[U-Boot] [PATCH v3] mx6: Add initial SPL support for HummingBoard-i2eX
Add the initial SPL support for HummingBoard-i2eX, which is based on a MX6 Dual.
For more information about HummingBoard, please check: http://www.solid-run.com/products/hummingboard/
Based on the work from Jon Nettleton and Rabeeh Khoury.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Currently only HummingBoard-i2eX is supported.
After this initial patch is accepted, then we can add the other Hummingboard and Cubox-i variants as well.
Changes since v2: - Avoid undef CONFIG_CMD_IMLS as suggested by Tom - Change the name from mx6cuboxi_spl_defconfig to mx6cuboxi_defconfig as spl will be the only supported method for these boards
Changes since v1: - Addressed several comments made by Tom Rini - Remove empty lines from README as pointed out by Nikolay Dimitrov - Fixed sparse warnings - Fixed DDR settings arch/arm/Kconfig | 6 + board/solidrun/mx6cuboxi/Kconfig | 15 ++ board/solidrun/mx6cuboxi/MAINTAINERS | 6 + board/solidrun/mx6cuboxi/Makefile | 9 + board/solidrun/mx6cuboxi/README | 21 +++ board/solidrun/mx6cuboxi/mx6cuboxi.c | 330 +++++++++++++++++++++++++++++++++++ configs/mx6cuboxi_defconfig | 6 + include/configs/mx6cuboxi.h | 205 ++++++++++++++++++++++ 8 files changed, 598 insertions(+) create mode 100644 board/solidrun/mx6cuboxi/Kconfig create mode 100644 board/solidrun/mx6cuboxi/MAINTAINERS create mode 100644 board/solidrun/mx6cuboxi/Makefile create mode 100644 board/solidrun/mx6cuboxi/README create mode 100644 board/solidrun/mx6cuboxi/mx6cuboxi.c create mode 100644 configs/mx6cuboxi_defconfig create mode 100644 include/configs/mx6cuboxi.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7ed0e20..7c383cb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -523,6 +523,11 @@ config TARGET_MX6SABRESD select CPU_V7 select SUPPORT_SPL
+config TARGET_MX6CUBOXI + bool "Support Solid-run mx6 boards" + select CPU_V7 + select SUPPORT_SPL + config TARGET_MX6SLEVK bool "Support mx6slevk" select CPU_V7 @@ -856,6 +861,7 @@ source "board/siemens/draco/Kconfig" source "board/siemens/pxm2/Kconfig" source "board/siemens/rut/Kconfig" source "board/silica/pengwyn/Kconfig" +source "board/solidrun/mx6cuboxi/Kconfig" source "board/solidrun/hummingboard/Kconfig" source "board/spear/spear300/Kconfig" source "board/spear/spear310/Kconfig" diff --git a/board/solidrun/mx6cuboxi/Kconfig b/board/solidrun/mx6cuboxi/Kconfig new file mode 100644 index 0000000..31d88b2 --- /dev/null +++ b/board/solidrun/mx6cuboxi/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MX6CUBOXI + +config SYS_BOARD + default "mx6cuboxi" + +config SYS_VENDOR + default "solidrun" + +config SYS_SOC + default "mx6" + +config SYS_CONFIG_NAME + default "mx6cuboxi" + +endif diff --git a/board/solidrun/mx6cuboxi/MAINTAINERS b/board/solidrun/mx6cuboxi/MAINTAINERS new file mode 100644 index 0000000..3d468ed --- /dev/null +++ b/board/solidrun/mx6cuboxi/MAINTAINERS @@ -0,0 +1,6 @@ +MX6CUBOXI BOARD +M: Fabio Estevam fabio.estevam@freescale.com +S: Maintained +F: board/solidrun/mx6cuboxi/ +F: include/configs/mx6cuboxi.h +F: configs/mx6cuboxi_spl_defconfig diff --git a/board/solidrun/mx6cuboxi/Makefile b/board/solidrun/mx6cuboxi/Makefile new file mode 100644 index 0000000..df425ac --- /dev/null +++ b/board/solidrun/mx6cuboxi/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2011 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx6cuboxi.o diff --git a/board/solidrun/mx6cuboxi/README b/board/solidrun/mx6cuboxi/README new file mode 100644 index 0000000..3050c48 --- /dev/null +++ b/board/solidrun/mx6cuboxi/README @@ -0,0 +1,21 @@ +How to use U-boot on Solid-run mx6 hummingboard +----------------------------------------------- + +- Build U-boot for hummingboard: + +$ make mrproper +$ make mx6cuboxi_defconfig +$ make + +This will generate the SPL image called SPL and the u-boot.img. + +- Flash the SPL image into the SD