[U-Boot] [PATCH 1/2] common: Log should depends on DM not be selected by DM
Better use depends on instead of select.
I found this in connection to setup imply CMD_DM and it seems to not standard that it is selecting DM which is not used anywhere else.
--- common/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/Kconfig b/common/Kconfig index 4c7a1a9af865..cb17911e1681 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -424,7 +424,7 @@ menu "Logging"
config LOG bool "Enable logging support" - select DM + depends on DM help This enables support for logging of status and debug messages. These can be displayed on the console, recorded in a memory buffer, or
CMD_DM is used for debug purpose and it shouldn't be enabled by default via Kconfig. Unfortunately this is in the tree for quite a long time that's why solution is to use imply DM for all targets which are enabling DM.
Based on this discussion: https://lists.denx.de/pipermail/u-boot/2018-July/334952.html
Done by: for i in `git grep "select DM" | grep -v DM_ | cut -d ':' -f 1 | sort | uniq`; do sed -i 's/select DM$/select DM\n\timply CMD_DM/g' $i; done
And checked by for i in `ls configs/*`; do NAME=`basename $i`; echo $NAME; make $NAME; make savedefconfig; cp defconfig $i; done
--- arch/Kconfig | 3 +++ arch/arm/Kconfig | 25 +++++++++++++++++++++++++ arch/arm/mach-at91/Kconfig | 6 ++++++ arch/arm/mach-imx/mx5/Kconfig | 2 ++ arch/arm/mach-imx/mx6/Kconfig | 26 ++++++++++++++++++++++++++ arch/arm/mach-imx/mx7/Kconfig | 5 +++++ arch/arm/mach-meson/Kconfig | 2 ++ arch/arm/mach-omap2/am33xx/Kconfig | 18 ++++++++++++++++++ arch/arm/mach-omap2/omap3/Kconfig | 10 ++++++++++ arch/arm/mach-rmobile/Kconfig.32 | 8 ++++++++ arch/arm/mach-tegra/Kconfig | 1 + arch/microblaze/Kconfig | 1 + arch/mips/Kconfig | 6 ++++++ arch/powerpc/cpu/mpc83xx/Kconfig | 1 + cmd/Kconfig | 1 - 15 files changed, 114 insertions(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index dd5a8870017f..4b1265cb5331 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -49,6 +49,7 @@ config NIOS2 select SUPPORT_OF_CONTROL select OF_CONTROL select DM + imply CMD_DM select CPU
config PPC @@ -67,6 +68,7 @@ config SANDBOX select BOARD_LATE_INIT select SUPPORT_OF_CONTROL select DM + imply CMD_DM select DM_KEYBOARD select DM_SPI_FLASH select DM_SERIAL @@ -102,6 +104,7 @@ config X86 select SUPPORT_OF_CONTROL select OF_CONTROL select DM + imply CMD_DM select DM_PCI select PCI select TIMER diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 64d58a624182..86c01afa58a3 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -436,6 +436,7 @@ config ARCH_MVEBU select OF_CONTROL select OF_SEPARATE select DM + imply CMD_DM select DM_ETH select DM_SERIAL select DM_SPI @@ -493,6 +494,7 @@ config TARGET_STV0991 bool "Support stv0991" select CPU_V7A select DM + imply CMD_DM select DM_SERIAL select DM_SPI select DM_SPI_FLASH @@ -528,6 +530,7 @@ config TARGET_MX35PDK config ARCH_BCM283X bool "Broadcom BCM283X family" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select OF_CONTROL @@ -546,6 +549,7 @@ config ARCH_BCMSTB bool "Broadcom BCM7XXX family" select CPU_V7A select DM + imply CMD_DM select OF_CONTROL select OF_PRIOR_STAGE help @@ -600,6 +604,7 @@ config TARGET_BCMNS2 config ARCH_EXYNOS bool "Samsung EXYNOS" select DM + imply CMD_DM select DM_I2C select DM_SPI_FLASH select DM_SERIAL @@ -613,6 +618,7 @@ config ARCH_S5PC1XX bool "Samsung S5PC1XX" select CPU_V7A select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select DM_I2C @@ -625,6 +631,7 @@ config ARCH_HIGHBANK config ARCH_INTEGRATOR bool "ARM Ltd. Integrator family" select DM + imply CMD_DM select DM_SERIAL select PL01X_SERIAL
