[U-Boot] [PATCH] serial: add environment control for SERIAL_MULTI
Add a new special environment variable "serial" that allows selection of serial device when CONFIG_SERIAL_MULTI is defined. This replaces the existing calls to serial_assign() from cmd_nvedit.c and iomux.c that were not doing anything.
Signed-off-by: Allen Martin amartin@nvidia.com --- common/cmd_nvedit.c | 7 ++++++- common/iomux.c | 10 ---------- doc/driver-model/UDM-serial.txt | 5 +++-- 3 files changed, 9 insertions(+), 13 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 1f9c674..d1ee07d 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -238,11 +238,16 @@ int env_check_apply(const char *name, const char *oldval, /* Try assigning specified device */ if (console_assign(console, newval) < 0) return 1; +#endif /* CONFIG_CONSOLE_MUX */ + }
+#ifdef CONFIG_SERIAL_MULTI + /* Check for serial redirection */ + if (strcmp(name, "serial") == 0) { if (serial_assign(newval) < 0) return 1; -#endif /* CONFIG_CONSOLE_MUX */ } +#endif /* CONFIG_SERIAL_MULTI */
/* * Some variables like "ethaddr" and "serial#" can be set only once and diff --git a/common/iomux.c b/common/iomux.c index dbc2312..6a75704 100644 --- a/common/iomux.c +++ b/common/iomux.c @@ -135,16 +135,6 @@ int iomux_doenv(const int console, const char *arg) */ if (console_assign(console, start[j]) < 0) continue; - /* - * This was taken from common/cmd_nvedit.c. - * This will never work because serial_assign() returns - * 1 upon error, not -1. - * This would almost always return an error anyway because - * serial_assign() expects the name of a serial device, like - * serial_smc, but the user generally only wants to set serial. - */ - if (serial_assign(start[j]) < 0) - continue; cons_set[cs_idx++] = dev; } free(console_args); diff --git a/doc/driver-model/UDM-serial.txt b/doc/driver-model/UDM-serial.txt index 9feb2e5..66f3e6b 100644 --- a/doc/driver-model/UDM-serial.txt +++ b/doc/driver-model/UDM-serial.txt @@ -26,8 +26,9 @@ and serial_setbrg() are often called from platform-dependent places. It's important to consider current implementation of CONFIG_SERIAL_MULTI though. This resides in common/serial.c and behaves as a multiplexer for serial ports. This, by calling serial_assign(), allows user to switch I/O from one serial port -to another. Though the environmental variables "stdin", "stdout", "stderr" -remain set to "serial". +to another. The environment variable "serial" is used to select which of the +serial ports is the currently active port. The environmental variables +"stdin", "stdout", "stderr" remain set to "serial".
These variables are managed by the IOMUX. This resides in common/iomux.c and manages all console input/output from U-Boot. For serial port, only one IOMUX is
Dear Allen Martin,
Drop this, it's default. There's no CONFIG_SERIAL_MULTI in the tree at all anymore.
- /* Check for serial redirection */
- if (strcmp(name, "serial") == 0) { if (serial_assign(newval) < 0) return 1;
cons_set[cs_idx++] = dev; } free(console_args);continue;
Best regards, Marek Vasut
Two things. First, should I or should I not need to have CONFIG_CONSOLE_MUX set? If I set it, adding serial=eserial3 to my default environment switches from eserial0 to eserial3 when we get to that point in the boot, otherwise I do have to manually setenv serial eserial3 for anything to happen. And the second thing, I can't get any output on the other UART, either way. It goes away from eserial0 but nothing ever shows up to eserial3 (the easiest one here to test).
Hi Allen,
Changes to this directly conflict with the environment callback series I sent out RFC (soon be be a real series). Can we hold off on this until that happens?
These variables are managed by the IOMUX. This resides in common/iomux.c and manages all console input/output from U-Boot. For serial port, only one IOMUX is -- 1.7.10.4
On 10/25/2012 04:36 PM, Joe Hershberger wrote:
Hi Allen,
The problem here is that serial output on Tegra simply doesn't work (after some point in boot?) without this patch. It seems better to get everything working before adding new features doesn't it? Otherwise, if the environment callback stuff (or any other change right now) breaks something Tegra-specific, there would be no way to identify which change broke it.
Hi Stephen,
Hi Allen,
Fair enough. However I don't think this patch is the right way to fix it.
-Joe
On Thu, Oct 25, 2012 at 03:47:09PM -0700, Joe Hershberger wrote:
Hi Stephen,
Hi Allen,
Ok, would removing the existing calls to serial_assign() from iomux.c and cmd_nvedit.c be an ok first step? They don't appear to do anything useful right now and that would fix tegra and raspberry pi.
-Allen
Hi Allen,
Hi Stephen,
Hi Allen,
I think that's fine to just remove those 2 calls. Seem like a good short-term solution.
-Joe
On Thu, Oct 25, 2012 at 04:18:11PM -0700, Joe Hershberger wrote:
Hi Allen,
Hi Stephen,
Hi Allen,
Ok, I'll send out a patch for that now, thanks.
-Allen
So I think this requires (for example) the following environment variables:
stdout=serial serial=eserial0
Is it possible to allow the following instead:
stdout=eserial0
That way, one could presumably set:
stdout=eserial0,eserial3
and hence allow the use of multiple serial consoles?
Hi Stephen,
stdout=eserial0
This is precisely what the patch I had pre-Marek serial did.
Though it didn't allow this.
-Joe
On Thu, Oct 25, 2012 at 03:46:01PM -0700, Joe Hershberger wrote:
Hi Stephen,
stdout=eserial0
In your patch would "stdout=serial" still work for case where there is only one serial port? I think it's important to try to preserve that to no be too disruptive.
Shouldn't that be (nearly) transparent through iomux?
-Allen
Hi Allen,
Hi Stephen,
stdout=eserial0
It used to support stdout=serial based on not being CONFIG_SERIAL_MULTI. Now that that's gone, I'm guessing it would simply be based on only having one registered serial device.
If that's what iomux does, then sure! I haven't used I/O mux on a device before.
-Joe
Dear Joe Hershberger,
Hi Allen,
Hi Stephen,
stdout=eserial0
This is what we should do, indeed.
participants (5)
Allen Martin
Joe Hershberger
Stephen Warren
