[PATCH RESEND] ARM: imx: mx6ull: Add iMX6ULL VisionSOM SoM and EVK
Add iMX6ULL VisionSOM SoM and VisionCB-RT-STD evaluation board support. The SoM has an iMX6ULL, 512 MiB of DRAM and microSD slot. The carrier board has Ethernet, USB host port, USB OTG port.
Signed-off-by: Arkadiusz Karas arkadiusz.karas@somlabs.com Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- NOTE: There are other variants and options of the VisionSOM available: - iMX6UL instead of iMX6ULL - NAND can be populated (optional, easy to add support for) - eMMC can be populated (optional, easy to add support for) --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6ull-somlabs-visionsom.dts | 276 ++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 13 + board/somlabs/visionsom-6ull/Kconfig | 12 + board/somlabs/visionsom-6ull/MAINTAINERS | 6 + board/somlabs/visionsom-6ull/Makefile | 4 + board/somlabs/visionsom-6ull/imximage.cfg | 107 +++++++ board/somlabs/visionsom-6ull/visionsom-6ull.c | 146 +++++++++ configs/somlabs_visionsom_6ull_defconfig | 49 ++++ include/configs/somlabs_visionsom_6ull.h | 116 ++++++++ 10 files changed, 730 insertions(+) create mode 100644 arch/arm/dts/imx6ull-somlabs-visionsom.dts create mode 100644 board/somlabs/visionsom-6ull/Kconfig create mode 100644 board/somlabs/visionsom-6ull/MAINTAINERS create mode 100644 board/somlabs/visionsom-6ull/Makefile create mode 100644 board/somlabs/visionsom-6ull/imximage.cfg create mode 100644 board/somlabs/visionsom-6ull/visionsom-6ull.c create mode 100644 configs/somlabs_visionsom_6ull_defconfig create mode 100644 include/configs/somlabs_visionsom_6ull.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 04a8cccda5..b2f127d398 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -676,6 +676,7 @@ dtb-$(CONFIG_MX6ULL) += \ imx6ull-colibri.dtb \ imx6ull-phytec-segin-ff-rdk-emmc.dtb \ imx6ull-dart-6ul.dtb \ + imx6ull-somlabs-visionsom.dtb \ imx6ulz-14x14-evk.dtb
dtb-$(CONFIG_ARCH_MX6) += \ diff --git a/arch/arm/dts/imx6ull-somlabs-visionsom.dts b/arch/arm/dts/imx6ull-somlabs-visionsom.dts new file mode 100644 index 0000000000..868f3f8440 --- /dev/null +++ b/arch/arm/dts/imx6ull-somlabs-visionsom.dts @@ -0,0 +1,276 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017-2019 SoMLabs + * Copyright (C) 2016 Freescale Semiconductor, Inc. + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include "imx6ull.dtsi" + +/ { + model = "SoMLabs VisionSOM-6ULL"; + compatible = "fsl,imx6ull-14x14-evk", "fsl,imx6ull"; + + chosen { + stdout-path = &uart1; + }; + + memory { + reg = <0x80000000 0x20000000>; + }; + + leds { + compatible = "gpio-leds"; + + usr0 { + label = "usr0"; + gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + usr1 { + label = "usr1"; + gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + + usr2 { + label = "usr2"; + gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc1"; + }; + + usr3 { + label = "usr3"; + gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usb_otg1_vbus: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_otg1>; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_usb_otg2_vbus: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_otg2>; + regulator-name = "usb_otg2_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio2 8 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + }; +}; + +&cpu0 { + arm-supply = <®_arm>; + soc-supply = <®_soc>; +}; + +&clks { + assigned-clocks = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>; + assigned-clock-rates = <786432000>; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet1>; + phy-mode = "rmii"; + phy-handle = <ðphy0>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; + }; + +}; + +&gpc { + fsl,cpu_pupscr_sw2iso = <0x1>; + fsl,cpu_pupscr_sw = <0x0>; + fsl,cpu_pdnscr_iso2sw = <0x1>; + fsl,cpu_pdnscr_iso = <0x1>; + fsl,ldo-bypass = <0>; /* DCDC, ldo-enable */ +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + +}; + +&i2c2 { + clock_frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog_1>; + + pinctrl_hog_1: hoggrp-1 { + fsl,pins = < + /* 32kHz low power reference clock for WiFi */ + MX6UL_PAD_JTAG_TCK__OSC32K_32K_OUT 0x17099 + /* LED 0..3 */ + MX6UL_PAD_JTAG_MOD__GPIO1_IO10 0x17099 + MX6UL_PAD_JTAG_TMS__GPIO1_IO11 0x17099 + MX6UL_PAD_JTAG_TDI__GPIO1_IO13 0x17099 + MX6UL_PAD_JTAG_TDO__GPIO1_IO12 0x17099 + >; + }; + + pinctrl_enet1: enet1grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO07__ENET1_MDC 0x1b0b0 + MX6UL_PAD_GPIO1_IO06__ENET1_MDIO 0x1F829 + + MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 + MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x400010a9 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0 + MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0 + MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0 + >; + }; + + pinctrl_tsc: tscgrp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO01__GPIO1_IO01 0xb0 + MX6UL_PAD_GPIO1_IO02__GPIO1_IO02 0xb0 + MX6UL_PAD_GPIO1_IO03__GPIO1_IO03 0xb0 + MX6UL_PAD_GPIO1_IO04__GPIO1_IO04 0xb0 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 + MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x10069 + MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x17059 + MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17059 + MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17059 + MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17059 + MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17059 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6UL_PAD_ENET2_RX_ER__WDOG1_WDOG_ANY 0x30b0 + >; + }; + + pinctrl_usb_otg1: usbotg1grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO00__ANATOP_OTG1_ID 0x17059 + MX6UL_PAD_ENET2_TX_DATA1__GPIO2_IO12 0x10b0 + >; + }; + + pinctrl_usb_otg2: usbotg2grp { + fsl,pins = < + MX6UL_PAD_ENET2_RX_DATA0__GPIO2_IO08 0x10b0 + >; + }; +}; + +&tsc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_tsc>; + xnur-gpio = <&gpio1 3 GPIO_ACTIVE_LOW>; + measure-delay-time = <0xffff>; + pre-charge-time = <0xfff>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&usbotg1 { + vbus-supply = <®_usb_otg1_vbus>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_otg1>; + dr_mode = "otg"; + srp-disable; + hnp-disable; + adp-disable; + status = "okay"; +}; + +&usbotg2 { + vbus-supply = <®_usb_otg2_vbus>; + dr_mode = "host"; + status = "okay"; +}; + +&usbphy1 { + tx-d-cal = <0x5>; +}; + +&usbphy2 { + tx-d-cal = <0x5>; +}; + +&usdhc2 { + non-removable; + disable-wp; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,wdog_b; +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index f1a1021f10..9d91f9ab44 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -540,6 +540,18 @@ config TARGET_SKSIMX6 bool "sks-imx6" select SUPPORT_SPL
+config TARGET_SOMLABS_VISIONSOM_6ULL + bool "visionsom-6ull" + select MX6ULL + select BOARD_LATE_INIT + select DM + select DM_ETH + select DM_GPIO + select DM_MMC + select DM_SERIAL + select DM_THERMAL + imply CMD_DM + config TARGET_TBS2910 bool "TBS2910 Matrix ARM mini PC"