@@ -659,6 +666,7 @@ config ARCH_MX8M bool "NXP i.MX8M platform" select ARM64 select DM + imply CMD_DM select SUPPORT_SPL
config ARCH_MX23 @@ -722,12 +730,14 @@ config ARCH_OWL bool "Actions Semi OWL SoCs" select ARM64 select DM + imply CMD_DM select DM_SERIAL select OF_CONTROL
config ARCH_QEMU bool "QEMU Virtual Platform" select DM + imply CMD_DM select DM_SERIAL select OF_CONTROL select PL01X_SERIAL @@ -735,6 +745,7 @@ config ARCH_QEMU config ARCH_RMOBILE bool "Renesas ARM SoCs" select DM + imply CMD_DM select DM_SERIAL select BOARD_EARLY_INIT_F imply FAT_WRITE @@ -749,6 +760,7 @@ config ARCH_SNAPDRAGON bool "Qualcomm Snapdragon SoCs" select ARM64 select DM + imply CMD_DM select DM_GPIO select DM_SERIAL select SPMI @@ -761,6 +773,7 @@ config ARCH_SOCFPGA select ARCH_MISC_INIT select CPU_V7A if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select DM + imply CMD_DM select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select OF_CONTROL @@ -796,6 +809,7 @@ config ARCH_SUNXI select CMD_MMC if MMC select CMD_USB if DISTRO_DEFAULTS select DM + imply CMD_DM select DM_ETH select DM_GPIO select DM_KEYBOARD @@ -845,6 +859,7 @@ config ARCH_ZYNQ select BOARD_EARLY_INIT_F if WDT select SPL_OF_CONTROL if SPL select DM + imply CMD_DM select DM_ETH if NET select SPL_DM if SPL select DM_MMC if MMC @@ -867,6 +882,7 @@ config ARCH_ZYNQMP_R5 select CPU_V7R select OF_CONTROL select DM + imply CMD_DM select DM_SERIAL select CLK
@@ -875,6 +891,7 @@ config ARCH_ZYNQMP select ARM64 select BOARD_LATE_INIT select DM + imply CMD_DM select OF_CONTROL select DM_SERIAL select SUPPORT_SPL @@ -1003,6 +1020,7 @@ config TARGET_HIKEY bool "Support HiKey 96boards Consumer Edition Platform" select ARM64 select DM + imply CMD_DM select DM_GPIO select DM_SERIAL select OF_CONTROL @@ -1016,6 +1034,7 @@ config TARGET_POPLAR bool "Support Poplar 96boards Enterprise Edition Platform" select ARM64 select DM + imply CMD_DM select OF_CONTROL select DM_SERIAL select DM_USB @@ -1215,6 +1234,7 @@ config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_GPIO select DM_I2C select DM_MMC @@ -1240,6 +1260,7 @@ config STM32 bool "Support STMicroelectronics STM32 MCU with cortex M" select CPU_V7M select DM + imply CMD_DM select DM_SERIAL select SYS_THUMB_BUILD
@@ -1247,6 +1268,7 @@ config ARCH_STI bool "Support STMicrolectronics SoCs" select CPU_V7A select DM + imply CMD_DM select DM_SERIAL select BLK select DM_MMC @@ -1261,6 +1283,7 @@ config ARCH_STM32MP select BOARD_LATE_INIT select CLK select DM + imply CMD_DM select DM_GPIO select DM_RESET select DM_SERIAL @@ -1284,6 +1307,7 @@ config ARCH_ROCKCHIP select OF_CONTROL select BLK select DM + imply CMD_DM select SPL_DM if SPL select SYS_MALLOC_F select SYS_THUMB_BUILD if !ARM64 @@ -1319,6 +1343,7 @@ config ARCH_ASPEED bool "Support Aspeed SoCs" select OF_CONTROL select DM + imply CMD_DM
endchoice
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index ce6be3829afe..a7274489cebf 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -76,6 +76,7 @@ config TARGET_SNAPPER9260 bool "Support snapper9260" select AT91SAM9260 select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -84,6 +85,7 @@ config TARGET_GURNARD select AT91SAM9G45 select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_SPI select DM_GPIO @@ -206,6 +208,7 @@ config TARGET_CORVUS select AT91SAM9M10G45 select SUPPORT_SPL select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select DM_ETH @@ -215,6 +218,7 @@ config TARGET_TAURUS select AT91SAM9G20 select SUPPORT_SPL select DM + imply CMD_DM select DM_SERIAL select DM_SPI select DM_GPIO @@ -226,6 +230,7 @@ config TARGET_SMARTWEB select AT91SAM9260 select SUPPORT_SPL select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select DM_ETH @@ -235,6 +240,7 @@ config TARGET_VINCO select SAMA5D4 select SUPPORT_SPL select DM + imply CMD_DM select DM_SPI select SPI