card: + +sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync + +- Flash the u-boot.img image into the SD card: + +sudo dd if=u-boot.img of=/dev/mmcblk0 bs=1k seek=69; sync + +- Insert the SD card in the hummingboard, power it up and U-boot messages +should come up. diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c new file mode 100644 index 0000000..b696dcb --- /dev/null +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -0,0 +1,330 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com + * + * Based on SPL code from Solidrun tree, which is: + * Author: Tungyi Lin tungyilin1127@gmail.com + * + * Derived from EDM_CF_IMX6 code by TechNexion,Inc + * Ported to SolidRun microSOM by Rabeeh Khoury rabeeh@solid-run.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/crm_regs.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mx6-ddr.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ENET_PAD_CTRL_PD (PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ENET_PAD_CTRL_CLK ((PAD_CTL_PUS_100K_UP & ~PAD_CTL_PKE) | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define ETH_PHY_RESET IMX_GPIO_NR(4, 15) + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC2_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; /* uSDHC2 is always present */ +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + usdhc_cfg[0].esdhc_base = USDHC2_BASE_ADDR; + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + +static iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* AR8035 reset */ + MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + /* AR8035 interrupt */ + MX6_PAD_DI0_PIN2__GPIO4_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* GPIO16 -> AR8035 25MHz */ + MX6_PAD_GPIO_16__ENET_REF_CLK | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* AR8035 CLK_25M --> ENET_REF_CLK (V22) */ + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL_CLK), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), +}; + +static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + + gpio_direction_output(ETH_PHY_RESET, 0); + mdelay(2); + gpio_set_value(ETH_PHY_RESET, 1); +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + + int ret = enable_fec_anatop_clock(ENET_25MHZ); + if (ret) + return ret; + + /* set gpr1[ENET_CLK_SEL] */ + setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK); + + setup_iomux_enet(); + + return cpu_eth_init(bis); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + return 0; +} + +int checkboard(void) +{ + puts("Board: MX6 Hummingboard\n"); + return 0; +} + +#ifdef CONFIG_SPL_BUILD +static const struct mx6dq_iomux_ddr_regs mx6_ddr_ioregs = { + .dram_sdclk_0 = 0x00020030, + .dram_sdclk_1 = 0x00020030, + .dram_cas = 0x00020030, + .dram_ras = 0x00020030, + .dram_reset = 0x00020030, + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = 0x00003030, + .dram_sdodt1 = 0x00003030, + .dram_sdqs0 = 0x00000030, + .dram_sdqs1 = 0x00000030, + .dram_sdqs2 = 0x00000030, + .dram_sdqs3 = 0x00000030, + .dram_sdqs4 = 0x00000030, + .dram_sdqs5 = 0x00000030, + .dram_sdqs6 = 0x00000030, + .dram_sdqs7 = 0x00000030, + .dram_dqm0 = 0x00020030, + .dram_dqm1 = 0x00020030, + .dram_dqm2 = 0x00020030, + .dram_dqm3 = 0x00020030, + .dram_dqm4 = 0x00020030, + .dram_dqm5 = 0x00020030, + .dram_dqm6 = 0x00020030, + .dram_dqm7 = 0x00020030, +}; + +static const struct mx6dq_iomux_grp_regs mx6_grp_ioregs = { + .grp_ddr_type = 0x000C0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = 0x00000030, + .grp_ctlds = 0x00000030, + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_b2ds = 0x00000030, + .grp_b3ds = 0x00000030, + .grp_b4ds = 0x00000030, + .grp_b5ds = 0x00000030, + .grp_b6ds = 0x00000030, + .grp_b7ds = 0x00000030, +}; + +static const struct mx6_mmdc_calibration mx6_mmcd_calib = { + .p0_mpwldectrl0 = 0x00000000, + .p0_mpwldectrl1 = 0x00000000, + .p1_mpwldectrl0 = 0x00000000, + .p1_mpwldectrl1 = 0x00000000, + .p0_mpdgctrl0 = 