[U-Boot] [PATCH] support for 2 DRAM banks and FLASH bank with 16MB in KS8695
Hello,
The patch attached add support for a flash bank size of 16 MB and for a second DRAM bank for the KS8695 (ARM9 core) depending on the configuration.
A better solution would be to calculate the values for the registers (only some shifts are needed) but this was the lazy implementation.
I hope, I don't make to much mistakes in the presentation of my patch because it is the first patch I publish to this list. Sadly I don't have access to the development PC any more because it was a project for a subsidiary company and I finished the project at end of September.
Signed-off-by: Michael Bernstein Michael.Bernstein@controlware.de
diff --unified --recursive --new-file u-boot-2009.11/cpu/arm920t/ks8695/lowlevel_init.S u-boot-2009.11.new/cpu/arm920t/ks8695/lowlevel_init.S --- u-boot-2009.11/cpu/arm920t/ks8695/lowlevel_init.S 2009-12-15 23:20:54.000000000 +0100 +++ u-boot-2009.11.new/cpu/arm920t/ks8695/lowlevel_init.S 2010-01-29 11:38:04.000000000 +0100 @@ -96,7 +96,17 @@ str r2, [r1] /* large flash map */ ldr pc, =(highflash+0x02000000-0x00f00000) /* jump to high flash address */ highflash: - ldr r2, =0x8fe00040 +#if (PHYS_FLASH_BANK_SIZE == 0x01000000) + ldr r2, =0xbfe00071 /* 16MB and start at 32MB */ + str r2, [r1] /* remap flash range */ + ldr r1, =(KS8695_IO_BASE+KS8695_MEM_CTRL1) + ldr r2, =0xc0300000 + str r2, [r1] /* flash2 region unused */ + ldr r1, =(KS8695_IO_BASE+KS8695_MEM_GENERAL) + ldr r2, =0x30000003 /* data width 32 */ + str r2, [r1] /* enable first flash select */ +#else + ldr r2, =0x8fe00040 /* 4MB start at 32MB */ str r2, [r1] /* remap flash range */
/* @@ -111,6 +121,7 @@ ldr r1, =(KS8695_IO_BASE+KS8695_MEM_GENERAL) ldr r2, =0x30000005 str r2, [r1] /* enable both flash selects */ +#endif
#ifdef CONFIG_CM41xx /* @@ -138,7 +149,15 @@ #endif str r2, [r1] /* configure sdram bank0 setup */ ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_CTRL1) - mov r2, #0 +#if (CONFIG_NR_DRAM_BANKS == 2) +#if (PHYS_SDRAM_2_SIZE == 0x02000000) + ldr r2, =0xFFE0000E /* 32MB and start at 32MB */ +#else + ldr r2, =0x7FD0000E /* 16MB and start at 16MB */ +#endif +#else /* CONFIG_NR_DRAM_BANKS == 2 */ + mov r2, #0 /* no second SDRAM bank */ +#endif /* CONFIG_NR_DRAM_BANKS == 2 */ str r2, [r1] /* configure sdram bank1 setup */
ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_GENERAL)
_________________________________________________ Michael Bernstein NOC
Controlware GmbH Waldstrasse 92, 63128 Dietzenbach, GERMANY Tel.: +49 6074 858-177 Fax: +49 6074 858-148 Michael.Bernstein@controlware.de www.controlware.de _________________________________________________ State-of-the-art Technology for Worldwide Telecommunications <<< Dienstleistung nach Maß >>>
Emergency Response Services Schnelle und zuverlässige Unterstützung bei IT-Sicherheitsvorfällen aller Art. Weitere Infos unter http://www.controlware.de/ers
Diese E-Mail kann vertrauliche oder rechtlich geschützte Informationen enthalten. Wenn Sie nicht der beabsichtigte Empfänger sind, informieren Sie bitte sofort den Absender und löschen Sie diese E-Mail. Das unbefugte Kopieren dieser E-Mail oder die unbefugte Weitergabe der enthaltenen Informationen ist nicht gestattet.
The information contained in this message is confidential or protected by law. If you are not the intended recipient, please contact the sender and delete this message. Any unauthorised copying of this message or unauthorised distribution of the information contained herein is prohibited.
Controlware GmbH Kommunikationssysteme Telefon: (0 60 74) 8 58-0 E-Mail: info@controlware.de http://www.controlware.de
Sitz: 63128 Dietzenbach, Registergericht: Offenbach a.M., HRB Nr. 6431, USt.-Id.-Nr. DE 113539225 Geschäftsführung: Helmut E. Wörner (Vorsitzender), Bernd Schwefing, Hubert Potthoff Beirat: Dr. Gert Sieger (Vorsitzender), Dr. Peter Pagé, Kurt Sibold
Dear "Bernstein, Michael",
In message EC8E3D9A08FBD540BB1137DDACCB0ABD995EFE82FE@NTEXCCR.controlware.de you wrote:
Please restrict the line length in the commit message to 70 characters or less.
I hope, I don't make to much mistakes in the presentation of my patch because it is the first patch I publish to this list. Sadly I don't have access to the development PC any more because it was a project for a subsidiary co> mpany and I finished the project at end of September.
Such comments should not be part of the commit message, so please move this into the comment section.
Please see http://www.denx.de/wiki/view/U-Boot/Patches#Commit_message_conventions and http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions
Bernstein, Michael
