[U-Boot] [PATCH] sh: Add support pin function control using GPIO
Renesas SH and R-Mobile set up device using PFC. This provide the framework. Most codes were brought from linux kernel.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/gpio/Makefile | 1 + drivers/gpio/sh_pfc.c | 629 +++++++++++++++++++++++++++++++++++++++++++++++++ include/sh_pfc.h | 192 +++++++++++++++ 3 files changed, 822 insertions(+) create mode 100644 drivers/gpio/sh_pfc.c create mode 100644 include/sh_pfc.h
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index fb3b09a..9192582 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -39,6 +39,7 @@ COBJS-$(CONFIG_TEGRA2_GPIO) += tegra2_gpio.o COBJS-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o COBJS-$(CONFIG_ALTERA_PIO) += altera_pio.o COBJS-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o +COBJS-$(CONFIG_SH_GPIO_PFC) += sh_pfc.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/gpio/sh_pfc.c b/drivers/gpio/sh_pfc.c new file mode 100644 index 0000000..7a5af20 --- /dev/null +++ b/drivers/gpio/sh_pfc.c @@ -0,0 +1,629 @@ +/* + * Pinmuxed GPIO support for SuperH. + * Copy from linux kernel driver/sh/pfc.c + * + * Copyright (C) 2008 Magnus Damm + * + * This file is subject to the terms and conditions of the GNU General Public + * License. See the file "COPYING" in the main directory of this archive + * for more details. + */ + +#include <common.h> +#include <asm/bitops.h> +#include <asm/io.h> +#include <sh_pfc.h> + +static struct pinmux_info *gpioc; + +#define pfc_phys_to_virt(p, a) ((void *)a) + +static int enum_in_range(pinmux_enum_t enum_id, struct pinmux_range *r) +{ + if (enum_id < r->begin) + return 0; + + if (enum_id > r->end) + return 0; + + return 1; +} + +static unsigned long gpio_read_raw_reg(void *mapped_reg, + unsigned long reg_width) +{ + switch (reg_width) { + + case 8: + return readb(mapped_reg); + case 16: + return readw(mapped_reg); + case 32: + return readl(mapped_reg); + } + + BUG(); + return 0; +} + +static void gpio_write_raw_reg(void *mapped_reg, + unsigned long reg_width, + unsigned long data) +{ + switch (reg_width) { + case 8: + writeb(data, mapped_reg); + return; + case 16: + writew(data, mapped_reg); + return; + case 32: + writel(data, mapped_reg); + return; + } + + BUG(); +} + +static int gpio_read_bit(struct pinmux_data_reg *dr, + unsigned long in_pos) +{ + unsigned long pos; + + pos = dr->reg_width - (in_pos + 1); + + debug("read_bit: addr = %lx, pos = %ld, " + "r_width = %ld\n", dr->reg, pos, dr->reg_width); + + return (gpio_read_raw_reg(dr->mapped_reg, dr->reg_width) >> pos) & 1; +} + +static void gpio_write_bit(struct pinmux_data_reg *dr, + unsigned long in_pos, unsigned long value) +{ + unsigned long pos; + + pos = dr->reg_width - (in_pos + 1); + + debug("write_bit addr = %lx, value = %d, pos = %ld, " + "r_width = %ld\n", + dr->reg, !!value, pos, dr->reg_width); + + if (value) + __set_bit(pos, &dr->reg_shadow); + else + __clear_bit(pos, &dr->reg_shadow); + + gpio_write_raw_reg(dr->mapped_reg, dr->reg_width, dr->reg_shadow); +} + +static void config_reg_helper(struct pinmux_info *gpioc, + struct pinmux_cfg_reg *crp, + unsigned long in_pos, +#if 0 + void __iomem **mapped_regp, +#else + void **mapped_regp, +#endif + unsigned long *maskp, + unsigned long *posp) +{ + int k; + + *mapped_regp = pfc_phys_to_virt(gpioc, crp->reg); + + if (crp->field_width) { + *maskp = (1 << crp->field_width) - 1; + *posp = crp->reg_width - ((in_pos + 1) * crp->field_width); + } else { + *maskp = (1 << crp->var_field_width[in_pos]) - 1; + *posp = crp->reg_width; + for (k = 0; k <= in_pos; k++) + *posp -= crp->var_field_width[k]; + } +} + +static int read_config_reg(struct pinmux_info *gpioc, + struct pinmux_cfg_reg *crp, + unsigned long field) +{ + void *mapped_reg; + + unsigned long mask, pos; + + config_reg_helper(gpioc, crp, field, &mapped_reg, &mask, &pos); + + debug("read_reg: addr = %lx, field = %ld, " + "r_width = %ld, f_width = %ld\n", + crp->reg, field, crp->reg_width, crp->field_width); + + return (gpio_read_raw_reg(mapped_reg, crp->reg_width) >> pos) & mask; +} + +static void write_config_reg(struct pinmux_info *gpioc, + struct pinmux_cfg_reg *crp, + unsigned long field, unsigned long value) +{ + void *mapped_reg; + unsigned long mask, pos, data; + + config_reg_helper(gpioc, crp, field, &mapped_reg, &mask, &pos); + + debug("write_reg addr = %lx, value = %ld, field = %ld, " + "r_width = %ld, f_width = %ld\n", + crp->reg, value, field, crp->reg_width, crp->field_width); + + mask = ~(mask << pos); + value = value << pos; + + data = gpio_read_raw_reg(mapped_reg, crp->reg_width); + data &= mask; + data |= value; + + if (gpioc->unlock_reg) + gpio_write_raw_reg(pfc_phys_to_virt(gpioc, gpioc->unlock_reg), + 32, ~data); + + gpio_write_raw_reg(mapped_reg, crp->reg_width, data); +} + +static int setup_data_reg(struct pinmux_info *gpioc, unsigned gpio) +{ + struct pinmux_gpio *gpiop = &gpioc->gpios[gpio]; + struct pinmux_data_reg *data_reg; + int k, n; + + if (!enum_in_range(gpiop->enum_id, &gpioc->data)) + return -1; + + k = 0; + while (1) { + data_reg = gpioc->data_regs + k; + + if (!data_reg->reg_width) + break; + + data_reg->mapped_reg = pfc_phys_to_virt(gpioc, data_reg->reg); + + for (n = 0; n < data_reg->reg_width; n++) { + if (data_reg->enum_ids[n] == gpiop->enum_id) { + gpiop->flags &= ~PINMUX_FLAG_DREG; + gpiop->flags |= (k << PINMUX_FLAG_DREG_SHIFT); + gpiop->flags &= ~PINMUX_FLAG_DBIT; + gpiop->flags |= (n << PINMUX_FLAG_DBIT_SHIFT); + return 0; + } + } + k++; + } + + BUG(); + + return -1; +} + +static void setup_data_regs(struct pinmux_info *gpioc) +{ + struct pinmux_data_reg *drp; + int k; + + for (k = gpioc->first_gpio; k <= gpioc->last_gpio; k++) + setup_data_reg(gpioc, k); + + k = 0; + while (1) { + drp = gpioc->data_regs + k; + + if (!drp->reg_width) + break; + + drp->reg_shadow = gpio_read_raw_reg(drp->mapped_reg, + drp->reg_width); + k++; + } +} + +static int get_data_reg(struct pinmux_info *gpioc, unsigned gpio, + struct pinmux_data_reg **drp, int *bitp) +{ + struct pinmux_gpio *gpiop = &gpioc->gpios[gpio]; + int k, n; + + if (!enum_in_range(gpiop->enum_id, &gpioc->data)) + return -1; + + k = (gpiop->flags & PINMUX_FLAG_DREG) >> PINMUX_FLAG_DREG_SHIFT; + n = (gpiop->flags & PINMUX_FLAG_DBIT) >> PINMUX_FLAG_DBIT_SHIFT; + *drp = gpioc->data_regs + k; + *bitp = n; + return 0; +} + +static int get_config_reg(struct pinmux_info *gpioc, pinmux_enum_t enum_id, + struct pinmux_cfg_reg **crp, + int *fieldp, int *valuep, + unsigned long **cntp) +{ + struct pinmux_cfg_reg *config_reg; + unsigned long r_width, f_width, curr_width, ncomb; + int k, m, n, pos, bit_pos; + + k = 0; + while (1) { + config_reg = gpioc->cfg_regs + k; + + r_width = config_reg->reg_width; + f_width = config_reg->field_width; + + if (!r_width) + break; + + pos = 0; + m = 0; + for (bit_pos = 0; bit_pos < r_width; bit_pos += curr_width) { + if (f_width) + curr_width = f_width; + else + curr_width = config_reg->var_field_width[m]; + + ncomb = 1 << curr_width; + for (n = 0; n < ncomb; n++) { + if (config_reg->enum_ids[pos + n] == enum_id) { + *crp = config_reg; + *fieldp = m; + *valuep = n; + *cntp = &config_reg->cnt[m]; + return 0; + } + } + pos += ncomb; + m++; + } + k++; + } + + return -1; +} + +static int get_gpio_enum_id(struct pinmux_info *gpioc, unsigned gpio, + int pos, pinmux_enum_t *enum_idp) +{ + pinmux_enum_t enum_id = gpioc->gpios[gpio].enum_id; + pinmux_enum_t *data = gpioc->gpio_data; + int k; + + if (!enum_in_range(enum_id, &gpioc->data)) { + if (!enum_in_range(enum_id, &gpioc->mark)) { + debug("non data/mark enum_id for gpio %d\n", gpio); + return -1; + } + } + + if (pos) { + *enum_idp = data[pos + 1]; + return pos + 1; + } + + for (k = 0; k < gpioc->gpio_data_size; k++) { + if (data[k] == enum_id) { + *enum_idp = data[k + 1]; + return k + 1; + } + } + + debug("cannot locate data/mark enum_id for gpio %d\n", gpio); + return -1; +} + +enum { GPIO_CFG_DRYRUN, GPIO_CFG_REQ, GPIO_CFG_FREE }; + +static int pinmux_config_gpio(struct pinmux_info *gpioc, unsigned gpio, + int pinmux_type, int cfg_mode) +{ + struct pinmux_cfg_reg *cr = NULL; + pinmux_enum_t enum_id; + struct pinmux_range *range; + int in_range, pos, field, value; + unsigned long *cntp; + + switch (pinmux_type) { + + case PINMUX_TYPE_FUNCTION: + range = NULL; + break; + + case PINMUX_TYPE_OUTPUT: + range = &gpioc->output; + break; + + case PINMUX_TYPE_INPUT: + range = &gpioc->input; + break; + + case PINMUX_TYPE_INPUT_PULLUP: + range = &gpioc->input_pu; + break; + + case PINMUX_TYPE_INPUT_PULLDOWN: + range = &gpioc->input_pd; + break; + + default: + goto out_err; + } + + pos = 0; + enum_id = 0; + field = 0; + value = 0; + while (1) { + pos = get_gpio_enum_id(gpioc, gpio, pos, &enum_id); + if (pos <= 0) + goto out_err; + + if (!enum_id) + break; + + /* first check if this is a function enum */ + in_range = enum_in_range(enum_id, &gpioc->function); + if (!in_range) { + /* not a function enum */ + if (range) { + /* + * other range exists, so this pin is + * a regular GPIO pin that now is being + * bound to a specific direction. + * + * for this case we only allow function enums + * and the enums that match the other range. + */ + in_range = enum_in_range(enum_id, range); + + /* + * special case pass through for fixed + * input-only or output-only pins without + * function enum register association. + */ + if (in_range && enum_id == range->force) + continue; + } else { + /* + * no other range exists, so this pin + * must then be of the function type. + * + * allow function type pins to select + * any combination of function/in/out + * in their MARK lists. + */ + in_range = 1; + } + } + + if (!in_range) + continue; + + if (get_config_reg(gpioc, enum_id, &cr, + &field, &value, &cntp) != 0) + goto out_err; + + switch (cfg_mode) { + case GPIO_CFG_DRYRUN: + if (!*cntp || + (read_config_reg(gpioc, cr, field) != value)) + continue; + break; + + case GPIO_CFG_REQ: + write_config_reg(gpioc, cr, field, value); + *cntp = *cntp + 1; + break; + + case GPIO_CFG_FREE: + *cntp = *cntp - 1; + break; + } + } + + return 0; + out_err: + return -1; +} + +#if 0 +static DEFINE_SPINLOCK(gpio_lock); +static struct pinmux_info *chip_to_pinmux(struct gpio_chip *chip) +{ + return container_of(chip, struct pinmux_info, chip); +} +#endif + +static int sh_gpio_request(unsigned offset) +{ + struct pinmux_data_reg *dummy; + int i, ret, pinmux_type; + + ret = -1; + + if (!gpioc) + goto err_out; + + if ((gpioc->gpios[offset].flags & PINMUX_FLAG_TYPE) != PINMUX_TYPE_NONE) + goto err_out; + + /* setup pin function here if no data is associated with pin */ + + if (get_data_reg(gpioc, offset, &dummy, &i) != 0) + pinmux_type = PINMUX_TYPE_FUNCTION; + else + pinmux_type = PINMUX_TYPE_GPIO; + + if (pinmux_type == PINMUX_TYPE_FUNCTION) { + if (pinmux_config_gpio(gpioc, offset, + pinmux_type, + GPIO_CFG_DRYRUN) != 0) + goto err_out; + + if (pinmux_config_gpio(gpioc, offset, + pinmux_type, + GPIO_CFG_REQ) != 0) + BUG(); + } + + gpioc->gpios[offset].flags &= ~PINMUX_FLAG_TYPE; + gpioc->gpios[offset].flags |= pinmux_type; + + ret = 0; +err_out: + return ret; +} + +static void sh_gpio_free(unsigned offset) +{ + int pinmux_type; + + if (!gpioc) + return; + + pinmux_type = gpioc->gpios[offset].flags & PINMUX_FLAG_TYPE; + pinmux_config_gpio(gpioc, offset, pinmux_type, GPIO_CFG_FREE); + gpioc->gpios[offset].flags &= ~PINMUX_FLAG_TYPE; + gpioc->gpios[offset].flags |= PINMUX_TYPE_NONE; +} + +static int pinmux_direction(struct pinmux_info *gpioc, + unsigned gpio, int new_pinmux_type) +{ + int pinmux_type; + int ret = -1; + + if (!gpioc) + goto err_out; + + pinmux_type = gpioc->gpios[gpio].flags & PINMUX_FLAG_TYPE; + + switch (pinmux_type) { + case PINMUX_TYPE_GPIO: + break; + case PINMUX_TYPE_OUTPUT: + case PINMUX_TYPE_INPUT: + case PINMUX_TYPE_INPUT_PULLUP: + case PINMUX_TYPE_INPUT_PULLDOWN: + pinmux_config_gpio(gpioc, gpio, pinmux_type, GPIO_CFG_FREE); + break; + default: + goto err_out; + } + + if (pinmux_config_gpio(gpioc, gpio, + new_pinmux_type, + GPIO_CFG_DRYRUN) != 0) + goto err_out; + + if (pinmux_config_gpio(gpioc, gpio, + new_pinmux_type, + GPIO_CFG_REQ) != 0) + BUG(); + + gpioc->gpios[gpio].flags &= ~PINMUX_FLAG_TYPE; + gpioc->gpios[gpio].flags |= new_pinmux_type; + + ret = 0; + err_out: + return ret; +} + +static int sh_gpio_direction_input(unsigned offset) +{ + return pinmux_direction(gpioc, offset, PINMUX_TYPE_INPUT); +} + +static void sh_gpio_set_value(struct pinmux_info *gpioc, + unsigned gpio, int value) +{ + struct pinmux_data_reg *dr = NULL; + int bit = 0; + + if (!gpioc || get_data_reg(gpioc, gpio, &dr, &bit) != 0) + BUG(); + else + gpio_write_bit(dr, bit, value); +} + +static int sh_gpio_direction_output(unsigned offset, int value) +{ + sh_gpio_set_value(gpioc, offset, value); + return pinmux_direction(gpioc, offset, PINMUX_TYPE_OUTPUT); +} + +static int sh_gpio_get_value(struct pinmux_info *gpioc, unsigned gpio) +{ + struct pinmux_data_reg *dr = NULL; + int bit = 0; + + if (!gpioc || get_data_reg(gpioc, gpio, &dr, &bit) != 0) + return -1; + + return gpio_read_bit(dr, bit); +} + +static int sh_gpio_get(unsigned offset) +{ + return sh_gpio_get_value(gpioc, offset); +} + +static void sh_gpio_set(unsigned offset, int value) +{ + sh_gpio_set_value(gpioc, offset, value); +} + +int register_pinmux(struct pinmux_info *pip) +{ + if (pip != NULL) { + gpioc = pip; + debug("%s deregistering\n", pip->name); + setup_data_regs(gpioc); + } + return 0; +} + +int unregister_pinmux(struct pinmux_info *pip) +{ + debug("%s deregistering\n", pip->name); + if (gpioc != pip) + return -1; + + gpioc = NULL; + return 0; +} + +int gpio_request(unsigned gpio, const char *label) +{ + sh_gpio_request(gpio); + return 0; +} + +int gpio_free(unsigned gpio) +{ + sh_gpio_free(gpio); + return 0; +} + +int gpio_direction_input(unsigned gpio) +{ + return sh_gpio_direction_input(gpio); +} + +int gpio_direction_output(unsigned gpio, int value) +{ + return sh_gpio_direction_output(gpio, value); +} + +void gpio_set_value(unsigned gpio, int value) +{ + sh_gpio_set(gpio, value); +} + +int gpio_get_value(unsigned gpio) +{ + return sh_gpio_get(gpio); +} diff --git a/include/sh_pfc.h b/include/sh_pfc.h new file mode 100644 index 0000000..4e0dc71 --- /dev/null +++ b/include/sh_pfc.h @@ -0,0 +1,192 @@ +/* + * SuperH Pin Function Controller Support + * Copy from Linux kernel. (include/linux/sh_pfc.h) + * + * Copyright (c) 2008 Magnus Damm + * + * This file is subject to the terms and conditions of the GNU General Public + * License. See the file "COPYING" in the main directory of this archive + * for more details. + */ + +#ifndef __SH_PFC_H +#define __SH_PFC_H + +typedef unsigned short pinmux_enum_t; +typedef unsigned short pinmux_flag_t; + +#define PINMUX_TYPE_NONE 0 +#define PINMUX_TYPE_FUNCTION 1 +#define PINMUX_TYPE_GPIO 2 +#define PINMUX_TYPE_OUTPUT 3 +#define PINMUX_TYPE_INPUT 4 +#define PINMUX_TYPE_INPUT_PULLUP 5 +#define PINMUX_TYPE_INPUT_PULLDOWN 6 + +#define PINMUX_FLAG_TYPE (0x7) +#define PINMUX_FLAG_WANT_PULLUP (1 << 3) +#define PINMUX_FLAG_WANT_PULLDOWN (1 << 4) + +#define PINMUX_FLAG_DBIT_SHIFT 5 +#define PINMUX_FLAG_DBIT (0x1f << PINMUX_FLAG_DBIT_SHIFT) +#define PINMUX_FLAG_DREG_SHIFT 10 +#define PINMUX_FLAG_DREG (0x3f << PINMUX_FLAG_DREG_SHIFT) + +struct pinmux_gpio { + pinmux_enum_t enum_id; + pinmux_flag_t flags; +}; + +#define PINMUX_GPIO(gpio, data_or_mark) [gpio] = { data_or_mark } +#define PINMUX_DATA(data_or_mark, ids...) data_or_mark, ids, 0 + +struct pinmux_cfg_reg { + unsigned long reg, reg_width, field_width; + unsigned long *cnt; + pinmux_enum_t *enum_ids; + unsigned long *var_field_width; +}; + +#define PINMUX_CFG_REG(name, r, r_width, f_width) \ + .reg = r, .reg_width = r_width, .field_width = f_width, \ + .cnt = (unsigned long [r_width / f_width]) {}, \ + .enum_ids = (pinmux_enum_t [(r_width / f_width) * (1 << f_width)]) + +#define PINMUX_CFG_REG_VAR(name, r, r_width, var_fw0, var_fwn...) \ + .reg = r, .reg_width = r_width, \ + .cnt = (unsigned long [r_width]) {}, \ + .var_field_width = (unsigned long [r_width]) { var_fw0, var_fwn, 0 }, \ + .enum_ids = (pinmux_enum_t []) + +struct pinmux_data_reg { + unsigned long reg, reg_width, reg_shadow; + pinmux_enum_t *enum_ids; + void *mapped_reg; +}; + +#define PINMUX_DATA_REG(name, r, r_width) \ + .reg = r, .reg_width = r_width, \ + .enum_ids = (pinmux_enum_t [r_width]) \ + +struct pinmux_irq { + int irq; + pinmux_enum_t *enum_ids; +}; + +#define PINMUX_IRQ(irq_nr, ids...) \ + { .irq = irq_nr, .enum_ids = (pinmux_enum_t []) { ids, 0 } } \ + +struct pinmux_range { + pinmux_enum_t begin; + pinmux_enum_t end; + pinmux_enum_t force; +}; + +struct pinmux_info { + char *name; + pinmux_enum_t reserved_id; + struct pinmux_range data; + struct pinmux_range input; + struct pinmux_range input_pd; + struct pinmux_range input_pu; + struct pinmux_range output; + struct pinmux_range mark; + struct pinmux_range function; + + unsigned first_gpio, last_gpio; + + struct pinmux_gpio *gpios; + struct pinmux_cfg_reg *cfg_regs; + struct pinmux_data_reg *data_regs; + + pinmux_enum_t *gpio_data; + unsigned int gpio_data_size; + + struct pinmux_irq *gpio_irq; + unsigned int gpio_irq_size; + + struct resource *resource; + unsigned int num_resources; + unsigned long unlock_reg; +}; + +int register_pinmux(struct pinmux_info *pip); +int unregister_pinmux(struct pinmux_info *pip); + +/* helper macro for port */ +#define PORT_1(fn, pfx, sfx) fn(pfx, sfx) + +#define PORT_10(fn, pfx, sfx) \ + PORT_1(fn, pfx##0, sfx), PORT_1(fn, pfx##1, sfx), \ + PORT_1(fn, pfx##2, sfx), PORT_1(fn, pfx##3, sfx), \ + PORT_1(fn, pfx##4, sfx), PORT_1(fn, pfx##5, sfx), \ + PORT_1(fn, pfx##6, sfx), PORT_1(fn, pfx##7, sfx), \ + PORT_1(fn, pfx##8, sfx), PORT_1(fn, pfx##9, sfx) + +#define PORT_90(fn, pfx, sfx) \ + PORT_10(fn, pfx##1, sfx), PORT_10(fn, pfx##2, sfx), \ + PORT_10(fn, pfx##3, sfx), PORT_10(fn, pfx##4, sfx), \ + PORT_10(fn, pfx##5, sfx), PORT_10(fn, pfx##6, sfx), \ + PORT_10(fn, pfx##7, sfx), PORT_10(fn, pfx##8, sfx), \ + PORT_10(fn, pfx##9, sfx) + +#define _PORT_ALL(pfx, sfx) pfx##_##sfx +#define _GPIO_PORT(pfx, sfx) PINMUX_GPIO(GPIO_PORT##pfx, PORT##pfx##_DATA) +#define PORT_ALL(str) CPU_ALL_PORT(_PORT_ALL, PORT, str) +#define GPIO_PORT_ALL() CPU_ALL_PORT(_GPIO_PORT, , unused) +#define GPIO_FN(str) PINMUX_GPIO(GPIO_FN_##str, str##_MARK) + +/* helper macro for pinmux_enum_t */ +#define PORT_DATA_I(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, PORT##nr##_IN) + +#define PORT_DATA_I_PD(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, \ + PORT##nr##_IN, PORT##nr##_IN_PD) + +#define PORT_DATA_I_PU(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, \ + PORT##nr##_IN, PORT##nr##_IN_PU) + +#define PORT_DATA_I_PU_PD(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, \ + PORT##nr##_IN, PORT##nr##_IN_PD, PORT##nr##_IN_PU) + +#define PORT_DATA_O(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, PORT##nr##_OUT) + +#define PORT_DATA_IO(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, PORT##nr##_OUT, \ + PORT##nr##_IN) + +#define PORT_DATA_IO_PD(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, PORT##nr##_OUT, \ + PORT##nr##_IN, PORT##nr##_IN_PD) + +#define PORT_DATA_IO_PU(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, PORT##nr##_OUT, \ + PORT##nr##_IN, PORT##nr##_IN_PU) + +#define PORT_DATA_IO_PU_PD(nr) \ + PINMUX_DATA(PORT##nr##_DATA, PORT##nr##_FN0, PORT##nr##_OUT, \ + PORT##nr##_IN, PORT##nr##_IN_PD, PORT##nr##_IN_PU) + +/* helper macro for top 4 bits in PORTnCR */ +#define _PCRH(in, in_pd, in_pu, out) \ + 0, (out), (in), 0, \ + 0, 0, 0, 0, \ + 0, 0, (in_pd), 0, \ + 0, 0, (in_pu), 0 + +#define PORTCR(nr, reg) \ + { \ + PINMUX_CFG_REG("PORT" nr "CR", reg, 8, 4) { \ + _PCRH(PORT##nr##_IN, PORT##nr##_IN_PD, \ + PORT##nr##_IN_PU, PORT##nr##_OUT), \ + PORT##nr##_FN0, PORT##nr##_FN1, \ + PORT##nr##_FN2, PORT##nr##_FN3, \ + PORT##nr##_FN4, PORT##nr##_FN5, \ + PORT##nr##_FN6, PORT##nr##_FN7 } \ + } + +#endif /* __SH_PFC_H */
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM, USB, Ethernet, and more.
