[U-Boot] [PATCH v2 1/2] mx7_common: Put early/late init configs into board file
CONFIG_BOARD_EARLY_INIT_F and CONFIG_BOARD_LATE_INIT should not be placed into mx7_common because not all boards need these options.
Move them to the board file instead.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes since v1: - None
include/configs/mx7_common.h | 3 --- include/configs/mx7dsabresd.h | 3 +++ 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index fac7c3f..a78fc7c 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -32,9 +32,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_BOARD_LATE_INIT - #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 2c981e0..d233572 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -14,6 +14,9 @@ #define CONFIG_DBG_MONITOR #define PHYS_SDRAM_SIZE SZ_1G
+#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + /* Uncomment to enable secure boot support */ /* #define CONFIG_SECURE_BOOT */ #define CONFIG_CSF_SIZE 0x4000
Add the basic support for Warp7 board.
For more information about this reference design, please visit:
https://www.element14.com/community/docs/DOC-79058/l/warp-7-the-next-generat...
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes since v1: - Select MX7D in the Kconfig (Peng)
arch/arm/cpu/armv7/mx7/Kconfig | 7 ++ board/warp7/Kconfig | 9 +++ board/warp7/MAINTAINERS | 6 ++ board/warp7/Makefile | 6 ++ board/warp7/imximage.cfg | 95 ++++++++++++++++++++++++++ board/warp7/warp7.c | 102 ++++++++++++++++++++++++++++ configs/warp7_defconfig | 12 ++++ include/configs/warp7.h | 149 +++++++++++++++++++++++++++++++++++++++++ 8 files changed, 386 insertions(+) create mode 100644 board/warp7/Kconfig create mode 100644 board/warp7/MAINTAINERS create mode 100644 board/warp7/Makefile create mode 100644 board/warp7/imximage.cfg create mode 100644 board/warp7/warp7.c create mode 100644 configs/warp7_defconfig create mode 100644 include/configs/warp7.h
diff --git a/arch/arm/cpu/armv7/mx7/Kconfig b/arch/arm/cpu/armv7/mx7/Kconfig index 97d6238..8e1ddcd 100644 --- a/arch/arm/cpu/armv7/mx7/Kconfig +++ b/arch/arm/cpu/armv7/mx7/Kconfig @@ -18,11 +18,18 @@ config TARGET_MX7DSABRESD select DM select DM_THERMAL
+config TARGET_WARP7 + bool "warp7" + select MX7D + select DM + select DM_THERMAL + endchoice
config SYS_SOC default "mx7"
source "board/freescale/mx7dsabresd/Kconfig" +source "board/warp7/Kconfig"
endif diff --git a/board/warp7/Kconfig b/board/warp7/Kconfig new file mode 100644 index 0000000..61c33fb --- /dev/null +++ b/board/warp7/Kconfig @@ -0,0 +1,9 @@ +if TARGET_WARP7 + +config SYS_BOARD + default "warp7" + +config SYS_CONFIG_NAME + default "warp7" + +endif diff --git a/board/warp7/MAINTAINERS b/board/warp7/MAINTAINERS new file mode 100644 index 0000000..1d3ee29 --- /dev/null +++ b/board/warp7/MAINTAINERS @@ -0,0 +1,6 @@ +WARP7 BOARD +M: Fabio Estevam fabio.estevam@nxp.com +S: Maintained +F: board/warp7/ +F: include/configs/warp7.h +F: configs/warp7_defconfig diff --git a/board/warp7/Makefile b/board/warp7/Makefile new file mode 100644 index 0000000..f39d1d8 --- /dev/null +++ b/board/warp7/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2016 NXP Semiconductors +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := warp7.o diff --git a/board/warp7/imximage.cfg b/board/warp7/imximage.cfg new file mode 100644 index 0000000..e7b6d30 --- /dev/null +++ b/board/warp7/imximage.cfg @@ -0,0 +1,95 @@ +/* + * Copyright (C) 2016 NXP Semiconductors + * + * SPDX-License-Identifier: GPL-2.0 + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +IMAGE_VERSION 2 +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +DATA 4 0x30340004 0x4F400005 + +DATA 4 0x30391000 0x00000002 +DATA 4 0x307a0000 0x03040008 +DATA 4 0x307a0064 0x00200038 +DATA 4 0x307a0490 0x00000001 +DATA 4 0x307a00d0 0x00350001 +DATA 4 0x307a00dc 0x00c3000a +DATA 4 0x307a00e0 0x00010000 +DATA 4 0x307a00e4 0x00110006 +DATA 4 0x307a00f4 0x0000033f +DATA 4 0x307a0100 0x0a0e110b +DATA 4 0x307a0104 0x00020211 +DATA 4 0x307a0108 0x03060708 +DATA 4 0x307a010c 0x00a0500c +DATA 4 0x307a0110 0x05020307 +DATA 4 0x307a0114 0x02020404 +DATA 4 0x307a0118 0x02020003 +DATA 4 0x307a011c 0x00000202 +DATA 4 0x307a0120 0x00000202 + +DATA 4 0x307a0180 0x00600018 +DATA 4 0x307a0184 0x00e00100 +DATA 4 0x307a0190 0x02098205 +DATA 4 0x307a0194 0x00060303 +DATA 4 0x307a01a0 0x80400003 +DATA 4 0x307a01a4 0x00100020 +DATA 4 0x307a01a8 0x80100004 + +DATA 4 0x307a0200 0x00000015 +DATA 4 0x307a0204 0x00161616 +DATA 4 0x307a0210 0x00000f0f +DATA 4 0x307a0214 0x04040404 +DATA 4 0x307a0218 0x0f0f0404 + +DATA 4 0x307a0240 0x06000600 +DATA 4 0x307a0244 0x00000000 +DATA 4 0x30391000 0x00000000 +DATA 4 0x30790000 0x17421e40 +DATA 4 0x30790004 0x10210100 +DATA 4 0x30790008 0x00010000 +DATA 4 0x30790010 0x0007080c +DATA 4 0x307900b0 0x1010007e + +DATA 4 0x3079001C 0x01010000 +DATA 4 0x3079009c 0x00000d6e + +DATA 4 0x30790030 0x06060606 +DATA 4 0x30790020 0x0a0a0a0a +DATA 4 0x30790050 0x01000008 +DATA 4 0x30790050 0x00000008 +DATA 4 0x30790018 0x0000000f +DATA 4 0x307900c0 0x0e487304 +DATA 4 0x307900c0 0x0e4c7304 +DATA 4 0x307900c0 0x0e4c7306 +DATA 4 0x307900c0 0x0e4c7304 + +CHECK_BITS_SET 4 0x307900c4 0x1 + +DATA 4 0x307900c0 0x0e487304 + +DATA 4 0x30384130 0x00000000 +DATA 4 0x30340020 0x00000178 +DATA 4 0x30384130 0x00000002 + +CHECK_BITS_SET 4 0x307a0004 0x1 diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c new file mode 100644 index 0000000..8c5bf9a --- /dev/null +++ b/board/warp7/warp7.c @@ -0,0 +1,102 @@ +/* + * Copyright (C) 2016 NXP Semiconductors + * Author: Fabio Estevam fabio.estevam@nxp.