0x0314031c, + .p0_mpdgctrl1 = 0x023e0304, + .p1_mpdgctrl0 = 0x03240330, + .p1_mpdgctrl1 = 0x03180260, + .p0_mprddlctl = 0x3630323c, + .p1_mprddlctl = 0x3436283a, + .p0_mpwrdlctl = 0x36344038, + .p1_mpwrdlctl = 0x422a423c, +}; + +static struct mx6_ddr3_cfg mem_ddr = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, + .SRT = 1, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + +/* + * This section requires the differentiation between Solidrun mx6 boards, but + * for now, it will configure only for the mx6dual hummingboard version. + */ +static void spl_dram_init(void) +{ + struct mx6_ddr_sysinfo sysinfo = { + /* width of data bus: 0=16, 1=32, 2=64 */ + .dsize = 2, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + .ncs = 1, /* single chip select */ + .cs1_mirror = 0, + .rtt_wr = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Wr = RZQ/4 */ + .rtt_nom = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Nom = RZQ/4 */ + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + }; + + mx6dq_dram_iocfg(64, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&sysinfo, &mx6_mmcd_calib, &mem_ddr); +} + +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* iomux and setup of i2c */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig new file mode 100644 index 0000000..85dc58a --- /dev/null +++ b/configs/mx6cuboxi_defconfig @@ -0,0 +1,6 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_ARM=y +CONFIG_TARGET_MX6CUBOXI=y +CONFIG_DM=y +CONFIG_DM_THERMAL=y diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h new file mode 100644 index 0000000..5d58b16 --- /dev/null +++ b/include/configs/mx6cuboxi.h @@ -0,0 +1,205 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Configuration settings for the SolidRun mx6 based boards + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __MX6CUBOXI_CONFIG_H +#define __MX6CUBOXI_CONFIG_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> +#include "mx6_common.h" + +#define CONFIG_MX6 +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#include "imx6_spl.h" + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_IMX6_THERMAL +#define CONFIG_SYS_GENERIC_BOARD + +#define CONFIG_SYS_MALLOC_LEN (2 * SZ_1M) +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO +#define CONFIG_MXC_UART +#define CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* Ethernet Configuration */ +#define CONFIG_FEC_MXC +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_PHYLIB +#define CONFIG_PHY_ATHEROS + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_NO_FLASH + +/* Command definition */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 1 + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +#define CONFIG_MXC_UART_BASE UART1_BASE +#define CONFIG_CONSOLE_DEV "ttymxc0" +#define CONFIG_MMCROOT "/dev/mmcblk0p2" +#define CONFIG_DEFAULT_FDT_FILE "imx6q-hummingboard.dtb" +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#define CONFIG_SYS_MMC_ENV_DEV 0 /* SDHC2 */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x18000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "console=" CONFIG_CONSOLE_DEV "\0" \ + "bootm_size=0x10000000\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcpart=1\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "update_sd_firmware=" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "if mmc dev ${mmcdev}; then " \ + "if ${get_cmd} ${update_sd_firmware_filename}; then " \ + "setexpr fw_sz ${filesize} / 0x200; " \ + "setexpr fw_sz ${fw_sz} + 1; " \ + "mmc write ${loadaddr} 0x2 ${fw_sz}; " \ + "fi; " \ + "fi\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE MMDC0_ARB_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* Environment organization */ +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (8 * 64 * 1024) + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_CACHE + +#endif /* __MX6CUBOXI_CONFIG_H */
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