diff --git a/arch/arm/mach-imx/mx5/Kconfig b/arch/arm/mach-imx/mx5/Kconfig index 3654670442fb..e12af6f0b541 100644 --- a/arch/arm/mach-imx/mx5/Kconfig +++ b/arch/arm/mach-imx/mx5/Kconfig @@ -23,6 +23,7 @@ config TARGET_KP_IMX53 select BOARD_LATE_INIT select MX53 select DM + imply CMD_DM select DM_SERIAL select DM_ETH select DM_I2C @@ -43,6 +44,7 @@ config TARGET_MX53CX9020 select BOARD_LATE_INIT select MX53 select DM + imply CMD_DM select DM_SERIAL
config TARGET_MX53EVK diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 521fad74b5a2..df5b16a0f3d5 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -62,6 +62,7 @@ config MX6UL_LITESOM bool select MX6UL select DM + imply CMD_DM select DM_THERMAL select SUPPORT_SPL
@@ -70,6 +71,7 @@ config MX6UL_OPOS6UL select MX6UL select BOARD_LATE_INIT select DM + imply CMD_DM select DM_GPIO select DM_MMC select DM_THERMAL @@ -108,6 +110,7 @@ config TARGET_APALIS_IMX6 select BOARD_LATE_INIT select SUPPORT_SPL select DM + imply CMD_DM select DM_SERIAL select DM_THERMAL imply CMD_SATA @@ -129,6 +132,7 @@ config TARGET_CGTQMX6EVAL select BOARD_LATE_INIT select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL
config TARGET_CM_FX6 @@ -137,6 +141,7 @@ config TARGET_CM_FX6 select MX6QDL select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -145,6 +150,7 @@ config TARGET_COLIBRI_IMX6 select BOARD_LATE_INIT select SUPPORT_SPL select DM + imply CMD_DM select DM_SERIAL select DM_THERMAL
@@ -155,6 +161,7 @@ config TARGET_DHCOMIMX6 select BOARD_EARLY_INIT_F select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL imply CMD_SPL
@@ -162,6 +169,7 @@ config TARGET_DISPLAY5 bool "LWN DISPLAY5 board" select SUPPORT_SPL select DM + imply CMD_DM select DM_SERIAL
config TARGET_EMBESTMX6BOARDS @@ -201,6 +209,7 @@ config TARGET_MX6LOGICPD select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select DM + imply CMD_DM select DM_ETH select DM_GPIO select DM_I2C @@ -226,6 +235,7 @@ config TARGET_MX6DL_MAMOJ select OF_CONTROL select PINCTRL select DM + imply CMD_DM select DM_ETH select DM_GPIO select DM_I2C @@ -258,6 +268,7 @@ config TARGET_MX6Q_ENGICAM select OF_CONTROL select SPL_OF_LIBFDT select DM + imply CMD_DM select DM_ETH select DM_GPIO select DM_I2C @@ -275,6 +286,7 @@ config TARGET_MX6SABREAUTO select BOARD_LATE_INIT select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL select BOARD_EARLY_INIT_F
@@ -284,6 +296,7 @@ config TARGET_MX6SABRESD select BOARD_LATE_INIT select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL select BOARD_EARLY_INIT_F
@@ -297,6 +310,7 @@ config TARGET_MX6SLLEVK select BOARD_LATE_INIT select MX6SLL select DM + imply CMD_DM select DM_THERMAL
config TARGET_MX6SXSABRESD @@ -305,6 +319,7 @@ config TARGET_MX6SXSABRESD select MX6SX select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL select BOARD_EARLY_INIT_F
@@ -313,6 +328,7 @@ config TARGET_MX6SXSABREAUTO select BOARD_LATE_INIT select MX6SX select DM + imply CMD_DM select DM_THERMAL select BOARD_EARLY_INIT_F
@@ -321,6 +337,7 @@ config TARGET_MX6UL_9X9_EVK select BOARD_LATE_INIT select MX6UL select DM + imply CMD_DM select DM_THERMAL select SUPPORT_SPL