This patch supports the following functions: - 512MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SMSC) - I2C
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/mach-types.h | 2 + board/kmc/kzm/Makefile | 51 ++++++ board/kmc/kzm/kzm.c | 142 +++++++++++++++++ board/kmc/kzm/lowlevel_init.S | 308 +++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/kzm_a9_gt.h | 164 ++++++++++++++++++++ 6 files changed, 668 insertions(+) create mode 100644 board/kmc/kzm/Makefile create mode 100644 board/kmc/kzm/kzm.c create mode 100644 board/kmc/kzm/lowlevel_init.S create mode 100644 include/configs/kzm_a9_gt.h
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 2d5c3bc..98c992c 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -1106,6 +1106,8 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_ATDGP318 3494 #define MACH_TYPE_OMAP5_SEVM 3777
+#define MACH_TYPE_KZM9G 4140 + #ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type # undef machine_arch_type diff --git a/board/kmc/kzm/Makefile b/board/kmc/kzm/Makefile new file mode 100644 index 0000000..8601230 --- /dev/null +++ b/board/kmc/kzm/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com +# (C) Copyright 2012 Renesas Solutions Corp. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := kzm.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj) .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/kmc/kzm/kzm.c b/board/kmc/kzm/kzm.c new file mode 100644 index 0000000..ae0868e --- /dev/null +++ b/board/kmc/kzm/kzm.c @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * (C) Copyright 2012 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <netdev.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define CS0BCR_D (0x06C00400) +#define CS4BCR_D (0x06C00400) +#define CS0WCR_D (0x55062C42) +#define CS4WCR_D (0x19051443) +#define CMNCR_BROMMD0 (1 << 21) +#define CMNCR_BROMMD1 (1 << 22) +#define CMNCR_BROMMD (CMNCR_BROMMD0|CMNCR_BROMMD1) +#define VCLKCR1_D (0x27) + +#define SMSTPCR1_CMT0 (1 << 24) +#define SMSTPCR1_I2C0 (1 << 16) +#define SMSTPCR3_USB (1 << 22) + +#define PORT32CR (0xE6051020) +#define PORT33CR (0xE6051021) +#define PORT34CR (0xE6051022) +#define PORT35CR (0xE6051023) + +int board_early_init_f(void) +{ + writel(CS0BCR_D, CS0BCR); + writel(CS4BCR_D, CS4BCR); + writel(CS0WCR_D, CS0WCR); + writel(CS4WCR_D, CS4WCR); + + clrsetbits_le32(CMNCR, ~CMNCR_BROMMD, CMNCR_BROMMD); + + clrbits_le32(SMSTPCR1, (SMSTPCR1_CMT0|SMSTPCR1_I2C0)); + clrbits_le32(SRCR1, (SMSTPCR1_CMT0|SMSTPCR1_I2C0)); + clrbits_le32(SMSTPCR3, SMSTPCR3_USB); + clrbits_le32(SRCR3, SMSTPCR3_USB); + writel(VCLKCR1_D, VCLKCR1); + + /* Setup SCIF4 / workaround */ + writeb(0x12, PORT32CR); + writeb(0x22, PORT33CR); + writeb(0x12, PORT34CR); + writeb(0x22, PORT35CR); + + return 0; +} + +int board_init(void) +{ + sh73a0_pinmux_init(); + + /* SCIFA 4 */ + gpio_request(GPIO_FN_SCIFA4_TXD, NULL); + gpio_request(GPIO_FN_SCIFA4_RXD, NULL); + gpio_request(GPIO_FN_SCIFA4_RTS_, NULL); + gpio_request(GPIO_FN_SCIFA4_CTS_, NULL); + + /* Ethernet/SMSC */ + gpio_request(GPIO_PORT224, NULL); + gpio_direction_input(GPIO_PORT224); + + /* SMSC/USB */ + gpio_request(GPIO_FN_CS4_, NULL); + + /* MMCIF */ + gpio_request(GPIO_FN_MMCCLK0, NULL); + gpio_request(GPIO_FN_MMCCMD0_PU, NULL); + gpio_request(GPIO_FN_MMCD0_0_PU, NULL); + gpio_request(GPIO_FN_MMCD0_1_PU, NULL); + gpio_request(GPIO_FN_MMCD0_2_PU, NULL); + gpio_request(GPIO_FN_MMCD0_3_PU, NULL); + gpio_request(GPIO_FN_MMCD0_4_PU, NULL); + gpio_request(GPIO_FN_MMCD0_5_PU, NULL); + gpio_request(GPIO_FN_MMCD0_6_PU, NULL); + gpio_request(GPIO_FN_MMCD0_7_PU, NULL); + + /* SDHI */ + gpio_request(GPIO_FN_SDHIWP0, NULL); + gpio_request(GPIO_FN_SDHICD0, NULL); + gpio_request(GPIO_FN_SDHICMD0, NULL); + gpio_request(GPIO_FN_SDHICLK0, NULL); + gpio_request(GPIO_FN_SDHID0_3, NULL); + gpio_request(GPIO_FN_SDHID0_2, NULL); + gpio_request(GPIO_FN_SDHID0_1, NULL); + gpio_request(GPIO_FN_SDHID0_0, NULL); + gpio_request(GPIO_FN_SDHI0_VCCQ_MC0_ON, NULL); + gpio_request(GPIO_PORT15, NULL); + gpio_direction_output(GPIO_PORT15, 1); + + /* I2C */ + gpio_request(GPIO_FN_PORT27_I2C_SCL3, NULL); + gpio_request(GPIO_FN_PORT28_I2C_SDA3, NULL); + + gd->bd->bi_boot_params = (CONFIG_SYS_SDRAM_BASE + 0x100); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int ret = 0; +#ifdef CONFIG_SMC911X + ret = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return ret; +} + +void reset_cpu(ulong addr) +{ +} diff --git a/board/kmc/kzm/lowlevel_init.S b/board/kmc/kzm/lowlevel_init.S new file mode 100644 index 0000000..5221611 --- /dev/null +++ b/board/kmc/kzm/lowlevel_init.S @@ -0,0 +1,308 @@ +/* + * Copyright (C) 2012 Nobuhiro Iwamatsu nobuhiro.Iwamatsu.yj@renesas.com + * Copyright (C) 2012 Renesas Solutions Corp. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/macro.h> + +/* loop until a value was compare */ +.macro cmp_loop, addr, data, cmp + ldr r0, =\addr + ldr r1, =\data + ldr r2, =\cmp +2: + ldr r3, [r0, #0] + and r3, r1, r3 + cmp r2, r3 + bne 2b +.endm + +/* read value from addr, and calc OR with data */ +.macro or_write32, addr, data + ldr r4, =\addr + ldr r5, =\data + ldr r6, [r4] + orr r5, r6, r5 + str r5, [r4] +.endm + +/* read value from addr, and calc AND with data */ +.macro and_write32, addr, data + ldr r4, =\addr + ldr r5, =\data + ldr r6, [r4] + and r5, r6, r5 + str r5, [r4] +.endm + +.globl lowlevel_init + +lowlevel_init: + + ldr r0, =MERAM_BASE + mov r1, #0x0 + str r1, [r0] + + mrc p15, 0, r0, c0, c0, 5 + ands r0, r0, #0xF + beq lowlevel_init__ + b wait_interrupt + + .pool + .align 4 + +wait_interrupt: + ldr r1, =ICCICR + mov