@@ -694,6 +706,7 @@ source "board/logicpd/imx6/Kconfig" source "board/seco/Kconfig" source "board/sks-kinkel/sksimx6/Kconfig" source "board/solidrun/mx6cuboxi/Kconfig" +source "board/somlabs/visionsom-6ull/Kconfig" source "board/technexion/pico-imx6/Kconfig" source "board/technexion/pico-imx6ul/Kconfig" source "board/tbs/tbs2910/Kconfig" diff --git a/board/somlabs/visionsom-6ull/Kconfig b/board/somlabs/visionsom-6ull/Kconfig new file mode 100644 index 0000000000..37408aa798 --- /dev/null +++ b/board/somlabs/visionsom-6ull/Kconfig @@ -0,0 +1,12 @@ +if TARGET_SOMLABS_VISIONSOM_6ULL + +config SYS_BOARD + default "visionsom-6ull" + +config SYS_VENDOR + default "somlabs" + +config SYS_CONFIG_NAME + default "somlabs_visionsom_6ull" + +endif diff --git a/board/somlabs/visionsom-6ull/MAINTAINERS b/board/somlabs/visionsom-6ull/MAINTAINERS new file mode 100644 index 0000000000..905c000bc4 --- /dev/null +++ b/board/somlabs/visionsom-6ull/MAINTAINERS @@ -0,0 +1,6 @@ +VISIONSOM-6ULL BOARD +M: Arkadiusz Karas arkadiusz.karas@somlabs.com +S: Maintained +F: board/somlabs/visionsom-6ull/ +F: include/configs/somlabs_visionsom_6ull.h +F: configs/somlabs_visionsom_6ull_defconfig diff --git a/board/somlabs/visionsom-6ull/Makefile b/board/somlabs/visionsom-6ull/Makefile new file mode 100644 index 0000000000..9c3768aa45 --- /dev/null +++ b/board/somlabs/visionsom-6ull/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ +# (C) Copyright 2019 Arkadiusz Karas arkadiusz.karas@somlabs.com + +obj-y := visionsom-6ull.o diff --git a/board/somlabs/visionsom-6ull/imximage.cfg b/board/somlabs/visionsom-6ull/imximage.cfg new file mode 100644 index 0000000000..b49a2df6dd --- /dev/null +++ b/board/somlabs/visionsom-6ull/imximage.cfg @@ -0,0 +1,107 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2017 A. Karas + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : sd + */ + +BOOT_FROM sd + +/* + * Secure boot support + */ +#ifdef CONFIG_IMX_HAB +CSF CONFIG_CSF_SIZE +#endif + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* Micron MT41K256M16TW-107 */ + +/* Enable all clocks */ +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff + +DATA 4 0x020E04B4 0x000C0000 +DATA 4 0x020E04AC 0x00000000 +DATA 4 0x020E027C 0x00000030 +DATA 4 0x020E0250 0x00000030 +DATA 4 0x020E024C 0x00000030 +DATA 4 0x020E0490 0x00000030 +DATA 4 0x020E0288 0x00000030 +DATA 4 0x020E0270 0x00000000 +DATA 4 0x020E0260 0x00000030 +DATA 4 0x020E0264 0x00000030 +DATA 4 0x020E04A0 0x00000030 +DATA 4 0x020E0494 0x00020000 +DATA 4 0x020E0280 0x00000030 +DATA 4 0x020E0284 0x00000030 +DATA 4 0x020E04B0 0x00020000 +DATA 4 0x020E0498 0x00000030 +DATA 4 0x020E04A4 0x00000030 +DATA 4 0x020E0244 0x00000030 +DATA 4 0x020E0248 0x00000030 +DATA 4 0x021B001C 0x00008000 +DATA 4 0x021B0800 0xA1390003 +DATA 4 0x021B080C 0x00000000 +DATA 4 0x021B083C 0x41570155 +DATA 4 0x021B0848 0x4040474A +DATA 4 0x021B0850 0x40405550 +DATA 4 0x021B081C 0x33333333 +DATA 4 0x021B0820 0x33333333 +DATA 4 0x021B082C 0xf3333333 +DATA 4 0x021B0830 0xf3333333 +DATA 4 0x021B08C0 0x00921012 +DATA 4 0x021B08b8 0x00000800 +DATA 4 0x021B0004 0x0002002D +DATA 4 0x021B0008 0x1B333030 +DATA 4 0x021B000C 0x676B52F3 +DATA 4 0x021B0010 0xB66D0B63 +DATA 4 0x021B0014 0x01FF00DB +DATA 4 0x021B0018 0x00201740 +DATA 4 0x021B001C 0x00008000 +DATA 4 0x021B002C 0x000026D2 +DATA 4 0x021B0030 0x006B1023 +DATA 4 0x021B0040 0x0000004F +DATA 4 0x021B0000 0x84180000 +DATA 4 0x021B0890 0x23400A38 +DATA 4 0x021B001C 0x02008032 +DATA 4 0x021B001C 0x00008033 +DATA 4 0x021B001C 0x00048031 +DATA 4 0x021B001C 0x15208030 +DATA 4 0x021B001C 0x04008040 +DATA 4 0x021B0020 0x00000800 +DATA 4 0x021B0818 0x00000227 +DATA 4 0x021B0004 0x0002552D +DATA 4 0x021B0404 0x00011006 +DATA 4 0x021B001C 0x00000000 diff --git a/board/somlabs/visionsom-6ull/visionsom-6ull.c b/board/somlabs/visionsom-6ull/visionsom-6ull.c new file mode 100644 index 0000000000..bc7257be40 --- /dev/null +++ b/board/somlabs/visionsom-6ull/visionsom-6ull.