[PATCH v2 0/2] dfu: sf: fix flash probe when DM_SPI_FLASH is enabled
With DM_SPI_FLASH is enabled, the code uses the legacy SPI FLASH code leading to probable errors since it doesn't use speed and mode provided by DT.
This adds the DM functions as dummy inline functions to add both legacy and DM support in DFU sf code avoiding using #if/#else conditionals.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- Changes in v2: - switch to if(IS_ENABLED()) - add SPI FLASH DM functions as dummy inline functions - Link to v1: https://lore.kernel.org/r/20240917-uboot-topic-dfu-sf-dt-v1-1-8cf38451eea4@l...
--- Neil Armstrong (2): spi: add DM_SPI_FLASH compatibility inline functions dfu: sf: rely on DT for spi speed and mode
drivers/dfu/dfu_sf.c | 16 +++++++++++++++- include/spi_flash.h | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 49 insertions(+), 1 deletion(-) --- base-commit: 19dbc09405d3503ce3efef3c2e4b4f0f1a03372d change-id: 20240917-uboot-topic-dfu-sf-dt-8ae62e5c7d79
To smoothly handle the transition from the legacy SPI FLASH API to the the driver model API, add the DM functions as dummy inline functions.
Today, client code uses #if/#else conditionals, but it's better to use if(IS_ENABLED()) to make sure all code builds fine and avoid configuration hell, leaving the compiler remove the dead code.
An example is cmd/sf, which could make use of those dummy functions to drop the conditional compilation.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- include/spi_flash.h | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/include/spi_flash.h b/include/spi_flash.h index 10d19fd4b11..2e703e85250 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -139,6 +139,40 @@ int sandbox_sf_bind_emul(struct sandbox_state *state, int busnum, int cs, void sandbox_sf_unbind_emul(struct sandbox_state *state, int busnum, int cs);
#else +/* Compatibility functions for when DM_SPI_FLASH is disabled */ +static inline int spi_flash_probe_bus_cs(unsigned int busnum, unsigned int cs, + struct udevice **devp) +{ + return -ENODEV; +} + +static inline int spi_flash_read_dm(struct udevice *dev, u32 offset, size_t len, + void *buf) +{ + return -ENODEV; +} + +static inline int spi_flash_write_dm(struct udevice *dev, u32 offset, size_t len, + const void *buf) +{ + return -ENODEV; +} + +static inline int spi_flash_erase_dm(struct udevice *dev, u32 offset, size_t len) +{ + return -ENODEV; +} + +static inline int spl_flash_get_sw_write_prot(struct udevice *dev) +{ + return -ENODEV; +} + +static inline int spi_flash_std_probe(struct udevice *dev) +{ + return -ENODEV; +} + struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode);
Hi Neil,
Thank you for the patch.
On mar., oct. 01, 2024 at 18:06, Neil Armstrong neil.armstrong@linaro.org wrote:
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
- return -ENODEV;
void *buf)
- return -ENODEV;
const void *buf)
- return -ENODEV;
- return -ENODEV;
- return -ENODEV;
- return -ENODEV;
-- 2.34.1
Hi Jagan, Vignesh,
I'd like to submit this through u-boot-dfu but before that i'd prefer to have an Acked-by from one of you.
Any opinion on this ?
Thank you for your time!
- return -ENODEV;
void *buf)
- return -ENODEV;
const void *buf)
- return -ENODEV;
- return -ENODEV;
- return -ENODEV;
- return -ENODEV;
-- 2.34.1
Align with cmd_sf, and try to rely on DT for spi speed and mode, and still fallback on spi_flash_probe() if it fails.
With the current scheme, spi_flash_probe() will be called with CONFIG_SF_DEFAULT_SPEED and CONFIG_SF_DEFAULT_MODE with are set to 0 by default on DT platforms using DM_SPI_FLASH.
Like cmd_sf, keep the option to specify the speed and mode from the dfu_alt_mode string, but rely on DT properties if not specified.
Using CONFIG_SF_DEFAULT_SPEED and CONFIG_SF_DEFAULT_MODE makes the SPIFC controller on Amlogic Meson G12B & SM1 hardware fail and is unable to recover until a system reboot.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/dfu/dfu_sf.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/drivers/dfu/dfu_sf.c b/drivers/dfu/dfu_sf.c index 7c1c0f9e2dc..8f7296adec6 100644 --- a/drivers/dfu/dfu_sf.c +++ b/drivers/dfu/dfu_sf.c @@ -123,6 +123,7 @@ static struct spi_flash *parse_dev(char *devstr) unsigned int mode = CONFIG_SF_DEFAULT_MODE; char *s, *endp; struct spi_flash *dev; + bool use_dt = true;
s = strsep(&devstr, ":"); if (!s || !*s || (bus = simple_strtoul(s, &endp, 0), *endp)) { @@ -143,6 +144,8 @@ static struct spi_flash *parse_dev(char *devstr) printf("Invalid SPI speed %s\n", s); return NULL; } + if (IS_ENABLED(CONFIG_DM_SPI_FLASH)) + use_dt = false; }
s = strsep(&devstr, ":"); @@ -152,9 +155,20 @@ static struct spi_flash *parse_dev(char *devstr) printf("Invalid SPI mode %s\n", s); return NULL; } + if (IS_ENABLED(CONFIG_DM_SPI_FLASH)) + use_dt = false; }
- dev = spi_flash_probe(bus, cs, speed, mode); + if (IS_ENABLED(CONFIG_DM_SPI_FLASH) && use_dt) { + struct udevice *new; + + if (!spi_flash_probe_bus_cs(bus, cs, &new)) + dev = dev_get_uclass_priv(new); + else + dev = NULL; + } else { + dev = spi_flash_probe(bus, cs, speed, mode); + } if (!dev) { printf("Failed to create SPI flash at %u:%u:%u:%u\n", bus, cs, speed, mode);
Hi Neil,
bool use_dt = true;
use_dt = false;
}use_dt = false;
- if (IS_ENABLED(CONFIG_DM_SPI_FLASH) && use_dt) {
else
dev = NULL;
- } else {
- } if (!dev) { printf("Failed to create SPI flash at %u:%u:%u:%u\n", bus, cs, speed, mode);
-- 2.34.1
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-dfu (u-boot-dfu)
[1/2] spi: add DM_SPI_FLASH compatibility inline functions https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/0872ac098a40063... [2/2] dfu: sf: rely on DT for spi speed and mode https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/97c29f868dd4e6d...
-- Mattijs
Mattijs Korpershoek
Neil Armstrong
