[PATCH] rockchip: add support for Radxa ROCK Pi E v3.0
ROCK Pi E v3.0 uses DDR4 SDRAM instead of DDR3 SDRAM used in v1.2x.
prepare new rk3328-rock-pi-e-v3.dts in u-boot which just includes upstream rk3328-rock-pi-e.dts.
defconfig still uses CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock-pi-e.dtb"
because v3.0 and prior are compatible.
Suggested-by: Jonas Karlman jonas@kwiboo.se Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- ...dtsi => rk3328-rock-pi-e-base-u-boot.dtsi} | 1 - arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi | 47 +-------- arch/arm/dts/rk3328-rock-pi-e-v3-u-boot.dtsi | 4 + arch/arm/dts/rk3328-rock-pi-e-v3.dts | 4 + board/rockchip/evb_rk3328/MAINTAINERS | 4 +- configs/rock-pi-e-v3-rk3328_defconfig | 97 +++++++++++++++++++ 6 files changed, 111 insertions(+), 46 deletions(-) copy arch/arm/dts/{rk3328-rock-pi-e-u-boot.dtsi => rk3328-rock-pi-e-base-u-boot.dtsi} (94%) rewrite arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi (88%) create mode 100644 arch/arm/dts/rk3328-rock-pi-e-v3-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-rock-pi-e-v3.dts create mode 100644 configs/rock-pi-e-v3-rk3328_defconfig
diff --git a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi b/arch/arm/dts/rk3328-rock-pi-e-base-u-boot.dtsi similarity index 94% copy from arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi copy to arch/arm/dts/rk3328-rock-pi-e-base-u-boot.dtsi index d314bfad6f..39bb66c4fc 100644 --- a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock-pi-e-base-u-boot.dtsi @@ -4,7 +4,6 @@ */
#include "rk3328-u-boot.dtsi" -#include "rk3328-sdram-ddr3-666.dtsi"
/ { smbios { diff --git a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi dissimilarity index 88% index d314bfad6f..8e82f6a6f1 100644 --- a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi @@ -1,43 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2020 Radxa - */ - -#include "rk3328-u-boot.dtsi" -#include "rk3328-sdram-ddr3-666.dtsi" - -/ { - smbios { - compatible = "u-boot,sysinfo-smbios"; - - smbios { - system { - manufacturer = "radxa"; - product = "rock-pi-e_rk3328"; - }; - - baseboard { - manufacturer = "radxa"; - product = "rock-pi-e_rk3328"; - }; - - chassis { - manufacturer = "radxa"; - product = "rock-pi-e_rk3328"; - }; - }; - }; -}; - -&u2phy_host { - phy-supply = <&vcc_host_5v>; -}; - -&vcc_host_5v { - /delete-property/ regulator-always-on; - /delete-property/ regulator-boot-on; -}; - -&vcc_sd { - bootph-pre-ram; -}; +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3328-rock-pi-e-base-u-boot.dtsi" +#include "rk3328-sdram-ddr3-666.dtsi" diff --git a/arch/arm/dts/rk3328-rock-pi-e-v3-u-boot.dtsi b/arch/arm/dts/rk3328-rock-pi-e-v3-u-boot.dtsi new file mode 100644 index 0000000000..4d89ae54e6 --- /dev/null +++ b/arch/arm/dts/rk3328-rock-pi-e-v3-u-boot.dtsi @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3328-rock-pi-e-base-u-boot.dtsi" +#include "rk3328-sdram-ddr4-666.dtsi" diff --git a/arch/arm/dts/rk3328-rock-pi-e-v3.dts b/arch/arm/dts/rk3328-rock-pi-e-v3.dts new file mode 100644 index 0000000000..f1c1c36a99 --- /dev/null +++ b/arch/arm/dts/rk3328-rock-pi-e-v3.dts @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +/dts-v1/; +#include "rk3328-rock-pi-e.dts" diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index 675b72dd06..8f619e54e0 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -64,5 +64,5 @@ M: Banglang Huang banglang.huang@foxmail.com R: Jonas Karlman jonas@kwiboo.se S: Maintained F: configs/rock-pi-e-rk3328_defconfig -F: arch/arm/dts/rk3328-rock-pi-e.dts -F: arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi +F: configs/rock-pi-e-v3-rk3328_defconfig +F: arch/arm/dts/rk3328-rock-pi-e* diff --git a/configs/rock-pi-e-v3-rk3328_defconfig b/configs/rock-pi-e-v3-rk3328_defconfig new file mode 100644 index 0000000000..4c6cc634bd --- /dev/null +++ b/configs/rock-pi-e-v3-rk3328_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3328-rock-pi-e-v3" +CONFIG_DM_RESET=y +CONFIG_ROCKCHIP_RK3328=y +CONFIG_DEBUG_UART_BASE=0xFF130000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock-pi-e.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_POWER=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +# CONFIG_OF_UPSTREAM is not set +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_TPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y +CONFIG_PHY_GIGE=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RNG=y +CONFIG_RNG_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSINFO=y +CONFIG_SYSINFO_SMBIOS=y +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- (C) Copyright 2020 Radxa
- smbios {
smbios {
system {
baseboard {
chassis {
-&u2phy_host {
-&vcc_host_5v {
-&vcc_sd {
- bootph-pre-ram;
FUKAUMI Naoki
Kever Yang