r2, #0x0 + str r2, [r1] + mov r2, #0xF0 + ldr r1, =ICCPMR + str r2, [r1] + ldr r1, =ICCICR + mov r2, #0x1 + str r2, [r1] + +wait_loop: + wfi + + ldr r2, [r1, #0xC] + str r2, [r1, #0x10] + + ldr r0, =MERAM_BASE + ldr r2, [r0] + cmp r2, #0 + movne pc, r2 + + b wait_loop + +wait_loop_end: + .pool + .align 4 + +lowlevel_init__: + + mov r0, #0x200000 + +loop0: + subs r0, r0, #1 + bne loop0 + + write16 RWTCSRA0, 0xA507 + .pool + + and_write32 LIFEC_SEC_SRC, 0xFFFFFFE7 + + and_write32 SRCR3, 0xFFFF7FFF + and_write32 SMSTPCR2,0xFFFBFFFF + and_write32 SRCR2, 0xFFFBFFFF + write32 PLLECR, 0x00000000 + + cmp_loop PLLECR, 0x00000F00, 0x00000000 + cmp_loop FRQCRB, 0x80000000, 0x00000000 + + write32 PLL0CR, 0x2D000000 + write32 PLL1CR, 0x17100000 + write32 FRQCRB, 0x96235880 + cmp_loop FRQCRB, 0x80000000, 0x00000000 + + write32 FLCKCR, 0x0000000B + and_write32 SMSTPCR0, 0xFFFFFFFD + + and_write32 SRCR0, 0xFFFFFFFD + write32 SMGPIOTIME, 0x00000514 + write32 SMCMT2TIME, 0x00000514 + write32 SMCPGTIME, 0x00000514 + write32 SMSYSCTIME, 0x00000514 + + write32 DVFSCR4, 0x00092000 + write32 DVFSCR5, 0x000000DC + write32 PLLECR, 0x00000000 + cmp_loop PLLECR, 0x00000F00, 0x00000000 + + write32 FRQCRA, 0x0012453C + write32 FRQCRB, 0x80331350 + cmp_loop FRQCRB, 0x80000000, 0x00000000 + write32 FRQCRD, 0x00000B0B + cmp_loop FRQCRD, 0x80000000, 0x00000000 + + write32 PCLKCR, 0x00000003 + write32 VCLKCR1, 0x0000012F + write32 VCLKCR2, 0x00000119 + write32 VCLKCR3, 0x00000119 + write32 ZBCKCR, 0x00000002 + write32 FLCKCR, 0x00000005 + write32 SD0CKCR, 0x00000080 + write32 SD1CKCR, 0x00000080 + write32 SD2CKCR, 0x00000080 + write32 FSIACKCR, 0x0000003F + write32 FSIBCKCR, 0x0000003F + write32 SUBCKCR, 0x00000080 + write32 SPUACKCR, 0x0000000B + write32 SPUVCKCR, 0x0000000B + write32 MSUCKCR, 0x0000013F + write32 HSICKCR, 0x00000080 + write32 MFCK1CR, 0x0000003F + write32 MFCK2CR, 0x0000003F + write32 DSITCKCR, 0x00000107 + write32 DSI0PCKCR, 0x00000313 + write32 DSI1PCKCR, 0x0000130D + write32 DSI0PHYCR, 0x2A800E0E + write32 PLL0CR, 0x1E000000 + write32 PLL0CR, 0x2D000000 + write32 PLL1CR, 0x17100000 + write32 PLL2CR, 0x27000080 + write32 PLL3CR, 0x1D000000 + write32 PLL0STPCR, 0x00080000 + write32 PLL1STPCR, 0x000120C0 + write32 PLL2STPCR, 0x00012000 + write32 PLL3STPCR, 0x00000030 + write32 PLLECR, 0x0000000B + cmp_loop PLLECR, 0x00000B00, 0x00000B00 + + write32 DVFSCR3, 0x000120F0 + write32 MPMODE, 0x00000020 + write32 VREFCR, 0x0000028A + write32 RMSTPCR0, 0xE4628087 + write32 RMSTPCR1, 0xFFFFFFFF + write32 RMSTPCR2, 0x53FFFFFF + write32 RMSTPCR3, 0xFFFFFFFF + write32 RMSTPCR4, 0x00800D3D + write32 RMSTPCR5, 0xFFFFF3FF + write32 SMSTPCR2, 0x00000000 + write32 SRCR2, 0x00040000 + and_write32 PLLECR, 0xFFFFFFF7 + cmp_loop PLLECR, 0x00000800, 0x00000000 + + write32 HPBCTRL6, 0x00000001 + cmp_loop HPBCTRL6, 0x00000001, 0x00000001 + + write32 FRQCRD, 0x00001414 + cmp_loop FRQCRD, 0x80000000, 0x00000000 + + write32 PLL3CR, 0x1D000000 + or_write32 PLLECR, 0x00000008 + cmp_loop PLLECR, 0x00000800, 0x00000800 + + or_write32 DLLCNT0A, 0x00000002 + write32 SDGENCNTA, 0x00000005 + cmp_loop SDGENCNTA, 0xFFFFFFFF, 0x00000000 + + write32 SDCR0A, 0xACC90159 + write32 SDCR1A, 0x00010059 + write32 SDWCRC0A, 0x50874114 + write32 SDWCRC1A, 0x33199B37 + write32 SDWCRC2A, 0x008F2313 + write32 SDWCR00A, 0x31020707 + write32 SDWCR01A, 0x0017040A + write32 SDWCR10A, 0x31020707 + write32 SDWCR11A, 0x0017040A + write32 SDDRVCR0A, 0x05555555 + write32 SDWCR2A, 0x30000000 + or_write32 SDPCRA, 0x00000080 + cmp_loop SDPCRA, 0x00000080, 0x00000080 + write32 SDGENCNTA, 0x00002710 + cmp_loop SDGENCNTA, 0xFFFFFFFF, 0x00000000 + write32 SDMRACR0A, 0x0000003F + write32 SDMRA1, 0x00000000 + write32 SDGENCNTA, 0x000001F4 + cmp_loop SDGENCNTA, 0xFFFFFFFF, 0x00000000 + write32 SDMRACR0A, 0x0000FF0A + write32 SDMRA3, 0x00000000 + write32 SDGENCNTA, 0x00000032 + cmp_loop SDGENCNTA, 0xFFFFFFFF, 0x00000000 + write32 SDMRACR0A, 0x00002201 + write32 SDMRA1, 0x00000000 + write32 SDMRACR0A, 0x00000402 + write32 SDMRA1, 0x00000000 + write32 SDMRACR0A, 0x00000403 + write32 SDMRA1, 0x00000000 + write32 SDMRA2, 0x00000000 + write32 SDMRTMPCRA, 0x88800004 + write32 SDMRTMPMSKA,0x00000004 + write32 RTCORA, 0xA55A0032 + write32 RTCORHA, 0xA55A000C + write32 RTCSRA, 0xA55A2048 + or_write32 SDCR0A, 0x00000800 + or_write32 SDCR1A, 0x00000400 + write32 ZQCCRA, 0xFFF20000 + + or_write32 DLLCNT0B, 0x00000002 + write32 SDGENCNTB, 0x00000005 + cmp_loop SDGENCNTB, 0xFFFFFFFF, 0x00000000 + + write32 SDCR0B, 0xACC90159 + write32 SDCR1B, 0x00010059 + write32 SDWCRC0B, 0x50874114 + write32 SDWCRC1B, 0x33199B37 + write32 SDWCRC2B, 0x008F2313 + write32 SDWCR00B, 0x31020707 + write32 SDWCR01B, 0x0017040A + write32 SDWCR10B, 0x31020707 + write32 SDWCR11B, 0x0017040A + write32 SDDRVCR0B, 0x05555555 + write32 SDWCR2B, 0x30000000 + or_write32 SDPCRB, 0x00000080 + cmp_loop SDPCRB, 0x00000080, 0x00000080 + + write32 SDGENCNTB, 0x00002710 + cmp_loop SDGENCNTB, 0xFFFFFFFF, 0x00000000 + write32 SDMRACR0B, 0x0000003F + write32 SDMRB1, 0x00000000 + write32 SDGENCNTB, 0x000001F4 + cmp_loop SDGENCNTB, 0xFFFFFFFF, 0x00000000 + + write32 SDMRACR0B, 0x0000FF0A + write32 SDMRB3, 0x00000000 + write32 SDGENCNTB, 0x00000032 + cmp_loop SDGENCNTB, 0xFFFFFFFF, 0x00000000 + + write32 SDMRACR0B, 0x00002201 + write32 SDMRB1, 0x00000000 + write32 SDMRACR0B, 0x00000402 + write32 SDMRB1, 0x00000000 + write32 SDMRACR0B, 0x00000403 + write32 SDMRB1, 0x00000000 + write32 SDMRB2, 0x00000000 + write32 SDMRTMPCRB, 0x88800004 + write32 SDMRTMPMSKB, 0x00000004 + write32 RTCORB, 0xA55A0032 + write32 RTCORHB, 