism/librem5/librem5.h @@ -57,7 +57,7 @@ /* Could be ASPEN, BIRCH or CHESTNUT. assume CHESTNUT */ #define BOARD_REV_UNKNOWN BOARD_REV_CHESTNUT
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static const iomux_v3_cfg_t configure_pads[] = { IMX8MQ_PAD_GPIO1_IO00__GPIO1_IO0 | MUX_PAD_CTRL(PAD_CTL_DSE6), IMX8MQ_PAD_GPIO1_IO03__GPIO1_IO3 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, @@ -151,7 +151,7 @@ static inline void init_pinmux(void) gpio_direction_output(AUDIO_EN, 1); gpio_direction_output(DSI_EN, 1); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#define USB1_BASE_ADDR 0x38100000 #define USB2_BASE_ADDR 0x38200000 diff --git a/board/radxa/rockpi4-rk3399/rockpi4-rk3399.c b/board/radxa/rockpi4-rk3399/rockpi4-rk3399.c index a533128b92f..fd827467b30 100644 --- a/board/radxa/rockpi4-rk3399/rockpi4-rk3399.c +++ b/board/radxa/rockpi4-rk3399/rockpi4-rk3399.c @@ -18,7 +18,7 @@ struct efi_capsule_update_info update_info = {
#endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #if IS_ENABLED(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) && IS_ENABLED(CONFIG_EFI_PARTITION) static bool board_is_rockpi_4b(void) { @@ -55,4 +55,4 @@ void rockchip_capsule_update_board_setup(void) } } #endif /* CONFIG_EFI_HAVE_CAPSULE_SUPPORT && CONFIG_EFI_PARTITION */ -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/board/renesas/alt/Makefile b/board/renesas/alt/Makefile index 53418699b27..f9c131fc6cd 100644 --- a/board/renesas/alt/Makefile +++ b/board/renesas/alt/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := alt_spl.o else obj-y := alt.o qos.o diff --git a/board/renesas/condor/Makefile b/board/renesas/condor/Makefile index 19e6038430b..cb965cde35f 100644 --- a/board/renesas/condor/Makefile +++ b/board/renesas/condor/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := ../rcar-common/common.o diff --git a/board/renesas/draak/Makefile b/board/renesas/draak/Makefile index 1fc90d1dab4..8859cf902ca 100644 --- a/board/renesas/draak/Makefile +++ b/board/renesas/draak/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := draak.o ../rcar-common/common.o diff --git a/board/renesas/eagle/Makefile b/board/renesas/eagle/Makefile index 9fb6a7c0f0a..98164b5ea29 100644 --- a/board/renesas/eagle/Makefile +++ b/board/renesas/eagle/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := ../rcar-common/v3-common.o ../rcar-common/common.o diff --git a/board/renesas/ebisu/Makefile b/board/renesas/ebisu/Makefile index 956ce8a90fa..283d3a4ae36 100644 --- a/board/renesas/ebisu/Makefile +++ b/board/renesas/ebisu/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := ../rcar-common/common.o diff --git a/board/renesas/falcon/Makefile b/board/renesas/falcon/Makefile index 3b202c24fb1..2e240d3bad6 100644 --- a/board/renesas/falcon/Makefile +++ b/board/renesas/falcon/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := falcon.o ../rcar-common/common.o diff --git a/board/renesas/gose/Makefile b/board/renesas/gose/Makefile index c6a1dc21cda..2c45bd74014 100644 --- a/board/renesas/gose/Makefile +++ b/board/renesas/gose/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := gose_spl.o else obj-y := gose.o qos.o diff --git a/board/renesas/koelsch/Makefile b/board/renesas/koelsch/Makefile index 77cf067406c..1b0818fa7ec 100644 --- a/board/renesas/koelsch/Makefile +++ b/board/renesas/koelsch/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := koelsch_spl.o else obj-y := koelsch.o qos.o diff --git a/board/renesas/lager/Makefile b/board/renesas/lager/Makefile index 379368fdfce..77e380f9335 100644 --- a/board/renesas/lager/Makefile +++ b/board/renesas/lager/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := lager_spl.o else obj-y := lager.o qos.o diff --git a/board/renesas/porter/Makefile b/board/renesas/porter/Makefile index c237ee5ec77..9f22044bc79 100644 --- a/board/renesas/porter/Makefile +++ b/board/renesas/porter/Makefile @@ -7,7 +7,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := porter_spl.o else obj-y := porter.o qos.o diff --git a/board/renesas/salvator-x/Makefile b/board/renesas/salvator-x/Makefile index 95258079e40..0fc69ba9de6 100644 --- a/board/renesas/salvator-x/Makefile +++ b/board/renesas/salvator-x/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := salvator-x.o ../rcar-common/common.o diff --git a/board/renesas/silk/Makefile b/board/renesas/silk/Makefile index b5c3ad8d934..48dd7dbb8be 100644 --- a/board/renesas/silk/Makefile +++ b/board/renesas/silk/Makefile @@ -7,7 +7,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := silk_spl.o else obj-y := silk.o qos.o diff --git a/board/renesas/stout/Makefile b/board/renesas/stout/Makefile index b8875bb7b98..e1bca5339b9 100644 --- a/board/renesas/stout/Makefile +++ b/board/renesas/stout/Makefile @@ -8,7 +8,7 @@ # SPDX-License-Identifier: GPL-2.0 #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := stout_spl.o else obj-y := stout.o cpld.o qos.o diff --git a/board/renesas/ulcb/Makefile b/board/renesas/ulcb/Makefile index f4d24c68a67..ec2f161feae 100644 --- a/board/renesas/ulcb/Makefile +++ b/board/renesas/ulcb/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := ulcb.o cpld.o ../rcar-common/common.o diff --git a/board/renesas/v3hsk/Makefile b/board/renesas/v3hsk/Makefile index a9d597edd58..b29114c7239 100644 --- a/board/renesas/v3hsk/Makefile +++ b/board/renesas/v3hsk/Makefile @@ -7,7 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := ../rcar-common/v3-common.o ../rcar-common/common.o diff --git a/board/renesas/v3msk/Makefile b/board/renesas/v3msk/Makefile index ec493e572f1..f8c4bcdcf9f 100644 --- a/board/renesas/v3msk/Makefile +++ b/board/renesas/v3msk/Makefile @@ -7,7 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../rcar-common/gen3-spl.o else obj-y := ../rcar-common/v3-common.o ../rcar-common/common.o diff --git a/board/ronetix/imx7-cm/Makefile b/board/ronetix/imx7-cm/Makefile index 7e08f238a0d..1ca6332852f 100644 --- a/board/ronetix/imx7-cm/Makefile +++ b/board/ronetix/imx7-cm/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # (C) Copyright 2017 NXP Semiconductors
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += imx7-cm.o diff --git a/board/ronetix/imx8mq-cm/Makefile b/board/ronetix/imx8mq-cm/Makefile index 0d9d8e646db..4ca2a96d81e 100644 --- a/board/ronetix/imx8mq-cm/Makefile +++ b/board/ronetix/imx8mq-cm/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mq_cm.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/samsung/common/Makefile b/board/samsung/common/Makefile index d31b81abf1e..abecef8be11 100644 --- a/board/samsung/common/Makefile +++ b/board/samsung/common/Makefile @@ -6,7 +6,7 @@ obj-$(CONFIG_USB_GADGET_DOWNLOAD) += gadget.o obj-$(CONFIG_MISC_COMMON) += misc.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_BOARD_COMMON) += board.o sromc.o ifdef CONFIG_EXYNOS5_DT obj-y += exynos5-dt.o diff --git a/board/samsung/origen/Makefile b/board/samsung/origen/Makefile index 44691af09f4..940f689a601 100644 --- a/board/samsung/origen/Makefile +++ b/board/samsung/origen/Makefile @@ -2,7 +2,7 @@ # # Copyright (C) 2011 Samsung Electronics
diff --git a/board/samsung/smdkv310/Makefile b/board/samsung/smdkv310/Makefile index fccd8ffd2c1..b7f9d5a254c 100644 --- a/board/samsung/smdkv310/Makefile +++ b/board/samsung/smdkv310/Makefile @@ -2,7 +2,7 @@ # # Copyright (C) 2011 Samsung Electronics
diff --git a/board/seeed/npi_imx6ull/Makefile b/board/seeed/npi_imx6ull/Makefile index 93ea413517d..bd8f83148bb 100644 --- a/board/seeed/npi_imx6ull/Makefile +++ b/board/seeed/npi_imx6ull/Makefile @@ -1,4 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y := npi_imx6ull.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/sielaff/imx6dl-sielaff/Makefile b/board/sielaff/imx6dl-sielaff/Makefile index 65cecfe6f6c..9c8bab662e4 100644 --- a/board/sielaff/imx6dl-sielaff/Makefile +++ b/board/sielaff/imx6dl-sielaff/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # (C) Copyright 2022 Kontron Electronics GmbH
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := spl.o else obj-y := imx6dl-sielaff.o diff --git a/board/siemens/capricorn/Makefile b/board/siemens/capricorn/Makefile index 4dafac10829..e8a24c448b9 100644 --- a/board/siemens/capricorn/Makefile +++ b/board/siemens/capricorn/Makefile @@ -6,7 +6,7 @@ obj-y += board.o obj-y += ../common/eeprom.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += ../common/factoryset.o diff --git a/board/siemens/capricorn/board.c b/board/siemens/capricorn/board.c index 53dac8bfe1b..ad474d9baa0 100644 --- a/board/siemens/capricorn/board.c +++ b/board/siemens/capricorn/board.c @@ -235,7 +235,7 @@ void reset_cpu(void) { }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* LED's */ static int board_led_init(void) { @@ -265,7 +265,7 @@ static int board_led_init(void) mdelay(1); return ret; } -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */
int checkboard(void) { @@ -335,7 +335,7 @@ void board_late_mmc_env_init(void) run_command(cmd, 0); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int load_parameters_from_factoryset(void) { int ret; @@ -443,4 +443,4 @@ U_BOOT_CMD( "Reset eth phy", "[print]" ); -#endif /* ! CONFIG_SPL_BUILD */ +#endif /* ! CONFIG_XPL_BUILD */ diff --git a/board/siemens/common/board_am335x.c b/board/siemens/common/board_am335x.c index e6537b0675a..daf0bb930ec 100644 --- a/board/siemens/common/board_am335x.c +++ b/board/siemens/common/board_am335x.c @@ -22,7 +22,7 @@
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void set_uart_mux_conf(void) { enable_uart0_pin_mux(); @@ -52,9 +52,9 @@ void sdram_init(void)
return; } -#endif /* #ifdef CONFIG_SPL_BUILD */ +#endif /* #ifdef CONFIG_XPL_BUILD */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Basic board specific setup. Pinmux has been handled already. */ @@ -78,7 +78,7 @@ int board_init(void)
return 0; } -#endif /* #ifndef CONFIG_SPL_BUILD */ +#endif /* #ifndef CONFIG_XPL_BUILD */
#define OSC (V_OSCK/1000000) const struct dpll_params dpll_ddr = { @@ -89,7 +89,7 @@ const struct dpll_params *get_dpll_ddr_params(void) return &dpll_ddr; }
#define MAX_NR_LEDS 10 #define MAX_PIN_NUMBER 128 @@ -247,4 +247,4 @@ U_BOOT_CMD( "Set LEDs defined in environment", "<0|1>" ); -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ diff --git a/board/siemens/common/board_am335x.h b/board/siemens/common/board_am335x.h index 3a20352d457..4c9d5b04f12 100644 --- a/board/siemens/common/board_am335x.h +++ b/board/siemens/common/board_am335x.h @@ -22,7 +22,7 @@ void spl_draco_board_init(void); void draco_init_ddr(void); int draco_read_eeprom(void);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* Mux for init: uart?, i2c0 to read the main EEPROM */ void enable_uart0_pin_mux(void); void enable_uart1_pin_mux(void); @@ -34,6 +34,6 @@ void enable_i2c0_pin_mux(void);
/* Main mux function to enable other pinmux required on the board */ void enable_board_pin_mux(void); -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#endif /* _BOARD_AM335X_H_ */ diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index a250ccfe252..8261b3d37cc 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -5,7 +5,7 @@ * (C) Copyright 2013 Siemens Schweiz AG */
#include <env.h> #include <g_dnl.h> @@ -350,4 +350,4 @@ int g_dnl_get_board_bcd_device_number(int gcnum) { return factory_dat.version; } -#endif /* defined(CONFIG_SPL_BUILD) */ +#endif /* defined(CONFIG_XPL_BUILD) */ diff --git a/board/siemens/corvus/board.c b/board/siemens/corvus/board.c index cd27fc1cc37..a8714e055d7 100644 --- a/board/siemens/corvus/board.c +++ b/board/siemens/corvus/board.c @@ -114,7 +114,7 @@ static void corvus_nand_hw_init(void) at91_set_gpio_input(CFG_SYS_NAND_READY_PIN, 1); }
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #include <spl.h> #include <nand.h>
diff --git a/board/siemens/draco/Makefile b/board/siemens/draco/Makefile index aae536472c5..ac59c5bd985 100644 --- a/board/siemens/draco/Makefile +++ b/board/siemens/draco/Makefile @@ -9,13 +9,13 @@ # u-boot:/board/ti/am335x/Makefile # Copyright (C) 2011 Texas Instruments Incorporated - https://www.ti.com/
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := mux.o endif
obj-y += board.o obj-y += ../common/board_am335x.o obj-y += ../common/eeprom.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += ../common/factoryset.o endif diff --git a/board/siemens/draco/board.c b/board/siemens/draco/board.c index fc3eb06ccf2..147f827673b 100644 --- a/board/siemens/draco/board.c +++ b/board/siemens/draco/board.c @@ -28,7 +28,7 @@ #include "../common/eeprom.h" #include "../common/factoryset.h"
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static struct draco_baseboard_id __section(".data") settings;
#if DDR_PLL_FREQ == 303 @@ -106,7 +106,7 @@ static void print_chip_data(void) printf("hw version: \t'%s'\n", settings.chip.shwver); printf("max freq: \t%d MHz\n", dpll_mpu_opp100.m); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#define AM335X_NAND_ECC_MASK 0x0f #define AM335X_NAND_ECC_TYPE_16 0x02 @@ -142,7 +142,7 @@ static int draco_read_nand_geometry(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * Read header information from EEPROM into global structure. */ @@ -233,7 +233,7 @@ void spl_draco_board_init(void) { return; } -#endif /* if def CONFIG_SPL_BUILD */ +#endif /* if def CONFIG_XPL_BUILD */
#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) @@ -266,8 +266,8 @@ int board_late_init(void) } #endif
-#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD)) +#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD)) static void cpsw_control(int enabled) { /* VTP can be added here */ @@ -343,4 +343,4 @@ U_BOOT_CMD( "" ); #endif /* #if defined(CONFIG_DRIVER_TI_CPSW) */ -#endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) */ +#endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) */ diff --git a/board/siemens/pxm2/Makefile b/board/siemens/pxm2/Makefile index aae536472c5..ac59c5bd985 100644 --- a/board/siemens/pxm2/Makefile +++ b/board/siemens/pxm2/Makefile @@ -9,13 +9,13 @@ # u-boot:/board/ti/am335x/Makefile # Copyright (C) 2011 Texas Instruments Incorporated - https://www.ti.com/
obj-y += board.o obj-y += ../common/board_am335x.o obj-y += ../common/eeprom.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += ../common/factoryset.o endif diff --git a/board/siemens/pxm2/board.c b/board/siemens/pxm2/board.c index 888c7c09baf..4f9611372cd 100644 --- a/board/siemens/pxm2/board.c +++ b/board/siemens/pxm2/board.c @@ -28,7 +28,7 @@ #include "../common/eeprom.h" #include "../common/factoryset.h"
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void draco_init_ddr(void) { struct emif_regs pxm2_ddr3_emif_reg_data = { @@ -154,10 +154,10 @@ int draco_read_eeprom(void)
return 0; } -#endif /* if def CONFIG_SPL_BUILD */ +#endif /* if def CONFIG_XPL_BUILD */
-#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD)) +#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD)) static void cpsw_control(int enabled) { /* VTP can be added here */ @@ -198,15 +198,15 @@ static struct cpsw_platform_data cpsw_data = { .host_port_num = 0, .version = CPSW_CTRL_VERSION_2, }; -#endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) */ +#endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) */
#if defined(CONFIG_DRIVER_TI_CPSW) || \ (defined(CONFIG_USB_ETHER) && defined(CONFIG_USB_MUSB_GADGET)) int board_eth_init(struct bd_info *bis) { int n = 0; -#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD)) +#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD)) struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; #ifdef CONFIG_FACTORYSET int rv; diff --git a/board/siemens/rut/Makefile b/board/siemens/rut/Makefile index aae536472c5..ac59c5bd985 100644 --- a/board/siemens/rut/Makefile +++ b/board/siemens/rut/Makefile @@ -9,13 +9,13 @@ # u-boot:/board/ti/am335x/Makefile # Copyright (C) 2011 Texas Instruments Incorporated - https://www.ti.com/
obj-y += board.o obj-y += ../common/board_am335x.o obj-y += ../common/eeprom.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += ../common/factoryset.o endif diff --git a/board/siemens/rut/board.c b/board/siemens/rut/board.c index 8d316918e7a..828ae5c27a0 100644 --- a/board/siemens/rut/board.c +++ b/board/siemens/rut/board.c @@ -24,7 +24,7 @@ #include "../common/eeprom.h" #include "../common/factoryset.h"
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * Read header information from EEPROM into global structure. */ @@ -116,7 +116,7 @@ void spl_draco_board_init(void) REQUEST_AND_PULSE_RESET(MAXTOUCH_RESET_GPIO); REQUEST_AND_PULSE_RESET(DISPLAY_RESET_GPIO); } -#endif /* if def CONFIG_SPL_BUILD */ +#endif /* if def CONFIG_XPL_BUILD */
#if defined(CONFIG_DRIVER_TI_CPSW) static void cpsw_control(int enabled) @@ -168,7 +168,7 @@ int board_eth_init(struct bd_info *bis) int n = 0; int rv;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD factoryset_env_set(); #endif
@@ -183,7 +183,7 @@ int board_eth_init(struct bd_info *bis) return n; } #endif /* #if defined(CONFIG_DRIVER_TI_CPSW) */ -#endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) */ +#endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) */
#if defined(CONFIG_HW_WATCHDOG) static bool hw_watchdog_init_done; diff --git a/board/siemens/smartweb/smartweb.c b/board/siemens/smartweb/smartweb.c index e9e4bc348cb..6fa3ca573ae 100644 --- a/board/siemens/smartweb/smartweb.c +++ b/board/siemens/smartweb/smartweb.c @@ -191,7 +191,7 @@ int board_eth_init(struct bd_info *bis) #endif /* CONFIG_MACB */ #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #include <spl.h> #include <nand.h> #include <spi_flash.h> diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 3764ab48ab3..252b0787124 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -79,7 +79,7 @@ static void taurus_nand_hw_init(void) at91_set_gpio_output(CFG_SYS_NAND_ENABLE_PIN, 1); }
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #include <spl.h> #include <nand.h> #include <spi_flash.h> @@ -331,7 +331,7 @@ int dram_init(void) return 0; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) #if defined(CONFIG_BOARD_AXM) /* * Booting the Fallback Image. diff --git a/board/sifive/unleashed/Makefile b/board/sifive/unleashed/Makefile index 98e9111cbcc..d0a156d2cab 100644 --- a/board/sifive/unleashed/Makefile +++ b/board/sifive/unleashed/Makefile @@ -2,7 +2,7 @@ # # Copyright (c) 2019 Western Digital Corporation or its affiliates.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += unleashed.o diff --git a/board/sifive/unmatched/Makefile b/board/sifive/unmatched/Makefile index 13453300896..ce9deed9cdc 100644 --- a/board/sifive/unmatched/Makefile +++ b/board/sifive/unmatched/Makefile @@ -4,7 +4,7 @@
obj-$(CONFIG_ID_EEPROM) += hifive-platform-i2c-eeprom.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += unmatched.o diff --git a/board/silinux/ek874/Makefile b/board/silinux/ek874/Makefile index 4c8f0925f1e..6917a2418ca 100644 --- a/board/silinux/ek874/Makefile +++ b/board/silinux/ek874/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y := ../../renesas/rcar-common/gen3-spl.o else obj-y := ek874.o ../../renesas/rcar-common/common.o diff --git a/board/softing/vining_2000/vining_2000.c b/board/softing/vining_2000/vining_2000.c index bd430cfaa7f..769f3e2ff2a 100644 --- a/board/softing/vining_2000/vining_2000.c +++ b/board/softing/vining_2000/vining_2000.c @@ -402,7 +402,7 @@ void board_preboot_os(void) setbits_le32(&gpc_regs->cntr, PCIE_PHY_PUP_REQ); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <linux/libfdt.h> #include <spl.h> #include <asm/arch/mx6-ddr.h> diff --git a/board/softing/vining_fpga/socfpga.c b/board/softing/vining_fpga/socfpga.c index 2483fbcf263..ec2c7ea3631 100644 --- a/board/softing/vining_fpga/socfpga.c +++ b/board/softing/vining_fpga/socfpga.c @@ -43,7 +43,7 @@ int board_late_init(void) return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int misc_init_r(void) { uchar data[128]; diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 3406ba8616e..e9269ef5353 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -570,7 +570,7 @@ void board_boot_order(u32 *spl_boot_list) spl_boot_list[1] = BOOT_DEVICE_BOARD; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <asm/arch/mx6-ddr.h> static const struct mx6dq_iomux_ddr_regs mx6q_ddr_ioregs = { .dram_sdclk_0 = 0x00020030, diff --git a/board/st/common/cmd_stboard.c b/board/st/common/cmd_stboard.c index 50da063051b..b9d0abdba7d 100644 --- a/board/st/common/cmd_stboard.c +++ b/board/st/common/cmd_stboard.c @@ -29,7 +29,7 @@ * Board: MB<Board> Var<VarCPN>.<VarFG> Rev.<Revision>-<BOM> */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #include <command.h> #include <console.h> #include <misc.h> diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 6d86e4fe7aa..8966a09501e 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -27,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int rv; struct udevice *dev; rv = uclass_get_device(UCLASS_RAM, 0, &dev); @@ -45,7 +45,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/board/st/stm32mp1/Makefile b/board/st/stm32mp1/Makefile index f2d720b67b3..5e39b7b189f 100644 --- a/board/st/stm32mp1/Makefile +++ b/board/st/stm32mp1/Makefile @@ -3,7 +3,7 @@ # Copyright (C) 2018, STMicroelectronics - All Rights Reserved #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o else obj-y += stm32mp1.o diff --git a/board/starfive/visionfive2/Makefile b/board/starfive/visionfive2/Makefile index c7ba4f7ed67..97c25a2fd13 100644 --- a/board/starfive/visionfive2/Makefile +++ b/board/starfive/visionfive2/Makefile @@ -4,5 +4,5 @@ #
obj-y := starfive_visionfive2.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o obj-$(CONFIG_ID_EEPROM) += visionfive2-i2c-eeprom.o diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 961cdcde74d..824c322a0dc 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -281,7 +281,7 @@ int dram_init(void) return 0; }
-#if defined(CONFIG_NAND_SUNXI) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_NAND_SUNXI) && defined(CONFIG_XPL_BUILD) static void nand_pinmux_setup(void) { unsigned int pin; @@ -530,7 +530,7 @@ int mmc_get_env_dev(void) #endif #endif /* CONFIG_MMC */
static void sunxi_spl_store_dram_size(phys_addr_t dram_size) { @@ -641,7 +641,7 @@ void sunxi_board_init(void) else printf("Failed to set core voltage! Can't set CPU frequency\n"); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#ifdef CONFIG_USB_GADGET int g_dnl_board_usb_cable_connected(void) diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index 6c60c70b7b4..20fa61131cb 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -249,8 +249,8 @@ int board_late_init(void) } #endif
-#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD)) +#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD)) static void cpsw_control(int enabled) { /* VTP can be added here */ @@ -303,10 +303,10 @@ static struct cpsw_platform_data cpsw_data = { * when we build an SPL that has neither option but full U-Boot will. */ #if ((defined(CONFIG_SPL_ETH) || defined(CONFIG_SPL_USB_ETHER)) \ - && defined(CONFIG_SPL_BUILD)) || \ + && defined(CONFIG_XPL_BUILD)) || \ ((defined(CONFIG_DRIVER_TI_CPSW) || \ defined(CONFIG_USB_ETHER) && defined(CONFIG_MUSB_GADGET)) && \ - !defined(CONFIG_SPL_BUILD)) + !defined(CONFIG_XPL_BUILD)) int board_eth_init(struct bd_info *bis) { int rv, n = 0; @@ -323,8 +323,8 @@ int board_eth_init(struct bd_info *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
-#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD)) +#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD)) if (!env_get("ethaddr")) { printf("<ethaddr> not set. Validating first E-fuse MAC\n");
@@ -373,7 +373,7 @@ int board_eth_init(struct bd_info *bis)
#endif #if defined(CONFIG_USB_ETHER) && \ - (!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_USB_ETHER)) + (!defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_USB_ETHER)) if (is_valid_ether_addr(mac_addr)) eth_env_set_enetaddr("usbnet_devaddr", mac_addr);
diff --git a/board/technexion/pico-imx6/spl.c b/board/technexion/pico-imx6/spl.c index 50f51774264..700abb73289 100644 --- a/board/technexion/pico-imx6/spl.c +++ b/board/technexion/pico-imx6/spl.c @@ -24,7 +24,7 @@ #include <asm/arch/sys_proto.h> #include <spl.h>
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #include <asm/arch/mx6-ddr.h>
#define IMX6DQ_DRIVE_STRENGTH 0x30 diff --git a/board/technexion/pico-imx6ul/spl.c b/board/technexion/pico-imx6ul/spl.c index 67484e62dad..5b91868ba9c 100644 --- a/board/technexion/pico-imx6ul/spl.c +++ b/board/technexion/pico-imx6ul/spl.c @@ -18,7 +18,7 @@ #include <linux/libfdt.h> #include <spl.h>
#ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) diff --git a/board/technexion/pico-imx7d/spl.c b/board/technexion/pico-imx7d/spl.c index 8f219f76c60..cb60d3be420 100644 --- a/board/technexion/pico-imx7d/spl.c +++ b/board/technexion/pico-imx7d/spl.c @@ -21,7 +21,7 @@ #include <fsl_esdhc_imx.h> #include <spl.h>
#ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) diff --git a/board/technexion/pico-imx8mq/Makefile b/board/technexion/pico-imx8mq/Makefile index 7cfe1e02ef9..da3073cdf79 100644 --- a/board/technexion/pico-imx8mq/Makefile +++ b/board/technexion/pico-imx8mq/Makefile @@ -6,7 +6,7 @@
obj-y += pico-imx8mq.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_1gb.o lpddr4_timing_2gb.o lpddr4_timing_3gb.o lpddr4_timing_4gb.o endif diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index d7234532fe6..2f5ad769b9b 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -10,7 +10,7 @@ #include <init.h> #include <net.h> #include <pci.h> -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) #include <bootcount.h> #endif #include <asm/global_data.h> @@ -252,7 +252,7 @@ int board_eth_init(struct bd_info *bis) } #endif
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_BOARD_LATE_INIT) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_BOARD_LATE_INIT) int board_late_init(void) { pci_dev_t bdf; @@ -343,7 +343,7 @@ int board_late_init(void) } #endif
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_PCI) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_PCI) static int pcie_get_link_speed_width(pci_dev_t bdf, int *speed, int *width) { struct udevice *dev; diff --git a/board/theobroma-systems/jaguar_rk3588/Makefile b/board/theobroma-systems/jaguar_rk3588/Makefile index 532aab01532..d43bf194b68 100644 --- a/board/theobroma-systems/jaguar_rk3588/Makefile +++ b/board/theobroma-systems/jaguar_rk3588/Makefile @@ -5,6 +5,6 @@ #
obj-y += jaguar_rk3588.o -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-y += ../common/common.o endif diff --git a/board/theobroma-systems/puma_rk3399/Makefile b/board/theobroma-systems/puma_rk3399/Makefile index edd61a35c1e..2256e72cda1 100644 --- a/board/theobroma-systems/puma_rk3399/Makefile +++ b/board/theobroma-systems/puma_rk3399/Makefile @@ -5,6 +5,6 @@ #
obj-y += puma-rk3399.o -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-y += ../common/common.o endif diff --git a/board/theobroma-systems/ringneck_px30/Makefile b/board/theobroma-systems/ringneck_px30/Makefile index 45cc65baf9a..4d108f2d011 100644 --- a/board/theobroma-systems/ringneck_px30/Makefile +++ b/board/theobroma-systems/ringneck_px30/Makefile @@ -5,6 +5,6 @@ #
obj-y += ringneck-px30.o -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-y += ../common/common.o endif diff --git a/board/theobroma-systems/tiger_rk3588/Makefile b/board/theobroma-systems/tiger_rk3588/Makefile index 5c4c484657a..94b0859eb35 100644 --- a/board/theobroma-systems/tiger_rk3588/Makefile +++ b/board/theobroma-systems/tiger_rk3588/Makefile @@ -5,6 +5,6 @@ #
obj-y += tiger_rk3588.o -ifneq ($(CONFIG_SPL_BUILD),y) +ifneq ($(CONFIG_XPL_BUILD),y) obj-y += ../common/common.o endif diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 681002ba1da..720bf2cb3e1 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -569,8 +569,8 @@ void sdram_init(void) } #endif
-#if defined(CONFIG_CLOCK_SYNTHESIZER) && (!defined(CONFIG_SPL_BUILD) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD))) +#if defined(CONFIG_CLOCK_SYNTHESIZER) && (!defined(CONFIG_XPL_BUILD) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD))) static void request_and_set_gpio(int gpio, char *name, int val) { int ret; @@ -707,8 +707,8 @@ int board_init(void) gpmc_init(); #endif
-#if defined(CONFIG_CLOCK_SYNTHESIZER) && (!defined(CONFIG_SPL_BUILD) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD))) +#if defined(CONFIG_CLOCK_SYNTHESIZER) && (!defined(CONFIG_XPL_BUILD) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD))) if (board_is_icev2()) { int rv; u32 reg; @@ -798,7 +798,7 @@ int board_init(void) int board_late_init(void) { struct udevice *dev; -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo; #endif @@ -847,7 +847,7 @@ int board_late_init(void) env_set("boot_fit", "1"); #endif
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) /* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); mac_hi = readl(&cdev->macid0h); diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index cc5e64c9879..fc0d87daae4 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -515,7 +515,7 @@ int get_voltrail_opp(int rail_offset) return opp; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* No env to setup for SPL */ static inline void setup_board_eeprom_env(void) { }
@@ -538,7 +538,7 @@ void do_board_detect(void) #endif }
-#else /* CONFIG_SPL_BUILD */ +#else /* CONFIG_XPL_BUILD */
/* Override function to read eeprom information: actual i2c read done by SPL*/ void do_board_detect(void) @@ -616,7 +616,7 @@ invalid_eeprom: set_board_info_env(name); }
void vcores_init(void) { @@ -783,7 +783,7 @@ int board_late_init(void) if (board_is_bbai()) env_set("console", "ttyS0,115200n8");
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) board_ti_set_ethaddr(2); #endif
@@ -935,7 +935,7 @@ const struct mmc_platform_fixups *platform_fixups_mmc(uint32_t addr) } #endif
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_OS_BOOT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_OS_BOOT) int spl_start_uboot(void) { /* break into full u-boot on 'c' */ diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c index 9bdd0223cdb..1166c9b8e09 100644 --- a/board/ti/am62x/evm.c +++ b/board/ti/am62x/evm.c @@ -103,7 +103,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
void spl_board_init(void) { diff --git a/board/ti/am64x/evm.c b/board/ti/am64x/evm.c index 609e5cf6d51..00b8317d6bf 100644 --- a/board/ti/am64x/evm.c +++ b/board/ti/am64x/evm.c @@ -105,7 +105,7 @@ int board_fit_config_name_match(const char *name) } #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #if CONFIG_IS_ENABLED(USB_STORAGE) static int fixup_usb_boot(const void *fdt_blob) { diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index ea21d48bbc0..a43cc075b92 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -304,7 +304,7 @@ int __maybe_unused ti_i2c_eeprom_am_get(int bus_addr, int dev_addr) struct ti_common_eeprom *ep;
ep = TI_EEPROM_DATA; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD if (ep->header == TI_EEPROM_HEADER_MAGIC) return 0; /* EEPROM has already been read */ #endif @@ -350,7 +350,7 @@ int __maybe_unused ti_i2c_eeprom_dra7_get(int bus_addr, int dev_addr) struct ti_common_eeprom *ep;
ep = TI_EEPROM_DATA; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD if (ep->header == DRA7_EEPROM_HEADER_MAGIC) return 0; /* EEPROM has already been read */ #endif @@ -563,7 +563,7 @@ int __maybe_unused ti_i2c_eeprom_am6_get_base(int bus_addr, int dev_addr) * Always execute EEPROM read by not allowing to bypass it during the * first invocation of SPL which happens on the R5 core. */ -#if !(defined(CONFIG_SPL_BUILD) && defined(CONFIG_CPU_V7R)) +#if !(defined(CONFIG_XPL_BUILD) && defined(CONFIG_CPU_V7R)) if (ep->header == TI_EEPROM_HEADER_MAGIC) { debug("%s: EEPROM has already been read\n", __func__); return 0; diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 2b1db2541b0..98d63e14e29 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -713,7 +713,7 @@ int board_late_init(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void do_board_detect(void) { int rc; @@ -756,7 +756,7 @@ void do_board_detect(void) snprintf(sysinfo.board_string, SYSINFO_BOARD_NAME_MAX_LEN, "Board: %s REV %s\n", bname, board_ti_get_rev()); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
void vcores_init(void) { @@ -972,7 +972,7 @@ const struct mmc_platform_fixups *platform_fixups_mmc(uint32_t addr) } #endif
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_OS_BOOT) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_OS_BOOT) int spl_start_uboot(void) { /* break into full u-boot on 'c' */ diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index f3452ff0a8f..6221be9dcff 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -164,7 +164,7 @@ static void __maybe_unused detect_enable_hyperflash(void *blob) } #endif
-#if defined(CONFIG_SPL_BUILD) && (defined(CONFIG_TARGET_J7200_A72_EVM) || defined(CONFIG_TARGET_J7200_R5_EVM) || \ +#if defined(CONFIG_XPL_BUILD) && (defined(CONFIG_TARGET_J7200_A72_EVM) || defined(CONFIG_TARGET_J7200_R5_EVM) || \ defined(CONFIG_TARGET_J721E_A72_EVM) || defined(CONFIG_TARGET_J721E_R5_EVM)) void spl_perform_fixups(struct spl_image_info *spl_image) { @@ -340,7 +340,7 @@ static int probe_daughtercards(void) printf("Detected: %s rev %s\n", ep.name, ep.version); daughter_card_detect_flags[i] = true;
- if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD)) { int j; /* * Populate any MAC addresses from daughtercard into the U-Boot @@ -359,7 +359,7 @@ static int probe_daughtercards(void) } }
- if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD)) { char name_overlays[1024] = { 0 };
for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 5a0281d6b48..2cfeb3bec6c 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -239,7 +239,7 @@ static int probe_daughtercards(void) printf("Detected: %s rev %s\n", ep.name, ep.version); daughter_card_detect_flags[i] = true;
- if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD)) { int j; /* * Populate any MAC addresses from daughtercard into the U-Boot @@ -257,7 +257,7 @@ static int probe_daughtercards(void) } }
for (i = 0; i < ARRAY_SIZE(ext_cards); i++) { diff --git a/board/ti/ks2_evm/board.c b/board/ti/ks2_evm/board.c index c6735d37dda..48547719012 100644 --- a/board/ti/ks2_evm/board.c +++ b/board/ti/ks2_evm/board.c @@ -75,7 +75,7 @@ int board_init(void) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_board_init(void) { spl_init_keystone_plls(); diff --git a/board/ti/ks2_evm/board_k2e.c b/board/ti/ks2_evm/board_k2e.c index 4385be4221b..3ccf70c5ac7 100644 --- a/board/ti/ks2_evm/board_k2e.c +++ b/board/ti/ks2_evm/board_k2e.c @@ -109,7 +109,7 @@ int board_early_init_f(void) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_init_keystone_plls(void) { init_plls(); diff --git a/board/ti/ks2_evm/board_k2g.c b/board/ti/ks2_evm/board_k2g.c index d07b77d23e2..b1142ed5e96 100644 --- a/board/ti/ks2_evm/board_k2g.c +++ b/board/ti/ks2_evm/board_k2g.c @@ -346,7 +346,7 @@ int embedded_dtb_select(void) #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { -#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_TI_I2C_BOARD_DETECT) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_TI_I2C_BOARD_DETECT) int rc;
rc = ti_i2c_eeprom_am_get(CONFIG_EEPROM_BUS_ADDRESS, @@ -382,7 +382,7 @@ int board_early_init_f(void) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_init_keystone_plls(void) { init_plls(); diff --git a/board/ti/ks2_evm/board_k2hk.c b/board/ti/ks2_evm/board_k2hk.c index 2b5d2d75664..93249fa5f49 100644 --- a/board/ti/ks2_evm/board_k2hk.c +++ b/board/ti/ks2_evm/board_k2hk.c @@ -116,7 +116,7 @@ int board_fit_config_name_match(const char *name) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_init_keystone_plls(void) { init_plls(); diff --git a/board/ti/ks2_evm/board_k2l.c b/board/ti/ks2_evm/board_k2l.c index 1971bc94f7d..b813f21b682 100644 --- a/board/ti/ks2_evm/board_k2l.c +++ b/board/ti/ks2_evm/board_k2l.c @@ -104,7 +104,7 @@ int board_fit_config_name_match(const char *name) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD void spl_init_keystone_plls(void) { init_plls(); diff --git a/board/ti/omap3evm/evm.c b/board/ti/omap3evm/evm.c index 4eb08add256..8803643b032 100644 --- a/board/ti/omap3evm/evm.c +++ b/board/ti/omap3evm/evm.c @@ -117,7 +117,7 @@ int spl_start_uboot(void) } #endif /* CONFIG_SPL_OS_BOOT */
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) /* * Routine: get_board_mem_timings * Description: If we use SPL then there is no x-loader nor config header @@ -150,7 +150,7 @@ void get_board_mem_timings(struct board_sdrc_timings *timings) timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; timings->mr = MICRON_V_MR_165; } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* * Routine: misc_init_r diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index ad404f7e9c4..a2a3a9489aa 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -147,7 +147,7 @@ void board_mmc_power_init(void) } #endif
-#if defined(CONFIG_DRIVER_DM9000) & !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_DRIVER_DM9000) & !defined(CONFIG_XPL_BUILD) /* * Routine: board_eth_init * Description: Setting up the Ethernet hardware. diff --git a/board/topic/zynq/Makefile b/board/topic/zynq/Makefile index cc100b0f422..23a6dd86441 100644 --- a/board/topic/zynq/Makefile +++ b/board/topic/zynq/Makefile @@ -6,4 +6,4 @@ obj-y += ../../xilinx/common/board.o # Remove quotes hw-platform-y :=$(shell echo $(CONFIG_DEFAULT_DEVICE_TREE))
-obj-$(CONFIG_SPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o +obj-$(CONFIG_XPL_BUILD) += $(hw-platform-y)/ps7_init_gpl.o diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 4a1cfb89345..ec0f223c4aa 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -96,7 +96,7 @@ iomux_v3_cfg_t const uart1_pads_dte[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_XPL_BUILD) /* Apalis MMC1 */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -139,7 +139,7 @@ iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), MX6_PAD_SD3_RST__GPIO7_IO08 | MUX_PAD_CTRL(WEAK_PULLUP) | MUX_MODE_SION, }; -#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_SPL_BUILD */ +#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_XPL_BUILD */
int mx6_rgmii_rework(struct phy_device *phydev) { @@ -321,7 +321,7 @@ int board_ehci_hcd_init(int port) } #endif
-#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_XPL_BUILD) /* use the following sequence: eMMC, MMC1, SD1 */ struct fsl_esdhc_cfg usdhc_cfg[CFG_SYS_FSL_USDHC_NUM] = { {USDHC3_BASE_ADDR}, @@ -391,7 +391,7 @@ int board_mmc_init(struct bd_info *bis)
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); } -#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_SPL_BUILD */ +#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_XPL_BUILD */
int board_phy_config(struct phy_device *phydev) { @@ -748,7 +748,7 @@ void ldo_mode_set(int ldo_bypass) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <spl.h> #include <linux/libfdt.h> #include "asm/arch/mx6q-ddr.h" @@ -1042,7 +1042,7 @@ void reset_cpu(void) { }
static struct mxc_serial_plat mxc_serial_plat = { .reg = (struct mxc_uart *)UART1_BASE, diff --git a/board/toradex/apalis_imx6/do_fuse.c b/board/toradex/apalis_imx6/do_fuse.c index b404b01e032..698b05bc5ad 100644 --- a/board/toradex/apalis_imx6/do_fuse.c +++ b/board/toradex/apalis_imx6/do_fuse.c @@ -7,7 +7,7 @@ * Helpers for i.MX OTP fusing during module production */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #include <command.h> #include <console.h> #include <fuse.h> @@ -94,4 +94,4 @@ U_BOOT_CMD( "OTP fusing during module update", "updt_fuse [-n] [-y] - boot cfg fast boot mode fusing" ); -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/board/toradex/apalis_imx6/pf0100.c b/board/toradex/apalis_imx6/pf0100.c index 157aaec6fe0..7ea9bbb07ed 100644 --- a/board/toradex/apalis_imx6/pf0100.c +++ b/board/toradex/apalis_imx6/pf0100.c @@ -212,7 +212,7 @@ unsigned pmic_init(void) return programmed; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int pf0100_prog(void) { int rc; @@ -280,4 +280,4 @@ U_BOOT_CMD( "Program the OTP fuses on the PMIC PF0100", "" ); -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/board/toradex/apalis_t30/Makefile b/board/toradex/apalis_t30/Makefile index eed607043fc..2d079004c4b 100644 --- a/board/toradex/apalis_t30/Makefile +++ b/board/toradex/apalis_t30/Makefile @@ -1,6 +1,6 @@ # Copyright (c) 2014 Marcel Ziswiler # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_SPL_BUILD) += apalis_t30-spl.o +obj-$(CONFIG_XPL_BUILD) += apalis_t30-spl.o
obj-y += apalis_t30.o diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 251970b99cc..64cf99e9cfc 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -86,7 +86,7 @@ iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_XPL_BUILD) /* Colibri MMC */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -113,7 +113,7 @@ iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), MX6_PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL), }; -#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_SPL_BUILD */ +#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_XPL_BUILD */
/* mux auxiliary pins to GPIO, so they can be used from the U-Boot cmdline */ iomux_v3_cfg_t const gpio_pads[] = { @@ -289,7 +289,7 @@ int board_ehci_hcd_init(int port) } #endif
-#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_XPL_BUILD) /* use the following sequence: eMMC, MMC */ struct fsl_esdhc_cfg usdhc_cfg[CFG_SYS_FSL_USDHC_NUM] = { {USDHC3_BASE_ADDR}, @@ -346,7 +346,7 @@ int board_mmc_init(struct bd_info *bis)
int board_phy_config(struct phy_device *phydev) { @@ -677,7 +677,7 @@ void ldo_mode_set(int ldo_bypass) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <spl.h> #include <linux/libfdt.h> #include "asm/arch/mx6dl-ddr.h" @@ -1101,7 +1101,7 @@ void reset_cpu(void) { }
static struct mxc_serial_plat mxc_serial_plat = { .reg = (struct mxc_uart *)UART1_BASE, diff --git a/board/toradex/colibri_imx6/do_fuse.c b/board/toradex/colibri_imx6/do_fuse.c index b404b01e032..698b05bc5ad 100644 --- a/board/toradex/colibri_imx6/do_fuse.c +++ b/board/toradex/colibri_imx6/do_fuse.c @@ -7,7 +7,7 @@ * Helpers for i.MX OTP fusing during module production */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #include <command.h> #include <console.h> #include <fuse.h> @@ -94,4 +94,4 @@ U_BOOT_CMD( "OTP fusing during module update", "updt_fuse [-n] [-y] - boot cfg fast boot mode fusing" ); -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/board/toradex/colibri_imx6/pf0100.c b/board/toradex/colibri_imx6/pf0100.c index 58b7bc3bb9a..b5dffc87b35 100644 --- a/board/toradex/colibri_imx6/pf0100.c +++ b/board/toradex/colibri_imx6/pf0100.c @@ -197,7 +197,7 @@ unsigned pmic_init(void) return programmed; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int pf0100_prog(void) { int rc; @@ -265,4 +265,4 @@ U_BOOT_CMD( "Program the OTP fuses on the PMIC PF0100", "" ); -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/board/toradex/colibri_t30/Makefile b/board/toradex/colibri_t30/Makefile index 8f333235b17..1cc801c8cfd 100644 --- a/board/toradex/colibri_t30/Makefile +++ b/board/toradex/colibri_t30/Makefile @@ -1,6 +1,6 @@ # Copyright (c) 2013-2014 Stefan Agner # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_SPL_BUILD) += colibri_t30-spl.o +obj-$(CONFIG_XPL_BUILD) += colibri_t30-spl.o
obj-y += colibri_t30.o diff --git a/board/toradex/common/Makefile b/board/toradex/common/Makefile index 7b19b6e4c87..7e3905445a5 100644 --- a/board/toradex/common/Makefile +++ b/board/toradex/common/Makefile @@ -2,7 +2,7 @@ # Copyright (c) 2016 Toradex, Inc.
# Common for all Toradex modules -ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) # Necessary to create built-in.o obj- := __dummy__.o else diff --git a/board/toradex/verdin-imx8mm/Makefile b/board/toradex/verdin-imx8mm/Makefile index b38054254da..eee58aa2f83 100644 --- a/board/toradex/verdin-imx8mm/Makefile +++ b/board/toradex/verdin-imx8mm/Makefile @@ -5,7 +5,7 @@
obj-y += verdin-imx8mm.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/toradex/verdin-imx8mp/Makefile b/board/toradex/verdin-imx8mp/Makefile index 98fa14e4e2a..5edd1778816 100644 --- a/board/toradex/verdin-imx8mp/Makefile +++ b/board/toradex/verdin-imx8mp/Makefile @@ -5,7 +5,7 @@
obj-y += verdin-imx8mp.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o endif diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index 4cf214bf17c..bc30bdac462 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -209,7 +209,7 @@ int board_late_init(void) return 0; }
#include <linux/libfdt.h> #include <asm/arch/mx6-ddr.h> diff --git a/board/udoo/udoo_spl.c b/board/udoo/udoo_spl.c index 6c477530055..b845284d688 100644 --- a/board/udoo/udoo_spl.c +++ b/board/udoo/udoo_spl.c @@ -23,7 +23,7 @@ #include <asm/arch/sys_proto.h> #include <spl.h>
/* diff --git a/board/variscite/common/imx9_eeprom.c b/board/variscite/common/imx9_eeprom.c index 32551af5b40..bfa30adc256 100644 --- a/board/variscite/common/imx9_eeprom.c +++ b/board/variscite/common/imx9_eeprom.c @@ -83,7 +83,7 @@ int var_eeprom_get_dram_size(struct var_eeprom *ep, phys_size_t *size)
void var_eeprom_print_prod_info(struct var_eeprom *ep) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return;
flush_dcache_all(); diff --git a/board/variscite/dart_6ul/Makefile b/board/variscite/dart_6ul/Makefile index 48aa361bf2d..39c3f53e736 100644 --- a/board/variscite/dart_6ul/Makefile +++ b/board/variscite/dart_6ul/Makefile @@ -1,4 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y := dart_6ul.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/variscite/imx8mn_var_som/Makefile b/board/variscite/imx8mn_var_som/Makefile index a8b6a343ffc..36d9c36dd2d 100644 --- a/board/variscite/imx8mn_var_som/Makefile +++ b/board/variscite/imx8mn_var_som/Makefile @@ -6,7 +6,7 @@
obj-y += imx8mn_var_som.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-y += ddr4_timing.o endif diff --git a/board/variscite/imx8mn_var_som/imx8mn_var_som.c b/board/variscite/imx8mn_var_som/imx8mn_var_som.c index 532d8d60a76..80c84e64241 100644 --- a/board/variscite/imx8mn_var_som/imx8mn_var_som.c +++ b/board/variscite/imx8mn_var_som/imx8mn_var_som.c @@ -54,7 +54,7 @@ int board_mmc_get_env_dev(int devno) return devno; }
#if defined(CONFIG_DISPLAY_BOARDINFO)
@@ -227,4 +227,4 @@ int ft_board_setup(void *blob, struct bd_info *bd) } #endif /* CONFIG_OF_BOARD_SETUP */
-#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/board/variscite/imx93_var_som/Makefile b/board/variscite/imx93_var_som/Makefile index b63883901bd..8b160f189c1 100644 --- a/board/variscite/imx93_var_som/Makefile +++ b/board/variscite/imx93_var_som/Makefile @@ -8,7 +8,7 @@ obj-y += imx93_var_som.o obj-$(CONFIG_TARGET_IMX93_VAR_SOM) += ../common/imx9_eeprom.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += spl.o obj-$(CONFIG_TARGET_IMX93_VAR_SOM) += lpddr4x_timing.o else diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index f54f183038b..de9f8367d59 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -131,7 +131,7 @@ static int read_eeprom(BSP_VS_HWPARAM *header) return 0; }
-#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) +#if defined(CONFIG_XPL_BUILD) || defined(CONFIG_NOR_BOOT)
static const struct ddr_data ddr3_baltos_data = { .datardsratio0 = MT41K256M16HA125E_RD_DQS, @@ -371,8 +371,8 @@ int board_late_init(void) } #endif
-#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ - (defined(CONFIG_SPL_ETH) && defined(CONFIG_SPL_BUILD)) +#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_XPL_BUILD)) || \ + (defined(CONFIG_SPL_ETH) && defined(CONFIG_XPL_BUILD)) static void cpsw_control(int enabled) { /* VTP can be added here */ @@ -415,10 +415,10 @@ static struct cpsw_platform_data cpsw_data = { #endif
#if ((defined(CONFIG_SPL_ETH) || defined(CONFIG_SPL_USB_ETHER)) \ - && defined(CONFIG_SPL_BUILD)) || \ + && defined(CONFIG_XPL_BUILD)) || \ ((defined(CONFIG_DRIVER_TI_CPSW) || \ defined(CONFIG_USB_ETHER) && defined(CONFIG_USB_MUSB_GADGET)) && \ - !defined(CONFIG_SPL_BUILD)) + !defined(CONFIG_XPL_BUILD)) int board_eth_init(struct bd_info *bis) { int rv, n = 0; @@ -442,8 +442,8 @@ int board_eth_init(struct bd_info *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
diff --git a/board/wandboard/Makefile b/board/wandboard/Makefile index c3d80536b3a..6e5bcc11630 100644 --- a/board/wandboard/Makefile +++ b/board/wandboard/Makefile @@ -3,4 +3,4 @@ # (C) Copyright 2013 Freescale Semiconductor, Inc.
obj-y := wandboard.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_XPL_BUILD) += spl.o diff --git a/board/wexler/qc750/Makefile b/board/wexler/qc750/Makefile index 4daefc4159a..5f9ebafd89c 100644 --- a/board/wexler/qc750/Makefile +++ b/board/wexler/qc750/Makefile @@ -6,6 +6,6 @@ # (C) Copyright 2023 # Svyatoslav Ryhel clamor95@gmail.com
-obj-$(CONFIG_SPL_BUILD) += qc750-spl.o +obj-$(CONFIG_XPL_BUILD) += qc750-spl.o
obj-y += qc750.o diff --git a/board/work-microwave/work_92105/Makefile b/board/work-microwave/work_92105/Makefile index b837e7b0dd8..a96098d0f2a 100644 --- a/board/work-microwave/work_92105/Makefile +++ b/board/work-microwave/work_92105/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2014 DENX Software Engineering GmbH # Written-by: Albert ARIBAUD albert.aribaud@3adev.fr
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-y += work_92105_spl.o else obj-y += work_92105.o diff --git a/board/xilinx/common/Makefile b/board/xilinx/common/Makefile index d563290ab90..4b8fdec5830 100644 --- a/board/xilinx/common/Makefile +++ b/board/xilinx/common/Makefile @@ -8,6 +8,6 @@ obj-y += board.o ifndef CONFIG_ARCH_ZYNQ obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o endif -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_FRU) += fru.o fru_ops.o endif diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 5e5eb49ddf3..68f401e4b34 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -370,7 +370,7 @@ void *board_fdt_blob_setup(int *err) return fdt_blob; }
- if (!IS_ENABLED(CONFIG_SPL_BUILD) && + if (!IS_ENABLED(CONFIG_XPL_BUILD) && !IS_ENABLED(CONFIG_VERSAL_NO_DDR) && !IS_ENABLED(CONFIG_ZYNQMP_NO_DDR)) { fdt_blob = (void *)CONFIG_XILINX_OF_BOARD_DTB_ADDR; @@ -381,7 +381,7 @@ void *board_fdt_blob_setup(int *err) debug("DTB is not passed via %p\n", fdt_blob); }
- if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { /* * FDT is at end of BSS unless it is in a different memory * region @@ -515,7 +515,7 @@ int __maybe_unused board_fit_config_name_match(const char *name) { debug("%s: Check %s, default %s\n", __func__, name, board_name);
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) if (IS_ENABLED(CONFIG_REGEX)) { struct slre slre; int ret; diff --git a/board/xilinx/microblaze-generic/microblaze-generic.c b/board/xilinx/microblaze-generic/microblaze-generic.c index 2b035d53589..dc4523824b4 100644 --- a/board/xilinx/microblaze-generic/microblaze-generic.c +++ b/board/xilinx/microblaze-generic/microblaze-generic.c @@ -40,7 +40,7 @@ int board_late_init(void) ulong max_size; u32 status = 0;
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_SYSRESET_MICROBLAZE) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_SYSRESET_MICROBLAZE) int ret;
ret = device_bind_driver(gd->dm_root, "mb_soft_reset", diff --git a/board/xilinx/zynq/Makefile b/board/xilinx/zynq/Makefile index 85661715891..f40fe382f57 100644 --- a/board/xilinx/zynq/Makefile +++ b/board/xilinx/zynq/Makefile @@ -26,17 +26,17 @@ endif ifeq ($(init-objs),) ifneq ($(wildcard $(srctree)/$(src)/ps7_init_gpl.c),) init-objs := ps7_init_gpl.o -$(if $(CONFIG_SPL_BUILD),\ +$(if $(CONFIG_XPL_BUILD),\ $(warning Put custom ps7_init_gpl.c/h to board/xilinx/zynq/custom_hw_platform/)) endif endif
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_ZYNQ) += cmds.o obj-$(CONFIG_CMD_ZYNQ_RSA) += bootimg.o endif
-obj-$(CONFIG_SPL_BUILD) += $(init-objs) +obj-$(CONFIG_XPL_BUILD) += $(init-objs)
# Suppress "warning: function declaration isn't a prototype" CFLAGS_REMOVE_ps7_init_gpl.o := -Wstrict-prototypes diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index b9a91110ff7..a852d5b8ed5 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -27,7 +27,7 @@
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_DEBUG_UART_BOARD_INIT) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_DEBUG_UART_BOARD_INIT) void board_debug_uart_init(void) { /* Add initialization sequence if UART is not configured */ @@ -36,7 +36,7 @@ void board_debug_uart_init(void)
int board_init(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) printf("Silicon version:\t%d\n", zynq_get_silicon_version());
if (CONFIG_IS_ENABLED(DM_I2C) && CONFIG_IS_ENABLED(I2C_EEPROM)) diff --git a/board/xilinx/zynqmp/Makefile b/board/xilinx/zynqmp/Makefile index 9ab50eca400..544346d686e 100644 --- a/board/xilinx/zynqmp/Makefile +++ b/board/xilinx/zynqmp/Makefile @@ -26,16 +26,16 @@ endif ifeq ($(init-objs),) ifneq ($(wildcard $(srctree)/$(src)/psu_init_gpl.c),) init-objs := psu_init_gpl.o -$(if $(CONFIG_SPL_BUILD),\ +$(if $(CONFIG_XPL_BUILD),\ $(warning Put custom psu_init_gpl.c/h to board/xilinx/zynqmp/custom_hw_platform/)) endif endif
obj-$(CONFIG_$(SPL_)ZYNQMP_PSU_INIT_ENABLED) += $(init-objs)
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifneq ($(CONFIG_ZYNQMP_SPL_PM_CFG_OBJ_FILE),"") -obj-$(CONFIG_SPL_BUILD) += pm_cfg_obj.o +obj-$(CONFIG_XPL_BUILD) += pm_cfg_obj.o $(obj)/pm_cfg_obj.o: $(shell cd $(srctree); readlink -f $(CONFIG_ZYNQMP_SPL_PM_CFG_OBJ_FILE)) FORCE endif endif diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 20a675c010d..8cdd9d86009 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -86,7 +86,7 @@ int __maybe_unused psu_uboot_init(void) return 0; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) # if defined(CONFIG_DEBUG_UART_BOARD_INIT) void board_debug_uart_init(void) { @@ -120,7 +120,7 @@ static int multi_boot(void) return multiboot; }
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) static void restore_jtag(void) { if (current_el() != 3) @@ -155,7 +155,7 @@ int board_init(void) int ret; #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) /* Check *at build time* if the filename is an non-empty string */ if (sizeof(CONFIG_ZYNQMP_SPL_PM_CFG_OBJ_FILE) > 1) zynqmp_pmufw_load_config_object(zynqmp_pm_cfg_obj, diff --git a/boot/Makefile b/boot/Makefile index f4675d6ffd5..299a22ed689 100644 --- a/boot/Makefile +++ b/boot/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2004-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-$(CONFIG_BOOT_RETRY) += bootretry.o obj-$(CONFIG_CMD_BOOTM) += bootm.o bootm_os.o diff --git a/boot/image-android-dt.c b/boot/image-android-dt.c index 3b25018c2e7..653835cea76 100644 --- a/boot/image-android-dt.c +++ b/boot/image-android-dt.c @@ -72,7 +72,7 @@ bool android_dt_get_fdt_by_index(ulong hdr_addr, u32 index, ulong *addr, return true; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) static void android_dt_print_fdt_info(const struct fdt_header *fdt) { u32 fdt_size; diff --git a/boot/image-android.c b/boot/image-android.c index 774565fd1fe..fdfff58a2a7 100644 --- a/boot/image-android.c +++ b/boot/image-android.c @@ -652,7 +652,7 @@ bool android_image_get_dtb_by_index(ulong hdr_addr, ulong vendor_boot_img, return false; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) /** * android_print_contents - prints out the contents of the Android format image * @hdr: pointer to the Android format image header diff --git a/boot/image-fit-sig.c b/boot/image-fit-sig.c index fe328df4a85..35873b1fb0e 100644 --- a/boot/image-fit-sig.c +++ b/boot/image-fit-sig.c @@ -48,7 +48,7 @@ struct image_region *fit_region_make_list(const void *fit, * Use malloc() except in SPL (to save code size). In SPL the caller * must allocate the array. */ - if (!IS_ENABLED(CONFIG_SPL_BUILD) && !region) + if (!IS_ENABLED(CONFIG_XPL_BUILD) && !region) region = calloc(sizeof(*region), count); if (!region) return NULL; diff --git a/cmd/Makefile b/cmd/Makefile index 91227f1249c..ed62e1c45f8 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2004-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD # core command obj-y += boot.o obj-$(CONFIG_CMD_BOOTM) += bootm.o @@ -247,7 +247,7 @@ obj-$(CONFIG_ARCH_MVEBU) += mvebu/ obj-$(CONFIG_ARCH_KEYSTONE) += ti/ obj-$(CONFIG_ARCH_K3) += ti/ obj-$(CONFIG_ARCH_OMAP2PLUS) += ti/ -endif # !CONFIG_SPL_BUILD +endif # !CONFIG_XPL_BUILD
obj-$(CONFIG_$(SPL_)CMD_TLV_EEPROM) += tlv_eeprom.o
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 98a687bcabb..74ff5c6fc11 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -49,7 +49,7 @@ DECLARE_GLOBAL_DATA_PTR; */ #define MAX_ENV_SIZE (1 << 20) /* 1 MiB */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Command interface: print one or all environment variables * @@ -182,9 +182,9 @@ DONE: return 0; } #endif -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int do_env_set(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -503,9 +503,9 @@ static int do_env_select(struct cmd_tbl *cmdtp, int flag, int argc, } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int do_env_default(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -1289,4 +1289,4 @@ U_BOOT_CMD_COMPLETE( var_complete ); #endif -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/common/Makefile b/common/Makefile index d871113cbb9..9fdad4bc38d 100644 --- a/common/Makefile +++ b/common/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
# core -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += init/ obj-y += main.o obj-y += exports.o @@ -42,12 +42,12 @@ obj-$(CONFIG_MENU) += menu.o obj-$(CONFIG_UPDATE_COMMON) += update.o obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o
obj-$(CONFIG_$(SPL_TPL_)BOOTSTAGE) += bootstage.o obj-$(CONFIG_$(SPL_TPL_)BLOBLIST) += bloblist.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifdef CONFIG_SPL_DFU obj-$(CONFIG_DFU_OVER_USB) += dfu.o endif @@ -58,14 +58,14 @@ obj-$(CONFIG_SPL_USB_STORAGE) += usb_storage.o obj-$(CONFIG_SPL_MUSB_NEW) += usb.o obj-$(CONFIG_SPL_SPLASH_SCREEN) += splash.o obj-$(CONFIG_SPL_SPLASH_SOURCE) += splash_source.o -endif # CONFIG_SPL_BUILD +endif # CONFIG_XPL_BUILD
#others obj-$(CONFIG_DDR_SPD) += ddr_spd.o obj-$(CONFIG_SPD_EEPROM) += ddr_spd.o obj-$(CONFIG_HWCONFIG) += hwconfig.o obj-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifdef CONFIG_TPL_BUILD obj-$(CONFIG_TPL_SERIAL) += console.o else @@ -73,7 +73,7 @@ obj-$(CONFIG_SPL_SERIAL) += console.o endif else obj-y += console.o -endif # CONFIG_SPL_BUILD +endif # CONFIG_XPL_BUILD
obj-$(CONFIG_CROS_EC) += cros_ec.o obj-y += dlmalloc.o diff --git a/common/cli_readline.c b/common/cli_readline.c index 4cb82b40149..4e6797a1944 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -73,7 +73,7 @@ static char *delete_char (char *buffer, char *p, int *colp, int *np, int plen) #define getcmd_getch() getchar() #define getcmd_cbeep() getcmd_putch('\a')
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define HIST_MAX 3 #define HIST_SIZE 32 #else diff --git a/common/console.c b/common/console.c index c9e206aec41..22224701e45 100644 --- a/common/console.c +++ b/common/console.c @@ -191,7 +191,7 @@ static int console_setfile(int file, struct stdio_dev * dev) /* Assign the new device (leaving the existing one started) */ stdio_devices[file] = dev;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * Update monitor functions * (to use the console stuff by other applications) diff --git a/common/hash.c b/common/hash.c index ac63803fed9..db6925d6782 100644 --- a/common/hash.c +++ b/common/hash.c @@ -403,7 +403,7 @@ int hash_block(const char *algo_name, const void *data, unsigned int len, return 0; }
-#if !defined(CONFIG_SPL_BUILD) && (defined(CONFIG_CMD_HASH) || \ +#if !defined(CONFIG_XPL_BUILD) && (defined(CONFIG_CMD_HASH) || \ defined(CONFIG_CMD_SHA1SUM) || defined(CONFIG_CMD_CRC32)) || \ defined(CONFIG_CMD_MD5SUM) /** diff --git a/common/spl/Makefile b/common/spl/Makefile index 137b18428bd..10528b31a7c 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -6,7 +6,7 @@ # Based on common/Makefile. #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o obj-$(CONFIG_$(SPL_TPL_)BOOTROM_SUPPORT) += spl_bootrom.o obj-$(CONFIG_$(SPL_TPL_)LOAD_FIT) += spl_fit.o diff --git a/common/splash_source.c b/common/splash_source.c index 5b271160449..f43e7cc1be7 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -215,7 +215,7 @@ static int splash_init_virtio(void) } }
-#if defined(CONFIG_CMD_UBIFS) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_UBIFS) && !defined(CONFIG_XPL_BUILD) static int splash_mount_ubifs(struct splash_location *location) { int res; diff --git a/config.mk b/config.mk index b915c29b3f3..e294be2a4c4 100644 --- a/config.mk +++ b/config.mk @@ -21,7 +21,7 @@ VENDOR :=
ARCH := $(CONFIG_SYS_ARCH:"%"=%) CPU := $(CONFIG_SYS_CPU:"%"=%) -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifdef CONFIG_ARCH_TEGRA CPU := arm720t endif diff --git a/disk/part.c b/disk/part.c index 706d77b3194..303178161c0 100644 --- a/disk/part.c +++ b/disk/part.c @@ -482,7 +482,7 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, } #endif
-#if IS_ENABLED(CONFIG_CMD_UBIFS) && !IS_ENABLED(CONFIG_SPL_BUILD) +#if IS_ENABLED(CONFIG_CMD_UBIFS) && !IS_ENABLED(CONFIG_XPL_BUILD) /* * Special-case ubi, ubi goes through a mtd, rather than through * a regular block device. diff --git a/disk/part_dos.c b/disk/part_dos.c index 09af2aeeb99..96f748702fd 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -100,7 +100,7 @@ static int test_block_type(unsigned char *buffer)
static int part_test_dos(struct blk_desc *desc) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD ALLOC_CACHE_ALIGN_BUFFER(legacy_mbr, mbr, DIV_ROUND_UP(desc->blksz, sizeof(legacy_mbr)));
diff --git a/doc/develop/distro.rst b/doc/develop/distro.rst index 9e715b23ebb..637bc27fc2d 100644 --- a/doc/develop/distro.rst +++ b/doc/develop/distro.rst @@ -189,7 +189,7 @@ TO BE UPDATED:
In your board configuration file, include the following::
- #ifndef CONFIG_SPL_BUILD + #ifndef CONFIG_XPL_BUILD #include <config_distro_bootcmd.h> #endif
@@ -316,7 +316,7 @@ that it supports the correct set of possible boot device types. To provide this configuration, simply define macro BOOT_TARGET_DEVICES prior to including <config_distro_bootcmd.h>. For example::
- #ifndef CONFIG_SPL_BUILD + #ifndef CONFIG_XPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ diff --git a/doc/develop/qconfig.rst b/doc/develop/qconfig.rst index 123779eab17..a18f32470ca 100644 --- a/doc/develop/qconfig.rst +++ b/doc/develop/qconfig.rst @@ -226,7 +226,7 @@ Available options Look for moved config options in spl/include/autoconf.mk instead of include/autoconf.mk. This is useful for moving options for SPL build because SPL related options (mostly prefixed with CONFIG_SPL_) are - sometimes blocked by CONFIG_SPL_BUILD ifdef conditionals. + sometimes blocked by CONFIG_XPL_BUILD ifdef conditionals.
