[PATCH] clk: at91: compat: partially revert "dm: Remove uses of device_bind_offset()"
Revert changes in at91 compat.c that cause u-boot to fail booting on sama5d4_xplained and sama5d2_xplained
Log below:
<debug_uart> No serial driver found Could not initialize timer (err -19)
Fixes: a2703ce10c ("dm: Remove uses of device_bind_offset()") Cc: Simon Glass sjg@chromium.org Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- drivers/clk/at91/compat.c | 20 ++++++++++++-------- 1 file changed, 12 insertions(+), 8 deletions(-)
diff --git a/drivers/clk/at91/compat.c b/drivers/clk/at91/compat.c index e514f26656..dfdc3a6a92 100644 --- a/drivers/clk/at91/compat.c +++ b/drivers/clk/at91/compat.c @@ -62,30 +62,34 @@ static int at91_pmc_core_probe(struct udevice *dev) */ int at91_clk_sub_device_bind(struct udevice *dev, const char *drv_name) { - ofnode parent = dev_ofnode(dev); - ofnode node; + const void *fdt = gd->fdt_blob; + int offset = dev_of_offset(dev); bool pre_reloc_only = !(gd->flags & GD_FLG_RELOC); const char *name; int ret;
- ofnode_for_each_subnode(node, parent) { - if (pre_reloc_only && !ofnode_pre_reloc(node)) + for (offset = fdt_first_subnode(fdt, offset); + offset > 0; + offset = fdt_next_subnode(fdt, offset)) { + if (pre_reloc_only && + !ofnode_pre_reloc(offset_to_ofnode(offset))) continue; /* * If this node has "compatible" property, this is not * a clock sub-node, but a normal device. skip. */ - if (ofnode_read_prop(node, "compatible", NULL)) + fdt_get_property(fdt, offset, "compatible", &ret); + if (ret >= 0) continue;
if (ret != -FDT_ERR_NOTFOUND) return ret;
- name = ofnode_get_name(node); + name = fdt_get_name(fdt, offset, NULL); if (!name) return -EINVAL; - ret = device_bind_driver_to_node(dev, drv_name, name, node, - NULL); + ret = device_bind_driver_to_node(dev, drv_name, name, + offset_to_ofnode(offset), NULL); if (ret) return ret; }
On Tue, 2 Feb 2021 at 01:48, Eugen Hristev eugen.hristev@microchip.com wrote:
Log below:
Nice work.
Log below:
Nice work.
Applied to u-boot-atmel/master
Eugen Hristev
Eugen.Hristev@microchip.com