0xA55A000C + write32 RTCSRB, 0xA55A2048 + or_write32 SDCR0B, 0x00000800 + or_write32 SDCR1B, 0x00000400 + write32 ZQCCRB, 0xFFF20000 + or_write32 SDPDCR0B, 0x00030000 + write32 DPHYCNT1B, 0xA5390000 + write32 DPHYCNT0B, 0x00001200 + write32 DPHYCNT1B, 0x07CE0000 + write32 DPHYCNT0B, 0x00001247 + cmp_loop DPHYCNT2B, 0xFFFFFFFF, 0x07CE0000 + + and_write32 SDPDCR0B, 0xFFFCFFFF + + write32 FRQCRD, 0x00000B0B + cmp_loop FRQCRD, 0x80000000, 0x00000000 + + bx lr + + .pool + .align 4 diff --git a/boards.cfg b/boards.cfg index 9ef903a..dfd9908 100644 --- a/boards.cfg +++ b/boards.cfg @@ -232,6 +232,7 @@ harmony arm armv7 harmony nvidia seaboard arm armv7 seaboard nvidia tegra2 ventana arm armv7 ventana nvidia tegra2 u8500_href arm armv7 u8500 st-ericsson u8500 +kzm_a9_gt arm armv7 kzm kmc rmobile actux1_4_16 arm ixp actux1 - - actux1:FLASH2X2 actux1_4_32 arm ixp actux1 - - actux1:FLASH2X2,RAM_32MB actux1_8_16 arm ixp actux1 - - actux1:FLASH1X8 diff --git a/include/configs/kzm_a9_gt.h b/include/configs/kzm_a9_gt.h new file mode 100644 index 0000000..48b7afa --- /dev/null +++ b/include/configs/kzm_a9_gt.h @@ -0,0 +1,164 @@ +/* + * Copyright (C) 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * Copyright (C) 2012 Renesas Solutions Corp. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __KZM_A9_GT_H +#define __KZM_A9_GT_H + +#undef DEBUG + +#define CONFIG_ARM_CORTEXA9 1 +#define CONFIG_RMOBILE 1 +#define CONFIG_SH73A0 1 +#define CONFIG_KZM_A9_GT 1 +#define CONFIG_MACH_TYPE MACH_TYPE_KZM9G + +#include <asm/arch/rmobile.h> + +#define CONFIG_ARCH_CPU_INIT 1 +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_BOARD_EARLY_INIT_F 1 +#define CONFIG_L2_OFF 1 + +#include <config_cmd_default.h> +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTARGS "root=/dev/null console=ttySC4,115200" +#define CONFIG_INTEGRATOR 1 +#define CONFIG_ARCH_CINTEGRATOR 1 +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS + +/* MEMORY */ +#define KZM_SDRAM_BASE (0x40000000) +#define PHYS_SDRAM KZM_SDRAM_BASE +#define PHYS_SDRAM_SIZE (512 * 1024 * 1024) +#define CONFIG_NR_DRAM_BANKS (1) + +/* NOR Flash */ +#define KZM_FLASH_BASE (0x00000000) +#define CONFIG_SYS_FLASH_BASE (KZM_FLASH_BASE) +#define CONFIG_SYS_FLASH_CFI_WIDTH (FLASH_CFI_16BIT) +#define CONFIG_SYS_MAX_FLASH_BANKS (1) +#define CONFIG_SYS_MAX_FLASH_SECT (512) + +/* prompt */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 115200 } + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE 1 +#define CONFIG_CONS_SCIF4 1 +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE + +#define CONFIG_SYS_MEMTEST_START (KZM_SDRAM_BASE) +#define CONFIG_SYS_MEMTEST_END \ + (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) +#undef CONFIG_SYS_ALT_MEMTEST +#undef CONFIG_SYS_MEMTEST_SCRATCH +#undef CONFIG_SYS_LOADS_BAUD_CHANGE + +#define CONFIG_SYS_INIT_RAM_ADDR (0xE5600000) /* MERAM */ +#define CONFIG_SYS_INIT_RAM_SIZE (0x00010000) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_SDRAM_BASE KZM_SDRAM_BASE +#define CONFIG_SYS_SDRAM_SIZE PHYS_SDRAM_SIZE +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 32 * 1024 * 1024) + +#define CONFIG_SYS_MONITOR_BASE (KZM_FLASH_BASE) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) +#define CONFIG_SYS_GBL_DATA_SIZE (256) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +#define CONFIG_SYS_TEXT_BASE 0x00000000 +#define CONFIG_STANDALONE_LOAD_ADDR 0x41000000 + +/* FLASH */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#undef CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define FLASH_SECTOR_SIZE (256 * 1024) /* 256 KB sectors */ +#define CONFIG_ENV_SIZE FLASH_SECTOR_SIZE +#define CONFIG_ENV_OFFSET FLASH_SECTOR_SIZE +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) + +/* Timeout for Flash erase operations (in ms) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (3 * 1000) +/* Timeout for Flash write operations (in ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT (3 * 1000) +/* Timeout for Flash set sector lock bit operations (in ms) */ +#define CONFIG_SYS_FLASH_LOCK_TOUT (3 * 1000) +/* Timeout for Flash clear lock bit operations (in ms) */ +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (3 * 1000) + +#undef CONFIG_SYS_FLASH_PROTECTION +#undef CONFIG_SYS_DIRECT_FLASH_TFTP +#define CONFIG_ENV_IS_IN_FLASH + +/* GPIO / PFC */ +#define CONFIG_SH_GPIO_PFC 1 + +/* Clock */ +#define CONFIG_SYS_CLK_FREQ 48000000 +#define CONFIG_SYS_CPU_CLK (1196000000) +#define TMU_CLK_DIVIDER (4) /* 4 (default), 16, 64, 256 or 1024 */ +#define CFG_HZ (1000) +#define CONFIG_SYS_HZ CFG_HZ + +/* Ether */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_SMC911X 1 +#define CONFIG_SMC911X_BASE (0x10000000) +#define CONFIG_SMC911X_32_BIT 1 + +/* I2C */ +#define CONFIG_CMD_I2C 1 +#define CONFIG_SH_I2C 1 +#define CONFIG_HARD_I2C 1 +#define CONFIG_I2C_MULTI_BUS 1 +#define CONFIG_SYS_MAX_I2C_BUS 2 +#define CONFIG_SYS_I2C_MODULE 1 +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SH_I2C_DATA_HIGH 4 +#define CONFIG_SH_I2C_DATA_LOW 5 +#define CONFIG_SH_I2C_CLOCK (41666666) +#define CONFIG_SH_I2C_BASE0 (0xE6820000) +#define CONFIG_SH_I2C_BASE1 (0xE6822000) + +#endif /* __KZM_A9_GT_H */
Hi Nobuhiro,
On Thu, 21 Jun 2012 15:23:39 +0900, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote :
- 512MB DDR2-SDRAM
- Ethernet (SMSC)
- I2C
Board should be also added to MAINTAINERS
- $(call cmd_link_o_target, $(OBJS) $(SOBJS))
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj) .depend
- (C) Copyright 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
- (C) Copyright 2012 Renesas Solutions Corp.