-j, --jobs Specify the number of threads to run simultaneously. If not specified, diff --git a/doc/develop/tests_sandbox.rst b/doc/develop/tests_sandbox.rst index 72923070150..0630180bc55 100644 --- a/doc/develop/tests_sandbox.rst +++ b/doc/develop/tests_sandbox.rst @@ -278,7 +278,7 @@ Whatever sandbox build is used, which tests are present is determined by which source files are built. For sandbox_spl, the of_platdata tests are built because of the build rule in test/dm/Makefile::
- ifeq ($(CONFIG_SPL_BUILD),y) + ifeq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_SPL_OF_PLATDATA) += of_platdata.o else ...other tests for non-spl diff --git a/drivers/Makefile b/drivers/Makefile index 1acd94f3c17..1b7db812828 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -47,7 +47,7 @@ obj-y += bus/
ifndef CONFIG_TPL_BUILD ifndef CONFIG_VPL_BUILD -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD
obj-$(CONFIG_SPL_CPU) += cpu/ obj-$(CONFIG_SPL_CRYPTO) += crypto/ @@ -80,7 +80,7 @@ obj-$(CONFIG_TPL_MPC8XXX_INIT_DDR) += ddr/fsl/
endif
-ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),)
obj-y += ata/ obj-$(CONFIG_DM_DEMO) += demo/ diff --git a/drivers/block/Makefile b/drivers/block/Makefile index fe6a1fcf486..a551591fc91 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -9,7 +9,7 @@ ifndef CONFIG_$(SPL_)BLK obj-$(CONFIG_SPL_LEGACY_BLOCK) += blk_legacy.o endif
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_IDE) += ide.o obj-$(CONFIG_RKMTD) += rkmtd.o endif diff --git a/drivers/bus/Makefile b/drivers/bus/Makefile index 0802b9666bf..e14cb7fd9c7 100644 --- a/drivers/bus/Makefile +++ b/drivers/bus/Makefile @@ -3,7 +3,7 @@ # Makefile for the bus drivers. #
-ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),) obj-$(CONFIG_TI_PWMSS) += ti-pwmss.o obj-$(CONFIG_UNIPHIER_SYSTEM_BUS) += uniphier-system-bus.o endif diff --git a/drivers/clk/altera/clk-agilex.c b/drivers/clk/altera/clk-agilex.c index bdc7be0fb5d..e1ddd02f356 100644 --- a/drivers/clk/altera/clk-agilex.c +++ b/drivers/clk/altera/clk-agilex.c @@ -242,7 +242,7 @@ static void clk_basic_init(struct udevice *dev, if (!cfg) return;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* Always force clock manager into boot mode before any configuration */ clk_write_ctrl(plat, CM_REG_READL(plat, CLKMGR_CTRL) | CLKMGR_CTRL_BOOTMODE); diff --git a/drivers/clk/altera/clk-agilex5.c b/drivers/clk/altera/clk-agilex5.c index 72b923465df..716c71598bc 100644 --- a/drivers/clk/altera/clk-agilex5.c +++ b/drivers/clk/altera/clk-agilex5.c @@ -263,7 +263,7 @@ static void clk_basic_init(struct udevice *dev, clk_write_ctrl(plat, CM_REG_READL(plat, CLKMGR_CTRL) & ~CLKMGR_CTRL_BOOTMODE); } else { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* Always force clock manager into boot mode before any configuration */ clk_write_ctrl(plat, CM_REG_READL(plat, CLKMGR_CTRL) | CLKMGR_CTRL_BOOTMODE); diff --git a/drivers/clk/altera/clk-n5x.c b/drivers/clk/altera/clk-n5x.c index 3e256101a94..09db250ab6d 100644 --- a/drivers/clk/altera/clk-n5x.c +++ b/drivers/clk/altera/clk-n5x.c @@ -52,7 +52,7 @@ static void clk_basic_init(struct udevice *dev, if (!cfg) return;
-#if IS_ENABLED(CONFIG_SPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) /* Always force clock manager into boot mode before any configuration */ clk_write_ctrl(plat, CM_REG_READL(plat, CLKMGR_CTRL) | CLKMGR_CTRL_BOOTMODE); diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 16169dac234..a9937c22dcb 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -378,7 +378,7 @@ int clk_set_defaults(struct udevice *dev, enum clk_defaults_stage stage) * However, still set them for SPL. And still set them if explicitly * asked. */ - if (!(IS_ENABLED(CONFIG_SPL_BUILD) || (gd->flags & GD_FLG_RELOC))) + if (!(IS_ENABLED(CONFIG_XPL_BUILD) || (gd->flags & GD_FLG_RELOC))) if (stage != CLK_DEFAULTS_POST_FORCE) return 0;
diff --git a/drivers/clk/clk_vexpress_osc.c b/drivers/clk/clk_vexpress_osc.c index 2e0e7bbe68f..85ac92c908a 100644 --- a/drivers/clk/clk_vexpress_osc.c +++ b/drivers/clk/clk_vexpress_osc.c @@ -37,7 +37,7 @@ static ulong vexpress_osc_clk_get_rate(struct clk *clk) return data; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong vexpress_osc_clk_set_rate(struct clk *clk, ulong rate) { int err; @@ -64,7 +64,7 @@ static ulong vexpress_osc_clk_set_rate(struct clk *clk, ulong rate)
static struct clk_ops vexpress_osc_clk_ops = { .get_rate = vexpress_osc_clk_get_rate, -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD .set_rate = vexpress_osc_clk_set_rate, #endif }; diff --git a/drivers/clk/clk_zynq.c b/drivers/clk/clk_zynq.c index b62b4646f4e..a8505f62bba 100644 --- a/drivers/clk/clk_zynq.c +++ b/drivers/clk/clk_zynq.c @@ -43,13 +43,13 @@
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD enum zynq_clk_rclk {mio_clk, emio_clk}; #endif
struct zynq_clk_priv { ulong ps_clk_freq; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD struct clk gem_emio_clk[2]; #endif }; @@ -75,7 +75,7 @@ static void *zynq_clk_get_register(enum zynq_clk id) return &slcr_base->uart_clk_ctrl; case spi0_clk ... spi1_clk: return &slcr_base->spi_clk_ctrl; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case dci_clk: return &slcr_base->dci_clk_ctrl; case gem0_clk: @@ -150,7 +150,7 @@ static ulong zynq_clk_get_pll_rate(struct zynq_clk_priv *priv, enum zynq_clk id) return priv->ps_clk_freq * mul; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static enum zynq_clk_rclk zynq_clk_get_gem_rclk(enum zynq_clk id) { u32 clk_ctrl, srcsel; @@ -199,7 +199,7 @@ static ulong zynq_clk_get_cpu_rate(struct zynq_clk_priv *priv, enum zynq_clk id) return DIV_ROUND_CLOSEST(zynq_clk_get_pll_rate(priv, pll), div); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong zynq_clk_get_ddr2x_rate(struct zynq_clk_priv *priv) { u32 clk_ctrl, div; @@ -223,7 +223,7 @@ static ulong zynq_clk_get_ddr3x_rate(struct zynq_clk_priv *priv) return DIV_ROUND_CLOSEST(zynq_clk_get_pll_rate(priv, ddrpll_clk), div); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong zynq_clk_get_dci_rate(struct zynq_clk_priv *priv) { u32 clk_ctrl, div0, div1; @@ -251,7 +251,7 @@ static ulong zynq_clk_get_peripheral_rate(struct zynq_clk_priv *priv, if (!div0) div0 = 1;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD if (two_divs) { div1 = (clk_ctrl & CLK_CTRL_DIV1_MASK) >> CLK_CTRL_DIV1_SHIFT; if (!div1) @@ -268,7 +268,7 @@ static ulong zynq_clk_get_peripheral_rate(struct zynq_clk_priv *priv, div1); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong zynq_clk_get_gem_rate(struct zynq_clk_priv *priv, enum zynq_clk id) { struct clk *parent; @@ -366,7 +366,7 @@ static ulong zynq_clk_set_gem_rate(struct zynq_clk_priv *priv, enum zynq_clk id, } #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong zynq_clk_get_rate(struct clk *clk) { struct zynq_clk_priv *priv = dev_get_priv(clk->dev); @@ -502,7 +502,7 @@ static void zynq_clk_dump(struct udevice *dev)
static struct clk_ops zynq_clk_ops = { .get_rate = zynq_clk_get_rate, -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD .set_rate = zynq_clk_set_rate, #endif .enable = dummy_enable, @@ -514,7 +514,7 @@ static struct clk_ops zynq_clk_ops = { static int zynq_clk_probe(struct udevice *dev) { struct zynq_clk_priv *priv = dev_get_priv(dev); -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD unsigned int i; char name[16]; int ret; diff --git a/drivers/clk/imx/clk-imx8mm.c b/drivers/clk/imx/clk-imx8mm.c index a91c6767fac..bb6958f0ec2 100644 --- a/drivers/clk/imx/clk-imx8mm.c +++ b/drivers/clk/imx/clk-imx8mm.c @@ -31,7 +31,7 @@ static const char * const imx8mm_ahb_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_pll1_400m", "sys_pll2_125m", "sys_pll3_out", "audio_pll1_out", "video_pll1_out", };
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static const char * const imx8mm_enet_axi_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", "sys_pll2_250m", "sys_pll2_200m", "audio_pll1_out", "video_pll1_out", "sys_pll3_out", }; @@ -95,7 +95,7 @@ static const char * const imx8mm_pcie1_aux_sels[] = {"clock-osc-24m", "sys_pll2_ "sys_pll1_160m", "sys_pll1_200m", }; #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static const char * const imx8mm_pwm1_sels[] = {"clock-osc-24m", "sys_pll2_100m", "sys_pll1_160m", "sys_pll1_40m", "sys_pll3_out", "clk_ext1", "sys_pll1_80m", "video_pll1_out", }; @@ -357,7 +357,7 @@ static int imx8mm_clk_probe(struct udevice *dev) imx_clk_gate4("usb1_ctrl_root_clk", "usb_bus", base + 0x44d0, 0));
/* clks not needed in SPL stage */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD clk_dm(IMX8MM_CLK_ENET_AXI, imx8m_clk_composite("enet_axi", imx8mm_enet_axi_sels, base + 0x8880)); diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index 125215e84f4..be15ebd0e25 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -37,7 +37,7 @@ static const char * const imx8mn_enet_axi_sels[] = {"clock-osc-24m", "sys_pll1_2 "sys_pll2_250m", "sys_pll2_200m", "audio_pll1_out", "video_pll_out", "sys_pll3_out", };
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static const char * const imx8mn_enet_ref_sels[] = {"clock-osc-24m", "sys_pll2_125m", "sys_pll2_50m", "sys_pll2_100m", "sys_pll1_160m", "audio_pll1_out", "video_pll_out", "clk_ext4", }; @@ -97,7 +97,7 @@ static const char * const imx8mn_i2c4_sels[] = {"clock-osc-24m", "sys_pll1_160m" "sys_pll3_out", "audio_pll1_out", "video_pll_out", "audio_pll2_out", "sys_pll1_133m", };
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static const char * const imx8mn_pwm1_sels[] = {"clock-osc-24m", "sys_pll2_100m", "sys_pll1_160m", "sys_pll1_40m", "sys_pll3_out", "clk_ext1", "sys_pll1_80m", "video_pll_out", }; @@ -359,7 +359,7 @@ static int imx8mn_clk_probe(struct udevice *dev) imx_clk_gate4("usb1_ctrl_root_clk", "usb_bus", base + 0x44d0, 0));
/* clks not needed in SPL stage */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD clk_dm(IMX8MN_CLK_ENET_REF, imx8m_clk_composite("enet_ref", imx8mn_enet_ref_sels, base + 0xa980)); diff --git a/drivers/clk/imx/clk-imxrt1020.c b/drivers/clk/imx/clk-imxrt1020.c index c80b02975aa..752434cb0ad 100644 --- a/drivers/clk/imx/clk-imxrt1020.c +++ b/drivers/clk/imx/clk-imxrt1020.c @@ -124,7 +124,7 @@ static int imxrt1020_clk_probe(struct udevice *dev) clk_dm(IMXRT1020_CLK_SEMC, imx_clk_gate2("semc", "semc_podf", base + 0x74, 4));
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD struct clk *clk, *clk1;
clk_get_by_id(IMXRT1020_CLK_SEMC_SEL, &clk1); diff --git a/drivers/clk/imx/clk-imxrt1050.c b/drivers/clk/imx/clk-imxrt1050.c index 754f3948427..788e0650a92 100644 --- a/drivers/clk/imx/clk-imxrt1050.c +++ b/drivers/clk/imx/clk-imxrt1050.c @@ -180,7 +180,7 @@ static int imxrt1050_clk_probe(struct udevice *dev)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* bypass pll1 before setting its rate */ clk_get_by_id(IMXRT1050_CLK_PLL1_REF_SEL, &clk); clk_get_by_id(IMXRT1050_CLK_PLL1_BYPASS, &clk1); diff --git a/drivers/clk/rockchip/clk_px30.c b/drivers/clk/rockchip/clk_px30.c index d7825c66493..22ede1c38a8 100644 --- a/drivers/clk/rockchip/clk_px30.c +++ b/drivers/clk/rockchip/clk_px30.c @@ -989,7 +989,7 @@ static ulong px30_peri_set_clk(struct px30_clk_priv *priv, ulong clk_id, return px30_peri_get_clk(priv, clk_id); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong px30_crypto_get_clk(struct px30_clk_priv *priv, ulong clk_id) { struct px30_cru *cru = priv->cru; @@ -1261,7 +1261,7 @@ static ulong px30_clk_get_rate(struct clk *clk) case HCLK_PERI_PRE: rate = px30_peri_get_clk(priv, clk->id); break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case SCLK_CRYPTO: case SCLK_CRYPTO_APK: rate = px30_crypto_get_clk(priv, clk->id); @@ -1345,7 +1345,7 @@ static ulong px30_clk_set_rate(struct clk *clk, ulong rate) case HCLK_PERI_PRE: ret = px30_peri_set_clk(priv, clk->id, rate); break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case SCLK_CRYPTO: case SCLK_CRYPTO_APK: ret = px30_crypto_set_clk(priv, clk->id, rate); diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index f569a100f22..d8b03e1d7ab 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -80,7 +80,7 @@ enum { "divisors on line " __stringify(__LINE__));
/* Keep divisors as low as possible to reduce jitter and power usage */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 2, 2); static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 2); #endif @@ -371,7 +371,7 @@ static ulong rockchip_spi_set_clk(struct rk3188_cru *cru, uint gclk_rate, return rockchip_spi_get_clk(cru, gclk_rate, periph); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static void rkclk_init(struct rk3188_cru *cru, struct rk3188_grf *grf, bool has_bwadj) { @@ -557,7 +557,7 @@ static int rk3188_clk_probe(struct udevice *dev) return PTR_ERR(priv->grf); priv->has_bwadj = (type == RK3188A_CRU) ? 1 : 0;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #if CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3188_clk_plat *plat = dev_get_plat(dev);
diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 432a79291c8..43c44fadbe7 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -223,7 +223,7 @@ static int rkclk_configure_ddr(struct rockchip_cru *cru, struct rk3288_grf *grf, return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define VCO_MAX_KHZ 2200000 #define VCO_MIN_KHZ 440000 #define FREF_MAX_KHZ 2200000 @@ -421,7 +421,7 @@ static ulong rockchip_i2s_set_clk(struct rockchip_cru *cru, uint gclk_rate,
return rockchip_i2s_get_clk(cru, gclk_rate); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
static void rkclk_init(struct rockchip_cru *cru, struct rk3288_grf *grf) { @@ -819,7 +819,7 @@ static ulong rk3288_clk_set_rate(struct clk *clk, ulong rate) case SCLK_SPI2: new_rate = rockchip_spi_set_clk(cru, gclk_rate, clk->id, rate); break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case SCLK_I2S0: new_rate = rockchip_i2s_set_clk(cru, gclk_rate, rate); break; @@ -973,7 +973,7 @@ static int rk3288_clk_probe(struct udevice *dev) priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); if (IS_ERR(priv->grf)) return PTR_ERR(priv->grf); -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #if CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3288_clk_plat *plat = dev_get_plat(dev);
diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 9137dbe69ce..7701a9734ee 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -582,7 +582,7 @@ static ulong rk3328_spi_set_clk(struct rk3328_cru *cru, uint hz) return rk3328_spi_get_clk(cru); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong rk3328_vop_get_clk(struct rk3328_clk_priv *priv, ulong clk_id) { struct rk3328_cru *cru = priv->cru; @@ -746,7 +746,7 @@ static ulong rk3328_clk_set_rate(struct clk *clk, ulong rate) case SCLK_SPI: ret = rk3328_spi_set_clk(priv->cru, rate); break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case DCLK_LCDC: case ACLK_VOP_PRE: case ACLK_VIO_PRE: diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index d8943980521..630253fbb1d 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -50,7 +50,7 @@ struct pll_div { (_nr * _no) == hz, #hz "Hz cannot be hit with PLL " \ "divisors on line " __stringify(__LINE__));
-#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) static const struct pll_div apll_l_init_cfg = PLL_DIVISORS(APLL_L_HZ, 12, 2); static const struct pll_div apll_b_init_cfg = PLL_DIVISORS(APLL_B_HZ, 1, 2); #if !defined(CONFIG_TPL_BUILD) @@ -88,7 +88,7 @@ static uint32_t rkclk_pll_get_rate(struct rk3368_cru *cru, } }
-#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id, const struct pll_div *div) { @@ -130,7 +130,7 @@ static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id, } #endif
-#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) static void rkclk_init(struct rk3368_cru *cru) { u32 apllb, aplll, dpll, cpll, gpll; @@ -157,7 +157,7 @@ static void rkclk_init(struct rk3368_cru *cru) } #endif
-#if !IS_ENABLED(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(MMC) +#if !IS_ENABLED(CONFIG_XPL_BUILD) || CONFIG_IS_ENABLED(MMC) static ulong rk3368_mmc_get_clk(struct rk3368_cru *cru, uint clk_id) { u32 div, con, con_id, rate; @@ -469,7 +469,7 @@ static ulong rk3368_clk_get_rate(struct clk *clk) case SCLK_SPI0 ... SCLK_SPI2: rate = rk3368_spi_get_clk(priv->cru, clk->id); break; -#if !IS_ENABLED(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(MMC) +#if !IS_ENABLED(CONFIG_XPL_BUILD) || CONFIG_IS_ENABLED(MMC) case HCLK_SDMMC: case HCLK_EMMC: rate = rk3368_mmc_get_clk(priv->cru, clk->id); @@ -500,7 +500,7 @@ static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) ret = rk3368_ddr_set_clk(priv->cru, rate); break; #endif -#if !IS_ENABLED(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(MMC) +#if !IS_ENABLED(CONFIG_XPL_BUILD) || CONFIG_IS_ENABLED(MMC) case HCLK_SDMMC: case HCLK_EMMC: ret = rk3368_mmc_set_clk(clk, rate); @@ -586,7 +586,7 @@ static int rk3368_clk_probe(struct udevice *dev)
priv->cru = map_sysmem(plat->dtd.reg[0], plat->dtd.reg[1]); #endif -#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) rkclk_init(priv->cru); #endif
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 89924041299..155ea8d6353 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -56,7 +56,7 @@ struct pll_div {
static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 2, 2, 1); static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 2, 2); -#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) static const struct pll_div ppll_init_cfg = PLL_DIVISORS(PPLL_HZ, 2, 2, 1); #endif
@@ -1464,7 +1464,7 @@ static int rk3399_clk_probe(struct udevice *dev) priv->cru = map_sysmem(plat->dtd.reg[0], plat->dtd.reg[1]); #endif
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) init_clocks = true; #elif CONFIG_IS_ENABLED(HANDOFF) if (!(gd->flags & GD_FLG_RELOC)) { @@ -1658,7 +1658,7 @@ static struct clk_ops rk3399_pmuclk_ops = { .set_rate = rk3399_pmuclk_set_rate, };
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static void pmuclk_init(struct rk3399_pmucru *pmucru) { u32 pclk_div; @@ -1676,7 +1676,7 @@ static void pmuclk_init(struct rk3399_pmucru *pmucru)
static int rk3399_pmuclk_probe(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_PLATDATA) || !defined(CONFIG_SPL_BUILD) +#if CONFIG_IS_ENABLED(OF_PLATDATA) || !defined(CONFIG_XPL_BUILD) struct rk3399_pmuclk_priv *priv = dev_get_priv(dev); #endif
@@ -1686,7 +1686,7 @@ static int rk3399_pmuclk_probe(struct udevice *dev) priv->pmucru = map_sysmem(plat->dtd.reg[0], plat->dtd.reg[1]); #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD pmuclk_init(priv->pmucru); #endif return 0; diff --git a/drivers/clk/rockchip/clk_rk3568.c b/drivers/clk/rockchip/clk_rk3568.c index 35563509d61..977699d509d 100644 --- a/drivers/clk/rockchip/clk_rk3568.c +++ b/drivers/clk/rockchip/clk_rk3568.c @@ -91,7 +91,7 @@ static struct rockchip_pll_clock rk3568_pll_clks[] = { RK3568_PMU_MODE, 2, 10, 0, rk3568_pll_rates), };
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong rk3568_pmu_pll_set_rate(struct rk3568_clk_priv *priv, ulong pll_id, ulong rate) @@ -1707,7 +1707,7 @@ static ulong rk3568_emmc_set_bclk(struct rk3568_clk_priv *priv, ulong rate) return rk3568_emmc_get_bclk(priv); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong rk3568_aclk_vop_get_clk(struct rk3568_clk_priv *priv) { struct rk3568_cru *cru = priv->cru; @@ -2413,7 +2413,7 @@ static ulong rk3568_clk_get_rate(struct clk *clk) case TCLK_EMMC: rate = OSC_HZ; break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case ACLK_VOP: rate = rk3568_aclk_vop_get_clk(priv); break; @@ -2594,7 +2594,7 @@ static ulong rk3568_clk_set_rate(struct clk *clk, ulong rate) case TCLK_EMMC: ret = OSC_HZ; break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case ACLK_VOP: ret = rk3568_aclk_vop_set_clk(priv, rate); break; @@ -2894,7 +2894,7 @@ static void rk3568_clk_init(struct rk3568_clk_priv *priv) priv->gpll_hz = GPLL_HZ; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD ret = rk3568_bus_set_clk(priv, ACLK_BUS, 150000000); if (ret < 0) printf("Fail to set the ACLK_BUS clock.\n"); diff --git a/drivers/clk/rockchip/clk_rk3588.c b/drivers/clk/rockchip/clk_rk3588.c index db1384dacd2..6042fc10cdb 100644 --- a/drivers/clk/rockchip/clk_rk3588.c +++ b/drivers/clk/rockchip/clk_rk3588.c @@ -65,7 +65,7 @@ static struct rockchip_pll_clock rk3588_pll_clks[] = { RK3588_MODE_CON0, 0, 15, 0, rk3588_pll_rates), [PPLL] = PLL(pll_rk3588, PLL_PPLL, RK3588_PMU_PLL_CON(128), RK3588_MODE_CON0, 10, 15, 0, rk3588_pll_rates), -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * The SPLL is part of the SBUSCRU, not the main CRU and as * such only directly accessible during the SPL stage. @@ -76,7 +76,7 @@ static struct rockchip_pll_clock rk3588_pll_clks[] = {
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * * rational_best_approximation(31415, 10000, @@ -875,7 +875,7 @@ static ulong rk3588_mmc_set_clk(struct rk3588_clk_priv *priv, return rk3588_mmc_get_clk(priv, clk_id); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static ulong rk3588_aux16m_get_clk(struct rk3588_clk_priv *priv, ulong clk_id) { struct rk3588_cru *cru = priv->cru; @@ -1600,7 +1600,7 @@ static ulong rk3588_clk_get_rate(struct clk *clk) case CLK_GPU: rate = 200000000; break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case CLK_AUX16M_0: case CLK_AUX16M_1: rate = rk3588_aux16m_get_clk(priv, clk->id); @@ -1760,7 +1760,7 @@ static ulong rk3588_clk_set_rate(struct clk *clk, ulong rate) case CLK_150M_SRC: ret = 0; break; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD case CLK_AUX16M_0: case CLK_AUX16M_1: ret = rk3588_aux16m_set_clk(priv, clk->id, rate); @@ -1965,7 +1965,7 @@ static int rk3588_clk_probe(struct udevice *dev)
priv->sync_kernel = false;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD rockchip_pll_set_rate(&rk3588_pll_clks[B0PLL], priv->cru, B0PLL, LPLL_HZ); rockchip_pll_set_rate(&rk3588_pll_clks[B1PLL], priv->cru, @@ -2051,7 +2051,7 @@ U_BOOT_DRIVER(rockchip_rk3588_cru) = { .probe = rk3588_clk_probe, };
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define SCRU_BASE 0xfd7d0000 #define SBUSCRU_BASE 0xfd7d8000
diff --git a/drivers/clk/sifive/sifive-prci.c b/drivers/clk/sifive/sifive-prci.c index aa26d3a109b..de55504b5c9 100644 --- a/drivers/clk/sifive/sifive-prci.c +++ b/drivers/clk/sifive/sifive-prci.c @@ -670,7 +670,7 @@ static int sifive_prci_probe(struct udevice *dev) __prci_wrpll_read_cfg0(pd, pc->pwd); }
- if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { if (device_is_compatible(dev, "sifive,fu740-c000-prci")) { u32 prci_pll_reg; unsigned long parent_rate; diff --git a/drivers/clk/starfive/clk-jh7110-pll.c b/drivers/clk/starfive/clk-jh7110-pll.c index 581035842fc..6d2bfb3ecb7 100644 --- a/drivers/clk/starfive/clk-jh7110-pll.c +++ b/drivers/clk/starfive/clk-jh7110-pll.c @@ -348,10 +348,10 @@ struct clk *starfive_jh7110_pll(const char *name, const char *parent_name, return ERR_PTR(ret); }
- if (IS_ENABLED(CONFIG_SPL_BUILD) && pll->type == PLL0) + if (IS_ENABLED(CONFIG_XPL_BUILD) && pll->type == PLL0) jh7110_pllx_set_rate(clk, 1000000000);
- if (IS_ENABLED(CONFIG_SPL_BUILD) && pll->type == PLL2) + if (IS_ENABLED(CONFIG_XPL_BUILD) && pll->type == PLL2) jh7110_pllx_set_rate(clk, 1188000000);
return clk; diff --git a/drivers/clk/stm32/clk-stm32mp1.c b/drivers/clk/stm32/clk-stm32mp1.c index 204ac170531..4044edfb768 100644 --- a/drivers/clk/stm32/clk-stm32mp1.c +++ b/drivers/clk/stm32/clk-stm32mp1.c @@ -26,7 +26,7 @@
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) /* activate clock tree initialization in the driver */ #define STM32MP1_CLOCK_TREE_INIT #endif @@ -2279,7 +2279,7 @@ static int stm32mp1_clk_probe(struct udevice *dev) dev_err(dev, "clock tree initialization failed (%d)\n", result); #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #if defined(VERBOSE_DEBUG) /* display debug information for probe after relocation */ if (gd->flags & GD_FLG_RELOC) @@ -2314,7 +2314,7 @@ static const struct clk_ops stm32mp1_clk_ops = { .disable = stm32mp1_clk_disable, .get_rate = stm32mp1_clk_get_rate, .set_rate = stm32mp1_clk_set_rate, -#if IS_ENABLED(CONFIG_CMD_CLK) && !IS_ENABLED(CONFIG_SPL_BUILD) +#if IS_ENABLED(CONFIG_CMD_CLK) && !IS_ENABLED(CONFIG_XPL_BUILD) .dump = stm32mp1_clk_dump, #endif }; diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 7e3b3719d18..129b34a5cd2 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -611,7 +611,7 @@ int ofnode_read_u32_array(ofnode node, const char *propname, out_values, sz);
/* get the error right, but space is more important in SPL */ - if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD)) { if (ret == -FDT_ERR_NOTFOUND) return -EINVAL; else if (ret == -FDT_ERR_BADLAYOUT) @@ -1468,7 +1468,7 @@ int ofnode_read_simple_size_cells(ofnode node)
bool ofnode_pre_reloc(ofnode node) { -#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_TPL_BUILD) +#if defined(CONFIG_XPL_BUILD) || defined(CONFIG_TPL_BUILD) /* for SPL and TPL the remaining nodes after the fdtgrep 1st pass * had property bootph-all or bootph-pre-sram/bootph-pre-ram. * They are removed in final dtb (fdtgrep 2nd pass) diff --git a/drivers/crypto/fsl/jobdesc.c b/drivers/crypto/fsl/jobdesc.c index 55191736931..9c4ff4960fc 100644 --- a/drivers/crypto/fsl/jobdesc.c +++ b/drivers/crypto/fsl/jobdesc.c @@ -207,7 +207,7 @@ void inline_cnstr_jobdesc_hash(uint32_t *desc, append_store(desc, dma_addr_out, storelen, LDST_CLASS_2_CCB | LDST_SRCDST_BYTE_CONTEXT); } -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD void inline_cnstr_jobdesc_blob_encap(uint32_t *desc, uint8_t *key_idnfr, uint8_t *plain_txt, uint8_t *enc_blob, uint32_t in_sz) diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index 27e24808946..c45481bef0b 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -713,7 +713,7 @@ int sec_init_idx(uint8_t sec_idx)
ccsr_sec_t *sec = caam->sec; uint32_t mcr = sec_in32(&sec->mcfgr); -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_IMX8M) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_IMX8M) uint32_t jrdid_ms = 0; #endif #ifdef CONFIG_FSL_CORENET @@ -745,14 +745,14 @@ int sec_init_idx(uint8_t sec_idx) mcr |= (1 << MCFGR_PS_SHIFT); #endif sec_out32(&sec->mcfgr, mcr); -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_IMX8M) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_IMX8M) jrdid_ms = JRDID_MS_TZ_OWN | JRDID_MS_PRIM_TZ | JRDID_MS_PRIM_DID; sec_out32(&sec->jrliodnr[caam->jrid].ms, jrdid_ms); #endif jr_reset();
#ifdef CONFIG_FSL_CORENET -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * For SPL Build, Set the Liodns in SEC JR0 for * creating PAMU entries corresponding to these. diff --git a/drivers/ddr/altera/sdram_gen5.c b/drivers/ddr/altera/sdram_gen5.c index 46c53e7c7a3..3c79bb11802 100644 --- a/drivers/ddr/altera/sdram_gen5.c +++ b/drivers/ddr/altera/sdram_gen5.c @@ -20,7 +20,7 @@
#include "sequencer.h"
struct altera_gen5_sdram_priv { struct ram_info info; @@ -651,4 +651,4 @@ U_BOOT_DRIVER(altera_gen5_sdram) = { .priv_auto = sizeof(struct altera_gen5_sdram_priv), };
-#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/drivers/ddr/fsl/lc_common_dimm_params.c b/drivers/ddr/fsl/lc_common_dimm_params.c index cc128112e4f..9c5b108267a 100644 --- a/drivers/ddr/fsl/lc_common_dimm_params.c +++ b/drivers/ddr/fsl/lc_common_dimm_params.c @@ -409,18 +409,18 @@ compute_lowest_common_dimm_parameters(const unsigned int ctrl_num, if (dimm_params[i].n_ranks) { if (dimm_params[i].registered_dimm) { temp1 = 1; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD printf("Detected RDIMM %s\n", dimm_params[i].mpart); #endif } else { temp2 = 1; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD printf("Detected UDIMM %s\n", dimm_params[i].mpart); #endif } -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD puts(" "); #endif } diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index 888dfb7ff33..d59e94779ff 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -863,16 +863,16 @@ phys_size_t __fsl_ddr_sdram(fsl_ddr_info_t *pinfo) if ((first_ctrl == 0) && (total_memory - 1 > (phys_size_t)~0ULL)) { puts("Detected "); print_size(total_memory, " of memory\n"); -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD puts(" "); /* re-align to match init_dram print */ #endif puts("This U-Boot only supports <= "); print_size((unsigned long long)((phys_size_t)~0ULL)+1, " of DDR\n"); -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD puts(" "); /* re-align to match init_dram print */ #endif puts("You could rebuild it with CONFIG_PHYS_64BIT\n"); -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD puts(" "); /* re-align to match init_dram print */ #endif } diff --git a/drivers/ddr/imx/imx8m/Makefile b/drivers/ddr/imx/imx8m/Makefile index aed91dc23f4..883e6e1b0d7 100644 --- a/drivers/ddr/imx/imx8m/Makefile +++ b/drivers/ddr/imx/imx8m/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_IMX8M_DRAM) += ddr_init.o obj-y += ../phy/ endif diff --git a/drivers/ddr/imx/imx8ulp/Makefile b/drivers/ddr/imx/imx8ulp/Makefile index 7f44a92180f..4f2ad32351c 100644 --- a/drivers/ddr/imx/imx8ulp/Makefile +++ b/drivers/ddr/imx/imx8ulp/Makefile @@ -4,6 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_IMX8ULP_DRAM) += ddr_init.o endif diff --git a/drivers/ddr/imx/imx9/Makefile b/drivers/ddr/imx/imx9/Makefile index 9403f988b32..6c9506055b8 100644 --- a/drivers/ddr/imx/imx9/Makefile +++ b/drivers/ddr/imx/imx9/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_IMX9_DRAM) += ddr_init.o obj-y += ../phy/ endif diff --git a/drivers/ddr/imx/phy/Makefile b/drivers/ddr/imx/phy/Makefile index bb3d4ee5b74..592d0c6ebad 100644 --- a/drivers/ddr/imx/phy/Makefile +++ b/drivers/ddr/imx/phy/Makefile @@ -4,6 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_IMX_SNPS_DDR_PHY) += helper.o ddrphy_utils.o ddrphy_train.o ddrphy_csr.o endif diff --git a/drivers/ddr/marvell/a38x/Makefile b/drivers/ddr/marvell/a38x/Makefile index 4e8a9d190d7..f49d009920e 100644 --- a/drivers/ddr/marvell/a38x/Makefile +++ b/drivers/ddr/marvell/a38x/Makefile @@ -1,29 +1,29 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_SPL_BUILD) += mv_ddr_plat.o -obj-$(CONFIG_SPL_BUILD) += mv_ddr_sys_env_lib.o -obj-$(CONFIG_SPL_BUILD) += ddr3_debug.o -obj-$(CONFIG_SPL_BUILD) += ddr3_init.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_bist.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_centralization.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_db.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_hw_algo.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_ip_engine.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_leveling.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_pbs.o -obj-$(CONFIG_SPL_BUILD) += mv_ddr_build_message.o -obj-$(CONFIG_SPL_BUILD) += mv_ddr_common.o -obj-$(CONFIG_SPL_BUILD) += mv_ddr_spd.o -obj-$(CONFIG_SPL_BUILD) += mv_ddr_topology.o -obj-$(CONFIG_SPL_BUILD) += xor.o +obj-$(CONFIG_XPL_BUILD) += mv_ddr_plat.o +obj-$(CONFIG_XPL_BUILD) += mv_ddr_sys_env_lib.o +obj-$(CONFIG_XPL_BUILD) += ddr3_debug.o +obj-$(CONFIG_XPL_BUILD) += ddr3_init.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_bist.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_centralization.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_db.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_hw_algo.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_ip_engine.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_leveling.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_pbs.o +obj-$(CONFIG_XPL_BUILD) += mv_ddr_build_message.o +obj-$(CONFIG_XPL_BUILD) += mv_ddr_common.o +obj-$(CONFIG_XPL_BUILD) += mv_ddr_spd.o +obj-$(CONFIG_XPL_BUILD) += mv_ddr_topology.o +obj-$(CONFIG_XPL_BUILD) += xor.o
obj-$(CONFIG_ARMADA_38X_SUPPORT_OLD_DDR3_TRAINING) += old/
ifdef CONFIG_DDR4 - obj-$(CONFIG_SPL_BUILD) += mv_ddr4_mpr_pda_if.o - obj-$(CONFIG_SPL_BUILD) += mv_ddr4_training.o - obj-$(CONFIG_SPL_BUILD) += mv_ddr4_training_calibration.o - obj-$(CONFIG_SPL_BUILD) += mv_ddr4_training_db.o - obj-$(CONFIG_SPL_BUILD) += mv_ddr4_training_leveling.o + obj-$(CONFIG_XPL_BUILD) += mv_ddr4_mpr_pda_if.o + obj-$(CONFIG_XPL_BUILD) += mv_ddr4_training.o + obj-$(CONFIG_XPL_BUILD) += mv_ddr4_training_calibration.o + obj-$(CONFIG_XPL_BUILD) += mv_ddr4_training_db.o + obj-$(CONFIG_XPL_BUILD) += mv_ddr4_training_leveling.o endif diff --git a/drivers/ddr/marvell/a38x/old/Makefile b/drivers/ddr/marvell/a38x/old/Makefile index 1645a79b405..c9bc746cc2b 100644 --- a/drivers/ddr/marvell/a38x/old/Makefile +++ b/drivers/ddr/marvell/a38x/old/Makefile @@ -2,20 +2,20 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_SPL_BUILD) += ddr3_a38x.o -obj-$(CONFIG_SPL_BUILD) += ddr3_a38x_training.o -obj-$(CONFIG_SPL_BUILD) += ddr3_debug.o -obj-$(CONFIG_SPL_BUILD) += ddr3_hws_hw_training.o -obj-$(CONFIG_SPL_BUILD) += ddr3_init.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_bist.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_centralization.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_db.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_hw_algo.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_ip_engine.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_leveling.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_pbs.o -obj-$(CONFIG_SPL_BUILD) += ddr3_training_static.o +obj-$(CONFIG_XPL_BUILD) += ddr3_a38x.o +obj-$(CONFIG_XPL_BUILD) += ddr3_a38x_training.o +obj-$(CONFIG_XPL_BUILD) += ddr3_debug.o +obj-$(CONFIG_XPL_BUILD) += ddr3_hws_hw_training.o +obj-$(CONFIG_XPL_BUILD) += ddr3_init.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_bist.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_centralization.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_db.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_hw_algo.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_ip_engine.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_leveling.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_pbs.o +obj-$(CONFIG_XPL_BUILD) += ddr3_training_static.o
define IncludeSymbolRename CFLAGS_$(1) = -include $(srctree)/drivers/ddr/marvell/a38x/old/glue_symbol_renames.h diff --git a/drivers/ddr/marvell/axp/Makefile b/drivers/ddr/marvell/axp/Makefile index d04d9a21db2..01e427296e6 100644 --- a/drivers/ddr/marvell/axp/Makefile +++ b/drivers/ddr/marvell/axp/Makefile @@ -1,12 +1,12 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_SPL_BUILD) += ddr3_dfs.o -obj-$(CONFIG_SPL_BUILD) += ddr3_dqs.o -obj-$(CONFIG_SPL_BUILD) += ddr3_hw_training.o -obj-$(CONFIG_SPL_BUILD) += ddr3_init.o -obj-$(CONFIG_SPL_BUILD) += ddr3_pbs.o -obj-$(CONFIG_SPL_BUILD) += ddr3_read_leveling.o -obj-$(CONFIG_SPL_BUILD) += ddr3_sdram.o -obj-$(CONFIG_SPL_BUILD) += ddr3_spd.o -obj-$(CONFIG_SPL_BUILD) += ddr3_write_leveling.o -obj-$(CONFIG_SPL_BUILD) += xor.o +obj-$(CONFIG_XPL_BUILD) += ddr3_dfs.o +obj-$(CONFIG_XPL_BUILD) += ddr3_dqs.o +obj-$(CONFIG_XPL_BUILD) += ddr3_hw_training.o +obj-$(CONFIG_XPL_BUILD) += ddr3_init.o +obj-$(CONFIG_XPL_BUILD) += ddr3_pbs.o +obj-$(CONFIG_XPL_BUILD) += ddr3_read_leveling.o +obj-$(CONFIG_XPL_BUILD) += ddr3_sdram.o +obj-$(CONFIG_XPL_BUILD) += ddr3_spd.o +obj-$(CONFIG_XPL_BUILD) += ddr3_write_leveling.o +obj-$(CONFIG_XPL_BUILD) += xor.o diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index f99507d86c6..4b1b80d7abe 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -260,7 +260,7 @@ int zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size) int err; u32 ret_payload[PAYLOAD_ARG_CNT];
- if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) printf("Loading new PMUFW cfg obj (%ld bytes)\n", size);
flush_dcache_range((ulong)cfg_obj, (ulong)(cfg_obj + size)); @@ -282,7 +282,7 @@ int zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size) if (ret_payload[0]) printf("PMUFW returned 0x%08x status!\n", ret_payload[0]);
- if ((err || ret_payload[0]) && IS_ENABLED(CONFIG_SPL_BUILD)) + if ((err || ret_payload[0]) && IS_ENABLED(CONFIG_XPL_BUILD)) panic("PMUFW config object loading failed in EL3\n");
return 0; @@ -354,7 +354,7 @@ int __maybe_unused xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, debug("%s at EL%d, API ID: 0x%0x, 0x%0x, 0x%0x, 0x%0x, 0x%0x\n", __func__, current_el(), api_id, arg0, arg1, arg2, arg3);
- if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (IS_ENABLED(CONFIG_XPL_BUILD) || current_el() == 3) { #if defined(CONFIG_ZYNQMP_IPI) /* * Use fixed payload and arg size as the EL2 call. The firmware @@ -416,10 +416,10 @@ static int zynqmp_firmware_bind(struct udevice *dev) int ret; struct udevice *child;
- if ((IS_ENABLED(CONFIG_SPL_BUILD) && + if ((IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_SPL_POWER_DOMAIN) && IS_ENABLED(CONFIG_ZYNQMP_POWER_DOMAIN)) || - (!IS_ENABLED(CONFIG_SPL_BUILD) && + (!IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_ZYNQMP_POWER_DOMAIN))) { ret = device_bind_driver_to_node(dev, "zynqmp_power_domain", "zynqmp_power_domain", diff --git a/drivers/fpga/intel_sdm_mb.c b/drivers/fpga/intel_sdm_mb.c index 45caef4f5c1..5a65bd98779 100644 --- a/drivers/fpga/intel_sdm_mb.c +++ b/drivers/fpga/intel_sdm_mb.c @@ -17,7 +17,7 @@ #define RECONFIG_STATUS_POLL_RESP_TIMEOUT_MS 60000 #define RECONFIG_STATUS_INTERVAL_DELAY_US 1000000
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_ATF)
#define BITSTREAM_CHUNK_SIZE 0xFFFF0 #define RECONFIG_STATUS_POLL_RETRY_MAX 100 diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index 57467b4d975..3e86d854a01 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -414,13 +414,13 @@ static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize, if (bstype != BIT_PARTIAL) zynq_slcr_devcfg_enable();
- if (!IS_ENABLED(CONFIG_SPL_BUILD)) + if (!IS_ENABLED(CONFIG_XPL_BUILD)) puts("INFO:post config was not run, please run manually if needed\n");
return FPGA_SUCCESS; }
-#if defined(CONFIG_CMD_FPGA_LOADFS) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_FPGA_LOADFS) && !defined(CONFIG_XPL_BUILD) static int zynq_loadfs(xilinx_desc *desc, const void *buf, size_t bsize, fpga_fs_info *fsinfo) { @@ -504,7 +504,7 @@ static int zynq_loadfs(xilinx_desc *desc, const void *buf, size_t bsize,
struct xilinx_fpga_op zynq_op = { .load = zynq_load, -#if defined(CONFIG_CMD_FPGA_LOADFS) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_FPGA_LOADFS) && !defined(CONFIG_XPL_BUILD) .loadfs = zynq_loadfs, #endif }; diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index da0faf05246..990a670dd7b 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -3,7 +3,7 @@ # Copyright 2000-2008 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_DWAPB_GPIO) += dwapb_gpio.o obj-$(CONFIG_AXP_GPIO) += axp_gpio.o obj-$(CONFIG_DM_74X164) += 74x164_gpio.o diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 92ce68dd4a1..0213271e3a6 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -412,7 +412,7 @@ int dm_gpio_request(struct gpio_desc *desc, const char *label)
static int dm_gpio_requestf(struct gpio_desc *desc, const char *fmt, ...) { -#if !defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(USE_TINY_PRINTF) +#if !defined(CONFIG_XPL_BUILD) || !CONFIG_IS_ENABLED(USE_TINY_PRINTF) va_list args; char buf[40];
@@ -461,7 +461,7 @@ int gpio_request(unsigned gpio, const char *label) */ int gpio_requestf(unsigned gpio, const char *fmt, ...) { -#if !defined(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(USE_TINY_PRINTF) +#if !defined(CONFIG_XPL_BUILD) || !CONFIG_IS_ENABLED(USE_TINY_PRINTF) va_list args; char buf[40];
diff --git a/drivers/gpio/pca953x.c b/drivers/gpio/pca953x.c index fc4dcf9f986..2fb14590c0f 100644 --- a/drivers/gpio/pca953x.c +++ b/drivers/gpio/pca953x.c @@ -143,7 +143,7 @@ int pca953x_get_val(uint8_t chip) return (int)val; }
-#if defined(CONFIG_CMD_PCA953X) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_PCA953X) && !defined(CONFIG_XPL_BUILD) /* * Display pca953x information */ diff --git a/drivers/gpio/rk_gpio.c b/drivers/gpio/rk_gpio.c index 24ba12dd820..57c49c75939 100644 --- a/drivers/gpio/rk_gpio.c +++ b/drivers/gpio/rk_gpio.c @@ -126,7 +126,7 @@ static int rockchip_gpio_get_function(struct udevice *dev, unsigned offset) }
/* Simple SPL interface to GPIOs */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD
enum { PULL_NONE_1V8 = 0, @@ -169,7 +169,7 @@ int spl_gpio_output(void *vregs, uint gpio, int value)
return 0; } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
static int rockchip_gpio_probe(struct udevice *dev) { diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 83e65aa4aec..53dbbe97b5a 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -92,7 +92,7 @@ static void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) writel(value, &bank->dat); }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* Common GPIO API - SPL does not support driver model yet */ int gpio_set_value(unsigned gpio, int value) { @@ -118,7 +118,7 @@ static unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio) value = readl(&bank->dat); return !!(value & DAT_MASK(gpio)); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
static void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) { @@ -185,7 +185,7 @@ int s5p_gpio_get_pin(unsigned gpio) }
/* Driver model interface */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* set GPIO pin 'gpio' as an input */ static int exynos_gpio_direction_input(struct udevice *dev, unsigned offset) { @@ -230,7 +230,7 @@ static int exynos_gpio_set_value(struct udevice *dev, unsigned offset,
return 0; } -#endif /* nCONFIG_SPL_BUILD */ +#endif /* nCONFIG_XPL_BUILD */
/* * There is no common GPIO API for pull, drv, pin, rate (yet). These @@ -260,7 +260,7 @@ void gpio_set_rate(int gpio, int mode) s5p_gpio_get_pin(gpio), mode); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int exynos_gpio_get_function(struct udevice *dev, unsigned offset) { struct exynos_bank_info *state = dev_get_priv(dev); diff --git a/drivers/gpio/sunxi_gpio.c b/drivers/gpio/sunxi_gpio.c index 218ca2af397..2ca4960f17a 100644 --- a/drivers/gpio/sunxi_gpio.c +++ b/drivers/gpio/sunxi_gpio.c @@ -245,7 +245,7 @@ int sunxi_name_to_gpio(const char *name) { unsigned int gpio; int ret; -#if !defined CONFIG_SPL_BUILD && defined CONFIG_AXP_GPIO +#if !defined CONFIG_XPL_BUILD && defined CONFIG_AXP_GPIO char lookup[8];
if (strcasecmp(name, "AXP0-VBUS-ENABLE") == 0) { diff --git a/drivers/gpio/tca642x.c b/drivers/gpio/tca642x.c index 1d45b500746..8307a07e14e 100644 --- a/drivers/gpio/tca642x.c +++ b/drivers/gpio/tca642x.c @@ -164,7 +164,7 @@ int tca642x_set_inital_state(uchar chip, struct tca642x_bank_info init_data[]) return ret; }
-#if defined(CONFIG_CMD_TCA642X) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_TCA642X) && !defined(CONFIG_XPL_BUILD) /* * Display tca642x information */ diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index 0c40d36c41e..6cafffaad92 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -323,7 +323,7 @@ static int gpio_tegra_bind(struct udevice *parent) return 0;
/* TODO(sjg@chromium.org): Remove once SPL supports device tree */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD ctlr = (struct gpio_ctlr *)NV_PA_GPIO_BASE; bank_count = TEGRA_GPIO_BANKS; #else diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 71f315adf6f..3e855346bce 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -8,7 +8,7 @@ obj-$(CONFIG_$(SPL_TPL_)OF_CONTROL) += key_matrix.o obj-$(CONFIG_$(SPL_TPL_)DM_KEYBOARD) += input.o keyboard-uclass.o obj-$(CONFIG_BUTTON_KEYBOARD) += button_kbd.o
obj-$(CONFIG_APPLE_SPI_KEYB) += apple_spi_kbd.o obj-$(CONFIG_I8042_KEYB) += i8042.o diff --git a/drivers/mailbox/zynqmp-ipi.c b/drivers/mailbox/zynqmp-ipi.c index 4df69734ed9..713d93a200c 100644 --- a/drivers/mailbox/zynqmp-ipi.c +++ b/drivers/mailbox/zynqmp-ipi.c @@ -108,7 +108,7 @@ static int zynqmp_ipi_send(struct mbox_chan *chan, const void *data) writel(msg->buf[i], &mbx[i]);
/* Use SMC calls for Exception Level less than 3 where TF-A is available */ - if (!IS_ENABLED(CONFIG_SPL_BUILD) && current_el() < 3) { + if (!IS_ENABLED(CONFIG_XPL_BUILD) && current_el() < 3) { ret = zynqmp_ipi_fw_call(zynqmp, SMC_IPI_MAILBOX_NOTIFY, 0);
debug("%s, send %ld bytes\n", __func__, msg->len); @@ -148,7 +148,7 @@ static int zynqmp_ipi_recv(struct mbox_chan *chan, void *data) msg->buf[i] = readl(&mbx[i]);
/* Ack to remote if EL is not 3 */ - if (!IS_ENABLED(CONFIG_SPL_BUILD) && current_el() < 3) { + if (!IS_ENABLED(CONFIG_XPL_BUILD) && current_el() < 3) { ret = zynqmp_ipi_fw_call(zynqmp, SMC_IPI_MAILBOX_ACK, IPI_SMC_ACK_EIRQ_MASK); } @@ -168,7 +168,7 @@ static int zynqmp_ipi_dest_probe(struct udevice *dev)
node = dev_ofnode(dev);
- if (IS_ENABLED(CONFIG_SPL_BUILD) || of_machine_is_compatible("xlnx,zynqmp")) + if (IS_ENABLED(CONFIG_XPL_BUILD) || of_machine_is_compatible("xlnx,zynqmp")) zynqmp->el3_supported = true;
ret = dev_read_u32(dev->parent, "xlnx,ipi-id", &zynqmp->local_id); diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index e53d52c47b3..51ef51f1ed3 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -10,7 +10,7 @@ obj-$(CONFIG_$(SPL_TPL_)CROS_EC) += cros_ec.o obj-$(CONFIG_$(SPL_TPL_)CROS_EC_SANDBOX) += cros_ec_sandbox.o obj-$(CONFIG_$(SPL_TPL_)CROS_EC_LPC) += cros_ec_lpc.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_SANDBOX) += sandbox_adder.o obj-$(CONFIG_CROS_EC_I2C) += cros_ec_i2c.o obj-$(CONFIG_CROS_EC_SPI) += cros_ec_spi.o @@ -19,13 +19,13 @@ obj-$(CONFIG_SANDBOX) += swap_case.o endif
ifdef CONFIG_$(SPL_)DM_I2C -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_SANDBOX) += i2c_eeprom_emul.o obj-$(CONFIG_USB_HUB_USB251XB) += usb251xb.o endif endif ifdef CONFIG_SPL_OF_PLATDATA -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SANDBOX) += spltest_sandbox.o endif endif diff --git a/drivers/misc/gsc.c b/drivers/misc/gsc.c index feb02f97065..dee0bdd9663 100644 --- a/drivers/misc/gsc.c +++ b/drivers/misc/gsc.c @@ -389,7 +389,7 @@ static int gsc_probe(struct udevice *dev) if (priv->rtc) dev_set_priv(priv->rtc, priv);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD gsc_banner(dev); #endif
diff --git a/drivers/misc/imx8/scu.c b/drivers/misc/imx8/scu.c index bbd7e24200b..5d3db0bc4df 100644 --- a/drivers/misc/imx8/scu.c +++ b/drivers/misc/imx8/scu.c @@ -191,7 +191,7 @@ static int imx8_scu_probe(struct udevice *dev) if (addr == FDT_ADDR_T_NONE) return -EINVAL;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD plat->base = (struct mu_type *)CONFIG_MU_BASE_SPL; #else plat->base = (struct mu_type *)addr; diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 235c477c2e0..952201923d8 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -20,7 +20,7 @@ endif
obj-$(CONFIG_SUPPORT_EMMC_BOOT) += mmc_boot.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o endif
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index 83cdc9fd66d..c8db4f811c2 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -301,7 +301,7 @@ struct mmc *find_mmc_device(int dev_num) ret = blk_find_device(UCLASS_MMC, dev_num, &dev);
if (ret) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) printf("MMC Device %d not found\n", dev_num); #endif return NULL; @@ -373,7 +373,7 @@ void mmc_do_preinit(void) } }
-#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) void print_mmc_devices(char separator) { struct udevice *dev; diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 96b0e20d669..55d24451e6e 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -328,7 +328,7 @@ int mmc_poll_for_busy(struct mmc *mmc, int timeout_ms) break;
if (status & MMC_STATUS_MASK) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) log_err("Status Error: %#08x\n", status); #endif return -ECOMM; @@ -341,7 +341,7 @@ int mmc_poll_for_busy(struct mmc *mmc, int timeout_ms) }
if (timeout_ms <= 0) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) log_err("Timeout waiting card ready\n"); #endif return -ETIMEDOUT; @@ -483,7 +483,7 @@ static int mmc_read_blocks(struct mmc *mmc, void *dst, lbaint_t start,
if (blkcnt > 1) { if (mmc_send_stop_transmission(mmc, false)) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) log_err("mmc fail to send stop cmd\n"); #endif return 0; @@ -534,7 +534,7 @@ ulong mmc_bread(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt, return 0;
if ((start + blkcnt) > block_dev->lba) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) log_err("MMC: block number 0x" LBAF " exceeds max(0x" LBAF ")\n", start + blkcnt, block_dev->lba); #endif @@ -2424,7 +2424,7 @@ static int mmc_startup_v4(struct mmc *mmc) mmc->capacity_gp[i] <<= 19; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD if (part_completed) { mmc->enh_user_size = (ext_csd[EXT_CSD_ENH_SIZE_MULT + 2] << 16) + @@ -2723,7 +2723,7 @@ static int mmc_startup(struct mmc *mmc) bdesc->blksz = mmc->read_bl_len; bdesc->log2blksz = LOG2(bdesc->blksz); bdesc->lba = lldiv(mmc->capacity, mmc->read_bl_len); -#if !defined(CONFIG_SPL_BUILD) || \ +#if !defined(CONFIG_XPL_BUILD) || \ (defined(CONFIG_SPL_LIBCOMMON_SUPPORT) && \ !CONFIG_IS_ENABLED(USE_TINY_PRINTF)) sprintf(bdesc->vendor, "Man %06x Snr %04x%04x", @@ -2741,7 +2741,7 @@ static int mmc_startup(struct mmc *mmc) bdesc->revision[0] = 0; #endif
-#if !defined(CONFIG_DM_MMC) && (!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBDISK_SUPPORT)) +#if !defined(CONFIG_DM_MMC) && (!defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBDISK_SUPPORT)) part_init(bdesc); #endif
@@ -2953,7 +2953,7 @@ retry: err = mmc_send_op_cond(mmc);
if (err) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) if (!quiet) log_err("Card did not respond to voltage select! : %d\n", err); @@ -3008,7 +3008,7 @@ int mmc_start_init(struct mmc *mmc) #endif if (no_card) { mmc->has_init = 0; -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) log_err("MMC: no card present\n"); #endif return -ENOMEDIUM; @@ -3195,7 +3195,7 @@ int mmc_initialize(struct bd_info *bis) if (ret) return ret;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD print_mmc_devices(','); #endif
diff --git a/drivers/mmc/mmc_legacy.c b/drivers/mmc/mmc_legacy.c index a87d2276c1b..8f8ba34be71 100644 --- a/drivers/mmc/mmc_legacy.c +++ b/drivers/mmc/mmc_legacy.c @@ -44,7 +44,7 @@ struct mmc *find_mmc_device(int dev_num) return m; }
@@ -93,7 +93,7 @@ void mmc_list_add(struct mmc *mmc) list_add_tail(&mmc->link, &mmc_devices); }
-#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) void print_mmc_devices(char separator) { struct mmc *m; diff --git a/drivers/mmc/mmc_private.h b/drivers/mmc/mmc_private.h index b32123758ea..fc45f017e5d 100644 --- a/drivers/mmc/mmc_private.h +++ b/drivers/mmc/mmc_private.h @@ -67,7 +67,7 @@ static inline ulong mmc_bwrite(struct blk_desc *block_dev, lbaint_t start, } #endif
#ifdef CONFIG_MMC_TRACE void mmmc_trace_before_send(struct mmc *mmc, struct mmc_cmd *cmd); diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 8e51453d2ae..e66ab25d02a 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -59,8 +59,8 @@ DECLARE_GLOBAL_DATA_PTR;
/* simplify defines to OMAP_HSMMC_USE_GPIO */ -#if (defined(CONFIG_OMAP_GPIO) && !defined(CONFIG_SPL_BUILD)) || \ - (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_GPIO)) +#if (defined(CONFIG_OMAP_GPIO) && !defined(CONFIG_XPL_BUILD)) || \ + (defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_GPIO)) #define OMAP_HSMMC_USE_GPIO #else #undef OMAP_HSMMC_USE_GPIO diff --git a/drivers/mmc/rockchip_dw_mmc.c b/drivers/mmc/rockchip_dw_mmc.c index fb77b049834..ca5752d24f1 100644 --- a/drivers/mmc/rockchip_dw_mmc.c +++ b/drivers/mmc/rockchip_dw_mmc.c @@ -83,7 +83,7 @@ static int rockchip_dwmmc_of_to_plat(struct udevice *dev) return -EINVAL; priv->fifo_mode = dev_read_bool(dev, "fifo-mode");
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD if (!priv->fifo_mode) priv->fifo_mode = dev_read_bool(dev, "u-boot,spl-fifo-mode"); #endif diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 35667b86b50..a25bcaf017f 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -609,7 +609,7 @@ static int rockchip_sdhci_probe(struct udevice *dev) * Disable use of DMA and force use of PIO mode in SPL to fix an issue * where loading part of TF-A into SRAM using DMA silently fails. */ - if (IS_ENABLED(CONFIG_SPL_BUILD) && + if (IS_ENABLED(CONFIG_XPL_BUILD) && dev_read_bool(dev, "u-boot,spl-fifo-mode")) host->flags &= ~USE_DMA;
diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index 3147d3019c0..9dc1ceaa09b 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -61,7 +61,7 @@ static int socfpga_dwmci_clksel(struct dwmci_host *host) debug("%s: drvsel %d smplsel %d\n", __func__, priv->drvsel, priv->smplsel);
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_ATF) int ret;
ret = socfpga_secure_reg_write32(SOCFPGA_SECURE_REG_SYSMGR_SOC64_SDMMC, diff --git a/drivers/mmc/tmio-common.c b/drivers/mmc/tmio-common.c index 0b396122b46..9fff1bc1a10 100644 --- a/drivers/mmc/tmio-common.c +++ b/drivers/mmc/tmio-common.c @@ -385,7 +385,7 @@ static bool tmio_sd_addr_is_dmaable(struct mmc_data *data) return false; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD if (IS_ENABLED(CONFIG_ARCH_UNIPHIER) && !IS_ENABLED(CONFIG_ARM64)) { /* * For UniPhier ARMv7 SoCs, the stack is allocated in locked diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index 5b3650d52ee..cc89ff767ab 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -36,7 +36,7 @@ static ulong uniphier_sd_clk_get_rate(struct tmio_sd_priv *priv) { #if CONFIG_IS_ENABLED(CLK) return clk_get_rate(&priv->clk); -#elif CONFIG_SPL_BUILD +#elif CONFIG_XPL_BUILD return 100000000; #else return 0; @@ -50,7 +50,7 @@ static int uniphier_sd_probe(struct udevice *dev) priv->clk_get_rate = uniphier_sd_clk_get_rate; priv->read_poll_flag = TMIO_SD_DMA_INFO1_END_RD2;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int ret;
ret = clk_get_by_index(dev, 0, &priv->clk); diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 24d0556cd37..0e2bdab4e7e 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -289,7 +289,7 @@ static inline int arasan_zynqmp_set_in_tapdelay(u32 node_id, u32 itap_delay) { int ret;
- if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (IS_ENABLED(CONFIG_XPL_BUILD) || current_el() == 3) { if (node_id == NODE_SD_0) { ret = zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN, SD0_ITAPCHGWIN); @@ -339,7 +339,7 @@ static inline int arasan_zynqmp_set_in_tapdelay(u32 node_id, u32 itap_delay)
static inline int arasan_zynqmp_set_out_tapdelay(u32 node_id, u32 otap_delay) { - if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (IS_ENABLED(CONFIG_XPL_BUILD) || current_el() == 3) { if (node_id == NODE_SD_0) return zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, @@ -356,7 +356,7 @@ static inline int arasan_zynqmp_set_out_tapdelay(u32 node_id, u32 otap_delay)
static inline int zynqmp_dll_reset(u32 node_id, u32 type) { - if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3) { + if (IS_ENABLED(CONFIG_XPL_BUILD) || current_el() == 3) { if (node_id == NODE_SD_0) return zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST, type == PM_DLL_RESET_ASSERT ? diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 10d575e9f93..db010417b86 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -16,7 +16,7 @@ mtd-$(CONFIG_RENESAS_RPC_HF) += renesas_rpc_hf.o mtd-$(CONFIG_HBMC_AM654) += hbmc-am654.o
# U-Boot build -ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),)
ifneq ($(mtd-y),) obj-y += mtd.o diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 96e186600a1..68b53dced1b 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),) nandcore-objs := core.o bbt.o obj-$(CONFIG_MTD_NAND_CORE) += nandcore.o obj-$(CONFIG_MTD_RAW_NAND) += raw/ diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index 46fead6fa48..ca10ac7aecb 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
ifdef CONFIG_SPL_NAND_DRIVERS NORMAL_DRIVERS=y diff --git a/drivers/mtd/nand/raw/atmel_nand.c b/drivers/mtd/nand/raw/atmel_nand.c index 4dbf7b47135..605298628d6 100644 --- a/drivers/mtd/nand/raw/atmel_nand.c +++ b/drivers/mtd/nand/raw/atmel_nand.c @@ -1251,7 +1251,7 @@ static int at91_nand_ready(struct mtd_info *mtd) } #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* The following code is for SPL */ static struct mtd_info *mtd; static struct nand_chip nand_chip; @@ -1526,4 +1526,4 @@ void board_nand_init(void) if (atmel_nand_chip_init(i, base_addr[i])) log_err("atmel_nand: Fail to initialize #%d chip", i); } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c b/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c index c89661badbf..4430c4e93ee 100644 --- a/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c +++ b/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c @@ -152,7 +152,7 @@ static void lpc32xx_nand_init(void) &lpc32xx_nand_mlc_registers->time_reg); }
/** * lpc32xx_cmd_ctrl - write command to either cmd or data register @@ -606,7 +606,7 @@ void board_nand_init(void) pr_err("nand_register returned %i", ret); }
-#else /* defined(CONFIG_SPL_BUILD) */ +#else /* defined(CONFIG_XPL_BUILD) */
void nand_init(void) { @@ -770,4 +770,4 @@ unsigned int nand_page_size(void) return BYTES_PER_PAGE; }
-#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */ diff --git a/drivers/mtd/nand/raw/lpc32xx_nand_slc.c b/drivers/mtd/nand/raw/lpc32xx_nand_slc.c index 4d643bc64bc..109c31fb4d1 100644 --- a/drivers/mtd/nand/raw/lpc32xx_nand_slc.c +++ b/drivers/mtd/nand/raw/lpc32xx_nand_slc.c @@ -84,7 +84,7 @@ static struct nand_ecclayout lpc32xx_nand_oob_16 = { } };
