[U-Boot-Users] [PATCH] Call ft_board_setup() from the bootm command.
In the patch titled "Create new fdt boardsetup command..." I removed the call to ft_board_setup() from the routine fdt_chosen(), but I forgot to add a direct call back into cmd_bootm.c
This fixes the oversight by adding the direct call to the bootm command.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com ---
Thanks, Timur, for finding the screwup.
gvb
common/cmd_bootm.c | 4 ++++ common/cmd_fdt.c | 7 ------- include/fdt_support.h | 6 ++++++ 3 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index cf5dafd..c8825b6 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -980,6 +980,10 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, do_reset (cmdtp, flag, argc, argv); } #endif +#ifdef CONFIG_OF_BOARD_SETUP + /* Call the board-specific fixup routine */ + ft_board_setup(fdt, gd->bd); +#endif #endif /* CONFIG_OF_LIBFDT */ #if defined(CONFIG_OF_FLAT_TREE) /* move of_flat_tree if needed */ diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index 824088c..9ddec47 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -44,13 +44,6 @@ */ DECLARE_GLOBAL_DATA_PTR;
-/* - * Function prototypes/declarations. - */ -#ifdef CONFIG_OF_BOARD_SETUP -void ft_board_setup(void *blob, bd_t *bd); -#endif - static int fdt_valid(void); static int fdt_parse_prop(char *pathp, char *prop, char *newval, char *data, int *len); diff --git a/include/fdt_support.h b/include/fdt_support.h index a276834..60fa423 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -38,5 +38,11 @@ int fdt_env(void *fdt); int fdt_bd_t(void *fdt); #endif
+#ifdef CONFIG_OF_BOARD_SETUP +void ft_board_setup(void *blob, bd_t *bd); +void ft_cpu_setup(void *blob, bd_t *bd); +void ft_pci_setup(void *blob, bd_t *bd); +#endif + #endif /* ifdef CONFIG_OF_LIBFDT */ #endif /* ifndef __FDT_SUPPORT_H */
Jerry Van Baren