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx7-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/io.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> +#include <asm/arch/crm_regs.h> +#include <usb.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU100KOHM | \ + PAD_CTL_HYS) +#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ + PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_SIZE; + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc3_pads[] = { + MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_RESET_B__SD3_RESET_B | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +}; + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC3_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + /* Assume uSDHC3 emmc is always present */ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int checkboard(void) +{ + puts("Board: WARP7\n"); + + return 0; +} + +int board_usb_phy_mode(int port) +{ + return USB_INIT_DEVICE; +} diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig new file mode 100644 index 0000000..f37c9f5 --- /dev/null +++ b/configs/warp7_defconfig @@ -0,0 +1,12 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX7=y +CONFIG_TARGET_WARP7=y +CONFIG_IMX_RDC=y +CONFIG_IMX_BOOTAUX=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp7/imximage.cfg" +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set diff --git a/include/configs/warp7.h b/include/configs/warp7.h new file mode 100644 index 0000000..0798671 --- /dev/null +++ b/include/configs/warp7.h @@ -0,0 +1,149 @@ +/* + * Copyright (C) 2016 NXP Semiconductors + * + * Configuration settings for the i.MX7S Warp board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __WARP7_CONFIG_H +#define __WARP7_CONFIG_H + +#define CONFIG_BOOTDELAY 1 +#include "mx7_common.h" + +#define PHYS_SDRAM_SIZE SZ_512M + +#define CONFIG_BOARD_EARLY_INIT_F + +/* MMC Config*/ +#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC3_BASE_ADDR +#define CONFIG_SUPPORT_EMMC_BOOT +#define CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_DFU_ENV_SETTINGS \ + "dfu_alt_info=image raw 0 0x800000;"\ + "u-boot raw 0 0x4000;"\ + "bootimg part 0 1;"\ + "rootfs part 0 2\0" \ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_DFU_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx7d-warp.dtb\0" \ + "fdt_addr=0x83000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "fi; " \ + "fi; " \ + "fi" + +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x20000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_STACKSIZE SZ_128K + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_ENV_IS_IN_MMC + +#define CONFIG_ENV_OFFSET (8 * SZ_64K) +#define CONFIG_SYS_FSL_USDHC_NUM 1 + +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 0 +#define CONFIG_MMCROOT "/dev/mmcblk2p2" + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX7 +#define CONFIG_USB_STORAGE +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET + +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Only OTG1 port enabled */ + +#define CONFIG_IMX_THERMAL + +#define CONFIG_CI_UDC +#define CONFIG_USBD_HS +#define CONFIG_USB_GADGET_DUALSPEED + +#define CONFIG_USB_GADGET +#define CONFIG_CMD_USB_MASS_STORAGE +#define CONFIG_USB_FUNCTION_MASS_STORAGE +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USB_GADGET_VBUS_DRAW 2 + +#define CONFIG_G_DNL_VENDOR_NUM 0x0525 +#define CONFIG_G_DNL_PRODUCT_NUM 0xa4a5 +#define CONFIG_G_DNL_MANUFACTURER "FSL" + +/* USB Device Firmware Update support */ +#define CONFIG_CMD_DFU +#define CONFIG_USB_FUNCTION_DFU +#define CONFIG_DFU_MMC +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M +#define DFU_DEFAULT_POLL_TIMEOUT 300 + +#endif
Hi Stefano,
Do you think we could get the support for this new board into 2016.03?
Thanks
Hi Fabio,
On 04/03/2016 14:11, Fabio Estevam wrote:
Hi Stefano,
Really I have postponed to -next. As we have now two month cycle release, the merge window becomes more strictly and I will try to not let flow patches that are not fixes after window is closed.
Regards, Stefano
It makes sense. Just wanted to confirm, thanks.
Hi Stefano,
Could this series go into your -next tree then? I would like to submit other patches for warp7.
Thanks
On 11/03/2016 13:02, Fabio Estevam wrote:
Hi Stefano,
Yes, I pick them up.
Regards, Stefano
Hi Stefano,
I see the warp7 commit in your -next branch, but not in u-boot-imx master.
Do you plan to apply it to u-boot.imx master?
Thanks
Fabio Estevam
Stefano Babic