-#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_XPL_BUILD) #define ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / CFG_SYS_NAND_ECCSIZE)
/* @@ -162,7 +162,7 @@ static int lpc32xx_nand_dev_ready(struct mtd_info *mtd) return readl(&lpc32xx_nand_slc_regs->stat) & STAT_NAND_READY; }
-#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_XPL_BUILD) /* * Prepares DMA descriptors for NAND RD/WR operations * If the size is < 256 Bytes then it is assumed to be @@ -510,7 +510,7 @@ static void lpc32xx_write_byte(struct mtd_info *mtd, uint8_t byte) */ int board_nand_init(struct nand_chip *lpc32xx_chip) { -#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_XPL_BUILD) int ret;
/* Acquire a channel for our use */ @@ -533,7 +533,7 @@ int board_nand_init(struct nand_chip *lpc32xx_chip) lpc32xx_chip->read_byte = lpc32xx_read_byte; lpc32xx_chip->write_byte = lpc32xx_write_byte;
-#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_DMA_LPC32XX) && !defined(CONFIG_XPL_BUILD) /* Hardware ECC calculation is supported when DMA driver is selected */ lpc32xx_chip->ecc.mode = NAND_ECC_HW;
diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 0545c23e268..1b65c6f6443 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -414,7 +414,7 @@ static int nand_block_markbad_lowlevel(struct mtd_info *mtd, loff_t ofs) { struct nand_chip *chip = mtd_to_nand(mtd); int ret = 0; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int res; #endif
@@ -434,7 +434,7 @@ static int nand_block_markbad_lowlevel(struct mtd_info *mtd, loff_t ofs) nand_release_device(mtd); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* Mark block bad in BBT */ if (chip->bbt) { res = nand_markbad_bbt(mtd, ofs); @@ -488,7 +488,7 @@ static int nand_block_isreserved(struct mtd_info *mtd, loff_t ofs) if (!chip->bbt) return 0; /* Return info from the table */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD return nand_isreserved_bbt(mtd, ofs); #else return 0; @@ -518,7 +518,7 @@ static int nand_block_checkbad(struct mtd_info *mtd, loff_t ofs, int allowbbt) return chip->block_bad(mtd, ofs);
/* Return info from the table */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD return nand_isbad_bbt(mtd, ofs, allowbbt); #else return 0; @@ -3729,7 +3729,7 @@ static void nand_set_defaults(struct nand_chip *chip, int busw) if (!chip->read_buf || chip->read_buf == nand_read_buf) chip->read_buf = busw ? nand_read_buf16 : nand_read_buf;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD if (!chip->scan_bbt) chip->scan_bbt = nand_default_bbt; #endif diff --git a/drivers/mtd/nand/raw/omap_gpmc.c b/drivers/mtd/nand/raw/omap_gpmc.c index a36e2a148cc..9c704c60e8e 100644 --- a/drivers/mtd/nand/raw/omap_gpmc.c +++ b/drivers/mtd/nand/raw/omap_gpmc.c @@ -1011,7 +1011,7 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, return 0; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* * omap_nand_switch_ecc - switch the ECC operation between different engines * (h/w and s/w) and different algorithms (hamming and BCHx) @@ -1072,7 +1072,7 @@ int __maybe_unused omap_nand_switch_ecc(uint32_t hardware, uint32_t eccstrength) err = nand_scan_tail(mtd); return err; } -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* * Board-specific NAND initialization. The following members of the diff --git a/drivers/mtd/nand/raw/sand_nand.c b/drivers/mtd/nand/raw/sand_nand.c index 229d7b5b65a..53489223030 100644 --- a/drivers/mtd/nand/raw/sand_nand.c +++ b/drivers/mtd/nand/raw/sand_nand.c @@ -680,7 +680,7 @@ void board_nand_init(void) log_info("Failed to get sandbox NAND: %d\n", err); }
-#if IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_SPL_NAND_INIT) +#if IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_SPL_NAND_INIT) void nand_deselect(void) { nand_chip->select_chip(nand_to_mtd(nand_chip), -1); diff --git a/drivers/mtd/onenand/Makefile b/drivers/mtd/onenand/Makefile index 4dc417a5794..7f4a8514c17 100644 --- a/drivers/mtd/onenand/Makefile +++ b/drivers/mtd/onenand/Makefile @@ -3,7 +3,7 @@ # Copyright (C) 2005-2007 Samsung Electronics. # Kyungmin Park kyungmin.park@samsung.com
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_ONENAND) := onenand_uboot.o onenand_base.o onenand_bbt.o obj-$(CONFIG_SAMSUNG_ONENAND) += samsung.o else diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 409395382f5..2a287a62a47 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -6,7 +6,7 @@ obj-$(CONFIG_$(SPL_TPL_)DM_SPI_FLASH) += sf-uclass.o spi-nor-y := sf_probe.o spi-nor-ids.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o ifeq ($(CONFIG_$(SPL_TPL_)SPI_FLASH_TINY),y) spi-nor-y += spi-nor-tiny.o diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index a4d15bd64aa..102a9236826 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -54,7 +54,7 @@ struct spi_flash *spi_flash_probe(unsigned int busnum, unsigned int cs, struct udevice *bus; char *str;
-#if defined(CONFIG_SPL_BUILD) && CONFIG_IS_ENABLED(USE_TINY_PRINTF) +#if defined(CONFIG_XPL_BUILD) && CONFIG_IS_ENABLED(USE_TINY_PRINTF) str = "spi_flash"; #else char name[30]; diff --git a/drivers/mtd/spi/sf_dataflash.c b/drivers/mtd/spi/sf_dataflash.c index 6db24189c8e..438eb3698d5 100644 --- a/drivers/mtd/spi/sf_dataflash.c +++ b/drivers/mtd/spi/sf_dataflash.c @@ -438,7 +438,7 @@ static int add_dataflash(struct udevice *dev, char *name, int nr_pages, spi_flash->size = nr_pages * pagesize; spi_flash->erase_size = pagesize;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD printf("SPI DataFlash: Detected %s with page size ", spi_flash->name); print_size(spi_flash->page_size, ", erase size "); print_size(spi_flash->erase_size, ", total "); diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 8f7a77e7169..b29b390a0ae 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -1030,7 +1030,7 @@ static int spi_nor_erase(struct mtd_info *mtd, struct erase_info *instr)
while (len) { schedule(); - if (!IS_ENABLED(CONFIG_SPL_BUILD) && ctrlc()) { + if (!IS_ENABLED(CONFIG_XPL_BUILD) && ctrlc()) { addr_known = false; ret = -EINTR; goto erase_err; @@ -4262,7 +4262,7 @@ int spi_nor_scan(struct spi_nor *nor) nor->erase_size = mtd->erasesize; nor->sector_size = mtd->erasesize;
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD printf("SF: Detected %s with page size ", nor->name); print_size(nor->page_size, ", erase size "); print_size(nor->erase_size, ", total "); diff --git a/drivers/net/dwc_eth_xgmac_socfpga.c b/drivers/net/dwc_eth_xgmac_socfpga.c index 270c1b0ca6c..87fb7e887e7 100644 --- a/drivers/net/dwc_eth_xgmac_socfpga.c +++ b/drivers/net/dwc_eth_xgmac_socfpga.c @@ -37,7 +37,7 @@ static int dwxgmac_socfpga_do_setphy(struct udevice *dev, u32 modereg) u32 modemask = SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << xgmac->syscon_phy_regshift;
- if (!(IS_ENABLED(CONFIG_SPL_BUILD)) && IS_ENABLED(CONFIG_SPL_ATF)) { + if (!(IS_ENABLED(CONFIG_XPL_BUILD)) && IS_ENABLED(CONFIG_SPL_ATF)) { u32 index = ((u64)xgmac->syscon_phy - socfpga_get_sysmgr_addr() - SYSMGR_SOC64_EMAC0) >> 2;
diff --git a/drivers/net/dwmac_socfpga.c b/drivers/net/dwmac_socfpga.c index bba3fc4d34b..a9e2d8c0972 100644 --- a/drivers/net/dwmac_socfpga.c +++ b/drivers/net/dwmac_socfpga.c @@ -68,7 +68,7 @@ static int dwmac_socfpga_do_setphy(struct udevice *dev, u32 modereg) struct dwmac_socfpga_plat *pdata = dev_get_plat(dev); u32 modemask = SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << pdata->reg_shift;
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_ATF) u32 index = ((u64)pdata->phy_intf - socfpga_get_sysmgr_addr() - SYSMGR_SOC64_EMAC0) >> 2;
diff --git a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c index ede3959c94f..2c373c7c12e 100644 --- a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c +++ b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c @@ -671,7 +671,7 @@ const struct pinctrl_ops mtk_pinctrl_ops = { };
#if CONFIG_IS_ENABLED(DM_GPIO) || \ - (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_GPIO)) + (defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_GPIO)) static int mtk_gpio_get(struct udevice *dev, unsigned int off) { int val, err; @@ -814,7 +814,7 @@ int mtk_pinctrl_common_probe(struct udevice *dev, }
#if CONFIG_IS_ENABLED(DM_GPIO) || \ - (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_GPIO)) + (defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_GPIO)) ret = mtk_gpiochip_register(dev); #endif
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index eada1001240..fbf0271f08a 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -39,7 +39,7 @@ struct stm32_gpio_bank { struct list_head list; };
static char pin_name[PINNAME_SIZE]; static const char * const pinmux_mode[GPIOF_COUNT] = { @@ -488,7 +488,7 @@ static struct pinctrl_ops stm32_pinctrl_ops = { #else /* PINCTRL_FULL */ .set_state_simple = stm32_pinctrl_set_state_simple, #endif /* PINCTRL_FULL */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD .get_pin_name = stm32_pinctrl_get_pin_name, .get_pins_count = stm32_pinctrl_get_pins_count, .get_pin_muxing = stm32_pinctrl_get_pin_muxing, diff --git a/drivers/pinctrl/tegra/Makefile b/drivers/pinctrl/tegra/Makefile index 75d3cabc62b..b1dda417475 100644 --- a/drivers/pinctrl/tegra/Makefile +++ b/drivers/pinctrl/tegra/Makefile @@ -1,5 +1,5 @@ # SPDX-License-Identifier: GPL-2.0 -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD ifdef CONFIG_TEGRA20 obj-y += pinctrl-tegra20.o else diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier.h b/drivers/pinctrl/uniphier/pinctrl-uniphier.h index 5951835d6e8..da7bb4f6377 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier.h +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier.h @@ -126,7 +126,7 @@ struct uniphier_pinctrl_socdata {
#define __UNIPHIER_PINMUX_FUNCTION(func) #func
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* * a tricky way to drop unneeded *_pins and *_muxvals arrays from SPL, * suppressing "defined but not used" warnings. diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 6f7e6fb0a6b..5a987194cda 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -9,7 +9,7 @@ obj-y += pmic/ obj-y += regulator/
obj-$(CONFIG_AXP221_POWER) += axp221.o -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_AXP152_POWER) += axp152.o obj-$(CONFIG_AXP209_POWER) += axp209.o obj-$(CONFIG_AXP305_POWER) += axp_spl.o diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index 4d5a5ceafad..a14555cf472 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -237,7 +237,7 @@ static int rk8xx_bind(struct udevice *dev) if (!children) debug("%s: %s - no child found\n", __func__, dev->name);
- if (IS_ENABLED(CONFIG_SPL_BUILD) && + if (IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_ROCKCHIP_RK8XX_DISABLE_BOOT_ON_POWERON)) dev_or_flags(dev, DM_FLAG_PROBE_AFTER_BIND);
@@ -331,7 +331,7 @@ static int rk8xx_probe(struct udevice *dev) pmic_reg_read(dev, init_data[i].reg)); }
- if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD)) { printf("PMIC: RK%x ", show_variant); if (on_source && off_source) printf("(on=0x%02x, off=0x%02x)", diff --git a/drivers/power/pmic/stpmic1.c b/drivers/power/pmic/stpmic1.c index c99a0c27b33..f0415fbd172 100644 --- a/drivers/power/pmic/stpmic1.c +++ b/drivers/power/pmic/stpmic1.c @@ -91,7 +91,7 @@ static int stpmic1_bind(struct udevice *dev) dev_dbg(dev, "no child found\n"); #endif /* DM_REGULATOR */
- if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD)) { ret = device_bind_driver(dev, "stpmic1-nvm", "stpmic1-nvm", NULL); if (ret) @@ -124,7 +124,7 @@ U_BOOT_DRIVER(pmic_stpmic1) = { .ops = &stpmic1_ops, };
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int stpmic1_nvm_rw(struct udevice *dev, u8 addr, u8 *buf, int buf_len, enum pmic_nvm_op op) { @@ -230,7 +230,7 @@ U_BOOT_DRIVER(stpmic1_nvm) = { .id = UCLASS_MISC, .ops = &stpmic1_nvm_ops, }; -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#ifdef CONFIG_SYSRESET static int stpmic1_sysreset_request(struct udevice *dev, enum sysreset_t type) diff --git a/drivers/power/power_core.c b/drivers/power/power_core.c index 1caf9f09346..61b2fe5f54a 100644 --- a/drivers/power/power_core.c +++ b/drivers/power/power_core.c @@ -78,7 +78,7 @@ struct pmic *pmic_get(const char *s) return NULL; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD static int pmic_dump(struct pmic *p) { int i, ret; diff --git a/drivers/power/regulator/rk8xx.c b/drivers/power/regulator/rk8xx.c index 34e61511d88..3f18ee65ce0 100644 --- a/drivers/power/regulator/rk8xx.c +++ b/drivers/power/regulator/rk8xx.c @@ -16,7 +16,7 @@ #include <power/pmic.h> #include <power/regulator.h>
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define ENABLE_DRIVER #endif
diff --git a/drivers/power/sy8106a.c b/drivers/power/sy8106a.c index fb6028de71a..d9a2b6904b0 100644 --- a/drivers/power/sy8106a.c +++ b/drivers/power/sy8106a.c @@ -10,7 +10,7 @@ #define SY8106A_VOUT1_SEL 1 #define SY8106A_VOUT1_SEL_ENABLE (1 << 7)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static u8 sy8106a_mvolt_to_cfg(int mvolt, int min, int max, int div) { if (mvolt < min) diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index fdb2e78ec9e..35d8f5761e1 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -20,7 +20,7 @@ obj-$(CONFIG_K3_DDRSS) += k3-ddrss/ obj-$(CONFIG_IMXRT_SDRAM) += imxrt_sdram.o
obj-$(CONFIG_RAM_SIFIVE) += sifive/ -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_STARFIVE_DDR) += starfive/ endif
diff --git a/drivers/ram/mediatek/ddr3-mt7629.c b/drivers/ram/mediatek/ddr3-mt7629.c index c27c4593b9d..e9791697066 100644 --- a/drivers/ram/mediatek/ddr3-mt7629.c +++ b/drivers/ram/mediatek/ddr3-mt7629.c @@ -233,7 +233,7 @@ struct mtk_ddr3_priv { struct clk mem_mux; };
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static int mtk_ddr3_rank_size_detect(struct udevice *dev) { struct mtk_ddr3_priv *priv = dev_get_priv(dev); @@ -697,7 +697,7 @@ static int mtk_ddr3_probe(struct udevice *dev) if (priv->dramc_ao == FDT_ADDR_T_NONE) return -EINVAL;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD int ret;
ret = clk_get_by_index(dev, 0, &priv->phy); diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 618bce5c9f4..ffff7d55f33 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -84,7 +84,7 @@ const int ddrconf_table[] = { #define DQS_GATE_TRAINING_ERROR_RANK0 (1 << 4) #define DQS_GATE_TRAINING_ERROR_RANK1 (2 << 4)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static void copy_to_reg(u32 *dest, const u32 *src, u32 n) { int i; @@ -851,7 +851,7 @@ static int rk3188_dmc_of_to_plat(struct udevice *dev)
#if CONFIG_IS_ENABLED(OF_PLATDATA) static int conv_of_plat(struct udevice *dev) @@ -878,7 +878,7 @@ static int conv_of_plat(struct udevice *dev)
static int rk3188_dmc_probe(struct udevice *dev) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD struct rk3188_sdram_params *plat = dev_get_plat(dev); struct regmap *map; struct udevice *dev_clk; @@ -888,7 +888,7 @@ static int rk3188_dmc_probe(struct udevice *dev)
priv->pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #if CONFIG_IS_ENABLED(OF_PLATDATA) ret = conv_of_plat(dev); if (ret) @@ -950,12 +950,12 @@ U_BOOT_DRIVER(rockchip_rk3188_dmc) = { .id = UCLASS_RAM, .of_match = rk3188_dmc_ids, .ops = &rk3188_dmc_ops, -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD .of_to_plat = rk3188_dmc_of_to_plat, #endif .probe = rk3188_dmc_probe, .priv_auto = sizeof(struct dram_info), -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD .plat_auto = sizeof(struct rk3188_sdram_params), #endif }; diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index c9f61e933e9..25ceab98ee9 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -84,7 +84,7 @@ const int ddrconf_table[] = { #define DQS_GATE_TRAINING_ERROR_RANK1 (2 << 4)
#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) static void copy_to_reg(u32 *dest, const u32 *src, u32 n) { int i; @@ -1013,7 +1013,7 @@ static int rk3288_dmc_of_to_plat(struct udevice *dev)
#if CONFIG_IS_ENABLED(OF_PLATDATA) static int conv_of_plat(struct udevice *dev) @@ -1041,7 +1041,7 @@ static int conv_of_plat(struct udevice *dev) static int rk3288_dmc_probe(struct udevice *dev) { #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) struct rk3288_sdram_params *plat = dev_get_plat(dev); struct udevice *dev_clk; struct regmap *map; @@ -1051,7 +1051,7 @@ static int rk3288_dmc_probe(struct udevice *dev)
priv->pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU); #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) #if CONFIG_IS_ENABLED(OF_PLATDATA) ret = conv_of_plat(dev); if (ret) @@ -1119,13 +1119,13 @@ U_BOOT_DRIVER(rockchip_rk3288_dmc) = { .of_match = rk3288_dmc_ids, .ops = &rk3288_dmc_ops, #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) .of_to_plat = rk3288_dmc_of_to_plat, #endif .probe = rk3288_dmc_probe, .priv_auto = sizeof(struct dram_info), #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) .plat_auto = sizeof(struct rk3288_sdram_params), #endif }; diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 45270e27184..c3745f9445b 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3196,7 +3196,7 @@ U_BOOT_DRIVER(dmc_rk3399) = { .probe = rk3399_dmc_probe, .priv_auto = sizeof(struct dram_info), #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) .plat_auto = sizeof(struct rockchip_dmc_plat), #endif }; diff --git a/drivers/ram/rockchip/sdram_rv1126.c b/drivers/ram/rockchip/sdram_rv1126.c index 4fbb088a8d9..b371f597d23 100644 --- a/drivers/ram/rockchip/sdram_rv1126.c +++ b/drivers/ram/rockchip/sdram_rv1126.c @@ -34,7 +34,7 @@
struct dram_info { #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) void __iomem *pctl; void __iomem *phy; struct rv1126_cru *cru; @@ -49,7 +49,7 @@ struct dram_info { };
#define GRF_BASE_ADDR 0xfe000000 #define PMU_GRF_BASE_ADDR 0xfe020000 @@ -3507,7 +3507,7 @@ error: static int rv1126_dmc_probe(struct udevice *dev) { #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) if (rv1126_dmc_init(dev)) return 0; #else diff --git a/drivers/ram/sifive/sifive_ddr.c b/drivers/ram/sifive/sifive_ddr.c index bd2f438d727..c555d2af2d0 100644 --- a/drivers/ram/sifive/sifive_ddr.c +++ b/drivers/ram/sifive/sifive_ddr.c @@ -91,7 +91,7 @@ struct sifive_ddr_info { u32 *physical_filter_ctrl; };
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) struct sifive_ddr_params { struct sifive_ddrctl pctl_regs; struct sifive_ddrphy phy_regs; @@ -337,7 +337,7 @@ static int sifive_ddr_probe(struct udevice *dev) priv->info.base = gd->ram_base; priv->info.size = gd->ram_size;
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) int ret; u32 clock = 0;
@@ -404,7 +404,7 @@ U_BOOT_DRIVER(sifive_ddr) = { .ops = &sifive_ddr_ops, .probe = sifive_ddr_probe, .priv_auto = sizeof(struct sifive_ddr_info), -#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) .plat_auto = sizeof(struct sifive_dmc_plat), #endif }; diff --git a/drivers/ram/starfive/Makefile b/drivers/ram/starfive/Makefile index 1df42c377bd..f1567b04b4c 100644 --- a/drivers/ram/starfive/Makefile +++ b/drivers/ram/starfive/Makefile @@ -2,10 +2,10 @@ # # Copyright (c) 2022 StarFive, Inc # -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrphy_start.o obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrphy_train.o obj-$(CONFIG_SPL_STARFIVE_DDR) += starfive_ddr.o obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrphy_utils.o obj-$(CONFIG_SPL_STARFIVE_DDR) += ddrcsr_boot.o -endif \ No newline at end of file +endif diff --git a/drivers/ram/stm32mp1/stm32mp1_ram.c b/drivers/ram/stm32mp1/stm32mp1_ram.c index debc458c0e2..e9cd6229ec4 100644 --- a/drivers/ram/stm32mp1/stm32mp1_ram.c +++ b/drivers/ram/stm32mp1/stm32mp1_ram.c @@ -371,7 +371,7 @@ static int stm32mp1_ddr_probe(struct udevice *dev)
priv->info.base = STM32_DDR_BASE;
- if (IS_ENABLED(CONFIG_SPL_BUILD)) { + if (IS_ENABLED(CONFIG_XPL_BUILD)) { priv->info.size = 0; ret = stm32mp1_ddr_setup(dev);
diff --git a/drivers/reset/reset-socfpga.c b/drivers/reset/reset-socfpga.c index 866437fd24f..76d108080d9 100644 --- a/drivers/reset/reset-socfpga.c +++ b/drivers/reset/reset-socfpga.c @@ -46,7 +46,7 @@ struct socfpga_reset_data { */ static bool socfpga_reset_keep_enabled(void) { -#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) +#if !defined(CONFIG_XPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) const char *env_str; long val;
diff --git a/drivers/scsi/Makefile b/drivers/scsi/Makefile index 628be4c89fb..7c19a435722 100644 --- a/drivers/scsi/Makefile +++ b/drivers/scsi/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_SCSI) += scsi.o scsi-uclass.o ifdef CONFIG_SCSI obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += scsi_bootdev.o @@ -12,7 +12,7 @@ obj-$(CONFIG_SANDBOX) += scsi_emul.o endif endif
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD ifdef CONFIG_SPL_SATA obj-$(CONFIG_SCSI) += scsi.o scsi-uclass.o endif diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 78810f98367..66bd30b837b 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -63,7 +63,7 @@ obj-$(CONFIG_XEN_SERIAL) += serial_xen.o obj-$(CONFIG_XTENSA_SEMIHOSTING_SERIAL) += serial_xtensa_semihosting.o obj-$(CONFIG_S5P4418_PL011_SERIAL) += serial_s5p4418_pl011.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o endif obj-$(CONFIG_UART4_SERIAL) += serial_adi_uart4.o diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index 7e45a80969e..0b35582aaa4 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -218,7 +218,7 @@ static const struct dm_serial_ops atmel_serial_ops = { .setbrg = atmel_serial_setbrg, };
-#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_SPL_CLK) +#if defined(CONFIG_XPL_BUILD) && !defined(CONFIG_SPL_CLK) static int atmel_serial_enable_clk(struct udevice *dev) { struct atmel_serial_priv *priv = dev_get_priv(dev); diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 6fcb5b523ac..248fe3f778f 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -227,7 +227,7 @@ static void ns16550_setbrg(struct ns16550 *com_port, int baud_divisor)
void ns16550_init(struct ns16550 *com_port, int baud_divisor) { -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_OMAP34XX) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_OMAP34XX) /* * On some OMAP3/OMAP4 devices when UART3 is configured for boot mode * before SPL starts only THRE bit is set. We have to empty the @@ -303,7 +303,7 @@ void ns16550_putc(struct ns16550 *com_port, char c) char ns16550_getc(struct ns16550 *com_port) { while ((serial_in(&com_port->lsr) & UART_LSR_DR) == 0) { -#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB_TTY) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_USB_TTY) extern void usbtty_poll(void); usbtty_poll(); #endif diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 84f02f7ac76..9feaa1eceec 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -101,7 +101,7 @@ static void serial_find_console_or_panic(void) } } } - if (!IS_ENABLED(CONFIG_SPL_BUILD) || !CONFIG_IS_ENABLED(OF_CONTROL) || + if (!IS_ENABLED(CONFIG_XPL_BUILD) || !CONFIG_IS_ENABLED(OF_CONTROL) || !blob) { /* * Try to use CONFIG_CONS_INDEX if available (it is numbered diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index dc4bb06fa99..e10ca6eef76 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -315,7 +315,7 @@ static struct serial_device *get_current(void)
/* We must have a console device */ if (!dev) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD puts("Cannot find console\n"); hang(); #else diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index 801b7645afa..734780a124a 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -117,7 +117,7 @@ static void __maybe_unused s5p_serial_baud(struct s5p_uart *uart, u8 reg_width, writeb(val % 16, &uart->rest.value); }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int s5p_serial_setbrg(struct udevice *dev, int baudrate) { struct s5p_serial_plat *plat = dev_get_plat(dev); diff --git a/drivers/serial/serial_zynq.c b/drivers/serial/serial_zynq.c index 55f13c00ddf..b74712f3eeb 100644 --- a/drivers/serial/serial_zynq.c +++ b/drivers/serial/serial_zynq.c @@ -152,7 +152,7 @@ static int zynq_serial_setbrg(struct udevice *dev, int baudrate) return 0; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) static int zynq_serial_setconfig(struct udevice *dev, uint serial_config) { struct zynq_uart_plat *plat = dev_get_plat(dev); diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 6bd48b1b373..b520c727900 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -219,7 +219,7 @@ static int dw_spi_dwc_init(struct udevice *bus, struct dw_spi_priv *priv)
static int request_gpio_cs(struct udevice *bus) { -#if CONFIG_IS_ENABLED(DM_GPIO) && !defined(CONFIG_SPL_BUILD) +#if CONFIG_IS_ENABLED(DM_GPIO) && !defined(CONFIG_XPL_BUILD) struct dw_spi_priv *priv = dev_get_priv(bus); int ret;
@@ -482,7 +482,7 @@ static int poll_transfer(struct dw_spi_priv *priv) */ __weak void external_cs_manage(struct udevice *dev, bool on) { -#if CONFIG_IS_ENABLED(DM_GPIO) && !defined(CONFIG_SPL_BUILD) +#if CONFIG_IS_ENABLED(DM_GPIO) && !defined(CONFIG_XPL_BUILD) struct dw_spi_priv *priv = dev_get_priv(dev->parent);
if (!dm_gpio_is_valid(&priv->cs_gpio)) diff --git a/drivers/spi/rockchip_sfc.c b/drivers/spi/rockchip_sfc.c index 596c22aa010..43aefc20c9a 100644 --- a/drivers/spi/rockchip_sfc.c +++ b/drivers/spi/rockchip_sfc.c @@ -229,7 +229,7 @@ static int rockchip_sfc_ofdata_to_platdata(struct udevice *bus) sfc->regbase = dev_read_addr_ptr(bus); sfc->use_dma = !dev_read_bool(bus, "rockchip,sfc-no-dma");
- if (IS_ENABLED(CONFIG_SPL_BUILD) && sfc->use_dma) + if (IS_ENABLED(CONFIG_XPL_BUILD) && sfc->use_dma) sfc->use_dma = !dev_read_bool(bus, "u-boot,spl-sfc-no-dma");
#if CONFIG_IS_ENABLED(CLK) diff --git a/drivers/sysreset/sysreset_ast.c b/drivers/sysreset/sysreset_ast.c index ef09440bbef..4e15ebd53cc 100644 --- a/drivers/sysreset/sysreset_ast.c +++ b/drivers/sysreset/sysreset_ast.c @@ -33,7 +33,7 @@ static int ast_sysreset_request(struct udevice *dev, enum sysreset_t type) return -EPROTONOSUPPORT; }
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) ret = wdt_expire_now(wdt, reset_mode); if (ret) { debug("Sysreset failed: %d", ret); diff --git a/drivers/usb/cdns3/core.c b/drivers/usb/cdns3/core.c index cbe06a9e7b6..4cfd38ec245 100644 --- a/drivers/usb/cdns3/core.c +++ b/drivers/usb/cdns3/core.c @@ -149,7 +149,7 @@ static int cdns3_core_init_role(struct cdns3 *cdns)
dr_mode = best_dr_mode;
-#if defined(CONFIG_SPL_USB_HOST) || !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SPL_USB_HOST) || !defined(CONFIG_XPL_BUILD) if (dr_mode == USB_DR_MODE_OTG || dr_mode == USB_DR_MODE_HOST) { ret = cdns3_host_init(cdns); if (ret) { @@ -412,7 +412,7 @@ int cdns3_bind(struct udevice *parent)
switch (dr_mode) { #if defined(CONFIG_SPL_USB_HOST) || \ - (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB_HOST)) + (!defined(CONFIG_XPL_BUILD) && defined(CONFIG_USB_HOST)) case USB_DR_MODE_HOST: debug("%s: dr_mode: HOST\n", __func__); driver = "cdns-usb3-host"; @@ -498,7 +498,7 @@ int dm_usb_gadget_handle_interrupts(struct udevice *dev) #endif
#if defined(CONFIG_SPL_USB_HOST) || \ - (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB_HOST)) + (!defined(CONFIG_XPL_BUILD) && defined(CONFIG_USB_HOST)) static int cdns3_host_probe(struct udevice *dev) { struct cdns3_host_priv *priv = dev_get_priv(dev); diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 6abcce0d9c7..3158487cba4 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -7,7 +7,7 @@ obj-$(CONFIG_$(SPL_TPL_)USB_GADGET) += epautoconf.o config.o usbstring.o obj-$(CONFIG_$(SPL_TPL_)USB_ETHER) += epautoconf.o config.o usbstring.o ether.o obj-$(CONFIG_$(SPL_TPL_)USB_ETH_RNDIS) += rndis.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_USB_GADGET) += g_dnl.o obj-$(CONFIG_SPL_DFU) += f_dfu.o obj-$(CONFIG_SPL_USB_SDP_SUPPORT) += f_sdp.o @@ -21,7 +21,7 @@ obj-$(CONFIG_USB_GADGET_BCM_UDC_OTG_PHY) += bcm_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_DWC2_OTG) += dwc2_udc_otg.o obj-$(CONFIG_USB_GADGET_DWC2_OTG_PHY) += dwc2_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_MAX3420) += max3420_udc.o -ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o obj-$(CONFIG_DFU_OVER_USB) += f_dfu.o diff --git a/drivers/usb/gadget/f_sdp.c b/drivers/usb/gadget/f_sdp.c index 5d62eb475d0..36934b1bcf7 100644 --- a/drivers/usb/gadget/f_sdp.c +++ b/drivers/usb/gadget/f_sdp.c @@ -411,7 +411,7 @@ static void sdp_rx_data_complete(struct usb_ep *ep, struct usb_request *req) return; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD env_set_hex("filesize", sdp->dnl_bytes); #endif printf("done\n"); @@ -736,7 +736,7 @@ static u32 sdp_jump_imxheader(void *address) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD static ulong sdp_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) { @@ -825,7 +825,7 @@ static int sdp_handle_in_ep(struct spl_image_info *spl_image,
/* If imx header fails, try some U-Boot specific headers */ if (status) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) sdp_func->jmp_address = (u32)search_container_header((ulong)sdp_func->jmp_address, sdp_func->dnl_bytes); else if (IS_ENABLED(CONFIG_SPL_LOAD_FIT)) @@ -907,7 +907,7 @@ static void sdp_handle_out_ep(void) } }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int sdp_handle(struct udevice *udc) #else int spl_sdp_handle(struct udevice *udc, struct spl_image_info *spl_image, @@ -928,7 +928,7 @@ int spl_sdp_handle(struct udevice *udc, struct spl_image_info *spl_image, schedule(); dm_usb_gadget_handle_interrupts(udc);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD flag = sdp_handle_in_ep(spl_image, bootdev); #else flag = sdp_handle_in_ep(NULL, NULL); diff --git a/drivers/usb/mtu3/mtu3_plat.c b/drivers/usb/mtu3/mtu3_plat.c index f8e14eabfb2..26fee141f6e 100644 --- a/drivers/usb/mtu3/mtu3_plat.c +++ b/drivers/usb/mtu3/mtu3_plat.c @@ -266,7 +266,7 @@ U_BOOT_DRIVER(mtu3_peripheral) = { #endif
#if defined(CONFIG_SPL_USB_HOST) || \ - (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB_HOST)) + (!defined(CONFIG_XPL_BUILD) && defined(CONFIG_USB_HOST)) static int mtu3_host_probe(struct udevice *dev) { struct ssusb_mtk *ssusb = dev_to_ssusb(dev->parent); @@ -334,7 +334,7 @@ static int mtu3_glue_bind(struct udevice *parent) #endif
#if defined(CONFIG_SPL_USB_HOST) || \ - (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB_HOST)) + (!defined(CONFIG_XPL_BUILD) && defined(CONFIG_USB_HOST)) case USB_DR_MODE_HOST: dev_dbg(parent, "%s: dr_mode: host\n", __func__); driver = "mtu3-host"; diff --git a/dts/Makefile b/dts/Makefile index d6c2c9daf31..62a65688cf5 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -53,7 +53,7 @@ PHONY += arch-dtbs arch-dtbs: $(Q)$(MAKE) $(build)=$(dt_dir) dtbs
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_OF_EMBED) := dt-spl.dtb.o # support "out-of-tree" build for dtb-spl $(obj)/dt-spl.dtb.o: $(obj)/dt-spl.dtb.S FORCE diff --git a/env/Makefile b/env/Makefile index 673b979fdfa..c5145c1735f 100644 --- a/env/Makefile +++ b/env/Makefile @@ -8,7 +8,7 @@ obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += env.o obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += attr.o obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += flags.o
-ifndef CONFIG_SPL_BUILD +ifndef CONFIG_XPL_BUILD obj-y += callback.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += embedded.o diff --git a/env/common.c b/env/common.c index 6cba7f1c187..a58955a4f42 100644 --- a/env/common.c +++ b/env/common.c @@ -61,7 +61,7 @@ int env_do_env_set(int flag, int argc, char *const argv[], int env_flag)
debug("Initial value for argc=%d\n", argc);
-#if !IS_ENABLED(CONFIG_SPL_BUILD) && IS_ENABLED(CONFIG_CMD_NVEDIT_EFI) +#if !IS_ENABLED(CONFIG_XPL_BUILD) && IS_ENABLED(CONFIG_CMD_NVEDIT_EFI) if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'e') return do_env_set_efi(NULL, flag, --argc, ++argv); #endif @@ -551,7 +551,7 @@ int env_export(env_t *env_out) void env_relocate(void) { if (gd->env_valid == ENV_INVALID) { -#if defined(CONFIG_ENV_IS_NOWHERE) || defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_ENV_IS_NOWHERE) || defined(CONFIG_XPL_BUILD) /* Environment not changable */ env_set_default(NULL, 0); #else diff --git a/env/fat.c b/env/fat.c index f3f8b7301ee..b04b1d9c315 100644 --- a/env/fat.c +++ b/env/fat.c @@ -22,7 +22,7 @@ #include <asm/global_data.h> #include <linux/stddef.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* TODO(sjg@chromium.org): Figure out why this is needed */ # if !defined(CONFIG_TARGET_AM335X_EVM) || defined(CONFIG_SPL_OS_BOOT) # define LOADENV @@ -129,7 +129,7 @@ static int env_fat_load(void) if (!strcmp(ifname, "mmc")) mmc_initialize(NULL); #endif -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #if defined(CONFIG_AHCI) || defined(CONFIG_SCSI) if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "scsi")) scsi_scan(true); diff --git a/env/flash.c b/env/flash.c index 1bd6e7003d6..0f7393d830c 100644 --- a/env/flash.c +++ b/env/flash.c @@ -22,7 +22,7 @@
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD # if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_FLASH) # include <flash.h> # define CMD_SAVEENV @@ -35,11 +35,11 @@ DECLARE_GLOBAL_DATA_PTR; #if (!defined(CONFIG_MICROBLAZE) && !defined(CONFIG_ARCH_ZYNQ) && \ !defined(CONFIG_TARGET_MCCMON6) && !defined(CONFIG_TARGET_X600) && \ !defined(CONFIG_TARGET_EDMINIV2)) || \ - !defined(CONFIG_SPL_BUILD) + !defined(CONFIG_XPL_BUILD) #define LOADENV #endif
-#if !defined(CONFIG_TARGET_X600) || !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_TARGET_X600) || !defined(CONFIG_XPL_BUILD) #define INITENV #endif
diff --git a/env/mmc.c b/env/mmc.c index 0338aa6c56a..5fc0dae23a8 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -239,7 +239,7 @@ static void fini_mmc_for_env(struct mmc *mmc) mmc_set_env_part_restore(mmc); }
-#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_XPL_BUILD) static inline int write_env(struct mmc *mmc, unsigned long size, unsigned long offset, const void *buffer) { @@ -368,7 +368,7 @@ fini: fini_mmc_for_env(mmc); return ret; } -#endif /* CONFIG_CMD_SAVEENV && !CONFIG_SPL_BUILD */ +#endif /* CONFIG_CMD_SAVEENV && !CONFIG_XPL_BUILD */
static inline int read_env(struct mmc *mmc, unsigned long size, unsigned long offset, const void *buffer) @@ -498,7 +498,7 @@ U_BOOT_ENV_LOCATION(mmc) = { .location = ENVL_MMC, ENV_NAME("MMC") .load = env_mmc_load, -#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_XPL_BUILD) .save = env_save_ptr(env_mmc_save), .erase = ENV_ERASE_PTR(env_mmc_erase) #endif diff --git a/env/nand.c b/env/nand.c index fef5697ec39..fdaa903cd61 100644 --- a/env/nand.c +++ b/env/nand.c @@ -26,9 +26,9 @@ #include <u-boot/crc.h>
#if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_NAND) && \ - !defined(CONFIG_SPL_BUILD) + !defined(CONFIG_XPL_BUILD) #define CMD_SAVEENV -#elif defined(CONFIG_ENV_OFFSET_REDUND) && !defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_ENV_OFFSET_REDUND) && !defined(CONFIG_XPL_BUILD) #error CONFIG_ENV_OFFSET_REDUND must have CONFIG_CMD_SAVEENV & CONFIG_CMD_NAND #endif
@@ -224,7 +224,7 @@ static int env_nand_save(void) } #endif /* CMD_SAVEENV */
-#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) static int readenv(size_t offset, u_char *buf) { return nand_spl_load_image(offset, CONFIG_ENV_SIZE, buf); @@ -265,7 +265,7 @@ static int readenv(size_t offset, u_char *buf)
return 0; } -#endif /* #if defined(CONFIG_SPL_BUILD) */ +#endif /* #if defined(CONFIG_XPL_BUILD) */
#ifdef CONFIG_ENV_OFFSET_OOB int get_nand_env_oob(struct mtd_info *mtd, unsigned long *result) diff --git a/env/nowhere.c b/env/nowhere.c index 326f27db2e9..6b9b6e2fe0b 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -33,7 +33,7 @@ static int env_nowhere_load(void) * searches default_environment array in that case. * For U-Boot proper, import the default environment to allow reload. */ - if (!IS_ENABLED(CONFIG_SPL_BUILD)) + if (!IS_ENABLED(CONFIG_XPL_BUILD)) env_set_default(NULL, 0);
gd->env_valid = ENV_INVALID; diff --git a/env/sf.c b/env/sf.c index 21ac0c202e7..eb4c8d5ec95 100644 --- a/env/sf.c +++ b/env/sf.c @@ -329,7 +329,7 @@ done:
__weak void *env_sf_get_env_addr(void) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD return (void *)CONFIG_ENV_ADDR; #else return NULL; diff --git a/fs/Makefile b/fs/Makefile index 7b05c79e0cc..ec3e31c7c75 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # Copyright (c) 2012, NVIDIA CORPORATION. All rights reserved.
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_FS_LOADER) += fs.o obj-$(CONFIG_SPL_FS_FAT) += fat/ obj-$(CONFIG_SPL_FS_EXT4) += ext4/ diff --git a/fs/fs.c b/fs/fs.c index 4bc28d1dffb..e2915e7cf79 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -237,7 +237,7 @@ static struct fstype_info fstypes[] = { .mkdir = fs_mkdir_unsupported, }, #endif -#if IS_ENABLED(CONFIG_SANDBOX) && !IS_ENABLED(CONFIG_SPL_BUILD) +#if IS_ENABLED(CONFIG_SANDBOX) && !IS_ENABLED(CONFIG_XPL_BUILD) { .fstype = FS_TYPE_SANDBOX, .name = "sandbox", @@ -275,7 +275,7 @@ static struct fstype_info fstypes[] = { .ln = fs_ln_unsupported, }, #endif -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #ifdef CONFIG_CMD_UBIFS { .fstype = FS_TYPE_UBIFS, @@ -296,7 +296,7 @@ static struct fstype_info fstypes[] = { }, #endif #endif -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #ifdef CONFIG_FS_BTRFS { .fstype = FS_TYPE_BTRFS, diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index d6c15e2c406..644a0d77873 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -55,7 +55,7 @@ struct global_data { * @cur_serial_dev: current serial device */ struct udevice *cur_serial_dev; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /** * @jt: jump table * diff --git a/include/bootcount.h b/include/bootcount.h index bc06e17c9fb..847c0f02d98 100644 --- a/include/bootcount.h +++ b/include/bootcount.h @@ -120,13 +120,13 @@ static inline void bootcount_inc(void) return; }
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* Only increment bootcount when no bootcount support in SPL */ #if !defined(CONFIG_SPL_BOOTCOUNT_LIMIT) && !defined(CONFIG_TPL_BOOTCOUNT_LIMIT) bootcount_store(++bootcount); #endif env_set_ulong("bootcount", bootcount); -#endif /* !CONFIG_SPL_BUILD */ +#endif /* !CONFIG_XPL_BUILD */ }
#else diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 2a136b96a6d..0a4e4b8ff85 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -63,7 +63,7 @@ #define BOOTENV_SHARED_MMC BOOTENV_SHARED_BLKDEV(mmc) #define BOOTENV_DEV_MMC BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_MMC BOOTENV_DEV_NAME_BLKDEV -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define BOOTENV_SHARED_MMC #define BOOTENV_DEV_MMC BOOTENV_DEV_BLKDEV_NONE #define BOOTENV_DEV_NAME_MMC BOOTENV_DEV_NAME_BLKDEV_NONE @@ -198,7 +198,7 @@ #define BOOTENV_SHARED_SATA BOOTENV_SHARED_BLKDEV(sata) #define BOOTENV_DEV_SATA BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_SATA BOOTENV_DEV_NAME_BLKDEV -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define BOOTENV_SHARED_SATA #define BOOTENV_DEV_SATA BOOTENV_DEV_BLKDEV_NONE #define BOOTENV_DEV_NAME_SATA BOOTENV_DEV_NAME_BLKDEV_NONE @@ -305,7 +305,7 @@ BOOTENV_SHARED_BLKDEV_BODY(usb) #define BOOTENV_DEV_USB BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_USB BOOTENV_DEV_NAME_BLKDEV -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define BOOTENV_RUN_NET_USB_START #define BOOTENV_SHARED_USB #define BOOTENV_DEV_USB BOOTENV_DEV_BLKDEV_NONE @@ -412,7 +412,7 @@ "\0" #define BOOTENV_DEV_NAME_DHCP(devtypeu, devtypel, instance) \ "dhcp " -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define BOOTENV_DEV_DHCP BOOTENV_DEV_BLKDEV_NONE #define BOOTENV_DEV_NAME_DHCP BOOTENV_DEV_NAME_BLKDEV_NONE #else @@ -433,7 +433,7 @@ "fi\0" #define BOOTENV_DEV_NAME_PXE(devtypeu, devtypel, instance) \ "pxe " -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define BOOTENV_DEV_PXE BOOTENV_DEV_BLKDEV_NONE #define BOOTENV_DEV_NAME_PXE BOOTENV_DEV_NAME_BLKDEV_NONE #else diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 9efae58ce90..20fded56b77 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -43,7 +43,7 @@ #define CFG_SYS_NAND_U_BOOT_SIZE (576 << 10) #define CFG_SYS_NAND_U_BOOT_DST (0x11000000) #define CFG_SYS_NAND_U_BOOT_START (0x11000000) -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define CFG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CFG_SYS_NAND_U_BOOT_DST 0xD0000000 #define CFG_SYS_NAND_U_BOOT_START 0xD0000000 @@ -290,7 +290,7 @@ extern unsigned long get_sdram_size(void); /* * Config the L2 Cache as L2 SRAM */ -#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) #define CFG_SYS_INIT_L2_ADDR 0xD0000000 #define CFG_SYS_INIT_L2_ADDR_PHYS CFG_SYS_INIT_L2_ADDR diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 67f46562539..19d3c72a6f1 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -75,7 +75,7 @@
#include <config_distro_bootcmd.h>
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #include <env/ti/dfu.h>
#define CFG_EXTRA_ENV_SETTINGS \ @@ -181,7 +181,7 @@ #endif /* !CONFIG_MTD_RAW_NAND */
/* USB Device Firmware Update support */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define DFUARGS \ DFU_ALT_INFO_EMMC \ DFU_ALT_INFO_MMC \ diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index a8fa61c7e50..96efd38594a 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -16,7 +16,7 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
#define MEM_LAYOUT_ENV_SETTINGS \ "scriptaddr=0x80000000\0" \ @@ -70,7 +70,7 @@ "setenv boot_syslinux_conf "extlinux/extlinux.conf"; " \ "run bootcmd_ubifs0;\0"
-#endif /* ! CONFIG_SPL_BUILD */ +#endif /* ! CONFIG_XPL_BUILD */
#define SPLASH_SCREEN_NAND_PART "nand0,10" #define SPLASH_SCREEN_BMP_FILE_SIZE 0x26000 diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index dedef91ba59..55d5190b221 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -20,7 +20,7 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define CFG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ "kloadaddr=0x84000000\0" \ @@ -117,7 +117,7 @@ "setenv mmcpart 5; " \ "fi; " \ "setenv mmcroot /dev/mmcblk${mmcdev}p${mmcpart};\0" -#endif /* #ifndef CONFIG_SPL_BUILD */ +#endif /* #ifndef CONFIG_XPL_BUILD */
#if defined CONFIG_SHC_NETBOOT /* Network Boot */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 87ffa769d15..036995cbb48 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -35,7 +35,7 @@ /* NS16550 Configuration */ #define CFG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD /* USB Device Firmware Update support */ #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ @@ -63,7 +63,7 @@
#define CFG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 4b4362ccfd8..aa31f3b05a0 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -18,7 +18,7 @@ #define CFG_SYS_NS16550_COM2 UART2_BASE /* UART2 */ #define CFG_SYS_NS16550_COM3 UART3_BASE /* UART3 */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ DFU_ALT_INFO_MMC \ diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 9dcacad2fc0..1f61b2b6af6 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -13,10 +13,10 @@ #include "siemens-env-common.h"
/* SPL config */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_MALLOC_F_ADDR 0x00120000
/* ENET1 connects to base board and MUX with ESAI */ #define CFG_FEC_ENET_DEV 1 diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 98d4d8cf4bd..0d338389cb9 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -11,7 +11,7 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
#endif diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 416aa96366c..8db849c6d09 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -157,7 +157,7 @@ "console=ttyS2,115200n8\0" \ "hwconfig=dsp:wake=yes"
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* defines for SPL */
#endif diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 633ec1f32fa..96dcd731cb6 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -28,7 +28,7 @@ #define CFG_SYS_NS16550_COM2 UART2_BASE /* UART2 */ #define CFG_SYS_NS16550_COM3 UART3_BASE /* UART3 */
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ DFU_ALT_INFO_MMC \ @@ -37,7 +37,7 @@ DFU_ALT_INFO_QSPI #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #ifdef CONFIG_SPL_DFU #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ diff --git a/include/configs/ds116.h b/include/configs/ds116.h index c2326596811..2f2bc43269e 100644 --- a/include/configs/ds116.h +++ b/include/configs/ds116.h @@ -18,7 +18,7 @@ */ #include "mv-common.h"
#define KERNEL_ADDR_R __stringify(0x1000000) #define FDT_ADDR_R __stringify(0x2000000) @@ -39,6 +39,6 @@ "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "console=ttyS0,115200\0"
#endif /* _CONFIG_DS116_H */ diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 95256575583..431a78de416 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -43,7 +43,7 @@ */ #include "mv-common.h"
#define KERNEL_ADDR_R __stringify(0x1000000) #define FDT_ADDR_R __stringify(0x2000000) @@ -80,6 +80,6 @@ "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "console=ttyS0,115200\0"
#endif /* _CONFIG_SYNOLOGY_DS414_H */ diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 1b97ae22fc6..a89d298b525 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -15,7 +15,7 @@ #define CFG_SYS_UBOOT_BASE 0
/* Serial SPL */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_SERIAL) #define CFG_SYS_NS16550_CLK 40000000 #define CFG_SYS_NS16550_COM1 0xb0000c00 #endif diff --git a/include/configs/imx6q-bosch-acc.h b/include/configs/imx6q-bosch-acc.h index fab5063b73f..64ddbf711d3 100644 --- a/include/configs/imx6q-bosch-acc.h +++ b/include/configs/imx6q-bosch-acc.h @@ -92,7 +92,7 @@ /* SPL */ #ifdef CONFIG_SPL
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_SYS_FSL_USDHC_NUM 2
#ifdef CONFIG_SYS_BOOT_EMMC diff --git a/include/configs/imx6ulz_smm_m2.h b/include/configs/imx6ulz_smm_m2.h index 9da98d0af27..44a3fc02e8a 100644 --- a/include/configs/imx6ulz_smm_m2.h +++ b/include/configs/imx6ulz_smm_m2.h @@ -14,14 +14,14 @@
#define CFG_MXC_UART_BASE UART4_BASE
#define BOOT_TARGET_DEVICES(func) \ func(NAND, nand, 0) \
#define MEM_LAYOUT_ENV_SETTINGS \ "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index 146f7945719..6ed4a6fd3fc 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -14,7 +14,7 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x912000 /* For RAW image gives a error info not panic */ diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index fa20651d2df..2ec7f3d8b6f 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -21,7 +21,7 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index 9a5e5bd009d..d323f84ac7a 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -10,7 +10,7 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_MALLOC_F_ADDR 0x930000
/* For RAW image gives a error info not panic */ diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 9dd63fc1196..3bbbd900dd4 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -22,7 +22,7 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index 2158b0af74f..145dab91215 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -13,11 +13,11 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ # define CFG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 2) \ diff --git a/include/configs/imx8mm_phg.h b/include/configs/imx8mm_phg.h index d2d7ffa0f5b..038d3a7ce3f 100644 --- a/include/configs/imx8mm_phg.h +++ b/include/configs/imx8mm_phg.h @@ -14,7 +14,7 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x930000 #endif diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 66816618b0c..ed09dd09bcb 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -12,7 +12,7 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x930000 #endif diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index b82e35f4963..8b96f7fd1e4 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -23,7 +23,7 @@ EFI_GUID(0xb5fb6f08, 0xe142, 0x4db1, 0x97, 0xea, \ 0x5f, 0xd3, 0x6b, 0x9b, 0xe5, 0xb9)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_MALLOC_F_ADDR 0x184000 /* malloc f used before \ * GD_FLG_FULL_MALLOC_INIT \ * set \ diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index 2bbd6b1680f..ccbb0f85559 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -10,7 +10,7 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x182000 diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 9eefc31dc6f..666f46ac105 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -10,7 +10,7 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index cd73a72d2b7..3bc4b0034e8 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -9,7 +9,7 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ diff --git a/include/configs/imx8mq_reform2.h b/include/configs/imx8mq_reform2.h index 7fa441a8a83..40f96a5f219 100644 --- a/include/configs/imx8mq_reform2.h +++ b/include/configs/imx8mq_reform2.h @@ -10,7 +10,7 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 4d5abe2d073..842184bcae2 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -10,7 +10,7 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
#endif diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index 93999509948..1b6eb2b81cf 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -10,7 +10,7 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
#endif diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index aa9da19a11f..9308f5234f4 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -11,7 +11,7 @@
#define CFG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_MALLOC_F_ADDR 0x22040000
#endif diff --git a/include/configs/imx93_evk.h b/include/configs/imx93_evk.h index ce6567e2af6..53fb8c9b1ba 100644 --- a/include/configs/imx93_evk.h +++ b/include/configs/imx93_evk.h @@ -13,7 +13,7 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_MALLOC_F_ADDR 0x204D0000 #endif
diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 3a129c5cce7..72a28a6a413 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -10,7 +10,7 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <config.h> #endif
@@ -39,7 +39,7 @@ #undef BOOTENV_RUN_NET_USB_START #define BOOTENV_RUN_NET_USB_START
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x930000 #endif diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index 3dda7b66806..3f52d00d6c8 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -12,7 +12,7 @@ EFI_GUID(0xc898e959, 0x5b1f, 0x4e6d, 0x88, 0xe0, \ 0x40, 0xd4, 0x5c, 0xca, 0x13, 0x99)
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x182000 diff --git a/include/configs/librem5.h b/include/configs/librem5.h index 876b02f4da6..571c7724eaf 100644 --- a/include/configs/librem5.h +++ b/include/configs/librem5.h @@ -41,7 +41,7 @@ #define CONSOLE "ttymxc0" #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(USB, usb, 0) \ diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index e8f7a59c401..ec1aa14be01 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -15,7 +15,7 @@ #define CFG_SYS_UBOOT_BASE 0
/* Serial SPL */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_SERIAL) #define CFG_SYS_NS16550_CLK 40000000 #define CFG_SYS_NS16550_COM3 0xb0000e00
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index e500a7d80ff..a02c752bbcf 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -8,7 +8,7 @@ #define __LS1043A_COMMON_H
/* SPL build */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define SPL_NO_FMAN #define SPL_NO_DSPI #define SPL_NO_PCIE @@ -19,10 +19,10 @@ #define SPL_NO_QE #define SPL_NO_EEPROM #endif -#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_NAND_BOOT)) +#if (defined(CONFIG_XPL_BUILD) && defined(CONFIG_NAND_BOOT)) #define SPL_NO_MMC #endif -#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SD_BOOT_QSPI)) +#if (defined(CONFIG_XPL_BUILD) && defined(CONFIG_SD_BOOT_QSPI)) #define SPL_NO_IFC #endif
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 867b098a073..53ef5975a28 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -8,7 +8,7 @@ #define __LS1046A_COMMON_H
/* SPL build */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define SPL_NO_QBMAN #define SPL_NO_FMAN #define SPL_NO_ENV @@ -17,11 +17,11 @@ #define SPL_NO_USB #define SPL_NO_SATA #endif -#if defined(CONFIG_SPL_BUILD) && \ +#if defined(CONFIG_XPL_BUILD) && \ (defined(CONFIG_NAND_BOOT) || defined(CONFIG_QSPI_BOOT)) #define SPL_NO_MMC #endif -#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #define SPL_NO_IFC #endif
diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 34085eeecc7..cdf281947dc 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -7,7 +7,7 @@ #define __LS1088_COMMON_H
/* SPL build */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define SPL_NO_BOARDINFO #define SPL_NO_QIXIS #define SPL_NO_PCI diff --git a/include/configs/msc_sm2s_imx8mp.h b/include/configs/msc_sm2s_imx8mp.h index ea5c93ecf69..985b1ca91e6 100644 --- a/include/configs/msc_sm2s_imx8mp.h +++ b/include/configs/msc_sm2s_imx8mp.h @@ -20,7 +20,7 @@ #define CFG_FEC_MXC_PHYADDR 1 #endif
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) diff --git a/include/configs/mt7621.h b/include/configs/mt7621.h index e6dba707195..636d62dd883 100644 --- a/include/configs/mt7621.h +++ b/include/configs/mt7621.h @@ -15,7 +15,7 @@ #define CFG_SYS_INIT_SP_OFFSET 0x800000
/* Serial SPL */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_SERIAL) #define CFG_SYS_NS16550_CLK 50000000 #define CFG_SYS_NS16550_COM1 0xbe000c00 #endif diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h index 1df06811d65..ba876ac3029 100644 --- a/include/configs/mt7628.h +++ b/include/configs/mt7628.h @@ -13,7 +13,7 @@ #define CFG_SYS_INIT_SP_OFFSET 0x80000
/* Serial SPL */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_SERIAL) #define CFG_SYS_NS16550_CLK 40000000 #define CFG_SYS_NS16550_COM1 0xb0000c00 #endif diff --git a/include/configs/n2350.h b/include/configs/n2350.h index f98b9f8582d..c789df55bfb 100644 --- a/include/configs/n2350.h +++ b/include/configs/n2350.h @@ -18,7 +18,7 @@ */ #include "mv-common.h"
#endif /* _CONFIG_N2350_H */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index f5bd0913449..23d8917b718 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -98,7 +98,7 @@ #define CFG_SYS_NAND_U_BOOT_SIZE (832 << 10) #define CFG_SYS_NAND_U_BOOT_DST (0x11000000) #define CFG_SYS_NAND_U_BOOT_START (0x11000000) -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define CFG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CFG_SYS_NAND_U_BOOT_DST 0xf8f80000 #define CFG_SYS_NAND_U_BOOT_START 0xf8f80000 @@ -280,7 +280,7 @@ /* * Config the L2 Cache as L2 SRAM */ -#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_XPL_BUILD) #if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) #define CFG_SYS_INIT_L2_ADDR 0xf8f80000 #define CFG_SYS_INIT_L2_ADDR_PHYS CFG_SYS_INIT_L2_ADDR diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index 0910ae2d870..e74a3f184c6 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -14,7 +14,7 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index 422b89a3dd3..3012f64c0ae 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -9,7 +9,7 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index d652ae4ca34..c5bcd7dc5e8 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -13,7 +13,7 @@ #define CFG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xf8000000
#ifndef ROCKCHIP_DEVICE_SETTINGS #define ROCKCHIP_DEVICE_SETTINGS @@ -38,6 +38,6 @@ ROCKCHIP_DEVICE_SETTINGS \ "boot_targets=" BOOT_TARGETS "\0"
#endif /* __CONFIG_RK3399_COMMON_H */ diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 9121bba3738..9b8ab3cdf20 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -11,7 +11,7 @@ #define CFG_CPUID_OFFSET 0x7 #endif
#define BOOT_TARGETS "mmc1 mmc0 nvme scsi usb pxe dhcp spi"
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 4838bfd4f13..2acfdc7df4a 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -117,7 +117,7 @@ /* SPL NAND boot support */
/* Extra Environment */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD
#ifdef CONFIG_CMD_DHCP #define BOOT_TARGET_DEVICES_DHCP(func) func(DHCP, dhcp, na) diff --git a/include/configs/stm32mp15_common.h b/include/configs/stm32mp15_common.h index 29a1197b5ae..af6dd4a8095 100644 --- a/include/configs/stm32mp15_common.h +++ b/include/configs/stm32mp15_common.h @@ -33,7 +33,7 @@ #ifdef CONFIG_DISTRO_DEFAULTS /*****************************************************************************/
#ifdef CONFIG_CMD_MMC #define BOOT_TARGET_MMC0(func) func(MMC, mmc, 0) @@ -129,7 +129,7 @@ STM32MP_EXTRA \ STM32MP_BOARD_EXTRA_ENV
-#endif /* ifndef CONFIG_SPL_BUILD */ +#endif /* ifndef CONFIG_XPL_BUILD */ #endif /* ifdef CONFIG_DISTRO_DEFAULTS*/
#endif /* __CONFIG_STM32MP15_COMMMON_H */ diff --git a/include/configs/stm32mp15_dh_dhsom.h b/include/configs/stm32mp15_dh_dhsom.h index 6fe6e7b9b8c..0f466711cae 100644 --- a/include/configs/stm32mp15_dh_dhsom.h +++ b/include/configs/stm32mp15_dh_dhsom.h @@ -10,7 +10,7 @@
/* PHY needs a longer autoneg timeout */