@@ -329,6 +346,7 @@ config TARGET_MX6UL_14X14_EVK bool "mx6ul_14x14_evk" select MX6UL select DM + imply CMD_DM select DM_THERMAL select SUPPORT_SPL
@@ -338,6 +356,7 @@ config TARGET_MX6UL_ENGICAM select MX6UL select OF_CONTROL select DM + imply CMD_DM select DM_ETH select DM_GPIO select DM_I2C @@ -354,6 +373,7 @@ config TARGET_MX6ULL_14X14_EVK select BOARD_LATE_INIT select MX6ULL select DM + imply CMD_DM select DM_THERMAL
config TARGET_NITROGEN6X @@ -420,6 +440,7 @@ config TARGET_KP_IMX6Q_TPC select BOARD_EARLY_INIT_F select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL imply CMD_SPL
@@ -439,6 +460,7 @@ config TARGET_UDOO_NEO select SUPPORT_SPL select MX6SX select DM + imply CMD_DM select DM_THERMAL
config TARGET_SAMTEC_VINING_2000 @@ -446,6 +468,7 @@ config TARGET_SAMTEC_VINING_2000 select BOARD_LATE_INIT select MX6SX select DM + imply CMD_DM select DM_THERMAL
config TARGET_WANDBOARD @@ -464,6 +487,7 @@ config TARGET_XPRESS select BOARD_LATE_INIT select MX6UL select DM + imply CMD_DM select DM_THERMAL select SUPPORT_SPL
@@ -472,6 +496,7 @@ config TARGET_ZC5202 select BOARD_LATE_INIT select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL
config TARGET_ZC5601 @@ -479,6 +504,7 @@ config TARGET_ZC5601 select BOARD_LATE_INIT select SUPPORT_SPL select DM + imply CMD_DM select DM_THERMAL
endchoice diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach-imx/mx7/Kconfig index 2a3db860bbcf..88b49e4725d3 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -24,6 +24,7 @@ config TARGET_CL_SOM_IMX7 bool "CL-SOM-iMX7" select MX7D select DM + imply CMD_DM select DM_THERMAL select SUPPORT_SPL
@@ -32,6 +33,7 @@ config TARGET_MX7DSABRESD select BOARD_LATE_INIT select MX7D select DM + imply CMD_DM select DM_THERMAL
config TARGET_PICO_IMX7D @@ -39,6 +41,7 @@ config TARGET_PICO_IMX7D select BOARD_LATE_INIT select MX7D select DM + imply CMD_DM select DM_THERMAL
config TARGET_WARP7 @@ -46,12 +49,14 @@ config TARGET_WARP7 select BOARD_LATE_INIT select MX7D select DM + imply CMD_DM select DM_THERMAL
config TARGET_COLIBRI_IMX7 bool "Support Colibri iMX7S/iMX7D modules" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_THERMAL
diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index 9a06ccc8610e..7e06a49ee7ba 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -5,6 +5,7 @@ config MESON_GXBB select ARM64 select CLK select DM + imply CMD_DM select DM_SERIAL help The Amlogic Meson GXBaby (S905) is an ARM SoC with a @@ -15,6 +16,7 @@ config MESON_GXL select ARM64 select CLK select DM + imply CMD_DM select DM_SERIAL help The Amlogic Meson GXL (S905X and S905X) is an ARM SoC with a diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 76da6d911ed6..5322bc7fc23d 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -31,6 +31,7 @@ config TARGET_AM335X_EVM bool "Support am335x_evm" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select TI_I2C_BOARD_DETECT @@ -65,6 +66,7 @@ config TARGET_AM335X_BALTOS bool "Support am335x_baltos" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -72,6 +74,7 @@ config TARGET_AM335X_IGEP003X bool "Support am335x_igep003x" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -79,6 +82,7 @@ config TARGET_AM335X_SHC bool "Support am335x based shc board from bosch" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO imply CMD_SPL @@ -87,6 +91,7 @@ config TARGET_AM335X_SL50 bool "Support am335x_sl50" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -94,6 +99,7 @@ config TARGET_BAV335X bool "Support bav335x" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL help The BAV335x OEM Network Processor integrates all the functions of an @@ -117,11 +123,13 @@ config TARGET_CHILIBOARD select AM33XX_CHILISOM select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL
