[U-Boot] [PATCH 1/2] usb: gadget: composite: Fix NULL pointer crash in USB compliance test
On the DXR2 board (AM335x using MUSB) the USB compliance test suite (USB 2.0 Command Verifier) will cause the board to crash and reset upon the "BOS Descriptor Test - Addressed state". Here the output from the DRX2 while running this test:
GADGET DRIVER: usb_dnl_dfu musb-hdrc: peripheral reset irq lost! composite_setup (776) data abort pc : [<87f693ac>] lr : [<87f6911c>] sp : 86f33a58 ip : 00000000 fp : 86f3bbac r10: 00000f00 r9 : 86f33ef4 r8 : 86f37da8 r7 : 00000005 r6 : 86f33a90 r5 : 00000000 r4 : 86f37e30 r3 : 00000000 r2 : 00000000 r1 : 87f9c888 r0 : 00000016 Flags: Nzcv IRQs off FIQs on Mode SVC_32 Resetting CPU ...
resetting ...
By adding the case statement for USB_DT_BOS and therefore not running into the default case (jump to unkown label) this crash is fixed.
Signed-off-by: Stefan Roese sr@denx.de Cc: Roger Meier r.meier@siemens.com Cc: Samuel Egli samuel.egli@siemens.com Cc: Enrico Leto enrico.leto@siemens.com Cc: Heiko Schocher hs@denx.de Cc: Lukasz Majewski l.majewski@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/composite.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c index a4c5606..98c2da6 100644 --- a/drivers/usb/gadget/composite.c +++ b/drivers/usb/gadget/composite.c @@ -761,6 +761,14 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) if (value >= 0) value = min(w_length, (u16) value); break; + case USB_DT_BOS: + /* + * The USB compliance test (USB 2.0 Command Verifier) + * issues this request. We should not run into the + * default path here. But return for now until + * the superspeed support is added. + */ + break; default: goto unknown; }
Without this function the USB compliance test (USB 2.0 Command Verifier) will fail in the "Interface Descriptor Test" with this error message:
FAIL (1.2.51) A successful GetInterface request must return the alternate setting set by a prior call to SetInterface.
Lets add this function to read back the value so that the DFU device fully passes the USB compliance test.
Signed-off-by: Stefan Roese sr@denx.de Cc: Roger Meier r.meier@siemens.com Cc: Samuel Egli samuel.egli@siemens.com Cc: Enrico Leto enrico.leto@siemens.com Cc: Heiko Schocher hs@denx.de Cc: Lukasz Majewski l.majewski@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/f_dfu.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index ead71eb..77a1567 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -780,6 +780,13 @@ static int dfu_set_alt(struct usb_function *f, unsigned intf, unsigned alt) return 0; }
+static int __dfu_get_alt(struct usb_function *f, unsigned intf) +{ + struct f_dfu *f_dfu = func_to_dfu(f); + + return f_dfu->altsetting; +} + /* TODO: is this really what we need here? */ static void dfu_disable(struct usb_function *f) { @@ -806,6 +813,7 @@ static int dfu_bind_config(struct usb_configuration *c) f_dfu->usb_function.bind = dfu_bind; f_dfu->usb_function.unbind = dfu_unbind; f_dfu->usb_function.set_alt = dfu_set_alt; + f_dfu->usb_function.get_alt = __dfu_get_alt; f_dfu->usb_function.disable = dfu_disable; f_dfu->usb_function.strings = dfu_generic_strings; f_dfu->usb_function.setup = dfu_handle;
Hello Stefan,
Am 09.01.2015 14:54, schrieb Stefan Roese:
Thanks!
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Stefan,
resetting ...
Thanks!
bye, Heiko
case USB_DT_BOS:
default: goto unknown; }break;
resetting ...
Applied both, thank you!
Best regards, Marek Vasut
Heiko Schocher
Stefan Roese