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_EXTRA_ENV_SETTINGS \ "dfu_alt_info_ram=u-boot.itb ram " \ __stringify(CONFIG_SPL_LOAD_FIT_ADDRESS) \ diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index 45f7179f035..4a7474ff3f9 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -31,7 +31,7 @@ 115200}
/* Select serial console configuration */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_SYS_NS16550_COM1 OMAP34XX_UART1 #define CFG_SYS_NS16550_COM2 OMAP34XX_UART2 #define CFG_SYS_NS16550_COM3 OMAP34XX_UART3 diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index c4f116aabf8..7a333090b18 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -95,7 +95,7 @@ * So moving TEXT_BASE down to non-HS limit. */
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* No need for i2c in SPL mode as we will use SRI2C for PMIC access on OMAP4 */ #endif
diff --git a/include/configs/turris_1x.h b/include/configs/turris_1x.h index 3d398a6c1ec..c05614950c7 100644 --- a/include/configs/turris_1x.h +++ b/include/configs/turris_1x.h @@ -63,7 +63,7 @@ /* * For SD card builds without SPL it is needed to set CONFIG_SYS_RAMBOOT * - * if CONFIG_SPL_BUILD + * if CONFIG_XPL_BUILD * if CONFIG_FSL_PREPBL_ESDHC_BOOT_SECTOR * define CONFIG_SPL_MAX_SIZE = (CONFIG_SYS_L2_SIZE+CONFIG_FSL_PREPBL_ESDHC_BOOT_SECTOR_DATA * * SZ_512) @@ -121,7 +121,7 @@ */
/* Initial SRAM is used only for SD card boot in first stage image */ -#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_SPL) || defined(CONFIG_XPL_BUILD) #define CFG_SYS_INIT_L2_ADDR 0xf8f80000 #define CFG_SYS_INIT_L2_ADDR_PHYS CFG_SYS_INIT_L2_ADDR /* diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index 302194bc90f..03a12d519f2 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -31,7 +31,7 @@ #include "mv-common.h"
/* Include the common distro boot environment */ -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ @@ -86,6 +86,6 @@ "bootcmd_rescue=" TURRIS_OMNIA_BOOTCMD_RESCUE "\0" \ BOOTENV
#endif /* _CONFIG_TURRIS_OMNIA_H */ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index b018bbe29dd..c54383b886e 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -12,7 +12,7 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 0b88e95603d..bff417fdafb 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -12,13 +12,13 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x184000 /* For RAW image gives a error info not panic */
#define MEM_LAYOUT_ENV_SETTINGS \ "fdt_addr_r=0x50200000\0" \ diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 2cf7bc70d8d..752b23d055c 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -47,7 +47,7 @@ /* 0=user, 1=boot0, 2=boot1, * 4..7=general0..3. */ #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define CFG_MXC_UART_BASE UART1_BASE #endif
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index de0db7bb63f..bb0db7c5ca3 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -183,7 +183,7 @@ #endif
/* SPL can't handle all huge variables - define just DFU */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_DFU) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_DFU) #undef CFG_EXTRA_ENV_SETTINGS # define CFG_EXTRA_ENV_SETTINGS \ "dfu_alt_info_ram=uboot.bin ram 0x8000000 0x1000000;" \ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 03af859c951..37c77aa1611 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -44,7 +44,7 @@
/* Boot configuration */
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define BOOTENV #else
@@ -167,7 +167,7 @@ BOOT_TARGET_DEVICES_DHCP(func)
#include <config_distro_bootcmd.h> -#endif /* CONFIG_SPL_BUILD */ +#endif /* CONFIG_XPL_BUILD */
/* Default environment */ #ifndef CFG_EXTRA_ENV_SETTINGS diff --git a/include/env.h b/include/env.h index d2a5954ded8..01c3eeae7e2 100644 --- a/include/env.h +++ b/include/env.h @@ -44,7 +44,7 @@ struct env_clbk_tbl { * For SPL these are silently dropped to reduce code size, since environment * callbacks are not supported with SPL. */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define U_BOOT_ENV_CALLBACK(name, callback) \ static inline __maybe_unused void _u_boot_env_noop_##name(void) \ { \ diff --git a/include/env_callback.h b/include/env_callback.h index 8e500aaaf80..5121ae07fd9 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -85,7 +85,7 @@ "serial#:serialno," \ CFG_ENV_CALLBACK_LIST_STATIC
-#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD void env_callback_init(struct env_entry *var_entry); #else static inline void env_callback_init(struct env_entry *var_entry) diff --git a/include/fdtdec.h b/include/fdtdec.h index e80de24076c..555c9520379 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -143,7 +143,7 @@ extern u8 __dtb_dt_spl_begin[]; /* embedded device tree blob for SPL/TPL */ static inline u8 *dtb_dt_embedded(void) { #ifdef CONFIG_OF_EMBED -# ifdef CONFIG_SPL_BUILD +# ifdef CONFIG_XPL_BUILD return __dtb_dt_spl_begin; # else return __dtb_dt_begin; diff --git a/include/image-android-dt.h b/include/image-android-dt.h index 9a3aa8fa30f..d255744e8cb 100644 --- a/include/image-android-dt.h +++ b/include/image-android-dt.h @@ -13,7 +13,7 @@ bool android_dt_check_header(ulong hdr_addr); bool android_dt_get_fdt_by_index(ulong hdr_addr, u32 index, ulong *addr, u32 *size);
-#if !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_XPL_BUILD) void android_dt_print_contents(ulong hdr_addr); #endif
diff --git a/include/iotrace.h b/include/iotrace.h index d5610426cc8..5527c984fd2 100644 --- a/include/iotrace.h +++ b/include/iotrace.h @@ -42,7 +42,7 @@ struct iotrace_record { */
#if defined(CONFIG_IO_TRACE) && !defined(IOTRACE_IMPL) && \ - !defined(CONFIG_SPL_BUILD) + !defined(CONFIG_XPL_BUILD)
#undef readl #define readl(addr) iotrace_readl((const void *)(addr)) diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index 2bc704e1104..a59f2a61e6a 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -40,7 +40,7 @@ #define _CONFIG_PREFIX TPL_ #elif defined(CONFIG_VPL_BUILD) #define _CONFIG_PREFIX VPL_ -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) #define _CONFIG_PREFIX SPL_ #else #define _CONFIG_PREFIX @@ -53,8 +53,8 @@ /* * CONFIG_VAL(FOO) evaluates to the value of * CONFIG_TOOLS_FOO if USE_HOSTCC is defined, - * CONFIG_FOO if CONFIG_SPL_BUILD is undefined, - * CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. + * CONFIG_FOO if CONFIG_XPL_BUILD is undefined, + * CONFIG_SPL_FOO if CONFIG_XPL_BUILD is defined. * CONFIG_TPL_FOO if CONFIG_TPL_BUILD is defined. * CONFIG_VPL_FOO if CONFIG_VPL_BUILD is defined. */ @@ -106,22 +106,22 @@ long invalid_use_of_IF_ENABLED_INT(void); /* * CONFIG_IS_ENABLED(FOO) expands to * 1 if USE_HOSTCC is defined and CONFIG_TOOLS_FOO is set to 'y', - * 1 if CONFIG_SPL_BUILD is undefined and CONFIG_FOO is set to 'y', - * 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', + * 1 if CONFIG_XPL_BUILD is undefined and CONFIG_FOO is set to 'y', + * 1 if CONFIG_XPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * 1 if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * 0 otherwise. * * CONFIG_IS_ENABLED(FOO, (abc)) expands to * abc if USE_HOSTCC is defined and CONFIG_TOOLS_FOO is set to 'y', - * abc if CONFIG_SPL_BUILD is undefined and CONFIG_FOO is set to 'y', - * abc if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', + * abc if CONFIG_XPL_BUILD is undefined and CONFIG_FOO is set to 'y', + * abc if CONFIG_XPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * abc if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * nothing otherwise. * * CONFIG_IS_ENABLED(FOO, (abc), (def)) expands to * abc if USE_HOSTCC is defined and CONFIG_TOOLS_FOO is set to 'y', - * abc if CONFIG_SPL_BUILD is undefined and CONFIG_FOO is set to 'y', - * abc if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', + * abc if CONFIG_XPL_BUILD is undefined and CONFIG_FOO is set to 'y', + * abc if CONFIG_XPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * abc if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * def otherwise. * diff --git a/include/log.h b/include/log.h index 7c25bf0b081..371f99d82e7 100644 --- a/include/log.h +++ b/include/log.h @@ -246,7 +246,7 @@ int _log_buffer(enum log_category_t cat, enum log_level_t level, #define _DEBUG 0 #endif
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #define _SPL_BUILD 1 #else #define _SPL_BUILD 0 diff --git a/include/mmc.h b/include/mmc.h index 0044ff8bef7..e4b960b7294 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -726,7 +726,7 @@ struct mmc { u64 capacity_boot; u64 capacity_rpmb; u64 capacity_gp[4]; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD u64 enh_user_start; u64 enh_user_size; #endif diff --git a/include/mtd/cfi_flash.h b/include/mtd/cfi_flash.h index f4aecaac75f..be292e3ceb2 100644 --- a/include/mtd/cfi_flash.h +++ b/include/mtd/cfi_flash.h @@ -163,7 +163,7 @@ struct cfi_pri_hdr { #if defined(CONFIG_SYS_MAX_FLASH_BANKS_DETECT) /* map to cfi_flash_num_flash_banks only when supported */ #if IS_ENABLED(CONFIG_FLASH_CFI_DRIVER) && \ - (!IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_SPL_MTD)) + (!IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_SPL_MTD)) #define CFI_FLASH_BANKS (cfi_flash_num_flash_banks) /* board code can update this variable before CFI detection */ extern int cfi_flash_num_flash_banks; diff --git a/include/net.h b/include/net.h index bb2ae20f52a..dc8b5e9cc34 100644 --- a/include/net.h +++ b/include/net.h @@ -683,7 +683,7 @@ int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, /* Processes a received packet */ void net_process_received_packet(uchar *in_packet, int len);
-#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_XPL_BUILD) void nc_start(void); int nc_input_packet(uchar *pkt, struct in_addr src_ip, unsigned dest_port, unsigned src_port, unsigned len); @@ -691,7 +691,7 @@ int nc_input_packet(uchar *pkt, struct in_addr src_ip, unsigned dest_port,
static __always_inline int eth_is_on_demand_init(void) { -#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_XPL_BUILD) extern enum proto_t net_loop_last_protocol;
return net_loop_last_protocol != NETCONS; @@ -702,7 +702,7 @@ static __always_inline int eth_is_on_demand_init(void)
static inline void eth_set_last_protocol(int protocol) { -#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_XPL_BUILD) extern enum proto_t net_loop_last_protocol;
net_loop_last_protocol = protocol; diff --git a/include/part.h b/include/part.h index 797b542ef1f..92662677551 100644 --- a/include/part.h +++ b/include/part.h @@ -439,7 +439,7 @@ ulong disk_blk_erase(struct udevice *dev, lbaint_t start, lbaint_t blkcnt); * We don't support printing partition information in SPL and only support * getting partition information in a few cases. */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD # define part_print_ptr(x) NULL # if defined(CONFIG_SPL_FS_EXT4) || defined(CONFIG_SPL_FS_FAT) || \ defined(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION) diff --git a/include/sdp.h b/include/sdp.h index 5492f9c47d2..0a97f28073a 100644 --- a/include/sdp.h +++ b/include/sdp.h @@ -11,7 +11,7 @@
int sdp_init(struct udevice *udc);
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD #include <spl.h>
int spl_sdp_handle(struct udevice *udc, struct spl_image_info *spl_image, diff --git a/include/search.h b/include/search.h index 7faf23f4aca..3952198a0df 100644 --- a/include/search.h +++ b/include/search.h @@ -29,7 +29,7 @@ enum env_action { struct env_entry { const char *key; char *data; -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD int (*callback)(const char *name, const char *value, enum env_op op, int flags); #endif diff --git a/include/spl.h b/include/spl.h index de808ccd413..dd9aeeaf9cc 100644 --- a/include/spl.h +++ b/include/spl.h @@ -51,7 +51,7 @@ static inline bool u_boot_first_phase(void) if (IS_ENABLED(CONFIG_TPL_BUILD)) return true; } else if (IS_ENABLED(CONFIG_SPL)) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return true; } else { return true; @@ -90,7 +90,7 @@ enum u_boot_phase { * * To include code only in SPL, you might do: * - * #if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_TPL_BUILD) + * #if defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) * ... * #endif * @@ -102,7 +102,7 @@ enum u_boot_phase { * * To include code only in U-Boot proper, you might do: * - * #ifndef CONFIG_SPL_BUILD + * #ifndef CONFIG_XPL_BUILD * ... * #endif * @@ -120,7 +120,7 @@ static inline enum u_boot_phase spl_phase(void) return PHASE_TPL; #elif defined(CONFIG_VPL_BUILD) return PHASE_VPL; -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) return PHASE_SPL; #else DECLARE_GLOBAL_DATA_PTR; @@ -135,7 +135,7 @@ static inline enum u_boot_phase spl_phase(void) /* returns true if in U-Boot proper, false if in SPL */ static inline bool spl_in_proper(void) { -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD return false; #endif
@@ -154,7 +154,7 @@ static inline enum u_boot_phase spl_prev_phase(void) return PHASE_NONE; #elif defined(CONFIG_VPL_BUILD) return PHASE_TPL; /* VPL requires TPL */ -#elif defined(CONFIG_SPL_BUILD) +#elif defined(CONFIG_XPL_BUILD) return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : IS_ENABLED(CONFIG_TPL) ? PHASE_TPL : PHASE_NONE; @@ -227,7 +227,7 @@ static inline const char *spl_phase_prefix(enum u_boot_phase phase) }
/* A string name for SPL or TPL */ -#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD # ifdef CONFIG_TPL_BUILD # define SPL_TPL_NAME "TPL" # elif defined(CONFIG_VPL_BUILD) diff --git a/include/stdio.h b/include/stdio.h index 7b999a519ba..56609b846ff 100644 --- a/include/stdio.h +++ b/include/stdio.h @@ -9,9 +9,9 @@ int getchar(void); int tstc(void);
/* stdout */ -#if !defined(CONFIG_SPL_BUILD) || \ +#if !defined(CONFIG_XPL_BUILD) || \ (defined(CONFIG_TPL_BUILD) && defined(CONFIG_TPL_SERIAL)) || \ - (defined(CONFIG_SPL_BUILD) && !defined(CONFIG_TPL_BUILD) && \ + (defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) && \ defined(CONFIG_SPL_SERIAL)) void putc(const char c); void puts(const char *s); diff --git a/include/sunxi_gpio.h b/include/sunxi_gpio.h index db3742c0397..122987c395e 100644 --- a/include/sunxi_gpio.h +++ b/include/sunxi_gpio.h @@ -206,7 +206,7 @@ void sunxi_gpio_set_pull(u32 pin, u32 val); void sunxi_gpio_set_pull_bank(void *bank_base, int pin_offset, u32 val); int sunxi_name_to_gpio(const char *name);
-#if !defined CONFIG_SPL_BUILD && defined CONFIG_AXP_GPIO +#if !defined CONFIG_XPL_BUILD && defined CONFIG_AXP_GPIO int axp_gpio_init(void); #else static inline int axp_gpio_init(void) { return 0; } diff --git a/include/upl.h b/include/upl.h index 2ec5ef1b5cf..4d0eca88047 100644 --- a/include/upl.h +++ b/include/upl.h @@ -320,7 +320,7 @@ int upl_read_handoff(struct upl *upl, oftree tree); int upl_get_test_data(struct unit_test_state *uts, struct upl *upl); #endif /* USE_HOSTCC */
-#if CONFIG_IS_ENABLED(UPL) && defined(CONFIG_SPL_BUILD) +#if CONFIG_IS_ENABLED(UPL) && defined(CONFIG_XPL_BUILD)
/** * upl_set_fit_info() - Set up basic info about the FIT @@ -367,7 +367,7 @@ int _upl_add_image(int node, ulong load_addr, ulong size, const char *desc); static inline int upl_add_image(const void *fit, int node, ulong load_addr, ulong size) { - if (CONFIG_IS_ENABLED(UPL) && IS_ENABLED(CONFIG_SPL_BUILD)) { + if (CONFIG_IS_ENABLED(UPL) && IS_ENABLED(CONFIG_XPL_BUILD)) { const char *desc = fdt_getprop(fit, node, FIT_DESC_PROP, NULL);
return _upl_add_image(node, load_addr, size, desc); diff --git a/include/vbe.h b/include/vbe.h index 5ede8181b98..56bff63362f 100644 --- a/include/vbe.h +++ b/include/vbe.h @@ -41,7 +41,7 @@ struct vbe_handoff { */ static inline enum vbe_phase_t vbe_phase(void) { - if (IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_XPL_BUILD)) return VBE_PHASE_FIRMWARE;
return VBE_PHASE_OS; diff --git a/lib/Makefile b/lib/Makefile index d300249f57c..66f84408aae 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_driver/ @@ -96,7 +96,7 @@ obj-$(CONFIG_LIBAVB) += libavb/ obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += libfdt/ obj-$(CONFIG_$(SPL_TPL_)OF_REAL) += fdtdec_common.o fdtdec.o
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16-ccitt.o obj-$(CONFIG_$(SPL_TPL_)HASH) += crc16-ccitt.o obj-$(CONFIG_MMC_SPI_CRC_ON) += crc16-ccitt.o @@ -131,7 +131,7 @@ obj-$(CONFIG_LIB_UUID) += uuid.o obj-$(CONFIG_LIB_RAND) += rand.o obj-y += panic.o
-ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) # SPL U-Boot may use full-printf, tiny-printf or none at all ifdef CONFIG_$(SPL_TPL_)USE_TINY_PRINTF obj-$(CONFIG_$(SPL_TPL_)SPRINTF) += tiny-printf.o diff --git a/lib/crypto/Makefile b/lib/crypto/Makefile index bec1bc95a65..3259c951241 100644 --- a/lib/crypto/Makefile +++ b/lib/crypto/Makefile @@ -18,12 +18,12 @@ rsa_public_key-y := \ rsa_helper.o
$(obj)/rsapubkey.asn1.o: $(obj)/rsapubkey.asn1.c $(obj)/rsapubkey.asn1.h -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD CFLAGS_rsapubkey.asn1.o += -I$(obj) endif
$(obj)/rsa_helper.o: $(obj)/rsapubkey.asn1.h -ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD CFLAGS_rsa_helper.o += -I$(obj) endif
diff --git a/lib/display_options.c b/lib/display_options.c index d5df53ab15f..2c15cc5b5c4 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -236,7 +236,7 @@ int print_buffer(ulong addr, const void *data, uint width, uint count, addr += thislinelen * width; count -= thislinelen;
- if (!IS_ENABLED(CONFIG_SPL_BUILD) && ctrlc()) + if (!IS_ENABLED(CONFIG_XPL_BUILD) && ctrlc()) return -EINTR; }
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 5edc8dd2f9f..4199379c872 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1230,7 +1230,7 @@ static void *fdt_find_separate(void) if (IS_ENABLED(CONFIG_SANDBOX)) return NULL;
-#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_XPL_BUILD /* FDT is at end of BSS unless it is in a different memory region */ if (IS_ENABLED(CONFIG_SPL_SEPARATE_BSS)) fdt_blob = (ulong *)_image_binary_end; @@ -1714,7 +1714,7 @@ int fdtdec_setup(void) }
/* Allow the early environment to override the fdt address */ - if (!IS_ENABLED(CONFIG_SPL_BUILD)) { + if (!IS_ENABLED(CONFIG_XPL_BUILD)) { ulong addr;
addr = env_get_hex("fdtcontroladdr", 0); diff --git a/lib/hang.c b/lib/hang.c index 3cfb06e9ca8..f3c3c896f0a 100644 --- a/lib/hang.c +++ b/lib/hang.c @@ -22,7 +22,7 @@ */ void hang(void) { -#if !defined(CONFIG_SPL_BUILD) || \ +#if !defined(CONFIG_XPL_BUILD) || \ (CONFIG_IS_ENABLED(LIBCOMMON_SUPPORT) && \ CONFIG_IS_ENABLED(SERIAL)) puts("### ERROR ### Please RESET the board ###\n"); diff --git a/lib/hashtable.c b/lib/hashtable.c index 9613adc5540..e8a59e2dcac 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -221,7 +221,7 @@ static int do_callback(const struct env_entry *e, const char *name, const char *value, enum env_op op, int flags) { -#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_XPL_BUILD if (e->callback) return e->callback(name, value, op, flags); #endif @@ -487,7 +487,7 @@ int hdelete_r(const char *key, struct hsearch_data *htab, int flag) return 0; }
-#if !(defined(CONFIG_SPL_BUILD) && !defined(CONFIG_SPL_SAVEENV)) +#if !(defined(CONFIG_XPL_BUILD) && !defined(CONFIG_SPL_SAVEENV)) /* * hexport() */ diff --git a/lib/hexdump.c b/lib/hexdump.c index 2bc508ff504..29feccd60fc 100644 --- a/lib/hexdump.c +++ b/lib/hexdump.c @@ -157,7 +157,7 @@ int print_hex_dump(const char *prefix_str, int prefix_type, int rowsize, printf("%s%s\n", prefix_str, linebuf); break; } - if (!IS_ENABLED(CONFIG_SPL_BUILD) && ctrlc()) + if (!IS_ENABLED(CONFIG_XPL_BUILD) && ctrlc()) return -EINTR; }
diff --git a/lib/uuid.c b/lib/uuid.c index 11b86ffb02e..c6a27b7d044 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -477,7 +477,7 @@ void gen_rand_uuid_str(char *uuid_str, int str_format) uuid_bin_to_str(uuid_bin, uuid_str, str_format); }
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_CMD_UUID) +#if !defined(CONFIG_XPL_BUILD) && defined(CONFIG_CMD_UUID) int do_uuid(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { char uuid[UUID_STR_LEN + 1]; diff --git a/net/bootp.c b/net/bootp.c index 512ab2ed7c8..afd5b48094a 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -434,7 +434,7 @@ static u8 *add_vci(u8 *e) char *vci = NULL; char *env_vci = env_get("bootp_vci");
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_NET_VCI_STRING) +#if defined(CONFIG_XPL_BUILD) && defined(CONFIG_SPL_NET_VCI_STRING) vci = CONFIG_SPL_NET_VCI_STRING; #elif defined(CONFIG_BOOTP_VCI_STRING) vci = CONFIG_BOOTP_VCI_STRING; diff --git a/net/net.c b/net/net.c index 1e0b7c85624..fd7d413e488 100644 --- a/net/net.c +++ b/net/net.c @@ -305,7 +305,7 @@ U_BOOT_ENV_CALLBACK(dnsip, on_dnsip); */ void net_auto_load(void) { -#if defined(CONFIG_CMD_NFS) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_NFS) && !defined(CONFIG_XPL_BUILD) const char *s = env_get("autoload");
if (s != NULL && strcmp(s, "NFS") == 0) { @@ -559,7 +559,7 @@ restart: ping6_start(); break; #endif -#if defined(CONFIG_CMD_NFS) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_NFS) && !defined(CONFIG_XPL_BUILD) case NFS: nfs_start(); break; @@ -574,7 +574,7 @@ restart: cdp_start(); break; #endif -#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_XPL_BUILD) case NETCONS: nc_start(); break; @@ -1439,7 +1439,7 @@ void net_process_received_packet(uchar *in_packet, int len) } }
-#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_NETCONSOLE) && !defined(CONFIG_XPL_BUILD) nc_input_packet((uchar *)ip + IP_UDP_HDR_SIZE, src_ip, ntohs(ip->udp_dst), diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 5daceb26061..b70b75ee68d 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -324,7 +324,7 @@ endif # do not delete intermediate files automatically .SECONDARY:
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD SPL_ := SPL_ ifeq ($(CONFIG_VPL_BUILD),y) SPL_TPL_ := VPL_ diff --git a/scripts/Makefile.xpl b/scripts/Makefile.xpl index ad21d451a30..63d4ec334bc 100644 --- a/scripts/Makefile.xpl +++ b/scripts/Makefile.xpl @@ -31,7 +31,7 @@ include $(srctree)/scripts/Kbuild.include UBOOTINCLUDE := -I$(obj)/include $(UBOOTINCLUDE)
KBUILD_CPPFLAGS += -DCONFIG_XPL_BUILD -KBUILD_CPPFLAGS += -DCONFIG_SPL_BUILD +KBUILD_CPPFLAGS += -DCONFIG_XPL_BUILD ifeq ($(CONFIG_TPL_BUILD),y) KBUILD_CPPFLAGS += -DCONFIG_TPL_BUILD else @@ -55,7 +55,7 @@ endif
export SPL_NAME
-ifdef CONFIG_SPL_BUILD +ifdef CONFIG_XPL_BUILD SPL_ := SPL_ ifeq ($(CONFIG_VPL_BUILD),y) SPL_TPL_ := VPL_ diff --git a/test/Makefile b/test/Makefile index ed312cd0a48..f801d87e385 100644 --- a/test/Makefile +++ b/test/Makefile @@ -25,7 +25,7 @@ obj-$(CONFIG_$(SPL_)CMDLINE) += str_ut.o obj-$(CONFIG_UT_TIME) += time_ut.o obj-y += ut.o
-ifeq ($(CONFIG_SPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD),) obj-y += boot/ obj-$(CONFIG_UNIT_TEST) += common/ obj-y += log/ diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 38ba89ee33e..53fddebd49d 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -256,7 +256,7 @@ U_BOOT_LONGHELP(ut, "\ntime - very basic test of time functions" #endif #if defined(CONFIG_UT_UNICODE) && \ - !defined(CONFIG_SPL_BUILD) && !defined(API_BUILD) + !defined(CONFIG_XPL_BUILD) && !defined(API_BUILD) "\nunicode - Unicode functions" #endif ); diff --git a/test/dm/Makefile b/test/dm/Makefile index c12589d487c..c6c63051e0b 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -7,7 +7,7 @@ obj-$(CONFIG_UT_DM) += test-dm.o
# Tests for particular subsystems - when enabling driver model for a new # subsystem you must add sandbox tests here. -ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_SPL_OF_PLATDATA) += of_platdata.o else obj-$(CONFIG_UT_DM) += bus.o diff --git a/test/lib/Makefile b/test/lib/Makefile index 70f14c46b1e..a54387a058e 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -2,7 +2,7 @@ # # (C) Copyright 2018 # Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc -ifeq ($(CONFIG_SPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD),) obj-y += cmd_ut_lib.o obj-y += abuf.o obj-y += alist.o diff --git a/test/test-main.c b/test/test-main.c index b3d3e24cdce..479dbb33b72 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -47,7 +47,7 @@ enum fdtchk_t { static enum fdtchk_t fdt_action(void) { /* For sandbox SPL builds, do nothing */ - if (IS_ENABLED(CONFIG_SANDBOX) && IS_ENABLED(CONFIG_SPL_BUILD)) + if (IS_ENABLED(CONFIG_SANDBOX) && IS_ENABLED(CONFIG_XPL_BUILD)) return FDTCHK_NONE;
/* Do a copy for sandbox (but only the U-Boot build, not SPL) */ diff --git a/tools/binman/test/generated/autoconf.h b/tools/binman/test/generated/autoconf.h index 6a23039f469..75af48f9116 100644 --- a/tools/binman/test/generated/autoconf.h +++ b/tools/binman/test/generated/autoconf.h @@ -1,3 +1,3 @@ #define CONFIG_BINMAN 1 -#define CONFIG_SPL_BUILD 1 +#define CONFIG_XPL_BUILD 1 #define CONFIG_SPL_BINMAN_SYMBOLS 1
Update the various references to SPL in this document. Make sure to refer to 'phases' instead of 'stages', which is not a U-Boot term.
Fix a few U-boot typos and try to improve grammar a little while we are here.
doc/develop/spl.rst | 81 ++++++++++++++++++++++++--------------------- 1 file changed, 43 insertions(+), 38 deletions(-)
diff --git a/doc/develop/spl.rst b/doc/develop/spl.rst index 4bb48e6b7b3..fba4a439d3a 100644 --- a/doc/develop/spl.rst +++ b/doc/develop/spl.rst @@ -1,11 +1,12 @@ -Generic SPL framework +Generic xPL framework =====================
Overview --------
-To unify all existing implementations for a secondary program loader (SPL) -and to allow simply adding of new implementations this generic SPL framework +To unify all existing implementations for secondary/tertiary program loaders +(generically called xPL) +and to allow simply adding of new implementations this generic xPL framework has been created. With this framework almost all source files for a board can be reused. No code duplication or symlinking is necessary anymore.
@@ -13,36 +14,39 @@ can be reused. No code duplication or symlinking is necessary anymore. How it works ------------
-The object files for SPL are built separately and placed in the "spl" directory. -The final binaries which are generated are u-boot-spl, u-boot-spl.bin and -u-boot-spl.map. +The object files for xPL are built separately and placed in a subdirectory +("spl", "tpl" or "vpl"). +The final binaries which are generated for SPL are u-boot-spl, u-boot-spl.bin +and u-boot-spl.map
-A config option named CONFIG_SPL_BUILD is enabled by Kconfig for SPL. -Source files can therefore be compiled for SPL with different settings. +A config option named CONFIG_XPL_BUILD is enabled by Kconfig for xPL builds. +Source files can therefore be compiled for xPL with different settings.
For example::
- ifeq ($(CONFIG_SPL_BUILD),y) + ifeq ($(CONFIG_XPL_BUILD),y) obj-y += board_spl.o else obj-y += board.o endif
- obj-$(CONFIG_SPL_BUILD) += foo.o + obj-$(CONFIG_XPL_BUILD) += foo.o
- #ifdef CONFIG_SPL_BUILD + if (IS_ENABLED(CONFIG_XPL_BUILD)) foo(); - #endif
+ if (spl_phase() == PHASE_TPL) + bar();
-The building of SPL images can be enabled by CONFIG_SPL option in Kconfig. +The building of xPL images can be enabled by CONFIG_SPL (etc.) options in +Kconfig.
-Because SPL images normally have a different text base, one has to be -configured by defining CONFIG_SPL_TEXT_BASE. The linker script has to be -defined with CONFIG_SPL_LDSCRIPT. +Because xPL images normally have a different text base, one has to be +configured by defining CONFIG_xPL_TEXT_BASE. The linker script has to be +defined with CONFIG_xPL_LDSCRIPT.
-To support generic U-Boot libraries and drivers in the SPL binary one can -optionally define CONFIG_SPL_XXX_SUPPORT. Currently following options +To support generic U-Boot libraries and drivers in the xPL binary one can +optionally define CONFIG_xPL_XXX_SUPPORT. Currently following options are supported:
CONFIG_SPL_LIBCOMMON_SUPPORT (common/libcommon.o) @@ -75,7 +79,7 @@ CONFIG_SPL_DM_GPIO (drivers/gpio/gpio-uclass.o) CONFIG_SPL_BMP (drivers/video/bmp.o) CONFIG_SPL_BLOBLIST (common/bloblist.o)
-Adding SPL-specific code +Adding xPL-specific code ------------------------
To check whether a feature is enabled, use CONFIG_IS_ENABLED():: @@ -90,7 +94,7 @@ U-Boot Boot Phases ------------------
U-Boot goes through the following boot phases where TPL, VPL, SPL are optional. -While many boards use SPL, less use TPL. +While many boards use SPL, fewer use TPL.
TPL Very early init, as tiny as possible. This loads SPL (or VPL if enabled). @@ -177,29 +181,30 @@ files instead introduces another set of headaches. These warnings are not usually important to understanding the flow, however.
-Reserving memory in SPL +Reserving memory in xPL -----------------------
-If memory needs to be reserved in RAM during SPL stage with the requirement that -the SPL reserved memory remains preserved across further boot stages too +If memory needs to be reserved in RAM during an xPL phase with the requirement +that the xPL reserved memory remains preserved across further boot phases too then it needs to be reserved mandatorily starting from end of RAM. This is to -ensure that further stages can simply skip this region before carrying out +ensure that further phases can simply skip this region before carrying out further reservations or updating the relocation address.
-Also out of these regions which are to be preserved across further stages of +Also out of these regions which are to be preserved across further phases of boot, video framebuffer memory region must be reserved first starting from -end of RAM for which helper function spl_reserve_video_from_ram_top is provided -which makes sure that video memory is placed at top of reservation area with +end of RAM for which the helper function spl_reserve_video_from_ram_top() is +provided +which makes sure that video memory is placed at the top of reservation area with further reservations below it.
-The corresponding information of reservation for those regions can be passed to -further boot stages using a bloblist. For e.g. the information for -framebuffer area reserved by SPL can be passed onto U-boot using -BLOBLISTT_U_BOOT_VIDEO. - -The further boot stages need to parse each of the bloblist passed from SPL stage -starting from video bloblist and skip this whole SPL reserved memory area from -end of RAM as per the bloblists received, before carrying out further -reservations or updating the relocation address. For e.g, U-boot proper uses -function "setup_relocaddr_from_bloblist" to parse the bloblists passed from -previous stage and skip the memory reserved from previous stage accordingly. +The reservation information for these regions can be passed to the +further boot phases using a bloblist. For e.g. the information for the +framebuffer area reserved by xPL can be passed onto U-Boot using +BLOBLISTT_U_BOOT_VIDEO + +The further boot phases need to parse each of the blobs passed from xPL phase +starting from video bloblist and skip this whole xPL reserved-memory area from +end of RAM as per the blobs received, before carrying out further +reservations or updating the relocation address. For e.g, U-Boot proper uses +function setup_relocaddr_from_bloblist() to parse the bloblist passed from +previous phase and skip the memory reserved from previous phase accordingly.
SPL_BUILD is not a Kconfig symbol. Perhaps the intent here is to use SPL instead. However, this causes build errors, e.g. with T1024RDB_NAND
So drop the dependency on !SPL_BUILD since it does nothing.
drivers/net/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index e7d0ddfe25a..403d7e1c679 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -891,7 +891,7 @@ config FEC2_PHY_NORXERR
config SYS_DPAA_QBMAN bool "Device tree fixup for QBMan on freescale SOCs" - depends on (ARM || PPC) && !SPL_BUILD + depends on ARM || PPC default y if ARCH_B4860 || \ ARCH_B4420 || \ ARCH_P1023 || \
This uses XPL now, so update the comment.
arch/x86/cpu/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index fbd23af6ce9..ea11b09eacc 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -247,7 +247,7 @@ static int last_stage_init(void) } EVENT_SPY_SIMPLE(EVT_LAST_STAGE_INIT, last_stage_init);
-#endif /* !SYS_COREBOOT && !EFI_STUB && !SPL_BUILD */ +#endif /* !SYS_COREBOOT && !EFI_STUB && !XPL_BUILD */
static int x86_init_cpus(void) {
SPL_BUILD is not a Kconfig symbol so presumably the intent here is to use SPL instead. Change it.
arch/arm/mach-tegra/tegra124/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index fb016aa46c9..61bebc10a97 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -21,8 +21,8 @@ config TARGET_CEI_TK1_SOM bool "Colorado Engineering Inc Tegra124 TK1-som board" select ARCH_SUPPORT_PSCI select BOARD_LATE_INIT - select CPU_V7_HAS_NONSEC if !SPL_BUILD - select CPU_V7_HAS_VIRT if !SPL_BUILD + select CPU_V7_HAS_NONSEC if !SPL + select CPU_V7_HAS_VIRT if !SPL help The Colorado Engineering Tegra TK1-SOM is a very compact (51mmx58mm) board that is functionally almost the same as
This should now refer to xPL rather than SPL, so update it throughout the tree.
arch/arm/lib/cache.c | 2 +- doc/develop/logging.rst | 2 +- drivers/spi/spi-uclass.c | 4 ++-- include/log.h | 10 +++++----- 4 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index b2ae74a59f1..cac2159fe1a 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -62,7 +62,7 @@ int check_cache_range(unsigned long start, unsigned long stop) ok = 0;
if (!ok) { - warn_non_spl("CACHE: Misaligned operation at range [%08lx, %08lx]\n", + warn_non_xpl("CACHE: Misaligned operation at range [%08lx, %08lx]\n", start, stop); }
diff --git a/doc/develop/logging.rst b/doc/develop/logging.rst index 704a6bf1d84..d7a40c94bf0 100644 --- a/doc/develop/logging.rst +++ b/doc/develop/logging.rst @@ -292,7 +292,7 @@ Convert debug() statements in the code to log() statements
Convert error() statements in the code to log() statements
-Figure out what to do with BUG(), BUG_ON() and warn_non_spl() +Figure out what to do with BUG(), BUG_ON() and warn_non_xpl()
Add a way to browse log records
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 6e281725239..f6efebd2e90 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -538,7 +538,7 @@ int spi_slave_of_to_plat(struct udevice *dev, struct dm_spi_slave_plat *plat) mode |= SPI_TX_OCTAL; break; default: - warn_non_spl("spi-tx-bus-width %d not supported\n", value); + warn_non_xpl("spi-tx-bus-width %d not supported\n", value); break; }
@@ -556,7 +556,7 @@ int spi_slave_of_to_plat(struct udevice *dev, struct dm_spi_slave_plat *plat) mode |= SPI_RX_OCTAL; break; default: - warn_non_spl("spi-rx-bus-width %d not supported\n", value); + warn_non_xpl("spi-rx-bus-width %d not supported\n", value); break; }
diff --git a/include/log.h b/include/log.h index 371f99d82e7..bf81a27011f 100644 --- a/include/log.h +++ b/include/log.h @@ -247,9 +247,9 @@ int _log_buffer(enum log_category_t cat, enum log_level_t level, #endif
#ifdef CONFIG_XPL_BUILD -#define _SPL_BUILD 1 +#define _XPL_BUILD 1 #else -#define _SPL_BUILD 0 +#define _XPL_BUILD 0 #endif
#if CONFIG_IS_ENABLED(LOG) @@ -281,9 +281,9 @@ int _log_buffer(enum log_category_t cat, enum log_level_t level, #define debug(fmt, args...) \ debug_cond(_DEBUG, fmt, ##args)
-/* Show a message if not in SPL */ -#define warn_non_spl(fmt, args...) \ - debug_cond(!_SPL_BUILD, fmt, ##args) +/* Show a message if not in xPL */ +#define warn_non_xpl(fmt, args...) \ + debug_cond(!_XPL_BUILD, fmt, ##args)
/* * An assertion is run-time check done in debug mode only. If DEBUG is not
This now appears in the code base, so add it to the list of ignored symbols in qconfig
tools/qconfig.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/qconfig.py b/tools/qconfig.py index 8c2fc9efc5f..71e911eeb3b 100755 --- a/tools/qconfig.py +++ b/tools/qconfig.py @@ -77,7 +77,7 @@ IGNORE_SYMS = ['DEBUG_SECTION_MISMATCH', 'FTRACE_MCOUNT_RECORD', 'GCOV_KERNEL', 'IS_ENABLED_', 'IS_ENABLED_1', 'IS_ENABLED_2', 'IS_ENABLED_3', 'SPL_', 'TPL_', 'SPL_FOO', 'TPL_FOO', 'TOOLS_FOO', 'ACME', 'SPL_ACME', 'TPL_ACME', 'TRACE_BRANCH_PROFILING', - 'VAL', '_UNDEFINED', 'SPL_BUILD', ] + 'VAL', '_UNDEFINED', 'SPL_BUILD', 'XPL_BUILD', ]
SPL_PREFIXES = ['SPL_', 'TPL_', 'VPL_', 'TOOLS_']
Use the normal SPL_TPL_ approach for this option.
boot/Makefile | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/boot/Makefile b/boot/Makefile index 299a22ed689..5bf07e83388 100644 --- a/boot/Makefile +++ b/boot/Makefile @@ -58,9 +58,7 @@ obj-$(CONFIG_$(SPL_TPL_)FIT_CIPHER) += image-cipher.o
obj-$(CONFIG_CMD_ADTIMG) += image-android-dt.o
-ifdef CONFIG_SPL_BUILD -obj-$(CONFIG_SPL_LOAD_FIT) += common_fit.o -endif +obj-$(CONFIG_$(SPL_TPL_)LOAD_FIT) += common_fit.o
obj-$(CONFIG_$(SPL_TPL_)EXPO) += expo.o scene.o expo_build.o obj-$(CONFIG_$(SPL_TPL_)EXPO) += scene_menu.o scene_textline.o
Make this define mean SPL only, not TPL, VPL, etc.
scripts/Makefile.autoconf | 4 ++-- scripts/Makefile.xpl | 9 ++++++--- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index d7544022a31..c1eab2f3a1d 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -87,11 +87,11 @@ spl/u-boot.cfg: include/config.h FORCE
tpl/u-boot.cfg: include/config.h FORCE $(Q)mkdir -p $(dir $@) - $(call cmd,u_boot_cfg,-DCONFIG_XPL_BUILD -DCONFIG_SPL_BUILD -DCONFIG_TPL_BUILD) + $(call cmd,u_boot_cfg,-DCONFIG_XPL_BUILD -DCONFIG_TPL_BUILD)
vpl/u-boot.cfg: include/config.h FORCE $(Q)mkdir -p $(dir $@) - $(call cmd,u_boot_cfg,-DCONFIG_XPL_BUILD -DCONFIG_SPL_BUILD -DCONFIG_VPL_BUILD) + $(call cmd,u_boot_cfg,-DCONFIG_XPL_BUILD -DCONFIG_VPL_BUILD)
include/autoconf.mk: u-boot.cfg $(call cmd,autoconf) diff --git a/scripts/Makefile.xpl b/scripts/Makefile.xpl index 63d4ec334bc..b43ff998679 100644 --- a/scripts/Makefile.xpl +++ b/scripts/Makefile.xpl @@ -21,9 +21,10 @@ include $(srctree)/scripts/Kbuild.include
-include include/config/auto.conf
-# This file contains 0, 2 or 3 lines +# This file contains 0, or 2 lines # It is empty for U-Boot proper (where $(obj) is empty) -# For any xPL build it contains CONFIG_SPL_BUILD=y and CONFIG_XPL_BUILD=y +# For any xPL build it contains CONFIG_XPL_BUILD=y +# - for SPL builds it also contains CONFIG_SPL_BUILD=y # - for TPL builds it also contains CONFIG_TPL_BUILD=y # - for VPL builds it also contains CONFIG_VPL_BUILD=y -include $(obj)/include/autoconf.mk @@ -31,7 +32,9 @@ include $(srctree)/scripts/Kbuild.include UBOOTINCLUDE := -I$(obj)/include $(UBOOTINCLUDE)
KBUILD_CPPFLAGS += -DCONFIG_XPL_BUILD -KBUILD_CPPFLAGS += -DCONFIG_XPL_BUILD +ifeq ($(CONFIG_SPL_BUILD),y) +KBUILD_CPPFLAGS += -DCONFIG_SPL_BUILD +endif ifeq ($(CONFIG_TPL_BUILD),y) KBUILD_CPPFLAGS += -DCONFIG_TPL_BUILD else
Now that SPL means SPL (only) and is not defined for TPL, simplify some checks for SPL.
arch/arm/include/asm/arch-rockchip/boot0.h | 3 +-- arch/arm/mach-rockchip/rk3399/rk3399.c | 2 +- drivers/clk/rockchip/clk_rk3368.c | 8 ++++---- drivers/ram/rockchip/sdram_rk3288.c | 10 +++++----- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/ram/rockchip/sdram_rv1126.c | 9 +++------ 6 files changed, 15 insertions(+), 19 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/boot0.h b/arch/arm/include/asm/arch-rockchip/boot0.h index edb2a31c348..918f0495fa0 100644 --- a/arch/arm/include/asm/arch-rockchip/boot0.h +++ b/arch/arm/include/asm/arch-rockchip/boot0.h @@ -54,7 +54,6 @@ _start: ARM_VECTORS #endif
-#if !defined(CONFIG_TPL_BUILD) && defined(CONFIG_XPL_BUILD) && \ - (CONFIG_ROCKCHIP_SPL_RESERVE_IRAM > 0) +#if defined(CONFIG_SPL_BUILD) && (CONFIG_ROCKCHIP_SPL_RESERVE_IRAM > 0) .space CONFIG_ROCKCHIP_SPL_RESERVE_IRAM /* space for the ATF data */ #endif diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index edccb2a3980..47bcc71038b 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -169,7 +169,7 @@ void board_debug_uart_init(void) } #endif
-#if defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) +#if defined(CONFIG_SPL_BUILD) static void rk3399_force_power_on_reset(void) { ofnode node; diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 630253fbb1d..5ba19bce7b2 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -50,7 +50,7 @@ struct pll_div { (_nr * _no) == hz, #hz "Hz cannot be hit with PLL " \ "divisors on line " __stringify(__LINE__));
-#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) static const struct pll_div apll_l_init_cfg = PLL_DIVISORS(APLL_L_HZ, 12, 2); static const struct pll_div apll_b_init_cfg = PLL_DIVISORS(APLL_B_HZ, 1, 2); #if !defined(CONFIG_TPL_BUILD) @@ -88,7 +88,7 @@ static uint32_t rkclk_pll_get_rate(struct rk3368_cru *cru, } }
-#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id, const struct pll_div *div) { @@ -130,7 +130,7 @@ static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id, } #endif
-#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) static void rkclk_init(struct rk3368_cru *cru) { u32 apllb, aplll, dpll, cpll, gpll; @@ -586,7 +586,7 @@ static int rk3368_clk_probe(struct udevice *dev)
priv->cru = map_sysmem(plat->dtd.reg[0], plat->dtd.reg[1]); #endif -#if IS_ENABLED(CONFIG_XPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) +#if IS_ENABLED(CONFIG_XPL_BUILD) rkclk_init(priv->cru); #endif
diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index 25ceab98ee9..b6d51068baa 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -84,7 +84,7 @@ const int ddrconf_table[] = { #define DQS_GATE_TRAINING_ERROR_RANK1 (2 << 4)
#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) static void copy_to_reg(u32 *dest, const u32 *src, u32 n) { int i; @@ -1041,7 +1041,7 @@ static int conv_of_plat(struct udevice *dev) static int rk3288_dmc_probe(struct udevice *dev) { #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) struct rk3288_sdram_params *plat = dev_get_plat(dev); struct udevice *dev_clk; struct regmap *map; @@ -1051,7 +1051,7 @@ static int rk3288_dmc_probe(struct udevice *dev)
priv->pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU); #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) #if CONFIG_IS_ENABLED(OF_PLATDATA) ret = conv_of_plat(dev); if (ret) @@ -1119,13 +1119,13 @@ U_BOOT_DRIVER(rockchip_rk3288_dmc) = { .of_match = rk3288_dmc_ids, .ops = &rk3288_dmc_ops, #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) .of_to_plat = rk3288_dmc_of_to_plat, #endif .probe = rk3288_dmc_probe, .priv_auto = sizeof(struct dram_info), #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) .plat_auto = sizeof(struct rk3288_sdram_params), #endif }; diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index c3745f9445b..45270e27184 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3196,7 +3196,7 @@ U_BOOT_DRIVER(dmc_rk3399) = { .probe = rk3399_dmc_probe, .priv_auto = sizeof(struct dram_info), #if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) .plat_auto = sizeof(struct rockchip_dmc_plat), #endif }; diff --git a/drivers/ram/rockchip/sdram_rv1126.c b/drivers/ram/rockchip/sdram_rv1126.c index b371f597d23..58fd589f68e 100644 --- a/drivers/ram/rockchip/sdram_rv1126.c +++ b/drivers/ram/rockchip/sdram_rv1126.c @@ -33,8 +33,7 @@ #define DESKEW_MDF_DIFF_VAL (1)
struct dram_info { -#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) +#if defined(CONFIG_TPL_BUILD) || defined(CONFIG_SPL_BUILD) void __iomem *pctl; void __iomem *phy; struct rv1126_cru *cru; @@ -48,8 +47,7 @@ struct dram_info { struct rv1126_pmugrf *pmugrf; };
#define GRF_BASE_ADDR 0xfe000000 #define PMU_GRF_BASE_ADDR 0xfe020000 @@ -3506,8 +3504,7 @@ error:
static int rv1126_dmc_probe(struct udevice *dev) { -#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_XPL_BUILD)) +#if defined(CONFIG_TPL_BUILD) || defined(CONFIG_SPL_BUILD) if (rv1126_dmc_init(dev)) return 0; #else
Hi Simon,
This was changed from SPL to XPL just to be changed back to SPL in this patch?, such change probably just clutter git blame, was the change to use XPL really necessary in the first place?
Because SPL_BUILD was used together with !TPL_BUILD it is pretty obvious that SPL_BUILD did not need to change to XPL_BUILD in the first place.
Same.
- (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD))
Same.
Same.
Same.
Same.
Same.
Same.
This changes meaning of the code, similar to other rockchip sdram code this should only change CONFIG_XPL_BUILD back to CONFIG_SPL_BUILD.
DRAM on rockchip platform is initialized by TPL, or SPL when CONFIG_TPL is not enabled, not both in TPL and SPL.
Same.
Same.
Regards, Jonas
On Fri, Sep 27, 2024 at 02:13:32AM +0200, Jonas Karlman wrote:
Hi Simon,
This comment applies more globally to the series too. Once you have the knowledge of when "SPL_BUILD is just building for SPL" reworking things in light of that will make an easier to review series I believe.
Hi Jonas,
On Thu, 26 Sept 2024 at 18:13, Jonas Karlman jonas@kwiboo.se wrote:
Hi Simon,
Yes this is a bit of a corner case.
For the first patch, CONFIG_SPL_BUILD is defined for any 'SPL' build. For the second it is defined only for SPL. So in this case, yes, it doesn't matter. But across the whole of U-Boot, it does.
I got pretty deep down the rabbit hole on this one, and perhaps should not have gone ahead with the 'clean-up'. So I think we can just drop this patch. I'll look at what others might be dropped too.
arch/mips/mach-mtmips/mt7621/Makefile | 11 ++--------- 1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/arch/mips/mach-mtmips/mt7621/Makefile b/arch/mips/mach-mtmips/mt7621/Makefile index f48083e3559..3ddd6771051 100644 --- a/arch/mips/mach-mtmips/mt7621/Makefile +++ b/arch/mips/mach-mtmips/mt7621/Makefile @@ -3,12 +3,5 @@ obj-y += init.o obj-y += serial.o
-ifeq ($(CONFIG_XPL_BUILD),y) -ifeq ($(CONFIG_TPL_BUILD),y) -obj-y += tpl/ -else -obj-y += spl/ -endif - -obj-y += sram_init.o -endif +obj-$(CONFIG_SPL_BUILD) += spl/ sram_init.o +obj-$(CONFIG_TPL_BUILD) += tpl/ sram_init.o
arch/powerpc/cpu/mpc83xx/Makefile | 4 +--- arch/powerpc/lib/Makefile | 4 +--- 2 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/Makefile b/arch/powerpc/cpu/mpc83xx/Makefile index 9974239f881..7c4ef7657e5 100644 --- a/arch/powerpc/cpu/mpc83xx/Makefile +++ b/arch/powerpc/cpu/mpc83xx/Makefile @@ -7,13 +7,11 @@
MINIMAL=
-ifdef CONFIG_XPL_BUILD -ifndef CONFIG_TPL_BUILD +ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_INIT_MINIMAL MINIMAL=y endif endif -endif
extra-y = start.o
diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index f797f8cee66..b218ae2b91c 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -9,13 +9,11 @@ lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _lshrdi3.o
MINIMAL=
obj-y += bdinfo.o
arch/x86/cpu/apollolake/fsp_bindings.c | 2 +- arch/x86/cpu/broadwell/cpu_full.c | 2 +- arch/x86/lib/Makefile | 9 ++------- 3 files changed, 4 insertions(+), 9 deletions(-)
diff --git a/arch/x86/cpu/apollolake/fsp_bindings.c b/arch/x86/cpu/apollolake/fsp_bindings.c index b4bb677f5cd..4b0756e77cc 100644 --- a/arch/x86/cpu/apollolake/fsp_bindings.c +++ b/arch/x86/cpu/apollolake/fsp_bindings.c @@ -653,7 +653,7 @@ int fsp_m_update_config_from_dtb(ofnode node, struct fsp_m_config *cfg) } #endif
-#if !defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) +#if !defined(CONFIG_SPL_BUILD) const struct fsp_binding fsp_s_bindings[] = { { .type = FSP_UINT8, diff --git a/arch/x86/cpu/broadwell/cpu_full.c b/arch/x86/cpu/broadwell/cpu_full.c index 529dab18d5d..46a6436be54 100644 --- a/arch/x86/cpu/broadwell/cpu_full.c +++ b/arch/x86/cpu/broadwell/cpu_full.c @@ -84,7 +84,7 @@ static const u8 power_limit_time_msr_to_sec[] = { [0x11] = 128, };
-#if defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) +#if defined(CONFIG_SPL_BUILD) int arch_cpu_init(void) { return 0; diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 2738f0b577b..bf0605ad662 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -58,13 +58,8 @@ obj-$(CONFIG_FSP_VERSION1) += fsp1/ obj-$(CONFIG_FSP_VERSION2) += fsp2/ endif
-ifdef CONFIG_XPL_BUILD -ifdef CONFIG_TPL_BUILD -obj-y += tpl.o -else -obj-y += spl.o -endif -endif +obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_TPL_BUILD) += tpl.o
lib-$(CONFIG_USE_PRIVATE_LIBGCC) += div64.o
board/congatec/common/Makefile | 4 +--- board/freescale/common/Makefile | 4 +--- board/freescale/p1010rdb/Makefile | 4 +--- board/freescale/p1_p2_rdb_pc/Makefile | 4 +--- 4 files changed, 4 insertions(+), 12 deletions(-)
diff --git a/board/congatec/common/Makefile b/board/congatec/common/Makefile index f8170d9c653..d4ddfbf9716 100644 --- a/board/congatec/common/Makefile +++ b/board/congatec/common/Makefile @@ -7,13 +7,11 @@
MINIMAL=
ifdef MINIMAL # necessary to create built-in.o diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index c491dc8b241..0e1dec49238 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -5,13 +5,11 @@
MINIMAL=
ifdef MINIMAL # necessary to create built-in.o diff --git a/board/freescale/p1010rdb/Makefile b/board/freescale/p1010rdb/Makefile index df4e8001d38..c56ed82cb50 100644 --- a/board/freescale/p1010rdb/Makefile +++ b/board/freescale/p1010rdb/Makefile @@ -4,13 +4,11 @@
MINIMAL=
ifdef MINIMAL obj-y += spl_minimal.o diff --git a/board/freescale/p1_p2_rdb_pc/Makefile b/board/freescale/p1_p2_rdb_pc/Makefile index 8c13813e3b0..38f2f53ff03 100644 --- a/board/freescale/p1_p2_rdb_pc/Makefile +++ b/board/freescale/p1_p2_rdb_pc/Makefile @@ -4,13 +4,11 @@
MINIMAL=
drivers/mtd/Makefile | 2 +- drivers/mtd/nand/Makefile | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index db010417b86..2388d2aa27c 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -16,7 +16,7 @@ mtd-$(CONFIG_RENESAS_RPC_HF) += renesas_rpc_hf.o mtd-$(CONFIG_HBMC_AM654) += hbmc-am654.o
# U-Boot build -ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD),)
ifneq ($(mtd-y),) obj-y += mtd.o diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 68b53dced1b..ad02095b35b 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD),) nandcore-objs := core.o bbt.o obj-$(CONFIG_MTD_NAND_CORE) += nandcore.o obj-$(CONFIG_MTD_RAW_NAND) += raw/
drivers/core/ofnode.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 129b34a5cd2..1ea6dd0e58a 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1468,7 +1468,7 @@ int ofnode_read_simple_size_cells(ofnode node)
bool ofnode_pre_reloc(ofnode node) { -#if defined(CONFIG_XPL_BUILD) || defined(CONFIG_TPL_BUILD) +#if defined(CONFIG_XPL_BUILD) /* for SPL and TPL the remaining nodes after the fdtgrep 1st pass * had property bootph-all or bootph-pre-sram/bootph-pre-ram. * They are removed in final dtb (fdtgrep 2nd pass)
include/spl.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/spl.h b/include/spl.h index dd9aeeaf9cc..415d198da56 100644 --- a/include/spl.h +++ b/include/spl.h @@ -90,7 +90,7 @@ enum u_boot_phase { * * To include code only in SPL, you might do: * - * #if defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) + * #if defined(CONFIG_SPL_BUILD) * ... * #endif * @@ -120,7 +120,7 @@ static inline enum u_boot_phase spl_phase(void) return PHASE_TPL; #elif defined(CONFIG_VPL_BUILD) return PHASE_VPL; -#elif defined(CONFIG_XPL_BUILD) +#elif defined(CONFIG_SPL_BUILD) return PHASE_SPL; #else DECLARE_GLOBAL_DATA_PTR; @@ -154,7 +154,7 @@ static inline enum u_boot_phase spl_prev_phase(void) return PHASE_NONE; #elif defined(CONFIG_VPL_BUILD) return PHASE_TPL; /* VPL requires TPL */ -#elif defined(CONFIG_XPL_BUILD) +#elif defined(CONFIG_SPL_BUILD) return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : IS_ENABLED(CONFIG_TPL) ? PHASE_TPL : PHASE_NONE;
This variable does not exist so the condition will never be met. Fix it.
arch/powerpc/lib/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index b218ae2b91c..64ac4930b62 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -44,5 +44,5 @@ obj-y += traps.o endif # not minimal
ifdef CONFIG_XPL_BUILD -obj-$(CONFIG_$(SPL_TPL)_FRAMEWORK) += spl.o +obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o endif
This is always enabled for U-Boot proper, so simplify the condition in the common Makefile.
common/Makefile | 10 +--------- 1 file changed, 1 insertion(+), 9 deletions(-)
diff --git a/common/Makefile b/common/Makefile index 9fdad4bc38d..ae8984659c0 100644 --- a/common/Makefile +++ b/common/Makefile @@ -65,15 +65,7 @@ obj-$(CONFIG_DDR_SPD) += ddr_spd.o obj-$(CONFIG_SPD_EEPROM) += ddr_spd.o obj-$(CONFIG_HWCONFIG) += hwconfig.o obj-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o -ifdef CONFIG_XPL_BUILD -ifdef CONFIG_TPL_BUILD -obj-$(CONFIG_TPL_SERIAL) += console.o -else -obj-$(CONFIG_SPL_SERIAL) += console.o -endif -else -obj-y += console.o -endif # CONFIG_XPL_BUILD +obj-$(CONFIG_$(SPL_TPL_)SERIAL) += console.o
obj-$(CONFIG_CROS_EC) += cros_ec.o obj-y += dlmalloc.o
include/stdio.h | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/include/stdio.h b/include/stdio.h index 56609b846ff..d42fdd2728c 100644 --- a/include/stdio.h +++ b/include/stdio.h @@ -9,10 +9,7 @@ int getchar(void); int tstc(void);
/* stdout */ -#if !defined(CONFIG_XPL_BUILD) || \ - (defined(CONFIG_TPL_BUILD) && defined(CONFIG_TPL_SERIAL)) || \ - (defined(CONFIG_XPL_BUILD) && !defined(CONFIG_TPL_BUILD) && \ - defined(CONFIG_SPL_SERIAL)) +#if !defined(CONFIG_XPL_BUILD) || CONFIG_IS_ENABLED(SERIAL) void putc(const char c); void puts(const char *s); #ifdef CONFIG_CONSOLE_FLUSH_SUPPORT
The extra ifdefs can be avoided now. Tidy up this Makefile
drivers/Makefile | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/Makefile b/drivers/Makefile index 1b7db812828..260bde957db 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -45,9 +45,7 @@ obj-$(CONFIG_$(SPL_)VIDEO) += video/
obj-y += bus/
-ifndef CONFIG_TPL_BUILD -ifndef CONFIG_VPL_BUILD -ifdef CONFIG_XPL_BUILD +ifdef CONFIG_SPL_BUILD
obj-$(CONFIG_SPL_CPU) += cpu/ obj-$(CONFIG_SPL_CRYPTO) += crypto/ @@ -70,8 +68,6 @@ obj-$(CONFIG_SPL_SATA) += ata/ scsi/ obj-$(CONFIG_SPL_LEGACY_BLOCK) += block/ obj-$(CONFIG_SPL_THERMAL) += thermal/
-endif -endif endif
ifdef CONFIG_TPL_BUILD @@ -80,7 +76,7 @@ obj-$(CONFIG_TPL_MPC8XXX_INIT_DDR) += ddr/fsl/
endif
obj-y += ata/ obj-$(CONFIG_DM_DEMO) += demo/
Now that SPL means SPL (only) and is not defined for other phases, update kconfig rules.
include/linux/kconfig.h | 10 +++++----- tools/binman/test/generated/autoconf.h | 2 +- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index a59f2a61e6a..ec9584b2426 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -40,7 +40,7 @@ #define _CONFIG_PREFIX TPL_ #elif defined(CONFIG_VPL_BUILD) #define _CONFIG_PREFIX VPL_ -#elif defined(CONFIG_XPL_BUILD) +#elif defined(CONFIG_SPL_BUILD) #define _CONFIG_PREFIX SPL_ #else #define _CONFIG_PREFIX @@ -54,7 +54,7 @@ * CONFIG_VAL(FOO) evaluates to the value of * CONFIG_TOOLS_FOO if USE_HOSTCC is defined, * CONFIG_FOO if CONFIG_XPL_BUILD is undefined, - * CONFIG_SPL_FOO if CONFIG_XPL_BUILD is defined. + * CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. * CONFIG_TPL_FOO if CONFIG_TPL_BUILD is defined. * CONFIG_VPL_FOO if CONFIG_VPL_BUILD is defined. */ @@ -107,21 +107,21 @@ long invalid_use_of_IF_ENABLED_INT(void); * CONFIG_IS_ENABLED(FOO) expands to * 1 if USE_HOSTCC is defined and CONFIG_TOOLS_FOO is set to 'y', * 1 if CONFIG_XPL_BUILD is undefined and CONFIG_FOO is set to 'y', - * 1 if CONFIG_XPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', + * 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * 1 if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * 0 otherwise. * * CONFIG_IS_ENABLED(FOO, (abc)) expands to * abc if USE_HOSTCC is defined and CONFIG_TOOLS_FOO is set to 'y', * abc if CONFIG_XPL_BUILD is undefined and CONFIG_FOO is set to 'y', - * abc if CONFIG_XPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', + * abc if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * abc if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * nothing otherwise. * * CONFIG_IS_ENABLED(FOO, (abc), (def)) expands to * abc if USE_HOSTCC is defined and CONFIG_TOOLS_FOO is set to 'y', * abc if CONFIG_XPL_BUILD is undefined and CONFIG_FOO is set to 'y', - * abc if CONFIG_XPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', + * abc if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y', * abc if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y', * def otherwise. * diff --git a/tools/binman/test/generated/autoconf.h b/tools/binman/test/generated/autoconf.h index 75af48f9116..6a23039f469 100644 --- a/tools/binman/test/generated/autoconf.h +++ b/tools/binman/test/generated/autoconf.h @@ -1,3 +1,3 @@ #define CONFIG_BINMAN 1 -#define CONFIG_XPL_BUILD 1 +#define CONFIG_SPL_BUILD 1 #define CONFIG_SPL_BINMAN_SYMBOLS 1
If TPL is enabled, XPL must be, do drop the redundant check.
arch/arm/mach-rockchip/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 76756c3661b..70f0af4733c 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -15,7 +15,7 @@ obj-tpl-$(CONFIG_ROCKCHIP_PX30) += px30-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o
# Always include boot_mode.o, as we bypass it (i.e. turn it off) # inside of boot_mode.c when CONFIG_ROCKCHIP_BOOT_MODE_REG is 0. This way,
If TPL is enabled, XPL must be, so drop the redundant check.
drivers/bus/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/bus/Makefile b/drivers/bus/Makefile index e14cb7fd9c7..b7e6452c48c 100644 --- a/drivers/bus/Makefile +++ b/drivers/bus/Makefile @@ -3,7 +3,7 @@ # Makefile for the bus drivers. #
-ifeq ($(CONFIG_XPL_BUILD)$(CONFIG_TPL_BUILD),) +ifeq ($(CONFIG_XPL_BUILD),) obj-$(CONFIG_TI_PWMSS) += ti-pwmss.o obj-$(CONFIG_UNIPHIER_SYSTEM_BUS) += uniphier-system-bus.o endif
Use XPL_ as the symbol to indicate an SPL build. This means that SPL_ is no-longer set.