config TARGET_CM_T335 bool "Support cm_t335" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -129,6 +137,7 @@ config TARGET_DRACO bool "Support draco" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -136,24 +145,28 @@ config TARGET_ETAMIN bool "Support etamin" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
config TARGET_PCM051 bool "Support pcm051" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
config TARGET_PENGWYN bool "Support pengwyn" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
config TARGET_PEPPER bool "Support pepper" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -161,6 +174,7 @@ config TARGET_PXM2 bool "Support pxm2" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -168,6 +182,7 @@ config TARGET_RASTABAN bool "Support rastaban" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -175,6 +190,7 @@ config TARGET_RUT bool "Support rut" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -182,12 +198,14 @@ config TARGET_THUBAN bool "Support thuban" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
config TARGET_PDU001 bool "Support PDU001" select DM + imply CMD_DM select DM_SERIAL help Support for PDU001 platform developed by EETS GmbH. diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index 6d714f6cdb2c..05daceebd1b7 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -23,6 +23,7 @@ choice config TARGET_AM3517_EVM bool "AM3517 EVM" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select DM_I2C @@ -36,6 +37,7 @@ config TARGET_MT_VENTOUX config TARGET_OMAP3_BEAGLE bool "TI OMAP3 BeagleBoard" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select OMAP3_GPIO_5 @@ -56,12 +58,14 @@ config TARGET_CM_T3517 config TARGET_DEVKIT8000 bool "TimLL OMAP3 Devkit8000" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
config TARGET_OMAP3_EVM bool "TI OMAP3 EVM" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select OMAP3_GPIO_3 @@ -69,6 +73,7 @@ config TARGET_OMAP3_EVM config TARGET_OMAP3_IGEP00X0 bool "IGEP" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select OMAP3_GPIO_3 @@ -78,6 +83,7 @@ config TARGET_OMAP3_IGEP00X0 config TARGET_OMAP3_OVERO bool "OMAP35xx Gumstix Overo" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select OMAP3_GPIO_2 @@ -89,6 +95,7 @@ config TARGET_OMAP3_OVERO config TARGET_OMAP3_ZOOM1 bool "TI Zoom1" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
@@ -118,6 +125,7 @@ config TARGET_OMAP3_LOGIC bool "OMAP3 Logic" select BOARD_LATE_INIT select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select OMAP3_GPIO_3 @@ -143,12 +151,14 @@ config TARGET_TWISTER config TARGET_OMAP3_CAIRO bool "QUIPOS CAIRO" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO
config TARGET_SNIPER bool "LG Optimus Black" select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select OMAP3_GPIO_2 diff --git a/arch/arm/mach-rmobile/Kconfig.32 b/arch/arm/mach-rmobile/Kconfig.32 index c0b5b2457cb1..f4493ebd0b3a 100644 --- a/arch/arm/mach-rmobile/Kconfig.32 +++ b/arch/arm/mach-rmobile/Kconfig.32 @@ -40,12 +40,14 @@ config TARGET_ARMADILLO_800EVA config TARGET_BLANCHE bool "Blanche board" select DM + imply CMD_DM select DM_SERIAL select USE_TINY_PRINTF
