[U-Boot] [PATCH] buildman: Avoid hanging when the config changes
Something has changed in the last several month such that when buildman builds U-Boot incrementally and a new CONFIG option has been added to the Kconfig, the build hanges waiting for input:
Test new config (NEW_CONFIG) [N/y/?] (NEW)
Since binamn does not connect the build's stdin to anything this waits on stdin to the build thread, which never comes. Eventually I suspect all the threads end up in this state and the build does not progress.
Fix this by passing /dev/null as input to the build. That way, if there is a new CONFIG, the build will stop (and fail):
Error in reading or end of file.
tools/buildman/builder.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index a5a2ffdfdf2..05f82995416 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -408,7 +408,7 @@ class Builder: """ cmd = [self.gnu_make] + list(args) result = command.RunPipe([cmd], capture=True, capture_stderr=True, - cwd=cwd, raise_on_error=False, **kwargs) + cwd=cwd, raise_on_error=False, infile='/dev/null', **kwargs) if self.verbose_build: result.stdout = '%s\n' % (' '.join(cmd)) + result.stdout result.combined = '%s\n' % (' '.join(cmd)) + result.combined
Test new config (NEW_CONFIG) [N/y/?] (NEW) Error in reading or end of file.
Applied to u-boot-dm, and now in mainline.