Makefile | 4 +-- arch/arm/config.mk | 6 ++-- arch/arm/cpu/arm920t/Makefile | 2 +- arch/arm/cpu/arm926ejs/Makefile | 2 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv8/Makefile | 4 +-- arch/arm/lib/Makefile | 2 +- arch/arm/mach-at91/arm926ejs/Makefile | 2 +- arch/arm/mach-imx/Makefile | 2 +- arch/arm/mach-omap2/am33xx/Makefile | 2 +- arch/arm/mach-orion5x/Makefile | 4 +-- arch/arm/mach-stm32mp/stm32mp1/Makefile | 2 +- arch/arm/mach-tegra/Makefile | 2 +- arch/arm/mach-tegra/tegra20/Makefile | 2 +- arch/arm/mach-tegra/tegra30/Makefile | 2 +- arch/arm/mach-zynqmp/Makefile | 2 +- arch/riscv/Makefile | 2 +- arch/riscv/lib/Makefile | 8 ++--- arch/x86/Makefile | 2 +- arch/x86/cpu/Makefile | 12 +++---- arch/x86/cpu/intel_common/Makefile | 4 +-- arch/x86/cpu/ivybridge/Makefile | 6 ++-- arch/x86/cpu/qemu/Makefile | 2 +- arch/x86/lib/Makefile | 4 +-- board/bosch/guardian/Makefile | 2 +- board/freescale/common/Makefile | 4 +-- board/st/common/Makefile | 2 +- board/tcl/sl50/Makefile | 2 +- board/ti/am335x/Makefile | 2 +- board/ti/am43xx/Makefile | 2 +- board/vscom/baltos/Makefile | 2 +- board/xilinx/zynqmp/Makefile | 2 +- boot/Makefile | 2 +- cmd/Makefile | 2 +- doc/develop/tests_writing.rst | 6 ++-- drivers/Makefile | 14 ++++---- drivers/ata/Makefile | 2 +- drivers/block/Makefile | 2 +- drivers/bus/Makefile | 2 +- drivers/core/Makefile | 6 ++-- drivers/ddr/altera/Makefile | 2 +- drivers/dfu/Makefile | 16 ++++----- drivers/firmware/Makefile | 2 +- drivers/gpio/Makefile | 8 ++--- drivers/i2c/Makefile | 16 ++++----- drivers/led/Makefile | 2 +- drivers/mailbox/Makefile | 2 +- drivers/misc/Makefile | 10 +++--- drivers/mmc/Makefile | 6 ++-- drivers/mux/Makefile | 2 +- drivers/nvme/Makefile | 2 +- drivers/phy/Makefile | 6 ++-- drivers/phy/cadence/Makefile | 4 +-- drivers/phy/ti/Makefile | 2 +- drivers/pinctrl/Makefile | 8 ++--- drivers/power/domain/Makefile | 2 +- drivers/power/pmic/Makefile | 30 ++++++++-------- drivers/power/regulator/Makefile | 46 ++++++++++++------------- drivers/remoteproc/Makefile | 2 +- drivers/serial/Makefile | 2 +- drivers/timer/Makefile | 8 ++--- drivers/usb/cdns3/Makefile | 4 +-- drivers/usb/common/Makefile | 2 +- drivers/usb/dwc3/Makefile | 4 +-- drivers/usb/gadget/udc/Makefile | 4 +-- drivers/usb/host/Makefile | 2 +- drivers/video/Makefile | 2 +- drivers/video/tidss/Makefile | 2 +- fs/fat/Makefile | 4 +-- fs/squashfs/Makefile | 2 +- lib/Makefile | 28 +++++++-------- lib/acpi/Makefile | 8 ++--- lib/aes/Makefile | 2 +- lib/crypto/Makefile | 14 ++++---- lib/ecdsa/Makefile | 2 +- net/Makefile | 6 ++-- scripts/Kbuild.include | 4 +-- scripts/Makefile.xpl | 4 +-- test/Makefile | 22 ++++++------ test/fuzz/Makefile | 2 +- tools/qconfig.py | 6 ++-- 81 files changed, 219 insertions(+), 219 deletions(-)
diff --git a/Makefile b/Makefile index 4378993ccfd..d38adcbd1e6 100644 --- a/Makefile +++ b/Makefile @@ -829,7 +829,7 @@ KBUILD_HOSTCFLAGS += $(if $(CONFIG_TOOLS_DEBUG),-g) UBOOTINCLUDE := \ -Iinclude \ $(if $(KBUILD_SRC), -I$(srctree)/include) \ - $(if $(CONFIG_$(SPL_)SYS_THUMB_BUILD), \ + $(if $(CONFIG_$(XPL_)SYS_THUMB_BUILD), \ $(if $(CONFIG_HAS_THUMB2), \ $(if $(CONFIG_CPU_V7M), \ -I$(srctree)/arch/arm/thumb1/include), \ @@ -864,7 +864,7 @@ libs-y += disk/ libs-y += drivers/ libs-$(CONFIG_SYS_FSL_DDR) += drivers/ddr/fsl/ libs-$(CONFIG_SYS_FSL_MMDC) += drivers/ddr/fsl/ -libs-$(CONFIG_$(SPL_)ALTERA_SDRAM) += drivers/ddr/altera/ +libs-$(CONFIG_$(XPL_)ALTERA_SDRAM) += drivers/ddr/altera/ libs-y += drivers/usb/cdns3/ libs-y += drivers/usb/dwc3/ libs-y += drivers/usb/common/ diff --git a/arch/arm/config.mk b/arch/arm/config.mk index 084fd399931..e0045e22271 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -40,7 +40,7 @@ PLATFORM_ELFFLAGS += -B arm -O elf32-littlearm endif
# Choose between ARM/Thumb instruction sets -ifeq ($(CONFIG_$(SPL_)SYS_THUMB_BUILD),y) +ifeq ($(CONFIG_$(XPL_)SYS_THUMB_BUILD),y) AFLAGS_IMPLICIT_IT := $(call as-option,-Wa$(comma)-mimplicit-it=always) PF_CPPFLAGS_ARM := $(AFLAGS_IMPLICIT_IT) \ $(call cc-option, -mthumb -mthumb-interwork,\ @@ -53,7 +53,7 @@ PF_CPPFLAGS_ARM := $(call cc-option,-marm,) \ endif
# Only test once -ifeq ($(CONFIG_$(SPL_)SYS_THUMB_BUILD),y) +ifeq ($(CONFIG_$(XPL_)SYS_THUMB_BUILD),y) archprepare: checkthumb checkgcc6
checkthumb: @@ -116,7 +116,7 @@ LDFLAGS_u-boot += -pie # # http://sourceware.org/bugzilla/show_bug.cgi?id=12532 # -ifeq ($(CONFIG_$(SPL_)SYS_THUMB_BUILD),y) +ifeq ($(CONFIG_$(XPL_)SYS_THUMB_BUILD),y) ifeq ($(GAS_BUG_12532),) export GAS_BUG_12532:=$(shell if [ $(call binutils-version) -lt 0222 ] ; \ then echo y; else echo n; fi) diff --git a/arch/arm/cpu/arm920t/Makefile b/arch/arm/cpu/arm920t/Makefile index 5ac3740621c..06456fe5a81 100644 --- a/arch/arm/cpu/arm920t/Makefile +++ b/arch/arm/cpu/arm920t/Makefile @@ -9,6 +9,6 @@ obj-y += cpu.o
# some files can only build in ARM mode
-ifdef CONFIG_$(SPL_)SYS_THUMB_BUILD +ifdef CONFIG_$(XPL_)SYS_THUMB_BUILD CFLAGS_cpu.o := -marm endif diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index 75513889c5d..750cb94dc6e 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -17,7 +17,7 @@ obj-$(CONFIG_ARCH_SUNXI) += sunxi/
# some files can only build in ARM or THUMB2, not THUMB1
-ifdef CONFIG_$(SPL_)SYS_THUMB_BUILD +ifdef CONFIG_$(XPL_)SYS_THUMB_BUILD ifndef CONFIG_HAS_THUMB2
CFLAGS_cpu.o := -marm diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 0e7d769bd40..6461f5f5bde 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -17,7 +17,7 @@ obj-$(CONFIG_EFI_LOADER) += sctlr.o obj-$(CONFIG_ARMV7_NONSEC) += exception_level.o endif
-ifneq ($(CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT),y) +ifneq ($(CONFIG_$(XPL_)SKIP_LOWLEVEL_INIT),y) obj-y += lowlevel_init.o endif
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index 722ec89d239..c5f568e2cb7 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -9,7 +9,7 @@ obj-y += cpu.o ifndef CONFIG_$(SPL_TPL_)TIMER obj-$(CONFIG_SYS_ARCH_TIMER) += generic_timer.o endif -ifndef CONFIG_$(SPL_)SYS_DCACHE_OFF +ifndef CONFIG_$(XPL_)SYS_DCACHE_OFF obj-y += cache_v8.o obj-y += cache.o endif @@ -32,7 +32,7 @@ obj-$(CONFIG_ARMV8_SPIN_TABLE) += spin_table.o spin_table_v8.o else obj-$(CONFIG_ARCH_SUNXI) += fel_utils.o endif -obj-$(CONFIG_$(SPL_)ARMV8_SEC_FIRMWARE_SUPPORT) += sec_firmware.o sec_firmware_asm.o +obj-$(CONFIG_$(XPL_)ARMV8_SEC_FIRMWARE_SUPPORT) += sec_firmware.o sec_firmware_asm.o
ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_RECOVER_DATA_SECTION) += spl_data.o diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index e343e81cf32..b73a0397541 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -94,7 +94,7 @@ endif
-ifdef CONFIG_$(SPL_)SYS_THUMB_BUILD +ifdef CONFIG_$(XPL_)SYS_THUMB_BUILD asflags-$(CONFIG_HAS_THUMB2) += -DCONFIG_THUMB2_KERNEL ifndef CONFIG_HAS_THUMB2
diff --git a/arch/arm/mach-at91/arm926ejs/Makefile b/arch/arm/mach-at91/arm926ejs/Makefile index a8916862b3f..1695708831c 100644 --- a/arch/arm/mach-at91/arm926ejs/Makefile +++ b/arch/arm/mach-at91/arm926ejs/Makefile @@ -32,7 +32,7 @@ obj-y += lowlevel_init.o endif endif
CFLAGS_cache.o := -marm diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index af62a39a671..21d955b4aef 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -60,7 +60,7 @@ obj-$(CONFIG_IMX_RDC) += rdc-sema.o ifneq ($(CONFIG_XPL_BUILD),y) obj-$(CONFIG_IMX_BOOTAUX) += imx_bootaux.o endif -obj-$(CONFIG_$(SPL_)SATA) += sata.o +obj-$(CONFIG_$(XPL_)SATA) += sata.o obj-$(CONFIG_IMX_HAB) += hab.o obj-$(CONFIG_SYSCOUNTER_TIMER) += syscounter.o endif diff --git a/arch/arm/mach-omap2/am33xx/Makefile b/arch/arm/mach-omap2/am33xx/Makefile index 3f1af7f1633..6f3587f01d0 100644 --- a/arch/arm/mach-omap2/am33xx/Makefile +++ b/arch/arm/mach-omap2/am33xx/Makefile @@ -11,7 +11,7 @@ endif
obj-y += sys_info.o obj-y += ddr.o -ifeq ($(CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT),) +ifeq ($(CONFIG_$(XPL_)SKIP_LOWLEVEL_INIT),) obj-y += emif4.o endif obj-y += board.o diff --git a/arch/arm/mach-orion5x/Makefile b/arch/arm/mach-orion5x/Makefile index a8b87f6d710..3c381dedaf8 100644 --- a/arch/arm/mach-orion5x/Makefile +++ b/arch/arm/mach-orion5x/Makefile @@ -11,13 +11,13 @@ obj-y = cpu.o obj-y += dram.o obj-y += timer.o
-ifndef CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT +ifndef CONFIG_$(XPL_)SKIP_LOWLEVEL_INIT obj-y += lowlevel_init.o endif
CFLAGS_cpu.o := -marm diff --git a/arch/arm/mach-stm32mp/stm32mp1/Makefile b/arch/arm/mach-stm32mp/stm32mp1/Makefile index 5ae1a536ff1..db160c24cbc 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/Makefile +++ b/arch/arm/mach-stm32mp/stm32mp1/Makefile @@ -15,5 +15,5 @@ else obj-$(CONFIG_ARMV7_PSCI) += psci.o endif
-obj-$(CONFIG_$(SPL_)STM32MP15_PWR) += pwr_regulator.o +obj-$(CONFIG_$(XPL_)STM32MP15_PWR) += pwr_regulator.o obj-$(CONFIG_OF_SYSTEM_SETUP) += fdt.o diff --git a/arch/arm/mach-tegra/Makefile b/arch/arm/mach-tegra/Makefile index a87e6a6c352..ebac3473a1f 100644 --- a/arch/arm/mach-tegra/Makefile +++ b/arch/arm/mach-tegra/Makefile @@ -16,7 +16,7 @@ obj-$(CONFIG_TEGRA_GP_PADCTRL) += ap.o obj-y += board.o board2.o obj-y += cache.o obj-$(CONFIG_TEGRA_CLKRST) += clock.o -obj-$(CONFIG_$(SPL_)TEGRA_CRYPTO) += crypto.o +obj-$(CONFIG_$(XPL_)TEGRA_CRYPTO) += crypto.o obj-$(CONFIG_TEGRA_PMC) += powergate.o obj-y += xusb-padctl-dummy.o
diff --git a/arch/arm/mach-tegra/tegra20/Makefile b/arch/arm/mach-tegra/tegra20/Makefile index 2774c866b02..32c1866b099 100644 --- a/arch/arm/mach-tegra/tegra20/Makefile +++ b/arch/arm/mach-tegra/tegra20/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2010,2011 Nvidia Corporation.
obj-$(CONFIG_XPL_BUILD) += cpu.o -obj-$(CONFIG_$(SPL_)CMD_EBTUPDATE) += bct.o +obj-$(CONFIG_$(XPL_)CMD_EBTUPDATE) += bct.o
# The AVP is ARMv4T architecture so we must use special compiler # flags for any startup files it might use. diff --git a/arch/arm/mach-tegra/tegra30/Makefile b/arch/arm/mach-tegra/tegra30/Makefile index 5edc7c9ce7d..b36657a432f 100644 --- a/arch/arm/mach-tegra/tegra30/Makefile +++ b/arch/arm/mach-tegra/tegra30/Makefile @@ -3,6 +3,6 @@ # Copyright (c) 2010-2012, NVIDIA CORPORATION. All rights reserved.
obj-y += clock.o diff --git a/arch/arm/mach-zynqmp/Makefile b/arch/arm/mach-zynqmp/Makefile index 7c95f32a5c3..ff426044797 100644 --- a/arch/arm/mach-zynqmp/Makefile +++ b/arch/arm/mach-zynqmp/Makefile @@ -7,7 +7,7 @@ obj-y += aes.o clk.o cpu.o obj-$(CONFIG_MP) += mp.o obj-$(CONFIG_XPL_BUILD) += spl.o handoff.o psu_spl_init.o obj-$(CONFIG_SPL_ZYNQMP_DRAM_ECC_INIT) += ecc_spl_init.o -obj-$(CONFIG_$(SPL_)ZYNQMP_PSU_INIT_ENABLED) += psu_spl_init.o +obj-$(CONFIG_$(XPL_)ZYNQMP_PSU_INIT_ENABLED) += psu_spl_init.o
ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_ZYNQMP) += zynqmp.o diff --git a/arch/riscv/Makefile b/arch/riscv/Makefile index c36a8533e0f..4e6f347038d 100644 --- a/arch/riscv/Makefile +++ b/arch/riscv/Makefile @@ -48,7 +48,7 @@ endif ARCH_FLAGS = -march=$(RISCV_MARCH) -mabi=$(ABI) \ -mcmodel=$(CMODEL)
-ifeq ($(CONFIG_$(SPL_)FRAMEPOINTER),y) +ifeq ($(CONFIG_$(XPL_)FRAMEPOINTER),y) ARCH_FLAGS += -fno-omit-frame-pointer endif
diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 3bc34cd61fb..34b69c13392 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -11,19 +11,19 @@ obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o obj-$(CONFIG_CMD_GO) += boot.o obj-y += cache.o obj-$(CONFIG_SIFIVE_CACHE) += sifive_cache.o -ifeq ($(CONFIG_$(SPL_)RISCV_MMODE),y) -obj-$(CONFIG_$(SPL_)RISCV_ACLINT) += aclint_ipi.o +ifeq ($(CONFIG_$(XPL_)RISCV_MMODE),y) +obj-$(CONFIG_$(XPL_)RISCV_ACLINT) += aclint_ipi.o obj-$(CONFIG_ANDES_PLICSW) += andes_plicsw.o else obj-$(CONFIG_SBI) += sbi.o obj-$(CONFIG_SBI_IPI) += sbi_ipi.o endif obj-y += interrupts.o -ifeq ($(CONFIG_$(SPL_)SYSRESET),) +ifeq ($(CONFIG_$(XPL_)SYSRESET),) obj-y += reset.o endif obj-y += setjmp.o -obj-$(CONFIG_$(SPL_)SMP) += smp.o +obj-$(CONFIG_$(XPL_)SMP) += smp.o obj-$(CONFIG_XPL_BUILD) += spl.o obj-y += fdt_fixup.o obj-$(CONFIG_$(SPL)CMD_BDI) += bdinfo.o diff --git a/arch/x86/Makefile b/arch/x86/Makefile index 3c8c541efbc..bc1e1ede12a 100644 --- a/arch/x86/Makefile +++ b/arch/x86/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
ifeq ($(CONFIG_EFI_APP),) -ifdef CONFIG_$(SPL_)X86_64 +ifdef CONFIG_$(XPL_)X86_64 head-y := arch/x86/cpu/start64.o else ifeq ($(CONFIG_$(SPL_TPL_)X86_16BIT_INIT),y) diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index c21d6d6d438..8899830370c 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -6,7 +6,7 @@ # (C) Copyright 2002 # Daniel Engström, Omicron Ceti AB, daniel@omicron.se.
-ifeq ($(CONFIG_$(SPL_)X86_64),y) +ifeq ($(CONFIG_$(XPL_)X86_64),y) extra-y = start64.o else ifeq ($(CONFIG_$(SPL_TPL_)X86_16BIT_INIT),y) @@ -31,7 +31,7 @@ ifndef CONFIG_TPL_BUILD obj-y += cpu_x86.o endif
-ifndef CONFIG_$(SPL_)X86_64 +ifndef CONFIG_$(XPL_)X86_64 AFLAGS_REMOVE_call32.o := -mregparm=3 \ $(if $(CONFIG_EFI_STUB_64BIT),-march=i386 -m32) AFLAGS_call32.o := -fpic -fshort-wchar \ @@ -59,18 +59,18 @@ obj-$(CONFIG_QFW) += qfw_cpu.o ifndef CONFIG_SYS_COREBOOT obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += irq.o endif -ifndef CONFIG_$(SPL_)X86_64 -obj-$(CONFIG_$(SPL_)SMP) += mp_init.o +ifndef CONFIG_$(XPL_)X86_64 +obj-$(CONFIG_$(XPL_)SMP) += mp_init.o endif obj-y += mtrr.o obj-$(CONFIG_PCI) += pci.o -ifndef CONFIG_$(SPL_)X86_64 +ifndef CONFIG_$(XPL_)X86_64 obj-$(CONFIG_SMP) += sipi_vector.o endif obj-y += turbo.o obj-$(CONFIG_HAVE_ACPI_RESUME) += wakeup.o
-ifeq ($(CONFIG_$(SPL_)X86_64),y) +ifeq ($(CONFIG_$(XPL_)X86_64),y) obj-y += x86_64/ else obj-y += i386/ diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index 2e312a30353..d2db5897377 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -26,10 +26,10 @@ obj-y += cpu.o obj-y += fast_spi.o obj-y += lpc.o obj-y += lpss.o -obj-$(CONFIG_$(SPL_)INTEL_GENERIC_WIFI) += generic_wifi.o +obj-$(CONFIG_$(XPL_)INTEL_GENERIC_WIFI) += generic_wifi.o ifndef CONFIG_EFI_APP obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += microcode.o -ifndef CONFIG_$(SPL_)X86_64 +ifndef CONFIG_$(XPL_)X86_64 obj-y += microcode.o endif endif diff --git a/arch/x86/cpu/ivybridge/Makefile b/arch/x86/cpu/ivybridge/Makefile index 1f3b0c092f1..471ad8d7ebc 100644 --- a/arch/x86/cpu/ivybridge/Makefile +++ b/arch/x86/cpu/ivybridge/Makefile @@ -5,15 +5,15 @@ ifdef CONFIG_HAVE_FSP obj-y += fsp_configs.o ivybridge.o else -obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += cpu.o +obj-$(CONFIG_$(XPL_)X86_32BIT_INIT) += cpu.o obj-y += early_me.o obj-y += lpc.o obj-y += northbridge.o ifndef CONFIG_XPL_BUILD obj-y += sata.o endif -obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += sdram.o -ifndef CONFIG_$(SPL_)X86_32BIT_INIT +obj-$(CONFIG_$(XPL_)X86_32BIT_INIT) += sdram.o +ifndef CONFIG_$(XPL_)X86_32BIT_INIT obj-y += sdram_nop.o endif endif diff --git a/arch/x86/cpu/qemu/Makefile b/arch/x86/cpu/qemu/Makefile index b7dd5bd46c7..1439916ac2d 100644 --- a/arch/x86/cpu/qemu/Makefile +++ b/arch/x86/cpu/qemu/Makefile @@ -2,7 +2,7 @@ # # Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com
-ifndef CONFIG_$(SPL_)X86_64 +ifndef CONFIG_$(XPL_)X86_64 obj-y += car.o endif obj-y += dram.o diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index bf0605ad662..decf2e5c628 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -19,7 +19,7 @@ ifndef CONFIG_XPL_BUILD obj-$(CONFIG_CMD_BOOTM) += bootm.o endif obj-y += cmd_boot.o -obj-$(CONFIG_$(SPL_)COREBOOT_SYSINFO) += coreboot/ +obj-$(CONFIG_$(XPL_)COREBOOT_SYSINFO) += coreboot/ obj-$(CONFIG_SEABIOS) += coreboot_table.o obj-y += early_cmos.o obj-y += e820.o @@ -85,7 +85,7 @@ endif
ifdef CONFIG_EFI_STUB
-ifeq ($(CONFIG_$(SPL_)X86_64),) +ifeq ($(CONFIG_$(XPL_)X86_64),) extra-y += $(EFI_CRT0) $(EFI_RELOC) endif
diff --git a/board/bosch/guardian/Makefile b/board/bosch/guardian/Makefile index 20cecbfb64e..8e38881ec2c 100644 --- a/board/bosch/guardian/Makefile +++ b/board/bosch/guardian/Makefile @@ -5,7 +5,7 @@ # Copyright (C) 2018 Robert Bosch Power Tools GmbH #
-ifeq ($(CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT),) +ifeq ($(CONFIG_$(XPL_)SKIP_LOWLEVEL_INIT),) obj-y := mux.o endif
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 0e1dec49238..279d390db64 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -32,7 +32,7 @@ obj-$(CONFIG_FSL_NGPIXIS) += ngpixis.o endif obj-$(I2C_COMMON) += i2c_common.o obj-$(CONFIG_FSL_USE_PCA9547_MUX) += i2c_mux.o -obj-$(CONFIG_$(SPL_)VID) += vid.o +obj-$(CONFIG_$(XPL_)VID) += vid.o obj-$(CONFIG_FSL_QIXIS) += qixis.o ifndef CONFIG_XPL_BUILD obj-$(CONFIG_ID_EEPROM) += sys_eeprom.o @@ -52,7 +52,7 @@ obj-$(CONFIG_TARGET_MPC8548CDS) += cds_pci_ft.o obj-$(CONFIG_TARGET_P3041DS) += ics307_clk.o obj-$(CONFIG_TARGET_P4080DS) += ics307_clk.o obj-$(CONFIG_TARGET_P5040DS) += ics307_clk.o -ifeq ($(CONFIG_$(SPL_)POWER_LEGACY),y) +ifeq ($(CONFIG_$(XPL_)POWER_LEGACY),y) obj-$(CONFIG_POWER_PFUZE100) += pfuze.o endif obj-$(CONFIG_DM_PMIC_PFUZE100) += pfuze.o diff --git a/board/st/common/Makefile b/board/st/common/Makefile index b01245e4b48..fda48d2ff99 100644 --- a/board/st/common/Makefile +++ b/board/st/common/Makefile @@ -8,7 +8,7 @@ obj-$(CONFIG_PMIC_STPMIC1) += stpmic1.o
ifeq ($(CONFIG_ARCH_STM32MP),y) obj-$(CONFIG_SET_DFU_ALT_INFO) += stm32mp_dfu.o -obj-$(CONFIG_$(SPL_)DFU_VIRT) += stm32mp_dfu_virt.o +obj-$(CONFIG_$(XPL_)DFU_VIRT) += stm32mp_dfu_virt.o endif
obj-$(CONFIG_TYPEC_STUSB160X) += stusb160x.o diff --git a/board/tcl/sl50/Makefile b/board/tcl/sl50/Makefile index 0ac0ba36cdb..1502990174b 100644 --- a/board/tcl/sl50/Makefile +++ b/board/tcl/sl50/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2015 Toby Churchill Ltd - http://www.toby-churchill.com/
diff --git a/board/ti/am335x/Makefile b/board/ti/am335x/Makefile index 2b1e21a1788..6ef87c22eaa 100644 --- a/board/ti/am335x/Makefile +++ b/board/ti/am335x/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2011 Texas Instruments Incorporated - https://www.ti.com/
diff --git a/board/ti/am43xx/Makefile b/board/ti/am43xx/Makefile index b618f632eff..5b7b5b371a4 100644 --- a/board/ti/am43xx/Makefile +++ b/board/ti/am43xx/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2013 Texas Instruments Incorporated - https://www.ti.com/
diff --git a/board/vscom/baltos/Makefile b/board/vscom/baltos/Makefile index 2b1e21a1788..6ef87c22eaa 100644 --- a/board/vscom/baltos/Makefile +++ b/board/vscom/baltos/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2011 Texas Instruments Incorporated - https://www.ti.com/
diff --git a/board/xilinx/zynqmp/Makefile b/board/xilinx/zynqmp/Makefile index 544346d686e..6476f20eb83 100644 --- a/board/xilinx/zynqmp/Makefile +++ b/board/xilinx/zynqmp/Makefile @@ -31,7 +31,7 @@ $(warning Put custom psu_init_gpl.c/h to board/xilinx/zynqmp/custom_hw_platform/ endif endif
-obj-$(CONFIG_$(SPL_)ZYNQMP_PSU_INIT_ENABLED) += $(init-objs) +obj-$(CONFIG_$(XPL_)ZYNQMP_PSU_INIT_ENABLED) += $(init-objs)
ifdef CONFIG_XPL_BUILD ifneq ($(CONFIG_ZYNQMP_SPL_PM_CFG_OBJ_FILE),"") diff --git a/boot/Makefile b/boot/Makefile index 5bf07e83388..1b6901970e3 100644 --- a/boot/Makefile +++ b/boot/Makefile @@ -50,7 +50,7 @@ obj-$(CONFIG_$(SPL_TPL_)UPL_WRITE) += upl_write.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += image-fdt.o obj-$(CONFIG_$(SPL_TPL_)FIT_SIGNATURE) += fdt_region.o obj-$(CONFIG_$(SPL_TPL_)FIT) += image-fit.o -obj-$(CONFIG_$(SPL_)MULTI_DTB_FIT) += boot_fit.o common_fit.o +obj-$(CONFIG_$(XPL_)MULTI_DTB_FIT) += boot_fit.o common_fit.o obj-$(CONFIG_$(SPL_TPL_)IMAGE_PRE_LOAD) += image-pre-load.o obj-$(CONFIG_$(SPL_TPL_)IMAGE_SIGN_INFO) += image-sig.o obj-$(CONFIG_$(SPL_TPL_)FIT_SIGNATURE) += image-fit-sig.o diff --git a/cmd/Makefile b/cmd/Makefile index ed62e1c45f8..21d376309b9 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -249,7 +249,7 @@ obj-$(CONFIG_ARCH_K3) += ti/ obj-$(CONFIG_ARCH_OMAP2PLUS) += ti/ endif # !CONFIG_XPL_BUILD
-obj-$(CONFIG_$(SPL_)CMD_TLV_EEPROM) += tlv_eeprom.o +obj-$(CONFIG_$(XPL_)CMD_TLV_EEPROM) += tlv_eeprom.o
obj-$(CONFIG_CMD_BCM_EXT_UTILS) += broadcom/
diff --git a/doc/develop/tests_writing.rst b/doc/develop/tests_writing.rst index a328ebfef33..54efb7e1b04 100644 --- a/doc/develop/tests_writing.rst +++ b/doc/develop/tests_writing.rst @@ -321,15 +321,15 @@ to control that. Finally, add the test to the build by adding to the Makefile in the same directory::
- obj-$(CONFIG_$(SPL_)CMDLINE) += wibble.o + obj-$(CONFIG_$(XPL_)CMDLINE) += wibble.o
Note that CMDLINE is never enabled in SPL, so this test will only be present in U-Boot proper. See below for how to do SPL tests.
As before, you can add an extra Kconfig check if needed::
- ifneq ($(CONFIG_$(SPL_)WIBBLE),) - obj-$(CONFIG_$(SPL_)CMDLINE) += wibble.o + ifneq ($(CONFIG_$(XPL_)WIBBLE),) + obj-$(CONFIG_$(XPL_)CMDLINE) += wibble.o endif
diff --git a/drivers/Makefile b/drivers/Makefile index 260bde957db..fd247265fe5 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -33,15 +33,15 @@ obj-$(CONFIG_$(SPL_TPL_)SERIAL) += serial/ obj-$(CONFIG_$(SPL_TPL_)SPI) += spi/ obj-$(CONFIG_$(SPL_TPL_)TIMER) += timer/ obj-$(CONFIG_$(SPL_TPL_)VIRTIO) += virtio/ -obj-$(CONFIG_$(SPL_)DM_MAILBOX) += mailbox/ -obj-$(CONFIG_$(SPL_)REMOTEPROC) += remoteproc/ -obj-$(CONFIG_$(SPL_)SYSINFO) += sysinfo/ +obj-$(CONFIG_$(XPL_)DM_MAILBOX) += mailbox/ +obj-$(CONFIG_$(XPL_)REMOTEPROC) += remoteproc/ +obj-$(CONFIG_$(XPL_)SYSINFO) += sysinfo/ obj-$(CONFIG_$(SPL_TPL_)SM) += sm/ obj-$(CONFIG_$(SPL_TPL_)TPM) += tpm/ -obj-$(CONFIG_$(SPL_)NVME) += nvme/ +obj-$(CONFIG_$(XPL_)NVME) += nvme/ obj-$(CONFIG_XEN) += xen/ -obj-$(CONFIG_$(SPL_)FPGA) += fpga/ -obj-$(CONFIG_$(SPL_)VIDEO) += video/ +obj-$(CONFIG_$(XPL_)FPGA) += fpga/ +obj-$(CONFIG_$(XPL_)VIDEO) += video/
obj-y += bus/
@@ -52,7 +52,7 @@ obj-$(CONFIG_SPL_CRYPTO) += crypto/ obj-$(CONFIG_SPL_MPC8XXX_INIT_DDR) += ddr/fsl/ obj-$(CONFIG_ARMADA_38X) += ddr/marvell/a38x/ obj-$(CONFIG_ARMADA_XP) += ddr/marvell/axp/ -obj-$(CONFIG_$(SPL_)ALTERA_SDRAM) += ddr/altera/ +obj-$(CONFIG_$(XPL_)ALTERA_SDRAM) += ddr/altera/ obj-$(CONFIG_ARCH_IMX8M) += ddr/imx/imx8m/ obj-$(CONFIG_IMX8ULP_DRAM) += ddr/imx/imx8ulp/ obj-$(CONFIG_ARCH_IMX9) += ddr/imx/imx9/ diff --git a/drivers/ata/Makefile b/drivers/ata/Makefile index af6f0bf2780..ee10c4445b0 100644 --- a/drivers/ata/Makefile +++ b/drivers/ata/Makefile @@ -5,7 +5,7 @@
obj-$(CONFIG_DWC_AHCI) += dwc_ahci.o obj-$(CONFIG_AHCI) += ahci-uclass.o -obj-$(CONFIG_$(SPL_)AHCI_PCI) += ahci-pci.o +obj-$(CONFIG_$(XPL_)AHCI_PCI) += ahci-pci.o obj-$(CONFIG_SCSI_AHCI) += ahci.o obj-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o obj-$(CONFIG_FSL_SATA) += fsl_sata.o diff --git a/drivers/block/Makefile b/drivers/block/Makefile index a551591fc91..98a34c01c38 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -5,7 +5,7 @@
obj-$(CONFIG_$(SPL_TPL_)BLK) += blk-uclass.o
-ifndef CONFIG_$(SPL_)BLK +ifndef CONFIG_$(XPL_)BLK obj-$(CONFIG_SPL_LEGACY_BLOCK) += blk_legacy.o endif
diff --git a/drivers/bus/Makefile b/drivers/bus/Makefile index b7e6452c48c..c40139f04d0 100644 --- a/drivers/bus/Makefile +++ b/drivers/bus/Makefile @@ -8,4 +8,4 @@ obj-$(CONFIG_TI_PWMSS) += ti-pwmss.o obj-$(CONFIG_UNIPHIER_SYSTEM_BUS) += uniphier-system-bus.o endif
-obj-$(CONFIG_$(SPL_)TI_SYSC) += ti-sysc.o +obj-$(CONFIG_$(XPL_)TI_SYSC) += ti-sysc.o diff --git a/drivers/core/Makefile b/drivers/core/Makefile index acbd2bf2cef..20dbff6f956 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -6,16 +6,16 @@ obj-y += device.o fdtaddr.o lists.o root.o uclass.o util.o tag.o obj-$(CONFIG_$(SPL_TPL_)ACPIGEN) += acpi.o obj-$(CONFIG_$(SPL_TPL_)DEVRES) += devres.o obj-$(CONFIG_$(SPL_TPL_)DM_DEVICE_REMOVE) += device-remove.o -obj-$(CONFIG_$(SPL_)SIMPLE_BUS) += simple-bus.o +obj-$(CONFIG_$(XPL_)SIMPLE_BUS) += simple-bus.o obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o obj-$(CONFIG_DM) += dump.o obj-$(CONFIG_$(SPL_TPL_)REGMAP) += regmap.o obj-$(CONFIG_$(SPL_TPL_)SYSCON) += syscon-uclass.o -obj-$(CONFIG_$(SPL_)OF_LIVE) += of_access.o of_addr.o +obj-$(CONFIG_$(XPL_)OF_LIVE) += of_access.o of_addr.o ifndef CONFIG_DM_DEV_READ_INLINE obj-$(CONFIG_OF_CONTROL) += read.o endif -obj-$(CONFIG_$(SPL_)OF_PLATDATA) += read.o +obj-$(CONFIG_$(XPL_)OF_PLATDATA) += read.o obj-$(CONFIG_OF_CONTROL) += of_extra.o ofnode.o read_extra.o
ccflags-$(CONFIG_DM_DEBUG) += -DDEBUG diff --git a/drivers/ddr/altera/Makefile b/drivers/ddr/altera/Makefile index 9fa5d85a27e..c1d6a6b6c59 100644 --- a/drivers/ddr/altera/Makefile +++ b/drivers/ddr/altera/Makefile @@ -6,7 +6,7 @@ # (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw # Copyright (C) 2014-2021 Altera Corporation <www.altera.com>
-ifdef CONFIG_$(SPL_)ALTERA_SDRAM +ifdef CONFIG_$(XPL_)ALTERA_SDRAM obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += sdram_gen5.o sequencer.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += sdram_arria10.o obj-$(CONFIG_TARGET_SOCFPGA_STRATIX10) += sdram_soc64.o sdram_s10.o diff --git a/drivers/dfu/Makefile b/drivers/dfu/Makefile index dfbf64da667..05d7cc61caa 100644 --- a/drivers/dfu/Makefile +++ b/drivers/dfu/Makefile @@ -3,11 +3,11 @@ # Copyright (C) 2012 Samsung Electronics # Lukasz Majewski l.majewski@samsung.com
-obj-$(CONFIG_$(SPL_)DFU) += dfu.o -obj-$(CONFIG_$(SPL_)DFU_MMC) += dfu_mmc.o -obj-$(CONFIG_$(SPL_)DFU_MTD) += dfu_mtd.o -obj-$(CONFIG_$(SPL_)DFU_NAND) += dfu_nand.o -obj-$(CONFIG_$(SPL_)DFU_RAM) += dfu_ram.o -obj-$(CONFIG_$(SPL_)DFU_SF) += dfu_sf.o -obj-$(CONFIG_$(SPL_)DFU_WRITE_ALT) += dfu_alt.o -obj-$(CONFIG_$(SPL_)DFU_VIRT) += dfu_virt.o +obj-$(CONFIG_$(XPL_)DFU) += dfu.o +obj-$(CONFIG_$(XPL_)DFU_MMC) += dfu_mmc.o +obj-$(CONFIG_$(XPL_)DFU_MTD) += dfu_mtd.o +obj-$(CONFIG_$(XPL_)DFU_NAND) += dfu_nand.o +obj-$(CONFIG_$(XPL_)DFU_RAM) += dfu_ram.o +obj-$(CONFIG_$(XPL_)DFU_SF) += dfu_sf.o +obj-$(CONFIG_$(XPL_)DFU_WRITE_ALT) += dfu_alt.o +obj-$(CONFIG_$(XPL_)DFU_VIRT) += dfu_virt.o diff --git a/drivers/firmware/Makefile b/drivers/firmware/Makefile index 7ce83d72bd3..8b979f69ed9 100644 --- a/drivers/firmware/Makefile +++ b/drivers/firmware/Makefile @@ -1,5 +1,5 @@ obj-$(CONFIG_FIRMWARE) += firmware-uclass.o -obj-$(CONFIG_$(SPL_)ARM_PSCI_FW) += psci.o +obj-$(CONFIG_$(XPL_)ARM_PSCI_FW) += psci.o obj-$(CONFIG_TI_SCI_PROTOCOL) += ti_sci.o obj-$(CONFIG_SANDBOX) += firmware-sandbox.o obj-$(CONFIG_ZYNQMP_FIRMWARE) += firmware-zynqmp.o diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 990a670dd7b..24d1b0394fb 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -10,7 +10,7 @@ obj-$(CONFIG_DM_74X164) += 74x164_gpio.o endif obj-$(CONFIG_$(SPL_TPL_)DM_GPIO) += gpio-uclass.o
-obj-$(CONFIG_$(SPL_)DM_PCA953X) += pca953x_gpio.o +obj-$(CONFIG_$(XPL_)DM_PCA953X) += pca953x_gpio.o
obj-$(CONFIG_ASPEED_GPIO) += gpio-aspeed.o obj-$(CONFIG_ASPEED_G7_GPIO) += gpio-aspeed-g7.o @@ -57,12 +57,12 @@ obj-$(CONFIG_VYBRID_GPIO) += vybrid_gpio.o obj-$(CONFIG_HIKEY_GPIO) += hi6220_gpio.o obj-$(CONFIG_HSDK_CREG_GPIO) += hsdk-creg-gpio.o obj-$(CONFIG_IMX_RGPIO2P) += imx_rgpio2p.o -obj-$(CONFIG_$(SPL_)PALMAS_GPIO) += palmas_gpio.o +obj-$(CONFIG_$(XPL_)PALMAS_GPIO) += palmas_gpio.o obj-$(CONFIG_PIC32_GPIO) += pic32_gpio.o obj-$(CONFIG_OCTEON_GPIO) += octeon_gpio.o obj-$(CONFIG_MVEBU_GPIO) += mvebu_gpio.o obj-$(CONFIG_MSM_GPIO) += msm_gpio.o -obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o +obj-$(CONFIG_$(XPL_)PCF8575_GPIO) += pcf8575_gpio.o obj-$(CONFIG_$(SPL_TPL_)QCOM_PMIC_GPIO) += qcom_pmic_gpio.o obj-$(CONFIG_MT7620_GPIO) += mt7620_gpio.o obj-$(CONFIG_MT7621_GPIO) += mt7621_gpio.o @@ -71,7 +71,7 @@ obj-$(CONFIG_NX_GPIO) += nx_gpio.o obj-$(CONFIG_SIFIVE_GPIO) += sifive-gpio.o obj-$(CONFIG_NOMADIK_GPIO) += nmk_gpio.o obj-$(CONFIG_MAX7320_GPIO) += max7320_gpio.o -obj-$(CONFIG_$(SPL_)MAX77663_GPIO) += max77663_gpio.o +obj-$(CONFIG_$(XPL_)MAX77663_GPIO) += max77663_gpio.o obj-$(CONFIG_SL28CPLD_GPIO) += sl28cpld-gpio.o obj-$(CONFIG_ZYNQMP_GPIO_MODEPIN) += zynqmp_gpio_modepin.o obj-$(CONFIG_SLG7XL45106_I2C_GPO) += gpio_slg7xl45106.o diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 00b90523c62..bebd728e7da 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -2,15 +2,15 @@ # # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. -obj-$(CONFIG_$(SPL_)DM_I2C) += i2c-uclass.o -ifdef CONFIG_$(SPL_)ACPIGEN -obj-$(CONFIG_$(SPL_)DM_I2C) += acpi_i2c.o +obj-$(CONFIG_$(XPL_)DM_I2C) += i2c-uclass.o +ifdef CONFIG_$(XPL_)ACPIGEN +obj-$(CONFIG_$(XPL_)DM_I2C) += acpi_i2c.o endif -obj-$(CONFIG_$(SPL_)DM_I2C_GPIO) += i2c-gpio.o -obj-$(CONFIG_$(SPL_)I2C_CROS_EC_TUNNEL) += cros_ec_tunnel.o -obj-$(CONFIG_$(SPL_)I2C_CROS_EC_LDO) += cros_ec_ldo.o +obj-$(CONFIG_$(XPL_)DM_I2C_GPIO) += i2c-gpio.o +obj-$(CONFIG_$(XPL_)I2C_CROS_EC_TUNNEL) += cros_ec_tunnel.o +obj-$(CONFIG_$(XPL_)I2C_CROS_EC_LDO) += cros_ec_ldo.o
-obj-$(CONFIG_$(SPL_)SYS_I2C_LEGACY) += i2c_core.o +obj-$(CONFIG_$(XPL_)SYS_I2C_LEGACY) += i2c_core.o obj-$(CONFIG_SYS_I2C_ASPEED) += ast_i2c.o obj-$(CONFIG_SYS_I2C_AST2600) += ast2600_i2c.o obj-$(CONFIG_SYS_I2C_AT91) += at91_i2c.o @@ -57,4 +57,4 @@ obj-$(CONFIG_SYS_I2C_VERSATILE) += i2c-versatile.o obj-$(CONFIG_SYS_I2C_XILINX_XIIC) += xilinx_xiic.o obj-$(CONFIG_TEGRA186_BPMP_I2C) += tegra186_bpmp_i2c.o
-obj-$(CONFIG_$(SPL_)I2C_MUX) += muxes/ +obj-$(CONFIG_$(XPL_)I2C_MUX) += muxes/ diff --git a/drivers/led/Makefile b/drivers/led/Makefile index e27aa488482..aa64a38b4e1 100644 --- a/drivers/led/Makefile +++ b/drivers/led/Makefile @@ -10,6 +10,6 @@ obj-$(CONFIG_LED_BCM6358) += led_bcm6358.o obj-$(CONFIG_LED_BCM6753) += led_bcm6753.o obj-$(CONFIG_LED_BCM6858) += led_bcm6858.o obj-$(CONFIG_LED_PWM) += led_pwm.o -obj-$(CONFIG_$(SPL_)LED_GPIO) += led_gpio.o +obj-$(CONFIG_$(XPL_)LED_GPIO) += led_gpio.o obj-$(CONFIG_LED_CORTINA) += led_cortina.o obj-$(CONFIG_LED_LP5562) += led_lp5562.o diff --git a/drivers/mailbox/Makefile b/drivers/mailbox/Makefile index 59e8d0de93c..6072fa1956b 100644 --- a/drivers/mailbox/Makefile +++ b/drivers/mailbox/Makefile @@ -3,7 +3,7 @@ # Copyright (c) 2016, NVIDIA CORPORATION. #
-obj-$(CONFIG_$(SPL_)DM_MAILBOX) += mailbox-uclass.o +obj-$(CONFIG_$(XPL_)DM_MAILBOX) += mailbox-uclass.o obj-$(CONFIG_APPLE_MBOX) += apple-mbox.o obj-$(CONFIG_SANDBOX_MBOX) += sandbox-mbox.o obj-$(CONFIG_SANDBOX_MBOX) += sandbox-mbox-test.o diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 51ef51f1ed3..794c2a2d38e 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -18,7 +18,7 @@ obj-$(CONFIG_SANDBOX) += p2sb_sandbox.o p2sb_emul.o obj-$(CONFIG_SANDBOX) += swap_case.o endif
-ifdef CONFIG_$(SPL_)DM_I2C +ifdef CONFIG_$(XPL_)DM_I2C ifndef CONFIG_XPL_BUILD obj-$(CONFIG_SANDBOX) += i2c_eeprom_emul.o obj-$(CONFIG_USB_HUB_USB251XB) += usb251xb.o @@ -37,14 +37,14 @@ obj-$(CONFIG_FSL_DEVICE_DISABLE) += fsl_devdis.o obj-$(CONFIG_FSL_IFC) += fsl_ifc.o obj-$(CONFIG_FSL_IIM) += fsl_iim.o obj-$(CONFIG_FSL_SEC_MON) += fsl_sec_mon.o -obj-$(CONFIG_$(SPL_)FS_LOADER) += fs_loader.o +obj-$(CONFIG_$(XPL_)FS_LOADER) += fs_loader.o obj-$(CONFIG_GATEWORKS_SC) += gsc.o obj-$(CONFIG_GDSYS_IOEP) += gdsys_ioep.o obj-$(CONFIG_GDSYS_RXAUI_CTRL) += gdsys_rxaui_ctrl.o obj-$(CONFIG_GDSYS_SOC) += gdsys_soc.o obj-$(CONFIG_IRQ) += irq-uclass.o obj-$(CONFIG_SANDBOX) += irq_sandbox.o irq_sandbox_test.o -obj-$(CONFIG_$(SPL_)I2C_EEPROM) += i2c_eeprom.o +obj-$(CONFIG_$(XPL_)I2C_EEPROM) += i2c_eeprom.o obj-$(CONFIG_IHS_FPGA) += ihs_fpga.o obj-$(CONFIG_IMX8) += imx8/ obj-$(CONFIG_IMX_ELE) += imx_ele/ @@ -52,14 +52,14 @@ obj-$(CONFIG_LED_STATUS) += status_led.o obj-$(CONFIG_LED_STATUS_GPIO) += gpio_led.o obj-$(CONFIG_MPC83XX_SERDES) += mpc83xx_serdes.o obj-$(CONFIG_$(SPL_TPL_)LS2_SFP) += ls2_sfp.o -obj-$(CONFIG_$(SPL_)MXC_OCOTP) += mxc_ocotp.o +obj-$(CONFIG_$(XPL_)MXC_OCOTP) += mxc_ocotp.o obj-$(CONFIG_MXS_OCOTP) += mxs_ocotp.o obj-$(CONFIG_NPCM_OTP) += npcm_otp.o obj-$(CONFIG_NPCM_HOST) += npcm_host_intf.o obj-$(CONFIG_NUVOTON_NCT6102D) += nuvoton_nct6102d.o obj-$(CONFIG_P2SB) += p2sb-uclass.o obj-$(CONFIG_PCA9551_LED) += pca9551_led.o -obj-$(CONFIG_$(SPL_)PWRSEQ) += pwrseq-uclass.o +obj-$(CONFIG_$(XPL_)PWRSEQ) += pwrseq-uclass.o ifdef CONFIG_QFW obj-y += qfw.o obj-$(CONFIG_QFW_ACPI) += qfw_acpi.o diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 952201923d8..328653b8823 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -4,17 +4,17 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-y += mmc.o -obj-$(CONFIG_$(SPL_)DM_MMC) += mmc-uclass.o +obj-$(CONFIG_$(XPL_)DM_MMC) += mmc-uclass.o
ifdef CONFIG_$(SPL_TPL_)DM_MMC obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += mmc_bootdev.o endif
obj-$(CONFIG_$(SPL_TPL_)MMC_WRITE) += mmc_write.o -obj-$(CONFIG_$(SPL_)MMC_PWRSEQ) += mmc-pwrseq.o +obj-$(CONFIG_$(XPL_)MMC_PWRSEQ) += mmc-pwrseq.o obj-$(CONFIG_MMC_SDHCI_ADMA_HELPERS) += sdhci-adma.o
-ifndef CONFIG_$(SPL_)BLK +ifndef CONFIG_$(XPL_)BLK obj-y += mmc_legacy.o endif
diff --git a/drivers/mux/Makefile b/drivers/mux/Makefile index d4e24789d33..63770e12bd1 100644 --- a/drivers/mux/Makefile +++ b/drivers/mux/Makefile @@ -4,4 +4,4 @@ # Jean-Jacques Hiblot jjhiblot@ti.com
obj-$(CONFIG_MULTIPLEXER) += mux-uclass.o -obj-$(CONFIG_$(SPL_)MUX_MMIO) += mmio.o +obj-$(CONFIG_$(XPL_)MUX_MMIO) += mmio.o diff --git a/drivers/nvme/Makefile b/drivers/nvme/Makefile index fd3e68a91dc..8c32cfbfc0f 100644 --- a/drivers/nvme/Makefile +++ b/drivers/nvme/Makefile @@ -4,4 +4,4 @@
obj-y += nvme-uclass.o nvme.o nvme_show.o obj-$(CONFIG_NVME_APPLE) += nvme_apple.o -obj-$(CONFIG_$(SPL_)NVME_PCI) += nvme_pci.o +obj-$(CONFIG_$(XPL_)NVME_PCI) += nvme_pci.o diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 7a2b764492b..c35f9294dd9 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -8,8 +8,8 @@ obj-y += marvell/ obj-y += rockchip/ obj-y += socionext/
-obj-$(CONFIG_$(SPL_)PHY) += phy-uclass.o -obj-$(CONFIG_$(SPL_)NOP_PHY) += nop-phy.o +obj-$(CONFIG_$(XPL_)PHY) += phy-uclass.o +obj-$(CONFIG_$(XPL_)NOP_PHY) += nop-phy.o obj-$(CONFIG_MIPI_DPHY_HELPERS) += phy-core-mipi-dphy.o obj-$(CONFIG_AB8500_USB_PHY) += phy-ab8500-usb.o obj-$(CONFIG_APPLE_ATCPHY) += phy-apple-atc.o @@ -19,7 +19,7 @@ obj-$(CONFIG_BCM6358_USBH_PHY) += bcm6358-usbh-phy.o obj-$(CONFIG_BCM6368_USBH_PHY) += bcm6368-usbh-phy.o obj-$(CONFIG_BCM_SR_PCIE_PHY) += phy-bcm-sr-pcie.o obj-$(CONFIG_PHY_SANDBOX) += sandbox-phy.o -obj-$(CONFIG_$(SPL_)PIPE3_PHY) += ti-pipe3-phy.o +obj-$(CONFIG_$(XPL_)PIPE3_PHY) += ti-pipe3-phy.o obj-$(CONFIG_AM654_PHY) += phy-ti-am654.o obj-$(CONFIG_STI_USB_PHY) += sti_usb_phy.o obj-$(CONFIG_PHY_RCAR_GEN2) += phy-rcar-gen2.o diff --git a/drivers/phy/cadence/Makefile b/drivers/phy/cadence/Makefile index af63b32d9f5..e0da41cd7eb 100644 --- a/drivers/phy/cadence/Makefile +++ b/drivers/phy/cadence/Makefile @@ -1,2 +1,2 @@ -obj-$(CONFIG_$(SPL_)PHY_CADENCE_SIERRA) += phy-cadence-sierra.o -obj-$(CONFIG_$(SPL_)PHY_CADENCE_TORRENT) += phy-cadence-torrent.o +obj-$(CONFIG_$(XPL_)PHY_CADENCE_SIERRA) += phy-cadence-sierra.o +obj-$(CONFIG_$(XPL_)PHY_CADENCE_TORRENT) += phy-cadence-torrent.o diff --git a/drivers/phy/ti/Makefile b/drivers/phy/ti/Makefile index 873ddbf0363..699901fd15e 100644 --- a/drivers/phy/ti/Makefile +++ b/drivers/phy/ti/Makefile @@ -1 +1 @@ -obj-$(CONFIG_$(SPL_)PHY_J721E_WIZ) += phy-j721e-wiz.o +obj-$(CONFIG_$(XPL_)PHY_J721E_WIZ) += phy-j721e-wiz.o diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 6d7b7cd9051..634047a91f4 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -1,13 +1,13 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += pinctrl-uclass.o -obj-$(CONFIG_$(SPL_)PINCTRL_GENERIC) += pinctrl-generic.o +obj-$(CONFIG_$(XPL_)PINCTRL_GENERIC) += pinctrl-generic.o
obj-$(CONFIG_PINCTRL_APPLE) += pinctrl-apple.o obj-$(CONFIG_PINCTRL_AT91) += pinctrl-at91.o obj-$(CONFIG_PINCTRL_AT91PIO4) += pinctrl-at91-pio4.o obj-y += nxp/ -obj-$(CONFIG_$(SPL_)PINCTRL_ROCKCHIP) += rockchip/ +obj-$(CONFIG_$(XPL_)PINCTRL_ROCKCHIP) += rockchip/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_ARCH_ATH79) += ath79/ obj-$(CONFIG_PINCTRL_INTEL) += intel/ @@ -18,7 +18,7 @@ obj-$(CONFIG_ARCH_RENESAS) += renesas/ obj-$(CONFIG_ARCH_RZN1) += renesas/ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o obj-$(CONFIG_PINCTRL_SUNXI) += sunxi/ -obj-$(CONFIG_$(SPL_)PINCTRL_TEGRA) += tegra/ +obj-$(CONFIG_$(XPL_)PINCTRL_TEGRA) += tegra/ obj-$(CONFIG_PINCTRL_UNIPHIER) += uniphier/ obj-$(CONFIG_PINCTRL_PIC32) += pinctrl_pic32.o obj-$(CONFIG_PINCTRL_EXYNOS) += exynos/ @@ -32,7 +32,7 @@ obj-$(CONFIG_PINCTRL_QE) += pinctrl-qe-io.o obj-$(CONFIG_PINCTRL_SINGLE) += pinctrl-single.o obj-$(CONFIG_PINCTRL_STI) += pinctrl-sti.o obj-$(CONFIG_PINCTRL_STM32) += pinctrl_stm32.o -obj-$(CONFIG_$(SPL_)PINCTRL_STMFX) += pinctrl-stmfx.o +obj-$(CONFIG_$(XPL_)PINCTRL_STMFX) += pinctrl-stmfx.o obj-y += broadcom/ obj-$(CONFIG_PINCTRL_ZYNQMP) += pinctrl-zynqmp.o obj-$(CONFIG_PINCTRL_STARFIVE) += starfive/ diff --git a/drivers/power/domain/Makefile b/drivers/power/domain/Makefile index 2daab73eb75..110646c503a 100644 --- a/drivers/power/domain/Makefile +++ b/drivers/power/domain/Makefile @@ -3,7 +3,7 @@ # Copyright (c) 2016, NVIDIA CORPORATION. #
-obj-$(CONFIG_$(SPL_)POWER_DOMAIN) += power-domain-uclass.o +obj-$(CONFIG_$(XPL_)POWER_DOMAIN) += power-domain-uclass.o obj-$(CONFIG_APPLE_PMGR_POWER_DOMAIN) += apple-pmgr.o obj-$(CONFIG_BCM6328_POWER_DOMAIN) += bcm6328-power-domain.o obj-$(CONFIG_IMX8_POWER_DOMAIN) += imx8-power-domain-legacy.o imx8-power-domain.o diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index a2d59deeed8..48f7dd49ef8 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -4,33 +4,33 @@ # Lukasz Majewski l.majewski@samsung.com
obj-$(CONFIG_$(SPL_TPL_)DM_PMIC) += pmic-uclass.o -obj-$(CONFIG_$(SPL_)DM_PMIC_FAN53555) += fan53555.o -obj-$(CONFIG_$(SPL_)DM_PMIC_DA9063) += da9063.o -obj-$(CONFIG_$(SPL_)DM_PMIC_MAX77663) += max77663.o +obj-$(CONFIG_$(XPL_)DM_PMIC_FAN53555) += fan53555.o +obj-$(CONFIG_$(XPL_)DM_PMIC_DA9063) += da9063.o +obj-$(CONFIG_$(XPL_)DM_PMIC_MAX77663) += max77663.o obj-$(CONFIG_DM_PMIC_MAX77686) += max77686.o obj-$(CONFIG_DM_PMIC_MAX8998) += max8998.o obj-$(CONFIG_DM_PMIC_MC34708) += mc34708.o -obj-$(CONFIG_$(SPL_)DM_PMIC_BD71837) += bd71837.o -obj-$(CONFIG_$(SPL_)DM_PMIC_MP5416) += mp5416.o -obj-$(CONFIG_$(SPL_)DM_PMIC_PFUZE100) += pfuze100.o -obj-$(CONFIG_$(SPL_)DM_PMIC_PCA9450) += pca9450.o +obj-$(CONFIG_$(XPL_)DM_PMIC_BD71837) += bd71837.o +obj-$(CONFIG_$(XPL_)DM_PMIC_MP5416) += mp5416.o +obj-$(CONFIG_$(XPL_)DM_PMIC_PFUZE100) += pfuze100.o +obj-$(CONFIG_$(XPL_)DM_PMIC_PCA9450) += pca9450.o obj-$(CONFIG_PMIC_S2MPS11) += s2mps11.o obj-$(CONFIG_DM_PMIC_SANDBOX) += sandbox.o i2c_pmic_emul.o obj-$(CONFIG_PMIC_AB8500) += ab8500.o obj-$(CONFIG_PMIC_ACT8846) += act8846.o obj-$(CONFIG_PMIC_AS3722) += as3722.o as3722_gpio.o -obj-$(CONFIG_$(SPL_)PMIC_AXP) += axp.o +obj-$(CONFIG_$(XPL_)PMIC_AXP) += axp.o obj-$(CONFIG_PMIC_MAX8997) += max8997.o obj-$(CONFIG_PMIC_QCOM) += pmic_qcom.o obj-$(CONFIG_$(SPL_TPL_)PMIC_RK8XX) += rk8xx.o -obj-$(CONFIG_$(SPL_)PMIC_RN5T567) += rn5t567.o +obj-$(CONFIG_$(XPL_)PMIC_RN5T567) += rn5t567.o obj-$(CONFIG_PMIC_TPS65090) += tps65090.o obj-$(CONFIG_PMIC_S5M8767) += s5m8767.o obj-$(CONFIG_DM_PMIC_TPS65910) += pmic_tps65910_dm.o -obj-$(CONFIG_$(SPL_)DM_PMIC_TPS80031) += tps80031.o -obj-$(CONFIG_$(SPL_)PMIC_PALMAS) += palmas.o -obj-$(CONFIG_$(SPL_)PMIC_LP873X) += lp873x.o -obj-$(CONFIG_$(SPL_)PMIC_LP87565) += lp87565.o +obj-$(CONFIG_$(XPL_)DM_PMIC_TPS80031) += tps80031.o +obj-$(CONFIG_$(XPL_)PMIC_PALMAS) += palmas.o +obj-$(CONFIG_$(XPL_)PMIC_LP873X) += lp873x.o +obj-$(CONFIG_$(XPL_)PMIC_LP87565) += lp87565.o obj-$(CONFIG_PMIC_STPMIC1) += stpmic1.o obj-$(CONFIG_PMIC_TPS65217) += pmic_tps65217.o obj-$(CONFIG_PMIC_TPS65219) += tps65219.o @@ -38,7 +38,7 @@ obj-$(CONFIG_PMIC_TPS65941) += tps65941.o obj-$(CONFIG_PMIC_RAA215300) += raa215300.o obj-$(CONFIG_POWER_TPS65218) += pmic_tps65218.o
-ifeq ($(CONFIG_$(SPL_)POWER_LEGACY),y) +ifeq ($(CONFIG_$(XPL_)POWER_LEGACY),y) obj-$(CONFIG_POWER_LTC3676) += pmic_ltc3676.o obj-$(CONFIG_POWER_PCA9450) += pmic_pca9450.o obj-$(CONFIG_POWER_PFUZE100) += pmic_pfuze100.o @@ -47,5 +47,5 @@ obj-$(CONFIG_POWER_HI6553) += pmic_hi6553.o obj-$(CONFIG_POWER_MC34VR500) += pmic_mc34vr500.o endif
-obj-$(CONFIG_$(SPL_)POWER_TPS62362) += pmic_tps62362.o +obj-$(CONFIG_$(XPL_)POWER_TPS62362) += pmic_tps62362.o obj-$(CONFIG_SPL_POWER_TPS65910) += pmic_tps65910.o diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 54db0885657..cac02aaa36f 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -4,41 +4,41 @@ # Przemyslaw Marczak p.marczak@samsung.com #
-obj-$(CONFIG_$(SPL_)DM_REGULATOR) += regulator-uclass.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR) += regulator-uclass.o obj-$(CONFIG_REGULATOR_ACT8846) += act8846.o obj-$(CONFIG_REGULATOR_AS3722) += as3722_regulator.o -obj-$(CONFIG_$(SPL_)REGULATOR_AXP) += axp_regulator.o -obj-$(CONFIG_$(SPL_)REGULATOR_AXP_USB_POWER) += axp_usb_power.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_DA9063) += da9063.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_MAX77663) += max77663_regulator.o +obj-$(CONFIG_$(XPL_)REGULATOR_AXP) += axp_regulator.o +obj-$(CONFIG_$(XPL_)REGULATOR_AXP_USB_POWER) += axp_usb_power.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_DA9063) += da9063.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_MAX77663) += max77663_regulator.o obj-$(CONFIG_DM_REGULATOR_MAX77686) += max77686.o obj-$(CONFIG_DM_REGULATOR_NPCM8XX) += npcm8xx_regulator.o -obj-$(CONFIG_$(SPL_)DM_PMIC_PFUZE100) += pfuze100.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_BD71837) += bd71837.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_PCA9450) += pca9450.o -obj-$(CONFIG_$(SPL_)REGULATOR_PWM) += pwm_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_FAN53555) += fan53555.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_COMMON) += regulator_common.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_FIXED) += fixed.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_GPIO) += gpio-regulator.o +obj-$(CONFIG_$(XPL_)DM_PMIC_PFUZE100) += pfuze100.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_BD71837) += bd71837.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_PCA9450) += pca9450.o +obj-$(CONFIG_$(XPL_)REGULATOR_PWM) += pwm_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_FAN53555) += fan53555.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_COMMON) += regulator_common.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_FIXED) += fixed.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_GPIO) += gpio-regulator.o obj-$(CONFIG_DM_REGULATOR_QCOM_RPMH) += qcom-rpmh-regulator.o obj-$(CONFIG_$(SPL_TPL_)REGULATOR_RK8XX) += rk8xx.o obj-$(CONFIG_DM_REGULATOR_S2MPS11) += s2mps11_regulator.o obj-$(CONFIG_REGULATOR_S5M8767) += s5m8767.o obj-$(CONFIG_DM_REGULATOR_SANDBOX) += sandbox.o obj-$(CONFIG_REGULATOR_TPS65090) += tps65090_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_PALMAS) += palmas_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_PBIAS) += pbias_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP873X) += lp873x_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP87565) += lp87565_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_STM32_VREFBUF) += stm32-vrefbuf.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_PALMAS) += palmas_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_PBIAS) += pbias_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_LP873X) += lp873x_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_LP87565) += lp87565_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_STM32_VREFBUF) += stm32-vrefbuf.o obj-$(CONFIG_DM_REGULATOR_TPS65910) += tps65910_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_TPS65911) += tps65911_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_TPS65911) += tps65911_regulator.o obj-$(CONFIG_DM_REGULATOR_TPS62360) += tps62360_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_TPS6287X) += tps6287x_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_TPS80031) += tps80031_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMIC1) += stpmic1.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_TPS6287X) += tps6287x_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_TPS80031) += tps80031_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_STPMIC1) += stpmic1.o obj-$(CONFIG_DM_REGULATOR_TPS65941) += tps65941_regulator.o obj-$(CONFIG_DM_REGULATOR_SCMI) += scmi_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_ANATOP) += anatop_regulator.o +obj-$(CONFIG_$(XPL_)DM_REGULATOR_ANATOP) += anatop_regulator.o obj-$(CONFIG_DM_REGULATOR_TPS65219) += tps65219_regulator.o diff --git a/drivers/remoteproc/Makefile b/drivers/remoteproc/Makefile index e09ed1aa4d4..801b0965e4f 100644 --- a/drivers/remoteproc/Makefile +++ b/drivers/remoteproc/Makefile @@ -4,7 +4,7 @@ # Texas Instruments Incorporated - https://www.ti.com/ #
-obj-$(CONFIG_$(SPL_)REMOTEPROC) += rproc-uclass.o rproc-elf-loader.o +obj-$(CONFIG_$(XPL_)REMOTEPROC) += rproc-uclass.o rproc-elf-loader.o
# Remote proc drivers - Please keep this list alphabetically sorted. obj-$(CONFIG_K3_SYSTEM_CONTROLLER) += k3_system_controller.o diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 66bd30b837b..1c0b013eb1f 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -11,7 +11,7 @@ endif
obj-$(CONFIG_PL01X_SERIAL) += serial_pl01x.o obj-$(CONFIG_PL011_SERIAL) += serial_pl01x.o -obj-$(CONFIG_$(SPL_)SYS_NS16550_SERIAL) += serial_ns16550.o +obj-$(CONFIG_$(XPL_)SYS_NS16550_SERIAL) += serial_ns16550.o
obj-$(CONFIG_ALTERA_UART) += altera_uart.o obj-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index fec4af392e6..7a847e8388b 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -5,14 +5,14 @@ obj-y += timer-uclass.o obj-$(CONFIG_ADI_SC5XX_TIMER) += adi_sc5xx_timer.o obj-$(CONFIG_ALTERA_TIMER) += altera_timer.o -obj-$(CONFIG_$(SPL_)ANDES_PLMT_TIMER) += andes_plmt_timer.o +obj-$(CONFIG_$(XPL_)ANDES_PLMT_TIMER) += andes_plmt_timer.o obj-$(CONFIG_ARC_TIMER) += arc_timer.o obj-$(CONFIG_ARM_TWD_TIMER) += arm_twd_timer.o obj-$(CONFIG_AST_TIMER) += ast_timer.o obj-$(CONFIG_AST_IBEX_TIMER) += ast_ibex_timer.o obj-$(CONFIG_ATCPIT100_TIMER) += atcpit100_timer.o -obj-$(CONFIG_$(SPL_)ATMEL_PIT_TIMER) += atmel_pit_timer.o -obj-$(CONFIG_$(SPL_)ATMEL_TCB_TIMER) += atmel_tcb_timer.o +obj-$(CONFIG_$(XPL_)ATMEL_PIT_TIMER) += atmel_pit_timer.o +obj-$(CONFIG_$(XPL_)ATMEL_TCB_TIMER) += atmel_tcb_timer.o obj-$(CONFIG_CADENCE_TTC_TIMER) += cadence-ttc.o obj-$(CONFIG_DESIGNWARE_APB_TIMER) += dw-apb-timer.o obj-$(CONFIG_FTTMR010_TIMER) += fttmr010_timer.o @@ -27,7 +27,7 @@ obj-$(CONFIG_RISCV_TIMER) += riscv_timer.o obj-$(CONFIG_ROCKCHIP_TIMER) += rockchip_timer.o obj-$(CONFIG_SANDBOX_TIMER) += sandbox_timer.o obj-$(CONFIG_SP804_TIMER) += sp804_timer.o -obj-$(CONFIG_$(SPL_)RISCV_ACLINT) += riscv_aclint_timer.o +obj-$(CONFIG_$(XPL_)RISCV_ACLINT) += riscv_aclint_timer.o obj-$(CONFIG_ARM_GLOBAL_TIMER) += arm_global_timer.o obj-$(CONFIG_STM32_TIMER) += stm32_timer.o obj-$(CONFIG_TEGRA_TIMER) += tegra-timer.o diff --git a/drivers/usb/cdns3/Makefile b/drivers/usb/cdns3/Makefile index 18d7190755d..d6047856091 100644 --- a/drivers/usb/cdns3/Makefile +++ b/drivers/usb/cdns3/Makefile @@ -4,8 +4,8 @@ cdns3-y := core.o drd.o
obj-$(CONFIG_USB_CDNS3) += cdns3.o
-cdns3-$(CONFIG_$(SPL_)USB_CDNS3_GADGET) += gadget.o ep0.o +cdns3-$(CONFIG_$(XPL_)USB_CDNS3_GADGET) += gadget.o ep0.o
-cdns3-$(CONFIG_$(SPL_)USB_CDNS3_HOST) += host.o +cdns3-$(CONFIG_$(XPL_)USB_CDNS3_HOST) += host.o
obj-$(CONFIG_USB_CDNS3_TI) += cdns3-ti.o diff --git a/drivers/usb/common/Makefile b/drivers/usb/common/Makefile index 2e9353b76a6..11cc4657a0f 100644 --- a/drivers/usb/common/Makefile +++ b/drivers/usb/common/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2016 Freescale Semiconductor, Inc. #
-obj-$(CONFIG_$(SPL_)DM_USB) += common.o +obj-$(CONFIG_$(XPL_)DM_USB) += common.o obj-$(CONFIG_USB_ISP1760) += usb_urb.o obj-$(CONFIG_USB_MUSB_HOST) += usb_urb.o obj-$(CONFIG_USB_MUSB_GADGET) += usb_urb.o diff --git a/drivers/usb/dwc3/Makefile b/drivers/usb/dwc3/Makefile index a46b6824ab7..a085c9d4628 100644 --- a/drivers/usb/dwc3/Makefile +++ b/drivers/usb/dwc3/Makefile @@ -6,11 +6,11 @@ dwc3-y := core.o
obj-$(CONFIG_USB_DWC3_GADGET) += gadget.o ep0.o
-obj-$(CONFIG_$(SPL_)USB_DWC3_AM62) += dwc3-am62.o +obj-$(CONFIG_$(XPL_)USB_DWC3_AM62) += dwc3-am62.o obj-$(CONFIG_USB_DWC3_OMAP) += dwc3-omap.o obj-$(CONFIG_USB_DWC3_MESON_G12A) += dwc3-meson-g12a.o obj-$(CONFIG_USB_DWC3_MESON_GXL) += dwc3-meson-gxl.o -obj-$(CONFIG_$(SPL_)USB_DWC3_GENERIC) += dwc3-generic.o +obj-$(CONFIG_$(XPL_)USB_DWC3_GENERIC) += dwc3-generic.o obj-$(CONFIG_USB_DWC3_UNIPHIER) += dwc3-uniphier.o obj-$(CONFIG_USB_DWC3_LAYERSCAPE) += dwc3-layerscape.o obj-$(CONFIG_USB_DWC3_PHY_OMAP) += ti_usb_phy.o diff --git a/drivers/usb/gadget/udc/Makefile b/drivers/usb/gadget/udc/Makefile index 467c566f6d3..4b6a8fdfeee 100644 --- a/drivers/usb/gadget/udc/Makefile +++ b/drivers/usb/gadget/udc/Makefile @@ -2,9 +2,9 @@ # # USB peripheral controller drivers
-ifndef CONFIG_$(SPL_)DM_USB_GADGET +ifndef CONFIG_$(XPL_)DM_USB_GADGET obj-$(CONFIG_USB_DWC3_GADGET) += udc-core.o endif
-obj-$(CONFIG_$(SPL_)DM_USB_GADGET) += udc-core.o +obj-$(CONFIG_$(XPL_)DM_USB_GADGET) += udc-core.o obj-y += udc-uclass.o diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 8dad36f9369..07deb4fadd6 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifdef CONFIG_$(SPL_)DM_USB +ifdef CONFIG_$(XPL_)DM_USB obj-y += usb-uclass.o obj-$(CONFIG_SANDBOX) += usb-sandbox.o endif diff --git a/drivers/video/Makefile b/drivers/video/Makefile index f3f70cd04a1..93fed8c491a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -34,7 +34,7 @@ obj-${CONFIG_EXYNOS_FB} += exynos/ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/ obj-${CONFIG_VIDEO_STM32} += stm32/ obj-${CONFIG_VIDEO_TEGRA124} += tegra124/ -obj-${CONFIG_$(SPL_)VIDEO_TIDSS} += tidss/ +obj-${CONFIG_$(XPL_)VIDEO_TIDSS} += tidss/ obj-y += ti/
obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o diff --git a/drivers/video/tidss/Makefile b/drivers/video/tidss/Makefile index a29cee2a414..f0cbe1d4ed1 100644 --- a/drivers/video/tidss/Makefile +++ b/drivers/video/tidss/Makefile @@ -9,4 +9,4 @@ # Author: Tomi Valkeinen tomi.valkeinen@ti.com
-obj-${CONFIG_$(SPL_)VIDEO_TIDSS} = tidss_drv.o +obj-${CONFIG_$(XPL_)VIDEO_TIDSS} = tidss_drv.o diff --git a/fs/fat/Makefile b/fs/fat/Makefile index f84efaccc75..7414b3602aa 100644 --- a/fs/fat/Makefile +++ b/fs/fat/Makefile @@ -1,5 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_$(SPL_)FS_FAT) = fat.o -obj-$(CONFIG_$(SPL_)FAT_WRITE) = fat_write.o +obj-$(CONFIG_$(XPL_)FS_FAT) = fat.o +obj-$(CONFIG_$(XPL_)FAT_WRITE) = fat_write.o diff --git a/fs/squashfs/Makefile b/fs/squashfs/Makefile index ba66ee821c2..0772e1a497d 100644 --- a/fs/squashfs/Makefile +++ b/fs/squashfs/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_$(SPL_)FS_SQUASHFS) = sqfs.o \ +obj-$(CONFIG_$(XPL_)FS_SQUASHFS) = sqfs.o \ sqfs_inode.o \ sqfs_dir.o \ sqfs_decompressor.o diff --git a/lib/Makefile b/lib/Makefile index 66f84408aae..139476a4a23 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -71,25 +71,25 @@ obj-$(CONFIG_$(SPL_TPL_)CRC16) += crc16.o obj-y += crypto/
obj-$(CONFIG_$(SPL_TPL_)ACPI) += acpi/ -obj-$(CONFIG_$(SPL_)MD5) += md5.o +obj-$(CONFIG_$(XPL_)MD5) += md5.o obj-$(CONFIG_ECDSA) += ecdsa/ -obj-$(CONFIG_$(SPL_)RSA) += rsa/ +obj-$(CONFIG_$(XPL_)RSA) += rsa/ obj-$(CONFIG_HASH) += hash-checksum.o obj-$(CONFIG_BLAKE2) += blake2/blake2b.o -obj-$(CONFIG_$(SPL_)SHA1) += sha1.o -obj-$(CONFIG_$(SPL_)SHA256) += sha256.o -obj-$(CONFIG_$(SPL_)SHA512) += sha512.o +obj-$(CONFIG_$(XPL_)SHA1) += sha1.o +obj-$(CONFIG_$(XPL_)SHA256) += sha256.o +obj-$(CONFIG_$(XPL_)SHA512) += sha512.o obj-$(CONFIG_CRYPT_PW) += crypt/ -obj-$(CONFIG_$(SPL_)ASN1_DECODER) += asn1_decoder.o +obj-$(CONFIG_$(XPL_)ASN1_DECODER) += asn1_decoder.o
-obj-$(CONFIG_$(SPL_)ZLIB) += zlib/ -obj-$(CONFIG_$(SPL_)ZSTD) += zstd/ -obj-$(CONFIG_$(SPL_)GZIP) += gunzip.o -obj-$(CONFIG_$(SPL_)LZO) += lzo/ -obj-$(CONFIG_$(SPL_)LZMA) += lzma/ -obj-$(CONFIG_$(SPL_)LZ4) += lz4_wrapper.o +obj-$(CONFIG_$(XPL_)ZLIB) += zlib/ +obj-$(CONFIG_$(XPL_)ZSTD) += zstd/ +obj-$(CONFIG_$(XPL_)GZIP) += gunzip.o +obj-$(CONFIG_$(XPL_)LZO) += lzo/ +obj-$(CONFIG_$(XPL_)LZMA) += lzma/ +obj-$(CONFIG_$(XPL_)LZ4) += lz4_wrapper.o
-obj-$(CONFIG_$(SPL_)LIB_RATIONAL) += rational.o +obj-$(CONFIG_$(XPL_)LIB_RATIONAL) += rational.o
obj-$(CONFIG_LIBAVB) += libavb/
@@ -144,7 +144,7 @@ else obj-y += vsprintf.o strto.o obj-$(CONFIG_SSCANF) += sscanf.o endif -obj-$(CONFIG_$(SPL_)OID_REGISTRY) += oid_registry.o +obj-$(CONFIG_$(XPL_)OID_REGISTRY) += oid_registry.o
obj-y += abuf.o obj-y += alist.o diff --git a/lib/acpi/Makefile b/lib/acpi/Makefile index cc2868488a0..99be19adb4c 100644 --- a/lib/acpi/Makefile +++ b/lib/acpi/Makefile @@ -5,10 +5,10 @@ obj-y += acpi.o
ifdef CONFIG_$(SPL_TPL_)GENERATE_ACPI_TABLE
-obj-$(CONFIG_$(SPL_)ACPIGEN) += acpigen.o -obj-$(CONFIG_$(SPL_)ACPIGEN) += acpi_device.o -obj-$(CONFIG_$(SPL_)ACPIGEN) += acpi_dp.o -obj-$(CONFIG_$(SPL_)ACPIGEN) += acpi_table.o +obj-$(CONFIG_$(XPL_)ACPIGEN) += acpigen.o +obj-$(CONFIG_$(XPL_)ACPIGEN) += acpi_device.o +obj-$(CONFIG_$(XPL_)ACPIGEN) += acpi_dp.o +obj-$(CONFIG_$(XPL_)ACPIGEN) += acpi_table.o obj-y += acpi_writer.o
# With QEMU the ACPI tables come from there, not from U-Boot diff --git a/lib/aes/Makefile b/lib/aes/Makefile index daed52a713b..ad6228a7dad 100644 --- a/lib/aes/Makefile +++ b/lib/aes/Makefile @@ -2,4 +2,4 @@ # # Copyright (c) 2019, Softathome
-obj-$(CONFIG_$(SPL_)FIT_CIPHER) += aes-decrypt.o +obj-$(CONFIG_$(XPL_)FIT_CIPHER) += aes-decrypt.o diff --git a/lib/crypto/Makefile b/lib/crypto/Makefile index 3259c951241..de1510d3eb5 100644 --- a/lib/crypto/Makefile +++ b/lib/crypto/Makefile @@ -3,16 +3,16 @@ # Makefile for asymmetric cryptographic keys #
-obj-$(CONFIG_$(SPL_)ASYMMETRIC_KEY_TYPE) += asymmetric_keys.o +obj-$(CONFIG_$(XPL_)ASYMMETRIC_KEY_TYPE) += asymmetric_keys.o
asymmetric_keys-y := asymmetric_type.o
-obj-$(CONFIG_$(SPL_)ASYMMETRIC_PUBLIC_KEY_SUBTYPE) += public_key.o +obj-$(CONFIG_$(XPL_)ASYMMETRIC_PUBLIC_KEY_SUBTYPE) += public_key.o
# # RSA public key parser # -obj-$(CONFIG_$(SPL_)RSA_PUBLIC_KEY_PARSER) += rsa_public_key.o +obj-$(CONFIG_$(XPL_)RSA_PUBLIC_KEY_PARSER) += rsa_public_key.o rsa_public_key-y := \ rsapubkey.asn1.o \ rsa_helper.o @@ -30,7 +30,7 @@ endif # # X.509 Certificate handling # -obj-$(CONFIG_$(SPL_)X509_CERTIFICATE_PARSER) += x509_key_parser.o +obj-$(CONFIG_$(XPL_)X509_CERTIFICATE_PARSER) += x509_key_parser.o x509_key_parser-y := \ x509.asn1.o \ x509_akid.asn1.o \ @@ -47,11 +47,11 @@ $(obj)/x509_akid.asn1.o: $(obj)/x509_akid.asn1.c $(obj)/x509_akid.asn1.h # # PKCS#7 message handling # -obj-$(CONFIG_$(SPL_)PKCS7_MESSAGE_PARSER) += pkcs7_message.o +obj-$(CONFIG_$(XPL_)PKCS7_MESSAGE_PARSER) += pkcs7_message.o pkcs7_message-y := \ pkcs7.asn1.o \ pkcs7_parser.o -obj-$(CONFIG_$(SPL_)PKCS7_VERIFY) += pkcs7_verify.o +obj-$(CONFIG_$(XPL_)PKCS7_VERIFY) += pkcs7_verify.o
$(obj)/pkcs7_parser.o: $(obj)/pkcs7.asn1.h $(obj)/pkcs7.asn1.o: $(obj)/pkcs7.asn1.c $(obj)/pkcs7.asn1.h @@ -59,7 +59,7 @@ $(obj)/pkcs7.asn1.o: $(obj)/pkcs7.asn1.c $(obj)/pkcs7.asn1.h # # Signed PE binary-wrapped key handling # -obj-$(CONFIG_$(SPL_)MSCODE_PARSER) += mscode.o +obj-$(CONFIG_$(XPL_)MSCODE_PARSER) += mscode.o
mscode-y := \ mscode_parser.o \ diff --git a/lib/ecdsa/Makefile b/lib/ecdsa/Makefile index 771d6d3135b..32b6183f6ff 100644 --- a/lib/ecdsa/Makefile +++ b/lib/ecdsa/Makefile @@ -1 +1 @@ -obj-$(CONFIG_$(SPL_)ECDSA_VERIFY) += ecdsa-verify.o +obj-$(CONFIG_$(XPL_)ECDSA_VERIFY) += ecdsa-verify.o diff --git a/net/Makefile b/net/Makefile index 64ab7ec740a..a1d37855593 100644 --- a/net/Makefile +++ b/net/Makefile @@ -10,14 +10,14 @@ obj-$(CONFIG_CMD_BOOTP) += bootp.o obj-$(CONFIG_CMD_CDP) += cdp.o obj-$(CONFIG_CMD_DNS) += dns.o obj-$(CONFIG_DM_DSA) += dsa-uclass.o -obj-$(CONFIG_$(SPL_)DM_ETH) += eth-uclass.o +obj-$(CONFIG_$(XPL_)DM_ETH) += eth-uclass.o obj-$(CONFIG_$(SPL_TPL_)BOOTDEV_ETH) += eth_bootdev.o obj-$(CONFIG_DM_MDIO) += mdio-uclass.o obj-$(CONFIG_DM_MDIO_MUX) += mdio-mux-uclass.o -obj-$(CONFIG_$(SPL_)DM_ETH) += eth_common.o +obj-$(CONFIG_$(XPL_)DM_ETH) += eth_common.o obj-$(CONFIG_CMD_LINK_LOCAL) += link_local.o obj-$(CONFIG_IPV6) += ndisc.o -obj-$(CONFIG_$(SPL_)DM_ETH) += net.o +obj-$(CONFIG_$(XPL_)DM_ETH) += net.o obj-$(CONFIG_IPV6) += net6.o obj-$(CONFIG_CMD_NFS) += nfs.o obj-$(CONFIG_CMD_PING) += ping.o diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index b70b75ee68d..1a6b28feedf 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -325,7 +325,7 @@ endif .SECONDARY:
ifdef CONFIG_XPL_BUILD -SPL_ := SPL_ +XPL_ := SPL_ ifeq ($(CONFIG_VPL_BUILD),y) SPL_TPL_ := VPL_ else @@ -336,6 +336,6 @@ SPL_TPL_ := SPL_ endif endif else -SPL_ := +XPL_ := SPL_TPL_ := endif diff --git a/scripts/Makefile.xpl b/scripts/Makefile.xpl index b43ff998679..11ae93f8556 100644 --- a/scripts/Makefile.xpl +++ b/scripts/Makefile.xpl @@ -59,7 +59,7 @@ endif export SPL_NAME
ifdef CONFIG_XPL_BUILD -SPL_ := SPL_ +XPL_ := SPL_ ifeq ($(CONFIG_VPL_BUILD),y) SPL_TPL_ := VPL_ else @@ -70,7 +70,7 @@ SPL_TPL_ := SPL_ endif endif else -SPL_ := +XPL_ := SPL_TPL_ := endif
diff --git a/test/Makefile b/test/Makefile index f801d87e385..145c952d2c3 100644 --- a/test/Makefile +++ b/test/Makefile @@ -4,24 +4,24 @@
obj-y += test-main.o
-ifneq ($(CONFIG_$(SPL_)BLOBLIST),) -obj-$(CONFIG_$(SPL_)CMDLINE) += bloblist.o -obj-$(CONFIG_$(SPL_)CMDLINE) += bootm.o +ifneq ($(CONFIG_$(XPL_)BLOBLIST),) +obj-$(CONFIG_$(XPL_)CMDLINE) += bloblist.o +obj-$(CONFIG_$(XPL_)CMDLINE) += bootm.o endif -obj-$(CONFIG_$(SPL_)CMDLINE) += cmd/ -obj-$(CONFIG_$(SPL_)CMDLINE) += cmd_ut.o -obj-$(CONFIG_$(SPL_)CMDLINE) += command_ut.o -obj-$(CONFIG_$(SPL_)UT_COMPRESSION) += compression.o +obj-$(CONFIG_$(XPL_)CMDLINE) += cmd/ +obj-$(CONFIG_$(XPL_)CMDLINE) += cmd_ut.o +obj-$(CONFIG_$(XPL_)CMDLINE) += command_ut.o +obj-$(CONFIG_$(XPL_)UT_COMPRESSION) += compression.o obj-y += dm/ obj-$(CONFIG_FUZZ) += fuzz/ ifndef CONFIG_SANDBOX_VPL obj-$(CONFIG_UNIT_TEST) += lib/ endif ifneq ($(CONFIG_HUSH_PARSER),) -obj-$(CONFIG_$(SPL_)CMDLINE) += hush/ +obj-$(CONFIG_$(XPL_)CMDLINE) += hush/ endif -obj-$(CONFIG_$(SPL_)CMDLINE) += print_ut.o -obj-$(CONFIG_$(SPL_)CMDLINE) += str_ut.o +obj-$(CONFIG_$(XPL_)CMDLINE) += print_ut.o +obj-$(CONFIG_$(XPL_)CMDLINE) += str_ut.o obj-$(CONFIG_UT_TIME) += time_ut.o obj-y += ut.o
@@ -29,7 +29,7 @@ ifeq ($(CONFIG_XPL_BUILD),) obj-y += boot/ obj-$(CONFIG_UNIT_TEST) += common/ obj-y += log/ -obj-$(CONFIG_$(SPL_)UT_UNICODE) += unicode_ut.o +obj-$(CONFIG_$(XPL_)UT_UNICODE) += unicode_ut.o else obj-$(CONFIG_SPL_UT_LOAD) += image/ endif diff --git a/test/fuzz/Makefile b/test/fuzz/Makefile index 663b79ce80b..8a135b65e4b 100644 --- a/test/fuzz/Makefile +++ b/test/fuzz/Makefile @@ -4,5 +4,5 @@ # Written by Andrew Scull ascull@google.com #
-obj-$(CONFIG_$(SPL_)CMDLINE) += cmd_fuzz.o +obj-$(CONFIG_$(XPL_)CMDLINE) += cmd_fuzz.o obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o diff --git a/tools/qconfig.py b/tools/qconfig.py index 71e911eeb3b..e025f560928 100755 --- a/tools/qconfig.py +++ b/tools/qconfig.py @@ -1220,8 +1220,8 @@ def scan_makefiles(fnames):
>>> RE_MK_CONFIGS.search('CONFIG_FRED').groups() (None, 'FRED') - >>> RE_MK_CONFIGS.search('CONFIG_$(SPL_)MARY').groups() - ('$(SPL_)', 'MARY') + >>> RE_MK_CONFIGS.search('CONFIG_$(XPL_)MARY').groups() + ('$(XPL_)', 'MARY') >>> RE_MK_CONFIGS.search('CONFIG_$(SPL_TPL_)MARY').groups() ('$(SPL_TPL_)', 'MARY') """ @@ -1321,7 +1321,7 @@ def do_scan_source(path, do_update): spl_mode (int): If MODE_SPL, look at source code which implies an SPL_ option, but for which there is none; for MOD_PROPER, look at source code which implies a Proper - option (i.e. use of CONFIG_IS_ENABLED() or $(SPL_) or + option (i.e. use of CONFIG_IS_ENABLED() or $(XPL_) or $(SPL_TPL_) but for which there none; if MODE_NORMAL, ignore SPL
Use PHASE_ as the symbol to select a particular XPL build. This means that SPL_TPL_ is no-longer set.
