[U-Boot] [PULL] please pull u-boot-atmel/master
Dear Albert Aribaud,
please pull the following changes from u-boot-atmel/master into u-boot-arm/master.
The following changes since commit d0a51373131c4ba565a2391d5ed78b87c406ce98:
at91sam9260ek: move board id setup to config header (2013-05-12 16:49:14 +0200)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to 5ba444f092ae9f68a0bd1f53956be2e69d26cf61:
ARM: at91: add NAND partition table and index (2013-05-21 11:54:21 +0200)
---------------------------------------------------------------- Bo Shen (6): ARM: at91: add Atmel sama5d3 SoC new pmc register USB: ohci-at91: support sama5d3x devices ARM: atmel: add sama5d3xek support ARM: at91: fix and update README.at91 document ARM: at91: add at91sam9x5 and sama5d3x information ARM: at91: add NAND partition table and index
MAINTAINERS | 1 + arch/arm/cpu/armv7/at91/Makefile | 52 +++++ arch/arm/cpu/armv7/at91/clock.c | 125 ++++++++++++ arch/arm/cpu/armv7/at91/cpu.c | 90 +++++++++ arch/arm/cpu/armv7/at91/reset.c | 47 +++++ arch/arm/cpu/armv7/at91/sama5d3_devices.c | 196 ++++++++++++++++++ arch/arm/cpu/armv7/at91/timer.c | 139 +++++++++++++ arch/arm/include/asm/arch-at91/at91_dbu.h | 4 + arch/arm/include/asm/arch-at91/at91_pmc.h | 23 +++ arch/arm/include/asm/arch-at91/clk.h | 1 + arch/arm/include/asm/arch-at91/hardware.h | 2 + arch/arm/include/asm/arch-at91/sama5d3.h | 212 ++++++++++++++++++++ arch/arm/include/asm/arch-at91/sama5d3_smc.h | 79 ++++++++ board/atmel/sama5d3xek/Makefile | 51 +++++ board/atmel/sama5d3xek/sama5d3xek.c | 275 ++++++++++++++++++++++++++ boards.cfg | 3 + doc/README.at91 | 84 ++++++-- drivers/usb/host/ohci-at91.c | 14 +- include/configs/sama5d3xek.h | 245 +++++++++++++++++++++++ 19 files changed, 1624 insertions(+), 19 deletions(-) create mode 100644 arch/arm/cpu/armv7/at91/Makefile create mode 100644 arch/arm/cpu/armv7/at91/clock.c create mode 100644 arch/arm/cpu/armv7/at91/cpu.c create mode 100644 arch/arm/cpu/armv7/at91/reset.c create mode 100644 arch/arm/cpu/armv7/at91/sama5d3_devices.c create mode 100644 arch/arm/cpu/armv7/at91/timer.c create mode 100644 arch/arm/include/asm/arch-at91/sama5d3.h create mode 100644 arch/arm/include/asm/arch-at91/sama5d3_smc.h create mode 100644 board/atmel/sama5d3xek/Makefile create mode 100644 board/atmel/sama5d3xek/sama5d3xek.c create mode 100644 include/configs/sama5d3xek.h
Hi Andreas,
On Tue, 21 May 2013 11:59:26 +0200, Andreas Bießmann andreas.devel@googlemail.com wrote:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Andreas Bießmann