- project.
- MA 02111-1307 USA
- writel(CS0BCR_D, CS0BCR);
- writel(CS4BCR_D, CS4BCR);
- writel(CS0WCR_D, CS0WCR);
- writel(CS4WCR_D, CS4WCR);
- clrsetbits_le32(CMNCR, ~CMNCR_BROMMD, CMNCR_BROMMD);
- clrbits_le32(SMSTPCR1, (SMSTPCR1_CMT0|SMSTPCR1_I2C0));
- clrbits_le32(SRCR1, (SMSTPCR1_CMT0|SMSTPCR1_I2C0));
- clrbits_le32(SMSTPCR3, SMSTPCR3_USB);
- clrbits_le32(SRCR3, SMSTPCR3_USB);
- writel(VCLKCR1_D, VCLKCR1);
- /* Setup SCIF4 / workaround */
- writeb(0x12, PORT32CR);
- writeb(0x22, PORT33CR);
- writeb(0x12, PORT34CR);
- writeb(0x22, PORT35CR);
- sh73a0_pinmux_init();
- /* SCIFA 4 */
- gpio_request(GPIO_FN_SCIFA4_TXD, NULL);
- gpio_request(GPIO_FN_SCIFA4_RXD, NULL);
- gpio_request(GPIO_FN_SCIFA4_RTS_, NULL);
- gpio_request(GPIO_FN_SCIFA4_CTS_, NULL);
- /* Ethernet/SMSC */
- gpio_request(GPIO_PORT224, NULL);
- gpio_direction_input(GPIO_PORT224);
- /* SMSC/USB */
- gpio_request(GPIO_FN_CS4_, NULL);
- /* MMCIF */
- gpio_request(GPIO_FN_MMCCLK0, NULL);
- gpio_request(GPIO_FN_MMCCMD0_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_0_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_1_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_2_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_3_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_4_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_5_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_6_PU, NULL);
- gpio_request(GPIO_FN_MMCD0_7_PU, NULL);
- /* SDHI */
- gpio_request(GPIO_FN_SDHIWP0, NULL);
- gpio_request(GPIO_FN_SDHICD0, NULL);
- gpio_request(GPIO_FN_SDHICMD0, NULL);
- gpio_request(GPIO_FN_SDHICLK0, NULL);
- gpio_request(GPIO_FN_SDHID0_3, NULL);
- gpio_request(GPIO_FN_SDHID0_2, NULL);
- gpio_request(GPIO_FN_SDHID0_1, NULL);
- gpio_request(GPIO_FN_SDHID0_0, NULL);
- gpio_request(GPIO_FN_SDHI0_VCCQ_MC0_ON, NULL);
- gpio_request(GPIO_PORT15, NULL);
- gpio_direction_output(GPIO_PORT15, 1);
- /* I2C */
- gpio_request(GPIO_FN_PORT27_I2C_SCL3, NULL);
- gpio_request(GPIO_FN_PORT28_I2C_SDA3, NULL);
- gd->bd->bi_boot_params = (CONFIG_SYS_SDRAM_BASE + 0x100);
- gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
- int ret = 0;
- ret = smc911x_initialize(0, CONFIG_SMC911X_BASE);
- return ret;
- Copyright (C) 2012 Nobuhiro Iwamatsu nobuhiro.Iwamatsu.yj@renesas.com
- Copyright (C) 2012 Renesas Solutions Corp.
- project.
- MA 02111-1307 USA
- ldr r0, =\addr
- ldr r1, =\data
- ldr r2, =\cmp
+2:
- ldr r3, [r0, #0]
- and r3, r1, r3
- cmp r2, r3
- bne 2b
+.endm
- ldr r4, =\addr
- ldr r5, =\data
- ldr r6, [r4]
- orr r5, r6, r5
- str r5, [r4]
+.endm
- ldr r4, =\addr
- ldr r5, =\data
- ldr r6, [r4]
- and r5, r6, r5
- str r5, [r4]
+.endm
+lowlevel_init:
- ldr r0, =MERAM_BASE
- mov r1, #0x0
- str r1, [r0]
- mrc p15, 0, r0, c0, c0, 5
- ands r0, r0, #0xF
- beq lowlevel_init__
- b wait_interrupt
- .pool
- .align 4
+wait_interrupt:
- ldr r1, =ICCICR
- mov r2, #0x0
- str r2, [r1]
- mov r2, #0xF0
- ldr r1, =ICCPMR
- str r2, [r1]
- ldr r1, =ICCICR
- mov r2, #0x1
- str r2, [r1]
+wait_loop:
- wfi
- ldr r2, [r1, #0xC]
- str r2, [r1, #0x10]
- ldr r2, [r0]
- cmp r2, #0
- movne pc, r2
- b wait_loop
+wait_loop_end:
- .pool
- .align 4
+lowlevel_init__:
- mov r0, #0x200000
+loop0:
- subs r0, r0, #1
- bne loop0
- write16 RWTCSRA0, 0xA507
- .pool
- and_write32 LIFEC_SEC_SRC, 0xFFFFFFE7
- and_write32 SRCR3, 0xFFFF7FFF
- and_write32 SMSTPCR2,0xFFFBFFFF
- and_write32 SRCR2, 0xFFFBFFFF
- write32 PLLECR, 0x00000000
- cmp_loop PLLECR, 0x00000F00, 0x00000000
- cmp_loop FRQCRB, 0x80000000, 0x00000000
- write32 PLL0CR, 0x2D000000
- write32 PLL1CR, 0x17100000
- write32 FRQCRB, 0x96235880
- write32 FLCKCR, 0x0000000B
- and_write32 SMSTPCR0, 0xFFFFFFFD
- and_write32 SRCR0, 0xFFFFFFFD
- write32 SMGPIOTIME, 0x00000514
- write32 SMCMT2TIME, 0x00000514
- write32 SMCPGTIME, 0x00000514
- write32 SMSYSCTIME, 0x00000514
- write32 DVFSCR4, 0x00092000
- write32 DVFSCR5, 0x000000DC
- write32 FRQCRA, 0x0012453C
- write32 FRQCRB, 0x80331350
- write32 FRQCRD, 0x00000B0B
- cmp_loop FRQCRD, 0x80000000, 0x00000000
- write32 PCLKCR, 0x00000003
- write32 VCLKCR1, 0x0000012F
- write32 VCLKCR2, 0x00000119
- write32 VCLKCR3, 0x00000119
- write32 ZBCKCR, 0x00000002
- write32 FLCKCR, 0x00000005
- write32 SD0CKCR, 0x00000080
- write32 SD1CKCR, 0x00000080
- write32 SD2CKCR, 0x00000080
- write32 FSIACKCR, 0x0000003F
- write32 FSIBCKCR, 0x0000003F
- write32 SUBCKCR, 0x00000080
- write32 SPUACKCR, 0x0000000B
- write32 SPUVCKCR, 0x0000000B
- write32 MSUCKCR, 0x0000013F
- write32 HSICKCR, 0x00000080
- write32 MFCK1CR, 0x0000003F
- write32 MFCK2CR, 0x0000003F
- write32 DSITCKCR, 0x00000107
- write32 DSI0PCKCR, 0x00000313
- write32 DSI1PCKCR, 0x0000130D
- write32 DSI0PHYCR, 0x2A800E0E
- write32 PLL0CR, 0x1E000000
- write32 PLL2CR, 0x27000080
- write32 PLL3CR, 0x1D000000
- write32 PLL0STPCR, 0x00080000
- write32 PLL1STPCR, 0x000120C0
- write32 PLL2STPCR, 0x00012000
- write32 PLL3STPCR, 0x00000030
- write32 PLLECR, 0x0000000B
- cmp_loop PLLECR, 0x00000B00, 0x00000B00
- write32 DVFSCR3, 0x000120F0
- write32 MPMODE, 0x00000020
- write32 VREFCR, 0x0000028A
- write32 RMSTPCR0, 0xE4628087
- write32 RMSTPCR1, 0xFFFFFFFF
- write32 RMSTPCR2, 0x53FFFFFF
- write32 RMSTPCR3, 0xFFFFFFFF
- write32 RMSTPCR4, 0x00800D3D
- write32 RMSTPCR5, 0xFFFFF3FF
- write32 SMSTPCR2, 0x00000000
- write32 SRCR2, 0x00040000
- and_write32 PLLECR, 0xFFFFFFF7
- cmp_loop PLLECR, 0x00000800, 0x00000000
- write32 HPBCTRL6, 0x00000001