config TARGET_GOSE bool "Gose board" select DM + imply CMD_DM select DM_SERIAL select SUPPORT_SPL select USE_TINY_PRINTF @@ -54,6 +56,7 @@ config TARGET_GOSE config TARGET_KOELSCH bool "Koelsch board" select DM + imply CMD_DM select DM_SERIAL select SUPPORT_SPL select USE_TINY_PRINTF @@ -62,6 +65,7 @@ config TARGET_KOELSCH config TARGET_LAGER bool "Lager board" select DM + imply CMD_DM select DM_SERIAL select SUPPORT_SPL select USE_TINY_PRINTF @@ -73,6 +77,7 @@ config TARGET_KZM9G config TARGET_ALT bool "Alt board" select DM + imply CMD_DM select DM_SERIAL select SUPPORT_SPL select USE_TINY_PRINTF @@ -81,6 +86,7 @@ config TARGET_ALT config TARGET_SILK bool "Silk board" select DM + imply CMD_DM select DM_SERIAL select SUPPORT_SPL select USE_TINY_PRINTF @@ -89,6 +95,7 @@ config TARGET_SILK config TARGET_PORTER bool "Porter board" select DM + imply CMD_DM select DM_SERIAL select SUPPORT_SPL select USE_TINY_PRINTF @@ -97,6 +104,7 @@ config TARGET_PORTER config TARGET_STOUT bool "Stout board" select DM + imply CMD_DM select DM_SERIAL select SUPPORT_SPL select USE_TINY_PRINTF diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 0fb0c6339018..7dcf2199c50c 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -24,6 +24,7 @@ config TEGRA_COMMON bool "Tegra common options" select CLK select DM + imply CMD_DM select DM_ETH select DM_GPIO select DM_I2C diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index c56459345136..ca5dbe8b2ad1 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -14,6 +14,7 @@ config TARGET_MICROBLAZE_GENERIC select SUPPORT_SPL select OF_CONTROL select DM + imply CMD_DM select DM_SERIAL select SYSRESET
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index d07b92d1b442..c66fa2198e17 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -25,6 +25,7 @@ config TARGET_QEMU_MIPS config TARGET_MALTA bool "Support malta" select DM + imply CMD_DM select DM_SERIAL select DYNAMIC_IO_PORT_BASE select MIPS_CM @@ -74,11 +75,13 @@ config ARCH_ATH79 bool "Support QCA/Atheros ath79" select OF_CONTROL select DM + imply CMD_DM
config ARCH_BMIPS bool "Support BMIPS SoCs" select OF_CONTROL select DM + imply CMD_DM select CLK select CPU select RAM @@ -88,10 +91,12 @@ config MACH_PIC32 bool "Support Microchip PIC32" select OF_CONTROL select DM + imply CMD_DM
config TARGET_BOSTON bool "Support Boston" select DM + imply CMD_DM select DM_SERIAL select OF_CONTROL select MIPS_CM @@ -112,6 +117,7 @@ config TARGET_XILFPGA bool "Support Imagination Xilfpga" select OF_CONTROL select DM + imply CMD_DM select DM_SERIAL select DM_GPIO select DM_ETH diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index 05d29d2fd95f..f37223d7656f 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -64,6 +64,7 @@ config TARGET_MPC837XERDB config TARGET_IDS8313 bool "Support ids8313" select DM + imply CMD_DM
config TARGET_KM8360 bool "Support km8360" diff --git a/cmd/Kconfig b/cmd/Kconfig index 2fa0829925c1..44a1bc569f70 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -640,7 +640,6 @@ config CMD_DFU config CMD_DM bool "dm - Access to driver model information" depends on DM - default y help Provides access to driver model data structures and information, such as a list of devices, list of uclasses and the state of each
OK, I'm glad you did this, but now the (mostly) sorted lists are un-sorted. Please update to keep them alphabetically sorted, thanks!
How this should be sorted? sorted "select" list first followed by sorted "imply" list?
Thanks, Michal
Yes, that's approximately how I've been doing it. It won't be 100% sorted as some arches aren't, but it should be close. Thanks again!
Ok. Patches sent. I have done some sorting before this patch.
Thanks, Michal
Michal Simek