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017-2019 A. Karas, SomLabs + * Copyright (C) 2015-2016 Freescale Semiconductor, Inc. + */ + +#include <init.h> +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/io.h> +#include <common.h> +#include <env.h> +#include <fsl_esdhc_imx.h> +#include <i2c.h> +#include <miiphy.h> +#include <linux/sizes.h> +#include <mmc.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +#ifdef CONFIG_FEC_MXC +static int setup_fec(void) +{ + struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + int ret; + + /* + * Use 50M anatop loopback REF_CLK1 for ENET1, + * clear gpr1[13], set gpr1[17]. + */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK, + IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK); + + ret = enable_fec_anatop_clock(0, ENET_50MHZ); + if (ret) + return ret; + + enable_enet_clk(1); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x8190); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int mmc_map_to_kernel_blk(int devno) +{ + return devno; +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_SYS_I2C + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); +#endif + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + + return 0; +} + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"sd1", MAKE_CFGVAL(0x42, 0x20, 0x00, 0x00)}, + {"sd2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int board_late_init(void) +{ +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + + if (is_cpu_type(MXC_CPU_MX6ULL)) + env_set("board", "visionsom-6ull"); + else + env_set("board", "visionsom-6ul"); + + return 0; +} + +int checkboard(void) +{ + printf("Board: SoMLabs VisionSOM-6UL%s\n", + is_cpu_type(MXC_CPU_MX6ULL) ? "L" : ""); + + return 0; +} diff --git a/configs/somlabs_visionsom_6ull_defconfig b/configs/somlabs_visionsom_6ull_defconfig new file mode 100644 index 0000000000..e39c03573a --- /dev/null +++ b/configs/somlabs_visionsom_6ull_defconfig @@ -0,0 +1,49 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_TARGET_SOMLABS_VISIONSOM_6ULL=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/somlabs/visionsom-6ull/imximage.cfg" +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_BOUNCE_BUFFER=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +# CONFIG_CMD_MDIO is not set +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ull-somlabs-visionsom" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y +CONFIG_LZO=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h new file mode 100644 index 0000000000..6759f24c08 --- /dev/null +++ b/include/configs/somlabs_visionsom_6ull.h @@ -0,0 +1,116 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2017-2019 A. Karas, SomLabs + * Copyright (C) 2015-2016 Freescale Semiconductor, Inc. + * + * Configuration settings for the SoMlabs VisionSOM 6ULL board. + */ +#ifndef __SOMLABS_VISIONSOM_6ULL_H +#define __SOMLABS_VISIONSOM_6ULL_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> +#include "mx6_common.h" +#include <asm/mach-imx/gpio.h> + +/* SPL options */ +#include "imx6_spl.h" + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M) + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* MMC Configs */ +#ifdef CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR + +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#endif /* CONFIG_FSL_USDHC */ + +#define CONFIG_CMD_READ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + "console=ttymxc0\0" \ + "initrd_addr=0x86800000\0" \ + "fdt_addr=0x83000000\0" \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "splashimage=0x80000000\0" \ + "splashfile=/boot/splash.bmp\0" \ + "mmcdev=1\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk1p1 rootwait rw\0" \ + "setrootmmc=setenv rootspec root=${mmcroot}\0" \ + "setbootscriptmmc=setenv loadbootscript " \ + "load mmc ${mmcdev}:${mmcpart} " \ + "${loadaddr} /boot/${script};\0" \ + "setloadmmc=setenv loadimage load mmc ${mmcdev}:${mmcpart} " \ + "${loadaddr} /boot/${image}; " \ + "setenv loadfdt load mmc ${mmcdev}:${mmcpart} " \ + "${fdt_addr} /boot/${fdt_file};\0" \ + "setbootargs=setenv bootargs console=${console},${baudrate} " \ + "${rootspec}\0" \ + "execbootscript=echo Running bootscript...; source\0" \ + "setfdtfile=setenv fdt_file somlabs-visionsom-6ull.dtb\0" \ + "checkbootdev=run setbootscriptmmc; " \ + "run setrootmmc; " \ + "run setloadmmc; " \ + +#define CONFIG_BOOTCOMMAND \ + "run setfdtfile; " \ + "run checkbootdev; " \ + "run loadfdt;" \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run setbootargs; " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "fi; " \ + "fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x8000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +/* Physical Memory Map */ +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* environment organization */ +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ + +/* USB Configs */ +#ifdef CONFIG_CMD_USB +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#endif + +#ifdef CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1 +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_ETHPRIME "eth0" +#endif + +#define CONFIG_IMX_THERMAL + +#endif
Hi Marek,
Patch was already applied to u-boot-imx, -master. I could not find it in patchwork, that's the reason you did not get an e-mail of confirmation.
Regards, Stefano
- imx6ull-somlabs-visionsom.dtb \ imx6ulz-14x14-evk.dtb
- Copyright (C) 2017-2019 SoMLabs
- Copyright (C) 2016 Freescale Semiconductor, Inc.
+/dts-v1/;
- model = "SoMLabs VisionSOM-6ULL";
- compatible = "fsl,imx6ull-14x14-evk", "fsl,imx6ull";
- chosen {
- memory {
- leds {
usr0 {
label = "usr0";
usr1 {
label = "usr1";
usr2 {
label = "usr2";
usr3 {
label = "usr3";
- regulators {
#size-cells = <0>;
reg = <2>;
enable-active-high;
reg = <3>;
enable-active-high;
+&cpu0 {
- arm-supply = <®_arm>;
- soc-supply = <®_soc>;
+&clks {
- assigned-clocks = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>;
- assigned-clock-rates = <786432000>;
+&fec1 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_enet1>;
- phy-mode = "rmii";
- phy-handle = <ðphy0>;
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <1>;
+&gpc {
- fsl,cpu_pupscr_sw2iso = <0x1>;
- fsl,cpu_pupscr_sw = <0x0>;
- fsl,cpu_pdnscr_iso2sw = <0x1>;
- fsl,cpu_pdnscr_iso = <0x1>;
- fsl,ldo-bypass = <0>; /* DCDC, ldo-enable */
+&i2c1 {
- clock-frequency = <100000>;
- pinctrl-0 = <&pinctrl_i2c1>;
+&i2c2 {
- clock_frequency = <100000>;
- pinctrl-0 = <&pinctrl_i2c2>;
+&iomuxc {
- pinctrl-0 = <&pinctrl_hog_1>;
- pinctrl_hog_1: hoggrp-1 {
fsl,pins = <
/* LED 0..3 */
- pinctrl_enet1: enet1grp {
fsl,pins = <
- pinctrl_i2c1: i2c1grp {
fsl,pins = <
- pinctrl_i2c2: i2c2grp {
fsl,pins = <
- pinctrl_tsc: tscgrp {
fsl,pins = <
- pinctrl_uart1: uart1grp {
fsl,pins = <
- pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
- pinctrl_wdog: wdoggrp {
fsl,pins = <
