[U-Boot] [PATCH v2][repost] arm: Kirkwood: add SYSRSTn Duration Counter Support
I am sorry for previous post v2, pls ignore it, this is the right patch for the same
This feature can be used to trigger special command "sysrstcmd" using reset key long press event and environment variable "sysrstdelay" is set (useful for reset to factory or manufacturing mode execution)
Kirkwood SoC implements a hardware-based SYSRSTn duration counter. When SYSRSTn is asserted low, a SYSRSTn duration counter is running. The counter value is stored in the SYSRSTn Length Counter Register The counter is based on the 25-MHz reference clock (40ns) It is a 29-bit counter, yielding a maximum counting duration of 2^29/25 MHz (21.4 seconds). When the counter reach its maximum value, it remains at this value until counter reset is triggered by setting bit 31 of KW_REG_SYSRST_CNT
Implementation: Upon long reset assertion (> ${sysrstdleay} in secs) sysrstcmd will be executed if pre-defined in environment variables. This feature will be disabled if "sysrstdelay" variable is unset.
for-ex. setenv sysrst_cmd "echo starting factory reset; nand erase 0xa0000 0x20000; echo finish ed sysrst command;" will erase particular nand sector if triggered by this event
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- Change log: v2: updated as per review feedback for v1 bug fix in the previous post (V2) fixed
cpu/arm926ejs/kirkwood/cpu.c | 75 +++++++++++++++++++++++++++++++++++ include/asm-arm/arch-kirkwood/cpu.h | 2 + 2 files changed, 77 insertions(+), 0 deletions(-)
diff --git a/cpu/arm926ejs/kirkwood/cpu.c b/cpu/arm926ejs/kirkwood/cpu.c index 795a739..97318ff 100644 --- a/cpu/arm926ejs/kirkwood/cpu.c +++ b/cpu/arm926ejs/kirkwood/cpu.c @@ -195,6 +195,78 @@ int kw_config_mpp(u32 mpp0_7, u32 mpp8_15, u32 mpp16_23, u32 mpp24_31, return 0; }
+/* + * SYSRSTn Duration Counter Support + * + * Kirkwood SoC implements a hardware-based SYSRSTn duration counter. + * When SYSRSTn is asserted low, a SYSRSTn duration counter is running. + * The SYSRSTn duration counter is useful for implementing a manufacturer + * or factory reset. Upon a long reset assertion that is greater than a + * pre-configured environment variable value for sysrstdelay, + * The counter value is stored in the SYSRSTn Length Counter Register + * The counter is based on the 25-MHz reference clock (40ns) + * It is a 29-bit counter, yielding a maximum counting duration of + * 2^29/25 MHz (21.4 seconds). When the counter reach its maximum value, + * it remains at this value until counter reset is triggered by setting + * bit 31 of KW_REG_SYSRST_CNT + */ +static void kw_sysrst_action(void) +{ + int ret; + char *s = getenv("sysrstcmd"); + + if (!s) { + printf("Error.. %s failed, check sysrstcmd\n", + __FUNCTION__); + return; + } + + printf("Starting %s process...\n", __FUNCTION__); +#if !defined(CONFIG_SYS_HUSH_PARSER) + ret = run_command (s, 0); +#else + ret = parse_string_outer(s, FLAG_PARSE_SEMICOLON + | FLAG_EXIT_FROM_LOOP); +#endif + if (ret < 0) + printf("Error.. %s failed\n", __FUNCTION__); + else + printf("%s process finished\n", __FUNCTION__); +} + +static void kw_sysrst_check(void) +{ + u32 sysrst_cnt, sysrst_dly; + char *s; + + /* + * no action if sysrstdelay environment variable is not defined + */ + s = getenv("sysrstdelay"); + if (s == NULL) + return; + + /* read sysrstdelay value */ + sysrst_dly = (u32) simple_strtoul(s, NULL, 10); + + /* read SysRst Length counter register (bits 28:0) */ + sysrst_cnt = (0x1fffffff & readl(KW_REG_SYSRST_CNT)); + printf("H/w Rst hold time: %d.%d secs\n", + sysrst_cnt / SYSRST_CNT_1SEC_VAL, + sysrst_cnt % SYSRST_CNT_1SEC_VAL); + + /* clear the counter for next valid read*/ + writel(1 << 31, KW_REG_SYSRST_CNT); + + /* + * sysrst_action: + * if H/w Reset key is pressed and hold for time + * more than sysrst_dly in seconds + */ + if (sysrst_cnt >= SYSRST_CNT_1SEC_VAL * sysrst_dly) + kw_sysrst_action(); +} + #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { @@ -298,6 +370,9 @@ int arch_misc_init(void) temp = get_cr(); set_cr(temp & ~CR_V);
