[U-Boot-Users] [PATCH] net: smc911x: sh: Add support RSK7203 board to smc911x
The RSK board has the SMSC9118 wired up 'incorrectly'. This problem can support in the software side. I put a code to evade it.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com --- drivers/net/smc911x.c | 37 +++++++++++++++++++++++++++++++++++-- 1 files changed, 35 insertions(+), 2 deletions(-)
diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index 1484b0b..ec731ea 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -53,6 +53,39 @@ static inline void reg_write(u32 addr, u32 val) *(volatile u16*)addr = (u16)val; *(volatile u16*)(addr + 2) = (u16)(val >> 16); } + +#if 0 //defined(CONFIG_RSK7203) +/* + * The RSK board has the SMSC9118 wired up 'incorrectly'. + * Byte-swapping is necessary, and so poor performance is inevitable. + * It seems that this is a problem with the SMSC chip, which has an + * endian facility, but it only works at the word level so... + */ +/* 2301_6745 --> 0123_4567 */ +#define PKT_SWAP(x) ((vu_long)((((vu_long)x << 8) & 0x0000FF00)|\ + (((vu_long)x >> 8) & 0x000000FF)|\ + (((vu_long)x << 8) & 0xFF000000)|\ + (((vu_long)x >> 8) & 0x00FF0000))) + +static inline u32 pkt_data_pull(u32 addr) +{ + volatile u16 *addr_16 = (u16 *)addr; + u32 d0 = (((*addr_16) << 16) & 0xFFFF0000); + u32 d1 = ((*(addr_16 + 1) & 0x0000FFFF)); + return PKT_SWAP((d0|d1)); +} + +static inline void pkt_data_push(u32 addr, u32 val) +{ + *(volatile u16 *)(addr + 2) = PKT_SWAP((u16)val); + *(volatile u16 *)(addr) = PKT_SWAP((u16)(val >> 16)); +} + +#else +# define pkt_data_pull(x) reg_read(x) +# define pkt_data_push(x, l) reg_write(x, l) +#endif /* CONFIG_RSK7203*/ + #else #error "SMC911X: undefined bus width" #endif /* CONFIG_DRIVER_SMC911X_16_BIT */ @@ -641,7 +674,7 @@ int eth_send(volatile void *packet, int length) tmplen = (length + 3) / 4;
while (tmplen--) - reg_write(TX_DATA_FIFO, *data++); + pkt_data_push(TX_DATA_FIFO, *data++);
/* wait for transmission */ while (!((reg_read(TX_FIFO_INF) & TX_FIFO_INF_TSUSED) >> 16)); @@ -684,7 +717,7 @@ int eth_rx(void)
tmplen = (pktlen + 2+ 3) / 4; while (tmplen--) - *data++ = reg_read(RX_DATA_FIFO); + *data++ = pkt_data_pull(RX_DATA_FIFO);
if (status & RX_STS_ES) printf(DRIVERNAME
Hi Nobuhiro,
Putting a board fix in a common driver is not cool. Please provide more generic word-swapping versions of reg_read and reg_write, or something else like that.
regards, Ben
Hi, Ben.
Thank you for your comments.
2008/7/4 Ben Warren biggerbadderben@gmail.com:
Hi Nobuhiro,
Yes , I know. However, this problem occurs in read/write of FIFO. Therefore, I made a pkt_data_pull/pkt_data_push function newly. And I change it with a preprocessor.
OK, I will change swabXX and resend.
Best regards, Nobuhiro
Ben Warren
Nobuhiro Iwamatsu
Nobuhiro Iwamatsu