Update the comment in bootstage to refer to this symbol, instead of SPL_
Makefile | 2 +- arch/arm/cpu/armv8/Makefile | 2 +- arch/arm/lib/Makefile | 16 +++--- arch/arm/mach-at91/arm926ejs/Makefile | 2 +- arch/arm/mach-omap2/Makefile | 2 +- arch/arm/mach-rockchip/Makefile | 2 +- arch/powerpc/lib/Makefile | 2 +- arch/riscv/lib/Makefile | 14 ++--- arch/x86/Makefile | 6 +- arch/x86/cpu/Makefile | 8 +-- arch/x86/cpu/broadwell/Makefile | 10 ++-- arch/x86/cpu/intel_common/Makefile | 10 ++-- arch/x86/lib/Makefile | 6 +- board/coreboot/coreboot/Makefile | 2 +- boot/Makefile | 80 +++++++++++++-------------- common/Makefile | 26 ++++----- common/bootstage.c | 4 +- common/init/Makefile | 2 +- common/spl/Makefile | 56 +++++++++---------- disk/Makefile | 18 +++--- drivers/Makefile | 70 +++++++++++------------ drivers/adc/Makefile | 2 +- drivers/block/Makefile | 8 +-- drivers/cache/Makefile | 2 +- drivers/clk/Makefile | 18 +++--- drivers/clk/exynos/Makefile | 2 +- drivers/clk/imx/Makefile | 20 +++---- drivers/clk/ti/Makefile | 4 +- drivers/core/Makefile | 10 ++-- drivers/crypto/fsl/Makefile | 2 +- drivers/gpio/Makefile | 6 +- drivers/input/Makefile | 6 +- drivers/misc/Makefile | 16 +++--- drivers/mmc/Makefile | 6 +- drivers/mtd/Makefile | 4 +- drivers/mtd/nand/Makefile | 2 +- drivers/mtd/nand/raw/Makefile | 2 +- drivers/mtd/spi/Makefile | 8 +-- drivers/pinctrl/starfive/Makefile | 4 +- drivers/power/Makefile | 8 +-- drivers/power/acpi_pmc/Makefile | 2 +- drivers/power/pmic/Makefile | 4 +- drivers/power/regulator/Makefile | 2 +- drivers/ram/Makefile | 2 +- drivers/reset/Makefile | 2 +- drivers/rng/Makefile | 2 +- drivers/rtc/Makefile | 6 +- drivers/scsi/Makefile | 2 +- drivers/serial/Makefile | 2 +- drivers/spi/Makefile | 2 +- drivers/sysreset/Makefile | 14 ++--- drivers/tpm/Makefile | 4 +- drivers/usb/gadget/Makefile | 6 +- drivers/usb/host/Makefile | 4 +- drivers/video/Makefile | 16 +++--- drivers/watchdog/Makefile | 2 +- env/Makefile | 22 ++++---- fs/sandbox/Makefile | 2 +- lib/Makefile | 34 ++++++------ lib/acpi/Makefile | 2 +- lib/libfdt/Makefile | 2 +- lib/rsa/Makefile | 4 +- net/Makefile | 6 +- scripts/Kbuild.include | 8 +-- scripts/Makefile.xpl | 44 +++++++-------- test/dm/Makefile | 4 +- tools/qconfig.py | 6 +- 67 files changed, 338 insertions(+), 338 deletions(-)
diff --git a/Makefile b/Makefile index d38adcbd1e6..ca74406f21c 100644 --- a/Makefile +++ b/Makefile @@ -883,7 +883,7 @@ libs-y += drivers/usb/ulpi/ ifdef CONFIG_POST libs-y += post/ endif -libs-$(CONFIG_$(SPL_TPL_)UNIT_TEST) += test/ +libs-$(CONFIG_$(PHASE_)UNIT_TEST) += test/ libs-$(CONFIG_UT_ENV) += test/env/ libs-$(CONFIG_UT_OPTEE) += test/optee/ libs-$(CONFIG_UT_OVERLAY) += test/overlay/ diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index c5f568e2cb7..8747d2eb186 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -6,7 +6,7 @@ extra-y := start.o
obj-y += cpu.o -ifndef CONFIG_$(SPL_TPL_)TIMER +ifndef CONFIG_$(PHASE_)TIMER obj-$(CONFIG_SYS_ARCH_TIMER) += generic_timer.o endif ifndef CONFIG_$(XPL_)SYS_DCACHE_OFF diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index b73a0397541..211ff4960e1 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -34,7 +34,7 @@ obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o else -obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o +obj-$(CONFIG_$(PHASE_)FRAMEWORK) += spl.o ifdef CONFIG_SPL_FRAMEWORK obj-$(CONFIG_CMD_BOOTI) += image.o obj-$(CONFIG_CMD_BOOTZ) += zimage.o @@ -42,14 +42,14 @@ endif obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o endif ifdef CONFIG_ARM64 -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset-arm64.o -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy-arm64.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_MEMSET) += memset-arm64.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_MEMCPY) += memcpy-arm64.o else -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset.o -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_MEMSET) += memset.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_MEMCPY) += memcpy.o endif -obj-$(CONFIG_$(SPL_TPL_)SYS_L2_PL310) += cache-pl310.o -obj-$(CONFIG_$(SPL_TPL_)SEMIHOSTING) += semihosting.o +obj-$(CONFIG_$(PHASE_)SYS_L2_PL310) += cache-pl310.o +obj-$(CONFIG_$(PHASE_)SEMIHOSTING) += semihosting.o
ifneq ($(filter y,$(CONFIG_SAVE_PREV_BL_INITRAMFS_START_ADDR) $(CONFIG_SAVE_PREV_BL_FDT_ADDR)),) obj-y += save_prev_bl_data.o @@ -73,7 +73,7 @@ obj-y += interrupts_64.o else obj-y += interrupts.o endif -ifndef CONFIG_$(SPL_TPL_)SYSRESET +ifndef CONFIG_$(PHASE_)SYSRESET obj-y += reset.o endif
diff --git a/arch/arm/mach-at91/arm926ejs/Makefile b/arch/arm/mach-at91/arm926ejs/Makefile index 1695708831c..8f0bc5d997e 100644 --- a/arch/arm/mach-at91/arm926ejs/Makefile +++ b/arch/arm/mach-at91/arm926ejs/Makefile @@ -16,7 +16,7 @@ obj-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o obj-$(CONFIG_SAM9X60) += sam9x60_devices.o obj-y += clock.o obj-y += cpu.o -ifndef CONFIG_$(SPL_TPL_)SYSRESET +ifndef CONFIG_$(PHASE_)SYSRESET obj-y += reset.o endif ifneq ($(CONFIG_ATMEL_PIT_TIMER),y) diff --git a/arch/arm/mach-omap2/Makefile b/arch/arm/mach-omap2/Makefile index 9a85c764a55..fb5ea97e56e 100644 --- a/arch/arm/mach-omap2/Makefile +++ b/arch/arm/mach-omap2/Makefile @@ -26,7 +26,7 @@ obj-y += vc.o obj-y += abb.o endif
-ifeq ($(CONFIG_$(SPL_TPL_)SYS_DCACHE_OFF),) +ifeq ($(CONFIG_$(PHASE_)SYS_DCACHE_OFF),) obj-y += omap-cache.o endif
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 70f0af4733c..c0265fe006e 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -29,7 +29,7 @@ ifeq ($(CONFIG_TPL_BUILD),) obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o endif
-obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram.o +obj-$(CONFIG_$(PHASE_)RAM) += sdram.o
obj-$(CONFIG_ROCKCHIP_PX30) += px30/ obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index 64ac4930b62..6089901fe74 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -44,5 +44,5 @@ obj-y += traps.o endif # not minimal
ifdef CONFIG_XPL_BUILD -obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o +obj-$(CONFIG_$(PHASE_)FRAMEWORK) += spl.o endif diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 34b69c13392..608118135d7 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -40,11 +40,11 @@ extra-$(CONFIG_CMD_BOOTEFI_HELLO_COMPILE) += $(EFI_CRT0) $(EFI_RELOC) extra-$(CONFIG_CMD_BOOTEFI_SELFTEST) += $(EFI_CRT0) $(EFI_RELOC) extra-$(CONFIG_EFI) += $(EFI_CRT0) $(EFI_RELOC)
-obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset.o -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMMOVE) += memmove.o -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy.o -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_STRLEN) += strlen_zbb.o -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_STRCMP) += strcmp_zbb.o -obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_STRNCMP) += strncmp_zbb.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_MEMSET) += memset.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_MEMMOVE) += memmove.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_MEMCPY) += memcpy.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_STRLEN) += strlen_zbb.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_STRCMP) += strcmp_zbb.o +obj-$(CONFIG_$(PHASE_)USE_ARCH_STRNCMP) += strncmp_zbb.o
-obj-$(CONFIG_$(SPL_TPL_)SEMIHOSTING) += semihosting.o +obj-$(CONFIG_$(PHASE_)SEMIHOSTING) += semihosting.o diff --git a/arch/x86/Makefile b/arch/x86/Makefile index bc1e1ede12a..fd409b9f720 100644 --- a/arch/x86/Makefile +++ b/arch/x86/Makefile @@ -4,7 +4,7 @@ ifeq ($(CONFIG_EFI_APP),) ifdef CONFIG_$(XPL_)X86_64 head-y := arch/x86/cpu/start64.o else -ifeq ($(CONFIG_$(SPL_TPL_)X86_16BIT_INIT),y) +ifeq ($(CONFIG_$(PHASE_)X86_16BIT_INIT),y) head-y := arch/x86/cpu/start.o else ifndef CONFIG_SPL @@ -20,8 +20,8 @@ endif endif endif # EFI
-head-$(CONFIG_$(SPL_TPL_)X86_16BIT_INIT) += arch/x86/cpu/start16.o -head-$(CONFIG_$(SPL_TPL_)X86_16BIT_INIT) += arch/x86/cpu/resetvec.o +head-$(CONFIG_$(PHASE_)X86_16BIT_INIT) += arch/x86/cpu/start16.o +head-$(CONFIG_$(PHASE_)X86_16BIT_INIT) += arch/x86/cpu/resetvec.o
libs-y += arch/x86/cpu/ libs-y += arch/x86/lib/ diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 8899830370c..39c8b0835cc 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -9,7 +9,7 @@ ifeq ($(CONFIG_$(XPL_)X86_64),y) extra-y = start64.o else -ifeq ($(CONFIG_$(SPL_TPL_)X86_16BIT_INIT),y) +ifeq ($(CONFIG_$(PHASE_)X86_16BIT_INIT),y) extra-y = start.o else ifndef CONFIG_SPL @@ -24,7 +24,7 @@ endif endif endif
-extra-$(CONFIG_$(SPL_TPL_)X86_16BIT_INIT) += resetvec.o start16.o +extra-$(CONFIG_$(PHASE_)X86_16BIT_INIT) += resetvec.o start16.o
obj-y += cpu.o ifndef CONFIG_TPL_BUILD @@ -54,10 +54,10 @@ obj-$(CONFIG_INTEL_QUARK) += quark/ obj-$(CONFIG_INTEL_QUEENSBAY) += queensbay/ obj-$(CONFIG_INTEL_TANGIER) += tangier/ obj-$(CONFIG_APIC) += lapic.o ioapic.o -obj-$(CONFIG_$(SPL_TPL_)ACPI_GPE) += acpi_gpe.o +obj-$(CONFIG_$(PHASE_)ACPI_GPE) += acpi_gpe.o obj-$(CONFIG_QFW) += qfw_cpu.o ifndef CONFIG_SYS_COREBOOT -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += irq.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += irq.o endif ifndef CONFIG_$(XPL_)X86_64 obj-$(CONFIG_$(XPL_)SMP) += mp_init.o diff --git a/arch/x86/cpu/broadwell/Makefile b/arch/x86/cpu/broadwell/Makefile index 6c6d0edac9b..dfe013e3833 100644 --- a/arch/x86/cpu/broadwell/Makefile +++ b/arch/x86/cpu/broadwell/Makefile @@ -2,8 +2,8 @@ # # Copyright (c) 2016 Google, Inc
-obj-$(CONFIG_$(SPL_TPL_)X86_16BIT_INIT) += cpu.o -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += cpu_full.o +obj-$(CONFIG_$(PHASE_)X86_16BIT_INIT) += cpu.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += cpu_full.o
ifdef CONFIG_SPL ifndef CONFIG_XPL_BUILD @@ -18,7 +18,7 @@ obj-y += sata.o endif endif
-ifeq ($(CONFIG_$(SPL_TPL_)X86_32BIT_INIT),) +ifeq ($(CONFIG_$(PHASE_)X86_32BIT_INIT),) #obj-y += cpu_from_spl.o endif
@@ -29,5 +29,5 @@ obj-y += northbridge.o obj-y += pch.o obj-y += pinctrl_broadwell.o obj-y += power_state.o -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += refcode.o -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += sdram.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += refcode.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += sdram.o diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index d2db5897377..a28e6c77c9c 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -5,10 +5,10 @@ obj-$(CONFIG_INTEL_ACPIGEN) += acpi.o
ifdef CONFIG_HAVE_MRC -obj-$(CONFIG_$(SPL_TPL_)X86_16BIT_INIT) += car.o -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += me_status.o -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += report_platform.o -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += mrc.o +obj-$(CONFIG_$(PHASE_)X86_16BIT_INIT) += car.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += me_status.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += report_platform.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += mrc.o endif
ifndef CONFIG_XPL_BUILD @@ -28,7 +28,7 @@ obj-y += lpc.o obj-y += lpss.o obj-$(CONFIG_$(XPL_)INTEL_GENERIC_WIFI) += generic_wifi.o ifndef CONFIG_EFI_APP -obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += microcode.o +obj-$(CONFIG_$(PHASE_)X86_32BIT_INIT) += microcode.o ifndef CONFIG_$(XPL_)X86_64 obj-y += microcode.o endif diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index decf2e5c628..8677b2a88dc 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -5,7 +5,7 @@
obj-y += bdinfo.o
-ifndef CONFIG_$(SPL_TPL_)X86_64 +ifndef CONFIG_$(PHASE_)X86_64 obj-y += bios.o obj-y += bios_asm.o obj-y += bios_interrupts.o @@ -27,7 +27,7 @@ obj-y += init_helpers.o obj-y += interrupts.o obj-y += lpc-uclass.o obj-y += mpspec.o -obj-$(CONFIG_$(SPL_TPL_)ACPIGEN) += acpi_nhlt.o +obj-$(CONFIG_$(PHASE_)ACPIGEN) += acpi_nhlt.o obj-y += northbridge-uclass.o obj-$(CONFIG_I8259_PIC) += i8259.o obj-$(CONFIG_I8254_TIMER) += i8254.o @@ -44,7 +44,7 @@ obj-y += acpi.o obj-$(CONFIG_HAVE_ACPI_RESUME) += acpi_s3.o ifndef CONFIG_QEMU obj-y += acpigen.o -obj-$(CONFIG_$(SPL_TPL_)GENERATE_ACPI_TABLE) += acpi_table.o +obj-$(CONFIG_$(PHASE_)GENERATE_ACPI_TABLE) += acpi_table.o endif obj-y += tables.o ifndef CONFIG_XPL_BUILD diff --git a/board/coreboot/coreboot/Makefile b/board/coreboot/coreboot/Makefile index 75bfbd18943..0abdb7df534 100644 --- a/board/coreboot/coreboot/Makefile +++ b/board/coreboot/coreboot/Makefile @@ -11,4 +11,4 @@ # Daniel Engström, Omicron Ceti AB, daniel@omicron.se.
obj-y += coreboot.o -obj-$(CONFIG_$(SPL_TPL_)SMBIOS_PARSER) += sysinfo.o +obj-$(CONFIG_$(PHASE_)SMBIOS_PARSER) += sysinfo.o diff --git a/boot/Makefile b/boot/Makefile index 1b6901970e3..b24f806d5bf 100644 --- a/boot/Makefile +++ b/boot/Makefile @@ -19,54 +19,54 @@ obj-y += image.o image-board.o obj-$(CONFIG_ANDROID_AB) += android_ab.o obj-$(CONFIG_ANDROID_BOOT_IMAGE) += image-android.o image-android-dt.o
-obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootdev-uclass.o -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootflow.o -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootmeth-uclass.o -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootstd-uclass.o - -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD_PROG) += prog_boot.o - -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_EXTLINUX) += bootmeth_extlinux.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_EXTLINUX_PXE) += bootmeth_pxe.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_EFILOADER) += bootmeth_efi.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_CROS) += bootm.o bootm_os.o bootmeth_cros.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_QFW) += bootmeth_qfw.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_SANDBOX) += bootmeth_sandbox.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_SCRIPT) += bootmeth_script.o -obj-$(CONFIG_$(SPL_TPL_)CEDIT) += cedit.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_EFI_BOOTMGR) += bootmeth_efi_mgr.o -ifdef CONFIG_$(SPL_TPL_)BOOTSTD_FULL -obj-$(CONFIG_$(SPL_TPL_)EXPO) += bootflow_menu.o -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootflow_menu.o +obj-$(CONFIG_$(PHASE_)BOOTSTD) += bootdev-uclass.o +obj-$(CONFIG_$(PHASE_)BOOTSTD) += bootflow.o +obj-$(CONFIG_$(PHASE_)BOOTSTD) += bootmeth-uclass.o +obj-$(CONFIG_$(PHASE_)BOOTSTD) += bootstd-uclass.o + +obj-$(CONFIG_$(PHASE_)BOOTSTD_PROG) += prog_boot.o + +obj-$(CONFIG_$(PHASE_)BOOTMETH_EXTLINUX) += bootmeth_extlinux.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_EXTLINUX_PXE) += bootmeth_pxe.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_EFILOADER) += bootmeth_efi.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_CROS) += bootm.o bootm_os.o bootmeth_cros.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_QFW) += bootmeth_qfw.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_SANDBOX) += bootmeth_sandbox.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_SCRIPT) += bootmeth_script.o +obj-$(CONFIG_$(PHASE_)CEDIT) += cedit.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_EFI_BOOTMGR) += bootmeth_efi_mgr.o +ifdef CONFIG_$(PHASE_)BOOTSTD_FULL +obj-$(CONFIG_$(PHASE_)EXPO) += bootflow_menu.o +obj-$(CONFIG_$(PHASE_)BOOTSTD) += bootflow_menu.o endif
-obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdt_support.o -obj-$(CONFIG_$(SPL_TPL_)FDT_SIMPLEFB) += fdt_simplefb.o +obj-$(CONFIG_$(PHASE_)OF_LIBFDT) += fdt_support.o +obj-$(CONFIG_$(PHASE_)FDT_SIMPLEFB) += fdt_simplefb.o
-obj-$(CONFIG_$(SPL_TPL_)UPL) += upl_common.o -obj-$(CONFIG_$(SPL_TPL_)UPL_READ) += upl_read.o -obj-$(CONFIG_$(SPL_TPL_)UPL_WRITE) += upl_write.o +obj-$(CONFIG_$(PHASE_)UPL) += upl_common.o +obj-$(CONFIG_$(PHASE_)UPL_READ) += upl_read.o +obj-$(CONFIG_$(PHASE_)UPL_WRITE) += upl_write.o
-obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += image-fdt.o -obj-$(CONFIG_$(SPL_TPL_)FIT_SIGNATURE) += fdt_region.o -obj-$(CONFIG_$(SPL_TPL_)FIT) += image-fit.o +obj-$(CONFIG_$(PHASE_)OF_LIBFDT) += image-fdt.o +obj-$(CONFIG_$(PHASE_)FIT_SIGNATURE) += fdt_region.o +obj-$(CONFIG_$(PHASE_)FIT) += image-fit.o obj-$(CONFIG_$(XPL_)MULTI_DTB_FIT) += boot_fit.o common_fit.o -obj-$(CONFIG_$(SPL_TPL_)IMAGE_PRE_LOAD) += image-pre-load.o -obj-$(CONFIG_$(SPL_TPL_)IMAGE_SIGN_INFO) += image-sig.o -obj-$(CONFIG_$(SPL_TPL_)FIT_SIGNATURE) += image-fit-sig.o -obj-$(CONFIG_$(SPL_TPL_)FIT_CIPHER) += image-cipher.o +obj-$(CONFIG_$(PHASE_)IMAGE_PRE_LOAD) += image-pre-load.o +obj-$(CONFIG_$(PHASE_)IMAGE_SIGN_INFO) += image-sig.o +obj-$(CONFIG_$(PHASE_)FIT_SIGNATURE) += image-fit-sig.o +obj-$(CONFIG_$(PHASE_)FIT_CIPHER) += image-cipher.o
obj-$(CONFIG_CMD_ADTIMG) += image-android-dt.o
-obj-$(CONFIG_$(SPL_TPL_)LOAD_FIT) += common_fit.o +obj-$(CONFIG_$(PHASE_)LOAD_FIT) += common_fit.o
-obj-$(CONFIG_$(SPL_TPL_)EXPO) += expo.o scene.o expo_build.o -obj-$(CONFIG_$(SPL_TPL_)EXPO) += scene_menu.o scene_textline.o +obj-$(CONFIG_$(PHASE_)EXPO) += expo.o scene.o expo_build.o +obj-$(CONFIG_$(PHASE_)EXPO) += scene_menu.o scene_textline.o
-obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_VBE) += vbe.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_VBE_REQUEST) += vbe_request.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_VBE_SIMPLE) += vbe_simple.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_VBE_SIMPLE_FW) += vbe_simple_fw.o -obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_VBE_SIMPLE_OS) += vbe_simple_os.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_VBE) += vbe.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_VBE_REQUEST) += vbe_request.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_VBE_SIMPLE) += vbe_simple.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_VBE_SIMPLE_FW) += vbe_simple_fw.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_VBE_SIMPLE_OS) += vbe_simple_os.o
-obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_ANDROID) += bootmeth_android.o +obj-$(CONFIG_$(PHASE_)BOOTMETH_ANDROID) += bootmeth_android.o diff --git a/common/Makefile b/common/Makefile index ae8984659c0..2ee5ef9cc6e 100644 --- a/common/Makefile +++ b/common/Makefile @@ -44,8 +44,8 @@ obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o
-obj-$(CONFIG_$(SPL_TPL_)BOOTSTAGE) += bootstage.o -obj-$(CONFIG_$(SPL_TPL_)BLOBLIST) += bloblist.o +obj-$(CONFIG_$(PHASE_)BOOTSTAGE) += bootstage.o +obj-$(CONFIG_$(PHASE_)BLOBLIST) += bloblist.o
ifdef CONFIG_XPL_BUILD ifdef CONFIG_SPL_DFU @@ -65,16 +65,16 @@ obj-$(CONFIG_DDR_SPD) += ddr_spd.o obj-$(CONFIG_SPD_EEPROM) += ddr_spd.o obj-$(CONFIG_HWCONFIG) += hwconfig.o obj-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o -obj-$(CONFIG_$(SPL_TPL_)SERIAL) += console.o +obj-$(CONFIG_$(PHASE_)SERIAL) += console.o
obj-$(CONFIG_CROS_EC) += cros_ec.o obj-y += dlmalloc.o -obj-$(CONFIG_$(SPL_TPL_)SYS_MALLOC_F) += malloc_simple.o +obj-$(CONFIG_$(PHASE_)SYS_MALLOC_F) += malloc_simple.o
-obj-$(CONFIG_$(SPL_TPL_)CYCLIC) += cyclic.o -obj-$(CONFIG_$(SPL_TPL_)EVENT) += event.o +obj-$(CONFIG_$(PHASE_)CYCLIC) += cyclic.o +obj-$(CONFIG_$(PHASE_)EVENT) += event.o
-obj-$(CONFIG_$(SPL_TPL_)HASH) += hash.o +obj-$(CONFIG_$(PHASE_)HASH) += hash.o obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o @@ -88,15 +88,15 @@ obj-$(CONFIG_FSL_DDR_INTERACTIVE) += cli_getch.o cli_simple.o cli_readline.o obj-$(CONFIG_STM32MP1_DDR_INTERACTIVE) += cli_getch.o cli_simple.o cli_readline.o obj-$(CONFIG_DFU_OVER_USB) += dfu.o obj-y += command.o -obj-$(CONFIG_$(SPL_TPL_)LOG) += log.o -obj-$(CONFIG_$(SPL_TPL_)LOG_CONSOLE) += log_console.o -obj-$(CONFIG_$(SPL_TPL_)LOG_SYSLOG) += log_syslog.o +obj-$(CONFIG_$(PHASE_)LOG) += log.o +obj-$(CONFIG_$(PHASE_)LOG_CONSOLE) += log_console.o +obj-$(CONFIG_$(PHASE_)LOG_SYSLOG) += log_syslog.o obj-y += s_record.o obj-$(CONFIG_CMD_LOADB) += xyzModem.o -obj-$(CONFIG_$(SPL_TPL_)YMODEM_SUPPORT) += xyzModem.o +obj-$(CONFIG_$(PHASE_)YMODEM_SUPPORT) += xyzModem.o
-obj-$(CONFIG_$(SPL_TPL_)AVB_VERIFY) += avb_verify.o -obj-$(CONFIG_$(SPL_TPL_)STACKPROTECTOR) += stackprot.o +obj-$(CONFIG_$(PHASE_)AVB_VERIFY) += avb_verify.o +obj-$(CONFIG_$(PHASE_)STACKPROTECTOR) += stackprot.o obj-$(CONFIG_SCP03) += scp03.o
obj-$(CONFIG_QFW) += qfw.o diff --git a/common/bootstage.c b/common/bootstage.c index 49acc9078a6..72d80ee9fe5 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -351,7 +351,7 @@ void bootstage_report(void) } if (data->rec_count > RECORD_COUNT) printf("Overflowed internal boot id table by %d entries\n" - "Please increase CONFIG_(SPL_TPL_)BOOTSTAGE_RECORD_COUNT\n", + "Please increase CONFIG_(PHASE_)BOOTSTAGE_RECORD_COUNT\n", data->rec_count - RECORD_COUNT);
puts("\nAccumulated time:\n"); @@ -473,7 +473,7 @@ int bootstage_unstash(const void *base, int size)
if (data->rec_count + hdr->count > RECORD_COUNT) { debug("%s: Bootstage has %d records, we have space for %d\n" - "Please increase CONFIG_(SPL_)BOOTSTAGE_RECORD_COUNT\n", + "Please increase CONFIG_(PHASE_)BOOTSTAGE_RECORD_COUNT\n", __func__, hdr->count, RECORD_COUNT - data->rec_count); return -ENOSPC; } diff --git a/common/init/Makefile b/common/init/Makefile index 853b56d1e57..224e092f88c 100644 --- a/common/init/Makefile +++ b/common/init/Makefile @@ -5,4 +5,4 @@ #
obj-y += board_init.o -obj-$(CONFIG_$(SPL_TPL_)HANDOFF) += handoff.o +obj-$(CONFIG_$(PHASE_)HANDOFF) += handoff.o diff --git a/common/spl/Makefile b/common/spl/Makefile index 10528b31a7c..75123eb666b 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -7,35 +7,35 @@ #
ifdef CONFIG_XPL_BUILD -obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o -obj-$(CONFIG_$(SPL_TPL_)BOOTROM_SUPPORT) += spl_bootrom.o -obj-$(CONFIG_$(SPL_TPL_)LOAD_FIT) += spl_fit.o -obj-$(CONFIG_$(SPL_TPL_)BLK_FS) += spl_blk_fs.o -obj-$(CONFIG_$(SPL_TPL_)LEGACY_IMAGE_FORMAT) += spl_legacy.o -obj-$(CONFIG_$(SPL_TPL_)NOR_SUPPORT) += spl_nor.o -obj-$(CONFIG_$(SPL_TPL_)XIP_SUPPORT) += spl_xip.o -obj-$(CONFIG_$(SPL_TPL_)YMODEM_SUPPORT) += spl_ymodem.o +obj-$(CONFIG_$(PHASE_)FRAMEWORK) += spl.o +obj-$(CONFIG_$(PHASE_)BOOTROM_SUPPORT) += spl_bootrom.o +obj-$(CONFIG_$(PHASE_)LOAD_FIT) += spl_fit.o +obj-$(CONFIG_$(PHASE_)BLK_FS) += spl_blk_fs.o +obj-$(CONFIG_$(PHASE_)LEGACY_IMAGE_FORMAT) += spl_legacy.o +obj-$(CONFIG_$(PHASE_)NOR_SUPPORT) += spl_nor.o +obj-$(CONFIG_$(PHASE_)XIP_SUPPORT) += spl_xip.o +obj-$(CONFIG_$(PHASE_)YMODEM_SUPPORT) += spl_ymodem.o ifndef CONFIG_SPL_UBI -obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += spl_nand.o -obj-$(CONFIG_$(SPL_TPL_)ONENAND_SUPPORT) += spl_onenand.o +obj-$(CONFIG_$(PHASE_)NAND_SUPPORT) += spl_nand.o +obj-$(CONFIG_$(PHASE_)ONENAND_SUPPORT) += spl_onenand.o endif -obj-$(CONFIG_$(SPL_TPL_)UBI) += spl_ubi.o -obj-$(CONFIG_$(SPL_TPL_)NET) += spl_net.o -obj-$(CONFIG_$(SPL_TPL_)MMC) += spl_mmc.o -obj-$(CONFIG_$(SPL_TPL_)ATF) += spl_atf.o -obj-$(CONFIG_$(SPL_TPL_)OPTEE_IMAGE) += spl_optee.o -obj-$(CONFIG_$(SPL_TPL_)OPENSBI) += spl_opensbi.o -obj-$(CONFIG_$(SPL_TPL_)USB_STORAGE) += spl_usb.o -obj-$(CONFIG_$(SPL_TPL_)FS_FAT) += spl_fat.o -obj-$(CONFIG_$(SPL_TPL_)FS_EXT4) += spl_ext.o -obj-$(CONFIG_$(SPL_TPL_)LOAD_IMX_CONTAINER) += spl_imx_container.o -obj-$(CONFIG_$(SPL_TPL_)SATA) += spl_sata.o -obj-$(CONFIG_$(SPL_TPL_)NVME) += spl_nvme.o -obj-$(CONFIG_$(SPL_TPL_)SEMIHOSTING) += spl_semihosting.o -obj-$(CONFIG_$(SPL_TPL_)DFU) += spl_dfu.o -obj-$(CONFIG_$(SPL_TPL_)SPI_LOAD) += spl_spi.o -obj-$(CONFIG_$(SPL_TPL_)RAM_SUPPORT) += spl_ram.o -obj-$(CONFIG_$(SPL_TPL_)USB_SDP_SUPPORT) += spl_sdp.o +obj-$(CONFIG_$(PHASE_)UBI) += spl_ubi.o +obj-$(CONFIG_$(PHASE_)NET) += spl_net.o +obj-$(CONFIG_$(PHASE_)MMC) += spl_mmc.o +obj-$(CONFIG_$(PHASE_)ATF) += spl_atf.o +obj-$(CONFIG_$(PHASE_)OPTEE_IMAGE) += spl_optee.o +obj-$(CONFIG_$(PHASE_)OPENSBI) += spl_opensbi.o +obj-$(CONFIG_$(PHASE_)USB_STORAGE) += spl_usb.o +obj-$(CONFIG_$(PHASE_)FS_FAT) += spl_fat.o +obj-$(CONFIG_$(PHASE_)FS_EXT4) += spl_ext.o +obj-$(CONFIG_$(PHASE_)LOAD_IMX_CONTAINER) += spl_imx_container.o +obj-$(CONFIG_$(PHASE_)SATA) += spl_sata.o +obj-$(CONFIG_$(PHASE_)NVME) += spl_nvme.o +obj-$(CONFIG_$(PHASE_)SEMIHOSTING) += spl_semihosting.o +obj-$(CONFIG_$(PHASE_)DFU) += spl_dfu.o +obj-$(CONFIG_$(PHASE_)SPI_LOAD) += spl_spi.o +obj-$(CONFIG_$(PHASE_)RAM_SUPPORT) += spl_ram.o +obj-$(CONFIG_$(PHASE_)USB_SDP_SUPPORT) += spl_sdp.o endif
-obj-$(CONFIG_$(SPL_TPL_)UPL) += spl_upl.o +obj-$(CONFIG_$(PHASE_)UPL) += spl_upl.o diff --git a/disk/Makefile b/disk/Makefile index 45588cf66e4..2248a659f8b 100644 --- a/disk/Makefile +++ b/disk/Makefile @@ -5,16 +5,16 @@
#ccflags-y += -DET_DEBUG -DDEBUG
-obj-$(CONFIG_$(SPL_TPL_)PARTITIONS) += part.o -ifdef CONFIG_$(SPL_TPL_)BLK -obj-$(CONFIG_$(SPL_TPL_)PARTITIONS) += disk-uclass.o +obj-$(CONFIG_$(PHASE_)PARTITIONS) += part.o +ifdef CONFIG_$(PHASE_)BLK +obj-$(CONFIG_$(PHASE_)PARTITIONS) += disk-uclass.o endif
# Must have BLK or SPL_LEGACY_BLOCK to support partitions -ifneq ($(CONFIG_$(SPL_TPL_)BLK),$(CONFIG_SPL_LEGACY_BLOCK),) -obj-$(CONFIG_$(SPL_TPL_)MAC_PARTITION) += part_mac.o -obj-$(CONFIG_$(SPL_TPL_)DOS_PARTITION) += part_dos.o -obj-$(CONFIG_$(SPL_TPL_)ISO_PARTITION) += part_iso.o -obj-$(CONFIG_$(SPL_TPL_)AMIGA_PARTITION) += part_amiga.o -obj-$(CONFIG_$(SPL_TPL_)EFI_PARTITION) += part_efi.o +ifneq ($(CONFIG_$(PHASE_)BLK),$(CONFIG_SPL_LEGACY_BLOCK),) +obj-$(CONFIG_$(PHASE_)MAC_PARTITION) += part_mac.o +obj-$(CONFIG_$(PHASE_)DOS_PARTITION) += part_dos.o +obj-$(CONFIG_$(PHASE_)ISO_PARTITION) += part_iso.o +obj-$(CONFIG_$(PHASE_)AMIGA_PARTITION) += part_amiga.o +obj-$(CONFIG_$(PHASE_)EFI_PARTITION) += part_efi.o endif diff --git a/drivers/Makefile b/drivers/Makefile index fd247265fe5..af593501261 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -1,43 +1,43 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_$(SPL_TPL_)ADC) += adc/ -obj-$(CONFIG_$(SPL_TPL_)BIOSEMU) += bios_emulator/ -obj-$(CONFIG_$(SPL_TPL_)BLK) += block/ -obj-$(CONFIG_$(SPL_TPL_)BOOTCOUNT_LIMIT) += bootcount/ -obj-$(CONFIG_$(SPL_TPL_)BUTTON) += button/ -obj-$(CONFIG_$(SPL_TPL_)CACHE) += cache/ -obj-$(CONFIG_$(SPL_TPL_)CLK) += clk/ -obj-$(CONFIG_$(SPL_TPL_)DM) += core/ -obj-$(CONFIG_$(SPL_TPL_)DMA) += dma/ -obj-$(CONFIG_$(SPL_TPL_)DMA_LEGACY) += dma/ -obj-$(CONFIG_$(SPL_TPL_)DFU) += dfu/ -obj-$(CONFIG_$(SPL_TPL_)EXTCON) += extcon/ -obj-$(CONFIG_$(SPL_TPL_)GPIO) += gpio/ -obj-$(CONFIG_$(SPL_TPL_)DRIVERS_MISC) += misc/ -obj-$(CONFIG_$(SPL_TPL_)SYSRESET) += sysreset/ -obj-$(CONFIG_$(SPL_TPL_)FIRMWARE) +=firmware/ -obj-$(CONFIG_$(SPL_TPL_)I2C) += i2c/ -obj-$(CONFIG_$(SPL_TPL_)INPUT) += input/ -obj-$(CONFIG_$(SPL_TPL_)LED) += led/ -obj-$(CONFIG_$(SPL_TPL_)MMC) += mmc/ +obj-$(CONFIG_$(PHASE_)ADC) += adc/ +obj-$(CONFIG_$(PHASE_)BIOSEMU) += bios_emulator/ +obj-$(CONFIG_$(PHASE_)BLK) += block/ +obj-$(CONFIG_$(PHASE_)BOOTCOUNT_LIMIT) += bootcount/ +obj-$(CONFIG_$(PHASE_)BUTTON) += button/ +obj-$(CONFIG_$(PHASE_)CACHE) += cache/ +obj-$(CONFIG_$(PHASE_)CLK) += clk/ +obj-$(CONFIG_$(PHASE_)DM) += core/ +obj-$(CONFIG_$(PHASE_)DMA) += dma/ +obj-$(CONFIG_$(PHASE_)DMA_LEGACY) += dma/ +obj-$(CONFIG_$(PHASE_)DFU) += dfu/ +obj-$(CONFIG_$(PHASE_)EXTCON) += extcon/ +obj-$(CONFIG_$(PHASE_)GPIO) += gpio/ +obj-$(CONFIG_$(PHASE_)DRIVERS_MISC) += misc/ +obj-$(CONFIG_$(PHASE_)SYSRESET) += sysreset/ +obj-$(CONFIG_$(PHASE_)FIRMWARE) +=firmware/ +obj-$(CONFIG_$(PHASE_)I2C) += i2c/ +obj-$(CONFIG_$(PHASE_)INPUT) += input/ +obj-$(CONFIG_$(PHASE_)LED) += led/ +obj-$(CONFIG_$(PHASE_)MMC) += mmc/ obj-y += mtd/ -obj-$(CONFIG_$(SPL_TPL_)ETH) += net/ -obj-$(CONFIG_$(SPL_TPL_)PCH) += pch/ -obj-$(CONFIG_$(SPL_TPL_)PCI) += pci/ -obj-$(CONFIG_$(SPL_TPL_)PHY) += phy/ -obj-$(CONFIG_$(SPL_TPL_)PINCTRL) += pinctrl/ -obj-$(CONFIG_$(SPL_TPL_)POWER) += power/ -obj-$(CONFIG_$(SPL_TPL_)RAM) += ram/ -obj-$(CONFIG_$(SPL_TPL_)RTC) += rtc/ -obj-$(CONFIG_$(SPL_TPL_)SERIAL) += serial/ -obj-$(CONFIG_$(SPL_TPL_)SPI) += spi/ -obj-$(CONFIG_$(SPL_TPL_)TIMER) += timer/ -obj-$(CONFIG_$(SPL_TPL_)VIRTIO) += virtio/ +obj-$(CONFIG_$(PHASE_)ETH) += net/ +obj-$(CONFIG_$(PHASE_)PCH) += pch/ +obj-$(CONFIG_$(PHASE_)PCI) += pci/ +obj-$(CONFIG_$(PHASE_)PHY) += phy/ +obj-$(CONFIG_$(PHASE_)PINCTRL) += pinctrl/ +obj-$(CONFIG_$(PHASE_)POWER) += power/ +obj-$(CONFIG_$(PHASE_)RAM) += ram/ +obj-$(CONFIG_$(PHASE_)RTC) += rtc/ +obj-$(CONFIG_$(PHASE_)SERIAL) += serial/ +obj-$(CONFIG_$(PHASE_)SPI) += spi/ +obj-$(CONFIG_$(PHASE_)TIMER) += timer/ +obj-$(CONFIG_$(PHASE_)VIRTIO) += virtio/ obj-$(CONFIG_$(XPL_)DM_MAILBOX) += mailbox/ obj-$(CONFIG_$(XPL_)REMOTEPROC) += remoteproc/ obj-$(CONFIG_$(XPL_)SYSINFO) += sysinfo/ -obj-$(CONFIG_$(SPL_TPL_)SM) += sm/ -obj-$(CONFIG_$(SPL_TPL_)TPM) += tpm/ +obj-$(CONFIG_$(PHASE_)SM) += sm/ +obj-$(CONFIG_$(PHASE_)TPM) += tpm/ obj-$(CONFIG_$(XPL_)NVME) += nvme/ obj-$(CONFIG_XEN) += xen/ obj-$(CONFIG_$(XPL_)FPGA) += fpga/ @@ -122,7 +122,7 @@ obj-$(CONFIG_W1_EEPROM) += w1-eeprom/ obj-$(CONFIG_MACH_PIC32) += ddr/microchip/ obj-$(CONFIG_FUZZ) += fuzz/ obj-$(CONFIG_DM_HWSPINLOCK) += hwspinlock/ -obj-$(CONFIG_$(SPL_TPL_)DM_RNG) += rng/ +obj-$(CONFIG_$(PHASE_)DM_RNG) += rng/ endif
obj-y += soc/ diff --git a/drivers/adc/Makefile b/drivers/adc/Makefile index dca0b39c2e2..665a7965412 100644 --- a/drivers/adc/Makefile +++ b/drivers/adc/Makefile @@ -4,7 +4,7 @@ # Przemyslaw Marczak p.marczak@samsung.com #
-obj-$(CONFIG_$(SPL_TPL_)ADC) += adc-uclass.o +obj-$(CONFIG_$(PHASE_)ADC) += adc-uclass.o obj-$(CONFIG_ADC_EXYNOS) += exynos-adc.o obj-$(CONFIG_ADC_SANDBOX) += sandbox.o obj-$(CONFIG_SARADC_ROCKCHIP) += rockchip-saradc.o diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 98a34c01c38..ee290620545 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)BLK) += blk-uclass.o +obj-$(CONFIG_$(PHASE_)BLK) += blk-uclass.o
ifndef CONFIG_$(XPL_)BLK obj-$(CONFIG_SPL_LEGACY_BLOCK) += blk_legacy.o @@ -14,9 +14,9 @@ obj-$(CONFIG_IDE) += ide.o obj-$(CONFIG_RKMTD) += rkmtd.o endif obj-$(CONFIG_SANDBOX) += sandbox.o host-uclass.o host_dev.o -obj-$(CONFIG_$(SPL_TPL_)BLOCK_CACHE) += blkcache.o -obj-$(CONFIG_$(SPL_TPL_)BLKMAP) += blkmap.o -obj-$(CONFIG_$(SPL_TPL_)BLKMAP) += blkmap_helper.o +obj-$(CONFIG_$(PHASE_)BLOCK_CACHE) += blkcache.o +obj-$(CONFIG_$(PHASE_)BLKMAP) += blkmap.o +obj-$(CONFIG_$(PHASE_)BLKMAP) += blkmap_helper.o
obj-$(CONFIG_EFI_MEDIA) += efi-media-uclass.o obj-$(CONFIG_EFI_MEDIA_SANDBOX) += sb_efi_media.o diff --git a/drivers/cache/Makefile b/drivers/cache/Makefile index e1b71e0ed51..2f683866b87 100644 --- a/drivers/cache/Makefile +++ b/drivers/cache/Makefile @@ -1,5 +1,5 @@
-obj-$(CONFIG_$(SPL_TPL_)CACHE) += cache-uclass.o +obj-$(CONFIG_$(PHASE_)CACHE) += cache-uclass.o obj-$(CONFIG_SANDBOX) += sandbox_cache.o obj-$(CONFIG_L2X0_CACHE) += cache-l2x0.o obj-$(CONFIG_NCORE_CACHE) += cache-ncore.o diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index f9b90a38b00..7f84f22d4b1 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -4,13 +4,13 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. #
-obj-$(CONFIG_$(SPL_TPL_)CLK) += clk-uclass.o -obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_rate.o -obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_factor.o -obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk.o clk-divider.o clk-mux.o clk-gate.o -obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk-fixed-factor.o -obj-$(CONFIG_$(SPL_TPL_)CLK_COMPOSITE_CCF) += clk-composite.o -obj-$(CONFIG_$(SPL_TPL_)CLK_GPIO) += clk-gpio.o +obj-$(CONFIG_$(PHASE_)CLK) += clk-uclass.o +obj-$(CONFIG_$(PHASE_)CLK) += clk_fixed_rate.o +obj-$(CONFIG_$(PHASE_)CLK) += clk_fixed_factor.o +obj-$(CONFIG_$(PHASE_)CLK_CCF) += clk.o clk-divider.o clk-mux.o clk-gate.o +obj-$(CONFIG_$(PHASE_)CLK_CCF) += clk-fixed-factor.o +obj-$(CONFIG_$(PHASE_)CLK_COMPOSITE_CCF) += clk-composite.o +obj-$(CONFIG_$(PHASE_)CLK_GPIO) += clk-gpio.o
obj-y += adi/ obj-y += analogbits/ @@ -18,7 +18,7 @@ obj-y += imx/ obj-$(CONFIG_CLK_JH7110) += starfive/ obj-y += tegra/ obj-y += ti/ -obj-$(CONFIG_$(SPL_TPL_)CLK_INTEL) += intel/ +obj-$(CONFIG_$(PHASE_)CLK_INTEL) += intel/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ obj-$(CONFIG_ARCH_MESON) += meson/ @@ -42,7 +42,7 @@ obj-$(CONFIG_CLK_OCTEON) += clk_octeon.o obj-$(CONFIG_CLK_OWL) += owl/ obj-$(CONFIG_CLK_QCOM) += qcom/ obj-$(CONFIG_CLK_RENESAS) += renesas/ -obj-$(CONFIG_$(SPL_TPL_)CLK_SCMI) += clk_scmi.o +obj-$(CONFIG_$(PHASE_)CLK_SCMI) += clk_scmi.o obj-$(CONFIG_CLK_SIFIVE) += sifive/ obj-$(CONFIG_CLK_SOPHGO) += sophgo/ obj-$(CONFIG_CLK_SUNXI) += sunxi/ diff --git a/drivers/clk/exynos/Makefile b/drivers/clk/exynos/Makefile index 734100e2bff..77385864fef 100644 --- a/drivers/clk/exynos/Makefile +++ b/drivers/clk/exynos/Makefile @@ -7,6 +7,6 @@ # Thomas Abraham thomas.ab@samsung.com # Sam Protsenko semen.protsenko@linaro.org
-obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk.o clk-pll.o +obj-$(CONFIG_$(PHASE_)CLK_CCF) += clk.o clk-pll.o obj-$(CONFIG_CLK_EXYNOS7420) += clk-exynos7420.o obj-$(CONFIG_CLK_EXYNOS850) += clk-exynos850.o diff --git a/drivers/clk/imx/Makefile b/drivers/clk/imx/Makefile index 6d4bcd35714..a89ee7acb12 100644 --- a/drivers/clk/imx/Makefile +++ b/drivers/clk/imx/Makefile @@ -2,25 +2,25 @@ # # SPDX-License-Identifier: GPL-2.0
-obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk-gate2.o clk-pllv3.o clk-pfd.o -obj-$(CONFIG_$(SPL_TPL_)CLK_IMX6Q) += clk-imx6q.o +obj-$(CONFIG_$(PHASE_)CLK_CCF) += clk-gate2.o clk-pllv3.o clk-pfd.o +obj-$(CONFIG_$(PHASE_)CLK_IMX6Q) += clk-imx6q.o obj-$(CONFIG_CLK_IMX8) += clk-imx8.o
ifdef CONFIG_CLK_IMX8 obj-$(CONFIG_IMX8QXP) += clk-imx8qxp.o obj-$(CONFIG_IMX8QM) += clk-imx8qm.o endif -obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MM) += clk-imx8mm.o clk-pll14xx.o \ +obj-$(CONFIG_$(PHASE_)CLK_IMX8MM) += clk-imx8mm.o clk-pll14xx.o \ clk-composite-8m.o -obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MN) += clk-imx8mn.o clk-pll14xx.o \ +obj-$(CONFIG_$(PHASE_)CLK_IMX8MN) += clk-imx8mn.o clk-pll14xx.o \ clk-composite-8m.o -obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MP) += clk-imx8mp.o clk-pll14xx.o \ +obj-$(CONFIG_$(PHASE_)CLK_IMX8MP) += clk-imx8mp.o clk-pll14xx.o \ clk-composite-8m.o -obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MQ) += clk-imx8mq.o clk-pll14xx.o \ +obj-$(CONFIG_$(PHASE_)CLK_IMX8MQ) += clk-imx8mq.o clk-pll14xx.o \ clk-composite-8m.o -obj-$(CONFIG_$(SPL_TPL_)CLK_IMX93) += clk-imx93.o clk-fracn-gppll.o \ +obj-$(CONFIG_$(PHASE_)CLK_IMX93) += clk-imx93.o clk-fracn-gppll.o \ clk-gate-93.o clk-composite-93.o
-obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1020) += clk-imxrt1020.o -obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1050) += clk-imxrt1050.o -obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1170) += clk-imxrt1170.o +obj-$(CONFIG_$(PHASE_)CLK_IMXRT1020) += clk-imxrt1020.o +obj-$(CONFIG_$(PHASE_)CLK_IMXRT1050) += clk-imxrt1050.o +obj-$(CONFIG_$(PHASE_)CLK_IMXRT1170) += clk-imxrt1170.o diff --git a/drivers/clk/ti/Makefile b/drivers/clk/ti/Makefile index 07aa9a53e08..a58f19f46d9 100644 --- a/drivers/clk/ti/Makefile +++ b/drivers/clk/ti/Makefile @@ -11,5 +11,5 @@ obj-$(CONFIG_CLK_TI_DIVIDER) += clk-divider.o obj-$(CONFIG_CLK_TI_GATE) += clk-gate.o obj-$(CONFIG_CLK_TI_MUX) += clk-mux.o obj-$(CONFIG_CLK_TI_SCI) += clk-sci.o -obj-$(CONFIG_$(SPL_TPL_)CLK_K3_PLL) += clk-k3-pll.o -obj-$(CONFIG_$(SPL_TPL_)CLK_K3) += clk-k3.o +obj-$(CONFIG_$(PHASE_)CLK_K3_PLL) += clk-k3-pll.o +obj-$(CONFIG_$(PHASE_)CLK_K3) += clk-k3.o diff --git a/drivers/core/Makefile b/drivers/core/Makefile index 20dbff6f956..9ea57911f89 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -3,14 +3,14 @@ # Copyright (c) 2013 Google, Inc
obj-y += device.o fdtaddr.o lists.o root.o uclass.o util.o tag.o -obj-$(CONFIG_$(SPL_TPL_)ACPIGEN) += acpi.o -obj-$(CONFIG_$(SPL_TPL_)DEVRES) += devres.o -obj-$(CONFIG_$(SPL_TPL_)DM_DEVICE_REMOVE) += device-remove.o +obj-$(CONFIG_$(PHASE_)ACPIGEN) += acpi.o +obj-$(CONFIG_$(PHASE_)DEVRES) += devres.o +obj-$(CONFIG_$(PHASE_)DM_DEVICE_REMOVE) += device-remove.o obj-$(CONFIG_$(XPL_)SIMPLE_BUS) += simple-bus.o obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o obj-$(CONFIG_DM) += dump.o -obj-$(CONFIG_$(SPL_TPL_)REGMAP) += regmap.o -obj-$(CONFIG_$(SPL_TPL_)SYSCON) += syscon-uclass.o +obj-$(CONFIG_$(PHASE_)REGMAP) += regmap.o +obj-$(CONFIG_$(PHASE_)SYSCON) += syscon-uclass.o obj-$(CONFIG_$(XPL_)OF_LIVE) += of_access.o of_addr.o ifndef CONFIG_DM_DEV_READ_INLINE obj-$(CONFIG_OF_CONTROL) += read.o diff --git a/drivers/crypto/fsl/Makefile b/drivers/crypto/fsl/Makefile index 4fbce519a0b..965c4938c8c 100644 --- a/drivers/crypto/fsl/Makefile +++ b/drivers/crypto/fsl/Makefile @@ -6,6 +6,6 @@ obj-y += sec.o obj-$(CONFIG_FSL_CAAM) += jr.o fsl_hash.o jobdesc.o error.o obj-$(CONFIG_CMD_BLOB)$(CONFIG_IMX_CAAM_DEK_ENCAP) += fsl_blob.o obj-$(CONFIG_RSA_FREESCALE_EXP) += fsl_rsa.o -obj-$(CONFIG_$(SPL_TPL_)FSL_CAAM_RNG) += rng.o +obj-$(CONFIG_$(PHASE_)FSL_CAAM_RNG) += rng.o obj-$(CONFIG_FSL_DCP_RNG) += dcp_rng.o obj-$(CONFIG_FSL_MFGPROT) += fsl_mfgprot.o diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 24d1b0394fb..21b4325e4f9 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -8,7 +8,7 @@ obj-$(CONFIG_DWAPB_GPIO) += dwapb_gpio.o obj-$(CONFIG_AXP_GPIO) += axp_gpio.o obj-$(CONFIG_DM_74X164) += 74x164_gpio.o endif -obj-$(CONFIG_$(SPL_TPL_)DM_GPIO) += gpio-uclass.o +obj-$(CONFIG_$(PHASE_)DM_GPIO) += gpio-uclass.o
obj-$(CONFIG_$(XPL_)DM_PCA953X) += pca953x_gpio.o
@@ -24,7 +24,7 @@ obj-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o obj-$(CONFIG_INTEL_BROADWELL_GPIO) += intel_broadwell_gpio.o obj-$(CONFIG_IPROC_GPIO) += iproc_gpio.o obj-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o -obj-$(CONFIG_$(SPL_TPL_)MCP230XX_GPIO) += mcp230xx_gpio.o +obj-$(CONFIG_$(PHASE_)MCP230XX_GPIO) += mcp230xx_gpio.o obj-$(CONFIG_MXC_GPIO) += mxc_gpio.o obj-$(CONFIG_MXS_GPIO) += mxs_gpio.o obj-$(CONFIG_NPCM_GPIO) += npcm_gpio.o @@ -63,7 +63,7 @@ obj-$(CONFIG_OCTEON_GPIO) += octeon_gpio.o obj-$(CONFIG_MVEBU_GPIO) += mvebu_gpio.o obj-$(CONFIG_MSM_GPIO) += msm_gpio.o obj-$(CONFIG_$(XPL_)PCF8575_GPIO) += pcf8575_gpio.o -obj-$(CONFIG_$(SPL_TPL_)QCOM_PMIC_GPIO) += qcom_pmic_gpio.o +obj-$(CONFIG_$(PHASE_)QCOM_PMIC_GPIO) += qcom_pmic_gpio.o obj-$(CONFIG_MT7620_GPIO) += mt7620_gpio.o obj-$(CONFIG_MT7621_GPIO) += mt7621_gpio.o obj-$(CONFIG_MSCC_SGPIO) += mscc_sgpio.o diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 3e855346bce..8d4107b8848 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -3,9 +3,9 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)CROS_EC_KEYB) += cros_ec_keyb.o -obj-$(CONFIG_$(SPL_TPL_)OF_CONTROL) += key_matrix.o -obj-$(CONFIG_$(SPL_TPL_)DM_KEYBOARD) += input.o keyboard-uclass.o +obj-$(CONFIG_$(PHASE_)CROS_EC_KEYB) += cros_ec_keyb.o +obj-$(CONFIG_$(PHASE_)OF_CONTROL) += key_matrix.o +obj-$(CONFIG_$(PHASE_)DM_KEYBOARD) += input.o keyboard-uclass.o obj-$(CONFIG_BUTTON_KEYBOARD) += button_kbd.o
ifndef CONFIG_XPL_BUILD diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 794c2a2d38e..79e54c4a1b5 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -3,12 +3,12 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)MISC) += misc-uclass.o -obj-$(CONFIG_$(SPL_TPL_)NVMEM) += nvmem.o +obj-$(CONFIG_$(PHASE_)MISC) += misc-uclass.o +obj-$(CONFIG_$(PHASE_)NVMEM) += nvmem.o
-obj-$(CONFIG_$(SPL_TPL_)CROS_EC) += cros_ec.o -obj-$(CONFIG_$(SPL_TPL_)CROS_EC_SANDBOX) += cros_ec_sandbox.o -obj-$(CONFIG_$(SPL_TPL_)CROS_EC_LPC) += cros_ec_lpc.o +obj-$(CONFIG_$(PHASE_)CROS_EC) += cros_ec.o +obj-$(CONFIG_$(PHASE_)CROS_EC_SANDBOX) += cros_ec_sandbox.o +obj-$(CONFIG_$(PHASE_)CROS_EC_LPC) += cros_ec_lpc.o
ifndef CONFIG_XPL_BUILD obj-$(CONFIG_SANDBOX) += sandbox_adder.o @@ -51,7 +51,7 @@ obj-$(CONFIG_IMX_ELE) += imx_ele/ obj-$(CONFIG_LED_STATUS) += status_led.o obj-$(CONFIG_LED_STATUS_GPIO) += gpio_led.o obj-$(CONFIG_MPC83XX_SERDES) += mpc83xx_serdes.o -obj-$(CONFIG_$(SPL_TPL_)LS2_SFP) += ls2_sfp.o +obj-$(CONFIG_$(PHASE_)LS2_SFP) += ls2_sfp.o obj-$(CONFIG_$(XPL_)MXC_OCOTP) += mxc_ocotp.o obj-$(CONFIG_MXS_OCOTP) += mxs_ocotp.o obj-$(CONFIG_NPCM_OTP) += npcm_otp.o @@ -70,7 +70,7 @@ obj-$(CONFIG_SANDBOX) += qfw_sandbox.o endif obj-$(CONFIG_ROCKCHIP_EFUSE) += rockchip-efuse.o obj-$(CONFIG_ROCKCHIP_OTP) += rockchip-otp.o -obj-$(CONFIG_$(SPL_TPL_)ROCKCHIP_IODOMAIN) += rockchip-io-domain.o +obj-$(CONFIG_$(PHASE_)ROCKCHIP_IODOMAIN) += rockchip-io-domain.o obj-$(CONFIG_SANDBOX) += syscon_sandbox.o misc_sandbox.o obj-$(CONFIG_SIFIVE_OTP) += sifive-otp.o obj-$(CONFIG_SMSC_LPC47M) += smsc_lpc47m.o @@ -81,7 +81,7 @@ obj-$(CONFIG_SYS_DPAA_QBMAN) += fsl_portals.o obj-$(CONFIG_TEGRA186_BPMP) += tegra186_bpmp.o obj-$(CONFIG_TEGRA_CAR) += tegra_car.o obj-$(CONFIG_TEST_DRV) += test_drv.o -obj-$(CONFIG_$(SPL_TPL_)TURRIS_OMNIA_MCU) += turris_omnia_mcu.o +obj-$(CONFIG_$(PHASE_)TURRIS_OMNIA_MCU) += turris_omnia_mcu.o obj-$(CONFIG_TWL4030_LED) += twl4030_led.o obj-$(CONFIG_VEXPRESS_CONFIG) += vexpress_config.o obj-$(CONFIG_WINBOND_W83627) += winbond_w83627.o diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 328653b8823..868f3090ff2 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -6,11 +6,11 @@ obj-y += mmc.o obj-$(CONFIG_$(XPL_)DM_MMC) += mmc-uclass.o