+ /* checks and execute resset to factory event */ + kw_sysrst_check(); + return 0; } #endif /* CONFIG_ARCH_MISC_INIT */ diff --git a/include/asm-arm/arch-kirkwood/cpu.h b/include/asm-arm/arch-kirkwood/cpu.h index d1440af..b3022a3 100644 --- a/include/asm-arm/arch-kirkwood/cpu.h +++ b/include/asm-arm/arch-kirkwood/cpu.h @@ -36,6 +36,8 @@ ((_x ? KW_EGIGA0_BASE : KW_EGIGA1_BASE) + 0x44c)
#define KW_REG_DEVICE_ID (KW_MPP_BASE + 0x34) +#define KW_REG_SYSRST_CNT (KW_MPP_BASE + 0x50) +#define SYSRST_CNT_1SEC_VAL (25*1000000) #define KW_REG_MPP_OUT_DRV_REG (KW_MPP_BASE + 0xE0)
enum memory_bank {
Dear Prafulla Wadaskar,
This comment does not belong to the commit message. Please move below the "---" line.
That's a typo, it's "sysrstdelay", right? Please fix while we are at it.
- int ret;
- char *s = getenv("sysrstcmd");
- if (!s) {
__FUNCTION__);
return;
Why is this considered an error? I think it is perfectly legal to not define this environment variable. For example, it is also no error to set "bootdelay" and not define "bootcmd". I think we should implement consistent behaviour.
- printf("Starting %s process...\n", __FUNCTION__);
This should be a debug(), I think. Don't produce too much output.
- if (ret < 0)
- else
Ditto - please turn into debug().
- u32 sysrst_cnt, sysrst_dly;
- char *s;
- s = getenv("sysrstdelay");
- if (s == NULL)
return;
- /* read sysrstdelay value */
- sysrst_dly = (u32) simple_strtoul(s, NULL, 10);
- /* read SysRst Length counter register (bits 28:0) */
- sysrst_cnt = (0x1fffffff & readl(KW_REG_SYSRST_CNT));
- printf("H/w Rst hold time: %d.%d secs\n",
This should be debvug(), too ?
Thanks.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Wednesday, August 19, 2009 12:50 PM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ashish Karkare; Prabhanjan Sarnaik; Ronen Shitrit Subject: Re: [U-Boot] [PATCH v2][repost] arm: Kirkwood: add SYSRSTn Duration Counter Support
Okay I will add this in my next post
"sysrstcmd" using
maximum value,
sysrstcmd will be
Thanks.. I will take care
- int ret;
- if (!s) {
__FUNCTION__);
return;
It is similar with one difference- sysrstcmd is additionally gated with h/w trigger, Secondly it is not as known as bootcmd, so it is always better to throw some error message. This save some of developer's time and email exchanges :-)
- if (ret < 0)
- else
Okay no issues..I will do it
- char *s;
- if (s == NULL)
return;
Does it harm if we keep this info? It is just like "cpu name, speed etc". SysRST is a feature provided by h/w that we are supporting, It may help users who are willing to use this feature Any way it is gated by "sysrstdelay" So I think we must keep this print alive
Regards.. Prafulla . .
Thanks.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If a person (a) is poorly, (b) receives treatment intended to make him better, and (c) gets better, then no power of reasoning known to medical science can convince him that it may not have been the treatment that restored his health.
- Sir Peter Medawar, The Art of the Soluble
In message 73173D32E9439E4ABB5151606C3E19E202E391599F@SC-VEXCH1.marvell.com you wrote:
- if (!s) {
__FUNCTION__);
return;
Um... yes... agreed, but that's not actually so special. Consider for example the use of "altbootcmd" in connection with the boot count limit feature, or the "failbootcmd" which gets run in case of critical POST errors. None of these produce any such error messages. For consistency I recommend to remove this message here, too.