- pinctrl_usb_otg1: usbotg1grp {
fsl,pins = <
- pinctrl_usb_otg2: usbotg2grp {
fsl,pins = <
+&tsc {
- pinctrl-0 = <&pinctrl_tsc>;
- xnur-gpio = <&gpio1 3 GPIO_ACTIVE_LOW>;
- measure-delay-time = <0xffff>;
- pre-charge-time = <0xfff>;
- status = "okay";
+&uart1 {
- pinctrl-0 = <&pinctrl_uart1>;
- status = "okay";
+&usbotg1 {
- vbus-supply = <®_usb_otg1_vbus>;
- pinctrl-0 = <&pinctrl_usb_otg1>;
- dr_mode = "otg";
- srp-disable;
- hnp-disable;
- adp-disable;
- status = "okay";
+&usbotg2 {
- vbus-supply = <®_usb_otg2_vbus>;
- dr_mode = "host";
- status = "okay";
+&usbphy1 {
- tx-d-cal = <0x5>;
+&usbphy2 {
- tx-d-cal = <0x5>;
+&usdhc2 {
- non-removable;
- disable-wp;
- status = "okay";
+&wdog1 {
- pinctrl-0 = <&pinctrl_wdog>;
- fsl,wdog_b;
- bool "visionsom-6ull"
- select MX6ULL
- select BOARD_LATE_INIT
- select DM
- select DM_ETH
- select DM_GPIO
- select DM_MMC
- select DM_SERIAL
- select DM_THERMAL
- imply CMD_DM
+config SYS_BOARD
- default "visionsom-6ull"
+config SYS_VENDOR
- default "somlabs"
- default "somlabs_visionsom_6ull"
- Copyright (C) 2017 A. Karas
- Copyright (C) 2015 Freescale Semiconductor, Inc.
- Refer docs/README.imxmage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
+IMAGE_VERSION 2
- Boot Device : sd
+BOOT_FROM sd
- Secure boot support
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- Addr-type register length (1,2 or 4 bytes)
- Address absolute address of the register
- value value to be stored in the register
- Copyright (C) 2017-2019 A. Karas, SomLabs
- Copyright (C) 2015-2016 Freescale Semiconductor, Inc.
- PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- gd->ram_size = imx_ddr_size();
- MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
- struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR;
- int ret;
- clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK,
- ret = enable_fec_anatop_clock(0, ENET_50MHZ);
- if (ret)
return ret;
- enable_enet_clk(1);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x8190);
- if (phydev->drv->config)
+} +#endif
- return devno;
- return devno;
- setup_iomux_uart();
- /* Address of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1);
- setup_fec();
- /* 4 bit bus width */
- {"sd1", MAKE_CFGVAL(0x42, 0x20, 0x00, 0x00)},
- {"sd2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)},
- {NULL, 0},
+}; +#endif
- add_board_boot_modes(board_boot_modes);
- if (is_cpu_type(MXC_CPU_MX6ULL))
- else
- printf("Board: SoMLabs VisionSOM-6UL%s\n",
- Configuration settings for the SoMlabs VisionSOM 6ULL board.
- "bootm_size=0x10000000\0" \
- "console=ttymxc0\0" \
- "initrd_addr=0x86800000\0" \
- "fdt_addr=0x83000000\0" \
- "script=boot.scr\0" \
- "image=zImage\0" \
- "splashimage=0x80000000\0" \
- "splashfile=/boot/splash.bmp\0" \
- "mmcdev=1\0" \
- "mmcpart=1\0" \
- "mmcroot=/dev/mmcblk1p1 rootwait rw\0" \
- "setrootmmc=setenv rootspec root=${mmcroot}\0" \
- "setbootscriptmmc=setenv loadbootscript " \
- "setloadmmc=setenv loadimage load mmc ${mmcdev}:${mmcpart} " \
- "setbootargs=setenv bootargs console=${console},${baudrate} " \
"${rootspec}\0" \
- "execbootscript=echo Running bootscript...; source\0" \
- "setfdtfile=setenv fdt_file somlabs-visionsom-6ull.dtb\0" \
- "checkbootdev=run setbootscriptmmc; " \
- "run setfdtfile; " \
- "run checkbootdev; " \
- "run loadfdt;" \
- "if run loadbootscript; then " \
- "else " \
"fi; " \
- "fi"
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
On 1/21/20 9:12 AM, Stefano Babic wrote:
Hi Marek,
I have a feeling I hit some gap when the ML setup was being updated. Anyway, thanks.
Stefano Babic