-ifdef CONFIG_$(SPL_TPL_)DM_MMC -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += mmc_bootdev.o +ifdef CONFIG_$(PHASE_)DM_MMC +obj-$(CONFIG_$(PHASE_)BOOTSTD) += mmc_bootdev.o endif
-obj-$(CONFIG_$(SPL_TPL_)MMC_WRITE) += mmc_write.o +obj-$(CONFIG_$(PHASE_)MMC_WRITE) += mmc_write.o obj-$(CONFIG_$(XPL_)MMC_PWRSEQ) += mmc-pwrseq.o obj-$(CONFIG_MMC_SDHCI_ADMA_HELPERS) += sdhci-adma.o
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 2388d2aa27c..e204f19ff8b 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -34,9 +34,9 @@ else ifneq ($(mtd-y),) obj-$(CONFIG_SPL_MTD) += mtd.o endif -obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += nand/ +obj-$(CONFIG_$(PHASE_)NAND_SUPPORT) += nand/ obj-$(CONFIG_SPL_ONENAND_SUPPORT) += onenand/ -obj-$(CONFIG_$(SPL_TPL_)SPI_FLASH_SUPPORT) += spi/ +obj-$(CONFIG_$(PHASE_)SPI_FLASH_SUPPORT) += spi/ obj-$(CONFIG_SPL_UBI) += ubispl/
endif diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index ad02095b35b..cf53c5f601e 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -6,5 +6,5 @@ obj-$(CONFIG_MTD_NAND_CORE) += nandcore.o obj-$(CONFIG_MTD_RAW_NAND) += raw/ obj-$(CONFIG_MTD_SPI_NAND) += spi/ else -obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += raw/ +obj-$(CONFIG_$(PHASE_)NAND_SUPPORT) += raw/ endif diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index ca10ac7aecb..b47a3d787ce 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -18,7 +18,7 @@ obj-$(CONFIG_SPL_NAND_BASE) += nand_base.o nand_amd.o nand_hynix.o \ nand_macronix.o nand_micron.o \ nand_samsung.o nand_toshiba.o obj-$(CONFIG_SPL_NAND_IDENT) += nand_ids.o nand_timings.o -obj-$(CONFIG_$(SPL_TPL_)NAND_INIT) += nand.o +obj-$(CONFIG_$(PHASE_)NAND_INIT) += nand.o ifeq ($(CONFIG_SPL_ENV_SUPPORT),y) obj-$(CONFIG_ENV_IS_IN_NAND) += nand_util.o endif diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 2a287a62a47..44e67cd913a 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -3,12 +3,12 @@ # (C) Copyright 2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)DM_SPI_FLASH) += sf-uclass.o +obj-$(CONFIG_$(PHASE_)DM_SPI_FLASH) += sf-uclass.o spi-nor-y := sf_probe.o spi-nor-ids.o
ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o -ifeq ($(CONFIG_$(SPL_TPL_)SPI_FLASH_TINY),y) +ifeq ($(CONFIG_$(PHASE_)SPI_FLASH_TINY),y) spi-nor-y += spi-nor-tiny.o else spi-nor-y += spi-nor-core.o @@ -19,6 +19,6 @@ endif
obj-$(CONFIG_SPI_FLASH) += spi-nor.o obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o -obj-$(CONFIG_$(SPL_TPL_)SPI_FLASH_MTD) += sf_mtd.o +obj-$(CONFIG_$(PHASE_)SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o -obj-$(CONFIG_$(SPL_TPL_)BOOTDEV_SPI_FLASH) += sf_bootdev.o +obj-$(CONFIG_$(PHASE_)BOOTDEV_SPI_FLASH) += sf_bootdev.o diff --git a/drivers/pinctrl/starfive/Makefile b/drivers/pinctrl/starfive/Makefile index a4a12069b36..1503153ddc9 100644 --- a/drivers/pinctrl/starfive/Makefile +++ b/drivers/pinctrl/starfive/Makefile @@ -1,6 +1,6 @@
# SPDX-License-Identifier: GPL-2.0 # Core -obj-$(CONFIG_$(SPL_TPL_)PINCTRL_STARFIVE) += pinctrl-starfive.o +obj-$(CONFIG_$(PHASE_)PINCTRL_STARFIVE) += pinctrl-starfive.o # SoC Drivers -obj-$(CONFIG_$(SPL_TPL_)PINCTRL_STARFIVE_JH7110) += pinctrl-jh7110-sys.o pinctrl-jh7110-aon.o +obj-$(CONFIG_$(PHASE_)PINCTRL_STARFIVE_JH7110) += pinctrl-jh7110-sys.o pinctrl-jh7110-aon.o diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 5a987194cda..3f4d56f5139 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -3,8 +3,8 @@ # Copyright (c) 2009 Wind River Systems, Inc. # Tom Rix <Tom.Rix at windriver.com>
-obj-$(CONFIG_$(SPL_TPL_)ACPI_PMC) += acpi_pmc/ -obj-$(CONFIG_$(SPL_TPL_)POWER_DOMAIN) += domain/ +obj-$(CONFIG_$(PHASE_)ACPI_PMC) += acpi_pmc/ +obj-$(CONFIG_$(PHASE_)POWER_DOMAIN) += domain/ obj-y += pmic/ obj-y += regulator/
@@ -23,9 +23,9 @@ obj-$(CONFIG_SY8106A_POWER) += sy8106a.o obj-$(CONFIG_TPS6586X_POWER) += tps6586x.o obj-$(CONFIG_TWL4030_POWER) += twl4030.o obj-$(CONFIG_PALMAS_POWER) += palmas.o -obj-$(CONFIG_$(SPL_TPL_)POWER_LEGACY) += power_core.o +obj-$(CONFIG_$(PHASE_)POWER_LEGACY) += power_core.o obj-$(CONFIG_DIALOG_POWER) += power_dialog.o obj-$(CONFIG_POWER_FSL) += power_fsl.o -obj-$(CONFIG_$(SPL_TPL_)POWER_I2C) += power_i2c.o +obj-$(CONFIG_$(PHASE_)POWER_I2C) += power_i2c.o obj-$(CONFIG_POWER_SPI) += power_spi.o obj-$(CONFIG_POWER_MT6323) += mt6323.o diff --git a/drivers/power/acpi_pmc/Makefile b/drivers/power/acpi_pmc/Makefile index 0db52a65824..3259b397a9a 100644 --- a/drivers/power/acpi_pmc/Makefile +++ b/drivers/power/acpi_pmc/Makefile @@ -3,4 +3,4 @@ # Copyright 2019 Google LLC
obj-y += acpi-pmc-uclass.o -obj-$(CONFIG_$(SPL_TPL_)ACPI_PMC_SANDBOX) += sandbox.o pmc_emul.o +obj-$(CONFIG_$(PHASE_)ACPI_PMC_SANDBOX) += sandbox.o pmc_emul.o diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 48f7dd49ef8..bc138f563ff 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -3,7 +3,7 @@ # Copyright (C) 2012 Samsung Electronics # Lukasz Majewski l.majewski@samsung.com
-obj-$(CONFIG_$(SPL_TPL_)DM_PMIC) += pmic-uclass.o +obj-$(CONFIG_$(PHASE_)DM_PMIC) += pmic-uclass.o obj-$(CONFIG_$(XPL_)DM_PMIC_FAN53555) += fan53555.o obj-$(CONFIG_$(XPL_)DM_PMIC_DA9063) += da9063.o obj-$(CONFIG_$(XPL_)DM_PMIC_MAX77663) += max77663.o @@ -22,7 +22,7 @@ obj-$(CONFIG_PMIC_AS3722) += as3722.o as3722_gpio.o obj-$(CONFIG_$(XPL_)PMIC_AXP) += axp.o obj-$(CONFIG_PMIC_MAX8997) += max8997.o obj-$(CONFIG_PMIC_QCOM) += pmic_qcom.o -obj-$(CONFIG_$(SPL_TPL_)PMIC_RK8XX) += rk8xx.o +obj-$(CONFIG_$(PHASE_)PMIC_RK8XX) += rk8xx.o obj-$(CONFIG_$(XPL_)PMIC_RN5T567) += rn5t567.o obj-$(CONFIG_PMIC_TPS65090) += tps65090.o obj-$(CONFIG_PMIC_S5M8767) += s5m8767.o diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index cac02aaa36f..ca6c89d13b5 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -22,7 +22,7 @@ obj-$(CONFIG_$(XPL_)DM_REGULATOR_COMMON) += regulator_common.o obj-$(CONFIG_$(XPL_)DM_REGULATOR_FIXED) += fixed.o obj-$(CONFIG_$(XPL_)DM_REGULATOR_GPIO) += gpio-regulator.o obj-$(CONFIG_DM_REGULATOR_QCOM_RPMH) += qcom-rpmh-regulator.o -obj-$(CONFIG_$(SPL_TPL_)REGULATOR_RK8XX) += rk8xx.o +obj-$(CONFIG_$(PHASE_)REGULATOR_RK8XX) += rk8xx.o obj-$(CONFIG_DM_REGULATOR_S2MPS11) += s2mps11_regulator.o obj-$(CONFIG_REGULATOR_S5M8767) += s5m8767.o obj-$(CONFIG_DM_REGULATOR_SANDBOX) += sandbox.o diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index 35d8f5761e1..f92e86eaa3f 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -3,7 +3,7 @@ # Copyright (c) 2015 Google, Inc # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # -obj-$(CONFIG_$(SPL_TPL_)DM) += ram-uclass.o +obj-$(CONFIG_$(PHASE_)DM) += ram-uclass.o obj-$(CONFIG_MPC83XX_SDRAM) += mpc83xx_sdram.o obj-$(CONFIG_SANDBOX) += sandbox_ram.o obj-$(CONFIG_STM32MP1_DDR) += stm32mp1/ diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 2eb639e4a65..d99a78c9828 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -32,4 +32,4 @@ obj-$(CONFIG_RESET_SCMI) += reset-scmi.o obj-$(CONFIG_RESET_ZYNQMP) += reset-zynqmp.o obj-$(CONFIG_RESET_DRA7) += reset-dra7.o obj-$(CONFIG_RESET_AT91) += reset-at91.o -obj-$(CONFIG_$(SPL_TPL_)RESET_JH7110) += reset-jh7110.o +obj-$(CONFIG_$(PHASE_)RESET_JH7110) += reset-jh7110.o diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 30553c9d6e9..30c58272d41 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -3,7 +3,7 @@ # Copyright (c) 2019, Linaro Limited #
-obj-$(CONFIG_$(SPL_TPL_)DM_RNG) += rng-uclass.o +obj-$(CONFIG_$(PHASE_)DM_RNG) += rng-uclass.o obj-$(CONFIG_RNG_MESON) += meson-rng.o obj-$(CONFIG_RNG_SANDBOX) += sandbox_rng.o obj-$(CONFIG_RNG_MSM) += msm_rng.o diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 03a424c31a5..99b5a2a346a 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. #ccflags-y += -DDEBUG
-obj-$(CONFIG_$(SPL_TPL_)DM_RTC) += rtc-uclass.o +obj-$(CONFIG_$(PHASE_)DM_RTC) += rtc-uclass.o
obj-$(CONFIG_RTC_ARMADA38X) += armada38x.o obj-$(CONFIG_RTC_DAVINCI) += davinci.o @@ -17,7 +17,7 @@ obj-$(CONFIG_RTC_DS3232) += ds3232.o obj-$(CONFIG_RTC_EMULATION) += emul_rtc.o obj-$(CONFIG_RTC_GOLDFISH) += goldfish_rtc.o obj-$(CONFIG_RTC_HT1380) += ht1380.o -obj-$(CONFIG_$(SPL_TPL_)RTC_SANDBOX) += i2c_rtc_emul.o +obj-$(CONFIG_$(PHASE_)RTC_SANDBOX) += i2c_rtc_emul.o obj-$(CONFIG_RTC_ISL1208) += isl1208.o obj-$(CONFIG_RTC_M41T62) += m41t62.o obj-$(CONFIG_RTC_MAX313XX) += max313xx.o @@ -37,6 +37,6 @@ obj-$(CONFIG_RTC_RX8025) += rx8025.o obj-$(CONFIG_RTC_RX8010SJ) += rx8010sj.o obj-$(CONFIG_RTC_S35392A) += s35392a.o obj-$(CONFIG_RTC_STM32) += stm32_rtc.o -obj-$(CONFIG_$(SPL_TPL_)RTC_SANDBOX) += sandbox_rtc.o +obj-$(CONFIG_$(PHASE_)RTC_SANDBOX) += sandbox_rtc.o obj-$(CONFIG_RTC_ABX80X) += abx80x.o obj-$(CONFIG_RTC_ZYNQMP) += zynqmp_rtc.o diff --git a/drivers/scsi/Makefile b/drivers/scsi/Makefile index 7c19a435722..b76de1b22a8 100644 --- a/drivers/scsi/Makefile +++ b/drivers/scsi/Makefile @@ -6,7 +6,7 @@ ifndef CONFIG_XPL_BUILD obj-$(CONFIG_SCSI) += scsi.o scsi-uclass.o ifdef CONFIG_SCSI -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += scsi_bootdev.o +obj-$(CONFIG_$(PHASE_)BOOTSTD) += scsi_bootdev.o obj-$(CONFIG_SANDBOX) += sandbox_scsi.o obj-$(CONFIG_SANDBOX) += scsi_emul.o endif diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 1c0b013eb1f..ebe692a9963 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2006-2009 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-ifeq ($(CONFIG_$(SPL_TPL_)DM_SERIAL),y) +ifeq ($(CONFIG_$(PHASE_)DM_SERIAL),y) obj-y += serial-uclass.o else obj-y += serial.o diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 32d7bf7237a..7051e2a00c6 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
# There are many options which enable SPI, so make this library available -ifdef CONFIG_$(SPL_TPL_)DM_SPI +ifdef CONFIG_$(PHASE_)DM_SPI obj-y += spi-uclass.o obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_CADENCE_OSPI_VERSAL) += cadence_ospi_versal.o diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index a6a0584585c..796fc9effa5 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -2,7 +2,7 @@ # # (C) Copyright 2016 Cadence Design Systems Inc.
-obj-$(CONFIG_$(SPL_TPL_)SYSRESET) += sysreset-uclass.o +obj-$(CONFIG_$(PHASE_)SYSRESET) += sysreset-uclass.o obj-$(CONFIG_ARCH_ASPEED) += sysreset_ast.o obj-$(CONFIG_ARCH_ROCKCHIP) += sysreset_rockchip.o obj-$(CONFIG_ARCH_STI) += sysreset_sti.o @@ -10,24 +10,24 @@ obj-$(CONFIG_SANDBOX) += sysreset_sandbox.o obj-$(CONFIG_SYSRESET_CV1800B) += sysreset_cv1800b.o obj-$(CONFIG_POWEROFF_GPIO) += poweroff_gpio.o obj-$(CONFIG_SYSRESET_GPIO) += sysreset_gpio.o -obj-$(CONFIG_$(SPL_TPL_)SYSRESET_MAX77663) += sysreset_max77663.o +obj-$(CONFIG_$(PHASE_)SYSRESET_MAX77663) += sysreset_max77663.o obj-$(CONFIG_SYSRESET_MPC83XX) += sysreset_mpc83xx.o obj-$(CONFIG_SYSRESET_MICROBLAZE) += sysreset_microblaze.o obj-$(CONFIG_SYSRESET_OCTEON) += sysreset_octeon.o -obj-$(CONFIG_$(SPL_TPL_)SYSRESET_PALMAS) += sysreset_palmas.o +obj-$(CONFIG_$(PHASE_)SYSRESET_PALMAS) += sysreset_palmas.o obj-$(CONFIG_SYSRESET_PSCI) += sysreset_psci.o obj-$(CONFIG_SYSRESET_SBI) += sysreset_sbi.o obj-$(CONFIG_SYSRESET_SOCFPGA) += sysreset_socfpga.o obj-$(CONFIG_SYSRESET_SOCFPGA_SOC64) += sysreset_socfpga_soc64.o obj-$(CONFIG_SYSRESET_TEGRA) += sysreset_tegra.o obj-$(CONFIG_SYSRESET_TI_SCI) += sysreset-ti-sci.o -obj-$(CONFIG_$(SPL_TPL_)SYSRESET_TPS65910) += sysreset_tps65910.o -obj-$(CONFIG_$(SPL_TPL_)SYSRESET_TPS80031) += sysreset_tps80031.o +obj-$(CONFIG_$(PHASE_)SYSRESET_TPS65910) += sysreset_tps65910.o +obj-$(CONFIG_$(PHASE_)SYSRESET_TPS80031) += sysreset_tps80031.o obj-$(CONFIG_SYSRESET_SYSCON) += sysreset_syscon.o obj-$(CONFIG_SYSRESET_WATCHDOG) += sysreset_watchdog.o obj-$(CONFIG_SYSRESET_RESETCTL) += sysreset_resetctl.o -obj-$(CONFIG_$(SPL_TPL_)SYSRESET_AT91) += sysreset_at91.o -obj-$(CONFIG_$(SPL_TPL_)SYSRESET_X86) += sysreset_x86.o +obj-$(CONFIG_$(PHASE_)SYSRESET_AT91) += sysreset_at91.o +obj-$(CONFIG_$(PHASE_)SYSRESET_X86) += sysreset_x86.o obj-$(CONFIG_SYSRESET_RAA215300) += sysreset_raa215300.o obj-$(CONFIG_SYSRESET_QCOM_PSHOLD) += sysreset_qcom-pshold.o obj-$(CONFIG_TARGET_XTFPGA) += sysreset_xtfpga.o diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 9540fd7fe78..76e516dbbaf 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # Copyright (c) 2011 The Chromium OS Authors. All rights reserved.
-obj-$(CONFIG_$(SPL_TPL_)TPM) += tpm-uclass.o +obj-$(CONFIG_$(PHASE_)TPM) += tpm-uclass.o
obj-$(CONFIG_TPM_ATMEL_TWI) += tpm_atmel_twi.o obj-$(CONFIG_TPM_TIS_INFINEON) += tpm_tis_infineon.o @@ -10,7 +10,7 @@ obj-$(CONFIG_TPM_TIS_SANDBOX) += tpm_tis_sandbox.o sandbox_common.o obj-$(CONFIG_TPM_ST33ZP24_I2C) += tpm_tis_st33zp24_i2c.o obj-$(CONFIG_TPM_ST33ZP24_SPI) += tpm_tis_st33zp24_spi.o
-obj-$(CONFIG_$(SPL_TPL_)TPM2_CR50_I2C) += cr50_i2c.o +obj-$(CONFIG_$(PHASE_)TPM2_CR50_I2C) += cr50_i2c.o obj-$(CONFIG_TPM2_TIS_SANDBOX) += tpm2_tis_sandbox.o sandbox_common.o obj-$(CONFIG_TPM2_TIS_SPI) += tpm2_tis_core.o tpm2_tis_spi.o obj-$(CONFIG_TPM2_TIS_I2C) += tpm2_tis_core.o tpm2_tis_i2c.o diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 3158487cba4..a44b2bfc1f2 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -3,9 +3,9 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)USB_GADGET) += epautoconf.o config.o usbstring.o -obj-$(CONFIG_$(SPL_TPL_)USB_ETHER) += epautoconf.o config.o usbstring.o ether.o -obj-$(CONFIG_$(SPL_TPL_)USB_ETH_RNDIS) += rndis.o +obj-$(CONFIG_$(PHASE_)USB_GADGET) += epautoconf.o config.o usbstring.o +obj-$(CONFIG_$(PHASE_)USB_ETHER) += epautoconf.o config.o usbstring.o ether.o +obj-$(CONFIG_$(PHASE_)USB_ETH_RNDIS) += rndis.o
ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_USB_GADGET) += g_dnl.o diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 07deb4fadd6..792956e647a 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -8,8 +8,8 @@ obj-y += usb-uclass.o obj-$(CONFIG_SANDBOX) += usb-sandbox.o endif
-ifdef CONFIG_$(SPL_TPL_)USB_STORAGE -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += usb_bootdev.o +ifdef CONFIG_$(PHASE_)USB_STORAGE +obj-$(CONFIG_$(PHASE_)BOOTSTD) += usb_bootdev.o endif
# ohci diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 93fed8c491a..af8b2b266e2 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -4,12 +4,12 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
ifdef CONFIG_DM -obj-$(CONFIG_$(SPL_TPL_)BACKLIGHT) += backlight-uclass.o +obj-$(CONFIG_$(PHASE_)BACKLIGHT) += backlight-uclass.o obj-$(CONFIG_BACKLIGHT_GPIO) += backlight_gpio.o obj-$(CONFIG_BACKLIGHT_PWM) += pwm_backlight.o -obj-$(CONFIG_$(SPL_TPL_)CONSOLE_NORMAL) += console_normal.o +obj-$(CONFIG_$(PHASE_)CONSOLE_NORMAL) += console_normal.o obj-$(CONFIG_CONSOLE_ROTATION) += console_rotate.o -ifdef CONFIG_$(SPL_TPL_)CONSOLE_NORMAL +ifdef CONFIG_$(PHASE_)CONSOLE_NORMAL obj-y += console_core.o else ifdef CONFIG_CONSOLE_ROTATION obj-y += console_core.o @@ -18,14 +18,14 @@ obj-$(CONFIG_CONSOLE_ROTATION) += console_core.o obj-$(CONFIG_CONSOLE_TRUETYPE) += console_truetype.o fonts/ obj-$(CONFIG_DISPLAY) += display-uclass.o obj-$(CONFIG_VIDEO_MIPI_DSI) += dsi-host-uclass.o -obj-$(CONFIG_$(SPL_TPL_)VIDEO) += video-uclass.o vidconsole-uclass.o -obj-$(CONFIG_$(SPL_TPL_)VIDEO) += video_bmp.o -obj-$(CONFIG_$(SPL_TPL_)PANEL) += panel-uclass.o +obj-$(CONFIG_$(PHASE_)VIDEO) += video-uclass.o vidconsole-uclass.o +obj-$(CONFIG_$(PHASE_)VIDEO) += video_bmp.o +obj-$(CONFIG_$(PHASE_)PANEL) += panel-uclass.o obj-$(CONFIG_PANEL_HX8238D) += hx8238d.o -obj-$(CONFIG_$(SPL_TPL_)SIMPLE_PANEL) += simple_panel.o +obj-$(CONFIG_$(PHASE_)SIMPLE_PANEL) += simple_panel.o
obj-$(CONFIG_VIDEO_LOGO) += u_boot_logo.o -obj-$(CONFIG_$(SPL_TPL_)BMP) += bmp.o +obj-$(CONFIG_$(PHASE_)BMP) += bmp.o
endif
diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 7b39adcf0ff..1639d827fee 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -14,7 +14,7 @@ obj-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o obj-$(CONFIG_OMAP_WATCHDOG) += omap_wdt.o obj-$(CONFIG_DESIGNWARE_WATCHDOG) += designware_wdt.o obj-$(CONFIG_ULP_WATCHDOG) += ulp_wdog.o -obj-$(CONFIG_$(SPL_TPL_)WDT) += wdt-uclass.o +obj-$(CONFIG_$(PHASE_)WDT) += wdt-uclass.o obj-$(CONFIG_WDT_SANDBOX) += sandbox_wdt.o obj-$(CONFIG_WDT_ALARM_SANDBOX) += sandbox_alarm-wdt.o obj-$(CONFIG_WDT_APPLE) += apple_wdt.o diff --git a/env/Makefile b/env/Makefile index c5145c1735f..a54e924d419 100644 --- a/env/Makefile +++ b/env/Makefile @@ -3,10 +3,10 @@ # (C) Copyright 2004-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += common.o -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += env.o -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += attr.o -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += flags.o +obj-$(CONFIG_$(PHASE_)ENV_SUPPORT) += common.o +obj-$(CONFIG_$(PHASE_)ENV_SUPPORT) += env.o +obj-$(CONFIG_$(PHASE_)ENV_SUPPORT) += attr.o +obj-$(CONFIG_$(PHASE_)ENV_SUPPORT) += flags.o
ifndef CONFIG_XPL_BUILD obj-y += callback.o @@ -20,12 +20,12 @@ obj-$(CONFIG_ENV_IS_IN_REMOTE) += remote.o obj-$(CONFIG_ENV_IS_IN_UBI) += ubi.o endif
-obj-$(CONFIG_$(SPL_TPL_)ENV_IS_NOWHERE) += nowhere.o -obj-$(CONFIG_$(SPL_TPL_)ENV_IS_IN_MMC) += mmc.o -obj-$(CONFIG_$(SPL_TPL_)ENV_IS_IN_FAT) += fat.o -obj-$(CONFIG_$(SPL_TPL_)ENV_IS_IN_EXT4) += ext4.o -obj-$(CONFIG_$(SPL_TPL_)ENV_IS_IN_NAND) += nand.o -obj-$(CONFIG_$(SPL_TPL_)ENV_IS_IN_SPI_FLASH) += sf.o -obj-$(CONFIG_$(SPL_TPL_)ENV_IS_IN_FLASH) += flash.o +obj-$(CONFIG_$(PHASE_)ENV_IS_NOWHERE) += nowhere.o +obj-$(CONFIG_$(PHASE_)ENV_IS_IN_MMC) += mmc.o +obj-$(CONFIG_$(PHASE_)ENV_IS_IN_FAT) += fat.o +obj-$(CONFIG_$(PHASE_)ENV_IS_IN_EXT4) += ext4.o +obj-$(CONFIG_$(PHASE_)ENV_IS_IN_NAND) += nand.o +obj-$(CONFIG_$(PHASE_)ENV_IS_IN_SPI_FLASH) += sf.o +obj-$(CONFIG_$(PHASE_)ENV_IS_IN_FLASH) += flash.o
CFLAGS_embedded.o := -Wa,--no-warn -DENV_CRC=$(shell tools/envcrc 2>/dev/null) diff --git a/fs/sandbox/Makefile b/fs/sandbox/Makefile index 880d59dd693..54ad842d1fe 100644 --- a/fs/sandbox/Makefile +++ b/fs/sandbox/Makefile @@ -9,4 +9,4 @@ # Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de
obj-y := sandboxfs.o -obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += host_bootdev.o +obj-$(CONFIG_$(PHASE_)BOOTSTD) += host_bootdev.o diff --git a/lib/Makefile b/lib/Makefile index 139476a4a23..7ccc91f5d33 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -20,7 +20,7 @@ obj-$(CONFIG_OPTEE_LIB) += optee/
obj-$(CONFIG_AES) += aes.o obj-$(CONFIG_AES) += aes/ -obj-$(CONFIG_$(SPL_TPL_)BINMAN_FDT) += binman.o +obj-$(CONFIG_$(PHASE_)BINMAN_FDT) += binman.o
ifndef API_BUILD ifneq ($(CONFIG_CHARSET),) @@ -56,8 +56,8 @@ obj-$(CONFIG_BITREVERSE) += bitrev.o obj-y += list_sort.o endif
-obj-$(CONFIG_$(SPL_TPL_)TPM) += tpm-common.o -ifeq ($(CONFIG_$(SPL_TPL_)TPM),y) +obj-$(CONFIG_$(PHASE_)TPM) += tpm-common.o +ifeq ($(CONFIG_$(PHASE_)TPM),y) obj-$(CONFIG_TPM) += tpm_api.o obj-$(CONFIG_TPM_V1) += tpm-v1.o obj-$(CONFIG_TPM_V2) += tpm-v2.o @@ -65,12 +65,12 @@ obj-$(CONFIG_EFI_TCG2_PROTOCOL) += tpm_tcg2.o obj-$(CONFIG_MEASURED_BOOT) += tpm_tcg2.o endif
-obj-$(CONFIG_$(SPL_TPL_)CRC8) += crc8.o -obj-$(CONFIG_$(SPL_TPL_)CRC16) += crc16.o +obj-$(CONFIG_$(PHASE_)CRC8) += crc8.o +obj-$(CONFIG_$(PHASE_)CRC16) += crc16.o
obj-y += crypto/
-obj-$(CONFIG_$(SPL_TPL_)ACPI) += acpi/ +obj-$(CONFIG_$(PHASE_)ACPI) += acpi/ obj-$(CONFIG_$(XPL_)MD5) += md5.o obj-$(CONFIG_ECDSA) += ecdsa/ obj-$(CONFIG_$(XPL_)RSA) += rsa/ @@ -93,12 +93,12 @@ obj-$(CONFIG_$(XPL_)LIB_RATIONAL) += rational.o
obj-$(CONFIG_LIBAVB) += libavb/
-obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += libfdt/ -obj-$(CONFIG_$(SPL_TPL_)OF_REAL) += fdtdec_common.o fdtdec.o +obj-$(CONFIG_$(PHASE_)OF_LIBFDT) += libfdt/ +obj-$(CONFIG_$(PHASE_)OF_REAL) += fdtdec_common.o fdtdec.o
ifdef CONFIG_XPL_BUILD obj-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16-ccitt.o -obj-$(CONFIG_$(SPL_TPL_)HASH) += crc16-ccitt.o +obj-$(CONFIG_$(PHASE_)HASH) += crc16-ccitt.o obj-$(CONFIG_MMC_SPI_CRC_ON) += crc16-ccitt.o obj-y += net_utils.o endif @@ -110,15 +110,15 @@ obj-y += display_options.o CFLAGS_display_options.o := $(if $(BUILD_TAG),-DBUILD_TAG='"$(BUILD_TAG)"') obj-$(CONFIG_BCH) += bch.o obj-$(CONFIG_MMC_SPI) += crc7.o -obj-$(CONFIG_$(SPL_TPL_)CRC32) += crc32.o +obj-$(CONFIG_$(PHASE_)CRC32) += crc32.o obj-$(CONFIG_CRC32C) += crc32c.o obj-y += ctype.o obj-y += div64.o -obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdtdec.o fdtdec_common.o +obj-$(CONFIG_$(PHASE_)OF_LIBFDT) += fdtdec.o fdtdec_common.o obj-y += hang.o obj-y += linux_compat.o obj-y += linux_string.o -obj-$(CONFIG_$(SPL_TPL_)LMB) += lmb.o +obj-$(CONFIG_$(PHASE_)LMB) += lmb.o obj-y += membuff.o obj-$(CONFIG_REGEX) += slre.o obj-y += string.o @@ -133,12 +133,12 @@ obj-y += panic.o
ifeq ($(CONFIG_XPL_BUILD),y) # SPL U-Boot may use full-printf, tiny-printf or none at all -ifdef CONFIG_$(SPL_TPL_)USE_TINY_PRINTF -obj-$(CONFIG_$(SPL_TPL_)SPRINTF) += tiny-printf.o +ifdef CONFIG_$(PHASE_)USE_TINY_PRINTF +obj-$(CONFIG_$(PHASE_)SPRINTF) += tiny-printf.o else -obj-$(CONFIG_$(SPL_TPL_)SPRINTF) += vsprintf.o +obj-$(CONFIG_$(PHASE_)SPRINTF) += vsprintf.o endif -obj-$(CONFIG_$(SPL_TPL_)STRTO) += strto.o +obj-$(CONFIG_$(PHASE_)STRTO) += strto.o else # Main U-Boot always uses the full printf support obj-y += vsprintf.o strto.o @@ -152,7 +152,7 @@ obj-y += date.o obj-y += rtc-lib.o obj-$(CONFIG_LIB_ELF) += elf.o
# # Build a fast OID lookup registry from include/linux/oid_registry.h diff --git a/lib/acpi/Makefile b/lib/acpi/Makefile index 99be19adb4c..dcca0c67268 100644 --- a/lib/acpi/Makefile +++ b/lib/acpi/Makefile @@ -3,7 +3,7 @@
obj-y += acpi.o
-ifdef CONFIG_$(SPL_TPL_)GENERATE_ACPI_TABLE +ifdef CONFIG_$(PHASE_)GENERATE_ACPI_TABLE
obj-$(CONFIG_$(XPL_)ACPIGEN) += acpigen.o obj-$(CONFIG_$(XPL_)ACPIGEN) += acpi_device.o diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index 1fe50ecbe52..c492377032b 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -16,4 +16,4 @@ obj-y += \ obj-$(CONFIG_OF_LIBFDT_OVERLAY) += fdt_overlay.o
ccflags-y := -I$(srctree)/scripts/dtc/libfdt \ - -DFDT_ASSUME_MASK=$(CONFIG_$(SPL_TPL_)OF_LIBFDT_ASSUME_MASK) + -DFDT_ASSUME_MASK=$(CONFIG_$(PHASE_)OF_LIBFDT_ASSUME_MASK) diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index c9ac72c1e26..1f9b24001bf 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -5,6 +5,6 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)RSA_VERIFY) += rsa-verify.o -obj-$(CONFIG_$(SPL_TPL_)RSA_VERIFY_WITH_PKEY) += rsa-keyprop.o +obj-$(CONFIG_$(PHASE_)RSA_VERIFY) += rsa-verify.o +obj-$(CONFIG_$(PHASE_)RSA_VERIFY_WITH_PKEY) += rsa-keyprop.o obj-$(CONFIG_RSA_SOFTWARE_EXP) += rsa-mod-exp.o diff --git a/net/Makefile b/net/Makefile index a1d37855593..a7075c36a04 100644 --- a/net/Makefile +++ b/net/Makefile @@ -11,7 +11,7 @@ obj-$(CONFIG_CMD_CDP) += cdp.o obj-$(CONFIG_CMD_DNS) += dns.o obj-$(CONFIG_DM_DSA) += dsa-uclass.o obj-$(CONFIG_$(XPL_)DM_ETH) += eth-uclass.o -obj-$(CONFIG_$(SPL_TPL_)BOOTDEV_ETH) += eth_bootdev.o +obj-$(CONFIG_$(PHASE_)BOOTDEV_ETH) += eth_bootdev.o obj-$(CONFIG_DM_MDIO) += mdio-uclass.o obj-$(CONFIG_DM_MDIO_MUX) += mdio-mux-uclass.o obj-$(CONFIG_$(XPL_)DM_ETH) += eth_common.o @@ -27,8 +27,8 @@ obj-$(CONFIG_CMD_PCAP) += pcap.o obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_TFTPBOOT) += tftp.o -obj-$(CONFIG_$(SPL_TPL_)UDP_FUNCTION_FASTBOOT) += fastboot_udp.o -obj-$(CONFIG_$(SPL_TPL_)TCP_FUNCTION_FASTBOOT) += fastboot_tcp.o +obj-$(CONFIG_$(PHASE_)UDP_FUNCTION_FASTBOOT) += fastboot_udp.o +obj-$(CONFIG_$(PHASE_)TCP_FUNCTION_FASTBOOT) += fastboot_tcp.o obj-$(CONFIG_CMD_WOL) += wol.o obj-$(CONFIG_PROT_UDP) += udp.o obj-$(CONFIG_PROT_TCP) += tcp.o diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 1a6b28feedf..edc91b24e45 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -327,15 +327,15 @@ endif ifdef CONFIG_XPL_BUILD XPL_ := SPL_ ifeq ($(CONFIG_VPL_BUILD),y) -SPL_TPL_ := VPL_ +PHASE_ := VPL_ else ifeq ($(CONFIG_TPL_BUILD),y) -SPL_TPL_ := TPL_ +PHASE_ := TPL_ else -SPL_TPL_ := SPL_ +PHASE_ := SPL_ endif endif else XPL_ := -SPL_TPL_ := +PHASE_ := endif diff --git a/scripts/Makefile.xpl b/scripts/Makefile.xpl index 11ae93f8556..dca5f4539d0 100644 --- a/scripts/Makefile.xpl +++ b/scripts/Makefile.xpl @@ -61,17 +61,17 @@ export SPL_NAME ifdef CONFIG_XPL_BUILD XPL_ := SPL_ ifeq ($(CONFIG_VPL_BUILD),y) -SPL_TPL_ := VPL_ +PHASE_ := VPL_ else ifeq ($(CONFIG_TPL_BUILD),y) -SPL_TPL_ := TPL_ +PHASE_ := TPL_ else -SPL_TPL_ := SPL_ +PHASE_ := SPL_ endif endif else XPL_ := -SPL_TPL_ := +PHASE_ := endif
ifeq ($(obj)$(CONFIG_SUPPORT_SPL),spl) @@ -93,7 +93,7 @@ include $(srctree)/scripts/Makefile.lib KBUILD_CFLAGS += -ffunction-sections -fdata-sections LDFLAGS_FINAL += --gc-sections
-ifeq ($(CONFIG_$(SPL_TPL_)STACKPROTECTOR),y) +ifeq ($(CONFIG_$(PHASE_)STACKPROTECTOR),y) KBUILD_CFLAGS += -fstack-protector-strong else KBUILD_CFLAGS += -fno-stack-protector @@ -117,8 +117,8 @@ endif libs-y += common/init/
# Special handling for a few options which support SPL/TPL/VPL -libs-$(CONFIG_$(SPL_TPL_)LIBCOMMON_SUPPORT) += boot/ common/ cmd/ env/ -libs-$(CONFIG_$(SPL_TPL_)LIBGENERIC_SUPPORT) += lib/ +libs-$(CONFIG_$(PHASE_)LIBCOMMON_SUPPORT) += boot/ common/ cmd/ env/ +libs-$(CONFIG_$(PHASE_)LIBGENERIC_SUPPORT) += lib/ ifdef CONFIG_SPL_FRAMEWORK libs-$(CONFIG_PARTITIONS) += disk/ endif @@ -131,7 +131,7 @@ libs-y += dts/ libs-y += fs/ libs-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/ libs-$(CONFIG_SPL_NET) += net/ -libs-$(CONFIG_$(SPL_TPL_)UNIT_TEST) += test/ +libs-$(CONFIG_$(PHASE_)UNIT_TEST) += test/
head-y := $(addprefix $(obj)/,$(head-y)) libs-y := $(addprefix $(obj)/,$(libs-y)) @@ -147,12 +147,12 @@ endif
u-boot-spl-init := $(head-y) u-boot-spl-main := $(libs-y) -ifdef CONFIG_$(SPL_TPL_)OF_PLATDATA +ifdef CONFIG_$(PHASE_)OF_PLATDATA platdata-hdr := include/generated/dt-structs-gen.h include/generated/dt-decl.h platdata-inst := $(obj)/dts/dt-uclass.o $(obj)/dts/dt-device.o platdata-noinst := $(obj)/dts/dt-plat.o
-ifdef CONFIG_$(SPL_TPL_)OF_PLATDATA_INST +ifdef CONFIG_$(PHASE_)OF_PLATDATA_INST u-boot-spl-platdata := $(platdata-inst) u-boot-spl-old-platdata := $(platdata-noinst) else @@ -169,9 +169,9 @@ endif # OF_PLATDATA
# Linker Script # First test whether there's a linker-script for the specific stage defined... -ifneq ($(CONFIG_$(SPL_TPL_)LDSCRIPT),) +ifneq ($(CONFIG_$(PHASE_)LDSCRIPT),) # need to strip off double quotes -LDSCRIPT := $(addprefix $(srctree)/,$(CONFIG_$(SPL_TPL_)LDSCRIPT:"%"=%)) +LDSCRIPT := $(addprefix $(srctree)/,$(CONFIG_$(PHASE_)LDSCRIPT:"%"=%)) else # ...then fall back to the generic SPL linker-script ifneq ($(CONFIG_SPL_LDSCRIPT),) @@ -205,11 +205,11 @@ LDPPFLAGS += \
# Turn various CONFIG symbols into IMAGE symbols for easy reuse of # the scripts between SPL, TPL and VPL. -ifneq ($(CONFIG_$(SPL_TPL_)MAX_SIZE),0x0) -LDPPFLAGS += -DIMAGE_MAX_SIZE=$(CONFIG_$(SPL_TPL_)MAX_SIZE) +ifneq ($(CONFIG_$(PHASE_)MAX_SIZE),0x0) +LDPPFLAGS += -DIMAGE_MAX_SIZE=$(CONFIG_$(PHASE_)MAX_SIZE) endif -ifneq ($(CONFIG_$(SPL_TPL_)TEXT_BASE),) -LDPPFLAGS += -DIMAGE_TEXT_BASE=$(CONFIG_$(SPL_TPL_)TEXT_BASE) +ifneq ($(CONFIG_$(PHASE_)TEXT_BASE),) +LDPPFLAGS += -DIMAGE_TEXT_BASE=$(CONFIG_$(PHASE_)TEXT_BASE) endif
MKIMAGEOUTPUT ?= /dev/null @@ -323,7 +323,7 @@ endif # - OF_REAL is enabled # - we have either OF_SEPARATE or OF_HOSTFILE build_dtb := -ifneq ($(CONFIG_$(SPL_TPL_)OF_REAL),) +ifneq ($(CONFIG_$(PHASE_)OF_REAL),) ifneq ($(CONFIG_OF_SEPARATE)$(CONFIG_SANDBOX),) build_dtb := y endif @@ -331,7 +331,7 @@ endif
ifneq ($(build_dtb),) $(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin \ - $(if $(CONFIG_$(SPL_TPL_)SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ + $(if $(CONFIG_$(PHASE_)SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ $(FINAL_DTB_CONTAINER) FORCE $(call if_changed,cat)
@@ -355,7 +355,7 @@ pythonpath = PYTHONPATH=scripts/dtc/pylibfdt DTOC_ARGS := $(pythonpath) $(srctree)/tools/dtoc/dtoc \ -d $(obj)/$(SPL_BIN).dtb -p $(SPL_NAME)
-ifneq ($(CONFIG_$(SPL_TPL_)OF_PLATDATA_INST),) +ifneq ($(CONFIG_$(PHASE_)OF_PLATDATA_INST),) DTOC_ARGS += -i endif
@@ -400,7 +400,7 @@ quiet_cmd_objcopy = OBJCOPY $@ cmd_objcopy = $(OBJCOPY) $(OBJCOPYFLAGS) $(OBJCOPYFLAGS_$(@F)) $< $@
OBJCOPYFLAGS_$(SPL_BIN)-nodtb.bin = $(SPL_OBJCFLAGS) -O binary \ - $(if $(CONFIG_$(SPL_TPL_)X86_16BIT_INIT),-R .start16 -R .resetvec) + $(if $(CONFIG_$(PHASE_)X86_16BIT_INIT),-R .start16 -R .resetvec)
$(obj)/$(SPL_BIN)-nodtb.bin: $(obj)/$(SPL_BIN) FORCE $(call if_changed,objcopy) @@ -429,8 +429,8 @@ LDFLAGS_$(SPL_BIN) += $(call ld-option, --no-dynamic-linker) LDFLAGS_$(SPL_BIN) += --build-id=none
# Pick the best match (e.g. SPL_TEXT_BASE for SPL, TPL_TEXT_BASE for TPL) -ifneq ($(CONFIG_$(SPL_TPL_)TEXT_BASE),) -LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_$(SPL_TPL_)TEXT_BASE) +ifneq ($(CONFIG_$(PHASE_)TEXT_BASE),) +LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_$(PHASE_)TEXT_BASE) endif
ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 diff --git a/test/dm/Makefile b/test/dm/Makefile index c6c63051e0b..6c9ebb8d07c 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -42,7 +42,7 @@ obj-$(CONFIG_CLK) += clk.o clk_ccf.o obj-$(CONFIG_CPU) += cpu.o obj-$(CONFIG_CROS_EC) += cros_ec.o obj-$(CONFIG_PWM_CROS_EC) += cros_ec_pwm.o -obj-$(CONFIG_$(SPL_TPL_)DEVRES) += devres.o +obj-$(CONFIG_$(PHASE_)DEVRES) += devres.o obj-$(CONFIG_DMA) += dma.o obj-$(CONFIG_VIDEO_MIPI_DSI) += dsi_host.o obj-$(CONFIG_DM_DSA) += dsa.o @@ -102,7 +102,7 @@ obj-$(CONFIG_DM_RESET) += reset.o obj-$(CONFIG_SYSRESET) += sysreset.o obj-$(CONFIG_DM_REGULATOR) += regulator.o obj-$(CONFIG_CMD_RKMTD) += rkmtd.o -obj-$(CONFIG_$(SPL_TPL_)DM_RNG) += rng.o +obj-$(CONFIG_$(PHASE_)DM_RNG) += rng.o obj-$(CONFIG_DM_RTC) += rtc.o obj-$(CONFIG_SCMI_FIRMWARE) += scmi.o obj-$(CONFIG_SCSI) += scsi.o diff --git a/tools/qconfig.py b/tools/qconfig.py index e025f560928..7b4934b726d 100755 --- a/tools/qconfig.py +++ b/tools/qconfig.py @@ -1222,8 +1222,8 @@ def scan_makefiles(fnames): (None, 'FRED') >>> RE_MK_CONFIGS.search('CONFIG_$(XPL_)MARY').groups() ('$(XPL_)', 'MARY') - >>> RE_MK_CONFIGS.search('CONFIG_$(SPL_TPL_)MARY').groups() - ('$(SPL_TPL_)', 'MARY') + >>> RE_MK_CONFIGS.search('CONFIG_$(PHASE_)MARY').groups() + ('$(PHASE_)', 'MARY') """ all_uses = collections.defaultdict(list) fname_uses = {} @@ -1322,7 +1322,7 @@ def do_scan_source(path, do_update): an SPL_ option, but for which there is none; for MOD_PROPER, look at source code which implies a Proper option (i.e. use of CONFIG_IS_ENABLED() or $(XPL_) or - $(SPL_TPL_) but for which there none; + $(PHASE_) but for which there none; if MODE_NORMAL, ignore SPL
Returns:
Rename these to use the word PHASE instead.
common/spl/spl.c | 36 ++++++++++++++++++------------------ common/spl/spl_fit.c | 2 +- common/spl/spl_legacy.c | 2 +- include/spl.h | 14 +++++++------- 4 files changed, 27 insertions(+), 27 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index c13b2b8f714..dc73d3aff00 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -97,9 +97,9 @@ __weak int dram_init_banksize(void) #if CONFIG_IS_ENABLED(OS_BOOT) __weak int spl_start_uboot(void) { - puts(SPL_TPL_PROMPT + puts(PHASE_PROMPT "Please implement spl_start_uboot() for your board\n"); - puts(SPL_TPL_PROMPT "Direct Linux boot not active!\n"); + puts(PHASE_PROMPT "Direct Linux boot not active!\n"); return 1; }
@@ -140,13 +140,13 @@ void spl_fixup_fdt(void *fdt_blob) /* fixup the memory dt node */ err = fdt_shrink_to_minimum(fdt_blob, 0); if (err == 0) { - printf(SPL_TPL_PROMPT "fdt_shrink_to_minimum err - %d\n", err); + printf(PHASE_PROMPT "fdt_shrink_to_minimum err - %d\n", err); return; }
err = arch_fixup_fdt(fdt_blob); if (err) { - printf(SPL_TPL_PROMPT "arch_fixup_fdt err - %d\n", err); + printf(PHASE_PROMPT "arch_fixup_fdt err - %d\n", err); return; } #endif @@ -330,7 +330,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->load_addr = start; spl_image->entry_point = start; spl_image->size = size; - debug(SPL_TPL_PROMPT + debug(PHASE_PROMPT "payload Image, load addr: 0x%lx size: %d\n", spl_image->load_addr, spl_image->size); return 0; @@ -344,7 +344,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->load_addr = CONFIG_SYS_LOAD_ADDR; spl_image->entry_point = CONFIG_SYS_LOAD_ADDR; spl_image->size = end - start; - debug(SPL_TPL_PROMPT + debug(PHASE_PROMPT "payload zImage, load addr: 0x%lx size: %d\n", spl_image->load_addr, spl_image->size); return 0; @@ -423,7 +423,7 @@ static int write_spl_handoff(void) ret = handoff_arch_save(ho); if (ret) return ret; - debug(SPL_TPL_PROMPT "Wrote SPL handoff\n"); + debug(PHASE_PROMPT "Wrote SPL handoff\n");
return 0; } @@ -624,11 +624,11 @@ static int boot_from_devices(struct spl_image_info *spl_image, printf("Trying to boot from %s\n", spl_loader_name(loader)); else if (CONFIG_IS_ENABLED(SHOW_ERRORS)) { - printf(SPL_TPL_PROMPT + printf(PHASE_PROMPT "Unsupported Boot Device %d\n", bootdev); } else { - puts(SPL_TPL_PROMPT + puts(PHASE_PROMPT "Unsupported Boot Device!\n"); } } @@ -674,7 +674,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) struct spl_image_info spl_image; int ret, os;
- debug(">>" SPL_TPL_PROMPT "board_init_r()\n"); + debug(">>" PHASE_PROMPT "board_init_r()\n");
spl_set_bd();
@@ -694,7 +694,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) if (ret) { debug("%s: Failed to set up bloblist: ret=%d\n", __func__, ret); - puts(SPL_TPL_PROMPT "Cannot set up bloblist\n"); + puts(PHASE_PROMPT "Cannot set up bloblist\n"); hang(); } } @@ -703,7 +703,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
ret = setup_spl_handoff(); if (ret) { - puts(SPL_TPL_PROMPT "Cannot set up SPL handoff\n"); + puts(PHASE_PROMPT "Cannot set up SPL handoff\n"); hang(); } } @@ -724,7 +724,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) if (CONFIG_IS_ENABLED(PCI) && !(gd->flags & GD_FLG_DM_DEAD)) { ret = pci_init(); if (ret) - puts(SPL_TPL_PROMPT "Cannot initialize PCI\n"); + puts(PHASE_PROMPT "Cannot initialize PCI\n"); /* Don't fail. We still can try other boot methods. */ }
@@ -751,10 +751,10 @@ void board_init_r(gd_t *dummy1, ulong dummy2) ARRAY_SIZE(spl_boot_list)); if (ret) { if (CONFIG_IS_ENABLED(SHOW_ERRORS)) - printf(SPL_TPL_PROMPT "failed to boot from all boot devices (err=%d)\n", + printf(PHASE_PROMPT "failed to boot from all boot devices (err=%d)\n", ret); else - puts(SPL_TPL_PROMPT "failed to boot from all boot devices\n"); + puts(PHASE_PROMPT "failed to boot from all boot devices\n"); hang(); }
@@ -808,13 +808,13 @@ void board_init_r(gd_t *dummy1, ulong dummy2) if (CONFIG_IS_ENABLED(HANDOFF)) { ret = write_spl_handoff(); if (ret) - printf(SPL_TPL_PROMPT + printf(PHASE_PROMPT "SPL hand-off write failed (err=%d)\n", ret); } if (CONFIG_IS_ENABLED(UPL_OUT) && (gd->flags & GD_FLG_UPL)) { ret = spl_write_upl_handoff(&spl_image); if (ret) { - printf(SPL_TPL_PROMPT + printf(PHASE_PROMPT "UPL hand-off write failed (err=%d)\n", ret); hang(); } @@ -844,7 +844,7 @@ void preloader_console_init(void) gd->flags |= GD_FLG_HAVE_CONSOLE;
#if CONFIG_IS_ENABLED(BANNER_PRINT) - puts("\nU-Boot " SPL_TPL_NAME " " PLAIN_VERSION " (" U_BOOT_DATE " - " + puts("\nU-Boot " PHASE_NAME " " PLAIN_VERSION " (" U_BOOT_DATE " - " U_BOOT_TIME " " U_BOOT_TZ ")\n"); #endif #ifdef CONFIG_SPL_DISPLAY_PRINT diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 1ad5a69d807..3160f573bfb 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -904,7 +904,7 @@ int spl_load_fit_image(struct spl_image_info *spl_image, spl_image->os = IH_OS_INVALID; spl_image->name = genimg_get_os_name(spl_image->os);
- debug(SPL_TPL_PROMPT "payload image: %32s load addr: 0x%lx size: %d\n", + debug(PHASE_PROMPT "payload image: %32s load addr: 0x%lx size: %d\n", spl_image->name, spl_image->load_addr, spl_image->size);
#ifdef CONFIG_SPL_FIT_SIGNATURE diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c index a77893455f2..9252b3a3de0 100644 --- a/common/spl/spl_legacy.c +++ b/common/spl/spl_legacy.c @@ -71,7 +71,7 @@ int spl_parse_legacy_header(struct spl_image_info *spl_image,
spl_image->os = image_get_os(header); spl_image->name = image_get_name(header); - debug(SPL_TPL_PROMPT + debug(PHASE_PROMPT "payload image: %32s load addr: 0x%lx size: %d\n", spl_image->name, spl_image->load_addr, spl_image->size);
diff --git a/include/spl.h b/include/spl.h index 415d198da56..47666eace91 100644 --- a/include/spl.h +++ b/include/spl.h @@ -229,16 +229,16 @@ static inline const char *spl_phase_prefix(enum u_boot_phase phase) /* A string name for SPL or TPL */ #ifdef CONFIG_XPL_BUILD # ifdef CONFIG_TPL_BUILD -# define SPL_TPL_NAME "TPL" +# define PHASE_NAME "TPL" # elif defined(CONFIG_VPL_BUILD) -# define SPL_TPL_NAME "VPL" -# else -# define SPL_TPL_NAME "SPL" +# define PHASE_NAME "VPL" +# elif defined(CONFIG_SPL_BUILD) +# define PHASE_NAME "SPL" # endif -# define SPL_TPL_PROMPT SPL_TPL_NAME ": " +# define PHASE_PROMPT PHASE_NAME ": " #else -# define SPL_TPL_NAME "" -# define SPL_TPL_PROMPT "" +# define PHASE_NAME "" +# define PHASE_PROMPT "" #endif
Take account of the new XPL_ and PHASE_ instead of the old SPL_ and SPL_TPL_
tools/qconfig.py | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/tools/qconfig.py b/tools/qconfig.py index 7b4934b726d..058d72cf4bc 100755 --- a/tools/qconfig.py +++ b/tools/qconfig.py @@ -1175,7 +1175,7 @@ def prefix_config(cfg): return oper + cfg
-RE_MK_CONFIGS = re.compile(r'CONFIG_($(SPL_(?:TPL_)?))?([A-Za-z0-9_]*)') +RE_MK_CONFIGS = re.compile(r'CONFIG_($(XPL_)|$(PHASE_))?([A-Za-z0-9_]*)') RE_IFDEF = re.compile(r'(ifdef|ifndef)') RE_C_CONFIGS = re.compile(r'CONFIG_([A-Za-z0-9_]*)') RE_CONFIG_IS = re.compile(r'CONFIG_IS_ENABLED(([A-Za-z0-9_]*))') @@ -1186,7 +1186,7 @@ class ConfigUse: """Set up a new ConfigUse
Args: - cfg (str): CONFIG option, without any CONFIG_ or SPL_ prefix + cfg (str): CONFIG option, without any CONFIG_ or xPL_ prefix is_spl (bool): True if this option relates to SPL fname (str): Makefile filename where the CONFIG option was found rest (str): Line of the Makefile @@ -1319,7 +1319,7 @@ def do_scan_source(path, do_update): key (ConfigUse): object value (list of str): matching lines spl_mode (int): If MODE_SPL, look at source code which implies - an SPL_ option, but for which there is none; + an xPL_ option, but for which there is none; for MOD_PROPER, look at source code which implies a Proper option (i.e. use of CONFIG_IS_ENABLED() or $(XPL_) or $(PHASE_) but for which there none; @@ -1341,7 +1341,7 @@ def do_scan_source(path, do_update): if spl_mode == MODE_SPL: check = use.is_spl
- # If it is an SPL symbol, try prepending all SPL_ prefixes to + # If it is an SPL symbol, try prepending all xPL_ prefixes to # find at least one SPL symbol if use.is_spl: for prefix in SPL_PREFIXES: @@ -1354,7 +1354,7 @@ def do_scan_source(path, do_update): continue elif spl_mode == MODE_PROPER: # Try to find the Proper version of this symbol, i.e. without - # the SPL_ prefix + # the xPL_ prefix proper_name = is_not_proper(name) if proper_name: name = proper_name @@ -1450,7 +1450,7 @@ def do_scan_source(path, do_update): show_uses(not_found) spl_not_found |= {is_not_proper(key) or key for key in not_found.keys()}
- print('\nCONFIG options used as Proper in Makefiles but without a non-SPL_ variant:') + print('\nCONFIG options used as Proper in Makefiles but without a non-xPL_ variant:') not_found = check_not_found(all_uses, MODE_PROPER) show_uses(not_found) proper_not_found |= {not_found.keys()} @@ -1468,16 +1468,16 @@ def do_scan_source(path, do_update): show_uses(not_found) spl_not_found |= {is_not_proper(key) or key for key in not_found.keys()}
- print('\nCONFIG options used as Proper in source but without a non-SPL_ variant:') + print('\nCONFIG options used as Proper in source but without a non-xPL_ variant:') not_found = check_not_found(all_uses, MODE_PROPER) show_uses(not_found) proper_not_found |= {not_found.keys()}
- print('\nCONFIG options used as SPL but without an SPL_ variant:') + print('\nCONFIG options used as SPL but without an xPL_ variant:') for item in sorted(spl_not_found): print(f' {item}')
- print('\nCONFIG options used as Proper but without a non-SPL_ variant:') + print('\nCONFIG options used as Proper but without a non-xPL_ variant:') for item in sorted(proper_not_found): print(f' {item}')
This is a better name for this function, so update it.
