[U-Boot] [PATCH] arm: Use mtune for Xscale
Otherwise with GCC 8 we see this warning [which is rendered to an error with -Werror, which happens for buildman/travisci], see [1]: ------------------------------->8------------------------------- cc1: warning: switch -mcpu=xscale conflicts with -march=armv5te switch ------------------------------->8-------------------------------
Interesting enough with GCC 7.3.0 (which is current default in buildman) that change leads to another failure, see [2]: ------------------------------->8------------------------------- Error: selected processor does not support `pld [lr]' in ARM mode ------------------------------->8-------------------------------
So I guess this change might be put in series with buildman toolchain bump.
[1] https://travis-ci.org/abrodkin/u-boot/jobs/383219348 [2] https://travis-ci.org/abrodkin/u-boot/jobs/383594006
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Albert Aribaud albert.u.boot@aribaud.net --- arch/arm/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 680c6e8516dc..18e0193c43c0 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -37,7 +37,7 @@ tune-$(CONFIG_CPU_ARM920T) = tune-$(CONFIG_CPU_ARM926EJS) = tune-$(CONFIG_CPU_ARM946ES) = tune-$(CONFIG_CPU_SA1100) =-mtune=strongarm1100 -tune-$(CONFIG_CPU_PXA) =-mcpu=xscale +tune-$(CONFIG_CPU_PXA) =-mtune=xscale tune-$(CONFIG_CPU_ARM1136) = tune-$(CONFIG_CPU_ARM1176) = tune-$(CONFIG_CPU_V7A) =
Hello,
Just a short update.
Even though problem listed above got solved with this patch but it introduces another issue I missed initially with GCC 8.1.0, see [3]: ------------------------------->8------------------------------- arm: + h2200 +arch/arm/cpu/pxa/start.S: Assembler messages: +arch/arm/cpu/pxa/start.S:179: Error: selected processor does not support `strd r4,[r1],#8' in ARM mode ------------------------------->8-------------------------------
[3] https://travis-ci.org/abrodkin/u-boot/jobs/383423699
So that doesn't seem to be the easy fix :(
-Alexey
Alexey Brodkin
