[U-Boot-Users] [PATCH] (resubmit) ppc4xx: ML507: Environment in flash and MTD Support
-Relocate the location of u-boot in the flash -Save the environment in one sector of the flash memory -MTD Support
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@uam.es --- -Previus commit included files from other commit
Makefile | 2 +- board/xilinx/ml507/xparameters.h | 2 +- include/configs/ml507.h | 15 +++++++++++---- 3 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/Makefile b/Makefile index 8f4fdd0..ea572cf 100644 --- a/Makefile +++ b/Makefile @@ -1352,7 +1352,7 @@ ml300_config: unconfig ml507_flash_config: unconfig @mkdir -p $(obj)include $(obj)board/xilinx/ml507 @cp $(obj)board/xilinx/ml507/u-boot-rom.lds $(obj)board/xilinx/ml507/u-boot.lds - @echo "TEXT_BASE = 0xFE3E0000" > $(obj)board/xilinx/ml507/config.tmp + @echo "TEXT_BASE = 0xFE360000" > $(obj)board/xilinx/ml507/config.tmp @$(MKCONFIG) $(@:_flash_config=) ppc ppc4xx ml507 xilinx
ml507_config: unconfig diff --git a/board/xilinx/ml507/xparameters.h b/board/xilinx/ml507/xparameters.h index 6a8e183..77d2ddf 100644 --- a/board/xilinx/ml507/xparameters.h +++ b/board/xilinx/ml507/xparameters.h @@ -24,7 +24,7 @@ #define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 #define XPAR_IIC_EEPROM_BASEADDR 0x81600000 #define XPAR_INTC_0_BASEADDR 0x81800000 -#define XPAR_LLTEMAC_0_BASEADDR 0x81c00000 +#define XPAR_LLTEMAC_0_BASEADDR 0x81C00000 #define XPAR_UARTLITE_0_BASEADDR 0x84000000 #define XPAR_FLASH_MEM0_BASEADDR 0xFE000000 #define XPAR_PLB_CLOCK_FREQ_HZ 100000000 diff --git a/include/configs/ml507.h b/include/configs/ml507.h index a79bc1e..c653a51 100644 --- a/include/configs/ml507.h +++ b/include/configs/ml507.h @@ -33,7 +33,7 @@ #define CFG_SDRAM_SIZE_MB 256 #define CFG_MONITOR_BASE TEXT_BASE #define CFG_MONITOR_LEN ( 192 * 1024 ) -#define CFG_MALLOC_LEN ( 128 * 1024 ) +#define CFG_MALLOC_LEN ( CFG_ENV_SIZE + 128 * 1024 )
/*Uart*/ #define CONFIG_XILINX_UARTLITE @@ -49,6 +49,8 @@ #define CONFIG_CMD_ELF #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO +#define CONFIG_CMD_JFFS2 +#define CONFIG_JFFS2_CMDLINE #undef CONFIG_CMD_I2C #undef CONFIG_CMD_DTT #undef CONFIG_CMD_NET @@ -58,9 +60,11 @@ #undef CONFIG_CMD_IMLS
/*Env*/ -#define CFG_ENV_IS_NOWHERE -#define CFG_ENV_SIZE 0x200 -#define CFG_ENV_OFFSET 0x100 +#define CFG_ENV_IS_IN_FLASH +#define CFG_ENV_SIZE 0x20000 +#define CFG_ENV_SECT_SIZE 0x20000 +#define CFG_ENV_OFFSET 0x340000 +#define CFG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CFG_ENV_OFFSET)
/*Misc*/ #define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ @@ -111,5 +115,8 @@ #define CFG_MAX_FLASH_BANKS 1 #define CFG_MAX_FLASH_SECT 259 #define CFG_FLASH_PROTECTION +#define MTDIDS_DEFAULT "nor0=ml507-flash" +#define MTDPARTS_DEFAULT "mtdparts=ml507-flash:-(user)" +
#endif /* __CONFIG_H */
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@uam.es --- Previus commit had compiling warnings
common/cmd_load.c | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/common/cmd_load.c b/common/cmd_load.c index 1b75a7b..ae56543 100644 --- a/common/cmd_load.c +++ b/common/cmd_load.c @@ -38,7 +38,7 @@ static ulong load_serial_ymodem (ulong offset); #endif
#if defined(CONFIG_CMD_LOADS) -static ulong load_serial (ulong offset); +static ulong load_serial (long offset); static int read_record (char *buf, ulong len); # if defined(CONFIG_CMD_SAVES) static int save_serial (ulong offset, ulong size); @@ -53,7 +53,7 @@ static int do_echo = 1; #if defined(CONFIG_CMD_LOADS) int do_load_serial (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { - ulong offset = 0; + long offset = 0; ulong addr; int i; char *env_echo; @@ -72,7 +72,7 @@ int do_load_serial (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
#ifdef CFG_LOADS_BAUD_CHANGE if (argc >= 2) { - offset = simple_strtoul(argv[1], NULL, 16); + offset = simple_strtol(argv[1], NULL, 16); } if (argc == 3) { load_baudrate = (int)simple_strtoul(argv[2], NULL, 10); @@ -95,7 +95,7 @@ int do_load_serial (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } #else /* ! CFG_LOADS_BAUD_CHANGE */ if (argc == 2) { - offset = simple_strtoul(argv[1], NULL, 16); + offset = simple_strtol(argv[1], NULL, 16); } #endif /* CFG_LOADS_BAUD_CHANGE */
@@ -141,7 +141,7 @@ int do_load_serial (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
static ulong -load_serial (ulong offset) +load_serial (long offset) { char record[SREC_MAXRECLEN + 1]; /* buffer for one S-Record */ char binbuf[SREC_MAXBINLEN]; /* buffer for binary data */
Dear Ricardo Ribalda Delgado,
In message 1217414369-28247-2-git-send-email-ricardo.ribalda@uam.es you wrote:
I think it makes little sense to change only one command and leave the other, similar commands unchanged. All commands that provide similar functions should behave the same.
So this one should be changed, too?
Maybe others as well?
Hi Wolfgang:
Up to my knowledge, u-boot can load .bin, .elf and .srec binary files.
.bin files are just raw binaries with no location info. When you load this file the offset mean the "absolute address" .srec files have info about location. The offset really mean offset, and is relative to the address specified in the file .elf files have info about location, but right now (UTMK), u-boot does not support offsets.
I think that his patch is enough, other binaries should not be fixed because there is no reason to locate a .bin file in the address -0x234
What do you think?
Best regards
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Pardon me for breathing, which I never do anyway so I don't know why I bother to say it, oh God, I'm so depressed. Here's another of those self-satisfied doors. Life! Don't talk to me about life." - Marvin the Paranoid Android
I think I did send this mail to the old mail list
---------- Forwarded message ---------- From: Ricardo Ribalda Delgado ricardo.ribalda@uam.es Date: Tue, Aug 19, 2008 at 08:59 Subject: Re: [U-Boot-Users] [PATCH] (Resend)Allows negative offset in command loads To: Wolfgang Denk wd@denx.de Cc: u-boot@lists.denx.de
Hi Wolfgang:
What do you think?
Best regards
-- Ricardo Ribalda http://www.eps.uam.es/~rribalda/
Applied, thanks.