- cmp_loop HPBCTRL6, 0x00000001, 0x00000001
- write32 FRQCRD, 0x00001414
- or_write32 PLLECR, 0x00000008
- cmp_loop PLLECR, 0x00000800, 0x00000800
- or_write32 DLLCNT0A, 0x00000002
- write32 SDGENCNTA, 0x00000005
- cmp_loop SDGENCNTA, 0xFFFFFFFF, 0x00000000
- write32 SDCR0A, 0xACC90159
- write32 SDCR1A, 0x00010059
- write32 SDWCRC0A, 0x50874114
- write32 SDWCRC1A, 0x33199B37
- write32 SDWCRC2A, 0x008F2313
- write32 SDWCR00A, 0x31020707
- write32 SDWCR01A, 0x0017040A
- write32 SDWCR10A, 0x31020707
- write32 SDWCR11A, 0x0017040A
- write32 SDDRVCR0A, 0x05555555
- write32 SDWCR2A, 0x30000000
- or_write32 SDPCRA, 0x00000080
- cmp_loop SDPCRA, 0x00000080, 0x00000080
- write32 SDGENCNTA, 0x00002710
- write32 SDMRACR0A, 0x0000003F
- write32 SDMRA1, 0x00000000
- write32 SDGENCNTA, 0x000001F4
- write32 SDMRACR0A, 0x0000FF0A
- write32 SDMRA3, 0x00000000
- write32 SDGENCNTA, 0x00000032
- write32 SDMRACR0A, 0x00002201
- write32 SDMRACR0A, 0x00000402
- write32 SDMRACR0A, 0x00000403
- write32 SDMRA2, 0x00000000
- write32 SDMRTMPCRA, 0x88800004
- write32 SDMRTMPMSKA,0x00000004
- write32 RTCORA, 0xA55A0032
- write32 RTCORHA, 0xA55A000C
- write32 RTCSRA, 0xA55A2048
- or_write32 SDCR0A, 0x00000800
- or_write32 SDCR1A, 0x00000400
- write32 ZQCCRA, 0xFFF20000
- or_write32 DLLCNT0B, 0x00000002
- write32 SDGENCNTB, 0x00000005
- cmp_loop SDGENCNTB, 0xFFFFFFFF, 0x00000000
- write32 SDCR0B, 0xACC90159
- write32 SDCR1B, 0x00010059
- write32 SDWCRC0B, 0x50874114
- write32 SDWCRC1B, 0x33199B37
- write32 SDWCRC2B, 0x008F2313
- write32 SDWCR00B, 0x31020707
- write32 SDWCR01B, 0x0017040A
- write32 SDWCR10B, 0x31020707
- write32 SDWCR11B, 0x0017040A
- write32 SDDRVCR0B, 0x05555555
- write32 SDWCR2B, 0x30000000
- or_write32 SDPCRB, 0x00000080
- cmp_loop SDPCRB, 0x00000080, 0x00000080
- write32 SDGENCNTB, 0x00002710
- write32 SDMRACR0B, 0x0000003F
- write32 SDMRB1, 0x00000000
- write32 SDGENCNTB, 0x000001F4
- write32 SDMRACR0B, 0x0000FF0A
- write32 SDMRB3, 0x00000000
- write32 SDGENCNTB, 0x00000032
- write32 SDMRACR0B, 0x00002201
- write32 SDMRACR0B, 0x00000402
- write32 SDMRACR0B, 0x00000403
- write32 SDMRB2, 0x00000000
- write32 SDMRTMPCRB, 0x88800004
- write32 SDMRTMPMSKB, 0x00000004
- write32 RTCORB, 0xA55A0032
- write32 RTCORHB, 0xA55A000C
- write32 RTCSRB, 0xA55A2048
- or_write32 SDCR0B, 0x00000800
- or_write32 SDCR1B, 0x00000400
- write32 ZQCCRB, 0xFFF20000
- or_write32 SDPDCR0B, 0x00030000
- write32 DPHYCNT1B, 0xA5390000
- write32 DPHYCNT0B, 0x00001200
- write32 DPHYCNT1B, 0x07CE0000
- write32 DPHYCNT0B, 0x00001247
- cmp_loop DPHYCNT2B, 0xFFFFFFFF, 0x07CE0000
- and_write32 SDPDCR0B, 0xFFFCFFFF
Can't all this be simplified by using tables?
- bx lr
- .pool
- .align 4
- Copyright (C) 2012 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
- MA 02111-1307 USA
+#undef DEBUG
I think the "1" is unneeded; dito below.
- (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024))
Amicalement,
Hi, Albert.
Thank you for your review.
2012/6/26 Albert ARIBAUD albert.u.boot@aribaud.net:
Hi Nobuhiro,
Oh, I will add .
+clean:
+distclean: clean
- project.
- MA 02111-1307 USA
- /* SCIFA 4 */
- /* SMSC/USB */
- /* MMCIF */
- /* SDHI */
- /* I2C */
- int ret = 0;
- return ret;
- project.
- MA 02111-1307 USA
- ldr r0, =\addr
- ldr r1, =\data
- ldr r2, =\cmp
+2:
- ldr r3, [r0, #0]
- and r3, r1, r3
- cmp r2, r3
- bne 2b
+.endm
- ldr r4, =\addr
- ldr r5, =\data
- ldr r6, [r4]
- orr r5, r6, r5
- str r5, [r4]
+.endm
- ldr r4, =\addr
- ldr r5, =\data
- ldr r6, [r4]
- and r5, r6, r5
- str r5, [r4]
+.endm
+lowlevel_init:
- mov r1, #0x0
- str r1, [r0]
- ands r0, r0, #0xF
- b wait_interrupt
- .pool
- .align 4
+wait_interrupt:
- ldr r1, =ICCICR
- mov r2, #0x0
- str r2, [r1]
- mov r2, #0xF0
- ldr r1, =ICCPMR
- str r2, [r1]
- ldr r1, =ICCICR
- mov r2, #0x1
- str r2, [r1]
+wait_loop:
- wfi
- ldr r2, [r0]
- cmp r2, #0
- movne pc, r2
- b wait_loop
+wait_loop_end:
- .pool
- .align 4
+lowlevel_init__:
- mov r0, #0x200000
+loop0:
- subs r0, r0, #1
- bne loop0
- .pool
I like this style. Because the information of the register is because it can be formed from a data sheet automatically. It is very painful to make a table from a data sheet separately. However, I obey it if a policy of ARM is to use the table.
I will fix this and resend.
- bx lr
- .pool
- .align 4
- MA 02111-1307 USA
+#undef DEBUG
OK, I rewrite config of this board.
- CONFIG_SYS_INIT_RAM_SIZE - \
- GENERATED_GBL_DATA_SIZE)
Best regards, Nobuhiro
Dear Nobuhiro Iwamatsu,
In message CABMQnV+RAOvBXAgnMv9Vo2HYjqZ7uZ2-TOx91qAYNrWX4PQM_Q@mail.gmail.com you wrote:
cmp_loop SDGENCNTB, 0xFFFFFFFF,> 0x00000000
I disagree. You cannot really like this style.
Such a list of completely hard-coded magic numbers, without any comments, is not readable and not maintainable. No programmer can like such code. It is a horrible mess.
I wonder why this is written in assembly at all? Why don't you write all this in C? I cannot see any strong reason that would prevent an implementation in C.
Hi, Wolfgang.
2012/6/27 Wolfgang Denk wd@denx.de:
- cmp_loop SDGENCNTB, 0xFFFFFFFF,> 0x00000000
I agree.
In my case, the portion of initialization of a board is mounted based on a hardware designer's information, and the manual of CPU. Since these are templates in many cases, a transplant is easy. However, it also knows that there are various problems so that you may point out
OK, I will change coding style for sh port and rmobile port.
Albert ARIBAUD
Nobuhiro Iwamatsu