Tidy up the function comment to mention VPL. Use SPL_BUILD in the SPL check, for clarity.
arch/arm/mach-omap2/am33xx/board.c | 2 +- common/bloblist.c | 4 ++-- common/spl/spl.c | 4 ++-- include/spl.h | 16 +++++++++------- 4 files changed, 14 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index e720fb6b21f..4e9ad8935e3 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -526,7 +526,7 @@ EVENT_SPY_SIMPLE(EVT_DM_POST_INIT_F, am33xx_dm_post_init); #ifdef CONFIG_DEBUG_UART_BOARD_INIT void board_debug_uart_init(void) { - if (u_boot_first_phase()) { + if (xpl_is_first_phase()) { hw_data_init(); set_uart_mux_conf(); setup_early_clocks(); diff --git a/common/bloblist.c b/common/bloblist.c index 2008ab4d25c..fb86789df42 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -504,13 +504,13 @@ int bloblist_init(void) * If U-Boot is not in the first phase, an existing bloblist must be * at a fixed address. */ - bool from_addr = fixed && !u_boot_first_phase(); + bool from_addr = fixed && !xpl_is_first_phase(); /* * If U-Boot is in the first phase that an arch custom routine should * install the bloblist passed from previous loader to this fixed * address. */ - bool from_boot_arg = fixed && u_boot_first_phase(); + bool from_boot_arg = fixed && xpl_is_first_phase();
if (spl_prev_phase() == PHASE_TPL && !IS_ENABLED(CONFIG_TPL_BLOBLIST)) from_addr = false; diff --git a/common/spl/spl.c b/common/spl/spl.c index dc73d3aff00..674ab35ede0 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -464,13 +464,13 @@ static int spl_common_init(bool setup_malloc) gd->malloc_ptr = 0; } #endif - ret = bootstage_init(u_boot_first_phase()); + ret = bootstage_init(xpl_is_first_phase()); if (ret) { debug("%s: Failed to set up bootstage: ret=%d\n", __func__, ret); return ret; } - if (!u_boot_first_phase()) { + if (!xpl_is_first_phase()) { ret = bootstage_unstash_default(); if (ret) log_debug("Failed to unstash bootstage: ret=%d\n", ret); diff --git a/include/spl.h b/include/spl.h index 47666eace91..c313c57f1aa 100644 --- a/include/spl.h +++ b/include/spl.h @@ -34,24 +34,26 @@ struct spl_boot_device; enum boot_device;
/* - * u_boot_first_phase() - check if this is the first U-Boot phase + * xpl_is_first_phase() - check if this is the first U-Boot phase * - * U-Boot has up to three phases: TPL, SPL and U-Boot proper. Depending on the - * build flags we can determine whether the current build is for the first + * U-Boot has up to four phases: TPL, VPL, SPL and U-Boot proper. Depending on + * the build flags we can determine whether the current build is for the first * phase of U-Boot or not. If there is no SPL, then this is U-Boot proper. If * there is SPL but no TPL, the the first phase is SPL. If there is TPL, then - * it is the first phase. + * it is the first phase, etc. * - * @returns true if this is the first phase of U-Boot + * Note that VPL can never be the first phase. If it exists, it is loaded from + * TPL * + * Return: true if this is the first phase of U-Boot */ -static inline bool u_boot_first_phase(void) +static inline bool xpl_is_first_phase(void) { if (IS_ENABLED(CONFIG_TPL)) { if (IS_ENABLED(CONFIG_TPL_BUILD)) return true; } else if (IS_ENABLED(CONFIG_SPL)) { - if (IS_ENABLED(CONFIG_XPL_BUILD)) + if (IS_ENABLED(CONFIG_SPL_BUILD)) return true; } else { return true;
This name fits better with the new naming scheme, so update it.
arch/sandbox/cpu/spl.c | 2 +- common/spl/spl.c | 2 +- doc/device-tree-bindings/bootph.yaml | 2 +- include/spl.h | 12 ++++++------ 4 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 1c33a520c64..6c6f4fd8c3e 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -91,7 +91,7 @@ static int load_from_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { struct sandbox_state *state = state_get_current(); - enum u_boot_phase next_phase; + enum xpl_phase_t next_phase; const char *fname; ulong pos, size; int full_size; diff --git a/common/spl/spl.c b/common/spl/spl.c index 674ab35ede0..81b3501ebaf 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -441,7 +441,7 @@ static inline int write_spl_handoff(void) { return 0; } */ static enum bootstage_id get_bootstage_id(bool start) { - enum u_boot_phase phase = spl_phase(); + enum xpl_phase_t phase = spl_phase();
if (IS_ENABLED(CONFIG_TPL_BUILD) && phase == PHASE_TPL) return start ? BOOTSTAGE_ID_START_TPL : BOOTSTAGE_ID_END_TPL; diff --git a/doc/device-tree-bindings/bootph.yaml b/doc/device-tree-bindings/bootph.yaml index a3ccf06efa7..a364b3fe37f 100644 --- a/doc/device-tree-bindings/bootph.yaml +++ b/doc/device-tree-bindings/bootph.yaml @@ -83,6 +83,6 @@ properties: bootph-all: type: boolean description: - Include this node in all phases (for U-Boot see enum u_boot_phase). + Include this node in all phases (for U-Boot see enum xpl_phase_t).
additionalProperties: true diff --git a/include/spl.h b/include/spl.h index c313c57f1aa..31f01cb5cce 100644 --- a/include/spl.h +++ b/include/spl.h @@ -62,7 +62,7 @@ static inline bool xpl_is_first_phase(void) return false; }
-enum u_boot_phase { +enum xpl_phase_t { PHASE_NONE, /* Invalid phase, signifying before U-Boot */ PHASE_TPL, /* Running in TPL */ PHASE_VPL, /* Running in VPL */ @@ -116,7 +116,7 @@ enum u_boot_phase { * * Return: U-Boot phase */ -static inline enum u_boot_phase spl_phase(void) +static inline enum xpl_phase_t spl_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_TPL; @@ -150,7 +150,7 @@ static inline bool spl_in_proper(void) * Return: the previous phase from this one, e.g. if called in SPL this returns * PHASE_TPL, if TPL is enabled */ -static inline enum u_boot_phase spl_prev_phase(void) +static inline enum xpl_phase_t spl_prev_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_NONE; @@ -172,7 +172,7 @@ static inline enum u_boot_phase spl_prev_phase(void) * Return: the next phase from this one, e.g. if called in TPL this returns * PHASE_SPL */ -static inline enum u_boot_phase spl_next_phase(void) +static inline enum xpl_phase_t spl_next_phase(void) { #ifdef CONFIG_TPL_BUILD return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : PHASE_SPL; @@ -188,7 +188,7 @@ static inline enum u_boot_phase spl_next_phase(void) * * Return: phase name */ -static inline const char *spl_phase_name(enum u_boot_phase phase) +static inline const char *spl_phase_name(enum xpl_phase_t phase) { switch (phase) { case PHASE_TPL: @@ -211,7 +211,7 @@ static inline const char *spl_phase_name(enum u_boot_phase phase) * @phase: Phase to look up * Return: phase prefix ("spl", "tpl", etc.) */ -static inline const char *spl_phase_prefix(enum u_boot_phase phase) +static inline const char *spl_phase_prefix(enum xpl_phase_t phase) { switch (phase) { case PHASE_TPL:
Rename this function to indicate that it refers to any xPL phase.
README | 6 +++--- arch/sandbox/cpu/spl.c | 2 +- arch/sandbox/cpu/start.c | 2 +- arch/x86/cpu/apollolake/cpu_spl.c | 4 ++-- arch/x86/cpu/apollolake/hostbridge.c | 2 +- arch/x86/cpu/apollolake/lpc.c | 2 +- arch/x86/cpu/apollolake/pch.c | 2 +- arch/x86/cpu/apollolake/pmc.c | 4 ++-- arch/x86/cpu/apollolake/punit.c | 2 +- arch/x86/cpu/apollolake/spl.c | 2 +- arch/x86/cpu/broadwell/cpu.c | 2 +- arch/x86/cpu/i386/cpu.c | 2 +- arch/x86/cpu/intel_common/mrc.c | 2 +- arch/x86/cpu/intel_common/p2sb.c | 6 +++--- arch/x86/lib/fsp2/fsp_dram.c | 2 +- arch/x86/lib/fsp2/fsp_init.c | 4 ++-- boot/fdt_simplefb.c | 2 +- boot/vbe_simple_fw.c | 4 ++-- common/board_f.c | 2 +- common/bootstage.c | 2 +- common/spl/spl.c | 6 +++--- doc/develop/spl.rst | 4 ++-- drivers/i2c/designware_i2c_pci.c | 4 ++-- drivers/misc/p2sb-uclass.c | 2 +- drivers/pci/pci-uclass.c | 4 ++-- drivers/pci/pci_rom.c | 4 ++-- drivers/pinctrl/intel/pinctrl.c | 6 +++--- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/spi/ich.c | 4 ++-- drivers/sysreset/sysreset-uclass.c | 2 +- drivers/video/console_truetype.c | 6 +++--- drivers/video/video-uclass.c | 6 +++--- include/spl.h | 10 +++++----- lib/fdtdec.c | 2 +- lib/lmb.c | 4 ++-- lib/time.c | 2 +- 37 files changed, 63 insertions(+), 63 deletions(-)
diff --git a/README b/README index a88e14a0449..54ffbd0975b 100644 --- a/README +++ b/README @@ -1512,7 +1512,7 @@ Low Level (hardware related) configuration options: Set when the currently running compilation is for an artifact that will end up in one of the 'xPL' builds, i.e. SPL, TPL or VPL. Code that needs phase-specific behaviour can check this, - or (where possible) use spl_phase() instead. + or (where possible) use xpl_phase() instead.
Note that CONFIG_XPL_BUILD *is* always defined when either of CONFIG_TPL_BUILD / CONFIG_VPL_BUILD is defined. This can be @@ -1522,13 +1522,13 @@ Low Level (hardware related) configuration options: Set when the currently running compilation is for an artifact that will end up in the TPL build (as opposed to SPL, VPL or U-Boot proper). Code that needs phase-specific behaviour can - check this, or (where possible) use spl_phase() instead. + check this, or (where possible) use xpl_phase() instead.
- CONFIG_VPL_BUILD Set when the currently running compilation is for an artifact that will end up in the VPL build (as opposed to the SPL, TPL or U-Boot proper). Code that needs phase-specific behaviour can - check this, or (where possible) use spl_phase() instead. + check this, or (where possible) use xpl_phase() instead.
- CONFIG_ARCH_MAP_SYSMEM Generally U-Boot (and in particular the md command) uses diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 6c6f4fd8c3e..7497d90fb89 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -27,7 +27,7 @@ int sandbox_find_next_phase(char *fname, int maxlen, bool use_img) const char *cur_prefix, *next_prefix; int ret;
- cur_prefix = spl_phase_prefix(spl_phase()); + cur_prefix = spl_phase_prefix(xpl_phase()); next_prefix = spl_phase_prefix(spl_next_phase()); ret = os_find_u_boot(fname, maxlen, use_img, cur_prefix, next_prefix); if (ret) diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index ef587ef48b0..81752edc9f8 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -206,7 +206,7 @@ static int sandbox_cmdline_cb_test_fdt(struct sandbox_state *state, char *relname; int len;
- if (spl_phase() <= PHASE_SPL) + if (xpl_phase() <= PHASE_SPL) relname = "../arch/sandbox/dts/test.dtb"; else relname = "arch/sandbox/dts/test.dtb"; diff --git a/arch/x86/cpu/apollolake/cpu_spl.c b/arch/x86/cpu/apollolake/cpu_spl.c index 8798fa79d4c..8198667fa50 100644 --- a/arch/x86/cpu/apollolake/cpu_spl.c +++ b/arch/x86/cpu/apollolake/cpu_spl.c @@ -184,9 +184,9 @@ int arch_cpu_init(void) { int ret = 0;
- if (spl_phase() == PHASE_TPL) + if (xpl_phase() == PHASE_TPL) ret = arch_cpu_init_tpl(); - else if (spl_phase() == PHASE_SPL) + else if (xpl_phase() == PHASE_SPL) ret = arch_cpu_init_spl(); if (ret) printf("%s: Error %d\n", __func__, ret); diff --git a/arch/x86/cpu/apollolake/hostbridge.c b/arch/x86/cpu/apollolake/hostbridge.c index 9ee362239ef..039236df02d 100644 --- a/arch/x86/cpu/apollolake/hostbridge.c +++ b/arch/x86/cpu/apollolake/hostbridge.c @@ -255,7 +255,7 @@ static int apl_hostbridge_of_to_plat(struct udevice *dev)
static int apl_hostbridge_probe(struct udevice *dev) { - if (spl_phase() == PHASE_TPL) + if (xpl_phase() == PHASE_TPL) return apl_hostbridge_early_init(dev);
return 0; diff --git a/arch/x86/cpu/apollolake/lpc.c b/arch/x86/cpu/apollolake/lpc.c index 531ff1cd91f..f34c199bf73 100644 --- a/arch/x86/cpu/apollolake/lpc.c +++ b/arch/x86/cpu/apollolake/lpc.c @@ -80,7 +80,7 @@ int lpc_open_pmio_window(uint base, uint size)
lgir_reg_num = find_unused_pmio_window(); if (lgir_reg_num < 0) { - if (spl_phase() > PHASE_TPL) { + if (xpl_phase() > PHASE_TPL) { log_err("LPC: Cannot open IO window: %lx size %lx\n", bridge_base, size - bridged_size); log_err("No more IO windows\n"); diff --git a/arch/x86/cpu/apollolake/pch.c b/arch/x86/cpu/apollolake/pch.c index 32190312ff8..07ef26f6bde 100644 --- a/arch/x86/cpu/apollolake/pch.c +++ b/arch/x86/cpu/apollolake/pch.c @@ -12,7 +12,7 @@
static int apl_set_spi_protect(struct udevice *dev, bool protect) { - if (spl_phase() == PHASE_SPL) + if (xpl_phase() == PHASE_SPL) return lpc_set_spi_protect(dev, BIOS_CTRL, protect);
return 0; diff --git a/arch/x86/cpu/apollolake/pmc.c b/arch/x86/cpu/apollolake/pmc.c index 32fd0344861..bfb8a07d47a 100644 --- a/arch/x86/cpu/apollolake/pmc.c +++ b/arch/x86/cpu/apollolake/pmc.c @@ -115,7 +115,7 @@ int apl_pmc_ofdata_to_uc_plat(struct udevice *dev) ARRAY_SIZE(base)); if (ret) return log_msg_ret("Missing/short early-regs", ret); - if (spl_phase() == PHASE_TPL) { + if (xpl_phase() == PHASE_TPL) { upriv->pmc_bar0 = (void *)base[0]; upriv->pmc_bar2 = (void *)base[2];
@@ -186,7 +186,7 @@ static int enable_pmcbar(struct udevice *dev)
static int apl_pmc_probe(struct udevice *dev) { - if (spl_phase() == PHASE_TPL) { + if (xpl_phase() == PHASE_TPL) { return enable_pmcbar(dev); } else { struct acpi_pmc_upriv *upriv = dev_get_uclass_priv(dev); diff --git a/arch/x86/cpu/apollolake/punit.c b/arch/x86/cpu/apollolake/punit.c index b1503c25140..9c708e9df55 100644 --- a/arch/x86/cpu/apollolake/punit.c +++ b/arch/x86/cpu/apollolake/punit.c @@ -77,7 +77,7 @@ static int punit_init(struct udevice *dev)
static int apl_punit_probe(struct udevice *dev) { - if (spl_phase() == PHASE_SPL) + if (xpl_phase() == PHASE_SPL) return punit_init(dev);
return 0; diff --git a/arch/x86/cpu/apollolake/spl.c b/arch/x86/cpu/apollolake/spl.c index b351d73e7d8..510f8c4350f 100644 --- a/arch/x86/cpu/apollolake/spl.c +++ b/arch/x86/cpu/apollolake/spl.c @@ -116,7 +116,7 @@ static int spl_fast_spi_load_image(struct spl_image_info *spl_image, return ret;
spl_image->size = CONFIG_SYS_MONITOR_LEN; /* We don't know SPL size */ - spl_image->entry_point = spl_phase() == PHASE_TPL ? + spl_image->entry_point = xpl_phase() == PHASE_TPL ? CONFIG_SPL_TEXT_BASE : CONFIG_TEXT_BASE; spl_image->load_addr = spl_image->entry_point; spl_image->os = IH_OS_U_BOOT; diff --git a/arch/x86/cpu/broadwell/cpu.c b/arch/x86/cpu/broadwell/cpu.c index dc6717eca40..87463748c4d 100644 --- a/arch/x86/cpu/broadwell/cpu.c +++ b/arch/x86/cpu/broadwell/cpu.c @@ -68,7 +68,7 @@ int arch_cpu_init(void) post_code(POST_CPU_INIT);
/* Do a mini-init if TPL has already done the full init */ - if (IS_ENABLED(CONFIG_TPL) && spl_phase() != PHASE_TPL) + if (IS_ENABLED(CONFIG_TPL) && xpl_phase() != PHASE_TPL) return x86_cpu_reinit_f(); else return x86_cpu_init_f(); diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index 934e98ac582..d837fb97982 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -271,7 +271,7 @@ static void identify_cpu(struct cpu_device_id *cpu) * Do a quick and dirty check to save space - Intel and AMD only and * just the vendor. This is enough for most TPL code. */ - if (spl_phase() == PHASE_TPL) { + if (xpl_phase() == PHASE_TPL) { struct cpuid_result result;
result = cpuid(0x00000000); diff --git a/arch/x86/cpu/intel_common/mrc.c b/arch/x86/cpu/intel_common/mrc.c index c834c05d130..baa1f0e32d6 100644 --- a/arch/x86/cpu/intel_common/mrc.c +++ b/arch/x86/cpu/intel_common/mrc.c @@ -259,7 +259,7 @@ int mrc_common_init(struct udevice *dev, void *pei_data, bool use_asm_linkage) return ret;
delay = dev_read_u32_default(dev, "fspm,training-delay", 0); - if (spl_phase() == PHASE_SPL) { + if (xpl_phase() == PHASE_SPL) { if (delay) printf("SDRAM training (%d seconds)...", delay); else diff --git a/arch/x86/cpu/intel_common/p2sb.c b/arch/x86/cpu/intel_common/p2sb.c index 7aad8f8ca56..406c41013fc 100644 --- a/arch/x86/cpu/intel_common/p2sb.c +++ b/arch/x86/cpu/intel_common/p2sb.c @@ -96,7 +96,7 @@ int p2sb_of_to_plat(struct udevice *dev) return log_msg_ret("Missing/short early-regs", ret); plat->mmio_base = base[0]; /* TPL sets up the initial BAR */ - if (spl_phase() == PHASE_TPL) { + if (xpl_phase() == PHASE_TPL) { plat->bdf = pci_get_devfn(dev); if (plat->bdf < 0) return log_msg_ret("Cannot get p2sb PCI address", @@ -114,9 +114,9 @@ int p2sb_of_to_plat(struct udevice *dev)
static int p2sb_probe(struct udevice *dev) { - if (spl_phase() == PHASE_TPL) + if (xpl_phase() == PHASE_TPL) return p2sb_early_init(dev); - else if (spl_phase() == PHASE_SPL) + else if (xpl_phase() == PHASE_SPL) return p2sb_spl_init(dev);
return 0; diff --git a/arch/x86/lib/fsp2/fsp_dram.c b/arch/x86/lib/fsp2/fsp_dram.c index a50dc985a3c..4c4c8334bdb 100644 --- a/arch/x86/lib/fsp2/fsp_dram.c +++ b/arch/x86/lib/fsp2/fsp_dram.c @@ -28,7 +28,7 @@ int dram_init(void)
return 0; } - if (spl_phase() == PHASE_SPL) { + if (xpl_phase() == PHASE_SPL) { bool s3wake = false;
s3wake = IS_ENABLED(CONFIG_HAVE_ACPI_RESUME) && diff --git a/arch/x86/lib/fsp2/fsp_init.c b/arch/x86/lib/fsp2/fsp_init.c index ecbadaae75c..1a2bf46c5c5 100644 --- a/arch/x86/lib/fsp2/fsp_init.c +++ b/arch/x86/lib/fsp2/fsp_init.c @@ -25,7 +25,7 @@ int fsp_setup_pinctrl(void) int ret;
/* Make sure pads are set up early in U-Boot */ - if (!ll_boot_init() || spl_phase() != PHASE_BOARD_F) + if (!ll_boot_init() || xpl_phase() != PHASE_BOARD_F) return 0;
/* Probe all pinctrl devices to set up the pads */ @@ -134,7 +134,7 @@ int fsp_locate_fsp(enum fsp_type_t type, struct binman_entry *entry, return log_msg_ret("Could not get flash mmap", ret); }
- if (spl_phase() >= PHASE_BOARD_F) { + if (xpl_phase() >= PHASE_BOARD_F) { if (type != FSP_S) return -EPROTONOSUPPORT; ret = binman_entry_find("intel-fsp-s", entry); diff --git a/boot/fdt_simplefb.c b/boot/fdt_simplefb.c index 53415548459..71b833eb9bd 100644 --- a/boot/fdt_simplefb.c +++ b/boot/fdt_simplefb.c @@ -27,7 +27,7 @@ static int fdt_simplefb_configure_node(void *blob, int off) struct udevice *dev; int ret;
- if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && spl_phase() > PHASE_SPL) { + if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && xpl_phase() > PHASE_SPL) { struct video_handoff *ho;
ho = bloblist_find(BLOBLISTT_U_BOOT_VIDEO, sizeof(*ho)); diff --git a/boot/vbe_simple_fw.c b/boot/vbe_simple_fw.c index 4d6da9490a7..da9701f9eb9 100644 --- a/boot/vbe_simple_fw.c +++ b/boot/vbe_simple_fw.c @@ -157,7 +157,7 @@ static int simple_load_from_image(struct spl_image_info *spl_image, struct vbe_handoff *handoff; int ret;
- if (spl_phase() != PHASE_VPL && spl_phase() != PHASE_SPL) + if (xpl_phase() != PHASE_VPL && xpl_phase() != PHASE_SPL) return -ENOENT;
ret = bloblist_ensure_size(BLOBLISTT_VBE, sizeof(struct vbe_handoff), @@ -197,7 +197,7 @@ static int simple_load_from_image(struct spl_image_info *spl_image, bootflow_free(&bflow);
/* Record that VBE was used in this phase */ - handoff->phases |= 1 << spl_phase(); + handoff->phases |= 1 << xpl_phase();
return 0; } diff --git a/common/board_f.c b/common/board_f.c index 154675d0e40..f1bd70fdd6c 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -397,7 +397,7 @@ __weak int arch_reserve_mmu(void)
static int reserve_video_from_videoblob(void) { - if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && spl_phase() > PHASE_SPL) { + if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && xpl_phase() > PHASE_SPL) { struct video_handoff *ho; int ret = 0;
diff --git a/common/bootstage.c b/common/bootstage.c index 72d80ee9fe5..dd6aed7c2fd 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -489,7 +489,7 @@ int bootstage_unstash(const void *base, int size) for (rec = data->record + data->next_id, i = 0; i < hdr->count; i++, rec++) { rec->name = ptr; - if (spl_phase() == PHASE_SPL) + if (xpl_phase() == PHASE_SPL) rec->name = strdup(ptr);
/* Assume no data corruption here */ diff --git a/common/spl/spl.c b/common/spl/spl.c index 81b3501ebaf..a0de495e529 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -441,7 +441,7 @@ static inline int write_spl_handoff(void) { return 0; } */ static enum bootstage_id get_bootstage_id(bool start) { - enum xpl_phase_t phase = spl_phase(); + enum xpl_phase_t phase = xpl_phase();
if (IS_ENABLED(CONFIG_TPL_BUILD) && phase == PHASE_TPL) return start ? BOOTSTAGE_ID_START_TPL : BOOTSTAGE_ID_END_TPL; @@ -476,7 +476,7 @@ static int spl_common_init(bool setup_malloc) log_debug("Failed to unstash bootstage: ret=%d\n", ret); } bootstage_mark_name(get_bootstage_id(true), - spl_phase_name(spl_phase())); + spl_phase_name(xpl_phase())); #if CONFIG_IS_ENABLED(LOG) ret = log_init(); if (ret) { @@ -493,7 +493,7 @@ static int spl_common_init(bool setup_malloc) } if (CONFIG_IS_ENABLED(DM)) { bootstage_start(BOOTSTAGE_ID_ACCUM_DM_SPL, - spl_phase() == PHASE_TPL ? "dm tpl" : "dm_spl"); + xpl_phase() == PHASE_TPL ? "dm tpl" : "dm_spl"); /* With CONFIG_SPL_OF_PLATDATA, bring in all devices */ ret = dm_init_and_scan(!CONFIG_IS_ENABLED(OF_PLATDATA)); bootstage_accum(BOOTSTAGE_ID_ACCUM_DM_SPL); diff --git a/doc/develop/spl.rst b/doc/develop/spl.rst index fba4a439d3a..aa6d28fa333 100644 --- a/doc/develop/spl.rst +++ b/doc/develop/spl.rst @@ -35,7 +35,7 @@ For example:: if (IS_ENABLED(CONFIG_XPL_BUILD)) foo();
- if (spl_phase() == PHASE_TPL) + if (xpl_phase() == PHASE_TPL) bar();
The building of xPL images can be enabled by CONFIG_SPL (etc.) options in @@ -121,7 +121,7 @@ Further usages of U-Boot SPL comprise: Checking the boot phase -----------------------
-Use `spl_phase()` to find the current U-Boot phase, e.g. `PHASE_SPL`. You can +Use `xpl_phase()` to find the current U-Boot phase, e.g. `PHASE_SPL`. You can also find the previous and next phase and get the phase name.
diff --git a/drivers/i2c/designware_i2c_pci.c b/drivers/i2c/designware_i2c_pci.c index 11c98672265..c21c412231c 100644 --- a/drivers/i2c/designware_i2c_pci.c +++ b/drivers/i2c/designware_i2c_pci.c @@ -37,7 +37,7 @@ static int designware_i2c_pci_of_to_plat(struct udevice *dev) { struct dw_i2c *priv = dev_get_priv(dev);
- if (spl_phase() < PHASE_SPL) { + if (xpl_phase() < PHASE_SPL) { u32 base; int ret;
@@ -53,7 +53,7 @@ static int designware_i2c_pci_of_to_plat(struct udevice *dev) PCI_COMMAND_MASTER); }
- if (spl_phase() < PHASE_BOARD_F) { + if (xpl_phase() < PHASE_BOARD_F) { /* Handle early, fixed mapping into a different address space */ priv->regs = (struct i2c_regs *)dm_pci_read_bar32(dev, 0); } else { diff --git a/drivers/misc/p2sb-uclass.c b/drivers/misc/p2sb-uclass.c index 016c8073378..d7ce0383ac9 100644 --- a/drivers/misc/p2sb-uclass.c +++ b/drivers/misc/p2sb-uclass.c @@ -198,7 +198,7 @@ static int p2sb_child_post_bind(struct udevice *dev)
static int p2sb_post_bind(struct udevice *dev) { - if (spl_phase() > PHASE_TPL && !CONFIG_IS_ENABLED(OF_PLATDATA)) + if (xpl_phase() > PHASE_TPL && !CONFIG_IS_ENABLED(OF_PLATDATA)) return dm_scan_fdt_dev(dev);
return 0; diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 6571e653049..59894d2430b 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -722,7 +722,7 @@ static bool pci_need_device_pre_reloc(struct udevice *bus, uint vendor, u32 vendev; int index;
- if (spl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(PCI_PNP)) + if (xpl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(PCI_PNP)) return true;
for (index = 0; @@ -798,7 +798,7 @@ static int pci_find_and_bind_driver(struct udevice *parent, if (!(gd->flags & GD_FLG_RELOC) && !(drv->flags & DM_FLAG_PRE_RELOC) && (!CONFIG_IS_ENABLED(PCI_PNP) || - spl_phase() != PHASE_SPL)) + xpl_phase() != PHASE_SPL)) return log_msg_ret("pre", -EPERM);
/* diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 78e5de937cd..2753df275ca 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -379,7 +379,7 @@ int vesa_setup_video(struct udevice *dev, int (*int15_handler)(void)) }
/* In U-Boot proper, collect the information added by SPL (see below) */ - if (IS_ENABLED(CONFIG_SPL_VIDEO) && spl_phase() > PHASE_SPL && + if (IS_ENABLED(CONFIG_SPL_VIDEO) && xpl_phase() > PHASE_SPL && CONFIG_IS_ENABLED(BLOBLIST)) { struct video_handoff *ho;
@@ -425,7 +425,7 @@ int vesa_setup_video(struct udevice *dev, int (*int15_handler)(void)) mode_info.vesa.bits_per_pixel);
/* In SPL, store the information for use by U-Boot proper */ - if (spl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(BLOBLIST)) { + if (xpl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(BLOBLIST)) { struct video_handoff *ho;
ho = bloblist_add(BLOBLISTT_U_BOOT_VIDEO, sizeof(*ho), 0); diff --git a/drivers/pinctrl/intel/pinctrl.c b/drivers/pinctrl/intel/pinctrl.c index 6cfe83a593a..19525f82a22 100644 --- a/drivers/pinctrl/intel/pinctrl.c +++ b/drivers/pinctrl/intel/pinctrl.c @@ -273,7 +273,7 @@ static int pinctrl_configure_itss(struct udevice *dev, irq = pcr_read32(dev, PAD_CFG1_OFFSET(pad_cfg_offset)); irq &= PAD_CFG1_IRQ_MASK; if (!irq) { - if (spl_phase() > PHASE_TPL) + if (xpl_phase() > PHASE_TPL) log_err("GPIO %u doesn't support APIC routing\n", cfg->pad);
@@ -315,7 +315,7 @@ static int pinctrl_pad_reset_config_override(const struct pad_community *comm, return config_value; } } - if (spl_phase() > PHASE_TPL) + if (xpl_phase() > PHASE_TPL) log_err("Logical-to-Chipset mapping not found\n");
return -ENOENT; @@ -622,7 +622,7 @@ int intel_pinctrl_of_to_plat(struct udevice *dev, struct intel_pinctrl_priv *priv = dev_get_priv(dev);
if (!comm) { - if (spl_phase() > PHASE_TPL) + if (xpl_phase() > PHASE_TPL) log_err("Cannot find community for pid %d\n", pplat->pid); return -EDOM; diff --git a/drivers/power/acpi_pmc/acpi-pmc-uclass.c b/drivers/power/acpi_pmc/acpi-pmc-uclass.c index c289cede15b..1e94104091e 100644 --- a/drivers/power/acpi_pmc/acpi-pmc-uclass.c +++ b/drivers/power/acpi_pmc/acpi-pmc-uclass.c @@ -60,7 +60,7 @@ int pmc_gpe_init(struct udevice *dev) * are different and if they aren't, use the reset values. */ if (dw[0] == dw[1] || dw[1] == dw[2]) { - if (spl_phase() > PHASE_TPL) + if (xpl_phase() > PHASE_TPL) log_info("PMC: Using default GPE route"); gpio_cfg = readl(upriv->gpe_cfg); for (i = 0; i < upriv->gpe0_count; i++) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 45270e27184..7f8a6ba8410 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -193,7 +193,7 @@ struct io_setting { */ static bool phase_sdram_init(void) { - return spl_phase() == PHASE_TPL || + return xpl_phase() == PHASE_TPL || (!IS_ENABLED(CONFIG_TPL) && !IS_ENABLED(CONFIG_ROCKCHIP_EXTERNAL_TPL) && !spl_in_proper()); diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index e48ca65fe72..2264ca83d66 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -779,7 +779,7 @@ static int ich_init_controller(struct udevice *dev, struct ich_spi_plat *plat, struct ich_spi_priv *ctlr) { - if (spl_phase() == PHASE_TPL) { + if (xpl_phase() == PHASE_TPL) { struct ich_spi_plat *plat = dev_get_plat(dev); int ret;
@@ -867,7 +867,7 @@ static int ich_spi_probe(struct udevice *dev) if (ret) return ret;
- if (spl_phase() == PHASE_TPL) { + if (xpl_phase() == PHASE_TPL) { /* Cache the BIOS to speed things up */ ret = ich_cache_bios_region(dev); if (ret) diff --git a/drivers/sysreset/sysreset-uclass.c b/drivers/sysreset/sysreset-uclass.c index d30b008bf9a..536ac727142 100644 --- a/drivers/sysreset/sysreset-uclass.c +++ b/drivers/sysreset/sysreset-uclass.c @@ -102,7 +102,7 @@ void sysreset_walk_halt(enum sysreset_t type) mdelay(100);
/* Still no reset? Give up */ - if (spl_phase() <= PHASE_SPL) + if (xpl_phase() <= PHASE_SPL) log_err("no sysreset\n"); else log_err("System reset not supported on this platform\n"); diff --git a/drivers/video/console_truetype.c b/drivers/video/console_truetype.c index c435162d3f9..17a29817664 100644 --- a/drivers/video/console_truetype.c +++ b/drivers/video/console_truetype.c @@ -802,7 +802,7 @@ static int truetype_entry_save(struct udevice *dev, struct abuf *buf) struct console_tt_store store; const uint size = sizeof(store);
- if (spl_phase() <= PHASE_SPL) + if (xpl_phase() <= PHASE_SPL) return -ENOSYS;
/* @@ -826,7 +826,7 @@ static int truetype_entry_restore(struct udevice *dev, struct abuf *buf) struct console_tt_priv *priv = dev_get_priv(dev); struct console_tt_store store;
memcpy(&store, abuf_data(buf), sizeof(store)); @@ -853,7 +853,7 @@ static int truetype_set_cursor_visible(struct udevice *dev, bool visible, uint out, val; int ret;
if (!visible) diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 41bb7647fda..9823673f817 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -128,7 +128,7 @@ int video_reserve(ulong *addrp) struct udevice *dev; ulong size;
- if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && spl_phase() == PHASE_BOARD_F) + if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && xpl_phase() == PHASE_BOARD_F) return 0;
gd->video_top = *addrp; @@ -421,7 +421,7 @@ bool video_is_active(void) struct udevice *dev;
/* Assume video to be active if SPL passed video hand-off to U-boot */ - if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && spl_phase() > PHASE_SPL) + if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && xpl_phase() > PHASE_SPL) return true;
for (uclass_find_first_device(UCLASS_VIDEO, &dev); @@ -573,7 +573,7 @@ static int video_post_probe(struct udevice *dev) * NOTE: * This assumes that reserved video memory only uses a single framebuffer */ - if (spl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(BLOBLIST)) { + if (xpl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(BLOBLIST)) { struct video_handoff *ho;
ho = bloblist_add(BLOBLISTT_U_BOOT_VIDEO, sizeof(*ho), 0); diff --git a/include/spl.h b/include/spl.h index 31f01cb5cce..09472f7f9bc 100644 --- a/include/spl.h +++ b/include/spl.h @@ -74,7 +74,7 @@ enum xpl_phase_t { };
/** - * spl_phase() - Find out the phase of U-Boot + * xpl_phase() - Find out the phase of U-Boot * * This can be used to avoid #ifdef logic and use if() instead. * @@ -86,7 +86,7 @@ enum xpl_phase_t { * * but with this you can use: * - * if (spl_phase() == PHASE_TPL) { + * if (xpl_phase() == PHASE_TPL) { * ... * } * @@ -98,7 +98,7 @@ enum xpl_phase_t { * * but with this you can use: * - * if (spl_phase() == PHASE_SPL) { + * if (xpl_phase() == PHASE_SPL) { * ... * } * @@ -110,13 +110,13 @@ enum xpl_phase_t { * * but with this you can use: * - * if (spl_phase() == PHASE_BOARD_F) { + * if (xpl_phase() == PHASE_BOARD_F) { * ... * } * * Return: U-Boot phase */ -static inline enum xpl_phase_t spl_phase(void) +static inline enum xpl_phase_t xpl_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_TPL; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 4199379c872..cdc2edbd61e 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -608,7 +608,7 @@ int fdtdec_get_chosen_node(const void *blob, const char *name) static int fdtdec_prepare_fdt(const void *blob) { if (!blob || ((uintptr_t)blob & 3) || fdt_check_header(blob)) { - if (spl_phase() <= PHASE_SPL) { + if (xpl_phase() <= PHASE_SPL) { puts("Missing DTB\n"); } else { printf("No valid device tree binary found at %p\n", diff --git a/lib/lmb.c b/lib/lmb.c index 3ed570fb29b..380d92a6718 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -749,9 +749,9 @@ int lmb_init(void) lmb_add_memory();
/* Reserve the U-Boot image region once U-Boot has relocated */ - if (spl_phase() == PHASE_SPL) + if (xpl_phase() == PHASE_SPL) lmb_reserve_common_spl(); - else if (spl_phase() == PHASE_BOARD_R) + else if (xpl_phase() == PHASE_BOARD_R) lmb_reserve_common((void *)gd->fdt_blob);
return 0; diff --git a/lib/time.c b/lib/time.c index 872f73d521e..d88edafb196 100644 --- a/lib/time.c +++ b/lib/time.c @@ -100,7 +100,7 @@ uint64_t notrace get_ticks(void)
ret = timer_get_count(gd->timer, &count); if (ret) { - if (spl_phase() > PHASE_TPL) + if (xpl_phase() > PHASE_TPL) panic("Could not read count from timer (err %d)\n", ret); else
Give this function a slightly easier name.
drivers/mtd/nand/raw/sand_nand.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/serial/ns16550.c | 4 ++-- include/spl.h | 4 ++-- 4 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/nand/raw/sand_nand.c b/drivers/mtd/nand/raw/sand_nand.c index 53489223030..3678bb8a41b 100644 --- a/drivers/mtd/nand/raw/sand_nand.c +++ b/drivers/mtd/nand/raw/sand_nand.c @@ -601,7 +601,7 @@ static int sand_nand_probe(struct udevice *dev) }
nand = &chip->nand; - nand->options = spl_in_proper() ? 0 : NAND_SKIP_BBTSCAN; + nand->options = not_xpl() ? 0 : NAND_SKIP_BBTSCAN; nand->flash_node = np; nand->dev_ready = sand_nand_dev_ready; nand->cmdfunc = sand_nand_command; diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 7f8a6ba8410..5676c099a43 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -196,7 +196,7 @@ static bool phase_sdram_init(void) return xpl_phase() == PHASE_TPL || (!IS_ENABLED(CONFIG_TPL) && !IS_ENABLED(CONFIG_ROCKCHIP_EXTERNAL_TPL) && - !spl_in_proper()); + !not_xpl()); }
static struct io_setting * diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 248fe3f778f..3489228127e 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -473,7 +473,7 @@ static int ns16550_serial_getinfo(struct udevice *dev, struct ns16550_plat *plat = com_port->plat;
/* save code size */ - if (!spl_in_proper()) + if (!not_xpl()) return -ENOSYS;
info->type = SERIAL_CHIP_16550_COMPATIBLE; @@ -555,7 +555,7 @@ int ns16550_serial_of_to_plat(struct udevice *dev) struct clk clk; int err;
- addr = spl_in_proper() ? dev_read_addr_size(dev, &size) : + addr = not_xpl() ? dev_read_addr_size(dev, &size) : dev_read_addr(dev); err = ns16550_serial_assign_base(plat, addr, size); if (err && !device_is_on_pci_bus(dev)) diff --git a/include/spl.h b/include/spl.h index 09472f7f9bc..bea4d78f8c6 100644 --- a/include/spl.h +++ b/include/spl.h @@ -134,8 +134,8 @@ static inline enum xpl_phase_t xpl_phase(void) #endif }
-/* returns true if in U-Boot proper, false if in SPL */ -static inline bool spl_in_proper(void) +/* returns true if in U-Boot proper, false if in xPL */ +static inline bool not_xpl(void) { #ifdef CONFIG_XPL_BUILD return false;
Add the opposite function to not_xpl() for completeness.
include/spl.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/spl.h b/include/spl.h index bea4d78f8c6..3281b02d63b 100644 --- a/include/spl.h +++ b/include/spl.h @@ -144,6 +144,16 @@ static inline bool not_xpl(void) return true; }
+/* returns true if in xPL, false if in U-Boot proper */ +static inline bool is_xpl(void) +{ +#ifdef CONFIG_XPL_BUILD + return true; +#endif + + return false; +} + /** * spl_prev_phase() - Figure out the previous U-Boot phase *
Rename this to use the xpl prefix.
arch/sandbox/cpu/spl.c | 4 ++-- arch/x86/lib/tpl.c | 2 +- common/bloblist.c | 2 +- common/spl/spl.c | 14 +++++++------- include/spl.h | 8 ++++---- lib/fdtdec.c | 2 +- 6 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 7497d90fb89..71d785f4c3e 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -28,7 +28,7 @@ int sandbox_find_next_phase(char *fname, int maxlen, bool use_img) int ret;
cur_prefix = spl_phase_prefix(xpl_phase()); - next_prefix = spl_phase_prefix(spl_next_phase()); + next_prefix = spl_phase_prefix(xpl_next_phase()); ret = os_find_u_boot(fname, maxlen, use_img, cur_prefix, next_prefix); if (ret) return log_msg_ret("find", ret); @@ -101,7 +101,7 @@ static int load_from_image(struct spl_image_info *spl_image, if (!IS_ENABLED(CONFIG_SANDBOX_VPL)) return -ENOENT;
- next_phase = spl_next_phase(); + next_phase = xpl_next_phase(); pos = spl_get_image_pos(); size = spl_get_image_size(); if (pos == BINMAN_SYM_MISSING || size == BINMAN_SYM_MISSING) { diff --git a/arch/x86/lib/tpl.c b/arch/x86/lib/tpl.c index 7c03dea0711..0606b4a1c67 100644 --- a/arch/x86/lib/tpl.c +++ b/arch/x86/lib/tpl.c @@ -103,7 +103,7 @@ int spl_spi_load_image(void)
void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { - debug("Jumping to %s at %lx\n", spl_phase_name(spl_next_phase()), + debug("Jumping to %s at %lx\n", spl_phase_name(xpl_next_phase()), (ulong)spl_image->entry_point); #ifdef DEBUG print_buffer(spl_image->entry_point, (void *)spl_image->entry_point, 1, diff --git a/common/bloblist.c b/common/bloblist.c index fb86789df42..6640ad1fd69 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -512,7 +512,7 @@ int bloblist_init(void) */ bool from_boot_arg = fixed && xpl_is_first_phase();
- if (spl_prev_phase() == PHASE_TPL && !IS_ENABLED(CONFIG_TPL_BLOBLIST)) + if (xpl_prev_phase() == PHASE_TPL && !IS_ENABLED(CONFIG_TPL_BLOBLIST)) from_addr = false; if (fixed) addr = IF_ENABLED_INT(CONFIG_BLOBLIST_FIXED, diff --git a/common/spl/spl.c b/common/spl/spl.c index a0de495e529..a221b64f81d 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -176,10 +176,10 @@ ulong spl_get_image_pos(void) return BINMAN_SYM_MISSING;
#ifdef CONFIG_VPL - if (spl_next_phase() == PHASE_VPL) + if (xpl_next_phase() == PHASE_VPL) return binman_sym(ulong, u_boot_vpl_any, image_pos); #endif - return spl_next_phase() == PHASE_SPL ? + return xpl_next_phase() == PHASE_SPL ? binman_sym(ulong, u_boot_spl_any, image_pos) : binman_sym(ulong, u_boot_any, image_pos); } @@ -190,10 +190,10 @@ ulong spl_get_image_size(void) return BINMAN_SYM_MISSING;
#ifdef CONFIG_VPL - if (spl_next_phase() == PHASE_VPL) + if (xpl_next_phase() == PHASE_VPL) return binman_sym(ulong, u_boot_vpl_any, size); #endif - return spl_next_phase() == PHASE_SPL ? + return xpl_next_phase() == PHASE_SPL ? binman_sym(ulong, u_boot_spl_any, size) : binman_sym(ulong, u_boot_any, size); } @@ -201,10 +201,10 @@ ulong spl_get_image_size(void) ulong spl_get_image_text_base(void) { #ifdef CONFIG_VPL - if (spl_next_phase() == PHASE_VPL) + if (xpl_next_phase() == PHASE_VPL) return CONFIG_VPL_TEXT_BASE; #endif - return spl_next_phase() == PHASE_SPL ? CONFIG_SPL_TEXT_BASE : + return xpl_next_phase() == PHASE_SPL ? CONFIG_SPL_TEXT_BASE : CONFIG_TEXT_BASE; }
@@ -762,7 +762,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
os = spl_image.os; if (os == IH_OS_U_BOOT) { - debug("Jumping to %s...\n", spl_phase_name(spl_next_phase())); + debug("Jumping to %s...\n", spl_phase_name(xpl_next_phase())); } else if (CONFIG_IS_ENABLED(ATF) && os == IH_OS_ARM_TRUSTED_FIRMWARE) { debug("Jumping to U-Boot via ARM Trusted Firmware\n"); spl_fixup_fdt(spl_image_fdt_addr(&spl_image)); diff --git a/include/spl.h b/include/spl.h index 3281b02d63b..dfa56e49c53 100644 --- a/include/spl.h +++ b/include/spl.h @@ -155,12 +155,12 @@ static inline bool is_xpl(void) }
/** - * spl_prev_phase() - Figure out the previous U-Boot phase + * xpl_prev_phase() - Figure out the previous U-Boot phase * * Return: the previous phase from this one, e.g. if called in SPL this returns * PHASE_TPL, if TPL is enabled */ -static inline enum xpl_phase_t spl_prev_phase(void) +static inline enum xpl_phase_t xpl_prev_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_NONE; @@ -177,12 +177,12 @@ static inline enum xpl_phase_t spl_prev_phase(void) }
/** - * spl_next_phase() - Figure out the next U-Boot phase + * xpl_next_phase() - Figure out the next U-Boot phase * * Return: the next phase from this one, e.g. if called in TPL this returns * PHASE_SPL */ -static inline enum xpl_phase_t spl_next_phase(void) +static inline enum xpl_phase_t xpl_next_phase(void) { #ifdef CONFIG_TPL_BUILD return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : PHASE_SPL; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index cdc2edbd61e..b2d38795a48 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1676,7 +1676,7 @@ int fdtdec_setup(void) * not whether this phase creates one. */ if (CONFIG_IS_ENABLED(BLOBLIST) && - (spl_prev_phase() != PHASE_TPL || + (xpl_prev_phase() != PHASE_TPL || !IS_ENABLED(CONFIG_TPL_BLOBLIST))) { ret = bloblist_maybe_init(); if (!ret) {
Use simpler names for these functions.
arch/sandbox/cpu/spl.c | 4 ++-- arch/x86/lib/tpl.c | 2 +- cmd/vbe.c | 2 +- common/spl/spl.c | 5 ++--- include/spl.h | 8 ++++---- 5 files changed, 10 insertions(+), 11 deletions(-)
diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 71d785f4c3e..c50df5f9179 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -27,8 +27,8 @@ int sandbox_find_next_phase(char *fname, int maxlen, bool use_img) const char *cur_prefix, *next_prefix; int ret;
- cur_prefix = spl_phase_prefix(xpl_phase()); - next_prefix = spl_phase_prefix(xpl_next_phase()); + cur_prefix = xpl_prefix(xpl_phase()); + next_prefix = xpl_prefix(xpl_next_phase()); ret = os_find_u_boot(fname, maxlen, use_img, cur_prefix, next_prefix); if (ret) return log_msg_ret("find", ret); diff --git a/arch/x86/lib/tpl.c b/arch/x86/lib/tpl.c index 0606b4a1c67..f7df7e03621 100644 --- a/arch/x86/lib/tpl.c +++ b/arch/x86/lib/tpl.c @@ -103,7 +103,7 @@ int spl_spi_load_image(void)
void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { - debug("Jumping to %s at %lx\n", spl_phase_name(xpl_next_phase()), + debug("Jumping to %s at %lx\n", xpl_name(xpl_next_phase()), (ulong)spl_image->entry_point); #ifdef DEBUG print_buffer(spl_image->entry_point, (void *)spl_image->entry_point, 1, diff --git a/cmd/vbe.c b/cmd/vbe.c index 423d9e5f8f0..186f6e6860d 100644 --- a/cmd/vbe.c +++ b/cmd/vbe.c @@ -93,7 +93,7 @@ static int do_vbe_state(struct cmd_tbl *cmdtp, int flag, int argc, printf("Phases:"); for (i = PHASE_NONE; i < PHASE_COUNT; i++) { if (handoff->phases & (1 << i)) - printf(" %s", spl_phase_name(i)); + printf(" %s", xpl_name(i));
} if (!handoff->phases) diff --git a/common/spl/spl.c b/common/spl/spl.c index a221b64f81d..94657d00591 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -475,8 +475,7 @@ static int spl_common_init(bool setup_malloc) if (ret) log_debug("Failed to unstash bootstage: ret=%d\n", ret); } - bootstage_mark_name(get_bootstage_id(true), - spl_phase_name(xpl_phase())); + bootstage_mark_name(get_bootstage_id(true), xpl_name(xpl_phase())); #if CONFIG_IS_ENABLED(LOG) ret = log_init(); if (ret) { @@ -762,7 +761,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
os = spl_image.os; if (os == IH_OS_U_BOOT) { - debug("Jumping to %s...\n", spl_phase_name(xpl_next_phase())); + debug("Jumping to %s...\n", xpl_name(xpl_next_phase())); } else if (CONFIG_IS_ENABLED(ATF) && os == IH_OS_ARM_TRUSTED_FIRMWARE) { debug("Jumping to U-Boot via ARM Trusted Firmware\n"); spl_fixup_fdt(spl_image_fdt_addr(&spl_image)); diff --git a/include/spl.h b/include/spl.h index dfa56e49c53..0dad8de69cb 100644 --- a/include/spl.h +++ b/include/spl.h @@ -194,11 +194,11 @@ static inline enum xpl_phase_t xpl_next_phase(void) }
/** - * spl_phase_name() - Get the name of the current phase + * xpl_name() - Get the name of a phase * * Return: phase name */ -static inline const char *spl_phase_name(enum xpl_phase_t phase) +static inline const char *xpl_name(enum xpl_phase_t phase) { switch (phase) { case PHASE_TPL: @@ -216,12 +216,12 @@ static inline const char *spl_phase_name(enum xpl_phase_t phase) }
/** - * spl_phase_prefix() - Get the prefix of the current phase + * xpl_prefix() - Get the prefix of the current phase * * @phase: Phase to look up * Return: phase prefix ("spl", "tpl", etc.) */ -static inline const char *spl_phase_prefix(enum xpl_phase_t phase) +static inline const char *xpl_prefix(enum xpl_phase_t phase) { switch (phase) { case PHASE_TPL:
This should not be in the generic README file, so drop it.
README | 10 +--------- 1 file changed, 1 insertion(+), 9 deletions(-)
diff --git a/README b/README index 54ffbd0975b..5115d28fac1 100644 --- a/README +++ b/README @@ -213,15 +213,7 @@ board_init_r(): there.
SPL-specific notes: - - stack is optionally in SDRAM, if CONFIG_SPL_STACK_R is defined and - CONFIG_SYS_FSL_HAS_CCI400 - - Defined For SoC that has cache coherent interconnect - CCN-400 - - CONFIG_SYS_FSL_HAS_CCN504 - - Defined for SoC that has cache coherent interconnect CCN-504 + - stack is optionally in SDRAM, if CONFIG_SPL_STACK_R is defined
The following options need to be configured:
Move this section to rst, changing it just enough so that it builds.
README | 81 ------------------------------------- doc/develop/index.rst | 1 + doc/develop/init.rst | 92 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 93 insertions(+), 81 deletions(-) create mode 100644 doc/develop/init.rst
diff --git a/README b/README index 5115d28fac1..5a5b93fecb8 100644 --- a/README +++ b/README @@ -134,87 +134,6 @@ run some of U-Boot's tests. See doc/arch/sandbox/sandbox.rst for more details.
-Board Initialisation Flow: --------------------------- - -This is the intended start-up flow for boards. This should apply for both -SPL and U-Boot proper (i.e. they both follow the same rules). - -Note: "SPL" stands for "Secondary Program Loader," which is explained in -more detail later in this file. - -At present, SPL mostly uses a separate code path, but the function names -and roles of each function are the same. Some boards or architectures -may not conform to this. At least most ARM boards which use -CONFIG_SPL_FRAMEWORK conform to this. - -Execution typically starts with an architecture-specific (and possibly -CPU-specific) start.S file, such as: - - - arch/arm/cpu/armv7/start.S - - arch/powerpc/cpu/mpc83xx/start.S - - arch/mips/cpu/start.S - -and so on. From there, three functions are called; the purpose and -limitations of each of these functions are described below. - -lowlevel_init(): - - purpose: essential init to permit execution to reach board_init_f() - - no global_data or BSS - - there is no stack (ARMv7 may have one but it will soon be removed) - - must not set up SDRAM or use console - - must only do the bare minimum to allow execution to continue to - board_init_f() - - this is almost never needed - - return normally from this function - -board_init_f(): - - purpose: set up the machine ready for running board_init_r(): - i.e. SDRAM and serial UART - - global_data is available - - stack is in SRAM - - BSS is not available, so you cannot use global/static variables, - only stack variables and global_data - - Non-SPL-specific notes: - - dram_init() is called to set up DRAM. If already done in SPL this - can do nothing - - SPL-specific notes: - - you can override the entire board_init_f() function with your own - version as needed. - - preloader_console_init() can be called here in extremis - - should set up SDRAM, and anything needed to make the UART work - - there is no need to clear BSS, it will be done by crt0.S - - for specific scenarios on certain architectures an early BSS *can* - be made available (via CONFIG_SPL_EARLY_BSS by moving the clearing - of BSS prior to entering board_init_f()) but doing so is discouraged. - Instead it is strongly recommended to architect any code changes - or additions such to not depend on the availability of BSS during - board_init_f() as indicated in other sections of this README to - maintain compatibility and consistency across the entire code base. - - must return normally from this function (don't call board_init_r() - directly) - -Here the BSS is cleared. For SPL, if CONFIG_SPL_STACK_R is defined, then at -this point the stack and global_data are relocated to below -CONFIG_SPL_STACK_R_ADDR. For non-SPL, U-Boot is relocated to run at the top of -memory. - -board_init_r(): - - purpose: main execution, common code - - global_data is available - - SDRAM is available - - BSS is available, all static/global variables can be used - - execution eventually continues to main_loop() - - Non-SPL-specific notes: - - U-Boot is relocated to the top of memory and is now running from - there. - - SPL-specific notes: - - stack is optionally in SDRAM, if CONFIG_SPL_STACK_R is defined - The following options need to be configured:
- CPU Type: Define exactly one, e.g. CONFIG_MPC85XX. diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 0d0e60ab56c..da9643dca14 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -38,6 +38,7 @@ Implementation distro driver-model/index environment + init expo cedit event diff --git a/doc/develop/init.rst b/doc/develop/init.rst new file mode 100644 index 00000000000..2955d9bdbc3 --- /dev/null +++ b/doc/develop/init.rst @@ -0,0 +1,92 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Board Initialisation Flow +------------------------- + +This is the intended start-up flow for boards. This should apply for both +SPL and U-Boot proper (i.e. they both follow the same rules). + +Note: "SPL" stands for "Secondary Program Loader," which is explained in +more detail later in this file. + +At present, SPL mostly uses a separate code path, but the function names +and roles of each function are the same. Some boards or architectures +may not conform to this. At least most ARM boards which use +CONFIG_SPL_FRAMEWORK conform to this. + +Execution typically starts with an architecture-specific (and possibly +CPU-specific) start.S file, such as: + +- arch/arm/cpu/armv7/start.S +- arch/powerpc/cpu/mpc83xx/start.S +- arch/mips/cpu/start.S + +and so on. From there, three functions are called; the purpose and +limitations of each of these functions are described below. + +lowlevel_init() +~~~~~~~~~~~~~~~ + +- purpose: essential init to permit execution to reach board_init_f() +- no global_data or BSS +- there is no stack (ARMv7 may have one but it will soon be removed) +- must not set up SDRAM or use console +- must only do the bare minimum to allow execution to continue to + board_init_f() +- this is almost never needed +- return normally from this function + +board_init_f() +~~~~~~~~~~~~~~ + +- purpose: set up the machine ready for running board_init_r(): + i.e. SDRAM and serial UART +- global_data is available +- stack is in SRAM +- BSS is not available, so you cannot use global/static variables, + only stack variables and global_data + +Non-xPL-specific notes: + + - dram_init() is called to set up DRAM. If already done in SPL this + can do nothing + +xPL-specific notes: + + - you can override the entire board_init_f() function with your own + version as needed. + - preloader_console_init() can be called here in extremis + - should set up SDRAM, and anything needed to make the UART work + - there is no need to clear BSS, it will be done by crt0.S + - for specific scenarios on certain architectures an early BSS *can* + be made available (via CONFIG_SPL_EARLY_BSS by moving the clearing + of BSS prior to entering board_init_f()) but doing so is discouraged. + Instead it is strongly recommended to architect any code changes + or additions such to not depend on the availability of BSS during + board_init_f() as indicated in other sections of this README to + maintain compatibility and consistency across the entire code base. + - must return normally from this function (don't call board_init_r() + directly) + +Here the BSS is cleared. For SPL, if CONFIG_SPL_STACK_R is defined, then at +this point the stack and global_data are relocated to below +CONFIG_SPL_STACK_R_ADDR. For non-SPL, U-Boot is relocated to run at the top of +memory. + +board_init_r() +~~~~~~~~~~~~~~ + + - purpose: main execution, common code + - global_data is available + - SDRAM is available + - BSS is available, all static/global variables can be used + - execution eventually continues to main_loop() + +Non-SPL-specific notes: + + - U-Boot is relocated to the top of memory and is now running from + there. + +SPL-specific notes: + + - stack is optionally in SDRAM, if CONFIG_SPL_STACK_R is defined
Update the documentation here to cover the meaning of xPL
doc/develop/init.rst | 23 ++++++++++++----------- 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/doc/develop/init.rst b/doc/develop/init.rst index 2955d9bdbc3..ce985781bb4 100644 --- a/doc/develop/init.rst +++ b/doc/develop/init.rst @@ -4,15 +4,16 @@ Board Initialisation Flow -------------------------
This is the intended start-up flow for boards. This should apply for both -SPL and U-Boot proper (i.e. they both follow the same rules). +xPL and U-Boot proper (i.e. they both follow the same rules).
-Note: "SPL" stands for "Secondary Program Loader," which is explained in -more detail later in this file. +Note: "xPL" stands for "any Program Loader", including SPL (Secondary +Program Loader), TPL (Tertiary Program Loader) and VPL (Verifying Program +Loader). The boot sequence is TPL->VPL->SPL->U-Boot proper
-At present, SPL mostly uses a separate code path, but the function names +At present, xPL mostly uses a separate code path, but the function names and roles of each function are the same. Some boards or architectures may not conform to this. At least most ARM boards which use -CONFIG_SPL_FRAMEWORK conform to this. +CONFIG_xPL_FRAMEWORK conform to this.
Execution typically starts with an architecture-specific (and possibly CPU-specific) start.S file, such as: @@ -48,7 +49,7 @@ board_init_f()
- - dram_init() is called to set up DRAM. If already done in SPL this + - dram_init() is called to set up DRAM. If already done in xPL this can do nothing
xPL-specific notes: @@ -68,9 +69,9 @@ xPL-specific notes: - must return normally from this function (don't call board_init_r() directly)
-Here the BSS is cleared. For SPL, if CONFIG_SPL_STACK_R is defined, then at +Here the BSS is cleared. For xPL, if CONFIG_xPL_STACK_R is defined, then at this point the stack and global_data are relocated to below -CONFIG_SPL_STACK_R_ADDR. For non-SPL, U-Boot is relocated to run at the top of +CONFIG_xPL_STACK_R_ADDR. For non-xPL, U-Boot is relocated to run at the top of memory.
board_init_r() @@ -82,11 +83,11 @@ board_init_r() - BSS is available, all static/global variables can be used - execution eventually continues to main_loop()
-Non-SPL-specific notes: +Non-xPL-specific notes:
- U-Boot is relocated to the top of memory and is now running from there.
-SPL-specific notes: +xPL-specific notes:
- - stack is optionally in SDRAM, if CONFIG_SPL_STACK_R is defined + - stack is optionally in SDRAM, if CONFIG_xPL_STACK_R is defined
Jonas Karlman