Well, for developers it may be useful during test - but it should not be present for regular users of the production version. Maybe you change it into a debug() ?
Well, yes, it does. It adds output, which makes the boot process more noisy and addds to the boot time. And normally none of the end users will actually ever look at this information.
Well, this _is_ information which the end users regularly check and pay attention to.
Really? What is the advantage for the enduser to know if he pressed the button for 5.1 or 5.3 seconds?
Please make it a debug().
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Thursday, August 20, 2009 3:08 PM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ashish Karkare; Prabhanjan Sarnaik; Ronen Shitrit Subject: Re: [U-Boot] [PATCH v2][repost] arm: Kirkwood: add SYSRSTn Duration Counter Support
In message <73173D32E9439E4ABB5151606C3E19E202E391599F@SC-VEXCH1.marvell. com> you wrote:
- if (!s) {
__FUNCTION__);
return;
legal to not
no error to
should implement
Agreed I will do this.
That's understood but only in case sysrstdelay is defined which is not default case :-)
No, I mean it is useful in case of 4.9 or 5.1 :-)
Should I? even though by default it will not show up :-)
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "...this does not mean that some of us should not want, in a rather dispassionate sort of way, to put a bullet through csh's head." - Larry Wall in 1992Aug6.221512.5963@netlabs.com
In message 73173D32E9439E4ABB5151606C3E19E202E39159C0@SC-VEXCH1.marvell.com you wrote:
I don;t see why that should make any difference?
What for? He can see the difference from different behaviour.
If you really feel you want to be verbose you can lard your definitions of bootcmd, altbootcmd, failbootcmd, sysrstcmd, etc. with any number of "echo" commands you like.
But please don't make the default output more verbose than really necessary.
Please do. Keep in mind: No news is good news.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Saturday, August 22, 2009 3:37 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ashish Karkare; Prabhanjan Sarnaik; Ronen Shitrit Subject: Re: [U-Boot] [PATCH v2][repost] arm: Kirkwood: add SYSRSTn Duration Counter Support
<snip..>
Patch v3 is already posted for the same Thanks... Regards. Prafulla . .
ok
but I think make optionnal will be better
Best Regards, J.
-----Original Message----- From: Jean-Christophe PLAGNIOL-VILLARD [mailto:plagnioj@jcrosoft.com] Sent: Thursday, August 20, 2009 4:00 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ashish Karkare; Prabhanjan Sarnaik; Ronen Shitrit Subject: Re: [U-Boot] [PATCH v2][repost] arm: Kirkwood: add SYSRSTn Duration Counter Support
"sysrstcmd" using
maximum value,
sysrstcmd will be
ok
Hi Jean Thanks.. I didn't understod what you want to say here, can you pls explain?
Best Regards, J.
ok
the patch is fine for I but I think we may create a CONFIG_ somethink to enable it only if the use want it and do not impact the U-Boot size otherwise
Best Regards, J.
-----Original Message----- From: Jean-Christophe PLAGNIOL-VILLARD [mailto:plagnioj@jcrosoft.com] Sent: Thursday, August 20, 2009 10:50 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ashish Karkare; Prabhanjan Sarnaik; Ronen Shitrit Subject: Re: [U-Boot] [PATCH v2][repost] arm: Kirkwood: add SYSRSTn Duration Counter Support
ok
Okay I got it WE can do this but, There are just two APIs, overall size impact is not much (<100 bytes max). And this is very useful feature. So can we make it by default enabled?
Regards... Prafulla ..
Best Regards, J.
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Prafulla Wadaskar Sent: Thursday, August 20, 2009 3:16 PM To: Jean-Christophe PLAGNIOL-VILLARD Cc: u-boot@lists.denx.de; Ashish Karkare; Prabhanjan Sarnaik; Ronen Shitrit Subject: Re: [U-Boot] [PATCH v2][repost] arm: Kirkwood: add SYSRSTn Duration Counter Support
ok
somethink
U-Boot size
otherwise
The actual u-boot.bin size diff for newly posted patch is (169464- 169344= 120 bytes)
ok fine
Best Regards, J.
Prafulla Wadaskar
