[U-Boot] [resent] New chapter in i.MX51 datasheet an issue?
Hi all,
I discovered a bug in u-boot, that got evident after Freescale updated the i.MX51 datasheets to revision 5 in March this year. I don't know if it is a serious problem or not, but if I believe the wording of the datasheet many of the boards that use a i.MX51 processor and running u-boot as of latest git, can potentially suffer "permanent damage", whatever that means.
I am referring to the new paragraphs at the end of chapter 4.3.4 of the datasheet, and the wrong interpretation of the meaning of the HVE bit in the iomuxc.h header file of u-boot here:
arch/arm/include/asm/arch-mx5/iomux.h:
... 69 PAD_CTL_DRV_VOT_LOW = 0x0 << 13, /* Low voltage mode */ 70 PAD_CTL_DRV_VOT_HIGH = 0x1 << 13,/* High voltage mode */ ...
According to the reference manual, the correct meaning of this bit is negated:
"Bit 13: High / Low Output Voltage Range. This bit selects the output voltage mode for SD2_CMD. 0 High output voltage mode 1 Low output voltage mode"
Added to the new paragraph in the datasheet:
"The UHVIO type of I/O cells have to be configured properly according to their supply voltage level, in order to prevent permanent damage to them and in order to not degrade their timing performance."
Seems like we may have a problem here!
I would like to know if anyone is aware of this? Does anyone know of a board that is actually destroyed this way?
On 04/05/2012 12:08, David Jander wrote:
Hi all,
Hi David,
Agree. The header defines the bit wrongly.
It seems to me that the Reference Manual is correct. It is from 24/2/2010 and it was not updated.
After a reset, value is set to 1, and this means low-voltage for the most pins.
At the moment, we have no problems and I can explain why. The only boards setting these pins (for SD card) are mx51evk and vision2. Both are setting PAD_CTL_DRV_VOT_HIGH, and because the define is wrong, they are really setting the pin to low output voltage mode.
For other boards and other pins, voltage is not explicitely set : this means they work in low voltage mode after a reset.
To fix arch/arm/include/asm/arch-mx5/iomux.h and synchronize it with the documentation, we need also to change mx51evk / vision2, setting the pins to PAD_CTL_DRV_VOT_LOW, and they will work as now.
We can also drop completely PAD_CTL_DRV_VOT_HIGH from these two boards and use the reset value.
Best regards, Stefano Babic
Dear Stefano,
Hi all,
Hi David,
Yes, but is none of those boards using 3.15 or 3.3V? If they are, those bits must be cleared!
AFAIK, most SD-cards need 3.1V or more to work, and the EVK boots from an SD card. That means, the rails NVCC_PER15 and/or NVCC_PER17 are probably powered from a 3.15 or 3.3V supply, so the HVE bits for those pins must be cleared in able to avoid damage (3.3V is what they call "Ultra High Voltage").
Everyone reading the documentation as it was available before 03-2012 would most probably think this is ok, even for 3.1...3.6V powered pins, but according to the new documentation, it isn't. So probably many boards need to be re-designed or at least u-boot board-code needs to be fixed for them. This is a different issue though, and needs to be addressed by the different BSP maintainers or board manufacturers.
... and probably die. The setting is most probably wrong. All we need to do, is change the define in the header files, and not touch the mx51evk / vision2 BSP files. But the respective maintainers need to be warned IMHO.
PAD_CTL_DRV_VOT_HIGH should be a NOP in a bit mask, since its value should be 0. PAD_CTL_DRV_VOT_LOW should be 1. Board code most probably shouldn't be changed, because it most probably assumes that the "meaning" of the define is right, and not its value.
On 07/05/2012 09:11, David Jander wrote:
Dear Stefano,
Hi David,
This is a good question - also because SD was tested and it is working on these cards. I am asking to myself how it can work if voltage is wrong.
Really I have expected that SD does not work if the voltage is lower as specified, not that theree is a damage - I can understand this in the opposite case (setting high voltage when low voltage is required).
I think only u-boot code should be fixed.
well, they will work as now - with low voltage instead of high voltage. Anyway, I agree that this should be wrong, because when the code was written was thought that the voltage should be high.
Go ahead in this direction. Then we can test on these boards (mx51evk / vision2 / efikamx), the only ones having these issue).
Dear Stefano Babic,
Dear Stefano,
Hi David,
Respective maintainer just woke up ... just send me the efika patch, I should be able to test ;-)
Best regards, Marek Vasut
Dear Stefano,
Hi David,
That is the whole point: You probably won't notice anything with the wrong settings.... besides slightly lower drive-strength on the pin. Things should just work with either setting. The problem is that now Freescale is telling us that using the incorrect settings can cause "permanent damage" to the chip!!! No idea what sort of damage nor whether it occurs frequently.....
The setting doesn't affect the actual output voltage or something like that. This bit only changes some electrical characteristics of the PAD-IO circuitry, in order to perform better for lower or for higher rail power... depending on its value. Apparently Freescale now discovered that its not only affecting minor timing details that probably are irrelevant for most uses, but also that the chip can malfunction ("permanent damage can occur").
Potentially also board code, in the cases where the settings are not matching the actual hardware.... not because it doesn't work, but rather to avoid possible "permanent damage". That's something board designers/BSP maintainers should care about.
See above.
I agree we should only change the headers, but... if there are more i.MX51 boards, they may all potentially need to fix their board code.... and that is up to them. Unfortunately this warning/wake-up call should come from Freescale themselves, but I have not heared anything from them.
Dear David Jander,
Dear Stefano,
Hi David,
I think it might have something to do with ESD. It's probably unlikely to happen anyway.
See above.
On Tue, 8 May 2012 14:51:52 +0200 Marek Vasut marex@denx.de wrote:
Dear David Jander,
Dear Stefano,
Hi David,
Why do you think that? ESD protection is not something that could possibly have something to do with a running board and wrong PAD configuration bit settings. Or do you mean that IO-pad ESD protection is the thing that gets destroyed by wrong settings?
AFAICS, this bit probably enables and disables a different set of output transistors on the pad.
Whether damage is likely to happen or not, is not clear to me yet. I am waiting on a reply from Freescale about this issue right now. I will post any important findings here as soon as I know more.
What we can do is to change all MX51 boards in mainline (the three boards we have already mentioned), explaining in the commit-id of the patch why we change. We do not care about boards that were not pushed to mainline.
Seems reasonable. Are you also implying that you are willing to propose a patch? (Swapping the two values seems fairly trivial....)
Patch is coming
David Jander
Stefano Babic
